3.1 Parabolic model problem¶
#imports
Geometry: \((-1,1)^2\)
Mesh
shape.edges.Max(Y).name="top"
time = 0.0
dt = 0.001
bilinear forms for
mass matrix separately.
m += u*v*dx
<ngsolve.comp.BilinearForm at 0x7f285c3c43b0>
Implicit Euler method¶
or in an incremental form:
/usr/lib/python3/dist-packages/scipy/__init__.py:146: UserWarning: A NumPy version >=1.17.3 and <1.25.0 is required for this version of SciPy (detected version 1.26.3
print(mstar.AsVector())
0.00520833
0.00260417
0.00260417
-0.000520833
8.68056e-05
-0.000520833
8.68056e-05
-0.000260417
-1.32137e-19
0.000173611
0.00823929
0.00207589
0.00204376
0.00411964
-0.000415177
6.91962e-05
-0.000408752
6.81253e-05
-0.000823929
0.000137321
-0.000207589
1.05879e-19
-0.000204376
-1.05032e-19
0.000138392
0.000136251
0.00520833
0.00260417
0.00260417
-0.000520833
8.68056e-05
-0.000520833
8.68056e-05
-0.000260417
1.32137e-19
0.000173611
0.00827496
0.00209025
0.00204723
0.00413748
-0.000418049
6.96749e-05
-0.000409446
6.82411e-05
-0.000827496
0.000137916
-0.000209025
1.05032e-19
-0.000204723
-1.04185e-19
0.00013935
0.000136482
0.00260417
0.0195488
0.00333868
0.00643574
0.00717025
-0.000520833
-8.68056e-05
-0.000260417
-1.42302e-19
-0.000667736
0.000111289
-0.00128715
0.000214525
-0.00143405
0.000239008
-0.000333868
-1.72795e-19
-0.000383157
1.96512e-19
0.000173611
0.000222579
0.000255438
0.00333868
0.0199715
0.00282601
0.00715975
0.00664708
-0.000667736
-0.000111289
-0.000333868
-1.86347e-19
-0.000565201
9.42002e-05
-0.00143195
0.000238658
-0.00132942
0.000221569
-0.000282601
-1.40607e-19
-0.000382107
1.89735e-19
0.000222579
0.0001884
0.000254738
0.00282601
0.0165345
0.0025482
0.00571903
0.00544123
-0.000565201
-9.42002e-05
-0.000282601
-1.5416e-19
-0.00050964
8.494e-05
-0.00114381
0.000190634
-0.00108825
0.000181374
-0.00025482
-1.28749e-19
-0.000289303
1.49078e-19
0.0001884
0.00016988
0.000192868
0.0025482
0.0146259
0.00229409
0.00501886
0.00476475
-0.00050964
-8.494e-05
-0.00025482
-1.38913e-19
-0.000458819
7.64698e-05
-0.00100377
0.000167295
-0.000952951
0.000158825
-0.000229409
-1.16891e-19
-0.000247066
1.23667e-19
0.00016988
0.00015294
0.000164711
0.00229409
0.0128843
0.00205426
0.00438791
0.00414808
-0.000458819
-7.64698e-05
-0.000229409
-1.23667e-19
-0.000410852
6.84754e-05
-0.000877582
0.000146264
-0.000829615
0.000138269
-0.000205426
-1.05879e-19
-0.000209382
1.05032e-19
0.00015294
0.000136951
0.000139588
0.00205426
0.0113433
0.00188867
0.00378299
0.00361739
-0.000410852
-6.84754e-05
-0.000205426
-1.11808e-19
-0.000377733
6.29555e-05
-0.000756598
0.0001261
-0.000723479
0.00012058
-0.000188867
-9.74088e-20
-0.000172873
8.72444e-20
0.000136951
0.000125911
0.000115249
0.00207589
0.00188867
0.0112674
0.0035578
0.00374502
-0.000415177
-6.91962e-05
-0.000207589
-6.77626e-21
-0.000377733
-6.29555e-05
-0.000188867
-1.01644e-19
-0.00071156
0.000118593
-0.000749004
0.000124834
-0.000166913
8.63974e-20
0.000125911
0.000138392
0.000111275
0.00204376
0.011037
0.00182396
0.00369454
0.00347474
-0.000408752
-6.81253e-05
-0.000204376
-1.11808e-19
-0.000364791
6.07985e-05
-0.000738909
0.000123151
-0.000694948
0.000115825
-0.000182396
-9.31736e-20
-0.000165078
8.38563e-20
0.000136251
0.000121597
0.000110052
0.00182396
0.0108765
0.00194398
0.00349425
0.00361428
-0.000364791
-6.07985e-05
-0.000182396
-9.82558e-20
-0.000388797
6.47995e-05
-0.00069885
0.000116475
-0.000722856
0.000120476
-0.000194398
-9.91029e-20
-0.00016703
8.63974e-20
0.000121597
0.000129599
0.000111353
0.00194398
0.0120504
0.00210766
0.00391754
0.00408122
-0.000388797
-6.47995e-05
-0.000194398
-1.06726e-19
-0.000421533
7.02554e-05
-0.000783508
0.000130585
-0.000816244
0.000136041
-0.000210766
-1.06726e-19
-0.000197356
9.91029e-20
0.000129599
0.000140511
0.000131571
0.00210766
0.013149
0.00223556
0.00433894
0.00446684
-0.000421533
-7.02554e-05
-0.000210766
-1.15196e-19
-0.000447112
7.45186e-05
-0.000867788
0.000144631
-0.000893368
0.000148895
-0.000223556
-1.15196e-19
-0.000223128
1.13502e-19
0.000140511
0.000149037
0.000148752
0.00223556
0.0137898
0.00227834
0.00461655
0.00465933
-0.000447112
-7.45186e-05
-0.000223556
-1.21973e-19
-0.000455667
7.59445e-05
-0.00092331
0.000153885
-0.000931866
0.000155311
-0.000227834
-1.16891e-19
-0.000238099
1.20279e-19
0.000149037
0.000151889
0.000158733
0.00227834
0.0137701
0.00222092
0.00466414
0.00460672
-0.000455667
-7.59445e-05
-0.000227834
-1.23667e-19
-0.000444183
7.40305e-05
-0.000932829
0.000155471
-0.000921345
0.000153557
-0.000222092
-1.10114e-19
-0.000238581
1.21973e-19
0.000151889
0.000148061
0.000159054
0.00260417
0.00222092
0.0159979
0.00577804
0.00539478
-0.000520833
-8.68056e-05
-0.000260417
-8.47033e-21
-0.000444183
-7.40305e-05
-0.000222092
-1.20279e-19
-0.00115561
0.000192601
-0.00107896
0.000179826
-0.000317387
-1.66018e-19
0.000148061
0.000173611
0.000211591
0.00260417
0.00577804
0.0208155
0.00213338
0.00567023
0.00462974
-0.000260417
-1.40607e-19
-0.000520833
-8.68056e-05
-0.00115561
-0.000192601
-0.000317387
-1.74489e-19
-0.000426676
7.11127e-05
-0.00113405
0.000189008
-0.000925948
0.000154325
-0.000213338
-1.07573e-19
-0.000249636
1.28749e-19
0.000173611
0.000142225
0.000211591
0.000166424
0.00213338
0.0130808
0.00245703
0.00408339
0.00440703
-0.000426676
-7.11127e-05
-0.000213338
-1.15196e-19
-0.000491405
8.19009e-05
-0.000816677
0.000136113
-0.000881406
0.000146901
-0.000245703
-1.27055e-19
-0.000195001
9.65618e-20
0.000142225
0.000163802
0.00013
0.00245703
0.0151149
0.00253105
0.00502639
0.0051004
-0.000491405
-8.19009e-05
-0.000245703
-1.35525e-19
-0.000506209
8.43682e-05
-0.00100528
0.000167546
-0.00102008
0.000170013
-0.000253105
-1.28749e-19
-0.000256936
1.30443e-19
0.000163802
0.000168736
0.000171291
0.00253105
0.0147573
0.00233337
0.00504528
0.0048476
-0.000506209
-8.43682e-05
-0.000253105
-1.38913e-19
-0.000466674
7.7779e-05
-0.00100906
0.000168176
-0.00096952
0.000161587
-0.000233337
-1.18585e-19
-0.000251423
1.30443e-19
0.000168736
0.000155558
0.000167615
0.00233337
0.0131456
0.00208849
0.00448428
0.00423941
-0.000466674
-7.7779e-05
-0.000233337
-1.25361e-19
-0.000417699
6.96165e-05
-0.000896857
0.000149476
-0.000847882
0.000141314
-0.000208849
-1.09267e-19
-0.000215091
1.10114e-19
0.000155558
0.000139233
0.000143394
0.00208849
0.0115252
0.00191176
0.00385083
0.00367409
-0.000417699
-6.96165e-05
-0.000208849
-1.15196e-19
-0.000382351
6.37252e-05
-0.000770166
0.000128361
-0.000734818
0.00012247
-0.000191176
-9.65618e-20
-0.000176233
8.97855e-20
0.000139233
0.00012745
0.000117489
0.00209025
0.00191176
0.0113796
0.00359955
0.00377804
-0.000418049
-6.96749e-05
-0.000209025
-5.0822e-21
-0.000382351
-6.37252e-05
-0.000191176
-1.01644e-19
-0.00071991
0.000119985
-0.000755608
0.000125935
-0.000168779
8.47033e-20
0.00012745
0.00013935
0.000112519
0.00204723
0.0110568
0.0018212
0.00370721
0.00348118
-0.000409446
-6.82411e-05
-0.000204723
-1.11808e-19
-0.00036424
6.07067e-05
-0.000741441
0.000123574
-0.000696235
0.000116039
-0.00018212
-9.31736e-20
-0.000165997
8.30092e-20
0.000136482
0.000121413
0.000110665
0.0018212
0.010812
0.00192355
0.00348244
0.00358479
-0.00036424
-6.07067e-05
-0.00018212
-9.82558e-20
-0.000384711
6.41185e-05
-0.000696488
0.000116081
-0.000716959
0.000119493
-0.000192355
-9.82558e-20
-0.000166124
8.47033e-20
0.000121413
0.000128237
0.000110749
0.00192355
0.0117603
0.00204529
0.00383488
0.00395662
-0.000384711
-6.41185e-05
-0.000192355
-1.05032e-19
-0.000409058
6.81764e-05
-0.000766976
0.000127829
-0.000791323
0.000131887
-0.000204529
-1.03338e-19
-0.000191133
9.91029e-20
0.000128237
0.000136353
0.000127422
0.00204529
0.0123838
0.00211338
0.00407853
0.00414662
-0.000409058
-6.81764e-05
-0.000204529
-1.11808e-19
-0.000422677
7.04461e-05
-0.000815705
0.000135951
-0.000829324
0.000138221
-0.000211338
-1.10961e-19
-0.000203324
1.04185e-19
0.000136353
0.000140892
0.000135549
0.00211338
0.0134801
0.00237036
0.00436969
0.00462666
-0.000422677
-7.04461e-05
-0.000211338
-1.15196e-19
-0.000474071
7.90119e-05
-0.000873938
0.000145656
-0.000925333
0.000154222
-0.000237036
-1.21973e-19
-0.000225631
1.15196e-19
0.000140892
0.000158024
0.00015042
0.00237036
0.0176168
0.00309706
0.00643805
0.00571135
-0.000474071
-7.90119e-05
-0.000237036
-1.32137e-19
-0.000619411
0.000103235
-0.00128761
0.000214602
-0.00114227
0.000190378
-0.000309706
-1.57548e-19
-0.0003341
-1.72795e-19
0.000158024
0.00020647
0.000222733
0.00260417
0.00643574
0.00309706
0.0190656
0.00692863
-0.000260417
-6.77626e-21
-0.000520833
-8.68056e-05
-0.00128715
-0.000214525
-0.000383157
-1.01644e-20
-0.000619411
-0.000103235
-0.000309706
-1.69407e-19
-0.00138573
0.000230954
0.000173611
0.00020647
0.000255438
0.00717025
0.00715975
0.00643805
0.00692863
0.0482623
0.00732708
0.00653677
0.00670178
-0.000333868
-6.77626e-21
-0.000383157
-2.10064e-19
-0.00143405
-0.000239008
-0.00143195
-0.000238658
-0.000382107
-1.01644e-20
-0.000309706
-1.01644e-20
-0.00128761
-0.000214602
-0.0003341
-1.81265e-19
-0.00138573
-0.000230954
-0.00146542
0.000244236
-0.00130735
0.000217892
-0.00134036
0.000223393
-0.0003506
-1.79571e-19
-0.000319578
1.64324e-19
0.000222579
0.000254738
0.00020647
0.000255438
0.000222733
0.000233734
0.000213052
0.00664708
0.00571903
0.00732708
0.0380433
0.00579165
0.00597555
0.00658292
-0.000282601
-6.77626e-21
-0.000382107
-2.06676e-19
-0.00132942
-0.000221569
-0.00114381
-0.000190634
-0.000289303
-3.38813e-21
-0.00146542
-0.000244236
-0.0003506
-1.89735e-19
-0.00115833
0.000193055
-0.00119511
0.000199185
-0.00131658
0.000219431
-0.000289863
-1.47384e-19
-0.000307692
-1.57548e-19
0.0001884
0.000254738
0.000192868
0.000193242
0.000233734
0.000205128
0.00544123
0.00501886
0.00579165
0.0321184
0.00495698
0.005661
0.0052487
-0.00025482
-5.0822e-21
-0.000289303
-1.57548e-19
-0.00108825
-0.000181374
-0.00100377
-0.000167295
-0.000247066
-6.77626e-21
-0.00115833
-0.000193055
-0.000289863
-1.57548e-19
-0.000991396
0.000165233
-0.0011322
0.0001887
-0.00104974
0.000174957
-0.000248632
-1.27055e-19
-0.000276238
1.42302e-19
0.00016988
0.000192868
0.000164711
0.000193242
0.000165755
0.000184158
0.00476475
0.00438791
0.00495698
0.0274883
0.00419246
0.00439926
0.00478694
-0.000229409
-3.38813e-21
-0.000247066
-1.33831e-19
-0.000952951
-0.000158825
-0.000877582
-0.000146264
-0.000209382
-6.77626e-21
-0.000991396
-0.000165233
-0.000248632
-1.35525e-19
-0.000838491
0.000139749
-0.000879852
0.000146642
-0.000957388
0.000159565
-0.000209864
-1.06726e-19
-0.000230062
-1.16891e-19
0.00015294
0.000164711
0.000139588
0.000139909
0.000165755
0.000153374
0.00414808
0.00378299
0.00419246
0.0229244
0.00339801
0.00391612
0.00348676
-0.000205426
-5.0822e-21
-0.000209382
-1.15196e-19
-0.000829615
-0.000138269
-0.000756598
-0.0001261
-0.000172873
-1.69407e-21
-0.000838491
-0.000139749
-0.000209864
-1.15196e-19
-0.000679602
0.000113267
-0.000783224
0.000130537
-0.000697353
0.000116225
-0.000166928
-8.89385e-20
-0.000181748
9.31736e-20
0.000136951
0.000139588
0.000115249
0.000139909
0.000111286
0.000121165
0.00361739
0.0035578
0.00339801
0.0188525
0.00292067
0.00288818
0.00247044
-0.000188867
-5.0822e-21
-0.000172873
-9.40207e-20
-0.000723479
-0.00012058
-0.00071156
-0.000118593
-0.000166913
-5.0822e-21
-0.000679602
-0.000113267
-0.000166928
-9.23266e-20
-0.000584135
9.73558e-05
-0.000577636
9.62727e-05
-0.000494088
8.2348e-05
-0.000125154
-6.35275e-20
-0.00012189
6.09864e-20
0.000125911
0.000115249
0.000111275
0.000111286
8.34361e-05
8.12599e-05
0.00411964
0.00374502
0.00369454
0.00292067
0.019862
0.0028907
0.00249146
-0.000207589
-1.13502e-19
-0.000204376
-3.38813e-21
-0.000823929
-0.000137321
-0.000166913
-9.06325e-20
-0.000749004
-0.000124834
-0.000738909
-0.000123151
-0.000165078
-6.77626e-21
-0.000584135
-9.73558e-05
-0.000125154
-6.69156e-20
-0.00057814
9.63567e-05
-0.000498292
8.30486e-05
-0.000123992
-6.35275e-20
0.000138392
0.000111275
0.000136251
0.000110052
8.34361e-05
8.26611e-05
0.00347474
0.00349425
0.0028907
0.0184461
0.00330099
0.00244731
0.00283809
-0.000182396
-3.38813e-21
-0.000165078
-9.06325e-20
-0.000694948
-0.000115825
-0.00069885
-0.000116475
-0.00016703
-3.38813e-21
-0.00057814
-9.63567e-05
-0.000123992
-6.77626e-20
-0.000660198
0.000110033
-0.000489463
8.15771e-05
-0.000567619
9.46032e-05
-0.00016307
-8.47033e-20
-0.00012074
6.18334e-20
0.000121597
0.000110052
0.000111353
8.26611e-05
0.000108713
8.04932e-05
0.00361428
0.00391754
0.00330099
0.0220011
0.00398018
0.003782
0.00340607
-0.000194398
-5.0822e-21
-0.00016703
-8.97855e-20
-0.000722856
-0.000120476
-0.000783508
-0.000130585
-0.000197356
-3.38813e-21
-0.000660198
-0.000110033
-0.00016307
-8.89385e-20
-0.000796036
0.000132673
-0.0007564
0.000126067
-0.000681215
0.000113536
-0.000200662
-1.04185e-19
-0.000177538
-9.23266e-20
0.000129599
0.000111353
0.000131571
0.000133775
0.000108713
0.000118358
0.00408122
0.00433894
0.00398018
0.0256174
0.00452959
0.0041979
0.00448959
-0.000210766
-3.38813e-21
-0.000197356
-1.06726e-19
-0.000816244
-0.000136041
-0.000867788
-0.000144631
-0.000223128
-5.0822e-21
-0.000796036
-0.000132673
-0.000200662
-1.0842e-19
-0.000905917
0.000150986
-0.00083958
0.00013993
-0.000897917
0.000149653
-0.000229831
-1.18585e-19
-0.000219128
1.11808e-19
0.000140511
0.000131571
0.000148752
0.000133775
0.000153221
0.000146085
0.00446684
0.00461655
0.00452959
0.0284055
0.00489079
0.0048451
0.0050566
-0.000223556
-6.77626e-21
-0.000223128
-1.21973e-19
-0.000893368
-0.000148895
-0.00092331
-0.000153885
-0.000238099
-3.38813e-21
-0.000905917
-0.000150986
-0.000229831
-1.25361e-19
-0.000978159
0.000163026
-0.000969021
0.000161503
-0.00101132
0.000168553
-0.00025098
-1.30443e-19
-0.00025468
1.33831e-19
0.000149037
0.000148752
0.000158733
0.000153221
0.00016732
0.000169786
0.00465933
0.00466414
0.00489079
0.0293038
0.00483702
0.00515554
0.00509695
-0.000227834
-1.01644e-20
-0.000238099
-1.30443e-19
-0.000931866
-0.000155311
-0.000932829
-0.000155471
-0.000238581
-3.38813e-21
-0.000978159
-0.000163026
-0.00025098
-1.35525e-19
-0.000967404
0.000161234
-0.00103111
0.000171851
-0.00101939
0.000169898
-0.000245121
-1.25361e-19
-0.000264574
1.37219e-19
0.000151889
0.000158733
0.000159054
0.00016732
0.000163414
0.000176383
0.00460672
0.00539478
0.00567023
0.00483702
0.0296137
0.00457507
0.00452992
-0.000222092
-3.38813e-21
-0.000238581
-1.28749e-19
-0.000921345
-0.000153557
-0.000317387
-1.01644e-20
-0.00107896
-0.000179826
-0.00113405
-0.000189008
-0.000249636
-6.77626e-21
-0.000967404
-0.000161234
-0.000245121
-1.33831e-19
-0.000915014
0.000152502
-0.000905984
0.000150997
-0.000207871
-1.09267e-19
0.000148061
0.000159054
0.000211591
0.000166424
0.000163414
0.000138581
0.00462974
0.00408339
0.00457507
0.0214627
0.00402288
0.00415159
-0.000213338
-3.38813e-21
-0.000249636
-1.35525e-19
-0.000925948
-0.000154325
-0.000816677
-0.000136113
-0.000195001
-5.0822e-21
-0.000915014
-0.000152502
-0.000207871
-1.13502e-19
-0.000804577
0.000134096
-0.000830317
0.000138386
-0.000207288
-1.05879e-19
0.000142225
0.00013
0.000166424
0.000138581
0.000138192
0.00440703
0.00502639
0.00402288
0.0307427
0.00578985
0.00517445
0.00632206
-0.000245703
-5.0822e-21
-0.000195001
-1.05032e-19
-0.000881406
-0.000146901
-0.00100528
-0.000167546
-0.000256936
-8.47033e-21
-0.000804577
-0.000134096
-0.000207288
-1.13502e-19
-0.00115797
0.000192995
-0.00103489
0.000172482
-0.00126441
0.000210735
-0.000322049
-1.67713e-19
-0.000310157
1.60936e-19
0.000163802
0.00013
0.000171291
0.000214699
0.000138192
0.000206772
0.0051004
0.00504528
0.00578985
0.0337514
0.0051692
0.00604057
0.00660608
-0.000253105
-1.01644e-20
-0.000256936
-1.38913e-19
-0.00102008
-0.000170013
-0.00100906
-0.000168176
-0.000251423
-6.77626e-21
-0.00115797
-0.000192995
-0.000322049
-1.76183e-19
-0.00103384
0.000172307
-0.00120811
0.000201352
-0.00132122
0.000220203
-0.000265497
-1.35525e-19
-0.000338559
-1.72795e-19
0.000168736
0.000171291
0.000167615
0.000176998
0.000214699
0.000225706
0.0048476
0.00448428
0.0051692
0.0285982
0.00432996
0.00512151
0.00464559
-0.000233337
-5.0822e-21
-0.000251423
-1.38913e-19
-0.00096952
-0.000161587
-0.000896857
-0.000149476
-0.000215091
-6.77626e-21
-0.00103384
-0.000172307
-0.000265497
-1.43996e-19
-0.000865993
0.000144332
-0.0010243
0.000170717
-0.000929118
0.000154853
-0.000217905
-1.13502e-19
-0.000246654
1.23667e-19
0.000155558
0.000167615
0.000143394
0.000176998
0.00014527
0.000164436
0.00423941
0.00385083
0.00432996
0.0235276
0.00346737
0.00405703
0.00358302
-0.000208849
-5.0822e-21
-0.000215091
-1.16891e-19
-0.000847882
-0.000141314
-0.000770166
-0.000128361
-0.000176233
-8.47033e-21
-0.000865993
-0.000144332
-0.000217905
-1.16891e-19
-0.000693475
0.000115579
-0.000811407
0.000135234
-0.000716605
0.000119434
-0.000170504
-8.55503e-20
-0.000187798
9.40207e-20
0.000139233
0.000143394
0.000117489
0.00014527
0.000113669
0.000125199
0.00367409
0.00359955
0.00346737
0.0191475
0.00295431
0.00294536
0.00250683
-0.000191176
-3.38813e-21
-0.000176233
-9.48677e-20
-0.000734818
-0.00012247
-0.00071991
-0.000119985
-0.000168779
-5.0822e-21
-0.000693475
-0.000115579
-0.000170504
-9.23266e-20
-0.000590861
9.84769e-05
-0.000589072
9.81786e-05
-0.000501367
8.35611e-05
-0.000126651
-6.43745e-20
-0.000124032
6.35275e-20
0.00012745
0.000117489
0.000112519
0.000113669
8.44343e-05
8.2688e-05
0.00413748
0.00377804
0.00370721
0.00295431
0.0200032
0.00290982
0.00251636
-0.000209025
-1.13502e-19
-0.000204723
-3.38813e-21
-0.000827496
-0.000137916
-0.000168779
-9.23266e-20
-0.000755608
-0.000125935
-0.000741441
-0.000123574
-0.000165997
-5.0822e-21
-0.000590861
-9.84769e-05
-0.000126651
-6.86097e-20
-0.000581964
9.6994e-05
-0.000503272
8.38786e-05
-0.000124984
-6.35275e-20
0.00013935
0.000112519
0.000136482
0.000110665
8.44343e-05
8.3323e-05
0.00348118
0.00348244
0.00290982
0.0184768
0.00329119
0.00246604
0.00284615
-0.00018212
-6.77626e-21
-0.000165997
-8.97855e-20
-0.000696235
-0.000116039
-0.000696488
-0.000116081
-0.000166124
-5.0822e-21
-0.000581964
-9.6994e-05
-0.000124984
-6.77626e-20
-0.000658239
0.000109706
-0.000493208
8.22013e-05
-0.00056923
9.48717e-05
-0.000162995
-8.21622e-20
-0.00012162
6.09864e-20
0.000121413
0.000110665
0.000110749
8.3323e-05
0.000108664
8.10797e-05
0.00358479
0.00383488
0.00329119
0.0217142
0.00387442
0.00373103
0.00339789
-0.000192355
-3.38813e-21
-0.000166124
-9.23266e-20
-0.000716959
-0.000119493
-0.000766976
-0.000127829
-0.000191133
-5.0822e-21
-0.000658239
-0.000109706
-0.000162995
-8.80914e-20
-0.000774883
0.000129147
-0.000746206
0.000124368
-0.000679579
0.000113263
-0.000196309
-1.00797e-19
-0.000176794
-9.14796e-20
0.000128237
0.000110749
0.000127422
0.000130873
0.000108664
0.000117863
0.00395662
0.00407853
0.00387442
0.0242183
0.00412017
0.00403235
0.0041562
-0.000204529
-6.77626e-21
-0.000191133
-1.05032e-19
-0.000791323
-0.000131887
-0.000815705
-0.000135951
-0.000203324
-3.38813e-21
-0.000774883
-0.000129147
-0.000196309
-1.0842e-19
-0.000824034
0.000137339
-0.00080647
0.000134412
-0.000831239
0.00013854
-0.000208694
-1.0842e-19
-0.000206926
1.02491e-19
0.000136353
0.000127422
0.000135549
0.000130873
0.000139129
0.000137951
0.00414662
0.00436969
0.00412017
0.0244604
0.00415141
0.0039322
0.00374036
-0.000211338
-3.38813e-21
-0.000203324
-1.11808e-19
-0.000829324
-0.000138221
-0.000873938
-0.000145656
-0.000225631
-1.69407e-21
-0.000824034
-0.000137339
-0.000208694
-1.13502e-19
-0.000830281
0.00013838
-0.00078644
0.000131073
-0.000748073
0.000124679
-0.00018951
-9.65618e-20
-0.000184526
9.48677e-20
0.000140892
0.000135549
0.00015042
0.000139129
0.00012634
0.000123018
0.00462666
0.00571135
0.00653677
0.00415141
0.0304277
0.0053511
0.00405043
-0.000237036
-5.0822e-21
-0.000225631
-1.25361e-19
-0.000925333
-0.000154222
