3.7 DG/HDG splitting¶
For a problem of the form
order = 3
shape.edges.name="cyl"
HDG spaces¶
V = FESpace ([V1,V2,Q])
v, vhat, q = V.TestFunction()
nu = 0.001 # viscosity
def tang(vec):
return vec - (vec*n)*n
Stokes discretization¶
alpha = 4 # SIP parameter
<ngsolve.comp.BilinearForm at 0x7fcd683782f0>
The mass matrix is simply
Initial conditions¶
gfu = GridFunction(V)
U0 = 1.5
scenes = [ \
Application of convection¶
mixed mass matrices¶
uL2, vL2 = VL2.TnT()
convection operator¶
vel = gfu.components[0]
un = InnerProduct(vel,n)
def __init__(self,tau,steps):
def Mult(self, x, y):
for i in range(self.steps):
def CreateColVector(self):
return CreateVVector(self.h)
Setup of \(M^*\):
t = 0; tend = 0
tau = 0.01; substeps = 10
The time loop:
for s in scenes : s.Draw()
%%time
tend += 1
res = gfu.vec.CreateVector()
t += tau
print ("\r t =", t, end="")
for s in scenes : s.Redraw()
- more-to-come:
t = 0.01 t = 0.02
</pre>
t = 0.01 t = 0.02
end{sphinxVerbatim}
t = 0.01 t = 0.02
- more-to-come:
t = 0.03 t = 0.04
</pre>
t = 0.03 t = 0.04
end{sphinxVerbatim}
t = 0.03 t = 0.04
- more-to-come:
t = 0.05 t = 0.060000000000000005
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.07 t = 0.08
</pre>
t = 0.07 t = 0.08
end{sphinxVerbatim}
t = 0.07 t = 0.08
- more-to-come:
t = 0.09 t = 0.09999999999999999
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.10999999999999999 t = 0.11999999999999998
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.12999999999999998 t = 0.13999999999999999
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.15 t = 0.16
</pre>
t = 0.15 t = 0.16
end{sphinxVerbatim}
t = 0.15 t = 0.16
- more-to-come:
t = 0.17 t = 0.18000000000000002
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.19000000000000003 t = 0.20000000000000004
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.21000000000000005 t = 0.22000000000000006
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.23000000000000007 t = 0.24000000000000007
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.25000000000000006 t = 0.26000000000000006
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.2700000000000001 t = 0.2800000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.2900000000000001 t = 0.3000000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.3100000000000001 t = 0.3200000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.3300000000000001 t = 0.34000000000000014
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.35000000000000014 t = 0.36000000000000015
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.37000000000000016 t = 0.38000000000000017
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.3900000000000002 t = 0.4000000000000002
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.4100000000000002 t = 0.4200000000000002
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.4300000000000002 t = 0.4400000000000002
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.45000000000000023 t = 0.46000000000000024
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.47000000000000025 t = 0.48000000000000026
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.49000000000000027 t = 0.5000000000000002
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.5100000000000002 t = 0.5200000000000002
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.5300000000000002 t = 0.5400000000000003
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.5500000000000003 t = 0.5600000000000003
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.5700000000000003 t = 0.5800000000000003
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.5900000000000003 t = 0.6000000000000003
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.6100000000000003 t = 0.6200000000000003
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.6300000000000003 t = 0.6400000000000003
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.6500000000000004 t = 0.6600000000000004
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.6700000000000004 t = 0.6800000000000004
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.6900000000000004 t = 0.7000000000000004
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.7100000000000004 t = 0.7200000000000004
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.7300000000000004 t = 0.7400000000000004
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.7500000000000004 t = 0.7600000000000005
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.7700000000000005 t = 0.7800000000000005
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.7900000000000005 t = 0.8000000000000005
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.8100000000000005 t = 0.8200000000000005
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.8300000000000005 t = 0.8400000000000005
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.8500000000000005 t = 0.8600000000000005
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.8700000000000006 t = 0.8800000000000006
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.8900000000000006 t = 0.9000000000000006
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.9100000000000006 t = 0.9200000000000006 t = 0.9300000000000006
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.9400000000000006 t = 0.9500000000000006
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.9600000000000006 t = 0.9700000000000006
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 0.9800000000000006 t = 0.9900000000000007
</pre>
end{sphinxVerbatim}
- t = 1.0000000000000007CPU times: user 11.6 s, sys: 47.1 ms, total: 11.6 s
Wall time: 11.6 s </pre>
Wall time: 11.6 s end{sphinxVerbatim}
Wall time: 11.6 s
ConvertL2Operator¶
def NewMult(self, x, y):
The time loop:
%%time
tend += 1
t += tau
- more-to-come:
t = 1.0100000000000007 t = 1.0200000000000007
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.0300000000000007 t = 1.0400000000000007 t = 1.0500000000000007
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.0600000000000007 t = 1.0700000000000007
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.0800000000000007 t = 1.0900000000000007 t = 1.1000000000000008
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.1100000000000008 t = 1.1200000000000008
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.1300000000000008 t = 1.1400000000000008 t = 1.1500000000000008
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.1600000000000008 t = 1.1700000000000008
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.1800000000000008 t = 1.1900000000000008
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.2000000000000008 t = 1.2100000000000009 t = 1.2200000000000009
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.2300000000000009 t = 1.2400000000000009
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.2500000000000009 t = 1.260000000000001 t = 1.270000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.280000000000001 t = 1.290000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.300000000000001 t = 1.310000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.320000000000001 t = 1.330000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.340000000000001 t = 1.350000000000001 t = 1.360000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.370000000000001 t = 1.380000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.390000000000001 t = 1.400000000000001 t = 1.410000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.420000000000001 t = 1.430000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.440000000000001 t = 1.450000000000001 t = 1.460000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.470000000000001 t = 1.480000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.490000000000001 t = 1.500000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.5100000000000011 t = 1.5200000000000011 t = 1.5300000000000011
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.5400000000000011 t = 1.5500000000000012
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.5600000000000012 t = 1.5700000000000012 t = 1.5800000000000012
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.5900000000000012 t = 1.6000000000000012
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.6100000000000012 t = 1.6200000000000012 t = 1.6300000000000012
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.6400000000000012 t = 1.6500000000000012
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.6600000000000013 t = 1.6700000000000013 t = 1.6800000000000013
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.6900000000000013 t = 1.7000000000000013
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.7100000000000013 t = 1.7200000000000013
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.7300000000000013 t = 1.7400000000000013 t = 1.7500000000000013
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.7600000000000013 t = 1.7700000000000014
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.7800000000000014 t = 1.7900000000000014
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.8000000000000014 t = 1.8100000000000014
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.8200000000000014 t = 1.8300000000000014 t = 1.8400000000000014
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.8500000000000014 t = 1.8600000000000014
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.8700000000000014 t = 1.8800000000000014 t = 1.8900000000000015
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.9000000000000015 t = 1.9100000000000015
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.9200000000000015 t = 1.9300000000000015
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.9400000000000015 t = 1.9500000000000015
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.9600000000000015 t = 1.9700000000000015
</pre>
end{sphinxVerbatim}
- more-to-come:
t = 1.9800000000000015 t = 1.9900000000000015
</pre>
end{sphinxVerbatim}
- t = 2.0000000000000013CPU times: user 11.2 s, sys: 28.2 ms, total: 11.2 s
Wall time: 11.2 s </pre>
Wall time: 11.2 s end{sphinxVerbatim}
Wall time: 11.2 s
Tasks:
