This page was generated from unit-7-optimization/03_Shape_Derivative_Laplace_SemiAuto.ipynb.
7.3 PDE-Constrained Shape Optimization (semi-automated)¶
subject to that
Here, we want to compute the shape derivative by differentiation of a suitably defined perturbed Lagrangian using automated differentiation. For details we refer to
Gangl, K. Sturm, M. Neunteufel, J. Schöberl. Fully and Semi-Automated Shape Differentiation in NGSolve, Struct. Multidisc. Optim., 63, pp.1579-1607, 2021.
ud = x*(1-x)*y*(1-y)
State equation¶
u, v = fes.TnT()
scene = Draw(gfu, mesh, "state")
a += grad(u)*grad(v)*dx
fstate = LinearForm(fes)
fstate += f*v*dx
def SolveStateEquation():
rhs = gfu.vec.CreateVector()
gfu.vec.data += update
fstate.Assemble()
Adjoint equation¶
q=4
def Cost(u):
return (u-ud)**q*dx
p, w = fes.TnT()
gfp = GridFunction(fes)
fadjoint = LinearForm(fes)
def SolveAdjointEquation():
rhs = gfp.vec.CreateVector()
gfp.vec.data += update
fadjoint.Assemble()
The integrand depends on the parameter
We define the perturbed PDE and cost function involving parameters
J = Parameter(1)
F = Id(2)
#Finv = 2*Id(2) - F # consistent linearization at F = I (avoids calling Inv() for speedup)
def Equation(u,v):
return ( (Inv(F.trans)*grad(u))*(Inv(F.trans)*grad(v))-f*v)*J*dx
# return ( (Finv.trans*grad(u))*(Finv.trans*grad(v))-f*v)*J*dx
def CostAuto(u):
return J*(u-ud)**q*dx
PHI, X = VEC.TnT()
Lagrangian = CostAuto(gfu) + Equation(gfu,gfp)
dJOmegaAuto = LinearForm(VEC)
dJOmegaAuto += Lagrangian.Diff(J, div(X))
dJOmegaAuto += Lagrangian.Diff(F, grad(X).trans) # grad(X).trans is Jacobian
dJOmegaAuto += Lagrangian.Diff(x, X[0]) + Lagrangian.Diff(y, X[1])
b = BilinearForm(VEC)
gfX = GridFunction(VEC)
rhs = gfX.vec.CreateVector()
gfX.vec.data += update
b.Assemble()
dJOmegaAuto.Assemble()
Draw(-gfX, mesh, "gfX")
gfset = GridFunction(VEC)
gfset.Set((0,0))
mesh.SetDeformation(gfset)
gfset.Set((0,0))
print('Cost at initial design', Integrate (CostAuto(gfu), mesh))
scale = 0.5 / Norm(gfX.vec)
sceneSet.Redraw()
Cost at initial design 5.152244130814951e-09
fstate.Assemble()
print('Cost at new design', Integrate (CostAuto(gfu), mesh))
Cost at new design 9.793644493069302e-10
Equation can also be used to define the bilinear form. The following defines the same bilinear form as above:
aAuto += Equation(u,v)
gfset.Set((0,0))
fstate.Assemble()
LineSearch = False
iter_max = 600
Jold = Integrate(CostAuto(gfu), mesh)
converged = False
for k in range(iter_max):
fstate.Assemble()
fadjoint.Assemble()
b.Assemble()
scale = 0.01 / Norm(gfX.vec)
gfsetOld = gfset
if LineSearch:
scale = scale / 2
if scale <= 1e-12:
converged = True
break
fstate.Assemble()
if converged==True:
break
Jold = Jnew
cost at iteration 0 : 5.152244130814932e-09
cost at iteration 1 : 4.942040315052465e-09
cost at iteration 2 : 4.5850808690470135e-09
cost at iteration 3 : 4.249439885598259e-09
cost at iteration 4 : 3.934229274496262e-09
cost at iteration 5 : 3.6385740544274783e-09
cost at iteration 6 : 3.3616132927088307e-09
cost at iteration 7 : 3.102501038477676e-09
cost at iteration 8 : 2.8604072470352507e-09
cost at iteration 9 : 2.634518692682722e-09
cost at iteration 10 : 2.424039866929757e-09
cost at iteration 11 : 2.2281938583607805e-09
cost at iteration 12 : 2.0462232096623734e-09
cost at iteration 13 : 1.877390746276767e-09
cost at iteration 14 : 1.7209803697550375e-09
cost at iteration 15 : 1.576297807005677e-09
cost at iteration 16 : 1.4426713040877673e-09
cost at iteration 17 : 1.3194522497306325e-09
cost at iteration 18 : 1.2060157090339114e-09
cost at iteration 19 : 1.1017608413450996e-09
cost at iteration 20 : 1.0061111674975642e-09
cost at iteration 21 : 9.185146395774446e-10
cost at iteration 22 : 8.384434500547998e-10
cost at iteration 23 : 7.653934950250658e-10
cost at iteration 24 : 6.988833766917684e-10
cost at iteration 25 : 6.384527911306818e-10
cost at iteration 26 : 5.836600972575326e-10
cost at iteration 27 : 5.340788023199241e-10
cost at iteration 28 : 4.892926352905075e-10
cost at iteration 29 : 4.488888372771933e-10
cost at iteration 30 : 4.124493475644511e-10
cost at iteration 31 : 3.795398821676597e-10
cost at iteration 32 : 3.496978994973505e-10
cost at iteration 33 : 3.224229646055943e-10
cost at iteration 34 : 2.9717833433569407e-10
cost at iteration 35 : 2.734208497181494e-10
cost at iteration 36 : 2.506798047504566e-10
cost at iteration 37 : 2.2867865248925986e-10
cost at iteration 38 : 2.0741877930875087e-10
cost at iteration 39 : 1.8711564698267465e-10
cost at iteration 40 : 1.680225990721038e-10
cost at iteration 41 : 1.5030409913780633e-10
cost at iteration 42 : 1.340169892860871e-10
cost at iteration 43 : 1.1914272597739713e-10
cost at iteration 44 : 1.056211889134839e-10
cost at iteration 45 : 9.337291061389827e-11
cost at iteration 46 : 8.231145824835373e-11
cost at iteration 47 : 7.23497539531662e-11
cost at iteration 48 : 6.340308482728872e-11
cost at iteration 49 : 5.539042161627136e-11
cost at iteration 50 : 4.823491672945069e-11
cost at iteration 51 : 4.186402390638018e-11
cost at iteration 52 : 3.620945390576394e-11
cost at iteration 53 : 3.12070653802054e-11
cost at iteration 54 : 2.6796734440610483e-11
cost at iteration 55 : 2.2922220688921818e-11
cost at iteration 56 : 1.9531036130474335e-11
cost at iteration 57 : 1.6574318562732776e-11
cost at iteration 58 : 1.4006709060443762e-11
cost at iteration 59 : 1.1786232362324965e-11
cost at iteration 60 : 9.874178616578768e-12
cost at iteration 61 : 8.234984789862004e-12
cost at iteration 62 : 6.8361140194980614e-12
cost at iteration 63 : 5.647931255556368e-12
cost at iteration 64 : 4.643573755009424e-12
cost at iteration 65 : 3.79881527448045e-12
cost at iteration 66 : 3.0919233641335144e-12
cost at iteration 67 : 2.5035095464609645e-12
cost at iteration 68 : 2.016373380151357e-12
cost at iteration 69 : 1.6153408584893742e-12
cost at iteration 70 : 1.2871018492123458e-12
cost at iteration 71 : 1.0200425660121514e-12
cost at iteration 72 : 8.04101811907473e-13
cost at iteration 73 : 6.306625713390689e-13
cost at iteration 74 : 4.937810587536974e-13
cost at iteration 75 : 4.038743115985516e-13
cost at iteration 76 : 3.6977366617695585e-13
cost at iteration 77 : 3.391503989858549e-13
cost at iteration 78 : 3.0994728647082915e-13
cost at iteration 79 : 2.8418809614113074e-13
cost at iteration 80 : 2.602015679563889e-13
cost at iteration 81 : 2.3870400427207476e-13
cost at iteration 82 : 2.189402326498232e-13
cost at iteration 83 : 2.0107235167501253e-13
cost at iteration 84 : 1.847560962827504e-13
cost at iteration 85 : 1.6993450676810084e-13
cost at iteration 86 : 1.5644707213282408e-13
cost at iteration 87 : 1.441612852898547e-13
cost at iteration 88 : 1.3299888316163557e-13
cost at iteration 89 : 1.2281207207771698e-13
cost at iteration 90 : 1.1355919196768976e-13
cost at iteration 91 : 1.0510144282710361e-13
cost at iteration 92 : 9.741322745022404e-14
cost at iteration 93 : 9.037356222322941e-14
cost at iteration 94 : 8.396375795060642e-14
cost at iteration 95 : 7.808287254019635e-14
cost at iteration 96 : 7.271510922055711e-14
cost at iteration 97 : 6.77789668727767e-14
cost at iteration 98 : 6.325978293235702e-14
cost at iteration 99 : 5.909367708276851e-14
cost at iteration 100 : 5.5266312266776365e-14
cost at iteration 101 : 5.1729119032482634e-14
cost at iteration 102 : 4.8467672516927466e-14
cost at iteration 103 : 4.5446296325404274e-14
cost at iteration 104 : 4.265025279546492e-14
cost at iteration 105 : 4.005445437800318e-14
cost at iteration 106 : 3.764374632744396e-14
cost at iteration 107 : 3.540156117394774e-14
cost at iteration 108 : 3.331231820891711e-14
cost at iteration 109 : 3.1366187136757206e-14
cost at iteration 110 : 2.954722865704113e-14
cost at iteration 111 : 2.7850855087319455e-14
cost at iteration 112 : 2.6260891448208297e-14
cost at iteration 113 : 2.4776761800528488e-14
cost at iteration 114 : 2.3382213446773128e-14
cost at iteration 115 : 2.2079678770587107e-14
cost at iteration 116 : 2.0853002877993295e-14
cost at iteration 117 : 1.9706812337217115e-14
cost at iteration 118 : 1.862523000766937e-14
cost at iteration 119 : 1.7614416588232597e-14
cost at iteration 120 : 1.6658948127921077e-14
cost at iteration 121 : 1.5765982826450304e-14
cost at iteration 122 : 1.4920714712236086e-14
cost at iteration 123 : 1.4130859202355867e-14
cost at iteration 124 : 1.3382376270812139e-14
cost at iteration 125 : 1.2683167514497975e-14
cost at iteration 126 : 1.202007901338602e-14
cost at iteration 127 : 1.1400864336218601e-14
cost at iteration 128 : 1.0813330171009113e-14
cost at iteration 129 : 1.0264752199471035e-14
cost at iteration 130 : 9.743925711461055e-15
cost at iteration 131 : 9.257338158356138e-15
cost at iteration 132 : 8.794835075022783e-15
cost at iteration 133 : 8.361938256590832e-15
cost at iteration 134 : 7.94975512261959e-15
cost at iteration 135 : 7.562856884085308e-15
cost at iteration 136 : 7.193878599785462e-15
cost at iteration 137 : 6.846491064372645e-15
cost at iteration 138 : 6.514948805575775e-15
cost at iteration 139 : 6.201993142147536e-15
cost at iteration 140 : 5.903399994243567e-15
cost at iteration 141 : 5.6209360772933205e-15
cost at iteration 142 : 5.351731791472277e-15
cost at iteration 143 : 5.096582419347018e-15
cost at iteration 144 : 4.853808998451093e-15
cost at iteration 145 : 4.623288548177376e-15
cost at iteration 146 : 4.4043868182233105e-15
cost at iteration 147 : 4.1961450156421914e-15
cost at iteration 148 : 3.998842878687953e-15
cost at iteration 149 : 3.8107802788536896e-15
cost at iteration 150 : 3.633031539817425e-15
cost at iteration 151 : 3.4632519214800258e-15
cost at iteration 152 : 3.3031996120242764e-15
cost at iteration 153 : 3.1499799330321967e-15
cost at iteration 154 : 3.0059307879100035e-15
cost at iteration 155 : 2.867699581347287e-15
cost at iteration 156 : 2.738103985676431e-15
cost at iteration 157 : 2.6134257441728256e-15
cost at iteration 158 : 2.4968635516442203e-15
cost at iteration 159 : 2.38443555774674e-15
cost at iteration 160 : 2.279621895111495e-15
cost at iteration 161 : 2.1783221309662862e-15
cost at iteration 162 : 2.0842133225064412e-15
cost at iteration 163 : 1.993409186588248e-15
cost at iteration 164 : 1.909848596847841e-15
cost at iteration 165 : 1.8308844456745757e-15
cost at iteration 166 : 1.7603512878472203e-15
cost at iteration 167 : 1.6953726890043395e-15
cost at iteration 168 : 1.6337580822264638e-15
cost at iteration 169 : 1.5755635686952429e-15
cost at iteration 170 : 1.5186186097079618e-15
cost at iteration 171 : 1.465086425287961e-15
cost at iteration 172 : 1.4125312442929655e-15
cost at iteration 173 : 1.3633234413160113e-15
cost at iteration 174 : 1.3151003514189375e-15
cost at iteration 175 : 1.2700675006280674e-15
cost at iteration 176 : 1.226032639454432e-15
cost at iteration 177 : 1.1849951382265766e-15
cost at iteration 178 : 1.144936271885594e-15
cost at iteration 179 : 1.1076635467262861e-15
cost at iteration 180 : 1.0713194283535159e-15
cost at iteration 181 : 1.0375421921162177e-15
cost at iteration 182 : 1.0046226390029162e-15
cost at iteration 183 : 9.740506483991214e-16
cost at iteration 184 : 9.442543155934123e-16
cost at iteration 185 : 9.165922758378797e-16
cost at iteration 186 : 8.896205658754849e-16
cost at iteration 187 : 8.645802600791525e-16
cost at iteration 188 : 8.401471777233702e-16
cost at iteration 189 : 8.174557391862637e-16
cost at iteration 190 : 7.95294172079007e-16
cost at iteration 191 : 7.746990604426485e-16
cost at iteration 192 : 7.545642017578473e-16
cost at iteration 193 : 7.358356189500002e-16
cost at iteration 194 : 7.175062626986021e-16
cost at iteration 195 : 7.0043772220014e-16
cost at iteration 196 : 6.83716077240544e-16
cost at iteration 197 : 6.681237361936978e-16
cost at iteration 198 : 6.528342847574644e-16
cost at iteration 199 : 6.385555190391363e-16
cost at iteration 200 : 6.245433219296647e-16
cost at iteration 201 : 6.114348986356576e-16
cost at iteration 202 : 5.98563637869376e-16
cost at iteration 203 : 5.864997317207091e-16
cost at iteration 204 : 5.746496889312711e-16
cost at iteration 205 : 5.635199036823379e-16
cost at iteration 206 : 5.525860006247824e-16
cost at iteration 207 : 5.422934930100947e-16
cost at iteration 208 : 5.321834675266953e-16
cost at iteration 209 : 5.226432264394739e-16
cost at iteration 210 : 5.132759802960449e-16
cost at iteration 211 : 5.04413283780636e-16
cost at iteration 212 : 4.957174143768553e-16
cost at iteration 213 : 4.87466467852465e-16
cost at iteration 214 : 4.7937898066731075e-16
cost at iteration 215 : 4.716817283990702e-16
cost at iteration 216 : 4.641469183892862e-16
cost at iteration 217 : 4.569520140990757e-16
cost at iteration 218 : 4.499204999808767e-16
cost at iteration 219 : 4.431824198080625e-16
cost at iteration 220 : 4.3661031365091153e-16
cost at iteration 221 : 4.3028859413004123e-16
cost at iteration 222 : 4.2413678887625054e-16
cost at iteration 223 : 4.181953733069096e-16
cost at iteration 224 : 4.124289319615828e-16
cost at iteration 225 : 4.068356099179253e-16
cost at iteration 226 : 4.0142324174716734e-16
cost at iteration 227 : 3.9614916813659984e-16
cost at iteration 228 : 3.910627789680601e-16
cost at iteration 229 : 3.8608206077185916e-16
cost at iteration 230 : 3.8129636622816025e-16
cost at iteration 231 : 3.765857067084717e-16
cost at iteration 232 : 3.7207789882330614e-16
cost at iteration 233 : 3.6761629049167306e-16
cost at iteration 234 : 3.6336574961092133e-16
cost at iteration 235 : 3.5913420859252025e-16
cost at iteration 236 : 3.5512225373229503e-16
cost at iteration 237 : 3.5110358932165345e-16
cost at iteration 238 : 3.4731326124524073e-16
cost at iteration 239 : 3.434918754410022e-16
cost at iteration 240 : 3.399077476394114e-16
cost at iteration 241 : 3.3626946028307666e-16
cost at iteration 242 : 3.3287747381834904e-16
cost at iteration 243 : 3.2940936966289136e-16
cost at iteration 244 : 3.261966884789644e-16
cost at iteration 245 : 3.2288698309760543e-16
cost at iteration 246 : 3.198418669398781e-16
cost at iteration 247 : 3.166797888701883e-16
cost at iteration 248 : 3.1379148139979635e-16
cost at iteration 249 : 3.1076716832069005e-16
cost at iteration 250 : 3.0802579837855145e-16
cost at iteration 251 : 3.0513020545184464e-16
cost at iteration 252 : 3.025266997344011e-16
cost at iteration 253 : 2.9975151852030033e-16
cost at iteration 254 : 2.972775241844618e-16
cost at iteration 255 : 2.9461511077193494e-16
cost at iteration 256 : 2.9226292670054327e-16
cost at iteration 257 : 2.897062378873735e-16
cost at iteration 258 : 2.8746875352619843e-16
cost at iteration 259 : 2.850112900464336e-16
cost at iteration 260 : 2.828819308751007e-16
cost at iteration 261 : 2.805176868089569e-16
cost at iteration 262 : 2.784903656362595e-16
cost at iteration 263 : 2.7621378325412945e-16
cost at iteration 264 : 2.7428285663742125e-16
cost at iteration 265 : 2.720887860286002e-16
cost at iteration 266 : 2.7024901520951365e-16
cost at iteration 267 : 2.6813267813107392e-16
cost at iteration 268 : 2.663791939596475e-16
cost at iteration 269 : 2.643361514131085e-16
cost at iteration 270 : 2.6266442280042437e-16
cost at iteration 271 : 2.6069054590670973e-16
cost at iteration 272 : 2.590963514047489e-16
cost at iteration 273 : 2.5718779520142113e-16
cost at iteration 274 : 2.5566719735941047e-16
cost at iteration 275 : 2.5382037719069413e-16
cost at iteration 276 : 2.52369699381016e-16
cost at iteration 277 : 2.5058126959174554e-16
cost at iteration 278 : 2.4919707503579335e-16
cost at iteration 279 : 2.474639097152262e-16
cost at iteration 280 : 2.4614298247273943e-16
cost at iteration 281 : 2.4446215802470727e-16
cost at iteration 282 : 2.4320148573822024e-16
cost at iteration 283 : 2.4157026508067735e-16
cost at iteration 284 : 2.403670232913649e-16
cost at iteration 285 : 2.3878284151190023e-16
cost at iteration 286 : 2.3763437938453045e-16
cost at iteration 287 : 2.360948306982518e-16
cost at iteration 288 : 2.3499865801179527e-16
cost at iteration 289 : 2.335014838860535e-16
cost at iteration 290 : 2.324552591626938e-16
cost at iteration 291 : 2.3099833748874366e-16
cost at iteration 292 : 2.299998571481534e-16
cost at iteration 293 : 2.285811923534648e-16
cost at iteration 294 : 2.276283807921332e-16
cost at iteration 295 : 2.2624609479886886e-16
cost at iteration 296 : 2.253369953046784e-16
cost at iteration 297 : 2.239893192508544e-16
cost at iteration 298 : 2.231220856732583e-16
cost at iteration 299 : 2.218073523219687e-16
cost at iteration 300 : 2.2098024142623818e-16
cost at iteration 301 : 2.1969687819681792e-16
cost at iteration 302 : 2.18908242638487e-16
cost at iteration 303 : 2.1765476520047076e-16
cost at iteration 304 : 2.1690304706279428e-16
cost at iteration 305 : 2.1567805344012128e-16
cost at iteration 306 : 2.1496177828295586e-16
cost at iteration 307 : 2.1376394342118567e-16
cost at iteration 308 : 2.1308171479525445e-16
cost at iteration 309 : 2.119097855499005e-16
cost at iteration 310 : 2.1126027993476103e-16
cost at iteration 311 : 2.101130704428174e-16
cost at iteration 312 : 2.0949503257106578e-16
cost at iteration 313 : 2.083714199720127e-16
cost at iteration 314 : 2.0778365850600407e-16
cost at iteration 315 : 2.0668257898182499e-16
cost at iteration 316 : 2.0612396251226557e-16
cost at iteration 317 : 2.0504440761911728e-16
cost at iteration 318 : 2.0451386095812034e-16
cost at iteration 319 : 2.0345487422497733e-16
cost at iteration 320 : 2.029513749684247e-16
cost at iteration 321 : 2.0191204874046022e-16
cost at iteration 322 : 2.0143462407727032e-16
cost at iteration 323 : 2.0041409658377315e-16
cost at iteration 324 : 1.9996182033141956e-16
cost at iteration 325 : 1.9895927296007836e-16
cost at iteration 326 : 1.9853126280792777e-16
cost at iteration 327 : 1.9754591756882086e-16
cost at iteration 328 : 1.9714133251236317e-16
cost at iteration 329 : 1.961724496768217e-16
cost at iteration 330 : 1.957904876273831e-16
cost at iteration 331 : 1.9483736352783183e-16
cost at iteration 332 : 1.9447725908397684e-16
cost at iteration 333 : 1.9353922406242817e-16
cost at iteration 334 : 1.932002464302995e-16
cost at iteration 335 : 1.922766629240335e-16
cost at iteration 336 : 1.9195811397504393e-16
cost at iteration 337 : 1.910483747291865e-16
cost at iteration 338 : 1.9074958718456637e-16
cost at iteration 339 : 1.8985311358198643e-16
cost at iteration 340 : 1.8957344931455586e-16
cost at iteration 341 : 1.886896898143024e-16
cost at iteration 342 : 1.884285382587229e-16
cost at iteration 343 : 1.875569669351599e-16
cost at iteration 344 : 1.8731374359860514e-16
cost at iteration 345 : 1.864538587737831e-16
cost at iteration 346 : 1.862280038396937e-16
cost at iteration 347 : 1.8537932680217822e-16
cost at iteration 348 : 1.8517030382042721e-16
cost at iteration 349 : 1.843323776245457e-16
cost at iteration 350 : 1.8413967228174857e-16
cost at iteration 351 : 1.8331206062132077e-16
cost at iteration 352 : 1.8313517958576101e-16
cost at iteration 353 : 1.823174657372084e-16
cost at iteration 354 : 1.821559355731144e-16
