This page was generated from unit-3.5.1-dgapply/dgapply-scalar.ipynb.
3.5.1 Operator applications for Discontinuous Galerkin discretizations - linear transport¶
In the previous units we already saw DG discretizations. However, we only solved stationary problems in these cases so that DG discretizations have only been treated in terms of solving linear systems (where HDG has some advantages over classical DG discretizations).
Here, however, we treat DG discretizations in the case where operator applications are more relevant than the solution of linear systems, as e.g. in explicit time integration schemes. Note that for continuous Galerkin methods, in unit 3.2 we already saw simple ways on how to use operator applications within an IMEX scheme. We will develop this further and take a look at efficient ways to do it for DG methods.
In this unit we start with a model PDE problem: The unsteady scalar linear transport problem
Find \(u: [0,T] \to V_D := \{ u \in L^2(\Omega), b \cdot \nabla u \in L^2(\Omega), u|_{\Gamma_{in}} = u_D\}\), s.t. \begin{equation} \int_{\Omega} \partial_t u v + b \cdot \nabla u v = \int_{\Omega} f v \qquad \forall v \in V_0 = \{ u \in L^2(\Omega), b \cdot \nabla u \in L^2(\Omega), u|_{\Gamma_{in}} = 0\} \end{equation}
We consider the unit square \((0,1)^2\) and a given advection velocity \(b\). Accordingly the inflow boundary is \(\Gamma_{in} = \{ x \cdot y = 0\}\).
# import libraries, define geometry and generate mesh
shape = Rectangle(1,1).Face()
shape.edges.Max(Y).name="top"
geom = OCCGeometry(shape, dim=2)
mesh = Mesh(geom.GenerateMesh(maxh=0.1))
We consider higher order discretizations and set \(k=5\) here:
order = 4
Warning
We will make some timing measurements.
To avoid the impact of initialization overheads you may want to increase \(k\) and decrease the mesh size.
Convection and boundary values:¶
To make cases with
CoefficientFunctionswe use theIfPos-CoefficientFunction.IfPos(a,b,c):adecides on the evaluation. Ifais positivebis evaluated, otherwisec.
b = CF((1+sin(4*pi*y),2))
ubnd = 0.1 * IfPos(x-0.125,IfPos(0.625-x,1+cos(8*pi*x),0),0)
Draw(b,mesh,vectors = {"grid_size" : 32}, min = 2, max = 3, autoscale=False,
height = "30vh")
We consider an Upwind DG discretization (in space):
Find \(u: [0,T] \to V_h := \bigoplus_{T\in\mathcal{T}_h} \mathcal{P}^k(T)\) so that
Here \(\hat{u}\) is the Upwind flux, i.e. \(\hat{u} = u\) on the outflow boundary part \(\partial T_{out} = \{ x\in \partial T \mid b(x) \cdot n_T(x) \geq 0 \}\) of \(T\) and \(\hat{u} = u^{other}\) else, with \(u^{other}\) the value from the neighboring element.
In the following we only treat the explicit time integration case here (take a look at unit 2.8 for solving linear systems with DG formulations).
Explicit time stepping with a DG formulation¶
Upwind-in-space combined with an explicit Euler scheme in time yields:
In our first example we set \(u_0 = f = 0\).
# roughly estimated time step:
dt = 1e-3 / (order+1)
Computing convection applications \(C u^n\)¶
We recall:
We can define the bilinear form without setting up a matrix with storage. (
nonassemble=True)A
BilinearFormis allowed to be nonlinear in the 1st argument (for operator applications)
VT = L2(mesh,order=order)
u,v = VT.TnT()
c = BilinearForm(VT, nonassemble=True)
To access the neighbor function we can use
u.Other(), cf. unit 2.8.To incorporate boundary conditions (\(\hat{u}\) on inflow boundaries), we can use the argument
bndof.Other()(not possible in unit 2.8 )If there is no neighbor element (boundary!) the
CoefficientFunctionbndis evaluated.
upw_flux = b*n * IfPos(b*n, u, u.Other(bnd=ubnd))
c += - b * grad(v) * u * dx + upw_flux * v * dS
Bilinearform for operator applications¶
Due to the nonassemble=True in the constructor of the BilinearForm we can use c.mat * x to realize the operator application without assembling a matrix first:
gfu = GridFunction(VT)
#Draw(gfu,mesh, settings = { "subdivision" : 10 },
# min=-0.1,max=2.1,autoscale=False)
#Operator application (equivalent to assemble and mult but faster)
res = gfu.vec.CreateVector()
res.data = c.mat * gfu.vec
# this does not work:
c2 = BilinearForm(VT)
res.data = c2.mat * gfu.vec
Cell In[10], line 3
1 # this does not work:
2 c2 = BilinearForm(VT)
----> 3 res.data = c2.mat * gfu.vec
TypeError: matrix not ready - assemble bilinearform first
Solving mass matrix problems (see also unit-2.11)¶
We also have to deal with the mass matrix:
Need to invert the mass matrix
For DG methods the mass matrix is block diagonal, often even diagonal.
FESpace offers (if available):
Mass(rho): mass matrix as an operator (not a sparse matrix)Mass(rho).Inverse(): inverse mass matrix as an operator (not a sparse matrix)
invm = VT.Mass(1).Inverse() # not a sparse matrix
print(invm)
Print base-matrix
The (simple) time loop¶
def SolveAndVisualize(conv_op, t=0, tend=0.6, dt=dt, dt_sample=0.06, rhs_vec = None):
gfu.vec[:] = 0; cnt = 0;
sample_rate = int(floor(dt_sample*tend/dt))
gfu_t = GridFunction(gfu.space,multidim=0)
gfu_t.AddMultiDimComponent(gfu.vec)
if rhs_vec:
inv_rhs = invm * rhs_vec
while t < tend-0.5*dt:
if rhs_vec:
res = invm @ conv_op * gfu.vec + inv_rhs
gfu.vec.data -= dt * res
t += dt; cnt += 1; print("\r t=",t,end="")
if (cnt+1) % sample_rate == 0:
return gfu_t
%%time
gfu_t = SolveAndVisualize(c.mat)
- more-to-come:
t= 0.0002 t= 0.0004 t= 0.0006000000000000001 t= 0.0008 t= 0.001 t= 0.0012000000000000001 t= 0.0014000000000000002 t= 0.0016000000000000003 t= 0.0018000000000000004 t= 0.0020000000000000005 t= 0.0022000000000000006 t= 0.0024000000000000007 t= 0.0026000000000000007 t= 0.002800000000000001 t= 0.003000000000000001 t= 0.003200000000000001 t= 0.003400000000000001 t= 0.003600000000000001 t= 0.0038000000000000013 t= 0.004000000000000001 t= 0.004200000000000001 t= 0.0044 t= 0.0046 t= 0.0048 t= 0.004999999999999999 t= 0.005199999999999999 t= 0.0053999999999999986 t= 0.005599999999999998 t= 0.005799999999999998 t= 0.0059999999999999975 t= 0.006199999999999997 t= 0.006399999999999997 t= 0.0065999999999999965 t= 0.006799999999999996 t= 0.006999999999999996 t= 0.0071999999999999955 t= 0.007399999999999995 t= 0.007599999999999995 t= 0.0077999999999999944 t= 0.007999999999999995 t= 0.008199999999999995 t= 0.008399999999999996 t= 0.008599999999999997 t= 0.008799999999999997 t= 0.008999999999999998 t= 0.009199999999999998 t= 0.009399999999999999 t= 0.0096 t= 0.0098 t= 0.01 t= 0.0102
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.010400000000000001 t= 0.010600000000000002 t= 0.010800000000000002 t= 0.011000000000000003 t= 0.011200000000000003 t= 0.011400000000000004 t= 0.011600000000000004 t= 0.011800000000000005 t= 0.012000000000000005 t= 0.012200000000000006 t= 0.012400000000000007 t= 0.012600000000000007 t= 0.012800000000000008 t= 0.013000000000000008 t= 0.013200000000000009 t= 0.013400000000000009 t= 0.01360000000000001 t= 0.01380000000000001 t= 0.01400000000000001 t= 0.014200000000000011 t= 0.014400000000000012 t= 0.014600000000000012 t= 0.014800000000000013 t= 0.015000000000000013 t= 0.015200000000000014 t= 0.015400000000000014 t= 0.015600000000000015 t= 0.015800000000000015 t= 0.016000000000000014 t= 0.016200000000000013 t= 0.016400000000000012 t= 0.01660000000000001 t= 0.01680000000000001 t= 0.017000000000000008 t= 0.017200000000000007 t= 0.017400000000000006 t= 0.017600000000000005 t= 0.017800000000000003 t= 0.018000000000000002 t= 0.0182 t= 0.0184 t= 0.0186 t= 0.018799999999999997 t= 0.018999999999999996 t= 0.019199999999999995 t= 0.019399999999999994 t= 0.019599999999999992 t= 0.01979999999999999 t= 0.01999999999999999 t= 0.02019999999999999 t= 0.020399999999999988 t= 0.020599999999999986 t= 0.020799999999999985 t= 0.020999999999999984 t= 0.021199999999999983 t= 0.02139999999999998 t= 0.02159999999999998 t= 0.02179999999999998 t= 0.021999999999999978 t= 0.022199999999999977 t= 0.022399999999999975 t= 0.022599999999999974 t= 0.022799999999999973 t= 0.022999999999999972 t= 0.02319999999999997 t= 0.02339999999999997 t= 0.023599999999999968 t= 0.023799999999999967 t= 0.023999999999999966 t= 0.024199999999999965 t= 0.024399999999999963 t= 0.024599999999999962 t= 0.02479999999999996 t= 0.02499999999999996 t= 0.02519999999999996 t= 0.025399999999999957 t= 0.025599999999999956 t= 0.025799999999999955 t= 0.025999999999999954 t= 0.026199999999999952 t= 0.02639999999999995 t= 0.02659999999999995 t= 0.02679999999999995 t= 0.026999999999999948 t= 0.027199999999999946 t= 0.027399999999999945 t= 0.027599999999999944 t= 0.027799999999999943 t= 0.02799999999999994 t= 0.02819999999999994 t= 0.02839999999999994 t= 0.028599999999999938 t= 0.028799999999999937 t= 0.028999999999999936 t= 0.029199999999999934 t= 0.029399999999999933 t= 0.029599999999999932 t= 0.02979999999999993 t= 0.02999999999999993 t= 0.03019999999999993 t= 0.030399999999999927 t= 0.030599999999999926 t= 0.030799999999999925 t= 0.030999999999999923 t= 0.031199999999999922 t= 0.03139999999999992 t= 0.03159999999999992 t= 0.03179999999999992 t= 0.03199999999999992 t= 0.032199999999999916 t= 0.032399999999999915 t= 0.032599999999999914 t= 0.03279999999999991 t= 0.03299999999999991 t= 0.03319999999999991 t= 0.03339999999999991 t= 0.03359999999999991 t= 0.033799999999999907 t= 0.033999999999999905 t= 0.034199999999999904 t= 0.0343999999999999 t= 0.0345999999999999 t= 0.0347999999999999 t= 0.0349999999999999 t= 0.0351999999999999 t= 0.0353999999999999 t= 0.035599999999999896 t= 0.035799999999999894 t= 0.03599999999999989 t= 0.03619999999999989 t= 0.03639999999999989 t= 0.03659999999999989 t= 0.03679999999999989 t= 0.03699999999999989 t= 0.037199999999999886 t= 0.037399999999999885 t= 0.037599999999999884 t= 0.03779999999999988 t= 0.03799999999999988 t= 0.03819999999999988 t= 0.03839999999999988 t= 0.03859999999999988 t= 0.038799999999999876 t= 0.038999999999999875 t= 0.039199999999999874 t= 0.03939999999999987 t= 0.03959999999999987 t= 0.03979999999999987 t= 0.03999999999999987 t= 0.04019999999999987 t= 0.04039999999999987 t= 0.040599999999999865 t= 0.040799999999999864 t= 0.04099999999999986 t= 0.04119999999999986 t= 0.04139999999999986 t= 0.04159999999999986 t= 0.04179999999999986 t= 0.04199999999999986 t= 0.042199999999999856 t= 0.042399999999999854 t= 0.04259999999999985 t= 0.04279999999999985 t= 0.04299999999999985 t= 0.04319999999999985 t= 0.04339999999999985 t= 0.04359999999999985 t= 0.043799999999999846 t= 0.043999999999999845 t= 0.044199999999999844 t= 0.04439999999999984 t= 0.04459999999999984 t= 0.04479999999999984 t= 0.04499999999999984 t= 0.04519999999999984 t= 0.045399999999999836 t= 0.045599999999999835 t= 0.045799999999999834 t= 0.04599999999999983 t= 0.04619999999999983 t= 0.04639999999999983 t= 0.04659999999999983 t= 0.04679999999999983 t= 0.04699999999999983 t= 0.047199999999999825 t= 0.047399999999999824 t= 0.04759999999999982 t= 0.04779999999999982 t= 0.04799999999999982 t= 0.04819999999999982 t= 0.04839999999999982 t= 0.04859999999999982 t= 0.048799999999999816 t= 0.048999999999999815 t= 0.04919999999999981 t= 0.04939999999999981 t= 0.04959999999999981 t= 0.04979999999999981 t= 0.04999999999999981 t= 0.05019999999999981 t= 0.050399999999999806 t= 0.050599999999999805 t= 0.050799999999999804 t= 0.0509999999999998 t= 0.0511999999999998 t= 0.0513999999999998 t= 0.0515999999999998 t= 0.0517999999999998 t= 0.051999999999999796 t= 0.052199999999999795 t= 0.052399999999999794 t= 0.05259999999999979 t= 0.05279999999999979 t= 0.05299999999999979 t= 0.05319999999999979 t= 0.05339999999999979 t= 0.05359999999999979 t= 0.053799999999999785 t= 0.053999999999999784 t= 0.05419999999999978 t= 0.05439999999999978 t= 0.05459999999999978 t= 0.05479999999999978 t= 0.05499999999999978 t= 0.05519999999999978 t= 0.055399999999999776 t= 0.055599999999999775 t= 0.05579999999999977 t= 0.05599999999999977 t= 0.05619999999999977 t= 0.05639999999999977 t= 0.05659999999999977 t= 0.05679999999999977 t= 0.056999999999999766 t= 0.057199999999999765 t= 0.057399999999999764 t= 0.05759999999999976 t= 0.05779999999999976 t= 0.05799999999999976 t= 0.05819999999999976 t= 0.05839999999999976 t= 0.058599999999999756 t= 0.058799999999999755 t= 0.058999999999999754 t= 0.05919999999999975 t= 0.05939999999999975 t= 0.05959999999999975 t= 0.05979999999999975 t= 0.05999999999999975 t= 0.06019999999999975 t= 0.060399999999999746 t= 0.060599999999999744 t= 0.06079999999999974 t= 0.06099999999999974 t= 0.06119999999999974 t= 0.06139999999999974 t= 0.06159999999999974 t= 0.06179999999999974 t= 0.061999999999999736 t= 0.062199999999999735 t= 0.06239999999999973 t= 0.06259999999999974 t= 0.06279999999999974 t= 0.06299999999999975 t= 0.06319999999999976 t= 0.06339999999999976 t= 0.06359999999999977 t= 0.06379999999999977 t= 0.06399999999999978 t= 0.06419999999999979 t= 0.06439999999999979 t= 0.0645999999999998 t= 0.0647999999999998 t= 0.06499999999999981 t= 0.06519999999999981 t= 0.06539999999999982 t= 0.06559999999999983 t= 0.06579999999999983 t= 0.06599999999999984 t= 0.06619999999999984 t= 0.06639999999999985 t= 0.06659999999999985 t= 0.06679999999999986 t= 0.06699999999999987 t= 0.06719999999999987 t= 0.06739999999999988 t= 0.06759999999999988 t= 0.06779999999999989 t= 0.0679999999999999 t= 0.0681999999999999
</pre>
end{sphinxVerbatim}
- more-to-come:
- t= 0.0683999999999999
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.06859999999999991 t= 0.06879999999999992 t= 0.06899999999999992 t= 0.06919999999999993 t= 0.06939999999999993 t= 0.06959999999999994 t= 0.06979999999999995 t= 0.06999999999999995 t= 0.07019999999999996 t= 0.07039999999999996 t= 0.07059999999999997 t= 0.07079999999999997 t= 0.07099999999999998 t= 0.07119999999999999 t= 0.07139999999999999 t= 0.0716 t= 0.0718 t= 0.07200000000000001 t= 0.07220000000000001 t= 0.07240000000000002 t= 0.07260000000000003 t= 0.07280000000000003 t= 0.07300000000000004 t= 0.07320000000000004 t= 0.07340000000000005 t= 0.07360000000000005 t= 0.07380000000000006 t= 0.07400000000000007 t= 0.07420000000000007 t= 0.07440000000000008 t= 0.07460000000000008 t= 0.07480000000000009 t= 0.0750000000000001 t= 0.0752000000000001 t= 0.0754000000000001 t= 0.07560000000000011 t= 0.07580000000000012 t= 0.07600000000000012 t= 0.07620000000000013 t= 0.07640000000000013 t= 0.07660000000000014 t= 0.07680000000000015 t= 0.07700000000000015 t= 0.07720000000000016 t= 0.07740000000000016 t= 0.07760000000000017 t= 0.07780000000000017 t= 0.07800000000000018 t= 0.07820000000000019 t= 0.07840000000000019 t= 0.0786000000000002 t= 0.0788000000000002 t= 0.07900000000000021 t= 0.07920000000000021 t= 0.07940000000000022 t= 0.07960000000000023 t= 0.07980000000000023 t= 0.08000000000000024 t= 0.08020000000000024 t= 0.08040000000000025 t= 0.08060000000000025 t= 0.08080000000000026 t= 0.08100000000000027 t= 0.08120000000000027 t= 0.08140000000000028 t= 0.08160000000000028 t= 0.08180000000000029 t= 0.0820000000000003 t= 0.0822000000000003 t= 0.0824000000000003 t= 0.08260000000000031 t= 0.08280000000000032 t= 0.08300000000000032 t= 0.08320000000000033 t= 0.08340000000000033 t= 0.08360000000000034 t= 0.08380000000000035 t= 0.08400000000000035 t= 0.08420000000000036 t= 0.08440000000000036 t= 0.08460000000000037 t= 0.08480000000000038 t= 0.08500000000000038 t= 0.08520000000000039 t= 0.08540000000000039 t= 0.0856000000000004 t= 0.0858000000000004 t= 0.08600000000000041 t= 0.08620000000000042 t= 0.08640000000000042 t= 0.08660000000000043 t= 0.08680000000000043 t= 0.08700000000000044 t= 0.08720000000000044 t= 0.08740000000000045 t= 0.08760000000000046 t= 0.08780000000000046 t= 0.08800000000000047 t= 0.08820000000000047 t= 0.08840000000000048 t= 0.08860000000000048 t= 0.08880000000000049 t= 0.0890000000000005 t= 0.0892000000000005 t= 0.0894000000000005 t= 0.08960000000000051 t= 0.08980000000000052 t= 0.09000000000000052 t= 0.09020000000000053 t= 0.09040000000000054 t= 0.09060000000000054 t= 0.09080000000000055 t= 0.09100000000000055 t= 0.09120000000000056 t= 0.09140000000000056 t= 0.09160000000000057 t= 0.09180000000000058 t= 0.09200000000000058 t= 0.09220000000000059 t= 0.09240000000000059 t= 0.0926000000000006 t= 0.0928000000000006 t= 0.09300000000000061 t= 0.09320000000000062 t= 0.09340000000000062 t= 0.09360000000000063 t= 0.09380000000000063 t= 0.09400000000000064 t= 0.09420000000000064 t= 0.09440000000000065 t= 0.09460000000000066 t= 0.09480000000000066 t= 0.09500000000000067 t= 0.09520000000000067 t= 0.09540000000000068 t= 0.09560000000000068 t= 0.09580000000000069 t= 0.0960000000000007 t= 0.0962000000000007 t= 0.09640000000000071 t= 0.09660000000000071 t= 0.09680000000000072 t= 0.09700000000000072 t= 0.09720000000000073 t= 0.09740000000000074 t= 0.09760000000000074 t= 0.09780000000000075 t= 0.09800000000000075 t= 0.09820000000000076 t= 0.09840000000000076 t= 0.09860000000000077 t= 0.09880000000000078 t= 0.09900000000000078 t= 0.09920000000000079 t= 0.0994000000000008 t= 0.0996000000000008 t= 0.0998000000000008 t= 0.10000000000000081 t= 0.10020000000000082 t= 0.10040000000000082 t= 0.10060000000000083 t= 0.10080000000000083 t= 0.10100000000000084 t= 0.10120000000000084 t= 0.10140000000000085 t= 0.10160000000000086 t= 0.10180000000000086 t= 0.10200000000000087 t= 0.10220000000000087 t= 0.10240000000000088 t= 0.10260000000000088 t= 0.10280000000000089 t= 0.1030000000000009 t= 0.1032000000000009 t= 0.10340000000000091 t= 0.10360000000000091 t= 0.10380000000000092 t= 0.10400000000000093 t= 0.10420000000000093 t= 0.10440000000000094 t= 0.10460000000000094 t= 0.10480000000000095 t= 0.10500000000000095 t= 0.10520000000000096 t= 0.10540000000000097 t= 0.10560000000000097 t= 0.10580000000000098 t= 0.10600000000000098 t= 0.10620000000000099 t= 0.106400000000001 t= 0.106600000000001 t= 0.106800000000001 t= 0.10700000000000101 t= 0.10720000000000102 t= 0.10740000000000102 t= 0.10760000000000103 t= 0.10780000000000103 t= 0.10800000000000104 t= 0.10820000000000105 t= 0.10840000000000105 t= 0.10860000000000106 t= 0.10880000000000106 t= 0.10900000000000107 t= 0.10920000000000107 t= 0.10940000000000108 t= 0.10960000000000109 t= 0.10980000000000109 t= 0.1100000000000011 t= 0.1102000000000011 t= 0.11040000000000111 t= 0.11060000000000111 t= 0.11080000000000112 t= 0.11100000000000113 t= 0.11120000000000113 t= 0.11140000000000114 t= 0.11160000000000114 t= 0.11180000000000115 t= 0.11200000000000115 t= 0.11220000000000116 t= 0.11240000000000117 t= 0.11260000000000117 t= 0.11280000000000118 t= 0.11300000000000118 t= 0.11320000000000119 t= 0.1134000000000012 t= 0.1136000000000012 t= 0.1138000000000012 t= 0.11400000000000121 t= 0.11420000000000122 t= 0.11440000000000122 t= 0.11460000000000123 t= 0.11480000000000123 t= 0.11500000000000124 t= 0.11520000000000125 t= 0.11540000000000125 t= 0.11560000000000126 t= 0.11580000000000126 t= 0.11600000000000127 t= 0.11620000000000127 t= 0.11640000000000128 t= 0.11660000000000129 t= 0.11680000000000129 t= 0.1170000000000013 t= 0.1172000000000013 t= 0.11740000000000131 t= 0.11760000000000131 t= 0.11780000000000132 t= 0.11800000000000133 t= 0.11820000000000133 t= 0.11840000000000134 t= 0.11860000000000134 t= 0.11880000000000135 t= 0.11900000000000135 t= 0.11920000000000136 t= 0.11940000000000137 t= 0.11960000000000137 t= 0.11980000000000138 t= 0.12000000000000138 t= 0.12020000000000139 t= 0.1204000000000014 t= 0.1206000000000014 t= 0.1208000000000014 t= 0.12100000000000141 t= 0.12120000000000142 t= 0.12140000000000142 t= 0.12160000000000143 t= 0.12180000000000143 t= 0.12200000000000144 t= 0.12220000000000145 t= 0.12240000000000145 t= 0.12260000000000146 t= 0.12280000000000146 t= 0.12300000000000147 t= 0.12320000000000147 t= 0.12340000000000148 t= 0.12360000000000149 t= 0.12380000000000149 t= 0.1240000000000015 t= 0.1242000000000015 t= 0.12440000000000151 t= 0.12460000000000152 t= 0.12480000000000152 t= 0.12500000000000153 t= 0.12520000000000153 t= 0.12540000000000154 t= 0.12560000000000154 t= 0.12580000000000155 t= 0.12600000000000156 t= 0.12620000000000156 t= 0.12640000000000157 t= 0.12660000000000157 t= 0.12680000000000158 t= 0.12700000000000158 t= 0.1272000000000016 t= 0.1274000000000016 t= 0.1276000000000016 t= 0.1278000000000016 t= 0.1280000000000016 t= 0.12820000000000162 t= 0.12840000000000162 t= 0.12860000000000163 t= 0.12880000000000164 t= 0.12900000000000164 t= 0.12920000000000165 t= 0.12940000000000165 t= 0.12960000000000166 t= 0.12980000000000166 t= 0.13000000000000167 t= 0.13020000000000168 t= 0.13040000000000168 t= 0.1306000000000017 t= 0.1308000000000017 t= 0.1310000000000017 t= 0.1312000000000017 t= 0.1314000000000017 t= 0.13160000000000172 t= 0.13180000000000172 t= 0.13200000000000173 t= 0.13220000000000173 t= 0.13240000000000174 t= 0.13260000000000174 t= 0.13280000000000175 t= 0.13300000000000176 t= 0.13320000000000176 t= 0.13340000000000177 t= 0.13360000000000177 t= 0.13380000000000178 t= 0.13400000000000178 t= 0.1342000000000018 t= 0.1344000000000018 t= 0.1346000000000018 t= 0.1348000000000018 t= 0.1350000000000018 t= 0.13520000000000182 t= 0.13540000000000182 t= 0.13560000000000183 t= 0.13580000000000184 t= 0.13600000000000184 t= 0.13620000000000185 t= 0.13640000000000185 t= 0.13660000000000186 t= 0.13680000000000186 t= 0.13700000000000187 t= 0.13720000000000188 t= 0.13740000000000188 t= 0.1376000000000019 t= 0.1378000000000019 t= 0.1380000000000019 t= 0.1382000000000019 t= 0.1384000000000019 t= 0.13860000000000192 t= 0.13880000000000192 t= 0.13900000000000193 t= 0.13920000000000193 t= 0.13940000000000194 t= 0.13960000000000194 t= 0.13980000000000195 t= 0.14000000000000196 t= 0.14020000000000196 t= 0.14040000000000197 t= 0.14060000000000197 t= 0.14080000000000198 t= 0.14100000000000198 t= 0.141200000000002 t= 0.141400000000002 t= 0.141600000000002 t= 0.141800000000002 t= 0.142000000000002 t= 0.14220000000000202 t= 0.14240000000000202 t= 0.14260000000000203 t= 0.14280000000000204 t= 0.14300000000000204 t= 0.14320000000000205 t= 0.14340000000000205 t= 0.14360000000000206 t= 0.14380000000000207 t= 0.14400000000000207 t= 0.14420000000000208 t= 0.14440000000000208 t= 0.1446000000000021 t= 0.1448000000000021 t= 0.1450000000000021 t= 0.1452000000000021 t= 0.1454000000000021 t= 0.14560000000000212 t= 0.14580000000000212 t= 0.14600000000000213 t= 0.14620000000000213 t= 0.14640000000000214
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.14660000000000215 t= 0.14680000000000215 t= 0.14700000000000216 t= 0.14720000000000216 t= 0.14740000000000217 t= 0.14760000000000217 t= 0.14780000000000218 t= 0.14800000000000219 t= 0.1482000000000022 t= 0.1484000000000022 t= 0.1486000000000022 t= 0.1488000000000022 t= 0.14900000000000221 t= 0.14920000000000222 t= 0.14940000000000223 t= 0.14960000000000223 t= 0.14980000000000224 t= 0.15000000000000224 t= 0.15020000000000225 t= 0.15040000000000225 t= 0.15060000000000226 t= 0.15080000000000227 t= 0.15100000000000227 t= 0.15120000000000228 t= 0.15140000000000228 t= 0.1516000000000023 t= 0.1518000000000023 t= 0.1520000000000023 t= 0.1522000000000023 t= 0.1524000000000023 t= 0.15260000000000232 t= 0.15280000000000232 t= 0.15300000000000233 t= 0.15320000000000233 t= 0.15340000000000234 t= 0.15360000000000235 t= 0.15380000000000235 t= 0.15400000000000236 t= 0.15420000000000236 t= 0.15440000000000237 t= 0.15460000000000237 t= 0.15480000000000238 t= 0.15500000000000239 t= 0.1552000000000024 t= 0.1554000000000024 t= 0.1556000000000024 t= 0.1558000000000024 t= 0.15600000000000241 t= 0.15620000000000242 t= 0.15640000000000243 t= 0.15660000000000243 t= 0.15680000000000244 t= 0.15700000000000244 t= 0.15720000000000245 t= 0.15740000000000245 t= 0.15760000000000246 t= 0.15780000000000247 t= 0.15800000000000247 t= 0.15820000000000248 t= 0.15840000000000248 t= 0.1586000000000025 t= 0.1588000000000025 t= 0.1590000000000025 t= 0.1592000000000025 t= 0.1594000000000025 t= 0.15960000000000252 t= 0.15980000000000252 t= 0.16000000000000253 t= 0.16020000000000253 t= 0.16040000000000254 t= 0.16060000000000255 t= 0.16080000000000255 t= 0.16100000000000256 t= 0.16120000000000256 t= 0.16140000000000257 t= 0.16160000000000257 t= 0.16180000000000258 t= 0.1620000000000026 t= 0.1622000000000026 t= 0.1624000000000026 t= 0.1626000000000026 t= 0.1628000000000026 t= 0.16300000000000262 t= 0.16320000000000262 t= 0.16340000000000263 t= 0.16360000000000263 t= 0.16380000000000264 t= 0.16400000000000264 t= 0.16420000000000265 t= 0.16440000000000266 t= 0.16460000000000266 t= 0.16480000000000267 t= 0.16500000000000267 t= 0.16520000000000268 t= 0.16540000000000268 t= 0.1656000000000027 t= 0.1658000000000027 t= 0.1660000000000027 t= 0.1662000000000027 t= 0.1664000000000027 t= 0.16660000000000272 t= 0.16680000000000272 t= 0.16700000000000273 t= 0.16720000000000274 t= 0.16740000000000274 t= 0.16760000000000275 t= 0.16780000000000275 t= 0.16800000000000276 t= 0.16820000000000276 t= 0.16840000000000277 t= 0.16860000000000278 t= 0.16880000000000278 t= 0.1690000000000028 t= 0.1692000000000028 t= 0.1694000000000028 t= 0.1696000000000028 t= 0.1698000000000028 t= 0.17000000000000282 t= 0.17020000000000282 t= 0.17040000000000283 t= 0.17060000000000283 t= 0.17080000000000284 t= 0.17100000000000284 t= 0.17120000000000285 t= 0.17140000000000286 t= 0.17160000000000286 t= 0.17180000000000287 t= 0.17200000000000287 t= 0.17220000000000288 t= 0.17240000000000288 t= 0.1726000000000029 t= 0.1728000000000029 t= 0.1730000000000029 t= 0.1732000000000029 t= 0.1734000000000029 t= 0.17360000000000292 t= 0.17380000000000292 t= 0.17400000000000293 t= 0.17420000000000294 t= 0.17440000000000294 t= 0.17460000000000295 t= 0.17480000000000295 t= 0.17500000000000296 t= 0.17520000000000296 t= 0.17540000000000297 t= 0.17560000000000298 t= 0.17580000000000298 t= 0.176000000000003 t= 0.176200000000003 t= 0.176400000000003 t= 0.176600000000003 t= 0.176800000000003 t= 0.17700000000000302 t= 0.17720000000000302 t= 0.17740000000000303 t= 0.17760000000000303 t= 0.17780000000000304 t= 0.17800000000000304 t= 0.17820000000000305 t= 0.17840000000000306 t= 0.17860000000000306 t= 0.17880000000000307 t= 0.17900000000000307 t= 0.17920000000000308 t= 0.17940000000000308 t= 0.1796000000000031 t= 0.1798000000000031 t= 0.1800000000000031 t= 0.1802000000000031 t= 0.1804000000000031 t= 0.18060000000000312 t= 0.18080000000000312 t= 0.18100000000000313 t= 0.18120000000000314 t= 0.18140000000000314 t= 0.18160000000000315 t= 0.18180000000000315 t= 0.18200000000000316 t= 0.18220000000000316 t= 0.18240000000000317 t= 0.18260000000000318 t= 0.18280000000000318 t= 0.1830000000000032 t= 0.1832000000000032 t= 0.1834000000000032 t= 0.1836000000000032 t= 0.1838000000000032 t= 0.18400000000000322 t= 0.18420000000000322 t= 0.18440000000000323 t= 0.18460000000000323 t= 0.18480000000000324 t= 0.18500000000000325 t= 0.18520000000000325 t= 0.18540000000000326 t= 0.18560000000000326 t= 0.18580000000000327 t= 0.18600000000000327 t= 0.18620000000000328 t= 0.18640000000000329 t= 0.1866000000000033 t= 0.1868000000000033 t= 0.1870000000000033 t= 0.1872000000000033 t= 0.18740000000000331 t= 0.18760000000000332 t= 0.18780000000000333 t= 0.18800000000000333 t= 0.18820000000000334 t= 0.18840000000000334 t= 0.18860000000000335 t= 0.18880000000000335 t= 0.18900000000000336 t= 0.18920000000000337 t= 0.18940000000000337 t= 0.18960000000000338 t= 0.18980000000000338 t= 0.1900000000000034 t= 0.1902000000000034 t= 0.1904000000000034 t= 0.1906000000000034 t= 0.1908000000000034 t= 0.19100000000000342 t= 0.19120000000000342 t= 0.19140000000000343 t= 0.19160000000000343 t= 0.19180000000000344 t= 0.19200000000000345 t= 0.19220000000000345 t= 0.19240000000000346 t= 0.19260000000000346 t= 0.19280000000000347 t= 0.19300000000000347 t= 0.19320000000000348 t= 0.19340000000000349 t= 0.1936000000000035 t= 0.1938000000000035 t= 0.1940000000000035 t= 0.1942000000000035 t= 0.19440000000000351 t= 0.19460000000000352 t= 0.19480000000000353 t= 0.19500000000000353 t= 0.19520000000000354 t= 0.19540000000000354 t= 0.19560000000000355 t= 0.19580000000000355 t= 0.19600000000000356 t= 0.19620000000000357 t= 0.19640000000000357 t= 0.19660000000000358 t= 0.19680000000000358 t= 0.1970000000000036 t= 0.1972000000000036 t= 0.1974000000000036 t= 0.1976000000000036 t= 0.1978000000000036 t= 0.19800000000000362 t= 0.19820000000000362 t= 0.19840000000000363 t= 0.19860000000000363 t= 0.19880000000000364 t= 0.19900000000000365 t= 0.19920000000000365 t= 0.19940000000000366 t= 0.19960000000000366 t= 0.19980000000000367 t= 0.20000000000000367 t= 0.20020000000000368 t= 0.2004000000000037 t= 0.2006000000000037 t= 0.2008000000000037 t= 0.2010000000000037 t= 0.2012000000000037 t= 0.20140000000000371 t= 0.20160000000000372 t= 0.20180000000000373 t= 0.20200000000000373 t= 0.20220000000000374 t= 0.20240000000000374 t= 0.20260000000000375 t= 0.20280000000000376 t= 0.20300000000000376 t= 0.20320000000000377 t= 0.20340000000000377 t= 0.20360000000000378 t= 0.20380000000000378 t= 0.2040000000000038 t= 0.2042000000000038 t= 0.2044000000000038 t= 0.2046000000000038 t= 0.2048000000000038 t= 0.20500000000000382 t= 0.20520000000000382 t= 0.20540000000000383 t= 0.20560000000000384 t= 0.20580000000000384 t= 0.20600000000000385 t= 0.20620000000000385 t= 0.20640000000000386 t= 0.20660000000000386 t= 0.20680000000000387 t= 0.20700000000000388 t= 0.20720000000000388 t= 0.2074000000000039 t= 0.2076000000000039 t= 0.2078000000000039 t= 0.2080000000000039 t= 0.2082000000000039 t= 0.20840000000000392 t= 0.20860000000000392 t= 0.20880000000000393 t= 0.20900000000000393 t= 0.20920000000000394 t= 0.20940000000000394 t= 0.20960000000000395 t= 0.20980000000000396 t= 0.21000000000000396 t= 0.21020000000000397 t= 0.21040000000000397 t= 0.21060000000000398 t= 0.21080000000000398 t= 0.211000000000004 t= 0.211200000000004 t= 0.211400000000004 t= 0.211600000000004 t= 0.211800000000004 t= 0.21200000000000402 t= 0.21220000000000402 t= 0.21240000000000403 t= 0.21260000000000404 t= 0.21280000000000404 t= 0.21300000000000405 t= 0.21320000000000405 t= 0.21340000000000406 t= 0.21360000000000406 t= 0.21380000000000407 t= 0.21400000000000408 t= 0.21420000000000408 t= 0.2144000000000041 t= 0.2146000000000041 t= 0.2148000000000041 t= 0.2150000000000041 t= 0.2152000000000041 t= 0.21540000000000412 t= 0.21560000000000412 t= 0.21580000000000413 t= 0.21600000000000413 t= 0.21620000000000414 t= 0.21640000000000414 t= 0.21660000000000415 t= 0.21680000000000416 t= 0.21700000000000416 t= 0.21720000000000417 t= 0.21740000000000417 t= 0.21760000000000418 t= 0.21780000000000418 t= 0.2180000000000042 t= 0.2182000000000042
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.2184000000000042 t= 0.2186000000000042 t= 0.2188000000000042 t= 0.21900000000000422 t= 0.21920000000000422 t= 0.21940000000000423 t= 0.21960000000000424 t= 0.21980000000000424 t= 0.22000000000000425 t= 0.22020000000000425 t= 0.22040000000000426 t= 0.22060000000000426 t= 0.22080000000000427 t= 0.22100000000000428 t= 0.22120000000000428 t= 0.2214000000000043 t= 0.2216000000000043 t= 0.2218000000000043 t= 0.2220000000000043 t= 0.2222000000000043 t= 0.22240000000000432 t= 0.22260000000000432 t= 0.22280000000000433 t= 0.22300000000000433 t= 0.22320000000000434 t= 0.22340000000000435 t= 0.22360000000000435 t= 0.22380000000000436 t= 0.22400000000000436 t= 0.22420000000000437 t= 0.22440000000000437 t= 0.22460000000000438 t= 0.22480000000000439 t= 0.2250000000000044 t= 0.2252000000000044 t= 0.2254000000000044 t= 0.2256000000000044 t= 0.2258000000000044 t= 0.22600000000000442 t= 0.22620000000000443 t= 0.22640000000000443 t= 0.22660000000000444 t= 0.22680000000000444 t= 0.22700000000000445 t= 0.22720000000000445 t= 0.22740000000000446 t= 0.22760000000000447 t= 0.22780000000000447 t= 0.22800000000000448 t= 0.22820000000000448 t= 0.2284000000000045 t= 0.2286000000000045 t= 0.2288000000000045 t= 0.2290000000000045 t= 0.2292000000000045 t= 0.22940000000000452 t= 0.22960000000000452 t= 0.22980000000000453 t= 0.23000000000000453 t= 0.23020000000000454 t= 0.23040000000000455 t= 0.23060000000000455 t= 0.23080000000000456 t= 0.23100000000000456 t= 0.23120000000000457 t= 0.23140000000000457 t= 0.23160000000000458 t= 0.23180000000000459 t= 0.2320000000000046 t= 0.2322000000000046 t= 0.2324000000000046 t= 0.2326000000000046 t= 0.23280000000000461 t= 0.23300000000000462 t= 0.23320000000000463 t= 0.23340000000000463 t= 0.23360000000000464 t= 0.23380000000000464 t= 0.23400000000000465 t= 0.23420000000000465 t= 0.23440000000000466 t= 0.23460000000000467 t= 0.23480000000000467 t= 0.23500000000000468 t= 0.23520000000000468 t= 0.2354000000000047 t= 0.2356000000000047 t= 0.2358000000000047 t= 0.2360000000000047 t= 0.2362000000000047 t= 0.23640000000000472 t= 0.23660000000000472 t= 0.23680000000000473 t= 0.23700000000000473 t= 0.23720000000000474 t= 0.23740000000000475 t= 0.23760000000000475 t= 0.23780000000000476 t= 0.23800000000000476 t= 0.23820000000000477 t= 0.23840000000000477 t= 0.23860000000000478 t= 0.2388000000000048 t= 0.2390000000000048 t= 0.2392000000000048 t= 0.2394000000000048 t= 0.2396000000000048 t= 0.23980000000000481 t= 0.24000000000000482 t= 0.24020000000000483 t= 0.24040000000000483 t= 0.24060000000000484 t= 0.24080000000000484 t= 0.24100000000000485 t= 0.24120000000000485 t= 0.24140000000000486 t= 0.24160000000000487 t= 0.24180000000000487 t= 0.24200000000000488 t= 0.24220000000000488 t= 0.2424000000000049 t= 0.2426000000000049 t= 0.2428000000000049 t= 0.2430000000000049 t= 0.2432000000000049 t= 0.24340000000000492 t= 0.24360000000000492 t= 0.24380000000000493 t= 0.24400000000000494 t= 0.24420000000000494 t= 0.24440000000000495 t= 0.24460000000000495 t= 0.24480000000000496 t= 0.24500000000000496 t= 0.24520000000000497 t= 0.24540000000000498 t= 0.24560000000000498 t= 0.245800000000005 t= 0.246000000000005 t= 0.246200000000005 t= 0.246400000000005 t= 0.246600000000005 t= 0.24680000000000502 t= 0.24700000000000502 t= 0.24720000000000503 t= 0.24740000000000503 t= 0.24760000000000504 t= 0.24780000000000504 t= 0.24800000000000505 t= 0.24820000000000506 t= 0.24840000000000506 t= 0.24860000000000507 t= 0.24880000000000507 t= 0.24900000000000508 t= 0.24920000000000508 t= 0.2494000000000051 t= 0.2496000000000051 t= 0.2498000000000051 t= 0.2500000000000051 t= 0.2502000000000051 t= 0.25040000000000506 t= 0.25060000000000504 t= 0.250800000000005 t= 0.251000000000005 t= 0.251200000000005 t= 0.25140000000000495 t= 0.25160000000000493 t= 0.2518000000000049 t= 0.2520000000000049 t= 0.25220000000000486 t= 0.25240000000000484 t= 0.2526000000000048 t= 0.2528000000000048 t= 0.2530000000000048 t= 0.25320000000000475 t= 0.25340000000000473 t= 0.2536000000000047 t= 0.2538000000000047 t= 0.25400000000000467 t= 0.25420000000000464 t= 0.2544000000000046 t= 0.2546000000000046 t= 0.2548000000000046 t= 0.25500000000000456 t= 0.25520000000000453 t= 0.2554000000000045 t= 0.2556000000000045 t= 0.25580000000000447 t= 0.25600000000000445 t= 0.2562000000000044 t= 0.2564000000000044 t= 0.2566000000000044 t= 0.25680000000000436 t= 0.25700000000000434 t= 0.2572000000000043 t= 0.2574000000000043 t= 0.25760000000000427 t= 0.25780000000000425 t= 0.2580000000000042 t= 0.2582000000000042 t= 0.2584000000000042 t= 0.25860000000000416 t= 0.25880000000000414 t= 0.2590000000000041 t= 0.2592000000000041 t= 0.25940000000000407 t= 0.25960000000000405 t= 0.259800000000004 t= 0.260000000000004 t= 0.260200000000004 t= 0.26040000000000396 t= 0.26060000000000394 t= 0.2608000000000039 t= 0.2610000000000039 t= 0.2612000000000039 t= 0.26140000000000385 t= 0.26160000000000383 t= 0.2618000000000038 t= 0.2620000000000038 t= 0.26220000000000376 t= 0.26240000000000374 t= 0.2626000000000037 t= 0.2628000000000037 t= 0.2630000000000037 t= 0.26320000000000365 t= 0.26340000000000363 t= 0.2636000000000036 t= 0.2638000000000036 t= 0.26400000000000357 t= 0.26420000000000354 t= 0.2644000000000035 t= 0.2646000000000035 t= 0.2648000000000035 t= 0.26500000000000346 t= 0.26520000000000343 t= 0.2654000000000034 t= 0.2656000000000034 t= 0.26580000000000337 t= 0.26600000000000334 t= 0.2662000000000033 t= 0.2664000000000033 t= 0.2666000000000033 t= 0.26680000000000326 t= 0.26700000000000323 t= 0.2672000000000032 t= 0.2674000000000032 t= 0.26760000000000317 t= 0.26780000000000315 t= 0.2680000000000031 t= 0.2682000000000031 t= 0.2684000000000031 t= 0.26860000000000306 t= 0.26880000000000304 t= 0.269000000000003 t= 0.269200000000003 t= 0.26940000000000297 t= 0.26960000000000295
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.2698000000000029 t= 0.2700000000000029 t= 0.2702000000000029 t= 0.27040000000000286 t= 0.27060000000000284 t= 0.2708000000000028 t= 0.2710000000000028 t= 0.27120000000000277 t= 0.27140000000000275 t= 0.27160000000000273 t= 0.2718000000000027 t= 0.2720000000000027 t= 0.27220000000000266 t= 0.27240000000000264 t= 0.2726000000000026 t= 0.2728000000000026 t= 0.2730000000000026 t= 0.27320000000000255 t= 0.27340000000000253 t= 0.2736000000000025 t= 0.2738000000000025 t= 0.27400000000000246 t= 0.27420000000000244 t= 0.2744000000000024 t= 0.2746000000000024 t= 0.2748000000000024 t= 0.27500000000000235 t= 0.27520000000000233 t= 0.2754000000000023 t= 0.2756000000000023 t= 0.27580000000000227 t= 0.27600000000000224 t= 0.2762000000000022 t= 0.2764000000000022 t= 0.2766000000000022 t= 0.27680000000000216 t= 0.27700000000000213 t= 0.2772000000000021 t= 0.2774000000000021 t= 0.27760000000000207 t= 0.27780000000000205 t= 0.278000000000002 t= 0.278200000000002 t= 0.278400000000002 t= 0.27860000000000196 t= 0.27880000000000194 t= 0.2790000000000019 t= 0.2792000000000019 t= 0.27940000000000187 t= 0.27960000000000185 t= 0.2798000000000018 t= 0.2800000000000018 t= 0.2802000000000018 t= 0.28040000000000176 t= 0.28060000000000174 t= 0.2808000000000017 t= 0.2810000000000017 t= 0.28120000000000167 t= 0.28140000000000165 t= 0.2816000000000016 t= 0.2818000000000016 t= 0.2820000000000016 t= 0.28220000000000156 t= 0.28240000000000154 t= 0.2826000000000015 t= 0.2828000000000015 t= 0.2830000000000015 t= 0.28320000000000145 t= 0.28340000000000143 t= 0.2836000000000014 t= 0.2838000000000014 t= 0.28400000000000136 t= 0.28420000000000134 t= 0.2844000000000013 t= 0.2846000000000013 t= 0.2848000000000013 t= 0.28500000000000125 t= 0.28520000000000123 t= 0.2854000000000012 t= 0.2856000000000012 t= 0.28580000000000116 t= 0.28600000000000114 t= 0.2862000000000011 t= 0.2864000000000011 t= 0.2866000000000011 t= 0.28680000000000105 t= 0.28700000000000103 t= 0.287200000000001 t= 0.287400000000001 t= 0.28760000000000097 t= 0.28780000000000094 t= 0.2880000000000009 t= 0.2882000000000009 t= 0.2884000000000009 t= 0.28860000000000086 t= 0.28880000000000083 t= 0.2890000000000008 t= 0.2892000000000008 t= 0.28940000000000077 t= 0.28960000000000075 t= 0.2898000000000007 t= 0.2900000000000007 t= 0.2902000000000007 t= 0.29040000000000066 t= 0.29060000000000064 t= 0.2908000000000006 t= 0.2910000000000006 t= 0.29120000000000057 t= 0.29140000000000055 t= 0.2916000000000005 t= 0.2918000000000005 t= 0.2920000000000005 t= 0.29220000000000046 t= 0.29240000000000044 t= 0.2926000000000004 t= 0.2928000000000004 t= 0.29300000000000037 t= 0.29320000000000035 t= 0.2934000000000003 t= 0.2936000000000003 t= 0.2938000000000003 t= 0.29400000000000026 t= 0.29420000000000024 t= 0.2944000000000002 t= 0.2946000000000002 t= 0.2948000000000002 t= 0.29500000000000015 t= 0.29520000000000013 t= 0.2954000000000001 t= 0.2956000000000001 t= 0.29580000000000006 t= 0.29600000000000004 t= 0.2962 t= 0.2964 t= 0.2966 t= 0.29679999999999995 t= 0.29699999999999993 t= 0.2971999999999999 t= 0.2973999999999999 t= 0.29759999999999986 t= 0.29779999999999984 t= 0.2979999999999998 t= 0.2981999999999998 t= 0.2983999999999998 t= 0.29859999999999975 t= 0.29879999999999973 t= 0.2989999999999997 t= 0.2991999999999997 t= 0.29939999999999967 t= 0.29959999999999964 t= 0.2997999999999996 t= 0.2999999999999996 t= 0.3001999999999996 t= 0.30039999999999956 t= 0.30059999999999953 t= 0.3007999999999995 t= 0.3009999999999995 t= 0.30119999999999947 t= 0.30139999999999945 t= 0.3015999999999994 t= 0.3017999999999994 t= 0.3019999999999994 t= 0.30219999999999936 t= 0.30239999999999934 t= 0.3025999999999993 t= 0.3027999999999993 t= 0.30299999999999927 t= 0.30319999999999925 t= 0.3033999999999992 t= 0.3035999999999992 t= 0.3037999999999992 t= 0.30399999999999916 t= 0.30419999999999914 t= 0.3043999999999991 t= 0.3045999999999991 t= 0.30479999999999907 t= 0.30499999999999905 t= 0.305199999999999 t= 0.305399999999999 t= 0.305599999999999 t= 0.30579999999999896 t= 0.30599999999999894 t= 0.3061999999999989 t= 0.3063999999999989 t= 0.3065999999999989 t= 0.30679999999999885 t= 0.30699999999999883 t= 0.3071999999999988 t= 0.3073999999999988 t= 0.30759999999999876 t= 0.30779999999999874 t= 0.3079999999999987 t= 0.3081999999999987 t= 0.3083999999999987 t= 0.30859999999999865 t= 0.30879999999999863 t= 0.3089999999999986 t= 0.3091999999999986 t= 0.30939999999999857 t= 0.30959999999999854 t= 0.3097999999999985 t= 0.3099999999999985 t= 0.3101999999999985 t= 0.31039999999999845 t= 0.31059999999999843 t= 0.3107999999999984 t= 0.3109999999999984 t= 0.31119999999999837 t= 0.31139999999999834 t= 0.3115999999999983 t= 0.3117999999999983 t= 0.3119999999999983 t= 0.31219999999999826 t= 0.31239999999999823 t= 0.3125999999999982 t= 0.3127999999999982 t= 0.31299999999999817 t= 0.31319999999999815 t= 0.3133999999999981 t= 0.3135999999999981 t= 0.3137999999999981 t= 0.31399999999999806 t= 0.31419999999999804 t= 0.314399999999998 t= 0.314599999999998 t= 0.31479999999999797 t= 0.31499999999999795 t= 0.3151999999999979 t= 0.3153999999999979 t= 0.3155999999999979 t= 0.31579999999999786 t= 0.31599999999999784 t= 0.3161999999999978 t= 0.3163999999999978 t= 0.31659999999999777 t= 0.31679999999999775 t= 0.31699999999999773 t= 0.3171999999999977 t= 0.3173999999999977 t= 0.31759999999999766 t= 0.31779999999999764 t= 0.3179999999999976 t= 0.3181999999999976 t= 0.3183999999999976 t= 0.31859999999999755 t= 0.31879999999999753 t= 0.3189999999999975 t= 0.3191999999999975 t= 0.31939999999999746 t= 0.31959999999999744 t= 0.3197999999999974 t= 0.3199999999999974 t= 0.3201999999999974 t= 0.32039999999999735 t= 0.32059999999999733 t= 0.3207999999999973 t= 0.3209999999999973 t= 0.32119999999999727 t= 0.32139999999999724 t= 0.3215999999999972 t= 0.3217999999999972 t= 0.3219999999999972 t= 0.32219999999999716 t= 0.32239999999999713 t= 0.3225999999999971 t= 0.3227999999999971 t= 0.32299999999999707 t= 0.32319999999999705 t= 0.323399999999997 t= 0.323599999999997 t= 0.323799999999997 t= 0.32399999999999696 t= 0.32419999999999694 t= 0.3243999999999969 t= 0.3245999999999969 t= 0.32479999999999687 t= 0.32499999999999685 t= 0.3251999999999968 t= 0.3253999999999968 t= 0.3255999999999968 t= 0.32579999999999676 t= 0.32599999999999674 t= 0.3261999999999967 t= 0.3263999999999967 t= 0.32659999999999667 t= 0.32679999999999665 t= 0.3269999999999966 t= 0.3271999999999966 t= 0.3273999999999966 t= 0.32759999999999656 t= 0.32779999999999654 t= 0.3279999999999965 t= 0.3281999999999965 t= 0.3283999999999965 t= 0.32859999999999645 t= 0.32879999999999643 t= 0.3289999999999964 t= 0.3291999999999964 t= 0.32939999999999636 t= 0.32959999999999634 t= 0.3297999999999963 t= 0.3299999999999963 t= 0.3301999999999963 t= 0.33039999999999625 t= 0.33059999999999623
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.3307999999999962 t= 0.3309999999999962 t= 0.33119999999999616 t= 0.33139999999999614 t= 0.3315999999999961 t= 0.3317999999999961 t= 0.3319999999999961 t= 0.33219999999999605 t= 0.33239999999999603 t= 0.332599999999996 t= 0.332799999999996 t= 0.33299999999999597 t= 0.33319999999999594 t= 0.3333999999999959 t= 0.3335999999999959 t= 0.3337999999999959 t= 0.33399999999999586 t= 0.33419999999999583 t= 0.3343999999999958 t= 0.3345999999999958 t= 0.33479999999999577 t= 0.33499999999999575 t= 0.3351999999999957 t= 0.3353999999999957 t= 0.3355999999999957 t= 0.33579999999999566 t= 0.33599999999999564 t= 0.3361999999999956 t= 0.3363999999999956 t= 0.33659999999999557 t= 0.33679999999999555 t= 0.3369999999999955 t= 0.3371999999999955 t= 0.3373999999999955 t= 0.33759999999999546 t= 0.33779999999999544 t= 0.3379999999999954 t= 0.3381999999999954 t= 0.33839999999999537 t= 0.33859999999999535 t= 0.3387999999999953 t= 0.3389999999999953 t= 0.3391999999999953 t= 0.33939999999999526 t= 0.33959999999999524 t= 0.3397999999999952 t= 0.3399999999999952 t= 0.3401999999999952 t= 0.34039999999999515 t= 0.34059999999999513 t= 0.3407999999999951 t= 0.3409999999999951 t= 0.34119999999999506 t= 0.34139999999999504 t= 0.341599999999995 t= 0.341799999999995 t= 0.341999999999995 t= 0.34219999999999495 t= 0.34239999999999493 t= 0.3425999999999949 t= 0.3427999999999949 t= 0.34299999999999486 t= 0.34319999999999484 t= 0.3433999999999948 t= 0.3435999999999948 t= 0.3437999999999948 t= 0.34399999999999475 t= 0.34419999999999473 t= 0.3443999999999947 t= 0.3445999999999947 t= 0.34479999999999467 t= 0.34499999999999464 t= 0.3451999999999946 t= 0.3453999999999946 t= 0.3455999999999946 t= 0.34579999999999456 t= 0.34599999999999453 t= 0.3461999999999945 t= 0.3463999999999945 t= 0.34659999999999447 t= 0.34679999999999445 t= 0.3469999999999944 t= 0.3471999999999944 t= 0.3473999999999944 t= 0.34759999999999436 t= 0.34779999999999434 t= 0.3479999999999943 t= 0.3481999999999943 t= 0.34839999999999427 t= 0.34859999999999425 t= 0.3487999999999942 t= 0.3489999999999942 t= 0.3491999999999942 t= 0.34939999999999416 t= 0.34959999999999414 t= 0.3497999999999941 t= 0.3499999999999941 t= 0.35019999999999407 t= 0.35039999999999405 t= 0.350599999999994 t= 0.350799999999994 t= 0.350999999999994 t= 0.35119999999999396 t= 0.35139999999999394 t= 0.3515999999999939 t= 0.3517999999999939 t= 0.3519999999999939 t= 0.35219999999999385 t= 0.35239999999999383 t= 0.3525999999999938 t= 0.3527999999999938 t= 0.35299999999999376 t= 0.35319999999999374 t= 0.3533999999999937 t= 0.3535999999999937 t= 0.3537999999999937 t= 0.35399999999999365 t= 0.35419999999999363 t= 0.3543999999999936 t= 0.3545999999999936 t= 0.35479999999999356 t= 0.35499999999999354 t= 0.3551999999999935 t= 0.3553999999999935 t= 0.3555999999999935 t= 0.35579999999999345 t= 0.35599999999999343 t= 0.3561999999999934 t= 0.3563999999999934 t= 0.35659999999999337 t= 0.35679999999999334 t= 0.3569999999999933 t= 0.3571999999999933 t= 0.3573999999999933 t= 0.35759999999999326 t= 0.35779999999999323 t= 0.3579999999999932 t= 0.3581999999999932 t= 0.35839999999999317 t= 0.35859999999999315 t= 0.3587999999999931 t= 0.3589999999999931 t= 0.3591999999999931 t= 0.35939999999999306 t= 0.35959999999999304 t= 0.359799999999993 t= 0.359999999999993 t= 0.36019999999999297 t= 0.36039999999999295 t= 0.3605999999999929 t= 0.3607999999999929 t= 0.3609999999999929 t= 0.36119999999999286 t= 0.36139999999999284 t= 0.3615999999999928 t= 0.3617999999999928 t= 0.36199999999999277 t= 0.36219999999999275 t= 0.36239999999999273 t= 0.3625999999999927 t= 0.3627999999999927 t= 0.36299999999999266 t= 0.36319999999999264 t= 0.3633999999999926 t= 0.3635999999999926 t= 0.3637999999999926 t= 0.36399999999999255 t= 0.36419999999999253 t= 0.3643999999999925 t= 0.3645999999999925 t= 0.36479999999999246 t= 0.36499999999999244 t= 0.3651999999999924 t= 0.3653999999999924 t= 0.3655999999999924 t= 0.36579999999999235 t= 0.36599999999999233 t= 0.3661999999999923 t= 0.3663999999999923 t= 0.36659999999999227 t= 0.36679999999999224 t= 0.3669999999999922 t= 0.3671999999999922 t= 0.3673999999999922 t= 0.36759999999999216 t= 0.36779999999999213 t= 0.3679999999999921 t= 0.3681999999999921 t= 0.36839999999999207 t= 0.36859999999999205 t= 0.368799999999992 t= 0.368999999999992 t= 0.369199999999992 t= 0.36939999999999196 t= 0.36959999999999193 t= 0.3697999999999919 t= 0.3699999999999919 t= 0.37019999999999187 t= 0.37039999999999185 t= 0.3705999999999918 t= 0.3707999999999918 t= 0.3709999999999918 t= 0.37119999999999176 t= 0.37139999999999174 t= 0.3715999999999917 t= 0.3717999999999917 t= 0.37199999999999167 t= 0.37219999999999165 t= 0.3723999999999916 t= 0.3725999999999916 t= 0.3727999999999916 t= 0.37299999999999156 t= 0.37319999999999154 t= 0.3733999999999915 t= 0.3735999999999915 t= 0.3737999999999915 t= 0.37399999999999145 t= 0.37419999999999143 t= 0.3743999999999914 t= 0.3745999999999914 t= 0.37479999999999136 t= 0.37499999999999134 t= 0.3751999999999913 t= 0.3753999999999913 t= 0.3755999999999913 t= 0.37579999999999125 t= 0.37599999999999123 t= 0.3761999999999912 t= 0.3763999999999912 t= 0.37659999999999116
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.37679999999999114 t= 0.3769999999999911 t= 0.3771999999999911 t= 0.3773999999999911 t= 0.37759999999999105 t= 0.37779999999999103 t= 0.377999999999991 t= 0.378199999999991 t= 0.37839999999999097 t= 0.37859999999999094 t= 0.3787999999999909 t= 0.3789999999999909 t= 0.3791999999999909 t= 0.37939999999999086 t= 0.37959999999999083 t= 0.3797999999999908 t= 0.3799999999999908 t= 0.38019999999999077 t= 0.38039999999999075 t= 0.3805999999999907 t= 0.3807999999999907 t= 0.3809999999999907 t= 0.38119999999999066 t= 0.38139999999999064 t= 0.3815999999999906 t= 0.3817999999999906 t= 0.38199999999999057 t= 0.38219999999999055 t= 0.3823999999999905 t= 0.3825999999999905 t= 0.3827999999999905 t= 0.38299999999999046 t= 0.38319999999999044 t= 0.3833999999999904 t= 0.3835999999999904 t= 0.38379999999999037 t= 0.38399999999999035 t= 0.3841999999999903 t= 0.3843999999999903 t= 0.3845999999999903 t= 0.38479999999999026 t= 0.38499999999999024 t= 0.3851999999999902 t= 0.3853999999999902 t= 0.3855999999999902 t= 0.38579999999999015 t= 0.38599999999999013 t= 0.3861999999999901 t= 0.3863999999999901 t= 0.38659999999999006 t= 0.38679999999999004 t= 0.38699999999999 t= 0.38719999999999 t= 0.38739999999999 t= 0.38759999999998995 t= 0.38779999999998993 t= 0.3879999999999899 t= 0.3881999999999899 t= 0.38839999999998986 t= 0.38859999999998984 t= 0.3887999999999898 t= 0.3889999999999898 t= 0.3891999999999898 t= 0.38939999999998975 t= 0.38959999999998973 t= 0.3897999999999897 t= 0.3899999999999897 t= 0.39019999999998967 t= 0.39039999999998964 t= 0.3905999999999896 t= 0.3907999999999896 t= 0.3909999999999896 t= 0.39119999999998956 t= 0.39139999999998953 t= 0.3915999999999895 t= 0.3917999999999895 t= 0.39199999999998947 t= 0.39219999999998945 t= 0.3923999999999894 t= 0.3925999999999894 t= 0.3927999999999894 t= 0.39299999999998936 t= 0.39319999999998934 t= 0.3933999999999893 t= 0.3935999999999893 t= 0.39379999999998927 t= 0.39399999999998925 t= 0.3941999999999892 t= 0.3943999999999892 t= 0.3945999999999892 t= 0.39479999999998916 t= 0.39499999999998914 t= 0.3951999999999891 t= 0.3953999999999891 t= 0.39559999999998907 t= 0.39579999999998905 t= 0.395999999999989 t= 0.396199999999989 t= 0.396399999999989 t= 0.39659999999998896 t= 0.39679999999998894 t= 0.3969999999999889 t= 0.3971999999999889 t= 0.3973999999999889 t= 0.39759999999998885 t= 0.39779999999998883 t= 0.3979999999999888 t= 0.3981999999999888 t= 0.39839999999998876 t= 0.39859999999998874 t= 0.3987999999999887 t= 0.3989999999999887 t= 0.3991999999999887 t= 0.39939999999998865 t= 0.39959999999998863 t= 0.3997999999999886 t= 0.3999999999999886 t= 0.40019999999998856 t= 0.40039999999998854 t= 0.4005999999999885 t= 0.4007999999999885 t= 0.4009999999999885 t= 0.40119999999998845 t= 0.40139999999998843 t= 0.4015999999999884 t= 0.4017999999999884 t= 0.40199999999998837 t= 0.40219999999998834 t= 0.4023999999999883 t= 0.4025999999999883 t= 0.4027999999999883 t= 0.40299999999998826 t= 0.40319999999998823 t= 0.4033999999999882 t= 0.4035999999999882 t= 0.40379999999998817 t= 0.40399999999998815 t= 0.4041999999999881 t= 0.4043999999999881 t= 0.4045999999999881 t= 0.40479999999998806 t= 0.40499999999998804 t= 0.405199999999988 t= 0.405399999999988 t= 0.40559999999998797 t= 0.40579999999998795 t= 0.4059999999999879 t= 0.4061999999999879 t= 0.4063999999999879 t= 0.40659999999998786 t= 0.40679999999998784 t= 0.4069999999999878 t= 0.4071999999999878 t= 0.40739999999998777 t= 0.40759999999998775 t= 0.40779999999998773 t= 0.4079999999999877 t= 0.4081999999999877 t= 0.40839999999998766 t= 0.40859999999998764 t= 0.4087999999999876 t= 0.4089999999999876 t= 0.4091999999999876 t= 0.40939999999998755 t= 0.40959999999998753 t= 0.4097999999999875 t= 0.4099999999999875 t= 0.41019999999998746 t= 0.41039999999998744 t= 0.4105999999999874 t= 0.4107999999999874 t= 0.4109999999999874 t= 0.41119999999998735 t= 0.41139999999998733 t= 0.4115999999999873 t= 0.4117999999999873 t= 0.41199999999998727 t= 0.41219999999998724 t= 0.4123999999999872 t= 0.4125999999999872 t= 0.4127999999999872 t= 0.41299999999998716 t= 0.41319999999998713 t= 0.4133999999999871 t= 0.4135999999999871 t= 0.41379999999998707 t= 0.41399999999998705 t= 0.414199999999987 t= 0.414399999999987 t= 0.414599999999987 t= 0.41479999999998696 t= 0.41499999999998693 t= 0.4151999999999869 t= 0.4153999999999869 t= 0.41559999999998687 t= 0.41579999999998685 t= 0.4159999999999868 t= 0.4161999999999868 t= 0.4163999999999868 t= 0.41659999999998676 t= 0.41679999999998674 t= 0.4169999999999867 t= 0.4171999999999867 t= 0.41739999999998667 t= 0.41759999999998665 t= 0.4177999999999866 t= 0.4179999999999866 t= 0.4181999999999866 t= 0.41839999999998656 t= 0.41859999999998654 t= 0.4187999999999865 t= 0.4189999999999865 t= 0.4191999999999865 t= 0.41939999999998645 t= 0.41959999999998643 t= 0.4197999999999864 t= 0.4199999999999864 t= 0.42019999999998636 t= 0.42039999999998634 t= 0.4205999999999863 t= 0.4207999999999863 t= 0.4209999999999863 t= 0.42119999999998625 t= 0.42139999999998623 t= 0.4215999999999862 t= 0.4217999999999862 t= 0.42199999999998616 t= 0.42219999999998614 t= 0.4223999999999861 t= 0.4225999999999861 t= 0.4227999999999861 t= 0.42299999999998605 t= 0.42319999999998603 t= 0.423399999999986 t= 0.423599999999986 t= 0.42379999999998597 t= 0.42399999999998594 t= 0.4241999999999859 t= 0.4243999999999859 t= 0.4245999999999859 t= 0.42479999999998586 t= 0.42499999999998583 t= 0.4251999999999858 t= 0.4253999999999858 t= 0.42559999999998577 t= 0.42579999999998575 t= 0.4259999999999857 t= 0.4261999999999857 t= 0.4263999999999857 t= 0.42659999999998566 t= 0.42679999999998564 t= 0.4269999999999856 t= 0.4271999999999856 t= 0.42739999999998557 t= 0.42759999999998555 t= 0.4277999999999855 t= 0.4279999999999855 t= 0.4281999999999855 t= 0.42839999999998546 t= 0.42859999999998544 t= 0.4287999999999854 t= 0.4289999999999854 t= 0.42919999999998537 t= 0.42939999999998535 t= 0.4295999999999853 t= 0.4297999999999853 t= 0.4299999999999853 t= 0.43019999999998526 t= 0.43039999999998524 t= 0.4305999999999852 t= 0.4307999999999852 t= 0.4309999999999852 t= 0.43119999999998515 t= 0.43139999999998513 t= 0.4315999999999851 t= 0.4317999999999851 t= 0.43199999999998506 t= 0.43219999999998504 t= 0.432399999999985 t= 0.432599999999985 t= 0.432799999999985 t= 0.43299999999998495 t= 0.43319999999998493 t= 0.4333999999999849 t= 0.4335999999999849 t= 0.43379999999998486 t= 0.43399999999998484 t= 0.4341999999999848 t= 0.4343999999999848 t= 0.4345999999999848 t= 0.43479999999998475 t= 0.43499999999998473 t= 0.4351999999999847 t= 0.4353999999999847 t= 0.43559999999998467 t= 0.43579999999998464 t= 0.4359999999999846 t= 0.4361999999999846 t= 0.4363999999999846 t= 0.43659999999998456 t= 0.43679999999998453 t= 0.4369999999999845 t= 0.4371999999999845 t= 0.43739999999998447 t= 0.43759999999998445 t= 0.4377999999999844 t= 0.4379999999999844 t= 0.4381999999999844 t= 0.43839999999998436 t= 0.43859999999998434 t= 0.4387999999999843 t= 0.4389999999999843 t= 0.43919999999998427 t= 0.43939999999998425 t= 0.4395999999999842 t= 0.4397999999999842 t= 0.4399999999999842 t= 0.44019999999998416 t= 0.44039999999998414 t= 0.4405999999999841 t= 0.4407999999999841 t= 0.44099999999998407 t= 0.44119999999998405 t= 0.441399999999984 t= 0.441599999999984 t= 0.441799999999984 t= 0.44199999999998396 t= 0.44219999999998394 t= 0.4423999999999839 t= 0.4425999999999839 t= 0.4427999999999839 t= 0.44299999999998385 t= 0.44319999999998383 t= 0.4433999999999838 t= 0.4435999999999838 t= 0.44379999999998376 t= 0.44399999999998374 t= 0.4441999999999837 t= 0.4443999999999837 t= 0.4445999999999837 t= 0.44479999999998365 t= 0.44499999999998363 t= 0.4451999999999836 t= 0.4453999999999836 t= 0.44559999999998356 t= 0.44579999999998354 t= 0.4459999999999835 t= 0.4461999999999835 t= 0.4463999999999835 t= 0.44659999999998345 t= 0.44679999999998343 t= 0.4469999999999834 t= 0.4471999999999834 t= 0.44739999999998337 t= 0.44759999999998334 t= 0.4477999999999833 t= 0.4479999999999833 t= 0.4481999999999833 t= 0.44839999999998326 t= 0.44859999999998323 t= 0.4487999999999832 t= 0.4489999999999832 t= 0.44919999999998317 t= 0.44939999999998315 t= 0.4495999999999831 t= 0.4497999999999831 t= 0.4499999999999831 t= 0.45019999999998306 t= 0.45039999999998304 t= 0.450599999999983 t= 0.450799999999983 t= 0.45099999999998297 t= 0.45119999999998295 t= 0.4513999999999829 t= 0.4515999999999829 t= 0.4517999999999829 t= 0.45199999999998286 t= 0.45219999999998284 t= 0.4523999999999828 t= 0.4525999999999828 t= 0.45279999999998277 t= 0.45299999999998275 t= 0.45319999999998273 t= 0.4533999999999827 t= 0.4535999999999827 t= 0.45379999999998266 t= 0.45399999999998264 t= 0.4541999999999826 t= 0.4543999999999826 t= 0.4545999999999826 t= 0.45479999999998255 t= 0.45499999999998253 t= 0.4551999999999825 t= 0.4553999999999825 t= 0.45559999999998246 t= 0.45579999999998244 t= 0.4559999999999824 t= 0.4561999999999824 t= 0.4563999999999824 t= 0.45659999999998235 t= 0.45679999999998233 t= 0.4569999999999823 t= 0.4571999999999823 t= 0.45739999999998227 t= 0.45759999999998224 t= 0.4577999999999822 t= 0.4579999999999822 t= 0.4581999999999822 t= 0.45839999999998216 t= 0.45859999999998213 t= 0.4587999999999821 t= 0.4589999999999821 t= 0.45919999999998207 t= 0.45939999999998204 t= 0.459599999999982 t= 0.459799999999982 t= 0.459999999999982 t= 0.46019999999998196 t= 0.46039999999998193 t= 0.4605999999999819 t= 0.4607999999999819 t= 0.46099999999998187 t= 0.46119999999998185 t= 0.4613999999999818 t= 0.4615999999999818 t= 0.4617999999999818 t= 0.46199999999998176 t= 0.46219999999998174 t= 0.4623999999999817 t= 0.4625999999999817 t= 0.46279999999998167 t= 0.46299999999998165 t= 0.4631999999999816 t= 0.4633999999999816 t= 0.4635999999999816 t= 0.46379999999998156 t= 0.46399999999998154 t= 0.4641999999999815 t= 0.4643999999999815 t= 0.46459999999998147 t= 0.46479999999998145 t= 0.46499999999998143 t= 0.4651999999999814 t= 0.4653999999999814 t= 0.46559999999998136 t= 0.46579999999998134 t= 0.4659999999999813 t= 0.4661999999999813 t= 0.4663999999999813 t= 0.46659999999998125 t= 0.46679999999998123 t= 0.4669999999999812 t= 0.4671999999999812 t= 0.46739999999998116 t= 0.46759999999998114 t= 0.4677999999999811 t= 0.4679999999999811 t= 0.4681999999999811 t= 0.46839999999998105 t= 0.46859999999998103 t= 0.468799999999981 t= 0.468999999999981 t= 0.46919999999998097 t= 0.46939999999998094 t= 0.4695999999999809 t= 0.4697999999999809 t= 0.4699999999999809 t= 0.47019999999998086 t= 0.47039999999998083 t= 0.4705999999999808 t= 0.4707999999999808 t= 0.47099999999998077 t= 0.47119999999998075 t= 0.4713999999999807 t= 0.4715999999999807 t= 0.4717999999999807 t= 0.47199999999998066 t= 0.47219999999998064 t= 0.4723999999999806 t= 0.4725999999999806 t= 0.47279999999998057 t= 0.47299999999998055 t= 0.4731999999999805 t= 0.4733999999999805 t= 0.4735999999999805 t= 0.47379999999998046 t= 0.47399999999998044 t= 0.4741999999999804 t= 0.4743999999999804 t= 0.47459999999998037 t= 0.47479999999998035 t= 0.4749999999999803 t= 0.4751999999999803 t= 0.4753999999999803 t= 0.47559999999998026 t= 0.47579999999998024 t= 0.4759999999999802 t= 0.4761999999999802 t= 0.4763999999999802 t= 0.47659999999998015 t= 0.47679999999998013 t= 0.4769999999999801 t= 0.4771999999999801 t= 0.47739999999998006 t= 0.47759999999998004 t= 0.47779999999998 t= 0.47799999999998 t= 0.47819999999998 t= 0.47839999999997995 t= 0.47859999999997993 t= 0.4787999999999799 t= 0.4789999999999799 t= 0.47919999999997986 t= 0.47939999999997984 t= 0.4795999999999798 t= 0.4797999999999798 t= 0.4799999999999798 t= 0.48019999999997975 t= 0.48039999999997973 t= 0.4805999999999797 t= 0.4807999999999797 t= 0.48099999999997967 t= 0.48119999999997964 t= 0.4813999999999796 t= 0.4815999999999796 t= 0.4817999999999796 t= 0.48199999999997956 t= 0.48219999999997953 t= 0.4823999999999795 t= 0.4825999999999795 t= 0.48279999999997947 t= 0.48299999999997945 t= 0.4831999999999794 t= 0.4833999999999794 t= 0.4835999999999794 t= 0.48379999999997936 t= 0.48399999999997934 t= 0.4841999999999793 t= 0.4843999999999793 t= 0.48459999999997927 t= 0.48479999999997925 t= 0.4849999999999792 t= 0.4851999999999792 t= 0.4853999999999792 t= 0.48559999999997916 t= 0.48579999999997914 t= 0.4859999999999791 t= 0.4861999999999791 t= 0.48639999999997907 t= 0.48659999999997905 t= 0.486799999999979 t= 0.486999999999979 t= 0.487199999999979 t= 0.48739999999997896 t= 0.48759999999997894 t= 0.4877999999999789 t= 0.4879999999999789 t= 0.4881999999999789 t= 0.48839999999997885 t= 0.48859999999997883 t= 0.4887999999999788 t= 0.4889999999999788 t= 0.48919999999997876 t= 0.48939999999997874 t= 0.4895999999999787 t= 0.4897999999999787 t= 0.4899999999999787 t= 0.49019999999997865 t= 0.49039999999997863 t= 0.4905999999999786 t= 0.4907999999999786 t= 0.49099999999997856 t= 0.49119999999997854 t= 0.4913999999999785 t= 0.4915999999999785 t= 0.4917999999999785 t= 0.49199999999997845 t= 0.49219999999997843 t= 0.4923999999999784 t= 0.4925999999999784 t= 0.49279999999997837 t= 0.49299999999997834 t= 0.4931999999999783 t= 0.4933999999999783 t= 0.4935999999999783 t= 0.49379999999997826 t= 0.49399999999997823 t= 0.4941999999999782 t= 0.4943999999999782 t= 0.49459999999997817 t= 0.49479999999997815 t= 0.4949999999999781 t= 0.4951999999999781 t= 0.4953999999999781 t= 0.49559999999997806 t= 0.49579999999997804 t= 0.495999999999978 t= 0.496199999999978 t= 0.49639999999997797 t= 0.49659999999997795 t= 0.4967999999999779 t= 0.4969999999999779 t= 0.4971999999999779 t= 0.49739999999997786 t= 0.49759999999997784 t= 0.4977999999999778 t= 0.4979999999999778 t= 0.49819999999997777 t= 0.49839999999997775 t= 0.4985999999999777 t= 0.4987999999999777 t= 0.4989999999999777 t= 0.49919999999997766 t= 0.49939999999997764 t= 0.4995999999999776 t= 0.4997999999999776 t= 0.4999999999999776 t= 0.5001999999999776 t= 0.5003999999999775 t= 0.5005999999999775 t= 0.5007999999999775 t= 0.5009999999999775 t= 0.5011999999999774 t= 0.5013999999999774 t= 0.5015999999999774 t= 0.5017999999999774 t= 0.5019999999999774 t= 0.5021999999999773 t= 0.5023999999999773 t= 0.5025999999999773 t= 0.5027999999999773 t= 0.5029999999999772 t= 0.5031999999999772 t= 0.5033999999999772 t= 0.5035999999999772 t= 0.5037999999999772 t= 0.5039999999999771 t= 0.5041999999999771 t= 0.5043999999999771 t= 0.5045999999999771 t= 0.504799999999977 t= 0.504999999999977 t= 0.505199999999977 t= 0.505399999999977 t= 0.505599999999977 t= 0.5057999999999769 t= 0.5059999999999769 t= 0.5061999999999769 t= 0.5063999999999769 t= 0.5065999999999768 t= 0.5067999999999768 t= 0.5069999999999768 t= 0.5071999999999768 t= 0.5073999999999768 t= 0.5075999999999767 t= 0.5077999999999767 t= 0.5079999999999767 t= 0.5081999999999767 t= 0.5083999999999766 t= 0.5085999999999766 t= 0.5087999999999766 t= 0.5089999999999766 t= 0.5091999999999766 t= 0.5093999999999765 t= 0.5095999999999765 t= 0.5097999999999765 t= 0.5099999999999765 t= 0.5101999999999765 t= 0.5103999999999764 t= 0.5105999999999764 t= 0.5107999999999764 t= 0.5109999999999764 t= 0.5111999999999763 t= 0.5113999999999763 t= 0.5115999999999763 t= 0.5117999999999763 t= 0.5119999999999763 t= 0.5121999999999762 t= 0.5123999999999762 t= 0.5125999999999762 t= 0.5127999999999762 t= 0.5129999999999761 t= 0.5131999999999761 t= 0.5133999999999761 t= 0.5135999999999761 t= 0.513799999999976 t= 0.513999999999976 t= 0.514199999999976 t= 0.514399999999976 t= 0.514599999999976 t= 0.5147999999999759 t= 0.5149999999999759 t= 0.5151999999999759 t= 0.5153999999999759 t= 0.5155999999999759 t= 0.5157999999999758 t= 0.5159999999999758 t= 0.5161999999999758 t= 0.5163999999999758 t= 0.5165999999999757 t= 0.5167999999999757 t= 0.5169999999999757 t= 0.5171999999999757 t= 0.5173999999999757 t= 0.5175999999999756 t= 0.5177999999999756 t= 0.5179999999999756 t= 0.5181999999999756 t= 0.5183999999999755 t= 0.5185999999999755 t= 0.5187999999999755 t= 0.5189999999999755 t= 0.5191999999999755 t= 0.5193999999999754 t= 0.5195999999999754 t= 0.5197999999999754 t= 0.5199999999999754 t= 0.5201999999999753 t= 0.5203999999999753 t= 0.5205999999999753 t= 0.5207999999999753 t= 0.5209999999999753 t= 0.5211999999999752 t= 0.5213999999999752 t= 0.5215999999999752 t= 0.5217999999999752 t= 0.5219999999999752 t= 0.5221999999999751 t= 0.5223999999999751 t= 0.5225999999999751 t= 0.5227999999999751 t= 0.522999999999975 t= 0.523199999999975 t= 0.523399999999975 t= 0.523599999999975 t= 0.523799999999975 t= 0.5239999999999749 t= 0.5241999999999749 t= 0.5243999999999749 t= 0.5245999999999749 t= 0.5247999999999748 t= 0.5249999999999748 t= 0.5251999999999748 t= 0.5253999999999748 t= 0.5255999999999748 t= 0.5257999999999747 t= 0.5259999999999747 t= 0.5261999999999747 t= 0.5263999999999747 t= 0.5265999999999746 t= 0.5267999999999746 t= 0.5269999999999746 t= 0.5271999999999746 t= 0.5273999999999746 t= 0.5275999999999745 t= 0.5277999999999745 t= 0.5279999999999745 t= 0.5281999999999745 t= 0.5283999999999744 t= 0.5285999999999744 t= 0.5287999999999744 t= 0.5289999999999744 t= 0.5291999999999744 t= 0.5293999999999743 t= 0.5295999999999743 t= 0.5297999999999743 t= 0.5299999999999743 t= 0.5301999999999742 t= 0.5303999999999742 t= 0.5305999999999742 t= 0.5307999999999742 t= 0.5309999999999742 t= 0.5311999999999741 t= 0.5313999999999741 t= 0.5315999999999741 t= 0.5317999999999741 t= 0.531999999999974 t= 0.532199999999974 t= 0.532399999999974 t= 0.532599999999974 t= 0.532799999999974 t= 0.5329999999999739 t= 0.5331999999999739 t= 0.5333999999999739 t= 0.5335999999999739 t= 0.5337999999999739 t= 0.5339999999999738 t= 0.5341999999999738 t= 0.5343999999999738 t= 0.5345999999999738 t= 0.5347999999999737 t= 0.5349999999999737 t= 0.5351999999999737 t= 0.5353999999999737 t= 0.5355999999999737 t= 0.5357999999999736 t= 0.5359999999999736 t= 0.5361999999999736 t= 0.5363999999999736 t= 0.5365999999999735 t= 0.5367999999999735 t= 0.5369999999999735 t= 0.5371999999999735 t= 0.5373999999999735 t= 0.5375999999999734 t= 0.5377999999999734 t= 0.5379999999999734 t= 0.5381999999999734 t= 0.5383999999999733 t= 0.5385999999999733 t= 0.5387999999999733 t= 0.5389999999999733 t= 0.5391999999999733 t= 0.5393999999999732 t= 0.5395999999999732 t= 0.5397999999999732 t= 0.5399999999999732 t= 0.5401999999999731 t= 0.5403999999999731 t= 0.5405999999999731 t= 0.5407999999999731 t= 0.5409999999999731 t= 0.541199999999973 t= 0.541399999999973 t= 0.541599999999973 t= 0.541799999999973 t= 0.541999999999973 t= 0.5421999999999729 t= 0.5423999999999729 t= 0.5425999999999729 t= 0.5427999999999729 t= 0.5429999999999728 t= 0.5431999999999728 t= 0.5433999999999728 t= 0.5435999999999728 t= 0.5437999999999727 t= 0.5439999999999727 t= 0.5441999999999727 t= 0.5443999999999727 t= 0.5445999999999727 t= 0.5447999999999726 t= 0.5449999999999726 t= 0.5451999999999726 t= 0.5453999999999726 t= 0.5455999999999726 t= 0.5457999999999725 t= 0.5459999999999725 t= 0.5461999999999725 t= 0.5463999999999725 t= 0.5465999999999724 t= 0.5467999999999724 t= 0.5469999999999724 t= 0.5471999999999724 t= 0.5473999999999724 t= 0.5475999999999723 t= 0.5477999999999723 t= 0.5479999999999723 t= 0.5481999999999723 t= 0.5483999999999722 t= 0.5485999999999722 t= 0.5487999999999722 t= 0.5489999999999722 t= 0.5491999999999722 t= 0.5493999999999721 t= 0.5495999999999721 t= 0.5497999999999721 t= 0.5499999999999721 t= 0.550199999999972 t= 0.550399999999972 t= 0.550599999999972 t= 0.550799999999972 t= 0.550999999999972 t= 0.5511999999999719 t= 0.5513999999999719 t= 0.5515999999999719 t= 0.5517999999999719 t= 0.5519999999999718 t= 0.5521999999999718 t= 0.5523999999999718 t= 0.5525999999999718 t= 0.5527999999999718 t= 0.5529999999999717 t= 0.5531999999999717 t= 0.5533999999999717 t= 0.5535999999999717 t= 0.5537999999999716 t= 0.5539999999999716 t= 0.5541999999999716 t= 0.5543999999999716 t= 0.5545999999999716 t= 0.5547999999999715 t= 0.5549999999999715 t= 0.5551999999999715 t= 0.5553999999999715 t= 0.5555999999999715 t= 0.5557999999999714 t= 0.5559999999999714 t= 0.5561999999999714 t= 0.5563999999999714 t= 0.5565999999999713 t= 0.5567999999999713 t= 0.5569999999999713 t= 0.5571999999999713 t= 0.5573999999999713 t= 0.5575999999999712 t= 0.5577999999999712 t= 0.5579999999999712 t= 0.5581999999999712 t= 0.5583999999999711 t= 0.5585999999999711 t= 0.5587999999999711 t= 0.5589999999999711 t= 0.559199999999971 t= 0.559399999999971 t= 0.559599999999971 t= 0.559799999999971 t= 0.559999999999971 t= 0.5601999999999709 t= 0.5603999999999709 t= 0.5605999999999709 t= 0.5607999999999709 t= 0.5609999999999709 t= 0.5611999999999708 t= 0.5613999999999708 t= 0.5615999999999708 t= 0.5617999999999708 t= 0.5619999999999707 t= 0.5621999999999707 t= 0.5623999999999707 t= 0.5625999999999707 t= 0.5627999999999707 t= 0.5629999999999706 t= 0.5631999999999706 t= 0.5633999999999706 t= 0.5635999999999706 t= 0.5637999999999705 t= 0.5639999999999705 t= 0.5641999999999705 t= 0.5643999999999705 t= 0.5645999999999705 t= 0.5647999999999704 t= 0.5649999999999704 t= 0.5651999999999704 t= 0.5653999999999704 t= 0.5655999999999703 t= 0.5657999999999703 t= 0.5659999999999703 t= 0.5661999999999703 t= 0.5663999999999703 t= 0.5665999999999702 t= 0.5667999999999702 t= 0.5669999999999702 t= 0.5671999999999702 t= 0.5673999999999702 t= 0.5675999999999701 t= 0.5677999999999701 t= 0.5679999999999701 t= 0.5681999999999701 t= 0.56839999999997 t= 0.56859999999997
</pre>
end{sphinxVerbatim}
t= 0.56879999999997 t= 0.56899999999997 t= 0.56919999999997 t= 0.5693999999999699 t= 0.5695999999999699 t= 0.5697999999999699 t= 0.5699999999999699 t= 0.5701999999999698 t= 0.5703999999999698 t= 0.5705999999999698 t= 0.5707999999999698 t= 0.5709999999999698 t= 0.5711999999999697 t= 0.5713999999999697 t= 0.5715999999999697 t= 0.5717999999999697 t= 0.5719999999999696 t= 0.5721999999999696 t= 0.5723999999999696 t= 0.5725999999999696 t= 0.5727999999999696 t= 0.5729999999999695 t= 0.5731999999999695 t= 0.5733999999999695 t= 0.5735999999999695 t= 0.5737999999999694 t= 0.5739999999999694 t= 0.5741999999999694 t= 0.5743999999999694 t= 0.5745999999999694 t= 0.5747999999999693 t= 0.5749999999999693 t= 0.5751999999999693 t= 0.5753999999999693 t= 0.5755999999999692 t= 0.5757999999999692 t= 0.5759999999999692 t= 0.5761999999999692 t= 0.5763999999999692 t= 0.5765999999999691 t= 0.5767999999999691 t= 0.5769999999999691 t= 0.5771999999999691 t= 0.577399999999969 t= 0.577599999999969 t= 0.577799999999969 t= 0.577999999999969 t= 0.578199999999969 t= 0.5783999999999689 t= 0.5785999999999689 t= 0.5787999999999689 t= 0.5789999999999689 t= 0.5791999999999689 t= 0.5793999999999688 t= 0.5795999999999688 t= 0.5797999999999688 t= 0.5799999999999688 t= 0.5801999999999687 t= 0.5803999999999687 t= 0.5805999999999687 t= 0.5807999999999687 t= 0.5809999999999687 t= 0.5811999999999686 t= 0.5813999999999686 t= 0.5815999999999686 t= 0.5817999999999686 t= 0.5819999999999685 t= 0.5821999999999685 t= 0.5823999999999685 t= 0.5825999999999685 t= 0.5827999999999685 t= 0.5829999999999684 t= 0.5831999999999684 t= 0.5833999999999684 t= 0.5835999999999684 t= 0.5837999999999683 t= 0.5839999999999683 t= 0.5841999999999683 t= 0.5843999999999683 t= 0.5845999999999683 t= 0.5847999999999682 t= 0.5849999999999682 t= 0.5851999999999682 t= 0.5853999999999682 t= 0.5855999999999681 t= 0.5857999999999681 t= 0.5859999999999681 t= 0.5861999999999681 t= 0.5863999999999681 t= 0.586599999999968 t= 0.586799999999968 t= 0.586999999999968 t= 0.587199999999968 t= 0.587399999999968 t= 0.5875999999999679 t= 0.5877999999999679 t= 0.5879999999999679 t= 0.5881999999999679 t= 0.5883999999999678 t= 0.5885999999999678 t= 0.5887999999999678 t= 0.5889999999999678 t= 0.5891999999999677 t= 0.5893999999999677 t= 0.5895999999999677 t= 0.5897999999999677 t= 0.5899999999999677 t= 0.5901999999999676 t= 0.5903999999999676 t= 0.5905999999999676 t= 0.5907999999999676 t= 0.5909999999999676 t= 0.5911999999999675 t= 0.5913999999999675 t= 0.5915999999999675 t= 0.5917999999999675 t= 0.5919999999999674 t= 0.5921999999999674 t= 0.5923999999999674 t= 0.5925999999999674 t= 0.5927999999999674 t= 0.5929999999999673 t= 0.5931999999999673 t= 0.5933999999999673 t= 0.5935999999999673 t= 0.5937999999999672 t= 0.5939999999999672 t= 0.5941999999999672 t= 0.5943999999999672 t= 0.5945999999999672 t= 0.5947999999999671 t= 0.5949999999999671 t= 0.5951999999999671 t= 0.5953999999999671 t= 0.595599999999967 t= 0.595799999999967 t= 0.595999999999967 t= 0.596199999999967 t= 0.596399999999967 t= 0.5965999999999669 t= 0.5967999999999669 t= 0.5969999999999669 t= 0.5971999999999669 t= 0.5973999999999668 t= 0.5975999999999668 t= 0.5977999999999668 t= 0.5979999999999668 t= 0.5981999999999668 t= 0.5983999999999667 t= 0.5985999999999667 t= 0.5987999999999667 t= 0.5989999999999667 t= 0.5991999999999666 t= 0.5993999999999666 t= 0.5995999999999666 t= 0.5997999999999666 t= 0.5999999999999666CPU times: user 9.88 s, sys: 64.9 ms, total: 9.95 s
Wall time: 9.91 s </pre>
Wall time: 9.91 s end{sphinxVerbatim}
Wall time: 9.91 s
Draw(gfu_t,mesh,interpolate_multidim=True,animate=True,
min=0, max=0.2, autoscale=False, deformation=True, height = "60vh")
Skeleton formulation (cf. unit 2.8)¶
So far we considered the DG formulation with integrals on the boundary of each element. Instead one could formulate the problem in terms of facet integrals where every facet appears only once.
Then, the corresponding formulation is:
Find \(u: [0,T] \to V_h := \bigoplus_{T\in\mathcal{T}_h} \mathcal{P}^k(T)\) so that
Here \(\mathcal{F}^{inner}\) is the set of interior facets and \(\mathcal{F}^{bound}\) is the set of boundary facets.
integral types:¶
The facet integrals are divided into inner facets and boundary facets. To obtain these integrals we combine the DifferentialSymbol dx or ds with skeleton=True.