-0.0003341
-6.77626e-21
-0.00114227
-0.000190378
-0.00130735
-0.000217892
-0.000319578
-1.01644e-20
-0.000830281
-0.00013838
-0.00018951
-1.03338e-19
-0.00107022
0.00017837
-0.000810085
0.000135014
-0.000215533
-1.11808e-19
0.000158024
0.00015042
0.000222733
0.00012634
0.000143689
0.000213052
0.00597555
0.005661
0.036801
0.00646794
0.00560492
0.00682002
0.00627154
-0.000289863
-6.77626e-21
-0.00119511
-0.000199185
-0.000307692
-1.69407e-19
-0.0011322
-0.0001887
-0.000276238
-5.0822e-21
-0.00129359
0.000215598
-0.00112098
0.000186831
-0.001364
0.000227334
-0.00125431
0.000209051
-0.000339102
1.71101e-19
-0.000284254
-1.47384e-19
-0.0003429
1.77877e-19
0.000193242
0.000205128
0.000184158
0.000226068
0.0002286
0.000189503
0.00670178
0.00658292
0.0053511
0.00646794
0.0356228
0.00464169
0.00587739
-0.0003506
-6.77626e-21
-0.000319578
-1.72795e-19
-0.00134036
-0.000223393
-0.000307692
-1.35525e-20
-0.00131658
-0.000219431
-0.00107022
-0.00017837
-0.000215533
-1.15196e-19
-0.00129359
-0.000215598
-0.000339102
-1.35525e-20
-0.000928338
0.000154723
-0.00117548
0.000195913
-0.000248636
1.27055e-19
0.000233734
0.000205128
0.000143689
0.000213052
0.000165758
0.000226068
0.00439926
0.00391612
0.0252273
0.0036879
0.0046604
0.00403713
0.00452649
-0.000209864
-3.38813e-21
-0.000879852
-0.000146642
-0.000230062
-1.25361e-19
-0.000783224
-0.000130537
-0.000181748
-5.0822e-21
-0.000737581
0.00012293
-0.000932079
0.000155347
-0.000807427
0.000134571
-0.000905298
0.000150883
-0.000187043
-9.57147e-20
-0.000235978
1.20279e-19
-0.000216671
-1.10114e-19
0.000139909
0.000121165
0.000153374
0.000124695
0.000144447
0.000157319
0.00348676
0.00288818
0.0036879
0.0189902
0.00245699
0.00291903
0.00355137
-0.000166928
-1.69407e-21
-0.000181748
-9.82558e-20
-0.000697353
-0.000116225
-0.000577636
-9.62727e-05
-0.00012189
-3.38813e-21
-0.000737581
-0.00012293
-0.000187043
-9.99499e-20
-0.000491397
8.18995e-05
-0.000583806
9.7301e-05
-0.000710274
0.000118379
-0.000123809
-6.26804e-20
-0.000168094
-8.63974e-20
0.000111286
0.000121165
8.12599e-05
8.25392e-05
0.000112063
0.000124695
0.00247044
0.00249146
0.00244731
0.00245699
0.0123117
0.00244549
-0.000125154
-2.5411e-21
-0.00012189
-6.60686e-20
-0.000494088
-8.2348e-05
-0.000123992
-5.0822e-21
-0.000498292
-8.30486e-05
-0.000489463
-8.15771e-05
-0.00012074
-1.69407e-21
-0.000491397
-8.18995e-05
-0.000123809
-6.86097e-20
-0.000489097
8.15162e-05
8.34361e-05
8.12599e-05
8.26611e-05
8.04932e-05
8.25392e-05
0.003782
0.0041979
0.0245023
0.00362452
0.00448278
0.00398638
0.00442873
-0.000200662
-3.38813e-21
-0.0007564
-0.000126067
-0.000177538
-9.74088e-20
-0.00083958
-0.00013993
-0.000219128
-3.38813e-21
-0.000724903
0.000120817
-0.000896555
0.000149426
-0.000797275
0.000132879
-0.000885746
0.000147624
-0.000184914
9.23266e-20
-0.00022915
-1.20279e-19
-0.000213723
1.06726e-19
0.000133775
0.000118358
0.000146085
0.000152767
0.000123276
0.000142482
0.00283809
0.00340607
0.00291903
0.00244549
0.00362452
0.0187633
0.00353008
-0.00016307
-6.77626e-21
-0.00012074
-6.52215e-20
-0.000567619
-9.46032e-05
-0.000177538
-6.77626e-21
-0.000681215
-0.000113536
-0.000123809
-1.69407e-21
-0.000583806
-9.7301e-05
-0.000168094
-8.97855e-20
-0.000489097
-8.15162e-05
-0.000724903
-0.000120817
-0.000184914
-6.77626e-21
-0.000706017
0.000117669
0.000108713
8.04932e-05
0.000118358
8.25392e-05
0.000112063
0.000123276
0.00448959
0.0048451
0.00448278
0.0292834
0.00526624
0.00488587
0.00531382
-0.000229831
-5.0822e-21
-0.000219128
-1.18585e-19
-0.000897917
-0.000149653
-0.000969021
-0.000161503
-0.00025468
-6.77626e-21
-0.000896555
-0.000149426
-0.00022915
-1.25361e-19
-0.00105325
0.000175541
-0.000977174
0.000162862
-0.00106276
0.000177127
-0.000271945
-1.37219e-19
-0.000259437
1.32137e-19
0.000153221
0.000146085
0.000169786
0.000152767
0.000181296
0.000172958
0.0050566
0.00515554
0.00526624
0.034294
0.00589549
0.00672523
0.00619493
-0.00025098
-6.77626e-21
-0.00025468
-1.40607e-19
-0.00101132
-0.000168553
-0.00103111
-0.000171851
-0.000264574
-6.77626e-21
-0.00105325
-0.000175541
-0.000271945
-1.47384e-19
-0.0011791
0.000196516
-0.00134505
0.000224174
-0.00123899
0.000206498
-0.000324975
-1.69407e-19
-0.000347549
-1.79571e-19
0.00016732
0.000169786
0.000176383
0.00021665
0.000181296
0.000231699
0.00509695
0.00452992
0.00415159
0.00517445
0.00589549
0.0311997
0.00635132
-0.000245121
-6.77626e-21
-0.000264574
-1.4569e-19
-0.00101939
-0.000169898
-0.000207871
-3.38813e-21
-0.000905984
-0.000150997
-0.000207288
-3.38813e-21
-0.000830317
-0.000138386
-0.00103489
-0.000172482
-0.000310157
-3.38813e-21
-0.0011791
-0.000196516
-0.000324975
-1.76183e-19
-0.00127026
0.000211711
0.000163414
0.000176383
0.000138581
0.000138192
0.000206772
0.00021665
0.00604057
0.00512151
0.0348624
0.0068771
0.00501892
0.00543259
0.00637171
-0.000265497
-6.77626e-21
-0.00120811
-0.000201352
-0.000338559
-1.84653e-19
-0.0010243
-0.000170717
-0.000246654
-6.77626e-21
-0.00137542
0.000229237
-0.00100378
0.000167297
-0.00108652
0.000181086
-0.00127434
0.00021239
-0.00034915
1.76183e-19
-0.000255238
-1.30443e-19
-0.000288021
-1.49078e-19
0.000176998
0.000225706
0.000164436
0.000170159
0.000232767
0.000192014
0.00632206
0.00660608
0.00672523
0.00635132
0.0068771
0.0470308
0.00708252
0.0070665
-0.000322049
-1.01644e-20
-0.000310157
-1.69407e-19
-0.00126441
-0.000210735
-0.000338559
-1.35525e-20
-0.00132122
-0.000220203
-0.000324975
-1.01644e-20
-0.00134505
-0.000224174
-0.000347549
-1.88041e-19
-0.00127026
-0.000211711
-0.00137542
-0.000229237
-0.00034915
-1.35525e-20
-0.0014165
0.000236084
-0.0014133
0.00023555
-0.000359102
-1.82959e-19
0.000214699
0.000225706
0.000206772
0.00021665
0.000232767
0.000231699
0.000239401
0.00464559
0.00405703
0.00501892
0.0265767
0.00381334
0.00421241
0.00482944
-0.000217905
-5.0822e-21
-0.000246654
-1.32137e-19
-0.000929118
-0.000154853
-0.000811407
-0.000135234
-0.000187798
-3.38813e-21
-0.00100378
-0.000167297
-0.000255238
-1.37219e-19
-0.000762667
0.000127111
-0.000842482
0.000140414
-0.000965889
0.000160981
-0.000193535
-9.99499e-20
-0.000227706
-1.16891e-19
0.00014527
0.000164436
0.000125199
0.000129024
0.000170159
0.000151804
0.00358302
0.00294536
0.00381334
0.0194656
0.00249606
0.00297409
0.0036537
-0.000170504
-5.0822e-21
-0.000187798
-9.99499e-20
-0.000716605
-0.000119434
-0.000589072
-9.81786e-05
-0.000124032
-3.38813e-21
-0.000762667
-0.000127111
-0.000193535
-1.03338e-19
-0.000499211
8.32019e-05
-0.000594818
9.91363e-05
-0.000730741
0.00012179
-0.000125574
-6.52215e-20
-0.000171835
-8.89385e-20
0.000113669
0.000125199
8.2688e-05
0.000129024
8.37158e-05
0.000114557
0.00250683
0.00251636
0.00246604
0.00249606
0.0124572
0.00247193
-0.000126651
-2.5411e-21
-0.000124032
-6.77626e-20
-0.000501367
-8.35611e-05
-0.000124984
-5.0822e-21
-0.000503272
-8.38786e-05
-0.000493208
-8.22013e-05
-0.00012162
-3.38813e-21
-0.000499211
-8.32019e-05
-0.000125574
-6.86097e-20
-0.000494387
8.23978e-05
8.44343e-05
8.2688e-05
8.3323e-05
8.10797e-05
8.37158e-05
0.00373103
0.00403235
0.024226
0.00363982
0.00431845
0.00406353
0.00444084
-0.000196309
-5.0822e-21
-0.000746206
-0.000124368
-0.000176794
-9.65618e-20
-0.00080647
-0.000134412
-0.000206926
-1.69407e-21
-0.000727963
0.000121327
-0.000863691
0.000143948
-0.000812706
0.000135451
-0.000888169
0.000148028
-0.000187188
9.74088e-20
-0.000224919
-1.16891e-19
-0.000219165
1.13502e-19
0.000130873
0.000117863
0.000137951
0.000149946
0.000124792
0.00014611
0.00284615
0.00339789
0.00297409
0.00247193
0.00363982
0.0189201
0.00359023
-0.000162995
-6.77626e-21
-0.00012162
-6.77626e-20
-0.00056923
-9.48717e-05
-0.000176794
-5.0822e-21
-0.000679579
-0.000113263
-0.000125574
-2.5411e-21
-0.000594818
-9.91363e-05
-0.000171835
-9.23266e-20
-0.000494387
-8.23978e-05
-0.000727963
-0.000121327
-0.000187188
-1.69407e-21
-0.000718046
0.000119674
0.000108664
8.10797e-05
0.000117863
8.37158e-05
0.000114557
0.000124792
0.0041562
0.0039322
0.00431845
0.0268652
0.00413787
0.00518194
0.00513853
-0.000208694
-6.77626e-21
-0.000206926
-1.10114e-19
-0.000831239
-0.00013854
-0.00078644
-0.000131073
-0.000184526
-3.38813e-21
-0.000863691
-0.000143948
-0.000224919
-1.25361e-19
-0.000827574
0.000137929
-0.00103639
0.000172731
-0.00102771
0.000171284
-0.000229261
-1.15196e-19
-0.000288933
-1.4569e-19
0.000139129
0.000137951
0.000123018
0.00015284
0.000149946
0.000192622
0.00374036
0.00405043
0.00464169
0.00413787
0.0213493
0.00477897
-0.00018951
-5.0822e-21
-0.000184526
-1.01644e-19
-0.000748073
-0.000124679
-0.000215533
-6.77626e-21
-0.000810085
-0.000135014
-0.000928338
-0.000154723
-0.000248636
-3.38813e-21
-0.000827574
-0.000137929
-0.000229261
-1.21973e-19
-0.000955794
0.000159299
0.00012634
0.000123018
0.000143689
0.000165758
0.00015284
0.0052487
0.00478694
0.00560492
0.0046604
0.0308418
0.00502904
0.0055118
-0.000248632
-3.38813e-21
-0.000276238
-1.49078e-19
-0.00104974
-0.000174957
-0.000230062
-5.0822e-21
-0.000957388
-0.000159565
-0.00112098
-0.000186831
-0.000284254
-1.52466e-19
-0.000932079
-0.000155347
-0.000235978
-5.0822e-21
-0.00100581
0.000167635
-0.00110236
0.000183727
-0.000266926
-1.35525e-19
0.000165755
0.000184158
0.000153374
0.000189503
0.000157319
0.000177951
0.00403713
0.00355137
0.00398638
0.00353008
0.0239716
0.00441856
0.00444803
-0.000187043
-6.77626e-21
-0.000807427
-0.000134571
-0.000216671
-1.18585e-19
-0.000168094
-5.0822e-21
-0.000710274
-0.000118379
-0.000184914
-1.01644e-19
-0.000797275
-0.000132879
-0.000213723
-5.0822e-21
-0.000706017
-0.000117669
-0.000883712
0.000147285
-0.000889607
0.000148268
-0.000228133
-1.15196e-19
0.000112063
0.000124695
0.000123276
0.000144447
0.000142482
0.000152088
0.00442873
0.00488587
0.00441856
0.029176
0.00531511
0.00484415
0.00528356
-0.00022915
-6.77626e-21
-0.000213723
-1.15196e-19
-0.000885746
-0.000147624
-0.000977174
-0.000162862
-0.000259437
-8.47033e-21
-0.000883712
-0.000147285
-0.000228133
-1.25361e-19
-0.00106302
0.00017717
-0.00096883
0.000161472
-0.00105671
0.000176119
-0.000272073
-1.38913e-19
-0.000256283
1.27055e-19
0.000152767
0.000172958
0.000142482
0.000152088
0.000181382
0.000170855
0.00421241
0.0036537
0.00406353
0.00359023
0.0247841
0.00467484
0.00458943
-0.000193535
-3.38813e-21
-0.000842482
-0.000140414
-0.000227706
-1.21973e-19
-0.000171835
-3.38813e-21
-0.000730741
-0.00012179
-0.000187188
-1.03338e-19
-0.000812706
-0.000135451
-0.000219165
-3.38813e-21
-0.000718046
-0.000119674
-0.000934968
0.000155828
-0.000917886
0.000152981
-0.000239778
1.23667e-19
0.000129024
0.000151804
0.000114557
0.000124792
0.00014611
0.000159852
0.00543259
0.00482944
0.00467484
0.0315322
0.00580245
0.00513419
0.00565866
-0.000255238
-5.0822e-21
-0.00108652
-0.000181086
-0.000288021
-1.57548e-19
-0.000227706
-3.38813e-21
-0.000965889
-0.000160981
-0.000934968
-0.000155828
-0.000239778
-6.77626e-21
-0.00116049
0.000193415
-0.00102684
0.00017114
-0.00113173
0.000188622
-0.000292224
1.5416e-19
-0.000273641
-1.38913e-19
0.000170159
0.000151804
0.000192014
0.000159852
0.000182428
0.000194816
0.00637171
0.00708252
0.00580245
0.03776
0.00657054
0.00593778
0.00599505
-0.00034915
-1.89735e-19
-0.000288021
-0.00021239
-0.0014165
-0.000236084
-0.000359102
-1.96512e-19
-0.00116049
-0.000193415
-0.000292224
-3.38813e-21
-0.00131411
0.000219018
-0.00118756
0.000197926
-0.00119901
0.000199835
-0.000297952
1.50772e-19
-0.000301553
-1.55854e-19
0.000232767
0.000192014
0.000239401
0.000198635
0.000194816
0.000201035
0.00531382
0.00619493
0.0070665
0.00531511
0.00657054
0.0361611
0.00570025
-0.000271945
-6.77626e-21
-0.000259437
-1.40607e-19
-0.00106276
-0.000177127
-0.000347549
-1.01644e-20
-0.00123899
-0.000206498
-0.000359102
-1.01644e-20
-0.0014133
-0.00023555
-0.00106302
-0.00017717
-0.000272073
-1.49078e-19
-0.00131411
-0.000219018
-0.000297952
-1.35525e-20
-0.00114005
0.000190008
0.000181296
0.000172958
0.000231699
0.000239401
0.000181382
0.000198635
0.00682002
0.00587739
0.00518194
0.00477897
0.0422237
0.00611276
0.0068291
0.00662353
-0.000339102
-1.86347e-19
-0.001364
-0.000227334
-0.0003429
-3.38813e-21
-0.000248636
-1.35525e-19
-0.00117548
-0.000195913
-0.000229261
-3.38813e-21
-0.00103639
-0.000172731
-0.000288933
-1.59242e-19
-0.000955794
-0.000159299
-0.00122255
0.000203759
-0.00136582
0.000227637
-0.00132471
0.000220784
-0.000322343
1.6263e-19
-0.000340011
-1.76183e-19
0.000165758
0.000226068
0.00015284
0.0002286
0.000192622
0.000214895
0.000226674
0.00444084
0.00513853
0.00458943
0.00513419
0.00611276
0.0313756
0.00595984
-0.000224919
-6.77626e-21
-0.000219165
-1.18585e-19
-0.000888169
-0.000148028
-0.000288933
-6.77626e-21
-0.00102771
-0.000171284
-0.000239778
-1.30443e-19
-0.000917886
-0.000152981
-0.00102684
-0.00017114
-0.000273641
-1.47384e-19
-0.00122255
-0.000203759
-0.000322343
-1.01644e-20
-0.00119197
0.000198661
0.000149946
0.000192622
0.00014611
0.000159852
0.000182428
0.000214895
0.00452649
0.00502904
0.00444803
0.00484415
0.0295762
0.00541744
0.005311
-0.000235978
-1.30443e-19
-0.000216671
-6.77626e-21
-0.000905298
-0.000150883
-0.00100581
-0.000167635
-0.000266926
-1.4569e-19
-0.000228133
-6.77626e-21
-0.000889607
-0.000148268
-0.00096883
-0.000161472
-0.000256283
-1.18585e-20
-0.00108349
0.000180581
-0.0010622
0.000177033
-0.000274818
1.37219e-19
0.000144447
0.000157319
0.000152088
0.000170855
0.000177951
0.000183212
0.00627154
0.0055118
0.0068291
0.00541744
0.0361049
0.00636346
0.00571154
-0.000284254
-6.77626e-21
-0.0003429
-1.89735e-19
-0.00125431
-0.000209051
-0.000266926
-5.0822e-21
-0.00110236
-0.000183727
-0.00136582
-0.000227637
-0.000340011
-1.84653e-19
-0.00108349
-0.000180581
-0.000274818
-5.0822e-21
-0.00127269
0.000212115
-0.00114231
0.000190385
-0.000296336
1.52466e-19
0.0002286
0.000189503
0.000177951
0.000183212
0.000226674
0.000197557
0.00565866
0.00593778
0.00662353
0.00595984
0.00636346
0.0365222
0.00597889
-0.000292224
-1.60936e-19
-0.000273641
-8.47033e-21
-0.00113173
-0.000188622
-0.00118756
-0.000197926
-0.000301553
-1.64324e-19
-0.000322343
-1.74489e-19
-0.000340011
-6.77626e-21
-0.00132471
-0.000220784
-0.00119197
-0.000198661
-0.00127269
-0.000212115
-0.000296336
-1.01644e-20
-0.00119578
0.000199296
0.000182428
0.000194816
0.000214895
0.000201035
0.000226674
0.000197557
0.00528356
0.00599505
0.00570025
0.005311
0.00571154
0.00597889
0.0339803
-0.000272073
-1.01644e-20
-0.000256283
-1.38913e-19
-0.00105671
-0.000176119
-0.000297952
-1.59242e-19
-0.000301553
-0.000199835
-0.00114005
-0.000190008
-0.000274818
-1.52466e-19
-0.0010622
-0.000177033
-0.000296336
-1.6263e-19
-0.00114231
-0.000190385
-0.00119578
-0.000199296
0.000181382
0.000170855
0.000198635
0.000183212
0.000201035
0.000197557
-0.000520833
-0.000520833
-0.000260417
8.68056e-05
4.34028e-05
-6.2004e-06
4.34028e-05
-6.2004e-06
-2.48016e-05
8.68056e-05
-8.68056e-05
-6.77626e-21
9.3006e-06
-6.2004e-06
3.1002e-06
6.2004e-06
-3.1002e-06
-8.47033e-22
-0.000520833
-0.000260417
-0.000520833
4.34028e-05
-6.2004e-06
8.68056e-05
1.94818e-20
4.34028e-05
6.2004e-06
-2.48016e-05
8.68056e-05
-1.42302e-19
-8.68056e-05
-6.2004e-06
3.1002e-06
1.94818e-20
9.3006e-06
6.2004e-06
3.1002e-06
-1.09055e-20
-0.000415177
-0.000415177
-0.000207589
6.91962e-05
1.52466e-20
3.45981e-05
-4.94259e-06
3.45981e-05
-4.94259e-06
-1.97703e-05
6.91962e-05
-6.91962e-05
-1.13502e-19
1.52466e-20
7.41388e-06
-4.94259e-06
2.47129e-06
4.94259e-06
-2.47129e-06
-9.1056e-21
-0.000408752
-0.000408752
-0.000204376
6.81253e-05
3.40626e-05
-4.86609e-06
3.40626e-05
-4.86609e-06
-1.94644e-05
6.81253e-05
-6.81253e-05
-3.38813e-21
7.29914e-06
-4.86609e-06
2.43305e-06
4.86609e-06
-2.43305e-06
-6.35275e-22
-0.000823929
-0.000207589
-0.000204376
-0.000823929
3.45981e-05
-4.94259e-06
3.40626e-05
-4.86609e-06
0.000137321
1.60936e-20
3.45981e-05
4.94259e-06
3.40626e-05
4.86609e-06
-1.97703e-05
-1.94644e-05
0.000137321
-6.77626e-21
-1.11808e-19
-0.000137321
-4.94259e-06
2.47129e-06
-4.86609e-06
2.43305e-06
1.60936e-20
1.4713e-05
4.94259e-06
2.47129e-06
4.86609e-06
2.43305e-06
-8.47033e-22
-8.89385e-21
-0.000520833
-0.000520833
-0.000260417
8.68056e-05
1.94818e-20
4.34028e-05
-6.2004e-06
4.34028e-05
-6.2004e-06
-2.48016e-05
8.68056e-05
-8.68056e-05
-1.40607e-19
1.94818e-20
9.3006e-06
-6.2004e-06
3.1002e-06
6.2004e-06
-3.1002e-06
-1.10114e-20
-0.000520833
-0.000260417
-0.000520833
4.34028e-05
-6.2004e-06
8.68056e-05
4.34028e-05
6.2004e-06
-2.48016e-05
8.68056e-05
-8.47033e-21
-8.68056e-05
-6.2004e-06
3.1002e-06
9.3006e-06
6.2004e-06
3.1002e-06
-1.27055e-21
-0.000418049
-0.000418049
-0.000209025
6.96749e-05
1.60936e-20
3.48374e-05
-4.97678e-06
3.48374e-05
-4.97678e-06
-1.99071e-05
6.96749e-05
-6.96749e-05
-1.13502e-19
1.60936e-20
7.46516e-06
-4.97678e-06
2.48839e-06
4.97678e-06
-2.48839e-06
-8.99973e-21
-0.000409446
-0.000409446
-0.000204723
6.82411e-05
4.23516e-22
3.41205e-05
-4.87436e-06
3.41205e-05
-4.87436e-06
-1.94974e-05
6.82411e-05
-6.82411e-05
-3.38813e-21
4.23516e-22
7.31154e-06
-4.87436e-06
2.43718e-06
4.87436e-06
-2.43718e-06
-8.47033e-22
-0.000827496
-0.000209025
-0.000204723
-0.000827496
3.48374e-05
-4.97678e-06
3.41205e-05
-4.87436e-06
0.000137916
1.60936e-20
3.48374e-05
4.97678e-06
3.41205e-05
4.87436e-06
-1.99071e-05
-1.94974e-05
0.000137916
-5.0822e-21
-1.11808e-19
-0.000137916
-4.97678e-06
2.48839e-06
-4.87436e-06
2.43718e-06
1.60936e-20
1.47767e-05
4.97678e-06
2.48839e-06
4.87436e-06
2.43718e-06
-1.05879e-21
-8.68209e-21
-0.000667736
-0.000667736
-0.000333868
0.000111289
5.56447e-05
-7.94924e-06
5.56447e-05
-7.94924e-06
-3.1797e-05
0.000111289
-0.000111289
-6.77626e-21
1.19239e-05
-7.94924e-06
3.97462e-06
7.94924e-06
-3.97462e-06
-1.69407e-21
-0.000260417
-0.00128715
-0.00128715
-0.000383157
4.34028e-05
6.2004e-06
4.34028e-05
6.2004e-06
0.000214525
4.91279e-20
6.38595e-05
-9.12279e-06
6.38595e-05
-9.12279e-06
-2.48016e-05
-3.64911e-05
-1.32137e-19
0.000214525
-0.000214525
-2.10064e-19
-6.2004e-06
-3.1002e-06
6.2004e-06
3.1002e-06
4.91279e-20
2.29848e-05
-9.12279e-06
4.56139e-06
9.12279e-06
-4.56139e-06
-9.74088e-21
-1.65171e-20
-0.00143405
-0.000333868
-0.000383157
-0.00143405
5.56447e-05
-7.94924e-06
6.38595e-05
-9.12279e-06
0.000239008
2.6258e-20
5.56447e-05
7.94924e-06
6.38595e-05
9.12279e-06
-3.1797e-05
-3.64911e-05
0.000239008
-1.86347e-19
-1.01644e-20
-0.000239008
-7.94924e-06
3.97462e-06
-9.12279e-06
4.56139e-06
2.6258e-20
2.5608e-05
7.94924e-06
3.97462e-06
9.12279e-06
4.56139e-06
-1.43996e-20
-1.69407e-21
-0.000565201
-0.000565201
-0.000282601
9.42002e-05
4.71001e-05
-6.72859e-06
4.71001e-05
-6.72859e-06
-2.69143e-05
9.42002e-05
-9.42002e-05
-6.77626e-21
1.00929e-05
-6.72859e-06
3.36429e-06
6.72859e-06
-3.36429e-06
-8.47033e-22
-0.000333868
-0.00143195
-0.00143195
-0.000382107
5.56447e-05
7.94924e-06
5.56447e-05
7.94924e-06
0.000238658
5.59042e-20
6.36845e-05
-9.09779e-06
6.36845e-05
-9.09779e-06
-3.1797e-05
-3.63912e-05
-1.72795e-19
0.000238658
-0.000238658
-2.06676e-19
-7.94924e-06
-3.97462e-06
7.94924e-06
3.97462e-06
5.59042e-20
2.55705e-05
-9.09779e-06
4.5489e-06
9.09779e-06
-4.5489e-06
-1.3129e-20
-1.63054e-20
-0.00132942
-0.000282601
-0.000382107
-0.00132942
4.71001e-05
-6.72859e-06
6.36845e-05
-9.09779e-06
0.000221569
2.11758e-20
4.71001e-05
6.72859e-06
6.36845e-05
9.09779e-06
-2.69143e-05
-3.63912e-05
0.000221569
-1.5416e-19
-1.01644e-20
-0.000221569
-6.72859e-06
3.36429e-06
-9.09779e-06
4.5489e-06
2.11758e-20
2.37396e-05
6.72859e-06
3.36429e-06
9.09779e-06
4.5489e-06
-1.20702e-20
-1.69407e-21
-0.00050964
-0.00050964
-0.00025482
8.494e-05
4.247e-05
-6.06714e-06
4.247e-05
-6.06714e-06
-2.42686e-05
8.494e-05
-8.494e-05
-5.0822e-21
9.10072e-06
-6.06714e-06
3.03357e-06
6.06714e-06
-3.03357e-06
-1.27055e-21
-0.000282601
-0.00114381
-0.00114381
-0.000289303
4.71001e-05
6.72859e-06