cost at iteration 355 : 1.8134772140295692e-16
cost at iteration 356 : 1.8120108754933917e-16
cost at iteration 357 : 1.8040199258169182e-16
cost at iteration 358 : 1.8026981839143316e-16
cost at iteration 359 : 1.7947947893124026e-16
cost at iteration 360 : 1.793613447663281e-16
cost at iteration 361 : 1.7857941307458443e-16
cost at iteration 362 : 1.7847491545375535e-16
cost at iteration 363 : 1.7770105897118833e-16
cost at iteration 364 : 1.7760980976654561e-16
cost at iteration 365 : 1.7684371038233778e-16
cost at iteration 366 : 1.7676533606184192e-16
cost at iteration 367 : 1.7600668942448574e-16
cost at iteration 368 : 1.759408303372099e-16
cost at iteration 369 : 1.7518934520467335e-16
cost at iteration 370 : 1.7513565490622787e-16
cost at iteration 371 : 1.7439105253269426e-16
cost at iteration 372 : 1.743491971483068e-16
cost at iteration 373 : 1.736112107052476e-16
cost at iteration 374 : 1.7358086832798953e-16
cost at iteration 375 : 1.7284924235719093e-16
cost at iteration 376 : 1.7283010247944134e-16
cost at iteration 377 : 1.7210459237594076e-16
cost at iteration 378 : 1.7209635535175837e-16
cost at iteration 379 : 1.7137672687480183e-16
cost at iteration 380 : 1.7137910341159073e-16
cost at iteration 381 : 1.7066513222180986e-16
cost at iteration 382 : 1.706778428993043e-16
cost at iteration 383 : 1.699693141203524e-16
cost at iteration 384 : 1.699920889355304e-16
cost at iteration 385 : 1.6928879673878522e-16
cost at iteration 386 : 1.6932137467487976e-16
cost at iteration 387 : 1.6862312188564432e-16
cost at iteration 388 : 1.6866525050412874e-16
cost at iteration 389 : 1.6797184822807972e-16
cost at iteration 390 : 1.680232832820546e-16
cost at iteration 391 : 1.6733455055065764e-16
cost at iteration 392 : 1.6739505561858717e-16
cost at iteration 393 : 1.6671081905231273e-16
cost at iteration 394 : 1.6678016519078775e-16
cost at iteration 395 : 1.6610025867914903e-16
cost at iteration 396 : 1.6617822409369363e-16
cost at iteration 397 : 1.6550248849086405e-16
cost at iteration 398 : 1.6558885822372232e-16
cost at iteration 399 : 1.649171410591977e-16
cost at iteration 400 : 1.6501170669309652e-16
cost at iteration 401 : 1.6434386189606726e-16
cost at iteration 402 : 1.644464212731847e-16
cost at iteration 403 : 1.637823089102414e-16
cost at iteration 404 : 1.6389266586536326e-16
cost at iteration 405 : 1.6323215189041745e-16
cost at iteration 406 : 1.6335011599765204e-16
cost at iteration 407 : 1.6269307201367388e-16
cost at iteration 408 : 1.6281845834588197e-16
cost at iteration 409 : 1.621647613775169e-16
cost at iteration 410 : 1.6229739027774668e-16
cost at iteration 411 : 1.616469225544755e-16
cost at iteration 412 : 1.6178661941882892e-16
cost at iteration 413 : 1.611392681678837e-16
cost at iteration 414 : 1.6128586323910014e-16
cost at iteration 415 : 1.606415204876609e-16
cost at iteration 416 : 1.6079484865887437e-16
cost at iteration 417 : 1.6015341104511591e-16
cost at iteration 418 : 1.6031331167329163e-16
cost at iteration 419 : 1.596746802656835e-16
cost at iteration 420 : 1.598409969941008e-16
cost at iteration 421 : 1.5920507711866923e-16
cost at iteration 422 : 1.5937765770805937e-16
cost at iteration 423 : 1.5874435878306582e-16
cost at iteration 424 : 1.589230549508373e-16
cost at iteration 425 : 1.5829229032858286e-16
cost at iteration 426 : 1.5847695759587763e-16
cost at iteration 427 : 1.5784864441115632e-16
cost at iteration 428 : 1.5803914195717128e-16
cost at iteration 429 : 1.57413200982215e-16
cost at iteration 430 : 1.5760939150541144e-16
cost at iteration 431 : 1.5698574701080476e-16
cost at iteration 432 : 1.5718749659670622e-16
cost at iteration 433 : 1.565660762181502e-16
cost at iteration 434 : 1.5677325421340915e-16
cost at iteration 435 : 1.561539888238974e-16
cost at iteration 436 : 1.5636646771618433e-16