# or:
dskel_inflow = ds(skeleton=True, definedon=mesh.Boundaries("left|bottom"))
dskel_outflow = ds(skeleton=True, definedon=mesh.Boundaries("right|top"))
Skeleton formulation of \(C\)¶
c = BilinearForm(VT,nonassemble=True)
c += -b * grad(v) * u * dx
c += upw_flux * (v-v.Other()) * dskel_inner
c += b*n * IfPos(b*n,u,ubnd) * v * dskel_bound
#alternatively (if you know in/out beforehand):
#c += b*n * ubnd * v * dskel_inflow
#c += b*n * u * v * dskel_outflow
Next run¶
%%time
gfu_t = SolveAndVisualize(c.mat)
#Draw(gfu_t,mesh,interpolate_multidim=True,animate=True,
# min=0, max=0.2, autoscale=False, deformation=True)
- more-to-come:
t= 0.0002 t= 0.0004 t= 0.0006000000000000001 t= 0.0008 t= 0.001 t= 0.0012000000000000001 t= 0.0014000000000000002 t= 0.0016000000000000003 t= 0.0018000000000000004 t= 0.0020000000000000005 t= 0.0022000000000000006 t= 0.0024000000000000007 t= 0.0026000000000000007 t= 0.002800000000000001 t= 0.003000000000000001 t= 0.003200000000000001 t= 0.003400000000000001 t= 0.003600000000000001 t= 0.0038000000000000013 t= 0.004000000000000001 t= 0.004200000000000001 t= 0.0044 t= 0.0046 t= 0.0048 t= 0.004999999999999999 t= 0.005199999999999999 t= 0.0053999999999999986 t= 0.005599999999999998 t= 0.005799999999999998 t= 0.0059999999999999975 t= 0.006199999999999997 t= 0.006399999999999997 t= 0.0065999999999999965 t= 0.006799999999999996 t= 0.006999999999999996 t= 0.0071999999999999955 t= 0.007399999999999995 t= 0.007599999999999995 t= 0.0077999999999999944 t= 0.007999999999999995 t= 0.008199999999999995 t= 0.008399999999999996 t= 0.008599999999999997 t= 0.008799999999999997 t= 0.008999999999999998 t= 0.009199999999999998 t= 0.009399999999999999 t= 0.0096 t= 0.0098 t= 0.01 t= 0.0102 t= 0.010400000000000001 t= 0.010600000000000002 t= 0.010800000000000002 t= 0.011000000000000003 t= 0.011200000000000003 t= 0.011400000000000004 t= 0.011600000000000004 t= 0.011800000000000005 t= 0.012000000000000005 t= 0.012200000000000006 t= 0.012400000000000007 t= 0.012600000000000007 t= 0.012800000000000008 t= 0.013000000000000008 t= 0.013200000000000009 t= 0.013400000000000009 t= 0.01360000000000001 t= 0.01380000000000001 t= 0.01400000000000001 t= 0.014200000000000011 t= 0.014400000000000012 t= 0.014600000000000012 t= 0.014800000000000013 t= 0.015000000000000013 t= 0.015200000000000014 t= 0.015400000000000014 t= 0.015600000000000015 t= 0.015800000000000015 t= 0.016000000000000014 t= 0.016200000000000013 t= 0.016400000000000012 t= 0.01660000000000001 t= 0.01680000000000001 t= 0.017000000000000008 t= 0.017200000000000007 t= 0.017400000000000006 t= 0.017600000000000005 t= 0.017800000000000003 t= 0.018000000000000002 t= 0.0182 t= 0.0184 t= 0.0186 t= 0.018799999999999997 t= 0.018999999999999996 t= 0.019199999999999995 t= 0.019399999999999994
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.019599999999999992 t= 0.01979999999999999 t= 0.01999999999999999 t= 0.02019999999999999 t= 0.020399999999999988 t= 0.020599999999999986 t= 0.020799999999999985 t= 0.020999999999999984 t= 0.021199999999999983 t= 0.02139999999999998 t= 0.02159999999999998 t= 0.02179999999999998 t= 0.021999999999999978 t= 0.022199999999999977 t= 0.022399999999999975 t= 0.022599999999999974 t= 0.022799999999999973 t= 0.022999999999999972 t= 0.02319999999999997 t= 0.02339999999999997 t= 0.023599999999999968 t= 0.023799999999999967 t= 0.023999999999999966 t= 0.024199999999999965 t= 0.024399999999999963 t= 0.024599999999999962 t= 0.02479999999999996 t= 0.02499999999999996 t= 0.02519999999999996 t= 0.025399999999999957 t= 0.025599999999999956 t= 0.025799999999999955 t= 0.025999999999999954 t= 0.026199999999999952 t= 0.02639999999999995 t= 0.02659999999999995 t= 0.02679999999999995 t= 0.026999999999999948 t= 0.027199999999999946 t= 0.027399999999999945 t= 0.027599999999999944 t= 0.027799999999999943 t= 0.02799999999999994 t= 0.02819999999999994 t= 0.02839999999999994 t= 0.028599999999999938 t= 0.028799999999999937 t= 0.028999999999999936 t= 0.029199999999999934 t= 0.029399999999999933 t= 0.029599999999999932 t= 0.02979999999999993 t= 0.02999999999999993 t= 0.03019999999999993 t= 0.030399999999999927 t= 0.030599999999999926 t= 0.030799999999999925 t= 0.030999999999999923 t= 0.031199999999999922 t= 0.03139999999999992 t= 0.03159999999999992 t= 0.03179999999999992 t= 0.03199999999999992 t= 0.032199999999999916 t= 0.032399999999999915 t= 0.032599999999999914 t= 0.03279999999999991 t= 0.03299999999999991 t= 0.03319999999999991 t= 0.03339999999999991 t= 0.03359999999999991 t= 0.033799999999999907 t= 0.033999999999999905 t= 0.034199999999999904 t= 0.0343999999999999 t= 0.0345999999999999 t= 0.0347999999999999 t= 0.0349999999999999 t= 0.0351999999999999 t= 0.0353999999999999 t= 0.035599999999999896 t= 0.035799999999999894 t= 0.03599999999999989 t= 0.03619999999999989 t= 0.03639999999999989 t= 0.03659999999999989 t= 0.03679999999999989 t= 0.03699999999999989 t= 0.037199999999999886 t= 0.037399999999999885 t= 0.037599999999999884 t= 0.03779999999999988 t= 0.03799999999999988 t= 0.03819999999999988 t= 0.03839999999999988 t= 0.03859999999999988 t= 0.038799999999999876 t= 0.038999999999999875 t= 0.039199999999999874 t= 0.03939999999999987 t= 0.03959999999999987 t= 0.03979999999999987 t= 0.03999999999999987 t= 0.04019999999999987 t= 0.04039999999999987 t= 0.040599999999999865 t= 0.040799999999999864 t= 0.04099999999999986 t= 0.04119999999999986 t= 0.04139999999999986 t= 0.04159999999999986 t= 0.04179999999999986 t= 0.04199999999999986 t= 0.042199999999999856 t= 0.042399999999999854 t= 0.04259999999999985 t= 0.04279999999999985 t= 0.04299999999999985 t= 0.04319999999999985 t= 0.04339999999999985 t= 0.04359999999999985 t= 0.043799999999999846 t= 0.043999999999999845 t= 0.044199999999999844 t= 0.04439999999999984 t= 0.04459999999999984 t= 0.04479999999999984 t= 0.04499999999999984 t= 0.04519999999999984 t= 0.045399999999999836 t= 0.045599999999999835 t= 0.045799999999999834 t= 0.04599999999999983 t= 0.04619999999999983 t= 0.04639999999999983 t= 0.04659999999999983 t= 0.04679999999999983 t= 0.04699999999999983 t= 0.047199999999999825 t= 0.047399999999999824 t= 0.04759999999999982 t= 0.04779999999999982 t= 0.04799999999999982 t= 0.04819999999999982 t= 0.04839999999999982 t= 0.04859999999999982 t= 0.048799999999999816 t= 0.048999999999999815 t= 0.04919999999999981 t= 0.04939999999999981 t= 0.04959999999999981 t= 0.04979999999999981 t= 0.04999999999999981 t= 0.05019999999999981 t= 0.050399999999999806 t= 0.050599999999999805 t= 0.050799999999999804 t= 0.0509999999999998 t= 0.0511999999999998 t= 0.0513999999999998 t= 0.0515999999999998 t= 0.0517999999999998 t= 0.051999999999999796 t= 0.052199999999999795 t= 0.052399999999999794 t= 0.05259999999999979 t= 0.05279999999999979 t= 0.05299999999999979 t= 0.05319999999999979 t= 0.05339999999999979 t= 0.05359999999999979 t= 0.053799999999999785 t= 0.053999999999999784 t= 0.05419999999999978 t= 0.05439999999999978 t= 0.05459999999999978 t= 0.05479999999999978 t= 0.05499999999999978 t= 0.05519999999999978 t= 0.055399999999999776 t= 0.055599999999999775 t= 0.05579999999999977 t= 0.05599999999999977 t= 0.05619999999999977 t= 0.05639999999999977 t= 0.05659999999999977 t= 0.05679999999999977 t= 0.056999999999999766 t= 0.057199999999999765 t= 0.057399999999999764 t= 0.05759999999999976 t= 0.05779999999999976 t= 0.05799999999999976 t= 0.05819999999999976 t= 0.05839999999999976 t= 0.058599999999999756 t= 0.058799999999999755 t= 0.058999999999999754 t= 0.05919999999999975 t= 0.05939999999999975 t= 0.05959999999999975 t= 0.05979999999999975 t= 0.05999999999999975 t= 0.06019999999999975 t= 0.060399999999999746 t= 0.060599999999999744 t= 0.06079999999999974 t= 0.06099999999999974 t= 0.06119999999999974 t= 0.06139999999999974 t= 0.06159999999999974 t= 0.06179999999999974 t= 0.061999999999999736 t= 0.062199999999999735 t= 0.06239999999999973 t= 0.06259999999999974 t= 0.06279999999999974 t= 0.06299999999999975 t= 0.06319999999999976 t= 0.06339999999999976 t= 0.06359999999999977 t= 0.06379999999999977 t= 0.06399999999999978 t= 0.06419999999999979 t= 0.06439999999999979 t= 0.0645999999999998 t= 0.0647999999999998 t= 0.06499999999999981 t= 0.06519999999999981 t= 0.06539999999999982 t= 0.06559999999999983 t= 0.06579999999999983 t= 0.06599999999999984 t= 0.06619999999999984 t= 0.06639999999999985 t= 0.06659999999999985 t= 0.06679999999999986 t= 0.06699999999999987 t= 0.06719999999999987 t= 0.06739999999999988 t= 0.06759999999999988 t= 0.06779999999999989 t= 0.0679999999999999 t= 0.0681999999999999 t= 0.0683999999999999 t= 0.06859999999999991 t= 0.06879999999999992 t= 0.06899999999999992 t= 0.06919999999999993 t= 0.06939999999999993 t= 0.06959999999999994 t= 0.06979999999999995 t= 0.06999999999999995 t= 0.07019999999999996 t= 0.07039999999999996 t= 0.07059999999999997 t= 0.07079999999999997 t= 0.07099999999999998 t= 0.07119999999999999 t= 0.07139999999999999 t= 0.0716 t= 0.0718 t= 0.07200000000000001 t= 0.07220000000000001 t= 0.07240000000000002 t= 0.07260000000000003 t= 0.07280000000000003 t= 0.07300000000000004 t= 0.07320000000000004 t= 0.07340000000000005 t= 0.07360000000000005 t= 0.07380000000000006 t= 0.07400000000000007 t= 0.07420000000000007 t= 0.07440000000000008 t= 0.07460000000000008 t= 0.07480000000000009 t= 0.0750000000000001 t= 0.0752000000000001 t= 0.0754000000000001 t= 0.07560000000000011 t= 0.07580000000000012 t= 0.07600000000000012 t= 0.07620000000000013 t= 0.07640000000000013 t= 0.07660000000000014 t= 0.07680000000000015 t= 0.07700000000000015 t= 0.07720000000000016 t= 0.07740000000000016 t= 0.07760000000000017 t= 0.07780000000000017 t= 0.07800000000000018 t= 0.07820000000000019 t= 0.07840000000000019 t= 0.0786000000000002 t= 0.0788000000000002 t= 0.07900000000000021 t= 0.07920000000000021 t= 0.07940000000000022 t= 0.07960000000000023 t= 0.07980000000000023 t= 0.08000000000000024 t= 0.08020000000000024 t= 0.08040000000000025 t= 0.08060000000000025 t= 0.08080000000000026 t= 0.08100000000000027 t= 0.08120000000000027 t= 0.08140000000000028 t= 0.08160000000000028 t= 0.08180000000000029 t= 0.0820000000000003 t= 0.0822000000000003 t= 0.0824000000000003 t= 0.08260000000000031 t= 0.08280000000000032 t= 0.08300000000000032 t= 0.08320000000000033 t= 0.08340000000000033 t= 0.08360000000000034 t= 0.08380000000000035 t= 0.08400000000000035 t= 0.08420000000000036 t= 0.08440000000000036 t= 0.08460000000000037 t= 0.08480000000000038 t= 0.08500000000000038 t= 0.08520000000000039 t= 0.08540000000000039 t= 0.0856000000000004 t= 0.0858000000000004 t= 0.08600000000000041 t= 0.08620000000000042 t= 0.08640000000000042 t= 0.08660000000000043 t= 0.08680000000000043 t= 0.08700000000000044 t= 0.08720000000000044 t= 0.08740000000000045 t= 0.08760000000000046 t= 0.08780000000000046 t= 0.08800000000000047 t= 0.08820000000000047 t= 0.08840000000000048 t= 0.08860000000000048 t= 0.08880000000000049 t= 0.0890000000000005 t= 0.0892000000000005 t= 0.0894000000000005 t= 0.08960000000000051 t= 0.08980000000000052 t= 0.09000000000000052 t= 0.09020000000000053 t= 0.09040000000000054 t= 0.09060000000000054 t= 0.09080000000000055 t= 0.09100000000000055 t= 0.09120000000000056 t= 0.09140000000000056 t= 0.09160000000000057 t= 0.09180000000000058 t= 0.09200000000000058 t= 0.09220000000000059 t= 0.09240000000000059 t= 0.0926000000000006 t= 0.0928000000000006 t= 0.09300000000000061 t= 0.09320000000000062 t= 0.09340000000000062 t= 0.09360000000000063 t= 0.09380000000000063 t= 0.09400000000000064 t= 0.09420000000000064 t= 0.09440000000000065 t= 0.09460000000000066 t= 0.09480000000000066 t= 0.09500000000000067 t= 0.09520000000000067 t= 0.09540000000000068 t= 0.09560000000000068 t= 0.09580000000000069 t= 0.0960000000000007 t= 0.0962000000000007 t= 0.09640000000000071 t= 0.09660000000000071 t= 0.09680000000000072 t= 0.09700000000000072 t= 0.09720000000000073 t= 0.09740000000000074 t= 0.09760000000000074 t= 0.09780000000000075 t= 0.09800000000000075 t= 0.09820000000000076 t= 0.09840000000000076 t= 0.09860000000000077 t= 0.09880000000000078 t= 0.09900000000000078 t= 0.09920000000000079 t= 0.0994000000000008 t= 0.0996000000000008 t= 0.0998000000000008 t= 0.10000000000000081 t= 0.10020000000000082 t= 0.10040000000000082 t= 0.10060000000000083 t= 0.10080000000000083 t= 0.10100000000000084 t= 0.10120000000000084 t= 0.10140000000000085 t= 0.10160000000000086 t= 0.10180000000000086 t= 0.10200000000000087 t= 0.10220000000000087 t= 0.10240000000000088 t= 0.10260000000000088 t= 0.10280000000000089 t= 0.1030000000000009 t= 0.1032000000000009 t= 0.10340000000000091 t= 0.10360000000000091 t= 0.10380000000000092 t= 0.10400000000000093 t= 0.10420000000000093 t= 0.10440000000000094 t= 0.10460000000000094 t= 0.10480000000000095 t= 0.10500000000000095 t= 0.10520000000000096 t= 0.10540000000000097 t= 0.10560000000000097 t= 0.10580000000000098 t= 0.10600000000000098 t= 0.10620000000000099 t= 0.106400000000001 t= 0.106600000000001 t= 0.106800000000001 t= 0.10700000000000101 t= 0.10720000000000102 t= 0.10740000000000102 t= 0.10760000000000103 t= 0.10780000000000103 t= 0.10800000000000104 t= 0.10820000000000105 t= 0.10840000000000105 t= 0.10860000000000106 t= 0.10880000000000106 t= 0.10900000000000107 t= 0.10920000000000107 t= 0.10940000000000108 t= 0.10960000000000109 t= 0.10980000000000109 t= 0.1100000000000011 t= 0.1102000000000011 t= 0.11040000000000111 t= 0.11060000000000111 t= 0.11080000000000112 t= 0.11100000000000113 t= 0.11120000000000113 t= 0.11140000000000114 t= 0.11160000000000114 t= 0.11180000000000115 t= 0.11200000000000115 t= 0.11220000000000116 t= 0.11240000000000117 t= 0.11260000000000117 t= 0.11280000000000118 t= 0.11300000000000118 t= 0.11320000000000119 t= 0.1134000000000012 t= 0.1136000000000012 t= 0.1138000000000012 t= 0.11400000000000121 t= 0.11420000000000122 t= 0.11440000000000122 t= 0.11460000000000123 t= 0.11480000000000123 t= 0.11500000000000124 t= 0.11520000000000125 t= 0.11540000000000125 t= 0.11560000000000126 t= 0.11580000000000126 t= 0.11600000000000127 t= 0.11620000000000127 t= 0.11640000000000128 t= 0.11660000000000129 t= 0.11680000000000129 t= 0.1170000000000013 t= 0.1172000000000013 t= 0.11740000000000131 t= 0.11760000000000131 t= 0.11780000000000132 t= 0.11800000000000133 t= 0.11820000000000133 t= 0.11840000000000134 t= 0.11860000000000134 t= 0.11880000000000135 t= 0.11900000000000135 t= 0.11920000000000136 t= 0.11940000000000137 t= 0.11960000000000137 t= 0.11980000000000138 t= 0.12000000000000138 t= 0.12020000000000139 t= 0.1204000000000014 t= 0.1206000000000014 t= 0.1208000000000014 t= 0.12100000000000141 t= 0.12120000000000142 t= 0.12140000000000142 t= 0.12160000000000143 t= 0.12180000000000143 t= 0.12200000000000144 t= 0.12220000000000145 t= 0.12240000000000145 t= 0.12260000000000146 t= 0.12280000000000146 t= 0.12300000000000147 t= 0.12320000000000147 t= 0.12340000000000148 t= 0.12360000000000149 t= 0.12380000000000149 t= 0.1240000000000015 t= 0.1242000000000015 t= 0.12440000000000151 t= 0.12460000000000152 t= 0.12480000000000152 t= 0.12500000000000153 t= 0.12520000000000153 t= 0.12540000000000154 t= 0.12560000000000154 t= 0.12580000000000155 t= 0.12600000000000156 t= 0.12620000000000156 t= 0.12640000000000157 t= 0.12660000000000157 t= 0.12680000000000158 t= 0.12700000000000158 t= 0.1272000000000016 t= 0.1274000000000016 t= 0.1276000000000016 t= 0.1278000000000016 t= 0.1280000000000016 t= 0.12820000000000162 t= 0.12840000000000162 t= 0.12860000000000163 t= 0.12880000000000164 t= 0.12900000000000164 t= 0.12920000000000165 t= 0.12940000000000165 t= 0.12960000000000166 t= 0.12980000000000166 t= 0.13000000000000167 t= 0.13020000000000168 t= 0.13040000000000168 t= 0.1306000000000017 t= 0.1308000000000017 t= 0.1310000000000017 t= 0.1312000000000017 t= 0.1314000000000017 t= 0.13160000000000172 t= 0.13180000000000172 t= 0.13200000000000173 t= 0.13220000000000173 t= 0.13240000000000174 t= 0.13260000000000174 t= 0.13280000000000175 t= 0.13300000000000176 t= 0.13320000000000176 t= 0.13340000000000177 t= 0.13360000000000177 t= 0.13380000000000178 t= 0.13400000000000178 t= 0.1342000000000018 t= 0.1344000000000018 t= 0.1346000000000018 t= 0.1348000000000018 t= 0.1350000000000018 t= 0.13520000000000182 t= 0.13540000000000182 t= 0.13560000000000183 t= 0.13580000000000184 t= 0.13600000000000184 t= 0.13620000000000185 t= 0.13640000000000185 t= 0.13660000000000186 t= 0.13680000000000186 t= 0.13700000000000187 t= 0.13720000000000188 t= 0.13740000000000188 t= 0.1376000000000019 t= 0.1378000000000019 t= 0.1380000000000019 t= 0.1382000000000019 t= 0.1384000000000019 t= 0.13860000000000192 t= 0.13880000000000192 t= 0.13900000000000193 t= 0.13920000000000193 t= 0.13940000000000194 t= 0.13960000000000194 t= 0.13980000000000195 t= 0.14000000000000196 t= 0.14020000000000196 t= 0.14040000000000197 t= 0.14060000000000197 t= 0.14080000000000198 t= 0.14100000000000198 t= 0.141200000000002 t= 0.141400000000002 t= 0.141600000000002 t= 0.141800000000002 t= 0.142000000000002 t= 0.14220000000000202 t= 0.14240000000000202 t= 0.14260000000000203 t= 0.14280000000000204 t= 0.14300000000000204 t= 0.14320000000000205 t= 0.14340000000000205 t= 0.14360000000000206 t= 0.14380000000000207 t= 0.14400000000000207 t= 0.14420000000000208 t= 0.14440000000000208 t= 0.1446000000000021 t= 0.1448000000000021 t= 0.1450000000000021 t= 0.1452000000000021 t= 0.1454000000000021 t= 0.14560000000000212 t= 0.14580000000000212 t= 0.14600000000000213 t= 0.14620000000000213 t= 0.14640000000000214 t= 0.14660000000000215 t= 0.14680000000000215 t= 0.14700000000000216
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.14720000000000216 t= 0.14740000000000217 t= 0.14760000000000217 t= 0.14780000000000218 t= 0.14800000000000219 t= 0.1482000000000022 t= 0.1484000000000022 t= 0.1486000000000022 t= 0.1488000000000022 t= 0.14900000000000221 t= 0.14920000000000222 t= 0.14940000000000223 t= 0.14960000000000223 t= 0.14980000000000224 t= 0.15000000000000224 t= 0.15020000000000225 t= 0.15040000000000225 t= 0.15060000000000226 t= 0.15080000000000227 t= 0.15100000000000227 t= 0.15120000000000228 t= 0.15140000000000228 t= 0.1516000000000023 t= 0.1518000000000023 t= 0.1520000000000023 t= 0.1522000000000023 t= 0.1524000000000023 t= 0.15260000000000232 t= 0.15280000000000232 t= 0.15300000000000233 t= 0.15320000000000233 t= 0.15340000000000234 t= 0.15360000000000235 t= 0.15380000000000235 t= 0.15400000000000236 t= 0.15420000000000236 t= 0.15440000000000237 t= 0.15460000000000237 t= 0.15480000000000238 t= 0.15500000000000239 t= 0.1552000000000024 t= 0.1554000000000024 t= 0.1556000000000024 t= 0.1558000000000024 t= 0.15600000000000241 t= 0.15620000000000242 t= 0.15640000000000243 t= 0.15660000000000243 t= 0.15680000000000244 t= 0.15700000000000244 t= 0.15720000000000245 t= 0.15740000000000245 t= 0.15760000000000246 t= 0.15780000000000247 t= 0.15800000000000247 t= 0.15820000000000248 t= 0.15840000000000248 t= 0.1586000000000025 t= 0.1588000000000025 t= 0.1590000000000025 t= 0.1592000000000025 t= 0.1594000000000025 t= 0.15960000000000252 t= 0.15980000000000252 t= 0.16000000000000253 t= 0.16020000000000253 t= 0.16040000000000254 t= 0.16060000000000255 t= 0.16080000000000255 t= 0.16100000000000256 t= 0.16120000000000256 t= 0.16140000000000257 t= 0.16160000000000257 t= 0.16180000000000258 t= 0.1620000000000026 t= 0.1622000000000026 t= 0.1624000000000026 t= 0.1626000000000026 t= 0.1628000000000026 t= 0.16300000000000262 t= 0.16320000000000262 t= 0.16340000000000263 t= 0.16360000000000263 t= 0.16380000000000264 t= 0.16400000000000264 t= 0.16420000000000265 t= 0.16440000000000266 t= 0.16460000000000266 t= 0.16480000000000267 t= 0.16500000000000267 t= 0.16520000000000268 t= 0.16540000000000268 t= 0.1656000000000027 t= 0.1658000000000027 t= 0.1660000000000027 t= 0.1662000000000027 t= 0.1664000000000027 t= 0.16660000000000272 t= 0.16680000000000272 t= 0.16700000000000273 t= 0.16720000000000274 t= 0.16740000000000274 t= 0.16760000000000275 t= 0.16780000000000275 t= 0.16800000000000276 t= 0.16820000000000276 t= 0.16840000000000277 t= 0.16860000000000278 t= 0.16880000000000278 t= 0.1690000000000028 t= 0.1692000000000028 t= 0.1694000000000028 t= 0.1696000000000028 t= 0.1698000000000028 t= 0.17000000000000282 t= 0.17020000000000282 t= 0.17040000000000283 t= 0.17060000000000283 t= 0.17080000000000284 t= 0.17100000000000284 t= 0.17120000000000285 t= 0.17140000000000286 t= 0.17160000000000286 t= 0.17180000000000287 t= 0.17200000000000287 t= 0.17220000000000288 t= 0.17240000000000288 t= 0.1726000000000029 t= 0.1728000000000029 t= 0.1730000000000029 t= 0.1732000000000029 t= 0.1734000000000029 t= 0.17360000000000292 t= 0.17380000000000292 t= 0.17400000000000293 t= 0.17420000000000294 t= 0.17440000000000294 t= 0.17460000000000295 t= 0.17480000000000295 t= 0.17500000000000296 t= 0.17520000000000296 t= 0.17540000000000297 t= 0.17560000000000298 t= 0.17580000000000298 t= 0.176000000000003 t= 0.176200000000003 t= 0.176400000000003 t= 0.176600000000003 t= 0.176800000000003 t= 0.17700000000000302 t= 0.17720000000000302 t= 0.17740000000000303 t= 0.17760000000000303 t= 0.17780000000000304 t= 0.17800000000000304 t= 0.17820000000000305 t= 0.17840000000000306 t= 0.17860000000000306 t= 0.17880000000000307 t= 0.17900000000000307 t= 0.17920000000000308 t= 0.17940000000000308 t= 0.1796000000000031 t= 0.1798000000000031 t= 0.1800000000000031 t= 0.1802000000000031 t= 0.1804000000000031 t= 0.18060000000000312 t= 0.18080000000000312 t= 0.18100000000000313 t= 0.18120000000000314 t= 0.18140000000000314 t= 0.18160000000000315 t= 0.18180000000000315 t= 0.18200000000000316 t= 0.18220000000000316 t= 0.18240000000000317 t= 0.18260000000000318 t= 0.18280000000000318 t= 0.1830000000000032 t= 0.1832000000000032 t= 0.1834000000000032 t= 0.1836000000000032 t= 0.1838000000000032 t= 0.18400000000000322 t= 0.18420000000000322 t= 0.18440000000000323 t= 0.18460000000000323 t= 0.18480000000000324 t= 0.18500000000000325 t= 0.18520000000000325 t= 0.18540000000000326 t= 0.18560000000000326 t= 0.18580000000000327 t= 0.18600000000000327 t= 0.18620000000000328 t= 0.18640000000000329 t= 0.1866000000000033 t= 0.1868000000000033 t= 0.1870000000000033 t= 0.1872000000000033 t= 0.18740000000000331 t= 0.18760000000000332 t= 0.18780000000000333 t= 0.18800000000000333 t= 0.18820000000000334 t= 0.18840000000000334 t= 0.18860000000000335 t= 0.18880000000000335 t= 0.18900000000000336 t= 0.18920000000000337 t= 0.18940000000000337 t= 0.18960000000000338 t= 0.18980000000000338 t= 0.1900000000000034 t= 0.1902000000000034 t= 0.1904000000000034 t= 0.1906000000000034 t= 0.1908000000000034 t= 0.19100000000000342 t= 0.19120000000000342 t= 0.19140000000000343 t= 0.19160000000000343 t= 0.19180000000000344 t= 0.19200000000000345 t= 0.19220000000000345 t= 0.19240000000000346 t= 0.19260000000000346 t= 0.19280000000000347 t= 0.19300000000000347 t= 0.19320000000000348 t= 0.19340000000000349 t= 0.1936000000000035 t= 0.1938000000000035 t= 0.1940000000000035 t= 0.1942000000000035 t= 0.19440000000000351 t= 0.19460000000000352 t= 0.19480000000000353 t= 0.19500000000000353 t= 0.19520000000000354 t= 0.19540000000000354 t= 0.19560000000000355 t= 0.19580000000000355 t= 0.19600000000000356 t= 0.19620000000000357 t= 0.19640000000000357 t= 0.19660000000000358 t= 0.19680000000000358 t= 0.1970000000000036 t= 0.1972000000000036 t= 0.1974000000000036 t= 0.1976000000000036 t= 0.1978000000000036 t= 0.19800000000000362 t= 0.19820000000000362 t= 0.19840000000000363 t= 0.19860000000000363 t= 0.19880000000000364 t= 0.19900000000000365 t= 0.19920000000000365 t= 0.19940000000000366 t= 0.19960000000000366 t= 0.19980000000000367 t= 0.20000000000000367 t= 0.20020000000000368 t= 0.2004000000000037 t= 0.2006000000000037 t= 0.2008000000000037 t= 0.2010000000000037 t= 0.2012000000000037 t= 0.20140000000000371 t= 0.20160000000000372 t= 0.20180000000000373 t= 0.20200000000000373 t= 0.20220000000000374 t= 0.20240000000000374 t= 0.20260000000000375 t= 0.20280000000000376 t= 0.20300000000000376 t= 0.20320000000000377 t= 0.20340000000000377 t= 0.20360000000000378 t= 0.20380000000000378 t= 0.2040000000000038 t= 0.2042000000000038 t= 0.2044000000000038 t= 0.2046000000000038 t= 0.2048000000000038 t= 0.20500000000000382 t= 0.20520000000000382 t= 0.20540000000000383 t= 0.20560000000000384 t= 0.20580000000000384 t= 0.20600000000000385 t= 0.20620000000000385 t= 0.20640000000000386 t= 0.20660000000000386 t= 0.20680000000000387 t= 0.20700000000000388 t= 0.20720000000000388 t= 0.2074000000000039 t= 0.2076000000000039 t= 0.2078000000000039 t= 0.2080000000000039 t= 0.2082000000000039 t= 0.20840000000000392 t= 0.20860000000000392 t= 0.20880000000000393 t= 0.20900000000000393 t= 0.20920000000000394 t= 0.20940000000000394 t= 0.20960000000000395 t= 0.20980000000000396 t= 0.21000000000000396 t= 0.21020000000000397 t= 0.21040000000000397 t= 0.21060000000000398 t= 0.21080000000000398 t= 0.211000000000004 t= 0.211200000000004 t= 0.211400000000004 t= 0.211600000000004 t= 0.211800000000004 t= 0.21200000000000402 t= 0.21220000000000402 t= 0.21240000000000403 t= 0.21260000000000404 t= 0.21280000000000404 t= 0.21300000000000405 t= 0.21320000000000405 t= 0.21340000000000406 t= 0.21360000000000406 t= 0.21380000000000407 t= 0.21400000000000408 t= 0.21420000000000408 t= 0.2144000000000041 t= 0.2146000000000041 t= 0.2148000000000041 t= 0.2150000000000041 t= 0.2152000000000041 t= 0.21540000000000412 t= 0.21560000000000412 t= 0.21580000000000413 t= 0.21600000000000413 t= 0.21620000000000414 t= 0.21640000000000414 t= 0.21660000000000415 t= 0.21680000000000416 t= 0.21700000000000416 t= 0.21720000000000417 t= 0.21740000000000417 t= 0.21760000000000418 t= 0.21780000000000418 t= 0.2180000000000042 t= 0.2182000000000042 t= 0.2184000000000042 t= 0.2186000000000042 t= 0.2188000000000042 t= 0.21900000000000422 t= 0.21920000000000422 t= 0.21940000000000423 t= 0.21960000000000424 t= 0.21980000000000424 t= 0.22000000000000425 t= 0.22020000000000425 t= 0.22040000000000426 t= 0.22060000000000426 t= 0.22080000000000427 t= 0.22100000000000428 t= 0.22120000000000428 t= 0.2214000000000043 t= 0.2216000000000043 t= 0.2218000000000043 t= 0.2220000000000043 t= 0.2222000000000043 t= 0.22240000000000432 t= 0.22260000000000432 t= 0.22280000000000433 t= 0.22300000000000433 t= 0.22320000000000434 t= 0.22340000000000435 t= 0.22360000000000435 t= 0.22380000000000436 t= 0.22400000000000436 t= 0.22420000000000437 t= 0.22440000000000437 t= 0.22460000000000438 t= 0.22480000000000439 t= 0.2250000000000044 t= 0.2252000000000044 t= 0.2254000000000044 t= 0.2256000000000044 t= 0.2258000000000044 t= 0.22600000000000442 t= 0.22620000000000443 t= 0.22640000000000443 t= 0.22660000000000444 t= 0.22680000000000444 t= 0.22700000000000445 t= 0.22720000000000445 t= 0.22740000000000446 t= 0.22760000000000447 t= 0.22780000000000447 t= 0.22800000000000448 t= 0.22820000000000448 t= 0.2284000000000045 t= 0.2286000000000045 t= 0.2288000000000045 t= 0.2290000000000045 t= 0.2292000000000045 t= 0.22940000000000452 t= 0.22960000000000452 t= 0.22980000000000453 t= 0.23000000000000453 t= 0.23020000000000454 t= 0.23040000000000455 t= 0.23060000000000455 t= 0.23080000000000456 t= 0.23100000000000456 t= 0.23120000000000457 t= 0.23140000000000457 t= 0.23160000000000458 t= 0.23180000000000459 t= 0.2320000000000046 t= 0.2322000000000046 t= 0.2324000000000046 t= 0.2326000000000046 t= 0.23280000000000461 t= 0.23300000000000462 t= 0.23320000000000463 t= 0.23340000000000463 t= 0.23360000000000464 t= 0.23380000000000464 t= 0.23400000000000465 t= 0.23420000000000465 t= 0.23440000000000466 t= 0.23460000000000467 t= 0.23480000000000467 t= 0.23500000000000468 t= 0.23520000000000468 t= 0.2354000000000047 t= 0.2356000000000047 t= 0.2358000000000047 t= 0.2360000000000047 t= 0.2362000000000047 t= 0.23640000000000472 t= 0.23660000000000472 t= 0.23680000000000473 t= 0.23700000000000473 t= 0.23720000000000474 t= 0.23740000000000475 t= 0.23760000000000475 t= 0.23780000000000476 t= 0.23800000000000476 t= 0.23820000000000477 t= 0.23840000000000477 t= 0.23860000000000478 t= 0.2388000000000048 t= 0.2390000000000048 t= 0.2392000000000048 t= 0.2394000000000048 t= 0.2396000000000048 t= 0.23980000000000481 t= 0.24000000000000482 t= 0.24020000000000483 t= 0.24040000000000483 t= 0.24060000000000484 t= 0.24080000000000484 t= 0.24100000000000485 t= 0.24120000000000485 t= 0.24140000000000486 t= 0.24160000000000487 t= 0.24180000000000487 t= 0.24200000000000488 t= 0.24220000000000488 t= 0.2424000000000049 t= 0.2426000000000049 t= 0.2428000000000049 t= 0.2430000000000049 t= 0.2432000000000049 t= 0.24340000000000492 t= 0.24360000000000492 t= 0.24380000000000493 t= 0.24400000000000494 t= 0.24420000000000494 t= 0.24440000000000495 t= 0.24460000000000495 t= 0.24480000000000496 t= 0.24500000000000496 t= 0.24520000000000497 t= 0.24540000000000498 t= 0.24560000000000498 t= 0.245800000000005 t= 0.246000000000005 t= 0.246200000000005 t= 0.246400000000005 t= 0.246600000000005 t= 0.24680000000000502 t= 0.24700000000000502 t= 0.24720000000000503 t= 0.24740000000000503 t= 0.24760000000000504 t= 0.24780000000000504 t= 0.24800000000000505 t= 0.24820000000000506 t= 0.24840000000000506 t= 0.24860000000000507 t= 0.24880000000000507 t= 0.24900000000000508 t= 0.24920000000000508 t= 0.2494000000000051 t= 0.2496000000000051 t= 0.2498000000000051 t= 0.2500000000000051 t= 0.2502000000000051 t= 0.25040000000000506 t= 0.25060000000000504 t= 0.250800000000005 t= 0.251000000000005 t= 0.251200000000005 t= 0.25140000000000495 t= 0.25160000000000493 t= 0.2518000000000049 t= 0.2520000000000049 t= 0.25220000000000486 t= 0.25240000000000484 t= 0.2526000000000048 t= 0.2528000000000048 t= 0.2530000000000048 t= 0.25320000000000475 t= 0.25340000000000473 t= 0.2536000000000047 t= 0.2538000000000047 t= 0.25400000000000467 t= 0.25420000000000464 t= 0.2544000000000046 t= 0.2546000000000046 t= 0.2548000000000046 t= 0.25500000000000456 t= 0.25520000000000453 t= 0.2554000000000045 t= 0.2556000000000045 t= 0.25580000000000447 t= 0.25600000000000445 t= 0.2562000000000044 t= 0.2564000000000044 t= 0.2566000000000044 t= 0.25680000000000436 t= 0.25700000000000434 t= 0.2572000000000043 t= 0.2574000000000043 t= 0.25760000000000427 t= 0.25780000000000425 t= 0.2580000000000042 t= 0.2582000000000042 t= 0.2584000000000042 t= 0.25860000000000416 t= 0.25880000000000414 t= 0.2590000000000041 t= 0.2592000000000041 t= 0.25940000000000407 t= 0.25960000000000405 t= 0.259800000000004 t= 0.260000000000004 t= 0.260200000000004 t= 0.26040000000000396 t= 0.26060000000000394 t= 0.2608000000000039 t= 0.2610000000000039 t= 0.2612000000000039 t= 0.26140000000000385 t= 0.26160000000000383 t= 0.2618000000000038 t= 0.2620000000000038 t= 0.26220000000000376 t= 0.26240000000000374 t= 0.2626000000000037 t= 0.2628000000000037 t= 0.2630000000000037 t= 0.26320000000000365 t= 0.26340000000000363 t= 0.2636000000000036 t= 0.2638000000000036 t= 0.26400000000000357 t= 0.26420000000000354 t= 0.2644000000000035 t= 0.2646000000000035 t= 0.2648000000000035 t= 0.26500000000000346 t= 0.26520000000000343 t= 0.2654000000000034 t= 0.2656000000000034 t= 0.26580000000000337 t= 0.26600000000000334 t= 0.2662000000000033 t= 0.2664000000000033 t= 0.2666000000000033 t= 0.26680000000000326 t= 0.26700000000000323 t= 0.2672000000000032 t= 0.2674000000000032 t= 0.26760000000000317 t= 0.26780000000000315 t= 0.2680000000000031 t= 0.2682000000000031 t= 0.2684000000000031 t= 0.26860000000000306 t= 0.26880000000000304 t= 0.269000000000003 t= 0.269200000000003 t= 0.26940000000000297 t= 0.26960000000000295 t= 0.2698000000000029 t= 0.2700000000000029 t= 0.2702000000000029 t= 0.27040000000000286 t= 0.27060000000000284 t= 0.2708000000000028 t= 0.2710000000000028 t= 0.27120000000000277 t= 0.27140000000000275 t= 0.27160000000000273 t= 0.2718000000000027 t= 0.2720000000000027 t= 0.27220000000000266 t= 0.27240000000000264 t= 0.2726000000000026 t= 0.2728000000000026 t= 0.2730000000000026 t= 0.27320000000000255 t= 0.27340000000000253 t= 0.2736000000000025 t= 0.2738000000000025 t= 0.27400000000000246 t= 0.27420000000000244 t= 0.2744000000000024 t= 0.2746000000000024 t= 0.2748000000000024 t= 0.27500000000000235 t= 0.27520000000000233 t= 0.2754000000000023 t= 0.2756000000000023 t= 0.27580000000000227 t= 0.27600000000000224 t= 0.2762000000000022 t= 0.2764000000000022 t= 0.2766000000000022 t= 0.27680000000000216 t= 0.27700000000000213 t= 0.2772000000000021 t= 0.2774000000000021 t= 0.27760000000000207 t= 0.27780000000000205 t= 0.278000000000002 t= 0.278200000000002 t= 0.278400000000002 t= 0.27860000000000196 t= 0.27880000000000194 t= 0.2790000000000019 t= 0.2792000000000019 t= 0.27940000000000187 t= 0.27960000000000185 t= 0.2798000000000018 t= 0.2800000000000018 t= 0.2802000000000018 t= 0.28040000000000176 t= 0.28060000000000174 t= 0.2808000000000017 t= 0.2810000000000017 t= 0.28120000000000167 t= 0.28140000000000165 t= 0.2816000000000016 t= 0.2818000000000016 t= 0.2820000000000016 t= 0.28220000000000156 t= 0.28240000000000154 t= 0.2826000000000015 t= 0.2828000000000015 t= 0.2830000000000015 t= 0.28320000000000145 t= 0.28340000000000143 t= 0.2836000000000014 t= 0.2838000000000014 t= 0.28400000000000136 t= 0.28420000000000134 t= 0.2844000000000013 t= 0.2846000000000013 t= 0.2848000000000013 t= 0.28500000000000125 t= 0.28520000000000123 t= 0.2854000000000012 t= 0.2856000000000012 t= 0.28580000000000116 t= 0.28600000000000114 t= 0.2862000000000011 t= 0.2864000000000011 t= 0.2866000000000011 t= 0.28680000000000105 t= 0.28700000000000103 t= 0.287200000000001 t= 0.287400000000001 t= 0.28760000000000097 t= 0.28780000000000094 t= 0.2880000000000009 t= 0.2882000000000009 t= 0.2884000000000009 t= 0.28860000000000086 t= 0.28880000000000083 t= 0.2890000000000008 t= 0.2892000000000008 t= 0.28940000000000077 t= 0.28960000000000075 t= 0.2898000000000007 t= 0.2900000000000007 t= 0.2902000000000007 t= 0.29040000000000066 t= 0.29060000000000064 t= 0.2908000000000006 t= 0.2910000000000006 t= 0.29120000000000057 t= 0.29140000000000055 t= 0.2916000000000005 t= 0.2918000000000005 t= 0.2920000000000005 t= 0.29220000000000046 t= 0.29240000000000044 t= 0.2926000000000004 t= 0.2928000000000004 t= 0.29300000000000037 t= 0.29320000000000035 t= 0.2934000000000003 t= 0.2936000000000003 t= 0.2938000000000003 t= 0.29400000000000026 t= 0.29420000000000024 t= 0.2944000000000002 t= 0.2946000000000002 t= 0.2948000000000002 t= 0.29500000000000015 t= 0.29520000000000013 t= 0.2954000000000001 t= 0.2956000000000001 t= 0.29580000000000006 t= 0.29600000000000004 t= 0.2962 t= 0.2964 t= 0.2966 t= 0.29679999999999995 t= 0.29699999999999993 t= 0.2971999999999999 t= 0.2973999999999999 t= 0.29759999999999986 t= 0.29779999999999984 t= 0.2979999999999998 t= 0.2981999999999998 t= 0.2983999999999998 t= 0.29859999999999975 t= 0.29879999999999973 t= 0.2989999999999997 t= 0.2991999999999997 t= 0.29939999999999967 t= 0.29959999999999964 t= 0.2997999999999996 t= 0.2999999999999996 t= 0.3001999999999996 t= 0.30039999999999956 t= 0.30059999999999953 t= 0.3007999999999995 t= 0.3009999999999995 t= 0.30119999999999947 t= 0.30139999999999945 t= 0.3015999999999994 t= 0.3017999999999994 t= 0.3019999999999994 t= 0.30219999999999936 t= 0.30239999999999934 t= 0.3025999999999993 t= 0.3027999999999993 t= 0.30299999999999927 t= 0.30319999999999925 t= 0.3033999999999992 t= 0.3035999999999992 t= 0.3037999999999992 t= 0.30399999999999916 t= 0.30419999999999914 t= 0.3043999999999991 t= 0.3045999999999991 t= 0.30479999999999907 t= 0.30499999999999905 t= 0.305199999999999 t= 0.305399999999999 t= 0.305599999999999 t= 0.30579999999999896 t= 0.30599999999999894 t= 0.3061999999999989 t= 0.3063999999999989 t= 0.3065999999999989 t= 0.30679999999999885 t= 0.30699999999999883 t= 0.3071999999999988 t= 0.3073999999999988 t= 0.30759999999999876 t= 0.30779999999999874 t= 0.3079999999999987 t= 0.3081999999999987 t= 0.3083999999999987 t= 0.30859999999999865 t= 0.30879999999999863 t= 0.3089999999999986 t= 0.3091999999999986 t= 0.30939999999999857 t= 0.30959999999999854 t= 0.3097999999999985 t= 0.3099999999999985 t= 0.3101999999999985 t= 0.31039999999999845 t= 0.31059999999999843 t= 0.3107999999999984 t= 0.3109999999999984 t= 0.31119999999999837 t= 0.31139999999999834 t= 0.3115999999999983 t= 0.3117999999999983 t= 0.3119999999999983 t= 0.31219999999999826 t= 0.31239999999999823 t= 0.3125999999999982 t= 0.3127999999999982 t= 0.31299999999999817 t= 0.31319999999999815 t= 0.3133999999999981 t= 0.3135999999999981 t= 0.3137999999999981 t= 0.31399999999999806 t= 0.31419999999999804 t= 0.314399999999998 t= 0.314599999999998 t= 0.31479999999999797 t= 0.31499999999999795 t= 0.3151999999999979 t= 0.3153999999999979 t= 0.3155999999999979 t= 0.31579999999999786 t= 0.31599999999999784 t= 0.3161999999999978 t= 0.3163999999999978 t= 0.31659999999999777 t= 0.31679999999999775 t= 0.31699999999999773 t= 0.3171999999999977 t= 0.3173999999999977 t= 0.31759999999999766 t= 0.31779999999999764 t= 0.3179999999999976 t= 0.3181999999999976 t= 0.3183999999999976 t= 0.31859999999999755 t= 0.31879999999999753 t= 0.3189999999999975 t= 0.3191999999999975 t= 0.31939999999999746 t= 0.31959999999999744 t= 0.3197999999999974 t= 0.3199999999999974 t= 0.3201999999999974 t= 0.32039999999999735 t= 0.32059999999999733 t= 0.3207999999999973 t= 0.3209999999999973 t= 0.32119999999999727 t= 0.32139999999999724 t= 0.3215999999999972 t= 0.3217999999999972 t= 0.3219999999999972 t= 0.32219999999999716 t= 0.32239999999999713 t= 0.3225999999999971 t= 0.3227999999999971 t= 0.32299999999999707 t= 0.32319999999999705 t= 0.323399999999997 t= 0.323599999999997 t= 0.323799999999997 t= 0.32399999999999696 t= 0.32419999999999694 t= 0.3243999999999969 t= 0.3245999999999969 t= 0.32479999999999687 t= 0.32499999999999685 t= 0.3251999999999968 t= 0.3253999999999968 t= 0.3255999999999968 t= 0.32579999999999676 t= 0.32599999999999674 t= 0.3261999999999967 t= 0.3263999999999967 t= 0.32659999999999667 t= 0.32679999999999665 t= 0.3269999999999966 t= 0.3271999999999966 t= 0.3273999999999966 t= 0.32759999999999656 t= 0.32779999999999654 t= 0.3279999999999965 t= 0.3281999999999965 t= 0.3283999999999965 t= 0.32859999999999645 t= 0.32879999999999643 t= 0.3289999999999964 t= 0.3291999999999964 t= 0.32939999999999636 t= 0.32959999999999634 t= 0.3297999999999963 t= 0.3299999999999963 t= 0.3301999999999963 t= 0.33039999999999625 t= 0.33059999999999623 t= 0.3307999999999962 t= 0.3309999999999962 t= 0.33119999999999616 t= 0.33139999999999614 t= 0.3315999999999961 t= 0.3317999999999961 t= 0.3319999999999961 t= 0.33219999999999605 t= 0.33239999999999603 t= 0.332599999999996 t= 0.332799999999996 t= 0.33299999999999597 t= 0.33319999999999594 t= 0.3333999999999959 t= 0.3335999999999959 t= 0.3337999999999959 t= 0.33399999999999586 t= 0.33419999999999583 t= 0.3343999999999958 t= 0.3345999999999958 t= 0.33479999999999577 t= 0.33499999999999575 t= 0.3351999999999957 t= 0.3353999999999957 t= 0.3355999999999957 t= 0.33579999999999566 t= 0.33599999999999564 t= 0.3361999999999956 t= 0.3363999999999956 t= 0.33659999999999557 t= 0.33679999999999555 t= 0.3369999999999955 t= 0.3371999999999955 t= 0.3373999999999955 t= 0.33759999999999546 t= 0.33779999999999544 t= 0.3379999999999954 t= 0.3381999999999954 t= 0.33839999999999537 t= 0.33859999999999535 t= 0.3387999999999953 t= 0.3389999999999953 t= 0.3391999999999953 t= 0.33939999999999526 t= 0.33959999999999524 t= 0.3397999999999952 t= 0.3399999999999952 t= 0.3401999999999952 t= 0.34039999999999515 t= 0.34059999999999513 t= 0.3407999999999951 t= 0.3409999999999951 t= 0.34119999999999506 t= 0.34139999999999504 t= 0.341599999999995 t= 0.341799999999995 t= 0.341999999999995 t= 0.34219999999999495 t= 0.34239999999999493 t= 0.3425999999999949 t= 0.3427999999999949 t= 0.34299999999999486 t= 0.34319999999999484 t= 0.3433999999999948 t= 0.3435999999999948 t= 0.3437999999999948 t= 0.34399999999999475 t= 0.34419999999999473 t= 0.3443999999999947 t= 0.3445999999999947 t= 0.34479999999999467 t= 0.34499999999999464 t= 0.3451999999999946 t= 0.3453999999999946 t= 0.3455999999999946 t= 0.34579999999999456 t= 0.34599999999999453 t= 0.3461999999999945 t= 0.3463999999999945 t= 0.34659999999999447 t= 0.34679999999999445 t= 0.3469999999999944 t= 0.3471999999999944 t= 0.3473999999999944 t= 0.34759999999999436 t= 0.34779999999999434 t= 0.3479999999999943 t= 0.3481999999999943 t= 0.34839999999999427 t= 0.34859999999999425 t= 0.3487999999999942 t= 0.3489999999999942 t= 0.3491999999999942 t= 0.34939999999999416 t= 0.34959999999999414 t= 0.3497999999999941 t= 0.3499999999999941 t= 0.35019999999999407 t= 0.35039999999999405 t= 0.350599999999994 t= 0.350799999999994 t= 0.350999999999994 t= 0.35119999999999396 t= 0.35139999999999394 t= 0.3515999999999939 t= 0.3517999999999939 t= 0.3519999999999939 t= 0.35219999999999385 t= 0.35239999999999383 t= 0.3525999999999938 t= 0.3527999999999938 t= 0.35299999999999376 t= 0.35319999999999374 t= 0.3533999999999937 t= 0.3535999999999937 t= 0.3537999999999937 t= 0.35399999999999365 t= 0.35419999999999363 t= 0.3543999999999936 t= 0.3545999999999936 t= 0.35479999999999356 t= 0.35499999999999354 t= 0.3551999999999935 t= 0.3553999999999935 t= 0.3555999999999935 t= 0.35579999999999345 t= 0.35599999999999343 t= 0.3561999999999934 t= 0.3563999999999934 t= 0.35659999999999337 t= 0.35679999999999334 t= 0.3569999999999933 t= 0.3571999999999933 t= 0.3573999999999933 t= 0.35759999999999326 t= 0.35779999999999323 t= 0.3579999999999932 t= 0.3581999999999932 t= 0.35839999999999317 t= 0.35859999999999315 t= 0.3587999999999931 t= 0.3589999999999931 t= 0.3591999999999931 t= 0.35939999999999306 t= 0.35959999999999304 t= 0.359799999999993 t= 0.359999999999993 t= 0.36019999999999297 t= 0.36039999999999295 t= 0.3605999999999929 t= 0.3607999999999929 t= 0.3609999999999929 t= 0.36119999999999286 t= 0.36139999999999284 t= 0.3615999999999928 t= 0.3617999999999928 t= 0.36199999999999277 t= 0.36219999999999275 t= 0.36239999999999273 t= 0.3625999999999927 t= 0.3627999999999927 t= 0.36299999999999266 t= 0.36319999999999264 t= 0.3633999999999926 t= 0.3635999999999926 t= 0.3637999999999926 t= 0.36399999999999255 t= 0.36419999999999253 t= 0.3643999999999925 t= 0.3645999999999925 t= 0.36479999999999246 t= 0.36499999999999244 t= 0.3651999999999924 t= 0.3653999999999924 t= 0.3655999999999924 t= 0.36579999999999235 t= 0.36599999999999233 t= 0.3661999999999923 t= 0.3663999999999923 t= 0.36659999999999227 t= 0.36679999999999224 t= 0.3669999999999922 t= 0.3671999999999922 t= 0.3673999999999922 t= 0.36759999999999216 t= 0.36779999999999213 t= 0.3679999999999921 t= 0.3681999999999921 t= 0.36839999999999207 t= 0.36859999999999205 t= 0.368799999999992 t= 0.368999999999992 t= 0.369199999999992 t= 0.36939999999999196 t= 0.36959999999999193 t= 0.3697999999999919 t= 0.3699999999999919 t= 0.37019999999999187 t= 0.37039999999999185 t= 0.3705999999999918 t= 0.3707999999999918 t= 0.3709999999999918 t= 0.37119999999999176 t= 0.37139999999999174 t= 0.3715999999999917 t= 0.3717999999999917 t= 0.37199999999999167 t= 0.37219999999999165 t= 0.3723999999999916 t= 0.3725999999999916 t= 0.3727999999999916 t= 0.37299999999999156 t= 0.37319999999999154 t= 0.3733999999999915 t= 0.3735999999999915 t= 0.3737999999999915 t= 0.37399999999999145 t= 0.37419999999999143 t= 0.3743999999999914 t= 0.3745999999999914 t= 0.37479999999999136 t= 0.37499999999999134 t= 0.3751999999999913 t= 0.3753999999999913 t= 0.3755999999999913 t= 0.37579999999999125 t= 0.37599999999999123 t= 0.3761999999999912 t= 0.3763999999999912 t= 0.37659999999999116 t= 0.37679999999999114 t= 0.3769999999999911 t= 0.3771999999999911 t= 0.3773999999999911 t= 0.37759999999999105 t= 0.37779999999999103 t= 0.377999999999991 t= 0.378199999999991 t= 0.37839999999999097 t= 0.37859999999999094 t= 0.3787999999999909 t= 0.3789999999999909 t= 0.3791999999999909 t= 0.37939999999999086 t= 0.37959999999999083 t= 0.3797999999999908 t= 0.3799999999999908 t= 0.38019999999999077 t= 0.38039999999999075 t= 0.3805999999999907 t= 0.3807999999999907 t= 0.3809999999999907 t= 0.38119999999999066 t= 0.38139999999999064 t= 0.3815999999999906 t= 0.3817999999999906 t= 0.38199999999999057 t= 0.38219999999999055 t= 0.3823999999999905 t= 0.3825999999999905 t= 0.3827999999999905 t= 0.38299999999999046 t= 0.38319999999999044 t= 0.3833999999999904 t= 0.3835999999999904 t= 0.38379999999999037 t= 0.38399999999999035 t= 0.3841999999999903 t= 0.3843999999999903 t= 0.3845999999999903 t= 0.38479999999999026 t= 0.38499999999999024 t= 0.3851999999999902 t= 0.3853999999999902 t= 0.3855999999999902 t= 0.38579999999999015 t= 0.38599999999999013 t= 0.3861999999999901 t= 0.3863999999999901 t= 0.38659999999999006 t= 0.38679999999999004 t= 0.38699999999999 t= 0.38719999999999 t= 0.38739999999999 t= 0.38759999999998995 t= 0.38779999999998993 t= 0.3879999999999899 t= 0.3881999999999899 t= 0.38839999999998986 t= 0.38859999999998984 t= 0.3887999999999898 t= 0.3889999999999898 t= 0.3891999999999898 t= 0.38939999999998975 t= 0.38959999999998973 t= 0.3897999999999897 t= 0.3899999999999897 t= 0.39019999999998967 t= 0.39039999999998964 t= 0.3905999999999896 t= 0.3907999999999896 t= 0.3909999999999896 t= 0.39119999999998956 t= 0.39139999999998953 t= 0.3915999999999895 t= 0.3917999999999895 t= 0.39199999999998947 t= 0.39219999999998945 t= 0.3923999999999894 t= 0.3925999999999894 t= 0.3927999999999894 t= 0.39299999999998936 t= 0.39319999999998934 t= 0.3933999999999893 t= 0.3935999999999893 t= 0.39379999999998927 t= 0.39399999999998925 t= 0.3941999999999892 t= 0.3943999999999892 t= 0.3945999999999892 t= 0.39479999999998916 t= 0.39499999999998914 t= 0.3951999999999891 t= 0.3953999999999891 t= 0.39559999999998907 t= 0.39579999999998905 t= 0.395999999999989 t= 0.396199999999989 t= 0.396399999999989 t= 0.39659999999998896 t= 0.39679999999998894 t= 0.3969999999999889 t= 0.3971999999999889 t= 0.3973999999999889 t= 0.39759999999998885 t= 0.39779999999998883 t= 0.3979999999999888 t= 0.3981999999999888 t= 0.39839999999998876 t= 0.39859999999998874 t= 0.3987999999999887 t= 0.3989999999999887 t= 0.3991999999999887 t= 0.39939999999998865 t= 0.39959999999998863 t= 0.3997999999999886 t= 0.3999999999999886 t= 0.40019999999998856 t= 0.40039999999998854 t= 0.4005999999999885 t= 0.4007999999999885 t= 0.4009999999999885 t= 0.40119999999998845 t= 0.40139999999998843 t= 0.4015999999999884 t= 0.4017999999999884 t= 0.40199999999998837 t= 0.40219999999998834 t= 0.4023999999999883 t= 0.4025999999999883 t= 0.4027999999999883 t= 0.40299999999998826 t= 0.40319999999998823 t= 0.4033999999999882 t= 0.4035999999999882 t= 0.40379999999998817 t= 0.40399999999998815 t= 0.4041999999999881 t= 0.4043999999999881 t= 0.4045999999999881 t= 0.40479999999998806 t= 0.40499999999998804 t= 0.405199999999988 t= 0.405399999999988 t= 0.40559999999998797 t= 0.40579999999998795 t= 0.4059999999999879 t= 0.4061999999999879 t= 0.4063999999999879 t= 0.40659999999998786 t= 0.40679999999998784 t= 0.4069999999999878 t= 0.4071999999999878 t= 0.40739999999998777 t= 0.40759999999998775 t= 0.40779999999998773 t= 0.4079999999999877 t= 0.4081999999999877 t= 0.40839999999998766 t= 0.40859999999998764 t= 0.4087999999999876 t= 0.4089999999999876 t= 0.4091999999999876 t= 0.40939999999998755 t= 0.40959999999998753 t= 0.4097999999999875 t= 0.4099999999999875 t= 0.41019999999998746 t= 0.41039999999998744 t= 0.4105999999999874 t= 0.4107999999999874 t= 0.4109999999999874 t= 0.41119999999998735 t= 0.41139999999998733 t= 0.4115999999999873 t= 0.4117999999999873 t= 0.41199999999998727 t= 0.41219999999998724 t= 0.4123999999999872 t= 0.4125999999999872 t= 0.4127999999999872 t= 0.41299999999998716 t= 0.41319999999998713 t= 0.4133999999999871 t= 0.4135999999999871 t= 0.41379999999998707 t= 0.41399999999998705 t= 0.414199999999987 t= 0.414399999999987 t= 0.414599999999987 t= 0.41479999999998696 t= 0.41499999999998693 t= 0.4151999999999869 t= 0.4153999999999869 t= 0.41559999999998687 t= 0.41579999999998685 t= 0.4159999999999868 t= 0.4161999999999868 t= 0.4163999999999868 t= 0.41659999999998676 t= 0.41679999999998674 t= 0.4169999999999867 t= 0.4171999999999867 t= 0.41739999999998667 t= 0.41759999999998665 t= 0.4177999999999866 t= 0.4179999999999866 t= 0.4181999999999866 t= 0.41839999999998656 t= 0.41859999999998654 t= 0.4187999999999865 t= 0.4189999999999865 t= 0.4191999999999865 t= 0.41939999999998645 t= 0.41959999999998643 t= 0.4197999999999864 t= 0.4199999999999864 t= 0.42019999999998636 t= 0.42039999999998634 t= 0.4205999999999863 t= 0.4207999999999863 t= 0.4209999999999863 t= 0.42119999999998625 t= 0.42139999999998623 t= 0.4215999999999862 t= 0.4217999999999862 t= 0.42199999999998616 t= 0.42219999999998614 t= 0.4223999999999861 t= 0.4225999999999861 t= 0.4227999999999861 t= 0.42299999999998605 t= 0.42319999999998603 t= 0.423399999999986 t= 0.423599999999986 t= 0.42379999999998597 t= 0.42399999999998594 t= 0.4241999999999859 t= 0.4243999999999859 t= 0.4245999999999859 t= 0.42479999999998586 t= 0.42499999999998583 t= 0.4251999999999858 t= 0.4253999999999858 t= 0.42559999999998577 t= 0.42579999999998575 t= 0.4259999999999857 t= 0.4261999999999857 t= 0.4263999999999857 t= 0.42659999999998566 t= 0.42679999999998564 t= 0.4269999999999856 t= 0.4271999999999856 t= 0.42739999999998557 t= 0.42759999999998555 t= 0.4277999999999855 t= 0.4279999999999855 t= 0.4281999999999855 t= 0.42839999999998546 t= 0.42859999999998544 t= 0.4287999999999854 t= 0.4289999999999854 t= 0.42919999999998537 t= 0.42939999999998535 t= 0.4295999999999853 t= 0.4297999999999853 t= 0.4299999999999853 t= 0.43019999999998526 t= 0.43039999999998524 t= 0.4305999999999852 t= 0.4307999999999852 t= 0.4309999999999852 t= 0.43119999999998515 t= 0.43139999999998513 t= 0.4315999999999851 t= 0.4317999999999851 t= 0.43199999999998506 t= 0.43219999999998504 t= 0.432399999999985 t= 0.432599999999985 t= 0.432799999999985 t= 0.43299999999998495 t= 0.43319999999998493 t= 0.4333999999999849 t= 0.4335999999999849 t= 0.43379999999998486 t= 0.43399999999998484 t= 0.4341999999999848 t= 0.4343999999999848 t= 0.4345999999999848 t= 0.43479999999998475 t= 0.43499999999998473 t= 0.4351999999999847 t= 0.4353999999999847 t= 0.43559999999998467 t= 0.43579999999998464 t= 0.4359999999999846 t= 0.4361999999999846 t= 0.4363999999999846 t= 0.43659999999998456 t= 0.43679999999998453 t= 0.4369999999999845 t= 0.4371999999999845 t= 0.43739999999998447 t= 0.43759999999998445 t= 0.4377999999999844 t= 0.4379999999999844 t= 0.4381999999999844 t= 0.43839999999998436 t= 0.43859999999998434 t= 0.4387999999999843 t= 0.4389999999999843 t= 0.43919999999998427 t= 0.43939999999998425 t= 0.4395999999999842 t= 0.4397999999999842 t= 0.4399999999999842 t= 0.44019999999998416 t= 0.44039999999998414 t= 0.4405999999999841 t= 0.4407999999999841 t= 0.44099999999998407 t= 0.44119999999998405 t= 0.441399999999984 t= 0.441599999999984 t= 0.441799999999984 t= 0.44199999999998396 t= 0.44219999999998394 t= 0.4423999999999839 t= 0.4425999999999839 t= 0.4427999999999839 t= 0.44299999999998385 t= 0.44319999999998383 t= 0.4433999999999838 t= 0.4435999999999838 t= 0.44379999999998376 t= 0.44399999999998374 t= 0.4441999999999837 t= 0.4443999999999837 t= 0.4445999999999837 t= 0.44479999999998365 t= 0.44499999999998363 t= 0.4451999999999836 t= 0.4453999999999836 t= 0.44559999999998356 t= 0.44579999999998354 t= 0.4459999999999835 t= 0.4461999999999835 t= 0.4463999999999835 t= 0.44659999999998345 t= 0.44679999999998343 t= 0.4469999999999834 t= 0.4471999999999834 t= 0.44739999999998337 t= 0.44759999999998334 t= 0.4477999999999833 t= 0.4479999999999833 t= 0.4481999999999833 t= 0.44839999999998326 t= 0.44859999999998323 t= 0.4487999999999832 t= 0.4489999999999832 t= 0.44919999999998317 t= 0.44939999999998315 t= 0.4495999999999831 t= 0.4497999999999831 t= 0.4499999999999831 t= 0.45019999999998306 t= 0.45039999999998304 t= 0.450599999999983 t= 0.450799999999983 t= 0.45099999999998297 t= 0.45119999999998295 t= 0.4513999999999829 t= 0.4515999999999829 t= 0.4517999999999829 t= 0.45199999999998286 t= 0.45219999999998284 t= 0.4523999999999828 t= 0.4525999999999828 t= 0.45279999999998277 t= 0.45299999999998275 t= 0.45319999999998273 t= 0.4533999999999827 t= 0.4535999999999827 t= 0.45379999999998266 t= 0.45399999999998264 t= 0.4541999999999826 t= 0.4543999999999826 t= 0.4545999999999826 t= 0.45479999999998255 t= 0.45499999999998253 t= 0.4551999999999825 t= 0.4553999999999825 t= 0.45559999999998246 t= 0.45579999999998244 t= 0.4559999999999824 t= 0.4561999999999824 t= 0.4563999999999824 t= 0.45659999999998235 t= 0.45679999999998233 t= 0.4569999999999823 t= 0.4571999999999823 t= 0.45739999999998227 t= 0.45759999999998224 t= 0.4577999999999822 t= 0.4579999999999822 t= 0.4581999999999822 t= 0.45839999999998216 t= 0.45859999999998213 t= 0.4587999999999821 t= 0.4589999999999821 t= 0.45919999999998207 t= 0.45939999999998204 t= 0.459599999999982 t= 0.459799999999982 t= 0.459999999999982 t= 0.46019999999998196 t= 0.46039999999998193 t= 0.4605999999999819 t= 0.4607999999999819 t= 0.46099999999998187 t= 0.46119999999998185 t= 0.4613999999999818 t= 0.4615999999999818 t= 0.4617999999999818 t= 0.46199999999998176 t= 0.46219999999998174 t= 0.4623999999999817 t= 0.4625999999999817 t= 0.46279999999998167 t= 0.46299999999998165 t= 0.4631999999999816 t= 0.4633999999999816 t= 0.4635999999999816 t= 0.46379999999998156 t= 0.46399999999998154 t= 0.4641999999999815 t= 0.4643999999999815 t= 0.46459999999998147 t= 0.46479999999998145 t= 0.46499999999998143 t= 0.4651999999999814 t= 0.4653999999999814 t= 0.46559999999998136 t= 0.46579999999998134 t= 0.4659999999999813 t= 0.4661999999999813 t= 0.4663999999999813 t= 0.46659999999998125 t= 0.46679999999998123 t= 0.4669999999999812 t= 0.4671999999999812 t= 0.46739999999998116 t= 0.46759999999998114 t= 0.4677999999999811 t= 0.4679999999999811 t= 0.4681999999999811 t= 0.46839999999998105 t= 0.46859999999998103 t= 0.468799999999981 t= 0.468999999999981 t= 0.46919999999998097 t= 0.46939999999998094 t= 0.4695999999999809 t= 0.4697999999999809 t= 0.4699999999999809 t= 0.47019999999998086 t= 0.47039999999998083 t= 0.4705999999999808 t= 0.4707999999999808 t= 0.47099999999998077 t= 0.47119999999998075 t= 0.4713999999999807 t= 0.4715999999999807 t= 0.4717999999999807 t= 0.47199999999998066 t= 0.47219999999998064 t= 0.4723999999999806 t= 0.4725999999999806 t= 0.47279999999998057 t= 0.47299999999998055 t= 0.4731999999999805 t= 0.4733999999999805 t= 0.4735999999999805 t= 0.47379999999998046 t= 0.47399999999998044 t= 0.4741999999999804 t= 0.4743999999999804 t= 0.47459999999998037 t= 0.47479999999998035 t= 0.4749999999999803 t= 0.4751999999999803 t= 0.4753999999999803 t= 0.47559999999998026 t= 0.47579999999998024 t= 0.4759999999999802 t= 0.4761999999999802 t= 0.4763999999999802 t= 0.47659999999998015 t= 0.47679999999998013 t= 0.4769999999999801 t= 0.4771999999999801 t= 0.47739999999998006 t= 0.47759999999998004 t= 0.47779999999998 t= 0.47799999999998 t= 0.47819999999998 t= 0.47839999999997995 t= 0.47859999999997993
</pre>
end{sphinxVerbatim}
t= 0.4787999999999799 t= 0.4789999999999799 t= 0.47919999999997986 t= 0.47939999999997984 t= 0.4795999999999798 t= 0.4797999999999798 t= 0.4799999999999798 t= 0.48019999999997975 t= 0.48039999999997973 t= 0.4805999999999797 t= 0.4807999999999797 t= 0.48099999999997967 t= 0.48119999999997964 t= 0.4813999999999796 t= 0.4815999999999796 t= 0.4817999999999796 t= 0.48199999999997956 t= 0.48219999999997953 t= 0.4823999999999795 t= 0.4825999999999795 t= 0.48279999999997947 t= 0.48299999999997945 t= 0.4831999999999794 t= 0.4833999999999794 t= 0.4835999999999794 t= 0.48379999999997936 t= 0.48399999999997934 t= 0.4841999999999793 t= 0.4843999999999793 t= 0.48459999999997927 t= 0.48479999999997925 t= 0.4849999999999792 t= 0.4851999999999792 t= 0.4853999999999792 t= 0.48559999999997916 t= 0.48579999999997914 t= 0.4859999999999791 t= 0.4861999999999791 t= 0.48639999999997907 t= 0.48659999999997905 t= 0.486799999999979 t= 0.486999999999979 t= 0.487199999999979 t= 0.48739999999997896 t= 0.48759999999997894 t= 0.4877999999999789 t= 0.4879999999999789 t= 0.4881999999999789 t= 0.48839999999997885 t= 0.48859999999997883 t= 0.4887999999999788 t= 0.4889999999999788 t= 0.48919999999997876 t= 0.48939999999997874 t= 0.4895999999999787 t= 0.4897999999999787 t= 0.4899999999999787 t= 0.49019999999997865 t= 0.49039999999997863 t= 0.4905999999999786 t= 0.4907999999999786 t= 0.49099999999997856 t= 0.49119999999997854 t= 0.4913999999999785 t= 0.4915999999999785 t= 0.4917999999999785 t= 0.49199999999997845 t= 0.49219999999997843 t= 0.4923999999999784 t= 0.4925999999999784 t= 0.49279999999997837 t= 0.49299999999997834 t= 0.4931999999999783 t= 0.4933999999999783 t= 0.4935999999999783 t= 0.49379999999997826 t= 0.49399999999997823 t= 0.4941999999999782 t= 0.4943999999999782 t= 0.49459999999997817 t= 0.49479999999997815 t= 0.4949999999999781 t= 0.4951999999999781 t= 0.4953999999999781 t= 0.49559999999997806 t= 0.49579999999997804 t= 0.495999999999978 t= 0.496199999999978 t= 0.49639999999997797 t= 0.49659999999997795 t= 0.4967999999999779 t= 0.4969999999999779 t= 0.4971999999999779 t= 0.49739999999997786 t= 0.49759999999997784 t= 0.4977999999999778 t= 0.4979999999999778 t= 0.49819999999997777 t= 0.49839999999997775 t= 0.4985999999999777 t= 0.4987999999999777 t= 0.4989999999999777 t= 0.49919999999997766 t= 0.49939999999997764 t= 0.4995999999999776 t= 0.4997999999999776 t= 0.4999999999999776 t= 0.5001999999999776 t= 0.5003999999999775 t= 0.5005999999999775 t= 0.5007999999999775 t= 0.5009999999999775 t= 0.5011999999999774 t= 0.5013999999999774 t= 0.5015999999999774 t= 0.5017999999999774 t= 0.5019999999999774 t= 0.5021999999999773 t= 0.5023999999999773 t= 0.5025999999999773 t= 0.5027999999999773 t= 0.5029999999999772 t= 0.5031999999999772 t= 0.5033999999999772 t= 0.5035999999999772 t= 0.5037999999999772 t= 0.5039999999999771 t= 0.5041999999999771 t= 0.5043999999999771 t= 0.5045999999999771 t= 0.504799999999977 t= 0.504999999999977 t= 0.505199999999977 t= 0.505399999999977 t= 0.505599999999977 t= 0.5057999999999769 t= 0.5059999999999769 t= 0.5061999999999769 t= 0.5063999999999769 t= 0.5065999999999768 t= 0.5067999999999768 t= 0.5069999999999768 t= 0.5071999999999768 t= 0.5073999999999768 t= 0.5075999999999767 t= 0.5077999999999767 t= 0.5079999999999767 t= 0.5081999999999767 t= 0.5083999999999766 t= 0.5085999999999766 t= 0.5087999999999766 t= 0.5089999999999766 t= 0.5091999999999766 t= 0.5093999999999765 t= 0.5095999999999765 t= 0.5097999999999765 t= 0.5099999999999765 t= 0.5101999999999765 t= 0.5103999999999764 t= 0.5105999999999764 t= 0.5107999999999764 t= 0.5109999999999764 t= 0.5111999999999763 t= 0.5113999999999763 t= 0.5115999999999763 t= 0.5117999999999763 t= 0.5119999999999763 t= 0.5121999999999762 t= 0.5123999999999762 t= 0.5125999999999762 t= 0.5127999999999762 t= 0.5129999999999761 t= 0.5131999999999761 t= 0.5133999999999761 t= 0.5135999999999761 t= 0.513799999999976 t= 0.513999999999976 t= 0.514199999999976 t= 0.514399999999976 t= 0.514599999999976 t= 0.5147999999999759 t= 0.5149999999999759 t= 0.5151999999999759 t= 0.5153999999999759 t= 0.5155999999999759 t= 0.5157999999999758 t= 0.5159999999999758 t= 0.5161999999999758 t= 0.5163999999999758 t= 0.5165999999999757 t= 0.5167999999999757 t= 0.5169999999999757 t= 0.5171999999999757 t= 0.5173999999999757 t= 0.5175999999999756 t= 0.5177999999999756 t= 0.5179999999999756 t= 0.5181999999999756 t= 0.5183999999999755 t= 0.5185999999999755 t= 0.5187999999999755 t= 0.5189999999999755 t= 0.5191999999999755 t= 0.5193999999999754 t= 0.5195999999999754 t= 0.5197999999999754 t= 0.5199999999999754 t= 0.5201999999999753 t= 0.5203999999999753 t= 0.5205999999999753 t= 0.5207999999999753 t= 0.5209999999999753 t= 0.5211999999999752 t= 0.5213999999999752 t= 0.5215999999999752 t= 0.5217999999999752 t= 0.5219999999999752 t= 0.5221999999999751 t= 0.5223999999999751 t= 0.5225999999999751 t= 0.5227999999999751 t= 0.522999999999975 t= 0.523199999999975 t= 0.523399999999975 t= 0.523599999999975 t= 0.523799999999975 t= 0.5239999999999749 t= 0.5241999999999749 t= 0.5243999999999749 t= 0.5245999999999749 t= 0.5247999999999748 t= 0.5249999999999748 t= 0.5251999999999748 t= 0.5253999999999748 t= 0.5255999999999748 t= 0.5257999999999747 t= 0.5259999999999747 t= 0.5261999999999747 t= 0.5263999999999747 t= 0.5265999999999746 t= 0.5267999999999746 t= 0.5269999999999746 t= 0.5271999999999746 t= 0.5273999999999746 t= 0.5275999999999745 t= 0.5277999999999745 t= 0.5279999999999745 t= 0.5281999999999745 t= 0.5283999999999744 t= 0.5285999999999744 t= 0.5287999999999744 t= 0.5289999999999744 t= 0.5291999999999744 t= 0.5293999999999743 t= 0.5295999999999743 t= 0.5297999999999743 t= 0.5299999999999743 t= 0.5301999999999742 t= 0.5303999999999742 t= 0.5305999999999742 t= 0.5307999999999742 t= 0.5309999999999742 t= 0.5311999999999741 t= 0.5313999999999741 t= 0.5315999999999741 t= 0.5317999999999741 t= 0.531999999999974 t= 0.532199999999974 t= 0.532399999999974 t= 0.532599999999974 t= 0.532799999999974 t= 0.5329999999999739 t= 0.5331999999999739 t= 0.5333999999999739 t= 0.5335999999999739 t= 0.5337999999999739 t= 0.5339999999999738 t= 0.5341999999999738 t= 0.5343999999999738 t= 0.5345999999999738 t= 0.5347999999999737 t= 0.5349999999999737 t= 0.5351999999999737 t= 0.5353999999999737 t= 0.5355999999999737 t= 0.5357999999999736 t= 0.5359999999999736 t= 0.5361999999999736 t= 0.5363999999999736 t= 0.5365999999999735 t= 0.5367999999999735 t= 0.5369999999999735 t= 0.5371999999999735 t= 0.5373999999999735 t= 0.5375999999999734 t= 0.5377999999999734 t= 0.5379999999999734 t= 0.5381999999999734 t= 0.5383999999999733 t= 0.5385999999999733 t= 0.5387999999999733 t= 0.5389999999999733 t= 0.5391999999999733 t= 0.5393999999999732 t= 0.5395999999999732 t= 0.5397999999999732 t= 0.5399999999999732 t= 0.5401999999999731 t= 0.5403999999999731 t= 0.5405999999999731 t= 0.5407999999999731 t= 0.5409999999999731 t= 0.541199999999973 t= 0.541399999999973 t= 0.541599999999973 t= 0.541799999999973 t= 0.541999999999973 t= 0.5421999999999729 t= 0.5423999999999729 t= 0.5425999999999729 t= 0.5427999999999729 t= 0.5429999999999728 t= 0.5431999999999728 t= 0.5433999999999728 t= 0.5435999999999728 t= 0.5437999999999727 t= 0.5439999999999727 t= 0.5441999999999727 t= 0.5443999999999727 t= 0.5445999999999727 t= 0.5447999999999726 t= 0.5449999999999726 t= 0.5451999999999726 t= 0.5453999999999726 t= 0.5455999999999726 t= 0.5457999999999725 t= 0.5459999999999725 t= 0.5461999999999725 t= 0.5463999999999725 t= 0.5465999999999724 t= 0.5467999999999724 t= 0.5469999999999724 t= 0.5471999999999724 t= 0.5473999999999724 t= 0.5475999999999723 t= 0.5477999999999723 t= 0.5479999999999723 t= 0.5481999999999723 t= 0.5483999999999722 t= 0.5485999999999722 t= 0.5487999999999722 t= 0.5489999999999722 t= 0.5491999999999722 t= 0.5493999999999721 t= 0.5495999999999721 t= 0.5497999999999721 t= 0.5499999999999721 t= 0.550199999999972 t= 0.550399999999972 t= 0.550599999999972 t= 0.550799999999972 t= 0.550999999999972 t= 0.5511999999999719 t= 0.5513999999999719 t= 0.5515999999999719 t= 0.5517999999999719 t= 0.5519999999999718 t= 0.5521999999999718 t= 0.5523999999999718 t= 0.5525999999999718 t= 0.5527999999999718 t= 0.5529999999999717 t= 0.5531999999999717 t= 0.5533999999999717 t= 0.5535999999999717 t= 0.5537999999999716 t= 0.5539999999999716 t= 0.5541999999999716 t= 0.5543999999999716 t= 0.5545999999999716 t= 0.5547999999999715 t= 0.5549999999999715 t= 0.5551999999999715 t= 0.5553999999999715 t= 0.5555999999999715 t= 0.5557999999999714 t= 0.5559999999999714 t= 0.5561999999999714 t= 0.5563999999999714 t= 0.5565999999999713 t= 0.5567999999999713 t= 0.5569999999999713 t= 0.5571999999999713 t= 0.5573999999999713 t= 0.5575999999999712 t= 0.5577999999999712 t= 0.5579999999999712 t= 0.5581999999999712 t= 0.5583999999999711 t= 0.5585999999999711 t= 0.5587999999999711 t= 0.5589999999999711 t= 0.559199999999971 t= 0.559399999999971 t= 0.559599999999971 t= 0.559799999999971 t= 0.559999999999971 t= 0.5601999999999709 t= 0.5603999999999709 t= 0.5605999999999709 t= 0.5607999999999709 t= 0.5609999999999709 t= 0.5611999999999708 t= 0.5613999999999708 t= 0.5615999999999708 t= 0.5617999999999708 t= 0.5619999999999707 t= 0.5621999999999707 t= 0.5623999999999707 t= 0.5625999999999707 t= 0.5627999999999707 t= 0.5629999999999706 t= 0.5631999999999706 t= 0.5633999999999706 t= 0.5635999999999706 t= 0.5637999999999705 t= 0.5639999999999705 t= 0.5641999999999705 t= 0.5643999999999705 t= 0.5645999999999705 t= 0.5647999999999704 t= 0.5649999999999704 t= 0.5651999999999704 t= 0.5653999999999704 t= 0.5655999999999703 t= 0.5657999999999703 t= 0.5659999999999703 t= 0.5661999999999703 t= 0.5663999999999703 t= 0.5665999999999702 t= 0.5667999999999702 t= 0.5669999999999702 t= 0.5671999999999702 t= 0.5673999999999702 t= 0.5675999999999701 t= 0.5677999999999701 t= 0.5679999999999701 t= 0.5681999999999701 t= 0.56839999999997 t= 0.56859999999997 t= 0.56879999999997 t= 0.56899999999997 t= 0.56919999999997 t= 0.5693999999999699 t= 0.5695999999999699 t= 0.5697999999999699 t= 0.5699999999999699 t= 0.5701999999999698 t= 0.5703999999999698 t= 0.5705999999999698 t= 0.5707999999999698 t= 0.5709999999999698 t= 0.5711999999999697 t= 0.5713999999999697 t= 0.5715999999999697 t= 0.5717999999999697 t= 0.5719999999999696 t= 0.5721999999999696 t= 0.5723999999999696 t= 0.5725999999999696 t= 0.5727999999999696 t= 0.5729999999999695 t= 0.5731999999999695 t= 0.5733999999999695 t= 0.5735999999999695 t= 0.5737999999999694 t= 0.5739999999999694 t= 0.5741999999999694 t= 0.5743999999999694 t= 0.5745999999999694 t= 0.5747999999999693 t= 0.5749999999999693 t= 0.5751999999999693 t= 0.5753999999999693 t= 0.5755999999999692 t= 0.5757999999999692 t= 0.5759999999999692 t= 0.5761999999999692 t= 0.5763999999999692 t= 0.5765999999999691 t= 0.5767999999999691 t= 0.5769999999999691 t= 0.5771999999999691 t= 0.577399999999969 t= 0.577599999999969 t= 0.577799999999969 t= 0.577999999999969 t= 0.578199999999969 t= 0.5783999999999689 t= 0.5785999999999689 t= 0.5787999999999689 t= 0.5789999999999689 t= 0.5791999999999689 t= 0.5793999999999688 t= 0.5795999999999688 t= 0.5797999999999688 t= 0.5799999999999688 t= 0.5801999999999687 t= 0.5803999999999687 t= 0.5805999999999687 t= 0.5807999999999687 t= 0.5809999999999687 t= 0.5811999999999686 t= 0.5813999999999686 t= 0.5815999999999686 t= 0.5817999999999686 t= 0.5819999999999685 t= 0.5821999999999685 t= 0.5823999999999685 t= 0.5825999999999685 t= 0.5827999999999685 t= 0.5829999999999684 t= 0.5831999999999684 t= 0.5833999999999684 t= 0.5835999999999684 t= 0.5837999999999683 t= 0.5839999999999683 t= 0.5841999999999683 t= 0.5843999999999683 t= 0.5845999999999683 t= 0.5847999999999682 t= 0.5849999999999682 t= 0.5851999999999682 t= 0.5853999999999682 t= 0.5855999999999681 t= 0.5857999999999681 t= 0.5859999999999681 t= 0.5861999999999681 t= 0.5863999999999681 t= 0.586599999999968 t= 0.586799999999968 t= 0.586999999999968 t= 0.587199999999968 t= 0.587399999999968 t= 0.5875999999999679 t= 0.5877999999999679 t= 0.5879999999999679 t= 0.5881999999999679 t= 0.5883999999999678 t= 0.5885999999999678 t= 0.5887999999999678 t= 0.5889999999999678 t= 0.5891999999999677 t= 0.5893999999999677 t= 0.5895999999999677 t= 0.5897999999999677 t= 0.5899999999999677 t= 0.5901999999999676 t= 0.5903999999999676 t= 0.5905999999999676 t= 0.5907999999999676 t= 0.5909999999999676 t= 0.5911999999999675 t= 0.5913999999999675 t= 0.5915999999999675 t= 0.5917999999999675 t= 0.5919999999999674 t= 0.5921999999999674 t= 0.5923999999999674 t= 0.5925999999999674 t= 0.5927999999999674 t= 0.5929999999999673 t= 0.5931999999999673 t= 0.5933999999999673 t= 0.5935999999999673 t= 0.5937999999999672 t= 0.5939999999999672 t= 0.5941999999999672 t= 0.5943999999999672 t= 0.5945999999999672 t= 0.5947999999999671 t= 0.5949999999999671 t= 0.5951999999999671 t= 0.5953999999999671 t= 0.595599999999967 t= 0.595799999999967 t= 0.595999999999967 t= 0.596199999999967 t= 0.596399999999967 t= 0.5965999999999669 t= 0.5967999999999669 t= 0.5969999999999669 t= 0.5971999999999669 t= 0.5973999999999668 t= 0.5975999999999668 t= 0.5977999999999668 t= 0.5979999999999668 t= 0.5981999999999668 t= 0.5983999999999667 t= 0.5985999999999667 t= 0.5987999999999667 t= 0.5989999999999667 t= 0.5991999999999666 t= 0.5993999999999666 t= 0.5995999999999666 t= 0.5997999999999666 t= 0.5999999999999666CPU times: user 7.65 s, sys: 93.9 ms, total: 7.74 s
Wall time: 7.7 s </pre>
Wall time: 7.7 s end{sphinxVerbatim}
Wall time: 7.7 s
TraceOperator (Purpose: avoid neighbor access Other())¶
The trace operator maps from an FESpace to a compatible FacetFESpace by evaluating the traces.
The stored value on a facet is the sum of the traces of the aligned elements.
No need to access the neighbor (.Other()) later on.
VF = FacetFESpace(mesh, order=order)
V = VT*VF
trace = VT.TraceOperator(VF, False)
#info output about the trace operator
print("The space VT has {} dofs.".format(VT.ndof))
print("The trace space VF has {} dofs.".format(VF.ndof))
print("trace represents an {} x {} operator".format(trace.height, trace.width))
The space VT has 3480 dofs.
The trace space VF has 1840 dofs.
