This page was generated from unit-2.1.4-bddc/bddc.ipynb.
2.1.4 Element-wise BDDC Preconditioner¶
Let us start with a simple description of the element-wise BDDC in the context of Lagrange finite element space \(V\). Here the BDDC preconditioner is constructed on an auxiliary space \(\widetilde{V}\) obtained by connecting only element vertices (leaving edge and face shape functions discontinuous). Although larger, the auxiliary space allows local elimination of edge and face variables. Hence an analogue of the original matrix \(A\) on this space, named \(\widetilde A\), is less expensive to invert. This inverse is used to construct a preconditioner for \(A\) as follows:
Here, \(R\) is the averaging operator for the discontinuous edge and face variables.
SetHeapSize(100*1000*1000)
Built-in options¶
Effect of condensation¶
c = Preconditioner(a, "bddc")
lams = TestPreconditioner(5)
1.00052
1.03338
1.09991
4.55515
4.60067
4.79194
1.00023
1.02753
1.08363
4.06546
4.12581
4.22957
Tuning the auxiliary space¶
wb_fulledges |
wb_withedges |
2D |
3D |
True |
any value |
all |
all |
False/Undefined |
Undefined |
none |
first |
False/Undefined |
False |
none |
none |
False/Undefined |
True |
first |
first |
wb_withedges=False)
1.00106
1.07035
1.22031
25.4058
25.406
26.9095
Customize¶
fes = H1(mesh, order=10)
for ed in mesh.edges:
dofs = fes.GetDofNrs(ed)
for d in dofs:
max(lams)/min(lams)
9.989385160527847
max(lams)/min(lams)
13.974958344241555
p = 5
wb_withedges=False)
print("NDOF = ", fes.ndof)
f += v*dx
pre=pre, maxsteps=500)
Draw(gfu)
NDOF = 747331
WARNING: kwarg 'coarsetype' is an undocumented flags option for class <class 'ngsolve.comp.Preconditioner'>, maybe there is a typo?
CG iteration 1, residual = 0.728413955096221
CG iteration 2, residual = 0.30380646339754314
CG iteration 3, residual = 0.2731573265198621
CG iteration 4, residual = 0.3216444680361294
CG iteration 5, residual = 0.3362137537776381
CG iteration 6, residual = 0.23091380686774432
CG iteration 7, residual = 0.17758171344641402
CG iteration 8, residual = 0.14575584903552563
CG iteration 9, residual = 0.10943345664815447
CG iteration 10, residual = 0.07987287960772062
CG iteration 11, residual = 0.05836078710530288
CG iteration 12, residual = 0.046300361745948766
CG iteration 13, residual = 0.037001482312351966
CG iteration 14, residual = 0.028875962787518923
CG iteration 15, residual = 0.021947291835534437
CG iteration 16, residual = 0.016880369393393824
CG iteration 17, residual = 0.013424016729028253
CG iteration 18, residual = 0.01040727678661801
CG iteration 19, residual = 0.007831119292639903
CG iteration 20, residual = 0.0060689826343194656
CG iteration 21, residual = 0.004699791356400355
CG iteration 22, residual = 0.003501308129888214
CG iteration 23, residual = 0.0026881998338427224
CG iteration 24, residual = 0.00209137099409742
CG iteration 25, residual = 0.0016265345742919575
CG iteration 26, residual = 0.0012407145818787027
CG iteration 27, residual = 0.000974217326326128
CG iteration 28, residual = 0.0007649510760337331
CG iteration 29, residual = 0.0005840071559368029
CG iteration 30, residual = 0.0004482828193544686
CG iteration 31, residual = 0.0003444113786343964
CG iteration 32, residual = 0.0002614638825316051
CG iteration 33, residual = 0.00020257170195518711
CG iteration 34, residual = 0.0001607905743217917
CG iteration 35, residual = 0.00012530547877779633
CG iteration 36, residual = 9.847428119410474e-05
CG iteration 37, residual = 9.303129148712098e-05
CG iteration 38, residual = 6.767177670123184e-05
CG iteration 39, residual = 4.976033460788856e-05
CG iteration 40, residual = 3.781832151841206e-05
CG iteration 41, residual = 2.9229010597209936e-05
CG iteration 42, residual = 2.284850244517014e-05