cost at iteration 437 : 1.5574929130339111e-16
cost at iteration 438 : 1.5596694660691191e-16
cost at iteration 439 : 1.5535179615563268e-16
cost at iteration 440 : 1.5557450630195892e-16
cost at iteration 441 : 1.5496132168116996e-16
cost at iteration 442 : 1.55188967915013e-16
cost at iteration 443 : 1.545776917695315e-16
cost at iteration 444 : 1.5481015804939887e-16
cost at iteration 445 : 1.5420073569578073e-16
cost at iteration 446 : 1.5443790859902958e-16
cost at iteration 447 : 1.5383028792560656e-16
cost at iteration 448 : 1.540720565579317e-16
cost at iteration 449 : 1.53466187928712e-16
cost at iteration 450 : 1.5371244383754085e-16
cost at iteration 451 : 1.5310827999991574e-16
cost at iteration 452 : 1.5335891709182028e-16
cost at iteration 453 : 1.527564130877784e-16
cost at iteration 454 : 1.5301132754944943e-16
cost at iteration 455 : 1.524104406302455e-16
cost at iteration 456 : 1.5266953085297048e-16
cost at iteration 457 : 1.5207022039702934e-16
cost at iteration 458 : 1.5233338690458242e-16
cost at iteration 459 : 1.5173561433851837e-16
cost at iteration 460 : 1.5200275971803373e-16
cost at iteration 461 : 1.5140648844066614e-16
cost at iteration 462 : 1.516775172766264e-16
cost at iteration 463 : 1.5108271258589096e-16
cost at iteration 464 : 1.5135753139687952e-16
cost at iteration 465 : 1.5076416041936353e-16
cost at iteration 466 : 1.5104267759757492e-16
cost at iteration 467 : 1.5045070922084224e-16
cost at iteration 468 : 1.5073283497409743e-16
cost at iteration 469 : 1.5014223978133123e-16
cost at iteration 470 : 1.5042788607760608e-16
cost at iteration 471 : 1.4983863628481296e-16
cost at iteration 472 : 1.501277167990092e-16
cost at iteration 473 : 1.4953978619449397e-16
cost at iteration 474 : 1.4983221625748982e-16
cost at iteration 475 : 1.4924558014345087e-16
cost at iteration 476 : 1.4954127669321576e-16
cost at iteration 477 : 1.4895591182962204e-16
cost at iteration 478 : 1.4925479336429774e-16
cost at iteration 479 : 1.4867067791469916e-16
cost at iteration 480 : 1.4897266444769876e-16
cost at iteration 481 : 1.4838977792698903e-16
cost at iteration 482 : 1.4869479094375846e-16
cost at iteration 483 : 1.481131141678875e-16
cost at iteration 484 : 1.4842107658454463e-16
cost at iteration 485 : 1.4784059162198223e-16
cost at iteration 486 : 1.4815142774546313e-16
cost at iteration 487 : 1.4757211787041374e-16
cost at iteration 488 : 1.4788575336029933e-16
cost at iteration 489 : 1.4730760300760668e-16
cost at iteration 490 : 1.4762396483936073e-16
cost at iteration 491 : 1.47046959560976e-16
cost at iteration 492 : 1.4736597599065448e-16
cost at iteration 493 : 1.467901024136654e-16
cost at iteration 494 : 1.4711170294397777e-16
cost at iteration 495 : 1.465369487301466e-16
cost at iteration 496 : 1.4686106407775486e-16
cost at iteration 497 : 1.4628741788446219e-16
cost at iteration 498 : 1.4661397994863944e-16
cost at iteration 499 : 1.4604143139116283e-16
cost at iteration 500 : 1.4637037322347936e-16
cost at iteration 501 : 1.4579891283868717e-16
cost at iteration 502 : 1.4613016861391273e-16
cost at iteration 503 : 1.455597878251272e-16
cost at iteration 504 : 1.458932928132044e-16
cost at iteration 505 : 1.45323983896376e-16
cost at iteration 506 : 1.456596744353838e-16
cost at iteration 507 : 1.4509143048637867e-16
cost at iteration 508 : 1.4542924395647864e-16
cost at iteration 509 : 1.4486205885955271e-16
cost at iteration 510 : 1.4520193365789582e-16
cost at iteration 511 : 1.4463580205525197e-16
cost at iteration 512 : 1.4497767757173801e-16
cost at iteration 513 : 1.4441259483410705e-16
cost at iteration 514 : 1.4475641142802497e-16
cost at iteration 515 : 1.4419237362632653e-16
cost at iteration 516 : 1.4453807260382347e-16
cost at iteration 517 : 1.4397507648170726e-16