trace represents an 1840 x 3480 operator
example application of the trace operator:
gfuF = GridFunction(VF)
gfuF.vec.data = trace * gfu.vec
To make use of the trace operator, we split the previous (element_boundary) formulation into three parts:
part 1: element local volume integrals (no interaction with neighbor elements) (on
VT)part 2: couplings on the facets (on
VT\(\times\)V)part 3: (rhs + ) boundary terms (on
VT)
Part 1:
uT, vT = VT.TnT()
c1 = BilinearForm(space=VT, nonassemble=True) # part 1
c1 += -uT * b * grad(vT) * dx
Part 2:
uT,uF = V.TrialFunction()
c2 = BilinearForm(trialspace=V, testspace=VT, nonassemble=True) # part 2
# here uf-u = u_me + u_other - u_me is the neighbor value
# on bnd: uf = u_me and hence uf-u = 0
c2 += b*n * IfPos(b*n, uT, uF-uT) * vT * dx(element_boundary=True)
Right hand side (Part 3):
rhs = LinearForm(VT) # part 3
rhs += b*n * IfPos(b*n, 0, ubnd) * vT * dskel_bound # dskel_inflow
rhs.Assemble()
<ngsolve.comp.LinearForm at 0x7f4a1a58b070>
Note that c1 and c2 act on different spaces. To make them compatible, we combine: * TraceOperator: VT \(\to\) VF * Embeddings: VT \(\to\) VT \(\times\) VF and VF \(\to\) VT \(\times\) VF (cf. unit 2.10)
The Embeddings are (with \(n_F = \operatorname{dim}(V_F)\), \(n_T = \operatorname{dim}(V_T)\), \(n_V=n_F+n_T\))
embT = Embedding(V.ndof, V.Range(0))
embF = Embedding(V.ndof, V.Range(1))
embV = embT + embF @ trace
The operators can now be combined easily. Recall: * c1: VT \(\to\) VT' \(\quad\) \(\bullet\) c2: VT \(\times\) VF \(\to\) VT' \(\quad\) \(\bullet\) \(\Rightarrow\) c: VT \(\to\) VT'
c = c1.mat + c2.mat @ embV
The time loop:
%%time
gfu_t = SolveAndVisualize(c, rhs_vec=rhs.vec)
- more-to-come:
t= 0.0002 t= 0.0004 t= 0.0006000000000000001 t= 0.0008 t= 0.001 t= 0.0012000000000000001 t= 0.0014000000000000002 t= 0.0016000000000000003 t= 0.0018000000000000004 t= 0.0020000000000000005 t= 0.0022000000000000006 t= 0.0024000000000000007 t= 0.0026000000000000007 t= 0.002800000000000001 t= 0.003000000000000001 t= 0.003200000000000001 t= 0.003400000000000001 t= 0.003600000000000001 t= 0.0038000000000000013 t= 0.004000000000000001 t= 0.004200000000000001 t= 0.0044 t= 0.0046 t= 0.0048 t= 0.004999999999999999 t= 0.005199999999999999 t= 0.0053999999999999986 t= 0.005599999999999998 t= 0.005799999999999998 t= 0.0059999999999999975 t= 0.006199999999999997 t= 0.006399999999999997 t= 0.0065999999999999965 t= 0.006799999999999996 t= 0.006999999999999996 t= 0.0071999999999999955 t= 0.007399999999999995 t= 0.007599999999999995 t= 0.0077999999999999944 t= 0.007999999999999995 t= 0.008199999999999995 t= 0.008399999999999996 t= 0.008599999999999997 t= 0.008799999999999997 t= 0.008999999999999998 t= 0.009199999999999998 t= 0.009399999999999999 t= 0.0096 t= 0.0098 t= 0.01 t= 0.0102 t= 0.010400000000000001 t= 0.010600000000000002 t= 0.010800000000000002 t= 0.011000000000000003 t= 0.011200000000000003 t= 0.011400000000000004 t= 0.011600000000000004 t= 0.011800000000000005 t= 0.012000000000000005 t= 0.012200000000000006 t= 0.012400000000000007 t= 0.012600000000000007 t= 0.012800000000000008 t= 0.013000000000000008 t= 0.013200000000000009 t= 0.013400000000000009 t= 0.01360000000000001 t= 0.01380000000000001 t= 0.01400000000000001 t= 0.014200000000000011 t= 0.014400000000000012 t= 0.014600000000000012 t= 0.014800000000000013 t= 0.015000000000000013 t= 0.015200000000000014 t= 0.015400000000000014 t= 0.015600000000000015 t= 0.015800000000000015 t= 0.016000000000000014 t= 0.016200000000000013 t= 0.016400000000000012 t= 0.01660000000000001 t= 0.01680000000000001 t= 0.017000000000000008 t= 0.017200000000000007 t= 0.017400000000000006 t= 0.017600000000000005 t= 0.017800000000000003 t= 0.018000000000000002 t= 0.0182 t= 0.0184 t= 0.0186 t= 0.018799999999999997 t= 0.018999999999999996 t= 0.019199999999999995 t= 0.019399999999999994 t= 0.019599999999999992 t= 0.01979999999999999 t= 0.01999999999999999 t= 0.02019999999999999 t= 0.020399999999999988 t= 0.020599999999999986 t= 0.020799999999999985 t= 0.020999999999999984 t= 0.021199999999999983 t= 0.02139999999999998 t= 0.02159999999999998 t= 0.02179999999999998 t= 0.021999999999999978 t= 0.022199999999999977 t= 0.022399999999999975 t= 0.022599999999999974 t= 0.022799999999999973 t= 0.022999999999999972 t= 0.02319999999999997 t= 0.02339999999999997 t= 0.023599999999999968 t= 0.023799999999999967 t= 0.023999999999999966 t= 0.024199999999999965 t= 0.024399999999999963 t= 0.024599999999999962 t= 0.02479999999999996 t= 0.02499999999999996 t= 0.02519999999999996 t= 0.025399999999999957 t= 0.025599999999999956 t= 0.025799999999999955 t= 0.025999999999999954 t= 0.026199999999999952 t= 0.02639999999999995 t= 0.02659999999999995 t= 0.02679999999999995 t= 0.026999999999999948 t= 0.027199999999999946 t= 0.027399999999999945 t= 0.027599999999999944 t= 0.027799999999999943 t= 0.02799999999999994 t= 0.02819999999999994 t= 0.02839999999999994 t= 0.028599999999999938 t= 0.028799999999999937 t= 0.028999999999999936 t= 0.029199999999999934 t= 0.029399999999999933 t= 0.029599999999999932 t= 0.02979999999999993 t= 0.02999999999999993 t= 0.03019999999999993 t= 0.030399999999999927 t= 0.030599999999999926 t= 0.030799999999999925 t= 0.030999999999999923 t= 0.031199999999999922 t= 0.03139999999999992 t= 0.03159999999999992 t= 0.03179999999999992 t= 0.03199999999999992 t= 0.032199999999999916 t= 0.032399999999999915 t= 0.032599999999999914 t= 0.03279999999999991 t= 0.03299999999999991 t= 0.03319999999999991 t= 0.03339999999999991 t= 0.03359999999999991 t= 0.033799999999999907 t= 0.033999999999999905 t= 0.034199999999999904 t= 0.0343999999999999 t= 0.0345999999999999 t= 0.0347999999999999 t= 0.0349999999999999 t= 0.0351999999999999 t= 0.0353999999999999 t= 0.035599999999999896 t= 0.035799999999999894 t= 0.03599999999999989 t= 0.03619999999999989 t= 0.03639999999999989 t= 0.03659999999999989 t= 0.03679999999999989 t= 0.03699999999999989 t= 0.037199999999999886 t= 0.037399999999999885 t= 0.037599999999999884 t= 0.03779999999999988 t= 0.03799999999999988 t= 0.03819999999999988 t= 0.03839999999999988 t= 0.03859999999999988 t= 0.038799999999999876 t= 0.038999999999999875 t= 0.039199999999999874 t= 0.03939999999999987 t= 0.03959999999999987 t= 0.03979999999999987 t= 0.03999999999999987 t= 0.04019999999999987 t= 0.04039999999999987 t= 0.040599999999999865 t= 0.040799999999999864 t= 0.04099999999999986 t= 0.04119999999999986 t= 0.04139999999999986 t= 0.04159999999999986 t= 0.04179999999999986 t= 0.04199999999999986 t= 0.042199999999999856 t= 0.042399999999999854 t= 0.04259999999999985 t= 0.04279999999999985 t= 0.04299999999999985 t= 0.04319999999999985 t= 0.04339999999999985 t= 0.04359999999999985 t= 0.043799999999999846 t= 0.043999999999999845 t= 0.044199999999999844 t= 0.04439999999999984 t= 0.04459999999999984 t= 0.04479999999999984 t= 0.04499999999999984 t= 0.04519999999999984 t= 0.045399999999999836 t= 0.045599999999999835 t= 0.045799999999999834 t= 0.04599999999999983 t= 0.04619999999999983 t= 0.04639999999999983 t= 0.04659999999999983 t= 0.04679999999999983 t= 0.04699999999999983 t= 0.047199999999999825 t= 0.047399999999999824 t= 0.04759999999999982 t= 0.04779999999999982 t= 0.04799999999999982 t= 0.04819999999999982 t= 0.04839999999999982 t= 0.04859999999999982 t= 0.048799999999999816 t= 0.048999999999999815 t= 0.04919999999999981 t= 0.04939999999999981 t= 0.04959999999999981 t= 0.04979999999999981 t= 0.04999999999999981 t= 0.05019999999999981 t= 0.050399999999999806 t= 0.050599999999999805 t= 0.050799999999999804 t= 0.0509999999999998 t= 0.0511999999999998 t= 0.0513999999999998 t= 0.0515999999999998 t= 0.0517999999999998 t= 0.051999999999999796 t= 0.052199999999999795 t= 0.052399999999999794 t= 0.05259999999999979 t= 0.05279999999999979 t= 0.05299999999999979 t= 0.05319999999999979 t= 0.05339999999999979 t= 0.05359999999999979 t= 0.053799999999999785 t= 0.053999999999999784 t= 0.05419999999999978 t= 0.05439999999999978 t= 0.05459999999999978 t= 0.05479999999999978 t= 0.05499999999999978 t= 0.05519999999999978 t= 0.055399999999999776 t= 0.055599999999999775 t= 0.05579999999999977 t= 0.05599999999999977 t= 0.05619999999999977 t= 0.05639999999999977 t= 0.05659999999999977 t= 0.05679999999999977
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.056999999999999766 t= 0.057199999999999765
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.057399999999999764 t= 0.05759999999999976 t= 0.05779999999999976 t= 0.05799999999999976 t= 0.05819999999999976 t= 0.05839999999999976 t= 0.058599999999999756 t= 0.058799999999999755 t= 0.058999999999999754 t= 0.05919999999999975 t= 0.05939999999999975 t= 0.05959999999999975 t= 0.05979999999999975 t= 0.05999999999999975 t= 0.06019999999999975 t= 0.060399999999999746 t= 0.060599999999999744 t= 0.06079999999999974 t= 0.06099999999999974 t= 0.06119999999999974 t= 0.06139999999999974 t= 0.06159999999999974 t= 0.06179999999999974 t= 0.061999999999999736 t= 0.062199999999999735 t= 0.06239999999999973 t= 0.06259999999999974 t= 0.06279999999999974 t= 0.06299999999999975 t= 0.06319999999999976 t= 0.06339999999999976 t= 0.06359999999999977 t= 0.06379999999999977 t= 0.06399999999999978 t= 0.06419999999999979 t= 0.06439999999999979 t= 0.0645999999999998 t= 0.0647999999999998 t= 0.06499999999999981 t= 0.06519999999999981 t= 0.06539999999999982 t= 0.06559999999999983 t= 0.06579999999999983 t= 0.06599999999999984 t= 0.06619999999999984 t= 0.06639999999999985 t= 0.06659999999999985 t= 0.06679999999999986 t= 0.06699999999999987 t= 0.06719999999999987 t= 0.06739999999999988 t= 0.06759999999999988 t= 0.06779999999999989 t= 0.0679999999999999 t= 0.0681999999999999 t= 0.0683999999999999 t= 0.06859999999999991 t= 0.06879999999999992 t= 0.06899999999999992 t= 0.06919999999999993 t= 0.06939999999999993 t= 0.06959999999999994 t= 0.06979999999999995 t= 0.06999999999999995 t= 0.07019999999999996 t= 0.07039999999999996 t= 0.07059999999999997 t= 0.07079999999999997 t= 0.07099999999999998 t= 0.07119999999999999 t= 0.07139999999999999 t= 0.0716 t= 0.0718 t= 0.07200000000000001 t= 0.07220000000000001 t= 0.07240000000000002 t= 0.07260000000000003 t= 0.07280000000000003 t= 0.07300000000000004 t= 0.07320000000000004 t= 0.07340000000000005 t= 0.07360000000000005 t= 0.07380000000000006 t= 0.07400000000000007 t= 0.07420000000000007 t= 0.07440000000000008 t= 0.07460000000000008 t= 0.07480000000000009 t= 0.0750000000000001 t= 0.0752000000000001 t= 0.0754000000000001 t= 0.07560000000000011 t= 0.07580000000000012 t= 0.07600000000000012 t= 0.07620000000000013 t= 0.07640000000000013 t= 0.07660000000000014 t= 0.07680000000000015 t= 0.07700000000000015 t= 0.07720000000000016 t= 0.07740000000000016 t= 0.07760000000000017 t= 0.07780000000000017 t= 0.07800000000000018 t= 0.07820000000000019 t= 0.07840000000000019 t= 0.0786000000000002 t= 0.0788000000000002 t= 0.07900000000000021 t= 0.07920000000000021 t= 0.07940000000000022 t= 0.07960000000000023 t= 0.07980000000000023 t= 0.08000000000000024 t= 0.08020000000000024 t= 0.08040000000000025 t= 0.08060000000000025 t= 0.08080000000000026 t= 0.08100000000000027 t= 0.08120000000000027 t= 0.08140000000000028 t= 0.08160000000000028 t= 0.08180000000000029 t= 0.0820000000000003 t= 0.0822000000000003 t= 0.0824000000000003 t= 0.08260000000000031 t= 0.08280000000000032 t= 0.08300000000000032 t= 0.08320000000000033 t= 0.08340000000000033 t= 0.08360000000000034 t= 0.08380000000000035 t= 0.08400000000000035 t= 0.08420000000000036 t= 0.08440000000000036 t= 0.08460000000000037 t= 0.08480000000000038 t= 0.08500000000000038 t= 0.08520000000000039 t= 0.08540000000000039 t= 0.0856000000000004 t= 0.0858000000000004 t= 0.08600000000000041 t= 0.08620000000000042 t= 0.08640000000000042 t= 0.08660000000000043 t= 0.08680000000000043 t= 0.08700000000000044 t= 0.08720000000000044 t= 0.08740000000000045 t= 0.08760000000000046 t= 0.08780000000000046 t= 0.08800000000000047 t= 0.08820000000000047 t= 0.08840000000000048 t= 0.08860000000000048 t= 0.08880000000000049 t= 0.0890000000000005 t= 0.0892000000000005 t= 0.0894000000000005 t= 0.08960000000000051 t= 0.08980000000000052 t= 0.09000000000000052 t= 0.09020000000000053 t= 0.09040000000000054 t= 0.09060000000000054 t= 0.09080000000000055 t= 0.09100000000000055 t= 0.09120000000000056 t= 0.09140000000000056 t= 0.09160000000000057 t= 0.09180000000000058 t= 0.09200000000000058 t= 0.09220000000000059 t= 0.09240000000000059 t= 0.0926000000000006 t= 0.0928000000000006 t= 0.09300000000000061 t= 0.09320000000000062 t= 0.09340000000000062 t= 0.09360000000000063 t= 0.09380000000000063 t= 0.09400000000000064 t= 0.09420000000000064 t= 0.09440000000000065 t= 0.09460000000000066 t= 0.09480000000000066 t= 0.09500000000000067 t= 0.09520000000000067 t= 0.09540000000000068 t= 0.09560000000000068 t= 0.09580000000000069 t= 0.0960000000000007 t= 0.0962000000000007 t= 0.09640000000000071 t= 0.09660000000000071 t= 0.09680000000000072 t= 0.09700000000000072 t= 0.09720000000000073 t= 0.09740000000000074 t= 0.09760000000000074 t= 0.09780000000000075 t= 0.09800000000000075 t= 0.09820000000000076 t= 0.09840000000000076 t= 0.09860000000000077 t= 0.09880000000000078 t= 0.09900000000000078 t= 0.09920000000000079 t= 0.0994000000000008 t= 0.0996000000000008 t= 0.0998000000000008 t= 0.10000000000000081 t= 0.10020000000000082 t= 0.10040000000000082 t= 0.10060000000000083 t= 0.10080000000000083 t= 0.10100000000000084 t= 0.10120000000000084 t= 0.10140000000000085 t= 0.10160000000000086 t= 0.10180000000000086 t= 0.10200000000000087 t= 0.10220000000000087 t= 0.10240000000000088 t= 0.10260000000000088 t= 0.10280000000000089 t= 0.1030000000000009 t= 0.1032000000000009 t= 0.10340000000000091 t= 0.10360000000000091 t= 0.10380000000000092 t= 0.10400000000000093 t= 0.10420000000000093 t= 0.10440000000000094 t= 0.10460000000000094 t= 0.10480000000000095 t= 0.10500000000000095 t= 0.10520000000000096 t= 0.10540000000000097 t= 0.10560000000000097 t= 0.10580000000000098 t= 0.10600000000000098 t= 0.10620000000000099 t= 0.106400000000001 t= 0.106600000000001 t= 0.106800000000001 t= 0.10700000000000101 t= 0.10720000000000102 t= 0.10740000000000102 t= 0.10760000000000103 t= 0.10780000000000103 t= 0.10800000000000104 t= 0.10820000000000105 t= 0.10840000000000105 t= 0.10860000000000106 t= 0.10880000000000106 t= 0.10900000000000107 t= 0.10920000000000107 t= 0.10940000000000108 t= 0.10960000000000109 t= 0.10980000000000109 t= 0.1100000000000011 t= 0.1102000000000011 t= 0.11040000000000111 t= 0.11060000000000111 t= 0.11080000000000112 t= 0.11100000000000113 t= 0.11120000000000113 t= 0.11140000000000114 t= 0.11160000000000114 t= 0.11180000000000115 t= 0.11200000000000115 t= 0.11220000000000116 t= 0.11240000000000117 t= 0.11260000000000117 t= 0.11280000000000118 t= 0.11300000000000118 t= 0.11320000000000119 t= 0.1134000000000012 t= 0.1136000000000012 t= 0.1138000000000012 t= 0.11400000000000121 t= 0.11420000000000122 t= 0.11440000000000122 t= 0.11460000000000123 t= 0.11480000000000123 t= 0.11500000000000124 t= 0.11520000000000125 t= 0.11540000000000125 t= 0.11560000000000126 t= 0.11580000000000126 t= 0.11600000000000127 t= 0.11620000000000127 t= 0.11640000000000128 t= 0.11660000000000129 t= 0.11680000000000129 t= 0.1170000000000013 t= 0.1172000000000013 t= 0.11740000000000131 t= 0.11760000000000131 t= 0.11780000000000132 t= 0.11800000000000133 t= 0.11820000000000133 t= 0.11840000000000134 t= 0.11860000000000134 t= 0.11880000000000135 t= 0.11900000000000135 t= 0.11920000000000136 t= 0.11940000000000137 t= 0.11960000000000137 t= 0.11980000000000138 t= 0.12000000000000138 t= 0.12020000000000139 t= 0.1204000000000014 t= 0.1206000000000014 t= 0.1208000000000014 t= 0.12100000000000141 t= 0.12120000000000142 t= 0.12140000000000142 t= 0.12160000000000143 t= 0.12180000000000143 t= 0.12200000000000144 t= 0.12220000000000145 t= 0.12240000000000145 t= 0.12260000000000146 t= 0.12280000000000146 t= 0.12300000000000147 t= 0.12320000000000147 t= 0.12340000000000148 t= 0.12360000000000149 t= 0.12380000000000149 t= 0.1240000000000015 t= 0.1242000000000015 t= 0.12440000000000151 t= 0.12460000000000152 t= 0.12480000000000152 t= 0.12500000000000153 t= 0.12520000000000153 t= 0.12540000000000154 t= 0.12560000000000154 t= 0.12580000000000155 t= 0.12600000000000156 t= 0.12620000000000156 t= 0.12640000000000157 t= 0.12660000000000157 t= 0.12680000000000158 t= 0.12700000000000158 t= 0.1272000000000016 t= 0.1274000000000016 t= 0.1276000000000016 t= 0.1278000000000016 t= 0.1280000000000016 t= 0.12820000000000162 t= 0.12840000000000162 t= 0.12860000000000163 t= 0.12880000000000164 t= 0.12900000000000164 t= 0.12920000000000165 t= 0.12940000000000165 t= 0.12960000000000166 t= 0.12980000000000166 t= 0.13000000000000167 t= 0.13020000000000168 t= 0.13040000000000168 t= 0.1306000000000017 t= 0.1308000000000017 t= 0.1310000000000017 t= 0.1312000000000017 t= 0.1314000000000017 t= 0.13160000000000172 t= 0.13180000000000172 t= 0.13200000000000173 t= 0.13220000000000173 t= 0.13240000000000174 t= 0.13260000000000174 t= 0.13280000000000175 t= 0.13300000000000176 t= 0.13320000000000176 t= 0.13340000000000177 t= 0.13360000000000177 t= 0.13380000000000178 t= 0.13400000000000178 t= 0.1342000000000018 t= 0.1344000000000018 t= 0.1346000000000018 t= 0.1348000000000018 t= 0.1350000000000018 t= 0.13520000000000182 t= 0.13540000000000182 t= 0.13560000000000183 t= 0.13580000000000184 t= 0.13600000000000184 t= 0.13620000000000185 t= 0.13640000000000185 t= 0.13660000000000186 t= 0.13680000000000186 t= 0.13700000000000187 t= 0.13720000000000188 t= 0.13740000000000188 t= 0.1376000000000019 t= 0.1378000000000019 t= 0.1380000000000019 t= 0.1382000000000019 t= 0.1384000000000019 t= 0.13860000000000192 t= 0.13880000000000192 t= 0.13900000000000193 t= 0.13920000000000193 t= 0.13940000000000194 t= 0.13960000000000194 t= 0.13980000000000195 t= 0.14000000000000196 t= 0.14020000000000196 t= 0.14040000000000197 t= 0.14060000000000197 t= 0.14080000000000198 t= 0.14100000000000198 t= 0.141200000000002 t= 0.141400000000002 t= 0.141600000000002 t= 0.141800000000002 t= 0.142000000000002 t= 0.14220000000000202 t= 0.14240000000000202 t= 0.14260000000000203 t= 0.14280000000000204 t= 0.14300000000000204 t= 0.14320000000000205 t= 0.14340000000000205 t= 0.14360000000000206 t= 0.14380000000000207 t= 0.14400000000000207 t= 0.14420000000000208 t= 0.14440000000000208 t= 0.1446000000000021 t= 0.1448000000000021 t= 0.1450000000000021 t= 0.1452000000000021 t= 0.1454000000000021 t= 0.14560000000000212 t= 0.14580000000000212 t= 0.14600000000000213 t= 0.14620000000000213 t= 0.14640000000000214 t= 0.14660000000000215 t= 0.14680000000000215 t= 0.14700000000000216 t= 0.14720000000000216 t= 0.14740000000000217 t= 0.14760000000000217 t= 0.14780000000000218 t= 0.14800000000000219 t= 0.1482000000000022 t= 0.1484000000000022 t= 0.1486000000000022 t= 0.1488000000000022 t= 0.14900000000000221 t= 0.14920000000000222 t= 0.14940000000000223 t= 0.14960000000000223 t= 0.14980000000000224 t= 0.15000000000000224 t= 0.15020000000000225 t= 0.15040000000000225 t= 0.15060000000000226 t= 0.15080000000000227 t= 0.15100000000000227 t= 0.15120000000000228 t= 0.15140000000000228 t= 0.1516000000000023 t= 0.1518000000000023 t= 0.1520000000000023 t= 0.1522000000000023 t= 0.1524000000000023 t= 0.15260000000000232 t= 0.15280000000000232 t= 0.15300000000000233 t= 0.15320000000000233 t= 0.15340000000000234 t= 0.15360000000000235 t= 0.15380000000000235 t= 0.15400000000000236 t= 0.15420000000000236 t= 0.15440000000000237 t= 0.15460000000000237 t= 0.15480000000000238 t= 0.15500000000000239 t= 0.1552000000000024 t= 0.1554000000000024 t= 0.1556000000000024 t= 0.1558000000000024 t= 0.15600000000000241 t= 0.15620000000000242 t= 0.15640000000000243 t= 0.15660000000000243 t= 0.15680000000000244 t= 0.15700000000000244 t= 0.15720000000000245 t= 0.15740000000000245 t= 0.15760000000000246 t= 0.15780000000000247 t= 0.15800000000000247 t= 0.15820000000000248 t= 0.15840000000000248 t= 0.1586000000000025 t= 0.1588000000000025 t= 0.1590000000000025 t= 0.1592000000000025 t= 0.1594000000000025 t= 0.15960000000000252 t= 0.15980000000000252 t= 0.16000000000000253 t= 0.16020000000000253 t= 0.16040000000000254 t= 0.16060000000000255 t= 0.16080000000000255 t= 0.16100000000000256 t= 0.16120000000000256 t= 0.16140000000000257 t= 0.16160000000000257 t= 0.16180000000000258 t= 0.1620000000000026 t= 0.1622000000000026 t= 0.1624000000000026 t= 0.1626000000000026 t= 0.1628000000000026 t= 0.16300000000000262 t= 0.16320000000000262 t= 0.16340000000000263 t= 0.16360000000000263 t= 0.16380000000000264 t= 0.16400000000000264 t= 0.16420000000000265 t= 0.16440000000000266 t= 0.16460000000000266 t= 0.16480000000000267 t= 0.16500000000000267 t= 0.16520000000000268 t= 0.16540000000000268 t= 0.1656000000000027 t= 0.1658000000000027 t= 0.1660000000000027 t= 0.1662000000000027 t= 0.1664000000000027 t= 0.16660000000000272 t= 0.16680000000000272 t= 0.16700000000000273 t= 0.16720000000000274 t= 0.16740000000000274 t= 0.16760000000000275 t= 0.16780000000000275 t= 0.16800000000000276 t= 0.16820000000000276 t= 0.16840000000000277 t= 0.16860000000000278 t= 0.16880000000000278 t= 0.1690000000000028 t= 0.1692000000000028 t= 0.1694000000000028 t= 0.1696000000000028 t= 0.1698000000000028 t= 0.17000000000000282 t= 0.17020000000000282 t= 0.17040000000000283 t= 0.17060000000000283 t= 0.17080000000000284 t= 0.17100000000000284 t= 0.17120000000000285 t= 0.17140000000000286 t= 0.17160000000000286 t= 0.17180000000000287 t= 0.17200000000000287 t= 0.17220000000000288 t= 0.17240000000000288 t= 0.1726000000000029 t= 0.1728000000000029 t= 0.1730000000000029 t= 0.1732000000000029 t= 0.1734000000000029 t= 0.17360000000000292 t= 0.17380000000000292 t= 0.17400000000000293 t= 0.17420000000000294 t= 0.17440000000000294 t= 0.17460000000000295 t= 0.17480000000000295 t= 0.17500000000000296 t= 0.17520000000000296 t= 0.17540000000000297 t= 0.17560000000000298 t= 0.17580000000000298 t= 0.176000000000003 t= 0.176200000000003 t= 0.176400000000003 t= 0.176600000000003 t= 0.176800000000003 t= 0.17700000000000302 t= 0.17720000000000302 t= 0.17740000000000303 t= 0.17760000000000303 t= 0.17780000000000304 t= 0.17800000000000304 t= 0.17820000000000305 t= 0.17840000000000306 t= 0.17860000000000306 t= 0.17880000000000307 t= 0.17900000000000307 t= 0.17920000000000308 t= 0.17940000000000308 t= 0.1796000000000031 t= 0.1798000000000031 t= 0.1800000000000031 t= 0.1802000000000031 t= 0.1804000000000031 t= 0.18060000000000312 t= 0.18080000000000312 t= 0.18100000000000313 t= 0.18120000000000314 t= 0.18140000000000314 t= 0.18160000000000315 t= 0.18180000000000315 t= 0.18200000000000316 t= 0.18220000000000316 t= 0.18240000000000317 t= 0.18260000000000318 t= 0.18280000000000318 t= 0.1830000000000032 t= 0.1832000000000032 t= 0.1834000000000032 t= 0.1836000000000032 t= 0.1838000000000032 t= 0.18400000000000322 t= 0.18420000000000322 t= 0.18440000000000323 t= 0.18460000000000323 t= 0.18480000000000324 t= 0.18500000000000325 t= 0.18520000000000325 t= 0.18540000000000326 t= 0.18560000000000326 t= 0.18580000000000327 t= 0.18600000000000327 t= 0.18620000000000328 t= 0.18640000000000329 t= 0.1866000000000033 t= 0.1868000000000033 t= 0.1870000000000033 t= 0.1872000000000033 t= 0.18740000000000331 t= 0.18760000000000332 t= 0.18780000000000333 t= 0.18800000000000333 t= 0.18820000000000334 t= 0.18840000000000334 t= 0.18860000000000335 t= 0.18880000000000335 t= 0.18900000000000336 t= 0.18920000000000337 t= 0.18940000000000337 t= 0.18960000000000338 t= 0.18980000000000338 t= 0.1900000000000034 t= 0.1902000000000034 t= 0.1904000000000034 t= 0.1906000000000034 t= 0.1908000000000034 t= 0.19100000000000342 t= 0.19120000000000342 t= 0.19140000000000343 t= 0.19160000000000343 t= 0.19180000000000344 t= 0.19200000000000345 t= 0.19220000000000345 t= 0.19240000000000346 t= 0.19260000000000346 t= 0.19280000000000347 t= 0.19300000000000347 t= 0.19320000000000348 t= 0.19340000000000349 t= 0.1936000000000035 t= 0.1938000000000035 t= 0.1940000000000035 t= 0.1942000000000035 t= 0.19440000000000351 t= 0.19460000000000352 t= 0.19480000000000353 t= 0.19500000000000353 t= 0.19520000000000354 t= 0.19540000000000354 t= 0.19560000000000355 t= 0.19580000000000355 t= 0.19600000000000356 t= 0.19620000000000357 t= 0.19640000000000357 t= 0.19660000000000358 t= 0.19680000000000358 t= 0.1970000000000036 t= 0.1972000000000036 t= 0.1974000000000036 t= 0.1976000000000036 t= 0.1978000000000036 t= 0.19800000000000362 t= 0.19820000000000362 t= 0.19840000000000363 t= 0.19860000000000363 t= 0.19880000000000364 t= 0.19900000000000365 t= 0.19920000000000365 t= 0.19940000000000366 t= 0.19960000000000366 t= 0.19980000000000367 t= 0.20000000000000367 t= 0.20020000000000368 t= 0.2004000000000037 t= 0.2006000000000037 t= 0.2008000000000037 t= 0.2010000000000037 t= 0.2012000000000037 t= 0.20140000000000371 t= 0.20160000000000372 t= 0.20180000000000373 t= 0.20200000000000373 t= 0.20220000000000374 t= 0.20240000000000374 t= 0.20260000000000375 t= 0.20280000000000376 t= 0.20300000000000376 t= 0.20320000000000377 t= 0.20340000000000377 t= 0.20360000000000378 t= 0.20380000000000378 t= 0.2040000000000038 t= 0.2042000000000038 t= 0.2044000000000038 t= 0.2046000000000038 t= 0.2048000000000038 t= 0.20500000000000382 t= 0.20520000000000382 t= 0.20540000000000383 t= 0.20560000000000384 t= 0.20580000000000384 t= 0.20600000000000385 t= 0.20620000000000385 t= 0.20640000000000386 t= 0.20660000000000386 t= 0.20680000000000387 t= 0.20700000000000388 t= 0.20720000000000388 t= 0.2074000000000039 t= 0.2076000000000039 t= 0.2078000000000039 t= 0.2080000000000039 t= 0.2082000000000039 t= 0.20840000000000392 t= 0.20860000000000392 t= 0.20880000000000393 t= 0.20900000000000393 t= 0.20920000000000394 t= 0.20940000000000394 t= 0.20960000000000395 t= 0.20980000000000396 t= 0.21000000000000396 t= 0.21020000000000397 t= 0.21040000000000397 t= 0.21060000000000398 t= 0.21080000000000398 t= 0.211000000000004 t= 0.211200000000004 t= 0.211400000000004 t= 0.211600000000004 t= 0.211800000000004 t= 0.21200000000000402 t= 0.21220000000000402 t= 0.21240000000000403 t= 0.21260000000000404 t= 0.21280000000000404 t= 0.21300000000000405 t= 0.21320000000000405 t= 0.21340000000000406 t= 0.21360000000000406 t= 0.21380000000000407 t= 0.21400000000000408 t= 0.21420000000000408 t= 0.2144000000000041 t= 0.2146000000000041 t= 0.2148000000000041 t= 0.2150000000000041 t= 0.2152000000000041 t= 0.21540000000000412 t= 0.21560000000000412 t= 0.21580000000000413 t= 0.21600000000000413 t= 0.21620000000000414 t= 0.21640000000000414 t= 0.21660000000000415 t= 0.21680000000000416 t= 0.21700000000000416 t= 0.21720000000000417 t= 0.21740000000000417 t= 0.21760000000000418 t= 0.21780000000000418 t= 0.2180000000000042 t= 0.2182000000000042 t= 0.2184000000000042 t= 0.2186000000000042 t= 0.2188000000000042 t= 0.21900000000000422 t= 0.21920000000000422 t= 0.21940000000000423 t= 0.21960000000000424 t= 0.21980000000000424 t= 0.22000000000000425 t= 0.22020000000000425 t= 0.22040000000000426 t= 0.22060000000000426 t= 0.22080000000000427 t= 0.22100000000000428 t= 0.22120000000000428 t= 0.2214000000000043 t= 0.2216000000000043 t= 0.2218000000000043 t= 0.2220000000000043 t= 0.2222000000000043 t= 0.22240000000000432 t= 0.22260000000000432 t= 0.22280000000000433 t= 0.22300000000000433 t= 0.22320000000000434 t= 0.22340000000000435 t= 0.22360000000000435 t= 0.22380000000000436 t= 0.22400000000000436 t= 0.22420000000000437 t= 0.22440000000000437 t= 0.22460000000000438 t= 0.22480000000000439 t= 0.2250000000000044 t= 0.2252000000000044 t= 0.2254000000000044 t= 0.2256000000000044 t= 0.2258000000000044 t= 0.22600000000000442 t= 0.22620000000000443 t= 0.22640000000000443 t= 0.22660000000000444 t= 0.22680000000000444 t= 0.22700000000000445 t= 0.22720000000000445 t= 0.22740000000000446 t= 0.22760000000000447 t= 0.22780000000000447 t= 0.22800000000000448 t= 0.22820000000000448 t= 0.2284000000000045 t= 0.2286000000000045 t= 0.2288000000000045 t= 0.2290000000000045 t= 0.2292000000000045 t= 0.22940000000000452 t= 0.22960000000000452 t= 0.22980000000000453 t= 0.23000000000000453 t= 0.23020000000000454 t= 0.23040000000000455 t= 0.23060000000000455 t= 0.23080000000000456 t= 0.23100000000000456 t= 0.23120000000000457 t= 0.23140000000000457 t= 0.23160000000000458 t= 0.23180000000000459 t= 0.2320000000000046 t= 0.2322000000000046 t= 0.2324000000000046 t= 0.2326000000000046 t= 0.23280000000000461 t= 0.23300000000000462 t= 0.23320000000000463 t= 0.23340000000000463 t= 0.23360000000000464 t= 0.23380000000000464 t= 0.23400000000000465 t= 0.23420000000000465 t= 0.23440000000000466 t= 0.23460000000000467 t= 0.23480000000000467 t= 0.23500000000000468 t= 0.23520000000000468 t= 0.2354000000000047 t= 0.2356000000000047 t= 0.2358000000000047 t= 0.2360000000000047 t= 0.2362000000000047 t= 0.23640000000000472 t= 0.23660000000000472 t= 0.23680000000000473 t= 0.23700000000000473 t= 0.23720000000000474 t= 0.23740000000000475 t= 0.23760000000000475 t= 0.23780000000000476 t= 0.23800000000000476 t= 0.23820000000000477 t= 0.23840000000000477 t= 0.23860000000000478 t= 0.2388000000000048 t= 0.2390000000000048 t= 0.2392000000000048 t= 0.2394000000000048 t= 0.2396000000000048 t= 0.23980000000000481 t= 0.24000000000000482 t= 0.24020000000000483 t= 0.24040000000000483 t= 0.24060000000000484 t= 0.24080000000000484 t= 0.24100000000000485 t= 0.24120000000000485 t= 0.24140000000000486 t= 0.24160000000000487 t= 0.24180000000000487 t= 0.24200000000000488 t= 0.24220000000000488 t= 0.2424000000000049 t= 0.2426000000000049 t= 0.2428000000000049 t= 0.2430000000000049 t= 0.2432000000000049 t= 0.24340000000000492 t= 0.24360000000000492 t= 0.24380000000000493 t= 0.24400000000000494 t= 0.24420000000000494 t= 0.24440000000000495 t= 0.24460000000000495 t= 0.24480000000000496 t= 0.24500000000000496 t= 0.24520000000000497 t= 0.24540000000000498 t= 0.24560000000000498 t= 0.245800000000005 t= 0.246000000000005 t= 0.246200000000005 t= 0.246400000000005 t= 0.246600000000005 t= 0.24680000000000502 t= 0.24700000000000502 t= 0.24720000000000503 t= 0.24740000000000503 t= 0.24760000000000504 t= 0.24780000000000504 t= 0.24800000000000505 t= 0.24820000000000506 t= 0.24840000000000506 t= 0.24860000000000507 t= 0.24880000000000507 t= 0.24900000000000508 t= 0.24920000000000508 t= 0.2494000000000051 t= 0.2496000000000051 t= 0.2498000000000051 t= 0.2500000000000051 t= 0.2502000000000051 t= 0.25040000000000506 t= 0.25060000000000504 t= 0.250800000000005 t= 0.251000000000005 t= 0.251200000000005 t= 0.25140000000000495 t= 0.25160000000000493 t= 0.2518000000000049 t= 0.2520000000000049 t= 0.25220000000000486 t= 0.25240000000000484 t= 0.2526000000000048 t= 0.2528000000000048 t= 0.2530000000000048 t= 0.25320000000000475 t= 0.25340000000000473 t= 0.2536000000000047 t= 0.2538000000000047 t= 0.25400000000000467 t= 0.25420000000000464 t= 0.2544000000000046 t= 0.2546000000000046 t= 0.2548000000000046 t= 0.25500000000000456 t= 0.25520000000000453 t= 0.2554000000000045 t= 0.2556000000000045 t= 0.25580000000000447 t= 0.25600000000000445 t= 0.2562000000000044 t= 0.2564000000000044 t= 0.2566000000000044 t= 0.25680000000000436 t= 0.25700000000000434 t= 0.2572000000000043 t= 0.2574000000000043 t= 0.25760000000000427 t= 0.25780000000000425 t= 0.2580000000000042 t= 0.2582000000000042 t= 0.2584000000000042 t= 0.25860000000000416 t= 0.25880000000000414 t= 0.2590000000000041 t= 0.2592000000000041 t= 0.25940000000000407 t= 0.25960000000000405 t= 0.259800000000004 t= 0.260000000000004 t= 0.260200000000004 t= 0.26040000000000396 t= 0.26060000000000394 t= 0.2608000000000039 t= 0.2610000000000039 t= 0.2612000000000039 t= 0.26140000000000385 t= 0.26160000000000383 t= 0.2618000000000038 t= 0.2620000000000038 t= 0.26220000000000376 t= 0.26240000000000374 t= 0.2626000000000037 t= 0.2628000000000037 t= 0.2630000000000037 t= 0.26320000000000365 t= 0.26340000000000363 t= 0.2636000000000036 t= 0.2638000000000036 t= 0.26400000000000357 t= 0.26420000000000354 t= 0.2644000000000035 t= 0.2646000000000035 t= 0.2648000000000035 t= 0.26500000000000346 t= 0.26520000000000343 t= 0.2654000000000034 t= 0.2656000000000034 t= 0.26580000000000337 t= 0.26600000000000334 t= 0.2662000000000033 t= 0.2664000000000033 t= 0.2666000000000033 t= 0.26680000000000326 t= 0.26700000000000323 t= 0.2672000000000032 t= 0.2674000000000032 t= 0.26760000000000317 t= 0.26780000000000315 t= 0.2680000000000031 t= 0.2682000000000031 t= 0.2684000000000031 t= 0.26860000000000306 t= 0.26880000000000304 t= 0.269000000000003 t= 0.269200000000003 t= 0.26940000000000297 t= 0.26960000000000295 t= 0.2698000000000029 t= 0.2700000000000029 t= 0.2702000000000029 t= 0.27040000000000286 t= 0.27060000000000284 t= 0.2708000000000028 t= 0.2710000000000028 t= 0.27120000000000277 t= 0.27140000000000275 t= 0.27160000000000273 t= 0.2718000000000027 t= 0.2720000000000027 t= 0.27220000000000266 t= 0.27240000000000264 t= 0.2726000000000026 t= 0.2728000000000026 t= 0.2730000000000026 t= 0.27320000000000255 t= 0.27340000000000253 t= 0.2736000000000025 t= 0.2738000000000025 t= 0.27400000000000246 t= 0.27420000000000244 t= 0.2744000000000024 t= 0.2746000000000024 t= 0.2748000000000024 t= 0.27500000000000235 t= 0.27520000000000233 t= 0.2754000000000023 t= 0.2756000000000023 t= 0.27580000000000227 t= 0.27600000000000224 t= 0.2762000000000022 t= 0.2764000000000022 t= 0.2766000000000022 t= 0.27680000000000216 t= 0.27700000000000213 t= 0.2772000000000021 t= 0.2774000000000021 t= 0.27760000000000207 t= 0.27780000000000205 t= 0.278000000000002 t= 0.278200000000002 t= 0.278400000000002 t= 0.27860000000000196 t= 0.27880000000000194 t= 0.2790000000000019 t= 0.2792000000000019 t= 0.27940000000000187 t= 0.27960000000000185 t= 0.2798000000000018 t= 0.2800000000000018 t= 0.2802000000000018 t= 0.28040000000000176 t= 0.28060000000000174 t= 0.2808000000000017 t= 0.2810000000000017 t= 0.28120000000000167 t= 0.28140000000000165 t= 0.2816000000000016 t= 0.2818000000000016 t= 0.2820000000000016 t= 0.28220000000000156 t= 0.28240000000000154 t= 0.2826000000000015 t= 0.2828000000000015 t= 0.2830000000000015 t= 0.28320000000000145 t= 0.28340000000000143 t= 0.2836000000000014 t= 0.2838000000000014 t= 0.28400000000000136 t= 0.28420000000000134 t= 0.2844000000000013 t= 0.2846000000000013 t= 0.2848000000000013 t= 0.28500000000000125 t= 0.28520000000000123 t= 0.2854000000000012 t= 0.2856000000000012 t= 0.28580000000000116 t= 0.28600000000000114 t= 0.2862000000000011 t= 0.2864000000000011 t= 0.2866000000000011 t= 0.28680000000000105 t= 0.28700000000000103 t= 0.287200000000001 t= 0.287400000000001 t= 0.28760000000000097 t= 0.28780000000000094 t= 0.2880000000000009 t= 0.2882000000000009 t= 0.2884000000000009 t= 0.28860000000000086 t= 0.28880000000000083 t= 0.2890000000000008 t= 0.2892000000000008 t= 0.28940000000000077 t= 0.28960000000000075 t= 0.2898000000000007 t= 0.2900000000000007 t= 0.2902000000000007 t= 0.29040000000000066 t= 0.29060000000000064 t= 0.2908000000000006 t= 0.2910000000000006 t= 0.29120000000000057 t= 0.29140000000000055 t= 0.2916000000000005 t= 0.2918000000000005 t= 0.2920000000000005 t= 0.29220000000000046 t= 0.29240000000000044 t= 0.2926000000000004 t= 0.2928000000000004 t= 0.29300000000000037 t= 0.29320000000000035 t= 0.2934000000000003 t= 0.2936000000000003 t= 0.2938000000000003 t= 0.29400000000000026 t= 0.29420000000000024 t= 0.2944000000000002 t= 0.2946000000000002 t= 0.2948000000000002 t= 0.29500000000000015 t= 0.29520000000000013 t= 0.2954000000000001 t= 0.2956000000000001 t= 0.29580000000000006 t= 0.29600000000000004 t= 0.2962 t= 0.2964 t= 0.2966 t= 0.29679999999999995 t= 0.29699999999999993 t= 0.2971999999999999 t= 0.2973999999999999 t= 0.29759999999999986 t= 0.29779999999999984 t= 0.2979999999999998 t= 0.2981999999999998 t= 0.2983999999999998 t= 0.29859999999999975 t= 0.29879999999999973 t= 0.2989999999999997 t= 0.2991999999999997 t= 0.29939999999999967 t= 0.29959999999999964 t= 0.2997999999999996 t= 0.2999999999999996 t= 0.3001999999999996 t= 0.30039999999999956 t= 0.30059999999999953 t= 0.3007999999999995 t= 0.3009999999999995 t= 0.30119999999999947 t= 0.30139999999999945 t= 0.3015999999999994 t= 0.3017999999999994 t= 0.3019999999999994 t= 0.30219999999999936 t= 0.30239999999999934 t= 0.3025999999999993 t= 0.3027999999999993 t= 0.30299999999999927 t= 0.30319999999999925 t= 0.3033999999999992 t= 0.3035999999999992 t= 0.3037999999999992 t= 0.30399999999999916 t= 0.30419999999999914 t= 0.3043999999999991 t= 0.3045999999999991 t= 0.30479999999999907 t= 0.30499999999999905 t= 0.305199999999999 t= 0.305399999999999 t= 0.305599999999999 t= 0.30579999999999896 t= 0.30599999999999894 t= 0.3061999999999989 t= 0.3063999999999989 t= 0.3065999999999989 t= 0.30679999999999885 t= 0.30699999999999883 t= 0.3071999999999988 t= 0.3073999999999988 t= 0.30759999999999876 t= 0.30779999999999874 t= 0.3079999999999987 t= 0.3081999999999987 t= 0.3083999999999987 t= 0.30859999999999865 t= 0.30879999999999863 t= 0.3089999999999986 t= 0.3091999999999986 t= 0.30939999999999857 t= 0.30959999999999854 t= 0.3097999999999985 t= 0.3099999999999985 t= 0.3101999999999985 t= 0.31039999999999845 t= 0.31059999999999843 t= 0.3107999999999984 t= 0.3109999999999984 t= 0.31119999999999837 t= 0.31139999999999834 t= 0.3115999999999983 t= 0.3117999999999983 t= 0.3119999999999983 t= 0.31219999999999826 t= 0.31239999999999823 t= 0.3125999999999982 t= 0.3127999999999982 t= 0.31299999999999817 t= 0.31319999999999815 t= 0.3133999999999981 t= 0.3135999999999981 t= 0.3137999999999981 t= 0.31399999999999806 t= 0.31419999999999804 t= 0.314399999999998 t= 0.314599999999998 t= 0.31479999999999797 t= 0.31499999999999795 t= 0.3151999999999979 t= 0.3153999999999979 t= 0.3155999999999979 t= 0.31579999999999786 t= 0.31599999999999784 t= 0.3161999999999978 t= 0.3163999999999978 t= 0.31659999999999777 t= 0.31679999999999775 t= 0.31699999999999773 t= 0.3171999999999977 t= 0.3173999999999977 t= 0.31759999999999766 t= 0.31779999999999764 t= 0.3179999999999976 t= 0.3181999999999976 t= 0.3183999999999976 t= 0.31859999999999755 t= 0.31879999999999753 t= 0.3189999999999975 t= 0.3191999999999975 t= 0.31939999999999746 t= 0.31959999999999744 t= 0.3197999999999974 t= 0.3199999999999974 t= 0.3201999999999974 t= 0.32039999999999735 t= 0.32059999999999733 t= 0.3207999999999973 t= 0.3209999999999973 t= 0.32119999999999727 t= 0.32139999999999724 t= 0.3215999999999972 t= 0.3217999999999972 t= 0.3219999999999972 t= 0.32219999999999716 t= 0.32239999999999713 t= 0.3225999999999971 t= 0.3227999999999971 t= 0.32299999999999707 t= 0.32319999999999705 t= 0.323399999999997 t= 0.323599999999997 t= 0.323799999999997 t= 0.32399999999999696 t= 0.32419999999999694 t= 0.3243999999999969 t= 0.3245999999999969 t= 0.32479999999999687 t= 0.32499999999999685 t= 0.3251999999999968 t= 0.3253999999999968 t= 0.3255999999999968 t= 0.32579999999999676 t= 0.32599999999999674 t= 0.3261999999999967 t= 0.3263999999999967 t= 0.32659999999999667 t= 0.32679999999999665 t= 0.3269999999999966 t= 0.3271999999999966 t= 0.3273999999999966 t= 0.32759999999999656 t= 0.32779999999999654 t= 0.3279999999999965 t= 0.3281999999999965 t= 0.3283999999999965 t= 0.32859999999999645 t= 0.32879999999999643 t= 0.3289999999999964 t= 0.3291999999999964 t= 0.32939999999999636 t= 0.32959999999999634 t= 0.3297999999999963 t= 0.3299999999999963 t= 0.3301999999999963 t= 0.33039999999999625 t= 0.33059999999999623 t= 0.3307999999999962 t= 0.3309999999999962 t= 0.33119999999999616 t= 0.33139999999999614 t= 0.3315999999999961 t= 0.3317999999999961 t= 0.3319999999999961 t= 0.33219999999999605 t= 0.33239999999999603 t= 0.332599999999996 t= 0.332799999999996 t= 0.33299999999999597 t= 0.33319999999999594 t= 0.3333999999999959 t= 0.3335999999999959 t= 0.3337999999999959 t= 0.33399999999999586 t= 0.33419999999999583 t= 0.3343999999999958 t= 0.3345999999999958 t= 0.33479999999999577 t= 0.33499999999999575 t= 0.3351999999999957 t= 0.3353999999999957 t= 0.3355999999999957 t= 0.33579999999999566 t= 0.33599999999999564 t= 0.3361999999999956 t= 0.3363999999999956 t= 0.33659999999999557 t= 0.33679999999999555 t= 0.3369999999999955 t= 0.3371999999999955 t= 0.3373999999999955 t= 0.33759999999999546 t= 0.33779999999999544 t= 0.3379999999999954 t= 0.3381999999999954 t= 0.33839999999999537 t= 0.33859999999999535 t= 0.3387999999999953 t= 0.3389999999999953 t= 0.3391999999999953 t= 0.33939999999999526 t= 0.33959999999999524 t= 0.3397999999999952 t= 0.3399999999999952 t= 0.3401999999999952 t= 0.34039999999999515 t= 0.34059999999999513 t= 0.3407999999999951 t= 0.3409999999999951 t= 0.34119999999999506 t= 0.34139999999999504 t= 0.341599999999995 t= 0.341799999999995 t= 0.341999999999995 t= 0.34219999999999495 t= 0.34239999999999493 t= 0.3425999999999949 t= 0.3427999999999949 t= 0.34299999999999486 t= 0.34319999999999484 t= 0.3433999999999948 t= 0.3435999999999948 t= 0.3437999999999948 t= 0.34399999999999475 t= 0.34419999999999473 t= 0.3443999999999947 t= 0.3445999999999947 t= 0.34479999999999467 t= 0.34499999999999464 t= 0.3451999999999946 t= 0.3453999999999946 t= 0.3455999999999946 t= 0.34579999999999456 t= 0.34599999999999453 t= 0.3461999999999945 t= 0.3463999999999945 t= 0.34659999999999447 t= 0.34679999999999445 t= 0.3469999999999944 t= 0.3471999999999944 t= 0.3473999999999944 t= 0.34759999999999436 t= 0.34779999999999434 t= 0.3479999999999943 t= 0.3481999999999943 t= 0.34839999999999427 t= 0.34859999999999425 t= 0.3487999999999942 t= 0.3489999999999942 t= 0.3491999999999942 t= 0.34939999999999416 t= 0.34959999999999414 t= 0.3497999999999941 t= 0.3499999999999941 t= 0.35019999999999407 t= 0.35039999999999405 t= 0.350599999999994 t= 0.350799999999994 t= 0.350999999999994 t= 0.35119999999999396 t= 0.35139999999999394
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.3515999999999939 t= 0.3517999999999939 t= 0.3519999999999939 t= 0.35219999999999385 t= 0.35239999999999383 t= 0.3525999999999938 t= 0.3527999999999938 t= 0.35299999999999376 t= 0.35319999999999374 t= 0.3533999999999937 t= 0.3535999999999937 t= 0.3537999999999937 t= 0.35399999999999365 t= 0.35419999999999363 t= 0.3543999999999936 t= 0.3545999999999936
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.35479999999999356 t= 0.35499999999999354 t= 0.3551999999999935 t= 0.3553999999999935 t= 0.3555999999999935 t= 0.35579999999999345 t= 0.35599999999999343 t= 0.3561999999999934 t= 0.3563999999999934 t= 0.35659999999999337 t= 0.35679999999999334 t= 0.3569999999999933 t= 0.3571999999999933 t= 0.3573999999999933 t= 0.35759999999999326 t= 0.35779999999999323 t= 0.3579999999999932 t= 0.3581999999999932 t= 0.35839999999999317 t= 0.35859999999999315 t= 0.3587999999999931 t= 0.3589999999999931 t= 0.3591999999999931 t= 0.35939999999999306 t= 0.35959999999999304 t= 0.359799999999993 t= 0.359999999999993 t= 0.36019999999999297 t= 0.36039999999999295 t= 0.3605999999999929 t= 0.3607999999999929 t= 0.3609999999999929 t= 0.36119999999999286 t= 0.36139999999999284 t= 0.3615999999999928 t= 0.3617999999999928 t= 0.36199999999999277 t= 0.36219999999999275 t= 0.36239999999999273 t= 0.3625999999999927 t= 0.3627999999999927 t= 0.36299999999999266 t= 0.36319999999999264 t= 0.3633999999999926 t= 0.3635999999999926 t= 0.3637999999999926 t= 0.36399999999999255 t= 0.36419999999999253 t= 0.3643999999999925 t= 0.3645999999999925 t= 0.36479999999999246 t= 0.36499999999999244 t= 0.3651999999999924 t= 0.3653999999999924 t= 0.3655999999999924 t= 0.36579999999999235 t= 0.36599999999999233 t= 0.3661999999999923 t= 0.3663999999999923 t= 0.36659999999999227 t= 0.36679999999999224 t= 0.3669999999999922 t= 0.3671999999999922 t= 0.3673999999999922 t= 0.36759999999999216 t= 0.36779999999999213 t= 0.3679999999999921 t= 0.3681999999999921 t= 0.36839999999999207 t= 0.36859999999999205 t= 0.368799999999992 t= 0.368999999999992 t= 0.369199999999992 t= 0.36939999999999196 t= 0.36959999999999193 t= 0.3697999999999919 t= 0.3699999999999919 t= 0.37019999999999187 t= 0.37039999999999185 t= 0.3705999999999918 t= 0.3707999999999918 t= 0.3709999999999918 t= 0.37119999999999176 t= 0.37139999999999174 t= 0.3715999999999917 t= 0.3717999999999917 t= 0.37199999999999167 t= 0.37219999999999165 t= 0.3723999999999916 t= 0.3725999999999916 t= 0.3727999999999916 t= 0.37299999999999156 t= 0.37319999999999154 t= 0.3733999999999915 t= 0.3735999999999915 t= 0.3737999999999915 t= 0.37399999999999145 t= 0.37419999999999143 t= 0.3743999999999914 t= 0.3745999999999914 t= 0.37479999999999136 t= 0.37499999999999134 t= 0.3751999999999913 t= 0.3753999999999913 t= 0.3755999999999913 t= 0.37579999999999125 t= 0.37599999999999123 t= 0.3761999999999912 t= 0.3763999999999912 t= 0.37659999999999116 t= 0.37679999999999114 t= 0.3769999999999911 t= 0.3771999999999911 t= 0.3773999999999911 t= 0.37759999999999105 t= 0.37779999999999103 t= 0.377999999999991 t= 0.378199999999991 t= 0.37839999999999097 t= 0.37859999999999094 t= 0.3787999999999909 t= 0.3789999999999909 t= 0.3791999999999909 t= 0.37939999999999086 t= 0.37959999999999083 t= 0.3797999999999908 t= 0.3799999999999908 t= 0.38019999999999077 t= 0.38039999999999075 t= 0.3805999999999907 t= 0.3807999999999907 t= 0.3809999999999907 t= 0.38119999999999066 t= 0.38139999999999064 t= 0.3815999999999906 t= 0.3817999999999906 t= 0.38199999999999057 t= 0.38219999999999055 t= 0.3823999999999905 t= 0.3825999999999905 t= 0.3827999999999905 t= 0.38299999999999046 t= 0.38319999999999044 t= 0.3833999999999904 t= 0.3835999999999904 t= 0.38379999999999037 t= 0.38399999999999035 t= 0.3841999999999903 t= 0.3843999999999903 t= 0.3845999999999903 t= 0.38479999999999026 t= 0.38499999999999024 t= 0.3851999999999902 t= 0.3853999999999902 t= 0.3855999999999902 t= 0.38579999999999015 t= 0.38599999999999013 t= 0.3861999999999901 t= 0.3863999999999901 t= 0.38659999999999006 t= 0.38679999999999004 t= 0.38699999999999 t= 0.38719999999999 t= 0.38739999999999 t= 0.38759999999998995 t= 0.38779999999998993 t= 0.3879999999999899 t= 0.3881999999999899 t= 0.38839999999998986 t= 0.38859999999998984 t= 0.3887999999999898 t= 0.3889999999999898 t= 0.3891999999999898 t= 0.38939999999998975 t= 0.38959999999998973 t= 0.3897999999999897 t= 0.3899999999999897 t= 0.39019999999998967 t= 0.39039999999998964 t= 0.3905999999999896 t= 0.3907999999999896 t= 0.3909999999999896 t= 0.39119999999998956 t= 0.39139999999998953 t= 0.3915999999999895 t= 0.3917999999999895 t= 0.39199999999998947 t= 0.39219999999998945 t= 0.3923999999999894 t= 0.3925999999999894 t= 0.3927999999999894 t= 0.39299999999998936 t= 0.39319999999998934 t= 0.3933999999999893 t= 0.3935999999999893 t= 0.39379999999998927 t= 0.39399999999998925 t= 0.3941999999999892 t= 0.3943999999999892 t= 0.3945999999999892 t= 0.39479999999998916 t= 0.39499999999998914 t= 0.3951999999999891 t= 0.3953999999999891 t= 0.39559999999998907 t= 0.39579999999998905 t= 0.395999999999989 t= 0.396199999999989 t= 0.396399999999989 t= 0.39659999999998896 t= 0.39679999999998894 t= 0.3969999999999889 t= 0.3971999999999889 t= 0.3973999999999889 t= 0.39759999999998885 t= 0.39779999999998883 t= 0.3979999999999888 t= 0.3981999999999888 t= 0.39839999999998876 t= 0.39859999999998874 t= 0.3987999999999887 t= 0.3989999999999887 t= 0.3991999999999887 t= 0.39939999999998865 t= 0.39959999999998863 t= 0.3997999999999886 t= 0.3999999999999886 t= 0.40019999999998856 t= 0.40039999999998854 t= 0.4005999999999885 t= 0.4007999999999885 t= 0.4009999999999885 t= 0.40119999999998845 t= 0.40139999999998843 t= 0.4015999999999884 t= 0.4017999999999884 t= 0.40199999999998837 t= 0.40219999999998834 t= 0.4023999999999883 t= 0.4025999999999883 t= 0.4027999999999883 t= 0.40299999999998826 t= 0.40319999999998823 t= 0.4033999999999882 t= 0.4035999999999882 t= 0.40379999999998817 t= 0.40399999999998815 t= 0.4041999999999881 t= 0.4043999999999881 t= 0.4045999999999881 t= 0.40479999999998806 t= 0.40499999999998804 t= 0.405199999999988 t= 0.405399999999988 t= 0.40559999999998797 t= 0.40579999999998795 t= 0.4059999999999879 t= 0.4061999999999879 t= 0.4063999999999879 t= 0.40659999999998786 t= 0.40679999999998784 t= 0.4069999999999878 t= 0.4071999999999878 t= 0.40739999999998777 t= 0.40759999999998775 t= 0.40779999999998773 t= 0.4079999999999877 t= 0.4081999999999877 t= 0.40839999999998766 t= 0.40859999999998764 t= 0.4087999999999876 t= 0.4089999999999876 t= 0.4091999999999876 t= 0.40939999999998755 t= 0.40959999999998753 t= 0.4097999999999875 t= 0.4099999999999875 t= 0.41019999999998746 t= 0.41039999999998744 t= 0.4105999999999874 t= 0.4107999999999874 t= 0.4109999999999874 t= 0.41119999999998735 t= 0.41139999999998733 t= 0.4115999999999873 t= 0.4117999999999873 t= 0.41199999999998727 t= 0.41219999999998724 t= 0.4123999999999872 t= 0.4125999999999872 t= 0.4127999999999872 t= 0.41299999999998716 t= 0.41319999999998713 t= 0.4133999999999871 t= 0.4135999999999871 t= 0.41379999999998707 t= 0.41399999999998705 t= 0.414199999999987 t= 0.414399999999987 t= 0.414599999999987 t= 0.41479999999998696 t= 0.41499999999998693 t= 0.4151999999999869 t= 0.4153999999999869 t= 0.41559999999998687 t= 0.41579999999998685 t= 0.4159999999999868 t= 0.4161999999999868 t= 0.4163999999999868 t= 0.41659999999998676 t= 0.41679999999998674 t= 0.4169999999999867 t= 0.4171999999999867 t= 0.41739999999998667 t= 0.41759999999998665 t= 0.4177999999999866 t= 0.4179999999999866 t= 0.4181999999999866 t= 0.41839999999998656 t= 0.41859999999998654 t= 0.4187999999999865 t= 0.4189999999999865 t= 0.4191999999999865 t= 0.41939999999998645 t= 0.41959999999998643 t= 0.4197999999999864 t= 0.4199999999999864 t= 0.42019999999998636 t= 0.42039999999998634
</pre>
end{sphinxVerbatim}
- more-to-come:
t= 0.4205999999999863 t= 0.4207999999999863 t= 0.4209999999999863 t= 0.42119999999998625 t= 0.42139999999998623 t= 0.4215999999999862 t= 0.4217999999999862 t= 0.42199999999998616 t= 0.42219999999998614 t= 0.4223999999999861 t= 0.4225999999999861 t= 0.4227999999999861 t= 0.42299999999998605 t= 0.42319999999998603 t= 0.423399999999986 t= 0.423599999999986 t= 0.42379999999998597 t= 0.42399999999998594 t= 0.4241999999999859 t= 0.4243999999999859 t= 0.4245999999999859 t= 0.42479999999998586 t= 0.42499999999998583 t= 0.4251999999999858 t= 0.4253999999999858 t= 0.42559999999998577 t= 0.42579999999998575 t= 0.4259999999999857 t= 0.4261999999999857 t= 0.4263999999999857 t= 0.42659999999998566 t= 0.42679999999998564 t= 0.4269999999999856 t= 0.4271999999999856 t= 0.42739999999998557 t= 0.42759999999998555 t= 0.4277999999999855 t= 0.4279999999999855 t= 0.4281999999999855 t= 0.42839999999998546 t= 0.42859999999998544 t= 0.4287999999999854 t= 0.4289999999999854 t= 0.42919999999998537 t= 0.42939999999998535 t= 0.4295999999999853 t= 0.4297999999999853 t= 0.4299999999999853 t= 0.43019999999998526 t= 0.43039999999998524 t= 0.4305999999999852 t= 0.4307999999999852 t= 0.4309999999999852 t= 0.43119999999998515 t= 0.43139999999998513 t= 0.4315999999999851 t= 0.4317999999999851 t= 0.43199999999998506 t= 0.43219999999998504 t= 0.432399999999985 t= 0.432599999999985 t= 0.432799999999985 t= 0.43299999999998495 t= 0.43319999999998493 t= 0.4333999999999849 t= 0.4335999999999849 t= 0.43379999999998486 t= 0.43399999999998484 t= 0.4341999999999848 t= 0.4343999999999848 t= 0.4345999999999848 t= 0.43479999999998475 t= 0.43499999999998473 t= 0.4351999999999847 t= 0.4353999999999847 t= 0.43559999999998467 t= 0.43579999999998464 t= 0.4359999999999846 t= 0.4361999999999846 t= 0.4363999999999846 t= 0.43659999999998456 t= 0.43679999999998453 t= 0.4369999999999845 t= 0.4371999999999845 t= 0.43739999999998447 t= 0.43759999999998445 t= 0.4377999999999844 t= 0.4379999999999844 t= 0.4381999999999844 t= 0.43839999999998436 t= 0.43859999999998434 t= 0.4387999999999843 t= 0.4389999999999843 t= 0.43919999999998427 t= 0.43939999999998425 t= 0.4395999999999842 t= 0.4397999999999842 t= 0.4399999999999842 t= 0.44019999999998416 t= 0.44039999999998414 t= 0.4405999999999841 t= 0.4407999999999841 t= 0.44099999999998407 t= 0.44119999999998405 t= 0.441399999999984 t= 0.441599999999984 t= 0.441799999999984 t= 0.44199999999998396 t= 0.44219999999998394 t= 0.4423999999999839 t= 0.4425999999999839 t= 0.4427999999999839 t= 0.44299999999998385 t= 0.44319999999998383 t= 0.4433999999999838 t= 0.4435999999999838 t= 0.44379999999998376 t= 0.44399999999998374 t= 0.4441999999999837 t= 0.4443999999999837 t= 0.4445999999999837 t= 0.44479999999998365 t= 0.44499999999998363 t= 0.4451999999999836 t= 0.4453999999999836 t= 0.44559999999998356 t= 0.44579999999998354 t= 0.4459999999999835 t= 0.4461999999999835 t= 0.4463999999999835 t= 0.44659999999998345 t= 0.44679999999998343 t= 0.4469999999999834 t= 0.4471999999999834 t= 0.44739999999998337 t= 0.44759999999998334 t= 0.4477999999999833 t= 0.4479999999999833 t= 0.4481999999999833 t= 0.44839999999998326 t= 0.44859999999998323 t= 0.4487999999999832 t= 0.4489999999999832 t= 0.44919999999998317 t= 0.44939999999998315 t= 0.4495999999999831 t= 0.4497999999999831 t= 0.4499999999999831 t= 0.45019999999998306 t= 0.45039999999998304 t= 0.450599999999983 t= 0.450799999999983 t= 0.45099999999998297 t= 0.45119999999998295 t= 0.4513999999999829 t= 0.4515999999999829 t= 0.4517999999999829 t= 0.45199999999998286 t= 0.45219999999998284 t= 0.4523999999999828 t= 0.4525999999999828 t= 0.45279999999998277 t= 0.45299999999998275 t= 0.45319999999998273 t= 0.4533999999999827 t= 0.4535999999999827 t= 0.45379999999998266 t= 0.45399999999998264 t= 0.4541999999999826 t= 0.4543999999999826 t= 0.4545999999999826 t= 0.45479999999998255 t= 0.45499999999998253 t= 0.4551999999999825 t= 0.4553999999999825 t= 0.45559999999998246 t= 0.45579999999998244 t= 0.4559999999999824 t= 0.4561999999999824 t= 0.4563999999999824 t= 0.45659999999998235 t= 0.45679999999998233 t= 0.4569999999999823 t= 0.4571999999999823 t= 0.45739999999998227 t= 0.45759999999998224 t= 0.4577999999999822 t= 0.4579999999999822 t= 0.4581999999999822 t= 0.45839999999998216 t= 0.45859999999998213 t= 0.4587999999999821 t= 0.4589999999999821 t= 0.45919999999998207 t= 0.45939999999998204 t= 0.459599999999982 t= 0.459799999999982 t= 0.459999999999982 t= 0.46019999999998196 t= 0.46039999999998193 t= 0.4605999999999819 t= 0.4607999999999819 t= 0.46099999999998187 t= 0.46119999999998185 t= 0.4613999999999818 t= 0.4615999999999818 t= 0.4617999999999818 t= 0.46199999999998176 t= 0.46219999999998174 t= 0.4623999999999817 t= 0.4625999999999817 t= 0.46279999999998167 t= 0.46299999999998165 t= 0.4631999999999816 t= 0.4633999999999816 t= 0.4635999999999816 t= 0.46379999999998156 t= 0.46399999999998154 t= 0.4641999999999815 t= 0.4643999999999815 t= 0.46459999999998147 t= 0.46479999999998145 t= 0.46499999999998143 t= 0.4651999999999814 t= 0.4653999999999814 t= 0.46559999999998136 t= 0.46579999999998134 t= 0.4659999999999813 t= 0.4661999999999813 t= 0.4663999999999813 t= 0.46659999999998125 t= 0.46679999999998123 t= 0.4669999999999812 t= 0.4671999999999812 t= 0.46739999999998116 t= 0.46759999999998114 t= 0.4677999999999811 t= 0.4679999999999811 t= 0.4681999999999811 t= 0.46839999999998105 t= 0.46859999999998103 t= 0.468799999999981 t= 0.468999999999981 t= 0.46919999999998097 t= 0.46939999999998094 t= 0.4695999999999809 t= 0.4697999999999809 t= 0.4699999999999809 t= 0.47019999999998086 t= 0.47039999999998083 t= 0.4705999999999808 t= 0.4707999999999808 t= 0.47099999999998077 t= 0.47119999999998075 t= 0.4713999999999807 t= 0.4715999999999807 t= 0.4717999999999807 t= 0.47199999999998066 t= 0.47219999999998064 t= 0.4723999999999806 t= 0.4725999999999806 t= 0.47279999999998057 t= 0.47299999999998055 t= 0.4731999999999805 t= 0.4733999999999805 t= 0.4735999999999805 t= 0.47379999999998046 t= 0.47399999999998044 t= 0.4741999999999804 t= 0.4743999999999804 t= 0.47459999999998037 t= 0.47479999999998035 t= 0.4749999999999803 t= 0.4751999999999803 t= 0.4753999999999803 t= 0.47559999999998026 t= 0.47579999999998024 t= 0.4759999999999802 t= 0.4761999999999802 t= 0.4763999999999802 t= 0.47659999999998015 t= 0.47679999999998013 t= 0.4769999999999801 t= 0.4771999999999801 t= 0.47739999999998006 t= 0.47759999999998004 t= 0.47779999999998 t= 0.47799999999998 t= 0.47819999999998 t= 0.47839999999997995 t= 0.47859999999997993 t= 0.4787999999999799 t= 0.4789999999999799 t= 0.47919999999997986 t= 0.47939999999997984 t= 0.4795999999999798 t= 0.4797999999999798 t= 0.4799999999999798 t= 0.48019999999997975 t= 0.48039999999997973 t= 0.4805999999999797 t= 0.4807999999999797 t= 0.48099999999997967 t= 0.48119999999997964 t= 0.4813999999999796 t= 0.4815999999999796 t= 0.4817999999999796 t= 0.48199999999997956 t= 0.48219999999997953 t= 0.4823999999999795 t= 0.4825999999999795 t= 0.48279999999997947 t= 0.48299999999997945 t= 0.4831999999999794 t= 0.4833999999999794 t= 0.4835999999999794 t= 0.48379999999997936 t= 0.48399999999997934 t= 0.4841999999999793 t= 0.4843999999999793 t= 0.48459999999997927 t= 0.48479999999997925 t= 0.4849999999999792 t= 0.4851999999999792 t= 0.4853999999999792 t= 0.48559999999997916 t= 0.48579999999997914 t= 0.4859999999999791 t= 0.4861999999999791 t= 0.48639999999997907 t= 0.48659999999997905 t= 0.486799999999979 t= 0.486999999999979 t= 0.487199999999979 t= 0.48739999999997896 t= 0.48759999999997894 t= 0.4877999999999789 t= 0.4879999999999789 t= 0.4881999999999789 t= 0.48839999999997885 t= 0.48859999999997883 t= 0.4887999999999788 t= 0.4889999999999788 t= 0.48919999999997876 t= 0.48939999999997874 t= 0.4895999999999787 t= 0.4897999999999787 t= 0.4899999999999787 t= 0.49019999999997865 t= 0.49039999999997863 t= 0.4905999999999786 t= 0.4907999999999786 t= 0.49099999999997856 t= 0.49119999999997854 t= 0.4913999999999785 t= 0.4915999999999785 t= 0.4917999999999785 t= 0.49199999999997845 t= 0.49219999999997843 t= 0.4923999999999784 t= 0.4925999999999784 t= 0.49279999999997837 t= 0.49299999999997834 t= 0.4931999999999783 t= 0.4933999999999783 t= 0.4935999999999783 t= 0.49379999999997826 t= 0.49399999999997823 t= 0.4941999999999782 t= 0.4943999999999782 t= 0.49459999999997817 t= 0.49479999999997815 t= 0.4949999999999781 t= 0.4951999999999781 t= 0.4953999999999781 t= 0.49559999999997806 t= 0.49579999999997804 t= 0.495999999999978 t= 0.496199999999978 t= 0.49639999999997797 t= 0.49659999999997795 t= 0.4967999999999779 t= 0.4969999999999779 t= 0.4971999999999779 t= 0.49739999999997786 t= 0.49759999999997784 t= 0.4977999999999778 t= 0.4979999999999778 t= 0.49819999999997777 t= 0.49839999999997775 t= 0.4985999999999777 t= 0.4987999999999777 t= 0.4989999999999777 t= 0.49919999999997766 t= 0.49939999999997764 t= 0.4995999999999776 t= 0.4997999999999776 t= 0.4999999999999776 t= 0.5001999999999776 t= 0.5003999999999775 t= 0.5005999999999775 t= 0.5007999999999775 t= 0.5009999999999775 t= 0.5011999999999774 t= 0.5013999999999774 t= 0.5015999999999774 t= 0.5017999999999774 t= 0.5019999999999774 t= 0.5021999999999773 t= 0.5023999999999773 t= 0.5025999999999773 t= 0.5027999999999773 t= 0.5029999999999772 t= 0.5031999999999772 t= 0.5033999999999772 t= 0.5035999999999772 t= 0.5037999999999772 t= 0.5039999999999771 t= 0.5041999999999771 t= 0.5043999999999771 t= 0.5045999999999771 t= 0.504799999999977 t= 0.504999999999977 t= 0.505199999999977 t= 0.505399999999977 t= 0.505599999999977 t= 0.5057999999999769 t= 0.5059999999999769 t= 0.5061999999999769 t= 0.5063999999999769 t= 0.5065999999999768 t= 0.5067999999999768 t= 0.5069999999999768 t= 0.5071999999999768 t= 0.5073999999999768 t= 0.5075999999999767 t= 0.5077999999999767 t= 0.5079999999999767 t= 0.5081999999999767 t= 0.5083999999999766 t= 0.5085999999999766 t= 0.5087999999999766 t= 0.5089999999999766 t= 0.5091999999999766 t= 0.5093999999999765 t= 0.5095999999999765 t= 0.5097999999999765 t= 0.5099999999999765 t= 0.5101999999999765 t= 0.5103999999999764 t= 0.5105999999999764 t= 0.5107999999999764 t= 0.5109999999999764 t= 0.5111999999999763 t= 0.5113999999999763 t= 0.5115999999999763 t= 0.5117999999999763 t= 0.5119999999999763 t= 0.5121999999999762 t= 0.5123999999999762 t= 0.5125999999999762 t= 0.5127999999999762 t= 0.5129999999999761 t= 0.5131999999999761 t= 0.5133999999999761 t= 0.5135999999999761 t= 0.513799999999976 t= 0.513999999999976 t= 0.514199999999976 t= 0.514399999999976 t= 0.514599999999976 t= 0.5147999999999759 t= 0.5149999999999759 t= 0.5151999999999759 t= 0.5153999999999759 t= 0.5155999999999759 t= 0.5157999999999758 t= 0.5159999999999758 t= 0.5161999999999758 t= 0.5163999999999758 t= 0.5165999999999757 t= 0.5167999999999757 t= 0.5169999999999757 t= 0.5171999999999757 t= 0.5173999999999757 t= 0.5175999999999756 t= 0.5177999999999756 t= 0.5179999999999756 t= 0.5181999999999756 t= 0.5183999999999755 t= 0.5185999999999755 t= 0.5187999999999755 t= 0.5189999999999755 t= 0.5191999999999755 t= 0.5193999999999754 t= 0.5195999999999754 t= 0.5197999999999754 t= 0.5199999999999754 t= 0.5201999999999753 t= 0.5203999999999753 t= 0.5205999999999753 t= 0.5207999999999753 t= 0.5209999999999753 t= 0.5211999999999752 t= 0.5213999999999752 t= 0.5215999999999752 t= 0.5217999999999752 t= 0.5219999999999752 t= 0.5221999999999751 t= 0.5223999999999751 t= 0.5225999999999751 t= 0.5227999999999751 t= 0.522999999999975 t= 0.523199999999975 t= 0.523399999999975 t= 0.523599999999975 t= 0.523799999999975 t= 0.5239999999999749 t= 0.5241999999999749 t= 0.5243999999999749 t= 0.5245999999999749 t= 0.5247999999999748 t= 0.5249999999999748 t= 0.5251999999999748 t= 0.5253999999999748 t= 0.5255999999999748 t= 0.5257999999999747 t= 0.5259999999999747 t= 0.5261999999999747 t= 0.5263999999999747 t= 0.5265999999999746 t= 0.5267999999999746 t= 0.5269999999999746 t= 0.5271999999999746 t= 0.5273999999999746 t= 0.5275999999999745 t= 0.5277999999999745 t= 0.5279999999999745 t= 0.5281999999999745 t= 0.5283999999999744 t= 0.5285999999999744 t= 0.5287999999999744 t= 0.5289999999999744 t= 0.5291999999999744 t= 0.5293999999999743 t= 0.5295999999999743 t= 0.5297999999999743 t= 0.5299999999999743 t= 0.5301999999999742 t= 0.5303999999999742 t= 0.5305999999999742 t= 0.5307999999999742 t= 0.5309999999999742 t= 0.5311999999999741 t= 0.5313999999999741 t= 0.5315999999999741 t= 0.5317999999999741 t= 0.531999999999974 t= 0.532199999999974 t= 0.532399999999974 t= 0.532599999999974 t= 0.532799999999974 t= 0.5329999999999739 t= 0.5331999999999739 t= 0.5333999999999739 t= 0.5335999999999739 t= 0.5337999999999739 t= 0.5339999999999738 t= 0.5341999999999738 t= 0.5343999999999738 t= 0.5345999999999738 t= 0.5347999999999737 t= 0.5349999999999737 t= 0.5351999999999737 t= 0.5353999999999737 t= 0.5355999999999737 t= 0.5357999999999736 t= 0.5359999999999736 t= 0.5361999999999736 t= 0.5363999999999736 t= 0.5365999999999735 t= 0.5367999999999735 t= 0.5369999999999735 t= 0.5371999999999735 t= 0.5373999999999735 t= 0.5375999999999734 t= 0.5377999999999734 t= 0.5379999999999734 t= 0.5381999999999734 t= 0.5383999999999733 t= 0.5385999999999733 t= 0.5387999999999733 t= 0.5389999999999733 t= 0.5391999999999733 t= 0.5393999999999732 t= 0.5395999999999732 t= 0.5397999999999732 t= 0.5399999999999732 t= 0.5401999999999731 t= 0.5403999999999731 t= 0.5405999999999731 t= 0.5407999999999731 t= 0.5409999999999731 t= 0.541199999999973 t= 0.541399999999973 t= 0.541599999999973 t= 0.541799999999973 t= 0.541999999999973 t= 0.5421999999999729 t= 0.5423999999999729 t= 0.5425999999999729 t= 0.5427999999999729 t= 0.5429999999999728 t= 0.5431999999999728 t= 0.5433999999999728 t= 0.5435999999999728 t= 0.5437999999999727 t= 0.5439999999999727 t= 0.5441999999999727 t= 0.5443999999999727 t= 0.5445999999999727 t= 0.5447999999999726 t= 0.5449999999999726 t= 0.5451999999999726 t= 0.5453999999999726 t= 0.5455999999999726 t= 0.5457999999999725 t= 0.5459999999999725 t= 0.5461999999999725 t= 0.5463999999999725 t= 0.5465999999999724 t= 0.5467999999999724 t= 0.5469999999999724 t= 0.5471999999999724 t= 0.5473999999999724 t= 0.5475999999999723 t= 0.5477999999999723 t= 0.5479999999999723 t= 0.5481999999999723 t= 0.5483999999999722 t= 0.5485999999999722 t= 0.5487999999999722 t= 0.5489999999999722 t= 0.5491999999999722 t= 0.5493999999999721 t= 0.5495999999999721 t= 0.5497999999999721 t= 0.5499999999999721 t= 0.550199999999972 t= 0.550399999999972 t= 0.550599999999972 t= 0.550799999999972 t= 0.550999999999972 t= 0.5511999999999719 t= 0.5513999999999719 t= 0.5515999999999719 t= 0.5517999999999719 t= 0.5519999999999718 t= 0.5521999999999718 t= 0.5523999999999718 t= 0.5525999999999718 t= 0.5527999999999718 t= 0.5529999999999717 t= 0.5531999999999717 t= 0.5533999999999717 t= 0.5535999999999717 t= 0.5537999999999716 t= 0.5539999999999716 t= 0.5541999999999716 t= 0.5543999999999716 t= 0.5545999999999716 t= 0.5547999999999715 t= 0.5549999999999715 t= 0.5551999999999715 t= 0.5553999999999715 t= 0.5555999999999715 t= 0.5557999999999714 t= 0.5559999999999714 t= 0.5561999999999714 t= 0.5563999999999714 t= 0.5565999999999713 t= 0.5567999999999713 t= 0.5569999999999713 t= 0.5571999999999713 t= 0.5573999999999713 t= 0.5575999999999712 t= 0.5577999999999712 t= 0.5579999999999712 t= 0.5581999999999712 t= 0.5583999999999711 t= 0.5585999999999711 t= 0.5587999999999711 t= 0.5589999999999711 t= 0.559199999999971 t= 0.559399999999971 t= 0.559599999999971 t= 0.559799999999971 t= 0.559999999999971 t= 0.5601999999999709 t= 0.5603999999999709 t= 0.5605999999999709 t= 0.5607999999999709 t= 0.5609999999999709 t= 0.5611999999999708 t= 0.5613999999999708 t= 0.5615999999999708 t= 0.5617999999999708 t= 0.5619999999999707 t= 0.5621999999999707 t= 0.5623999999999707 t= 0.5625999999999707 t= 0.5627999999999707 t= 0.5629999999999706 t= 0.5631999999999706 t= 0.5633999999999706 t= 0.5635999999999706 t= 0.5637999999999705 t= 0.5639999999999705 t= 0.5641999999999705 t= 0.5643999999999705 t= 0.5645999999999705 t= 0.5647999999999704 t= 0.5649999999999704 t= 0.5651999999999704 t= 0.5653999999999704 t= 0.5655999999999703 t= 0.5657999999999703 t= 0.5659999999999703 t= 0.5661999999999703 t= 0.5663999999999703 t= 0.5665999999999702 t= 0.5667999999999702 t= 0.5669999999999702 t= 0.5671999999999702 t= 0.5673999999999702 t= 0.5675999999999701 t= 0.5677999999999701 t= 0.5679999999999701 t= 0.5681999999999701 t= 0.56839999999997 t= 0.56859999999997 t= 0.56879999999997 t= 0.56899999999997 t= 0.56919999999997 t= 0.5693999999999699 t= 0.5695999999999699 t= 0.5697999999999699 t= 0.5699999999999699 t= 0.5701999999999698 t= 0.5703999999999698 t= 0.5705999999999698 t= 0.5707999999999698 t= 0.5709999999999698 t= 0.5711999999999697 t= 0.5713999999999697 t= 0.5715999999999697 t= 0.5717999999999697 t= 0.5719999999999696 t= 0.5721999999999696 t= 0.5723999999999696 t= 0.5725999999999696 t= 0.5727999999999696 t= 0.5729999999999695 t= 0.5731999999999695 t= 0.5733999999999695 t= 0.5735999999999695 t= 0.5737999999999694 t= 0.5739999999999694 t= 0.5741999999999694
</pre>
end{sphinxVerbatim}
t= 0.5743999999999694 t= 0.5745999999999694 t= 0.5747999999999693 t= 0.5749999999999693 t= 0.5751999999999693 t= 0.5753999999999693 t= 0.5755999999999692 t= 0.5757999999999692 t= 0.5759999999999692 t= 0.5761999999999692 t= 0.5763999999999692 t= 0.5765999999999691 t= 0.5767999999999691 t= 0.5769999999999691 t= 0.5771999999999691 t= 0.577399999999969 t= 0.577599999999969 t= 0.577799999999969 t= 0.577999999999969 t= 0.578199999999969 t= 0.5783999999999689 t= 0.5785999999999689 t= 0.5787999999999689 t= 0.5789999999999689 t= 0.5791999999999689 t= 0.5793999999999688 t= 0.5795999999999688 t= 0.5797999999999688 t= 0.5799999999999688 t= 0.5801999999999687 t= 0.5803999999999687 t= 0.5805999999999687 t= 0.5807999999999687 t= 0.5809999999999687 t= 0.5811999999999686 t= 0.5813999999999686 t= 0.5815999999999686 t= 0.5817999999999686 t= 0.5819999999999685 t= 0.5821999999999685 t= 0.5823999999999685 t= 0.5825999999999685 t= 0.5827999999999685 t= 0.5829999999999684 t= 0.5831999999999684 t= 0.5833999999999684 t= 0.5835999999999684 t= 0.5837999999999683 t= 0.5839999999999683 t= 0.5841999999999683 t= 0.5843999999999683 t= 0.5845999999999683 t= 0.5847999999999682 t= 0.5849999999999682 t= 0.5851999999999682 t= 0.5853999999999682 t= 0.5855999999999681 t= 0.5857999999999681 t= 0.5859999999999681 t= 0.5861999999999681 t= 0.5863999999999681 t= 0.586599999999968 t= 0.586799999999968 t= 0.586999999999968 t= 0.587199999999968 t= 0.587399999999968 t= 0.5875999999999679 t= 0.5877999999999679 t= 0.5879999999999679 t= 0.5881999999999679 t= 0.5883999999999678 t= 0.5885999999999678 t= 0.5887999999999678 t= 0.5889999999999678 t= 0.5891999999999677 t= 0.5893999999999677 t= 0.5895999999999677 t= 0.5897999999999677 t= 0.5899999999999677 t= 0.5901999999999676 t= 0.5903999999999676 t= 0.5905999999999676 t= 0.5907999999999676 t= 0.5909999999999676 t= 0.5911999999999675 t= 0.5913999999999675 t= 0.5915999999999675 t= 0.5917999999999675 t= 0.5919999999999674 t= 0.5921999999999674 t= 0.5923999999999674 t= 0.5925999999999674 t= 0.5927999999999674 t= 0.5929999999999673 t= 0.5931999999999673 t= 0.5933999999999673 t= 0.5935999999999673 t= 0.5937999999999672 t= 0.5939999999999672 t= 0.5941999999999672 t= 0.5943999999999672 t= 0.5945999999999672 t= 0.5947999999999671 t= 0.5949999999999671 t= 0.5951999999999671 t= 0.5953999999999671 t= 0.595599999999967 t= 0.595799999999967 t= 0.595999999999967 t= 0.596199999999967 t= 0.596399999999967 t= 0.5965999999999669 t= 0.5967999999999669 t= 0.5969999999999669 t= 0.5971999999999669 t= 0.5973999999999668 t= 0.5975999999999668 t= 0.5977999999999668 t= 0.5979999999999668 t= 0.5981999999999668 t= 0.5983999999999667 t= 0.5985999999999667 t= 0.5987999999999667 t= 0.5989999999999667 t= 0.5991999999999666 t= 0.5993999999999666 t= 0.5995999999999666 t= 0.5997999999999666 t= 0.5999999999999666CPU times: user 8.24 s, sys: 36.6 ms, total: 8.28 s
Wall time: 8.24 s </pre>
Wall time: 8.24 s end{sphinxVerbatim}
Wall time: 8.24 s
#Draw(gfu_t,mesh,interpolate_multidim=True,animate=True,
# min=0, max=0.2, autoscale=False, deformation=True)
Speed up with geom_free integrals¶
With \(u(x) = \hat{u}(\hat{x})\), \(v(x) = \hat{v}(\hat{x})\) (directly mapped) and \(\mathbf{w}(x) = \frac{1}{|\operatorname{det}(F)|} F \cdot \hat{\mathbf{w}}(\hat{x})\) (Piola mapped) there holds
and similarly for the facet integrals.
Integrals are independent of the "physical element" (up to ordering) similar to integrals in unit-2.11.
\(\leadsto\) allows to prepare intermediate computations for a large class of elements at once.
