6.1.2 Surface PDEs¶
Surface Poisson equation¶
Homogeneous Dirichlet data¶
finitesphere = sphere * bot
mesh.Curve(2)
u, v = fes.TnT()
print(fes.FreeDofs())
350: 111111111111111111
force = sin(x)*y*exp(z)
f += force*v*ds
<ngsolve.comp.LinearForm at 0x7ff14469e870>
Solving is done as usual
Draw(gfu, mesh, "u")
Inhomogeneous Dirichlet data¶
r = f.vec.CreateVector()
Draw(gfu)
a += grad(u)*grad(v)*ds
Cell In[7], line 1
2 a.Assemble()
The second class is given by
Space |
Surface Space |
L2 |
SurfaceL2 |
HDiv |
HDivSurface |
HDivDiv |
HDivDivSurface |
FacetFESpace |
FacetSurface |