cost at iteration 518 : 1.4432260007397844e-16
cost at iteration 519 : 1.4376064302145237e-16
cost at iteration 520 : 1.4410993436374158e-16
cost at iteration 521 : 1.4354901439157366e-16
cost at iteration 522 : 1.4390001750283616e-16
cost at iteration 523 : 1.4334013321792994e-16
cost at iteration 524 : 1.4369279298121054e-16
cost at iteration 525 : 1.431339435627649e-16
cost at iteration 526 : 1.4348820570620588e-16
cost at iteration 527 : 1.429303908827552e-16
cost at iteration 528 : 1.4328620196122045e-16
cost at iteration 529 : 1.4272942198842682e-16
cost at iteration 530 : 1.430867293657746e-16
cost at iteration 531 : 1.4253098500493843e-16
cost at iteration 532 : 1.4288973683682302e-16
cost at iteration 533 : 1.4233502933424897e-16
cost at iteration 534 : 1.4269517455142133e-16
cost at iteration 535 : 1.4214150561839265e-16
cost at iteration 536 : 1.4250299391064337e-16
cost at iteration 537 : 1.4195036570410074e-16
cost at iteration 538 : 1.4231314750464212e-16
cost at iteration 539 : 1.4176156260855069e-16
cost at iteration 540 : 1.4212558907882763e-16
cost at iteration 541 : 1.4157505048615555e-16
cost at iteration 542 : 1.4194027350125768e-16
cost at iteration 543 : 1.4139078459658481e-16
cost at iteration 544 : 1.4175715673092965e-16
cost at iteration 545 : 1.412087212736892e-16
cost at iteration 546 : 1.4157619578725473e-16
cost at iteration 547 : 1.410288178954645e-16
cost at iteration 548 : 1.4139734872042035e-16
cost at iteration 549 : 1.4085103285502554e-16
cost at iteration 550 : 1.412205745827154e-16
cost at iteration 551 : 1.4067532553248807e-16
cost at iteration 552 : 1.4104583340072967e-16
cost at iteration 553 : 1.4050165626764143e-16
cost at iteration 554 : 1.408730861485722e-16
cost at iteration 555 : 1.4032998633370535e-16
cost at iteration 556 : 1.4070229472178032e-16
cost at iteration 557 : 1.401602779116803e-16
cost at iteration 558 : 1.4053342191212164e-16
cost at iteration 559 : 1.399924940656708e-16
cost at iteration 560 : 1.4036643138316976e-16
cost at iteration 561 : 1.398265987188784e-16
cost at iteration 562 : 1.4020128764663507e-16
cost at iteration 563 : 1.3966255663039752e-16
cost at iteration 564 : 1.4003795603949572e-16
cost at iteration 565 : 1.3950033337271977e-16
cost at iteration 566 : 1.3987640270169748e-16
cost at iteration 567 : 1.3933989530991096e-16
cost at iteration 568 : 1.3971659455467772e-16
cost at iteration 569 : 1.391812095764909e-16
cost at iteration 570 : 1.3955849928045728e-16
cost at iteration 571 : 1.3902424405688303e-16
cost at iteration 572 : 1.3940208530141564e-16
cost at iteration 573 : 1.3886896736564823e-16
cost at iteration 574 : 1.3924732176066803e-16
cost at iteration 575 : 1.3871534882811324e-16
cost at iteration 576 : 1.3909417850302663e-16
cost at iteration 577 : 1.3856335846175704e-16
cost at iteration 578 : 1.3894262605652236e-16
cost at iteration 579 : 1.38412966958033e-16
cost at iteration 580 : 1.3879263561453963e-16
cost at iteration 581 : 1.382641456648277e-16
cost at iteration 582 : 1.386441790184188e-16
cost at iteration 583 : 1.3811686656939737e-16
cost at iteration 584 : 1.3849722874061082e-16
cost at iteration 585 : 1.3797110228179945e-16
cost at iteration 586 : 1.383517578683031e-16
cost at iteration 587 : 1.3782682601882337e-16
cost at iteration 588 : 1.3820774008754965e-16
cost at iteration 589 : 1.3768401158844114e-16
cost at iteration 590 : 1.380651496679117e-16
cost at iteration 591 : 1.3754263337463832e-16
cost at iteration 592 : 1.37923961447428e-16
cost at iteration 593 : 1.3740266632272429e-16
cost at iteration 594 : 1.3778415081813202e-16
cost at iteration 595 : 1.3726408592508702e-16
cost at iteration 596 : 1.3764569371194857e-16
cost at iteration 597 : 1.371268682073487e-16
cost at iteration 598 : 1.375085665870151e-16
cost at iteration 599 : 1.3699098971486164e-16