Piola wind:
gfwind = GridFunction(HDiv(mesh, order=order))
gfwind.Set(b)
b=gfwind; # <- overwrite old name "b"
Same as before, but with geom_free=True flag:
# part 1
uT, vT = VT.TnT()
c1 = BilinearForm(space=VT, nonassemble=True, geom_free=True)
c1 += -uT * b * grad(vT) * dx
# part 2
uT,uF = V.TrialFunction()
c2 = BilinearForm(trialspace=V, testspace=VT, nonassemble=True, geom_free=True)
# here uf-u = u_me + u_other - u_me is the neighbor value
c2 += b*n * IfPos(b*n, uT, uF-uT) * vT * dx(element_boundary=True)
c = c1.mat + c2.mat @ embV
%%time
gfu_t = SolveAndVisualize(c, rhs_vec=rhs.vec)
t= 0.0002 t= 0.0004 t= 0.0006000000000000001 t= 0.0008 t= 0.001 t= 0.0012000000000000001 t= 0.0014000000000000002 t= 0.0016000000000000003 t= 0.0018000000000000004 t= 0.0020000000000000005 t= 0.0022000000000000006 t= 0.0024000000000000007 t= 0.0026000000000000007 t= 0.002800000000000001 t= 0.003000000000000001 t= 0.003200000000000001 t= 0.003400000000000001 t= 0.003600000000000001 t= 0.0038000000000000013 t= 0.004000000000000001 t= 0.004200000000000001 t= 0.0044 t= 0.0046 t= 0.0048 t= 0.004999999999999999 t= 0.005199999999999999 t= 0.0053999999999999986 t= 0.005599999999999998 t= 0.005799999999999998 t= 0.0059999999999999975 t= 0.006199999999999997 t= 0.006399999999999997 t= 0.0065999999999999965 t= 0.006799999999999996 t= 0.006999999999999996 t= 0.0071999999999999955 t= 0.007399999999999995 t= 0.007599999999999995 t= 0.0077999999999999944 t= 0.007999999999999995 t= 0.008199999999999995 t= 0.008399999999999996 t= 0.008599999999999997 t= 0.008799999999999997 t= 0.008999999999999998 t= 0.009199999999999998 t= 0.009399999999999999 t= 0.0096 t= 0.0098 t= 0.01 t= 0.0102 t= 0.010400000000000001 t= 0.010600000000000002 t= 0.010800000000000002 t= 0.011000000000000003 t= 0.011200000000000003 t= 0.011400000000000004 t= 0.011600000000000004 t= 0.011800000000000005 t= 0.012000000000000005 t= 0.012200000000000006 t= 0.012400000000000007 t= 0.012600000000000007 t= 0.012800000000000008 t= 0.013000000000000008 t= 0.013200000000000009 t= 0.013400000000000009 t= 0.01360000000000001 t= 0.01380000000000001 t= 0.01400000000000001 t= 0.014200000000000011 t= 0.014400000000000012 t= 0.014600000000000012 t= 0.014800000000000013 t= 0.015000000000000013 t= 0.015200000000000014 t= 0.015400000000000014 t= 0.015600000000000015 t= 0.015800000000000015 t= 0.016000000000000014 t= 0.016200000000000013 t= 0.016400000000000012 t= 0.01660000000000001 t= 0.01680000000000001 t= 0.017000000000000008 t= 0.017200000000000007 t= 0.017400000000000006 t= 0.017600000000000005 t= 0.017800000000000003 t= 0.018000000000000002 t= 0.0182 t= 0.0184 t= 0.0186 t= 0.018799999999999997 t= 0.018999999999999996 t= 0.019199999999999995 t= 0.019399999999999994 t= 0.019599999999999992 t= 0.01979999999999999 t= 0.01999999999999999 t= 0.02019999999999999 t= 0.020399999999999988 t= 0.020599999999999986 t= 0.020799999999999985 t= 0.020999999999999984 t= 0.021199999999999983 t= 0.02139999999999998 t= 0.02159999999999998 t= 0.02179999999999998 t= 0.021999999999999978 t= 0.022199999999999977 t= 0.022399999999999975 t= 0.022599999999999974 t= 0.022799999999999973 t= 0.022999999999999972 t= 0.02319999999999997 t= 0.02339999999999997 t= 0.023599999999999968 t= 0.023799999999999967 t= 0.023999999999999966 t= 0.024199999999999965 t= 0.024399999999999963 t= 0.024599999999999962 t= 0.02479999999999996 t= 0.02499999999999996 t= 0.02519999999999996 t= 0.025399999999999957 t= 0.025599999999999956 t= 0.025799999999999955 t= 0.025999999999999954 t= 0.026199999999999952 t= 0.02639999999999995 t= 0.02659999999999995 t= 0.02679999999999995 t= 0.026999999999999948 t= 0.027199999999999946 t= 0.027399999999999945 t= 0.027599999999999944 t= 0.027799999999999943 t= 0.02799999999999994 t= 0.02819999999999994 t= 0.02839999999999994 t= 0.028599999999999938 t= 0.028799999999999937 t= 0.028999999999999936 t= 0.029199999999999934 t= 0.029399999999999933 t= 0.029599999999999932 t= 0.02979999999999993 t= 0.02999999999999993 t= 0.03019999999999993 t= 0.030399999999999927 t= 0.030599999999999926 t= 0.030799999999999925 t= 0.030999999999999923 t= 0.031199999999999922 t= 0.03139999999999992 t= 0.03159999999999992 t= 0.03179999999999992 t= 0.03199999999999992 t= 0.032199999999999916 t= 0.032399999999999915 t= 0.032599999999999914 t= 0.03279999999999991 t= 0.03299999999999991 t= 0.03319999999999991 t= 0.03339999999999991 t= 0.03359999999999991 t= 0.033799999999999907 t= 0.033999999999999905 t= 0.034199999999999904 t= 0.0343999999999999 t= 0.0345999999999999 t= 0.0347999999999999 t= 0.0349999999999999 t= 0.0351999999999999 t= 0.0353999999999999 t= 0.035599999999999896 t= 0.035799999999999894 t= 0.03599999999999989 t= 0.03619999999999989 t= 0.03639999999999989 t= 0.03659999999999989 t= 0.03679999999999989 t= 0.03699999999999989 t= 0.037199999999999886 t= 0.037399999999999885 t= 0.037599999999999884 t= 0.03779999999999988 t= 0.03799999999999988 t= 0.03819999999999988 t= 0.03839999999999988 t= 0.03859999999999988 t= 0.038799999999999876 t= 0.038999999999999875 t= 0.039199999999999874 t= 0.03939999999999987 t= 0.03959999999999987 t= 0.03979999999999987 t= 0.03999999999999987 t= 0.04019999999999987 t= 0.04039999999999987 t= 0.040599999999999865 t= 0.040799999999999864 t= 0.04099999999999986 t= 0.04119999999999986 t= 0.04139999999999986 t= 0.04159999999999986 t= 0.04179999999999986 t= 0.04199999999999986 t= 0.042199999999999856 t= 0.042399999999999854 t= 0.04259999999999985 t= 0.04279999999999985 t= 0.04299999999999985 t= 0.04319999999999985 t= 0.04339999999999985 t= 0.04359999999999985 t= 0.043799999999999846 t= 0.043999999999999845 t= 0.044199999999999844 t= 0.04439999999999984 t= 0.04459999999999984 t= 0.04479999999999984 t= 0.04499999999999984 t= 0.04519999999999984 t= 0.045399999999999836 t= 0.045599999999999835 t= 0.045799999999999834 t= 0.04599999999999983 t= 0.04619999999999983 t= 0.04639999999999983 t= 0.04659999999999983 t= 0.04679999999999983 t= 0.04699999999999983 t= 0.047199999999999825 t= 0.047399999999999824 t= 0.04759999999999982 t= 0.04779999999999982 t= 0.04799999999999982 t= 0.04819999999999982 t= 0.04839999999999982 t= 0.04859999999999982 t= 0.048799999999999816 t= 0.048999999999999815 t= 0.04919999999999981 t= 0.04939999999999981 t= 0.04959999999999981 t= 0.04979999999999981 t= 0.04999999999999981 t= 0.05019999999999981 t= 0.050399999999999806 t= 0.050599999999999805 t= 0.050799999999999804 t= 0.0509999999999998 t= 0.0511999999999998 t= 0.0513999999999998 t= 0.0515999999999998 t= 0.0517999999999998 t= 0.051999999999999796 t= 0.052199999999999795 t= 0.052399999999999794 t= 0.05259999999999979 t= 0.05279999999999979 t= 0.05299999999999979 t= 0.05319999999999979 t= 0.05339999999999979 t= 0.05359999999999979 t= 0.053799999999999785 t= 0.053999999999999784 t= 0.05419999999999978 t= 0.05439999999999978 t= 0.05459999999999978 t= 0.05479999999999978 t= 0.05499999999999978 t= 0.05519999999999978 t= 0.055399999999999776 t= 0.055599999999999775 t= 0.05579999999999977 t= 0.05599999999999977 t= 0.05619999999999977 t= 0.05639999999999977 t= 0.05659999999999977 t= 0.05679999999999977 t= 0.056999999999999766 t= 0.057199999999999765 t= 0.057399999999999764 t= 0.05759999999999976 t= 0.05779999999999976 t= 0.05799999999999976 t= 0.05819999999999976 t= 0.05839999999999976 t= 0.058599999999999756 t= 0.058799999999999755 t= 0.058999999999999754 t= 0.05919999999999975 t= 0.05939999999999975 t= 0.05959999999999975 t= 0.05979999999999975 t= 0.05999999999999975 t= 0.06019999999999975 t= 0.060399999999999746 t= 0.060599999999999744 t= 0.06079999999999974 t= 0.06099999999999974 t= 0.06119999999999974 t= 0.06139999999999974 t= 0.06159999999999974 t= 0.06179999999999974 t= 0.061999999999999736 t= 0.062199999999999735 t= 0.06239999999999973 t= 0.06259999999999974 t= 0.06279999999999974 t= 0.06299999999999975 t= 0.06319999999999976 t= 0.06339999999999976 t= 0.06359999999999977 t= 0.06379999999999977 t= 0.06399999999999978 t= 0.06419999999999979 t= 0.06439999999999979 t= 0.0645999999999998 t= 0.0647999999999998 t= 0.06499999999999981 t= 0.06519999999999981 t= 0.06539999999999982 t= 0.06559999999999983 t= 0.06579999999999983 t= 0.06599999999999984 t= 0.06619999999999984 t= 0.06639999999999985 t= 0.06659999999999985 t= 0.06679999999999986 t= 0.06699999999999987 t= 0.06719999999999987 t= 0.06739999999999988 t= 0.06759999999999988 t= 0.06779999999999989 t= 0.0679999999999999 t= 0.0681999999999999 t= 0.0683999999999999 t= 0.06859999999999991 t= 0.06879999999999992 t= 0.06899999999999992 t= 0.06919999999999993 t= 0.06939999999999993 t= 0.06959999999999994 t= 0.06979999999999995 t= 0.06999999999999995 t= 0.07019999999999996 t= 0.07039999999999996 t= 0.07059999999999997 t= 0.07079999999999997 t= 0.07099999999999998 t= 0.07119999999999999 t= 0.07139999999999999 t= 0.0716 t= 0.0718 t= 0.07200000000000001 t= 0.07220000000000001 t= 0.07240000000000002 t= 0.07260000000000003 t= 0.07280000000000003 t= 0.07300000000000004 t= 0.07320000000000004 t= 0.07340000000000005 t= 0.07360000000000005 t= 0.07380000000000006 t= 0.07400000000000007 t= 0.07420000000000007 t= 0.07440000000000008 t= 0.07460000000000008 t= 0.07480000000000009 t= 0.0750000000000001 t= 0.0752000000000001 t= 0.0754000000000001 t= 0.07560000000000011 t= 0.07580000000000012 t= 0.07600000000000012 t= 0.07620000000000013 t= 0.07640000000000013 t= 0.07660000000000014 t= 0.07680000000000015 t= 0.07700000000000015 t= 0.07720000000000016 t= 0.07740000000000016 t= 0.07760000000000017 t= 0.07780000000000017 t= 0.07800000000000018 t= 0.07820000000000019 t= 0.07840000000000019 t= 0.0786000000000002 t= 0.0788000000000002 t= 0.07900000000000021 t= 0.07920000000000021 t= 0.07940000000000022 t= 0.07960000000000023 t= 0.07980000000000023 t= 0.08000000000000024 t= 0.08020000000000024 t= 0.08040000000000025 t= 0.08060000000000025 t= 0.08080000000000026 t= 0.08100000000000027 t= 0.08120000000000027 t= 0.08140000000000028 t= 0.08160000000000028 t= 0.08180000000000029 t= 0.0820000000000003 t= 0.0822000000000003 t= 0.0824000000000003 t= 0.08260000000000031 t= 0.08280000000000032 t= 0.08300000000000032 t= 0.08320000000000033 t= 0.08340000000000033 t= 0.08360000000000034 t= 0.08380000000000035 t= 0.08400000000000035 t= 0.08420000000000036 t= 0.08440000000000036 t= 0.08460000000000037 t= 0.08480000000000038 t= 0.08500000000000038 t= 0.08520000000000039 t= 0.08540000000000039 t= 0.0856000000000004 t= 0.0858000000000004 t= 0.08600000000000041 t= 0.08620000000000042 t= 0.08640000000000042 t= 0.08660000000000043 t= 0.08680000000000043 t= 0.08700000000000044 t= 0.08720000000000044 t= 0.08740000000000045 t= 0.08760000000000046 t= 0.08780000000000046 t= 0.08800000000000047 t= 0.08820000000000047 t= 0.08840000000000048 t= 0.08860000000000048 t= 0.08880000000000049 t= 0.0890000000000005 t= 0.0892000000000005 t= 0.0894000000000005 t= 0.08960000000000051 t= 0.08980000000000052 t= 0.09000000000000052 t= 0.09020000000000053 t= 0.09040000000000054 t= 0.09060000000000054 t= 0.09080000000000055 t= 0.09100000000000055 t= 0.09120000000000056 t= 0.09140000000000056 t= 0.09160000000000057 t= 0.09180000000000058 t= 0.09200000000000058 t= 0.09220000000000059 t= 0.09240000000000059 t= 0.0926000000000006 t= 0.0928000000000006 t= 0.09300000000000061 t= 0.09320000000000062 t= 0.09340000000000062 t= 0.09360000000000063 t= 0.09380000000000063 t= 0.09400000000000064 t= 0.09420000000000064 t= 0.09440000000000065 t= 0.09460000000000066 t= 0.09480000000000066 t= 0.09500000000000067 t= 0.09520000000000067 t= 0.09540000000000068 t= 0.09560000000000068 t= 0.09580000000000069 t= 0.0960000000000007 t= 0.0962000000000007 t= 0.09640000000000071 t= 0.09660000000000071 t= 0.09680000000000072 t= 0.09700000000000072 t= 0.09720000000000073 t= 0.09740000000000074 t= 0.09760000000000074 t= 0.09780000000000075 t= 0.09800000000000075 t= 0.09820000000000076 t= 0.09840000000000076 t= 0.09860000000000077 t= 0.09880000000000078 t= 0.09900000000000078 t= 0.09920000000000079 t= 0.0994000000000008 t= 0.0996000000000008 t= 0.0998000000000008 t= 0.10000000000000081 t= 0.10020000000000082 t= 0.10040000000000082 t= 0.10060000000000083 t= 0.10080000000000083 t= 0.10100000000000084 t= 0.10120000000000084 t= 0.10140000000000085 t= 0.10160000000000086 t= 0.10180000000000086 t= 0.10200000000000087 t= 0.10220000000000087 t= 0.10240000000000088 t= 0.10260000000000088 t= 0.10280000000000089 t= 0.1030000000000009 t= 0.1032000000000009 t= 0.10340000000000091 t= 0.10360000000000091 t= 0.10380000000000092 t= 0.10400000000000093 t= 0.10420000000000093 t= 0.10440000000000094 t= 0.10460000000000094 t= 0.10480000000000095 t= 0.10500000000000095 t= 0.10520000000000096 t= 0.10540000000000097 t= 0.10560000000000097 t= 0.10580000000000098 t= 0.10600000000000098 t= 0.10620000000000099 t= 0.106400000000001 t= 0.106600000000001 t= 0.106800000000001 t= 0.10700000000000101 t= 0.10720000000000102 t= 0.10740000000000102 t= 0.10760000000000103 t= 0.10780000000000103 t= 0.10800000000000104 t= 0.10820000000000105 t= 0.10840000000000105 t= 0.10860000000000106 t= 0.10880000000000106 t= 0.10900000000000107 t= 0.10920000000000107 t= 0.10940000000000108 t= 0.10960000000000109 t= 0.10980000000000109 t= 0.1100000000000011 t= 0.1102000000000011 t= 0.11040000000000111 t= 0.11060000000000111 t= 0.11080000000000112 t= 0.11100000000000113 t= 0.11120000000000113 t= 0.11140000000000114 t= 0.11160000000000114 t= 0.11180000000000115 t= 0.11200000000000115 t= 0.11220000000000116 t= 0.11240000000000117 t= 0.11260000000000117 t= 0.11280000000000118 t= 0.11300000000000118 t= 0.11320000000000119 t= 0.1134000000000012 t= 0.1136000000000012 t= 0.1138000000000012 t= 0.11400000000000121 t= 0.11420000000000122 t= 0.11440000000000122 t= 0.11460000000000123 t= 0.11480000000000123 t= 0.11500000000000124 t= 0.11520000000000125 t= 0.11540000000000125 t= 0.11560000000000126 t= 0.11580000000000126 t= 0.11600000000000127 t= 0.11620000000000127 t= 0.11640000000000128 t= 0.11660000000000129 t= 0.11680000000000129 t= 0.1170000000000013 t= 0.1172000000000013 t= 0.11740000000000131 t= 0.11760000000000131 t= 0.11780000000000132 t= 0.11800000000000133 t= 0.11820000000000133 t= 0.11840000000000134 t= 0.11860000000000134 t= 0.11880000000000135 t= 0.11900000000000135 t= 0.11920000000000136 t= 0.11940000000000137 t= 0.11960000000000137 t= 0.11980000000000138 t= 0.12000000000000138 t= 0.12020000000000139 t= 0.1204000000000014 t= 0.1206000000000014 t= 0.1208000000000014 t= 0.12100000000000141 t= 0.12120000000000142 t= 0.12140000000000142 t= 0.12160000000000143 t= 0.12180000000000143 t= 0.12200000000000144 t= 0.12220000000000145 t= 0.12240000000000145 t= 0.12260000000000146 t= 0.12280000000000146 t= 0.12300000000000147 t= 0.12320000000000147 t= 0.12340000000000148 t= 0.12360000000000149 t= 0.12380000000000149 t= 0.1240000000000015 t= 0.1242000000000015 t= 0.12440000000000151 t= 0.12460000000000152 t= 0.12480000000000152 t= 0.12500000000000153 t= 0.12520000000000153 t= 0.12540000000000154 t= 0.12560000000000154 t= 0.12580000000000155 t= 0.12600000000000156 t= 0.12620000000000156 t= 0.12640000000000157 t= 0.12660000000000157 t= 0.12680000000000158 t= 0.12700000000000158 t= 0.1272000000000016 t= 0.1274000000000016 t= 0.1276000000000016 t= 0.1278000000000016 t= 0.1280000000000016 t= 0.12820000000000162 t= 0.12840000000000162 t= 0.12860000000000163 t= 0.12880000000000164 t= 0.12900000000000164 t= 0.12920000000000165 t= 0.12940000000000165 t= 0.12960000000000166 t= 0.12980000000000166 t= 0.13000000000000167 t= 0.13020000000000168 t= 0.13040000000000168 t= 0.1306000000000017 t= 0.1308000000000017 t= 0.1310000000000017 t= 0.1312000000000017 t= 0.1314000000000017 t= 0.13160000000000172 t= 0.13180000000000172 t= 0.13200000000000173 t= 0.13220000000000173 t= 0.13240000000000174 t= 0.13260000000000174 t= 0.13280000000000175 t= 0.13300000000000176 t= 0.13320000000000176 t= 0.13340000000000177 t= 0.13360000000000177 t= 0.13380000000000178 t= 0.13400000000000178 t= 0.1342000000000018 t= 0.1344000000000018 t= 0.1346000000000018 t= 0.1348000000000018 t= 0.1350000000000018 t= 0.13520000000000182 t= 0.13540000000000182 t= 0.13560000000000183 t= 0.13580000000000184 t= 0.13600000000000184 t= 0.13620000000000185 t= 0.13640000000000185 t= 0.13660000000000186 t= 0.13680000000000186 t= 0.13700000000000187 t= 0.13720000000000188 t= 0.13740000000000188 t= 0.1376000000000019 t= 0.1378000000000019 t= 0.1380000000000019 t= 0.1382000000000019 t= 0.1384000000000019 t= 0.13860000000000192 t= 0.13880000000000192 t= 0.13900000000000193 t= 0.13920000000000193 t= 0.13940000000000194 t= 0.13960000000000194 t= 0.13980000000000195 t= 0.14000000000000196 t= 0.14020000000000196 t= 0.14040000000000197 t= 0.14060000000000197 t= 0.14080000000000198 t= 0.14100000000000198 t= 0.141200000000002 t= 0.141400000000002 t= 0.141600000000002 t= 0.141800000000002 t= 0.142000000000002 t= 0.14220000000000202 t= 0.14240000000000202 t= 0.14260000000000203 t= 0.14280000000000204 t= 0.14300000000000204 t= 0.14320000000000205 t= 0.14340000000000205 t= 0.14360000000000206 t= 0.14380000000000207 t= 0.14400000000000207 t= 0.14420000000000208 t= 0.14440000000000208 t= 0.1446000000000021 t= 0.1448000000000021 t= 0.1450000000000021 t= 0.1452000000000021 t= 0.1454000000000021 t= 0.14560000000000212 t= 0.14580000000000212 t= 0.14600000000000213 t= 0.14620000000000213 t= 0.14640000000000214 t= 0.14660000000000215 t= 0.14680000000000215 t= 0.14700000000000216 t= 0.14720000000000216 t= 0.14740000000000217 t= 0.14760000000000217 t= 0.14780000000000218 t= 0.14800000000000219 t= 0.1482000000000022 t= 0.1484000000000022 t= 0.1486000000000022 t= 0.1488000000000022 t= 0.14900000000000221 t= 0.14920000000000222 t= 0.14940000000000223 t= 0.14960000000000223 t= 0.14980000000000224 t= 0.15000000000000224 t= 0.15020000000000225 t= 0.15040000000000225 t= 0.15060000000000226 t= 0.15080000000000227 t= 0.15100000000000227 t= 0.15120000000000228 t= 0.15140000000000228 t= 0.1516000000000023 t= 0.1518000000000023 t= 0.1520000000000023 t= 0.1522000000000023 t= 0.1524000000000023 t= 0.15260000000000232 t= 0.15280000000000232 t= 0.15300000000000233 t= 0.15320000000000233 t= 0.15340000000000234 t= 0.15360000000000235 t= 0.15380000000000235 t= 0.15400000000000236 t= 0.15420000000000236 t= 0.15440000000000237 t= 0.15460000000000237 t= 0.15480000000000238 t= 0.15500000000000239 t= 0.1552000000000024 t= 0.1554000000000024 t= 0.1556000000000024 t= 0.1558000000000024 t= 0.15600000000000241 t= 0.15620000000000242 t= 0.15640000000000243 t= 0.15660000000000243 t= 0.15680000000000244 t= 0.15700000000000244 t= 0.15720000000000245 t= 0.15740000000000245 t= 0.15760000000000246 t= 0.15780000000000247 t= 0.15800000000000247 t= 0.15820000000000248 t= 0.15840000000000248 t= 0.1586000000000025 t= 0.1588000000000025 t= 0.1590000000000025 t= 0.1592000000000025 t= 0.1594000000000025 t= 0.15960000000000252 t= 0.15980000000000252 t= 0.16000000000000253 t= 0.16020000000000253 t= 0.16040000000000254 t= 0.16060000000000255 t= 0.16080000000000255 t= 0.16100000000000256 t= 0.16120000000000256 t= 0.16140000000000257 t= 0.16160000000000257 t= 0.16180000000000258 t= 0.1620000000000026 t= 0.1622000000000026 t= 0.1624000000000026 t= 0.1626000000000026 t= 0.1628000000000026 t= 0.16300000000000262 t= 0.16320000000000262 t= 0.16340000000000263 t= 0.16360000000000263 t= 0.16380000000000264 t= 0.16400000000000264 t= 0.16420000000000265 t= 0.16440000000000266 t= 0.16460000000000266 t= 0.16480000000000267 t= 0.16500000000000267 t= 0.16520000000000268 t= 0.16540000000000268 t= 0.1656000000000027 t= 0.1658000000000027 t= 0.1660000000000027 t= 0.1662000000000027 t= 0.1664000000000027 t= 0.16660000000000272 t= 0.16680000000000272 t= 0.16700000000000273 t= 0.16720000000000274 t= 0.16740000000000274 t= 0.16760000000000275 t= 0.16780000000000275 t= 0.16800000000000276 t= 0.16820000000000276 t= 0.16840000000000277 t= 0.16860000000000278 t= 0.16880000000000278 t= 0.1690000000000028 t= 0.1692000000000028 t= 0.1694000000000028 t= 0.1696000000000028 t= 0.1698000000000028 t= 0.17000000000000282 t= 0.17020000000000282 t= 0.17040000000000283 t= 0.17060000000000283 t= 0.17080000000000284 t= 0.17100000000000284 t= 0.17120000000000285 t= 0.17140000000000286 t= 0.17160000000000286 t= 0.17180000000000287 t= 0.17200000000000287 t= 0.17220000000000288 t= 0.17240000000000288 t= 0.1726000000000029 t= 0.1728000000000029 t= 0.1730000000000029 t= 0.1732000000000029 t= 0.1734000000000029 t= 0.17360000000000292 t= 0.17380000000000292 t= 0.17400000000000293 t= 0.17420000000000294 t= 0.17440000000000294 t= 0.17460000000000295 t= 0.17480000000000295 t= 0.17500000000000296 t= 0.17520000000000296 t= 0.17540000000000297 t= 0.17560000000000298 t= 0.17580000000000298 t= 0.176000000000003 t= 0.176200000000003 t= 0.176400000000003 t= 0.176600000000003 t= 0.176800000000003 t= 0.17700000000000302 t= 0.17720000000000302 t= 0.17740000000000303 t= 0.17760000000000303 t= 0.17780000000000304 t= 0.17800000000000304 t= 0.17820000000000305 t= 0.17840000000000306 t= 0.17860000000000306 t= 0.17880000000000307 t= 0.17900000000000307 t= 0.17920000000000308 t= 0.17940000000000308 t= 0.1796000000000031 t= 0.1798000000000031 t= 0.1800000000000031 t= 0.1802000000000031 t= 0.1804000000000031 t= 0.18060000000000312 t= 0.18080000000000312 t= 0.18100000000000313 t= 0.18120000000000314 t= 0.18140000000000314 t= 0.18160000000000315 t= 0.18180000000000315 t= 0.18200000000000316 t= 0.18220000000000316 t= 0.18240000000000317 t= 0.18260000000000318 t= 0.18280000000000318 t= 0.1830000000000032 t= 0.1832000000000032 t= 0.1834000000000032 t= 0.1836000000000032 t= 0.1838000000000032 t= 0.18400000000000322 t= 0.18420000000000322 t= 0.18440000000000323 t= 0.18460000000000323 t= 0.18480000000000324 t= 0.18500000000000325 t= 0.18520000000000325 t= 0.18540000000000326 t= 0.18560000000000326 t= 0.18580000000000327 t= 0.18600000000000327 t= 0.18620000000000328 t= 0.18640000000000329 t= 0.1866000000000033 t= 0.1868000000000033 t= 0.1870000000000033 t= 0.1872000000000033 t= 0.18740000000000331 t= 0.18760000000000332 t= 0.18780000000000333 t= 0.18800000000000333 t= 0.18820000000000334 t= 0.18840000000000334 t= 0.18860000000000335 t= 0.18880000000000335 t= 0.18900000000000336 t= 0.18920000000000337 t= 0.18940000000000337 t= 0.18960000000000338 t= 0.18980000000000338 t= 0.1900000000000034 t= 0.1902000000000034 t= 0.1904000000000034 t= 0.1906000000000034 t= 0.1908000000000034 t= 0.19100000000000342 t= 0.19120000000000342 t= 0.19140000000000343 t= 0.19160000000000343 t= 0.19180000000000344 t= 0.19200000000000345 t= 0.19220000000000345 t= 0.19240000000000346 t= 0.19260000000000346 t= 0.19280000000000347 t= 0.19300000000000347 t= 0.19320000000000348 t= 0.19340000000000349 t= 0.1936000000000035 t= 0.1938000000000035 t= 0.1940000000000035 t= 0.1942000000000035 t= 0.19440000000000351 t= 0.19460000000000352 t= 0.19480000000000353 t= 0.19500000000000353 t= 0.19520000000000354 t= 0.19540000000000354 t= 0.19560000000000355 t= 0.19580000000000355 t= 0.19600000000000356 t= 0.19620000000000357 t= 0.19640000000000357 t= 0.19660000000000358 t= 0.19680000000000358 t= 0.1970000000000036 t= 0.1972000000000036 t= 0.1974000000000036 t= 0.1976000000000036 t= 0.1978000000000036 t= 0.19800000000000362 t= 0.19820000000000362 t= 0.19840000000000363 t= 0.19860000000000363 t= 0.19880000000000364 t= 0.19900000000000365 t= 0.19920000000000365 t= 0.19940000000000366 t= 0.19960000000000366 t= 0.19980000000000367 t= 0.20000000000000367 t= 0.20020000000000368 t= 0.2004000000000037 t= 0.2006000000000037 t= 0.2008000000000037 t= 0.2010000000000037 t= 0.2012000000000037 t= 0.20140000000000371 t= 0.20160000000000372 t= 0.20180000000000373 t= 0.20200000000000373 t= 0.20220000000000374 t= 0.20240000000000374 t= 0.20260000000000375 t= 0.20280000000000376 t= 0.20300000000000376 t= 0.20320000000000377 t= 0.20340000000000377 t= 0.20360000000000378 t= 0.20380000000000378 t= 0.2040000000000038 t= 0.2042000000000038 t= 0.2044000000000038 t= 0.2046000000000038 t= 0.2048000000000038 t= 0.20500000000000382 t= 0.20520000000000382 t= 0.20540000000000383 t= 0.20560000000000384 t= 0.20580000000000384 t= 0.20600000000000385 t= 0.20620000000000385 t= 0.20640000000000386 t= 0.20660000000000386 t= 0.20680000000000387 t= 0.20700000000000388 t= 0.20720000000000388 t= 0.2074000000000039 t= 0.2076000000000039 t= 0.2078000000000039 t= 0.2080000000000039 t= 0.2082000000000039 t= 0.20840000000000392 t= 0.20860000000000392 t= 0.20880000000000393 t= 0.20900000000000393 t= 0.20920000000000394 t= 0.20940000000000394 t= 0.20960000000000395 t= 0.20980000000000396 t= 0.21000000000000396 t= 0.21020000000000397 t= 0.21040000000000397 t= 0.21060000000000398 t= 0.21080000000000398 t= 0.211000000000004 t= 0.211200000000004 t= 0.211400000000004 t= 0.211600000000004 t= 0.211800000000004 t= 0.21200000000000402 t= 0.21220000000000402 t= 0.21240000000000403 t= 0.21260000000000404 t= 0.21280000000000404 t= 0.21300000000000405 t= 0.21320000000000405 t= 0.21340000000000406 t= 0.21360000000000406 t= 0.21380000000000407 t= 0.21400000000000408 t= 0.21420000000000408 t= 0.2144000000000041 t= 0.2146000000000041 t= 0.2148000000000041 t= 0.2150000000000041 t= 0.2152000000000041 t= 0.21540000000000412 t= 0.21560000000000412 t= 0.21580000000000413 t= 0.21600000000000413 t= 0.21620000000000414 t= 0.21640000000000414 t= 0.21660000000000415 t= 0.21680000000000416 t= 0.21700000000000416 t= 0.21720000000000417 t= 0.21740000000000417 t= 0.21760000000000418 t= 0.21780000000000418 t= 0.2180000000000042 t= 0.2182000000000042 t= 0.2184000000000042 t= 0.2186000000000042 t= 0.2188000000000042 t= 0.21900000000000422 t= 0.21920000000000422 t= 0.21940000000000423 t= 0.21960000000000424 t= 0.21980000000000424 t= 0.22000000000000425 t= 0.22020000000000425 t= 0.22040000000000426 t= 0.22060000000000426 t= 0.22080000000000427 t= 0.22100000000000428 t= 0.22120000000000428 t= 0.2214000000000043 t= 0.2216000000000043 t= 0.2218000000000043 t= 0.2220000000000043 t= 0.2222000000000043 t= 0.22240000000000432 t= 0.22260000000000432 t= 0.22280000000000433 t= 0.22300000000000433 t= 0.22320000000000434 t= 0.22340000000000435 t= 0.22360000000000435 t= 0.22380000000000436 t= 0.22400000000000436 t= 0.22420000000000437 t= 0.22440000000000437 t= 0.22460000000000438 t= 0.22480000000000439 t= 0.2250000000000044 t= 0.2252000000000044 t= 0.2254000000000044 t= 0.2256000000000044 t= 0.2258000000000044 t= 0.22600000000000442 t= 0.22620000000000443 t= 0.22640000000000443 t= 0.22660000000000444 t= 0.22680000000000444 t= 0.22700000000000445 t= 0.22720000000000445 t= 0.22740000000000446 t= 0.22760000000000447 t= 0.22780000000000447 t= 0.22800000000000448 t= 0.22820000000000448 t= 0.2284000000000045 t= 0.2286000000000045 t= 0.2288000000000045 t= 0.2290000000000045 t= 0.2292000000000045 t= 0.22940000000000452 t= 0.22960000000000452 t= 0.22980000000000453 t= 0.23000000000000453 t= 0.23020000000000454 t= 0.23040000000000455 t= 0.23060000000000455 t= 0.23080000000000456 t= 0.23100000000000456 t= 0.23120000000000457 t= 0.23140000000000457 t= 0.23160000000000458 t= 0.23180000000000459 t= 0.2320000000000046 t= 0.2322000000000046 t= 0.2324000000000046 t= 0.2326000000000046 t= 0.23280000000000461 t= 0.23300000000000462 t= 0.23320000000000463 t= 0.23340000000000463 t= 0.23360000000000464 t= 0.23380000000000464 t= 0.23400000000000465 t= 0.23420000000000465 t= 0.23440000000000466 t= 0.23460000000000467 t= 0.23480000000000467 t= 0.23500000000000468 t= 0.23520000000000468 t= 0.2354000000000047 t= 0.2356000000000047 t= 0.2358000000000047 t= 0.2360000000000047 t= 0.2362000000000047 t= 0.23640000000000472 t= 0.23660000000000472 t= 0.23680000000000473 t= 0.23700000000000473 t= 0.23720000000000474 t= 0.23740000000000475 t= 0.23760000000000475 t= 0.23780000000000476 t= 0.23800000000000476 t= 0.23820000000000477 t= 0.23840000000000477 t= 0.23860000000000478 t= 0.2388000000000048 t= 0.2390000000000048 t= 0.2392000000000048 t= 0.2394000000000048 t= 0.2396000000000048 t= 0.23980000000000481 t= 0.24000000000000482 t= 0.24020000000000483 t= 0.24040000000000483 t= 0.24060000000000484 t= 0.24080000000000484 t= 0.24100000000000485 t= 0.24120000000000485 t= 0.24140000000000486 t= 0.24160000000000487 t= 0.24180000000000487 t= 0.24200000000000488 t= 0.24220000000000488 t= 0.2424000000000049 t= 0.2426000000000049 t= 0.2428000000000049 t= 0.2430000000000049 t= 0.2432000000000049 t= 0.24340000000000492 t= 0.24360000000000492 t= 0.24380000000000493 t= 0.24400000000000494 t= 0.24420000000000494 t= 0.24440000000000495 t= 0.24460000000000495 t= 0.24480000000000496 t= 0.24500000000000496 t= 0.24520000000000497 t= 0.24540000000000498 t= 0.24560000000000498 t= 0.245800000000005 t= 0.246000000000005 t= 0.246200000000005 t= 0.246400000000005 t= 0.246600000000005 t= 0.24680000000000502 t= 0.24700000000000502 t= 0.24720000000000503 t= 0.24740000000000503 t= 0.24760000000000504 t= 0.24780000000000504 t= 0.24800000000000505 t= 0.24820000000000506 t= 0.24840000000000506 t= 0.24860000000000507 t= 0.24880000000000507 t= 0.24900000000000508 t= 0.24920000000000508 t= 0.2494000000000051 t= 0.2496000000000051 t= 0.2498000000000051 t= 0.2500000000000051 t= 0.2502000000000051 t= 0.25040000000000506 t= 0.25060000000000504 t= 0.250800000000005 t= 0.251000000000005 t= 0.251200000000005 t= 0.25140000000000495 t= 0.25160000000000493 t= 0.2518000000000049 t= 0.2520000000000049 t= 0.25220000000000486 t= 0.25240000000000484 t= 0.2526000000000048 t= 0.2528000000000048 t= 0.2530000000000048 t= 0.25320000000000475 t= 0.25340000000000473 t= 0.2536000000000047 t= 0.2538000000000047 t= 0.25400000000000467 t= 0.25420000000000464 t= 0.2544000000000046 t= 0.2546000000000046 t= 0.2548000000000046 t= 0.25500000000000456 t= 0.25520000000000453 t= 0.2554000000000045 t= 0.2556000000000045 t= 0.25580000000000447 t= 0.25600000000000445 t= 0.2562000000000044 t= 0.2564000000000044 t= 0.2566000000000044 t= 0.25680000000000436 t= 0.25700000000000434 t= 0.2572000000000043 t= 0.2574000000000043 t= 0.25760000000000427 t= 0.25780000000000425 t= 0.2580000000000042 t= 0.2582000000000042 t= 0.2584000000000042 t= 0.25860000000000416 t= 0.25880000000000414 t= 0.2590000000000041 t= 0.2592000000000041 t= 0.25940000000000407 t= 0.25960000000000405 t= 0.259800000000004 t= 0.260000000000004 t= 0.260200000000004 t= 0.26040000000000396 t= 0.26060000000000394 t= 0.2608000000000039 t= 0.2610000000000039 t= 0.2612000000000039 t= 0.26140000000000385 t= 0.26160000000000383 t= 0.2618000000000038 t= 0.2620000000000038 t= 0.26220000000000376 t= 0.26240000000000374 t= 0.2626000000000037 t= 0.2628000000000037 t= 0.2630000000000037 t= 0.26320000000000365 t= 0.26340000000000363 t= 0.2636000000000036 t= 0.2638000000000036 t= 0.26400000000000357 t= 0.26420000000000354 t= 0.2644000000000035 t= 0.2646000000000035 t= 0.2648000000000035 t= 0.26500000000000346 t= 0.26520000000000343 t= 0.2654000000000034 t= 0.2656000000000034 t= 0.26580000000000337 t= 0.26600000000000334 t= 0.2662000000000033 t= 0.2664000000000033 t= 0.2666000000000033 t= 0.26680000000000326 t= 0.26700000000000323 t= 0.2672000000000032 t= 0.2674000000000032 t= 0.26760000000000317 t= 0.26780000000000315 t= 0.2680000000000031 t= 0.2682000000000031 t= 0.2684000000000031 t= 0.26860000000000306 t= 0.26880000000000304 t= 0.269000000000003 t= 0.269200000000003 t= 0.26940000000000297 t= 0.26960000000000295 t= 0.2698000000000029 t= 0.2700000000000029 t= 0.2702000000000029 t= 0.27040000000000286 t= 0.27060000000000284 t= 0.2708000000000028 t= 0.2710000000000028 t= 0.27120000000000277 t= 0.27140000000000275 t= 0.27160000000000273 t= 0.2718000000000027 t= 0.2720000000000027 t= 0.27220000000000266 t= 0.27240000000000264 t= 0.2726000000000026 t= 0.2728000000000026 t= 0.2730000000000026 t= 0.27320000000000255 t= 0.27340000000000253 t= 0.2736000000000025 t= 0.2738000000000025 t= 0.27400000000000246 t= 0.27420000000000244 t= 0.2744000000000024 t= 0.2746000000000024 t= 0.2748000000000024 t= 0.27500000000000235 t= 0.27520000000000233 t= 0.2754000000000023 t= 0.2756000000000023 t= 0.27580000000000227 t= 0.27600000000000224 t= 0.2762000000000022 t= 0.2764000000000022 t= 0.2766000000000022 t= 0.27680000000000216 t= 0.27700000000000213 t= 0.2772000000000021 t= 0.2774000000000021 t= 0.27760000000000207 t= 0.27780000000000205 t= 0.278000000000002 t= 0.278200000000002 t= 0.278400000000002 t= 0.27860000000000196 t= 0.27880000000000194 t= 0.2790000000000019 t= 0.2792000000000019 t= 0.27940000000000187 t= 0.27960000000000185 t= 0.2798000000000018 t= 0.2800000000000018 t= 0.2802000000000018 t= 0.28040000000000176 t= 0.28060000000000174 t= 0.2808000000000017 t= 0.2810000000000017 t= 0.28120000000000167 t= 0.28140000000000165 t= 0.2816000000000016 t= 0.2818000000000016 t= 0.2820000000000016 t= 0.28220000000000156 t= 0.28240000000000154 t= 0.2826000000000015 t= 0.2828000000000015 t= 0.2830000000000015 t= 0.28320000000000145 t= 0.28340000000000143 t= 0.2836000000000014 t= 0.2838000000000014 t= 0.28400000000000136 t= 0.28420000000000134 t= 0.2844000000000013 t= 0.2846000000000013 t= 0.2848000000000013 t= 0.28500000000000125 t= 0.28520000000000123 t= 0.2854000000000012 t= 0.2856000000000012 t= 0.28580000000000116 t= 0.28600000000000114 t= 0.2862000000000011 t= 0.2864000000000011 t= 0.2866000000000011 t= 0.28680000000000105 t= 0.28700000000000103 t= 0.287200000000001 t= 0.287400000000001 t= 0.28760000000000097 t= 0.28780000000000094 t= 0.2880000000000009 t= 0.2882000000000009 t= 0.2884000000000009 t= 0.28860000000000086 t= 0.28880000000000083 t= 0.2890000000000008 t= 0.2892000000000008 t= 0.28940000000000077 t= 0.28960000000000075 t= 0.2898000000000007 t= 0.2900000000000007 t= 0.2902000000000007 t= 0.29040000000000066 t= 0.29060000000000064 t= 0.2908000000000006 t= 0.2910000000000006 t= 0.29120000000000057 t= 0.29140000000000055 t= 0.2916000000000005 t= 0.2918000000000005 t= 0.2920000000000005 t= 0.29220000000000046 t= 0.29240000000000044 t= 0.2926000000000004 t= 0.2928000000000004 t= 0.29300000000000037 t= 0.29320000000000035 t= 0.2934000000000003 t= 0.2936000000000003 t= 0.2938000000000003 t= 0.29400000000000026 t= 0.29420000000000024 t= 0.2944000000000002 t= 0.2946000000000002 t= 0.2948000000000002 t= 0.29500000000000015 t= 0.29520000000000013 t= 0.2954000000000001 t= 0.2956000000000001 t= 0.29580000000000006 t= 0.29600000000000004 t= 0.2962 t= 0.2964 t= 0.2966 t= 0.29679999999999995 t= 0.29699999999999993 t= 0.2971999999999999 t= 0.2973999999999999 t= 0.29759999999999986 t= 0.29779999999999984 t= 0.2979999999999998 t= 0.2981999999999998 t= 0.2983999999999998 t= 0.29859999999999975 t= 0.29879999999999973 t= 0.2989999999999997 t= 0.2991999999999997 t= 0.29939999999999967 t= 0.29959999999999964 t= 0.2997999999999996 t= 0.2999999999999996 t= 0.3001999999999996 t= 0.30039999999999956 t= 0.30059999999999953 t= 0.3007999999999995 t= 0.3009999999999995 t= 0.30119999999999947 t= 0.30139999999999945 t= 0.3015999999999994 t= 0.3017999999999994 t= 0.3019999999999994 t= 0.30219999999999936 t= 0.30239999999999934 t= 0.3025999999999993 t= 0.3027999999999993 t= 0.30299999999999927 t= 0.30319999999999925 t= 0.3033999999999992 t= 0.3035999999999992 t= 0.3037999999999992 t= 0.30399999999999916 t= 0.30419999999999914 t= 0.3043999999999991 t= 0.3045999999999991 t= 0.30479999999999907 t= 0.30499999999999905 t= 0.305199999999999 t= 0.305399999999999 t= 0.305599999999999 t= 0.30579999999999896 t= 0.30599999999999894 t= 0.3061999999999989 t= 0.3063999999999989 t= 0.3065999999999989 t= 0.30679999999999885 t= 0.30699999999999883 t= 0.3071999999999988 t= 0.3073999999999988 t= 0.30759999999999876 t= 0.30779999999999874 t= 0.3079999999999987 t= 0.3081999999999987 t= 0.3083999999999987 t= 0.30859999999999865 t= 0.30879999999999863 t= 0.3089999999999986 t= 0.3091999999999986 t= 0.30939999999999857 t= 0.30959999999999854 t= 0.3097999999999985 t= 0.3099999999999985 t= 0.3101999999999985 t= 0.31039999999999845 t= 0.31059999999999843 t= 0.3107999999999984 t= 0.3109999999999984 t= 0.31119999999999837 t= 0.31139999999999834 t= 0.3115999999999983 t= 0.3117999999999983 t= 0.3119999999999983 t= 0.31219999999999826 t= 0.31239999999999823 t= 0.3125999999999982 t= 0.3127999999999982 t= 0.31299999999999817 t= 0.31319999999999815 t= 0.3133999999999981 t= 0.3135999999999981 t= 0.3137999999999981 t= 0.31399999999999806 t= 0.31419999999999804 t= 0.314399999999998 t= 0.314599999999998 t= 0.31479999999999797 t= 0.31499999999999795 t= 0.3151999999999979 t= 0.3153999999999979 t= 0.3155999999999979 t= 0.31579999999999786 t= 0.31599999999999784 t= 0.3161999999999978 t= 0.3163999999999978 t= 0.31659999999999777 t= 0.31679999999999775 t= 0.31699999999999773 t= 0.3171999999999977 t= 0.3173999999999977 t= 0.31759999999999766 t= 0.31779999999999764 t= 0.3179999999999976 t= 0.3181999999999976 t= 0.3183999999999976 t= 0.31859999999999755 t= 0.31879999999999753 t= 0.3189999999999975 t= 0.3191999999999975 t= 0.31939999999999746 t= 0.31959999999999744 t= 0.3197999999999974 t= 0.3199999999999974 t= 0.3201999999999974 t= 0.32039999999999735 t= 0.32059999999999733 t= 0.3207999999999973 t= 0.3209999999999973 t= 0.32119999999999727 t= 0.32139999999999724 t= 0.3215999999999972 t= 0.3217999999999972 t= 0.3219999999999972 t= 0.32219999999999716 t= 0.32239999999999713 t= 0.3225999999999971 t= 0.3227999999999971 t= 0.32299999999999707 t= 0.32319999999999705 t= 0.323399999999997 t= 0.323599999999997 t= 0.323799999999997 t= 0.32399999999999696 t= 0.32419999999999694 t= 0.3243999999999969 t= 0.3245999999999969 t= 0.32479999999999687 t= 0.32499999999999685 t= 0.3251999999999968 t= 0.3253999999999968 t= 0.3255999999999968 t= 0.32579999999999676 t= 0.32599999999999674 t= 0.3261999999999967 t= 0.3263999999999967 t= 0.32659999999999667 t= 0.32679999999999665 t= 0.3269999999999966 t= 0.3271999999999966 t= 0.3273999999999966 t= 0.32759999999999656 t= 0.32779999999999654 t= 0.3279999999999965 t= 0.3281999999999965 t= 0.3283999999999965 t= 0.32859999999999645 t= 0.32879999999999643 t= 0.3289999999999964 t= 0.3291999999999964 t= 0.32939999999999636 t= 0.32959999999999634 t= 0.3297999999999963 t= 0.3299999999999963 t= 0.3301999999999963 t= 0.33039999999999625 t= 0.33059999999999623 t= 0.3307999999999962 t= 0.3309999999999962 t= 0.33119999999999616 t= 0.33139999999999614 t= 0.3315999999999961 t= 0.3317999999999961 t= 0.3319999999999961 t= 0.33219999999999605 t= 0.33239999999999603 t= 0.332599999999996 t= 0.332799999999996 t= 0.33299999999999597 t= 0.33319999999999594 t= 0.3333999999999959 t= 0.3335999999999959 t= 0.3337999999999959 t= 0.33399999999999586 t= 0.33419999999999583 t= 0.3343999999999958 t= 0.3345999999999958 t= 0.33479999999999577 t= 0.33499999999999575 t= 0.3351999999999957 t= 0.3353999999999957 t= 0.3355999999999957 t= 0.33579999999999566 t= 0.33599999999999564 t= 0.3361999999999956 t= 0.3363999999999956 t= 0.33659999999999557 t= 0.33679999999999555 t= 0.3369999999999955 t= 0.3371999999999955 t= 0.3373999999999955 t= 0.33759999999999546 t= 0.33779999999999544 t= 0.3379999999999954 t= 0.3381999999999954 t= 0.33839999999999537 t= 0.33859999999999535 t= 0.3387999999999953 t= 0.3389999999999953 t= 0.3391999999999953 t= 0.33939999999999526 t= 0.33959999999999524 t= 0.3397999999999952 t= 0.3399999999999952 t= 0.3401999999999952 t= 0.34039999999999515 t= 0.34059999999999513 t= 0.3407999999999951 t= 0.3409999999999951 t= 0.34119999999999506 t= 0.34139999999999504 t= 0.341599999999995 t= 0.341799999999995 t= 0.341999999999995 t= 0.34219999999999495 t= 0.34239999999999493 t= 0.3425999999999949 t= 0.3427999999999949 t= 0.34299999999999486 t= 0.34319999999999484 t= 0.3433999999999948 t= 0.3435999999999948 t= 0.3437999999999948 t= 0.34399999999999475 t= 0.34419999999999473 t= 0.3443999999999947 t= 0.3445999999999947 t= 0.34479999999999467 t= 0.34499999999999464 t= 0.3451999999999946 t= 0.3453999999999946 t= 0.3455999999999946 t= 0.34579999999999456 t= 0.34599999999999453 t= 0.3461999999999945 t= 0.3463999999999945 t= 0.34659999999999447 t= 0.34679999999999445 t= 0.3469999999999944 t= 0.3471999999999944 t= 0.3473999999999944 t= 0.34759999999999436 t= 0.34779999999999434 t= 0.3479999999999943 t= 0.3481999999999943 t= 0.34839999999999427 t= 0.34859999999999425 t= 0.3487999999999942 t= 0.3489999999999942 t= 0.3491999999999942 t= 0.34939999999999416 t= 0.34959999999999414 t= 0.3497999999999941 t= 0.3499999999999941 t= 0.35019999999999407 t= 0.35039999999999405 t= 0.350599999999994 t= 0.350799999999994 t= 0.350999999999994 t= 0.35119999999999396 t= 0.35139999999999394 t= 0.3515999999999939 t= 0.3517999999999939 t= 0.3519999999999939 t= 0.35219999999999385 t= 0.35239999999999383 t= 0.3525999999999938 t= 0.3527999999999938 t= 0.35299999999999376 t= 0.35319999999999374 t= 0.3533999999999937 t= 0.3535999999999937 t= 0.3537999999999937 t= 0.35399999999999365 t= 0.35419999999999363 t= 0.3543999999999936 t= 0.3545999999999936 t= 0.35479999999999356 t= 0.35499999999999354 t= 0.3551999999999935 t= 0.3553999999999935 t= 0.3555999999999935 t= 0.35579999999999345 t= 0.35599999999999343 t= 0.3561999999999934 t= 0.3563999999999934 t= 0.35659999999999337 t= 0.35679999999999334 t= 0.3569999999999933 t= 0.3571999999999933 t= 0.3573999999999933 t= 0.35759999999999326 t= 0.35779999999999323 t= 0.3579999999999932 t= 0.3581999999999932 t= 0.35839999999999317 t= 0.35859999999999315 t= 0.3587999999999931 t= 0.3589999999999931 t= 0.3591999999999931 t= 0.35939999999999306 t= 0.35959999999999304 t= 0.359799999999993 t= 0.359999999999993 t= 0.36019999999999297 t= 0.36039999999999295 t= 0.3605999999999929 t= 0.3607999999999929 t= 0.3609999999999929 t= 0.36119999999999286 t= 0.36139999999999284 t= 0.3615999999999928 t= 0.3617999999999928 t= 0.36199999999999277 t= 0.36219999999999275 t= 0.36239999999999273 t= 0.3625999999999927 t= 0.3627999999999927 t= 0.36299999999999266 t= 0.36319999999999264 t= 0.3633999999999926 t= 0.3635999999999926 t= 0.3637999999999926 t= 0.36399999999999255 t= 0.36419999999999253 t= 0.3643999999999925 t= 0.3645999999999925 t= 0.36479999999999246 t= 0.36499999999999244 t= 0.3651999999999924 t= 0.3653999999999924 t= 0.3655999999999924 t= 0.36579999999999235 t= 0.36599999999999233 t= 0.3661999999999923 t= 0.3663999999999923 t= 0.36659999999999227 t= 0.36679999999999224 t= 0.3669999999999922 t= 0.3671999999999922 t= 0.3673999999999922 t= 0.36759999999999216 t= 0.36779999999999213 t= 0.3679999999999921 t= 0.3681999999999921 t= 0.36839999999999207 t= 0.36859999999999205 t= 0.368799999999992 t= 0.368999999999992 t= 0.369199999999992 t= 0.36939999999999196 t= 0.36959999999999193 t= 0.3697999999999919 t= 0.3699999999999919 t= 0.37019999999999187 t= 0.37039999999999185 t= 0.3705999999999918 t= 0.3707999999999918 t= 0.3709999999999918 t= 0.37119999999999176 t= 0.37139999999999174 t= 0.3715999999999917 t= 0.3717999999999917 t= 0.37199999999999167 t= 0.37219999999999165 t= 0.3723999999999916 t= 0.3725999999999916 t= 0.3727999999999916 t= 0.37299999999999156 t= 0.37319999999999154 t= 0.3733999999999915 t= 0.3735999999999915 t= 0.3737999999999915 t= 0.37399999999999145 t= 0.37419999999999143 t= 0.3743999999999914 t= 0.3745999999999914 t= 0.37479999999999136 t= 0.37499999999999134 t= 0.3751999999999913 t= 0.3753999999999913 t= 0.3755999999999913 t= 0.37579999999999125 t= 0.37599999999999123 t= 0.3761999999999912 t= 0.3763999999999912 t= 0.37659999999999116 t= 0.37679999999999114 t= 0.3769999999999911 t= 0.3771999999999911 t= 0.3773999999999911 t= 0.37759999999999105 t= 0.37779999999999103 t= 0.377999999999991 t= 0.378199999999991 t= 0.37839999999999097 t= 0.37859999999999094 t= 0.3787999999999909 t= 0.3789999999999909 t= 0.3791999999999909 t= 0.37939999999999086 t= 0.37959999999999083 t= 0.3797999999999908 t= 0.3799999999999908 t= 0.38019999999999077 t= 0.38039999999999075 t= 0.3805999999999907 t= 0.3807999999999907 t= 0.3809999999999907 t= 0.38119999999999066 t= 0.38139999999999064 t= 0.3815999999999906 t= 0.3817999999999906 t= 0.38199999999999057 t= 0.38219999999999055 t= 0.3823999999999905 t= 0.3825999999999905 t= 0.3827999999999905 t= 0.38299999999999046 t= 0.38319999999999044 t= 0.3833999999999904 t= 0.3835999999999904 t= 0.38379999999999037 t= 0.38399999999999035 t= 0.3841999999999903 t= 0.3843999999999903 t= 0.3845999999999903 t= 0.38479999999999026 t= 0.38499999999999024 t= 0.3851999999999902 t= 0.3853999999999902 t= 0.3855999999999902 t= 0.38579999999999015 t= 0.38599999999999013 t= 0.3861999999999901 t= 0.3863999999999901 t= 0.38659999999999006 t= 0.38679999999999004 t= 0.38699999999999 t= 0.38719999999999 t= 0.38739999999999 t= 0.38759999999998995 t= 0.38779999999998993 t= 0.3879999999999899 t= 0.3881999999999899 t= 0.38839999999998986 t= 0.38859999999998984 t= 0.3887999999999898 t= 0.3889999999999898 t= 0.3891999999999898 t= 0.38939999999998975 t= 0.38959999999998973 t= 0.3897999999999897 t= 0.3899999999999897 t= 0.39019999999998967 t= 0.39039999999998964 t= 0.3905999999999896 t= 0.3907999999999896 t= 0.3909999999999896 t= 0.39119999999998956 t= 0.39139999999998953 t= 0.3915999999999895 t= 0.3917999999999895 t= 0.39199999999998947 t= 0.39219999999998945 t= 0.3923999999999894 t= 0.3925999999999894 t= 0.3927999999999894 t= 0.39299999999998936 t= 0.39319999999998934 t= 0.3933999999999893 t= 0.3935999999999893 t= 0.39379999999998927 t= 0.39399999999998925 t= 0.3941999999999892 t= 0.3943999999999892 t= 0.3945999999999892 t= 0.39479999999998916 t= 0.39499999999998914 t= 0.3951999999999891 t= 0.3953999999999891 t= 0.39559999999998907 t= 0.39579999999998905 t= 0.395999999999989 t= 0.396199999999989 t= 0.396399999999989 t= 0.39659999999998896 t= 0.39679999999998894 t= 0.3969999999999889 t= 0.3971999999999889 t= 0.3973999999999889 t= 0.39759999999998885 t= 0.39779999999998883 t= 0.3979999999999888 t= 0.3981999999999888 t= 0.39839999999998876 t= 0.39859999999998874 t= 0.3987999999999887 t= 0.3989999999999887 t= 0.3991999999999887 t= 0.39939999999998865 t= 0.39959999999998863 t= 0.3997999999999886 t= 0.3999999999999886 t= 0.40019999999998856 t= 0.40039999999998854 t= 0.4005999999999885 t= 0.4007999999999885 t= 0.4009999999999885 t= 0.40119999999998845 t= 0.40139999999998843 t= 0.4015999999999884 t= 0.4017999999999884 t= 0.40199999999998837 t= 0.40219999999998834 t= 0.4023999999999883 t= 0.4025999999999883 t= 0.4027999999999883 t= 0.40299999999998826 t= 0.40319999999998823 t= 0.4033999999999882 t= 0.4035999999999882 t= 0.40379999999998817 t= 0.40399999999998815 t= 0.4041999999999881 t= 0.4043999999999881 t= 0.4045999999999881 t= 0.40479999999998806 t= 0.40499999999998804 t= 0.405199999999988 t= 0.405399999999988 t= 0.40559999999998797 t= 0.40579999999998795 t= 0.4059999999999879 t= 0.4061999999999879 t= 0.4063999999999879 t= 0.40659999999998786 t= 0.40679999999998784 t= 0.4069999999999878 t= 0.4071999999999878 t= 0.40739999999998777 t= 0.40759999999998775 t= 0.40779999999998773 t= 0.4079999999999877 t= 0.4081999999999877 t= 0.40839999999998766 t= 0.40859999999998764 t= 0.4087999999999876 t= 0.4089999999999876 t= 0.4091999999999876 t= 0.40939999999998755 t= 0.40959999999998753 t= 0.4097999999999875 t= 0.4099999999999875 t= 0.41019999999998746 t= 0.41039999999998744 t= 0.4105999999999874 t= 0.4107999999999874 t= 0.4109999999999874 t= 0.41119999999998735 t= 0.41139999999998733 t= 0.4115999999999873 t= 0.4117999999999873 t= 0.41199999999998727 t= 0.41219999999998724 t= 0.4123999999999872 t= 0.4125999999999872 t= 0.4127999999999872 t= 0.41299999999998716 t= 0.41319999999998713 t= 0.4133999999999871 t= 0.4135999999999871 t= 0.41379999999998707 t= 0.41399999999998705 t= 0.414199999999987 t= 0.414399999999987 t= 0.414599999999987 t= 0.41479999999998696 t= 0.41499999999998693 t= 0.4151999999999869 t= 0.4153999999999869 t= 0.41559999999998687 t= 0.41579999999998685 t= 0.4159999999999868 t= 0.4161999999999868 t= 0.4163999999999868 t= 0.41659999999998676 t= 0.41679999999998674 t= 0.4169999999999867 t= 0.4171999999999867 t= 0.41739999999998667 t= 0.41759999999998665 t= 0.4177999999999866 t= 0.4179999999999866 t= 0.4181999999999866 t= 0.41839999999998656 t= 0.41859999999998654 t= 0.4187999999999865 t= 0.4189999999999865 t= 0.4191999999999865 t= 0.41939999999998645 t= 0.41959999999998643 t= 0.4197999999999864 t= 0.4199999999999864 t= 0.42019999999998636 t= 0.42039999999998634 t= 0.4205999999999863 t= 0.4207999999999863 t= 0.4209999999999863 t= 0.42119999999998625 t= 0.42139999999998623 t= 0.4215999999999862 t= 0.4217999999999862 t= 0.42199999999998616 t= 0.42219999999998614 t= 0.4223999999999861 t= 0.4225999999999861 t= 0.4227999999999861 t= 0.42299999999998605 t= 0.42319999999998603 t= 0.423399999999986 t= 0.423599999999986 t= 0.42379999999998597 t= 0.42399999999998594 t= 0.4241999999999859 t= 0.4243999999999859 t= 0.4245999999999859 t= 0.42479999999998586 t= 0.42499999999998583 t= 0.4251999999999858 t= 0.4253999999999858 t= 0.42559999999998577 t= 0.42579999999998575 t= 0.4259999999999857 t= 0.4261999999999857 t= 0.4263999999999857 t= 0.42659999999998566 t= 0.42679999999998564 t= 0.4269999999999856 t= 0.4271999999999856 t= 0.42739999999998557 t= 0.42759999999998555 t= 0.4277999999999855 t= 0.4279999999999855 t= 0.4281999999999855 t= 0.42839999999998546 t= 0.42859999999998544 t= 0.4287999999999854 t= 0.4289999999999854 t= 0.42919999999998537 t= 0.42939999999998535 t= 0.4295999999999853 t= 0.4297999999999853 t= 0.4299999999999853 t= 0.43019999999998526 t= 0.43039999999998524 t= 0.4305999999999852 t= 0.4307999999999852 t= 0.4309999999999852 t= 0.43119999999998515 t= 0.43139999999998513 t= 0.4315999999999851 t= 0.4317999999999851 t= 0.43199999999998506 t= 0.43219999999998504 t= 0.432399999999985 t= 0.432599999999985 t= 0.432799999999985 t= 0.43299999999998495 t= 0.43319999999998493 t= 0.4333999999999849 t= 0.4335999999999849 t= 0.43379999999998486 t= 0.43399999999998484 t= 0.4341999999999848 t= 0.4343999999999848 t= 0.4345999999999848 t= 0.43479999999998475 t= 0.43499999999998473 t= 0.4351999999999847 t= 0.4353999999999847 t= 0.43559999999998467 t= 0.43579999999998464 t= 0.4359999999999846 t= 0.4361999999999846 t= 0.4363999999999846 t= 0.43659999999998456 t= 0.43679999999998453 t= 0.4369999999999845 t= 0.4371999999999845 t= 0.43739999999998447 t= 0.43759999999998445 t= 0.4377999999999844 t= 0.4379999999999844 t= 0.4381999999999844 t= 0.43839999999998436 t= 0.43859999999998434 t= 0.4387999999999843 t= 0.4389999999999843 t= 0.43919999999998427 t= 0.43939999999998425 t= 0.4395999999999842 t= 0.4397999999999842 t= 0.4399999999999842 t= 0.44019999999998416 t= 0.44039999999998414 t= 0.4405999999999841 t= 0.4407999999999841 t= 0.44099999999998407 t= 0.44119999999998405 t= 0.441399999999984 t= 0.441599999999984 t= 0.441799999999984 t= 0.44199999999998396 t= 0.44219999999998394 t= 0.4423999999999839 t= 0.4425999999999839 t= 0.4427999999999839 t= 0.44299999999998385 t= 0.44319999999998383 t= 0.4433999999999838 t= 0.4435999999999838 t= 0.44379999999998376 t= 0.44399999999998374 t= 0.4441999999999837 t= 0.4443999999999837 t= 0.4445999999999837 t= 0.44479999999998365 t= 0.44499999999998363 t= 0.4451999999999836 t= 0.4453999999999836 t= 0.44559999999998356 t= 0.44579999999998354 t= 0.4459999999999835 t= 0.4461999999999835 t= 0.4463999999999835 t= 0.44659999999998345 t= 0.44679999999998343 t= 0.4469999999999834 t= 0.4471999999999834 t= 0.44739999999998337 t= 0.44759999999998334 t= 0.4477999999999833 t= 0.4479999999999833 t= 0.4481999999999833 t= 0.44839999999998326 t= 0.44859999999998323 t= 0.4487999999999832 t= 0.4489999999999832 t= 0.44919999999998317 t= 0.44939999999998315 t= 0.4495999999999831 t= 0.4497999999999831 t= 0.4499999999999831 t= 0.45019999999998306 t= 0.45039999999998304 t= 0.450599999999983 t= 0.450799999999983 t= 0.45099999999998297 t= 0.45119999999998295 t= 0.4513999999999829 t= 0.4515999999999829 t= 0.4517999999999829 t= 0.45199999999998286 t= 0.45219999999998284 t= 0.4523999999999828 t= 0.4525999999999828 t= 0.45279999999998277 t= 0.45299999999998275 t= 0.45319999999998273 t= 0.4533999999999827 t= 0.4535999999999827 t= 0.45379999999998266 t= 0.45399999999998264 t= 0.4541999999999826 t= 0.4543999999999826 t= 0.4545999999999826 t= 0.45479999999998255 t= 0.45499999999998253 t= 0.4551999999999825 t= 0.4553999999999825 t= 0.45559999999998246 t= 0.45579999999998244 t= 0.4559999999999824 t= 0.4561999999999824 t= 0.4563999999999824 t= 0.45659999999998235 t= 0.45679999999998233 t= 0.4569999999999823 t= 0.4571999999999823 t= 0.45739999999998227 t= 0.45759999999998224 t= 0.4577999999999822 t= 0.4579999999999822 t= 0.4581999999999822 t= 0.45839999999998216 t= 0.45859999999998213 t= 0.4587999999999821 t= 0.4589999999999821 t= 0.45919999999998207 t= 0.45939999999998204 t= 0.459599999999982 t= 0.459799999999982 t= 0.459999999999982 t= 0.46019999999998196 t= 0.46039999999998193 t= 0.4605999999999819 t= 0.4607999999999819 t= 0.46099999999998187 t= 0.46119999999998185 t= 0.4613999999999818 t= 0.4615999999999818 t= 0.4617999999999818 t= 0.46199999999998176 t= 0.46219999999998174 t= 0.4623999999999817 t= 0.4625999999999817 t= 0.46279999999998167 t= 0.46299999999998165 t= 0.4631999999999816 t= 0.4633999999999816 t= 0.4635999999999816 t= 0.46379999999998156 t= 0.46399999999998154 t= 0.4641999999999815 t= 0.4643999999999815 t= 0.46459999999998147 t= 0.46479999999998145 t= 0.46499999999998143 t= 0.4651999999999814 t= 0.4653999999999814 t= 0.46559999999998136 t= 0.46579999999998134 t= 0.4659999999999813 t= 0.4661999999999813 t= 0.4663999999999813 t= 0.46659999999998125 t= 0.46679999999998123 t= 0.4669999999999812 t= 0.4671999999999812 t= 0.46739999999998116 t= 0.46759999999998114 t= 0.4677999999999811 t= 0.4679999999999811 t= 0.4681999999999811 t= 0.46839999999998105 t= 0.46859999999998103 t= 0.468799999999981 t= 0.468999999999981 t= 0.46919999999998097 t= 0.46939999999998094 t= 0.4695999999999809 t= 0.4697999999999809 t= 0.4699999999999809 t= 0.47019999999998086 t= 0.47039999999998083 t= 0.4705999999999808 t= 0.4707999999999808 t= 0.47099999999998077 t= 0.47119999999998075 t= 0.4713999999999807 t= 0.4715999999999807 t= 0.4717999999999807 t= 0.47199999999998066 t= 0.47219999999998064 t= 0.4723999999999806 t= 0.4725999999999806 t= 0.47279999999998057 t= 0.47299999999998055 t= 0.4731999999999805 t= 0.4733999999999805 t= 0.4735999999999805 t= 0.47379999999998046 t= 0.47399999999998044 t= 0.4741999999999804 t= 0.4743999999999804 t= 0.47459999999998037 t= 0.47479999999998035 t= 0.4749999999999803 t= 0.4751999999999803 t= 0.4753999999999803 t= 0.47559999999998026 t= 0.47579999999998024 t= 0.4759999999999802 t= 0.4761999999999802 t= 0.4763999999999802 t= 0.47659999999998015 t= 0.47679999999998013 t= 0.4769999999999801 t= 0.4771999999999801 t= 0.47739999999998006 t= 0.47759999999998004 t= 0.47779999999998 t= 0.47799999999998 t= 0.47819999999998 t= 0.47839999999997995 t= 0.47859999999997993 t= 0.4787999999999799 t= 0.4789999999999799 t= 0.47919999999997986 t= 0.47939999999997984 t= 0.4795999999999798 t= 0.4797999999999798 t= 0.4799999999999798 t= 0.48019999999997975 t= 0.48039999999997973 t= 0.4805999999999797 t= 0.4807999999999797 t= 0.48099999999997967 t= 0.48119999999997964 t= 0.4813999999999796 t= 0.4815999999999796 t= 0.4817999999999796 t= 0.48199999999997956 t= 0.48219999999997953 t= 0.4823999999999795 t= 0.4825999999999795 t= 0.48279999999997947 t= 0.48299999999997945 t= 0.4831999999999794 t= 0.4833999999999794 t= 0.4835999999999794 t= 0.48379999999997936 t= 0.48399999999997934 t= 0.4841999999999793 t= 0.4843999999999793 t= 0.48459999999997927 t= 0.48479999999997925 t= 0.4849999999999792 t= 0.4851999999999792 t= 0.4853999999999792 t= 0.48559999999997916 t= 0.48579999999997914 t= 0.4859999999999791 t= 0.4861999999999791 t= 0.48639999999997907 t= 0.48659999999997905 t= 0.486799999999979 t= 0.486999999999979 t= 0.487199999999979 t= 0.48739999999997896 t= 0.48759999999997894 t= 0.4877999999999789 t= 0.4879999999999789 t= 0.4881999999999789 t= 0.48839999999997885 t= 0.48859999999997883 t= 0.4887999999999788 t= 0.4889999999999788 t= 0.48919999999997876 t= 0.48939999999997874 t= 0.4895999999999787 t= 0.4897999999999787 t= 0.4899999999999787 t= 0.49019999999997865 t= 0.49039999999997863 t= 0.4905999999999786 t= 0.4907999999999786 t= 0.49099999999997856 t= 0.49119999999997854 t= 0.4913999999999785 t= 0.4915999999999785 t= 0.4917999999999785 t= 0.49199999999997845 t= 0.49219999999997843 t= 0.4923999999999784 t= 0.4925999999999784 t= 0.49279999999997837 t= 0.49299999999997834 t= 0.4931999999999783 t= 0.4933999999999783 t= 0.4935999999999783 t= 0.49379999999997826 t= 0.49399999999997823 t= 0.4941999999999782 t= 0.4943999999999782 t= 0.49459999999997817 t= 0.49479999999997815 t= 0.4949999999999781 t= 0.4951999999999781 t= 0.4953999999999781 t= 0.49559999999997806 t= 0.49579999999997804 t= 0.495999999999978 t= 0.496199999999978 t= 0.49639999999997797 t= 0.49659999999997795 t= 0.4967999999999779 t= 0.4969999999999779 t= 0.4971999999999779 t= 0.49739999999997786 t= 0.49759999999997784 t= 0.4977999999999778 t= 0.4979999999999778 t= 0.49819999999997777 t= 0.49839999999997775 t= 0.4985999999999777 t= 0.4987999999999777 t= 0.4989999999999777 t= 0.49919999999997766 t= 0.49939999999997764 t= 0.4995999999999776 t= 0.4997999999999776 t= 0.4999999999999776 t= 0.5001999999999776 t= 0.5003999999999775 t= 0.5005999999999775 t= 0.5007999999999775 t= 0.5009999999999775 t= 0.5011999999999774 t= 0.5013999999999774 t= 0.5015999999999774 t= 0.5017999999999774 t= 0.5019999999999774 t= 0.5021999999999773 t= 0.5023999999999773 t= 0.5025999999999773 t= 0.5027999999999773 t= 0.5029999999999772 t= 0.5031999999999772 t= 0.5033999999999772 t= 0.5035999999999772 t= 0.5037999999999772 t= 0.5039999999999771 t= 0.5041999999999771 t= 0.5043999999999771 t= 0.5045999999999771 t= 0.504799999999977 t= 0.504999999999977 t= 0.505199999999977 t= 0.505399999999977 t= 0.505599999999977 t= 0.5057999999999769 t= 0.5059999999999769 t= 0.5061999999999769 t= 0.5063999999999769 t= 0.5065999999999768 t= 0.5067999999999768 t= 0.5069999999999768 t= 0.5071999999999768 t= 0.5073999999999768 t= 0.5075999999999767 t= 0.5077999999999767 t= 0.5079999999999767 t= 0.5081999999999767 t= 0.5083999999999766 t= 0.5085999999999766 t= 0.5087999999999766 t= 0.5089999999999766 t= 0.5091999999999766 t= 0.5093999999999765 t= 0.5095999999999765 t= 0.5097999999999765 t= 0.5099999999999765 t= 0.5101999999999765 t= 0.5103999999999764 t= 0.5105999999999764 t= 0.5107999999999764 t= 0.5109999999999764 t= 0.5111999999999763 t= 0.5113999999999763 t= 0.5115999999999763 t= 0.5117999999999763 t= 0.5119999999999763 t= 0.5121999999999762 t= 0.5123999999999762 t= 0.5125999999999762 t= 0.5127999999999762 t= 0.5129999999999761 t= 0.5131999999999761 t= 0.5133999999999761 t= 0.5135999999999761 t= 0.513799999999976 t= 0.513999999999976 t= 0.514199999999976 t= 0.514399999999976 t= 0.514599999999976 t= 0.5147999999999759 t= 0.5149999999999759 t= 0.5151999999999759 t= 0.5153999999999759 t= 0.5155999999999759 t= 0.5157999999999758 t= 0.5159999999999758 t= 0.5161999999999758 t= 0.5163999999999758 t= 0.5165999999999757 t= 0.5167999999999757 t= 0.5169999999999757 t= 0.5171999999999757 t= 0.5173999999999757 t= 0.5175999999999756 t= 0.5177999999999756 t= 0.5179999999999756 t= 0.5181999999999756 t= 0.5183999999999755 t= 0.5185999999999755 t= 0.5187999999999755 t= 0.5189999999999755 t= 0.5191999999999755 t= 0.5193999999999754 t= 0.5195999999999754 t= 0.5197999999999754 t= 0.5199999999999754 t= 0.5201999999999753 t= 0.5203999999999753 t= 0.5205999999999753 t= 0.5207999999999753 t= 0.5209999999999753 t= 0.5211999999999752 t= 0.5213999999999752 t= 0.5215999999999752 t= 0.5217999999999752 t= 0.5219999999999752 t= 0.5221999999999751 t= 0.5223999999999751 t= 0.5225999999999751 t= 0.5227999999999751 t= 0.522999999999975 t= 0.523199999999975 t= 0.523399999999975 t= 0.523599999999975 t= 0.523799999999975 t= 0.5239999999999749 t= 0.5241999999999749 t= 0.5243999999999749 t= 0.5245999999999749 t= 0.5247999999999748 t= 0.5249999999999748 t= 0.5251999999999748 t= 0.5253999999999748 t= 0.5255999999999748 t= 0.5257999999999747 t= 0.5259999999999747 t= 0.5261999999999747 t= 0.5263999999999747 t= 0.5265999999999746 t= 0.5267999999999746 t= 0.5269999999999746 t= 0.5271999999999746 t= 0.5273999999999746 t= 0.5275999999999745 t= 0.5277999999999745 t= 0.5279999999999745 t= 0.5281999999999745 t= 0.5283999999999744 t= 0.5285999999999744 t= 0.5287999999999744 t= 0.5289999999999744 t= 0.5291999999999744 t= 0.5293999999999743 t= 0.5295999999999743 t= 0.5297999999999743 t= 0.5299999999999743 t= 0.5301999999999742 t= 0.5303999999999742 t= 0.5305999999999742 t= 0.5307999999999742 t= 0.5309999999999742 t= 0.5311999999999741 t= 0.5313999999999741 t= 0.5315999999999741 t= 0.5317999999999741 t= 0.531999999999974 t= 0.532199999999974 t= 0.532399999999974 t= 0.532599999999974 t= 0.532799999999974 t= 0.5329999999999739 t= 0.5331999999999739 t= 0.5333999999999739 t= 0.5335999999999739 t= 0.5337999999999739 t= 0.5339999999999738 t= 0.5341999999999738 t= 0.5343999999999738 t= 0.5345999999999738 t= 0.5347999999999737 t= 0.5349999999999737 t= 0.5351999999999737 t= 0.5353999999999737 t= 0.5355999999999737 t= 0.5357999999999736 t= 0.5359999999999736 t= 0.5361999999999736 t= 0.5363999999999736 t= 0.5365999999999735 t= 0.5367999999999735 t= 0.5369999999999735 t= 0.5371999999999735 t= 0.5373999999999735 t= 0.5375999999999734 t= 0.5377999999999734 t= 0.5379999999999734 t= 0.5381999999999734 t= 0.5383999999999733 t= 0.5385999999999733 t= 0.5387999999999733 t= 0.5389999999999733 t= 0.5391999999999733 t= 0.5393999999999732 t= 0.5395999999999732 t= 0.5397999999999732 t= 0.5399999999999732 t= 0.5401999999999731 t= 0.5403999999999731 t= 0.5405999999999731 t= 0.5407999999999731 t= 0.5409999999999731 t= 0.541199999999973 t= 0.541399999999973 t= 0.541599999999973 t= 0.541799999999973 t= 0.541999999999973 t= 0.5421999999999729 t= 0.5423999999999729 t= 0.5425999999999729 t= 0.5427999999999729 t= 0.5429999999999728 t= 0.5431999999999728 t= 0.5433999999999728 t= 0.5435999999999728 t= 0.5437999999999727 t= 0.5439999999999727 t= 0.5441999999999727 t= 0.5443999999999727 t= 0.5445999999999727 t= 0.5447999999999726 t= 0.5449999999999726 t= 0.5451999999999726 t= 0.5453999999999726 t= 0.5455999999999726 t= 0.5457999999999725 t= 0.5459999999999725 t= 0.5461999999999725 t= 0.5463999999999725 t= 0.5465999999999724 t= 0.5467999999999724 t= 0.5469999999999724 t= 0.5471999999999724 t= 0.5473999999999724 t= 0.5475999999999723 t= 0.5477999999999723 t= 0.5479999999999723 t= 0.5481999999999723 t= 0.5483999999999722 t= 0.5485999999999722 t= 0.5487999999999722 t= 0.5489999999999722 t= 0.5491999999999722 t= 0.5493999999999721 t= 0.5495999999999721 t= 0.5497999999999721 t= 0.5499999999999721 t= 0.550199999999972 t= 0.550399999999972 t= 0.550599999999972 t= 0.550799999999972 t= 0.550999999999972 t= 0.5511999999999719 t= 0.5513999999999719 t= 0.5515999999999719 t= 0.5517999999999719 t= 0.5519999999999718 t= 0.5521999999999718 t= 0.5523999999999718 t= 0.5525999999999718 t= 0.5527999999999718 t= 0.5529999999999717 t= 0.5531999999999717 t= 0.5533999999999717 t= 0.5535999999999717 t= 0.5537999999999716 t= 0.5539999999999716 t= 0.5541999999999716 t= 0.5543999999999716 t= 0.5545999999999716 t= 0.5547999999999715 t= 0.5549999999999715 t= 0.5551999999999715 t= 0.5553999999999715 t= 0.5555999999999715 t= 0.5557999999999714 t= 0.5559999999999714 t= 0.5561999999999714 t= 0.5563999999999714 t= 0.5565999999999713 t= 0.5567999999999713 t= 0.5569999999999713 t= 0.5571999999999713 t= 0.5573999999999713 t= 0.5575999999999712 t= 0.5577999999999712 t= 0.5579999999999712 t= 0.5581999999999712 t= 0.5583999999999711 t= 0.5585999999999711 t= 0.5587999999999711 t= 0.5589999999999711 t= 0.559199999999971 t= 0.559399999999971 t= 0.559599999999971 t= 0.559799999999971 t= 0.559999999999971 t= 0.5601999999999709 t= 0.5603999999999709 t= 0.5605999999999709 t= 0.5607999999999709 t= 0.5609999999999709 t= 0.5611999999999708 t= 0.5613999999999708 t= 0.5615999999999708 t= 0.5617999999999708 t= 0.5619999999999707 t= 0.5621999999999707 t= 0.5623999999999707 t= 0.5625999999999707 t= 0.5627999999999707 t= 0.5629999999999706 t= 0.5631999999999706 t= 0.5633999999999706 t= 0.5635999999999706 t= 0.5637999999999705 t= 0.5639999999999705 t= 0.5641999999999705 t= 0.5643999999999705 t= 0.5645999999999705 t= 0.5647999999999704 t= 0.5649999999999704 t= 0.5651999999999704 t= 0.5653999999999704 t= 0.5655999999999703 t= 0.5657999999999703 t= 0.5659999999999703 t= 0.5661999999999703 t= 0.5663999999999703 t= 0.5665999999999702 t= 0.5667999999999702 t= 0.5669999999999702 t= 0.5671999999999702 t= 0.5673999999999702 t= 0.5675999999999701 t= 0.5677999999999701 t= 0.5679999999999701 t= 0.5681999999999701 t= 0.56839999999997 t= 0.56859999999997 t= 0.56879999999997 t= 0.56899999999997 t= 0.56919999999997 t= 0.5693999999999699 t= 0.5695999999999699 t= 0.5697999999999699 t= 0.5699999999999699 t= 0.5701999999999698 t= 0.5703999999999698 t= 0.5705999999999698 t= 0.5707999999999698 t= 0.5709999999999698 t= 0.5711999999999697 t= 0.5713999999999697 t= 0.5715999999999697 t= 0.5717999999999697 t= 0.5719999999999696 t= 0.5721999999999696 t= 0.5723999999999696 t= 0.5725999999999696 t= 0.5727999999999696 t= 0.5729999999999695 t= 0.5731999999999695 t= 0.5733999999999695 t= 0.5735999999999695 t= 0.5737999999999694 t= 0.5739999999999694 t= 0.5741999999999694 t= 0.5743999999999694 t= 0.5745999999999694 t= 0.5747999999999693 t= 0.5749999999999693 t= 0.5751999999999693 t= 0.5753999999999693 t= 0.5755999999999692 t= 0.5757999999999692 t= 0.5759999999999692 t= 0.5761999999999692 t= 0.5763999999999692 t= 0.5765999999999691 t= 0.5767999999999691 t= 0.5769999999999691 t= 0.5771999999999691 t= 0.577399999999969 t= 0.577599999999969 t= 0.577799999999969 t= 0.577999999999969 t= 0.578199999999969 t= 0.5783999999999689 t= 0.5785999999999689 t= 0.5787999999999689 t= 0.5789999999999689 t= 0.5791999999999689 t= 0.5793999999999688 t= 0.5795999999999688 t= 0.5797999999999688 t= 0.5799999999999688 t= 0.5801999999999687 t= 0.5803999999999687 t= 0.5805999999999687 t= 0.5807999999999687 t= 0.5809999999999687 t= 0.5811999999999686 t= 0.5813999999999686 t= 0.5815999999999686 t= 0.5817999999999686 t= 0.5819999999999685 t= 0.5821999999999685 t= 0.5823999999999685 t= 0.5825999999999685 t= 0.5827999999999685 t= 0.5829999999999684 t= 0.5831999999999684 t= 0.5833999999999684 t= 0.5835999999999684 t= 0.5837999999999683 t= 0.5839999999999683 t= 0.5841999999999683 t= 0.5843999999999683 t= 0.5845999999999683 t= 0.5847999999999682 t= 0.5849999999999682 t= 0.5851999999999682 t= 0.5853999999999682 t= 0.5855999999999681 t= 0.5857999999999681 t= 0.5859999999999681 t= 0.5861999999999681 t= 0.5863999999999681 t= 0.586599999999968 t= 0.586799999999968 t= 0.586999999999968 t= 0.587199999999968 t= 0.587399999999968 t= 0.5875999999999679 t= 0.5877999999999679 t= 0.5879999999999679 t= 0.5881999999999679 t= 0.5883999999999678 t= 0.5885999999999678 t= 0.5887999999999678 t= 0.5889999999999678 t= 0.5891999999999677 t= 0.5893999999999677 t= 0.5895999999999677 t= 0.5897999999999677 t= 0.5899999999999677 t= 0.5901999999999676 t= 0.5903999999999676 t= 0.5905999999999676 t= 0.5907999999999676 t= 0.5909999999999676 t= 0.5911999999999675 t= 0.5913999999999675 t= 0.5915999999999675 t= 0.5917999999999675 t= 0.5919999999999674 t= 0.5921999999999674 t= 0.5923999999999674 t= 0.5925999999999674 t= 0.5927999999999674 t= 0.5929999999999673 t= 0.5931999999999673 t= 0.5933999999999673 t= 0.5935999999999673 t= 0.5937999999999672 t= 0.5939999999999672 t= 0.5941999999999672 t= 0.5943999999999672 t= 0.5945999999999672 t= 0.5947999999999671 t= 0.5949999999999671 t= 0.5951999999999671 t= 0.5953999999999671 t= 0.595599999999967 t= 0.595799999999967 t= 0.595999999999967 t= 0.596199999999967 t= 0.596399999999967 t= 0.5965999999999669 t= 0.5967999999999669 t= 0.5969999999999669 t= 0.5971999999999669 t= 0.5973999999999668 t= 0.5975999999999668 t= 0.5977999999999668 t= 0.5979999999999668 t= 0.5981999999999668 t= 0.5983999999999667 t= 0.5985999999999667 t= 0.5987999999999667 t= 0.5989999999999667 t= 0.5991999999999666 t= 0.5993999999999666 t= 0.5995999999999666 t= 0.5997999999999666 t= 0.5999999999999666CPU times: user 4.55 s, sys: 40.6 ms, total: 4.59 s
Wall time: 4.55 s </pre>
t= 0.0002 t= 0.0004 t= 0.0006000000000000001 t= 0.0008 t= 0.001 t= 0.0012000000000000001 t= 0.0014000000000000002 t= 0.0016000000000000003 t= 0.0018000000000000004 t= 0.0020000000000000005 t= 0.0022000000000000006 t= 0.0024000000000000007 t= 0.0026000000000000007 t= 0.002800000000000001 t= 0.003000000000000001 t= 0.003200000000000001 t= 0.003400000000000001 t= 0.003600000000000001 t= 0.0038000000000000013 t= 0.004000000000000001 t= 0.004200000000000001 t= 0.0044 t= 0.0046 t= 0.0048 t= 0.004999999999999999 t= 0.005199999999999999 t= 0.0053999999999999986 t= 0.005599999999999998 t= 0.005799999999999998 t= 0.0059999999999999975 t= 0.006199999999999997 t= 0.006399999999999997 t= 0.0065999999999999965 t= 0.006799999999999996 t= 0.006999999999999996 t= 0.0071999999999999955 t= 0.007399999999999995 t= 0.007599999999999995 t= 0.0077999999999999944 t= 0.007999999999999995 t= 0.008199999999999995 t= 0.008399999999999996 t= 0.008599999999999997 t= 0.008799999999999997 t= 0.008999999999999998 t= 0.009199999999999998 t= 0.009399999999999999 t= 0.0096 t= 0.0098 t= 0.01 t= 0.0102 t= 0.010400000000000001 t= 0.010600000000000002 t= 0.010800000000000002 t= 0.011000000000000003 t= 0.011200000000000003 t= 0.011400000000000004 t= 0.011600000000000004 t= 0.011800000000000005 t= 0.012000000000000005 t= 0.012200000000000006 t= 0.012400000000000007 t= 0.012600000000000007 t= 0.012800000000000008 t= 0.013000000000000008 t= 0.013200000000000009 t= 0.013400000000000009 t= 0.01360000000000001 t= 0.01380000000000001 t= 0.01400000000000001 t= 0.014200000000000011 t= 0.014400000000000012 t= 0.014600000000000012 t= 0.014800000000000013 t= 0.015000000000000013 t= 0.015200000000000014 t= 0.015400000000000014 t= 0.015600000000000015 t= 0.015800000000000015 t= 0.016000000000000014 t= 0.016200000000000013 t= 0.016400000000000012 t= 0.01660000000000001 t= 0.01680000000000001 t= 0.017000000000000008 t= 0.017200000000000007 t= 0.017400000000000006 t= 0.017600000000000005 t= 0.017800000000000003 t= 0.018000000000000002 t= 0.0182 t= 0.0184 t= 0.0186 t= 0.018799999999999997 t= 0.018999999999999996 t= 0.019199999999999995 t= 0.019399999999999994 t= 0.019599999999999992 t= 0.01979999999999999 t= 0.01999999999999999 t= 0.02019999999999999 t= 0.020399999999999988 t= 0.020599999999999986 t= 0.020799999999999985 t= 0.020999999999999984 t= 0.021199999999999983 t= 0.02139999999999998 t= 0.02159999999999998 t= 0.02179999999999998 t= 0.021999999999999978 t= 0.022199999999999977 t= 0.022399999999999975 t= 0.022599999999999974 t= 0.022799999999999973 t= 0.022999999999999972 t= 0.02319999999999997 t= 0.02339999999999997 t= 0.023599999999999968 t= 0.023799999999999967 t= 0.023999999999999966 t= 0.024199999999999965 t= 0.024399999999999963 t= 0.024599999999999962 t= 0.02479999999999996 t= 0.02499999999999996 t= 0.02519999999999996 t= 0.025399999999999957 t= 0.025599999999999956 t= 0.025799999999999955 t= 0.025999999999999954 t= 0.026199999999999952 t= 0.02639999999999995 t= 0.02659999999999995 t= 0.02679999999999995 t= 0.026999999999999948 t= 0.027199999999999946 t= 0.027399999999999945 t= 0.027599999999999944 t= 0.027799999999999943 t= 0.02799999999999994 t= 0.02819999999999994 t= 0.02839999999999994 t= 0.028599999999999938 t= 0.028799999999999937 t= 0.028999999999999936 t= 0.029199999999999934 t= 0.029399999999999933 t= 0.029599999999999932 t= 0.02979999999999993 t= 0.02999999999999993 t= 0.03019999999999993 t= 0.030399999999999927 t= 0.030599999999999926 t= 0.030799999999999925 t= 0.030999999999999923 t= 0.031199999999999922 t= 0.03139999999999992 t= 0.03159999999999992 t= 0.03179999999999992 t= 0.03199999999999992 t= 0.032199999999999916 t= 0.032399999999999915 t= 0.032599999999999914 t= 0.03279999999999991 t= 0.03299999999999991 t= 0.03319999999999991 t= 0.03339999999999991 t= 0.03359999999999991 t= 0.033799999999999907 t= 0.033999999999999905 t= 0.034199999999999904 t= 0.0343999999999999 t= 0.0345999999999999 t= 0.0347999999999999 t= 0.0349999999999999 t= 0.0351999999999999 t= 0.0353999999999999 t= 0.035599999999999896 t= 0.035799999999999894 t= 0.03599999999999989 t= 0.03619999999999989 t= 0.03639999999999989 t= 0.03659999999999989 t= 0.03679999999999989 t= 0.03699999999999989 t= 0.037199999999999886 t= 0.037399999999999885 t= 0.037599999999999884 t= 0.03779999999999988 t= 0.03799999999999988 t= 0.03819999999999988 t= 0.03839999999999988 t= 0.03859999999999988 t= 0.038799999999999876 t= 0.038999999999999875 t= 0.039199999999999874 t= 0.03939999999999987 t= 0.03959999999999987 t= 0.03979999999999987 t= 0.03999999999999987 t= 0.04019999999999987 t= 0.04039999999999987 t= 0.040599999999999865 t= 0.040799999999999864 t= 0.04099999999999986 t= 0.04119999999999986 t= 0.04139999999999986 t= 0.04159999999999986 t= 0.04179999999999986 t= 0.04199999999999986 t= 0.042199999999999856 t= 0.042399999999999854 t= 0.04259999999999985 t= 0.04279999999999985 t= 0.04299999999999985 t= 0.04319999999999985 t= 0.04339999999999985 t= 0.04359999999999985 t= 0.043799999999999846 t= 0.043999999999999845 t= 0.044199999999999844 t= 0.04439999999999984 t= 0.04459999999999984 t= 0.04479999999999984 t= 0.04499999999999984 t= 0.04519999999999984 t= 0.045399999999999836 t= 0.045599999999999835 t= 0.045799999999999834 t= 0.04599999999999983 t= 0.04619999999999983 t= 0.04639999999999983 t= 0.04659999999999983 t= 0.04679999999999983 t= 0.04699999999999983 t= 0.047199999999999825 t= 0.047399999999999824 t= 0.04759999999999982 t= 0.04779999999999982 t= 0.04799999999999982 t= 0.04819999999999982 t= 0.04839999999999982 t= 0.04859999999999982 t= 0.048799999999999816 t= 0.048999999999999815 t= 0.04919999999999981 t= 0.04939999999999981 t= 0.04959999999999981 t= 0.04979999999999981 t= 0.04999999999999981 t= 0.05019999999999981 t= 0.050399999999999806 t= 0.050599999999999805 t= 0.050799999999999804 t= 0.0509999999999998 t= 0.0511999999999998 t= 0.0513999999999998 t= 0.0515999999999998 t= 0.0517999999999998 t= 0.051999999999999796 t= 0.052199999999999795 t= 0.052399999999999794 t= 0.05259999999999979 t= 0.05279999999999979 t= 0.05299999999999979 t= 0.05319999999999979 t= 0.05339999999999979 t= 0.05359999999999979 t= 0.053799999999999785 t= 0.053999999999999784 t= 0.05419999999999978 t= 0.05439999999999978 t= 0.05459999999999978 t= 0.05479999999999978 t= 0.05499999999999978 t= 0.05519999999999978 t= 0.055399999999999776 t= 0.055599999999999775 t= 0.05579999999999977 t= 0.05599999999999977 t= 0.05619999999999977 t= 0.05639999999999977 t= 0.05659999999999977 t= 0.05679999999999977 t= 0.056999999999999766 t= 0.057199999999999765 t= 0.057399999999999764 t= 0.05759999999999976 t= 0.05779999999999976 t= 0.05799999999999976 t= 0.05819999999999976 t= 0.05839999999999976 t= 0.058599999999999756 t= 0.058799999999999755 t= 0.058999999999999754 t= 0.05919999999999975 t= 0.05939999999999975 t= 0.05959999999999975 t= 0.05979999999999975 t= 0.05999999999999975 t= 0.06019999999999975 t= 0.060399999999999746 t= 0.060599999999999744 t= 0.06079999999999974 t= 0.06099999999999974 t= 0.06119999999999974 t= 0.06139999999999974 t= 0.06159999999999974 t= 0.06179999999999974 t= 0.061999999999999736 t= 0.062199999999999735 t= 0.06239999999999973 t= 0.06259999999999974 t= 0.06279999999999974 t= 0.06299999999999975 t= 0.06319999999999976 t= 0.06339999999999976 t= 0.06359999999999977 t= 0.06379999999999977 t= 0.06399999999999978 t= 0.06419999999999979 t= 0.06439999999999979 t= 0.0645999999999998 t= 0.0647999999999998 t= 0.06499999999999981 t= 0.06519999999999981 t= 0.06539999999999982 t= 0.06559999999999983 t= 0.06579999999999983 t= 0.06599999999999984 t= 0.06619999999999984 t= 0.06639999999999985 t= 0.06659999999999985 t= 0.06679999999999986 t= 0.06699999999999987 t= 0.06719999999999987 t= 0.06739999999999988 t= 0.06759999999999988 t= 0.06779999999999989 t= 0.0679999999999999 t= 0.0681999999999999 t= 0.0683999999999999 t= 0.06859999999999991 t= 0.06879999999999992 t= 0.06899999999999992 t= 0.06919999999999993 t= 0.06939999999999993 t= 0.06959999999999994 t= 0.06979999999999995 t= 0.06999999999999995 t= 0.07019999999999996 t= 0.07039999999999996 t= 0.07059999999999997 t= 0.07079999999999997 t= 0.07099999999999998 t= 0.07119999999999999 t= 0.07139999999999999 t= 0.0716 t= 0.0718 t= 0.07200000000000001 t= 0.07220000000000001 t= 0.07240000000000002 t= 0.07260000000000003 t= 0.07280000000000003 t= 0.07300000000000004 t= 0.07320000000000004 t= 0.07340000000000005 t= 0.07360000000000005 t= 0.07380000000000006 t= 0.07400000000000007 t= 0.07420000000000007 t= 0.07440000000000008 t= 0.07460000000000008 t= 0.07480000000000009 t= 0.0750000000000001 t= 0.0752000000000001 t= 0.0754000000000001 t= 0.07560000000000011 t= 0.07580000000000012 t= 0.07600000000000012 t= 0.07620000000000013 t= 0.07640000000000013 t= 0.07660000000000014 t= 0.07680000000000015 t= 0.07700000000000015 t= 0.07720000000000016 t= 0.07740000000000016 t= 0.07760000000000017 t= 0.07780000000000017 t= 0.07800000000000018 t= 0.07820000000000019 t= 0.07840000000000019 t= 0.0786000000000002 t= 0.0788000000000002 t= 0.07900000000000021 t= 0.07920000000000021 t= 0.07940000000000022 t= 0.07960000000000023 t= 0.07980000000000023 t= 0.08000000000000024 t= 0.08020000000000024 t= 0.08040000000000025 t= 0.08060000000000025 t= 0.08080000000000026 t= 0.08100000000000027 t= 0.08120000000000027 t= 0.08140000000000028 t= 0.08160000000000028 t= 0.08180000000000029 t= 0.0820000000000003 t= 0.0822000000000003 t= 0.0824000000000003 t= 0.08260000000000031 t= 0.08280000000000032 t= 0.08300000000000032 t= 0.08320000000000033 t= 0.08340000000000033 t= 0.08360000000000034 t= 0.08380000000000035 t= 0.08400000000000035 t= 0.08420000000000036 t= 0.08440000000000036 t= 0.08460000000000037 t= 0.08480000000000038 t= 0.08500000000000038 t= 0.08520000000000039 t= 0.08540000000000039 t= 0.0856000000000004 t= 0.0858000000000004 t= 0.08600000000000041 t= 0.08620000000000042 t= 0.08640000000000042 t= 0.08660000000000043 t= 0.08680000000000043 t= 0.08700000000000044 t= 0.08720000000000044 t= 0.08740000000000045 t= 0.08760000000000046 t= 0.08780000000000046 t= 0.08800000000000047 t= 0.08820000000000047 t= 0.08840000000000048 t= 0.08860000000000048 t= 0.08880000000000049 t= 0.0890000000000005 t= 0.0892000000000005 t= 0.0894000000000005 t= 0.08960000000000051 t= 0.08980000000000052 t= 0.09000000000000052 t= 0.09020000000000053 t= 0.09040000000000054 t= 0.09060000000000054 t= 0.09080000000000055 t= 0.09100000000000055 t= 0.09120000000000056 t= 0.09140000000000056 t= 0.09160000000000057 t= 0.09180000000000058 t= 0.09200000000000058 t= 0.09220000000000059 t= 0.09240000000000059 t= 0.0926000000000006 t= 0.0928000000000006 t= 0.09300000000000061 t= 0.09320000000000062 t= 0.09340000000000062 t= 0.09360000000000063 t= 0.09380000000000063 t= 0.09400000000000064 t= 0.09420000000000064 t= 0.09440000000000065 t= 0.09460000000000066 t= 0.09480000000000066 t= 0.09500000000000067 t= 0.09520000000000067 t= 0.09540000000000068 t= 0.09560000000000068 t= 0.09580000000000069 t= 0.0960000000000007 t= 0.0962000000000007 t= 0.09640000000000071 t= 0.09660000000000071 t= 0.09680000000000072 t= 0.09700000000000072 t= 0.09720000000000073 t= 0.09740000000000074 t= 0.09760000000000074 t= 0.09780000000000075 t= 0.09800000000000075 t= 0.09820000000000076 t= 0.09840000000000076 t= 0.09860000000000077 t= 0.09880000000000078 t= 0.09900000000000078 t= 0.09920000000000079 t= 0.0994000000000008 t= 0.0996000000000008 t= 0.0998000000000008 t= 0.10000000000000081 t= 0.10020000000000082 t= 0.10040000000000082 t= 0.10060000000000083 t= 0.10080000000000083 t= 0.10100000000000084 t= 0.10120000000000084 t= 0.10140000000000085 t= 0.10160000000000086 t= 0.10180000000000086 t= 0.10200000000000087 t= 0.10220000000000087 t= 0.10240000000000088 t= 0.10260000000000088 t= 0.10280000000000089 t= 0.1030000000000009 t= 0.1032000000000009 t= 0.10340000000000091 t= 0.10360000000000091 t= 0.10380000000000092 t= 0.10400000000000093 t= 0.10420000000000093 t= 0.10440000000000094 t= 0.10460000000000094 t= 0.10480000000000095 t= 0.10500000000000095 t= 0.10520000000000096 t= 0.10540000000000097 t= 0.10560000000000097 t= 0.10580000000000098 t= 0.10600000000000098 t= 0.10620000000000099 t= 0.106400000000001 t= 0.106600000000001 t= 0.106800000000001 t= 0.10700000000000101 t= 0.10720000000000102 t= 0.10740000000000102 t= 0.10760000000000103 t= 0.10780000000000103 t= 0.10800000000000104 t= 0.10820000000000105 t= 0.10840000000000105 t= 0.10860000000000106 t= 0.10880000000000106 t= 0.10900000000000107 t= 0.10920000000000107 t= 0.10940000000000108 t= 0.10960000000000109 t= 0.10980000000000109 t= 0.1100000000000011 t= 0.1102000000000011 t= 0.11040000000000111 t= 0.11060000000000111 t= 0.11080000000000112 t= 0.11100000000000113 t= 0.11120000000000113 t= 0.11140000000000114 t= 0.11160000000000114 t= 0.11180000000000115 t= 0.11200000000000115 t= 0.11220000000000116 t= 0.11240000000000117 t= 0.11260000000000117 t= 0.11280000000000118 t= 0.11300000000000118 t= 0.11320000000000119 t= 0.1134000000000012 t= 0.1136000000000012 t= 0.1138000000000012 t= 0.11400000000000121 t= 0.11420000000000122 