4.71001e-05
6.72859e-06
0.000190634
4.82809e-20
4.82171e-05
-6.88816e-06
4.82171e-05
-6.88816e-06
-2.69143e-05
-2.75526e-05
-1.40607e-19
0.000190634
-0.000190634
-1.57548e-19
-6.72859e-06
-3.36429e-06
6.72859e-06
3.36429e-06
4.82809e-20
2.04251e-05
-6.88816e-06
3.44408e-06
6.88816e-06
-3.44408e-06
-1.12232e-20
-1.28114e-20
-0.00108825
-0.00025482
-0.000289303
-0.00108825
4.247e-05
-6.06714e-06
4.82171e-05
-6.88816e-06
0.000181374
1.86347e-20
4.247e-05
6.06714e-06
4.82171e-05
6.88816e-06
-2.42686e-05
-2.75526e-05
0.000181374
-1.38913e-19
-3.38813e-21
-0.000181374
-6.06714e-06
3.03357e-06
-6.88816e-06
3.44408e-06
1.86347e-20
1.9433e-05
6.06714e-06
3.03357e-06
6.88816e-06
3.44408e-06
-1.10114e-20
-1.27055e-21
-0.000458819
-0.000458819
-0.000229409
7.64698e-05
3.82349e-05
-5.46213e-06
3.82349e-05
-5.46213e-06
-2.18485e-05
7.64698e-05
-7.64698e-05
-3.38813e-21
8.19319e-06
-5.46213e-06
2.73106e-06
5.46213e-06
-2.73106e-06
-8.47033e-22
-0.00025482
-0.00100377
-0.00100377
-0.000247066
4.247e-05
6.06714e-06
4.247e-05
6.06714e-06
0.000167295
3.81165e-20
4.11777e-05
-5.88252e-06
4.11777e-05
-5.88252e-06
-2.42686e-05
-2.35301e-05
-1.28749e-19
0.000167295
-0.000167295
-1.33831e-19
-6.06714e-06
-3.03357e-06
6.06714e-06
3.03357e-06
3.81165e-20
1.79245e-05
-5.88252e-06
2.94126e-06
5.88252e-06
-2.94126e-06
-1.05879e-20
-1.06938e-20
-0.000952951
-0.000229409
-0.000247066
-0.000952951
3.82349e-05
-5.46213e-06
4.11777e-05
-5.88252e-06
0.000158825
1.69407e-20
3.82349e-05
5.46213e-06
4.11777e-05
5.88252e-06
-2.18485e-05
-2.35301e-05
0.000158825
-1.23667e-19
-6.77626e-21
-0.000158825
-5.46213e-06
2.73106e-06
-5.88252e-06
2.94126e-06
1.69407e-20
1.7017e-05
5.46213e-06
2.73106e-06
5.88252e-06
2.94126e-06
-9.84676e-21
-1.27055e-21
-0.000410852
-0.000410852
-0.000205426
6.84754e-05
-4.23516e-22
3.42377e-05
-4.8911e-06
3.42377e-05
-4.8911e-06
-1.95644e-05
6.84754e-05
-6.84754e-05
-5.0822e-21
-4.23516e-22
7.33665e-06
-4.8911e-06
2.44555e-06
4.8911e-06
-2.44555e-06
-8.47033e-22
-0.000229409
-0.000877582
-0.000877582
-0.000209382
3.82349e-05
5.46213e-06
3.82349e-05
5.46213e-06
0.000146264
3.13402e-20
3.48969e-05
-4.98528e-06
3.48969e-05
-4.98528e-06
-2.18485e-05
-1.99411e-05
-1.16891e-19
0.000146264
-0.000146264
-1.15196e-19
-5.46213e-06
-2.73106e-06
5.46213e-06
2.73106e-06
3.13402e-20
1.56711e-05
-4.98528e-06
2.49264e-06
4.98528e-06
-2.49264e-06
-9.42324e-21
-9.21148e-21
-0.000829615
-0.000205426
-0.000209382
-0.000829615
3.42377e-05
-4.8911e-06
3.48969e-05
-4.98528e-06
0.000138269
1.60936e-20
3.42377e-05
4.8911e-06
3.48969e-05
4.98528e-06
-1.95644e-05
-1.99411e-05
0.000138269
-1.11808e-19
-6.77626e-21
-0.000138269
-4.8911e-06
2.44555e-06
-4.98528e-06
2.49264e-06
1.60936e-20
1.48146e-05
4.8911e-06
2.44555e-06
4.98528e-06
2.49264e-06
-8.89385e-21
-1.27055e-21
-0.000377733
-0.000377733
-0.000188867
6.29555e-05
4.23516e-22
3.14778e-05
-4.49682e-06
3.14778e-05
-4.49682e-06
-1.79873e-05
6.29555e-05
-6.29555e-05
-5.0822e-21
4.23516e-22
6.74524e-06
-4.49682e-06
2.24841e-06
4.49682e-06
-2.24841e-06
-8.47033e-22
-0.000205426
-0.000756598
-0.000756598
-0.000172873
3.42377e-05
4.8911e-06
3.42377e-05
4.8911e-06
0.0001261
2.79521e-20
2.88121e-05
-4.11602e-06
2.88121e-05
-4.11602e-06
-1.95644e-05
-1.64641e-05
-1.05879e-19
0.0001261
-0.0001261
-9.40207e-20
-4.8911e-06
-2.44555e-06
4.8911e-06
2.44555e-06
2.79521e-20
1.35107e-05
-4.11602e-06
2.05801e-06
4.11602e-06
-2.05801e-06
-8.04681e-21
-7.30566e-21
-0.000723479
-0.000188867
-0.000172873
-0.000723479
3.14778e-05
-4.49682e-06
2.88121e-05
-4.11602e-06
0.00012058
1.43996e-20
3.14778e-05
4.49682e-06
2.88121e-05
4.11602e-06
-1.79873e-05
-1.64641e-05
0.00012058
-1.01644e-19
-1.69407e-21
-0.00012058
-4.49682e-06
2.24841e-06
-4.11602e-06
2.05801e-06
1.43996e-20
1.29193e-05
4.49682e-06
2.24841e-06
4.11602e-06
2.05801e-06
-8.15269e-21
-8.47033e-22
-0.000188867
-0.00071156
-0.00071156
-0.000166913
3.14778e-05
4.49682e-06
3.14778e-05
4.49682e-06
0.000118593
2.75286e-20
2.78189e-05
-3.97412e-06
2.78189e-05
-3.97412e-06
-1.79873e-05
-1.58965e-05
-9.74088e-20
0.000118593
-0.000118593
-9.06325e-20
-4.49682e-06
-2.24841e-06
4.49682e-06
2.24841e-06
2.75286e-20
1.27064e-05
-3.97412e-06
1.98706e-06
3.97412e-06
-1.98706e-06
-7.6233e-21
-7.51742e-21
-0.000207589
-0.000749004
-0.000166913
-0.000749004
3.45981e-05
4.94259e-06
3.45981e-05
4.94259e-06
2.78189e-05
-3.97412e-06
0.000124834
-1.65171e-20
2.78189e-05
3.97412e-06
-1.97703e-05
-1.58965e-05
1.05879e-19
0.000124834
-5.0822e-21
-0.000124834
-4.94259e-06
-2.47129e-06
4.94259e-06
2.47129e-06
-3.97412e-06
1.98706e-06
-1.65171e-20
1.33751e-05
3.97412e-06
1.98706e-06
8.89385e-21
-8.47033e-22
-0.000364791
-0.000364791
-0.000182396
6.07985e-05
3.03993e-05
-4.34275e-06
3.03993e-05
-4.34275e-06
-1.7371e-05
6.07985e-05
-6.07985e-05
-3.38813e-21
6.51413e-06
-4.34275e-06
2.17138e-06
4.34275e-06
-2.17138e-06
-6.35275e-22
-0.000204376
-0.000738909
-0.000738909
-0.000165078
3.40626e-05
4.86609e-06
3.40626e-05
4.86609e-06
0.000123151
2.83756e-20
2.75131e-05
-3.93044e-06
2.75131e-05
-3.93044e-06
-1.94644e-05
-1.57218e-05
-1.05032e-19
0.000123151
-0.000123151
-9.06325e-20
-4.86609e-06
-2.43305e-06
4.86609e-06
2.43305e-06
2.83756e-20
1.31948e-05
-3.93044e-06
1.96522e-06
3.93044e-06
-1.96522e-06
-8.04681e-21
-7.30566e-21
-0.000694948
-0.000182396
-0.000165078
-0.000694948
3.03993e-05
-4.34275e-06
2.75131e-05
-3.93044e-06
0.000115825
1.43996e-20
3.03993e-05
4.34275e-06
2.75131e-05
3.93044e-06
-1.7371e-05
-1.57218e-05
0.000115825
-9.82558e-20
-6.77626e-21
-0.000115825
-4.34275e-06
2.17138e-06
-3.93044e-06
1.96522e-06
1.43996e-20
1.24098e-05
4.34275e-06
2.17138e-06
3.93044e-06
1.96522e-06
-7.6233e-21
-1.05879e-21
-0.000388797
-0.000388797
-0.000194398
6.47995e-05
4.23516e-22
3.23997e-05
-4.62853e-06
3.23997e-05
-4.62853e-06
-1.85141e-05
6.47995e-05
-6.47995e-05
-5.0822e-21
4.23516e-22
6.9428e-06
-4.62853e-06
2.31427e-06
4.62853e-06
-2.31427e-06
-6.35275e-22
-0.000182396
-0.00069885
-0.00069885
-0.00016703
3.03993e-05
4.34275e-06
3.03993e-05
4.34275e-06
0.000116475
2.6258e-20
2.78383e-05
-3.97689e-06
2.78383e-05
-3.97689e-06
-1.7371e-05
-1.59076e-05
-9.31736e-20
0.000116475
-0.000116475
-8.97855e-20
-4.34275e-06
-2.17138e-06
4.34275e-06
2.17138e-06
2.6258e-20
1.24795e-05
-3.97689e-06
1.98845e-06
3.97689e-06
-1.98845e-06
-6.88214e-21
-7.30566e-21
-0.000722856
-0.000194398
-0.00016703
-0.000722856
3.23997e-05
-4.62853e-06
2.78383e-05
-3.97689e-06
0.000120476
1.52466e-20
3.23997e-05
4.62853e-06
2.78383e-05
3.97689e-06
-1.85141e-05
-1.59076e-05
0.000120476
-1.06726e-19
-3.38813e-21
-0.000120476
-4.62853e-06
2.31427e-06
-3.97689e-06
1.98845e-06
1.52466e-20
1.29081e-05
4.62853e-06
2.31427e-06
3.97689e-06
1.98845e-06
-8.15269e-21
-1.05879e-21
-0.000421533
-0.000421533
-0.000210766
7.02554e-05
3.51277e-05
-5.01824e-06
3.51277e-05
-5.01824e-06
-2.0073e-05
7.02554e-05
-7.02554e-05
-3.38813e-21
7.52737e-06
-5.01824e-06
2.50912e-06
5.01824e-06
-2.50912e-06
-1.05879e-21
-0.000194398
-0.000783508
-0.000783508
-0.000197356
3.23997e-05
4.62853e-06
3.23997e-05
4.62853e-06
0.000130585
2.87991e-20
3.28926e-05
-4.69895e-06
3.28926e-05
-4.69895e-06
-1.85141e-05
-1.87958e-05
-9.91029e-20
0.000130585
-0.000130585
-1.06726e-19
-4.62853e-06
-2.31427e-06
4.62853e-06
2.31427e-06
2.87991e-20
1.39912e-05
-4.69895e-06
2.34947e-06
4.69895e-06
-2.34947e-06
-7.83505e-21
-8.57621e-21
-0.000816244
-0.000210766
-0.000197356
-0.000816244
3.51277e-05
-5.01824e-06
3.28926e-05
-4.69895e-06
0.000136041
1.60936e-20
3.51277e-05
5.01824e-06
3.28926e-05
4.69895e-06
-2.0073e-05
-1.87958e-05
0.000136041
-1.15196e-19
-3.38813e-21
-0.000136041
-5.01824e-06
2.50912e-06
-4.69895e-06
2.34947e-06
1.60936e-20
1.45758e-05
5.01824e-06
2.50912e-06
4.69895e-06
2.34947e-06
-9.1056e-21
-1.05879e-21
-0.000447112
-0.000447112
-0.000223556
7.45186e-05
3.72593e-05
-5.32276e-06
3.72593e-05
-5.32276e-06
-2.1291e-05
7.45186e-05
-7.45186e-05
-6.77626e-21
7.98414e-06
-5.32276e-06
2.66138e-06
5.32276e-06
-2.66138e-06
-1.05879e-21
-0.000210766
-0.000867788
-0.000867788
-0.000223128
3.51277e-05
5.01824e-06
3.51277e-05
5.01824e-06
0.000144631
3.30343e-20
3.7188e-05
-5.31257e-06
3.7188e-05
-5.31257e-06
-2.0073e-05
-2.12503e-05
-1.06726e-19
0.000144631
-0.000144631
-1.21973e-19
-5.01824e-06
-2.50912e-06
5.01824e-06
2.50912e-06
3.30343e-20
1.54962e-05
-5.31257e-06
2.65629e-06
5.31257e-06
-2.65629e-06
-8.47033e-21
-9.74088e-21
-0.000893368
-0.000223556
-0.000223128
-0.000893368
3.72593e-05
-5.32276e-06
3.7188e-05
-5.31257e-06
0.000148895
1.77877e-20
3.72593e-05
5.32276e-06
3.7188e-05
5.31257e-06
-2.1291e-05
-2.12503e-05
0.000148895
-1.21973e-19
-5.0822e-21
-0.000148895
-5.32276e-06
2.66138e-06
-5.31257e-06
2.65629e-06
1.77877e-20
1.5953e-05
5.32276e-06
2.66138e-06
5.31257e-06
2.65629e-06
-9.52912e-21
-1.05879e-21
-0.000455667
-0.000455667
-0.000227834
7.59445e-05
3.79723e-05
-5.42461e-06
3.79723e-05
-5.42461e-06
-2.16984e-05
7.59445e-05
-7.59445e-05
-1.01644e-20
8.13692e-06
-5.42461e-06
2.71231e-06
5.42461e-06
-2.71231e-06
-1.05879e-21
-0.000223556
-0.00092331
-0.00092331
-0.000238099
3.72593e-05
5.32276e-06
3.72593e-05
5.32276e-06
0.000153885
3.47284e-20
3.96832e-05
-5.66903e-06
3.96832e-05
-5.66903e-06
-2.1291e-05
-2.26761e-05
-1.15196e-19
0.000153885
-0.000153885
-1.30443e-19
-5.32276e-06
-2.66138e-06
5.32276e-06
2.66138e-06
3.47284e-20
1.64877e-05
-5.66903e-06
2.83452e-06
5.66903e-06
-2.83452e-06
-8.89385e-21
-1.05879e-20
-0.000931866
-0.000227834
-0.000238099
-0.000931866
3.79723e-05
-5.42461e-06
3.96832e-05
-5.66903e-06
0.000155311
1.69407e-20
3.79723e-05
5.42461e-06
3.96832e-05
5.66903e-06
-2.16984e-05
-2.26761e-05
0.000155311
-1.23667e-19
-3.38813e-21
-0.000155311
-5.42461e-06
2.71231e-06
-5.66903e-06
2.83452e-06
1.69407e-20
1.66405e-05
5.42461e-06
2.71231e-06
5.66903e-06
2.83452e-06
-9.31736e-21
-1.48231e-21
-0.000444183
-0.000444183
-0.000222092
7.40305e-05
-4.23516e-22
3.70153e-05
-5.28789e-06
3.70153e-05
-5.28789e-06
-2.11516e-05
7.40305e-05
-7.40305e-05
-3.38813e-21
-4.23516e-22
7.93184e-06
-5.28789e-06
2.64395e-06
5.28789e-06
-2.64395e-06
-1.27055e-21
-0.000227834
-0.000932829
-0.000932829
-0.000238581
3.79723e-05
5.42461e-06
3.79723e-05
5.42461e-06
0.000155471
3.72694e-20
3.97635e-05
-5.68049e-06
3.97635e-05
-5.68049e-06
-2.16984e-05
-2.2722e-05
-1.16891e-19
0.000155471
-0.000155471
-1.28749e-19
-5.42461e-06
-2.71231e-06
5.42461e-06
2.71231e-06
3.72694e-20
1.66577e-05
-5.68049e-06
2.84025e-06
5.68049e-06
-2.84025e-06
-8.47033e-21
-1.0482e-20
-0.000921345
-0.000222092
-0.000238581
-0.000921345
3.70153e-05
-5.28789e-06
3.97635e-05
-5.68049e-06
0.000153557
1.77877e-20
3.70153e-05
5.28789e-06
3.97635e-05
5.68049e-06
-2.11516e-05
-2.2722e-05
0.000153557
-1.20279e-19
-3.38813e-21
-0.000153557
-5.28789e-06
2.64395e-06
-5.68049e-06
2.84025e-06
1.77877e-20
1.64526e-05
5.28789e-06
2.64395e-06
5.68049e-06
2.84025e-06
-9.52912e-21
-1.27055e-21
-0.000260417
-0.00115561
-0.00115561
-0.000317387
4.34028e-05
6.2004e-06
4.34028e-05
6.2004e-06
0.000192601
-1.86347e-20
5.28978e-05
-7.55683e-06
5.28978e-05
-7.55683e-06
-2.48016e-05
-3.02273e-05
1.32137e-19
0.000192601
-0.000192601
-1.01644e-20
-6.2004e-06
-3.1002e-06
6.2004e-06
3.1002e-06
-1.86347e-20
2.06358e-05
-7.55683e-06
3.77841e-06
7.55683e-06
-3.77841e-06
1.05879e-20
-1.69407e-21
-0.000222092
-0.00107896
-0.000317387
-0.00107896
3.70153e-05
5.28789e-06
3.70153e-05
5.28789e-06
5.28978e-05
-7.55683e-06
0.000179826
4.15046e-20
5.28978e-05
7.55683e-06
-2.11516e-05
-3.02273e-05
-1.10114e-19
0.000179826
-1.74489e-19
-0.000179826
-5.28789e-06
-2.64395e-06
5.28789e-06
2.64395e-06
-7.55683e-06
3.77841e-06
4.15046e-20
1.92671e-05
7.55683e-06
3.77841e-06
-8.47033e-21
-1.35525e-20
-0.000426676
-0.000426676
-0.000213338
7.11127e-05
3.55563e-05
-5.07948e-06
3.55563e-05
-5.07948e-06
-2.03179e-05
7.11127e-05
-7.11127e-05
-3.38813e-21
7.61921e-06
-5.07948e-06
2.53974e-06
5.07948e-06
-2.53974e-06
-1.27055e-21
-0.000317387
-0.00113405
-0.00113405
-0.000249636
5.28978e-05
7.55683e-06
5.28978e-05
7.55683e-06
0.000189008
4.06576e-20
4.1606e-05
-5.94371e-06
4.1606e-05
-5.94371e-06
-3.02273e-05
-2.37749e-05
-1.66018e-19
0.000189008
-0.000189008
-1.35525e-19
-7.55683e-06
-3.77841e-06
7.55683e-06
3.77841e-06
4.06576e-20
2.02508e-05
-5.94371e-06
2.97186e-06
5.94371e-06
-2.97186e-06
-1.2282e-20
-1.07997e-20
-0.000925948
-0.000213338
-0.000249636
-0.000925948
3.55563e-05
-5.07948e-06
4.1606e-05
-5.94371e-06
0.000154325
1.60936e-20
3.55563e-05
5.07948e-06
4.1606e-05
5.94371e-06
-2.03179e-05
-2.37749e-05
0.000154325
-1.15196e-19
-6.77626e-21
-0.000154325
-5.07948e-06
2.53974e-06
-5.94371e-06
2.97186e-06
1.60936e-20
1.65348e-05
5.07948e-06
2.53974e-06
5.94371e-06
2.97186e-06
-8.99973e-21
-1.05879e-21
-0.000491405
-0.000491405
-0.000245703
8.19009e-05
4.09505e-05
-5.85006e-06
4.09505e-05
-5.85006e-06
-2.34003e-05
8.19009e-05
-8.19009e-05
-5.0822e-21
8.7751e-06
-5.85006e-06
2.92503e-06
5.85006e-06
-2.92503e-06
-8.47033e-22
-0.000213338
-0.000816677
-0.000816677
-0.000195001
3.55563e-05
5.07948e-06
3.55563e-05
5.07948e-06
0.000136113
3.13402e-20
3.25001e-05
-4.64287e-06
3.25001e-05
-4.64287e-06
-2.03179e-05
-1.85715e-05
-1.07573e-19
0.000136113
-0.000136113
-1.05032e-19
-5.07948e-06
-2.53974e-06
5.07948e-06
2.53974e-06
3.13402e-20
1.45835e-05
-4.64287e-06
2.32143e-06
4.64287e-06
-2.32143e-06
-8.47033e-21
-8.57621e-21
-0.000881406
-0.000245703
-0.000195001
-0.000881406
4.09505e-05
-5.85006e-06
3.25001e-05
-4.64287e-06
0.000146901
1.99053e-20
4.09505e-05
5.85006e-06
3.25001e-05
4.64287e-06
-2.34003e-05
-1.85715e-05
0.000146901
-1.35525e-19
-5.0822e-21
-0.000146901
-5.85006e-06
2.92503e-06
-4.64287e-06
2.32143e-06
1.99053e-20
1.57394e-05
5.85006e-06
2.92503e-06
4.64287e-06
2.32143e-06
-1.02703e-20
-1.05879e-21
-0.000506209
-0.000506209
-0.000253105
8.43682e-05
4.23516e-22
4.21841e-05
-6.0263e-06
4.21841e-05
-6.0263e-06
-2.41052e-05
8.43682e-05
-8.43682e-05
-1.01644e-20
4.23516e-22
9.03945e-06
-6.0263e-06
3.01315e-06
6.0263e-06
-3.01315e-06
-1.27055e-21
-0.000245703
-0.00100528
-0.00100528
-0.000256936
4.09505e-05
5.85006e-06
4.09505e-05
5.85006e-06
0.000167546
4.06576e-20
4.28227e-05
-6.11752e-06
4.28227e-05
-6.11752e-06
-2.34003e-05
-2.44701e-05
-1.27055e-19
0.000167546
-0.000167546
-1.38913e-19
-5.85006e-06
-2.92503e-06
5.85006e-06
2.92503e-06
4.06576e-20
1.79514e-05
-6.11752e-06
3.05876e-06
6.11752e-06
-3.05876e-06
-9.42324e-21
-1.12232e-20
-0.00102008
-0.000253105
-0.000256936
-0.00102008
4.21841e-05
-6.0263e-06
4.28227e-05
-6.11752e-06
0.000170013
1.86347e-20
4.21841e-05
6.0263e-06
4.28227e-05
6.11752e-06
-2.41052e-05
-2.44701e-05
0.000170013
-1.38913e-19
-8.47033e-21
-0.000170013
-6.0263e-06
3.01315e-06
-6.11752e-06
3.05876e-06
1.86347e-20
1.82157e-05
6.0263e-06
3.01315e-06
6.11752e-06
3.05876e-06
-1.09055e-20
-1.27055e-21
-0.000466674
-0.000466674
-0.000233337
7.7779e-05
3.88895e-05
-5.55564e-06
3.88895e-05
-5.55564e-06
-2.22226e-05
7.7779e-05
-7.7779e-05
-5.0822e-21
8.33346e-06
-5.55564e-06
2.77782e-06
5.55564e-06
-2.77782e-06
-8.47033e-22
-0.000253105
-0.00100906
-0.00100906
-0.000251423
4.21841e-05
6.0263e-06
4.21841e-05
6.0263e-06
0.000168176
4.06576e-20
4.19039e-05
-5.98627e-06
4.19039e-05
-5.98627e-06
-2.41052e-05
-2.39451e-05
-1.28749e-19
0.000168176
-0.000168176
-1.38913e-19
-6.0263e-06
-3.01315e-06
6.0263e-06
3.01315e-06
4.06576e-20
1.80188e-05
-5.98627e-06
2.99313e-06
5.98627e-06
-2.99313e-06
-9.95264e-21
-1.10114e-20
-0.00096952
-0.000233337
-0.000251423
-0.00096952
3.88895e-05
-5.55564e-06
4.19039e-05
-5.98627e-06
0.000161587
1.77877e-20
3.88895e-05
5.55564e-06
4.19039e-05
5.98627e-06
-2.22226e-05
-2.39451e-05
0.000161587
-1.25361e-19
-6.77626e-21
-0.000161587
-5.55564e-06
2.77782e-06
-5.98627e-06
2.99313e-06
1.77877e-20
1.73129e-05
5.55564e-06
2.77782e-06
5.98627e-06
2.99313e-06
-9.84676e-21
-1.48231e-21
-0.000417699
-0.000417699
-0.000208849
6.96165e-05
3.48082e-05
-4.97261e-06
3.48082e-05
-4.97261e-06
-1.98904e-05
6.96165e-05
-6.96165e-05
-5.0822e-21
7.45891e-06
-4.97261e-06
2.4863e-06
4.97261e-06
-2.4863e-06
-1.27055e-21
-0.000233337
-0.000896857
-0.000896857
-0.000215091
3.88895e-05
5.55564e-06
3.88895e-05
5.55564e-06
0.000149476
3.30343e-20
3.58486e-05
-5.12123e-06
3.58486e-05
-5.12123e-06
-2.22226e-05
-2.04849e-05
-1.18585e-19
0.000149476
-0.000149476
-1.16891e-19
-5.55564e-06
-2.77782e-06
5.55564e-06
2.77782e-06
3.30343e-20
1.60153e-05
-5.12123e-06
2.56061e-06
5.12123e-06
-2.56061e-06
-8.99973e-21
-9.42324e-21
-0.000847882
-0.000208849
-0.000215091
-0.000847882
3.48082e-05
-4.97261e-06
3.58486e-05
-5.12123e-06
0.000141314
1.60936e-20
3.48082e-05
4.97261e-06
3.58486e-05
5.12123e-06
-1.98904e-05
-2.04849e-05
0.000141314
-1.15196e-19
-6.77626e-21
-0.000141314
-4.97261e-06
2.4863e-06
-5.12123e-06
2.56061e-06
1.60936e-20
1.51407e-05
4.97261e-06
2.4863e-06
5.12123e-06
2.56061e-06
-8.99973e-21
-1.27055e-21
-0.000382351
-0.000382351
-0.000191176
6.37252e-05
3.18626e-05
-4.5518e-06
3.18626e-05
-4.5518e-06
-1.82072e-05
6.37252e-05
-6.37252e-05
-3.38813e-21
6.8277e-06
-4.5518e-06
2.2759e-06
4.5518e-06
-2.2759e-06
-1.05879e-21
-0.000208849
-0.000770166
-0.000770166
-0.000176233
3.48082e-05
4.97261e-06
3.48082e-05
4.97261e-06
0.000128361
2.83756e-20
2.93722e-05
-4.19603e-06
2.93722e-05
-4.19603e-06
-1.98904e-05
-1.67841e-05
-1.09267e-19
0.000128361
-0.000128361
-9.48677e-20
-4.97261e-06
-2.4863e-06
4.97261e-06
2.4863e-06
2.83756e-20
1.3753e-05
-4.19603e-06
2.09802e-06
4.19603e-06
-2.09802e-06
-7.83505e-21
-7.41154e-21
-0.000734818
-0.000191176
-0.000176233
-0.000734818
3.18626e-05
-4.5518e-06
2.93722e-05
-4.19603e-06
0.00012247
1.52466e-20
3.18626e-05
4.5518e-06
2.93722e-05
4.19603e-06
-1.82072e-05
-1.67841e-05
0.00012247
-1.01644e-19
-8.47033e-21
-0.00012247
-4.5518e-06
2.2759e-06
-4.19603e-06
2.09802e-06
1.52466e-20
1.31218e-05
4.5518e-06
2.2759e-06
4.19603e-06
2.09802e-06
-8.15269e-21
-1.05879e-21
-0.000191176
-0.00071991
-0.00071991
-0.000168779
3.18626e-05
4.5518e-06
3.18626e-05
4.5518e-06
0.000119985
2.5411e-20
2.81299e-05
-4.01855e-06
2.81299e-05
-4.01855e-06
-1.82072e-05
-1.60742e-05
-9.65618e-20
0.000119985
-0.000119985
-9.23266e-20
-4.5518e-06
-2.2759e-06
4.5518e-06
2.2759e-06
2.5411e-20
1.28555e-05
-4.01855e-06
2.00928e-06
4.01855e-06
-2.00928e-06
-7.41154e-21
-7.30566e-21
-0.000209025
-0.000755608
-0.000168779
-0.000755608
3.48374e-05
4.97678e-06
3.48374e-05
4.97678e-06
2.81299e-05
-4.01855e-06
0.000125935
-1.43996e-20
2.81299e-05
4.01855e-06
-1.99071e-05
-1.60742e-05
1.05032e-19
0.000125935
-5.0822e-21
-0.000125935
-4.97678e-06
-2.48839e-06
4.97678e-06
2.48839e-06
-4.01855e-06
2.00928e-06
-1.43996e-20
1.3493e-05
4.01855e-06
2.00928e-06
7.83505e-21
-4.23516e-22
-0.00036424
-0.00036424
-0.00018212
6.07067e-05
3.03534e-05
-4.33619e-06
3.03534e-05
-4.33619e-06
-1.73448e-05
6.07067e-05
-6.07067e-05
-6.77626e-21
6.50429e-06
-4.33619e-06
2.1681e-06
4.33619e-06
-2.1681e-06
-8.47033e-22
-0.000204723
-0.000741441
-0.000741441
-0.000165997
3.41205e-05
4.87436e-06
3.41205e-05
4.87436e-06
0.000123574
2.87991e-20
2.76662e-05
-3.95232e-06
2.76662e-05
-3.95232e-06
-1.94974e-05
-1.58093e-05
-1.04185e-19
0.000123574
-0.000123574
-8.97855e-20
-4.87436e-06
-2.43718e-06
4.87436e-06
2.43718e-06
2.87991e-20
1.324e-05
-3.95232e-06
1.97616e-06
3.95232e-06
-1.97616e-06
-7.51742e-21
-7.30566e-21
-0.000696235
-0.00018212
-0.000165997
-0.000696235
3.03534e-05
-4.33619e-06
2.76662e-05
-3.95232e-06
0.000116039
1.35525e-20
3.03534e-05
4.33619e-06
2.76662e-05
3.95232e-06
-1.73448e-05
-1.58093e-05
0.000116039
-9.82558e-20
-5.0822e-21
-0.000116039
-4.33619e-06
2.1681e-06
-3.95232e-06
1.97616e-06
1.35525e-20
1.24328e-05
4.33619e-06
2.1681e-06
3.95232e-06
1.97616e-06
-7.72918e-21
-6.35275e-22
-0.000384711
-0.000384711
-0.000192355
6.41185e-05
