We choose \(f\) as
Let us set up the geometry.
# Generate the geometry
geo.AddCircle((0,0), r = 2.5)
mesh.Curve(2)
<ngsolve.comp.Mesh at 0x7f3eca2a7ec0>
#gfset.vec[:]=0
#gfset.Set((0.2*x,0))
#mesh.SetDeformation(gfset)
a =4.0/5.0
b = 2
gfset = GridFunction(VEC)
gfX = GridFunction(VEC)
Draw(gfset)
Shape derivative¶
# Test and trial functions
PHI, PSI = VEC.TnT()
# shape derivative
dJOmega = LinearForm(VEC)
Bilinear form¶
aX = BilinearForm(VEC)
The first optimisation step¶
Here
# assemble on deformed domain
aX.Assemble()
dJOmega.Assemble()
mesh.UnsetDeformation()
# unset deformation
# compute X_0
alpha = 20.0 / Norm(gfX.vec)
gfset.vec[:]=0
scene = Draw(gfset)
# input("A")
#draw deformed shape
# input("B")
Optimisation loop¶
import time
iter_max = 50
gfset.vec[:] = 0
converged = False
# input("A")
for k in range(iter_max):
Jold = Integrate(f, mesh)
# assemble bilinear form
aX.Assemble()
# assemble shape derivative
dJOmega.Assemble()
# step size control
gfset_old.data = gfset.vec
Jnew = Jold + 1
while Jnew > Jold:
gfset.vec.data = gfset_old
Jnew = Integrate(f, mesh)
if Jnew > Jold:
print("reducing step size")
alpha = 0.9*alpha
alpha = alpha*1.5
break
time.sleep(0.1)
Jold = Jnew
step size: 0.165
step size: 0.2475
step size: 0.556875
step size: 0.8353125
step size: 1.25296875
reducing step size
reducing step size
step size: 1.52235703125
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4982276723046877
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3270326873287925
reducing step size
reducing step size
reducing step size
step size: 1.4511102435940346
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4281101462330694
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4054746004152756
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3831978279986936
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3612741424249144
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3396979472674797
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.1866173613229614
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0510285285313932
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.034369726354171
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0179749661914572
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0018400629773228
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9859608979791321
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9703334177461629
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9549536330748863
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9398176179906492
reducing step size
reducing step size
reducing step size
step size: 1.027690565272775
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0114016698132016
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9953709533466624
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9795943237361178
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9640677537049005
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9487872798086778
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9337490014237104
reducing step size
reducing step size
reducing step size
step size: 1.0210545330568275
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0048708187078768
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.988943616231357
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.97326885991409
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9578425484844518
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9426607440909731
reducing step size
reducing step size
reducing step size
step size: 1.0307995236634793
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0144613512134133
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9983821387966807
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9825577818967535
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.96698424105369
reducing step size
reducing step size
reducing step size
step size: 1.05739726759221
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0406375209008738
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0241434161945948
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0079107430479106
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9919353577706012
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9762131823499371
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9607402034096908
reducing step size
reducing step size
reducing step size
step size: 1.050569412428497
Using SciPy optimize toolbox¶
ngsglobals.msg_level = 1
mesh.Curve(2)
a =4.0/5.0
b = 2
# element order
order = 1
PHI = VEC.TrialFunction()
PSI = VEC.TestFunction()
gfset.Set((0,0))
# only for new gui
#if scene:
# scene.setDeformation(True)
#Draw(gfset,mesh,"gfset")
Curve elements, order = 2
Shape derivative¶
fX = LinearForm(VEC)
# analytic shape derivative
Define the bilinear form
# Cauchy-Riemann descent CR
CR = False
# bilinear form for gradient
if CR == True:
gamma = 100
aX.Assemble()
def J(x_):
gfset.Set((0,0))
# x_ NumPy vector
cost_c = Integrate (f, mesh)
return cost_c
gfset.Set((0,0))
# x_ NumPy vector
fX.Assemble()
if euclid == True:
gfX.vec.data = fX.vec
gfX.vec.data = invaX * fX.vec
xk_ = np.copy(x0)
# maximal iteration
it_max = 50
nfval_total = 0
print('\n')
for i in range(1, it_max):
# compute descent direction
pk = -gradJ_(xk_)
# eval cost function
fold = J_(xk_)
# perform armijo stepsize
if CR == True:
alpha0 = 0.15
alpha0 = 0.11
nfval_total += nfval
xk_ = xk_ - step * grad_xk
break
elif i == it_max-1:
/tmp/ipykernel_88471/197104950.py:2: DeprecationWarning: Please use `line_search_armijo` from the `scipy.optimize` namespace, the `scipy.optimize.linesearch` namespace is deprecated.
gfset.vec[:]=0
n evals f: 49
f val: -1.1569989636230704
L-BFGS method¶
In the BFGS method we replace
by
# options for optimiser
options = {"maxiter":1000,
"disp":True,
"gtol":1e-10}
RUNNING THE L-BFGS-B CODE
Machine precision = 2.220D-16
N = 7760 M = 10
F = final function value
F = -1.1571107484943068
CONVERGENCE: REL_REDUCTION_OF_F_<=_FACTR*EPSMCH
fun: -1.1571107484943068
nfev: 94
nit: 13
njev: 94
status: 0
success: True
alpha = 100