t= 0.11440000000000122 t= 0.11460000000000123 t= 0.11480000000000123 t= 0.11500000000000124 t= 0.11520000000000125 t= 0.11540000000000125 t= 0.11560000000000126 t= 0.11580000000000126 t= 0.11600000000000127 t= 0.11620000000000127 t= 0.11640000000000128 t= 0.11660000000000129 t= 0.11680000000000129 t= 0.1170000000000013 t= 0.1172000000000013 t= 0.11740000000000131 t= 0.11760000000000131 t= 0.11780000000000132 t= 0.11800000000000133 t= 0.11820000000000133 t= 0.11840000000000134 t= 0.11860000000000134 t= 0.11880000000000135 t= 0.11900000000000135 t= 0.11920000000000136 t= 0.11940000000000137 t= 0.11960000000000137 t= 0.11980000000000138 t= 0.12000000000000138 t= 0.12020000000000139 t= 0.1204000000000014 t= 0.1206000000000014 t= 0.1208000000000014 t= 0.12100000000000141 t= 0.12120000000000142 t= 0.12140000000000142 t= 0.12160000000000143 t= 0.12180000000000143 t= 0.12200000000000144 t= 0.12220000000000145 t= 0.12240000000000145 t= 0.12260000000000146 t= 0.12280000000000146 t= 0.12300000000000147 t= 0.12320000000000147 t= 0.12340000000000148 t= 0.12360000000000149 t= 0.12380000000000149 t= 0.1240000000000015 t= 0.1242000000000015 t= 0.12440000000000151 t= 0.12460000000000152 t= 0.12480000000000152 t= 0.12500000000000153 t= 0.12520000000000153 t= 0.12540000000000154 t= 0.12560000000000154 t= 0.12580000000000155 t= 0.12600000000000156 t= 0.12620000000000156 t= 0.12640000000000157 t= 0.12660000000000157 t= 0.12680000000000158 t= 0.12700000000000158 t= 0.1272000000000016 t= 0.1274000000000016 t= 0.1276000000000016 t= 0.1278000000000016 t= 0.1280000000000016 t= 0.12820000000000162 t= 0.12840000000000162 t= 0.12860000000000163 t= 0.12880000000000164 t= 0.12900000000000164 t= 0.12920000000000165 t= 0.12940000000000165 t= 0.12960000000000166 t= 0.12980000000000166 t= 0.13000000000000167 t= 0.13020000000000168 t= 0.13040000000000168 t= 0.1306000000000017 t= 0.1308000000000017 t= 0.1310000000000017 t= 0.1312000000000017 t= 0.1314000000000017 t= 0.13160000000000172 t= 0.13180000000000172 t= 0.13200000000000173 t= 0.13220000000000173 t= 0.13240000000000174 t= 0.13260000000000174 t= 0.13280000000000175 t= 0.13300000000000176 t= 0.13320000000000176 t= 0.13340000000000177 t= 0.13360000000000177 t= 0.13380000000000178 t= 0.13400000000000178 t= 0.1342000000000018 t= 0.1344000000000018 t= 0.1346000000000018 t= 0.1348000000000018 t= 0.1350000000000018 t= 0.13520000000000182 t= 0.13540000000000182 t= 0.13560000000000183 t= 0.13580000000000184 t= 0.13600000000000184 t= 0.13620000000000185 t= 0.13640000000000185 t= 0.13660000000000186 t= 0.13680000000000186 t= 0.13700000000000187 t= 0.13720000000000188 t= 0.13740000000000188 t= 0.1376000000000019 t= 0.1378000000000019 t= 0.1380000000000019 t= 0.1382000000000019 t= 0.1384000000000019 t= 0.13860000000000192 t= 0.13880000000000192 t= 0.13900000000000193 t= 0.13920000000000193 t= 0.13940000000000194 t= 0.13960000000000194 t= 0.13980000000000195 t= 0.14000000000000196 t= 0.14020000000000196 t= 0.14040000000000197 t= 0.14060000000000197 t= 0.14080000000000198 t= 0.14100000000000198 t= 0.141200000000002 t= 0.141400000000002 t= 0.141600000000002 t= 0.141800000000002 t= 0.142000000000002 t= 0.14220000000000202 t= 0.14240000000000202 t= 0.14260000000000203 t= 0.14280000000000204 t= 0.14300000000000204 t= 0.14320000000000205 t= 0.14340000000000205 t= 0.14360000000000206 t= 0.14380000000000207 t= 0.14400000000000207 t= 0.14420000000000208 t= 0.14440000000000208 t= 0.1446000000000021 t= 0.1448000000000021 t= 0.1450000000000021 t= 0.1452000000000021 t= 0.1454000000000021 t= 0.14560000000000212 t= 0.14580000000000212 t= 0.14600000000000213 t= 0.14620000000000213 t= 0.14640000000000214 t= 0.14660000000000215 t= 0.14680000000000215 t= 0.14700000000000216 t= 0.14720000000000216 t= 0.14740000000000217 t= 0.14760000000000217 t= 0.14780000000000218 t= 0.14800000000000219 t= 0.1482000000000022 t= 0.1484000000000022 t= 0.1486000000000022 t= 0.1488000000000022 t= 0.14900000000000221 t= 0.14920000000000222 t= 0.14940000000000223 t= 0.14960000000000223 t= 0.14980000000000224 t= 0.15000000000000224 t= 0.15020000000000225 t= 0.15040000000000225 t= 0.15060000000000226 t= 0.15080000000000227 t= 0.15100000000000227 t= 0.15120000000000228 t= 0.15140000000000228 t= 0.1516000000000023 t= 0.1518000000000023 t= 0.1520000000000023 t= 0.1522000000000023 t= 0.1524000000000023 t= 0.15260000000000232 t= 0.15280000000000232 t= 0.15300000000000233 t= 0.15320000000000233 t= 0.15340000000000234 t= 0.15360000000000235 t= 0.15380000000000235 t= 0.15400000000000236 t= 0.15420000000000236 t= 0.15440000000000237 t= 0.15460000000000237 t= 0.15480000000000238 t= 0.15500000000000239 t= 0.1552000000000024 t= 0.1554000000000024 t= 0.1556000000000024 t= 0.1558000000000024 t= 0.15600000000000241 t= 0.15620000000000242 t= 0.15640000000000243 t= 0.15660000000000243 t= 0.15680000000000244 t= 0.15700000000000244 t= 0.15720000000000245 t= 0.15740000000000245 t= 0.15760000000000246 t= 0.15780000000000247 t= 0.15800000000000247 t= 0.15820000000000248 t= 0.15840000000000248 t= 0.1586000000000025 t= 0.1588000000000025 t= 0.1590000000000025 t= 0.1592000000000025 t= 0.1594000000000025 t= 0.15960000000000252 t= 0.15980000000000252 t= 0.16000000000000253 t= 0.16020000000000253 t= 0.16040000000000254 t= 0.16060000000000255 t= 0.16080000000000255 t= 0.16100000000000256 t= 0.16120000000000256 t= 0.16140000000000257 t= 0.16160000000000257 t= 0.16180000000000258 t= 0.1620000000000026 t= 0.1622000000000026 t= 0.1624000000000026 t= 0.1626000000000026 t= 0.1628000000000026 t= 0.16300000000000262 t= 0.16320000000000262 t= 0.16340000000000263 t= 0.16360000000000263 t= 0.16380000000000264 t= 0.16400000000000264 t= 0.16420000000000265 t= 0.16440000000000266 t= 0.16460000000000266 t= 0.16480000000000267 t= 0.16500000000000267 t= 0.16520000000000268 t= 0.16540000000000268 t= 0.1656000000000027 t= 0.1658000000000027 t= 0.1660000000000027 t= 0.1662000000000027 t= 0.1664000000000027 t= 0.16660000000000272 t= 0.16680000000000272 t= 0.16700000000000273 t= 0.16720000000000274 t= 0.16740000000000274 t= 0.16760000000000275 t= 0.16780000000000275 t= 0.16800000000000276 t= 0.16820000000000276 t= 0.16840000000000277 t= 0.16860000000000278 t= 0.16880000000000278 t= 0.1690000000000028 t= 0.1692000000000028 t= 0.1694000000000028 t= 0.1696000000000028 t= 0.1698000000000028 t= 0.17000000000000282 t= 0.17020000000000282 t= 0.17040000000000283 t= 0.17060000000000283 t= 0.17080000000000284 t= 0.17100000000000284 t= 0.17120000000000285 t= 0.17140000000000286 t= 0.17160000000000286 t= 0.17180000000000287 t= 0.17200000000000287 t= 0.17220000000000288 t= 0.17240000000000288 t= 0.1726000000000029 t= 0.1728000000000029 t= 0.1730000000000029 t= 0.1732000000000029 t= 0.1734000000000029 t= 0.17360000000000292 t= 0.17380000000000292 t= 0.17400000000000293 t= 0.17420000000000294 t= 0.17440000000000294 t= 0.17460000000000295 t= 0.17480000000000295 t= 0.17500000000000296 t= 0.17520000000000296 t= 0.17540000000000297 t= 0.17560000000000298 t= 0.17580000000000298 t= 0.176000000000003 t= 0.176200000000003 t= 0.176400000000003 t= 0.176600000000003 t= 0.176800000000003 t= 0.17700000000000302 t= 0.17720000000000302 t= 0.17740000000000303 t= 0.17760000000000303 t= 0.17780000000000304 t= 0.17800000000000304 t= 0.17820000000000305 t= 0.17840000000000306 t= 0.17860000000000306 t= 0.17880000000000307 t= 0.17900000000000307 t= 0.17920000000000308 t= 0.17940000000000308 t= 0.1796000000000031 t= 0.1798000000000031 t= 0.1800000000000031 t= 0.1802000000000031 t= 0.1804000000000031 t= 0.18060000000000312 t= 0.18080000000000312 t= 0.18100000000000313 t= 0.18120000000000314 t= 0.18140000000000314 t= 0.18160000000000315 t= 0.18180000000000315 t= 0.18200000000000316 t= 0.18220000000000316 t= 0.18240000000000317 t= 0.18260000000000318 t= 0.18280000000000318 t= 0.1830000000000032 t= 0.1832000000000032 t= 0.1834000000000032 t= 0.1836000000000032 t= 0.1838000000000032 t= 0.18400000000000322 t= 0.18420000000000322 t= 0.18440000000000323 t= 0.18460000000000323 t= 0.18480000000000324 t= 0.18500000000000325 t= 0.18520000000000325 t= 0.18540000000000326 t= 0.18560000000000326 t= 0.18580000000000327 t= 0.18600000000000327 t= 0.18620000000000328 t= 0.18640000000000329 t= 0.1866000000000033 t= 0.1868000000000033 t= 0.1870000000000033 t= 0.1872000000000033 t= 0.18740000000000331 t= 0.18760000000000332 t= 0.18780000000000333 t= 0.18800000000000333 t= 0.18820000000000334 t= 0.18840000000000334 t= 0.18860000000000335 t= 0.18880000000000335 t= 0.18900000000000336 t= 0.18920000000000337 t= 0.18940000000000337 t= 0.18960000000000338 t= 0.18980000000000338 t= 0.1900000000000034 t= 0.1902000000000034 t= 0.1904000000000034 t= 0.1906000000000034 t= 0.1908000000000034 t= 0.19100000000000342 t= 0.19120000000000342 t= 0.19140000000000343 t= 0.19160000000000343 t= 0.19180000000000344 t= 0.19200000000000345 t= 0.19220000000000345 t= 0.19240000000000346 t= 0.19260000000000346 t= 0.19280000000000347 t= 0.19300000000000347 t= 0.19320000000000348 t= 0.19340000000000349 t= 0.1936000000000035 t= 0.1938000000000035 t= 0.1940000000000035 t= 0.1942000000000035 t= 0.19440000000000351 t= 0.19460000000000352 t= 0.19480000000000353 t= 0.19500000000000353 t= 0.19520000000000354 t= 0.19540000000000354 t= 0.19560000000000355 t= 0.19580000000000355 t= 0.19600000000000356 t= 0.19620000000000357 t= 0.19640000000000357 t= 0.19660000000000358 t= 0.19680000000000358 t= 0.1970000000000036 t= 0.1972000000000036 t= 0.1974000000000036 t= 0.1976000000000036 t= 0.1978000000000036 t= 0.19800000000000362 t= 0.19820000000000362 t= 0.19840000000000363 t= 0.19860000000000363 t= 0.19880000000000364 t= 0.19900000000000365 t= 0.19920000000000365 t= 0.19940000000000366 t= 0.19960000000000366 t= 0.19980000000000367 t= 0.20000000000000367 t= 0.20020000000000368 t= 0.2004000000000037 t= 0.2006000000000037 t= 0.2008000000000037 t= 0.2010000000000037 t= 0.2012000000000037 t= 0.20140000000000371 t= 0.20160000000000372 t= 0.20180000000000373 t= 0.20200000000000373 t= 0.20220000000000374 t= 0.20240000000000374 t= 0.20260000000000375 t= 0.20280000000000376 t= 0.20300000000000376 t= 0.20320000000000377 t= 0.20340000000000377 t= 0.20360000000000378 t= 0.20380000000000378 t= 0.2040000000000038 t= 0.2042000000000038 t= 0.2044000000000038 t= 0.2046000000000038 t= 0.2048000000000038 t= 0.20500000000000382 t= 0.20520000000000382 t= 0.20540000000000383 t= 0.20560000000000384 t= 0.20580000000000384 t= 0.20600000000000385 t= 0.20620000000000385 t= 0.20640000000000386 t= 0.20660000000000386 t= 0.20680000000000387 t= 0.20700000000000388 t= 0.20720000000000388 t= 0.2074000000000039 t= 0.2076000000000039 t= 0.2078000000000039 t= 0.2080000000000039 t= 0.2082000000000039 t= 0.20840000000000392 t= 0.20860000000000392 t= 0.20880000000000393 t= 0.20900000000000393 t= 0.20920000000000394 t= 0.20940000000000394 t= 0.20960000000000395 t= 0.20980000000000396 t= 0.21000000000000396 t= 0.21020000000000397 t= 0.21040000000000397 t= 0.21060000000000398 t= 0.21080000000000398 t= 0.211000000000004 t= 0.211200000000004 t= 0.211400000000004 t= 0.211600000000004 t= 0.211800000000004 t= 0.21200000000000402 t= 0.21220000000000402 t= 0.21240000000000403 t= 0.21260000000000404 t= 0.21280000000000404 t= 0.21300000000000405 t= 0.21320000000000405 t= 0.21340000000000406 t= 0.21360000000000406 t= 0.21380000000000407 t= 0.21400000000000408 t= 0.21420000000000408 t= 0.2144000000000041 t= 0.2146000000000041 t= 0.2148000000000041 t= 0.2150000000000041 t= 0.2152000000000041 t= 0.21540000000000412 t= 0.21560000000000412 t= 0.21580000000000413 t= 0.21600000000000413 t= 0.21620000000000414 t= 0.21640000000000414 t= 0.21660000000000415 t= 0.21680000000000416 t= 0.21700000000000416 t= 0.21720000000000417 t= 0.21740000000000417 t= 0.21760000000000418 t= 0.21780000000000418 t= 0.2180000000000042 t= 0.2182000000000042 t= 0.2184000000000042 t= 0.2186000000000042 t= 0.2188000000000042 t= 0.21900000000000422 t= 0.21920000000000422 t= 0.21940000000000423 t= 0.21960000000000424 t= 0.21980000000000424 t= 0.22000000000000425 t= 0.22020000000000425 t= 0.22040000000000426 t= 0.22060000000000426 t= 0.22080000000000427 t= 0.22100000000000428 t= 0.22120000000000428 t= 0.2214000000000043 t= 0.2216000000000043 t= 0.2218000000000043 t= 0.2220000000000043 t= 0.2222000000000043 t= 0.22240000000000432 t= 0.22260000000000432 t= 0.22280000000000433 t= 0.22300000000000433 t= 0.22320000000000434 t= 0.22340000000000435 t= 0.22360000000000435 t= 0.22380000000000436 t= 0.22400000000000436 t= 0.22420000000000437 t= 0.22440000000000437 t= 0.22460000000000438 t= 0.22480000000000439 t= 0.2250000000000044 t= 0.2252000000000044 t= 0.2254000000000044 t= 0.2256000000000044 t= 0.2258000000000044 t= 0.22600000000000442 t= 0.22620000000000443 t= 0.22640000000000443 t= 0.22660000000000444 t= 0.22680000000000444 t= 0.22700000000000445 t= 0.22720000000000445 t= 0.22740000000000446 t= 0.22760000000000447 t= 0.22780000000000447 t= 0.22800000000000448 t= 0.22820000000000448 t= 0.2284000000000045 t= 0.2286000000000045 t= 0.2288000000000045 t= 0.2290000000000045 t= 0.2292000000000045 t= 0.22940000000000452 t= 0.22960000000000452 t= 0.22980000000000453 t= 0.23000000000000453 t= 0.23020000000000454 t= 0.23040000000000455 t= 0.23060000000000455 t= 0.23080000000000456 t= 0.23100000000000456 t= 0.23120000000000457 t= 0.23140000000000457 t= 0.23160000000000458 t= 0.23180000000000459 t= 0.2320000000000046 t= 0.2322000000000046 t= 0.2324000000000046 t= 0.2326000000000046 t= 0.23280000000000461 t= 0.23300000000000462 t= 0.23320000000000463 t= 0.23340000000000463 t= 0.23360000000000464 t= 0.23380000000000464 t= 0.23400000000000465 t= 0.23420000000000465 t= 0.23440000000000466 t= 0.23460000000000467 t= 0.23480000000000467 t= 0.23500000000000468 t= 0.23520000000000468 t= 0.2354000000000047 t= 0.2356000000000047 t= 0.2358000000000047 t= 0.2360000000000047 t= 0.2362000000000047 t= 0.23640000000000472 t= 0.23660000000000472 t= 0.23680000000000473 t= 0.23700000000000473 t= 0.23720000000000474 t= 0.23740000000000475 t= 0.23760000000000475 t= 0.23780000000000476 t= 0.23800000000000476 t= 0.23820000000000477 t= 0.23840000000000477 t= 0.23860000000000478 t= 0.2388000000000048 t= 0.2390000000000048 t= 0.2392000000000048 t= 0.2394000000000048 t= 0.2396000000000048 t= 0.23980000000000481 t= 0.24000000000000482 t= 0.24020000000000483 t= 0.24040000000000483 t= 0.24060000000000484 t= 0.24080000000000484 t= 0.24100000000000485 t= 0.24120000000000485 t= 0.24140000000000486 t= 0.24160000000000487 t= 0.24180000000000487 t= 0.24200000000000488 t= 0.24220000000000488 t= 0.2424000000000049 t= 0.2426000000000049 t= 0.2428000000000049 t= 0.2430000000000049 t= 0.2432000000000049 t= 0.24340000000000492 t= 0.24360000000000492 t= 0.24380000000000493 t= 0.24400000000000494 t= 0.24420000000000494 t= 0.24440000000000495 t= 0.24460000000000495 t= 0.24480000000000496 t= 0.24500000000000496 t= 0.24520000000000497 t= 0.24540000000000498 t= 0.24560000000000498 t= 0.245800000000005 t= 0.246000000000005 t= 0.246200000000005 t= 0.246400000000005 t= 0.246600000000005 t= 0.24680000000000502 t= 0.24700000000000502 t= 0.24720000000000503 t= 0.24740000000000503 t= 0.24760000000000504 t= 0.24780000000000504 t= 0.24800000000000505 t= 0.24820000000000506 t= 0.24840000000000506 t= 0.24860000000000507 t= 0.24880000000000507 t= 0.24900000000000508 t= 0.24920000000000508 t= 0.2494000000000051 t= 0.2496000000000051 t= 0.2498000000000051 t= 0.2500000000000051 t= 0.2502000000000051 t= 0.25040000000000506 t= 0.25060000000000504 t= 0.250800000000005 t= 0.251000000000005 t= 0.251200000000005 t= 0.25140000000000495 t= 0.25160000000000493 t= 0.2518000000000049 t= 0.2520000000000049 t= 0.25220000000000486 t= 0.25240000000000484 t= 0.2526000000000048 t= 0.2528000000000048 t= 0.2530000000000048 t= 0.25320000000000475 t= 0.25340000000000473 t= 0.2536000000000047 t= 0.2538000000000047 t= 0.25400000000000467 t= 0.25420000000000464 t= 0.2544000000000046 t= 0.2546000000000046 t= 0.2548000000000046 t= 0.25500000000000456 t= 0.25520000000000453 t= 0.2554000000000045 t= 0.2556000000000045 t= 0.25580000000000447 t= 0.25600000000000445 t= 0.2562000000000044 t= 0.2564000000000044 t= 0.2566000000000044 t= 0.25680000000000436 t= 0.25700000000000434 t= 0.2572000000000043 t= 0.2574000000000043 t= 0.25760000000000427 t= 0.25780000000000425 t= 0.2580000000000042 t= 0.2582000000000042 t= 0.2584000000000042 t= 0.25860000000000416 t= 0.25880000000000414 t= 0.2590000000000041 t= 0.2592000000000041 t= 0.25940000000000407 t= 0.25960000000000405 t= 0.259800000000004 t= 0.260000000000004 t= 0.260200000000004 t= 0.26040000000000396 t= 0.26060000000000394 t= 0.2608000000000039 t= 0.2610000000000039 t= 0.2612000000000039 t= 0.26140000000000385 t= 0.26160000000000383 t= 0.2618000000000038 t= 0.2620000000000038 t= 0.26220000000000376 t= 0.26240000000000374 t= 0.2626000000000037 t= 0.2628000000000037 t= 0.2630000000000037 t= 0.26320000000000365 t= 0.26340000000000363 t= 0.2636000000000036 t= 0.2638000000000036 t= 0.26400000000000357 t= 0.26420000000000354 t= 0.2644000000000035 t= 0.2646000000000035 t= 0.2648000000000035 t= 0.26500000000000346 t= 0.26520000000000343 t= 0.2654000000000034 t= 0.2656000000000034 t= 0.26580000000000337 t= 0.26600000000000334 t= 0.2662000000000033 t= 0.2664000000000033 t= 0.2666000000000033 t= 0.26680000000000326 t= 0.26700000000000323 t= 0.2672000000000032 t= 0.2674000000000032 t= 0.26760000000000317 t= 0.26780000000000315 t= 0.2680000000000031 t= 0.2682000000000031 t= 0.2684000000000031 t= 0.26860000000000306 t= 0.26880000000000304 t= 0.269000000000003 t= 0.269200000000003 t= 0.26940000000000297 t= 0.26960000000000295 t= 0.2698000000000029 t= 0.2700000000000029 t= 0.2702000000000029 t= 0.27040000000000286 t= 0.27060000000000284 t= 0.2708000000000028 t= 0.2710000000000028 t= 0.27120000000000277 t= 0.27140000000000275 t= 0.27160000000000273 t= 0.2718000000000027 t= 0.2720000000000027 t= 0.27220000000000266 t= 0.27240000000000264 t= 0.2726000000000026 t= 0.2728000000000026 t= 0.2730000000000026 t= 0.27320000000000255 t= 0.27340000000000253 t= 0.2736000000000025 t= 0.2738000000000025 t= 0.27400000000000246 t= 0.27420000000000244 t= 0.2744000000000024 t= 0.2746000000000024 t= 0.2748000000000024 t= 0.27500000000000235 t= 0.27520000000000233 t= 0.2754000000000023 t= 0.2756000000000023 t= 0.27580000000000227 t= 0.27600000000000224 t= 0.2762000000000022 t= 0.2764000000000022 t= 0.2766000000000022 t= 0.27680000000000216 t= 0.27700000000000213 t= 0.2772000000000021 t= 0.2774000000000021 t= 0.27760000000000207 t= 0.27780000000000205 t= 0.278000000000002 t= 0.278200000000002 t= 0.278400000000002 t= 0.27860000000000196 t= 0.27880000000000194 t= 0.2790000000000019 t= 0.2792000000000019 t= 0.27940000000000187 t= 0.27960000000000185 t= 0.2798000000000018 t= 0.2800000000000018 t= 0.2802000000000018 t= 0.28040000000000176 t= 0.28060000000000174 t= 0.2808000000000017 t= 0.2810000000000017 t= 0.28120000000000167 t= 0.28140000000000165 t= 0.2816000000000016 t= 0.2818000000000016 t= 0.2820000000000016 t= 0.28220000000000156 t= 0.28240000000000154 t= 0.2826000000000015 t= 0.2828000000000015 t= 0.2830000000000015 t= 0.28320000000000145 t= 0.28340000000000143 t= 0.2836000000000014 t= 0.2838000000000014 t= 0.28400000000000136 t= 0.28420000000000134 t= 0.2844000000000013 t= 0.2846000000000013 t= 0.2848000000000013 t= 0.28500000000000125 t= 0.28520000000000123 t= 0.2854000000000012 t= 0.2856000000000012 t= 0.28580000000000116 t= 0.28600000000000114 t= 0.2862000000000011 t= 0.2864000000000011 t= 0.2866000000000011 t= 0.28680000000000105 t= 0.28700000000000103 t= 0.287200000000001 t= 0.287400000000001 t= 0.28760000000000097 t= 0.28780000000000094 t= 0.2880000000000009 t= 0.2882000000000009 t= 0.2884000000000009 t= 0.28860000000000086 t= 0.28880000000000083 t= 0.2890000000000008 t= 0.2892000000000008 t= 0.28940000000000077 t= 0.28960000000000075 t= 0.2898000000000007 t= 0.2900000000000007 t= 0.2902000000000007 t= 0.29040000000000066 t= 0.29060000000000064 t= 0.2908000000000006 t= 0.2910000000000006 t= 0.29120000000000057 t= 0.29140000000000055 t= 0.2916000000000005 t= 0.2918000000000005 t= 0.2920000000000005 t= 0.29220000000000046 t= 0.29240000000000044 t= 0.2926000000000004 t= 0.2928000000000004 t= 0.29300000000000037 t= 0.29320000000000035 t= 0.2934000000000003 t= 0.2936000000000003 t= 0.2938000000000003 t= 0.29400000000000026 t= 0.29420000000000024 t= 0.2944000000000002 t= 0.2946000000000002 t= 0.2948000000000002 t= 0.29500000000000015 t= 0.29520000000000013 t= 0.2954000000000001 t= 0.2956000000000001 t= 0.29580000000000006 t= 0.29600000000000004 t= 0.2962 t= 0.2964 t= 0.2966 t= 0.29679999999999995 t= 0.29699999999999993 t= 0.2971999999999999 t= 0.2973999999999999 t= 0.29759999999999986 t= 0.29779999999999984 t= 0.2979999999999998 t= 0.2981999999999998 t= 0.2983999999999998 t= 0.29859999999999975 t= 0.29879999999999973 t= 0.2989999999999997 t= 0.2991999999999997 t= 0.29939999999999967 t= 0.29959999999999964 t= 0.2997999999999996 t= 0.2999999999999996 t= 0.3001999999999996 t= 0.30039999999999956 t= 0.30059999999999953 t= 0.3007999999999995 t= 0.3009999999999995 t= 0.30119999999999947 t= 0.30139999999999945 t= 0.3015999999999994 t= 0.3017999999999994 t= 0.3019999999999994 t= 0.30219999999999936 t= 0.30239999999999934 t= 0.3025999999999993 t= 0.3027999999999993 t= 0.30299999999999927 t= 0.30319999999999925 t= 0.3033999999999992 t= 0.3035999999999992 t= 0.3037999999999992 t= 0.30399999999999916 t= 0.30419999999999914 t= 0.3043999999999991 t= 0.3045999999999991 t= 0.30479999999999907 t= 0.30499999999999905 t= 0.305199999999999 t= 0.305399999999999 t= 0.305599999999999 t= 0.30579999999999896 t= 0.30599999999999894 t= 0.3061999999999989 t= 0.3063999999999989 t= 0.3065999999999989 t= 0.30679999999999885 t= 0.30699999999999883 t= 0.3071999999999988 t= 0.3073999999999988 t= 0.30759999999999876 t= 0.30779999999999874 t= 0.3079999999999987 t= 0.3081999999999987 t= 0.3083999999999987 t= 0.30859999999999865 t= 0.30879999999999863 t= 0.3089999999999986 t= 0.3091999999999986 t= 0.30939999999999857 t= 0.30959999999999854 t= 0.3097999999999985 t= 0.3099999999999985 t= 0.3101999999999985 t= 0.31039999999999845 t= 0.31059999999999843 t= 0.3107999999999984 t= 0.3109999999999984 t= 0.31119999999999837 t= 0.31139999999999834 t= 0.3115999999999983 t= 0.3117999999999983 t= 0.3119999999999983 t= 0.31219999999999826 t= 0.31239999999999823 t= 0.3125999999999982 t= 0.3127999999999982 t= 0.31299999999999817 t= 0.31319999999999815 t= 0.3133999999999981 t= 0.3135999999999981 t= 0.3137999999999981 t= 0.31399999999999806 t= 0.31419999999999804 t= 0.314399999999998 t= 0.314599999999998 t= 0.31479999999999797 t= 0.31499999999999795 t= 0.3151999999999979 t= 0.3153999999999979 t= 0.3155999999999979 t= 0.31579999999999786 t= 0.31599999999999784 t= 0.3161999999999978 t= 0.3163999999999978 t= 0.31659999999999777 t= 0.31679999999999775 t= 0.31699999999999773 t= 0.3171999999999977 t= 0.3173999999999977 t= 0.31759999999999766 t= 0.31779999999999764 t= 0.3179999999999976 t= 0.3181999999999976 t= 0.3183999999999976 t= 0.31859999999999755 t= 0.31879999999999753 t= 0.3189999999999975 t= 0.3191999999999975 t= 0.31939999999999746 t= 0.31959999999999744 t= 0.3197999999999974 t= 0.3199999999999974 t= 0.3201999999999974 t= 0.32039999999999735 t= 0.32059999999999733 t= 0.3207999999999973 t= 0.3209999999999973 t= 0.32119999999999727 t= 0.32139999999999724 t= 0.3215999999999972 t= 0.3217999999999972 t= 0.3219999999999972 t= 0.32219999999999716 t= 0.32239999999999713 t= 0.3225999999999971 t= 0.3227999999999971 t= 0.32299999999999707 t= 0.32319999999999705 t= 0.323399999999997 t= 0.323599999999997 t= 0.323799999999997 t= 0.32399999999999696 t= 0.32419999999999694 t= 0.3243999999999969 t= 0.3245999999999969 t= 0.32479999999999687 t= 0.32499999999999685 t= 0.3251999999999968 t= 0.3253999999999968 t= 0.3255999999999968 t= 0.32579999999999676 t= 0.32599999999999674 t= 0.3261999999999967 t= 0.3263999999999967 t= 0.32659999999999667 t= 0.32679999999999665 t= 0.3269999999999966 t= 0.3271999999999966 t= 0.3273999999999966 t= 0.32759999999999656 t= 0.32779999999999654 t= 0.3279999999999965 t= 0.3281999999999965 t= 0.3283999999999965 t= 0.32859999999999645 t= 0.32879999999999643 t= 0.3289999999999964 t= 0.3291999999999964 t= 0.32939999999999636 t= 0.32959999999999634 t= 0.3297999999999963 t= 0.3299999999999963 t= 0.3301999999999963 t= 0.33039999999999625 t= 0.33059999999999623 t= 0.3307999999999962 t= 0.3309999999999962 t= 0.33119999999999616 t= 0.33139999999999614 t= 0.3315999999999961 t= 0.3317999999999961 t= 0.3319999999999961 t= 0.33219999999999605 t= 0.33239999999999603 t= 0.332599999999996 t= 0.332799999999996 t= 0.33299999999999597 t= 0.33319999999999594 t= 0.3333999999999959 t= 0.3335999999999959 t= 0.3337999999999959 t= 0.33399999999999586 t= 0.33419999999999583 t= 0.3343999999999958 t= 0.3345999999999958 t= 0.33479999999999577 t= 0.33499999999999575 t= 0.3351999999999957 t= 0.3353999999999957 t= 0.3355999999999957 t= 0.33579999999999566 t= 0.33599999999999564 t= 0.3361999999999956 t= 0.3363999999999956 t= 0.33659999999999557 t= 0.33679999999999555 t= 0.3369999999999955 t= 0.3371999999999955 t= 0.3373999999999955 t= 0.33759999999999546 t= 0.33779999999999544 t= 0.3379999999999954 t= 0.3381999999999954 t= 0.33839999999999537 t= 0.33859999999999535 t= 0.3387999999999953 t= 0.3389999999999953 t= 0.3391999999999953 t= 0.33939999999999526 t= 0.33959999999999524 t= 0.3397999999999952 t= 0.3399999999999952 t= 0.3401999999999952 t= 0.34039999999999515 t= 0.34059999999999513 t= 0.3407999999999951 t= 0.3409999999999951 t= 0.34119999999999506 t= 0.34139999999999504 t= 0.341599999999995 t= 0.341799999999995 t= 0.341999999999995 t= 0.34219999999999495 t= 0.34239999999999493 t= 0.3425999999999949 t= 0.3427999999999949 t= 0.34299999999999486 t= 0.34319999999999484 t= 0.3433999999999948 t= 0.3435999999999948 t= 0.3437999999999948 t= 0.34399999999999475 t= 0.34419999999999473 t= 0.3443999999999947 t= 0.3445999999999947 t= 0.34479999999999467 t= 0.34499999999999464 t= 0.3451999999999946 t= 0.3453999999999946 t= 0.3455999999999946 t= 0.34579999999999456 t= 0.34599999999999453 t= 0.3461999999999945 t= 0.3463999999999945 t= 0.34659999999999447 t= 0.34679999999999445 t= 0.3469999999999944 t= 0.3471999999999944 t= 0.3473999999999944 t= 0.34759999999999436 t= 0.34779999999999434 t= 0.3479999999999943 t= 0.3481999999999943 t= 0.34839999999999427 t= 0.34859999999999425 t= 0.3487999999999942 t= 0.3489999999999942 t= 0.3491999999999942 t= 0.34939999999999416 t= 0.34959999999999414 t= 0.3497999999999941 t= 0.3499999999999941 t= 0.35019999999999407 t= 0.35039999999999405 t= 0.350599999999994 t= 0.350799999999994 t= 0.350999999999994 t= 0.35119999999999396 t= 0.35139999999999394 t= 0.3515999999999939 t= 0.3517999999999939 t= 0.3519999999999939 t= 0.35219999999999385 t= 0.35239999999999383 t= 0.3525999999999938 t= 0.3527999999999938 t= 0.35299999999999376 t= 0.35319999999999374 t= 0.3533999999999937 t= 0.3535999999999937 t= 0.3537999999999937 t= 0.35399999999999365 t= 0.35419999999999363 t= 0.3543999999999936 t= 0.3545999999999936 t= 0.35479999999999356 t= 0.35499999999999354 t= 0.3551999999999935 t= 0.3553999999999935 t= 0.3555999999999935 t= 0.35579999999999345 t= 0.35599999999999343 t= 0.3561999999999934 t= 0.3563999999999934 t= 0.35659999999999337 t= 0.35679999999999334 t= 0.3569999999999933 t= 0.3571999999999933 t= 0.3573999999999933 t= 0.35759999999999326 t= 0.35779999999999323 t= 0.3579999999999932 t= 0.3581999999999932 t= 0.35839999999999317 t= 0.35859999999999315 t= 0.3587999999999931 t= 0.3589999999999931 t= 0.3591999999999931 t= 0.35939999999999306 t= 0.35959999999999304 t= 0.359799999999993 t= 0.359999999999993 t= 0.36019999999999297 t= 0.36039999999999295 t= 0.3605999999999929 t= 0.3607999999999929 t= 0.3609999999999929 t= 0.36119999999999286 t= 0.36139999999999284 t= 0.3615999999999928 t= 0.3617999999999928 t= 0.36199999999999277 t= 0.36219999999999275 t= 0.36239999999999273 t= 0.3625999999999927 t= 0.3627999999999927 t= 0.36299999999999266 t= 0.36319999999999264 t= 0.3633999999999926 t= 0.3635999999999926 t= 0.3637999999999926 t= 0.36399999999999255 t= 0.36419999999999253 t= 0.3643999999999925 t= 0.3645999999999925 t= 0.36479999999999246 t= 0.36499999999999244 t= 0.3651999999999924 t= 0.3653999999999924 t= 0.3655999999999924 t= 0.36579999999999235 t= 0.36599999999999233 t= 0.3661999999999923 t= 0.3663999999999923 t= 0.36659999999999227 t= 0.36679999999999224 t= 0.3669999999999922 t= 0.3671999999999922 t= 0.3673999999999922 t= 0.36759999999999216 t= 0.36779999999999213 t= 0.3679999999999921 t= 0.3681999999999921 t= 0.36839999999999207 t= 0.36859999999999205 t= 0.368799999999992 t= 0.368999999999992 t= 0.369199999999992 t= 0.36939999999999196 t= 0.36959999999999193 t= 0.3697999999999919 t= 0.3699999999999919 t= 0.37019999999999187 t= 0.37039999999999185 t= 0.3705999999999918 t= 0.3707999999999918 t= 0.3709999999999918 t= 0.37119999999999176 t= 0.37139999999999174 t= 0.3715999999999917 t= 0.3717999999999917 t= 0.37199999999999167 t= 0.37219999999999165 t= 0.3723999999999916 t= 0.3725999999999916 t= 0.3727999999999916 t= 0.37299999999999156 t= 0.37319999999999154 t= 0.3733999999999915 t= 0.3735999999999915 t= 0.3737999999999915 t= 0.37399999999999145 t= 0.37419999999999143 t= 0.3743999999999914 t= 0.3745999999999914 t= 0.37479999999999136 t= 0.37499999999999134 t= 0.3751999999999913 t= 0.3753999999999913 t= 0.3755999999999913 t= 0.37579999999999125 t= 0.37599999999999123 t= 0.3761999999999912 t= 0.3763999999999912 t= 0.37659999999999116 t= 0.37679999999999114 t= 0.3769999999999911 t= 0.3771999999999911 t= 0.3773999999999911 t= 0.37759999999999105 t= 0.37779999999999103 t= 0.377999999999991 t= 0.378199999999991 t= 0.37839999999999097 t= 0.37859999999999094 t= 0.3787999999999909 t= 0.3789999999999909 t= 0.3791999999999909 t= 0.37939999999999086 t= 0.37959999999999083 t= 0.3797999999999908 t= 0.3799999999999908 t= 0.38019999999999077 t= 0.38039999999999075 t= 0.3805999999999907 t= 0.3807999999999907 t= 0.3809999999999907 t= 0.38119999999999066 t= 0.38139999999999064 t= 0.3815999999999906 t= 0.3817999999999906 t= 0.38199999999999057 t= 0.38219999999999055 t= 0.3823999999999905 t= 0.3825999999999905 t= 0.3827999999999905 t= 0.38299999999999046 t= 0.38319999999999044 t= 0.3833999999999904 t= 0.3835999999999904 t= 0.38379999999999037 t= 0.38399999999999035 t= 0.3841999999999903 t= 0.3843999999999903 t= 0.3845999999999903 t= 0.38479999999999026 t= 0.38499999999999024 t= 0.3851999999999902 t= 0.3853999999999902 t= 0.3855999999999902 t= 0.38579999999999015 t= 0.38599999999999013 t= 0.3861999999999901 t= 0.3863999999999901 t= 0.38659999999999006 t= 0.38679999999999004 t= 0.38699999999999 t= 0.38719999999999 t= 0.38739999999999 t= 0.38759999999998995 t= 0.38779999999998993 t= 0.3879999999999899 t= 0.3881999999999899 t= 0.38839999999998986 t= 0.38859999999998984 t= 0.3887999999999898 t= 0.3889999999999898 t= 0.3891999999999898 t= 0.38939999999998975 t= 0.38959999999998973 t= 0.3897999999999897 t= 0.3899999999999897 t= 0.39019999999998967 t= 0.39039999999998964 t= 0.3905999999999896 t= 0.3907999999999896 t= 0.3909999999999896 t= 0.39119999999998956 t= 0.39139999999998953 t= 0.3915999999999895 t= 0.3917999999999895 t= 0.39199999999998947 t= 0.39219999999998945 t= 0.3923999999999894 t= 0.3925999999999894 t= 0.3927999999999894 t= 0.39299999999998936 t= 0.39319999999998934 t= 0.3933999999999893 t= 0.3935999999999893 t= 0.39379999999998927 t= 0.39399999999998925 t= 0.3941999999999892 t= 0.3943999999999892 t= 0.3945999999999892 t= 0.39479999999998916 t= 0.39499999999998914 t= 0.3951999999999891 t= 0.3953999999999891 t= 0.39559999999998907 t= 0.39579999999998905 t= 0.395999999999989 t= 0.396199999999989 t= 0.396399999999989 t= 0.39659999999998896 t= 0.39679999999998894 t= 0.3969999999999889 t= 0.3971999999999889 t= 0.3973999999999889 t= 0.39759999999998885 t= 0.39779999999998883 t= 0.3979999999999888 t= 0.3981999999999888 t= 0.39839999999998876 t= 0.39859999999998874 t= 0.3987999999999887 t= 0.3989999999999887 t= 0.3991999999999887 t= 0.39939999999998865 t= 0.39959999999998863 t= 0.3997999999999886 t= 0.3999999999999886 t= 0.40019999999998856 t= 0.40039999999998854 t= 0.4005999999999885 t= 0.4007999999999885 t= 0.4009999999999885 t= 0.40119999999998845 t= 0.40139999999998843 t= 0.4015999999999884 t= 0.4017999999999884 t= 0.40199999999998837 t= 0.40219999999998834 t= 0.4023999999999883 t= 0.4025999999999883 t= 0.4027999999999883 t= 0.40299999999998826 t= 0.40319999999998823 t= 0.4033999999999882 t= 0.4035999999999882 t= 0.40379999999998817 t= 0.40399999999998815 t= 0.4041999999999881 t= 0.4043999999999881 t= 0.4045999999999881 t= 0.40479999999998806 t= 0.40499999999998804 t= 0.405199999999988 t= 0.405399999999988 t= 0.40559999999998797 t= 0.40579999999998795 t= 0.4059999999999879 t= 0.4061999999999879 t= 0.4063999999999879 t= 0.40659999999998786 t= 0.40679999999998784 t= 0.4069999999999878 t= 0.4071999999999878 t= 0.40739999999998777 t= 0.40759999999998775 t= 0.40779999999998773 t= 0.4079999999999877 t= 0.4081999999999877 t= 0.40839999999998766 t= 0.40859999999998764 t= 0.4087999999999876 t= 0.4089999999999876 t= 0.4091999999999876 t= 0.40939999999998755 t= 0.40959999999998753 t= 0.4097999999999875 t= 0.4099999999999875 t= 0.41019999999998746 t= 0.41039999999998744 t= 0.4105999999999874 t= 0.4107999999999874 t= 0.4109999999999874 t= 0.41119999999998735 t= 0.41139999999998733 t= 0.4115999999999873 t= 0.4117999999999873 t= 0.41199999999998727 t= 0.41219999999998724 t= 0.4123999999999872 t= 0.4125999999999872 t= 0.4127999999999872 t= 0.41299999999998716 t= 0.41319999999998713 t= 0.4133999999999871 t= 0.4135999999999871 t= 0.41379999999998707 t= 0.41399999999998705 t= 0.414199999999987 t= 0.414399999999987 t= 0.414599999999987 t= 0.41479999999998696 t= 0.41499999999998693 t= 0.4151999999999869 t= 0.4153999999999869 t= 0.41559999999998687 t= 0.41579999999998685 t= 0.4159999999999868 t= 0.4161999999999868 t= 0.4163999999999868 t= 0.41659999999998676 t= 0.41679999999998674 t= 0.4169999999999867 t= 0.4171999999999867 t= 0.41739999999998667 t= 0.41759999999998665 t= 0.4177999999999866 t= 0.4179999999999866 t= 0.4181999999999866 t= 0.41839999999998656 t= 0.41859999999998654 t= 0.4187999999999865 t= 0.4189999999999865 t= 0.4191999999999865 t= 0.41939999999998645 t= 0.41959999999998643 t= 0.4197999999999864 t= 0.4199999999999864 t= 0.42019999999998636 t= 0.42039999999998634 t= 0.4205999999999863 t= 0.4207999999999863 t= 0.4209999999999863 t= 0.42119999999998625 t= 0.42139999999998623 t= 0.4215999999999862 t= 0.4217999999999862 t= 0.42199999999998616 t= 0.42219999999998614 t= 0.4223999999999861 t= 0.4225999999999861 t= 0.4227999999999861 t= 0.42299999999998605 t= 0.42319999999998603 t= 0.423399999999986 t= 0.423599999999986 t= 0.42379999999998597 t= 0.42399999999998594 t= 0.4241999999999859 t= 0.4243999999999859 t= 0.4245999999999859 t= 0.42479999999998586 t= 0.42499999999998583 t= 0.4251999999999858 t= 0.4253999999999858 t= 0.42559999999998577 t= 0.42579999999998575 t= 0.4259999999999857 t= 0.4261999999999857 t= 0.4263999999999857 t= 0.42659999999998566 t= 0.42679999999998564 t= 0.4269999999999856 t= 0.4271999999999856 t= 0.42739999999998557 t= 0.42759999999998555 t= 0.4277999999999855 t= 0.4279999999999855 t= 0.4281999999999855 t= 0.42839999999998546 t= 0.42859999999998544 t= 0.4287999999999854 t= 0.4289999999999854 t= 0.42919999999998537 t= 0.42939999999998535 t= 0.4295999999999853 t= 0.4297999999999853 t= 0.4299999999999853 t= 0.43019999999998526 t= 0.43039999999998524 t= 0.4305999999999852 t= 0.4307999999999852 t= 0.4309999999999852 t= 0.43119999999998515 t= 0.43139999999998513 t= 0.4315999999999851 t= 0.4317999999999851 t= 0.43199999999998506 t= 0.43219999999998504 t= 0.432399999999985 t= 0.432599999999985 t= 0.432799999999985 t= 0.43299999999998495 t= 0.43319999999998493 t= 0.4333999999999849 t= 0.4335999999999849 t= 0.43379999999998486 t= 0.43399999999998484 t= 0.4341999999999848 t= 0.4343999999999848 t= 0.4345999999999848 t= 0.43479999999998475 t= 0.43499999999998473 t= 0.4351999999999847 t= 0.4353999999999847 t= 0.43559999999998467 t= 0.43579999999998464 t= 0.4359999999999846 t= 0.4361999999999846 t= 0.4363999999999846 t= 0.43659999999998456 t= 0.43679999999998453 t= 0.4369999999999845 t= 0.4371999999999845 t= 0.43739999999998447 t= 0.43759999999998445 t= 0.4377999999999844 t= 0.4379999999999844 t= 0.4381999999999844 t= 0.43839999999998436 t= 0.43859999999998434 t= 0.4387999999999843 t= 0.4389999999999843 t= 0.43919999999998427 t= 0.43939999999998425 t= 0.4395999999999842 t= 0.4397999999999842 t= 0.4399999999999842 t= 0.44019999999998416 t= 0.44039999999998414 t= 0.4405999999999841 t= 0.4407999999999841 t= 0.44099999999998407 t= 0.44119999999998405 t= 0.441399999999984 t= 0.441599999999984 t= 0.441799999999984 t= 0.44199999999998396 t= 0.44219999999998394 t= 0.4423999999999839 t= 0.4425999999999839 t= 0.4427999999999839 t= 0.44299999999998385 t= 0.44319999999998383 t= 0.4433999999999838 t= 0.4435999999999838 t= 0.44379999999998376 t= 0.44399999999998374 t= 0.4441999999999837 t= 0.4443999999999837 t= 0.4445999999999837 t= 0.44479999999998365 t= 0.44499999999998363 t= 0.4451999999999836 t= 0.4453999999999836 t= 0.44559999999998356 t= 0.44579999999998354 t= 0.4459999999999835 t= 0.4461999999999835 t= 0.4463999999999835 t= 0.44659999999998345 t= 0.44679999999998343 t= 0.4469999999999834 t= 0.4471999999999834 t= 0.44739999999998337 t= 0.44759999999998334 t= 0.4477999999999833 t= 0.4479999999999833 t= 0.4481999999999833 t= 0.44839999999998326 t= 0.44859999999998323 t= 0.4487999999999832 t= 0.4489999999999832 t= 0.44919999999998317 t= 0.44939999999998315 t= 0.4495999999999831 t= 0.4497999999999831 t= 0.4499999999999831 t= 0.45019999999998306 t= 0.45039999999998304 t= 0.450599999999983 t= 0.450799999999983 t= 0.45099999999998297 t= 0.45119999999998295 t= 0.4513999999999829 t= 0.4515999999999829 t= 0.4517999999999829 t= 0.45199999999998286 t= 0.45219999999998284 t= 0.4523999999999828 t= 0.4525999999999828 t= 0.45279999999998277 t= 0.45299999999998275 t= 0.45319999999998273 t= 0.4533999999999827 t= 0.4535999999999827 t= 0.45379999999998266 t= 0.45399999999998264 t= 0.4541999999999826 t= 0.4543999999999826 t= 0.4545999999999826 t= 0.45479999999998255 t= 0.45499999999998253 t= 0.4551999999999825 t= 0.4553999999999825 t= 0.45559999999998246 t= 0.45579999999998244 t= 0.4559999999999824 t= 0.4561999999999824 t= 0.4563999999999824 t= 0.45659999999998235 t= 0.45679999999998233 t= 0.4569999999999823 t= 0.4571999999999823 t= 0.45739999999998227 t= 0.45759999999998224 t= 0.4577999999999822 t= 0.4579999999999822 t= 0.4581999999999822 t= 0.45839999999998216 t= 0.45859999999998213 t= 0.4587999999999821 t= 0.4589999999999821 t= 0.45919999999998207 t= 0.45939999999998204 t= 0.459599999999982 t= 0.459799999999982 t= 0.459999999999982 t= 0.46019999999998196 t= 0.46039999999998193 t= 0.4605999999999819 t= 0.4607999999999819 t= 0.46099999999998187 t= 0.46119999999998185 t= 0.4613999999999818 t= 0.4615999999999818 t= 0.4617999999999818 t= 0.46199999999998176 t= 0.46219999999998174 t= 0.4623999999999817 t= 0.4625999999999817 t= 0.46279999999998167 t= 0.46299999999998165 t= 0.4631999999999816 t= 0.4633999999999816 t= 0.4635999999999816 t= 0.46379999999998156 t= 0.46399999999998154 t= 0.4641999999999815 t= 0.4643999999999815 t= 0.46459999999998147 t= 0.46479999999998145 t= 0.46499999999998143 t= 0.4651999999999814 t= 0.4653999999999814 t= 0.46559999999998136 t= 0.46579999999998134 t= 0.4659999999999813 t= 0.4661999999999813 t= 0.4663999999999813 t= 0.46659999999998125 t= 0.46679999999998123 t= 0.4669999999999812 t= 0.4671999999999812 t= 0.46739999999998116 t= 0.46759999999998114 t= 0.4677999999999811 t= 0.4679999999999811 t= 0.4681999999999811 t= 0.46839999999998105 t= 0.46859999999998103 t= 0.468799999999981 t= 0.468999999999981 t= 0.46919999999998097 t= 0.46939999999998094 t= 0.4695999999999809 t= 0.4697999999999809 t= 0.4699999999999809 t= 0.47019999999998086 t= 0.47039999999998083 t= 0.4705999999999808 t= 0.4707999999999808 t= 0.47099999999998077 t= 0.47119999999998075 t= 0.4713999999999807 t= 0.4715999999999807 t= 0.4717999999999807 t= 0.47199999999998066 t= 0.47219999999998064 t= 0.4723999999999806 t= 0.4725999999999806 t= 0.47279999999998057 t= 0.47299999999998055 t= 0.4731999999999805 t= 0.4733999999999805 t= 0.4735999999999805 t= 0.47379999999998046 t= 0.47399999999998044 t= 0.4741999999999804 t= 0.4743999999999804 t= 0.47459999999998037 t= 0.47479999999998035 t= 0.4749999999999803 t= 0.4751999999999803 t= 0.4753999999999803 t= 0.47559999999998026 t= 0.47579999999998024 t= 0.4759999999999802 t= 0.4761999999999802 t= 0.4763999999999802 t= 0.47659999999998015 t= 0.47679999999998013 t= 0.4769999999999801 t= 0.4771999999999801 t= 0.47739999999998006 t= 0.47759999999998004 t= 0.47779999999998 t= 0.47799999999998 t= 0.47819999999998 t= 0.47839999999997995 t= 0.47859999999997993 t= 0.4787999999999799 t= 0.4789999999999799 t= 0.47919999999997986 t= 0.47939999999997984 t= 0.4795999999999798 t= 0.4797999999999798 t= 0.4799999999999798 t= 0.48019999999997975 t= 0.48039999999997973 t= 0.4805999999999797 t= 0.4807999999999797 t= 0.48099999999997967 t= 0.48119999999997964 t= 0.4813999999999796 t= 0.4815999999999796 t= 0.4817999999999796 t= 0.48199999999997956 t= 0.48219999999997953 t= 0.4823999999999795 t= 0.4825999999999795 t= 0.48279999999997947 t= 0.48299999999997945 t= 0.4831999999999794 t= 0.4833999999999794 t= 0.4835999999999794 t= 0.48379999999997936 t= 0.48399999999997934 t= 0.4841999999999793 t= 0.4843999999999793 t= 0.48459999999997927 t= 0.48479999999997925 t= 0.4849999999999792 t= 0.4851999999999792 t= 0.4853999999999792 t= 0.48559999999997916 t= 0.48579999999997914 t= 0.4859999999999791 t= 0.4861999999999791 t= 0.48639999999997907 t= 0.48659999999997905 t= 0.486799999999979 t= 0.486999999999979 t= 0.487199999999979 t= 0.48739999999997896 t= 0.48759999999997894 t= 0.4877999999999789 t= 0.4879999999999789 t= 0.4881999999999789 t= 0.48839999999997885 t= 0.48859999999997883 t= 0.4887999999999788 t= 0.4889999999999788 t= 0.48919999999997876 t= 0.48939999999997874 t= 0.4895999999999787 t= 0.4897999999999787 t= 0.4899999999999787 t= 0.49019999999997865 t= 0.49039999999997863 t= 0.4905999999999786 t= 0.4907999999999786 t= 0.49099999999997856 t= 0.49119999999997854 t= 0.4913999999999785 t= 0.4915999999999785 t= 0.4917999999999785 t= 0.49199999999997845 t= 0.49219999999997843 t= 0.4923999999999784 t= 0.4925999999999784 t= 0.49279999999997837 t= 0.49299999999997834 t= 0.4931999999999783 t= 0.4933999999999783 t= 0.4935999999999783 t= 0.49379999999997826 t= 0.49399999999997823 t= 0.4941999999999782 t= 0.4943999999999782 t= 0.49459999999997817 t= 0.49479999999997815 t= 0.4949999999999781 t= 0.4951999999999781 t= 0.4953999999999781 t= 0.49559999999997806 t= 0.49579999999997804 t= 0.495999999999978 t= 0.496199999999978 t= 0.49639999999997797 t= 0.49659999999997795 t= 0.4967999999999779 t= 0.4969999999999779 t= 0.4971999999999779 t= 0.49739999999997786 t= 0.49759999999997784 t= 0.4977999999999778 t= 0.4979999999999778 t= 0.49819999999997777 t= 0.49839999999997775 t= 0.4985999999999777 t= 0.4987999999999777 t= 0.4989999999999777 t= 0.49919999999997766 t= 0.49939999999997764 t= 0.4995999999999776 t= 0.4997999999999776 t= 0.4999999999999776 t= 0.5001999999999776 t= 0.5003999999999775 t= 0.5005999999999775 t= 0.5007999999999775 t= 0.5009999999999775 t= 0.5011999999999774 t= 0.5013999999999774 t= 0.5015999999999774 t= 0.5017999999999774 t= 0.5019999999999774 t= 0.5021999999999773 t= 0.5023999999999773 t= 0.5025999999999773 t= 0.5027999999999773 t= 0.5029999999999772 t= 0.5031999999999772 t= 0.5033999999999772 t= 0.5035999999999772 t= 0.5037999999999772 t= 0.5039999999999771 t= 0.5041999999999771 t= 0.5043999999999771 t= 0.5045999999999771 t= 0.504799999999977 t= 0.504999999999977 t= 0.505199999999977 t= 0.505399999999977 t= 0.505599999999977 t= 0.5057999999999769 t= 0.5059999999999769 t= 0.5061999999999769 t= 0.5063999999999769 t= 0.5065999999999768 t= 0.5067999999999768 t= 0.5069999999999768 t= 0.5071999999999768 t= 0.5073999999999768 t= 0.5075999999999767 t= 0.5077999999999767 t= 0.5079999999999767 t= 0.5081999999999767 t= 0.5083999999999766 t= 0.5085999999999766 t= 0.5087999999999766 t= 0.5089999999999766 t= 0.5091999999999766 t= 0.5093999999999765 t= 0.5095999999999765 t= 0.5097999999999765 t= 0.5099999999999765 t= 0.5101999999999765 t= 0.5103999999999764 t= 0.5105999999999764 t= 0.5107999999999764 t= 0.5109999999999764 t= 0.5111999999999763 t= 0.5113999999999763 t= 0.5115999999999763 t= 0.5117999999999763 t= 0.5119999999999763 t= 0.5121999999999762 t= 0.5123999999999762 t= 0.5125999999999762 t= 0.5127999999999762 t= 0.5129999999999761 t= 0.5131999999999761 t= 0.5133999999999761 t= 0.5135999999999761 t= 0.513799999999976 t= 0.513999999999976 t= 0.514199999999976 t= 0.514399999999976 t= 0.514599999999976 t= 0.5147999999999759 t= 0.5149999999999759 t= 0.5151999999999759 t= 0.5153999999999759 t= 0.5155999999999759 t= 0.5157999999999758 t= 0.5159999999999758 t= 0.5161999999999758 t= 0.5163999999999758 t= 0.5165999999999757 t= 0.5167999999999757 t= 0.5169999999999757 t= 0.5171999999999757 t= 0.5173999999999757 t= 0.5175999999999756 t= 0.5177999999999756 t= 0.5179999999999756 t= 0.5181999999999756 t= 0.5183999999999755 t= 0.5185999999999755 t= 0.5187999999999755 t= 0.5189999999999755 t= 0.5191999999999755 t= 0.5193999999999754 t= 0.5195999999999754 t= 0.5197999999999754 t= 0.5199999999999754 t= 0.5201999999999753 t= 0.5203999999999753 t= 0.5205999999999753 t= 0.5207999999999753 t= 0.5209999999999753 t= 0.5211999999999752 t= 0.5213999999999752 t= 0.5215999999999752 t= 0.5217999999999752 t= 0.5219999999999752 t= 0.5221999999999751 t= 0.5223999999999751 t= 0.5225999999999751 t= 0.5227999999999751 t= 0.522999999999975 t= 0.523199999999975 t= 0.523399999999975 t= 0.523599999999975 t= 0.523799999999975 t= 0.5239999999999749 t= 0.5241999999999749 t= 0.5243999999999749 t= 0.5245999999999749 t= 0.5247999999999748 t= 0.5249999999999748 t= 0.5251999999999748 t= 0.5253999999999748 t= 0.5255999999999748 t= 0.5257999999999747 t= 0.5259999999999747 t= 0.5261999999999747 t= 0.5263999999999747 t= 0.5265999999999746 t= 0.5267999999999746 t= 0.5269999999999746 t= 0.5271999999999746 t= 0.5273999999999746 t= 0.5275999999999745 t= 0.5277999999999745 t= 0.5279999999999745 t= 0.5281999999999745 t= 0.5283999999999744 t= 0.5285999999999744 t= 0.5287999999999744 t= 0.5289999999999744 t= 0.5291999999999744 t= 0.5293999999999743 t= 0.5295999999999743 t= 0.5297999999999743 t= 0.5299999999999743 t= 0.5301999999999742 t= 0.5303999999999742 t= 0.5305999999999742 t= 0.5307999999999742 t= 0.5309999999999742 t= 0.5311999999999741 t= 0.5313999999999741 t= 0.5315999999999741 t= 0.5317999999999741 t= 0.531999999999974 t= 0.532199999999974 t= 0.532399999999974 t= 0.532599999999974 t= 0.532799999999974 t= 0.5329999999999739 t= 0.5331999999999739 t= 0.5333999999999739 t= 0.5335999999999739 t= 0.5337999999999739 t= 0.5339999999999738 t= 0.5341999999999738 t= 0.5343999999999738 t= 0.5345999999999738 t= 0.5347999999999737 t= 0.5349999999999737 t= 0.5351999999999737 t= 0.5353999999999737 t= 0.5355999999999737 t= 0.5357999999999736 t= 0.5359999999999736 t= 0.5361999999999736 t= 0.5363999999999736 t= 0.5365999999999735 t= 0.5367999999999735 t= 0.5369999999999735 t= 0.5371999999999735 t= 0.5373999999999735 t= 0.5375999999999734 t= 0.5377999999999734 t= 0.5379999999999734 t= 0.5381999999999734 t= 0.5383999999999733 t= 0.5385999999999733 t= 0.5387999999999733 t= 0.5389999999999733 t= 0.5391999999999733 t= 0.5393999999999732 t= 0.5395999999999732 t= 0.5397999999999732 t= 0.5399999999999732 t= 0.5401999999999731 t= 0.5403999999999731 t= 0.5405999999999731 t= 0.5407999999999731 t= 0.5409999999999731 t= 0.541199999999973 t= 0.541399999999973 t= 0.541599999999973 t= 0.541799999999973 t= 0.541999999999973 t= 0.5421999999999729 t= 0.5423999999999729 t= 0.5425999999999729 t= 0.5427999999999729 t= 0.5429999999999728 t= 0.5431999999999728 t= 0.5433999999999728 t= 0.5435999999999728 t= 0.5437999999999727 t= 0.5439999999999727 t= 0.5441999999999727 t= 0.5443999999999727 t= 0.5445999999999727 t= 0.5447999999999726 t= 0.5449999999999726 t= 0.5451999999999726 t= 0.5453999999999726 t= 0.5455999999999726 t= 0.5457999999999725 t= 0.5459999999999725 t= 0.5461999999999725 t= 0.5463999999999725 t= 0.5465999999999724 t= 0.5467999999999724 t= 0.5469999999999724 t= 0.5471999999999724 t= 0.5473999999999724 t= 0.5475999999999723 t= 0.5477999999999723 t= 0.5479999999999723 t= 0.5481999999999723 t= 0.5483999999999722 t= 0.5485999999999722 t= 0.5487999999999722 t= 0.5489999999999722 t= 0.5491999999999722 t= 0.5493999999999721 t= 0.5495999999999721 t= 0.5497999999999721 t= 0.5499999999999721 t= 0.550199999999972 t= 0.550399999999972 t= 0.550599999999972 t= 0.550799999999972 t= 0.550999999999972 t= 0.5511999999999719 t= 0.5513999999999719 t= 0.5515999999999719 t= 0.5517999999999719 t= 0.5519999999999718 t= 0.5521999999999718 t= 0.5523999999999718 t= 0.5525999999999718 t= 0.5527999999999718 t= 0.5529999999999717 t= 0.5531999999999717 t= 0.5533999999999717 t= 0.5535999999999717 t= 0.5537999999999716 t= 0.5539999999999716 t= 0.5541999999999716 t= 0.5543999999999716 t= 0.5545999999999716 t= 0.5547999999999715 t= 0.5549999999999715 t= 0.5551999999999715 t= 0.5553999999999715 t= 0.5555999999999715 t= 0.5557999999999714 t= 0.5559999999999714 t= 0.5561999999999714 t= 0.5563999999999714 t= 0.5565999999999713 t= 0.5567999999999713 t= 0.5569999999999713 t= 0.5571999999999713 t= 0.5573999999999713 t= 0.5575999999999712 t= 0.5577999999999712 t= 0.5579999999999712 t= 0.5581999999999712 t= 0.5583999999999711 t= 0.5585999999999711 t= 0.5587999999999711 t= 0.5589999999999711 t= 0.559199999999971 t= 0.559399999999971 t= 0.559599999999971 t= 0.559799999999971 t= 0.559999999999971 t= 0.5601999999999709 t= 0.5603999999999709 t= 0.5605999999999709 t= 0.5607999999999709 t= 0.5609999999999709 t= 0.5611999999999708 t= 0.5613999999999708 t= 0.5615999999999708 t= 0.5617999999999708 t= 0.5619999999999707 t= 0.5621999999999707 t= 0.5623999999999707 t= 0.5625999999999707 t= 0.5627999999999707 t= 0.5629999999999706 t= 0.5631999999999706 t= 0.5633999999999706 t= 0.5635999999999706 t= 0.5637999999999705 t= 0.5639999999999705 t= 0.5641999999999705 t= 0.5643999999999705 t= 0.5645999999999705 t= 0.5647999999999704 t= 0.5649999999999704 t= 0.5651999999999704 t= 0.5653999999999704 t= 0.5655999999999703 t= 0.5657999999999703 t= 0.5659999999999703 t= 0.5661999999999703 t= 0.5663999999999703 t= 0.5665999999999702 t= 0.5667999999999702 t= 0.5669999999999702 t= 0.5671999999999702 t= 0.5673999999999702 t= 0.5675999999999701 t= 0.5677999999999701 t= 0.5679999999999701 t= 0.5681999999999701 t= 0.56839999999997 t= 0.56859999999997 t= 0.56879999999997 t= 0.56899999999997 t= 0.56919999999997 t= 0.5693999999999699 t= 0.5695999999999699 t= 0.5697999999999699 t= 0.5699999999999699 t= 0.5701999999999698 t= 0.5703999999999698 t= 0.5705999999999698 t= 0.5707999999999698 t= 0.5709999999999698 t= 0.5711999999999697 t= 0.5713999999999697 t= 0.5715999999999697 t= 0.5717999999999697 t= 0.5719999999999696 t= 0.5721999999999696 t= 0.5723999999999696 t= 0.5725999999999696 t= 0.5727999999999696 t= 0.5729999999999695 t= 0.5731999999999695 t= 0.5733999999999695 t= 0.5735999999999695 t= 0.5737999999999694 t= 0.5739999999999694 t= 0.5741999999999694 t= 0.5743999999999694 t= 0.5745999999999694 t= 0.5747999999999693 t= 0.5749999999999693 t= 0.5751999999999693 t= 0.5753999999999693 t= 0.5755999999999692 t= 0.5757999999999692 t= 0.5759999999999692 t= 0.5761999999999692 t= 0.5763999999999692 t= 0.5765999999999691 t= 0.5767999999999691 t= 0.5769999999999691 t= 0.5771999999999691 t= 0.577399999999969 t= 0.577599999999969 t= 0.577799999999969 t= 0.577999999999969 t= 0.578199999999969 t= 0.5783999999999689 t= 0.5785999999999689 t= 0.5787999999999689 t= 0.5789999999999689 t= 0.5791999999999689 t= 0.5793999999999688 t= 0.5795999999999688 t= 0.5797999999999688 t= 0.5799999999999688 t= 0.5801999999999687 t= 0.5803999999999687 t= 0.5805999999999687 t= 0.5807999999999687 t= 0.5809999999999687 t= 0.5811999999999686 t= 0.5813999999999686 t= 0.5815999999999686 t= 0.5817999999999686 t= 0.5819999999999685 t= 0.5821999999999685 t= 0.5823999999999685 t= 0.5825999999999685 t= 0.5827999999999685 t= 0.5829999999999684 t= 0.5831999999999684 t= 0.5833999999999684 t= 0.5835999999999684 t= 0.5837999999999683 t= 0.5839999999999683 t= 0.5841999999999683 t= 0.5843999999999683 t= 0.5845999999999683 t= 0.5847999999999682 t= 0.5849999999999682 t= 0.5851999999999682 t= 0.5853999999999682 t= 0.5855999999999681 t= 0.5857999999999681 t= 0.5859999999999681 t= 0.5861999999999681 t= 0.5863999999999681 t= 0.586599999999968 t= 0.586799999999968 t= 0.586999999999968 t= 0.587199999999968 t= 0.587399999999968 t= 0.5875999999999679 t= 0.5877999999999679 t= 0.5879999999999679 t= 0.5881999999999679 t= 0.5883999999999678 t= 0.5885999999999678 t= 0.5887999999999678 t= 0.5889999999999678 t= 0.5891999999999677 t= 0.5893999999999677 t= 0.5895999999999677 t= 0.5897999999999677 t= 0.5899999999999677 t= 0.5901999999999676 t= 0.5903999999999676 t= 0.5905999999999676 t= 0.5907999999999676 t= 0.5909999999999676 t= 0.5911999999999675 t= 0.5913999999999675 t= 0.5915999999999675 t= 0.5917999999999675 t= 0.5919999999999674 t= 0.5921999999999674 t= 0.5923999999999674 t= 0.5925999999999674 t= 0.5927999999999674 t= 0.5929999999999673 t= 0.5931999999999673 t= 0.5933999999999673 t= 0.5935999999999673 t= 0.5937999999999672 t= 0.5939999999999672 t= 0.5941999999999672 t= 0.5943999999999672 t= 0.5945999999999672 t= 0.5947999999999671 t= 0.5949999999999671 t= 0.5951999999999671 t= 0.5953999999999671 t= 0.595599999999967 t= 0.595799999999967 t= 0.595999999999967 t= 0.596199999999967 t= 0.596399999999967 t= 0.5965999999999669 t= 0.5967999999999669 t= 0.5969999999999669 t= 0.5971999999999669 t= 0.5973999999999668 t= 0.5975999999999668 t= 0.5977999999999668 t= 0.5979999999999668 t= 0.5981999999999668 t= 0.5983999999999667 t= 0.5985999999999667 t= 0.5987999999999667 t= 0.5989999999999667 t= 0.5991999999999666 t= 0.5993999999999666 t= 0.5995999999999666 t= 0.5997999999999666 t= 0.5999999999999666CPU times: user 4.55 s, sys: 40.6 ms, total: 4.59 s
Wall time: 4.55 s end{sphinxVerbatim}
t= 0.0002 t= 0.0004 t= 0.0006000000000000001 t= 0.0008 t= 0.001 t= 0.0012000000000000001 t= 0.0014000000000000002 t= 0.0016000000000000003 t= 0.0018000000000000004 t= 0.0020000000000000005 t= 0.0022000000000000006 t= 0.0024000000000000007 t= 0.0026000000000000007 t= 0.002800000000000001 t= 0.003000000000000001 t= 0.003200000000000001 t= 0.003400000000000001 t= 0.003600000000000001 t= 0.0038000000000000013 t= 0.004000000000000001 t= 0.004200000000000001 t= 0.0044 t= 0.0046 t= 0.0048 t= 0.004999999999999999 t= 0.005199999999999999 t= 0.0053999999999999986 t= 0.005599999999999998 t= 0.005799999999999998 t= 0.0059999999999999975 t= 0.006199999999999997 t= 0.006399999999999997 t= 0.0065999999999999965 t= 0.006799999999999996 t= 0.006999999999999996 t= 0.0071999999999999955 t= 0.007399999999999995 t= 0.007599999999999995 t= 0.0077999999999999944 t= 0.007999999999999995 t= 0.008199999999999995 t= 0.008399999999999996 t= 0.008599999999999997 t= 0.008799999999999997 t= 0.008999999999999998 t= 0.009199999999999998 t= 0.009399999999999999 t= 0.0096 t= 0.0098 t= 0.01 t= 0.0102 t= 0.010400000000000001 t= 0.010600000000000002 t= 0.010800000000000002 t= 0.011000000000000003 t= 0.011200000000000003 t= 0.011400000000000004 t= 0.011600000000000004 t= 0.011800000000000005 t= 0.012000000000000005 t= 0.012200000000000006 t= 0.012400000000000007 t= 0.012600000000000007 t= 0.012800000000000008 t= 0.013000000000000008 t= 0.013200000000000009 t= 0.013400000000000009 t= 0.01360000000000001 t= 0.01380000000000001 t= 0.01400000000000001 t= 0.014200000000000011 t= 0.014400000000000012 t= 0.014600000000000012 t= 0.014800000000000013 t= 0.015000000000000013 t= 0.015200000000000014 t= 0.015400000000000014 t= 0.015600000000000015 t= 0.015800000000000015 t= 0.016000000000000014 t= 0.016200000000000013 t= 0.016400000000000012 t= 0.01660000000000001 t= 0.01680000000000001 t= 0.017000000000000008 t= 0.017200000000000007 t= 0.017400000000000006 t= 0.017600000000000005 t= 0.017800000000000003 t= 0.018000000000000002 t= 0.0182 t= 0.0184 t= 0.0186 t= 0.018799999999999997 t= 0.018999999999999996 t= 0.019199999999999995 t= 0.019399999999999994 t= 0.019599999999999992 t= 0.01979999999999999 t= 0.01999999999999999 t= 0.02019999999999999 t= 0.020399999999999988 t= 0.020599999999999986 t= 0.020799999999999985 t= 0.020999999999999984 t= 0.021199999999999983 t= 0.02139999999999998 t= 0.02159999999999998 t= 0.02179999999999998 t= 0.021999999999999978 t= 0.022199999999999977 t= 0.022399999999999975 t= 0.022599999999999974 t= 0.022799999999999973 t= 0.022999999999999972 t= 0.02319999999999997 t= 0.02339999999999997 t= 0.023599999999999968 t= 0.023799999999999967 t= 0.023999999999999966 t= 0.024199999999999965 t= 0.024399999999999963 t= 0.024599999999999962 t= 0.02479999999999996 t= 0.02499999999999996 t= 0.02519999999999996 t= 0.025399999999999957 t= 0.025599999999999956 t= 0.025799999999999955 t= 0.025999999999999954 t= 0.026199999999999952 t= 0.02639999999999995 t= 0.02659999999999995 t= 0.02679999999999995 t= 0.026999999999999948 t= 0.027199999999999946 t= 0.027399999999999945 t= 0.027599999999999944 t= 0.027799999999999943 t= 0.02799999999999994 t= 0.02819999999999994 t= 0.02839999999999994 t= 0.028599999999999938 t= 0.028799999999999937 t= 0.028999999999999936 t= 0.029199999999999934 t= 0.029399999999999933 t= 0.029599999999999932 t= 0.02979999999999993 t= 0.02999999999999993 t= 0.03019999999999993 t= 0.030399999999999927 t= 0.030599999999999926 t= 0.030799999999999925 t= 0.030999999999999923 t= 0.031199999999999922 t= 0.03139999999999992 t= 0.03159999999999992 t= 0.03179999999999992 t= 0.03199999999999992 t= 0.032199999999999916 t= 0.032399999999999915 t= 0.032599999999999914 t= 0.03279999999999991 t= 0.03299999999999991 t= 0.03319999999999991 t= 0.03339999999999991 t= 0.03359999999999991 t= 0.033799999999999907 t= 0.033999999999999905 t= 0.034199999999999904 t= 0.0343999999999999 t= 0.0345999999999999 t= 0.0347999999999999 t= 0.0349999999999999 t= 0.0351999999999999 t= 0.0353999999999999 t= 0.035599999999999896 t= 0.035799999999999894 t= 0.03599999999999989 t= 0.03619999999999989 t= 0.03639999999999989 t= 0.03659999999999989 t= 0.03679999999999989 t= 0.03699999999999989 t= 0.037199999999999886 t= 0.037399999999999885 t= 0.037599999999999884 t= 0.03779999999999988 t= 0.03799999999999988 t= 0.03819999999999988 t= 0.03839999999999988 t= 0.03859999999999988 t= 0.038799999999999876 t= 0.038999999999999875 t= 0.039199999999999874 t= 0.03939999999999987 t= 0.03959999999999987 t= 0.03979999999999987 t= 0.03999999999999987 t= 0.04019999999999987 t= 0.04039999999999987 t= 0.040599999999999865 t= 0.040799999999999864 t= 0.04099999999999986 t= 0.04119999999999986 t= 0.04139999999999986 t= 0.04159999999999986 t= 0.04179999999999986 t= 0.04199999999999986 t= 0.042199999999999856 t= 0.042399999999999854 t= 0.04259999999999985 t= 0.04279999999999985 t= 0.04299999999999985 t= 0.04319999999999985 t= 0.04339999999999985 t= 0.04359999999999985 t= 0.043799999999999846 t= 0.043999999999999845 t= 0.044199999999999844 t= 0.04439999999999984 t= 0.04459999999999984 t= 0.04479999999999984 t= 0.04499999999999984 t= 0.04519999999999984 t= 0.045399999999999836 t= 0.045599999999999835 t= 0.045799999999999834 t= 0.04599999999999983 t= 0.04619999999999983 t= 0.04639999999999983 t= 0.04659999999999983 t= 0.04679999999999983 t= 0.04699999999999983 t= 0.047199999999999825 t= 0.047399999999999824 t= 0.04759999999999982 t= 0.04779999999999982 t= 0.04799999999999982 t= 0.04819999999999982 t= 0.04839999999999982 t= 0.04859999999999982 t= 0.048799999999999816 t= 0.048999999999999815 t= 0.04919999999999981 t= 0.04939999999999981 t= 0.04959999999999981 t= 0.04979999999999981 t= 0.04999999999999981 t= 0.05019999999999981 t= 0.050399999999999806 t= 0.050599999999999805 t= 0.050799999999999804 t= 0.0509999999999998 t= 0.0511999999999998 t= 0.0513999999999998 t= 0.0515999999999998 t= 0.0517999999999998 t= 0.051999999999999796 t= 0.052199999999999795 t= 0.052399999999999794 t= 0.05259999999999979 t= 0.05279999999999979 t= 0.05299999999999979 t= 0.05319999999999979 t= 0.05339999999999979 t= 0.05359999999999979 t= 0.053799999999999785 t= 0.053999999999999784 t= 0.05419999999999978 t= 0.05439999999999978 t= 0.05459999999999978 t= 0.05479999999999978 t= 0.05499999999999978 t= 0.05519999999999978 t= 0.055399999999999776 t= 0.055599999999999775 t= 0.05579999999999977 t= 0.05599999999999977 t= 0.05619999999999977 t= 0.05639999999999977 t= 0.05659999999999977 t= 0.05679999999999977 t= 0.056999999999999766 t= 0.057199999999999765 t= 0.057399999999999764 t= 0.05759999999999976 t= 0.05779999999999976 t= 0.05799999999999976 t= 0.05819999999999976 t= 0.05839999999999976 t= 0.058599999999999756 t= 0.058799999999999755 t= 0.058999999999999754 t= 0.05919999999999975 t= 0.05939999999999975 t= 0.05959999999999975 t= 0.05979999999999975 t= 0.05999999999999975 t= 0.06019999999999975 t= 0.060399999999999746 t= 0.060599999999999744 t= 0.06079999999999974 t= 0.06099999999999974 t= 0.06119999999999974 t= 0.06139999999999974 t= 0.06159999999999974 t= 0.06179999999999974 t= 0.061999999999999736 t= 0.062199999999999735 t= 0.06239999999999973 t= 0.06259999999999974 t= 0.06279999999999974 t= 0.06299999999999975 t= 0.06319999999999976 t= 0.06339999999999976 t= 0.06359999999999977 t= 0.06379999999999977 t= 0.06399999999999978 t= 0.06419999999999979 t= 0.06439999999999979 t= 0.0645999999999998 t= 0.0647999999999998 t= 0.06499999999999981 t= 0.06519999999999981 t= 0.06539999999999982 t= 0.06559999999999983 t= 0.06579999999999983 t= 0.06599999999999984 t= 0.06619999999999984 t= 0.06639999999999985 t= 0.06659999999999985 t= 0.06679999999999986 t= 0.06699999999999987 t= 0.06719999999999987 t= 0.06739999999999988 t= 0.06759999999999988 t= 0.06779999999999989 t= 0.0679999999999999 t= 0.0681999999999999 t= 0.0683999999999999 t= 0.06859999999999991 t= 0.06879999999999992 t= 0.06899999999999992 t= 0.06919999999999993 t= 0.06939999999999993 t= 0.06959999999999994 t= 0.06979999999999995 t= 0.06999999999999995 t= 0.07019999999999996 t= 0.07039999999999996 t= 0.07059999999999997 t= 0.07079999999999997 t= 0.07099999999999998 t= 0.07119999999999999 t= 0.07139999999999999 t= 0.0716 t= 0.0718 t= 0.07200000000000001 t= 0.07220000000000001 t= 0.07240000000000002 t= 0.07260000000000003 t= 0.07280000000000003 t= 0.07300000000000004 t= 0.07320000000000004 t= 0.07340000000000005 t= 0.07360000000000005 t= 0.07380000000000006 t= 0.07400000000000007 t= 0.07420000000000007 t= 0.07440000000000008 t= 0.07460000000000008 t= 0.07480000000000009 t= 0.0750000000000001 t= 0.0752000000000001 t= 0.0754000000000001 t= 0.07560000000000011 t= 0.07580000000000012 t= 0.07600000000000012 t= 0.07620000000000013 t= 0.07640000000000013 t= 0.07660000000000014 t= 0.07680000000000015 t= 0.07700000000000015 t= 0.07720000000000016 t= 0.07740000000000016 t= 0.07760000000000017 t= 0.07780000000000017 t= 0.07800000000000018 t= 0.07820000000000019 t= 0.07840000000000019 t= 0.0786000000000002 t= 0.0788000000000002 t= 0.07900000000000021 t= 0.07920000000000021 t= 0.07940000000000022 t= 0.07960000000000023 t= 0.07980000000000023 t= 0.08000000000000024 t= 0.08020000000000024 t= 0.08040000000000025 t= 0.08060000000000025 t= 0.08080000000000026 t= 0.08100000000000027 t= 0.08120000000000027 t= 0.08140000000000028 t= 0.08160000000000028 t= 0.08180000000000029 t= 0.0820000000000003 t= 0.0822000000000003 t= 0.0824000000000003 t= 0.08260000000000031 t= 0.08280000000000032 t= 0.08300000000000032 t= 0.08320000000000033 t= 0.08340000000000033 t= 0.08360000000000034 t= 0.08380000000000035 t= 0.08400000000000035 t= 0.08420000000000036 t= 0.08440000000000036 t= 0.08460000000000037 t= 0.08480000000000038 t= 0.08500000000000038 t= 0.08520000000000039 t= 0.08540000000000039 t= 0.0856000000000004 t= 0.0858000000000004 t= 0.08600000000000041 t= 0.08620000000000042 t= 0.08640000000000042 t= 0.08660000000000043 t= 0.08680000000000043 t= 0.08700000000000044 t= 0.08720000000000044 t= 0.08740000000000045 t= 0.08760000000000046 t= 0.08780000000000046 t= 0.08800000000000047 t= 0.08820000000000047 t= 0.08840000000000048 t= 0.08860000000000048 t= 0.08880000000000049 t= 0.0890000000000005 t= 0.0892000000000005 t= 0.0894000000000005 t= 0.08960000000000051 t= 0.08980000000000052 t= 0.09000000000000052 t= 0.09020000000000053 t= 0.09040000000000054 t= 0.09060000000000054 t= 0.09080000000000055 t= 0.09100000000000055 t= 0.09120000000000056 t= 0.09140000000000056 t= 0.09160000000000057 t= 0.09180000000000058 t= 0.09200000000000058 t= 0.09220000000000059 t= 0.09240000000000059 t= 0.0926000000000006 t= 0.0928000000000006 t= 0.09300000000000061 t= 0.09320000000000062 t= 0.09340000000000062 t= 0.09360000000000063 t= 0.09380000000000063 t= 0.09400000000000064 t= 0.09420000000000064 t= 0.09440000000000065 t= 0.09460000000000066 t= 0.09480000000000066 t= 0.09500000000000067 t= 0.09520000000000067 t= 0.09540000000000068 t= 0.09560000000000068 t= 0.09580000000000069 t= 0.0960000000000007 t= 0.0962000000000007 t= 0.09640000000000071 t= 0.09660000000000071 t= 0.09680000000000072 t= 0.09700000000000072 t= 0.09720000000000073 t= 0.09740000000000074 t= 0.09760000000000074 t= 0.09780000000000075 t= 0.09800000000000075 t= 0.09820000000000076 t= 0.09840000000000076 t= 0.09860000000000077 t= 0.09880000000000078 t= 0.09900000000000078 t= 0.09920000000000079 t= 0.0994000000000008 t= 0.0996000000000008 t= 0.0998000000000008 t= 0.10000000000000081 t= 0.10020000000000082 t= 0.10040000000000082 t= 0.10060000000000083 t= 0.10080000000000083 t= 0.10100000000000084 t= 0.10120000000000084 t= 0.10140000000000085 t= 0.10160000000000086 t= 0.10180000000000086 t= 0.10200000000000087 t= 0.10220000000000087 t= 0.10240000000000088 t= 0.10260000000000088 t= 0.10280000000000089 t= 0.1030000000000009 t= 0.1032000000000009 t= 0.10340000000000091 t= 0.10360000000000091 t= 0.10380000000000092 t= 0.10400000000000093 t= 0.10420000000000093 t= 0.10440000000000094 t= 0.10460000000000094 t= 0.10480000000000095 t= 0.10500000000000095 t= 0.10520000000000096 t= 0.10540000000000097 t= 0.10560000000000097 t= 0.10580000000000098 t= 0.10600000000000098 t= 0.10620000000000099 t= 0.106400000000001 t= 0.106600000000001 t= 0.106800000000001 t= 0.10700000000000101 t= 0.10720000000000102 t= 0.10740000000000102 t= 0.10760000000000103 t= 0.10780000000000103 t= 0.10800000000000104 t= 0.10820000000000105 t= 0.10840000000000105 t= 0.10860000000000106 t= 0.10880000000000106 t= 0.10900000000000107 t= 0.10920000000000107 t= 0.10940000000000108 t= 0.10960000000000109 t= 0.10980000000000109 t= 0.1100000000000011 t= 0.1102000000000011 t= 0.11040000000000111 t= 0.11060000000000111 t= 0.11080000000000112 t= 0.11100000000000113 t= 0.11120000000000113 t= 0.11140000000000114 t= 0.11160000000000114 t= 0.11180000000000115 t= 0.11200000000000115 t= 0.11220000000000116 t= 0.11240000000000117 t= 0.11260000000000117 t= 0.11280000000000118 t= 0.11300000000000118 t= 0.11320000000000119 t= 0.1134000000000012 t= 0.1136000000000012 t= 0.1138000000000012 t= 0.11400000000000121 t= 0.11420000000000122 t= 0.11440000000000122 t= 0.11460000000000123 t= 0.11480000000000123 t= 0.11500000000000124 t= 0.11520000000000125 t= 0.11540000000000125 t= 0.11560000000000126 t= 0.11580000000000126 t= 0.11600000000000127 t= 0.11620000000000127 t= 0.11640000000000128 t= 0.11660000000000129 t= 0.11680000000000129 t= 0.1170000000000013 t= 0.1172000000000013 t= 0.11740000000000131 t= 0.11760000000000131 t= 0.11780000000000132 t= 0.11800000000000133 t= 0.11820000000000133 t= 0.11840000000000134 t= 0.11860000000000134 t= 0.11880000000000135 t= 0.11900000000000135 t= 0.11920000000000136 t= 0.11940000000000137 t= 0.11960000000000137 t= 0.11980000000000138 t= 0.12000000000000138 t= 0.12020000000000139 t= 0.1204000000000014 t= 0.1206000000000014 t= 0.1208000000000014 t= 0.12100000000000141 t= 0.12120000000000142 t= 0.12140000000000142 t= 0.12160000000000143 t= 0.12180000000000143 t= 0.12200000000000144 t= 0.12220000000000145 t= 0.12240000000000145 t= 0.12260000000000146 t= 0.12280000000000146 t= 0.12300000000000147 t= 0.12320000000000147 t= 0.12340000000000148 t= 0.12360000000000149 t= 0.12380000000000149 t= 0.1240000000000015 t= 0.1242000000000015 t= 0.12440000000000151 t= 0.12460000000000152 t= 0.12480000000000152 t= 0.12500000000000153 t= 0.12520000000000153 t= 0.12540000000000154 t= 0.12560000000000154 t= 0.12580000000000155 t= 0.12600000000000156 t= 0.12620000000000156 t= 0.12640000000000157 t= 0.12660000000000157 t= 0.12680000000000158 t= 0.12700000000000158 t= 0.1272000000000016 t= 0.1274000000000016 t= 0.1276000000000016 t= 0.1278000000000016 t= 0.1280000000000016 t= 0.12820000000000162 t= 0.12840000000000162 t= 0.12860000000000163 t= 0.12880000000000164 t= 0.12900000000000164 t= 0.12920000000000165 t= 0.12940000000000165 t= 0.12960000000000166 t= 0.12980000000000166 t= 0.13000000000000167 t= 0.13020000000000168 t= 0.13040000000000168 t= 0.1306000000000017 t= 0.1308000000000017 t= 0.1310000000000017 t= 0.1312000000000017 t= 0.1314000000000017 t= 0.13160000000000172 t= 0.13180000000000172 t= 0.13200000000000173 t= 0.13220000000000173 t= 0.13240000000000174 t= 0.13260000000000174 t= 0.13280000000000175 t= 0.13300000000000176 t= 0.13320000000000176 t= 0.13340000000000177 t= 0.13360000000000177 t= 0.13380000000000178 t= 0.13400000000000178 t= 0.1342000000000018 t= 0.1344000000000018 t= 0.1346000000000018 t= 0.1348000000000018 t= 0.1350000000000018 t= 0.13520000000000182 t= 0.13540000000000182 t= 0.13560000000000183 t= 0.13580000000000184 t= 0.13600000000000184 t= 0.13620000000000185 t= 0.13640000000000185 t= 0.13660000000000186 t= 0.13680000000000186 t= 0.13700000000000187 t= 0.13720000000000188 t= 0.13740000000000188 t= 0.1376000000000019 t= 0.1378000000000019 t= 0.1380000000000019 t= 0.1382000000000019 t= 0.1384000000000019 t= 0.13860000000000192 t= 0.13880000000000192 t= 0.13900000000000193 t= 0.13920000000000193 t= 0.13940000000000194 t= 0.13960000000000194 t= 0.13980000000000195 t= 0.14000000000000196 t= 0.14020000000000196 t= 0.14040000000000197 t= 0.14060000000000197 t= 0.14080000000000198 t= 0.14100000000000198 t= 0.141200000000002 t= 0.141400000000002 t= 0.141600000000002 t= 0.141800000000002 t= 0.142000000000002 t= 0.14220000000000202 t= 0.14240000000000202 t= 0.14260000000000203 t= 0.14280000000000204 t= 0.14300000000000204 t= 0.14320000000000205 t= 0.14340000000000205 t= 0.14360000000000206 t= 0.14380000000000207 t= 0.14400000000000207 t= 0.14420000000000208 t= 0.14440000000000208 t= 0.1446000000000021 t= 0.1448000000000021 t= 0.1450000000000021 t= 0.1452000000000021 t= 0.1454000000000021 t= 0.14560000000000212 t= 0.14580000000000212 t= 0.14600000000000213 t= 0.14620000000000213 t= 0.14640000000000214 t= 0.14660000000000215 t= 0.14680000000000215 t= 0.14700000000000216 t= 0.14720000000000216 t= 0.14740000000000217 t= 0.14760000000000217 t= 0.14780000000000218 t= 0.14800000000000219 t= 0.1482000000000022 t= 0.1484000000000022 t= 0.1486000000000022 t= 0.1488000000000022 t= 0.14900000000000221 t= 0.14920000000000222 t= 0.14940000000000223 t= 0.14960000000000223 t= 0.14980000000000224 t= 0.15000000000000224 t= 0.15020000000000225 t= 0.15040000000000225 t= 0.15060000000000226 t= 0.15080000000000227 t= 0.15100000000000227 t= 0.15120000000000228 t= 0.15140000000000228 t= 0.1516000000000023 t= 0.1518000000000023 t= 0.1520000000000023 t= 0.1522000000000023 t= 0.1524000000000023 t= 0.15260000000000232 t= 0.15280000000000232 t= 0.15300000000000233 t= 0.15320000000000233 t= 0.15340000000000234 t= 0.15360000000000235 t= 0.15380000000000235 t= 0.15400000000000236 t= 0.15420000000000236 t= 0.15440000000000237 t= 0.15460000000000237 t= 0.15480000000000238 t= 0.15500000000000239 t= 0.1552000000000024 t= 0.1554000000000024 t= 0.1556000000000024 t= 0.1558000000000024 t= 0.15600000000000241 t= 0.15620000000000242 t= 0.15640000000000243 t= 0.15660000000000243 t= 0.15680000000000244 t= 0.15700000000000244 t= 0.15720000000000245 t= 0.15740000000000245 t= 0.15760000000000246 t= 0.15780000000000247 t= 0.15800000000000247 t= 0.15820000000000248 t= 0.15840000000000248 t= 0.1586000000000025 t= 0.1588000000000025 t= 0.1590000000000025 t= 0.1592000000000025 t= 0.1594000000000025 t= 0.15960000000000252 t= 0.15980000000000252 t= 0.16000000000000253 t= 0.16020000000000253 t= 0.16040000000000254 t= 0.16060000000000255 t= 0.16080000000000255 t= 0.16100000000000256 t= 0.16120000000000256 t= 0.16140000000000257 t= 0.16160000000000257 t= 0.16180000000000258 t= 0.1620000000000026 t= 0.1622000000000026 t= 0.1624000000000026 t= 0.1626000000000026 t= 0.1628000000000026 t= 0.16300000000000262 t= 0.16320000000000262 t= 0.16340000000000263 t= 0.16360000000000263 t= 0.16380000000000264 t= 0.16400000000000264 t= 0.16420000000000265 t= 0.16440000000000266 t= 0.16460000000000266 t= 0.16480000000000267 t= 0.16500000000000267 t= 0.16520000000000268 t= 0.16540000000000268 t= 0.1656000000000027 t= 0.1658000000000027 t= 0.1660000000000027 t= 0.1662000000000027 t= 0.1664000000000027 t= 0.16660000000000272 t= 0.16680000000000272 t= 0.16700000000000273 t= 0.16720000000000274 t= 0.16740000000000274 t= 0.16760000000000275 t= 0.16780000000000275 t= 0.16800000000000276 t= 0.16820000000000276 t= 0.16840000000000277 t= 0.16860000000000278 t= 0.16880000000000278 t= 0.1690000000000028 t= 0.1692000000000028 t= 0.1694000000000028 t= 0.1696000000000028 t= 0.1698000000000028 t= 0.17000000000000282 t= 0.17020000000000282 t= 0.17040000000000283 t= 0.17060000000000283 t= 0.17080000000000284 t= 0.17100000000000284 t= 0.17120000000000285 t= 0.17140000000000286 t= 0.17160000000000286 t= 0.17180000000000287 t= 0.17200000000000287 t= 0.17220000000000288 t= 0.17240000000000288 t= 0.1726000000000029 t= 0.1728000000000029 t= 0.1730000000000029 t= 0.1732000000000029 t= 0.1734000000000029 t= 0.17360000000000292 t= 0.17380000000000292 t= 0.17400000000000293 t= 0.17420000000000294 t= 0.17440000000000294 t= 0.17460000000000295 t= 0.17480000000000295 t= 0.17500000000000296 t= 0.17520000000000296 t= 0.17540000000000297 t= 0.17560000000000298 t= 0.17580000000000298 t= 0.176000000000003 t= 0.176200000000003 t= 0.176400000000003 t= 0.176600000000003 t= 0.176800000000003 t= 0.17700000000000302 t= 0.17720000000000302 t= 0.17740000000000303 t= 0.17760000000000303 t= 0.17780000000000304 t= 0.17800000000000304 t= 0.17820000000000305 t= 0.17840000000000306 t= 0.17860000000000306 t= 0.17880000000000307 t= 0.17900000000000307 t= 0.17920000000000308 t= 0.17940000000000308 t= 0.1796000000000031 t= 0.1798000000000031 t= 0.1800000000000031 t= 0.1802000000000031 t= 0.1804000000000031 t= 0.18060000000000312 t= 0.18080000000000312 t= 0.18100000000000313 t= 0.18120000000000314 t= 0.18140000000000314 t= 0.18160000000000315 t= 0.18180000000000315 t= 0.18200000000000316 t= 0.18220000000000316 t= 0.18240000000000317 t= 0.18260000000000318 t= 0.18280000000000318 t= 0.1830000000000032 t= 0.1832000000000032 t= 0.1834000000000032 t= 0.1836000000000032 t= 0.1838000000000032 t= 0.18400000000000322 t= 0.18420000000000322 t= 0.18440000000000323 t= 0.18460000000000323 t= 0.18480000000000324 t= 0.18500000000000325 t= 0.18520000000000325 t= 0.18540000000000326 t= 0.18560000000000326 t= 0.18580000000000327 t= 0.18600000000000327 t= 0.18620000000000328 t= 0.18640000000000329 t= 0.1866000000000033 t= 0.1868000000000033 t= 0.1870000000000033 t= 0.1872000000000033 t= 0.18740000000000331 t= 0.18760000000000332 t= 0.18780000000000333 t= 0.18800000000000333 t= 0.18820000000000334 t= 0.18840000000000334 t= 0.18860000000000335 t= 0.18880000000000335 t= 0.18900000000000336 t= 0.18920000000000337 t= 0.18940000000000337 t= 0.18960000000000338 t= 0.18980000000000338 t= 0.1900000000000034 t= 0.1902000000000034 t= 0.1904000000000034 t= 0.1906000000000034 t= 0.1908000000000034 t= 0.19100000000000342 t= 0.19120000000000342 t= 0.19140000000000343 t= 0.19160000000000343 t= 0.19180000000000344 t= 0.19200000000000345 t= 0.19220000000000345 t= 0.19240000000000346 t= 0.19260000000000346 t= 0.19280000000000347 t= 0.19300000000000347 t= 0.19320000000000348 t= 0.19340000000000349 t= 0.1936000000000035 t= 0.1938000000000035 t= 0.1940000000000035 t= 0.1942000000000035 t= 0.19440000000000351 t= 0.19460000000000352 t= 0.19480000000000353 t= 0.19500000000000353 t= 0.19520000000000354 t= 0.19540000000000354 t= 0.19560000000000355 t= 0.19580000000000355 t= 0.19600000000000356 t= 0.19620000000000357 t= 0.19640000000000357 t= 0.19660000000000358 t= 0.19680000000000358 t= 0.1970000000000036 t= 0.1972000000000036 t= 0.1974000000000036 t= 0.1976000000000036 t= 0.1978000000000036 t= 0.19800000000000362 t= 0.19820000000000362 t= 0.19840000000000363 t= 0.19860000000000363 t= 0.19880000000000364 t= 0.19900000000000365 t= 0.19920000000000365 t= 0.19940000000000366 t= 0.19960000000000366 t= 0.19980000000000367 t= 0.20000000000000367 t= 0.20020000000000368 t= 0.2004000000000037 t= 0.2006000000000037 t= 0.2008000000000037 t= 0.2010000000000037 t= 0.2012000000000037 t= 0.20140000000000371 t= 0.20160000000000372 t= 0.20180000000000373 t= 0.20200000000000373 t= 0.20220000000000374 t= 0.20240000000000374 t= 0.20260000000000375 t= 0.20280000000000376 t= 0.20300000000000376 t= 0.20320000000000377 t= 0.20340000000000377 t= 0.20360000000000378 t= 0.20380000000000378 t= 0.2040000000000038 t= 0.2042000000000038 t= 0.2044000000000038 t= 0.2046000000000038 t= 0.2048000000000038 t= 0.20500000000000382 t= 0.20520000000000382 t= 0.20540000000000383 t= 0.20560000000000384 t= 0.20580000000000384 t= 0.20600000000000385 t= 0.20620000000000385 t= 0.20640000000000386 t= 0.20660000000000386 t= 0.20680000000000387 t= 0.20700000000000388 t= 0.20720000000000388 t= 0.2074000000000039 t= 0.2076000000000039 t= 0.2078000000000039 t= 0.2080000000000039 t= 0.2082000000000039 t= 0.20840000000000392 t= 0.20860000000000392 t= 0.20880000000000393 t= 0.20900000000000393 t= 0.20920000000000394 t= 0.20940000000000394 t= 0.20960000000000395 t= 0.20980000000000396 t= 0.21000000000000396 t= 0.21020000000000397 t= 0.21040000000000397 t= 0.21060000000000398 t= 0.21080000000000398 t= 0.211000000000004 t= 0.211200000000004 t= 0.211400000000004 t= 0.211600000000004 t= 0.211800000000004 t= 0.21200000000000402 t= 0.21220000000000402 t= 0.21240000000000403 t= 0.21260000000000404 t= 0.21280000000000404 t= 0.21300000000000405 t= 0.21320000000000405 t= 0.21340000000000406 t= 0.21360000000000406 t= 0.21380000000000407 t= 0.21400000000000408 t= 0.21420000000000408 t= 0.2144000000000041 t= 0.2146000000000041 t= 0.2148000000000041 t= 0.2150000000000041 t= 0.2152000000000041 t= 0.21540000000000412 t= 0.21560000000000412 t= 0.21580000000000413 t= 0.21600000000000413 t= 0.21620000000000414 t= 0.21640000000000414 t= 0.21660000000000415 t= 0.21680000000000416 t= 0.21700000000000416 t= 0.21720000000000417 t= 0.21740000000000417 t= 0.21760000000000418 t= 0.21780000000000418 t= 0.2180000000000042 t= 0.2182000000000042 t= 0.2184000000000042 t= 0.2186000000000042 t= 0.2188000000000042 t= 0.21900000000000422 t= 0.21920000000000422 t= 0.21940000000000423 t= 0.21960000000000424 t= 0.21980000000000424 t= 0.22000000000000425 t= 0.22020000000000425 t= 0.22040000000000426 t= 0.22060000000000426 t= 0.22080000000000427 t= 0.22100000000000428 t= 0.22120000000000428 t= 0.2214000000000043 t= 0.2216000000000043 t= 0.2218000000000043 t= 0.2220000000000043 t= 0.2222000000000043 t= 0.22240000000000432 t= 0.22260000000000432 t= 0.22280000000000433 t= 0.22300000000000433 t= 0.22320000000000434 t= 0.22340000000000435 t= 0.22360000000000435 t= 0.22380000000000436 t= 0.22400000000000436 t= 0.22420000000000437 t= 0.22440000000000437 t= 0.22460000000000438 t= 0.22480000000000439 t= 0.2250000000000044 t= 0.2252000000000044 t= 0.2254000000000044 t= 0.2256000000000044 t= 0.2258000000000044 t= 0.22600000000000442 t= 0.22620000000000443 t= 0.22640000000000443 t= 0.22660000000000444 t= 0.22680000000000444 t= 0.22700000000000445 t= 0.22720000000000445 t= 0.22740000000000446 t= 0.22760000000000447 t= 0.22780000000000447 t= 0.22800000000000448 t= 0.22820000000000448 t= 0.2284000000000045 t= 0.2286000000000045 t= 0.2288000000000045 t= 0.2290000000000045 t= 0.2292000000000045 t= 0.22940000000000452 t= 0.22960000000000452 t= 0.22980000000000453 t= 0.23000000000000453 t= 0.23020000000000454 t= 0.23040000000000455 t= 0.23060000000000455 t= 0.23080000000000456 t= 0.23100000000000456 t= 0.23120000000000457 t= 0.23140000000000457 t= 0.23160000000000458 t= 0.23180000000000459 t= 0.2320000000000046 t= 0.2322000000000046 t= 0.2324000000000046 t= 0.2326000000000046 t= 0.23280000000000461 t= 0.23300000000000462 t= 0.23320000000000463 t= 0.23340000000000463 t= 0.23360000000000464 t= 0.23380000000000464 t= 0.23400000000000465 t= 0.23420000000000465 t= 