CG iteration 43, residual = 1.7602008795506494e-05
CG iteration 44, residual = 1.3885655852333624e-05
CG iteration 45, residual = 1.081338716394434e-05
CG iteration 46, residual = 8.097364667583798e-06
CG iteration 47, residual = 6.141265217341453e-06
CG iteration 48, residual = 4.7932770427242e-06
CG iteration 49, residual = 3.646778086870511e-06
CG iteration 50, residual = 2.8305687352784085e-06
CG iteration 51, residual = 2.141470433460771e-06
CG iteration 52, residual = 1.6371318610893237e-06
CG iteration 53, residual = 1.26852133840877e-06
CG iteration 54, residual = 9.687252649047982e-07
CG iteration 55, residual = 7.429325199508625e-07
CG iteration 56, residual = 5.71811025795847e-07
CG iteration 57, residual = 4.438687311310632e-07
CG iteration 58, residual = 3.4280744006180695e-07
CG iteration 59, residual = 2.6918466522637116e-07
CG iteration 60, residual = 2.076158227954643e-07
CG iteration 61, residual = 1.600540362007019e-07
CG iteration 62, residual = 1.2394650470828008e-07
CG iteration 63, residual = 9.446044523044157e-08
CG iteration 64, residual = 8.030832246751548e-08
CG iteration 65, residual = 7.364647154346008e-08
CG iteration 66, residual = 5.1743744728368476e-08
CG iteration 67, residual = 3.8164809968716536e-08
CG iteration 68, residual = 2.9151607035882558e-08
CG iteration 69, residual = 2.2725681433941916e-08
CG iteration 70, residual = 1.7433852804772543e-08
CG iteration 71, residual = 1.3274757778117697e-08
CG iteration 72, residual = 1.0159836525497988e-08
CG iteration 73, residual = 7.80348987813223e-09
CG iteration 74, residual = 6.0279377057708994e-09
CG iteration 75, residual = 4.621588820032534e-09
CG iteration 76, residual = 3.542485446478203e-09
CG iteration 77, residual = 2.7647196408557473e-09
CG iteration 78, residual = 2.2518040124554074e-09
CG iteration 79, residual = 1.8280237141831688e-09
CG iteration 80, residual = 1.3671409375613476e-09
CG iteration 81, residual = 1.0504374873331068e-09
CG iteration 82, residual = 8.008707646869946e-10
CG iteration 83, residual = 6.16323044835653e-10
CG iteration 84, residual = 4.7715232678962e-10
CG iteration 85, residual = 3.7063451261223247e-10
CG iteration 86, residual = 2.8243514247393914e-10
CG iteration 87, residual = 2.2981932306232348e-10
CG iteration 88, residual = 1.8579664629840712e-10
CG iteration 89, residual = 1.407772010955181e-10
CG iteration 90, residual = 1.0798896458917621e-10
CG iteration 91, residual = 8.365070946385269e-11
CG iteration 92, residual = 6.543644046796077e-11
CG iteration 93, residual = 5.588123780619939e-11
CG iteration 94, residual = 4.9927716641722734e-11
CG iteration 95, residual = 3.5043301829303573e-11
CG iteration 96, residual = 2.5726391282670106e-11
CG iteration 97, residual = 1.957209838566714e-11
CG iteration 98, residual = 1.5055128291397034e-11
CG iteration 99, residual = 1.1661984952985266e-11
CG iteration 100, residual = 9.081019181161003e-12
CG iteration 101, residual = 6.932579404308459e-12
CG iteration 102, residual = 5.219352564840089e-12
CG iteration 103, residual = 3.946228702797267e-12
CG iteration 104, residual = 3.057941145798792e-12
CG iteration 105, residual = 2.3732906308463218e-12
CG iteration 106, residual = 1.827695368600787e-12
CG iteration 107, residual = 1.449427775371295e-12
CG iteration 108, residual = 1.1293717021517864e-12
CG iteration 109, residual = 8.999424205745139e-13
CG iteration 110, residual = 6.799899750969534e-13
Postscript¶
fes = fes_ho*fes_lo*fes_lam
- 1*uho*dx
solvers.Newton(a=a, u=gfu)
Draw(gfu.components[0],deformation=True, settings={"camera": {"transformations": [{"type": "rotateX", "angle": -45}]}})
Newton iteration 0
err = 0.39346141669994983
Newton iteration 1
err = 1.8488788182878563e-15