3.20592e-05
-4.57989e-06
3.20592e-05
-4.57989e-06
-1.83196e-05
6.41185e-05
-6.41185e-05
-3.38813e-21
6.86984e-06
-4.57989e-06
2.28995e-06
4.57989e-06
-2.28995e-06
-8.47033e-22
-0.00018212
-0.000696488
-0.000696488
-0.000166124
3.03534e-05
4.33619e-06
3.03534e-05
4.33619e-06
0.000116081
2.79521e-20
2.76873e-05
-3.95533e-06
2.76873e-05
-3.95533e-06
-1.73448e-05
-1.58213e-05
-9.31736e-20
0.000116081
-0.000116081
-9.23266e-20
-4.33619e-06
-2.1681e-06
4.33619e-06
2.1681e-06
2.79521e-20
1.24373e-05
-3.95533e-06
1.97767e-06
3.95533e-06
-1.97767e-06
-6.98802e-21
-7.19978e-21
-0.000716959
-0.000192355
-0.000166124
-0.000716959
3.20592e-05
-4.57989e-06
2.76873e-05
-3.95533e-06
0.000119493
1.52466e-20
3.20592e-05
4.57989e-06
2.76873e-05
3.95533e-06
-1.83196e-05
-1.58213e-05
0.000119493
-1.05032e-19
-5.0822e-21
-0.000119493
-4.57989e-06
2.28995e-06
-3.95533e-06
1.97767e-06
1.52466e-20
1.28028e-05
4.57989e-06
2.28995e-06
3.95533e-06
1.97767e-06
-8.36445e-21
-6.35275e-22
-0.000409058
-0.000409058
-0.000204529
6.81764e-05
3.40882e-05
-4.86974e-06
3.40882e-05
-4.86974e-06
-1.9479e-05
6.81764e-05
-6.81764e-05
-6.77626e-21
7.30461e-06
-4.86974e-06
2.43487e-06
4.86974e-06
-2.43487e-06
-8.47033e-22
-0.000192355
-0.000766976
-0.000766976
-0.000191133
3.20592e-05
4.57989e-06
3.20592e-05
4.57989e-06
0.000127829
3.04932e-20
3.18554e-05
-4.55078e-06
3.18554e-05
-4.55078e-06
-1.83196e-05
-1.82031e-05
-9.82558e-20
0.000127829
-0.000127829
-1.05032e-19
-4.57989e-06
-2.28995e-06
4.57989e-06
2.28995e-06
3.04932e-20
1.3696e-05
-4.55078e-06
2.27539e-06
4.55078e-06
-2.27539e-06
-7.41154e-21
-8.25857e-21
-0.000791323
-0.000204529
-0.000191133
-0.000791323
3.40882e-05
-4.86974e-06
3.18554e-05
-4.55078e-06
0.000131887
1.52466e-20
3.40882e-05
4.86974e-06
3.18554e-05
4.55078e-06
-1.9479e-05
-1.82031e-05
0.000131887
-1.11808e-19
-5.0822e-21
-0.000131887
-4.86974e-06
2.43487e-06
-4.55078e-06
2.27539e-06
1.52466e-20
1.41308e-05
4.86974e-06
2.43487e-06
4.55078e-06
2.27539e-06
-8.68209e-21
-8.47033e-22
-0.000422677
-0.000422677
-0.000211338
7.04461e-05
3.5223e-05
-5.03186e-06
3.5223e-05
-5.03186e-06
-2.01275e-05
7.04461e-05
-7.04461e-05
-3.38813e-21
7.5478e-06
-5.03186e-06
2.51593e-06
5.03186e-06
-2.51593e-06
-1.27055e-21
-0.000204529
-0.000815705
-0.000815705
-0.000203324
3.40882e-05
4.86974e-06
3.40882e-05
4.86974e-06
0.000135951
3.13402e-20
3.38873e-05
-4.84104e-06
3.38873e-05
-4.84104e-06
-1.9479e-05
-1.93641e-05
-1.03338e-19
0.000135951
-0.000135951
-1.11808e-19
-4.86974e-06
-2.43487e-06
4.86974e-06
2.43487e-06
3.13402e-20
1.45662e-05
-4.84104e-06
2.42052e-06
4.84104e-06
-2.42052e-06
-7.94093e-21
-8.89385e-21
-0.000829324
-0.000211338
-0.000203324
-0.000829324
3.5223e-05
-5.03186e-06
3.38873e-05
-4.84104e-06
0.000138221
1.52466e-20
3.5223e-05
5.03186e-06
3.38873e-05
4.84104e-06
-2.01275e-05
-1.93641e-05
0.000138221
-1.15196e-19
-3.38813e-21
-0.000138221
-5.03186e-06
2.51593e-06
-4.84104e-06
2.42052e-06
1.52466e-20
1.48094e-05
5.03186e-06
2.51593e-06
4.84104e-06
2.42052e-06
-8.99973e-21
-1.05879e-21
-0.000474071
-0.000474071
-0.000237036
7.90119e-05
3.95059e-05
-5.64371e-06
3.95059e-05
-5.64371e-06
-2.25748e-05
7.90119e-05
-7.90119e-05
-5.0822e-21
8.46556e-06
-5.64371e-06
2.82185e-06
5.64371e-06
-2.82185e-06
-1.05879e-21
-0.000211338
-0.000873938
-0.000873938
-0.000225631
3.5223e-05
5.03186e-06
3.5223e-05
5.03186e-06
0.000145656
3.47284e-20
3.76051e-05
-5.37216e-06
3.76051e-05
-5.37216e-06
-2.01275e-05
-2.14886e-05
-1.10961e-19
0.000145656
-0.000145656
-1.25361e-19
-5.03186e-06
-2.51593e-06
5.03186e-06
2.51593e-06
3.47284e-20
1.5606e-05
-5.37216e-06
2.68608e-06
5.37216e-06
-2.68608e-06
-8.04681e-21
-1.00585e-20
-0.000925333
-0.000237036
-0.000225631
-0.000925333
3.95059e-05
-5.64371e-06
3.76051e-05
-5.37216e-06
0.000154222
1.77877e-20
3.95059e-05
5.64371e-06
3.76051e-05
5.37216e-06
-2.25748e-05
-2.14886e-05
0.000154222
-1.32137e-19
-1.69407e-21
-0.000154222
-5.64371e-06
2.82185e-06
-5.37216e-06
2.68608e-06
1.77877e-20
1.65238e-05
5.64371e-06
2.82185e-06
5.37216e-06
2.68608e-06
-9.95264e-21
-1.48231e-21
-0.000619411
-0.000619411
-0.000309706
0.000103235
5.16176e-05
-7.37394e-06
5.16176e-05
-7.37394e-06
-2.94958e-05
0.000103235
-0.000103235
-1.01644e-20
1.10609e-05
-7.37394e-06
3.68697e-06
7.37394e-06
-3.68697e-06
-1.69407e-21
-0.00128761
-0.000309706
-0.00128761
-0.0003341
5.16176e-05
-7.37394e-06
0.000214602
2.37169e-20
5.56833e-05
-7.95475e-06
5.16176e-05
7.37394e-06
5.56833e-05
-7.95475e-06
-2.94958e-05
-3.1819e-05
0.000214602
-1.69407e-19
-0.000214602
-6.77626e-21
-7.37394e-06
3.68697e-06
2.37169e-20
2.2993e-05
-7.95475e-06
3.97738e-06
7.37394e-06
3.68697e-06
7.95475e-06
-3.97738e-06
-1.37643e-20
-1.27055e-21
-0.000237036
-0.00114227
-0.0003341
-0.00114227
3.95059e-05
5.64371e-06
3.95059e-05
5.64371e-06
5.56833e-05
-7.95475e-06
0.000190378
4.40457e-20
5.56833e-05
7.95475e-06
-2.25748e-05
-3.1819e-05
-1.21973e-19
0.000190378
-1.81265e-19
-0.000190378
-5.64371e-06
-2.82185e-06
5.64371e-06
2.82185e-06
-7.95475e-06
3.97738e-06
4.40457e-20
2.03977e-05
7.95475e-06
3.97738e-06
-9.1056e-21
-1.46113e-20
-0.000383157
-0.000309706
-0.00138573
-0.00138573
6.38595e-05
9.12279e-06
6.38595e-05
9.12279e-06
5.16176e-05
7.37394e-06
5.16176e-05
7.37394e-06
0.000230954
-3.38813e-21
-2.94958e-05
-3.64911e-05
1.96512e-19
-1.57548e-19
0.000230954
-0.000230954
-9.12279e-06
-4.56139e-06
9.12279e-06
4.56139e-06
-7.37394e-06
-3.68697e-06
7.37394e-06
3.68697e-06
-3.38813e-21
2.47451e-05
-1.2282e-20
1.50348e-20
-0.000382107
-0.00146542
-0.00146542
-0.0003506
6.36845e-05
9.09779e-06
6.36845e-05
9.09779e-06
0.000244236
-3.04932e-20
5.84334e-05
-8.34763e-06
5.84334e-05
-8.34763e-06
-3.63912e-05
-3.33905e-05
1.89735e-19
0.000244236
-0.000244236
-6.77626e-21
-9.09779e-06
-4.5489e-06
9.09779e-06
4.5489e-06
-3.04932e-20
2.61681e-05
-8.34763e-06
4.17381e-06
8.34763e-06
-4.17381e-06
1.43996e-20
-1.69407e-21
-0.0003341
-0.00130735
-0.00130735
-0.000319578
5.56833e-05
7.95475e-06
5.56833e-05
7.95475e-06
0.000217892
4.99749e-20
5.32629e-05
-7.60899e-06
5.32629e-05
-7.60899e-06
-3.1819e-05
-3.0436e-05
-1.72795e-19
0.000217892
-0.000217892
-1.72795e-19
-7.95475e-06
-3.97738e-06
7.95475e-06
3.97738e-06
4.99749e-20
2.33456e-05
-7.60899e-06
3.8045e-06
7.60899e-06
-3.8045e-06
-1.29173e-20
-1.3976e-20
-0.00134036
-0.0003506
-0.000319578
-0.00134036
5.84334e-05
-8.34763e-06
5.32629e-05
-7.60899e-06
0.000223393
2.6258e-20
5.84334e-05
8.34763e-06
5.32629e-05
7.60899e-06
-3.33905e-05
-3.0436e-05
0.000223393
-1.89735e-19
-1.01644e-20
-0.000223393
-8.34763e-06
4.17381e-06
-7.60899e-06
3.8045e-06
2.6258e-20
2.39349e-05
8.34763e-06
4.17381e-06
7.60899e-06
3.8045e-06
-1.50348e-20
-2.11758e-21
-0.000289303
-0.00115833
-0.00115833
-0.000289863
4.82171e-05
6.88816e-06
4.82171e-05
6.88816e-06
0.000193055
-2.20229e-20
4.83105e-05
-6.9015e-06
4.83105e-05
-6.9015e-06
-2.75526e-05
-2.7606e-05
1.49078e-19
0.000193055
-0.000193055
-6.77626e-21
-6.88816e-06
-3.44408e-06
6.88816e-06
3.44408e-06
-2.20229e-20
2.06845e-05
-6.9015e-06
3.45075e-06
6.9015e-06
-3.45075e-06
1.18585e-20
-8.47033e-22
-0.00119511
-0.000289863
-0.00119511
-0.000307692
4.83105e-05
-6.9015e-06
0.000199185
2.28699e-20
5.1282e-05
-7.326e-06
4.83105e-05
6.9015e-06
5.1282e-05
-7.326e-06
-2.7606e-05
-2.9304e-05
0.000199185
-1.57548e-19
-0.000199185
-1.35525e-20
-6.9015e-06
3.45075e-06
2.28699e-20
2.13412e-05
-7.326e-06
3.663e-06
6.9015e-06
3.45075e-06
7.326e-06
-3.663e-06
-1.2282e-20
-1.27055e-21
-0.0003506
-0.00131658
-0.000307692
-0.00131658
5.84334e-05
8.34763e-06
5.84334e-05
8.34763e-06
5.1282e-05
-7.326e-06
0.000219431
5.2516e-20
5.1282e-05
7.326e-06
-3.33905e-05
-2.9304e-05
-1.79571e-19
0.000219431
-1.69407e-19
-0.000219431
-8.34763e-06
-4.17381e-06
8.34763e-06
4.17381e-06
-7.326e-06
3.663e-06
5.2516e-20
2.35104e-05
7.326e-06
3.663e-06
-1.35525e-20
-1.33408e-20
-0.000247066
-0.000991396
-0.000991396
-0.000248632
4.11777e-05
5.88252e-06
4.11777e-05
5.88252e-06
0.000165233
-1.86347e-20
4.14387e-05
-5.91982e-06
4.14387e-05
-5.91982e-06
-2.35301e-05
-2.36793e-05
1.23667e-19
0.000165233
-0.000165233
-3.38813e-21
-5.88252e-06
-2.94126e-06
5.88252e-06
2.94126e-06
-1.86347e-20
1.77035e-05
-5.91982e-06
2.95991e-06
5.91982e-06
-2.95991e-06
1.00585e-20
-1.05879e-21
-0.000289863
-0.0011322
-0.0011322
-0.000276238
4.83105e-05
6.9015e-06
4.83105e-05
6.9015e-06
0.0001887
4.40457e-20
4.60396e-05
-6.57709e-06
4.60396e-05
-6.57709e-06
-2.7606e-05
-2.63083e-05
-1.47384e-19
0.0001887
-0.0001887
-1.49078e-19
-6.9015e-06
-3.45075e-06
6.9015e-06
3.45075e-06
4.40457e-20
2.02179e-05
-6.57709e-06
3.28854e-06
6.57709e-06
-3.28854e-06
-1.14349e-20
-1.21761e-20
-0.00104974
-0.000248632
-0.000276238
-0.00104974
4.14387e-05
-5.91982e-06
4.60396e-05
-6.57709e-06
0.000174957
1.99053e-20
4.14387e-05
5.91982e-06
4.60396e-05
6.57709e-06
-2.36793e-05
-2.63083e-05
0.000174957
-1.35525e-19
-5.0822e-21
-0.000174957
-5.91982e-06
2.95991e-06
-6.57709e-06
3.28854e-06
1.99053e-20
1.87454e-05
5.91982e-06
2.95991e-06
6.57709e-06
3.28854e-06
-1.0482e-20
-1.27055e-21
-0.000209382
-0.000838491
-0.000838491
-0.000209864
3.48969e-05
4.98528e-06
3.48969e-05
4.98528e-06
0.000139749
-1.69407e-20
3.49774e-05
-4.99677e-06
3.49774e-05
-4.99677e-06
-1.99411e-05
-1.99871e-05
1.05032e-19
0.000139749
-0.000139749
-3.38813e-21
-4.98528e-06
-2.49264e-06
4.98528e-06
2.49264e-06
-1.69407e-20
1.49731e-05
-4.99677e-06
2.49838e-06
4.99677e-06
-2.49838e-06
8.47033e-21
-1.05879e-21
-0.000879852
-0.000209864
-0.000879852
-0.000230062
3.49774e-05
-4.99677e-06
0.000146642
1.60936e-20
3.83436e-05
-5.47766e-06
3.49774e-05
4.99677e-06
3.83436e-05
-5.47766e-06
-1.99871e-05
-2.19106e-05
0.000146642
-1.15196e-19
-0.000146642
-5.0822e-21
-4.99677e-06
2.49838e-06
1.60936e-20
1.57116e-05
-5.47766e-06
2.73883e-06
4.99677e-06
2.49838e-06
5.47766e-06
-2.73883e-06
-8.99973e-21
-1.05879e-21
-0.000248632
-0.000957388
-0.000230062
-0.000957388
4.14387e-05
5.91982e-06
4.14387e-05
5.91982e-06
3.83436e-05
-5.47766e-06
0.000159565
3.81165e-20
3.83436e-05
5.47766e-06
-2.36793e-05
-2.19106e-05
-1.27055e-19
0.000159565
-1.25361e-19
-0.000159565
-5.91982e-06
-2.95991e-06
5.91982e-06
2.95991e-06
-5.47766e-06
2.73883e-06
3.81165e-20
1.70962e-05
5.47766e-06
2.73883e-06
-9.52912e-21
-1.00585e-20
-0.000172873
-0.000679602
-0.000679602
-0.000166928
2.88121e-05
4.11602e-06
2.88121e-05
4.11602e-06
0.000113267
-1.35525e-20
2.78214e-05
-3.97449e-06
2.78214e-05
-3.97449e-06
-1.64641e-05
-1.58979e-05
8.72444e-20
0.000113267
-0.000113267
-1.69407e-21
-4.11602e-06
-2.05801e-06
4.11602e-06
2.05801e-06
-1.35525e-20
1.21358e-05
-3.97449e-06
1.98724e-06
3.97449e-06
-1.98724e-06
6.98802e-21
-8.47033e-22
-0.000209864
-0.000783224
-0.000783224
-0.000181748
3.49774e-05
4.99677e-06
3.49774e-05
4.99677e-06
0.000130537
3.21873e-20
3.02913e-05
-4.32733e-06
3.02913e-05
-4.32733e-06
-1.99871e-05
-1.73093e-05
-1.06726e-19
0.000130537
-0.000130537
-9.82558e-20
-4.99677e-06
-2.49838e-06
4.99677e-06
2.49838e-06
3.21873e-20
1.39861e-05
-4.32733e-06
2.16366e-06
4.32733e-06
-2.16366e-06
-8.15269e-21
-7.94093e-21
-0.000697353
-0.000166928
-0.000181748
-0.000697353
2.78214e-05
-3.97449e-06
3.02913e-05
-4.32733e-06
0.000116225
1.27055e-20
2.78214e-05
3.97449e-06
3.02913e-05
4.32733e-06
-1.58979e-05
-1.73093e-05
0.000116225
-9.23266e-20
-5.0822e-21
-0.000116225
-3.97449e-06
1.98724e-06
-4.32733e-06
2.16366e-06
1.27055e-20
1.24527e-05
3.97449e-06
1.98724e-06
4.32733e-06
2.16366e-06
-7.19978e-21
-1.05879e-21
-0.000166913
-0.000584135
-0.000584135
-0.000125154
2.78189e-05
3.97412e-06
2.78189e-05
3.97412e-06
9.73558e-05
-1.27055e-20
2.0859e-05
-2.97986e-06
2.0859e-05
-2.97986e-06
-1.58965e-05
-1.19194e-05
8.63974e-20
9.73558e-05
-9.73558e-05
-2.5411e-21
-3.97412e-06
-1.98706e-06
3.97412e-06
1.98706e-06
-1.27055e-20
1.0431e-05
-2.97986e-06
1.48993e-06
2.97986e-06
-1.48993e-06
6.77626e-21
-5.29396e-22
-0.000166928
-0.000577636
-0.000577636
-0.00012189
2.78214e-05
3.97449e-06
2.78214e-05
3.97449e-06
9.62727e-05
2.15993e-20
2.0315e-05
-2.90214e-06
2.0315e-05
-2.90214e-06
-1.58979e-05
-1.16086e-05
-8.89385e-20
9.62727e-05
-9.62727e-05
-6.60686e-20
-3.97449e-06
-1.98724e-06
3.97449e-06
1.98724e-06
2.15993e-20
1.03149e-05
-2.90214e-06
1.45107e-06
2.90214e-06
-1.45107e-06
-6.67038e-21
-5.24102e-21
-0.000494088
-0.000125154
-0.00012189
-0.000494088
2.0859e-05
-2.97986e-06
2.0315e-05
-2.90214e-06
8.2348e-05
9.74088e-21
2.0859e-05
2.97986e-06
2.0315e-05
2.90214e-06
-1.19194e-05
-1.16086e-05
8.2348e-05
-6.69156e-20
-3.38813e-21
-8.2348e-05
-2.97986e-06
1.48993e-06
-2.90214e-06
1.45107e-06
9.74088e-21
8.823e-06
2.97986e-06
1.48993e-06
2.90214e-06
1.45107e-06
-5.29396e-21
-6.35275e-22
-0.000165078
-0.00057814
-0.00057814
-0.000123992
2.75131e-05
3.93044e-06
2.75131e-05
3.93044e-06
9.63567e-05
-1.18585e-20
2.06653e-05
-2.95218e-06
2.06653e-05
-2.95218e-06
-1.57218e-05
-1.18087e-05
8.38563e-20
9.63567e-05
-9.63567e-05
-5.0822e-21
-3.93044e-06
-1.96522e-06
3.93044e-06
1.96522e-06
-1.18585e-20
1.03239e-05
-2.95218e-06
1.47609e-06
2.95218e-06
-1.47609e-06
6.45863e-21
-6.35275e-22
-0.000125154
-0.000498292
-0.000123992
-0.000498292
2.0859e-05
2.97986e-06
2.0859e-05
2.97986e-06
2.06653e-05
-2.95218e-06
8.30486e-05
2.03288e-20
2.06653e-05
2.95218e-06
-1.19194e-05
-1.18087e-05
-6.35275e-20
8.30486e-05
-6.77626e-20
-8.30486e-05
-2.97986e-06
-1.48993e-06
2.97986e-06
1.48993e-06
-2.95218e-06
1.47609e-06
2.03288e-20
8.89806e-06
2.95218e-06
1.47609e-06
-5.0822e-21
-5.3469e-21
-0.00016703
-0.000660198
-0.000660198
-0.00016307
2.78383e-05
3.97689e-06
2.78383e-05
3.97689e-06
0.000110033
-1.35525e-20
2.71783e-05
-3.88261e-06
2.71783e-05
-3.88261e-06
-1.59076e-05
-1.55304e-05
8.63974e-20
0.000110033
-0.000110033
-6.77626e-21
-3.97689e-06
-1.98845e-06
3.97689e-06
1.98845e-06
-1.35525e-20
1.17893e-05
-3.88261e-06
1.94131e-06
3.88261e-06
-1.94131e-06
6.45863e-21
-8.47033e-22
-0.000123992
-0.000489463
-0.000489463
-0.00012074
2.06653e-05
2.95218e-06
2.06653e-05
2.95218e-06
8.15771e-05
1.94818e-20
2.01233e-05
-2.87476e-06
2.01233e-05
-2.87476e-06
-1.18087e-05
-1.1499e-05
-6.35275e-20
8.15771e-05
-8.15771e-05
-6.52215e-20
-2.95218e-06
-1.47609e-06
2.95218e-06
1.47609e-06
1.94818e-20
8.74041e-06
-2.87476e-06
1.43738e-06
2.87476e-06
-1.43738e-06
-4.87044e-21
-5.18808e-21
-0.000567619
-0.00016307
-0.00012074
-0.000567619
2.71783e-05
-3.88261e-06
2.01233e-05
-2.87476e-06
9.46032e-05
1.2282e-20
2.71783e-05
3.88261e-06
2.01233e-05
2.87476e-06
-1.55304e-05
-1.1499e-05
9.46032e-05
-8.89385e-20
-1.69407e-21
-9.46032e-05
-3.88261e-06
1.94131e-06
-2.87476e-06
1.43738e-06
1.2282e-20
1.01361e-05
3.88261e-06
1.94131e-06
2.87476e-06
1.43738e-06
-6.88214e-21
-6.35275e-22
-0.000197356
-0.000796036
-0.000796036
-0.000200662
3.28926e-05
4.69895e-06
3.28926e-05
4.69895e-06
0.000132673
-1.69407e-20
3.34437e-05
-4.77768e-06
3.34437e-05
-4.77768e-06
-1.87958e-05
-1.91107e-05
9.91029e-20
0.000132673
-0.000132673
-3.38813e-21
-4.69895e-06
-2.34947e-06
4.69895e-06
2.34947e-06
-1.69407e-20
1.42149e-05
-4.77768e-06
2.38884e-06
4.77768e-06
-2.38884e-06
7.6233e-21
-1.05879e-21
-0.0007564
-0.000200662
-0.0007564
-0.000177538
3.34437e-05
-4.77768e-06
0.000126067
1.60936e-20
2.95896e-05
-4.22708e-06
3.34437e-05
4.77768e-06
2.95896e-05
-4.22708e-06
-1.91107e-05
-1.69083e-05
0.000126067
-1.0842e-19
-0.000126067
-6.77626e-21
-4.77768e-06
2.38884e-06
1.60936e-20
1.35071e-05
-4.22708e-06
2.11354e-06
4.77768e-06
2.38884e-06
4.22708e-06
-2.11354e-06
-8.36445e-21
-6.35275e-22
-0.00016307
-0.000681215
-0.000177538
-0.000681215
2.71783e-05
3.88261e-06
2.71783e-05
3.88261e-06
2.95896e-05
-4.22708e-06
0.000113536
2.66815e-20
2.95896e-05
4.22708e-06
-1.55304e-05
-1.69083e-05
-8.47033e-20
0.000113536
-9.74088e-20
-0.000113536
-3.88261e-06
-1.94131e-06
3.88261e-06
1.94131e-06
-4.22708e-06
2.11354e-06
2.66815e-20
1.21645e-05
4.22708e-06
2.11354e-06
-6.24687e-21
-7.51742e-21
-0.000223128
-0.000905917
-0.000905917
-0.000229831
3.7188e-05
5.31257e-06
3.7188e-05
5.31257e-06
0.000150986
-1.69407e-20
3.83051e-05
-5.47216e-06
3.83051e-05
-5.47216e-06
-2.12503e-05
-2.18886e-05
1.13502e-19
0.000150986
-0.000150986
-5.0822e-21
-5.31257e-06
-2.65629e-06
5.31257e-06
2.65629e-06
-1.69407e-20
1.61771e-05
-5.47216e-06
2.73608e-06
5.47216e-06
-2.73608e-06
8.78797e-21
-8.47033e-22
-0.000200662
-0.00083958
-0.00083958
-0.000219128
3.34437e-05
4.77768e-06
3.34437e-05
4.77768e-06
0.00013993
3.13402e-20
3.65213e-05
-5.21733e-06
3.65213e-05
-5.21733e-06
-1.91107e-05
-2.08693e-05
-1.04185e-19
0.00013993
-0.00013993
-1.18585e-19
-4.77768e-06
-2.38884e-06
4.77768e-06
2.38884e-06
3.13402e-20
1.49925e-05
-5.21733e-06
2.60866e-06
5.21733e-06
-2.60866e-06
-7.6233e-21
-9.52912e-21
-0.000897917
-0.000229831
-0.000219128
-0.000897917
3.83051e-05
-5.47216e-06
3.65213e-05
-5.21733e-06
0.000149653
1.69407e-20
3.83051e-05
5.47216e-06
3.65213e-05
5.21733e-06
-2.18886e-05
-2.08693e-05
0.000149653
-1.25361e-19
-3.38813e-21
-0.000149653
-5.47216e-06
2.73608e-06
-5.21733e-06
2.60866e-06
1.69407e-20
1.60342e-05
5.47216e-06
2.73608e-06
5.21733e-06
2.60866e-06
-9.95264e-21
-1.48231e-21
-0.000238099
-0.000978159
-0.000978159
-0.00025098
3.96832e-05
5.66903e-06
3.96832e-05
5.66903e-06
0.000163026
-1.86347e-20
4.183e-05
-5.97572e-06
4.183e-05
-5.97572e-06
-2.26761e-05
-2.39029e-05
1.20279e-19
0.000163026
-0.000163026
-6.77626e-21
-5.66903e-06
-2.83452e-06
5.66903e-06
2.83452e-06
-1.86347e-20
1.74671e-05
-5.97572e-06
2.98786e-06
5.97572e-06
-2.98786e-06
9.52912e-21
-1.27055e-21
-0.000229831
-0.000969021
-0.000969021
-0.00025468
3.83051e-05
5.47216e-06
3.83051e-05
5.47216e-06
0.000161503
3.89635e-20
4.24466e-05
-6.0638e-06
4.24466e-05
-6.0638e-06
-2.18886e-05
-2.42552e-05
-1.18585e-19
0.000161503
-0.000161503
-1.40607e-19
-5.47216e-06
-2.73608e-06
5.47216e-06
2.73608e-06
3.89635e-20
1.73039e-05
-6.0638e-06
3.0319e-06
6.0638e-06
-3.0319e-06
-9.31736e-21
-1.09055e-20
-0.00101132
-0.00025098
-0.00025468
-0.00101132
4.183e-05
-5.97572e-06
4.24466e-05
-6.0638e-06
0.000168553
2.07523e-20
4.183e-05
5.97572e-06
4.24466e-05
6.0638e-06
-2.39029e-05
-2.42552e-05
0.000168553
-1.35525e-19
-6.77626e-21
-0.000168553
-5.97572e-06
2.98786e-06
-6.0638e-06
3.0319e-06
2.07523e-20
1.80593e-05
5.97572e-06
2.98786e-06
6.0638e-06
3.0319e-06
-1.05879e-20
-1.27055e-21
-0.000238581
-0.000967404
-0.000967404
-0.000245121
3.97635e-05
5.68049e-06
3.97635e-05
5.68049e-06
0.000161234
-1.86347e-20
4.08535e-05
-5.83622e-06
4.08535e-05
-5.83622e-06
-2.2722e-05
-2.33449e-05
1.21973e-19
0.000161234
-0.000161234
-6.77626e-21
-5.68049e-06
-2.84025e-06
5.68049e-06
2.84025e-06
-1.86347e-20
1.72751e-05
-5.83622e-06
2.91811e-06
5.83622e-06
-2.91811e-06
9.21148e-21
-8.47033e-22
-0.00025098
-0.00103111
-0.00103111
-0.000264574
4.183e-05
5.97572e-06
4.183e-05
5.97572e-06
0.000171851
3.89635e-20
4.40956e-05
-6.29938e-06
4.40956e-05
-6.29938e-06
-2.39029e-05
-2.51975e-05
-1.30443e-19
0.000171851
-0.000171851
-1.4569e-19
-5.97572e-06
-2.98786e-06
5.97572e-06
2.98786e-06
3.89635e-20
1.84126e-05
-6.29938e-06
3.14969e-06
6.29938e-06
-3.14969e-06
-9.74088e-21
-1.17526e-20
-0.00101939
-0.000245121
-0.000264574
-0.00101939
4.08535e-05
-5.83622e-06
4.40956e-05
-6.29938e-06
0.000169898
1.77877e-20
4.08535e-05
5.83622e-06
4.40956e-05
6.29938e-06
-2.33449e-05
-2.51975e-05
0.000169898
-1.33831e-19
-6.77626e-21
-0.000169898
-5.83622e-06
2.91811e-06
-6.29938e-06
3.14969e-06
1.77877e-20
1.82034e-05
5.83622e-06
2.91811e-06
6.29938e-06
3.14969e-06
-1.05879e-20
-1.27055e-21
-0.000249636
-0.000915014
-0.000915014
-0.000207871
4.1606e-05
5.94371e-06
4.1606e-05
5.94371e-06
0.000152502
-1.73642e-20
3.46451e-05
-4.94931e-06
3.46451e-05
-4.94931e-06
-2.37749e-05
-1.97972e-05
1.28749e-19
0.000152502
-0.000152502
-3.38813e-21
-5.94371e-06
-2.97186e-06
5.94371e-06