0.23440000000000466 t= 0.23460000000000467 t= 0.23480000000000467 t= 0.23500000000000468 t= 0.23520000000000468 t= 0.2354000000000047 t= 0.2356000000000047 t= 0.2358000000000047 t= 0.2360000000000047 t= 0.2362000000000047 t= 0.23640000000000472 t= 0.23660000000000472 t= 0.23680000000000473 t= 0.23700000000000473 t= 0.23720000000000474 t= 0.23740000000000475 t= 0.23760000000000475 t= 0.23780000000000476 t= 0.23800000000000476 t= 0.23820000000000477 t= 0.23840000000000477 t= 0.23860000000000478 t= 0.2388000000000048 t= 0.2390000000000048 t= 0.2392000000000048 t= 0.2394000000000048 t= 0.2396000000000048 t= 0.23980000000000481 t= 0.24000000000000482 t= 0.24020000000000483 t= 0.24040000000000483 t= 0.24060000000000484 t= 0.24080000000000484 t= 0.24100000000000485 t= 0.24120000000000485 t= 0.24140000000000486 t= 0.24160000000000487 t= 0.24180000000000487 t= 0.24200000000000488 t= 0.24220000000000488 t= 0.2424000000000049 t= 0.2426000000000049 t= 0.2428000000000049 t= 0.2430000000000049 t= 0.2432000000000049 t= 0.24340000000000492 t= 0.24360000000000492 t= 0.24380000000000493 t= 0.24400000000000494 t= 0.24420000000000494 t= 0.24440000000000495 t= 0.24460000000000495 t= 0.24480000000000496 t= 0.24500000000000496 t= 0.24520000000000497 t= 0.24540000000000498 t= 0.24560000000000498 t= 0.245800000000005 t= 0.246000000000005 t= 0.246200000000005 t= 0.246400000000005 t= 0.246600000000005 t= 0.24680000000000502 t= 0.24700000000000502 t= 0.24720000000000503 t= 0.24740000000000503 t= 0.24760000000000504 t= 0.24780000000000504 t= 0.24800000000000505 t= 0.24820000000000506 t= 0.24840000000000506 t= 0.24860000000000507 t= 0.24880000000000507 t= 0.24900000000000508 t= 0.24920000000000508 t= 0.2494000000000051 t= 0.2496000000000051 t= 0.2498000000000051 t= 0.2500000000000051 t= 0.2502000000000051 t= 0.25040000000000506 t= 0.25060000000000504 t= 0.250800000000005 t= 0.251000000000005 t= 0.251200000000005 t= 0.25140000000000495 t= 0.25160000000000493 t= 0.2518000000000049 t= 0.2520000000000049 t= 0.25220000000000486 t= 0.25240000000000484 t= 0.2526000000000048 t= 0.2528000000000048 t= 0.2530000000000048 t= 0.25320000000000475 t= 0.25340000000000473 t= 0.2536000000000047 t= 0.2538000000000047 t= 0.25400000000000467 t= 0.25420000000000464 t= 0.2544000000000046 t= 0.2546000000000046 t= 0.2548000000000046 t= 0.25500000000000456 t= 0.25520000000000453 t= 0.2554000000000045 t= 0.2556000000000045 t= 0.25580000000000447 t= 0.25600000000000445 t= 0.2562000000000044 t= 0.2564000000000044 t= 0.2566000000000044 t= 0.25680000000000436 t= 0.25700000000000434 t= 0.2572000000000043 t= 0.2574000000000043 t= 0.25760000000000427 t= 0.25780000000000425 t= 0.2580000000000042 t= 0.2582000000000042 t= 0.2584000000000042 t= 0.25860000000000416 t= 0.25880000000000414 t= 0.2590000000000041 t= 0.2592000000000041 t= 0.25940000000000407 t= 0.25960000000000405 t= 0.259800000000004 t= 0.260000000000004 t= 0.260200000000004 t= 0.26040000000000396 t= 0.26060000000000394 t= 0.2608000000000039 t= 0.2610000000000039 t= 0.2612000000000039 t= 0.26140000000000385 t= 0.26160000000000383 t= 0.2618000000000038 t= 0.2620000000000038 t= 0.26220000000000376 t= 0.26240000000000374 t= 0.2626000000000037 t= 0.2628000000000037 t= 0.2630000000000037 t= 0.26320000000000365 t= 0.26340000000000363 t= 0.2636000000000036 t= 0.2638000000000036 t= 0.26400000000000357 t= 0.26420000000000354 t= 0.2644000000000035 t= 0.2646000000000035 t= 0.2648000000000035 t= 0.26500000000000346 t= 0.26520000000000343 t= 0.2654000000000034 t= 0.2656000000000034 t= 0.26580000000000337 t= 0.26600000000000334 t= 0.2662000000000033 t= 0.2664000000000033 t= 0.2666000000000033 t= 0.26680000000000326 t= 0.26700000000000323 t= 0.2672000000000032 t= 0.2674000000000032 t= 0.26760000000000317 t= 0.26780000000000315 t= 0.2680000000000031 t= 0.2682000000000031 t= 0.2684000000000031 t= 0.26860000000000306 t= 0.26880000000000304 t= 0.269000000000003 t= 0.269200000000003 t= 0.26940000000000297 t= 0.26960000000000295 t= 0.2698000000000029 t= 0.2700000000000029 t= 0.2702000000000029 t= 0.27040000000000286 t= 0.27060000000000284 t= 0.2708000000000028 t= 0.2710000000000028 t= 0.27120000000000277 t= 0.27140000000000275 t= 0.27160000000000273 t= 0.2718000000000027 t= 0.2720000000000027 t= 0.27220000000000266 t= 0.27240000000000264 t= 0.2726000000000026 t= 0.2728000000000026 t= 0.2730000000000026 t= 0.27320000000000255 t= 0.27340000000000253 t= 0.2736000000000025 t= 0.2738000000000025 t= 0.27400000000000246 t= 0.27420000000000244 t= 0.2744000000000024 t= 0.2746000000000024 t= 0.2748000000000024 t= 0.27500000000000235 t= 0.27520000000000233 t= 0.2754000000000023 t= 0.2756000000000023 t= 0.27580000000000227 t= 0.27600000000000224 t= 0.2762000000000022 t= 0.2764000000000022 t= 0.2766000000000022 t= 0.27680000000000216 t= 0.27700000000000213 t= 0.2772000000000021 t= 0.2774000000000021 t= 0.27760000000000207 t= 0.27780000000000205 t= 0.278000000000002 t= 0.278200000000002 t= 0.278400000000002 t= 0.27860000000000196 t= 0.27880000000000194 t= 0.2790000000000019 t= 0.2792000000000019 t= 0.27940000000000187 t= 0.27960000000000185 t= 0.2798000000000018 t= 0.2800000000000018 t= 0.2802000000000018 t= 0.28040000000000176 t= 0.28060000000000174 t= 0.2808000000000017 t= 0.2810000000000017 t= 0.28120000000000167 t= 0.28140000000000165 t= 0.2816000000000016 t= 0.2818000000000016 t= 0.2820000000000016 t= 0.28220000000000156 t= 0.28240000000000154 t= 0.2826000000000015 t= 0.2828000000000015 t= 0.2830000000000015 t= 0.28320000000000145 t= 0.28340000000000143 t= 0.2836000000000014 t= 0.2838000000000014 t= 0.28400000000000136 t= 0.28420000000000134 t= 0.2844000000000013 t= 0.2846000000000013 t= 0.2848000000000013 t= 0.28500000000000125 t= 0.28520000000000123 t= 0.2854000000000012 t= 0.2856000000000012 t= 0.28580000000000116 t= 0.28600000000000114 t= 0.2862000000000011 t= 0.2864000000000011 t= 0.2866000000000011 t= 0.28680000000000105 t= 0.28700000000000103 t= 0.287200000000001 t= 0.287400000000001 t= 0.28760000000000097 t= 0.28780000000000094 t= 0.2880000000000009 t= 0.2882000000000009 t= 0.2884000000000009 t= 0.28860000000000086 t= 0.28880000000000083 t= 0.2890000000000008 t= 0.2892000000000008 t= 0.28940000000000077 t= 0.28960000000000075 t= 0.2898000000000007 t= 0.2900000000000007 t= 0.2902000000000007 t= 0.29040000000000066 t= 0.29060000000000064 t= 0.2908000000000006 t= 0.2910000000000006 t= 0.29120000000000057 t= 0.29140000000000055 t= 0.2916000000000005 t= 0.2918000000000005 t= 0.2920000000000005 t= 0.29220000000000046 t= 0.29240000000000044 t= 0.2926000000000004 t= 0.2928000000000004 t= 0.29300000000000037 t= 0.29320000000000035 t= 0.2934000000000003 t= 0.2936000000000003 t= 0.2938000000000003 t= 0.29400000000000026 t= 0.29420000000000024 t= 0.2944000000000002 t= 0.2946000000000002 t= 0.2948000000000002 t= 0.29500000000000015 t= 0.29520000000000013 t= 0.2954000000000001 t= 0.2956000000000001 t= 0.29580000000000006 t= 0.29600000000000004 t= 0.2962 t= 0.2964 t= 0.2966 t= 0.29679999999999995 t= 0.29699999999999993 t= 0.2971999999999999 t= 0.2973999999999999 t= 0.29759999999999986 t= 0.29779999999999984 t= 0.2979999999999998 t= 0.2981999999999998 t= 0.2983999999999998 t= 0.29859999999999975 t= 0.29879999999999973 t= 0.2989999999999997 t= 0.2991999999999997 t= 0.29939999999999967 t= 0.29959999999999964 t= 0.2997999999999996 t= 0.2999999999999996 t= 0.3001999999999996 t= 0.30039999999999956 t= 0.30059999999999953 t= 0.3007999999999995 t= 0.3009999999999995 t= 0.30119999999999947 t= 0.30139999999999945 t= 0.3015999999999994 t= 0.3017999999999994 t= 0.3019999999999994 t= 0.30219999999999936 t= 0.30239999999999934 t= 0.3025999999999993 t= 0.3027999999999993 t= 0.30299999999999927 t= 0.30319999999999925 t= 0.3033999999999992 t= 0.3035999999999992 t= 0.3037999999999992 t= 0.30399999999999916 t= 0.30419999999999914 t= 0.3043999999999991 t= 0.3045999999999991 t= 0.30479999999999907 t= 0.30499999999999905 t= 0.305199999999999 t= 0.305399999999999 t= 0.305599999999999 t= 0.30579999999999896 t= 0.30599999999999894 t= 0.3061999999999989 t= 0.3063999999999989 t= 0.3065999999999989 t= 0.30679999999999885 t= 0.30699999999999883 t= 0.3071999999999988 t= 0.3073999999999988 t= 0.30759999999999876 t= 0.30779999999999874 t= 0.3079999999999987 t= 0.3081999999999987 t= 0.3083999999999987 t= 0.30859999999999865 t= 0.30879999999999863 t= 0.3089999999999986 t= 0.3091999999999986 t= 0.30939999999999857 t= 0.30959999999999854 t= 0.3097999999999985 t= 0.3099999999999985 t= 0.3101999999999985 t= 0.31039999999999845 t= 0.31059999999999843 t= 0.3107999999999984 t= 0.3109999999999984 t= 0.31119999999999837 t= 0.31139999999999834 t= 0.3115999999999983 t= 0.3117999999999983 t= 0.3119999999999983 t= 0.31219999999999826 t= 0.31239999999999823 t= 0.3125999999999982 t= 0.3127999999999982 t= 0.31299999999999817 t= 0.31319999999999815 t= 0.3133999999999981 t= 0.3135999999999981 t= 0.3137999999999981 t= 0.31399999999999806 t= 0.31419999999999804 t= 0.314399999999998 t= 0.314599999999998 t= 0.31479999999999797 t= 0.31499999999999795 t= 0.3151999999999979 t= 0.3153999999999979 t= 0.3155999999999979 t= 0.31579999999999786 t= 0.31599999999999784 t= 0.3161999999999978 t= 0.3163999999999978 t= 0.31659999999999777 t= 0.31679999999999775 t= 0.31699999999999773 t= 0.3171999999999977 t= 0.3173999999999977 t= 0.31759999999999766 t= 0.31779999999999764 t= 0.3179999999999976 t= 0.3181999999999976 t= 0.3183999999999976 t= 0.31859999999999755 t= 0.31879999999999753 t= 0.3189999999999975 t= 0.3191999999999975 t= 0.31939999999999746 t= 0.31959999999999744 t= 0.3197999999999974 t= 0.3199999999999974 t= 0.3201999999999974 t= 0.32039999999999735 t= 0.32059999999999733 t= 0.3207999999999973 t= 0.3209999999999973 t= 0.32119999999999727 t= 0.32139999999999724 t= 0.3215999999999972 t= 0.3217999999999972 t= 0.3219999999999972 t= 0.32219999999999716 t= 0.32239999999999713 t= 0.3225999999999971 t= 0.3227999999999971 t= 0.32299999999999707 t= 0.32319999999999705 t= 0.323399999999997 t= 0.323599999999997 t= 0.323799999999997 t= 0.32399999999999696 t= 0.32419999999999694 t= 0.3243999999999969 t= 0.3245999999999969 t= 0.32479999999999687 t= 0.32499999999999685 t= 0.3251999999999968 t= 0.3253999999999968 t= 0.3255999999999968 t= 0.32579999999999676 t= 0.32599999999999674 t= 0.3261999999999967 t= 0.3263999999999967 t= 0.32659999999999667 t= 0.32679999999999665 t= 0.3269999999999966 t= 0.3271999999999966 t= 0.3273999999999966 t= 0.32759999999999656 t= 0.32779999999999654 t= 0.3279999999999965 t= 0.3281999999999965 t= 0.3283999999999965 t= 0.32859999999999645 t= 0.32879999999999643 t= 0.3289999999999964 t= 0.3291999999999964 t= 0.32939999999999636 t= 0.32959999999999634 t= 0.3297999999999963 t= 0.3299999999999963 t= 0.3301999999999963 t= 0.33039999999999625 t= 0.33059999999999623 t= 0.3307999999999962 t= 0.3309999999999962 t= 0.33119999999999616 t= 0.33139999999999614 t= 0.3315999999999961 t= 0.3317999999999961 t= 0.3319999999999961 t= 0.33219999999999605 t= 0.33239999999999603 t= 0.332599999999996 t= 0.332799999999996 t= 0.33299999999999597 t= 0.33319999999999594 t= 0.3333999999999959 t= 0.3335999999999959 t= 0.3337999999999959 t= 0.33399999999999586 t= 0.33419999999999583 t= 0.3343999999999958 t= 0.3345999999999958 t= 0.33479999999999577 t= 0.33499999999999575 t= 0.3351999999999957 t= 0.3353999999999957 t= 0.3355999999999957 t= 0.33579999999999566 t= 0.33599999999999564 t= 0.3361999999999956 t= 0.3363999999999956 t= 0.33659999999999557 t= 0.33679999999999555 t= 0.3369999999999955 t= 0.3371999999999955 t= 0.3373999999999955 t= 0.33759999999999546 t= 0.33779999999999544 t= 0.3379999999999954 t= 0.3381999999999954 t= 0.33839999999999537 t= 0.33859999999999535 t= 0.3387999999999953 t= 0.3389999999999953 t= 0.3391999999999953 t= 0.33939999999999526 t= 0.33959999999999524 t= 0.3397999999999952 t= 0.3399999999999952 t= 0.3401999999999952 t= 0.34039999999999515 t= 0.34059999999999513 t= 0.3407999999999951 t= 0.3409999999999951 t= 0.34119999999999506 t= 0.34139999999999504 t= 0.341599999999995 t= 0.341799999999995 t= 0.341999999999995 t= 0.34219999999999495 t= 0.34239999999999493 t= 0.3425999999999949 t= 0.3427999999999949 t= 0.34299999999999486 t= 0.34319999999999484 t= 0.3433999999999948 t= 0.3435999999999948 t= 0.3437999999999948 t= 0.34399999999999475 t= 0.34419999999999473 t= 0.3443999999999947 t= 0.3445999999999947 t= 0.34479999999999467 t= 0.34499999999999464 t= 0.3451999999999946 t= 0.3453999999999946 t= 0.3455999999999946 t= 0.34579999999999456 t= 0.34599999999999453 t= 0.3461999999999945 t= 0.3463999999999945 t= 0.34659999999999447 t= 0.34679999999999445 t= 0.3469999999999944 t= 0.3471999999999944 t= 0.3473999999999944 t= 0.34759999999999436 t= 0.34779999999999434 t= 0.3479999999999943 t= 0.3481999999999943 t= 0.34839999999999427 t= 0.34859999999999425 t= 0.3487999999999942 t= 0.3489999999999942 t= 0.3491999999999942 t= 0.34939999999999416 t= 0.34959999999999414 t= 0.3497999999999941 t= 0.3499999999999941 t= 0.35019999999999407 t= 0.35039999999999405 t= 0.350599999999994 t= 0.350799999999994 t= 0.350999999999994 t= 0.35119999999999396 t= 0.35139999999999394 t= 0.3515999999999939 t= 0.3517999999999939 t= 0.3519999999999939 t= 0.35219999999999385 t= 0.35239999999999383 t= 0.3525999999999938 t= 0.3527999999999938 t= 0.35299999999999376 t= 0.35319999999999374 t= 0.3533999999999937 t= 0.3535999999999937 t= 0.3537999999999937 t= 0.35399999999999365 t= 0.35419999999999363 t= 0.3543999999999936 t= 0.3545999999999936 t= 0.35479999999999356 t= 0.35499999999999354 t= 0.3551999999999935 t= 0.3553999999999935 t= 0.3555999999999935 t= 0.35579999999999345 t= 0.35599999999999343 t= 0.3561999999999934 t= 0.3563999999999934 t= 0.35659999999999337 t= 0.35679999999999334 t= 0.3569999999999933 t= 0.3571999999999933 t= 0.3573999999999933 t= 0.35759999999999326 t= 0.35779999999999323 t= 0.3579999999999932 t= 0.3581999999999932 t= 0.35839999999999317 t= 0.35859999999999315 t= 0.3587999999999931 t= 0.3589999999999931 t= 0.3591999999999931 t= 0.35939999999999306 t= 0.35959999999999304 t= 0.359799999999993 t= 0.359999999999993 t= 0.36019999999999297 t= 0.36039999999999295 t= 0.3605999999999929 t= 0.3607999999999929 t= 0.3609999999999929 t= 0.36119999999999286 t= 0.36139999999999284 t= 0.3615999999999928 t= 0.3617999999999928 t= 0.36199999999999277 t= 0.36219999999999275 t= 0.36239999999999273 t= 0.3625999999999927 t= 0.3627999999999927 t= 0.36299999999999266 t= 0.36319999999999264 t= 0.3633999999999926 t= 0.3635999999999926 t= 0.3637999999999926 t= 0.36399999999999255 t= 0.36419999999999253 t= 0.3643999999999925 t= 0.3645999999999925 t= 0.36479999999999246 t= 0.36499999999999244 t= 0.3651999999999924 t= 0.3653999999999924 t= 0.3655999999999924 t= 0.36579999999999235 t= 0.36599999999999233 t= 0.3661999999999923 t= 0.3663999999999923 t= 0.36659999999999227 t= 0.36679999999999224 t= 0.3669999999999922 t= 0.3671999999999922 t= 0.3673999999999922 t= 0.36759999999999216 t= 0.36779999999999213 t= 0.3679999999999921 t= 0.3681999999999921 t= 0.36839999999999207 t= 0.36859999999999205 t= 0.368799999999992 t= 0.368999999999992 t= 0.369199999999992 t= 0.36939999999999196 t= 0.36959999999999193 t= 0.3697999999999919 t= 0.3699999999999919 t= 0.37019999999999187 t= 0.37039999999999185 t= 0.3705999999999918 t= 0.3707999999999918 t= 0.3709999999999918 t= 0.37119999999999176 t= 0.37139999999999174 t= 0.3715999999999917 t= 0.3717999999999917 t= 0.37199999999999167 t= 0.37219999999999165 t= 0.3723999999999916 t= 0.3725999999999916 t= 0.3727999999999916 t= 0.37299999999999156 t= 0.37319999999999154 t= 0.3733999999999915 t= 0.3735999999999915 t= 0.3737999999999915 t= 0.37399999999999145 t= 0.37419999999999143 t= 0.3743999999999914 t= 0.3745999999999914 t= 0.37479999999999136 t= 0.37499999999999134 t= 0.3751999999999913 t= 0.3753999999999913 t= 0.3755999999999913 t= 0.37579999999999125 t= 0.37599999999999123 t= 0.3761999999999912 t= 0.3763999999999912 t= 0.37659999999999116 t= 0.37679999999999114 t= 0.3769999999999911 t= 0.3771999999999911 t= 0.3773999999999911 t= 0.37759999999999105 t= 0.37779999999999103 t= 0.377999999999991 t= 0.378199999999991 t= 0.37839999999999097 t= 0.37859999999999094 t= 0.3787999999999909 t= 0.3789999999999909 t= 0.3791999999999909 t= 0.37939999999999086 t= 0.37959999999999083 t= 0.3797999999999908 t= 0.3799999999999908 t= 0.38019999999999077 t= 0.38039999999999075 t= 0.3805999999999907 t= 0.3807999999999907 t= 0.3809999999999907 t= 0.38119999999999066 t= 0.38139999999999064 t= 0.3815999999999906 t= 0.3817999999999906 t= 0.38199999999999057 t= 0.38219999999999055 t= 0.3823999999999905 t= 0.3825999999999905 t= 0.3827999999999905 t= 0.38299999999999046 t= 0.38319999999999044 t= 0.3833999999999904 t= 0.3835999999999904 t= 0.38379999999999037 t= 0.38399999999999035 t= 0.3841999999999903 t= 0.3843999999999903 t= 0.3845999999999903 t= 0.38479999999999026 t= 0.38499999999999024 t= 0.3851999999999902 t= 0.3853999999999902 t= 0.3855999999999902 t= 0.38579999999999015 t= 0.38599999999999013 t= 0.3861999999999901 t= 0.3863999999999901 t= 0.38659999999999006 t= 0.38679999999999004 t= 0.38699999999999 t= 0.38719999999999 t= 0.38739999999999 t= 0.38759999999998995 t= 0.38779999999998993 t= 0.3879999999999899 t= 0.3881999999999899 t= 0.38839999999998986 t= 0.38859999999998984 t= 0.3887999999999898 t= 0.3889999999999898 t= 0.3891999999999898 t= 0.38939999999998975 t= 0.38959999999998973 t= 0.3897999999999897 t= 0.3899999999999897 t= 0.39019999999998967 t= 0.39039999999998964 t= 0.3905999999999896 t= 0.3907999999999896 t= 0.3909999999999896 t= 0.39119999999998956 t= 0.39139999999998953 t= 0.3915999999999895 t= 0.3917999999999895 t= 0.39199999999998947 t= 0.39219999999998945 t= 0.3923999999999894 t= 0.3925999999999894 t= 0.3927999999999894 t= 0.39299999999998936 t= 0.39319999999998934 t= 0.3933999999999893 t= 0.3935999999999893 t= 0.39379999999998927 t= 0.39399999999998925 t= 0.3941999999999892 t= 0.3943999999999892 t= 0.3945999999999892 t= 0.39479999999998916 t= 0.39499999999998914 t= 0.3951999999999891 t= 0.3953999999999891 t= 0.39559999999998907 t= 0.39579999999998905 t= 0.395999999999989 t= 0.396199999999989 t= 0.396399999999989 t= 0.39659999999998896 t= 0.39679999999998894 t= 0.3969999999999889 t= 0.3971999999999889 t= 0.3973999999999889 t= 0.39759999999998885 t= 0.39779999999998883 t= 0.3979999999999888 t= 0.3981999999999888 t= 0.39839999999998876 t= 0.39859999999998874 t= 0.3987999999999887 t= 0.3989999999999887 t= 0.3991999999999887 t= 0.39939999999998865 t= 0.39959999999998863 t= 0.3997999999999886 t= 0.3999999999999886 t= 0.40019999999998856 t= 0.40039999999998854 t= 0.4005999999999885 t= 0.4007999999999885 t= 0.4009999999999885 t= 0.40119999999998845 t= 0.40139999999998843 t= 0.4015999999999884 t= 0.4017999999999884 t= 0.40199999999998837 t= 0.40219999999998834 t= 0.4023999999999883 t= 0.4025999999999883 t= 0.4027999999999883 t= 0.40299999999998826 t= 0.40319999999998823 t= 0.4033999999999882 t= 0.4035999999999882 t= 0.40379999999998817 t= 0.40399999999998815 t= 0.4041999999999881 t= 0.4043999999999881 t= 0.4045999999999881 t= 0.40479999999998806 t= 0.40499999999998804 t= 0.405199999999988 t= 0.405399999999988 t= 0.40559999999998797 t= 0.40579999999998795 t= 0.4059999999999879 t= 0.4061999999999879 t= 0.4063999999999879 t= 0.40659999999998786 t= 0.40679999999998784 t= 0.4069999999999878 t= 0.4071999999999878 t= 0.40739999999998777 t= 0.40759999999998775 t= 0.40779999999998773 t= 0.4079999999999877 t= 0.4081999999999877 t= 0.40839999999998766 t= 0.40859999999998764 t= 0.4087999999999876 t= 0.4089999999999876 t= 0.4091999999999876 t= 0.40939999999998755 t= 0.40959999999998753 t= 0.4097999999999875 t= 0.4099999999999875 t= 0.41019999999998746 t= 0.41039999999998744 t= 0.4105999999999874 t= 0.4107999999999874 t= 0.4109999999999874 t= 0.41119999999998735 t= 0.41139999999998733 t= 0.4115999999999873 t= 0.4117999999999873 t= 0.41199999999998727 t= 0.41219999999998724 t= 0.4123999999999872 t= 0.4125999999999872 t= 0.4127999999999872 t= 0.41299999999998716 t= 0.41319999999998713 t= 0.4133999999999871 t= 0.4135999999999871 t= 0.41379999999998707 t= 0.41399999999998705 t= 0.414199999999987 t= 0.414399999999987 t= 0.414599999999987 t= 0.41479999999998696 t= 0.41499999999998693 t= 0.4151999999999869 t= 0.4153999999999869 t= 0.41559999999998687 t= 0.41579999999998685 t= 0.4159999999999868 t= 0.4161999999999868 t= 0.4163999999999868 t= 0.41659999999998676 t= 0.41679999999998674 t= 0.4169999999999867 t= 0.4171999999999867 t= 0.41739999999998667 t= 0.41759999999998665 t= 0.4177999999999866 t= 0.4179999999999866 t= 0.4181999999999866 t= 0.41839999999998656 t= 0.41859999999998654 t= 0.4187999999999865 t= 0.4189999999999865 t= 0.4191999999999865 t= 0.41939999999998645 t= 0.41959999999998643 t= 0.4197999999999864 t= 0.4199999999999864 t= 0.42019999999998636 t= 0.42039999999998634 t= 0.4205999999999863 t= 0.4207999999999863 t= 0.4209999999999863 t= 0.42119999999998625 t= 0.42139999999998623 t= 0.4215999999999862 t= 0.4217999999999862 t= 0.42199999999998616 t= 0.42219999999998614 t= 0.4223999999999861 t= 0.4225999999999861 t= 0.4227999999999861 t= 0.42299999999998605 t= 0.42319999999998603 t= 0.423399999999986 t= 0.423599999999986 t= 0.42379999999998597 t= 0.42399999999998594 t= 0.4241999999999859 t= 0.4243999999999859 t= 0.4245999999999859 t= 0.42479999999998586 t= 0.42499999999998583 t= 0.4251999999999858 t= 0.4253999999999858 t= 0.42559999999998577 t= 0.42579999999998575 t= 0.4259999999999857 t= 0.4261999999999857 t= 0.4263999999999857 t= 0.42659999999998566 t= 0.42679999999998564 t= 0.4269999999999856 t= 0.4271999999999856 t= 0.42739999999998557 t= 0.42759999999998555 t= 0.4277999999999855 t= 0.4279999999999855 t= 0.4281999999999855 t= 0.42839999999998546 t= 0.42859999999998544 t= 0.4287999999999854 t= 0.4289999999999854 t= 0.42919999999998537 t= 0.42939999999998535 t= 0.4295999999999853 t= 0.4297999999999853 t= 0.4299999999999853 t= 0.43019999999998526 t= 0.43039999999998524 t= 0.4305999999999852 t= 0.4307999999999852 t= 0.4309999999999852 t= 0.43119999999998515 t= 0.43139999999998513 t= 0.4315999999999851 t= 0.4317999999999851 t= 0.43199999999998506 t= 0.43219999999998504 t= 0.432399999999985 t= 0.432599999999985 t= 0.432799999999985 t= 0.43299999999998495 t= 0.43319999999998493 t= 0.4333999999999849 t= 0.4335999999999849 t= 0.43379999999998486 t= 0.43399999999998484 t= 0.4341999999999848 t= 0.4343999999999848 t= 0.4345999999999848 t= 0.43479999999998475 t= 0.43499999999998473 t= 0.4351999999999847 t= 0.4353999999999847 t= 0.43559999999998467 t= 0.43579999999998464 t= 0.4359999999999846 t= 0.4361999999999846 t= 0.4363999999999846 t= 0.43659999999998456 t= 0.43679999999998453 t= 0.4369999999999845 t= 0.4371999999999845 t= 0.43739999999998447 t= 0.43759999999998445 t= 0.4377999999999844 t= 0.4379999999999844 t= 0.4381999999999844 t= 0.43839999999998436 t= 0.43859999999998434 t= 0.4387999999999843 t= 0.4389999999999843 t= 0.43919999999998427 t= 0.43939999999998425 t= 0.4395999999999842 t= 0.4397999999999842 t= 0.4399999999999842 t= 0.44019999999998416 t= 0.44039999999998414 t= 0.4405999999999841 t= 0.4407999999999841 t= 0.44099999999998407 t= 0.44119999999998405 t= 0.441399999999984 t= 0.441599999999984 t= 0.441799999999984 t= 0.44199999999998396 t= 0.44219999999998394 t= 0.4423999999999839 t= 0.4425999999999839 t= 0.4427999999999839 t= 0.44299999999998385 t= 0.44319999999998383 t= 0.4433999999999838 t= 0.4435999999999838 t= 0.44379999999998376 t= 0.44399999999998374 t= 0.4441999999999837 t= 0.4443999999999837 t= 0.4445999999999837 t= 0.44479999999998365 t= 0.44499999999998363 t= 0.4451999999999836 t= 0.4453999999999836 t= 0.44559999999998356 t= 0.44579999999998354 t= 0.4459999999999835 t= 0.4461999999999835 t= 0.4463999999999835 t= 0.44659999999998345 t= 0.44679999999998343 t= 0.4469999999999834 t= 0.4471999999999834 t= 0.44739999999998337 t= 0.44759999999998334 t= 0.4477999999999833 t= 0.4479999999999833 t= 0.4481999999999833 t= 0.44839999999998326 t= 0.44859999999998323 t= 0.4487999999999832 t= 0.4489999999999832 t= 0.44919999999998317 t= 0.44939999999998315 t= 0.4495999999999831 t= 0.4497999999999831 t= 0.4499999999999831 t= 0.45019999999998306 t= 0.45039999999998304 t= 0.450599999999983 t= 0.450799999999983 t= 0.45099999999998297 t= 0.45119999999998295 t= 0.4513999999999829 t= 0.4515999999999829 t= 0.4517999999999829 t= 0.45199999999998286 t= 0.45219999999998284 t= 0.4523999999999828 t= 0.4525999999999828 t= 0.45279999999998277 t= 0.45299999999998275 t= 0.45319999999998273 t= 0.4533999999999827 t= 0.4535999999999827 t= 0.45379999999998266 t= 0.45399999999998264 t= 0.4541999999999826 t= 0.4543999999999826 t= 0.4545999999999826 t= 0.45479999999998255 t= 0.45499999999998253 t= 0.4551999999999825 t= 0.4553999999999825 t= 0.45559999999998246 t= 0.45579999999998244 t= 0.4559999999999824 t= 0.4561999999999824 t= 0.4563999999999824 t= 0.45659999999998235 t= 0.45679999999998233 t= 0.4569999999999823 t= 0.4571999999999823 t= 0.45739999999998227 t= 0.45759999999998224 t= 0.4577999999999822 t= 0.4579999999999822 t= 0.4581999999999822 t= 0.45839999999998216 t= 0.45859999999998213 t= 0.4587999999999821 t= 0.4589999999999821 t= 0.45919999999998207 t= 0.45939999999998204 t= 0.459599999999982 t= 0.459799999999982 t= 0.459999999999982 t= 0.46019999999998196 t= 0.46039999999998193 t= 0.4605999999999819 t= 0.4607999999999819 t= 0.46099999999998187 t= 0.46119999999998185 t= 0.4613999999999818 t= 0.4615999999999818 t= 0.4617999999999818 t= 0.46199999999998176 t= 0.46219999999998174 t= 0.4623999999999817 t= 0.4625999999999817 t= 0.46279999999998167 t= 0.46299999999998165 t= 0.4631999999999816 t= 0.4633999999999816 t= 0.4635999999999816 t= 0.46379999999998156 t= 0.46399999999998154 t= 0.4641999999999815 t= 0.4643999999999815 t= 0.46459999999998147 t= 0.46479999999998145 t= 0.46499999999998143 t= 0.4651999999999814 t= 0.4653999999999814 t= 0.46559999999998136 t= 0.46579999999998134 t= 0.4659999999999813 t= 0.4661999999999813 t= 0.4663999999999813 t= 0.46659999999998125 t= 0.46679999999998123 t= 0.4669999999999812 t= 0.4671999999999812 t= 0.46739999999998116 t= 0.46759999999998114 t= 0.4677999999999811 t= 0.4679999999999811 t= 0.4681999999999811 t= 0.46839999999998105 t= 0.46859999999998103 t= 0.468799999999981 t= 0.468999999999981 t= 0.46919999999998097 t= 0.46939999999998094 t= 0.4695999999999809 t= 0.4697999999999809 t= 0.4699999999999809 t= 0.47019999999998086 t= 0.47039999999998083 t= 0.4705999999999808 t= 0.4707999999999808 t= 0.47099999999998077 t= 0.47119999999998075 t= 0.4713999999999807 t= 0.4715999999999807 t= 0.4717999999999807 t= 0.47199999999998066 t= 0.47219999999998064 t= 0.4723999999999806 t= 0.4725999999999806 t= 0.47279999999998057 t= 0.47299999999998055 t= 0.4731999999999805 t= 0.4733999999999805 t= 0.4735999999999805 t= 0.47379999999998046 t= 0.47399999999998044 t= 0.4741999999999804 t= 0.4743999999999804 t= 0.47459999999998037 t= 0.47479999999998035 t= 0.4749999999999803 t= 0.4751999999999803 t= 0.4753999999999803 t= 0.47559999999998026 t= 0.47579999999998024 t= 0.4759999999999802 t= 0.4761999999999802 t= 0.4763999999999802 t= 0.47659999999998015 t= 0.47679999999998013 t= 0.4769999999999801 t= 0.4771999999999801 t= 0.47739999999998006 t= 0.47759999999998004 t= 0.47779999999998 t= 0.47799999999998 t= 0.47819999999998 t= 0.47839999999997995 t= 0.47859999999997993 t= 0.4787999999999799 t= 0.4789999999999799 t= 0.47919999999997986 t= 0.47939999999997984 t= 0.4795999999999798 t= 0.4797999999999798 t= 0.4799999999999798 t= 0.48019999999997975 t= 0.48039999999997973 t= 0.4805999999999797 t= 0.4807999999999797 t= 0.48099999999997967 t= 0.48119999999997964 t= 0.4813999999999796 t= 0.4815999999999796 t= 0.4817999999999796 t= 0.48199999999997956 t= 0.48219999999997953 t= 0.4823999999999795 t= 0.4825999999999795 t= 0.48279999999997947 t= 0.48299999999997945 t= 0.4831999999999794 t= 0.4833999999999794 t= 0.4835999999999794 t= 0.48379999999997936 t= 0.48399999999997934 t= 0.4841999999999793 t= 0.4843999999999793 t= 0.48459999999997927 t= 0.48479999999997925 t= 0.4849999999999792 t= 0.4851999999999792 t= 0.4853999999999792 t= 0.48559999999997916 t= 0.48579999999997914 t= 0.4859999999999791 t= 0.4861999999999791 t= 0.48639999999997907 t= 0.48659999999997905 t= 0.486799999999979 t= 0.486999999999979 t= 0.487199999999979 t= 0.48739999999997896 t= 0.48759999999997894 t= 0.4877999999999789 t= 0.4879999999999789 t= 0.4881999999999789 t= 0.48839999999997885 t= 0.48859999999997883 t= 0.4887999999999788 t= 0.4889999999999788 t= 0.48919999999997876 t= 0.48939999999997874 t= 0.4895999999999787 t= 0.4897999999999787 t= 0.4899999999999787 t= 0.49019999999997865 t= 0.49039999999997863 t= 0.4905999999999786 t= 0.4907999999999786 t= 0.49099999999997856 t= 0.49119999999997854 t= 0.4913999999999785 t= 0.4915999999999785 t= 0.4917999999999785 t= 0.49199999999997845 t= 0.49219999999997843 t= 0.4923999999999784 t= 0.4925999999999784 t= 0.49279999999997837 t= 0.49299999999997834 t= 0.4931999999999783 t= 0.4933999999999783 t= 0.4935999999999783 t= 0.49379999999997826 t= 0.49399999999997823 t= 0.4941999999999782 t= 0.4943999999999782 t= 0.49459999999997817 t= 0.49479999999997815 t= 0.4949999999999781 t= 0.4951999999999781 t= 0.4953999999999781 t= 0.49559999999997806 t= 0.49579999999997804 t= 0.495999999999978 t= 0.496199999999978 t= 0.49639999999997797 t= 0.49659999999997795 t= 0.4967999999999779 t= 0.4969999999999779 t= 0.4971999999999779 t= 0.49739999999997786 t= 0.49759999999997784 t= 0.4977999999999778 t= 0.4979999999999778 t= 0.49819999999997777 t= 0.49839999999997775 t= 0.4985999999999777 t= 0.4987999999999777 t= 0.4989999999999777 t= 0.49919999999997766 t= 0.49939999999997764 t= 0.4995999999999776 t= 0.4997999999999776 t= 0.4999999999999776 t= 0.5001999999999776 t= 0.5003999999999775 t= 0.5005999999999775 t= 0.5007999999999775 t= 0.5009999999999775 t= 0.5011999999999774 t= 0.5013999999999774 t= 0.5015999999999774 t= 0.5017999999999774 t= 0.5019999999999774 t= 0.5021999999999773 t= 0.5023999999999773 t= 0.5025999999999773 t= 0.5027999999999773 t= 0.5029999999999772 t= 0.5031999999999772 t= 0.5033999999999772 t= 0.5035999999999772 t= 0.5037999999999772 t= 0.5039999999999771 t= 0.5041999999999771 t= 0.5043999999999771 t= 0.5045999999999771 t= 0.504799999999977 t= 0.504999999999977 t= 0.505199999999977 t= 0.505399999999977 t= 0.505599999999977 t= 0.5057999999999769 t= 0.5059999999999769 t= 0.5061999999999769 t= 0.5063999999999769 t= 0.5065999999999768 t= 0.5067999999999768 t= 0.5069999999999768 t= 0.5071999999999768 t= 0.5073999999999768 t= 0.5075999999999767 t= 0.5077999999999767 t= 0.5079999999999767 t= 0.5081999999999767 t= 0.5083999999999766 t= 0.5085999999999766 t= 0.5087999999999766 t= 0.5089999999999766 t= 0.5091999999999766 t= 0.5093999999999765 t= 0.5095999999999765 t= 0.5097999999999765 t= 0.5099999999999765 t= 0.5101999999999765 t= 0.5103999999999764 t= 0.5105999999999764 t= 0.5107999999999764 t= 0.5109999999999764 t= 0.5111999999999763 t= 0.5113999999999763 t= 0.5115999999999763 t= 0.5117999999999763 t= 0.5119999999999763 t= 0.5121999999999762 t= 0.5123999999999762 t= 0.5125999999999762 t= 0.5127999999999762 t= 0.5129999999999761 t= 0.5131999999999761 t= 0.5133999999999761 t= 0.5135999999999761 t= 0.513799999999976 t= 0.513999999999976 t= 0.514199999999976 t= 0.514399999999976 t= 0.514599999999976 t= 0.5147999999999759 t= 0.5149999999999759 t= 0.5151999999999759 t= 0.5153999999999759 t= 0.5155999999999759 t= 0.5157999999999758 t= 0.5159999999999758 t= 0.5161999999999758 t= 0.5163999999999758 t= 0.5165999999999757 t= 0.5167999999999757 t= 0.5169999999999757 t= 0.5171999999999757 t= 0.5173999999999757 t= 0.5175999999999756 t= 0.5177999999999756 t= 0.5179999999999756 t= 0.5181999999999756 t= 0.5183999999999755 t= 0.5185999999999755 t= 0.5187999999999755 t= 0.5189999999999755 t= 0.5191999999999755 t= 0.5193999999999754 t= 0.5195999999999754 t= 0.5197999999999754 t= 0.5199999999999754 t= 0.5201999999999753 t= 0.5203999999999753 t= 0.5205999999999753 t= 0.5207999999999753 t= 0.5209999999999753 t= 0.5211999999999752 t= 0.5213999999999752 t= 0.5215999999999752 t= 0.5217999999999752 t= 0.5219999999999752 t= 0.5221999999999751 t= 0.5223999999999751 t= 0.5225999999999751 t= 0.5227999999999751 t= 0.522999999999975 t= 0.523199999999975 t= 0.523399999999975 t= 0.523599999999975 t= 0.523799999999975 t= 0.5239999999999749 t= 0.5241999999999749 t= 0.5243999999999749 t= 0.5245999999999749 t= 0.5247999999999748 t= 0.5249999999999748 t= 0.5251999999999748 t= 0.5253999999999748 t= 0.5255999999999748 t= 0.5257999999999747 t= 0.5259999999999747 t= 0.5261999999999747 t= 0.5263999999999747 t= 0.5265999999999746 t= 0.5267999999999746 t= 0.5269999999999746 t= 0.5271999999999746 t= 0.5273999999999746 t= 0.5275999999999745 t= 0.5277999999999745 t= 0.5279999999999745 t= 0.5281999999999745 t= 0.5283999999999744 t= 0.5285999999999744 t= 0.5287999999999744 t= 0.5289999999999744 t= 0.5291999999999744 t= 0.5293999999999743 t= 0.5295999999999743 t= 0.5297999999999743 t= 0.5299999999999743 t= 0.5301999999999742 t= 0.5303999999999742 t= 0.5305999999999742 t= 0.5307999999999742 t= 0.5309999999999742 t= 0.5311999999999741 t= 0.5313999999999741 t= 0.5315999999999741 t= 0.5317999999999741 t= 0.531999999999974 t= 0.532199999999974 t= 0.532399999999974 t= 0.532599999999974 t= 0.532799999999974 t= 0.5329999999999739 t= 0.5331999999999739 t= 0.5333999999999739 t= 0.5335999999999739 t= 0.5337999999999739 t= 0.5339999999999738 t= 0.5341999999999738 t= 0.5343999999999738 t= 0.5345999999999738 t= 0.5347999999999737 t= 0.5349999999999737 t= 0.5351999999999737 t= 0.5353999999999737 t= 0.5355999999999737 t= 0.5357999999999736 t= 0.5359999999999736 t= 0.5361999999999736 t= 0.5363999999999736 t= 0.5365999999999735 t= 0.5367999999999735 t= 0.5369999999999735 t= 0.5371999999999735 t= 0.5373999999999735 t= 0.5375999999999734 t= 0.5377999999999734 t= 0.5379999999999734 t= 0.5381999999999734 t= 0.5383999999999733 t= 0.5385999999999733 t= 0.5387999999999733 t= 0.5389999999999733 t= 0.5391999999999733 t= 0.5393999999999732 t= 0.5395999999999732 t= 0.5397999999999732 t= 0.5399999999999732 t= 0.5401999999999731 t= 0.5403999999999731 t= 0.5405999999999731 t= 0.5407999999999731 t= 0.5409999999999731 t= 0.541199999999973 t= 0.541399999999973 t= 0.541599999999973 t= 0.541799999999973 t= 0.541999999999973 t= 0.5421999999999729 t= 0.5423999999999729 t= 0.5425999999999729 t= 0.5427999999999729 t= 0.5429999999999728 t= 0.5431999999999728 t= 0.5433999999999728 t= 0.5435999999999728 t= 0.5437999999999727 t= 0.5439999999999727 t= 0.5441999999999727 t= 0.5443999999999727 t= 0.5445999999999727 t= 0.5447999999999726 t= 0.5449999999999726 t= 0.5451999999999726 t= 0.5453999999999726 t= 0.5455999999999726 t= 0.5457999999999725 t= 0.5459999999999725 t= 0.5461999999999725 t= 0.5463999999999725 t= 0.5465999999999724 t= 0.5467999999999724 t= 0.5469999999999724 t= 0.5471999999999724 t= 0.5473999999999724 t= 0.5475999999999723 t= 0.5477999999999723 t= 0.5479999999999723 t= 0.5481999999999723 t= 0.5483999999999722 t= 0.5485999999999722 t= 0.5487999999999722 t= 0.5489999999999722 t= 0.5491999999999722 t= 0.5493999999999721 t= 0.5495999999999721 t= 0.5497999999999721 t= 0.5499999999999721 t= 0.550199999999972 t= 0.550399999999972 t= 0.550599999999972 t= 0.550799999999972 t= 0.550999999999972 t= 0.5511999999999719 t= 0.5513999999999719 t= 0.5515999999999719 t= 0.5517999999999719 t= 0.5519999999999718 t= 0.5521999999999718 t= 0.5523999999999718 t= 0.5525999999999718 t= 0.5527999999999718 t= 0.5529999999999717 t= 0.5531999999999717 t= 0.5533999999999717 t= 0.5535999999999717 t= 0.5537999999999716 t= 0.5539999999999716 t= 0.5541999999999716 t= 0.5543999999999716 t= 0.5545999999999716 t= 0.5547999999999715 t= 0.5549999999999715 t= 0.5551999999999715 t= 0.5553999999999715 t= 0.5555999999999715 t= 0.5557999999999714 t= 0.5559999999999714 t= 0.5561999999999714 t= 0.5563999999999714 t= 0.5565999999999713 t= 0.5567999999999713 t= 0.5569999999999713 t= 0.5571999999999713 t= 0.5573999999999713 t= 0.5575999999999712 t= 0.5577999999999712 t= 0.5579999999999712 t= 0.5581999999999712 t= 0.5583999999999711 t= 0.5585999999999711 t= 0.5587999999999711 t= 0.5589999999999711 t= 0.559199999999971 t= 0.559399999999971 t= 0.559599999999971 t= 0.559799999999971 t= 0.559999999999971 t= 0.5601999999999709 t= 0.5603999999999709 t= 0.5605999999999709 t= 0.5607999999999709 t= 0.5609999999999709 t= 0.5611999999999708 t= 0.5613999999999708 t= 0.5615999999999708 t= 0.5617999999999708 t= 0.5619999999999707 t= 0.5621999999999707 t= 0.5623999999999707 t= 0.5625999999999707 t= 0.5627999999999707 t= 0.5629999999999706 t= 0.5631999999999706 t= 0.5633999999999706 t= 0.5635999999999706 t= 0.5637999999999705 t= 0.5639999999999705 t= 0.5641999999999705 t= 0.5643999999999705 t= 0.5645999999999705 t= 0.5647999999999704 t= 0.5649999999999704 t= 0.5651999999999704 t= 0.5653999999999704 t= 0.5655999999999703 t= 0.5657999999999703 t= 0.5659999999999703 t= 0.5661999999999703 t= 0.5663999999999703 t= 0.5665999999999702 t= 0.5667999999999702 t= 0.5669999999999702 t= 0.5671999999999702 t= 0.5673999999999702 t= 0.5675999999999701 t= 0.5677999999999701 t= 0.5679999999999701 t= 0.5681999999999701 t= 0.56839999999997 t= 0.56859999999997 t= 0.56879999999997 t= 0.56899999999997 t= 0.56919999999997 t= 0.5693999999999699 t= 0.5695999999999699 t= 0.5697999999999699 t= 0.5699999999999699 t= 0.5701999999999698 t= 0.5703999999999698 t= 0.5705999999999698 t= 0.5707999999999698 t= 0.5709999999999698 t= 0.5711999999999697 t= 0.5713999999999697 t= 0.5715999999999697 t= 0.5717999999999697 t= 0.5719999999999696 t= 0.5721999999999696 t= 0.5723999999999696 t= 0.5725999999999696 t= 0.5727999999999696 t= 0.5729999999999695 t= 0.5731999999999695 t= 0.5733999999999695 t= 0.5735999999999695 t= 0.5737999999999694 t= 0.5739999999999694 t= 0.5741999999999694 t= 0.5743999999999694 t= 0.5745999999999694 t= 0.5747999999999693 t= 0.5749999999999693 t= 0.5751999999999693 t= 0.5753999999999693 t= 0.5755999999999692 t= 0.5757999999999692 t= 0.5759999999999692 t= 0.5761999999999692 t= 0.5763999999999692 t= 0.5765999999999691 t= 0.5767999999999691 t= 0.5769999999999691 t= 0.5771999999999691 t= 0.577399999999969 t= 0.577599999999969 t= 0.577799999999969 t= 0.577999999999969 t= 0.578199999999969 t= 0.5783999999999689 t= 0.5785999999999689 t= 0.5787999999999689 t= 0.5789999999999689 t= 0.5791999999999689 t= 0.5793999999999688 t= 0.5795999999999688 t= 0.5797999999999688 t= 0.5799999999999688 t= 0.5801999999999687 t= 0.5803999999999687 t= 0.5805999999999687 t= 0.5807999999999687 t= 0.5809999999999687 t= 0.5811999999999686 t= 0.5813999999999686 t= 0.5815999999999686 t= 0.5817999999999686 t= 0.5819999999999685 t= 0.5821999999999685 t= 0.5823999999999685 t= 0.5825999999999685 t= 0.5827999999999685 t= 0.5829999999999684 t= 0.5831999999999684 t= 0.5833999999999684 t= 0.5835999999999684 t= 0.5837999999999683 t= 0.5839999999999683 t= 0.5841999999999683 t= 0.5843999999999683 t= 0.5845999999999683 t= 0.5847999999999682 t= 0.5849999999999682 t= 0.5851999999999682 t= 0.5853999999999682 t= 0.5855999999999681 t= 0.5857999999999681 t= 0.5859999999999681 t= 0.5861999999999681 t= 0.5863999999999681 t= 0.586599999999968 t= 0.586799999999968 t= 0.586999999999968 t= 0.587199999999968 t= 0.587399999999968 t= 0.5875999999999679 t= 0.5877999999999679 t= 0.5879999999999679 t= 0.5881999999999679 t= 0.5883999999999678 t= 0.5885999999999678 t= 0.5887999999999678 t= 0.5889999999999678 t= 0.5891999999999677 t= 0.5893999999999677 t= 0.5895999999999677 t= 0.5897999999999677 t= 0.5899999999999677 t= 0.5901999999999676 t= 0.5903999999999676 t= 0.5905999999999676 t= 0.5907999999999676 t= 0.5909999999999676 t= 0.5911999999999675 t= 0.5913999999999675 t= 0.5915999999999675 t= 0.5917999999999675 t= 0.5919999999999674 t= 0.5921999999999674 t= 0.5923999999999674 t= 0.5925999999999674 t= 0.5927999999999674 t= 0.5929999999999673 t= 0.5931999999999673 t= 0.5933999999999673 t= 0.5935999999999673 t= 0.5937999999999672 t= 0.5939999999999672 t= 0.5941999999999672 t= 0.5943999999999672 t= 0.5945999999999672 t= 0.5947999999999671 t= 0.5949999999999671 t= 0.5951999999999671 t= 0.5953999999999671 t= 0.595599999999967 t= 0.595799999999967 t= 0.595999999999967 t= 0.596199999999967 t= 0.596399999999967 t= 0.5965999999999669 t= 0.5967999999999669 t= 0.5969999999999669 t= 0.5971999999999669 t= 0.5973999999999668 t= 0.5975999999999668 t= 0.5977999999999668 t= 0.5979999999999668 t= 0.5981999999999668 t= 0.5983999999999667 t= 0.5985999999999667 t= 0.5987999999999667 t= 0.5989999999999667 t= 0.5991999999999666 t= 0.5993999999999666 t= 0.5995999999999666 t= 0.5997999999999666 t= 0.5999999999999666CPU times: user 4.55 s, sys: 40.6 ms, total: 4.59 s
Wall time: 4.55 s
#Draw(gfu_t,mesh,interpolate_multidim=True,animate=True,
# min=0, max=0.2, autoscale=False, deformation=True)
And now with the TaskManager:
[33]:
%%time
gfu_t = SolveAndVisualize(c, rhs_vec=rhs.vec)
t= 0.0002 t= 0.0004 t= 0.0006000000000000001 t= 0.0008 t= 0.001 t= 0.0012000000000000001 t= 0.0014000000000000002 t= 0.0016000000000000003 t= 0.0018000000000000004 t= 0.0020000000000000005 t= 0.0022000000000000006 t= 0.0024000000000000007 t= 0.0026000000000000007 t= 0.002800000000000001 t= 0.003000000000000001 t= 0.003200000000000001 t= 0.003400000000000001 t= 0.003600000000000001 t= 0.0038000000000000013 t= 0.004000000000000001 t= 0.004200000000000001 t= 0.0044 t= 0.0046 t= 0.0048 t= 0.004999999999999999 t= 0.005199999999999999 t= 0.0053999999999999986 t= 0.005599999999999998 t= 0.005799999999999998 t= 0.0059999999999999975 t= 0.006199999999999997 t= 0.006399999999999997 t= 0.0065999999999999965 t= 0.006799999999999996 t= 0.006999999999999996 t= 0.0071999999999999955 t= 0.007399999999999995 t= 0.007599999999999995 t= 0.0077999999999999944 t= 0.007999999999999995 t= 0.008199999999999995 t= 0.008399999999999996 t= 0.008599999999999997 t= 0.008799999999999997 t= 0.008999999999999998 t= 0.009199999999999998 t= 0.009399999999999999 t= 0.0096 t= 0.0098 t= 0.01 t= 0.0102 t= 0.010400000000000001 t= 0.010600000000000002 t= 0.010800000000000002 t= 0.011000000000000003 t= 0.011200000000000003 t= 0.011400000000000004 t= 0.011600000000000004 t= 0.011800000000000005 t= 0.012000000000000005 t= 0.012200000000000006 t= 0.012400000000000007 t= 0.012600000000000007 t= 0.012800000000000008 t= 0.013000000000000008 t= 0.013200000000000009 t= 0.013400000000000009 t= 0.01360000000000001 t= 0.01380000000000001 t= 0.01400000000000001 t= 0.014200000000000011 t= 0.014400000000000012 t= 0.014600000000000012 t= 0.014800000000000013 t= 0.015000000000000013 t= 0.015200000000000014 t= 0.015400000000000014 t= 0.015600000000000015 t= 0.015800000000000015 t= 0.016000000000000014 t= 0.016200000000000013 t= 0.016400000000000012 t= 0.01660000000000001 t= 0.01680000000000001 t= 0.017000000000000008 t= 0.017200000000000007 t= 0.017400000000000006 t= 0.017600000000000005 t= 0.017800000000000003 t= 0.018000000000000002 t= 0.0182 t= 0.0184 t= 0.0186 t= 0.018799999999999997 t= 0.018999999999999996 t= 0.019199999999999995 t= 0.019399999999999994 t= 0.019599999999999992 t= 0.01979999999999999 t= 0.01999999999999999 t= 0.02019999999999999 t= 0.020399999999999988 t= 0.020599999999999986 t= 0.020799999999999985 t= 0.020999999999999984 t= 0.021199999999999983 t= 0.02139999999999998 t= 0.02159999999999998 t= 0.02179999999999998 t= 0.021999999999999978 t= 0.022199999999999977 t= 0.022399999999999975 t= 0.022599999999999974 t= 0.022799999999999973 t= 0.022999999999999972 t= 0.02319999999999997 t= 0.02339999999999997 t= 0.023599999999999968 t= 0.023799999999999967 t= 0.023999999999999966 t= 0.024199999999999965 t= 0.024399999999999963 t= 0.024599999999999962 t= 0.02479999999999996 t= 0.02499999999999996 t= 0.02519999999999996 t= 0.025399999999999957 t= 0.025599999999999956 t= 0.025799999999999955 t= 0.025999999999999954 t= 0.026199999999999952 t= 0.02639999999999995 t= 0.02659999999999995 t= 0.02679999999999995 t= 0.026999999999999948 t= 0.027199999999999946 t= 0.027399999999999945 t= 0.027599999999999944 t= 0.027799999999999943 t= 0.02799999999999994 t= 0.02819999999999994 t= 0.02839999999999994 t= 0.028599999999999938 t= 0.028799999999999937 t= 0.028999999999999936 t= 0.029199999999999934 t= 0.029399999999999933 t= 0.029599999999999932 t= 0.02979999999999993 t= 0.02999999999999993 t= 0.03019999999999993 t= 0.030399999999999927 t= 0.030599999999999926 t= 0.030799999999999925 t= 0.030999999999999923 t= 0.031199999999999922 t= 0.03139999999999992 t= 0.03159999999999992 t= 0.03179999999999992 t= 0.03199999999999992 t= 0.032199999999999916 t= 0.032399999999999915 t= 0.032599999999999914 t= 0.03279999999999991 t= 0.03299999999999991 t= 0.03319999999999991 t= 0.03339999999999991 t= 0.03359999999999991 t= 0.033799999999999907 t= 0.033999999999999905 t= 0.034199999999999904 t= 0.0343999999999999 t= 0.0345999999999999 t= 0.0347999999999999 t= 0.0349999999999999 t= 0.0351999999999999 t= 0.0353999999999999 t= 0.035599999999999896 t= 0.035799999999999894 t= 0.03599999999999989 t= 0.03619999999999989 t= 0.03639999999999989 t= 0.03659999999999989 t= 0.03679999999999989 t= 0.03699999999999989 t= 0.037199999999999886 t= 0.037399999999999885 t= 0.037599999999999884 t= 0.03779999999999988 t= 0.03799999999999988 t= 0.03819999999999988 t= 0.03839999999999988 t= 0.03859999999999988 t= 0.038799999999999876 t= 0.038999999999999875 t= 0.039199999999999874 t= 0.03939999999999987 t= 0.03959999999999987 t= 0.03979999999999987 t= 0.03999999999999987 t= 0.04019999999999987 t= 0.04039999999999987 t= 0.040599999999999865 t= 0.040799999999999864 t= 0.04099999999999986 t= 0.04119999999999986 t= 0.04139999999999986 t= 0.04159999999999986 t= 0.04179999999999986 t= 0.04199999999999986 t= 0.042199999999999856 t= 0.042399999999999854 t= 0.04259999999999985 t= 0.04279999999999985 t= 0.04299999999999985 t= 0.04319999999999985 t= 0.04339999999999985 t= 0.04359999999999985 t= 0.043799999999999846 t= 0.043999999999999845 t= 0.044199999999999844 t= 0.04439999999999984 t= 0.04459999999999984 t= 0.04479999999999984 t= 0.04499999999999984 t= 0.04519999999999984 t= 0.045399999999999836 t= 0.045599999999999835 t= 0.045799999999999834 t= 0.04599999999999983 t= 0.04619999999999983 t= 0.04639999999999983 t= 0.04659999999999983 t= 0.04679999999999983 t= 0.04699999999999983 t= 0.047199999999999825 t= 0.047399999999999824 t= 0.04759999999999982 t= 0.04779999999999982 t= 0.04799999999999982 t= 0.04819999999999982 t= 0.04839999999999982 t= 0.04859999999999982 t= 0.048799999999999816 t= 0.048999999999999815 t= 0.04919999999999981 t= 0.04939999999999981 t= 0.04959999999999981 t= 0.04979999999999981 t= 0.04999999999999981 t= 0.05019999999999981 t= 0.050399999999999806 t= 0.050599999999999805 t= 0.050799999999999804 t= 0.0509999999999998 t= 0.0511999999999998 t= 0.0513999999999998 t= 0.0515999999999998 t= 0.0517999999999998 t= 0.051999999999999796 t= 0.052199999999999795 t= 0.052399999999999794 t= 0.05259999999999979 t= 0.05279999999999979 t= 0.05299999999999979 t= 0.05319999999999979 t= 0.05339999999999979 t= 0.05359999999999979 t= 0.053799999999999785 t= 0.053999999999999784 t= 0.05419999999999978 t= 0.05439999999999978 t= 0.05459999999999978 t= 0.05479999999999978 t= 0.05499999999999978 t= 0.05519999999999978 t= 0.055399999999999776 t= 0.055599999999999775 t= 0.05579999999999977 t= 0.05599999999999977 t= 0.05619999999999977 t= 0.05639999999999977 t= 0.05659999999999977 t= 0.05679999999999977 t= 0.056999999999999766 t= 0.057199999999999765 t= 0.057399999999999764 t= 0.05759999999999976 t= 0.05779999999999976 t= 0.05799999999999976 t= 0.05819999999999976 t= 0.05839999999999976 t= 0.058599999999999756 t= 0.058799999999999755 t= 0.058999999999999754 t= 0.05919999999999975 t= 0.05939999999999975 t= 0.05959999999999975 t= 0.05979999999999975 t= 0.05999999999999975 t= 0.06019999999999975 t= 0.060399999999999746 t= 0.060599999999999744 t= 0.06079999999999974 t= 0.06099999999999974 t= 0.06119999999999974 t= 0.06139999999999974 t= 0.06159999999999974 t= 0.06179999999999974 t= 0.061999999999999736 t= 0.062199999999999735 t= 0.06239999999999973 t= 0.06259999999999974 t= 0.06279999999999974 t= 0.06299999999999975 t= 0.06319999999999976 t= 0.06339999999999976 t= 0.06359999999999977 t= 0.06379999999999977 t= 0.06399999999999978 t= 0.06419999999999979 t= 0.06439999999999979 t= 0.0645999999999998 t= 0.0647999999999998 t= 0.06499999999999981 t= 0.06519999999999981 t= 0.06539999999999982 t= 0.06559999999999983 t= 0.06579999999999983 t= 0.06599999999999984 t= 0.06619999999999984 t= 0.06639999999999985 t= 0.06659999999999985 t= 0.06679999999999986 t= 0.06699999999999987 t= 0.06719999999999987 t= 0.06739999999999988 t= 0.06759999999999988 t= 0.06779999999999989 t= 0.0679999999999999 t= 0.0681999999999999 t= 0.0683999999999999 t= 0.06859999999999991 t= 0.06879999999999992 t= 0.06899999999999992 t= 0.06919999999999993 t= 0.06939999999999993 t= 0.06959999999999994 t= 0.06979999999999995 t= 0.06999999999999995 t= 0.07019999999999996 t= 0.07039999999999996 t= 0.07059999999999997 t= 0.07079999999999997 t= 0.07099999999999998 t= 0.07119999999999999 t= 0.07139999999999999 t= 0.0716 t= 0.0718 t= 0.07200000000000001 t= 0.07220000000000001 t= 0.07240000000000002 t= 0.07260000000000003 t= 0.07280000000000003 t= 0.07300000000000004 t= 0.07320000000000004 t= 0.07340000000000005 t= 0.07360000000000005 t= 0.07380000000000006 t= 0.07400000000000007 t= 0.07420000000000007 t= 0.07440000000000008 t= 0.07460000000000008 t= 0.07480000000000009 t= 0.0750000000000001 t= 0.0752000000000001 t= 0.0754000000000001 t= 0.07560000000000011 t= 0.07580000000000012 t= 0.07600000000000012 t= 0.07620000000000013 t= 0.07640000000000013 t= 0.07660000000000014 t= 0.07680000000000015 t= 0.07700000000000015 t= 0.07720000000000016 t= 0.07740000000000016 t= 0.07760000000000017 t= 0.07780000000000017 t= 0.07800000000000018 t= 0.07820000000000019 t= 0.07840000000000019 t= 0.0786000000000002 t= 0.0788000000000002 t= 0.07900000000000021 t= 0.07920000000000021 t= 0.07940000000000022 t= 0.07960000000000023 t= 0.07980000000000023 t= 0.08000000000000024 t= 0.08020000000000024 t= 0.08040000000000025 t= 0.08060000000000025 t= 0.08080000000000026 t= 0.08100000000000027 t= 0.08120000000000027 t= 0.08140000000000028 t= 0.08160000000000028 t= 0.08180000000000029 t= 0.0820000000000003 t= 0.0822000000000003 t= 0.0824000000000003 t= 0.08260000000000031 t= 0.08280000000000032 t= 0.08300000000000032 t= 0.08320000000000033 t= 0.08340000000000033 t= 0.08360000000000034 t= 0.08380000000000035 t= 0.08400000000000035 t= 0.08420000000000036 t= 0.08440000000000036 t= 0.08460000000000037 t= 0.08480000000000038 t= 0.08500000000000038 t= 0.08520000000000039 t= 0.08540000000000039 t= 0.0856000000000004 t= 0.0858000000000004 t= 0.08600000000000041 t= 0.08620000000000042 t= 0.08640000000000042 t= 0.08660000000000043 t= 0.08680000000000043 t= 0.08700000000000044 t= 0.08720000000000044 t= 0.08740000000000045 t= 0.08760000000000046 t= 0.08780000000000046 t= 0.08800000000000047 t= 0.08820000000000047 t= 0.08840000000000048 t= 0.08860000000000048 t= 0.08880000000000049 t= 0.0890000000000005 t= 0.0892000000000005 t= 0.0894000000000005 t= 0.08960000000000051 t= 0.08980000000000052 t= 0.09000000000000052 t= 0.09020000000000053 t= 0.09040000000000054 t= 0.09060000000000054 t= 0.09080000000000055 t= 0.09100000000000055 t= 0.09120000000000056 t= 0.09140000000000056 t= 0.09160000000000057 t= 0.09180000000000058 t= 0.09200000000000058 t= 0.09220000000000059 t= 0.09240000000000059 t= 0.0926000000000006 t= 0.0928000000000006 t= 0.09300000000000061 t= 0.09320000000000062 t= 0.09340000000000062 t= 0.09360000000000063 t= 0.09380000000000063 t= 0.09400000000000064 t= 0.09420000000000064 t= 0.09440000000000065 t= 0.09460000000000066 t= 0.09480000000000066 t= 0.09500000000000067 t= 0.09520000000000067 t= 0.09540000000000068 t= 0.09560000000000068 t= 0.09580000000000069 t= 0.0960000000000007 t= 0.0962000000000007 t= 0.09640000000000071 t= 0.09660000000000071 t= 0.09680000000000072 t= 0.09700000000000072 t= 0.09720000000000073 t= 0.09740000000000074 t= 0.09760000000000074 t= 0.09780000000000075 t= 0.09800000000000075 t= 0.09820000000000076 t= 0.09840000000000076 t= 0.09860000000000077 t= 0.09880000000000078 t= 0.09900000000000078 t= 0.09920000000000079 t= 0.0994000000000008 t= 0.0996000000000008 t= 0.0998000000000008 t= 0.10000000000000081 t= 0.10020000000000082 t= 0.10040000000000082 t= 0.10060000000000083 t= 0.10080000000000083 t= 0.10100000000000084 t= 0.10120000000000084 t= 0.10140000000000085 t= 0.10160000000000086 t= 0.10180000000000086 t= 0.10200000000000087 t= 0.10220000000000087 t= 0.10240000000000088 t= 0.10260000000000088 t= 0.10280000000000089 t= 0.1030000000000009 t= 0.1032000000000009 t= 0.10340000000000091 t= 0.10360000000000091 t= 0.10380000000000092 t= 0.10400000000000093 t= 0.10420000000000093 t= 0.10440000000000094 t= 0.10460000000000094 t= 0.10480000000000095 t= 0.10500000000000095 t= 0.10520000000000096 t= 0.10540000000000097 t= 0.10560000000000097 t= 0.10580000000000098 t= 0.10600000000000098 t= 0.10620000000000099 t= 0.106400000000001 t= 0.106600000000001 t= 0.106800000000001 t= 0.10700000000000101 t= 0.10720000000000102 t= 0.10740000000000102 t= 0.10760000000000103 t= 0.10780000000000103 t= 0.10800000000000104 t= 0.10820000000000105 t= 0.10840000000000105 t= 0.10860000000000106 t= 0.10880000000000106 t= 0.10900000000000107 t= 0.10920000000000107 t= 0.10940000000000108 t= 0.10960000000000109 t= 0.10980000000000109 t= 0.1100000000000011 t= 0.1102000000000011 t= 0.11040000000000111 t= 0.11060000000000111 t= 0.11080000000000112 t= 0.11100000000000113 t= 0.11120000000000113 t= 0.11140000000000114 t= 0.11160000000000114 t= 0.11180000000000115 t= 0.11200000000000115 t= 0.11220000000000116 t= 0.11240000000000117 t= 0.11260000000000117 t= 0.11280000000000118 t= 0.11300000000000118 t= 0.11320000000000119 t= 0.1134000000000012 t= 0.1136000000000012 t= 0.1138000000000012 t= 0.11400000000000121 t= 0.11420000000000122 t= 0.11440000000000122 t= 0.11460000000000123 t= 0.11480000000000123 t= 0.11500000000000124 t= 0.11520000000000125 t= 0.11540000000000125 t= 0.11560000000000126 t= 0.11580000000000126 t= 0.11600000000000127 t= 0.11620000000000127 t= 0.11640000000000128 t= 0.11660000000000129 t= 0.11680000000000129 t= 0.1170000000000013 t= 0.1172000000000013 t= 0.11740000000000131 t= 0.11760000000000131 t= 0.11780000000000132 t= 0.11800000000000133 t= 0.11820000000000133 t= 0.11840000000000134 t= 0.11860000000000134 t= 0.11880000000000135 t= 0.11900000000000135 t= 0.11920000000000136 t= 0.11940000000000137 t= 0.11960000000000137 t= 0.11980000000000138 t= 0.12000000000000138 t= 0.12020000000000139 t= 0.1204000000000014 t= 0.1206000000000014 t= 0.1208000000000014 t= 0.12100000000000141 t= 0.12120000000000142 t= 0.12140000000000142 t= 0.12160000000000143 t= 0.12180000000000143 t= 0.12200000000000144 t= 0.12220000000000145 t= 0.12240000000000145 t= 0.12260000000000146 t= 0.12280000000000146 t= 0.12300000000000147 t= 0.12320000000000147 t= 0.12340000000000148 t= 0.12360000000000149 t= 0.12380000000000149 t= 0.1240000000000015 t= 0.1242000000000015 t= 0.12440000000000151 t= 0.12460000000000152 t= 0.12480000000000152 t= 0.12500000000000153 t= 0.12520000000000153 t= 0.12540000000000154 t= 0.12560000000000154 t= 0.12580000000000155 t= 0.12600000000000156 t= 0.12620000000000156 t= 0.12640000000000157 t= 0.12660000000000157 t= 0.12680000000000158 t= 0.12700000000000158 t= 0.1272000000000016 t= 0.1274000000000016 t= 0.1276000000000016 t= 0.1278000000000016 t= 0.1280000000000016 t= 0.12820000000000162 t= 0.12840000000000162 t= 0.12860000000000163 t= 0.12880000000000164 t= 0.12900000000000164 t= 0.12920000000000165 t= 0.12940000000000165 t= 0.12960000000000166 t= 0.12980000000000166 t= 0.13000000000000167 t= 0.13020000000000168 t= 0.13040000000000168 t= 0.1306000000000017 t= 0.1308000000000017 t= 0.1310000000000017 t= 0.1312000000000017 t= 0.1314000000000017 t= 0.13160000000000172 t= 0.13180000000000172 t= 0.13200000000000173 t= 0.13220000000000173 t= 0.13240000000000174 t= 0.13260000000000174 t= 0.13280000000000175 t= 0.13300000000000176 t= 0.13320000000000176 t= 0.13340000000000177 t= 0.13360000000000177 t= 0.13380000000000178 t= 0.13400000000000178 t= 0.1342000000000018 t= 0.1344000000000018 t= 0.1346000000000018 t= 0.1348000000000018 t= 0.1350000000000018 t= 0.13520000000000182 t= 0.13540000000000182 t= 0.13560000000000183 t= 0.13580000000000184 t= 0.13600000000000184 t= 0.13620000000000185 t= 0.13640000000000185 t= 0.13660000000000186 t= 0.13680000000000186 t= 0.13700000000000187 t= 0.13720000000000188 t= 0.13740000000000188 t= 0.1376000000000019 t= 0.1378000000000019 t= 0.1380000000000019 t= 0.1382000000000019 t= 0.1384000000000019 t= 0.13860000000000192 t= 0.13880000000000192 t= 0.13900000000000193 t= 0.13920000000000193 t= 0.13940000000000194 t= 0.13960000000000194 t= 0.13980000000000195 t= 0.14000000000000196 t= 0.14020000000000196 t= 0.14040000000000197 t= 0.14060000000000197 t= 0.14080000000000198 t= 0.14100000000000198 t= 0.141200000000002 t= 0.141400000000002 t= 0.141600000000002 t= 0.141800000000002 t= 0.142000000000002 t= 0.14220000000000202 t= 0.14240000000000202 t= 0.14260000000000203 t= 0.14280000000000204 t= 0.14300000000000204 t= 0.14320000000000205 t= 0.14340000000000205 t= 0.14360000000000206 t= 0.14380000000000207 t= 0.14400000000000207 t= 0.14420000000000208 t= 0.14440000000000208 t= 0.1446000000000021 t= 0.1448000000000021 t= 0.1450000000000021 t= 0.1452000000000021 t= 0.1454000000000021 t= 0.14560000000000212 t= 0.14580000000000212 t= 0.14600000000000213 t= 0.14620000000000213 t= 0.14640000000000214 t= 0.14660000000000215 t= 0.14680000000000215 t= 0.14700000000000216 t= 0.14720000000000216 t= 0.14740000000000217 t= 0.14760000000000217 t= 0.14780000000000218 t= 0.14800000000000219 t= 0.1482000000000022 t= 0.1484000000000022 t= 0.1486000000000022 t= 0.1488000000000022 t= 0.14900000000000221 t= 0.14920000000000222 t= 0.14940000000000223 t= 0.14960000000000223 t= 0.14980000000000224 t= 0.15000000000000224 t= 0.15020000000000225 t= 0.15040000000000225 t= 0.15060000000000226 t= 0.15080000000000227 t= 0.15100000000000227 t= 0.15120000000000228 t= 0.15140000000000228 t= 0.1516000000000023 t= 0.1518000000000023 t= 0.1520000000000023 t= 0.1522000000000023 t= 0.1524000000000023 t= 0.15260000000000232 t= 0.15280000000000232 t= 0.15300000000000233 t= 0.15320000000000233 t= 0.15340000000000234 t= 0.15360000000000235 t= 0.15380000000000235 t= 0.15400000000000236 t= 0.15420000000000236 t= 0.15440000000000237 t= 0.15460000000000237 t= 0.15480000000000238 t= 0.15500000000000239 t= 0.1552000000000024 t= 0.1554000000000024 t= 0.1556000000000024 t= 0.1558000000000024 t= 0.15600000000000241 t= 0.15620000000000242 t= 0.15640000000000243 t= 0.15660000000000243 t= 0.15680000000000244 t= 0.15700000000000244 t= 0.15720000000000245 t= 0.15740000000000245 t= 0.15760000000000246 t= 0.15780000000000247 t= 0.15800000000000247 t= 0.15820000000000248 t= 0.15840000000000248 t= 0.1586000000000025 t= 0.1588000000000025 t= 0.1590000000000025 t= 0.1592000000000025 t= 0.1594000000000025 t= 0.15960000000000252 t= 0.15980000000000252 t= 0.16000000000000253 t= 0.16020000000000253 t= 0.16040000000000254 t= 0.16060000000000255 t= 0.16080000000000255 t= 0.16100000000000256 t= 0.16120000000000256 t= 0.16140000000000257 t= 0.16160000000000257 t= 0.16180000000000258 t= 0.1620000000000026 t= 0.1622000000000026 t= 0.1624000000000026 t= 0.1626000000000026 t= 0.1628000000000026 t= 0.16300000000000262 t= 0.16320000000000262 t= 0.16340000000000263 t= 0.16360000000000263 t= 0.16380000000000264 t= 0.16400000000000264 t= 0.16420000000000265 t= 0.16440000000000266 t= 0.16460000000000266 t= 0.16480000000000267 t= 0.16500000000000267 t= 0.16520000000000268 t= 0.16540000000000268 t= 0.1656000000000027 t= 0.1658000000000027 t= 0.1660000000000027 t= 0.1662000000000027 t= 0.1664000000000027 t= 0.16660000000000272 t= 0.16680000000000272 t= 0.16700000000000273 t= 0.16720000000000274 t= 0.16740000000000274 t= 0.16760000000000275 t= 0.16780000000000275 t= 0.16800000000000276 t= 0.16820000000000276 t= 0.16840000000000277 t= 0.16860000000000278 t= 0.16880000000000278 t= 0.1690000000000028 t= 0.1692000000000028 t= 0.1694000000000028 t= 0.1696000000000028 t= 0.1698000000000028 t= 0.17000000000000282 t= 0.17020000000000282 t= 0.17040000000000283 t= 0.17060000000000283 t= 0.17080000000000284 t= 0.17100000000000284 t= 0.17120000000000285 t= 0.17140000000000286 t= 0.17160000000000286 t= 0.17180000000000287 t= 0.17200000000000287 t= 0.17220000000000288 t= 0.17240000000000288 t= 0.1726000000000029 t= 0.1728000000000029 t= 0.1730000000000029 t= 0.1732000000000029 t= 0.1734000000000029 t= 0.17360000000000292 t= 0.17380000000000292 t= 0.17400000000000293 t= 0.17420000000000294 t= 0.17440000000000294 t= 0.17460000000000295 t= 0.17480000000000295 t= 0.17500000000000296 t= 0.17520000000000296 t= 0.17540000000000297 t= 0.17560000000000298 t= 0.17580000000000298 t= 0.176000000000003 t= 0.176200000000003 t= 0.176400000000003 t= 0.176600000000003 t= 0.176800000000003 t= 0.17700000000000302 t= 0.17720000000000302 t= 0.17740000000000303 t= 0.17760000000000303 t= 0.17780000000000304 t= 0.17800000000000304 t= 0.17820000000000305 t= 0.17840000000000306 t= 0.17860000000000306 t= 0.17880000000000307 t= 0.17900000000000307 t= 0.17920000000000308 t= 0.17940000000000308 t= 0.1796000000000031 t= 0.1798000000000031 t= 0.1800000000000031 t= 0.1802000000000031 t= 0.1804000000000031 t= 0.18060000000000312 t= 0.18080000000000312 t= 0.18100000000000313 t= 0.18120000000000314 t= 0.18140000000000314 t= 0.18160000000000315 t= 0.18180000000000315 t= 0.18200000000000316 t= 0.18220000000000316 t= 0.18240000000000317 t= 0.18260000000000318 t= 0.18280000000000318 t= 0.1830000000000032 t= 0.1832000000000032 t= 0.1834000000000032 t= 0.1836000000000032 t= 0.1838000000000032 t= 0.18400000000000322 t= 0.18420000000000322 t= 0.18440000000000323 t= 0.18460000000000323 t= 0.18480000000000324 t= 0.18500000000000325 t= 0.18520000000000325 t= 0.18540000000000326 t= 0.18560000000000326 t= 0.18580000000000327 t= 0.18600000000000327 t= 0.18620000000000328 t= 0.18640000000000329 t= 0.1866000000000033 t= 0.1868000000000033 t= 0.1870000000000033 t= 0.1872000000000033 t= 0.18740000000000331 t= 0.18760000000000332 t= 0.18780000000000333 t= 0.18800000000000333 t= 0.18820000000000334 t= 0.18840000000000334 t= 0.18860000000000335 t= 0.18880000000000335 t= 0.18900000000000336 t= 0.18920000000000337 t= 0.18940000000000337 t= 0.18960000000000338 t= 0.18980000000000338 t= 0.1900000000000034 t= 0.1902000000000034 t= 0.1904000000000034 t= 0.1906000000000034 t= 0.1908000000000034 t= 0.19100000000000342 t= 0.19120000000000342 t= 0.19140000000000343 t= 0.19160000000000343 t= 0.19180000000000344 t= 0.19200000000000345 t= 0.19220000000000345 t= 0.19240000000000346 t= 0.19260000000000346 t= 0.19280000000000347 t= 0.19300000000000347 t= 0.19320000000000348 t= 0.19340000000000349 t= 0.1936000000000035 t= 0.1938000000000035 t= 0.1940000000000035 t= 0.1942000000000035 t= 0.19440000000000351 t= 0.19460000000000352 t= 0.19480000000000353 t= 0.19500000000000353 t= 0.19520000000000354 t= 0.19540000000000354 t= 0.19560000000000355 t= 0.19580000000000355 t= 0.19600000000000356 t= 0.19620000000000357 t= 0.19640000000000357 t= 0.19660000000000358 t= 0.19680000000000358 t= 0.1970000000000036 t= 0.1972000000000036 t= 0.1974000000000036 t= 0.1976000000000036 t= 0.1978000000000036 t= 0.19800000000000362 t= 0.19820000000000362 t= 0.19840000000000363 t= 0.19860000000000363 t= 0.19880000000000364 t= 0.19900000000000365 t= 0.19920000000000365 t= 0.19940000000000366 t= 0.19960000000000366 t= 0.19980000000000367 t= 0.20000000000000367 t= 0.20020000000000368 t= 0.2004000000000037 t= 0.2006000000000037 t= 0.2008000000000037 t= 0.2010000000000037 t= 0.2012000000000037 t= 0.20140000000000371 t= 0.20160000000000372 t= 0.20180000000000373 t= 0.20200000000000373 t= 0.20220000000000374 t= 0.20240000000000374 t= 0.20260000000000375 t= 0.20280000000000376 t= 0.20300000000000376 t= 0.20320000000000377 t= 0.20340000000000377 t= 0.20360000000000378 t= 0.20380000000000378 t= 0.2040000000000038 t= 0.2042000000000038 t= 0.2044000000000038 t= 0.2046000000000038 t= 0.2048000000000038 t= 0.20500000000000382 t= 0.20520000000000382 t= 0.20540000000000383 t= 0.20560000000000384 t= 0.20580000000000384 t= 0.20600000000000385 t= 0.20620000000000385 t= 0.20640000000000386 t= 0.20660000000000386 t= 0.20680000000000387 t= 0.20700000000000388 t= 0.20720000000000388 t= 0.2074000000000039 t= 0.2076000000000039 t= 0.2078000000000039 t= 0.2080000000000039 t= 0.2082000000000039 t= 0.20840000000000392 t= 0.20860000000000392 t= 0.20880000000000393 t= 0.20900000000000393 t= 0.20920000000000394 t= 0.20940000000000394 t= 0.20960000000000395 t= 0.20980000000000396 t= 0.21000000000000396 t= 0.21020000000000397 t= 0.21040000000000397 t= 0.21060000000000398 t= 0.21080000000000398 t= 0.211000000000004 t= 0.211200000000004 t= 0.211400000000004 t= 0.211600000000004 t= 0.211800000000004 t= 0.21200000000000402 t= 0.21220000000000402 t= 0.21240000000000403 t= 0.21260000000000404 t= 0.21280000000000404 t= 0.21300000000000405 t= 0.21320000000000405 t= 0.21340000000000406 t= 0.21360000000000406 t= 0.21380000000000407 t= 0.21400000000000408 t= 0.21420000000000408 t= 0.2144000000000041 t= 0.2146000000000041 t= 0.2148000000000041 t= 0.2150000000000041 t= 0.2152000000000041 t= 0.21540000000000412 t= 0.21560000000000412 t= 0.21580000000000413 t= 0.21600000000000413 t= 0.21620000000000414 t= 0.21640000000000414 t= 0.21660000000000415 t= 0.21680000000000416 t= 0.21700000000000416 t= 0.21720000000000417 t= 0.21740000000000417 t= 0.21760000000000418 t= 0.21780000000000418 t= 0.2180000000000042 t= 0.2182000000000042 t= 0.2184000000000042 t= 0.2186000000000042 t= 0.2188000000000042 t= 0.21900000000000422 t= 0.21920000000000422 t= 0.21940000000000423 t= 0.21960000000000424 t= 0.21980000000000424 t= 0.22000000000000425 t= 0.22020000000000425 t= 0.22040000000000426 t= 0.22060000000000426 t= 0.22080000000000427 t= 0.22100000000000428 t= 0.22120000000000428 t= 0.2214000000000043 t= 0.2216000000000043 t= 0.2218000000000043 t= 0.2220000000000043 t= 0.2222000000000043 t= 0.22240000000000432 t= 0.22260000000000432 t= 0.22280000000000433 t= 0.22300000000000433 t= 0.22320000000000434 t= 0.22340000000000435 t= 0.22360000000000435 t= 0.22380000000000436 t= 0.22400000000000436 t= 0.22420000000000437 t= 0.22440000000000437 t= 0.22460000000000438 t= 0.22480000000000439 t= 0.2250000000000044 t= 0.2252000000000044 t= 0.2254000000000044 t= 0.2256000000000044 t= 0.2258000000000044 t= 0.22600000000000442 t= 0.22620000000000443 t= 0.22640000000000443 t= 0.22660000000000444 t= 0.22680000000000444 t= 0.22700000000000445 t= 0.22720000000000445 t= 0.22740000000000446 t= 0.22760000000000447 t= 0.22780000000000447 t= 0.22800000000000448 t= 0.22820000000000448 t= 0.2284000000000045 t= 0.2286000000000045 t= 0.2288000000000045 t= 0.2290000000000045 t= 0.2292000000000045 t= 0.22940000000000452 t= 0.22960000000000452 t= 0.22980000000000453 t= 0.23000000000000453 t= 0.23020000000000454 t= 0.23040000000000455 t= 0.23060000000000455 t= 0.23080000000000456 t= 0.23100000000000456 t= 0.23120000000000457 t= 0.23140000000000457 t= 0.23160000000000458 t= 0.23180000000000459 t= 0.2320000000000046 t= 0.2322000000000046 t= 0.2324000000000046 t= 0.2326000000000046 t= 0.23280000000000461 t= 0.23300000000000462 t= 0.23320000000000463 t= 0.23340000000000463 t= 0.23360000000000464 t= 0.23380000000000464 t= 0.23400000000000465 t= 0.23420000000000465 t= 0.23440000000000466 t= 0.23460000000000467 t= 0.23480000000000467 t= 0.23500000000000468 t= 0.23520000000000468 t= 0.2354000000000047 t= 0.2356000000000047 t= 0.2358000000000047 t= 0.2360000000000047 t= 0.2362000000000047 t= 0.23640000000000472 t= 0.23660000000000472 t= 0.23680000000000473 t= 0.23700000000000473 t= 0.23720000000000474 t= 0.23740000000000475 t= 0.23760000000000475 t= 0.23780000000000476 t= 0.23800000000000476 t= 0.23820000000000477 t= 0.23840000000000477 t= 0.23860000000000478 t= 0.2388000000000048 t= 0.2390000000000048 t= 0.2392000000000048 t= 0.2394000000000048 t= 0.2396000000000048 t= 0.23980000000000481 t= 0.24000000000000482 t= 0.24020000000000483 t= 0.24040000000000483 t= 0.24060000000000484 t= 0.24080000000000484 t= 0.24100000000000485 t= 0.24120000000000485 t= 0.24140000000000486 t= 0.24160000000000487 t= 0.24180000000000487 t= 0.24200000000000488 t= 0.24220000000000488 t= 0.2424000000000049 t= 0.2426000000000049 t= 0.2428000000000049 t= 0.2430000000000049 t= 0.2432000000000049 t= 0.24340000000000492 t= 0.24360000000000492 t= 0.24380000000000493 t= 0.24400000000000494 t= 0.24420000000000494 t= 0.24440000000000495 t= 0.24460000000000495 t= 0.24480000000000496 t= 0.24500000000000496 t= 0.24520000000000497 t= 0.24540000000000498 t= 0.24560000000000498 t= 0.245800000000005 t= 0.246000000000005 t= 0.246200000000005 t= 0.246400000000005 t= 0.246600000000005 t= 0.24680000000000502 t= 0.24700000000000502 t= 0.24720000000000503 t= 0.24740000000000503 t= 0.24760000000000504 t= 0.24780000000000504 t= 0.24800000000000505 t= 0.24820000000000506 t= 0.24840000000000506 t= 0.24860000000000507 t= 0.24880000000000507 t= 0.24900000000000508 t= 0.24920000000000508 t= 0.2494000000000051 t= 0.2496000000000051 t= 0.2498000000000051 t= 0.2500000000000051 t= 0.2502000000000051 t= 0.25040000000000506 t= 0.25060000000000504 t= 0.250800000000005 t= 0.251000000000005 t= 0.251200000000005 t= 0.25140000000000495 t= 0.25160000000000493 t= 0.2518000000000049 t= 0.2520000000000049 t= 0.25220000000000486 t= 0.25240000000000484 t= 0.2526000000000048 t= 0.2528000000000048 t= 0.2530000000000048 t= 0.25320000000000475 t= 0.25340000000000473 t= 0.2536000000000047 t= 0.2538000000000047 t= 0.25400000000000467 t= 0.25420000000000464 t= 0.2544000000000046 t= 0.2546000000000046 t= 0.2548000000000046 t= 0.25500000000000456 t= 0.25520000000000453 t= 0.2554000000000045 t= 0.2556000000000045 t= 0.25580000000000447 t= 0.25600000000000445 t= 0.2562000000000044 t= 0.2564000000000044 t= 0.2566000000000044 t= 0.25680000000000436 t= 0.25700000000000434 t= 0.2572000000000043 t= 0.2574000000000043 t= 0.25760000000000427 t= 0.25780000000000425 t= 0.2580000000000042 t= 0.2582000000000042 t= 0.2584000000000042 t= 0.25860000000000416 t= 0.25880000000000414 t= 0.2590000000000041 t= 0.2592000000000041 t= 0.25940000000000407 t= 0.25960000000000405 t= 0.259800000000004 t= 0.260000000000004 t= 0.260200000000004 t= 0.26040000000000396 t= 0.26060000000000394 t= 0.2608000000000039 t= 0.2610000000000039 t= 0.2612000000000039 t= 0.26140000000000385 t= 0.26160000000000383 t= 0.2618000000000038 t= 0.2620000000000038 t= 0.26220000000000376 t= 0.26240000000000374 t= 0.2626000000000037 t= 0.2628000000000037 t= 0.2630000000000037 t= 0.26320000000000365 t= 0.26340000000000363 t= 0.2636000000000036 t= 0.2638000000000036 t= 0.26400000000000357 t= 0.26420000000000354 t= 0.2644000000000035 t= 0.2646000000000035 t= 0.2648000000000035 t= 0.26500000000000346 t= 0.26520000000000343 t= 0.2654000000000034 t= 0.2656000000000034 t= 0.26580000000000337 t= 0.26600000000000334 t= 0.2662000000000033 t= 0.2664000000000033 t= 0.2666000000000033 t= 0.26680000000000326 t= 0.26700000000000323 t= 0.2672000000000032 t= 0.2674000000000032 t= 0.26760000000000317 t= 0.26780000000000315 t= 0.2680000000000031 t= 0.2682000000000031 t= 0.2684000000000031 t= 0.26860000000000306 t= 0.26880000000000304 t= 0.269000000000003 t= 0.269200000000003 t= 0.26940000000000297 t= 0.26960000000000295 t= 0.2698000000000029 t= 0.2700000000000029 t= 0.2702000000000029 t= 0.27040000000000286 t= 0.27060000000000284 t= 0.2708000000000028 t= 0.2710000000000028 t= 0.27120000000000277 t= 0.27140000000000275 t= 0.27160000000000273 t= 0.2718000000000027 t= 0.2720000000000027 t= 0.27220000000000266 t= 0.27240000000000264 t= 0.2726000000000026 t= 0.2728000000000026 t= 0.2730000000000026 t= 0.27320000000000255 t= 0.27340000000000253 t= 0.2736000000000025 t= 0.2738000000000025 t= 0.27400000000000246 t= 0.27420000000000244 t= 0.2744000000000024 t= 0.2746000000000024 t= 0.2748000000000024 t= 0.27500000000000235 t= 0.27520000000000233 t= 0.2754000000000023 t= 0.2756000000000023 t= 0.27580000000000227 t= 0.27600000000000224 t= 0.2762000000000022 t= 0.2764000000000022 t= 0.2766000000000022 t= 0.27680000000000216 t= 0.27700000000000213 t= 0.2772000000000021 t= 0.2774000000000021 t= 0.27760000000000207 t= 0.27780000000000205 t= 0.278000000000002 t= 0.278200000000002 t= 0.278400000000002 t= 0.27860000000000196 t= 0.27880000000000194 t= 0.2790000000000019 t= 0.2792000000000019 t= 0.27940000000000187 t= 0.27960000000000185 t= 0.2798000000000018 t= 0.2800000000000018 t= 0.2802000000000018 t= 0.28040000000000176 t= 0.28060000000000174 t= 0.2808000000000017 t= 0.2810000000000017 t= 0.28120000000000167 t= 0.28140000000000165 t= 0.2816000000000016 t= 0.2818000000000016 t= 0.2820000000000016 t= 0.28220000000000156 t= 0.28240000000000154 t= 0.2826000000000015 t= 0.2828000000000015 t= 0.2830000000000015 t= 0.28320000000000145 t= 0.28340000000000143 t= 0.2836000000000014 t= 0.2838000000000014 t= 0.28400000000000136 t= 0.28420000000000134 t= 0.2844000000000013 t= 0.2846000000000013 t= 0.2848000000000013 t= 0.28500000000000125 t= 0.28520000000000123 t= 0.2854000000000012 t= 0.2856000000000012 t= 0.28580000000000116 t= 0.28600000000000114 t= 0.2862000000000011 t= 0.2864000000000011 t= 0.2866000000000011 t= 0.28680000000000105 t= 0.28700000000000103 t= 0.287200000000001 t= 0.287400000000001 t= 0.28760000000000097 t= 0.28780000000000094 t= 0.2880000000000009 t= 0.2882000000000009 t= 0.2884000000000009 t= 0.28860000000000086 t= 0.28880000000000083 t= 0.2890000000000008 t= 0.2892000000000008 t= 0.28940000000000077 t= 0.28960000000000075 t= 0.2898000000000007 t= 0.2900000000000007 t= 0.2902000000000007 t= 0.29040000000000066 t= 0.29060000000000064 t= 0.2908000000000006 t= 0.2910000000000006 t= 0.29120000000000057 t= 0.29140000000000055 t= 0.2916000000000005 t= 0.2918000000000005 t= 0.2920000000000005 t= 0.29220000000000046 t= 0.29240000000000044 t= 0.2926000000000004 t= 0.2928000000000004 t= 0.29300000000000037 t= 0.29320000000000035 t= 0.2934000000000003 t= 0.2936000000000003 t= 0.2938000000000003 t= 0.29400000000000026 t= 0.29420000000000024 t= 0.2944000000000002 t= 0.2946000000000002 t= 0.2948000000000002 t= 0.29500000000000015 t= 0.29520000000000013 t= 0.2954000000000001 t= 0.2956000000000001 t= 0.29580000000000006 t= 0.29600000000000004 t= 0.2962 t= 0.2964 t= 0.2966 t= 0.29679999999999995 t= 0.29699999999999993 t= 0.2971999999999999 t= 0.2973999999999999 t= 0.29759999999999986 t= 0.29779999999999984 t= 0.2979999999999998 t= 0.2981999999999998 t= 0.2983999999999998 t= 0.29859999999999975 t= 0.29879999999999973 t= 0.2989999999999997 t= 0.2991999999999997 t= 0.29939999999999967 t= 0.29959999999999964 t= 0.2997999999999996 t= 0.2999999999999996 t= 0.3001999999999996 t= 0.30039999999999956 t= 0.30059999999999953 t= 0.3007999999999995 t= 0.3009999999999995 t= 0.30119999999999947 t= 0.30139999999999945 t= 0.3015999999999994 t= 0.3017999999999994 t= 0.3019999999999994 t= 0.30219999999999936 t= 0.30239999999999934 t= 0.3025999999999993 t= 0.3027999999999993 t= 0.30299999999999927 t= 0.30319999999999925 t= 0.3033999999999992 t= 0.3035999999999992 t= 0.3037999999999992 t= 0.30399999999999916 t= 0.30419999999999914 t= 0.3043999999999991 t= 0.3045999999999991 t= 0.30479999999999907 t= 0.30499999999999905 t= 0.305199999999999 t= 0.305399999999999 t= 0.305599999999999 t= 0.30579999999999896 t= 0.30599999999999894 t= 0.3061999999999989 t= 0.3063999999999989 t= 0.3065999999999989 t= 0.30679999999999885 t= 0.30699999999999883 t= 0.3071999999999988 t= 0.3073999999999988 t= 0.30759999999999876 t= 0.30779999999999874 t= 0.3079999999999987 t= 0.3081999999999987 t= 0.3083999999999987 t= 0.30859999999999865 t= 0.30879999999999863 t= 0.3089999999999986 t= 0.3091999999999986 t= 0.30939999999999857 t= 0.30959999999999854 t= 0.3097999999999985 t= 0.3099999999999985 t= 0.3101999999999985 t= 0.31039999999999845 t= 0.31059999999999843 t= 0.3107999999999984 t= 0.3109999999999984 t= 0.31119999999999837 t= 0.31139999999999834 t= 0.3115999999999983 t= 0.3117999999999983 t= 0.3119999999999983 t= 0.31219999999999826 t= 0.31239999999999823 t= 0.3125999999999982 t= 0.3127999999999982 t= 0.31299999999999817 t= 0.31319999999999815 t= 0.3133999999999981 t= 0.3135999999999981 t= 0.3137999999999981 t= 0.31399999999999806 t= 0.31419999999999804 t= 0.314399999999998 t= 0.314599999999998 t= 0.31479999999999797 t= 0.31499999999999795 t= 0.3151999999999979 t= 0.3153999999999979 t= 0.3155999999999979 t= 0.31579999999999786 t= 0.31599999999999784 t= 0.3161999999999978 t= 0.3163999999999978 t= 0.31659999999999777 t= 0.31679999999999775 t= 0.31699999999999773 t= 0.3171999999999977 t= 0.3173999999999977 t= 0.31759999999999766 t= 0.31779999999999764 t= 0.3179999999999976 t= 0.3181999999999976 t= 0.3183999999999976 t= 0.31859999999999755 t= 0.31879999999999753 t= 0.3189999999999975 t= 0.3191999999999975 t= 0.31939999999999746 t= 0.31959999999999744 t= 0.3197999999999974 t= 0.3199999999999974 t= 0.3201999999999974 t= 0.32039999999999735 t= 0.32059999999999733 t= 0.3207999999999973 t= 0.3209999999999973 t= 0.32119999999999727 t= 0.32139999999999724 t= 0.3215999999999972 t= 0.3217999999999972 t= 0.3219999999999972 t= 0.32219999999999716 t= 0.32239999999999713 t= 0.3225999999999971 t= 0.3227999999999971 t= 0.32299999999999707 t= 0.32319999999999705 t= 0.323399999999997 t= 0.323599999999997 t= 0.323799999999997 t= 0.32399999999999696 t= 0.32419999999999694 t= 0.3243999999999969 t= 0.3245999999999969 t= 0.32479999999999687 t= 0.32499999999999685 t= 0.3251999999999968 t= 0.3253999999999968 t= 0.3255999999999968 t= 0.32579999999999676 t= 0.32599999999999674 t= 0.3261999999999967 t= 0.3263999999999967 t= 0.32659999999999667 t= 0.32679999999999665 t= 0.3269999999999966 t= 0.3271999999999966 t= 0.3273999999999966 t= 0.32759999999999656 t= 0.32779999999999654 t= 0.3279999999999965 t= 0.3281999999999965 t= 0.3283999999999965 t= 0.32859999999999645 t= 0.32879999999999643 t= 0.3289999999999964 t= 0.3291999999999964 t= 0.32939999999999636 t= 0.32959999999999634 t= 0.3297999999999963 t= 0.3299999999999963 t= 0.3301999999999963 t= 0.33039999999999625 t= 0.33059999999999623 t= 0.3307999999999962 t= 0.3309999999999962 t= 0.33119999999999616 t= 0.33139999999999614 t= 0.3315999999999961 t= 0.3317999999999961 t= 0.3319999999999961 t= 0.33219999999999605 t= 0.33239999999999603 t= 0.332599999999996 t= 0.332799999999996 t= 0.33299999999999597 t= 0.33319999999999594 t= 0.3333999999999959 t= 0.3335999999999959 t= 0.3337999999999959 t= 0.33399999999999586 t= 0.33419999999999583 t= 0.3343999999999958 t= 0.3345999999999958 t= 0.33479999999999577 t= 0.33499999999999575 t= 0.3351999999999957 t= 0.3353999999999957 t= 0.3355999999999957 t= 0.33579999999999566 t= 0.33599999999999564 t= 0.3361999999999956 t= 0.3363999999999956 t= 0.33659999999999557 t= 0.33679999999999555 t= 0.3369999999999955 t= 0.3371999999999955 t= 0.3373999999999955 t= 0.33759999999999546 t= 0.33779999999999544 t= 0.3379999999999954 t= 0.3381999999999954 t= 0.33839999999999537 t= 0.33859999999999535 t= 0.3387999999999953 t= 0.3389999999999953 t= 0.3391999999999953 t= 0.33939999999999526 t= 0.33959999999999524 t= 0.3397999999999952 t= 0.3399999999999952 t= 0.3401999999999952 t= 0.34039999999999515 t= 0.34059999999999513 t= 0.3407999999999951 t= 0.3409999999999951 t= 0.34119999999999506 t= 0.34139999999999504 t= 0.341599999999995 t= 0.341799999999995 t= 0.341999999999995 t= 0.34219999999999495 t= 0.34239999999999493 t= 0.3425999999999949 t= 0.3427999999999949 t= 0.34299999999999486 t= 0.34319999999999484 t= 0.3433999999999948 t= 0.3435999999999948 t= 0.3437999999999948 t= 0.34399999999999475 t= 0.34419999999999473 t= 0.3443999999999947 t= 0.3445999999999947 t= 0.34479999999999467 t= 0.34499999999999464 t= 0.3451999999999946 t= 0.3453999999999946 t= 0.3455999999999946 t= 0.34579999999999456 t= 0.34599999999999453 t= 0.3461999999999945 t= 0.3463999999999945 t= 0.34659999999999447 t= 0.34679999999999445 t= 0.3469999999999944 t= 0.3471999999999944 t= 0.3473999999999944 t= 0.34759999999999436 t= 0.34779999999999434 t= 0.3479999999999943 t= 0.3481999999999943 t= 0.34839999999999427 t= 0.34859999999999425 t= 0.3487999999999942 t= 0.3489999999999942 t= 0.3491999999999942 t= 0.34939999999999416 t= 0.34959999999999414 t= 0.3497999999999941 t= 0.3499999999999941 t= 0.35019999999999407 t= 0.35039999999999405 t= 0.350599999999994 t= 0.350799999999994 t= 0.350999999999994 t= 0.35119999999999396 t= 0.35139999999999394 t= 0.3515999999999939 t= 0.3517999999999939 t= 0.3519999999999939 t= 0.35219999999999385 t= 0.35239999999999383 t= 0.3525999999999938 t= 0.3527999999999938 t= 0.35299999999999376 t= 0.35319999999999374 t= 0.3533999999999937 t= 0.3535999999999937 t= 0.3537999999999937 t= 0.35399999999999365 t= 0.35419999999999363 t= 0.3543999999999936 t= 0.3545999999999936 