2.97186e-06
-1.73642e-20
1.63395e-05
-4.94931e-06
2.47465e-06
4.94931e-06
-2.47465e-06
9.635e-21
-6.35275e-22
-0.000245121
-0.000905984
-0.000207871
-0.000905984
4.08535e-05
5.83622e-06
4.08535e-05
5.83622e-06
3.46451e-05
-4.94931e-06
0.000150997
3.81165e-20
3.46451e-05
4.94931e-06
-2.33449e-05
-1.97972e-05
-1.25361e-19
0.000150997
-1.13502e-19
-0.000150997
-5.83622e-06
-2.91811e-06
5.83622e-06
2.91811e-06
-4.94931e-06
2.47465e-06
3.81165e-20
1.61783e-05
4.94931e-06
2.47465e-06
-9.74088e-21
-8.89385e-21
-0.000195001
-0.000804577
-0.000804577
-0.000207288
3.25001e-05
4.64287e-06
3.25001e-05
4.64287e-06
0.000134096
-1.43996e-20
3.4548e-05
-4.93543e-06
3.4548e-05
-4.93543e-06
-1.85715e-05
-1.97417e-05
9.65618e-20
0.000134096
-0.000134096
-3.38813e-21
-4.64287e-06
-2.32143e-06
4.64287e-06
2.32143e-06
-1.43996e-20
1.43674e-05
-4.93543e-06
2.46771e-06
4.93543e-06
-2.46771e-06
7.72918e-21
-8.47033e-22
-0.000207871
-0.000830317
-0.000207288
-0.000830317
3.46451e-05
4.94931e-06
3.46451e-05
4.94931e-06
3.4548e-05
-4.93543e-06
0.000138386
3.21873e-20
3.4548e-05
4.93543e-06
-1.97972e-05
-1.97417e-05
-1.09267e-19
0.000138386
-1.13502e-19
-0.000138386
-4.94931e-06
-2.47465e-06
4.94931e-06
2.47465e-06
-4.93543e-06
2.46771e-06
3.21873e-20
1.48271e-05
4.93543e-06
2.46771e-06
-8.47033e-21
-8.89385e-21
-0.000256936
-0.00115797
-0.00115797
-0.000322049
4.28227e-05
6.11752e-06
4.28227e-05
6.11752e-06
0.000192995
-2.03288e-20
5.36748e-05
-7.66783e-06
5.36748e-05
-7.66783e-06
-2.44701e-05
-3.06713e-05
1.30443e-19
0.000192995
-0.000192995
-1.01644e-20
-6.11752e-06
-3.05876e-06
6.11752e-06
3.05876e-06
-2.03288e-20
2.0678e-05
-7.66783e-06
3.83392e-06
7.66783e-06
-3.83392e-06
1.01644e-20
-8.47033e-22
-0.000207288
-0.00103489
-0.00103489
-0.000310157
3.4548e-05
4.93543e-06
3.4548e-05
4.93543e-06
0.000172482
3.89635e-20
5.16929e-05
-7.3847e-06
5.16929e-05
-7.3847e-06
-1.97417e-05
-2.95388e-05
-1.05879e-19
0.000172482
-0.000172482
-1.69407e-19
-4.93543e-06
-2.46771e-06
4.93543e-06
2.46771e-06
3.89635e-20
1.84802e-05
-7.3847e-06
3.69235e-06
7.3847e-06
-3.69235e-06
-8.04681e-21
-1.33408e-20
-0.00126441
-0.000322049
-0.000310157
-0.00126441
5.36748e-05
-7.66783e-06
5.16929e-05
-7.3847e-06
0.000210735
2.5411e-20
5.36748e-05
7.66783e-06
5.16929e-05
7.3847e-06
-3.06713e-05
-2.95388e-05
0.000210735
-1.76183e-19
-3.38813e-21
-0.000210735
-7.66783e-06
3.83392e-06
-7.3847e-06
3.69235e-06
2.5411e-20
2.25788e-05
7.66783e-06
3.83392e-06
7.3847e-06
3.69235e-06
-1.35525e-20
-1.69407e-21
-0.000251423
-0.00103384
-0.00103384
-0.000265497
4.19039e-05
5.98627e-06
4.19039e-05
5.98627e-06
0.000172307
-2.03288e-20
4.42495e-05
-6.32136e-06
4.42495e-05
-6.32136e-06
-2.39451e-05
-2.52855e-05
1.30443e-19
0.000172307
-0.000172307
-6.77626e-21
-5.98627e-06
-2.99313e-06
5.98627e-06
2.99313e-06
-2.03288e-20
1.84614e-05
-6.32136e-06
3.16068e-06
6.32136e-06
-3.16068e-06
9.95264e-21
-1.27055e-21
-0.00120811
-0.000265497
-0.00120811
-0.000338559
4.42495e-05
-6.32136e-06
0.000201352
1.86347e-20
5.64265e-05
-8.06093e-06
4.42495e-05
6.32136e-06
5.64265e-05
-8.06093e-06
-2.52855e-05
-3.22437e-05
0.000201352
-1.43996e-19
-0.000201352
-1.35525e-20
-6.32136e-06
3.16068e-06
1.86347e-20
2.15734e-05
-8.06093e-06
4.03047e-06
6.32136e-06
3.16068e-06
8.06093e-06
-4.03047e-06
-1.10114e-20
-2.11758e-21
-0.000322049
-0.00132122
-0.000338559
-0.00132122
5.36748e-05
7.66783e-06
5.36748e-05
7.66783e-06
5.64265e-05
-8.06093e-06
0.000220203
5.33631e-20
5.64265e-05
8.06093e-06
-3.06713e-05
-3.22437e-05
-1.67713e-19
0.000220203
-1.84653e-19
-0.000220203
-7.66783e-06
-3.83392e-06
7.66783e-06
3.83392e-06
-8.06093e-06
4.03047e-06
5.33631e-20
2.35932e-05
8.06093e-06
4.03047e-06
-1.24937e-20
-1.46113e-20
-0.000215091
-0.000865993
-0.000865993
-0.000217905
3.58486e-05
5.12123e-06
3.58486e-05
5.12123e-06
0.000144332
-1.69407e-20
3.63175e-05
-5.18821e-06
3.63175e-05
-5.18821e-06
-2.04849e-05
-2.07529e-05
1.10114e-19
0.000144332
-0.000144332
-5.0822e-21
-5.12123e-06
-2.56061e-06
5.12123e-06
2.56061e-06
-1.69407e-20
1.54642e-05
-5.18821e-06
2.59411e-06
5.18821e-06
-2.59411e-06
8.57621e-21
-8.47033e-22
-0.000265497
-0.0010243
-0.0010243
-0.000246654
4.42495e-05
6.32136e-06
4.42495e-05
6.32136e-06
0.000170717
4.15046e-20
4.1109e-05
-5.87271e-06
4.1109e-05
-5.87271e-06
-2.52855e-05
-2.34909e-05
-1.35525e-19
0.000170717
-0.000170717
-1.32137e-19
-6.32136e-06
-3.16068e-06
6.32136e-06
3.16068e-06
4.15046e-20
1.82911e-05
-5.87271e-06
2.93636e-06
5.87271e-06
-2.93636e-06
-9.74088e-21
-1.05879e-20
-0.000929118
-0.000217905
-0.000246654
-0.000929118
3.63175e-05
-5.18821e-06
4.1109e-05
-5.87271e-06
0.000154853
1.60936e-20
3.63175e-05
5.18821e-06
4.1109e-05
5.87271e-06
-2.07529e-05
-2.34909e-05
0.000154853
-1.16891e-19
-6.77626e-21
-0.000154853
-5.18821e-06
2.59411e-06
-5.87271e-06
2.93636e-06
1.60936e-20
1.65914e-05
5.18821e-06
2.59411e-06
5.87271e-06
2.93636e-06
-9.31736e-21
-1.05879e-21
-0.000176233
-0.000693475
-0.000693475
-0.000170504
2.93722e-05
4.19603e-06
2.93722e-05
4.19603e-06
0.000115579
-1.52466e-20
2.84173e-05
-4.05962e-06
2.84173e-05
-4.05962e-06
-1.67841e-05
-1.62385e-05
8.97855e-20
0.000115579
-0.000115579
-5.0822e-21
-4.19603e-06
-2.09802e-06
4.19603e-06
2.09802e-06
-1.52466e-20
1.23835e-05
-4.05962e-06
2.02981e-06
4.05962e-06
-2.02981e-06
6.77626e-21
-8.47033e-22
-0.000217905
-0.000811407
-0.000811407
-0.000187798
3.63175e-05
5.18821e-06
3.63175e-05
5.18821e-06
0.000135234
3.04932e-20
3.12997e-05
-4.47139e-06
3.12997e-05
-4.47139e-06
-2.07529e-05
-1.78856e-05
-1.13502e-19
0.000135234
-0.000135234
-9.99499e-20
-5.18821e-06
-2.59411e-06
5.18821e-06
2.59411e-06
3.04932e-20
1.44894e-05
-4.47139e-06
2.2357e-06
4.47139e-06
-2.2357e-06
-8.47033e-21
-8.15269e-21
-0.000716605
-0.000170504
-0.000187798
-0.000716605
2.84173e-05
-4.05962e-06
3.12997e-05
-4.47139e-06
0.000119434
1.3129e-20
2.84173e-05
4.05962e-06
3.12997e-05
4.47139e-06
-1.62385e-05
-1.78856e-05
0.000119434
-9.23266e-20
-3.38813e-21
-0.000119434
-4.05962e-06
2.02981e-06
-4.47139e-06
2.2357e-06
1.3129e-20
1.27965e-05
4.05962e-06
2.02981e-06
4.47139e-06
2.2357e-06
-7.19978e-21
-1.05879e-21
-0.000168779
-0.000590861
-0.000590861
-0.000126651
2.81299e-05
4.01855e-06
2.81299e-05
4.01855e-06
9.84769e-05
-1.27055e-20
2.11086e-05
-3.01551e-06
2.11086e-05
-3.01551e-06
-1.60742e-05
-1.2062e-05
8.47033e-20
9.84769e-05
-9.84769e-05
-2.5411e-21
-4.01855e-06
-2.00928e-06
4.01855e-06
2.00928e-06
-1.27055e-20
1.05511e-05
-3.01551e-06
1.50776e-06
3.01551e-06
-1.50776e-06
6.45863e-21
-5.29396e-22
-0.000170504
-0.000589072
-0.000589072
-0.000124032
2.84173e-05
4.05962e-06
2.84173e-05
4.05962e-06
9.81786e-05
2.24464e-20
2.0672e-05
-2.95314e-06
2.0672e-05
-2.95314e-06
-1.62385e-05
-1.18126e-05
-8.55503e-20
9.81786e-05
-9.81786e-05
-6.77626e-20
-4.05962e-06
-2.02981e-06
4.05962e-06
2.02981e-06
2.24464e-20
1.05191e-05
-2.95314e-06
1.47657e-06
2.95314e-06
-1.47657e-06
-6.56451e-21
-5.3469e-21
-0.000501367
-0.000126651
-0.000124032
-0.000501367
2.11086e-05
-3.01551e-06
2.0672e-05
-2.95314e-06
8.35611e-05
9.74088e-21
2.11086e-05
3.01551e-06
2.0672e-05
2.95314e-06
-1.2062e-05
-1.18126e-05
8.35611e-05
-6.86097e-20
-3.38813e-21
-8.35611e-05
-3.01551e-06
1.50776e-06
-2.95314e-06
1.47657e-06
9.74088e-21
8.95298e-06
3.01551e-06
1.50776e-06
2.95314e-06
1.47657e-06
-5.39984e-21
-7.41154e-22
-0.000165997
-0.000581964
-0.000581964
-0.000124984
2.76662e-05
3.95232e-06
2.76662e-05
3.95232e-06
9.6994e-05
-1.27055e-20
2.08307e-05
-2.97582e-06
2.08307e-05
-2.97582e-06
-1.58093e-05
-1.19033e-05
8.30092e-20
9.6994e-05
-9.6994e-05
-5.0822e-21
-3.95232e-06
-1.97616e-06
3.95232e-06
1.97616e-06
-1.27055e-20
1.03922e-05
-2.97582e-06
1.48791e-06
2.97582e-06
-1.48791e-06
6.77626e-21
-5.29396e-22
-0.000126651
-0.000503272
-0.000124984
-0.000503272
2.11086e-05
3.01551e-06
2.11086e-05
3.01551e-06
2.08307e-05
-2.97582e-06
8.38786e-05
1.99053e-20
2.08307e-05
2.97582e-06
-1.2062e-05
-1.19033e-05
-6.43745e-20
8.38786e-05
-6.77626e-20
-8.38786e-05
-3.01551e-06
-1.50776e-06
3.01551e-06
1.50776e-06
-2.97582e-06
1.48791e-06
1.99053e-20
8.987e-06
2.97582e-06
1.48791e-06
-4.92338e-21
-5.24102e-21
-0.000166124
-0.000658239
-0.000658239
-0.000162995
2.76873e-05
3.95533e-06
2.76873e-05
3.95533e-06
0.000109706
-1.35525e-20
2.71659e-05
-3.88084e-06
2.71659e-05
-3.88084e-06
-1.58213e-05
-1.55234e-05
8.47033e-20
0.000109706
-0.000109706
-6.77626e-21
-3.95533e-06
-1.97767e-06
3.95533e-06
1.97767e-06
-1.35525e-20
1.17543e-05
-3.88084e-06
1.94042e-06
3.88084e-06
-1.94042e-06
6.67038e-21
-6.35275e-22
-0.000124984
-0.000493208
-0.000493208
-0.00012162
2.08307e-05
2.97582e-06
2.08307e-05
2.97582e-06
8.22013e-05
1.90582e-20
2.02699e-05
-2.89571e-06
2.02699e-05
-2.89571e-06
-1.19033e-05
-1.15828e-05
-6.35275e-20
8.22013e-05
-8.22013e-05
-6.77626e-20
-2.97582e-06
-1.48791e-06
2.97582e-06
1.48791e-06
1.90582e-20
8.80729e-06
-2.89571e-06
1.44785e-06
2.89571e-06
-1.44785e-06
-4.87044e-21
-5.29396e-21
-0.00056923
-0.000162995
-0.00012162
-0.00056923
2.71659e-05
-3.88084e-06
2.02699e-05
-2.89571e-06
9.48717e-05
1.2282e-20
2.71659e-05
3.88084e-06
2.02699e-05
2.89571e-06
-1.55234e-05
-1.15828e-05
9.48717e-05
-8.80914e-20
-3.38813e-21
-9.48717e-05
-3.88084e-06
1.94042e-06
-2.89571e-06
1.44785e-06
1.2282e-20
1.01648e-05
3.88084e-06
1.94042e-06
2.89571e-06
1.44785e-06
-6.88214e-21
-7.41154e-22
-0.000191133
-0.000774883
-0.000774883
-0.000196309
3.18554e-05
4.55078e-06
3.18554e-05
4.55078e-06
0.000129147
-1.56701e-20
3.27182e-05
-4.67402e-06
3.27182e-05
-4.67402e-06
-1.82031e-05
-1.86961e-05
9.91029e-20
0.000129147
-0.000129147
-5.0822e-21
-4.55078e-06
-2.27539e-06
4.55078e-06
2.27539e-06
-1.56701e-20
1.38372e-05
-4.67402e-06
2.33701e-06
4.67402e-06
-2.33701e-06
7.51742e-21
-8.47033e-22
-0.000746206
-0.000196309
-0.000746206
-0.000176794
3.27182e-05
-4.67402e-06
0.000124368
1.56701e-20
2.94656e-05
-4.20938e-06
3.27182e-05
4.67402e-06
2.94656e-05
-4.20938e-06
-1.86961e-05
-1.68375e-05
0.000124368
-1.0842e-19
-0.000124368
-5.0822e-21
-4.67402e-06
2.33701e-06
1.56701e-20
1.33251e-05
-4.20938e-06
2.10469e-06
4.67402e-06
2.33701e-06
4.20938e-06
-2.10469e-06
-8.36445e-21
-8.47033e-22
-0.000162995
-0.000679579
-0.000176794
-0.000679579
2.71659e-05
3.88084e-06
2.71659e-05
3.88084e-06
2.94656e-05
-4.20938e-06
0.000113263
2.71051e-20
2.94656e-05
4.20938e-06
-1.55234e-05
-1.68375e-05
-8.21622e-20
0.000113263
-9.65618e-20
-0.000113263
-3.88084e-06
-1.94042e-06
3.88084e-06
1.94042e-06
-4.20938e-06
2.10469e-06
2.71051e-20
1.21353e-05
4.20938e-06
2.10469e-06
-6.56451e-21
-7.51742e-21
-0.000203324
-0.000824034
-0.000824034
-0.000208694
3.38873e-05
4.84104e-06
3.38873e-05
4.84104e-06
0.000137339
-1.52466e-20
3.47823e-05
-4.9689e-06
3.47823e-05
-4.9689e-06
-1.93641e-05
-1.98756e-05
1.04185e-19
0.000137339
-0.000137339
-6.77626e-21
-4.84104e-06
-2.42052e-06
4.84104e-06
2.42052e-06
-1.52466e-20
1.47149e-05
-4.9689e-06
2.48445e-06
4.9689e-06
-2.48445e-06
8.04681e-21
-1.05879e-21
-0.000196309
-0.00080647
-0.00080647
-0.000206926
3.27182e-05
4.67402e-06
3.27182e-05
4.67402e-06
0.000134412
2.96462e-20
3.44877e-05
-4.92681e-06
3.44877e-05
-4.92681e-06
-1.86961e-05
-1.97072e-05
-1.00797e-19
0.000134412
-0.000134412
-1.10114e-19
-4.67402e-06
-2.33701e-06
4.67402e-06
2.33701e-06
2.96462e-20
1.44012e-05
-4.92681e-06
2.4634e-06
4.92681e-06
-2.4634e-06
-7.6233e-21
-8.99973e-21
-0.000831239
-0.000208694
-0.000206926
-0.000831239
3.47823e-05
-4.9689e-06
3.44877e-05
-4.92681e-06
0.00013854
1.52466e-20
3.47823e-05
4.9689e-06
3.44877e-05
4.92681e-06
-1.98756e-05
-1.97072e-05
0.00013854
-1.13502e-19
-1.69407e-21
-0.00013854
-4.9689e-06
2.48445e-06
-4.92681e-06
2.4634e-06
1.52466e-20
1.48436e-05
4.9689e-06
2.48445e-06
4.92681e-06
2.4634e-06
-8.99973e-21
-1.05879e-21
-0.000225631
-0.000830281
-0.000830281
-0.00018951
3.76051e-05
5.37216e-06
3.76051e-05
5.37216e-06
0.00013838
-1.69407e-20
3.1585e-05
-4.51214e-06
3.1585e-05
-4.51214e-06
-2.14886e-05
-1.80486e-05
1.15196e-19
0.00013838
-0.00013838
-5.0822e-21
-5.37216e-06
-2.68608e-06
5.37216e-06
2.68608e-06
-1.69407e-20
1.48265e-05
-4.51214e-06
2.25607e-06
4.51214e-06
-2.25607e-06
9.1056e-21
-8.47033e-22
-0.000208694
-0.00078644
-0.00078644
-0.000184526
3.47823e-05
4.9689e-06
3.47823e-05
4.9689e-06
0.000131073
3.04932e-20
3.07544e-05
-4.39349e-06
3.07544e-05
-4.39349e-06
-1.98756e-05
-1.75739e-05
-1.0842e-19
0.000131073
-0.000131073
-1.01644e-19
-4.9689e-06
-2.48445e-06
4.9689e-06
2.48445e-06
3.04932e-20
1.40436e-05
-4.39349e-06
2.19674e-06
4.39349e-06
-2.19674e-06
-8.15269e-21
-7.94093e-21
-0.000748073
-0.00018951
-0.000184526
-0.000748073
3.1585e-05
-4.51214e-06
3.07544e-05
-4.39349e-06
0.000124679
1.43996e-20
3.1585e-05
4.51214e-06
3.07544e-05
4.39349e-06
-1.80486e-05
-1.75739e-05
0.000124679
-1.03338e-19
-3.38813e-21
-0.000124679
-4.51214e-06
2.25607e-06
-4.39349e-06
2.19674e-06
1.43996e-20
1.33584e-05
4.51214e-06
2.25607e-06
4.39349e-06
2.19674e-06
-8.04681e-21
-8.47033e-22
-0.000319578
-0.00107022
-0.00107022
-0.000215533
5.32629e-05
7.60899e-06
5.32629e-05
7.60899e-06
0.00017837
-2.49875e-20
3.59221e-05
-5.13173e-06
3.59221e-05
-5.13173e-06
-2.05269e-05
-3.0436e-05
1.64324e-19
0.00017837
-0.00017837
-6.77626e-21
-7.60899e-06
-3.8045e-06
7.60899e-06
3.8045e-06
-2.49875e-20
1.91111e-05
-5.13173e-06
2.56587e-06
5.13173e-06
-2.56587e-06
-1.27055e-21
1.24937e-20
-0.00018951
-0.000810085
-0.000215533
-0.000810085
3.1585e-05
4.51214e-06
3.1585e-05
4.51214e-06
3.59221e-05
-5.13173e-06
0.000135014
3.21873e-20
3.59221e-05
5.13173e-06
-1.80486e-05
-2.05269e-05
-9.65618e-20
0.000135014
-1.15196e-19
-0.000135014
-4.51214e-06
-2.25607e-06
4.51214e-06
2.25607e-06
-5.13173e-06
2.56587e-06
3.21873e-20
1.44658e-05
5.13173e-06
2.56587e-06
-7.30566e-21
-9.31736e-21
-0.000307692
-0.00129359
-0.00129359
-0.000339102
5.1282e-05
7.326e-06
5.1282e-05
7.326e-06
0.000215598
4.74338e-20
5.65171e-05
-8.07387e-06
5.65171e-05
-8.07387e-06
-2.9304e-05
-3.22955e-05
-1.57548e-19
0.000215598
-0.000215598
-1.86347e-19
-7.326e-06
-3.663e-06
7.326e-06
3.663e-06
4.74338e-20
2.30998e-05
-8.07387e-06
4.03693e-06
8.07387e-06
-4.03693e-06
-1.20702e-20
-1.48231e-20
-0.000276238
-0.00112098
-0.00112098
-0.000284254
4.60396e-05
6.57709e-06
4.60396e-05
6.57709e-06
0.000186831
-2.37169e-20
4.73757e-05
-6.76796e-06
4.73757e-05
-6.76796e-06
-2.63083e-05
-2.70718e-05
1.42302e-19
0.000186831
-0.000186831
-6.77626e-21
-6.57709e-06
-3.28854e-06
6.57709e-06
3.28854e-06
-2.37169e-20
2.00176e-05
-6.76796e-06
3.38398e-06
6.76796e-06
-3.38398e-06
1.12232e-20
-1.27055e-21
-0.001364
-0.000339102
-0.001364
-0.0003429
5.65171e-05
-8.07387e-06
0.000227334
2.5411e-20
5.71499e-05
-8.16428e-06
5.65171e-05
8.07387e-06
5.71499e-05
-8.16428e-06
-3.22955e-05
-3.26571e-05
0.000227334
-1.35525e-20
-0.000227334
-1.89735e-19
-8.07387e-06
4.03693e-06
2.5411e-20
2.43572e-05
-8.16428e-06
4.08214e-06
8.07387e-06
4.03693e-06
8.16428e-06
-4.08214e-06
-2.11758e-21
-1.52466e-20
-0.00125431
-0.000284254
-0.0003429
-0.00125431
4.73757e-05
-6.76796e-06
5.71499e-05
-8.16428e-06
0.000209051
2.28699e-20
4.73757e-05
6.76796e-06
5.71499e-05
8.16428e-06
-3.26571e-05
-2.70718e-05
0.000209051
-1.52466e-19
-3.38813e-21
-0.000209051
-6.76796e-06
3.38398e-06
-8.16428e-06
4.08214e-06
2.28699e-20
2.23984e-05
6.76796e-06
3.38398e-06
8.16428e-06
4.08214e-06
-2.11758e-21
-1.20702e-20
-0.000215533
-0.000928338
-0.000928338
-0.000248636
3.59221e-05
5.13173e-06
3.59221e-05
5.13173e-06
0.000154723
3.47284e-20
4.14394e-05
-5.91991e-06
4.14394e-05
-5.91991e-06
-2.05269e-05
-2.36796e-05
-1.11808e-19
0.000154723
-0.000154723
-1.35525e-19
-5.13173e-06
-2.56587e-06
5.13173e-06
2.56587e-06
3.47284e-20
1.65775e-05
-5.91991e-06
2.95996e-06
5.91991e-06
-2.95996e-06
-8.57621e-21
-1.06938e-20
-0.000339102
-0.00117548
-0.000248636
-0.00117548
5.65171e-05
8.07387e-06
5.65171e-05
8.07387e-06
4.14394e-05
-5.91991e-06
0.000195913
-2.49875e-20
4.14394e-05
5.91991e-06
-2.36796e-05
-3.22955e-05
1.71101e-19
0.000195913
-3.38813e-21
-0.000195913
-8.07387e-06
-4.03693e-06
8.07387e-06
4.03693e-06
-5.91991e-06
2.95996e-06
-2.49875e-20
2.09907e-05
5.91991e-06
2.95996e-06
-1.05879e-21
1.3129e-20
-0.000181748
-0.000737581
-0.000737581
-0.000187043
3.02913e-05
4.32733e-06
3.02913e-05
4.32733e-06
0.00012293
-1.35525e-20
3.11738e-05
-4.45339e-06
3.11738e-05
-4.45339e-06
-1.73093e-05
-1.78136e-05
9.31736e-20
0.00012293
-0.00012293
-6.77626e-21
-4.32733e-06
-2.16366e-06
4.32733e-06
2.16366e-06
-1.35525e-20
1.31711e-05
-4.45339e-06
2.2267e-06
4.45339e-06
-2.2267e-06
6.98802e-21
-6.35275e-22
-0.000230062
-0.000932079
-0.000932079
-0.000235978
3.83436e-05
5.47766e-06
3.83436e-05
5.47766e-06
0.000155347
3.55754e-20
3.93297e-05
-5.61852e-06
3.93297e-05
-5.61852e-06
-2.19106e-05
-2.24741e-05
-1.16891e-19
0.000155347
-0.000155347
-1.30443e-19
-5.47766e-06
-2.73883e-06
5.47766e-06
2.73883e-06
3.55754e-20
1.66443e-05
-5.61852e-06
2.80926e-06
5.61852e-06
-2.80926e-06
-9.21148e-21
-1.01644e-20
-0.000807427
-0.000187043
-0.000807427
-0.000216671
3.11738e-05
-4.45339e-06
0.000134571
1.3976e-20
3.61118e-05
-5.15883e-06
3.11738e-05
4.45339e-06
3.61118e-05
-5.15883e-06
-1.78136e-05
-2.06353e-05
0.000134571
-9.99499e-20
-0.000134571
-6.77626e-21
-4.45339e-06
2.2267e-06
1.3976e-20
1.44183e-05
-5.15883e-06
2.57941e-06
4.45339e-06
2.2267e-06
5.15883e-06
-2.57941e-06
-8.15269e-21
-8.47033e-22
-0.000905298
-0.000235978
-0.000216671
-0.000905298
3.93297e-05
-5.61852e-06
3.61118e-05
-5.15883e-06
0.000150883
1.60936e-20
3.93297e-05
5.61852e-06
3.61118e-05
5.15883e-06
-2.06353e-05
-2.24741e-05
0.000150883
-5.0822e-21
-1.18585e-19
-0.000150883
-5.61852e-06
2.80926e-06
-5.15883e-06
2.57941e-06
1.60936e-20
1.6166e-05
5.61852e-06
2.80926e-06
5.15883e-06
2.57941e-06
-9.21148e-21
-1.48231e-21
-0.00012189
-0.000491397
-0.000491397
-0.000123809
2.0315e-05
2.90214e-06
2.0315e-05
2.90214e-06
8.18995e-05
-1.01644e-20
2.06348e-05
-2.94783e-06
2.06348e-05
-2.94783e-06
-1.16086e-05
-1.17913e-05
6.09864e-20
8.18995e-05
-8.18995e-05
-1.69407e-21
-2.90214e-06
-1.45107e-06
2.90214e-06
1.45107e-06
-1.01644e-20
8.77495e-06
-2.94783e-06
1.47391e-06
2.94783e-06
-1.47391e-06
4.87044e-21
-5.29396e-22
-0.000583806
-0.000123809
-0.000583806
-0.000168094
2.06348e-05
-2.94783e-06
9.7301e-05
8.89385e-21
2.80157e-05
-4.00224e-06
2.06348e-05
2.94783e-06
2.80157e-05
-4.00224e-06
-1.17913e-05
-1.6009e-05
9.7301e-05
-6.86097e-20
-9.7301e-05
-5.0822e-21
-2.94783e-06
1.47391e-06
8.89385e-21
1.04251e-05
-4.00224e-06
2.00112e-06
2.94783e-06
1.47391e-06
4.00224e-06
-2.00112e-06
-5.24102e-21
-4.23516e-22
-0.000187043
-0.000710274
-0.000168094
-0.000710274
3.11738e-05
4.45339e-06
3.11738e-05
4.45339e-06
2.80157e-05
-4.00224e-06
0.000118379
2.6258e-20
2.80157e-05
4.00224e-06
-1.6009e-05
-1.78136e-05
-9.57147e-20
0.000118379
-8.97855e-20
-0.000118379
-4.45339e-06
-2.2267e-06
4.45339e-06
2.2267e-06
-4.00224e-06
2.00112e-06
2.6258e-20
1.26835e-05
4.00224e-06
2.00112e-06
-6.98802e-21
-7.30566e-21
-0.00012074
-0.000123809
-0.000489097
-0.000489097
2.01233e-05
2.87476e-06
2.01233e-05
2.87476e-06
2.06348e-05
2.94783e-06
2.06348e-05
2.94783e-06
8.15162e-05
-1.69407e-21
-1.1499e-05
-1.17913e-05
6.18334e-20
-6.26804e-20
8.15162e-05
-8.15162e-05
-2.87476e-06
-1.43738e-06
2.87476e-06
1.43738e-06
-2.94783e-06
-1.47391e-06
2.94783e-06
1.47391e-06
-1.69407e-21
8.73388e-06
4.71162e-21
-4.76456e-21
-0.000177538
-0.000724903
-0.000724903
-0.000184914
2.95896e-05
4.22708e-06
2.95896e-05
4.22708e-06
0.000120817
2.71051e-20
3.0819e-05
-4.40272e-06
3.0819e-05
-4.40272e-06
-1.69083e-05
-1.76109e-05
-9.23266e-20
0.000120817
-0.000120817
-1.01644e-19
-4.22708e-06
-2.11354e-06
4.22708e-06
2.11354e-06
2.71051e-20
1.29447e-05
-4.40272e-06
2.20136e-06
4.40272e-06
-2.20136e-06
-6.77626e-21
-8.15269e-21
-0.000219128
-0.000896555
-0.000896555
-0.00022915
3.65213e-05
5.21733e-06
3.65213e-05
5.21733e-06
0.000149426
-1.65171e-20
3.81916e-05
-5.45595e-06
3.81916e-05
-5.45595e-06
-2.08693e-05
-2.18238e-05
1.11808e-19
0.000149426
-0.000149426
-6.77626e-21
-5.21733e-06
-2.60866e-06
5.21733e-06
2.60866e-06
-1.65171e-20
1.60099e-05
-5.45595e-06
2.72797e-06
5.45595e-06
-2.72797e-06
8.57621e-21
-1.05879e-21
-0.000797275
-0.000184914
-0.000797275
-0.000213723
3.0819e-05
-4.40272e-06
0.000132879
1.60936e-20
3.56206e-05
-5.08865e-06
3.0819e-05
4.40272e-06
3.56206e-05
-5.08865e-06
-1.76109e-05
-2.03546e-05
0.000132879
-6.77626e-21
-0.000132879
-1.15196e-19
-4.40272e-06
2.20136e-06
1.60936e-20
1.42371e-05
-5.08865e-06
2.54433e-06
4.40272e-06
2.20136e-06
5.08865e-06
-2.54433e-06
-1.05879e-21
-9.1056e-21
-0.000885746
-0.00022915
-0.000213723
-0.000885746
3.81916e-05
-5.45595e-06
3.56206e-05
-5.08865e-06
0.000147624
1.69407e-20
3.81916e-05
5.45595e-06
3.56206e-05
5.08865e-06
-2.18238e-05
-2.03546e-05
0.000147624
-1.25361e-19
-5.0822e-21
-0.000147624
-5.45595e-06
2.72797e-06
-5.08865e-06
2.54433e-06
1.69407e-20
1.58169e-05
5.45595e-06
2.72797e-06
5.08865e-06
2.54433e-06
-9.84676e-21
-8.47033e-22
-0.000168094
-0.000184914
-0.000706017
-0.000706017
2.80157e-05
4.00224e-06
2.80157e-05
4.00224e-06
3.0819e-05
4.40272e-06
3.0819e-05
4.40272e-06
0.000117669
-1.69407e-21
-1.6009e-05
-1.76109e-05
-8.63974e-20
9.23266e-20
0.000117669
-0.000117669
-4.00224e-06
-2.00112e-06
4.00224e-06
2.00112e-06
-4.40272e-06
-2.20136e-06
4.40272e-06
2.20136e-06
-1.69407e-21
1.26074e-05
-6.56451e-21
6.98802e-21
-0.00025468
-0.00105325
-0.00105325
-0.000271945
4.24466e-05
6.0638e-06
4.24466e-05
6.0638e-06
0.000175541
-2.03288e-20
4.53241e-05
-6.47487e-06
4.53241e-05
-6.47487e-06
-2.42552e-05
-2.58995e-05
1.33831e-19
0.000175541
-0.000175541
-6.77626e-21
-6.0638e-06
-3.0319e-06
6.0638e-06
3.0319e-06
-2.03288e-20
1.8808e-05
-6.47487e-06
3.23744e-06
6.47487e-06
-3.23744e-06
1.01644e-20
-8.47033e-22
-0.00022915
-0.000977174
-0.000977174
-0.000259437
3.81916e-05
5.45595e-06
3.81916e-05
5.45595e-06
0.000162862
3.55754e-20
4.32396e-05
-6.17708e-06
4.32396e-05
-6.17708e-06
-2.18238e-05
-2.47083e-05
-1.20279e-19
0.000162862
-0.000162862
-1.40607e-19
-5.45595e-06
-2.72797e-06
5.45595e-06
2.72797e-06
3.55754e-20
1.74495e-05
-6.17708e-06
3.08854e-06
6.17708e-06
-3.08854e-06
-9.21148e-21
-1.13291e-20
-0.00106276
-0.000271945
-0.000259437
-0.00106276
4.53241e-05
-6.47487e-06
4.32396e-05
-6.17708e-06
0.000177127
2.03288e-20
4.53241e-05
6.47487e-06
4.32396e-05
6.17708e-06
-2.58995e-05
-2.47083e-05
0.000177127
-1.47384e-19
-8.47033e-21
-0.000177127
-6.47487e-06
3.23744e-06
-6.17708e-06
3.08854e-06
2.03288e-20
1.89779e-05
6.47487e-06
3.23744e-06
6.17708e-06
3.08854e-06
-1.14349e-20
-1.27055e-21
-0.000264574
-0.0011791
-0.0011791
-0.000324975
4.40956e-05
6.29938e-06
4.40956e-05
6.29938e-06
0.000196516
-1.86347e-20
5.41625e-05
-7.7375e-06
5.41625e-05
-7.7375e-06
-2.51975e-05
-3.095e-05
1.37219e-19
0.000196516
-0.000196516
-1.01644e-20
-6.29938e-06
-3.14969e-06
6.29938e-06
3.14969e-06
-1.86347e-20
2.10553e-05
-7.7375e-06
3.86875e-06
7.7375e-06
-3.86875e-06
1.07997e-20
-1.69407e-21
-0.00134505
-0.000324975
-0.00134505
-0.000347549
5.41625e-05
-7.7375e-06
0.000224174
2.5411e-20
5.79248e-05
-8.27497e-06
5.41625e-05
7.7375e-06
5.79248e-05
-8.27497e-06
-3.095e-05
-3.30999e-05
0.000224174
-1.76183e-19
-0.000224174
-1.01644e-20
-7.7375e-06
3.86875e-06
2.5411e-20
2.40187e-05
-8.27497e-06
4.13748e-06
7.7375e-06
3.86875e-06
8.27497e-06
-4.13748e-06
-1.37643e-20
-8.47033e-22
-0.000271945
-0.00123899
-0.000347549
-0.00123899
4.53241e-05
6.47487e-06
4.53241e-05
6.47487e-06
5.79248e-05
-8.27497e-06
0.000206498
5.0822e-20
5.79248e-05
8.27497e-06
-2.58995e-05
-3.30999e-05
-1.37219e-19
0.000206498
-1.88041e-19
-0.000206498
-6.47487e-06
-3.23744e-06
6.47487e-06
3.23744e-06
-8.27497e-06
4.13748e-06
5.0822e-20
2.21248e-05
8.27497e-06
4.13748e-06
-1.05879e-20
-1.48231e-20
-0.000310157
-0.000324975
-0.00127026
-0.00127026
5.16929e-05
7.3847e-06
5.16929e-05
7.3847e-06
5.41625e-05
7.7375e-06
5.41625e-05
7.7375e-06
0.000211711
-2.95388e-05
-3.095e-05
1.60936e-19
-1.69407e-19
0.000211711
-0.000211711
-7.3847e-06
-3.69235e-06
7.3847e-06
3.69235e-06
-7.7375e-06
-3.86875e-06
7.7375e-06
3.86875e-06
2.26833e-05
1.2282e-20
-1.24937e-20
-0.000338559
-0.00137542
-0.00137542
-0.00034915
5.64265e-05
8.06093e-06
5.64265e-05
8.06093e-06
0.000229237
5.2516e-20
5.81917e-05
-8.3131e-06
5.81917e-05
-8.3131e-06
-3.22437e-05
-3.32524e-05
-1.72795e-19
0.000229237
-0.000229237
-1.89735e-19
-8.06093e-06
-4.03047e-06
8.06093e-06
4.03047e-06
5.2516e-20
2.45611e-05
-8.3131e-06
4.15655e-06
8.3131e-06
-4.15655e-06
-1.3129e-20
-1.46113e-20
-0.000246654
-0.00100378
-0.00100378
-0.000255238
4.1109e-05
5.87271e-06
4.1109e-05
5.87271e-06
0.000167297
-1.86347e-20
4.25397e-05
-6.07711e-06
4.25397e-05
-6.07711e-06
-2.34909e-05
-2.43084e-05
1.23667e-19
0.000167297
-0.000167297
-5.0822e-21
-5.87271e-06
-2.93636e-06
5.87271e-06
2.93636e-06
-1.86347e-20
1.79247e-05
-6.07711e-06
3.03855e-06
6.07711e-06
-3.03855e-06
9.84676e-21
-8.47033e-22
-0.00108652
-0.000255238
-0.00108652
-0.000288021
4.25397e-05
-6.07711e-06
0.000181086
1.94818e-20
4.80035e-05
-6.85764e-06
4.25397e-05
6.07711e-06
4.80035e-05
-6.85764e-06
-2.43084e-05
-2.74305e-05
0.000181086
-1.37219e-19
-0.000181086
-6.07711e-06
3.03855e-06
1.94818e-20
1.94021e-05
-6.85764e-06
3.42882e-06
6.07711e-06
3.03855e-06
6.85764e-06
-3.42882e-06
-1.11173e-20
-1.69407e-21
-0.00127434
-0.00034915
-0.000288021
-0.00127434
5.81917e-05
-8.3131e-06
4.80035e-05
-6.85764e-06
0.00021239
2.28699e-20
5.81917e-05
8.3131e-06
4.80035e-05
6.85764e-06
-3.32524e-05
-2.74305e-05
0.00021239
-1.35525e-20
-1.57548e-19
-0.00021239
-8.3131e-06
4.15655e-06
-6.85764e-06
3.42882e-06
2.28699e-20
2.27561e-05
8.3131e-06
4.15655e-06
6.85764e-06
3.42882e-06
-2.11758e-21
-1.17526e-20
-0.00034915
-0.0014165
-0.0014165
-0.000359102
5.81917e-05
8.3131e-06
5.81917e-05
8.3131e-06
0.000236084
-2.5411e-20
5.98503e-05
-8.55004e-06
5.98503e-05
-8.55004e-06
-3.32524e-05
-3.42001e-05
1.76183e-19
0.000236084
-0.000236084
-1.01644e-20
-8.3131e-06
-4.15655e-06
8.3131e-06
4.15655e-06
-2.5411e-20
2.52947e-05
-8.55004e-06
4.27502e-06
8.55004e-06
-4.27502e-06
1.27055e-20
-1.27055e-21
-0.000347549
-0.0014133
-0.000359102
-0.0014133
5.79248e-05
8.27497e-06
5.79248e-05
8.27497e-06
5.98503e-05
-8.55004e-06
0.00023555
5.42101e-20
5.98503e-05
8.55004e-06
-3.30999e-05
-3.42001e-05
-1.79571e-19
0.00023555
-1.96512e-19
-0.00023555
-8.27497e-06
-4.13748e-06
8.27497e-06
4.13748e-06
-8.55004e-06
4.27502e-06
5.42101e-20
2.52375e-05
8.55004e-06
4.27502e-06
-1.35525e-20
-1.50348e-20
-0.000187798
-0.000762667
-0.000762667
-0.000193535
3.12997e-05
4.47139e-06
3.12997e-05
4.47139e-06
0.000127111
-1.3129e-20
3.22559e-05
-4.60798e-06
3.22559e-05
-4.60798e-06
-1.78856e-05
-1.84319e-05
9.40207e-20
0.000127111
-0.000127111
-3.38813e-21
-4.47139e-06
-2.2357e-06
4.47139e-06
2.2357e-06
-1.3129e-20
1.36191e-05
-4.60798e-06
2.30399e-06
4.60798e-06
-2.30399e-06
6.98802e-21
-1.05879e-21
-0.000842482
-0.000193535
-0.000842482
-0.000227706
3.22559e-05
-4.60798e-06
0.000140414
1.52466e-20
3.7951e-05
-5.42157e-06
3.22559e-05
4.60798e-06
3.7951e-05
-5.42157e-06
-1.84319e-05
-2.16863e-05
0.000140414
-1.03338e-19
-0.000140414
-3.38813e-21
-4.60798e-06
2.30399e-06
1.52466e-20
1.50443e-05
-5.42157e-06
2.71078e-06
4.60798e-06
2.30399e-06
5.42157e-06
-2.71078e-06
-8.47033e-21
-8.47033e-22
-0.000255238
-0.000965889
-0.000227706
-0.000965889
4.25397e-05
6.07711e-06
4.25397e-05
6.07711e-06
3.7951e-05
-5.42157e-06
0.000160981
3.72694e-20
3.7951e-05
5.42157e-06
-2.43084e-05
-2.16863e-05
-1.30443e-19
0.000160981
-1.21973e-19
-0.000160981
-6.07711e-06
-3.03855e-06
6.07711e-06
3.03855e-06
-5.42157e-06
2.71078e-06
3.72694e-20
1.7248e-05
5.42157e-06
2.71078e-06
-1.01644e-20
-9.74088e-21
-0.000124032
-0.000499211
-0.000499211
-0.000125574
2.0672e-05
2.95314e-06
2.0672e-05
2.95314e-06
8.32019e-05
-1.03762e-20
2.09289e-05
-2.98985e-06
2.09289e-05
-2.98985e-06
-1.18126e-05
-1.19594e-05
6.35275e-20
8.32019e-05
-8.32019e-05
-2.5411e-21
-2.95314e-06
-1.47657e-06
2.95314e-06
1.47657e-06
-1.03762e-20
8.91449e-06
-2.98985e-06
1.49492e-06
2.98985e-06
-1.49492e-06
4.76456e-21
-5.29396e-22
-0.000594818
-0.000125574
-0.000594818
-0.000171835
2.09289e-05
-2.98985e-06
9.91363e-05
9.74088e-21
2.86392e-05
-4.09131e-06
2.09289e-05
2.98985e-06
2.86392e-05
-4.09131e-06
-1.19594e-05
-1.63653e-05
9.91363e-05
-6.86097e-20
-9.91363e-05
-3.38813e-21
-2.98985e-06
1.49492e-06
9.74088e-21
1.06217e-05
-4.09131e-06
2.04566e-06
2.98985e-06
1.49492e-06
4.09131e-06
-2.04566e-06
-5.24102e-21
-4.23516e-22
-0.000193535
-0.000730741
-0.000171835
-0.000730741
3.22559e-05
4.60798e-06
3.22559e-05
4.60798e-06
2.86392e-05
-4.09131e-06
0.00012179
2.71051e-20
2.86392e-05
4.09131e-06
-1.84319e-05
-1.63653e-05
-9.99499e-20
0.00012179
-9.23266e-20
-0.00012179
-4.60798e-06
-2.30399e-06
4.60798e-06
2.30399e-06
-4.09131e-06
2.04566e-06
2.71051e-20
1.30489e-05
4.09131e-06
2.04566e-06
-7.51742e-21
-7.51742e-21
-0.00012162
-0.000125574
-0.000494387
-0.000494387
2.02699e-05
2.89571e-06
2.02699e-05
2.89571e-06
2.09289e-05
2.98985e-06
2.09289e-05
2.98985e-06
8.23978e-05
1.69407e-21
-1.15828e-05
-1.19594e-05
6.09864e-20
-6.52215e-20
8.23978e-05
-8.23978e-05
-2.89571e-06
-1.44785e-06
2.89571e-06
1.44785e-06
-2.98985e-06
-1.49492e-06
2.98985e-06
1.49492e-06
1.69407e-21
8.82833e-06
4.76456e-21
-4.87044e-21
-0.000176794
-0.000727963
-0.000727963
-0.000187188
2.94656e-05
4.20938e-06
2.94656e-05
4.20938e-06
0.000121327
2.87991e-20
3.1198e-05
-4.45685e-06
3.1198e-05
-4.45685e-06
-1.68375e-05
-1.78274e-05
-9.14796e-20
0.000121327
-0.000121327
-1.03338e-19
-4.20938e-06
-2.10469e-06
4.20938e-06
2.10469e-06
2.87991e-20
1.29993e-05
-4.45685e-06
2.22843e-06
4.45685e-06
-2.22843e-06
-6.77626e-21
-7.94093e-21
-0.000206926
-0.000863691
-0.000863691
-0.000224919
3.44877e-05
4.92681e-06
3.44877e-05
4.92681e-06
0.000143948
-1.52466e-20
3.74866e-05
-5.35522e-06
3.74866e-05
-5.35522e-06
-1.97072e-05
-2.14209e-05
1.02491e-19
0.000143948
-0.000143948
-6.77626e-21
-4.92681e-06
-2.4634e-06
4.92681e-06
2.4634e-06
-1.52466e-20
1.5423e-05
-5.35522e-06
2.67761e-06
5.35522e-06
-2.67761e-06
8.25857e-21
-1.05879e-21
-0.000812706
-0.000187188
-0.000812706
-0.000219165
3.1198e-05
-4.45685e-06
0.000135451
1.60936e-20
3.65275e-05
-5.21822e-06
3.1198e-05
4.45685e-06
3.65275e-05
-5.21822e-06
-1.78274e-05
-2.08729e-05
0.000135451
-1.69407e-21
-0.000135451
-1.18585e-19
-4.45685e-06
2.22843e-06
1.60936e-20
1.45126e-05
-5.21822e-06
2.60911e-06
4.45685e-06
2.22843e-06
5.21822e-06
-2.60911e-06
-1.27055e-21
-9.52912e-21
-0.000888169
-0.000224919
-0.000219165
-0.000888169
3.74866e-05
-5.35522e-06
3.65275e-05
-5.21822e-06
0.000148028
1.69407e-20
3.74866e-05
5.35522e-06
3.65275e-05
5.21822e-06
-2.14209e-05
-2.08729e-05
0.000148028
-1.25361e-19
-3.38813e-21
-0.000148028
-5.35522e-06
2.67761e-06
-5.21822e-06
2.60911e-06
1.69407e-20
1.58602e-05
5.35522e-06
2.67761e-06
5.21822e-06
2.60911e-06
-9.84676e-21
-8.47033e-22
-0.000171835
-0.000187188
-0.000718046
-0.000718046
2.86392e-05
4.09131e-06
2.86392e-05
4.09131e-06
3.1198e-05
4.45685e-06
3.1198e-05
4.45685e-06
0.000119674
-8.47033e-22
-1.63653e-05
-1.78274e-05
-8.89385e-20
9.74088e-20
0.000119674
-0.000119674
-4.09131e-06
-2.04566e-06
4.09131e-06
2.04566e-06
-4.45685e-06
-2.22843e-06
4.45685e-06
2.22843e-06
-8.47033e-22
1.28223e-05
-7.19978e-21
7.30566e-21
-0.000184526
-0.000827574
-0.000827574
-0.000229261
3.07544e-05
4.39349e-06
3.07544e-05
4.39349e-06
0.000137929
-1.43996e-20
3.82101e-05
-5.45859e-06
3.82101e-05
-5.45859e-06
-1.75739e-05
-2.18344e-05
9.48677e-20
0.000137929
-0.000137929
-3.38813e-21
-4.39349e-06
-2.19674e-06
4.39349e-06
2.19674e-06
-1.43996e-20
1.47781e-05
-5.45859e-06
2.72929e-06
5.45859e-06
-2.72929e-06
7.41154e-21
-1.05879e-21
-0.00103639
-0.000229261
-0.00103639
-0.000288933
3.82101e-05
-5.45859e-06
0.000172731
1.69407e-20
4.81555e-05
-6.87936e-06
3.82101e-05
5.45859e-06
4.81555e-05
-6.87936e-06
-2.18344e-05
-2.75175e-05
0.000172731
-1.21973e-19
-0.000172731
-6.77626e-21
-5.45859e-06
2.72929e-06
1.69407e-20
1.85069e-05
-6.87936e-06
3.43968e-06
5.45859e-06
2.72929e-06
6.87936e-06
-3.43968e-06
-9.95264e-21
-1.69407e-21
-0.000224919
-0.00102771
-0.000288933
-0.00102771
3.74866e-05
5.35522e-06
3.74866e-05
5.35522e-06
4.81555e-05
-6.87936e-06
0.000171284
3.89635e-20
4.81555e-05
6.87936e-06
-2.14209e-05
-2.75175e-05
-1.16891e-19
0.000171284
-1.59242e-19
-0.000171284
-5.35522e-06
-2.67761e-06
5.35522e-06
2.67761e-06
-6.87936e-06
3.43968e-06
3.89635e-20
1.83519e-05
6.87936e-06
3.43968e-06
-8.89385e-21
-1.24937e-20
-0.000248636
-0.000229261
-0.000955794
-0.000955794
4.14394e-05
5.91991e-06
4.14394e-05
5.91991e-06
3.82101e-05
5.45859e-06
3.82101e-05
5.45859e-06
0.000159299
-3.38813e-21
-2.36796e-05
-2.18344e-05
1.27055e-19
-1.15196e-19
0.000159299
-0.000159299
-5.91991e-06
-2.95996e-06
5.91991e-06
2.95996e-06
-5.45859e-06
-2.72929e-06
5.45859e-06
2.72929e-06
-3.38813e-21
1.70677e-05
9.52912e-21
-9.31736e-21
-0.000235978
-0.00100581
-0.00100581
-0.000266926
3.93297e-05
5.61852e-06
3.93297e-05
5.61852e-06
0.000167635
-1.69407e-20
4.44877e-05
-6.35538e-06
4.44877e-05
-6.35538e-06
-2.24741e-05
-2.54215e-05
1.20279e-19
0.000167635
-0.000167635
-5.0822e-21
-5.61852e-06
-2.80926e-06
5.61852e-06
2.80926e-06
-1.69407e-20
1.79609e-05
-6.35538e-06
3.17769e-06
6.35538e-06
-3.17769e-06
8.89385e-21
-1.27055e-21
-0.000284254
-0.00110236
-0.000266926
-0.00110236
4.73757e-05
6.76796e-06
4.73757e-05
6.76796e-06
4.44877e-05
-6.35538e-06
0.000183727
4.23516e-20
4.44877e-05
6.35538e-06
-2.70718e-05
-2.54215e-05
-1.47384e-19
0.000183727
-1.4569e-19
-0.000183727
-6.76796e-06
-3.38398e-06
6.76796e-06
3.38398e-06
-6.35538e-06
3.17769e-06
4.23516e-20
1.9685e-05
6.35538e-06
3.17769e-06
-1.10114e-20
-1.15408e-20
-0.000213723
-0.000883712
-0.000883712
-0.000228133
3.56206e-05
5.08865e-06
3.56206e-05
5.08865e-06
0.000147285
-1.77877e-20
3.80221e-05
-5.43173e-06
3.80221e-05
-5.43173e-06
-2.03546e-05
-2.17269e-05
1.06726e-19
0.000147285
-0.000147285
-6.77626e-21
-5.08865e-06
-2.54433e-06
5.08865e-06
2.54433e-06
-1.77877e-20
1.57806e-05
-5.43173e-06
2.71586e-06
5.43173e-06
-2.71586e-06
8.47033e-21
-1.27055e-21
-0.000216671
-0.000889607
-0.000228133
-0.000889607
3.61118e-05
5.15883e-06
3.61118e-05
5.15883e-06
3.80221e-05
-5.43173e-06
0.000148268
3.38813e-20
3.80221e-05
5.43173e-06
-2.06353e-05
-2.17269e-05
-1.10114e-19
0.000148268
-1.25361e-19
-0.000148268
-5.15883e-06
-2.57941e-06
5.15883e-06
2.57941e-06
-5.43173e-06
2.71586e-06
3.38813e-20
1.58858e-05
5.43173e-06
2.71586e-06
-8.36445e-21
-9.52912e-21
-0.000259437
-0.00106302
-0.00106302
-0.000272073
4.32396e-05
6.17708e-06
4.32396e-05
6.17708e-06
0.00017717
-2.20229e-20
4.53455e-05
-6.47793e-06
4.53455e-05
-6.47793e-06
-2.47083e-05
-2.59117e-05
1.32137e-19
0.00017717
-0.00017717
-1.01644e-20
-6.17708e-06
-3.08854e-06
6.17708e-06
3.08854e-06
-2.20229e-20
1.89825e-05
-6.47793e-06
3.23897e-06
6.47793e-06
-3.23897e-06
9.84676e-21
-1.27055e-21
-0.000228133
-0.00096883
-0.00096883
-0.000256283
3.80221e-05
5.43173e-06
3.80221e-05
5.43173e-06
0.000161472
3.72694e-20
4.27138e-05
-6.10197e-06
4.27138e-05
-6.10197e-06
-2.17269e-05
-2.44079e-05
-1.15196e-19
0.000161472
-0.000161472
-1.38913e-19
-5.43173e-06
-2.71586e-06
5.43173e-06
2.71586e-06
3.72694e-20
1.73005e-05
-6.10197e-06
3.05098e-06
6.10197e-06
-3.05098e-06
-8.57621e-21
-1.10114e-20
-0.00105671
-0.000272073
-0.000256283
-0.00105671
4.53455e-05
-6.47793e-06
4.27138e-05
-6.10197e-06
0.000176119
1.94818e-20
4.53455e-05
6.47793e-06
4.27138e-05
6.10197e-06
-2.59117e-05
-2.44079e-05
0.000176119
-1.49078e-19
-1.18585e-20
-0.000176119
-6.47793e-06
3.23897e-06
-6.10197e-06
3.05098e-06
1.94818e-20
1.88698e-05
6.47793e-06
3.23897e-06
6.10197e-06
3.05098e-06
-1.18585e-20
-1.27055e-21
-0.000227706
-0.000934968
-0.000934968
-0.000239778
3.7951e-05
5.42157e-06
3.7951e-05
5.42157e-06
0.000155828
3.64224e-20
3.9963e-05
-5.709e-06
3.9963e-05
-5.709e-06
-2.16863e-05
-2.2836e-05
-1.16891e-19
0.000155828
-0.000155828
-1.30443e-19
-5.42157e-06
-2.71078e-06
5.42157e-06
2.71078e-06
3.64224e-20
1.66959e-05
-5.709e-06
2.8545e-06
5.709e-06
-2.8545e-06
-8.99973e-21
-1.0482e-20
-0.000219165
-0.000917886
-0.000239778
-0.000917886
3.65275e-05
5.21822e-06
3.65275e-05
5.21822e-06
3.9963e-05
-5.709e-06
0.000152981
-1.73642e-20
3.9963e-05
5.709e-06
-2.08729e-05
-2.2836e-05
1.13502e-19
0.000152981
-6.77626e-21
-0.000152981
-5.21822e-06
-2.60911e-06
5.21822e-06
2.60911e-06
-5.709e-06
2.8545e-06
-1.73642e-20
1.63908e-05
5.709e-06
2.8545e-06
8.57621e-21
-1.27055e-21
-0.000288021
-0.00116049
-0.00116049
-0.000292224
4.80035e-05
6.85764e-06
4.80035e-05
6.85764e-06
0.000193415
4.23516e-20
4.87041e-05
-6.95773e-06
4.87041e-05
-6.95773e-06
-2.74305e-05
-2.78309e-05
-1.49078e-19
0.000193415
-0.000193415
-1.60936e-19
-6.85764e-06
-3.42882e-06
6.85764e-06
3.42882e-06
4.23516e-20
2.0723e-05
-6.95773e-06
3.47886e-06
6.95773e-06
-3.47886e-06
-1.14349e-20
-1.27055e-20
-0.000239778
-0.00102684
-0.00102684
-0.000273641
3.9963e-05
5.709e-06
3.9963e-05
5.709e-06
0.00017114
-1.82112e-20
4.56069e-05
-6.51527e-06
4.56069e-05
-6.51527e-06
-2.2836e-05
-2.60611e-05
1.23667e-19
0.00017114
-0.00017114
-8.47033e-21
-5.709e-06
-2.8545e-06
5.709e-06
2.8545e-06
-1.82112e-20
1.83364e-05
-6.51527e-06
3.25763e-06
6.51527e-06
-3.25763e-06
9.635e-21
-1.27055e-21
-0.00113173
-0.000292224
-0.000273641
-0.00113173
4.87041e-05
-6.95773e-06
4.56069e-05
-6.51527e-06
0.000188622
2.11758e-20
4.87041e-05
6.95773e-06
4.56069e-05
6.51527e-06
-2.60611e-05
-2.78309e-05
0.000188622
-3.38813e-21
-1.47384e-19
-0.000188622
-6.95773e-06
3.47886e-06
-6.51527e-06
3.25763e-06
2.11758e-20
2.02095e-05
6.95773e-06
3.47886e-06
6.51527e-06
3.25763e-06
-1.16467e-20
-2.11758e-21
-0.000359102
-0.00131411
-0.00131411
-0.000297952
5.98503e-05
8.55004e-06
5.98503e-05
8.55004e-06
0.000219018
5.2516e-20
4.96587e-05
-7.0941e-06
4.96587e-05
-7.0941e-06
-3.42001e-05
-2.83764e-05
-1.82959e-19
0.000219018
-0.000219018
-1.59242e-19
-8.55004e-06
-4.27502e-06
8.55004e-06
4.27502e-06
5.2516e-20
2.34662e-05
-7.0941e-06
3.54705e-06
7.0941e-06
-3.54705e-06
-1.35525e-20
-1.3129e-20
-0.000292224
-0.00118756
-0.00118756
-0.000301553
4.87041e-05
6.95773e-06
4.87041e-05
6.95773e-06
0.000197926
-2.5411e-20
5.02589e-05
-7.17984e-06
5.02589e-05
-7.17984e-06
-2.78309e-05
-2.87193e-05
1.5416e-19
0.000197926
-0.000197926
-6.95773e-06
-3.47886e-06
6.95773e-06
3.47886e-06
-2.5411e-20
2.12063e-05
-7.17984e-06
3.58992e-06
7.17984e-06
-3.58992e-06
1.12232e-20
-1.69407e-21
-0.00119901
-0.000297952
-0.000301553
-0.00119901
4.96587e-05
-7.0941e-06
5.02589e-05
-7.17984e-06
0.000199835
2.4564e-20
4.96587e-05
7.0941e-06
5.02589e-05
7.17984e-06
-2.83764e-05
-2.87193e-05
0.000199835
-1.35525e-20
-1.64324e-19
-0.000199835
-7.0941e-06
3.54705e-06
-7.17984e-06
3.58992e-06
2.4564e-20
2.14109e-05
7.0941e-06
3.54705e-06
7.17984e-06
3.58992e-06
-2.11758e-21
-1.35525e-20
-0.000272073
-0.000297952
-0.00114005
-0.00114005
4.53455e-05
6.47793e-06
4.53455e-05
6.47793e-06
4.96587e-05
7.0941e-06
4.96587e-05
7.0941e-06
0.000190008
-1.69407e-21
-2.59117e-05
-2.83764e-05
-1.38913e-19
1.50772e-19
0.000190008
-0.000190008
-6.47793e-06
-3.23897e-06
6.47793e-06
3.23897e-06
-7.0941e-06
-3.54705e-06
7.0941e-06
3.54705e-06
-1.69407e-21
2.0358e-05
-1.05879e-20
1.16467e-20
-0.000288933
-0.00122255
-0.00122255
-0.000322343
4.81555e-05
6.87936e-06
4.81555e-05
6.87936e-06
0.000203759
4.40457e-20
5.37238e-05
-7.67483e-06
5.37238e-05
-7.67483e-06
-2.75175e-05
-3.06993e-05
-1.4569e-19
0.000203759
-0.000203759
-1.74489e-19
-6.87936e-06
-3.43968e-06