t= 0.35479999999999356 t= 0.35499999999999354 t= 0.3551999999999935 t= 0.3553999999999935 t= 0.3555999999999935 t= 0.35579999999999345 t= 0.35599999999999343 t= 0.3561999999999934 t= 0.3563999999999934 t= 0.35659999999999337 t= 0.35679999999999334 t= 0.3569999999999933 t= 0.3571999999999933 t= 0.3573999999999933 t= 0.35759999999999326 t= 0.35779999999999323 t= 0.3579999999999932 t= 0.3581999999999932 t= 0.35839999999999317 t= 0.35859999999999315 t= 0.3587999999999931 t= 0.3589999999999931 t= 0.3591999999999931 t= 0.35939999999999306 t= 0.35959999999999304 t= 0.359799999999993 t= 0.359999999999993 t= 0.36019999999999297 t= 0.36039999999999295 t= 0.3605999999999929 t= 0.3607999999999929 t= 0.3609999999999929 t= 0.36119999999999286 t= 0.36139999999999284 t= 0.3615999999999928 t= 0.3617999999999928 t= 0.36199999999999277 t= 0.36219999999999275 t= 0.36239999999999273 t= 0.3625999999999927 t= 0.3627999999999927 t= 0.36299999999999266 t= 0.36319999999999264 t= 0.3633999999999926 t= 0.3635999999999926 t= 0.3637999999999926 t= 0.36399999999999255 t= 0.36419999999999253 t= 0.3643999999999925 t= 0.3645999999999925 t= 0.36479999999999246 t= 0.36499999999999244 t= 0.3651999999999924 t= 0.3653999999999924 t= 0.3655999999999924 t= 0.36579999999999235 t= 0.36599999999999233 t= 0.3661999999999923 t= 0.3663999999999923 t= 0.36659999999999227 t= 0.36679999999999224 t= 0.3669999999999922 t= 0.3671999999999922 t= 0.3673999999999922 t= 0.36759999999999216 t= 0.36779999999999213 t= 0.3679999999999921 t= 0.3681999999999921 t= 0.36839999999999207 t= 0.36859999999999205 t= 0.368799999999992 t= 0.368999999999992 t= 0.369199999999992 t= 0.36939999999999196 t= 0.36959999999999193 t= 0.3697999999999919 t= 0.3699999999999919 t= 0.37019999999999187 t= 0.37039999999999185 t= 0.3705999999999918 t= 0.3707999999999918 t= 0.3709999999999918 t= 0.37119999999999176 t= 0.37139999999999174 t= 0.3715999999999917 t= 0.3717999999999917 t= 0.37199999999999167 t= 0.37219999999999165 t= 0.3723999999999916 t= 0.3725999999999916 t= 0.3727999999999916 t= 0.37299999999999156 t= 0.37319999999999154 t= 0.3733999999999915 t= 0.3735999999999915 t= 0.3737999999999915 t= 0.37399999999999145 t= 0.37419999999999143 t= 0.3743999999999914 t= 0.3745999999999914 t= 0.37479999999999136 t= 0.37499999999999134 t= 0.3751999999999913 t= 0.3753999999999913 t= 0.3755999999999913 t= 0.37579999999999125 t= 0.37599999999999123 t= 0.3761999999999912 t= 0.3763999999999912 t= 0.37659999999999116 t= 0.37679999999999114 t= 0.3769999999999911 t= 0.3771999999999911 t= 0.3773999999999911 t= 0.37759999999999105 t= 0.37779999999999103 t= 0.377999999999991 t= 0.378199999999991 t= 0.37839999999999097 t= 0.37859999999999094 t= 0.3787999999999909 t= 0.3789999999999909 t= 0.3791999999999909 t= 0.37939999999999086 t= 0.37959999999999083 t= 0.3797999999999908 t= 0.3799999999999908 t= 0.38019999999999077 t= 0.38039999999999075 t= 0.3805999999999907 t= 0.3807999999999907 t= 0.3809999999999907 t= 0.38119999999999066 t= 0.38139999999999064 t= 0.3815999999999906 t= 0.3817999999999906 t= 0.38199999999999057 t= 0.38219999999999055 t= 0.3823999999999905 t= 0.3825999999999905 t= 0.3827999999999905 t= 0.38299999999999046 t= 0.38319999999999044 t= 0.3833999999999904 t= 0.3835999999999904 t= 0.38379999999999037 t= 0.38399999999999035 t= 0.3841999999999903 t= 0.3843999999999903 t= 0.3845999999999903 t= 0.38479999999999026 t= 0.38499999999999024 t= 0.3851999999999902 t= 0.3853999999999902 t= 0.3855999999999902 t= 0.38579999999999015 t= 0.38599999999999013 t= 0.3861999999999901 t= 0.3863999999999901 t= 0.38659999999999006 t= 0.38679999999999004 t= 0.38699999999999 t= 0.38719999999999 t= 0.38739999999999 t= 0.38759999999998995 t= 0.38779999999998993 t= 0.3879999999999899 t= 0.3881999999999899 t= 0.38839999999998986 t= 0.38859999999998984 t= 0.3887999999999898 t= 0.3889999999999898 t= 0.3891999999999898 t= 0.38939999999998975 t= 0.38959999999998973 t= 0.3897999999999897 t= 0.3899999999999897 t= 0.39019999999998967 t= 0.39039999999998964 t= 0.3905999999999896 t= 0.3907999999999896 t= 0.3909999999999896 t= 0.39119999999998956 t= 0.39139999999998953 t= 0.3915999999999895 t= 0.3917999999999895 t= 0.39199999999998947 t= 0.39219999999998945 t= 0.3923999999999894 t= 0.3925999999999894 t= 0.3927999999999894 t= 0.39299999999998936 t= 0.39319999999998934 t= 0.3933999999999893 t= 0.3935999999999893 t= 0.39379999999998927 t= 0.39399999999998925 t= 0.3941999999999892 t= 0.3943999999999892 t= 0.3945999999999892 t= 0.39479999999998916 t= 0.39499999999998914 t= 0.3951999999999891 t= 0.3953999999999891 t= 0.39559999999998907 t= 0.39579999999998905 t= 0.395999999999989 t= 0.396199999999989 t= 0.396399999999989 t= 0.39659999999998896 t= 0.39679999999998894 t= 0.3969999999999889 t= 0.3971999999999889 t= 0.3973999999999889 t= 0.39759999999998885 t= 0.39779999999998883 t= 0.3979999999999888 t= 0.3981999999999888 t= 0.39839999999998876 t= 0.39859999999998874 t= 0.3987999999999887 t= 0.3989999999999887 t= 0.3991999999999887 t= 0.39939999999998865 t= 0.39959999999998863 t= 0.3997999999999886 t= 0.3999999999999886 t= 0.40019999999998856 t= 0.40039999999998854 t= 0.4005999999999885 t= 0.4007999999999885 t= 0.4009999999999885 t= 0.40119999999998845 t= 0.40139999999998843 t= 0.4015999999999884 t= 0.4017999999999884 t= 0.40199999999998837 t= 0.40219999999998834 t= 0.4023999999999883 t= 0.4025999999999883 t= 0.4027999999999883 t= 0.40299999999998826 t= 0.40319999999998823 t= 0.4033999999999882 t= 0.4035999999999882 t= 0.40379999999998817 t= 0.40399999999998815 t= 0.4041999999999881 t= 0.4043999999999881 t= 0.4045999999999881 t= 0.40479999999998806 t= 0.40499999999998804 t= 0.405199999999988 t= 0.405399999999988 t= 0.40559999999998797 t= 0.40579999999998795 t= 0.4059999999999879 t= 0.4061999999999879 t= 0.4063999999999879 t= 0.40659999999998786 t= 0.40679999999998784 t= 0.4069999999999878 t= 0.4071999999999878 t= 0.40739999999998777 t= 0.40759999999998775 t= 0.40779999999998773 t= 0.4079999999999877 t= 0.4081999999999877 t= 0.40839999999998766 t= 0.40859999999998764 t= 0.4087999999999876 t= 0.4089999999999876 t= 0.4091999999999876 t= 0.40939999999998755 t= 0.40959999999998753 t= 0.4097999999999875 t= 0.4099999999999875 t= 0.41019999999998746 t= 0.41039999999998744 t= 0.4105999999999874 t= 0.4107999999999874 t= 0.4109999999999874 t= 0.41119999999998735 t= 0.41139999999998733 t= 0.4115999999999873 t= 0.4117999999999873 t= 0.41199999999998727 t= 0.41219999999998724 t= 0.4123999999999872 t= 0.4125999999999872 t= 0.4127999999999872 t= 0.41299999999998716 t= 0.41319999999998713 t= 0.4133999999999871 t= 0.4135999999999871 t= 0.41379999999998707 t= 0.41399999999998705 t= 0.414199999999987 t= 0.414399999999987 t= 0.414599999999987 t= 0.41479999999998696 t= 0.41499999999998693 t= 0.4151999999999869 t= 0.4153999999999869 t= 0.41559999999998687 t= 0.41579999999998685 t= 0.4159999999999868 t= 0.4161999999999868 t= 0.4163999999999868 t= 0.41659999999998676 t= 0.41679999999998674 t= 0.4169999999999867 t= 0.4171999999999867 t= 0.41739999999998667 t= 0.41759999999998665 t= 0.4177999999999866 t= 0.4179999999999866 t= 0.4181999999999866 t= 0.41839999999998656 t= 0.41859999999998654 t= 0.4187999999999865 t= 0.4189999999999865 t= 0.4191999999999865 t= 0.41939999999998645 t= 0.41959999999998643 t= 0.4197999999999864 t= 0.4199999999999864 t= 0.42019999999998636 t= 0.42039999999998634 t= 0.4205999999999863 t= 0.4207999999999863 t= 0.4209999999999863 t= 0.42119999999998625 t= 0.42139999999998623 t= 0.4215999999999862 t= 0.4217999999999862 t= 0.42199999999998616 t= 0.42219999999998614 t= 0.4223999999999861 t= 0.4225999999999861 t= 0.4227999999999861 t= 0.42299999999998605 t= 0.42319999999998603 t= 0.423399999999986 t= 0.423599999999986 t= 0.42379999999998597 t= 0.42399999999998594 t= 0.4241999999999859 t= 0.4243999999999859 t= 0.4245999999999859 t= 0.42479999999998586 t= 0.42499999999998583 t= 0.4251999999999858 t= 0.4253999999999858 t= 0.42559999999998577 t= 0.42579999999998575 t= 0.4259999999999857 t= 0.4261999999999857 t= 0.4263999999999857 t= 0.42659999999998566 t= 0.42679999999998564 t= 0.4269999999999856 t= 0.4271999999999856 t= 0.42739999999998557 t= 0.42759999999998555 t= 0.4277999999999855 t= 0.4279999999999855 t= 0.4281999999999855 t= 0.42839999999998546 t= 0.42859999999998544 t= 0.4287999999999854 t= 0.4289999999999854 t= 0.42919999999998537 t= 0.42939999999998535 t= 0.4295999999999853 t= 0.4297999999999853 t= 0.4299999999999853 t= 0.43019999999998526 t= 0.43039999999998524 t= 0.4305999999999852 t= 0.4307999999999852 t= 0.4309999999999852 t= 0.43119999999998515 t= 0.43139999999998513 t= 0.4315999999999851 t= 0.4317999999999851 t= 0.43199999999998506 t= 0.43219999999998504 t= 0.432399999999985 t= 0.432599999999985 t= 0.432799999999985 t= 0.43299999999998495 t= 0.43319999999998493 t= 0.4333999999999849 t= 0.4335999999999849 t= 0.43379999999998486 t= 0.43399999999998484 t= 0.4341999999999848 t= 0.4343999999999848 t= 0.4345999999999848 t= 0.43479999999998475 t= 0.43499999999998473 t= 0.4351999999999847 t= 0.4353999999999847 t= 0.43559999999998467 t= 0.43579999999998464 t= 0.4359999999999846 t= 0.4361999999999846 t= 0.4363999999999846 t= 0.43659999999998456 t= 0.43679999999998453 t= 0.4369999999999845 t= 0.4371999999999845 t= 0.43739999999998447 t= 0.43759999999998445 t= 0.4377999999999844 t= 0.4379999999999844 t= 0.4381999999999844 t= 0.43839999999998436 t= 0.43859999999998434 t= 0.4387999999999843 t= 0.4389999999999843 t= 0.43919999999998427 t= 0.43939999999998425 t= 0.4395999999999842 t= 0.4397999999999842 t= 0.4399999999999842 t= 0.44019999999998416 t= 0.44039999999998414 t= 0.4405999999999841 t= 0.4407999999999841 t= 0.44099999999998407 t= 0.44119999999998405 t= 0.441399999999984 t= 0.441599999999984 t= 0.441799999999984 t= 0.44199999999998396 t= 0.44219999999998394 t= 0.4423999999999839 t= 0.4425999999999839 t= 0.4427999999999839 t= 0.44299999999998385 t= 0.44319999999998383 t= 0.4433999999999838 t= 0.4435999999999838 t= 0.44379999999998376 t= 0.44399999999998374 t= 0.4441999999999837 t= 0.4443999999999837 t= 0.4445999999999837 t= 0.44479999999998365 t= 0.44499999999998363 t= 0.4451999999999836 t= 0.4453999999999836 t= 0.44559999999998356 t= 0.44579999999998354 t= 0.4459999999999835 t= 0.4461999999999835 t= 0.4463999999999835 t= 0.44659999999998345 t= 0.44679999999998343 t= 0.4469999999999834 t= 0.4471999999999834 t= 0.44739999999998337 t= 0.44759999999998334 t= 0.4477999999999833 t= 0.4479999999999833 t= 0.4481999999999833 t= 0.44839999999998326 t= 0.44859999999998323 t= 0.4487999999999832 t= 0.4489999999999832 t= 0.44919999999998317 t= 0.44939999999998315 t= 0.4495999999999831 t= 0.4497999999999831 t= 0.4499999999999831 t= 0.45019999999998306 t= 0.45039999999998304 t= 0.450599999999983 t= 0.450799999999983 t= 0.45099999999998297 t= 0.45119999999998295 t= 0.4513999999999829 t= 0.4515999999999829 t= 0.4517999999999829 t= 0.45199999999998286 t= 0.45219999999998284 t= 0.4523999999999828 t= 0.4525999999999828 t= 0.45279999999998277 t= 0.45299999999998275 t= 0.45319999999998273 t= 0.4533999999999827 t= 0.4535999999999827 t= 0.45379999999998266 t= 0.45399999999998264 t= 0.4541999999999826 t= 0.4543999999999826 t= 0.4545999999999826 t= 0.45479999999998255 t= 0.45499999999998253 t= 0.4551999999999825 t= 0.4553999999999825 t= 0.45559999999998246 t= 0.45579999999998244 t= 0.4559999999999824 t= 0.4561999999999824 t= 0.4563999999999824 t= 0.45659999999998235 t= 0.45679999999998233 t= 0.4569999999999823 t= 0.4571999999999823 t= 0.45739999999998227 t= 0.45759999999998224 t= 0.4577999999999822 t= 0.4579999999999822 t= 0.4581999999999822 t= 0.45839999999998216 t= 0.45859999999998213 t= 0.4587999999999821 t= 0.4589999999999821 t= 0.45919999999998207 t= 0.45939999999998204 t= 0.459599999999982 t= 0.459799999999982 t= 0.459999999999982 t= 0.46019999999998196 t= 0.46039999999998193 t= 0.4605999999999819 t= 0.4607999999999819 t= 0.46099999999998187 t= 0.46119999999998185 t= 0.4613999999999818 t= 0.4615999999999818 t= 0.4617999999999818 t= 0.46199999999998176 t= 0.46219999999998174 t= 0.4623999999999817 t= 0.4625999999999817 t= 0.46279999999998167 t= 0.46299999999998165 t= 0.4631999999999816 t= 0.4633999999999816 t= 0.4635999999999816 t= 0.46379999999998156 t= 0.46399999999998154 t= 0.4641999999999815 t= 0.4643999999999815 t= 0.46459999999998147 t= 0.46479999999998145 t= 0.46499999999998143 t= 0.4651999999999814 t= 0.4653999999999814 t= 0.46559999999998136 t= 0.46579999999998134 t= 0.4659999999999813 t= 0.4661999999999813 t= 0.4663999999999813 t= 0.46659999999998125 t= 0.46679999999998123 t= 0.4669999999999812 t= 0.4671999999999812 t= 0.46739999999998116 t= 0.46759999999998114 t= 0.4677999999999811 t= 0.4679999999999811 t= 0.4681999999999811 t= 0.46839999999998105 t= 0.46859999999998103 t= 0.468799999999981 t= 0.468999999999981 t= 0.46919999999998097 t= 0.46939999999998094 t= 0.4695999999999809 t= 0.4697999999999809 t= 0.4699999999999809 t= 0.47019999999998086 t= 0.47039999999998083 t= 0.4705999999999808 t= 0.4707999999999808 t= 0.47099999999998077 t= 0.47119999999998075 t= 0.4713999999999807 t= 0.4715999999999807 t= 0.4717999999999807 t= 0.47199999999998066 t= 0.47219999999998064 t= 0.4723999999999806 t= 0.4725999999999806 t= 0.47279999999998057 t= 0.47299999999998055 t= 0.4731999999999805 t= 0.4733999999999805 t= 0.4735999999999805 t= 0.47379999999998046 t= 0.47399999999998044 t= 0.4741999999999804 t= 0.4743999999999804 t= 0.47459999999998037 t= 0.47479999999998035 t= 0.4749999999999803 t= 0.4751999999999803 t= 0.4753999999999803 t= 0.47559999999998026 t= 0.47579999999998024 t= 0.4759999999999802 t= 0.4761999999999802 t= 0.4763999999999802 t= 0.47659999999998015 t= 0.47679999999998013 t= 0.4769999999999801 t= 0.4771999999999801 t= 0.47739999999998006 t= 0.47759999999998004 t= 0.47779999999998 t= 0.47799999999998 t= 0.47819999999998 t= 0.47839999999997995 t= 0.47859999999997993 t= 0.4787999999999799 t= 0.4789999999999799 t= 0.47919999999997986 t= 0.47939999999997984 t= 0.4795999999999798 t= 0.4797999999999798 t= 0.4799999999999798 t= 0.48019999999997975 t= 0.48039999999997973 t= 0.4805999999999797 t= 0.4807999999999797 t= 0.48099999999997967 t= 0.48119999999997964 t= 0.4813999999999796 t= 0.4815999999999796 t= 0.4817999999999796 t= 0.48199999999997956 t= 0.48219999999997953 t= 0.4823999999999795 t= 0.4825999999999795 t= 0.48279999999997947 t= 0.48299999999997945 t= 0.4831999999999794 t= 0.4833999999999794 t= 0.4835999999999794 t= 0.48379999999997936 t= 0.48399999999997934 t= 0.4841999999999793 t= 0.4843999999999793 t= 0.48459999999997927 t= 0.48479999999997925 t= 0.4849999999999792 t= 0.4851999999999792 t= 0.4853999999999792 t= 0.48559999999997916 t= 0.48579999999997914 t= 0.4859999999999791 t= 0.4861999999999791 t= 0.48639999999997907 t= 0.48659999999997905 t= 0.486799999999979 t= 0.486999999999979 t= 0.487199999999979 t= 0.48739999999997896 t= 0.48759999999997894 t= 0.4877999999999789 t= 0.4879999999999789 t= 0.4881999999999789 t= 0.48839999999997885 t= 0.48859999999997883 t= 0.4887999999999788 t= 0.4889999999999788 t= 0.48919999999997876 t= 0.48939999999997874 t= 0.4895999999999787 t= 0.4897999999999787 t= 0.4899999999999787 t= 0.49019999999997865 t= 0.49039999999997863 t= 0.4905999999999786 t= 0.4907999999999786 t= 0.49099999999997856 t= 0.49119999999997854 t= 0.4913999999999785 t= 0.4915999999999785 t= 0.4917999999999785 t= 0.49199999999997845 t= 0.49219999999997843 t= 0.4923999999999784 t= 0.4925999999999784 t= 0.49279999999997837 t= 0.49299999999997834 t= 0.4931999999999783 t= 0.4933999999999783 t= 0.4935999999999783 t= 0.49379999999997826 t= 0.49399999999997823 t= 0.4941999999999782 t= 0.4943999999999782 t= 0.49459999999997817 t= 0.49479999999997815 t= 0.4949999999999781 t= 0.4951999999999781 t= 0.4953999999999781 t= 0.49559999999997806 t= 0.49579999999997804 t= 0.495999999999978 t= 0.496199999999978 t= 0.49639999999997797 t= 0.49659999999997795 t= 0.4967999999999779 t= 0.4969999999999779 t= 0.4971999999999779 t= 0.49739999999997786 t= 0.49759999999997784 t= 0.4977999999999778 t= 0.4979999999999778 t= 0.49819999999997777 t= 0.49839999999997775 t= 0.4985999999999777 t= 0.4987999999999777 t= 0.4989999999999777 t= 0.49919999999997766 t= 0.49939999999997764 t= 0.4995999999999776 t= 0.4997999999999776 t= 0.4999999999999776 t= 0.5001999999999776 t= 0.5003999999999775 t= 0.5005999999999775 t= 0.5007999999999775 t= 0.5009999999999775 t= 0.5011999999999774 t= 0.5013999999999774 t= 0.5015999999999774 t= 0.5017999999999774 t= 0.5019999999999774 t= 0.5021999999999773 t= 0.5023999999999773 t= 0.5025999999999773 t= 0.5027999999999773 t= 0.5029999999999772 t= 0.5031999999999772 t= 0.5033999999999772 t= 0.5035999999999772 t= 0.5037999999999772 t= 0.5039999999999771 t= 0.5041999999999771 t= 0.5043999999999771 t= 0.5045999999999771 t= 0.504799999999977 t= 0.504999999999977 t= 0.505199999999977 t= 0.505399999999977 t= 0.505599999999977 t= 0.5057999999999769 t= 0.5059999999999769 t= 0.5061999999999769 t= 0.5063999999999769 t= 0.5065999999999768 t= 0.5067999999999768 t= 0.5069999999999768 t= 0.5071999999999768 t= 0.5073999999999768 t= 0.5075999999999767 t= 0.5077999999999767 t= 0.5079999999999767 t= 0.5081999999999767 t= 0.5083999999999766 t= 0.5085999999999766 t= 0.5087999999999766 t= 0.5089999999999766 t= 0.5091999999999766 t= 0.5093999999999765 t= 0.5095999999999765 t= 0.5097999999999765 t= 0.5099999999999765 t= 0.5101999999999765 t= 0.5103999999999764 t= 0.5105999999999764 t= 0.5107999999999764 t= 0.5109999999999764 t= 0.5111999999999763 t= 0.5113999999999763 t= 0.5115999999999763 t= 0.5117999999999763 t= 0.5119999999999763 t= 0.5121999999999762 t= 0.5123999999999762 t= 0.5125999999999762 t= 0.5127999999999762 t= 0.5129999999999761 t= 0.5131999999999761 t= 0.5133999999999761 t= 0.5135999999999761 t= 0.513799999999976 t= 0.513999999999976 t= 0.514199999999976 t= 0.514399999999976 t= 0.514599999999976 t= 0.5147999999999759 t= 0.5149999999999759 t= 0.5151999999999759 t= 0.5153999999999759 t= 0.5155999999999759 t= 0.5157999999999758 t= 0.5159999999999758 t= 0.5161999999999758 t= 0.5163999999999758 t= 0.5165999999999757 t= 0.5167999999999757 t= 0.5169999999999757 t= 0.5171999999999757 t= 0.5173999999999757 t= 0.5175999999999756 t= 0.5177999999999756 t= 0.5179999999999756 t= 0.5181999999999756 t= 0.5183999999999755 t= 0.5185999999999755 t= 0.5187999999999755 t= 0.5189999999999755 t= 0.5191999999999755 t= 0.5193999999999754 t= 0.5195999999999754 t= 0.5197999999999754 t= 0.5199999999999754 t= 0.5201999999999753 t= 0.5203999999999753 t= 0.5205999999999753 t= 0.5207999999999753 t= 0.5209999999999753 t= 0.5211999999999752 t= 0.5213999999999752 t= 0.5215999999999752 t= 0.5217999999999752 t= 0.5219999999999752 t= 0.5221999999999751 t= 0.5223999999999751 t= 0.5225999999999751 t= 0.5227999999999751 t= 0.522999999999975 t= 0.523199999999975 t= 0.523399999999975 t= 0.523599999999975 t= 0.523799999999975 t= 0.5239999999999749 t= 0.5241999999999749 t= 0.5243999999999749 t= 0.5245999999999749 t= 0.5247999999999748 t= 0.5249999999999748 t= 0.5251999999999748 t= 0.5253999999999748 t= 0.5255999999999748 t= 0.5257999999999747 t= 0.5259999999999747 t= 0.5261999999999747 t= 0.5263999999999747 t= 0.5265999999999746 t= 0.5267999999999746 t= 0.5269999999999746 t= 0.5271999999999746 t= 0.5273999999999746 t= 0.5275999999999745 t= 0.5277999999999745 t= 0.5279999999999745 t= 0.5281999999999745 t= 0.5283999999999744 t= 0.5285999999999744 t= 0.5287999999999744 t= 0.5289999999999744 t= 0.5291999999999744 t= 0.5293999999999743 t= 0.5295999999999743 t= 0.5297999999999743 t= 0.5299999999999743 t= 0.5301999999999742 t= 0.5303999999999742 t= 0.5305999999999742 t= 0.5307999999999742 t= 0.5309999999999742 t= 0.5311999999999741 t= 0.5313999999999741 t= 0.5315999999999741 t= 0.5317999999999741 t= 0.531999999999974 t= 0.532199999999974 t= 0.532399999999974 t= 0.532599999999974 t= 0.532799999999974 t= 0.5329999999999739 t= 0.5331999999999739 t= 0.5333999999999739 t= 0.5335999999999739 t= 0.5337999999999739 t= 0.5339999999999738 t= 0.5341999999999738 t= 0.5343999999999738 t= 0.5345999999999738 t= 0.5347999999999737 t= 0.5349999999999737 t= 0.5351999999999737 t= 0.5353999999999737 t= 0.5355999999999737 t= 0.5357999999999736 t= 0.5359999999999736 t= 0.5361999999999736 t= 0.5363999999999736 t= 0.5365999999999735 t= 0.5367999999999735 t= 0.5369999999999735 t= 0.5371999999999735 t= 0.5373999999999735 t= 0.5375999999999734 t= 0.5377999999999734 t= 0.5379999999999734 t= 0.5381999999999734 t= 0.5383999999999733 t= 0.5385999999999733 t= 0.5387999999999733 t= 0.5389999999999733 t= 0.5391999999999733 t= 0.5393999999999732 t= 0.5395999999999732 t= 0.5397999999999732 t= 0.5399999999999732 t= 0.5401999999999731 t= 0.5403999999999731 t= 0.5405999999999731 t= 0.5407999999999731 t= 0.5409999999999731 t= 0.541199999999973 t= 0.541399999999973 t= 0.541599999999973 t= 0.541799999999973 t= 0.541999999999973 t= 0.5421999999999729 t= 0.5423999999999729 t= 0.5425999999999729 t= 0.5427999999999729 t= 0.5429999999999728 t= 0.5431999999999728 t= 0.5433999999999728 t= 0.5435999999999728 t= 0.5437999999999727 t= 0.5439999999999727 t= 0.5441999999999727 t= 0.5443999999999727 t= 0.5445999999999727 t= 0.5447999999999726 t= 0.5449999999999726 t= 0.5451999999999726 t= 0.5453999999999726 t= 0.5455999999999726 t= 0.5457999999999725 t= 0.5459999999999725 t= 0.5461999999999725 t= 0.5463999999999725 t= 0.5465999999999724 t= 0.5467999999999724 t= 0.5469999999999724 t= 0.5471999999999724 t= 0.5473999999999724 t= 0.5475999999999723 t= 0.5477999999999723 t= 0.5479999999999723 t= 0.5481999999999723 t= 0.5483999999999722 t= 0.5485999999999722 t= 0.5487999999999722 t= 0.5489999999999722 t= 0.5491999999999722 t= 0.5493999999999721 t= 0.5495999999999721 t= 0.5497999999999721 t= 0.5499999999999721 t= 0.550199999999972 t= 0.550399999999972 t= 0.550599999999972 t= 0.550799999999972 t= 0.550999999999972 t= 0.5511999999999719 t= 0.5513999999999719 t= 0.5515999999999719 t= 0.5517999999999719 t= 0.5519999999999718 t= 0.5521999999999718 t= 0.5523999999999718 t= 0.5525999999999718 t= 0.5527999999999718 t= 0.5529999999999717 t= 0.5531999999999717 t= 0.5533999999999717 t= 0.5535999999999717 t= 0.5537999999999716 t= 0.5539999999999716 t= 0.5541999999999716 t= 0.5543999999999716 t= 0.5545999999999716 t= 0.5547999999999715 t= 0.5549999999999715 t= 0.5551999999999715 t= 0.5553999999999715 t= 0.5555999999999715 t= 0.5557999999999714 t= 0.5559999999999714 t= 0.5561999999999714 t= 0.5563999999999714 t= 0.5565999999999713 t= 0.5567999999999713 t= 0.5569999999999713 t= 0.5571999999999713 t= 0.5573999999999713 t= 0.5575999999999712 t= 0.5577999999999712 t= 0.5579999999999712 t= 0.5581999999999712 t= 0.5583999999999711 t= 0.5585999999999711 t= 0.5587999999999711 t= 0.5589999999999711 t= 0.559199999999971 t= 0.559399999999971 t= 0.559599999999971 t= 0.559799999999971 t= 0.559999999999971 t= 0.5601999999999709 t= 0.5603999999999709 t= 0.5605999999999709 t= 0.5607999999999709 t= 0.5609999999999709 t= 0.5611999999999708 t= 0.5613999999999708 t= 0.5615999999999708 t= 0.5617999999999708 t= 0.5619999999999707 t= 0.5621999999999707 t= 0.5623999999999707 t= 0.5625999999999707 t= 0.5627999999999707 t= 0.5629999999999706 t= 0.5631999999999706 t= 0.5633999999999706 t= 0.5635999999999706 t= 0.5637999999999705 t= 0.5639999999999705 t= 0.5641999999999705 t= 0.5643999999999705 t= 0.5645999999999705 t= 0.5647999999999704 t= 0.5649999999999704 t= 0.5651999999999704 t= 0.5653999999999704 t= 0.5655999999999703 t= 0.5657999999999703 t= 0.5659999999999703 t= 0.5661999999999703 t= 0.5663999999999703 t= 0.5665999999999702 t= 0.5667999999999702 t= 0.5669999999999702 t= 0.5671999999999702 t= 0.5673999999999702 t= 0.5675999999999701 t= 0.5677999999999701 t= 0.5679999999999701 t= 0.5681999999999701 t= 0.56839999999997 t= 0.56859999999997 t= 0.56879999999997 t= 0.56899999999997 t= 0.56919999999997 t= 0.5693999999999699 t= 0.5695999999999699 t= 0.5697999999999699 t= 0.5699999999999699 t= 0.5701999999999698 t= 0.5703999999999698 t= 0.5705999999999698 t= 0.5707999999999698 t= 0.5709999999999698 t= 0.5711999999999697 t= 0.5713999999999697 t= 0.5715999999999697 t= 0.5717999999999697 t= 0.5719999999999696 t= 0.5721999999999696 t= 0.5723999999999696 t= 0.5725999999999696 t= 0.5727999999999696 t= 0.5729999999999695 t= 0.5731999999999695 t= 0.5733999999999695 t= 0.5735999999999695 t= 0.5737999999999694 t= 0.5739999999999694 t= 0.5741999999999694 t= 0.5743999999999694 t= 0.5745999999999694 t= 0.5747999999999693 t= 0.5749999999999693 t= 0.5751999999999693 t= 0.5753999999999693 t= 0.5755999999999692 t= 0.5757999999999692 t= 0.5759999999999692 t= 0.5761999999999692 t= 0.5763999999999692 t= 0.5765999999999691 t= 0.5767999999999691 t= 0.5769999999999691 t= 0.5771999999999691 t= 0.577399999999969 t= 0.577599999999969 t= 0.577799999999969 t= 0.577999999999969 t= 0.578199999999969 t= 0.5783999999999689 t= 0.5785999999999689 t= 0.5787999999999689 t= 0.5789999999999689 t= 0.5791999999999689 t= 0.5793999999999688 t= 0.5795999999999688 t= 0.5797999999999688 t= 0.5799999999999688 t= 0.5801999999999687 t= 0.5803999999999687 t= 0.5805999999999687 t= 0.5807999999999687 t= 0.5809999999999687 t= 0.5811999999999686 t= 0.5813999999999686 t= 0.5815999999999686 t= 0.5817999999999686 t= 0.5819999999999685 t= 0.5821999999999685 t= 0.5823999999999685 t= 0.5825999999999685 t= 0.5827999999999685 t= 0.5829999999999684 t= 0.5831999999999684 t= 0.5833999999999684 t= 0.5835999999999684 t= 0.5837999999999683 t= 0.5839999999999683 t= 0.5841999999999683 t= 0.5843999999999683 t= 0.5845999999999683 t= 0.5847999999999682 t= 0.5849999999999682 t= 0.5851999999999682 t= 0.5853999999999682 t= 0.5855999999999681 t= 0.5857999999999681 t= 0.5859999999999681 t= 0.5861999999999681 t= 0.5863999999999681 t= 0.586599999999968 t= 0.586799999999968 t= 0.586999999999968 t= 0.587199999999968 t= 0.587399999999968 t= 0.5875999999999679 t= 0.5877999999999679 t= 0.5879999999999679 t= 0.5881999999999679 t= 0.5883999999999678 t= 0.5885999999999678 t= 0.5887999999999678 t= 0.5889999999999678 t= 0.5891999999999677 t= 0.5893999999999677 t= 0.5895999999999677 t= 0.5897999999999677 t= 0.5899999999999677 t= 0.5901999999999676 t= 0.5903999999999676 t= 0.5905999999999676 t= 0.5907999999999676 t= 0.5909999999999676 t= 0.5911999999999675 t= 0.5913999999999675 t= 0.5915999999999675 t= 0.5917999999999675 t= 0.5919999999999674 t= 0.5921999999999674 t= 0.5923999999999674 t= 0.5925999999999674 t= 0.5927999999999674 t= 0.5929999999999673 t= 0.5931999999999673 t= 0.5933999999999673 t= 0.5935999999999673 t= 0.5937999999999672 t= 0.5939999999999672 t= 0.5941999999999672 t= 0.5943999999999672 t= 0.5945999999999672 t= 0.5947999999999671 t= 0.5949999999999671 t= 0.5951999999999671 t= 0.5953999999999671 t= 0.595599999999967 t= 0.595799999999967 t= 0.595999999999967 t= 0.596199999999967 t= 0.596399999999967 t= 0.5965999999999669 t= 0.5967999999999669 t= 0.5969999999999669 t= 0.5971999999999669 t= 0.5973999999999668 t= 0.5975999999999668 t= 0.5977999999999668 t= 0.5979999999999668 t= 0.5981999999999668 t= 0.5983999999999667 t= 0.5985999999999667 t= 0.5987999999999667 t= 0.5989999999999667 t= 0.5991999999999666 t= 0.5993999999999666 t= 0.5995999999999666 t= 0.5997999999999666 t= 0.5999999999999666CPU times: user 7.21 s, sys: 739 ms, total: 7.95 s
Wall time: 1.98 s </pre>
t= 0.0002 t= 0.0004 t= 0.0006000000000000001 t= 0.0008 t= 0.001 t= 0.0012000000000000001 t= 0.0014000000000000002 t= 0.0016000000000000003 t= 0.0018000000000000004 t= 0.0020000000000000005 t= 0.0022000000000000006 t= 0.0024000000000000007 t= 0.0026000000000000007 t= 0.002800000000000001 t= 0.003000000000000001 t= 0.003200000000000001 t= 0.003400000000000001 t= 0.003600000000000001 t= 0.0038000000000000013 t= 0.004000000000000001 t= 0.004200000000000001 t= 0.0044 t= 0.0046 t= 0.0048 t= 0.004999999999999999 t= 0.005199999999999999 t= 0.0053999999999999986 t= 0.005599999999999998 t= 0.005799999999999998 t= 0.0059999999999999975 t= 0.006199999999999997 t= 0.006399999999999997 t= 0.0065999999999999965 t= 0.006799999999999996 t= 0.006999999999999996 t= 0.0071999999999999955 t= 0.007399999999999995 t= 0.007599999999999995 t= 0.0077999999999999944 t= 0.007999999999999995 t= 0.008199999999999995 t= 0.008399999999999996 t= 0.008599999999999997 t= 0.008799999999999997 t= 0.008999999999999998 t= 0.009199999999999998 t= 0.009399999999999999 t= 0.0096 t= 0.0098 t= 0.01 t= 0.0102 t= 0.010400000000000001 t= 0.010600000000000002 t= 0.010800000000000002 t= 0.011000000000000003 t= 0.011200000000000003 t= 0.011400000000000004 t= 0.011600000000000004 t= 0.011800000000000005 t= 0.012000000000000005 t= 0.012200000000000006 t= 0.012400000000000007 t= 0.012600000000000007 t= 0.012800000000000008 t= 0.013000000000000008 t= 0.013200000000000009 t= 0.013400000000000009 t= 0.01360000000000001 t= 0.01380000000000001 t= 0.01400000000000001 t= 0.014200000000000011 t= 0.014400000000000012 t= 0.014600000000000012 t= 0.014800000000000013 t= 0.015000000000000013 t= 0.015200000000000014 t= 0.015400000000000014 t= 0.015600000000000015 t= 0.015800000000000015 t= 0.016000000000000014 t= 0.016200000000000013 t= 0.016400000000000012 t= 0.01660000000000001 t= 0.01680000000000001 t= 0.017000000000000008 t= 0.017200000000000007 t= 0.017400000000000006 t= 0.017600000000000005 t= 0.017800000000000003 t= 0.018000000000000002 t= 0.0182 t= 0.0184 t= 0.0186 t= 0.018799999999999997 t= 0.018999999999999996 t= 0.019199999999999995 t= 0.019399999999999994 t= 0.019599999999999992 t= 0.01979999999999999 t= 0.01999999999999999 t= 0.02019999999999999 t= 0.020399999999999988 t= 0.020599999999999986 t= 0.020799999999999985 t= 0.020999999999999984 t= 0.021199999999999983 t= 0.02139999999999998 t= 0.02159999999999998 t= 0.02179999999999998 t= 0.021999999999999978 t= 0.022199999999999977 t= 0.022399999999999975 t= 0.022599999999999974 t= 0.022799999999999973 t= 0.022999999999999972 t= 0.02319999999999997 t= 0.02339999999999997 t= 0.023599999999999968 t= 0.023799999999999967 t= 0.023999999999999966 t= 0.024199999999999965 t= 0.024399999999999963 t= 0.024599999999999962 t= 0.02479999999999996 t= 0.02499999999999996 t= 0.02519999999999996 t= 0.025399999999999957 t= 0.025599999999999956 t= 0.025799999999999955 t= 0.025999999999999954 t= 0.026199999999999952 t= 0.02639999999999995 t= 0.02659999999999995 t= 0.02679999999999995 t= 0.026999999999999948 t= 0.027199999999999946 t= 0.027399999999999945 t= 0.027599999999999944 t= 0.027799999999999943 t= 0.02799999999999994 t= 0.02819999999999994 t= 0.02839999999999994 t= 0.028599999999999938 t= 0.028799999999999937 t= 0.028999999999999936 t= 0.029199999999999934 t= 0.029399999999999933 t= 0.029599999999999932 t= 0.02979999999999993 t= 0.02999999999999993 t= 0.03019999999999993 t= 0.030399999999999927 t= 0.030599999999999926 t= 0.030799999999999925 t= 0.030999999999999923 t= 0.031199999999999922 t= 0.03139999999999992 t= 0.03159999999999992 t= 0.03179999999999992 t= 0.03199999999999992 t= 0.032199999999999916 t= 0.032399999999999915 t= 0.032599999999999914 t= 0.03279999999999991 t= 0.03299999999999991 t= 0.03319999999999991 t= 0.03339999999999991 t= 0.03359999999999991 t= 0.033799999999999907 t= 0.033999999999999905 t= 0.034199999999999904 t= 0.0343999999999999 t= 0.0345999999999999 t= 0.0347999999999999 t= 0.0349999999999999 t= 0.0351999999999999 t= 0.0353999999999999 t= 0.035599999999999896 t= 0.035799999999999894 t= 0.03599999999999989 t= 0.03619999999999989 t= 0.03639999999999989 t= 0.03659999999999989 t= 0.03679999999999989 t= 0.03699999999999989 t= 0.037199999999999886 t= 0.037399999999999885 t= 0.037599999999999884 t= 0.03779999999999988 t= 0.03799999999999988 t= 0.03819999999999988 t= 0.03839999999999988 t= 0.03859999999999988 t= 0.038799999999999876 t= 0.038999999999999875 t= 0.039199999999999874 t= 0.03939999999999987 t= 0.03959999999999987 t= 0.03979999999999987 t= 0.03999999999999987 t= 0.04019999999999987 t= 0.04039999999999987 t= 0.040599999999999865 t= 0.040799999999999864 t= 0.04099999999999986 t= 0.04119999999999986 t= 0.04139999999999986 t= 0.04159999999999986 t= 0.04179999999999986 t= 0.04199999999999986 t= 0.042199999999999856 t= 0.042399999999999854 t= 0.04259999999999985 t= 0.04279999999999985 t= 0.04299999999999985 t= 0.04319999999999985 t= 0.04339999999999985 t= 0.04359999999999985 t= 0.043799999999999846 t= 0.043999999999999845 t= 0.044199999999999844 t= 0.04439999999999984 t= 0.04459999999999984 t= 0.04479999999999984 t= 0.04499999999999984 t= 0.04519999999999984 t= 0.045399999999999836 t= 0.045599999999999835 t= 0.045799999999999834 t= 0.04599999999999983 t= 0.04619999999999983 t= 0.04639999999999983 t= 0.04659999999999983 t= 0.04679999999999983 t= 0.04699999999999983 t= 0.047199999999999825 t= 0.047399999999999824 t= 0.04759999999999982 t= 0.04779999999999982 t= 0.04799999999999982 t= 0.04819999999999982 t= 0.04839999999999982 t= 0.04859999999999982 t= 0.048799999999999816 t= 0.048999999999999815 t= 0.04919999999999981 t= 0.04939999999999981 t= 0.04959999999999981 t= 0.04979999999999981 t= 0.04999999999999981 t= 0.05019999999999981 t= 0.050399999999999806 t= 0.050599999999999805 t= 0.050799999999999804 t= 0.0509999999999998 t= 0.0511999999999998 t= 0.0513999999999998 t= 0.0515999999999998 t= 0.0517999999999998 t= 0.051999999999999796 t= 0.052199999999999795 t= 0.052399999999999794 t= 0.05259999999999979 t= 0.05279999999999979 t= 0.05299999999999979 t= 0.05319999999999979 t= 0.05339999999999979 t= 0.05359999999999979 t= 0.053799999999999785 t= 0.053999999999999784 t= 0.05419999999999978 t= 0.05439999999999978 t= 0.05459999999999978 t= 0.05479999999999978 t= 0.05499999999999978 t= 0.05519999999999978 t= 0.055399999999999776 t= 0.055599999999999775 t= 0.05579999999999977 t= 0.05599999999999977 t= 0.05619999999999977 t= 0.05639999999999977 t= 0.05659999999999977 t= 0.05679999999999977 t= 0.056999999999999766 t= 0.057199999999999765 t= 0.057399999999999764 t= 0.05759999999999976 t= 0.05779999999999976 t= 0.05799999999999976 t= 0.05819999999999976 t= 0.05839999999999976 t= 0.058599999999999756 t= 0.058799999999999755 t= 0.058999999999999754 t= 0.05919999999999975 t= 0.05939999999999975 t= 0.05959999999999975 t= 0.05979999999999975 t= 0.05999999999999975 t= 0.06019999999999975 t= 0.060399999999999746 t= 0.060599999999999744 t= 0.06079999999999974 t= 0.06099999999999974 t= 0.06119999999999974 t= 0.06139999999999974 t= 0.06159999999999974 t= 0.06179999999999974 t= 0.061999999999999736 t= 0.062199999999999735 t= 0.06239999999999973 t= 0.06259999999999974 t= 0.06279999999999974 t= 0.06299999999999975 t= 0.06319999999999976 t= 0.06339999999999976 t= 0.06359999999999977 t= 0.06379999999999977 t= 0.06399999999999978 t= 0.06419999999999979 t= 0.06439999999999979 t= 0.0645999999999998 t= 0.0647999999999998 t= 0.06499999999999981 t= 0.06519999999999981 t= 0.06539999999999982 t= 0.06559999999999983 t= 0.06579999999999983 t= 0.06599999999999984 t= 0.06619999999999984 t= 0.06639999999999985 t= 0.06659999999999985 t= 0.06679999999999986 t= 0.06699999999999987 t= 0.06719999999999987 t= 0.06739999999999988 t= 0.06759999999999988 t= 0.06779999999999989 t= 0.0679999999999999 t= 0.0681999999999999 t= 0.0683999999999999 t= 0.06859999999999991 t= 0.06879999999999992 t= 0.06899999999999992 t= 0.06919999999999993 t= 0.06939999999999993 t= 0.06959999999999994 t= 0.06979999999999995 t= 0.06999999999999995 t= 0.07019999999999996 t= 0.07039999999999996 t= 0.07059999999999997 t= 0.07079999999999997 t= 0.07099999999999998 t= 0.07119999999999999 t= 0.07139999999999999 t= 0.0716 t= 0.0718 t= 0.07200000000000001 t= 0.07220000000000001 t= 0.07240000000000002 t= 0.07260000000000003 t= 0.07280000000000003 t= 0.07300000000000004 t= 0.07320000000000004 t= 0.07340000000000005 t= 0.07360000000000005 t= 0.07380000000000006 t= 0.07400000000000007 t= 0.07420000000000007 t= 0.07440000000000008 t= 0.07460000000000008 t= 0.07480000000000009 t= 0.0750000000000001 t= 0.0752000000000001 t= 0.0754000000000001 t= 0.07560000000000011 t= 0.07580000000000012 t= 0.07600000000000012 t= 0.07620000000000013 t= 0.07640000000000013 t= 0.07660000000000014 t= 0.07680000000000015 t= 0.07700000000000015 t= 0.07720000000000016 t= 0.07740000000000016 t= 0.07760000000000017 t= 0.07780000000000017 t= 0.07800000000000018 t= 0.07820000000000019 t= 0.07840000000000019 t= 0.0786000000000002 t= 0.0788000000000002 t= 0.07900000000000021 t= 0.07920000000000021 t= 0.07940000000000022 t= 0.07960000000000023 t= 0.07980000000000023 t= 0.08000000000000024 t= 0.08020000000000024 t= 0.08040000000000025 t= 0.08060000000000025 t= 0.08080000000000026 t= 0.08100000000000027 t= 0.08120000000000027 t= 0.08140000000000028 t= 0.08160000000000028 t= 0.08180000000000029 t= 0.0820000000000003 t= 0.0822000000000003 t= 0.0824000000000003 t= 0.08260000000000031 t= 0.08280000000000032 t= 0.08300000000000032 t= 0.08320000000000033 t= 0.08340000000000033 t= 0.08360000000000034 t= 0.08380000000000035 t= 0.08400000000000035 t= 0.08420000000000036 t= 0.08440000000000036 t= 0.08460000000000037 t= 0.08480000000000038 t= 0.08500000000000038 t= 0.08520000000000039 t= 0.08540000000000039 t= 0.0856000000000004 t= 0.0858000000000004 t= 0.08600000000000041 t= 0.08620000000000042 t= 0.08640000000000042 t= 0.08660000000000043 t= 0.08680000000000043 t= 0.08700000000000044 t= 0.08720000000000044 t= 0.08740000000000045 t= 0.08760000000000046 t= 0.08780000000000046 t= 0.08800000000000047 t= 0.08820000000000047 t= 0.08840000000000048 t= 0.08860000000000048 t= 0.08880000000000049 t= 0.0890000000000005 t= 0.0892000000000005 t= 0.0894000000000005 t= 0.08960000000000051 t= 0.08980000000000052 t= 0.09000000000000052 t= 0.09020000000000053 t= 0.09040000000000054 t= 0.09060000000000054 t= 0.09080000000000055 t= 0.09100000000000055 t= 0.09120000000000056 t= 0.09140000000000056 t= 0.09160000000000057 t= 0.09180000000000058 t= 0.09200000000000058 t= 0.09220000000000059 t= 0.09240000000000059 t= 0.0926000000000006 t= 0.0928000000000006 t= 0.09300000000000061 t= 0.09320000000000062 t= 0.09340000000000062 t= 0.09360000000000063 t= 0.09380000000000063 t= 0.09400000000000064 t= 0.09420000000000064 t= 0.09440000000000065 t= 0.09460000000000066 t= 0.09480000000000066 t= 0.09500000000000067 t= 0.09520000000000067 t= 0.09540000000000068 t= 0.09560000000000068 t= 0.09580000000000069 t= 0.0960000000000007 t= 0.0962000000000007 t= 0.09640000000000071 t= 0.09660000000000071 t= 0.09680000000000072 t= 0.09700000000000072 t= 0.09720000000000073 t= 0.09740000000000074 t= 0.09760000000000074 t= 0.09780000000000075 t= 0.09800000000000075 t= 0.09820000000000076 t= 0.09840000000000076 t= 0.09860000000000077 t= 0.09880000000000078 t= 0.09900000000000078 t= 0.09920000000000079 t= 0.0994000000000008 t= 0.0996000000000008 t= 0.0998000000000008 t= 0.10000000000000081 t= 0.10020000000000082 t= 0.10040000000000082 t= 0.10060000000000083 t= 0.10080000000000083 t= 0.10100000000000084 t= 0.10120000000000084 t= 0.10140000000000085 t= 0.10160000000000086 t= 0.10180000000000086 t= 0.10200000000000087 t= 0.10220000000000087 t= 0.10240000000000088 t= 0.10260000000000088 t= 0.10280000000000089 t= 0.1030000000000009 t= 0.1032000000000009 t= 0.10340000000000091 t= 0.10360000000000091 t= 0.10380000000000092 t= 0.10400000000000093 t= 0.10420000000000093 t= 0.10440000000000094 t= 0.10460000000000094 t= 0.10480000000000095 t= 0.10500000000000095 t= 0.10520000000000096 t= 0.10540000000000097 t= 0.10560000000000097 t= 0.10580000000000098 t= 0.10600000000000098 t= 0.10620000000000099 t= 0.106400000000001 t= 0.106600000000001 t= 0.106800000000001 t= 0.10700000000000101 t= 0.10720000000000102 t= 0.10740000000000102 t= 0.10760000000000103 t= 0.10780000000000103 t= 0.10800000000000104 t= 0.10820000000000105 t= 0.10840000000000105 t= 0.10860000000000106 t= 0.10880000000000106 t= 0.10900000000000107 t= 0.10920000000000107 t= 0.10940000000000108 t= 0.10960000000000109 t= 0.10980000000000109 t= 0.1100000000000011 t= 0.1102000000000011 t= 0.11040000000000111 t= 0.11060000000000111 t= 0.11080000000000112 t= 0.11100000000000113 t= 0.11120000000000113 t= 0.11140000000000114 t= 0.11160000000000114 t= 0.11180000000000115 t= 0.11200000000000115 t= 0.11220000000000116 t= 0.11240000000000117 t= 0.11260000000000117 t= 0.11280000000000118 t= 0.11300000000000118 t= 0.11320000000000119 t= 0.1134000000000012 t= 0.1136000000000012 t= 0.1138000000000012 t= 0.11400000000000121 t= 0.11420000000000122 t= 0.11440000000000122 t= 0.11460000000000123 t= 0.11480000000000123 t= 0.11500000000000124 t= 0.11520000000000125 t= 0.11540000000000125 t= 0.11560000000000126 t= 0.11580000000000126 t= 0.11600000000000127 t= 0.11620000000000127 t= 0.11640000000000128 t= 0.11660000000000129 t= 0.11680000000000129 t= 0.1170000000000013 t= 0.1172000000000013 t= 0.11740000000000131 t= 0.11760000000000131 t= 0.11780000000000132 t= 0.11800000000000133 t= 0.11820000000000133 t= 0.11840000000000134 t= 0.11860000000000134 t= 0.11880000000000135 t= 0.11900000000000135 t= 0.11920000000000136 t= 0.11940000000000137 t= 0.11960000000000137 t= 0.11980000000000138 t= 0.12000000000000138 t= 0.12020000000000139 t= 0.1204000000000014 t= 0.1206000000000014 t= 0.1208000000000014 t= 0.12100000000000141 t= 0.12120000000000142 t= 0.12140000000000142 t= 0.12160000000000143 t= 0.12180000000000143 t= 0.12200000000000144 t= 0.12220000000000145 t= 0.12240000000000145 t= 0.12260000000000146 t= 0.12280000000000146 t= 0.12300000000000147 t= 0.12320000000000147 t= 0.12340000000000148 t= 0.12360000000000149 t= 0.12380000000000149 t= 0.1240000000000015 t= 0.1242000000000015 t= 0.12440000000000151 t= 0.12460000000000152 t= 0.12480000000000152 t= 0.12500000000000153 t= 0.12520000000000153 t= 0.12540000000000154 t= 0.12560000000000154 t= 0.12580000000000155 t= 0.12600000000000156 t= 0.12620000000000156 t= 0.12640000000000157 t= 0.12660000000000157 t= 0.12680000000000158 t= 0.12700000000000158 t= 0.1272000000000016 t= 0.1274000000000016 t= 0.1276000000000016 t= 0.1278000000000016 t= 0.1280000000000016 t= 0.12820000000000162 t= 0.12840000000000162 t= 0.12860000000000163 t= 0.12880000000000164 t= 0.12900000000000164 t= 0.12920000000000165 t= 0.12940000000000165 t= 0.12960000000000166 t= 0.12980000000000166 t= 0.13000000000000167 t= 0.13020000000000168 t= 0.13040000000000168 t= 0.1306000000000017 t= 0.1308000000000017 t= 0.1310000000000017 t= 0.1312000000000017 t= 0.1314000000000017 t= 0.13160000000000172 t= 0.13180000000000172 t= 0.13200000000000173 t= 0.13220000000000173 t= 0.13240000000000174 t= 0.13260000000000174 t= 0.13280000000000175 t= 0.13300000000000176 t= 0.13320000000000176 t= 0.13340000000000177 t= 0.13360000000000177 t= 0.13380000000000178 t= 0.13400000000000178 t= 0.1342000000000018 t= 0.1344000000000018 t= 0.1346000000000018 t= 0.1348000000000018 t= 0.1350000000000018 t= 0.13520000000000182 t= 0.13540000000000182 t= 0.13560000000000183 t= 0.13580000000000184 t= 0.13600000000000184 t= 0.13620000000000185 t= 0.13640000000000185 t= 0.13660000000000186 t= 0.13680000000000186 t= 0.13700000000000187 t= 0.13720000000000188 t= 0.13740000000000188 t= 0.1376000000000019 t= 0.1378000000000019 t= 0.1380000000000019 t= 0.1382000000000019 t= 0.1384000000000019 t= 0.13860000000000192 t= 0.13880000000000192 t= 0.13900000000000193 t= 0.13920000000000193 t= 0.13940000000000194 t= 0.13960000000000194 t= 0.13980000000000195 t= 0.14000000000000196 t= 0.14020000000000196 t= 0.14040000000000197 t= 0.14060000000000197 t= 0.14080000000000198 t= 0.14100000000000198 t= 0.141200000000002 t= 0.141400000000002 t= 0.141600000000002 t= 0.141800000000002 t= 0.142000000000002 t= 0.14220000000000202 t= 0.14240000000000202 t= 0.14260000000000203 t= 0.14280000000000204 t= 0.14300000000000204 t= 0.14320000000000205 t= 0.14340000000000205 t= 0.14360000000000206 t= 0.14380000000000207 t= 0.14400000000000207 t= 0.14420000000000208 t= 0.14440000000000208 t= 0.1446000000000021 t= 0.1448000000000021 t= 0.1450000000000021 t= 0.1452000000000021 t= 0.1454000000000021 t= 0.14560000000000212 t= 0.14580000000000212 t= 0.14600000000000213 t= 0.14620000000000213 t= 0.14640000000000214 t= 0.14660000000000215 t= 0.14680000000000215 t= 0.14700000000000216 t= 0.14720000000000216 t= 0.14740000000000217 t= 0.14760000000000217 t= 0.14780000000000218 t= 0.14800000000000219 t= 0.1482000000000022 t= 0.1484000000000022 t= 0.1486000000000022 t= 0.1488000000000022 t= 0.14900000000000221 t= 0.14920000000000222 t= 0.14940000000000223 t= 0.14960000000000223 t= 0.14980000000000224 t= 0.15000000000000224 t= 0.15020000000000225 t= 0.15040000000000225 t= 0.15060000000000226 t= 0.15080000000000227 t= 0.15100000000000227 t= 0.15120000000000228 t= 0.15140000000000228 t= 0.1516000000000023 t= 0.1518000000000023 t= 0.1520000000000023 t= 0.1522000000000023 t= 0.1524000000000023 t= 0.15260000000000232 t= 0.15280000000000232 t= 0.15300000000000233 t= 0.15320000000000233 t= 0.15340000000000234 t= 0.15360000000000235 t= 0.15380000000000235 t= 0.15400000000000236 t= 0.15420000000000236 t= 0.15440000000000237 t= 0.15460000000000237 t= 0.15480000000000238 t= 0.15500000000000239 t= 0.1552000000000024 t= 0.1554000000000024 t= 0.1556000000000024 t= 0.1558000000000024 t= 0.15600000000000241 t= 0.15620000000000242 t= 0.15640000000000243 t= 0.15660000000000243 t= 0.15680000000000244 t= 0.15700000000000244 t= 0.15720000000000245 t= 0.15740000000000245 t= 0.15760000000000246 t= 0.15780000000000247 t= 0.15800000000000247 t= 0.15820000000000248 t= 0.15840000000000248 t= 0.1586000000000025 t= 0.1588000000000025 t= 0.1590000000000025 t= 0.1592000000000025 t= 0.1594000000000025 t= 0.15960000000000252 t= 0.15980000000000252 t= 0.16000000000000253 t= 0.16020000000000253 t= 0.16040000000000254 t= 0.16060000000000255 t= 0.16080000000000255 t= 0.16100000000000256 t= 0.16120000000000256 t= 0.16140000000000257 t= 0.16160000000000257 t= 0.16180000000000258 t= 0.1620000000000026 t= 0.1622000000000026 t= 0.1624000000000026 t= 0.1626000000000026 t= 0.1628000000000026 t= 0.16300000000000262 t= 0.16320000000000262 t= 0.16340000000000263 t= 0.16360000000000263 t= 0.16380000000000264 t= 0.16400000000000264 t= 0.16420000000000265 t= 0.16440000000000266 t= 0.16460000000000266 t= 0.16480000000000267 t= 0.16500000000000267 t= 0.16520000000000268 t= 0.16540000000000268 t= 0.1656000000000027 t= 0.1658000000000027 t= 0.1660000000000027 t= 0.1662000000000027 t= 0.1664000000000027 t= 0.16660000000000272 t= 0.16680000000000272 t= 0.16700000000000273 t= 0.16720000000000274 t= 0.16740000000000274 t= 0.16760000000000275 t= 0.16780000000000275 t= 0.16800000000000276 t= 0.16820000000000276 t= 0.16840000000000277 t= 0.16860000000000278 t= 0.16880000000000278 t= 0.1690000000000028 t= 0.1692000000000028 t= 0.1694000000000028 t= 0.1696000000000028 t= 0.1698000000000028 t= 0.17000000000000282 t= 0.17020000000000282 t= 0.17040000000000283 t= 0.17060000000000283 t= 0.17080000000000284 t= 0.17100000000000284 t= 0.17120000000000285 t= 0.17140000000000286 t= 0.17160000000000286 t= 0.17180000000000287 t= 0.17200000000000287 t= 0.17220000000000288 t= 0.17240000000000288 t= 0.1726000000000029 t= 0.1728000000000029 t= 0.1730000000000029 t= 0.1732000000000029 t= 0.1734000000000029 t= 0.17360000000000292 t= 0.17380000000000292 t= 0.17400000000000293 t= 0.17420000000000294 t= 0.17440000000000294 t= 0.17460000000000295 t= 0.17480000000000295 t= 0.17500000000000296 t= 0.17520000000000296 t= 0.17540000000000297 t= 0.17560000000000298 t= 0.17580000000000298 t= 0.176000000000003 t= 0.176200000000003 t= 0.176400000000003 t= 0.176600000000003 t= 0.176800000000003 t= 0.17700000000000302 t= 0.17720000000000302 t= 0.17740000000000303 t= 0.17760000000000303 t= 0.17780000000000304 t= 0.17800000000000304 t= 0.17820000000000305 t= 0.17840000000000306 t= 0.17860000000000306 t= 0.17880000000000307 t= 0.17900000000000307 t= 0.17920000000000308 t= 0.17940000000000308 t= 0.1796000000000031 t= 0.1798000000000031 t= 0.1800000000000031 t= 0.1802000000000031 t= 0.1804000000000031 t= 0.18060000000000312 t= 0.18080000000000312 t= 0.18100000000000313 t= 0.18120000000000314 t= 0.18140000000000314 t= 0.18160000000000315 t= 0.18180000000000315 t= 0.18200000000000316 t= 0.18220000000000316 t= 0.18240000000000317 t= 0.18260000000000318 t= 0.18280000000000318 t= 0.1830000000000032 t= 0.1832000000000032 t= 0.1834000000000032 t= 0.1836000000000032 t= 0.1838000000000032 t= 0.18400000000000322 t= 0.18420000000000322 t= 0.18440000000000323 t= 0.18460000000000323 t= 0.18480000000000324 t= 0.18500000000000325 t= 0.18520000000000325 t= 0.18540000000000326 t= 0.18560000000000326 t= 0.18580000000000327 t= 0.18600000000000327 t= 0.18620000000000328 t= 0.18640000000000329 t= 0.1866000000000033 t= 0.1868000000000033 t= 0.1870000000000033 t= 0.1872000000000033 t= 0.18740000000000331 t= 0.18760000000000332 t= 0.18780000000000333 t= 0.18800000000000333 t= 0.18820000000000334 t= 0.18840000000000334 t= 0.18860000000000335 t= 0.18880000000000335 t= 0.18900000000000336 t= 0.18920000000000337 t= 0.18940000000000337 t= 0.18960000000000338 t= 0.18980000000000338 t= 0.1900000000000034 t= 0.1902000000000034 t= 0.1904000000000034 t= 0.1906000000000034 t= 0.1908000000000034 t= 0.19100000000000342 t= 0.19120000000000342 t= 0.19140000000000343 t= 0.19160000000000343 t= 0.19180000000000344 t= 0.19200000000000345 t= 0.19220000000000345 t= 0.19240000000000346 t= 0.19260000000000346 t= 0.19280000000000347 t= 0.19300000000000347 t= 0.19320000000000348 t= 0.19340000000000349 t= 0.1936000000000035 t= 0.1938000000000035 t= 0.1940000000000035 t= 0.1942000000000035 t= 0.19440000000000351 t= 0.19460000000000352 t= 0.19480000000000353 t= 0.19500000000000353 t= 0.19520000000000354 t= 0.19540000000000354 t= 0.19560000000000355 t= 0.19580000000000355 t= 0.19600000000000356 t= 0.19620000000000357 t= 0.19640000000000357 t= 0.19660000000000358 t= 0.19680000000000358 t= 0.1970000000000036 t= 0.1972000000000036 t= 0.1974000000000036 t= 0.1976000000000036 t= 0.1978000000000036 t= 0.19800000000000362 t= 0.19820000000000362 t= 0.19840000000000363 t= 0.19860000000000363 t= 0.19880000000000364 t= 0.19900000000000365 t= 0.19920000000000365 t= 0.19940000000000366 t= 0.19960000000000366 t= 0.19980000000000367 t= 0.20000000000000367 t= 0.20020000000000368 t= 0.2004000000000037 t= 0.2006000000000037 t= 0.2008000000000037 t= 0.2010000000000037 t= 0.2012000000000037 t= 0.20140000000000371 t= 0.20160000000000372 t= 0.20180000000000373 t= 0.20200000000000373 t= 0.20220000000000374 t= 0.20240000000000374 t= 0.20260000000000375 t= 0.20280000000000376 t= 0.20300000000000376 t= 0.20320000000000377 t= 0.20340000000000377 t= 0.20360000000000378 t= 0.20380000000000378 t= 0.2040000000000038 t= 0.2042000000000038 t= 0.2044000000000038 t= 0.2046000000000038 t= 0.2048000000000038 t= 0.20500000000000382 t= 0.20520000000000382 t= 0.20540000000000383 t= 0.20560000000000384 t= 0.20580000000000384 t= 0.20600000000000385 t= 0.20620000000000385 t= 0.20640000000000386 t= 0.20660000000000386 t= 0.20680000000000387 t= 0.20700000000000388 t= 0.20720000000000388 t= 0.2074000000000039 t= 0.2076000000000039 t= 0.2078000000000039 t= 0.2080000000000039 t= 0.2082000000000039 t= 0.20840000000000392 t= 0.20860000000000392 t= 0.20880000000000393 t= 0.20900000000000393 t= 0.20920000000000394 t= 0.20940000000000394 t= 0.20960000000000395 t= 0.20980000000000396 t= 0.21000000000000396 t= 0.21020000000000397 t= 0.21040000000000397 t= 0.21060000000000398 t= 0.21080000000000398 t= 0.211000000000004 t= 0.211200000000004 t= 0.211400000000004 t= 0.211600000000004 t= 0.211800000000004 t= 0.21200000000000402 t= 0.21220000000000402 t= 0.21240000000000403 t= 0.21260000000000404 t= 0.21280000000000404 t= 0.21300000000000405 t= 0.21320000000000405 t= 0.21340000000000406 t= 0.21360000000000406 t= 0.21380000000000407 t= 0.21400000000000408 t= 0.21420000000000408 t= 0.2144000000000041 t= 0.2146000000000041 t= 0.2148000000000041 t= 0.2150000000000041 t= 0.2152000000000041 t= 0.21540000000000412 t= 0.21560000000000412 t= 0.21580000000000413 t= 0.21600000000000413 t= 0.21620000000000414 t= 0.21640000000000414 t= 0.21660000000000415 t= 0.21680000000000416 t= 0.21700000000000416 t= 0.21720000000000417 t= 0.21740000000000417 t= 0.21760000000000418 t= 0.21780000000000418 t= 0.2180000000000042 t= 0.2182000000000042 t= 0.2184000000000042 t= 0.2186000000000042 t= 0.2188000000000042 t= 0.21900000000000422 t= 0.21920000000000422 t= 0.21940000000000423 t= 0.21960000000000424 t= 0.21980000000000424 t= 0.22000000000000425 t= 0.22020000000000425 t= 0.22040000000000426 t= 0.22060000000000426 t= 0.22080000000000427 t= 0.22100000000000428 t= 0.22120000000000428 t= 0.2214000000000043 t= 0.2216000000000043 t= 0.2218000000000043 t= 0.2220000000000043 t= 0.2222000000000043 t= 0.22240000000000432 t= 0.22260000000000432 t= 0.22280000000000433 t= 0.22300000000000433 t= 0.22320000000000434 t= 0.22340000000000435 t= 0.22360000000000435 t= 0.22380000000000436 t= 0.22400000000000436 t= 0.22420000000000437 t= 0.22440000000000437 t= 0.22460000000000438 t= 0.22480000000000439 t= 0.2250000000000044 t= 0.2252000000000044 t= 0.2254000000000044 t= 0.2256000000000044 t= 0.2258000000000044 t= 0.22600000000000442 t= 0.22620000000000443 t= 0.22640000000000443 t= 0.22660000000000444 t= 0.22680000000000444 t= 0.22700000000000445 t= 0.22720000000000445 t= 0.22740000000000446 t= 0.22760000000000447 t= 0.22780000000000447 t= 0.22800000000000448 t= 0.22820000000000448 t= 0.2284000000000045 t= 0.2286000000000045 t= 0.2288000000000045 t= 0.2290000000000045 t= 0.2292000000000045 t= 0.22940000000000452 t= 0.22960000000000452 t= 0.22980000000000453 t= 0.23000000000000453 t= 0.23020000000000454 t= 0.23040000000000455 t= 0.23060000000000455 t= 0.23080000000000456 t= 0.23100000000000456 t= 0.23120000000000457 t= 0.23140000000000457 t= 0.23160000000000458 t= 0.23180000000000459 t= 0.2320000000000046 t= 0.2322000000000046 t= 0.2324000000000046 t= 0.2326000000000046 t= 0.23280000000000461 t= 0.23300000000000462 t= 0.23320000000000463 t= 0.23340000000000463 t= 0.23360000000000464 t= 0.23380000000000464 t= 0.23400000000000465 t= 0.23420000000000465 t= 0.23440000000000466 t= 0.23460000000000467 t= 0.23480000000000467 t= 0.23500000000000468 t= 0.23520000000000468 t= 0.2354000000000047 t= 0.2356000000000047 t= 0.2358000000000047 t= 0.2360000000000047 t= 0.2362000000000047 t= 0.23640000000000472 t= 0.23660000000000472 t= 0.23680000000000473 t= 0.23700000000000473 t= 0.23720000000000474 t= 0.23740000000000475 t= 0.23760000000000475 t= 0.23780000000000476 t= 0.23800000000000476 t= 0.23820000000000477 t= 0.23840000000000477 t= 0.23860000000000478 t= 0.2388000000000048 t= 0.2390000000000048 t= 0.2392000000000048 t= 0.2394000000000048 t= 0.2396000000000048 t= 0.23980000000000481 t= 0.24000000000000482 t= 0.24020000000000483 t= 0.24040000000000483 t= 0.24060000000000484 t= 0.24080000000000484 t= 0.24100000000000485 t= 0.24120000000000485 t= 0.24140000000000486 t= 0.24160000000000487 t= 0.24180000000000487 t= 0.24200000000000488 t= 0.24220000000000488 t= 0.2424000000000049 t= 0.2426000000000049 t= 0.2428000000000049 t= 0.2430000000000049 t= 0.2432000000000049 t= 0.24340000000000492 t= 0.24360000000000492 t= 0.24380000000000493 t= 0.24400000000000494 t= 0.24420000000000494 t= 0.24440000000000495 t= 0.24460000000000495 t= 0.24480000000000496 t= 0.24500000000000496 t= 0.24520000000000497 t= 0.24540000000000498 t= 0.24560000000000498 t= 0.245800000000005 t= 0.246000000000005 t= 0.246200000000005 t= 0.246400000000005 t= 0.246600000000005 t= 0.24680000000000502 t= 0.24700000000000502 t= 0.24720000000000503 t= 0.24740000000000503 t= 0.24760000000000504 t= 0.24780000000000504 t= 0.24800000000000505 t= 0.24820000000000506 t= 0.24840000000000506 t= 0.24860000000000507 t= 0.24880000000000507 t= 0.24900000000000508 t= 0.24920000000000508 t= 0.2494000000000051 t= 0.2496000000000051 t= 0.2498000000000051 t= 0.2500000000000051 t= 0.2502000000000051 t= 0.25040000000000506 t= 0.25060000000000504 t= 0.250800000000005 t= 0.251000000000005 t= 0.251200000000005 t= 0.25140000000000495 t= 0.25160000000000493 t= 0.2518000000000049 t= 0.2520000000000049 t= 0.25220000000000486 t= 0.25240000000000484 t= 0.2526000000000048 t= 0.2528000000000048 t= 0.2530000000000048 t= 0.25320000000000475 t= 0.25340000000000473 t= 0.2536000000000047 t= 0.2538000000000047 t= 0.25400000000000467 t= 0.25420000000000464 t= 0.2544000000000046 t= 0.2546000000000046 t= 0.2548000000000046 t= 0.25500000000000456 t= 0.25520000000000453 t= 0.2554000000000045 t= 0.2556000000000045 t= 0.25580000000000447 t= 0.25600000000000445 t= 0.2562000000000044 t= 0.2564000000000044 t= 0.2566000000000044 t= 0.25680000000000436 t= 0.25700000000000434 t= 0.2572000000000043 t= 0.2574000000000043 t= 0.25760000000000427 t= 0.25780000000000425 t= 0.2580000000000042 t= 0.2582000000000042 t= 0.2584000000000042 t= 0.25860000000000416 t= 0.25880000000000414 t= 0.2590000000000041 t= 0.2592000000000041 t= 0.25940000000000407 t= 0.25960000000000405 t= 0.259800000000004 t= 0.260000000000004 t= 0.260200000000004 t= 0.26040000000000396 t= 0.26060000000000394 t= 0.2608000000000039 t= 0.2610000000000039 t= 0.2612000000000039 t= 0.26140000000000385 t= 0.26160000000000383 t= 0.2618000000000038 t= 0.2620000000000038 t= 0.26220000000000376 t= 0.26240000000000374 t= 0.2626000000000037 t= 0.2628000000000037 t= 0.2630000000000037 t= 0.26320000000000365 t= 0.26340000000000363 t= 0.2636000000000036 t= 0.2638000000000036 t= 0.26400000000000357 t= 0.26420000000000354 t= 0.2644000000000035 t= 0.2646000000000035 t= 0.2648000000000035 t= 0.26500000000000346 t= 0.26520000000000343 t= 0.2654000000000034 t= 0.2656000000000034 t= 0.26580000000000337 t= 0.26600000000000334 t= 0.2662000000000033 t= 0.2664000000000033 t= 0.2666000000000033 t= 0.26680000000000326 t= 0.26700000000000323 t= 0.2672000000000032 t= 0.2674000000000032 t= 0.26760000000000317 t= 0.26780000000000315 t= 0.2680000000000031 t= 0.2682000000000031 t= 0.2684000000000031 t= 0.26860000000000306 t= 0.26880000000000304 t= 0.269000000000003 t= 0.269200000000003 t= 0.26940000000000297 t= 0.26960000000000295 t= 0.2698000000000029 t= 0.2700000000000029 t= 0.2702000000000029 t= 0.27040000000000286 t= 0.27060000000000284 t= 0.2708000000000028 t= 0.2710000000000028 t= 0.27120000000000277 t= 0.27140000000000275 t= 0.27160000000000273 t= 0.2718000000000027 t= 0.2720000000000027 t= 0.27220000000000266 t= 0.27240000000000264 t= 0.2726000000000026 t= 0.2728000000000026 t= 0.2730000000000026 t= 0.27320000000000255 t= 0.27340000000000253 t= 0.2736000000000025 t= 0.2738000000000025 t= 0.27400000000000246 t= 0.27420000000000244 t= 0.2744000000000024 t= 0.2746000000000024 t= 0.2748000000000024 t= 0.27500000000000235 t= 0.27520000000000233 t= 0.2754000000000023 t= 0.2756000000000023 t= 0.27580000000000227 t= 0.27600000000000224 t= 0.2762000000000022 t= 0.2764000000000022 t= 0.2766000000000022 t= 0.27680000000000216 t= 0.27700000000000213 t= 0.2772000000000021 t= 0.2774000000000021 t= 0.27760000000000207 t= 0.27780000000000205 t= 0.278000000000002 t= 0.278200000000002 t= 0.278400000000002 t= 0.27860000000000196 t= 0.27880000000000194 t= 0.2790000000000019 t= 0.2792000000000019 t= 0.27940000000000187 t= 0.27960000000000185 t= 0.2798000000000018 t= 0.2800000000000018 t= 0.2802000000000018 t= 0.28040000000000176 t= 0.28060000000000174 t= 0.2808000000000017 t= 0.2810000000000017 t= 0.28120000000000167 t= 0.28140000000000165 t= 0.2816000000000016 t= 0.2818000000000016 t= 0.2820000000000016 t= 0.28220000000000156 t= 0.28240000000000154 t= 0.2826000000000015 t= 0.2828000000000015 t= 0.2830000000000015 t= 0.28320000000000145 t= 0.28340000000000143 t= 0.2836000000000014 t= 0.2838000000000014 t= 0.28400000000000136 t= 0.28420000000000134 t= 0.2844000000000013 t= 0.2846000000000013 t= 0.2848000000000013 t= 0.28500000000000125 t= 0.28520000000000123 t= 0.2854000000000012 t= 0.2856000000000012 t= 0.28580000000000116 t= 0.28600000000000114 t= 0.2862000000000011 t= 0.2864000000000011 t= 0.2866000000000011 t= 0.28680000000000105 t= 0.28700000000000103 t= 0.287200000000001 t= 0.287400000000001 t= 0.28760000000000097 t= 0.28780000000000094 t= 0.2880000000000009 t= 0.2882000000000009 t= 0.2884000000000009 t= 0.28860000000000086 t= 0.28880000000000083 t= 0.2890000000000008 t= 0.2892000000000008 t= 0.28940000000000077 t= 0.28960000000000075 t= 0.2898000000000007 t= 0.2900000000000007 t= 0.2902000000000007 t= 0.29040000000000066 t= 0.29060000000000064 t= 0.2908000000000006 t= 0.2910000000000006 t= 0.29120000000000057 t= 0.29140000000000055 t= 0.2916000000000005 t= 0.2918000000000005 t= 0.2920000000000005 t= 0.29220000000000046 t= 0.29240000000000044 t= 0.2926000000000004 t= 0.2928000000000004 t= 0.29300000000000037 t= 0.29320000000000035 t= 0.2934000000000003 t= 0.2936000000000003 t= 0.2938000000000003 t= 0.29400000000000026 t= 0.29420000000000024 t= 0.2944000000000002 t= 0.2946000000000002 t= 0.2948000000000002 t= 0.29500000000000015 t= 0.29520000000000013 t= 0.2954000000000001 t= 0.2956000000000001 t= 0.29580000000000006 t= 0.29600000000000004 t= 0.2962 t= 0.2964 t= 0.2966 t= 0.29679999999999995 t= 0.29699999999999993 t= 0.2971999999999999 t= 0.2973999999999999 t= 0.29759999999999986 t= 0.29779999999999984 t= 0.2979999999999998 t= 0.2981999999999998 t= 0.2983999999999998 t= 0.29859999999999975 t= 0.29879999999999973 t= 0.2989999999999997 t= 0.2991999999999997 t= 0.29939999999999967 t= 0.29959999999999964 t= 0.2997999999999996 t= 0.2999999999999996 t= 0.3001999999999996 t= 0.30039999999999956 t= 0.30059999999999953 t= 0.3007999999999995 t= 0.3009999999999995 t= 0.30119999999999947 t= 0.30139999999999945 t= 0.3015999999999994 t= 0.3017999999999994 t= 0.3019999999999994 t= 0.30219999999999936 t= 0.30239999999999934 t= 0.3025999999999993 t= 0.3027999999999993 t= 0.30299999999999927 t= 0.30319999999999925 t= 0.3033999999999992 t= 0.3035999999999992 t= 0.3037999999999992 t= 0.30399999999999916 t= 0.30419999999999914 t= 0.3043999999999991 t= 0.3045999999999991 t= 0.30479999999999907 t= 0.30499999999999905 t= 0.305199999999999 t= 0.305399999999999 t= 0.305599999999999 t= 0.30579999999999896 t= 0.30599999999999894 t= 0.3061999999999989 t= 0.3063999999999989 t= 0.3065999999999989 t= 0.30679999999999885 t= 0.30699999999999883 t= 0.3071999999999988 t= 0.3073999999999988 t= 0.30759999999999876 t= 0.30779999999999874 t= 0.3079999999999987 t= 0.3081999999999987 t= 0.3083999999999987 t= 0.30859999999999865 t= 0.30879999999999863 t= 0.3089999999999986 t= 0.3091999999999986 t= 0.30939999999999857 t= 0.30959999999999854 t= 0.3097999999999985 t= 0.3099999999999985 t= 0.3101999999999985 t= 0.31039999999999845 t= 0.31059999999999843 t= 0.3107999999999984 t= 0.3109999999999984 t= 0.31119999999999837 t= 0.31139999999999834 t= 0.3115999999999983 t= 0.3117999999999983 t= 0.3119999999999983 t= 0.31219999999999826 t= 0.31239999999999823 t= 0.3125999999999982 t= 0.3127999999999982 t= 0.31299999999999817 t= 0.31319999999999815 t= 0.3133999999999981 t= 0.3135999999999981 t= 0.3137999999999981 t= 0.31399999999999806 t= 0.31419999999999804 t= 0.314399999999998 t= 0.314599999999998 t= 0.31479999999999797 t= 0.31499999999999795 t= 0.3151999999999979 t= 0.3153999999999979 t= 0.3155999999999979 t= 0.31579999999999786 t= 0.31599999999999784 t= 0.3161999999999978 t= 0.3163999999999978 t= 0.31659999999999777 t= 0.31679999999999775 t= 0.31699999999999773 t= 0.3171999999999977 t= 0.3173999999999977 t= 0.31759999999999766 t= 0.31779999999999764 t= 0.3179999999999976 t= 0.3181999999999976 t= 0.3183999999999976 t= 0.31859999999999755 t= 0.31879999999999753 t= 0.3189999999999975 t= 0.3191999999999975 t= 0.31939999999999746 t= 0.31959999999999744 t= 0.3197999999999974 t= 0.3199999999999974 t= 0.3201999999999974 t= 0.32039999999999735 t= 0.32059999999999733 t= 0.3207999999999973 t= 0.3209999999999973 t= 0.32119999999999727 t= 0.32139999999999724 t= 0.3215999999999972 t= 0.3217999999999972 t= 0.3219999999999972 t= 0.32219999999999716 t= 0.32239999999999713 t= 0.3225999999999971 t= 0.3227999999999971 t= 0.32299999999999707 t= 0.32319999999999705 t= 0.323399999999997 t= 0.323599999999997 t= 0.323799999999997 t= 0.32399999999999696 t= 0.32419999999999694 t= 0.3243999999999969 t= 0.3245999999999969 t= 0.32479999999999687 t= 0.32499999999999685 t= 0.3251999999999968 t= 0.3253999999999968 t= 0.3255999999999968 t= 0.32579999999999676 t= 0.32599999999999674 t= 0.3261999999999967 t= 0.3263999999999967 t= 0.32659999999999667 t= 0.32679999999999665 t= 0.3269999999999966 t= 0.3271999999999966 t= 0.3273999999999966 t= 0.32759999999999656 t= 0.32779999999999654 t= 0.3279999999999965 t= 0.3281999999999965 t= 0.3283999999999965 t= 0.32859999999999645 t= 0.32879999999999643 t= 0.3289999999999964 t= 0.3291999999999964 t= 0.32939999999999636 t= 0.32959999999999634 t= 0.3297999999999963 t= 0.3299999999999963 t= 0.3301999999999963 t= 0.33039999999999625 t= 0.33059999999999623 t= 0.3307999999999962 t= 0.3309999999999962 t= 0.33119999999999616 t= 0.33139999999999614 t= 0.3315999999999961 t= 0.3317999999999961 t= 0.3319999999999961 t= 0.33219999999999605 t= 0.33239999999999603 t= 0.332599999999996 t= 0.332799999999996 t= 0.33299999999999597 t= 0.33319999999999594 t= 0.3333999999999959 t= 0.3335999999999959 t= 0.3337999999999959 t= 0.33399999999999586 t= 0.33419999999999583 t= 0.3343999999999958 t= 0.3345999999999958 t= 0.33479999999999577 t= 0.33499999999999575 t= 0.3351999999999957 t= 0.3353999999999957 t= 0.3355999999999957 t= 0.33579999999999566 t= 0.33599999999999564 t= 0.3361999999999956 t= 0.3363999999999956 t= 0.33659999999999557 t= 0.33679999999999555 t= 0.3369999999999955 t= 0.3371999999999955 t= 0.3373999999999955 t= 0.33759999999999546 t= 0.33779999999999544 t= 0.3379999999999954 t= 0.3381999999999954 t= 0.33839999999999537 t= 0.33859999999999535 t= 0.3387999999999953 t= 0.3389999999999953 t= 0.3391999999999953 t= 0.33939999999999526 t= 0.33959999999999524 t= 0.3397999999999952 t= 0.3399999999999952 t= 0.3401999999999952 t= 0.34039999999999515 t= 0.34059999999999513 t= 0.3407999999999951 t= 0.3409999999999951 t= 0.34119999999999506 t= 0.34139999999999504 t= 0.341599999999995 t= 0.341799999999995 t= 0.341999999999995 t= 0.34219999999999495 t= 0.34239999999999493 t= 0.3425999999999949 t= 0.3427999999999949 t= 0.34299999999999486 t= 0.34319999999999484 t= 0.3433999999999948 t= 0.3435999999999948 t= 0.3437999999999948 t= 0.34399999999999475 t= 0.34419999999999473 t= 0.3443999999999947 t= 0.3445999999999947 t= 0.34479999999999467 t= 0.34499999999999464 t= 0.3451999999999946 t= 0.3453999999999946 t= 0.3455999999999946 t= 0.34579999999999456 t= 0.34599999999999453 t= 0.3461999999999945 t= 0.3463999999999945 t= 0.34659999999999447 t= 0.34679999999999445 t= 0.3469999999999944 t= 0.3471999999999944 t= 0.3473999999999944 t= 0.34759999999999436 t= 0.34779999999999434 t= 0.3479999999999943 t= 0.3481999999999943 t= 0.34839999999999427 t= 0.34859999999999425 t= 0.3487999999999942 t= 0.3489999999999942 t= 0.3491999999999942 t= 0.34939999999999416 t= 0.34959999999999414 t= 0.3497999999999941 t= 0.3499999999999941 t= 0.35019999999999407 t= 0.35039999999999405 t= 0.350599999999994 t= 0.350799999999994 t= 0.350999999999994 t= 0.35119999999999396 t= 0.35139999999999394 t= 0.3515999999999939 t= 0.3517999999999939 t= 0.3519999999999939 t= 0.35219999999999385 t= 0.35239999999999383 t= 0.3525999999999938 t= 0.3527999999999938 t= 0.35299999999999376 t= 0.35319999999999374 t= 0.3533999999999937 t= 0.3535999999999937 t= 0.3537999999999937 t= 0.35399999999999365 t= 0.35419999999999363 t= 0.3543999999999936 t= 0.3545999999999936 t= 0.35479999999999356 t= 0.35499999999999354 t= 0.3551999999999935 t= 0.3553999999999935 t= 0.3555999999999935 t= 0.35579999999999345 t= 0.35599999999999343 t= 0.3561999999999934 t= 0.3563999999999934 t= 0.35659999999999337 t= 0.35679999999999334 t= 0.3569999999999933 t= 0.3571999999999933 t= 0.3573999999999933 t= 0.35759999999999326 t= 0.35779999999999323 t= 0.3579999999999932 t= 0.3581999999999932 t= 0.35839999999999317 t= 0.35859999999999315 t= 0.3587999999999931 t= 0.3589999999999931 t= 0.3591999999999931 t= 0.35939999999999306 t= 0.35959999999999304 t= 0.359799999999993 t= 0.359999999999993 t= 0.36019999999999297 t= 0.36039999999999295 t= 0.3605999999999929 t= 0.3607999999999929 t= 0.3609999999999929 t= 0.36119999999999286 t= 0.36139999999999284 t= 0.3615999999999928 t= 0.3617999999999928 t= 0.36199999999999277 t= 0.36219999999999275 t= 0.36239999999999273 t= 0.3625999999999927 t= 0.3627999999999927 t= 0.36299999999999266 t= 0.36319999999999264 t= 0.3633999999999926 t= 0.3635999999999926 t= 0.3637999999999926 t= 0.36399999999999255 t= 0.36419999999999253 t= 0.3643999999999925 t= 0.3645999999999925 t= 0.36479999999999246 t= 0.36499999999999244 t= 0.3651999999999924 t= 0.3653999999999924 t= 0.3655999999999924 t= 0.36579999999999235 t= 0.36599999999999233 t= 0.3661999999999923 t= 0.3663999999999923 t= 0.36659999999999227 t= 0.36679999999999224 t= 0.3669999999999922 t= 0.3671999999999922 t= 0.3673999999999922 t= 0.36759999999999216 t= 0.36779999999999213 t= 0.3679999999999921 t= 0.3681999999999921 t= 0.36839999999999207 t= 0.36859999999999205 t= 0.368799999999992 t= 0.368999999999992 t= 0.369199999999992 t= 0.36939999999999196 t= 0.36959999999999193 t= 0.3697999999999919 t= 0.3699999999999919 t= 0.37019999999999187 t= 0.37039999999999185 t= 0.3705999999999918 t= 0.3707999999999918 t= 0.3709999999999918 t= 0.37119999999999176 t= 0.37139999999999174 t= 0.3715999999999917 t= 0.3717999999999917 t= 0.37199999999999167 t= 0.37219999999999165 t= 0.3723999999999916 t= 0.3725999999999916 t= 0.3727999999999916 t= 0.37299999999999156 t= 0.37319999999999154 t= 0.3733999999999915 t= 0.3735999999999915 t= 0.3737999999999915 t= 0.37399999999999145 t= 0.37419999999999143 t= 0.3743999999999914 t= 0.3745999999999914 t= 0.37479999999999136 t= 0.37499999999999134 t= 0.3751999999999913 t= 0.3753999999999913 t= 0.3755999999999913 t= 0.37579999999999125 t= 0.37599999999999123 t= 0.3761999999999912 t= 0.3763999999999912 t= 0.37659999999999116 t= 0.37679999999999114 t= 0.3769999999999911 t= 0.3771999999999911 t= 0.3773999999999911 t= 0.37759999999999105 t= 0.37779999999999103 t= 0.377999999999991 t= 0.378199999999991 t= 0.37839999999999097 t= 0.37859999999999094 t= 0.3787999999999909 t= 0.3789999999999909 t= 0.3791999999999909 t= 0.37939999999999086 t= 0.37959999999999083 t= 0.3797999999999908 t= 0.3799999999999908 t= 0.38019999999999077 t= 0.38039999999999075 t= 0.3805999999999907 t= 0.3807999999999907 t= 0.3809999999999907 t= 0.38119999999999066 t= 0.38139999999999064 t= 0.3815999999999906 t= 0.3817999999999906 t= 0.38199999999999057 t= 0.38219999999999055 t= 0.3823999999999905 t= 0.3825999999999905 t= 0.3827999999999905 t= 0.38299999999999046 t= 0.38319999999999044 t= 0.3833999999999904 t= 0.3835999999999904 t= 0.38379999999999037 t= 0.38399999999999035 t= 0.3841999999999903 t= 0.3843999999999903 t= 0.3845999999999903 t= 0.38479999999999026 t= 0.38499999999999024 t= 0.3851999999999902 t= 0.3853999999999902 t= 0.3855999999999902 t= 0.38579999999999015 t= 0.38599999999999013 t= 0.3861999999999901 t= 0.3863999999999901 t= 0.38659999999999006 t= 0.38679999999999004 t= 0.38699999999999 t= 0.38719999999999 t= 0.38739999999999 t= 0.38759999999998995 t= 0.38779999999998993 t= 0.3879999999999899 t= 0.3881999999999899 t= 0.38839999999998986 t= 0.38859999999998984 t= 0.3887999999999898 t= 0.3889999999999898 t= 0.3891999999999898 t= 0.38939999999998975 t= 0.38959999999998973 t= 0.3897999999999897 t= 0.3899999999999897 t= 0.39019999999998967 t= 0.39039999999998964 t= 0.3905999999999896 t= 0.3907999999999896 t= 0.3909999999999896 t= 0.39119999999998956 t= 0.39139999999998953 t= 0.3915999999999895 t= 0.3917999999999895 t= 0.39199999999998947 t= 0.39219999999998945 t= 0.3923999999999894 t= 0.3925999999999894 t= 0.3927999999999894 t= 0.39299999999998936 t= 0.39319999999998934 t= 0.3933999999999893 t= 0.3935999999999893 t= 0.39379999999998927 t= 0.39399999999998925 t= 0.3941999999999892 t= 0.3943999999999892 t= 0.3945999999999892 t= 0.39479999999998916 t= 0.39499999999998914 t= 0.3951999999999891 t= 0.3953999999999891 t= 0.39559999999998907 t= 0.39579999999998905 t= 0.395999999999989 t= 0.396199999999989 t= 0.396399999999989 t= 0.39659999999998896 t= 0.39679999999998894 t= 0.3969999999999889 t= 0.3971999999999889 t= 0.3973999999999889 t= 0.39759999999998885 t= 0.39779999999998883 t= 0.3979999999999888 t= 0.3981999999999888 t= 0.39839999999998876 t= 0.39859999999998874 t= 0.3987999999999887 t= 0.3989999999999887 t= 0.3991999999999887 t= 0.39939999999998865 t= 0.39959999999998863 t= 0.3997999999999886 t= 0.3999999999999886 t= 0.40019999999998856 t= 0.40039999999998854 t= 0.4005999999999885 t= 0.4007999999999885 t= 0.4009999999999885 t= 0.40119999999998845 t= 0.40139999999998843 t= 0.4015999999999884 t= 0.4017999999999884 t= 0.40199999999998837 t= 0.40219999999998834 t= 0.4023999999999883 t= 0.4025999999999883 t= 0.4027999999999883 t= 0.40299999999998826 t= 0.40319999999998823 t= 0.4033999999999882 t= 0.4035999999999882 t= 0.40379999999998817 t= 0.40399999999998815 t= 0.4041999999999881 t= 0.4043999999999881 t= 0.4045999999999881 t= 0.40479999999998806 t= 0.40499999999998804 t= 0.405199999999988 t= 0.405399999999988 t= 0.40559999999998797 t= 0.40579999999998795 t= 0.4059999999999879 t= 0.4061999999999879 t= 0.4063999999999879 t= 0.40659999999998786 t= 0.40679999999998784 t= 0.4069999999999878 t= 0.4071999999999878 t= 0.40739999999998777 t= 0.40759999999998775 t= 0.40779999999998773 t= 0.4079999999999877 t= 0.4081999999999877 t= 0.40839999999998766 t= 0.40859999999998764 t= 0.4087999999999876 t= 0.4089999999999876 t= 0.4091999999999876 t= 0.40939999999998755 t= 0.40959999999998753 t= 0.4097999999999875 t= 0.4099999999999875 t= 0.41019999999998746 t= 0.41039999999998744 t= 0.4105999999999874 t= 0.4107999999999874 t= 0.4109999999999874 t= 0.41119999999998735 t= 0.41139999999998733 t= 0.4115999999999873 t= 0.4117999999999873 t= 0.41199999999998727 t= 0.41219999999998724 t= 0.4123999999999872 t= 0.4125999999999872 t= 0.4127999999999872 t= 0.41299999999998716 t= 0.41319999999998713 t= 0.4133999999999871 t= 0.4135999999999871 t= 0.41379999999998707 t= 0.41399999999998705 t= 0.414199999999987 t= 0.414399999999987 t= 0.414599999999987 t= 0.41479999999998696 t= 0.41499999999998693 t= 0.4151999999999869 t= 0.4153999999999869 t= 0.41559999999998687 t= 0.41579999999998685 t= 0.4159999999999868 t= 0.4161999999999868 t= 0.4163999999999868 t= 0.41659999999998676 t= 0.41679999999998674 t= 0.4169999999999867 t= 0.4171999999999867 t= 0.41739999999998667 t= 0.41759999999998665 t= 0.4177999999999866 t= 0.4179999999999866 t= 0.4181999999999866 t= 0.41839999999998656 t= 0.41859999999998654 t= 0.4187999999999865 t= 0.4189999999999865 t= 0.4191999999999865 t= 0.41939999999998645 t= 0.41959999999998643 t= 0.4197999999999864 t= 0.4199999999999864 t= 0.42019999999998636 t= 0.42039999999998634 t= 0.4205999999999863 t= 0.4207999999999863 t= 0.4209999999999863 t= 0.42119999999998625 t= 0.42139999999998623 t= 0.4215999999999862 t= 0.4217999999999862 t= 0.42199999999998616 t= 0.42219999999998614 t= 0.4223999999999861 t= 0.4225999999999861 t= 0.4227999999999861 t= 0.42299999999998605 t= 0.42319999999998603 t= 0.423399999999986 t= 0.423599999999986 t= 0.42379999999998597 t= 0.42399999999998594 t= 0.4241999999999859 t= 0.4243999999999859 t= 0.4245999999999859 t= 0.42479999999998586 t= 0.42499999999998583 t= 0.4251999999999858 t= 0.4253999999999858 t= 0.42559999999998577 t= 0.42579999999998575 t= 0.4259999999999857 t= 0.4261999999999857 t= 0.4263999999999857 t= 0.42659999999998566 t= 0.42679999999998564 t= 0.4269999999999856 t= 0.4271999999999856 t= 0.42739999999998557 t= 0.42759999999998555 t= 0.4277999999999855 t= 0.4279999999999855 t= 0.4281999999999855 t= 0.42839999999998546 t= 0.42859999999998544 t= 0.4287999999999854 t= 0.4289999999999854 t= 0.42919999999998537 t= 0.42939999999998535 t= 0.4295999999999853 t= 0.4297999999999853 t= 0.4299999999999853 t= 0.43019999999998526 t= 0.43039999999998524 t= 0.4305999999999852 t= 0.4307999999999852 t= 0.4309999999999852 t= 0.43119999999998515 t= 0.43139999999998513 t= 0.4315999999999851 t= 0.4317999999999851 t= 0.43199999999998506 t= 0.43219999999998504 t= 0.432399999999985 t= 0.432599999999985 t= 0.432799999999985 t= 0.43299999999998495 t= 0.43319999999998493 t= 0.4333999999999849 t= 0.4335999999999849 t= 0.43379999999998486 t= 0.43399999999998484 t= 0.4341999999999848 t= 0.4343999999999848 t= 0.4345999999999848 t= 0.43479999999998475 t= 0.43499999999998473 t= 0.4351999999999847 t= 0.4353999999999847 t= 0.43559999999998467 t= 0.43579999999998464 t= 0.4359999999999846 t= 0.4361999999999846 t= 0.4363999999999846 t= 0.43659999999998456 t= 0.43679999999998453 t= 0.4369999999999845 t= 0.4371999999999845 t= 0.43739999999998447 t= 0.43759999999998445 t= 0.4377999999999844 t= 0.4379999999999844 t= 0.4381999999999844 t= 0.43839999999998436 t= 0.43859999999998434 t= 0.4387999999999843 t= 0.4389999999999843 t= 0.43919999999998427 t= 0.43939999999998425 t= 0.4395999999999842 t= 0.4397999999999842 t= 0.4399999999999842 t= 0.44019999999998416 t= 0.44039999999998414 t= 0.4405999999999841 t= 0.4407999999999841 t= 0.44099999999998407 t= 0.44119999999998405 t= 0.441399999999984 t= 0.441599999999984 t= 0.441799999999984 t= 0.44199999999998396 t= 0.44219999999998394 t= 0.4423999999999839 t= 0.4425999999999839 t= 0.4427999999999839 t= 0.44299999999998385 t= 0.44319999999998383 t= 0.4433999999999838 t= 0.4435999999999838 t= 0.44379999999998376 t= 0.44399999999998374 t= 0.4441999999999837 t= 0.4443999999999837 t= 0.4445999999999837 t= 0.44479999999998365 t= 0.44499999999998363 t= 0.4451999999999836 t= 0.4453999999999836 t= 0.44559999999998356 t= 0.44579999999998354 t= 0.4459999999999835 t= 0.4461999999999835 t= 0.4463999999999835 t= 0.44659999999998345 t= 0.44679999999998343 t= 0.4469999999999834 t= 0.4471999999999834 t= 0.44739999999998337 t= 0.44759999999998334 t= 0.4477999999999833 t= 0.4479999999999833 t= 0.4481999999999833 t= 0.44839999999998326 t= 0.44859999999998323 t= 0.4487999999999832 t= 0.4489999999999832 t= 0.44919999999998317 t= 0.44939999999998315 t= 0.4495999999999831 t= 0.4497999999999831 t= 0.4499999999999831 t= 0.45019999999998306 t= 0.45039999999998304 t= 0.450599999999983 t= 0.450799999999983 t= 0.45099999999998297 t= 0.45119999999998295 t= 0.4513999999999829 t= 0.4515999999999829 t= 0.4517999999999829 t= 0.45199999999998286 t= 0.45219999999998284 t= 0.4523999999999828 t= 0.4525999999999828 t= 0.45279999999998277 t= 0.45299999999998275 t= 0.45319999999998273 t= 0.4533999999999827 t= 0.4535999999999827 t= 0.45379999999998266 t= 0.45399999999998264 t= 0.4541999999999826 t= 0.4543999999999826 t= 0.4545999999999826 t= 0.45479999999998255 t= 0.45499999999998253 t= 0.4551999999999825 t= 0.4553999999999825 t= 0.45559999999998246 t= 0.45579999999998244 t= 0.4559999999999824 t= 0.4561999999999824 t= 0.4563999999999824 t= 0.45659999999998235 t= 0.45679999999998233 t= 0.4569999999999823 t= 0.4571999999999823 t= 0.45739999999998227 t= 0.45759999999998224 t= 0.4577999999999822 t= 0.4579999999999822 t= 0.4581999999999822 t= 0.45839999999998216 t= 0.45859999999998213 t= 0.4587999999999821 t= 0.4589999999999821 t= 0.45919999999998207 t= 0.45939999999998204 t= 0.459599999999982 t= 0.459799999999982 t= 0.459999999999982 t= 0.46019999999998196 t= 0.46039999999998193 t= 0.4605999999999819 t= 0.4607999999999819 t= 0.46099999999998187 t= 0.46119999999998185 t= 0.4613999999999818 t= 0.4615999999999818 t= 0.4617999999999818 t= 0.46199999999998176 t= 0.46219999999998174 t= 0.4623999999999817 t= 0.4625999999999817 t= 0.46279999999998167 t= 0.46299999999998165 t= 0.4631999999999816 t= 0.4633999999999816 t= 0.4635999999999816 t= 0.46379999999998156 t= 0.46399999999998154 t= 0.4641999999999815 t= 0.4643999999999815 t= 0.46459999999998147 t= 0.46479999999998145 t= 0.46499999999998143 t= 0.4651999999999814 t= 0.4653999999999814 t= 0.46559999999998136 t= 0.46579999999998134 t= 0.4659999999999813 t= 0.4661999999999813 t= 0.4663999999999813 t= 0.46659999999998125 t= 0.46679999999998123 t= 0.4669999999999812 t= 0.4671999999999812 t= 0.46739999999998116 t= 0.46759999999998114 t= 0.4677999999999811 t= 0.4679999999999811 t= 0.4681999999999811 t= 0.46839999999998105 t= 0.46859999999998103 t= 0.468799999999981 t= 0.468999999999981 t= 0.46919999999998097 t= 0.46939999999998094 t= 0.4695999999999809 t= 0.4697999999999809 t= 0.4699999999999809 t= 0.47019999999998086 t= 0.47039999999998083 t= 0.4705999999999808 t= 0.4707999999999808 t= 0.47099999999998077 t= 0.47119999999998075 t= 0.4713999999999807 t= 0.4715999999999807 t= 0.4717999999999807 t= 0.47199999999998066 t= 0.47219999999998064 t= 0.4723999999999806 t= 0.4725999999999806 t= 0.47279999999998057 t= 0.47299999999998055 t= 0.4731999999999805 t= 0.4733999999999805 t= 0.4735999999999805 t= 0.47379999999998046 t= 0.47399999999998044 t= 0.4741999999999804 t= 0.4743999999999804 t= 0.47459999999998037 t= 0.47479999999998035 t= 0.4749999999999803 t= 0.4751999999999803 t= 0.4753999999999803 t= 0.47559999999998026 t= 0.47579999999998024 t= 0.4759999999999802 t= 0.4761999999999802 t= 0.4763999999999802 t= 