6.87936e-06
3.43968e-06
4.40457e-20
2.18313e-05
-7.67483e-06
3.83741e-06
7.67483e-06
-3.83741e-06
-1.14349e-20
-1.3976e-20
-0.0003429
-0.00136582
-0.00136582
-0.000340011
5.71499e-05
8.16428e-06
5.71499e-05
8.16428e-06
0.000227637
-2.71051e-20
5.66684e-05
-8.09549e-06
5.66684e-05
-8.09549e-06
-3.26571e-05
-3.2382e-05
1.77877e-19
0.000227637
-0.000227637
-6.77626e-21
-8.16428e-06
-4.08214e-06
8.16428e-06
4.08214e-06
-2.71051e-20
2.43897e-05
-8.09549e-06
4.04775e-06
8.09549e-06
-4.04775e-06
1.3129e-20
-2.11758e-21
-0.00132471
-0.000322343
-0.000340011
-0.00132471
5.37238e-05
-7.67483e-06
5.66684e-05
-8.09549e-06
0.000220784
2.6258e-20
5.37238e-05
7.67483e-06
5.66684e-05
8.09549e-06
-3.06993e-05
-3.2382e-05
0.000220784
-1.01644e-20
-1.84653e-19
-0.000220784
-7.67483e-06
3.83741e-06
-8.09549e-06
4.04775e-06
2.6258e-20
2.36555e-05
7.67483e-06
3.83741e-06
8.09549e-06
4.04775e-06
-1.27055e-21
-1.43996e-20
-0.000273641
-0.000322343
-0.00119197
-0.00119197
4.56069e-05
6.51527e-06
4.56069e-05
6.51527e-06
5.37238e-05
7.67483e-06
5.37238e-05
7.67483e-06
0.000198661
-5.0822e-21
-2.60611e-05
-3.06993e-05
-1.38913e-19
1.6263e-19
0.000198661
-0.000198661
-6.51527e-06
-3.25763e-06
6.51527e-06
3.25763e-06
-7.67483e-06
-3.83741e-06
7.67483e-06
3.83741e-06
-5.0822e-21
2.12851e-05
-1.07997e-20
1.29173e-20
-0.000266926
-0.00108349
-0.00108349
-0.000274818
4.44877e-05
6.35538e-06
4.44877e-05
6.35538e-06
0.000180581
4.23516e-20
4.5803e-05
-6.54328e-06
4.5803e-05
-6.54328e-06
-2.54215e-05
-2.61731e-05
-1.35525e-19
0.000180581
-0.000180581
-1.52466e-19
-6.35538e-06
-3.17769e-06
6.35538e-06
3.17769e-06
4.23516e-20
1.9348e-05
-6.54328e-06
3.27164e-06
6.54328e-06
-3.27164e-06
-1.03762e-20
-1.16467e-20
-0.000256283
-0.0010622
-0.000274818
-0.0010622
4.27138e-05
6.10197e-06
4.27138e-05
6.10197e-06
4.5803e-05
-6.54328e-06
0.000177033
-2.24464e-20
4.5803e-05
6.54328e-06
-2.44079e-05
-2.61731e-05
1.27055e-19
0.000177033
-5.0822e-21
-0.000177033
-6.10197e-06
-3.05098e-06
6.10197e-06
3.05098e-06
-6.54328e-06
3.27164e-06
-2.24464e-20
1.89679e-05
6.54328e-06
3.27164e-06
1.01644e-20
-1.69407e-21
-0.000340011
-0.00127269
-0.00127269
-0.000296336
5.66684e-05
8.09549e-06
5.66684e-05
8.09549e-06
0.000212115
4.65868e-20
4.93893e-05
-7.05561e-06
4.93893e-05
-7.05561e-06
-3.2382e-05
-2.82225e-05
-1.76183e-19
0.000212115
-0.000212115
-1.6263e-19
-8.09549e-06
-4.04775e-06
8.09549e-06
4.04775e-06
4.65868e-20
2.27267e-05
-7.05561e-06
3.52781e-06
7.05561e-06
-3.52781e-06
-1.29173e-20
-1.3129e-20
-0.000274818
-0.00114231
-0.000296336
-0.00114231
4.5803e-05
6.54328e-06
4.5803e-05
6.54328e-06
4.93893e-05
-7.05561e-06
0.000190385
-2.20229e-20
4.93893e-05
7.05561e-06
-2.61731e-05
-2.82225e-05
1.37219e-19
0.000190385
-1.01644e-20
-0.000190385
-6.54328e-06
-3.27164e-06
6.54328e-06
3.27164e-06
-7.05561e-06
3.52781e-06
-2.20229e-20
2.03983e-05
7.05561e-06
3.52781e-06
1.07997e-20
-1.27055e-21
-0.000301553
-0.000296336
-0.00119578
-0.00119578
5.02589e-05
7.17984e-06
5.02589e-05
7.17984e-06
4.93893e-05
7.05561e-06
4.93893e-05
7.05561e-06
0.000199296
-2.87193e-05
-2.82225e-05
-1.55854e-19
1.52466e-19
0.000199296
-0.000199296
-7.17984e-06
-3.58992e-06
7.17984e-06
3.58992e-06
-7.05561e-06
-3.52781e-06
7.05561e-06
3.52781e-06
2.13532e-05
-1.18585e-20
1.18585e-20
0.000173611
0.000173611
0.000173611
-2.48016e-05
-8.47033e-22
-2.48016e-05
-1.09055e-20
-2.48016e-05
-9.74088e-21
1.24008e-05
0.000222579
0.000222579
0.000222579
-3.1797e-05
-1.69407e-21
-3.1797e-05
-1.43996e-20
-3.1797e-05
-1.3129e-20
1.58985e-05
0.0001884
0.0001884
0.0001884
-2.69143e-05
-8.47033e-22
-2.69143e-05
-1.20702e-20
-2.69143e-05
-1.12232e-20
1.34572e-05
0.000254738
0.000254738
0.000254738
-3.63912e-05
-1.63054e-20
-3.63912e-05
-1.69407e-21
-3.63912e-05
1.43996e-20
1.81956e-05
0.00016988
0.00016988
0.00016988
-2.42686e-05
-1.27055e-21
-2.42686e-05
-1.10114e-20
-2.42686e-05
-1.05879e-20
1.21343e-05
0.000192868
0.000192868
0.000192868
-2.75526e-05
-1.28114e-20
-2.75526e-05
-1.27055e-21
-2.75526e-05
1.18585e-20
1.37763e-05
0.00015294
0.00015294
0.00015294
-2.18485e-05
-8.47033e-22
-2.18485e-05
-9.84676e-21
-2.18485e-05
-9.42324e-21
1.09243e-05
0.000164711
0.000164711
0.000164711
-2.35301e-05
-1.06938e-20
-2.35301e-05
-1.27055e-21
-2.35301e-05
1.00585e-20
1.1765e-05
0.000136951
0.000136951
0.000136951
-1.95644e-05
-8.47033e-22
-1.95644e-05
-8.89385e-21
-1.95644e-05
-8.04681e-21
9.7822e-06
0.000139588
0.000139588
0.000139588
-1.99411e-05
-9.21148e-21
-1.99411e-05
-1.27055e-21
-1.99411e-05
8.47033e-21
9.97055e-06
0.000125911
0.000125911
0.000125911
-1.79873e-05
-8.47033e-22
-1.79873e-05
-8.15269e-21
-1.79873e-05
-7.6233e-21
8.99365e-06
0.000115249
0.000115249
0.000115249
-1.64641e-05
-7.30566e-21
-1.64641e-05
-8.47033e-22
-1.64641e-05
6.98802e-21
8.23204e-06
0.000138392
0.000138392
0.000138392
-1.97703e-05
-9.1056e-21
-1.97703e-05
-8.47033e-22
-1.97703e-05
8.89385e-21
9.88517e-06
0.000111275
0.000111275
0.000111275
-1.58965e-05
-7.51742e-21
-1.58965e-05
-8.47033e-22
-1.58965e-05
6.77626e-21
7.94825e-06
0.000136251
0.000136251
0.000136251
-1.94644e-05
-6.35275e-22
-1.94644e-05
-8.89385e-21
-1.94644e-05
-8.04681e-21
9.73218e-06
0.000121597
0.000121597
0.000121597
-1.7371e-05
-6.35275e-22
-1.7371e-05
-7.6233e-21
-1.7371e-05
-6.88214e-21
8.6855e-06
0.000110052
0.000110052
0.000110052
-1.57218e-05
-7.30566e-21
-1.57218e-05
-1.05879e-21
-1.57218e-05
6.45863e-21
7.86088e-06
0.000129599
0.000129599
0.000129599
-1.85141e-05
-6.35275e-22
-1.85141e-05
-8.15269e-21
-1.85141e-05
-7.83505e-21
9.25706e-06
0.000111353
0.000111353
0.000111353
-1.59076e-05
-7.30566e-21
-1.59076e-05
-1.05879e-21
-1.59076e-05
6.45863e-21
7.95379e-06
0.000140511
0.000140511
0.000140511
-2.0073e-05
-1.05879e-21
-2.0073e-05
-9.1056e-21
-2.0073e-05
-8.47033e-21
1.00365e-05
0.000131571
0.000131571
0.000131571
-1.87958e-05
-8.57621e-21
-1.87958e-05
-1.05879e-21
-1.87958e-05
7.6233e-21
9.39789e-06
0.000149037
0.000149037
0.000149037
-2.1291e-05
-1.05879e-21
-2.1291e-05
-9.52912e-21
-2.1291e-05
-8.89385e-21
1.06455e-05
0.000148752
0.000148752
0.000148752
-2.12503e-05
-9.74088e-21
-2.12503e-05
-1.05879e-21
-2.12503e-05
8.78797e-21
1.06251e-05
0.000151889
0.000151889
0.000151889
-2.16984e-05
-1.05879e-21
-2.16984e-05
-9.31736e-21
-2.16984e-05
-8.47033e-21
1.08492e-05
0.000158733
0.000158733
0.000158733
-2.26761e-05
-1.05879e-20
-2.26761e-05
-1.48231e-21
-2.26761e-05
9.52912e-21
1.13381e-05
0.000148061
0.000148061
0.000148061
-2.11516e-05
-1.27055e-21
-2.11516e-05
-9.52912e-21
-2.11516e-05
-8.47033e-21
1.05758e-05
0.000159054
0.000159054
0.000159054
-2.2722e-05
-1.0482e-20
-2.2722e-05
-1.27055e-21
-2.2722e-05
9.21148e-21
1.1361e-05
0.000173611
0.000173611
0.000173611
-2.48016e-05
-1.10114e-20
-2.48016e-05
-1.27055e-21
-2.48016e-05
1.05879e-20
1.24008e-05
0.000142225
0.000142225
0.000142225
-2.03179e-05
-1.27055e-21
-2.03179e-05
-8.99973e-21
-2.03179e-05
-8.47033e-21
1.0159e-05
0.000163802
0.000163802
0.000163802
-2.34003e-05
-8.47033e-22
-2.34003e-05
-1.02703e-20
-2.34003e-05
-9.42324e-21
1.17001e-05
0.00013
0.00013
0.00013
-1.85715e-05
-8.57621e-21
-1.85715e-05
-1.05879e-21
-1.85715e-05
7.72918e-21
9.28574e-06
0.000168736
0.000168736
0.000168736
-2.41052e-05
-1.27055e-21
-2.41052e-05
-1.09055e-20
-2.41052e-05
-9.95264e-21
1.20526e-05
0.000171291
0.000171291
0.000171291
-2.44701e-05
-1.12232e-20
-2.44701e-05
-1.27055e-21
-2.44701e-05
1.01644e-20
1.2235e-05
0.000155558
0.000155558
0.000155558
-2.22226e-05
-8.47033e-22
-2.22226e-05
-9.84676e-21
-2.22226e-05
-8.99973e-21
1.11113e-05
0.000167615
0.000167615
0.000167615
-2.39451e-05
-1.10114e-20
-2.39451e-05
-1.48231e-21
-2.39451e-05
9.95264e-21
1.19725e-05
0.000139233
0.000139233
0.000139233
-1.98904e-05
-1.27055e-21
-1.98904e-05
-8.99973e-21
-1.98904e-05
-7.83505e-21
9.94521e-06
0.000143394
0.000143394
0.000143394
-2.04849e-05
-9.42324e-21
-2.04849e-05
-1.27055e-21
-2.04849e-05
8.57621e-21
1.02425e-05
0.00012745
0.00012745
0.00012745
-1.82072e-05
-1.05879e-21
-1.82072e-05
-8.15269e-21
-1.82072e-05
-7.41154e-21
9.1036e-06
0.000117489
0.000117489
0.000117489
-1.67841e-05
-7.41154e-21
-1.67841e-05
-1.05879e-21
-1.67841e-05
6.77626e-21
8.39206e-06
0.00013935
0.00013935
0.00013935
-1.99071e-05
-8.99973e-21
-1.99071e-05
-1.05879e-21
-1.99071e-05
7.83505e-21
9.95355e-06
0.000112519
0.000112519
0.000112519
-1.60742e-05
-7.30566e-21
-1.60742e-05
-4.23516e-22
-1.60742e-05
6.45863e-21
8.03711e-06
0.000136482
0.000136482
0.000136482
-1.94974e-05
-8.47033e-22
-1.94974e-05
-8.68209e-21
-1.94974e-05
-7.51742e-21
9.74872e-06
0.000121413
0.000121413
0.000121413
-1.73448e-05
-8.47033e-22
-1.73448e-05
-7.72918e-21
-1.73448e-05
-6.98802e-21
8.67239e-06
0.000110665
0.000110665
0.000110665
-1.58093e-05
-7.30566e-21
-1.58093e-05
-6.35275e-22
-1.58093e-05
6.77626e-21
7.90464e-06
0.000128237
0.000128237
0.000128237
-1.83196e-05
-8.47033e-22
-1.83196e-05
-8.36445e-21
-1.83196e-05
-7.41154e-21
9.15978e-06
0.000110749
0.000110749
0.000110749
-1.58213e-05
-7.19978e-21
-1.58213e-05
-6.35275e-22
-1.58213e-05
6.67038e-21
7.91067e-06
0.000136353
0.000136353
0.000136353
-1.9479e-05
-8.47033e-22
-1.9479e-05
-8.68209e-21
-1.9479e-05
-7.94093e-21
9.73948e-06
0.000127422
0.000127422
0.000127422
-1.82031e-05
-8.25857e-21
-1.82031e-05
-8.47033e-22
-1.82031e-05
7.51742e-21
9.10155e-06
0.000140892
0.000140892
0.000140892
-2.01275e-05
-1.27055e-21
-2.01275e-05
-8.99973e-21
-2.01275e-05
-8.04681e-21
1.00637e-05
0.000135549
0.000135549
0.000135549
-1.93641e-05
-8.89385e-21
-1.93641e-05
-1.05879e-21
-1.93641e-05
8.04681e-21
9.68207e-06
0.000158024
0.000158024
0.000158024
-2.25748e-05
-1.05879e-21
-2.25748e-05
-9.95264e-21
-2.25748e-05
-9.1056e-21
1.12874e-05
0.00015042
0.00015042
0.00015042
-2.14886e-05
-1.00585e-20
-2.14886e-05
-1.48231e-21
-2.14886e-05
9.1056e-21
1.07443e-05
0.00020647
0.00020647
0.00020647
-2.94958e-05
-1.69407e-21
-2.94958e-05
-1.37643e-20
-2.94958e-05
-1.2282e-20
1.47479e-05
0.000255438
0.000255438
0.000255438
-3.64911e-05
-1.65171e-20
-3.64911e-05
-1.69407e-21
-3.64911e-05
1.50348e-20
1.82456e-05
0.000211591
0.000211591
0.000211591
-3.02273e-05
-1.69407e-21
-3.02273e-05
-1.35525e-20
-3.02273e-05
-1.2282e-20
1.51137e-05
0.000166424
0.000166424
0.000166424
-2.37749e-05
-1.07997e-20
-2.37749e-05
-1.05879e-21
-2.37749e-05
9.635e-21
1.18874e-05
0.000222733
0.000222733
0.000222733
-3.1819e-05
-1.27055e-21
-3.1819e-05
-1.46113e-20
-3.1819e-05
-1.29173e-20
1.59095e-05
0.000193242
0.000193242
0.000193242
-2.7606e-05
-8.47033e-22
-2.7606e-05
-1.2282e-20
-2.7606e-05
-1.14349e-20
1.3803e-05
0.000233734
0.000233734
0.000233734
-3.33905e-05
-1.69407e-21
-3.33905e-05
-1.50348e-20
-3.33905e-05
-1.35525e-20
1.66953e-05
0.000205128
0.000205128
0.000205128
-2.9304e-05
-1.27055e-21
-2.9304e-05
-1.33408e-20
-2.9304e-05
-1.20702e-20
1.4652e-05
0.000139909
0.000139909
0.000139909
-1.99871e-05
-1.05879e-21
-1.99871e-05
-8.99973e-21
-1.99871e-05
-8.15269e-21
9.99353e-06
0.000111286
0.000111286
0.000111286
-1.58979e-05
-8.47033e-22
-1.58979e-05
-7.19978e-21
-1.58979e-05
-6.67038e-21
7.94897e-06
0.000121165
0.000121165
0.000121165
-1.73093e-05
-7.94093e-21
-1.73093e-05
-1.05879e-21
-1.73093e-05
6.98802e-21
8.65466e-06
8.34361e-05
8.34361e-05
8.34361e-05
-1.19194e-05
-5.29396e-22
-1.19194e-05
-5.29396e-21
-1.19194e-05
-5.0822e-21
5.95972e-06
8.12599e-05
8.12599e-05
8.12599e-05
-1.16086e-05
-5.24102e-21
-1.16086e-05
-6.35275e-22
-1.16086e-05
4.87044e-21
5.80428e-06
8.26611e-05
8.26611e-05
8.26611e-05
-1.18087e-05
-6.35275e-22
-1.18087e-05
-5.3469e-21
-1.18087e-05
-4.87044e-21
5.90436e-06
0.000133775
0.000133775
0.000133775
-1.91107e-05
-1.05879e-21
-1.91107e-05
-8.36445e-21
-1.91107e-05
-7.6233e-21
9.55535e-06
0.000108713
0.000108713
0.000108713
-1.55304e-05
-8.47033e-22
-1.55304e-05
-6.88214e-21
-1.55304e-05
-6.24687e-21
7.76522e-06
8.04932e-05
8.04932e-05
8.04932e-05
-1.1499e-05
-5.18808e-21
-1.1499e-05
-6.35275e-22
-1.1499e-05
4.71162e-21
5.74951e-06
0.000118358
0.000118358
0.000118358
-1.69083e-05
-6.35275e-22
-1.69083e-05
-7.51742e-21
-1.69083e-05
-6.77626e-21
8.45417e-06
0.000153221
0.000153221
0.000153221
-2.18886e-05
-8.47033e-22
-2.18886e-05
-9.95264e-21
-2.18886e-05
-9.31736e-21
1.09443e-05
0.000146085
0.000146085
0.000146085
-2.08693e-05
-9.52912e-21
-2.08693e-05
-1.48231e-21
-2.08693e-05
8.57621e-21
1.04347e-05
0.00016732
0.00016732
0.00016732
-2.39029e-05
-1.27055e-21
-2.39029e-05
-1.05879e-20
-2.39029e-05
-9.74088e-21
1.19514e-05
0.000169786
0.000169786
0.000169786
-2.42552e-05
-1.09055e-20
-2.42552e-05
-1.27055e-21
-2.42552e-05
1.01644e-20
1.21276e-05
0.000163414
0.000163414
0.000163414
-2.33449e-05
-8.47033e-22
-2.33449e-05
-1.05879e-20
-2.33449e-05
-9.74088e-21
1.16724e-05
0.000176383
0.000176383
0.000176383
-2.51975e-05
-1.17526e-20
-2.51975e-05
-1.27055e-21
-2.51975e-05
1.07997e-20
1.25988e-05
0.000138581
0.000138581
0.000138581
-1.97972e-05
-6.35275e-22
-1.97972e-05
-8.89385e-21
-1.97972e-05
-8.47033e-21
9.89861e-06
0.000176998
0.000176998
0.000176998
-2.52855e-05
-1.27055e-21
-2.52855e-05
-1.10114e-20
-2.52855e-05
-9.74088e-21
1.26427e-05
0.000214699
0.000214699
0.000214699
-3.06713e-05
-8.47033e-22
-3.06713e-05
-1.35525e-20
-3.06713e-05
-1.24937e-20
1.53357e-05
0.000225706
0.000225706
0.000225706
-3.22437e-05
-2.11758e-21
-3.22437e-05
-1.46113e-20
-3.22437e-05
-1.3129e-20
1.61219e-05
0.000138192
0.000138192
0.000138192
-1.97417e-05
-8.47033e-22
-1.97417e-05
-8.89385e-21
-1.97417e-05
-8.04681e-21
9.87085e-06
0.00014527
0.00014527
0.00014527
-2.07529e-05
-8.47033e-22
-2.07529e-05
-9.31736e-21
-2.07529e-05
-8.47033e-21
1.03764e-05
0.000164436
0.000164436
0.000164436
-2.34909e-05
-1.05879e-20
-2.34909e-05
-1.05879e-21
-2.34909e-05
9.84676e-21
1.17454e-05
0.000113669
0.000113669
0.000113669
-1.62385e-05
-8.47033e-22
-1.62385e-05
-7.19978e-21
-1.62385e-05
-6.56451e-21
8.11923e-06
0.000125199
0.000125199
0.000125199
-1.78856e-05
-8.15269e-21
-1.78856e-05
-1.05879e-21
-1.78856e-05
6.98802e-21
8.94278e-06
8.44343e-05
8.44343e-05
8.44343e-05
-1.2062e-05
-5.29396e-22
-1.2062e-05
-5.39984e-21
-1.2062e-05
-4.92338e-21
6.03102e-06
8.2688e-05
8.2688e-05
8.2688e-05
-1.18126e-05
-5.3469e-21
-1.18126e-05
-7.41154e-22
-1.18126e-05
4.76456e-21
5.90628e-06
8.3323e-05
8.3323e-05
8.3323e-05
-1.19033e-05
-5.29396e-22
-1.19033e-05
-5.24102e-21
-1.19033e-05
-4.87044e-21
5.95164e-06
0.000130873
0.000130873
0.000130873
-1.86961e-05
-8.47033e-22
-1.86961e-05
-8.36445e-21
-1.86961e-05
-7.6233e-21
9.34805e-06
0.000108664
0.000108664
0.000108664
-1.55234e-05
-6.35275e-22
-1.55234e-05
-6.88214e-21
-1.55234e-05
-6.56451e-21
7.76169e-06
8.10797e-05
8.10797e-05
8.10797e-05
-1.15828e-05
-5.29396e-21
-1.15828e-05
-7.41154e-22
-1.15828e-05
4.76456e-21
5.79141e-06
0.000117863
0.000117863
0.000117863
-1.68375e-05
-8.47033e-22
-1.68375e-05
-7.51742e-21
-1.68375e-05
-6.77626e-21
8.41875e-06
0.000139129
0.000139129
0.000139129
-1.98756e-05
-1.05879e-21
-1.98756e-05
-8.99973e-21
-1.98756e-05
-8.15269e-21
9.93779e-06
0.000137951
0.000137951
0.000137951
-1.97072e-05
-8.99973e-21
-1.97072e-05
-1.05879e-21
-1.97072e-05
8.25857e-21
9.85362e-06
0.00012634
0.00012634
0.00012634
-1.80486e-05
-8.47033e-22
-1.80486e-05
-8.04681e-21
-1.80486e-05
-7.30566e-21
9.02428e-06
0.000123018
0.000123018
0.000123018
-1.75739e-05
-7.94093e-21
-1.75739e-05
-8.47033e-22
-1.75739e-05
7.41154e-21
8.78697e-06
0.000165755
0.000165755
0.000165755
-2.36793e-05
-1.05879e-21
-2.36793e-05
-1.0482e-20
-2.36793e-05
-9.52912e-21
1.18396e-05
0.000184158
0.000184158
0.000184158
-2.63083e-05
-1.21761e-20
-2.63083e-05
-1.27055e-21
-2.63083e-05
1.12232e-20
1.31542e-05
0.000153374
0.000153374
0.000153374
-2.19106e-05
-1.05879e-21
-2.19106e-05
-1.00585e-20
-2.19106e-05
-9.21148e-21
1.09553e-05
0.000206772
0.000206772
0.000206772
-2.95388e-05
-1.33408e-20
-2.95388e-05
-1.69407e-21
-2.95388e-05
1.2282e-20
1.47694e-05
0.000143689
0.000143689
0.000143689
-2.05269e-05
-1.27055e-21
-2.05269e-05
-9.31736e-21
-2.05269e-05
-8.57621e-21
1.02635e-05
0.000213052
0.000213052
0.000213052
-3.0436e-05
-1.3976e-20
-3.0436e-05
-2.11758e-21
-3.0436e-05
1.24937e-20
1.5218e-05
8.25392e-05
8.25392e-05
8.25392e-05
-1.17913e-05
-5.29396e-22
-1.17913e-05
-5.24102e-21
-1.17913e-05
-4.76456e-21
5.89566e-06
0.000112063
0.000112063
0.000112063
-1.6009e-05
-4.23516e-22
-1.6009e-05
-6.98802e-21
-1.6009e-05
-6.56451e-21
8.00449e-06
0.000124695
0.000124695
0.000124695
-1.78136e-05
-6.35275e-22
-1.78136e-05
-8.15269e-21
-1.78136e-05
-7.30566e-21
8.90679e-06
0.00021665
0.00021665
0.00021665
-3.095e-05
-1.69407e-21
-3.095e-05
-1.37643e-20
-3.095e-05
-1.24937e-20
1.5475e-05
0.000152767
0.000152767
0.000152767
-2.18238e-05
-1.05879e-21
-2.18238e-05
-9.84676e-21
-2.18238e-05
-9.21148e-21
1.09119e-05
0.000129024
0.000129024
0.000129024
-1.84319e-05
-1.05879e-21
-1.84319e-05
-8.47033e-21
-1.84319e-05
-7.51742e-21
9.21597e-06
0.000170159
0.000170159
0.000170159
-2.43084e-05
-8.47033e-22
-2.43084e-05
-1.11173e-20
-2.43084e-05
-1.01644e-20
1.21542e-05
0.000151804
0.000151804
0.000151804
-2.16863e-05
-8.47033e-22
-2.16863e-05
-9.74088e-21
-2.16863e-05
-8.99973e-21
1.08431e-05
0.000232767
0.000232767
0.000232767
-3.32524e-05
-1.46113e-20
-3.32524e-05
-2.11758e-21
-3.32524e-05
1.27055e-20
1.66262e-05
0.000192014
0.000192014
0.000192014
-2.74305e-05
-1.69407e-21
-2.74305e-05
-1.17526e-20
-2.74305e-05
-1.14349e-20
1.37153e-05
0.000181296
0.000181296
0.000181296
-2.58995e-05
-8.47033e-22
-2.58995e-05
-1.14349e-20
-2.58995e-05
-1.05879e-20
1.29497e-05
0.000172958
0.000172958
0.000172958
-2.47083e-05
-1.13291e-20
-2.47083e-05
-1.27055e-21
-2.47083e-05
9.84676e-21
1.23542e-05
0.000231699
0.000231699
0.000231699
-3.30999e-05
-8.47033e-22
-3.30999e-05
-1.48231e-20
-3.30999e-05
-1.35525e-20
1.65499e-05
0.000165758
0.000165758
0.000165758
-2.36796e-05
-1.06938e-20
-2.36796e-05
-1.05879e-21
-2.36796e-05
9.52912e-21
1.18398e-05
0.000226068
0.000226068
0.000226068
-3.22955e-05
-1.48231e-20
-3.22955e-05
-2.11758e-21
-3.22955e-05
1.3129e-20
1.61477e-05
8.37158e-05
8.37158e-05
8.37158e-05
-1.19594e-05
-5.29396e-22
-1.19594e-05
-5.24102e-21
-1.19594e-05
-4.87044e-21
5.9797e-06
0.00015284
0.00015284
0.00015284
-2.18344e-05
-1.05879e-21
-2.18344e-05
-9.95264e-21
-2.18344e-05
-9.31736e-21
1.09172e-05
0.000149946
0.000149946
0.000149946
-2.14209e-05
-1.05879e-21
-2.14209e-05
-9.84676e-21
-2.14209e-05
-8.89385e-21
1.07104e-05
0.000114557
0.000114557
0.000114557
-1.63653e-05
-4.23516e-22
-1.63653e-05
-7.51742e-21
-1.63653e-05
-7.19978e-21
8.18263e-06
0.000239401
0.000239401
0.000239401
-3.42001e-05
-1.27055e-21
-3.42001e-05
-1.50348e-20
-3.42001e-05
-1.35525e-20
1.71001e-05
0.000123276
0.000123276
0.000123276
-1.76109e-05
-8.15269e-21
-1.76109e-05
-1.05879e-21
-1.76109e-05
6.98802e-21
8.80544e-06
0.000144447
0.000144447
0.000144447
-2.06353e-05
-8.47033e-22
-2.06353e-05
-9.21148e-21
-2.06353e-05
-8.36445e-21
1.03177e-05
0.000142482
0.000142482
0.000142482
-2.03546e-05
-9.1056e-21
-2.03546e-05
-8.47033e-22
-2.03546e-05
8.47033e-21
1.01773e-05
0.0002286
0.0002286
0.0002286
-3.26571e-05
-1.52466e-20
-3.26571e-05
-2.11758e-21
-3.26571e-05
1.3129e-20
1.63286e-05
0.000189503
0.000189503
0.000189503
-2.70718e-05
-1.27055e-21
-2.70718e-05
-1.20702e-20
-2.70718e-05
-1.10114e-20
1.35359e-05
0.000192622
0.000192622
0.000192622
-2.75175e-05
-1.69407e-21
-2.75175e-05
-1.24937e-20
-2.75175e-05
-1.14349e-20
1.37587e-05
0.000124792
0.000124792
0.000124792
-1.78274e-05
-7.94093e-21
-1.78274e-05
-1.27055e-21
-1.78274e-05
7.30566e-21
8.91371e-06
0.00014611
0.00014611
0.00014611
-2.08729e-05
-9.52912e-21
-2.08729e-05
-8.47033e-22
-2.08729e-05
8.57621e-21
1.04364e-05
0.000157319
0.000157319
0.000157319
-2.24741e-05
-1.01644e-20
-2.24741e-05
-1.48231e-21
-2.24741e-05
8.89385e-21
1.1237e-05
0.000159852