0.47659999999998015 t= 0.47679999999998013 t= 0.4769999999999801 t= 0.4771999999999801 t= 0.47739999999998006 t= 0.47759999999998004 t= 0.47779999999998 t= 0.47799999999998 t= 0.47819999999998 t= 0.47839999999997995 t= 0.47859999999997993 t= 0.4787999999999799 t= 0.4789999999999799 t= 0.47919999999997986 t= 0.47939999999997984 t= 0.4795999999999798 t= 0.4797999999999798 t= 0.4799999999999798 t= 0.48019999999997975 t= 0.48039999999997973 t= 0.4805999999999797 t= 0.4807999999999797 t= 0.48099999999997967 t= 0.48119999999997964 t= 0.4813999999999796 t= 0.4815999999999796 t= 0.4817999999999796 t= 0.48199999999997956 t= 0.48219999999997953 t= 0.4823999999999795 t= 0.4825999999999795 t= 0.48279999999997947 t= 0.48299999999997945 t= 0.4831999999999794 t= 0.4833999999999794 t= 0.4835999999999794 t= 0.48379999999997936 t= 0.48399999999997934 t= 0.4841999999999793 t= 0.4843999999999793 t= 0.48459999999997927 t= 0.48479999999997925 t= 0.4849999999999792 t= 0.4851999999999792 t= 0.4853999999999792 t= 0.48559999999997916 t= 0.48579999999997914 t= 0.4859999999999791 t= 0.4861999999999791 t= 0.48639999999997907 t= 0.48659999999997905 t= 0.486799999999979 t= 0.486999999999979 t= 0.487199999999979 t= 0.48739999999997896 t= 0.48759999999997894 t= 0.4877999999999789 t= 0.4879999999999789 t= 0.4881999999999789 t= 0.48839999999997885 t= 0.48859999999997883 t= 0.4887999999999788 t= 0.4889999999999788 t= 0.48919999999997876 t= 0.48939999999997874 t= 0.4895999999999787 t= 0.4897999999999787 t= 0.4899999999999787 t= 0.49019999999997865 t= 0.49039999999997863 t= 0.4905999999999786 t= 0.4907999999999786 t= 0.49099999999997856 t= 0.49119999999997854 t= 0.4913999999999785 t= 0.4915999999999785 t= 0.4917999999999785 t= 0.49199999999997845 t= 0.49219999999997843 t= 0.4923999999999784 t= 0.4925999999999784 t= 0.49279999999997837 t= 0.49299999999997834 t= 0.4931999999999783 t= 0.4933999999999783 t= 0.4935999999999783 t= 0.49379999999997826 t= 0.49399999999997823 t= 0.4941999999999782 t= 0.4943999999999782 t= 0.49459999999997817 t= 0.49479999999997815 t= 0.4949999999999781 t= 0.4951999999999781 t= 0.4953999999999781 t= 0.49559999999997806 t= 0.49579999999997804 t= 0.495999999999978 t= 0.496199999999978 t= 0.49639999999997797 t= 0.49659999999997795 t= 0.4967999999999779 t= 0.4969999999999779 t= 0.4971999999999779 t= 0.49739999999997786 t= 0.49759999999997784 t= 0.4977999999999778 t= 0.4979999999999778 t= 0.49819999999997777 t= 0.49839999999997775 t= 0.4985999999999777 t= 0.4987999999999777 t= 0.4989999999999777 t= 0.49919999999997766 t= 0.49939999999997764 t= 0.4995999999999776 t= 0.4997999999999776 t= 0.4999999999999776 t= 0.5001999999999776 t= 0.5003999999999775 t= 0.5005999999999775 t= 0.5007999999999775 t= 0.5009999999999775 t= 0.5011999999999774 t= 0.5013999999999774 t= 0.5015999999999774 t= 0.5017999999999774 t= 0.5019999999999774 t= 0.5021999999999773 t= 0.5023999999999773 t= 0.5025999999999773 t= 0.5027999999999773 t= 0.5029999999999772 t= 0.5031999999999772 t= 0.5033999999999772 t= 0.5035999999999772 t= 0.5037999999999772 t= 0.5039999999999771 t= 0.5041999999999771 t= 0.5043999999999771 t= 0.5045999999999771 t= 0.504799999999977 t= 0.504999999999977 t= 0.505199999999977 t= 0.505399999999977 t= 0.505599999999977 t= 0.5057999999999769 t= 0.5059999999999769 t= 0.5061999999999769 t= 0.5063999999999769 t= 0.5065999999999768 t= 0.5067999999999768 t= 0.5069999999999768 t= 0.5071999999999768 t= 0.5073999999999768 t= 0.5075999999999767 t= 0.5077999999999767 t= 0.5079999999999767 t= 0.5081999999999767 t= 0.5083999999999766 t= 0.5085999999999766 t= 0.5087999999999766 t= 0.5089999999999766 t= 0.5091999999999766 t= 0.5093999999999765 t= 0.5095999999999765 t= 0.5097999999999765 t= 0.5099999999999765 t= 0.5101999999999765 t= 0.5103999999999764 t= 0.5105999999999764 t= 0.5107999999999764 t= 0.5109999999999764 t= 0.5111999999999763 t= 0.5113999999999763 t= 0.5115999999999763 t= 0.5117999999999763 t= 0.5119999999999763 t= 0.5121999999999762 t= 0.5123999999999762 t= 0.5125999999999762 t= 0.5127999999999762 t= 0.5129999999999761 t= 0.5131999999999761 t= 0.5133999999999761 t= 0.5135999999999761 t= 0.513799999999976 t= 0.513999999999976 t= 0.514199999999976 t= 0.514399999999976 t= 0.514599999999976 t= 0.5147999999999759 t= 0.5149999999999759 t= 0.5151999999999759 t= 0.5153999999999759 t= 0.5155999999999759 t= 0.5157999999999758 t= 0.5159999999999758 t= 0.5161999999999758 t= 0.5163999999999758 t= 0.5165999999999757 t= 0.5167999999999757 t= 0.5169999999999757 t= 0.5171999999999757 t= 0.5173999999999757 t= 0.5175999999999756 t= 0.5177999999999756 t= 0.5179999999999756 t= 0.5181999999999756 t= 0.5183999999999755 t= 0.5185999999999755 t= 0.5187999999999755 t= 0.5189999999999755 t= 0.5191999999999755 t= 0.5193999999999754 t= 0.5195999999999754 t= 0.5197999999999754 t= 0.5199999999999754 t= 0.5201999999999753 t= 0.5203999999999753 t= 0.5205999999999753 t= 0.5207999999999753 t= 0.5209999999999753 t= 0.5211999999999752 t= 0.5213999999999752 t= 0.5215999999999752 t= 0.5217999999999752 t= 0.5219999999999752 t= 0.5221999999999751 t= 0.5223999999999751 t= 0.5225999999999751 t= 0.5227999999999751 t= 0.522999999999975 t= 0.523199999999975 t= 0.523399999999975 t= 0.523599999999975 t= 0.523799999999975 t= 0.5239999999999749 t= 0.5241999999999749 t= 0.5243999999999749 t= 0.5245999999999749 t= 0.5247999999999748 t= 0.5249999999999748 t= 0.5251999999999748 t= 0.5253999999999748 t= 0.5255999999999748 t= 0.5257999999999747 t= 0.5259999999999747 t= 0.5261999999999747 t= 0.5263999999999747 t= 0.5265999999999746 t= 0.5267999999999746 t= 0.5269999999999746 t= 0.5271999999999746 t= 0.5273999999999746 t= 0.5275999999999745 t= 0.5277999999999745 t= 0.5279999999999745 t= 0.5281999999999745 t= 0.5283999999999744 t= 0.5285999999999744 t= 0.5287999999999744 t= 0.5289999999999744 t= 0.5291999999999744 t= 0.5293999999999743 t= 0.5295999999999743 t= 0.5297999999999743 t= 0.5299999999999743 t= 0.5301999999999742 t= 0.5303999999999742 t= 0.5305999999999742 t= 0.5307999999999742 t= 0.5309999999999742 t= 0.5311999999999741 t= 0.5313999999999741 t= 0.5315999999999741 t= 0.5317999999999741 t= 0.531999999999974 t= 0.532199999999974 t= 0.532399999999974 t= 0.532599999999974 t= 0.532799999999974 t= 0.5329999999999739 t= 0.5331999999999739 t= 0.5333999999999739 t= 0.5335999999999739 t= 0.5337999999999739 t= 0.5339999999999738 t= 0.5341999999999738 t= 0.5343999999999738 t= 0.5345999999999738 t= 0.5347999999999737 t= 0.5349999999999737 t= 0.5351999999999737 t= 0.5353999999999737 t= 0.5355999999999737 t= 0.5357999999999736 t= 0.5359999999999736 t= 0.5361999999999736 t= 0.5363999999999736 t= 0.5365999999999735 t= 0.5367999999999735 t= 0.5369999999999735 t= 0.5371999999999735 t= 0.5373999999999735 t= 0.5375999999999734 t= 0.5377999999999734 t= 0.5379999999999734 t= 0.5381999999999734 t= 0.5383999999999733 t= 0.5385999999999733 t= 0.5387999999999733 t= 0.5389999999999733 t= 0.5391999999999733 t= 0.5393999999999732 t= 0.5395999999999732 t= 0.5397999999999732 t= 0.5399999999999732 t= 0.5401999999999731 t= 0.5403999999999731 t= 0.5405999999999731 t= 0.5407999999999731 t= 0.5409999999999731 t= 0.541199999999973 t= 0.541399999999973 t= 0.541599999999973 t= 0.541799999999973 t= 0.541999999999973 t= 0.5421999999999729 t= 0.5423999999999729 t= 0.5425999999999729 t= 0.5427999999999729 t= 0.5429999999999728 t= 0.5431999999999728 t= 0.5433999999999728 t= 0.5435999999999728 t= 0.5437999999999727 t= 0.5439999999999727 t= 0.5441999999999727 t= 0.5443999999999727 t= 0.5445999999999727 t= 0.5447999999999726 t= 0.5449999999999726 t= 0.5451999999999726 t= 0.5453999999999726 t= 0.5455999999999726 t= 0.5457999999999725 t= 0.5459999999999725 t= 0.5461999999999725 t= 0.5463999999999725 t= 0.5465999999999724 t= 0.5467999999999724 t= 0.5469999999999724 t= 0.5471999999999724 t= 0.5473999999999724 t= 0.5475999999999723 t= 0.5477999999999723 t= 0.5479999999999723 t= 0.5481999999999723 t= 0.5483999999999722 t= 0.5485999999999722 t= 0.5487999999999722 t= 0.5489999999999722 t= 0.5491999999999722 t= 0.5493999999999721 t= 0.5495999999999721 t= 0.5497999999999721 t= 0.5499999999999721 t= 0.550199999999972 t= 0.550399999999972 t= 0.550599999999972 t= 0.550799999999972 t= 0.550999999999972 t= 0.5511999999999719 t= 0.5513999999999719 t= 0.5515999999999719 t= 0.5517999999999719 t= 0.5519999999999718 t= 0.5521999999999718 t= 0.5523999999999718 t= 0.5525999999999718 t= 0.5527999999999718 t= 0.5529999999999717 t= 0.5531999999999717 t= 0.5533999999999717 t= 0.5535999999999717 t= 0.5537999999999716 t= 0.5539999999999716 t= 0.5541999999999716 t= 0.5543999999999716 t= 0.5545999999999716 t= 0.5547999999999715 t= 0.5549999999999715 t= 0.5551999999999715 t= 0.5553999999999715 t= 0.5555999999999715 t= 0.5557999999999714 t= 0.5559999999999714 t= 0.5561999999999714 t= 0.5563999999999714 t= 0.5565999999999713 t= 0.5567999999999713 t= 0.5569999999999713 t= 0.5571999999999713 t= 0.5573999999999713 t= 0.5575999999999712 t= 0.5577999999999712 t= 0.5579999999999712 t= 0.5581999999999712 t= 0.5583999999999711 t= 0.5585999999999711 t= 0.5587999999999711 t= 0.5589999999999711 t= 0.559199999999971 t= 0.559399999999971 t= 0.559599999999971 t= 0.559799999999971 t= 0.559999999999971 t= 0.5601999999999709 t= 0.5603999999999709 t= 0.5605999999999709 t= 0.5607999999999709 t= 0.5609999999999709 t= 0.5611999999999708 t= 0.5613999999999708 t= 0.5615999999999708 t= 0.5617999999999708 t= 0.5619999999999707 t= 0.5621999999999707 t= 0.5623999999999707 t= 0.5625999999999707 t= 0.5627999999999707 t= 0.5629999999999706 t= 0.5631999999999706 t= 0.5633999999999706 t= 0.5635999999999706 t= 0.5637999999999705 t= 0.5639999999999705 t= 0.5641999999999705 t= 0.5643999999999705 t= 0.5645999999999705 t= 0.5647999999999704 t= 0.5649999999999704 t= 0.5651999999999704 t= 0.5653999999999704 t= 0.5655999999999703 t= 0.5657999999999703 t= 0.5659999999999703 t= 0.5661999999999703 t= 0.5663999999999703 t= 0.5665999999999702 t= 0.5667999999999702 t= 0.5669999999999702 t= 0.5671999999999702 t= 0.5673999999999702 t= 0.5675999999999701 t= 0.5677999999999701 t= 0.5679999999999701 t= 0.5681999999999701 t= 0.56839999999997 t= 0.56859999999997 t= 0.56879999999997 t= 0.56899999999997 t= 0.56919999999997 t= 0.5693999999999699 t= 0.5695999999999699 t= 0.5697999999999699 t= 0.5699999999999699 t= 0.5701999999999698 t= 0.5703999999999698 t= 0.5705999999999698 t= 0.5707999999999698 t= 0.5709999999999698 t= 0.5711999999999697 t= 0.5713999999999697 t= 0.5715999999999697 t= 0.5717999999999697 t= 0.5719999999999696 t= 0.5721999999999696 t= 0.5723999999999696 t= 0.5725999999999696 t= 0.5727999999999696 t= 0.5729999999999695 t= 0.5731999999999695 t= 0.5733999999999695 t= 0.5735999999999695 t= 0.5737999999999694 t= 0.5739999999999694 t= 0.5741999999999694 t= 0.5743999999999694 t= 0.5745999999999694 t= 0.5747999999999693 t= 0.5749999999999693 t= 0.5751999999999693 t= 0.5753999999999693 t= 0.5755999999999692 t= 0.5757999999999692 t= 0.5759999999999692 t= 0.5761999999999692 t= 0.5763999999999692 t= 0.5765999999999691 t= 0.5767999999999691 t= 0.5769999999999691 t= 0.5771999999999691 t= 0.577399999999969 t= 0.577599999999969 t= 0.577799999999969 t= 0.577999999999969 t= 0.578199999999969 t= 0.5783999999999689 t= 0.5785999999999689 t= 0.5787999999999689 t= 0.5789999999999689 t= 0.5791999999999689 t= 0.5793999999999688 t= 0.5795999999999688 t= 0.5797999999999688 t= 0.5799999999999688 t= 0.5801999999999687 t= 0.5803999999999687 t= 0.5805999999999687 t= 0.5807999999999687 t= 0.5809999999999687 t= 0.5811999999999686 t= 0.5813999999999686 t= 0.5815999999999686 t= 0.5817999999999686 t= 0.5819999999999685 t= 0.5821999999999685 t= 0.5823999999999685 t= 0.5825999999999685 t= 0.5827999999999685 t= 0.5829999999999684 t= 0.5831999999999684 t= 0.5833999999999684 t= 0.5835999999999684 t= 0.5837999999999683 t= 0.5839999999999683 t= 0.5841999999999683 t= 0.5843999999999683 t= 0.5845999999999683 t= 0.5847999999999682 t= 0.5849999999999682 t= 0.5851999999999682 t= 0.5853999999999682 t= 0.5855999999999681 t= 0.5857999999999681 t= 0.5859999999999681 t= 0.5861999999999681 t= 0.5863999999999681 t= 0.586599999999968 t= 0.586799999999968 t= 0.586999999999968 t= 0.587199999999968 t= 0.587399999999968 t= 0.5875999999999679 t= 0.5877999999999679 t= 0.5879999999999679 t= 0.5881999999999679 t= 0.5883999999999678 t= 0.5885999999999678 t= 0.5887999999999678 t= 0.5889999999999678 t= 0.5891999999999677 t= 0.5893999999999677 t= 0.5895999999999677 t= 0.5897999999999677 t= 0.5899999999999677 t= 0.5901999999999676 t= 0.5903999999999676 t= 0.5905999999999676 t= 0.5907999999999676 t= 0.5909999999999676 t= 0.5911999999999675 t= 0.5913999999999675 t= 0.5915999999999675 t= 0.5917999999999675 t= 0.5919999999999674 t= 0.5921999999999674 t= 0.5923999999999674 t= 0.5925999999999674 t= 0.5927999999999674 t= 0.5929999999999673 t= 0.5931999999999673 t= 0.5933999999999673 t= 0.5935999999999673 t= 0.5937999999999672 t= 0.5939999999999672 t= 0.5941999999999672 t= 0.5943999999999672 t= 0.5945999999999672 t= 0.5947999999999671 t= 0.5949999999999671 t= 0.5951999999999671 t= 0.5953999999999671 t= 0.595599999999967 t= 0.595799999999967 t= 0.595999999999967 t= 0.596199999999967 t= 0.596399999999967 t= 0.5965999999999669 t= 0.5967999999999669 t= 0.5969999999999669 t= 0.5971999999999669 t= 0.5973999999999668 t= 0.5975999999999668 t= 0.5977999999999668 t= 0.5979999999999668 t= 0.5981999999999668 t= 0.5983999999999667 t= 0.5985999999999667 t= 0.5987999999999667 t= 0.5989999999999667 t= 0.5991999999999666 t= 0.5993999999999666 t= 0.5995999999999666 t= 0.5997999999999666 t= 0.5999999999999666CPU times: user 7.21 s, sys: 739 ms, total: 7.95 s
Wall time: 1.98 s end{sphinxVerbatim}
t= 0.0002 t= 0.0004 t= 0.0006000000000000001 t= 0.0008 t= 0.001 t= 0.0012000000000000001 t= 0.0014000000000000002 t= 0.0016000000000000003 t= 0.0018000000000000004 t= 0.0020000000000000005 t= 0.0022000000000000006 t= 0.0024000000000000007 t= 0.0026000000000000007 t= 0.002800000000000001 t= 0.003000000000000001 t= 0.003200000000000001 t= 0.003400000000000001 t= 0.003600000000000001 t= 0.0038000000000000013 t= 0.004000000000000001 t= 0.004200000000000001 t= 0.0044 t= 0.0046 t= 0.0048 t= 0.004999999999999999 t= 0.005199999999999999 t= 0.0053999999999999986 t= 0.005599999999999998 t= 0.005799999999999998 t= 0.0059999999999999975 t= 0.006199999999999997 t= 0.006399999999999997 t= 0.0065999999999999965 t= 0.006799999999999996 t= 0.006999999999999996 t= 0.0071999999999999955 t= 0.007399999999999995 t= 0.007599999999999995 t= 0.0077999999999999944 t= 0.007999999999999995 t= 0.008199999999999995 t= 0.008399999999999996 t= 0.008599999999999997 t= 0.008799999999999997 t= 0.008999999999999998 t= 0.009199999999999998 t= 0.009399999999999999 t= 0.0096 t= 0.0098 t= 0.01 t= 0.0102 t= 0.010400000000000001 t= 0.010600000000000002 t= 0.010800000000000002 t= 0.011000000000000003 t= 0.011200000000000003 t= 0.011400000000000004 t= 0.011600000000000004 t= 0.011800000000000005 t= 0.012000000000000005 t= 0.012200000000000006 t= 0.012400000000000007 t= 0.012600000000000007 t= 0.012800000000000008 t= 0.013000000000000008 t= 0.013200000000000009 t= 0.013400000000000009 t= 0.01360000000000001 t= 0.01380000000000001 t= 0.01400000000000001 t= 0.014200000000000011 t= 0.014400000000000012 t= 0.014600000000000012 t= 0.014800000000000013 t= 0.015000000000000013 t= 0.015200000000000014 t= 0.015400000000000014 t= 0.015600000000000015 t= 0.015800000000000015 t= 0.016000000000000014 t= 0.016200000000000013 t= 0.016400000000000012 t= 0.01660000000000001 t= 0.01680000000000001 t= 0.017000000000000008 t= 0.017200000000000007 t= 0.017400000000000006 t= 0.017600000000000005 t= 0.017800000000000003 t= 0.018000000000000002 t= 0.0182 t= 0.0184 t= 0.0186 t= 0.018799999999999997 t= 0.018999999999999996 t= 0.019199999999999995 t= 0.019399999999999994 t= 0.019599999999999992 t= 0.01979999999999999 t= 0.01999999999999999 t= 0.02019999999999999 t= 0.020399999999999988 t= 0.020599999999999986 t= 0.020799999999999985 t= 0.020999999999999984 t= 0.021199999999999983 t= 0.02139999999999998 t= 0.02159999999999998 t= 0.02179999999999998 t= 0.021999999999999978 t= 0.022199999999999977 t= 0.022399999999999975 t= 0.022599999999999974 t= 0.022799999999999973 t= 0.022999999999999972 t= 0.02319999999999997 t= 0.02339999999999997 t= 0.023599999999999968 t= 0.023799999999999967 t= 0.023999999999999966 t= 0.024199999999999965 t= 0.024399999999999963 t= 0.024599999999999962 t= 0.02479999999999996 t= 0.02499999999999996 t= 0.02519999999999996 t= 0.025399999999999957 t= 0.025599999999999956 t= 0.025799999999999955 t= 0.025999999999999954 t= 0.026199999999999952 t= 0.02639999999999995 t= 0.02659999999999995 t= 0.02679999999999995 t= 0.026999999999999948 t= 0.027199999999999946 t= 0.027399999999999945 t= 0.027599999999999944 t= 0.027799999999999943 t= 0.02799999999999994 t= 0.02819999999999994 t= 0.02839999999999994 t= 0.028599999999999938 t= 0.028799999999999937 t= 0.028999999999999936 t= 0.029199999999999934 t= 0.029399999999999933 t= 0.029599999999999932 t= 0.02979999999999993 t= 0.02999999999999993 t= 0.03019999999999993 t= 0.030399999999999927 t= 0.030599999999999926 t= 0.030799999999999925 t= 0.030999999999999923 t= 0.031199999999999922 t= 0.03139999999999992 t= 0.03159999999999992 t= 0.03179999999999992 t= 0.03199999999999992 t= 0.032199999999999916 t= 0.032399999999999915 t= 0.032599999999999914 t= 0.03279999999999991 t= 0.03299999999999991 t= 0.03319999999999991 t= 0.03339999999999991 t= 0.03359999999999991 t= 0.033799999999999907 t= 0.033999999999999905 t= 0.034199999999999904 t= 0.0343999999999999 t= 0.0345999999999999 t= 0.0347999999999999 t= 0.0349999999999999 t= 0.0351999999999999 t= 0.0353999999999999 t= 0.035599999999999896 t= 0.035799999999999894 t= 0.03599999999999989 t= 0.03619999999999989 t= 0.03639999999999989 t= 0.03659999999999989 t= 0.03679999999999989 t= 0.03699999999999989 t= 0.037199999999999886 t= 0.037399999999999885 t= 0.037599999999999884 t= 0.03779999999999988 t= 0.03799999999999988 t= 0.03819999999999988 t= 0.03839999999999988 t= 0.03859999999999988 t= 0.038799999999999876 t= 0.038999999999999875 t= 0.039199999999999874 t= 0.03939999999999987 t= 0.03959999999999987 t= 0.03979999999999987 t= 0.03999999999999987 t= 0.04019999999999987 t= 0.04039999999999987 t= 0.040599999999999865 t= 0.040799999999999864 t= 0.04099999999999986 t= 0.04119999999999986 t= 0.04139999999999986 t= 0.04159999999999986 t= 0.04179999999999986 t= 0.04199999999999986 t= 0.042199999999999856 t= 0.042399999999999854 t= 0.04259999999999985 t= 0.04279999999999985 t= 0.04299999999999985 t= 0.04319999999999985 t= 0.04339999999999985 t= 0.04359999999999985 t= 0.043799999999999846 t= 0.043999999999999845 t= 0.044199999999999844 t= 0.04439999999999984 t= 0.04459999999999984 t= 0.04479999999999984 t= 0.04499999999999984 t= 0.04519999999999984 t= 0.045399999999999836 t= 0.045599999999999835 t= 0.045799999999999834 t= 0.04599999999999983 t= 0.04619999999999983 t= 0.04639999999999983 t= 0.04659999999999983 t= 0.04679999999999983 t= 0.04699999999999983 t= 0.047199999999999825 t= 0.047399999999999824 t= 0.04759999999999982 t= 0.04779999999999982 t= 0.04799999999999982 t= 0.04819999999999982 t= 0.04839999999999982 t= 0.04859999999999982 t= 0.048799999999999816 t= 0.048999999999999815 t= 0.04919999999999981 t= 0.04939999999999981 t= 0.04959999999999981 t= 0.04979999999999981 t= 0.04999999999999981 t= 0.05019999999999981 t= 0.050399999999999806 t= 0.050599999999999805 t= 0.050799999999999804 t= 0.0509999999999998 t= 0.0511999999999998 t= 0.0513999999999998 t= 0.0515999999999998 t= 0.0517999999999998 t= 0.051999999999999796 t= 0.052199999999999795 t= 0.052399999999999794 t= 0.05259999999999979 t= 0.05279999999999979 t= 0.05299999999999979 t= 0.05319999999999979 t= 0.05339999999999979 t= 0.05359999999999979 t= 0.053799999999999785 t= 0.053999999999999784 t= 0.05419999999999978 t= 0.05439999999999978 t= 0.05459999999999978 t= 0.05479999999999978 t= 0.05499999999999978 t= 0.05519999999999978 t= 0.055399999999999776 t= 0.055599999999999775 t= 0.05579999999999977 t= 0.05599999999999977 t= 0.05619999999999977 t= 0.05639999999999977 t= 0.05659999999999977 t= 0.05679999999999977 t= 0.056999999999999766 t= 0.057199999999999765 t= 0.057399999999999764 t= 0.05759999999999976 t= 0.05779999999999976 t= 0.05799999999999976 t= 0.05819999999999976 t= 0.05839999999999976 t= 0.058599999999999756 t= 0.058799999999999755 t= 0.058999999999999754 t= 0.05919999999999975 t= 0.05939999999999975 t= 0.05959999999999975 t= 0.05979999999999975 t= 0.05999999999999975 t= 0.06019999999999975 t= 0.060399999999999746 t= 0.060599999999999744 t= 0.06079999999999974 t= 0.06099999999999974 t= 0.06119999999999974 t= 0.06139999999999974 t= 0.06159999999999974 t= 0.06179999999999974 t= 0.061999999999999736 t= 0.062199999999999735 t= 0.06239999999999973 t= 0.06259999999999974 t= 0.06279999999999974 t= 0.06299999999999975 t= 0.06319999999999976 t= 0.06339999999999976 t= 0.06359999999999977 t= 0.06379999999999977 t= 0.06399999999999978 t= 0.06419999999999979 t= 0.06439999999999979 t= 0.0645999999999998 t= 0.0647999999999998 t= 0.06499999999999981 t= 0.06519999999999981 t= 0.06539999999999982 t= 0.06559999999999983 t= 0.06579999999999983 t= 0.06599999999999984 t= 0.06619999999999984 t= 0.06639999999999985 t= 0.06659999999999985 t= 0.06679999999999986 t= 0.06699999999999987 t= 0.06719999999999987 t= 0.06739999999999988 t= 0.06759999999999988 t= 0.06779999999999989 t= 0.0679999999999999 t= 0.0681999999999999 t= 0.0683999999999999 t= 0.06859999999999991 t= 0.06879999999999992 t= 0.06899999999999992 t= 0.06919999999999993 t= 0.06939999999999993 t= 0.06959999999999994 t= 0.06979999999999995 t= 0.06999999999999995 t= 0.07019999999999996 t= 0.07039999999999996 t= 0.07059999999999997 t= 0.07079999999999997 t= 0.07099999999999998 t= 0.07119999999999999 t= 0.07139999999999999 t= 0.0716 t= 0.0718 t= 0.07200000000000001 t= 0.07220000000000001 t= 0.07240000000000002 t= 0.07260000000000003 t= 0.07280000000000003 t= 0.07300000000000004 t= 0.07320000000000004 t= 0.07340000000000005 t= 0.07360000000000005 t= 0.07380000000000006 t= 0.07400000000000007 t= 0.07420000000000007 t= 0.07440000000000008 t= 0.07460000000000008 t= 0.07480000000000009 t= 0.0750000000000001 t= 0.0752000000000001 t= 0.0754000000000001 t= 0.07560000000000011 t= 0.07580000000000012 t= 0.07600000000000012 t= 0.07620000000000013 t= 0.07640000000000013 t= 0.07660000000000014 t= 0.07680000000000015 t= 0.07700000000000015 t= 0.07720000000000016 t= 0.07740000000000016 t= 0.07760000000000017 t= 0.07780000000000017 t= 0.07800000000000018 t= 0.07820000000000019 t= 0.07840000000000019 t= 0.0786000000000002 t= 0.0788000000000002 t= 0.07900000000000021 t= 0.07920000000000021 t= 0.07940000000000022 t= 0.07960000000000023 t= 0.07980000000000023 t= 0.08000000000000024 t= 0.08020000000000024 t= 0.08040000000000025 t= 0.08060000000000025 t= 0.08080000000000026 t= 0.08100000000000027 t= 0.08120000000000027 t= 0.08140000000000028 t= 0.08160000000000028 t= 0.08180000000000029 t= 0.0820000000000003 t= 0.0822000000000003 t= 0.0824000000000003 t= 0.08260000000000031 t= 0.08280000000000032 t= 0.08300000000000032 t= 0.08320000000000033 t= 0.08340000000000033 t= 0.08360000000000034 t= 0.08380000000000035 t= 0.08400000000000035 t= 0.08420000000000036 t= 0.08440000000000036 t= 0.08460000000000037 t= 0.08480000000000038 t= 0.08500000000000038 t= 0.08520000000000039 t= 0.08540000000000039 t= 0.0856000000000004 t= 0.0858000000000004 t= 0.08600000000000041 t= 0.08620000000000042 t= 0.08640000000000042 t= 0.08660000000000043 t= 0.08680000000000043 t= 0.08700000000000044 t= 0.08720000000000044 t= 0.08740000000000045 t= 0.08760000000000046 t= 0.08780000000000046 t= 0.08800000000000047 t= 0.08820000000000047 t= 0.08840000000000048 t= 0.08860000000000048 t= 0.08880000000000049 t= 0.0890000000000005 t= 0.0892000000000005 t= 0.0894000000000005 t= 0.08960000000000051 t= 0.08980000000000052 t= 0.09000000000000052 t= 0.09020000000000053 t= 0.09040000000000054 t= 0.09060000000000054 t= 0.09080000000000055 t= 0.09100000000000055 t= 0.09120000000000056 t= 0.09140000000000056 t= 0.09160000000000057 t= 0.09180000000000058 t= 0.09200000000000058 t= 0.09220000000000059 t= 0.09240000000000059 t= 0.0926000000000006 t= 0.0928000000000006 t= 0.09300000000000061 t= 0.09320000000000062 t= 0.09340000000000062 t= 0.09360000000000063 t= 0.09380000000000063 t= 0.09400000000000064 t= 0.09420000000000064 t= 0.09440000000000065 t= 0.09460000000000066 t= 0.09480000000000066 t= 0.09500000000000067 t= 0.09520000000000067 t= 0.09540000000000068 t= 0.09560000000000068 t= 0.09580000000000069 t= 0.0960000000000007 t= 0.0962000000000007 t= 0.09640000000000071 t= 0.09660000000000071 t= 0.09680000000000072 t= 0.09700000000000072 t= 0.09720000000000073 t= 0.09740000000000074 t= 0.09760000000000074 t= 0.09780000000000075 t= 0.09800000000000075 t= 0.09820000000000076 t= 0.09840000000000076 t= 0.09860000000000077 t= 0.09880000000000078 t= 0.09900000000000078 t= 0.09920000000000079 t= 0.0994000000000008 t= 0.0996000000000008 t= 0.0998000000000008 t= 0.10000000000000081 t= 0.10020000000000082 t= 0.10040000000000082 t= 0.10060000000000083 t= 0.10080000000000083 t= 0.10100000000000084 t= 0.10120000000000084 t= 0.10140000000000085 t= 0.10160000000000086 t= 0.10180000000000086 t= 0.10200000000000087 t= 0.10220000000000087 t= 0.10240000000000088 t= 0.10260000000000088 t= 0.10280000000000089 t= 0.1030000000000009 t= 0.1032000000000009 t= 0.10340000000000091 t= 0.10360000000000091 t= 0.10380000000000092 t= 0.10400000000000093 t= 0.10420000000000093 t= 0.10440000000000094 t= 0.10460000000000094 t= 0.10480000000000095 t= 0.10500000000000095 t= 0.10520000000000096 t= 0.10540000000000097 t= 0.10560000000000097 t= 0.10580000000000098 t= 0.10600000000000098 t= 0.10620000000000099 t= 0.106400000000001 t= 0.106600000000001 t= 0.106800000000001 t= 0.10700000000000101 t= 0.10720000000000102 t= 0.10740000000000102 t= 0.10760000000000103 t= 0.10780000000000103 t= 0.10800000000000104 t= 0.10820000000000105 t= 0.10840000000000105 t= 0.10860000000000106 t= 0.10880000000000106 t= 0.10900000000000107 t= 0.10920000000000107 t= 0.10940000000000108 t= 0.10960000000000109 t= 0.10980000000000109 t= 0.1100000000000011 t= 0.1102000000000011 t= 0.11040000000000111 t= 0.11060000000000111 t= 0.11080000000000112 t= 0.11100000000000113 t= 0.11120000000000113 t= 0.11140000000000114 t= 0.11160000000000114 t= 0.11180000000000115 t= 0.11200000000000115 t= 0.11220000000000116 t= 0.11240000000000117 t= 0.11260000000000117 t= 0.11280000000000118 t= 0.11300000000000118 t= 0.11320000000000119 t= 0.1134000000000012 t= 0.1136000000000012 t= 0.1138000000000012 t= 0.11400000000000121 t= 0.11420000000000122 t= 0.11440000000000122 t= 0.11460000000000123 t= 0.11480000000000123 t= 0.11500000000000124 t= 0.11520000000000125 t= 0.11540000000000125 t= 0.11560000000000126 t= 0.11580000000000126 t= 0.11600000000000127 t= 0.11620000000000127 t= 0.11640000000000128 t= 0.11660000000000129 t= 0.11680000000000129 t= 0.1170000000000013 t= 0.1172000000000013 t= 0.11740000000000131 t= 0.11760000000000131 t= 0.11780000000000132 t= 0.11800000000000133 t= 0.11820000000000133 t= 0.11840000000000134 t= 0.11860000000000134 t= 0.11880000000000135 t= 0.11900000000000135 t= 0.11920000000000136 t= 0.11940000000000137 t= 0.11960000000000137 t= 0.11980000000000138 t= 0.12000000000000138 t= 0.12020000000000139 t= 0.1204000000000014 t= 0.1206000000000014 t= 0.1208000000000014 t= 0.12100000000000141 t= 0.12120000000000142 t= 0.12140000000000142 t= 0.12160000000000143 t= 0.12180000000000143 t= 0.12200000000000144 t= 0.12220000000000145 t= 0.12240000000000145 t= 0.12260000000000146 t= 0.12280000000000146 t= 0.12300000000000147 t= 0.12320000000000147 t= 0.12340000000000148 t= 0.12360000000000149 t= 0.12380000000000149 t= 0.1240000000000015 t= 0.1242000000000015 t= 0.12440000000000151 t= 0.12460000000000152 t= 0.12480000000000152 t= 0.12500000000000153 t= 0.12520000000000153 t= 0.12540000000000154 t= 0.12560000000000154 t= 0.12580000000000155 t= 0.12600000000000156 t= 0.12620000000000156 t= 0.12640000000000157 t= 0.12660000000000157 t= 0.12680000000000158 t= 0.12700000000000158 t= 0.1272000000000016 t= 0.1274000000000016 t= 0.1276000000000016 t= 0.1278000000000016 t= 0.1280000000000016 t= 0.12820000000000162 t= 0.12840000000000162 t= 0.12860000000000163 t= 0.12880000000000164 t= 0.12900000000000164 t= 0.12920000000000165 t= 0.12940000000000165 t= 0.12960000000000166 t= 0.12980000000000166 t= 0.13000000000000167 t= 0.13020000000000168 t= 0.13040000000000168 t= 0.1306000000000017 t= 0.1308000000000017 t= 0.1310000000000017 t= 0.1312000000000017 t= 0.1314000000000017 t= 0.13160000000000172 t= 0.13180000000000172 t= 0.13200000000000173 t= 0.13220000000000173 t= 0.13240000000000174 t= 0.13260000000000174 t= 0.13280000000000175 t= 0.13300000000000176 t= 0.13320000000000176 t= 0.13340000000000177 t= 0.13360000000000177 t= 0.13380000000000178 t= 0.13400000000000178 t= 0.1342000000000018 t= 0.1344000000000018 t= 0.1346000000000018 t= 0.1348000000000018 t= 0.1350000000000018 t= 0.13520000000000182 t= 0.13540000000000182 t= 0.13560000000000183 t= 0.13580000000000184 t= 0.13600000000000184 t= 0.13620000000000185 t= 0.13640000000000185 t= 0.13660000000000186 t= 0.13680000000000186 t= 0.13700000000000187 t= 0.13720000000000188 t= 0.13740000000000188 t= 0.1376000000000019 t= 0.1378000000000019 t= 0.1380000000000019 t= 0.1382000000000019 t= 0.1384000000000019 t= 0.13860000000000192 t= 0.13880000000000192 t= 0.13900000000000193 t= 0.13920000000000193 t= 0.13940000000000194 t= 0.13960000000000194 t= 0.13980000000000195 t= 0.14000000000000196 t= 0.14020000000000196 t= 0.14040000000000197 t= 0.14060000000000197 t= 0.14080000000000198 t= 0.14100000000000198 t= 0.141200000000002 t= 0.141400000000002 t= 0.141600000000002 t= 0.141800000000002 t= 0.142000000000002 t= 0.14220000000000202 t= 0.14240000000000202 t= 0.14260000000000203 t= 0.14280000000000204 t= 0.14300000000000204 t= 0.14320000000000205 t= 0.14340000000000205 t= 0.14360000000000206 t= 0.14380000000000207 t= 0.14400000000000207 t= 0.14420000000000208 t= 0.14440000000000208 t= 0.1446000000000021 t= 0.1448000000000021 t= 0.1450000000000021 t= 0.1452000000000021 t= 0.1454000000000021 t= 0.14560000000000212 t= 0.14580000000000212 t= 0.14600000000000213 t= 0.14620000000000213 t= 0.14640000000000214 t= 0.14660000000000215 t= 0.14680000000000215 t= 0.14700000000000216 t= 0.14720000000000216 t= 0.14740000000000217 t= 0.14760000000000217 t= 0.14780000000000218 t= 0.14800000000000219 t= 0.1482000000000022 t= 0.1484000000000022 t= 0.1486000000000022 t= 0.1488000000000022 t= 0.14900000000000221 t= 0.14920000000000222 t= 0.14940000000000223 t= 0.14960000000000223 t= 0.14980000000000224 t= 0.15000000000000224 t= 0.15020000000000225 t= 0.15040000000000225 t= 0.15060000000000226 t= 0.15080000000000227 t= 0.15100000000000227 t= 0.15120000000000228 t= 0.15140000000000228 t= 0.1516000000000023 t= 0.1518000000000023 t= 0.1520000000000023 t= 0.1522000000000023 t= 0.1524000000000023 t= 0.15260000000000232 t= 0.15280000000000232 t= 0.15300000000000233 t= 0.15320000000000233 t= 0.15340000000000234 t= 0.15360000000000235 t= 0.15380000000000235 t= 0.15400000000000236 t= 0.15420000000000236 t= 0.15440000000000237 t= 0.15460000000000237 t= 0.15480000000000238 t= 0.15500000000000239 t= 0.1552000000000024 t= 0.1554000000000024 t= 0.1556000000000024 t= 0.1558000000000024 t= 0.15600000000000241 t= 0.15620000000000242 t= 0.15640000000000243 t= 0.15660000000000243 t= 0.15680000000000244 t= 0.15700000000000244 t= 0.15720000000000245 t= 0.15740000000000245 t= 0.15760000000000246 t= 0.15780000000000247 t= 0.15800000000000247 t= 0.15820000000000248 t= 0.15840000000000248 t= 0.1586000000000025 t= 0.1588000000000025 t= 0.1590000000000025 t= 0.1592000000000025 t= 0.1594000000000025 t= 0.15960000000000252 t= 0.15980000000000252 t= 0.16000000000000253 t= 0.16020000000000253 t= 0.16040000000000254 t= 0.16060000000000255 t= 0.16080000000000255 t= 0.16100000000000256 t= 0.16120000000000256 t= 0.16140000000000257 t= 0.16160000000000257 t= 0.16180000000000258 t= 0.1620000000000026 t= 0.1622000000000026 t= 0.1624000000000026 t= 0.1626000000000026 t= 0.1628000000000026 t= 0.16300000000000262 t= 0.16320000000000262 t= 0.16340000000000263 t= 0.16360000000000263 t= 0.16380000000000264 t= 0.16400000000000264 t= 0.16420000000000265 t= 0.16440000000000266 t= 0.16460000000000266 t= 0.16480000000000267 t= 0.16500000000000267 t= 0.16520000000000268 t= 0.16540000000000268 t= 0.1656000000000027 t= 0.1658000000000027 t= 0.1660000000000027 t= 0.1662000000000027 t= 0.1664000000000027 t= 0.16660000000000272 t= 0.16680000000000272 t= 0.16700000000000273 t= 0.16720000000000274 t= 0.16740000000000274 t= 0.16760000000000275 t= 0.16780000000000275 t= 0.16800000000000276 t= 0.16820000000000276 t= 0.16840000000000277 t= 0.16860000000000278 t= 0.16880000000000278 t= 0.1690000000000028 t= 0.1692000000000028 t= 0.1694000000000028 t= 0.1696000000000028 t= 0.1698000000000028 t= 0.17000000000000282 t= 0.17020000000000282 t= 0.17040000000000283 t= 0.17060000000000283 t= 0.17080000000000284 t= 0.17100000000000284 t= 0.17120000000000285 t= 0.17140000000000286 t= 0.17160000000000286 t= 0.17180000000000287 t= 0.17200000000000287 t= 0.17220000000000288 t= 0.17240000000000288 t= 0.1726000000000029 t= 0.1728000000000029 t= 0.1730000000000029 t= 0.1732000000000029 t= 0.1734000000000029 t= 0.17360000000000292 t= 0.17380000000000292 t= 0.17400000000000293 t= 0.17420000000000294 t= 0.17440000000000294 t= 0.17460000000000295 t= 0.17480000000000295 t= 0.17500000000000296 t= 0.17520000000000296 t= 0.17540000000000297 t= 0.17560000000000298 t= 0.17580000000000298 t= 0.176000000000003 t= 0.176200000000003 t= 0.176400000000003 t= 0.176600000000003 t= 0.176800000000003 t= 0.17700000000000302 t= 0.17720000000000302 t= 0.17740000000000303 t= 0.17760000000000303 t= 0.17780000000000304 t= 0.17800000000000304 t= 0.17820000000000305 t= 0.17840000000000306 t= 0.17860000000000306 t= 0.17880000000000307 t= 0.17900000000000307 t= 0.17920000000000308 t= 0.17940000000000308 t= 0.1796000000000031 t= 0.1798000000000031 t= 0.1800000000000031 t= 0.1802000000000031 t= 0.1804000000000031 t= 0.18060000000000312 t= 0.18080000000000312 t= 0.18100000000000313 t= 0.18120000000000314 t= 0.18140000000000314 t= 0.18160000000000315 t= 0.18180000000000315 t= 0.18200000000000316 t= 0.18220000000000316 t= 0.18240000000000317 t= 0.18260000000000318 t= 0.18280000000000318 t= 0.1830000000000032 t= 0.1832000000000032 t= 0.1834000000000032 t= 0.1836000000000032 t= 0.1838000000000032 t= 0.18400000000000322 t= 0.18420000000000322 t= 0.18440000000000323 t= 0.18460000000000323 t= 0.18480000000000324 t= 0.18500000000000325 t= 0.18520000000000325 t= 0.18540000000000326 t= 0.18560000000000326 t= 0.18580000000000327 t= 0.18600000000000327 t= 0.18620000000000328 t= 0.18640000000000329 t= 0.1866000000000033 t= 0.1868000000000033 t= 0.1870000000000033 t= 0.1872000000000033 t= 0.18740000000000331 t= 0.18760000000000332 t= 0.18780000000000333 t= 0.18800000000000333 t= 0.18820000000000334 t= 0.18840000000000334 t= 0.18860000000000335 t= 0.18880000000000335 t= 0.18900000000000336 t= 0.18920000000000337 t= 0.18940000000000337 t= 0.18960000000000338 t= 0.18980000000000338 t= 0.1900000000000034 t= 0.1902000000000034 t= 0.1904000000000034 t= 0.1906000000000034 t= 0.1908000000000034 t= 0.19100000000000342 t= 0.19120000000000342 t= 0.19140000000000343 t= 0.19160000000000343 t= 0.19180000000000344 t= 0.19200000000000345 t= 0.19220000000000345 t= 0.19240000000000346 t= 0.19260000000000346 t= 0.19280000000000347 t= 0.19300000000000347 t= 0.19320000000000348 t= 0.19340000000000349 t= 0.1936000000000035 t= 0.1938000000000035 t= 0.1940000000000035 t= 0.1942000000000035 t= 0.19440000000000351 t= 0.19460000000000352 t= 0.19480000000000353 t= 0.19500000000000353 t= 0.19520000000000354 t= 0.19540000000000354 t= 0.19560000000000355 t= 0.19580000000000355 t= 0.19600000000000356 t= 0.19620000000000357 t= 0.19640000000000357 t= 0.19660000000000358 t= 0.19680000000000358 t= 0.1970000000000036 t= 0.1972000000000036 t= 0.1974000000000036 t= 0.1976000000000036 t= 0.1978000000000036 t= 0.19800000000000362 t= 0.19820000000000362 t= 0.19840000000000363 t= 0.19860000000000363 t= 0.19880000000000364 t= 0.19900000000000365 t= 0.19920000000000365 t= 0.19940000000000366 t= 0.19960000000000366 t= 0.19980000000000367 t= 0.20000000000000367 t= 0.20020000000000368 t= 0.2004000000000037 t= 0.2006000000000037 t= 0.2008000000000037 t= 0.2010000000000037 t= 0.2012000000000037 t= 0.20140000000000371 t= 0.20160000000000372 t= 0.20180000000000373 t= 0.20200000000000373 t= 0.20220000000000374 t= 0.20240000000000374 t= 0.20260000000000375 t= 0.20280000000000376 t= 0.20300000000000376 t= 0.20320000000000377 t= 0.20340000000000377 t= 0.20360000000000378 t= 0.20380000000000378 t= 0.2040000000000038 t= 0.2042000000000038 t= 0.2044000000000038 t= 0.2046000000000038 t= 0.2048000000000038 t= 0.20500000000000382 t= 0.20520000000000382 t= 0.20540000000000383 t= 0.20560000000000384 t= 0.20580000000000384 t= 0.20600000000000385 t= 0.20620000000000385 t= 0.20640000000000386 t= 0.20660000000000386 t= 0.20680000000000387 t= 0.20700000000000388 t= 0.20720000000000388 t= 0.2074000000000039 t= 0.2076000000000039 t= 0.2078000000000039 t= 0.2080000000000039 t= 0.2082000000000039 t= 0.20840000000000392 t= 0.20860000000000392 t= 0.20880000000000393 t= 0.20900000000000393 t= 0.20920000000000394 t= 0.20940000000000394 t= 0.20960000000000395 t= 0.20980000000000396 t= 0.21000000000000396 t= 0.21020000000000397 t= 0.21040000000000397 t= 0.21060000000000398 t= 0.21080000000000398 t= 0.211000000000004 t= 0.211200000000004 t= 0.211400000000004 t= 0.211600000000004 t= 0.211800000000004 t= 0.21200000000000402 t= 0.21220000000000402 t= 0.21240000000000403 t= 0.21260000000000404 t= 0.21280000000000404 t= 0.21300000000000405 t= 0.21320000000000405 t= 0.21340000000000406 t= 0.21360000000000406 t= 0.21380000000000407 t= 0.21400000000000408 t= 0.21420000000000408 t= 0.2144000000000041 t= 0.2146000000000041 t= 0.2148000000000041 t= 0.2150000000000041 t= 0.2152000000000041 t= 0.21540000000000412 t= 0.21560000000000412 t= 0.21580000000000413 t= 0.21600000000000413 t= 0.21620000000000414 t= 0.21640000000000414 t= 0.21660000000000415 t= 0.21680000000000416 t= 0.21700000000000416 t= 0.21720000000000417 t= 0.21740000000000417 t= 0.21760000000000418 t= 0.21780000000000418 t= 0.2180000000000042 t= 0.2182000000000042 t= 0.2184000000000042 t= 0.2186000000000042 t= 0.2188000000000042 t= 0.21900000000000422 t= 0.21920000000000422 t= 0.21940000000000423 t= 0.21960000000000424 t= 0.21980000000000424 t= 0.22000000000000425 t= 0.22020000000000425 t= 0.22040000000000426 t= 0.22060000000000426 t= 0.22080000000000427 t= 0.22100000000000428 t= 0.22120000000000428 t= 0.2214000000000043 t= 0.2216000000000043 t= 0.2218000000000043 t= 0.2220000000000043 t= 0.2222000000000043 t= 0.22240000000000432 t= 0.22260000000000432 t= 0.22280000000000433 t= 0.22300000000000433 t= 0.22320000000000434 t= 0.22340000000000435 t= 0.22360000000000435 t= 0.22380000000000436 t= 0.22400000000000436 t= 0.22420000000000437 t= 0.22440000000000437 t= 0.22460000000000438 t= 0.22480000000000439 t= 0.2250000000000044 t= 0.2252000000000044 t= 0.2254000000000044 t= 0.2256000000000044 t= 0.2258000000000044 t= 0.22600000000000442 t= 0.22620000000000443 t= 0.22640000000000443 t= 0.22660000000000444 t= 0.22680000000000444 t= 0.22700000000000445 t= 0.22720000000000445 t= 0.22740000000000446 t= 0.22760000000000447 t= 0.22780000000000447 t= 0.22800000000000448 t= 0.22820000000000448 t= 0.2284000000000045 t= 0.2286000000000045 t= 0.2288000000000045 t= 0.2290000000000045 t= 0.2292000000000045 t= 0.22940000000000452 t= 0.22960000000000452 t= 0.22980000000000453 t= 0.23000000000000453 t= 0.23020000000000454 t= 0.23040000000000455 t= 0.23060000000000455 t= 0.23080000000000456 t= 0.23100000000000456 t= 0.23120000000000457 t= 0.23140000000000457 t= 0.23160000000000458 t= 0.23180000000000459 t= 0.2320000000000046 t= 0.2322000000000046 t= 0.2324000000000046 t= 0.2326000000000046 t= 0.23280000000000461 t= 0.23300000000000462 t= 0.23320000000000463 t= 0.23340000000000463 t= 0.23360000000000464 t= 0.23380000000000464 t= 0.23400000000000465 t= 0.23420000000000465 t= 0.23440000000000466 t= 0.23460000000000467 t= 0.23480000000000467 t= 0.23500000000000468 t= 0.23520000000000468 t= 0.2354000000000047 t= 0.2356000000000047 t= 0.2358000000000047 t= 0.2360000000000047 t= 0.2362000000000047 t= 0.23640000000000472 t= 0.23660000000000472 t= 0.23680000000000473 t= 0.23700000000000473 t= 0.23720000000000474 t= 0.23740000000000475 t= 0.23760000000000475 t= 0.23780000000000476 t= 0.23800000000000476 t= 0.23820000000000477 t= 0.23840000000000477 t= 0.23860000000000478 t= 0.2388000000000048 t= 0.2390000000000048 t= 0.2392000000000048 t= 0.2394000000000048 t= 0.2396000000000048 t= 0.23980000000000481 t= 0.24000000000000482 t= 0.24020000000000483 t= 0.24040000000000483 t= 0.24060000000000484 t= 0.24080000000000484 t= 0.24100000000000485 t= 0.24120000000000485 t= 0.24140000000000486 t= 0.24160000000000487 t= 0.24180000000000487 t= 0.24200000000000488 t= 0.24220000000000488 t= 0.2424000000000049 t= 0.2426000000000049 t= 0.2428000000000049 t= 0.2430000000000049 t= 0.2432000000000049 t= 0.24340000000000492 t= 0.24360000000000492 t= 0.24380000000000493 t= 0.24400000000000494 t= 0.24420000000000494 t= 0.24440000000000495 t= 0.24460000000000495 t= 0.24480000000000496 t= 0.24500000000000496 t= 0.24520000000000497 t= 0.24540000000000498 t= 0.24560000000000498 t= 0.245800000000005 t= 0.246000000000005 t= 0.246200000000005 t= 0.246400000000005 t= 0.246600000000005 t= 0.24680000000000502 t= 0.24700000000000502 t= 0.24720000000000503 t= 0.24740000000000503 t= 0.24760000000000504 t= 0.24780000000000504 t= 0.24800000000000505 t= 0.24820000000000506 t= 0.24840000000000506 t= 0.24860000000000507 t= 0.24880000000000507 t= 0.24900000000000508 t= 0.24920000000000508 t= 0.2494000000000051 t= 0.2496000000000051 t= 0.2498000000000051 t= 0.2500000000000051 t= 0.2502000000000051 t= 0.25040000000000506 t= 0.25060000000000504 t= 0.250800000000005 t= 0.251000000000005 t= 0.251200000000005 t= 0.25140000000000495 t= 0.25160000000000493 t= 0.2518000000000049 t= 0.2520000000000049 t= 0.25220000000000486 t= 0.25240000000000484 t= 0.2526000000000048 t= 0.2528000000000048 t= 0.2530000000000048 t= 0.25320000000000475 t= 0.25340000000000473 t= 0.2536000000000047 t= 0.2538000000000047 t= 0.25400000000000467 t= 0.25420000000000464 t= 0.2544000000000046 t= 0.2546000000000046 t= 0.2548000000000046 t= 0.25500000000000456 t= 0.25520000000000453 t= 0.2554000000000045 t= 0.2556000000000045 t= 0.25580000000000447 t= 0.25600000000000445 t= 0.2562000000000044 t= 0.2564000000000044 t= 0.2566000000000044 t= 0.25680000000000436 t= 0.25700000000000434 t= 0.2572000000000043 t= 0.2574000000000043 t= 0.25760000000000427 t= 0.25780000000000425 t= 0.2580000000000042 t= 0.2582000000000042 t= 0.2584000000000042 t= 0.25860000000000416 t= 0.25880000000000414 t= 0.2590000000000041 t= 0.2592000000000041 t= 0.25940000000000407 t= 0.25960000000000405 t= 0.259800000000004 t= 0.260000000000004 t= 0.260200000000004 t= 0.26040000000000396 t= 0.26060000000000394 t= 0.2608000000000039 t= 0.2610000000000039 t= 0.2612000000000039 t= 0.26140000000000385 t= 0.26160000000000383 t= 0.2618000000000038 t= 0.2620000000000038 t= 0.26220000000000376 t= 0.26240000000000374 t= 0.2626000000000037 t= 0.2628000000000037 t= 0.2630000000000037 t= 0.26320000000000365 t= 0.26340000000000363 t= 0.2636000000000036 t= 0.2638000000000036 t= 0.26400000000000357 t= 0.26420000000000354 t= 0.2644000000000035 t= 0.2646000000000035 t= 0.2648000000000035 t= 0.26500000000000346 t= 0.26520000000000343 t= 0.2654000000000034 t= 0.2656000000000034 t= 0.26580000000000337 t= 0.26600000000000334 t= 0.2662000000000033 t= 0.2664000000000033 t= 0.2666000000000033 t= 0.26680000000000326 t= 0.26700000000000323 t= 0.2672000000000032 t= 0.2674000000000032 t= 0.26760000000000317 t= 0.26780000000000315 t= 0.2680000000000031 t= 0.2682000000000031 t= 0.2684000000000031 t= 0.26860000000000306 t= 0.26880000000000304 t= 0.269000000000003 t= 0.269200000000003 t= 0.26940000000000297 t= 0.26960000000000295 t= 0.2698000000000029 t= 0.2700000000000029 t= 0.2702000000000029 t= 0.27040000000000286 t= 0.27060000000000284 t= 0.2708000000000028 t= 0.2710000000000028 t= 0.27120000000000277 t= 0.27140000000000275 t= 0.27160000000000273 t= 0.2718000000000027 t= 0.2720000000000027 t= 0.27220000000000266 t= 0.27240000000000264 t= 0.2726000000000026 t= 0.2728000000000026 t= 0.2730000000000026 t= 0.27320000000000255 t= 0.27340000000000253 t= 0.2736000000000025 t= 0.2738000000000025 t= 0.27400000000000246 t= 0.27420000000000244 t= 0.2744000000000024 t= 0.2746000000000024 t= 0.2748000000000024 t= 0.27500000000000235 t= 0.27520000000000233 t= 0.2754000000000023 t= 0.2756000000000023 t= 0.27580000000000227 t= 0.27600000000000224 t= 0.2762000000000022 t= 0.2764000000000022 t= 0.2766000000000022 t= 0.27680000000000216 t= 0.27700000000000213 t= 0.2772000000000021 t= 0.2774000000000021 t= 0.27760000000000207 t= 0.27780000000000205 t= 0.278000000000002 t= 0.278200000000002 t= 0.278400000000002 t= 0.27860000000000196 t= 0.27880000000000194 t= 0.2790000000000019 t= 0.2792000000000019 t= 0.27940000000000187 t= 0.27960000000000185 t= 0.2798000000000018 t= 0.2800000000000018 t= 0.2802000000000018 t= 0.28040000000000176 t= 0.28060000000000174 t= 0.2808000000000017 t= 0.2810000000000017 t= 0.28120000000000167 t= 0.28140000000000165 t= 0.2816000000000016 t= 0.2818000000000016 t= 0.2820000000000016 t= 0.28220000000000156 t= 0.28240000000000154 t= 0.2826000000000015 t= 0.2828000000000015 t= 0.2830000000000015 t= 0.28320000000000145 t= 0.28340000000000143 t= 0.2836000000000014 t= 0.2838000000000014 t= 0.28400000000000136 t= 0.28420000000000134 t= 0.2844000000000013 t= 0.2846000000000013 t= 0.2848000000000013 t= 0.28500000000000125 t= 0.28520000000000123 t= 0.2854000000000012 t= 0.2856000000000012 t= 0.28580000000000116 t= 0.28600000000000114 t= 0.2862000000000011 t= 0.2864000000000011 t= 0.2866000000000011 t= 0.28680000000000105 t= 0.28700000000000103 t= 0.287200000000001 t= 0.287400000000001 t= 0.28760000000000097 t= 0.28780000000000094 t= 0.2880000000000009 t= 0.2882000000000009 t= 0.2884000000000009 t= 0.28860000000000086 t= 0.28880000000000083 t= 0.2890000000000008 t= 0.2892000000000008 t= 0.28940000000000077 t= 0.28960000000000075 t= 0.2898000000000007 t= 0.2900000000000007 t= 0.2902000000000007 t= 0.29040000000000066 t= 0.29060000000000064 t= 0.2908000000000006 t= 0.2910000000000006 t= 0.29120000000000057 t= 0.29140000000000055 t= 0.2916000000000005 t= 0.2918000000000005 t= 0.2920000000000005 t= 0.29220000000000046 t= 0.29240000000000044 t= 0.2926000000000004 t= 0.2928000000000004 t= 0.29300000000000037 t= 0.29320000000000035 t= 0.2934000000000003 t= 0.2936000000000003 t= 0.2938000000000003 t= 0.29400000000000026 t= 0.29420000000000024 t= 0.2944000000000002 t= 0.2946000000000002 t= 0.2948000000000002 t= 0.29500000000000015 t= 0.29520000000000013 t= 0.2954000000000001 t= 0.2956000000000001 t= 0.29580000000000006 t= 0.29600000000000004 t= 0.2962 t= 0.2964 t= 0.2966 t= 0.29679999999999995 t= 0.29699999999999993 t= 0.2971999999999999 t= 0.2973999999999999 t= 0.29759999999999986 t= 0.29779999999999984 t= 0.2979999999999998 t= 0.2981999999999998 t= 0.2983999999999998 t= 0.29859999999999975 t= 0.29879999999999973 t= 0.2989999999999997 t= 0.2991999999999997 t= 0.29939999999999967 t= 0.29959999999999964 t= 0.2997999999999996 t= 0.2999999999999996 t= 0.3001999999999996 t= 0.30039999999999956 t= 0.30059999999999953 t= 0.3007999999999995 t= 0.3009999999999995 t= 0.30119999999999947 t= 0.30139999999999945 t= 0.3015999999999994 t= 0.3017999999999994 t= 0.3019999999999994 t= 0.30219999999999936 t= 0.30239999999999934 t= 0.3025999999999993 t= 0.3027999999999993 t= 0.30299999999999927 t= 0.30319999999999925 t= 0.3033999999999992 t= 0.3035999999999992 t= 0.3037999999999992 t= 0.30399999999999916 t= 0.30419999999999914 t= 0.3043999999999991 t= 0.3045999999999991 t= 0.30479999999999907 t= 0.30499999999999905 t= 0.305199999999999 t= 0.305399999999999 t= 0.305599999999999 t= 0.30579999999999896 t= 0.30599999999999894 t= 0.3061999999999989 t= 0.3063999999999989 t= 0.3065999999999989 t= 0.30679999999999885 t= 0.30699999999999883 t= 0.3071999999999988 t= 0.3073999999999988 t= 0.30759999999999876 t= 0.30779999999999874 t= 0.3079999999999987 t= 0.3081999999999987 t= 0.3083999999999987 t= 0.30859999999999865 t= 0.30879999999999863 t= 0.3089999999999986 t= 0.3091999999999986 t= 0.30939999999999857 t= 0.30959999999999854 t= 0.3097999999999985 t= 0.3099999999999985 t= 0.3101999999999985 t= 0.31039999999999845 t= 0.31059999999999843 t= 0.3107999999999984 t= 0.3109999999999984 t= 0.31119999999999837 t= 0.31139999999999834 t= 0.3115999999999983 t= 0.3117999999999983 t= 0.3119999999999983 t= 0.31219999999999826 t= 0.31239999999999823 t= 0.3125999999999982 t= 0.3127999999999982 t= 0.31299999999999817 t= 0.31319999999999815 t= 0.3133999999999981 t= 0.3135999999999981 t= 0.3137999999999981 t= 0.31399999999999806 t= 0.31419999999999804 t= 0.314399999999998 t= 0.314599999999998 t= 0.31479999999999797 t= 0.31499999999999795 t= 0.3151999999999979 t= 0.3153999999999979 t= 0.3155999999999979 t= 0.31579999999999786 t= 0.31599999999999784 t= 0.3161999999999978 t= 0.3163999999999978 t= 0.31659999999999777 t= 0.31679999999999775 t= 0.31699999999999773 t= 0.3171999999999977 t= 0.3173999999999977 t= 0.31759999999999766 t= 0.31779999999999764 t= 0.3179999999999976 t= 0.3181999999999976 t= 0.3183999999999976 t= 0.31859999999999755 t= 0.31879999999999753 t= 0.3189999999999975 t= 0.3191999999999975 t= 0.31939999999999746 t= 0.31959999999999744 t= 0.3197999999999974 t= 0.3199999999999974 t= 0.3201999999999974 t= 0.32039999999999735 t= 0.32059999999999733 t= 0.3207999999999973 t= 0.3209999999999973 t= 0.32119999999999727 t= 0.32139999999999724 t= 0.3215999999999972 t= 0.3217999999999972 t= 0.3219999999999972 t= 0.32219999999999716 t= 0.32239999999999713 t= 0.3225999999999971 t= 0.3227999999999971 t= 0.32299999999999707 t= 0.32319999999999705 t= 0.323399999999997 t= 0.323599999999997 t= 0.323799999999997 t= 0.32399999999999696 t= 0.32419999999999694 t= 0.3243999999999969 t= 0.3245999999999969 t= 0.32479999999999687 t= 0.32499999999999685 t= 0.3251999999999968 t= 0.3253999999999968 t= 0.3255999999999968 t= 0.32579999999999676 t= 0.32599999999999674 t= 0.3261999999999967 t= 0.3263999999999967 t= 0.32659999999999667 t= 0.32679999999999665 t= 0.3269999999999966 t= 0.3271999999999966 t= 0.3273999999999966 t= 0.32759999999999656 t= 0.32779999999999654 t= 0.3279999999999965 t= 0.3281999999999965 t= 0.3283999999999965 t= 0.32859999999999645 t= 0.32879999999999643 t= 0.3289999999999964 t= 0.3291999999999964 t= 0.32939999999999636 t= 0.32959999999999634 t= 0.3297999999999963 t= 0.3299999999999963 t= 0.3301999999999963 t= 0.33039999999999625 t= 0.33059999999999623 t= 0.3307999999999962 t= 0.3309999999999962 t= 0.33119999999999616 t= 0.33139999999999614 t= 0.3315999999999961 t= 0.3317999999999961 t= 0.3319999999999961 t= 0.33219999999999605 t= 0.33239999999999603 t= 0.332599999999996 t= 0.332799999999996 t= 0.33299999999999597 t= 0.33319999999999594 t= 0.3333999999999959 t= 0.3335999999999959 t= 0.3337999999999959 t= 0.33399999999999586 t= 0.33419999999999583 t= 0.3343999999999958 t= 0.3345999999999958 t= 0.33479999999999577 t= 0.33499999999999575 t= 0.3351999999999957 t= 0.3353999999999957 t= 0.3355999999999957 t= 0.33579999999999566 t= 0.33599999999999564 t= 0.3361999999999956 t= 0.3363999999999956 t= 0.33659999999999557 t= 0.33679999999999555 t= 0.3369999999999955 t= 0.3371999999999955 t= 0.3373999999999955 t= 0.33759999999999546 t= 0.33779999999999544 t= 0.3379999999999954 t= 0.3381999999999954 t= 0.33839999999999537 t= 0.33859999999999535 t= 0.3387999999999953 t= 0.3389999999999953 t= 0.3391999999999953 t= 0.33939999999999526 t= 0.33959999999999524 t= 0.3397999999999952 t= 0.3399999999999952 t= 0.3401999999999952 t= 0.34039999999999515 t= 0.34059999999999513 t= 0.3407999999999951 t= 0.3409999999999951 t= 0.34119999999999506 t= 0.34139999999999504 t= 0.341599999999995 t= 0.341799999999995 t= 0.341999999999995 t= 0.34219999999999495 t= 0.34239999999999493 t= 0.3425999999999949 t= 0.3427999999999949 t= 0.34299999999999486 t= 0.34319999999999484 t= 0.3433999999999948 t= 0.3435999999999948 t= 0.3437999999999948 t= 0.34399999999999475 t= 0.34419999999999473 t= 0.3443999999999947 t= 0.3445999999999947 t= 0.34479999999999467 t= 0.34499999999999464 t= 0.3451999999999946 t= 0.3453999999999946 t= 0.3455999999999946 t= 0.34579999999999456 t= 0.34599999999999453 t= 0.3461999999999945 t= 0.3463999999999945 t= 0.34659999999999447 t= 0.34679999999999445 t= 0.3469999999999944 t= 0.3471999999999944 t= 0.3473999999999944 t= 0.34759999999999436 t= 0.34779999999999434 t= 0.3479999999999943 t= 0.3481999999999943 t= 0.34839999999999427 t= 0.34859999999999425 t= 0.3487999999999942 t= 0.3489999999999942 t= 0.3491999999999942 t= 0.34939999999999416 t= 0.34959999999999414 t= 0.3497999999999941 t= 0.3499999999999941 t= 0.35019999999999407 t= 0.35039999999999405 t= 0.350599999999994 t= 0.350799999999994 t= 0.350999999999994 t= 0.35119999999999396 t= 0.35139999999999394 t= 0.3515999999999939 t= 0.3517999999999939 t= 0.3519999999999939 t= 0.35219999999999385 t= 0.35239999999999383 t= 0.3525999999999938 t= 0.3527999999999938 t= 0.35299999999999376 t= 0.35319999999999374 t= 0.3533999999999937 t= 0.3535999999999937 t= 0.3537999999999937 t= 0.35399999999999365 t= 0.35419999999999363 t= 0.3543999999999936 t= 0.3545999999999936 t= 0.35479999999999356 t= 0.35499999999999354 t= 0.3551999999999935 t= 0.3553999999999935 t= 0.3555999999999935 t= 0.35579999999999345 t= 0.35599999999999343 t= 0.3561999999999934 t= 0.3563999999999934 t= 0.35659999999999337 t= 0.35679999999999334 t= 0.3569999999999933 t= 0.3571999999999933 t= 0.3573999999999933 t= 0.35759999999999326 t= 0.35779999999999323 t= 0.3579999999999932 t= 0.3581999999999932 t= 0.35839999999999317 t= 0.35859999999999315 t= 0.3587999999999931 t= 0.3589999999999931 t= 0.3591999999999931 t= 0.35939999999999306 t= 0.35959999999999304 t= 0.359799999999993 t= 0.359999999999993 t= 0.36019999999999297 t= 0.36039999999999295 t= 0.3605999999999929 t= 0.3607999999999929 t= 0.3609999999999929 t= 0.36119999999999286 t= 0.36139999999999284 t= 0.3615999999999928 t= 0.3617999999999928 t= 0.36199999999999277 t= 0.36219999999999275 t= 0.36239999999999273 t= 0.3625999999999927 t= 0.3627999999999927 t= 0.36299999999999266 t= 0.36319999999999264 t= 0.3633999999999926 t= 0.3635999999999926 t= 0.3637999999999926 t= 0.36399999999999255 t= 0.36419999999999253 t= 0.3643999999999925 t= 0.3645999999999925 t= 0.36479999999999246 t= 0.36499999999999244 t= 0.3651999999999924 t= 0.3653999999999924 t= 0.3655999999999924 t= 0.36579999999999235 t= 0.36599999999999233 t= 0.3661999999999923 t= 0.3663999999999923 t= 0.36659999999999227 t= 0.36679999999999224 t= 0.3669999999999922 t= 0.3671999999999922 t= 0.3673999999999922 t= 0.36759999999999216 t= 0.36779999999999213 t= 0.3679999999999921 t= 0.3681999999999921 t= 0.36839999999999207 t= 0.36859999999999205 t= 0.368799999999992 t= 0.368999999999992 t= 0.369199999999992 t= 0.36939999999999196 t= 0.36959999999999193 t= 0.3697999999999919 t= 0.3699999999999919 t= 0.37019999999999187 t= 0.37039999999999185 t= 0.3705999999999918 t= 0.3707999999999918 t= 0.3709999999999918 t= 0.37119999999999176 t= 0.37139999999999174 t= 0.3715999999999917 t= 0.3717999999999917 t= 0.37199999999999167 t= 0.37219999999999165 t= 0.3723999999999916 t= 0.3725999999999916 t= 0.3727999999999916 t= 0.37299999999999156 t= 0.37319999999999154 t= 0.3733999999999915 t= 0.3735999999999915 t= 0.3737999999999915 t= 0.37399999999999145 t= 0.37419999999999143 t= 0.3743999999999914 t= 0.3745999999999914 t= 0.37479999999999136 t= 0.37499999999999134 t= 0.3751999999999913 t= 0.3753999999999913 t= 0.3755999999999913 t= 0.37579999999999125 t= 0.37599999999999123 t= 0.3761999999999912 t= 0.3763999999999912 t= 0.37659999999999116 t= 0.37679999999999114 t= 0.3769999999999911 t= 0.3771999999999911 t= 0.3773999999999911 t= 0.37759999999999105 t= 0.37779999999999103 t= 0.377999999999991 t= 0.378199999999991 t= 0.37839999999999097 t= 0.37859999999999094 t= 0.3787999999999909 t= 0.3789999999999909 t= 0.3791999999999909 t= 0.37939999999999086 t= 0.37959999999999083 t= 0.3797999999999908 t= 0.3799999999999908 t= 0.38019999999999077 t= 0.38039999999999075 t= 0.3805999999999907 t= 0.3807999999999907 t= 0.3809999999999907 t= 0.38119999999999066 t= 0.38139999999999064 t= 0.3815999999999906 t= 0.3817999999999906 t= 0.38199999999999057 t= 0.38219999999999055 t= 0.3823999999999905 t= 0.3825999999999905 t= 0.3827999999999905 t= 0.38299999999999046 t= 0.38319999999999044 t= 0.3833999999999904 t= 0.3835999999999904 t= 0.38379999999999037 t= 0.38399999999999035 t= 0.3841999999999903 t= 0.3843999999999903 t= 0.3845999999999903 t= 0.38479999999999026 t= 0.38499999999999024 t= 0.3851999999999902 t= 0.3853999999999902 t= 0.3855999999999902 t= 0.38579999999999015 t= 0.38599999999999013 t= 0.3861999999999901 t= 0.3863999999999901 t= 0.38659999999999006 t= 0.38679999999999004 t= 0.38699999999999 t= 0.38719999999999 t= 0.38739999999999 t= 0.38759999999998995 t= 0.38779999999998993 t= 0.3879999999999899 t= 0.3881999999999899 t= 0.38839999999998986 t= 0.38859999999998984 t= 0.3887999999999898 t= 0.3889999999999898 t= 0.3891999999999898 t= 0.38939999999998975 t= 0.38959999999998973 t= 0.3897999999999897 t= 0.3899999999999897 t= 0.39019999999998967 t= 0.39039999999998964 t= 0.3905999999999896 t= 0.3907999999999896 t= 0.3909999999999896 t= 0.39119999999998956 t= 0.39139999999998953 t= 0.3915999999999895 t= 0.3917999999999895 t= 0.39199999999998947 t= 0.39219999999998945 t= 0.3923999999999894 t= 0.3925999999999894 t= 0.3927999999999894 t= 0.39299999999998936 t= 0.39319999999998934 t= 0.3933999999999893 t= 0.3935999999999893 t= 0.39379999999998927 t= 0.39399999999998925 t= 0.3941999999999892 t= 0.3943999999999892 t= 0.3945999999999892 t= 0.39479999999998916 t= 0.39499999999998914 t= 0.3951999999999891 t= 0.3953999999999891 t= 0.39559999999998907 t= 0.39579999999998905 t= 0.395999999999989 t= 0.396199999999989 t= 0.396399999999989 t= 0.39659999999998896 t= 0.39679999999998894 t= 0.3969999999999889 t= 0.3971999999999889 t= 0.3973999999999889 t= 0.39759999999998885 t= 0.39779999999998883 t= 0.3979999999999888 t= 0.3981999999999888 t= 0.39839999999998876 t= 0.39859999999998874 t= 0.3987999999999887 t= 0.3989999999999887 t= 0.3991999999999887 t= 0.39939999999998865 t= 0.39959999999998863 t= 0.3997999999999886 t= 0.3999999999999886 t= 0.40019999999998856 t= 0.40039999999998854 t= 0.4005999999999885 t= 0.4007999999999885 t= 0.4009999999999885 t= 0.40119999999998845 t= 0.40139999999998843 t= 0.4015999999999884 t= 0.4017999999999884 t= 0.40199999999998837 t= 0.40219999999998834 t= 0.4023999999999883 t= 0.4025999999999883 t= 0.4027999999999883 t= 0.40299999999998826 t= 0.40319999999998823 t= 0.4033999999999882 t= 0.4035999999999882 t= 0.40379999999998817 t= 0.40399999999998815 t= 0.4041999999999881 t= 0.4043999999999881 t= 0.4045999999999881 t= 0.40479999999998806 t= 0.40499999999998804 t= 0.405199999999988 t= 0.405399999999988 t= 0.40559999999998797 t= 0.40579999999998795 t= 0.4059999999999879 t= 0.4061999999999879 t= 0.4063999999999879 t= 0.40659999999998786 t= 0.40679999999998784 t= 0.4069999999999878 t= 0.4071999999999878 t= 0.40739999999998777 t= 0.40759999999998775 t= 0.40779999999998773 t= 0.4079999999999877 t= 0.4081999999999877 t= 0.40839999999998766 t= 0.40859999999998764 t= 0.4087999999999876 t= 0.4089999999999876 t= 0.4091999999999876 t= 0.40939999999998755 t= 0.40959999999998753 t= 0.4097999999999875 t= 0.4099999999999875 t= 0.41019999999998746 t= 0.41039999999998744 t= 0.4105999999999874 t= 0.4107999999999874 t= 0.4109999999999874 t= 0.41119999999998735 t= 0.41139999999998733 t= 0.4115999999999873 t= 0.4117999999999873 t= 0.41199999999998727 t= 0.41219999999998724 t= 0.4123999999999872 t= 0.4125999999999872 t= 0.4127999999999872 t= 0.41299999999998716 t= 0.41319999999998713 t= 0.4133999999999871 t= 0.4135999999999871 t= 0.41379999999998707 t= 0.41399999999998705 t= 0.414199999999987 t= 0.414399999999987 t= 0.414599999999987 t= 0.41479999999998696 t= 0.41499999999998693 t= 0.4151999999999869 t= 0.4153999999999869 t= 0.41559999999998687 t= 0.41579999999998685 t= 0.4159999999999868 t= 0.4161999999999868 t= 0.4163999999999868 t= 0.41659999999998676 t= 0.41679999999998674 t= 0.4169999999999867 t= 0.4171999999999867 t= 0.41739999999998667 t= 0.41759999999998665 t= 0.4177999999999866 t= 0.4179999999999866 t= 0.4181999999999866 t= 0.41839999999998656 t= 0.41859999999998654 t= 0.4187999999999865 t= 0.4189999999999865 t= 0.4191999999999865 t= 0.41939999999998645 t= 0.41959999999998643 t= 0.4197999999999864 t= 0.4199999999999864 t= 0.42019999999998636 t= 0.42039999999998634 t= 0.4205999999999863 t= 0.4207999999999863 t= 0.4209999999999863 t= 0.42119999999998625 t= 0.42139999999998623 t= 0.4215999999999862 t= 0.4217999999999862 t= 0.42199999999998616 t= 0.42219999999998614 t= 0.4223999999999861 t= 0.4225999999999861 t= 0.4227999999999861 t= 0.42299999999998605 t= 0.42319999999998603 t= 0.423399999999986 t= 0.423599999999986 t= 0.42379999999998597 t= 0.42399999999998594 t= 0.4241999999999859 t= 0.4243999999999859 t= 0.4245999999999859 t= 0.42479999999998586 t= 0.42499999999998583 t= 0.4251999999999858 t= 0.4253999999999858 t= 0.42559999999998577 t= 0.42579999999998575 t= 0.4259999999999857 t= 0.4261999999999857 t= 0.4263999999999857 t= 0.42659999999998566 t= 0.42679999999998564 t= 0.4269999999999856 t= 0.4271999999999856 t= 0.42739999999998557 t= 0.42759999999998555 t= 0.4277999999999855 t= 0.4279999999999855 t= 0.4281999999999855 t= 0.42839999999998546 t= 0.42859999999998544 t= 0.4287999999999854 t= 0.4289999999999854 t= 0.42919999999998537 t= 0.42939999999998535 t= 0.4295999999999853 t= 0.4297999999999853 t= 0.4299999999999853 t= 0.43019999999998526 t= 0.43039999999998524 t= 0.4305999999999852 t= 0.4307999999999852 t= 0.4309999999999852 t= 0.43119999999998515 t= 0.43139999999998513 t= 0.4315999999999851 t= 0.4317999999999851 t= 0.43199999999998506 t= 0.43219999999998504 t= 0.432399999999985 t= 0.432599999999985 t= 0.432799999999985 t= 0.43299999999998495 t= 0.43319999999998493 t= 0.4333999999999849 t= 0.4335999999999849 t= 0.43379999999998486 t= 0.43399999999998484 t= 0.4341999999999848 t= 0.4343999999999848 t= 0.4345999999999848 t= 0.43479999999998475 t= 0.43499999999998473 t= 0.4351999999999847 t= 0.4353999999999847 t= 0.43559999999998467 t= 0.43579999999998464 t= 0.4359999999999846 t= 0.4361999999999846 t= 0.4363999999999846 t= 0.43659999999998456 t= 0.43679999999998453 t= 0.4369999999999845 t= 0.4371999999999845 t= 0.43739999999998447 t= 0.43759999999998445 t= 0.4377999999999844 t= 0.4379999999999844 t= 0.4381999999999844 t= 0.43839999999998436 t= 0.43859999999998434 t= 0.4387999999999843 t= 0.4389999999999843 t= 0.43919999999998427 t= 0.43939999999998425 t= 0.4395999999999842 t= 0.4397999999999842 t= 0.4399999999999842 t= 0.44019999999998416 t= 0.44039999999998414 t= 0.4405999999999841 t= 0.4407999999999841 t= 0.44099999999998407 t= 0.44119999999998405 t= 0.441399999999984 t= 0.441599999999984 t= 0.441799999999984 t= 0.44199999999998396 t= 0.44219999999998394 t= 0.4423999999999839 t= 0.4425999999999839 t= 0.4427999999999839 t= 0.44299999999998385 t= 0.44319999999998383 t= 0.4433999999999838 t= 0.4435999999999838 t= 0.44379999999998376 t= 0.44399999999998374 t= 0.4441999999999837 t= 0.4443999999999837 t= 0.4445999999999837 t= 0.44479999999998365 t= 0.44499999999998363 t= 0.4451999999999836 t= 0.4453999999999836 t= 0.44559999999998356 t= 0.44579999999998354 t= 0.4459999999999835 t= 0.4461999999999835 t= 0.4463999999999835 t= 0.44659999999998345 t= 0.44679999999998343 t= 0.4469999999999834 t= 0.4471999999999834 t= 0.44739999999998337 t= 0.44759999999998334 t= 0.4477999999999833 t= 0.4479999999999833 t= 0.4481999999999833 t= 0.44839999999998326 t= 0.44859999999998323 t= 0.4487999999999832 t= 0.4489999999999832 t= 0.44919999999998317 t= 0.44939999999998315 t= 0.4495999999999831 t= 0.4497999999999831 t= 0.4499999999999831 t= 0.45019999999998306 t= 0.45039999999998304 t= 0.450599999999983 t= 0.450799999999983 t= 0.45099999999998297 t= 0.45119999999998295 t= 0.4513999999999829 t= 0.4515999999999829 t= 0.4517999999999829 t= 0.45199999999998286 t= 0.45219999999998284 t= 0.4523999999999828 t= 0.4525999999999828 t= 0.45279999999998277 t= 0.45299999999998275 t= 0.45319999999998273 t= 0.4533999999999827 t= 0.4535999999999827 t= 0.45379999999998266 t= 0.45399999999998264 t= 0.4541999999999826 t= 0.4543999999999826 t= 0.4545999999999826 t= 0.45479999999998255 t= 0.45499999999998253 t= 0.4551999999999825 t= 0.4553999999999825 t= 0.45559999999998246 t= 0.45579999999998244 t= 0.4559999999999824 t= 0.4561999999999824 t= 0.4563999999999824 t= 0.45659999999998235 t= 0.45679999999998233 t= 0.4569999999999823 t= 0.4571999999999823 t= 0.45739999999998227 t= 0.45759999999998224 t= 0.4577999999999822 t= 0.4579999999999822 t= 0.4581999999999822 t= 0.45839999999998216 t= 0.45859999999998213 t= 0.4587999999999821 t= 0.4589999999999821 t= 0.45919999999998207 t= 0.45939999999998204 t= 0.459599999999982 t= 0.459799999999982 t= 0.459999999999982 t= 0.46019999999998196 t= 0.46039999999998193 t= 0.4605999999999819 t= 0.4607999999999819 t= 0.46099999999998187 t= 0.46119999999998185 t= 0.4613999999999818 t= 0.4615999999999818 t= 0.4617999999999818 t= 0.46199999999998176 t= 0.46219999999998174 t= 0.4623999999999817 t= 0.4625999999999817 t= 0.46279999999998167 t= 0.46299999999998165 t= 0.4631999999999816 t= 0.4633999999999816 t= 0.4635999999999816 t= 0.46379999999998156 t= 0.46399999999998154 t= 0.4641999999999815 t= 0.4643999999999815 t= 0.46459999999998147 t= 0.46479999999998145 t= 0.46499999999998143 t= 0.4651999999999814 t= 0.4653999999999814 t= 0.46559999999998136 t= 0.46579999999998134 t= 0.4659999999999813 t= 0.4661999999999813 t= 0.4663999999999813 t= 0.46659999999998125 t= 0.46679999999998123 t= 0.4669999999999812 t= 0.4671999999999812 t= 0.46739999999998116 t= 0.46759999999998114 t= 0.4677999999999811 t= 0.4679999999999811 t= 0.4681999999999811 t= 0.46839999999998105 t= 0.46859999999998103 t= 0.468799999999981 t= 0.468999999999981 t= 0.46919999999998097 t= 0.46939999999998094 t= 0.4695999999999809 t= 0.4697999999999809 t= 0.4699999999999809 t= 0.47019999999998086 t= 0.47039999999998083 t= 0.4705999999999808 t= 0.4707999999999808 t= 0.47099999999998077 t= 0.47119999999998075 t= 0.4713999999999807 t= 0.4715999999999807 t= 0.4717999999999807 t= 0.47199999999998066 t= 0.47219999999998064 t= 0.4723999999999806 t= 0.4725999999999806 t= 0.47279999999998057 t= 0.47299999999998055 t= 0.4731999999999805 t= 0.4733999999999805 t= 0.4735999999999805 t= 0.47379999999998046 t= 0.47399999999998044 t= 0.4741999999999804 t= 0.4743999999999804 t= 0.47459999999998037 t= 0.47479999999998035 t= 0.4749999999999803 t= 0.4751999999999803 t= 0.4753999999999803 t= 0.47559999999998026 t= 0.47579999999998024 t= 0.4759999999999802 t= 0.4761999999999802 t= 0.4763999999999802 t= 0.47659999999998015 t= 0.47679999999998013 t= 0.4769999999999801 t= 0.4771999999999801 t= 0.47739999999998006 t= 0.47759999999998004 t= 0.47779999999998 t= 0.47799999999998 t= 0.47819999999998 t= 0.47839999999997995 t= 0.47859999999997993 t= 0.4787999999999799 t= 0.4789999999999799 t= 0.47919999999997986 t= 0.47939999999997984 t= 0.4795999999999798 t= 0.4797999999999798 t= 0.4799999999999798 t= 0.48019999999997975 t= 0.48039999999997973 t= 0.4805999999999797 t= 0.4807999999999797 t= 0.48099999999997967 t= 0.48119999999997964 t= 0.4813999999999796 t= 0.4815999999999796 t= 0.4817999999999796 t= 0.48199999999997956 t= 0.48219999999997953 t= 0.4823999999999795 t= 0.4825999999999795 t= 0.48279999999997947 t= 0.48299999999997945 t= 0.4831999999999794 t= 0.4833999999999794 t= 0.4835999999999794 t= 0.48379999999997936 t= 0.48399999999997934 t= 0.4841999999999793 t= 0.4843999999999793 t= 0.48459999999997927 t= 0.48479999999997925 t= 0.4849999999999792 t= 0.4851999999999792 t= 0.4853999999999792 t= 0.48559999999997916 t= 0.48579999999997914 t= 0.4859999999999791 t= 0.4861999999999791 t= 0.48639999999997907 t= 0.48659999999997905 t= 0.486799999999979 t= 0.486999999999979 t= 0.487199999999979 t= 0.48739999999997896 t= 0.48759999999997894 t= 0.4877999999999789 t= 0.4879999999999789 t= 0.4881999999999789 t= 0.48839999999997885 t= 0.48859999999997883 t= 0.4887999999999788 t= 0.4889999999999788 t= 0.48919999999997876 t= 0.48939999999997874 t= 0.4895999999999787 t= 0.4897999999999787 t= 0.4899999999999787 t= 0.49019999999997865 t= 0.49039999999997863 t= 0.4905999999999786 t= 0.4907999999999786 t= 0.49099999999997856 t= 0.49119999999997854 t= 0.4913999999999785 t= 0.4915999999999785 t= 0.4917999999999785 t= 0.49199999999997845 t= 0.49219999999997843 t= 0.4923999999999784 t= 0.4925999999999784 t= 0.49279999999997837 t= 0.49299999999997834 t= 0.4931999999999783 t= 0.4933999999999783 t= 0.4935999999999783 t= 0.49379999999997826 t= 0.49399999999997823 t= 0.4941999999999782 t= 0.4943999999999782 t= 0.49459999999997817 t= 0.49479999999997815 t= 0.4949999999999781 t= 0.4951999999999781 t= 0.4953999999999781 t= 0.49559999999997806 t= 0.49579999999997804 t= 0.495999999999978 t= 0.496199999999978 t= 0.49639999999997797 t= 0.49659999999997795 t= 0.4967999999999779 t= 0.4969999999999779 t= 0.4971999999999779 t= 0.49739999999997786 t= 0.49759999999997784 t= 0.4977999999999778 t= 0.4979999999999778 t= 0.49819999999997777 t= 0.49839999999997775 t= 0.4985999999999777 t= 0.4987999999999777 t= 0.4989999999999777 t= 0.49919999999997766 t= 0.49939999999997764 t= 0.4995999999999776 t= 0.4997999999999776 t= 0.4999999999999776 t= 0.5001999999999776 t= 0.5003999999999775 t= 0.5005999999999775 t= 0.5007999999999775 t= 0.5009999999999775 t= 0.5011999999999774 t= 0.5013999999999774 t= 0.5015999999999774 t= 0.5017999999999774 t= 0.5019999999999774 t= 0.5021999999999773 t= 0.5023999999999773 t= 0.5025999999999773 t= 0.5027999999999773 t= 0.5029999999999772 t= 0.5031999999999772 t= 0.5033999999999772 t= 0.5035999999999772 t= 0.5037999999999772 t= 0.5039999999999771 t= 0.5041999999999771 t= 0.5043999999999771 t= 0.5045999999999771 t= 0.504799999999977 t= 0.504999999999977 t= 0.505199999999977 t= 0.505399999999977 t= 0.505599999999977 t= 0.5057999999999769 t= 0.5059999999999769 t= 0.5061999999999769 t= 0.5063999999999769 t= 0.5065999999999768 t= 0.5067999999999768 t= 0.5069999999999768 t= 0.5071999999999768 t= 0.5073999999999768 t= 0.5075999999999767 t= 0.5077999999999767 t= 0.5079999999999767 t= 0.5081999999999767 t= 0.5083999999999766 t= 0.5085999999999766 t= 0.5087999999999766 t= 0.5089999999999766 t= 0.5091999999999766 t= 0.5093999999999765 t= 0.5095999999999765 t= 0.5097999999999765 t= 0.5099999999999765 t= 0.5101999999999765 t= 0.5103999999999764 t= 0.5105999999999764 t= 0.5107999999999764 t= 0.5109999999999764 t= 0.5111999999999763 t= 0.5113999999999763 t= 0.5115999999999763 t= 0.5117999999999763 t= 0.5119999999999763 t= 0.5121999999999762 t= 0.5123999999999762 t= 0.5125999999999762 t= 0.5127999999999762 t= 0.5129999999999761 t= 0.5131999999999761 t= 0.5133999999999761 t= 0.5135999999999761 t= 0.513799999999976 t= 0.513999999999976 t= 0.514199999999976 t= 0.514399999999976 t= 0.514599999999976 t= 0.5147999999999759 t= 0.5149999999999759 t= 0.5151999999999759 t= 0.5153999999999759 t= 0.5155999999999759 t= 0.5157999999999758 t= 0.5159999999999758 t= 0.5161999999999758 t= 0.5163999999999758 t= 0.5165999999999757 t= 0.5167999999999757 t= 0.5169999999999757 t= 0.5171999999999757 t= 0.5173999999999757 t= 0.5175999999999756 t= 0.5177999999999756 t= 0.5179999999999756 t= 0.5181999999999756 t= 0.5183999999999755 t= 0.5185999999999755 t= 0.5187999999999755 t= 0.5189999999999755 t= 0.5191999999999755 t= 0.5193999999999754 t= 0.5195999999999754 t= 0.5197999999999754 t= 0.5199999999999754 t= 0.5201999999999753 t= 0.5203999999999753 t= 0.5205999999999753 t= 0.5207999999999753 t= 0.5209999999999753 t= 0.5211999999999752 t= 0.5213999999999752 t= 0.5215999999999752 t= 0.5217999999999752 t= 0.5219999999999752 t= 0.5221999999999751 t= 0.5223999999999751 t= 0.5225999999999751 t= 0.5227999999999751 t= 0.522999999999975 t= 0.523199999999975 t= 0.523399999999975 t= 0.523599999999975 t= 0.523799999999975 t= 0.5239999999999749 t= 0.5241999999999749 t= 0.5243999999999749 t= 0.5245999999999749 t= 0.5247999999999748 t= 0.5249999999999748 t= 0.5251999999999748 t= 0.5253999999999748 t= 0.5255999999999748 t= 0.5257999999999747 t= 0.5259999999999747 t= 0.5261999999999747 t= 0.5263999999999747 t= 0.5265999999999746 t= 0.5267999999999746 t= 0.5269999999999746 t= 0.5271999999999746 t= 0.5273999999999746 t= 0.5275999999999745 t= 0.5277999999999745 t= 0.5279999999999745 t= 0.5281999999999745 t= 0.5283999999999744 t= 0.5285999999999744 t= 0.5287999999999744 t= 0.5289999999999744 t= 0.5291999999999744 t= 0.5293999999999743 t= 0.5295999999999743 t= 0.5297999999999743 t= 0.5299999999999743 t= 0.5301999999999742 t= 0.5303999999999742 t= 0.5305999999999742 t= 0.5307999999999742 t= 0.5309999999999742 t= 0.5311999999999741 t= 0.5313999999999741 t= 0.5315999999999741 t= 0.5317999999999741 t= 0.531999999999974 t= 0.532199999999974 t= 0.532399999999974 t= 0.532599999999974 t= 0.532799999999974 t= 0.5329999999999739 t= 0.5331999999999739 t= 0.5333999999999739 t= 0.5335999999999739 t= 0.5337999999999739 t= 0.5339999999999738 t= 0.5341999999999738 t= 0.5343999999999738 t= 0.5345999999999738 t= 0.5347999999999737 t= 0.5349999999999737 t= 0.5351999999999737 t= 0.5353999999999737 t= 0.5355999999999737 t= 0.5357999999999736 t= 0.5359999999999736 t= 0.5361999999999736 t= 0.5363999999999736 t= 0.5365999999999735 t= 0.5367999999999735 t= 0.5369999999999735 t= 0.5371999999999735 t= 0.5373999999999735 t= 0.5375999999999734 t= 0.5377999999999734 t= 0.5379999999999734 t= 0.5381999999999734 t= 0.5383999999999733 t= 0.5385999999999733 t= 0.5387999999999733 t= 0.5389999999999733 t= 0.5391999999999733 t= 0.5393999999999732 t= 0.5395999999999732 t= 0.5397999999999732 t= 0.5399999999999732 t= 0.5401999999999731 t= 0.5403999999999731 t= 0.5405999999999731 t= 0.5407999999999731 t= 0.5409999999999731 t= 0.541199999999973 t= 0.541399999999973 t= 0.541599999999973 t= 0.541799999999973 t= 0.541999999999973 t= 0.5421999999999729 t= 0.5423999999999729 t= 0.5425999999999729 t= 0.5427999999999729 t= 0.5429999999999728 t= 0.5431999999999728 t= 0.5433999999999728 t= 0.5435999999999728 t= 0.5437999999999727 t= 0.5439999999999727 t= 0.5441999999999727 t= 0.5443999999999727 t= 0.5445999999999727 t= 0.5447999999999726 t= 0.5449999999999726 t= 0.5451999999999726 t= 0.5453999999999726 t= 0.5455999999999726 t= 0.5457999999999725 t= 0.5459999999999725 t= 0.5461999999999725 t= 0.5463999999999725 t= 0.5465999999999724 t= 0.5467999999999724 t= 0.5469999999999724 t= 0.5471999999999724 t= 0.5473999999999724 t= 0.5475999999999723 t= 0.5477999999999723 t= 0.5479999999999723 t= 0.5481999999999723 t= 0.5483999999999722 t= 0.5485999999999722 t= 0.5487999999999722 t= 0.5489999999999722 t= 0.5491999999999722 t= 0.5493999999999721 t= 0.5495999999999721 t= 0.5497999999999721 t= 0.5499999999999721 t= 0.550199999999972 t= 0.550399999999972 t= 0.550599999999972 t= 0.550799999999972 t= 0.550999999999972 t= 0.5511999999999719 t= 0.5513999999999719 t= 0.5515999999999719 t= 0.5517999999999719 t= 0.5519999999999718 t= 0.5521999999999718 t= 0.5523999999999718 t= 0.5525999999999718 t= 0.5527999999999718 t= 0.5529999999999717 t= 0.5531999999999717 t= 0.5533999999999717 t= 0.5535999999999717 t= 0.5537999999999716 t= 0.5539999999999716 t= 0.5541999999999716 t= 0.5543999999999716 t= 0.5545999999999716 t= 0.5547999999999715 t= 0.5549999999999715 t= 0.5551999999999715 t= 0.5553999999999715 t= 0.5555999999999715 t= 0.5557999999999714 t= 0.5559999999999714 t= 0.5561999999999714 t= 0.5563999999999714 t= 0.5565999999999713 t= 0.5567999999999713 t= 0.5569999999999713 t= 0.5571999999999713 t= 0.5573999999999713 t= 0.5575999999999712 t= 0.5577999999999712 t= 0.5579999999999712 t= 0.5581999999999712 t= 0.5583999999999711 t= 0.5585999999999711 t= 0.5587999999999711 t= 0.5589999999999711 t= 0.559199999999971 t= 0.559399999999971 t= 0.559599999999971 t= 0.559799999999971 t= 0.559999999999971 t= 0.5601999999999709 t= 0.5603999999999709 t= 0.5605999999999709 t= 0.5607999999999709 t= 0.5609999999999709 t= 0.5611999999999708 t= 0.5613999999999708 t= 0.5615999999999708 t= 0.5617999999999708 t= 0.5619999999999707 t= 0.5621999999999707 t= 0.5623999999999707 t= 0.5625999999999707 t= 0.5627999999999707 t= 0.5629999999999706 t= 0.5631999999999706 t= 0.5633999999999706 t= 0.5635999999999706 t= 0.5637999999999705 t= 0.5639999999999705 t= 0.5641999999999705 t= 0.5643999999999705 t= 0.5645999999999705 t= 0.5647999999999704 t= 0.5649999999999704 t= 0.5651999999999704 t= 0.5653999999999704 t= 0.5655999999999703 t= 0.5657999999999703 t= 0.5659999999999703 t= 0.5661999999999703 t= 0.5663999999999703 t= 0.5665999999999702 t= 0.5667999999999702 t= 0.5669999999999702 t= 0.5671999999999702 t= 0.5673999999999702 t= 0.5675999999999701 t= 0.5677999999999701 t= 0.5679999999999701 t= 0.5681999999999701 t= 0.56839999999997 t= 0.56859999999997 t= 0.56879999999997 t= 0.56899999999997 t= 0.56919999999997 t= 0.5693999999999699 t= 0.5695999999999699 t= 0.5697999999999699 t= 0.5699999999999699 t= 0.5701999999999698 t= 0.5703999999999698 t= 0.5705999999999698 t= 0.5707999999999698 t= 0.5709999999999698 t= 0.5711999999999697 t= 0.5713999999999697 t= 0.5715999999999697 t= 0.5717999999999697 t= 0.5719999999999696 t= 0.5721999999999696 t= 0.5723999999999696 t= 0.5725999999999696 t= 0.5727999999999696 t= 0.5729999999999695 t= 0.5731999999999695 t= 0.5733999999999695 t= 0.5735999999999695 t= 0.5737999999999694 t= 0.5739999999999694 t= 0.5741999999999694 t= 0.5743999999999694 t= 0.5745999999999694 t= 0.5747999999999693 t= 0.5749999999999693 t= 0.5751999999999693 t= 0.5753999999999693 t= 0.5755999999999692 t= 0.5757999999999692 t= 0.5759999999999692 t= 0.5761999999999692 t= 0.5763999999999692 t= 0.5765999999999691 t= 0.5767999999999691 t= 0.5769999999999691 t= 0.5771999999999691 t= 0.577399999999969 t= 0.577599999999969 t= 0.577799999999969 t= 0.577999999999969 t= 0.578199999999969 t= 0.5783999999999689 t= 0.5785999999999689 t= 0.5787999999999689 t= 0.5789999999999689 t= 0.5791999999999689 t= 0.5793999999999688 t= 0.5795999999999688 t= 0.5797999999999688 t= 0.5799999999999688 t= 0.5801999999999687 t= 0.5803999999999687 t= 0.5805999999999687 t= 0.5807999999999687 t= 0.5809999999999687 t= 0.5811999999999686 t= 0.5813999999999686 t= 0.5815999999999686 t= 0.5817999999999686 t= 0.5819999999999685 t= 0.5821999999999685 t= 0.5823999999999685 t= 0.5825999999999685 t= 0.5827999999999685 t= 0.5829999999999684 t= 0.5831999999999684 t= 0.5833999999999684 t= 0.5835999999999684 t= 0.5837999999999683 t= 0.5839999999999683 t= 0.5841999999999683 t= 0.5843999999999683 t= 0.5845999999999683 t= 0.5847999999999682 t= 0.5849999999999682 t= 0.5851999999999682 t= 0.5853999999999682 t= 0.5855999999999681 t= 0.5857999999999681 t= 0.5859999999999681 t= 0.5861999999999681 t= 0.5863999999999681 t= 0.586599999999968 t= 0.586799999999968 t= 0.586999999999968 t= 0.587199999999968 t= 0.587399999999968 t= 0.5875999999999679 t= 0.5877999999999679 t= 0.5879999999999679 t= 0.5881999999999679 t= 0.5883999999999678 t= 0.5885999999999678 t= 0.5887999999999678 t= 0.5889999999999678 t= 0.5891999999999677 t= 0.5893999999999677 t= 0.5895999999999677 t= 0.5897999999999677 t= 0.5899999999999677 t= 0.5901999999999676 t= 0.5903999999999676 t= 0.5905999999999676 t= 0.5907999999999676 t= 0.5909999999999676 t= 0.5911999999999675 t= 0.5913999999999675 t= 0.5915999999999675 t= 0.5917999999999675 t= 0.5919999999999674 t= 0.5921999999999674 t= 0.5923999999999674 t= 0.5925999999999674 t= 0.5927999999999674 t= 0.5929999999999673 t= 0.5931999999999673 t= 0.5933999999999673 t= 0.5935999999999673 t= 0.5937999999999672 t= 0.5939999999999672 t= 0.5941999999999672 t= 0.5943999999999672 t= 0.5945999999999672 t= 0.5947999999999671 t= 0.5949999999999671 t= 0.5951999999999671 t= 0.5953999999999671 t= 0.595599999999967 t= 0.595799999999967 t= 0.595999999999967 t= 0.596199999999967 t= 0.596399999999967 t= 0.5965999999999669 t= 0.5967999999999669 t= 0.5969999999999669 t= 0.5971999999999669 t= 0.5973999999999668 t= 0.5975999999999668 t= 0.5977999999999668 t= 0.5979999999999668 t= 0.5981999999999668 t= 0.5983999999999667 t= 0.5985999999999667 t= 0.5987999999999667 t= 0.5989999999999667 t= 0.5991999999999666 t= 0.5993999999999666 t= 0.5995999999999666 t= 0.5997999999999666 t= 0.5999999999999666CPU times: user 7.21 s, sys: 739 ms, total: 7.95 s
Wall time: 1.98 s