0.000159852
0.000159852
-2.2836e-05
-1.0482e-20
-2.2836e-05
-1.27055e-21
-2.2836e-05
9.635e-21
1.1418e-05
0.000182428
0.000182428
0.000182428
-2.60611e-05
-1.27055e-21
-2.60611e-05
-1.16467e-20
-2.60611e-05
-1.07997e-20
1.30305e-05
0.000152088
0.000152088
0.000152088
-2.17269e-05
-1.27055e-21
-2.17269e-05
-9.52912e-21
-2.17269e-05
-8.57621e-21
1.08635e-05
0.000181382
0.000181382
0.000181382
-2.59117e-05
-1.27055e-21
-2.59117e-05
-1.18585e-20
-2.59117e-05
-1.05879e-20
1.29559e-05
0.000170855
0.000170855
0.000170855
-2.44079e-05
-1.10114e-20
-2.44079e-05
-1.27055e-21
-2.44079e-05
1.01644e-20
1.22039e-05
0.000198635
0.000198635
0.000198635
-2.83764e-05
-1.3129e-20
-2.83764e-05
-2.11758e-21
-2.83764e-05
1.16467e-20
1.41882e-05
0.000194816
0.000194816
0.000194816
-2.78309e-05
-1.27055e-20
-2.78309e-05
-2.11758e-21
-2.78309e-05
1.12232e-20
1.39155e-05
0.000177951
0.000177951
0.000177951
-2.54215e-05
-1.27055e-21
-2.54215e-05
-1.15408e-20
-2.54215e-05
-1.03762e-20
1.27108e-05
0.000214895
0.000214895
0.000214895
-3.06993e-05
-1.3976e-20
-3.06993e-05
-1.27055e-21
-3.06993e-05
1.29173e-20
1.53497e-05
0.000183212
0.000183212
0.000183212
-2.61731e-05
-1.16467e-20
-2.61731e-05
-1.69407e-21
-2.61731e-05
1.07997e-20
1.30866e-05
0.000201035
0.000201035
0.000201035
-2.87193e-05
-1.69407e-21
-2.87193e-05
-1.35525e-20
-2.87193e-05
-1.18585e-20
1.43597e-05
0.000226674
0.000226674
0.000226674
-3.2382e-05
-2.11758e-21
-3.2382e-05
-1.43996e-20
-3.2382e-05
-1.29173e-20
1.6191e-05
0.000197557
0.000197557
0.000197557
-2.82225e-05
-1.3129e-20
-2.82225e-05
-1.27055e-21
-2.82225e-05
1.18585e-20
1.41112e-05
f += gaussp*v*dx
<ngsolve.comp.LinearForm at 0x7f2834380770>
scene = Draw(gfu,mesh,"u")
nsamples = 10):
if initial_cond:
gfu.Set(initial_cond)
cnt = 0; time = t0
while time < tend - 0.5 * dt:
print("\r",time,end="")
if cnt % sample_int == 0:
cnt += 1; time = cnt * dt
return gfut
%%time
0 0.001 0.002 0.003 0.004 0.005 0.006 0.007 0.008 0.009000000000000001 0.01 0.011 0.012 0.013000000000000001 0.014 0.015 0.016 0.017 0.018000000000000002 0.019 0.02 0.021 0.022 0.023 0.024 0.025 0.026000000000000002 0.027 0.028 0.029 0.03 0.031 0.032 0.033 0.034 0.035 0.036000000000000004 0.037 0.038 0.039 0.04 0.041 0.042 0.043000000000000003 0.044 0.045 0.046 0.047 0.048 0.049 0.05 0.051000000000000004 0.052000000000000005 0.053 0.054 0.055 0.056 0.057 0.058 0.059000000000000004 0.06 0.061 0.062 0.063 0.064 0.065 0.066 0.067 0.068 0.069 0.07 0.07100000000000001 0.07200000000000001 0.073 0.074 0.075 0.076 0.077 0.078 0.079 0.08 0.081 0.082 0.083 0.084 0.085 0.08600000000000001 0.08700000000000001 0.088 0.089 0.09 0.091 0.092 0.093 0.094 0.095 0.096 0.097 0.098 0.099 0.1 0.101 0.10200000000000001 0.10300000000000001 0.10400000000000001 0.105 0.106 0.107 0.108 0.109 0.11 0.111 0.112 0.113 0.114 0.115 0.116 0.117 0.11800000000000001 0.11900000000000001 0.12 0.121 0.122 0.123 0.124 0.125 0.126 0.127 0.128 0.129 0.13 0.131 0.132 0.133 0.134 0.135 0.136 0.137 0.138 0.139 0.14 0.14100000000000001 0.14200000000000002 0.14300000000000002 0.14400000000000002 0.145 0.146 0.147 0.148 0.149 0.15 0.151 0.152 0.153 0.154 0.155 0.156 0.157 0.158 0.159 0.16 0.161 0.162 0.163 0.164 0.165 0.166 0.167 0.168 0.169 0.17 0.171 0.17200000000000001 0.17300000000000001 0.17400000000000002 0.17500000000000002 0.176 0.177 0.178 0.179 0.18 0.181 0.182 0.183 0.184 0.185 0.186 0.187 0.188 0.189 0.19 0.191 0.192 0.193 0.194 0.195 0.196 0.197 0.198 0.199 0.2 0.201 0.202 0.203 0.20400000000000001 0.20500000000000002 0.20600000000000002 0.20700000000000002 0.20800000000000002 0.209 0.21 0.211 0.212 0.213 0.214 0.215 0.216 0.217 0.218 0.219 0.22 0.221 0.222 0.223 0.224 0.225 0.226 0.227 0.228 0.229 0.23 0.231 0.232 0.233 0.234 0.23500000000000001 0.23600000000000002 0.23700000000000002 0.23800000000000002 0.23900000000000002 0.24 0.241 0.242 0.243 0.244 0.245 0.246 0.247 0.248 0.249 0.25 0.251 0.252 0.253 0.254 0.255 0.256 0.257 0.258 0.259 0.26 0.261 0.262 0.263 0.264 0.265 0.266 0.267 0.268 0.269 0.27 0.271 0.272 0.273 0.274 0.275 0.276 0.277 0.278 0.279 0.28 0.281 0.28200000000000003 0.28300000000000003 0.28400000000000003 0.28500000000000003 0.28600000000000003 0.28700000000000003 0.28800000000000003 0.289 0.29 0.291 0.292 0.293 0.294 0.295 0.296 0.297 0.298 0.299 0.3 0.301 0.302 0.303 0.304 0.305 0.306 0.307 0.308 0.309 0.31 0.311 0.312 0.313 0.314 0.315 0.316 0.317 0.318 0.319 0.32 0.321 0.322 0.323 0.324 0.325 0.326 0.327 0.328 0.329 0.33 0.331 0.332 0.333 0.334 0.335 0.336 0.337 0.338 0.339 0.34 0.341 0.342 0.343 0.34400000000000003 0.34500000000000003 0.34600000000000003 0.34700000000000003 0.34800000000000003 0.34900000000000003 0.35000000000000003 0.35100000000000003 0.352 0.353 0.354 0.355 0.356 0.357 0.358 0.359 0.36 0.361 0.362 0.363 0.364 0.365 0.366 0.367 0.368 0.369 0.37 0.371 0.372 0.373 0.374 0.375 0.376 0.377 0.378 0.379 0.38 0.381 0.382 0.383 0.384 0.385 0.386 0.387 0.388 0.389 0.39 0.391 0.392 0.393 0.394 0.395 0.396 0.397 0.398 0.399 0.4 0.401 0.402 0.403 0.404 0.405 0.406 0.40700000000000003 0.40800000000000003 0.40900000000000003 0.41000000000000003 0.41100000000000003 0.41200000000000003 0.41300000000000003 0.41400000000000003 0.41500000000000004 0.41600000000000004 0.417 0.418 0.419 0.42 0.421 0.422 0.423 0.424 0.425 0.426 0.427 0.428 0.429 0.43 0.431 0.432 0.433 0.434 0.435 0.436 0.437 0.438 0.439 0.44 0.441 0.442 0.443 0.444 0.445 0.446 0.447 0.448 0.449 0.45 0.451 0.452 0.453 0.454 0.455 0.456 0.457 0.458 0.459 0.46 0.461 0.462 0.463 0.464 0.465 0.466 0.467 0.468 0.46900000000000003 0.47000000000000003 0.47100000000000003 0.47200000000000003 0.47300000000000003 0.47400000000000003 0.47500000000000003 0.47600000000000003 0.47700000000000004 0.47800000000000004 0.47900000000000004 0.48 0.481 0.482 0.483 0.484 0.485 0.486 0.487 0.488 0.489 0.49 0.491 0.492 0.493 0.494 0.495 0.496 0.497 0.498 0.499 0.5 0.501 0.502 0.503 0.504 0.505 0.506 0.507 0.508 0.509 0.51 0.511 0.512 0.513 0.514 0.515 0.516 0.517 0.518 0.519 0.52 0.521 0.522 0.523 0.524 0.525 0.526 0.527 0.528 0.529 0.53 0.531 0.532 0.533 0.534 0.535 0.536 0.537 0.538 0.539 0.54 0.541 0.542 0.543 0.544 0.545 0.546 0.547 0.548 0.549 0.55 0.551 0.552 0.553 0.554 0.555 0.556 0.557 0.558 0.559 0.56 0.561 0.562 0.5630000000000001 0.5640000000000001 0.5650000000000001 0.5660000000000001 0.5670000000000001 0.5680000000000001 0.5690000000000001 0.5700000000000001 0.5710000000000001 0.5720000000000001 0.5730000000000001 0.5740000000000001 0.5750000000000001 0.5760000000000001 0.577 0.578 0.579 0.58 0.581 0.582 0.583 0.584 0.585 0.586 0.587 0.588 0.589 0.59 0.591 0.592 0.593 0.594 0.595 0.596 0.597 0.598 0.599 0.6 0.601 0.602 0.603 0.604 0.605 0.606 0.607 0.608 0.609 0.61 0.611 0.612 0.613 0.614 0.615 0.616 0.617 0.618 0.619 0.62 0.621 0.622 0.623 0.624 0.625 0.626 0.627 0.628 0.629 0.63 0.631 0.632 0.633 0.634 0.635 0.636 0.637 0.638 0.639 0.64 0.641 0.642 0.643 0.644 0.645 0.646 0.647 0.648 0.649 0.65 0.651 0.652 0.653 0.654 0.655 0.656 0.657 0.658 0.659 0.66 0.661 0.662 0.663 0.664 0.665 0.666 0.667 0.668 0.669 0.67 0.671 0.672 0.673 0.674 0.675 0.676 0.677 0.678 0.679 0.68 0.681 0.682 0.683 0.684 0.685 0.686 0.687 0.6880000000000001 0.6890000000000001 0.6900000000000001 0.6910000000000001 0.6920000000000001 0.6930000000000001 0.6940000000000001 0.6950000000000001 0.6960000000000001 0.6970000000000001 0.6980000000000001 0.6990000000000001 0.7000000000000001 0.7010000000000001 0.7020000000000001 0.7030000000000001 0.704 0.705 0.706 0.707 0.708 0.709 0.71 0.711 0.712 0.713 0.714 0.715 0.716 0.717 0.718 0.719 0.72 0.721 0.722 0.723 0.724 0.725 0.726 0.727 0.728 0.729 0.73 0.731 0.732 0.733 0.734 0.735 0.736 0.737 0.738 0.739 0.74 0.741 0.742 0.743 0.744 0.745 0.746 0.747 0.748 0.749 0.75 0.751 0.752 0.753 0.754 0.755 0.756 0.757 0.758 0.759 0.76 0.761 0.762 0.763 0.764 0.765 0.766 0.767 0.768 0.769 0.77 0.771 0.772 0.773 0.774 0.775 0.776 0.777 0.778 0.779 0.78 0.781 0.782 0.783 0.784 0.785 0.786 0.787 0.788 0.789 0.79 0.791 0.792 0.793 0.794 0.795 0.796 0.797 0.798 0.799 0.8 0.801 0.802 0.803 0.804 0.805 0.806 0.807 0.808 0.809 0.81 0.811 0.812 0.8130000000000001 0.8140000000000001 0.8150000000000001 0.8160000000000001 0.8170000000000001 0.8180000000000001 0.8190000000000001 0.8200000000000001 0.8210000000000001 0.8220000000000001 0.8230000000000001 0.8240000000000001 0.8250000000000001 0.8260000000000001 0.8270000000000001 0.8280000000000001 0.8290000000000001 0.8300000000000001 0.8310000000000001 0.8320000000000001 0.833 0.834 0.835 0.836 0.837 0.838 0.839 0.84 0.841 0.842 0.843 0.844 0.845 0.846 0.847 0.848 0.849 0.85 0.851 0.852 0.853 0.854 0.855 0.856 0.857 0.858 0.859 0.86 0.861 0.862 0.863 0.864 0.865 0.866 0.867 0.868 0.869 0.87 0.871 0.872 0.873 0.874 0.875 0.876 0.877 0.878 0.879 0.88 0.881 0.882 0.883 0.884 0.885 0.886 0.887 0.888 0.889 0.89 0.891 0.892 0.893 0.894 0.895 0.896 0.897 0.898 0.899 0.9 0.901 0.902 0.903 0.904 0.905 0.906 0.907 0.908 0.909 0.91 0.911 0.912 0.913 0.914 0.915 0.916 0.917 0.918 0.919 0.92 0.921 0.922 0.923 0.924 0.925 0.926 0.927 0.928 0.929 0.93 0.931 0.932 0.933 0.934 0.935 0.936 0.937 0.9380000000000001 0.9390000000000001 0.9400000000000001 0.9410000000000001 0.9420000000000001 0.9430000000000001 0.9440000000000001 0.9450000000000001 0.9460000000000001 0.9470000000000001 0.9480000000000001 0.9490000000000001 0.9500000000000001 0.9510000000000001 0.9520000000000001 0.9530000000000001 0.9540000000000001 0.9550000000000001 0.9560000000000001 0.9570000000000001 0.9580000000000001 0.9590000000000001 0.96 0.961 0.962 0.963 0.964 0.965 0.966 0.967 0.968 0.969 0.97 0.971 0.972 0.973 0.974 0.975 0.976 0.977 0.978 0.979 0.98 0.981 0.982 0.983 0.984 0.985 0.986 0.987 0.988 0.989 0.99 0.991 0.992 0.993 0.994 0.995 0.996 0.997 0.998 0.999 1.0 1.0010000000000001 1.002 1.0030000000000001 1.004 1.0050000000000001 1.006 1.0070000000000001 1.008 1.0090000000000001 1.01 1.0110000000000001 1.012 1.0130000000000001 1.014 1.0150000000000001 1.016 1.0170000000000001 1.018 1.0190000000000001 1.02 1.0210000000000001 1.022 1.0230000000000001 1.024 1.025 1.026 1.027 1.028 1.029 1.03 1.031 1.032 1.033 1.034 1.035 1.036 1.037 1.038 1.039 1.04 1.041 1.042 1.043 1.044 1.045 1.046 1.047 1.048 1.049 1.05 1.051 1.052 1.053 1.054 1.055 1.056 1.057 1.058 1.059 1.06 1.061 1.062 1.063 1.064 1.065 1.066 1.067 1.068 1.069 1.07 1.071 1.072 1.073 1.074 1.075 1.076 1.077 1.078 1.079 1.08 1.081 1.082 1.083 1.084 1.085 1.086 1.087 1.088 1.089 1.09 1.091 1.092 1.093 1.094 1.095 1.096 1.097 1.098 1.099 1.1 1.101 1.102 1.103 1.104 1.105 1.106 1.107 1.108 1.109 1.11 1.111 1.112 1.113 1.114 1.115 1.116 1.117 1.118 1.119 1.12 1.121 1.122 1.123 1.124 1.125 1.1260000000000001 1.127 1.1280000000000001 1.129 1.1300000000000001 1.131 1.1320000000000001 1.133 1.1340000000000001 1.135 1.1360000000000001 1.137 1.1380000000000001 1.139 1.1400000000000001 1.141 1.1420000000000001 1.143 1.1440000000000001 1.145 1.1460000000000001 1.147 1.1480000000000001 1.149 1.1500000000000001 1.151 1.1520000000000001 1.153 1.154 1.155 1.156 1.157 1.158 1.159 1.16 1.161 1.162 1.163 1.164 1.165 1.166 1.167 1.168 1.169 1.17 1.171 1.172 1.173 1.174 1.175 1.176 1.177 1.178 1.179 1.18 1.181 1.182 1.183 1.184 1.185 1.186 1.187 1.188 1.189 1.19 1.191 1.192 1.193 1.194 1.195 1.196 1.197 1.198 1.199 1.2 1.201 1.202 1.203 1.204 1.205 1.206 1.207 1.208 1.209 1.21 1.211 1.212 1.213 1.214 1.215 1.216 1.217 1.218 1.219 1.22 1.221 1.222 1.223 1.224 1.225 1.226 1.227 1.228 1.229 1.23 1.231 1.232 1.233 1.234 1.235 1.236 1.237 1.238 1.239 1.24 1.241 1.242 1.243 1.244 1.245 1.246 1.247 1.248 1.249 1.25 1.2510000000000001 1.252 1.2530000000000001 1.254 1.2550000000000001 1.256 1.2570000000000001 1.258 1.2590000000000001 1.26 1.2610000000000001 1.262 1.2630000000000001 1.264 1.2650000000000001 1.266 1.2670000000000001 1.268 1.2690000000000001 1.27 1.2710000000000001 1.272 1.2730000000000001 1.274 1.2750000000000001 1.276 1.2770000000000001 1.278 1.2790000000000001 1.28 1.281 1.282 1.283 1.284 1.285 1.286 1.287 1.288 1.289 1.29 1.291 1.292 1.293 1.294 1.295 1.296 1.297 1.298 1.299 1.3 1.301 1.302 1.303 1.304 1.305 1.306 1.307 1.308 1.309 1.31 1.311 1.312 1.313 1.314 1.315 1.316 1.317 1.318 1.319 1.32 1.321 1.322 1.323 1.324 1.325 1.326 1.327 1.328 1.329 1.33 1.331 1.332 1.333 1.334 1.335 1.336 1.337 1.338 1.339 1.34 1.341 1.342 1.343 1.344 1.345 1.346 1.347 1.348 1.349 1.35 1.351 1.352 1.353 1.354 1.355 1.356 1.357 1.358 1.359 1.36 1.361 1.362 1.363 1.364 1.365 1.366 1.367 1.368 1.369 1.37 1.371 1.372 1.373 1.374 1.375 1.3760000000000001 1.377 1.3780000000000001 1.379 1.3800000000000001 1.381 1.3820000000000001 1.383 1.3840000000000001 1.385 1.3860000000000001 1.387 1.3880000000000001 1.389 1.3900000000000001 1.391 1.3920000000000001 1.393 1.3940000000000001 1.395 1.3960000000000001 1.397 1.3980000000000001 1.399 1.4000000000000001 1.401 1.4020000000000001 1.403 1.4040000000000001 1.405 1.4060000000000001 1.407 1.408 1.409 1.41 1.411 1.412 1.413 1.414 1.415 1.416 1.417 1.418 1.419 1.42 1.421 1.422 1.423 1.424 1.425 1.426 1.427 1.428 1.429 1.43 1.431 1.432 1.433 1.434 1.435 1.436 1.437 1.438 1.439 1.44 1.441 1.442 1.443 1.444 1.445 1.446 1.447 1.448 1.449 1.45 1.451 1.452 1.453 1.454 1.455 1.456 1.457 1.458 1.459 1.46 1.461 1.462 1.463 1.464 1.465 1.466 1.467 1.468 1.469 1.47 1.471 1.472 1.473 1.474 1.475 1.476 1.477 1.478 1.479 1.48 1.481 1.482 1.483 1.484 1.485 1.486 1.487 1.488 1.489 1.49 1.491 1.492 1.493 1.494 1.495 1.496 1.497 1.498 1.499 1.5 1.5010000000000001 1.502 1.5030000000000001 1.504 1.5050000000000001 1.506 1.5070000000000001 1.508 1.5090000000000001 1.51 1.5110000000000001 1.512 1.5130000000000001 1.514 1.5150000000000001 1.516 1.5170000000000001 1.518 1.5190000000000001 1.52 1.5210000000000001 1.522 1.5230000000000001 1.524 1.5250000000000001 1.526 1.5270000000000001 1.528 1.5290000000000001 1.53 1.5310000000000001 1.532 1.5330000000000001 1.534 1.5350000000000001 1.536 1.537 1.538 1.539 1.54 1.541 1.542 1.543 1.544 1.545 1.546 1.547 1.548 1.549 1.55 1.551 1.552 1.553 1.554 1.555 1.556 1.557 1.558 1.559 1.56 1.561 1.562 1.563 1.564 1.565 1.566 1.567 1.568 1.569 1.57 1.571 1.572 1.573 1.574 1.575 1.576 1.577 1.578 1.579 1.58 1.581 1.582 1.583 1.584 1.585 1.586 1.587 1.588 1.589 1.59 1.591 1.592 1.593 1.594 1.595 1.596 1.597 1.598 1.599 1.6 1.601 1.602 1.603 1.604 1.605 1.606 1.607 1.608 1.609 1.61 1.611 1.612 1.613 1.614 1.615 1.616 1.617 1.618 1.619 1.62 1.621 1.622 1.623 1.624 1.625 1.6260000000000001 1.627 1.6280000000000001 1.629 1.6300000000000001 1.631 1.6320000000000001 1.633 1.6340000000000001 1.635 1.6360000000000001 1.637 1.6380000000000001 1.639 1.6400000000000001 1.641 1.6420000000000001 1.643 1.6440000000000001 1.645 1.6460000000000001 1.647 1.6480000000000001 1.649 1.6500000000000001 1.651 1.6520000000000001 1.653 1.6540000000000001 1.655 1.6560000000000001 1.657 1.6580000000000001 1.659 1.6600000000000001 1.661 1.6620000000000001 1.663 1.6640000000000001 1.665 1.666 1.667 1.668 1.669 1.67 1.671 1.672 1.673 1.674 1.675 1.676 1.677 1.678 1.679 1.68 1.681 1.682 1.683 1.684 1.685 1.686 1.687 1.688 1.689 1.69 1.691 1.692 1.693 1.694 1.695 1.696 1.697 1.698 1.699 1.7 1.701 1.702 1.703 1.704 1.705 1.706 1.707 1.708 1.709 1.71 1.711 1.712 1.713 1.714 1.715 1.716 1.717 1.718 1.719 1.72 1.721 1.722 1.723 1.724 1.725 1.726 1.727 1.728 1.729 1.73 1.731 1.732 1.733 1.734 1.735 1.736 1.737 1.738 1.739 1.74 1.741 1.742 1.743 1.744 1.745 1.746 1.747 1.748 1.749 1.75 1.7510000000000001 1.752 1.7530000000000001 1.754 1.7550000000000001 1.756 1.7570000000000001 1.758 1.7590000000000001 1.76 1.7610000000000001 1.762 1.7630000000000001 1.764 1.7650000000000001 1.766 1.7670000000000001 1.768 1.7690000000000001 1.77 1.7710000000000001 1.772 1.7730000000000001 1.774 1.7750000000000001 1.776 1.7770000000000001 1.778 1.7790000000000001 1.78 1.7810000000000001 1.782 1.7830000000000001 1.784 1.7850000000000001 1.786 1.7870000000000001 1.788 1.7890000000000001 1.79 1.7910000000000001 1.792 1.793 1.794 1.795 1.796 1.797 1.798 1.799 1.8 1.801 1.802 1.803 1.804 1.805 1.806 1.807 1.808 1.809 1.81 1.811 1.812 1.813 1.814 1.815 1.816 1.817 1.818 1.819 1.82 1.821 1.822 1.823 1.824 1.825 1.826 1.827 1.828 1.829 1.83 1.831 1.832 1.833 1.834 1.835 1.836 1.837 1.838 1.839 1.84 1.841 1.842 1.843 1.844 1.845 1.846 1.847 1.848 1.849 1.85 1.851 1.852 1.853 1.854 1.855 1.856 1.857 1.858 1.859 1.86 1.861 1.862 1.863 1.864 1.865 1.866 1.867 1.868 1.869 1.87 1.871 1.872 1.873 1.874 1.875 1.8760000000000001 1.877 1.8780000000000001 1.879 1.8800000000000001 1.881 1.8820000000000001 1.883 1.8840000000000001 1.885 1.8860000000000001 1.887 1.8880000000000001 1.889 1.8900000000000001 1.891 1.8920000000000001 1.893 1.8940000000000001 1.895 1.8960000000000001 1.897 1.8980000000000001 1.899 1.9000000000000001 1.901 1.9020000000000001 1.903 1.9040000000000001 1.905 1.9060000000000001 1.907 1.9080000000000001 1.909 1.9100000000000001 1.911 1.9120000000000001 1.913 1.9140000000000001 1.915 1.9160000000000001 1.917 1.9180000000000001 1.919 1.92 1.921 1.922 1.923 1.924 1.925 1.926 1.927 1.928 1.929 1.93 1.931 1.932 1.933 1.934 1.935 1.936 1.937 1.938 1.939 1.94 1.941 1.942 1.943 1.944 1.945 1.946 1.947 1.948 1.949 1.95 1.951 1.952 1.953 1.954 1.955 1.956 1.957 1.958 1.959 1.96 1.961 1.962 1.963 1.964 1.965 1.966 1.967 1.968 1.969 1.97 1.971 1.972 1.973 1.974 1.975 1.976 1.977 1.978 1.979 1.98 1.981 1.982 1.983 1.984 1.985 1.986 1.987 1.988 1.989 1.99 1.991 1.992 1.993 1.994 1.995 1.996 1.997 1.998 1.999CPU times: user 608 ms, sys: 21.9 ms, total: 630 ms
Wall time: 602 ms </pre>
Wall time: 602 ms end{sphinxVerbatim}
Wall time: 602 ms
Supplementary material:¶
R.h.s. data time-dependent
boundary data time-dependent
print(premstar_alt)
Sum of
Scale a = 1
Print base-matrix
Scale b = 1
Scale with 0.001:
Print base-matrix
%%time
CG iteration 1, residual = 0.0035057339716348147CG iteration 2, residual = 0.0002834627490531965 CG iteration 3, residual = 0.00024263039834510451 CG iteration 4, residual = 0.00024456972709674564 CG iteration 5, residual = 0.00015448504295567455 CG iteration 6, residual = 7.821151803176524e-05 CG iteration 7, residual = 5.073203767271228e-05 CG iteration 8, residual = 4.7425017756223996e-05 CG iteration 9, residual = 3.410628962677873e-05 CG iteration 10, residual = 2.5969155301851343e-05 CG iteration 11, residual = 3.355628610785994e-05 CG iteration 12, residual = 4.0465654275392375e-05 CG iteration 13, residual = 3.696882793422592e-05 CG iteration 14, residual = 3.7084750141514266e-05 CG iteration 15, residual = 3.299103712798381e-05 CG iteration 16, residual = 2.3322264029912498e-05 CG iteration 17, residual = 1.4942487703727611e-05 CG iteration 18, residual = 1.1201775298738749e-05 CG iteration 19, residual = 1.0280543927546932e-05 CG iteration 20, residual = 8.309341542074007e-06 CG iteration 21, residual = 6.491721486633316e-06 CG iteration 22, residual = 6.390133425069827e-06 CG iteration 23, residual = 5.736028117624518e-06 CG iteration 24, residual = 5.6842926631273295e-06 CG iteration 25, residual = 6.174968765275747e-06 CG iteration 26, residual = 6.593997695038199e-06 CG iteration 27, residual = 6.086805914560082e-06 CG iteration 28, residual = 4.729474748314116e-06 CG iteration 29, residual = 3.6344671905966728e-06 CG iteration 30, residual = 2.5143094857132473e-06 CG iteration 31, residual = 1.9448641889355736e-06 CG iteration 32, residual = 1.505663381611971e-06 CG iteration 33, residual = 1.1315533131770621e-06 CG iteration 34, residual = 7.68563152419886e-07 CG iteration 35, residual = 5.787283688098449e-07 CG iteration 36, residual = 5.041127194998003e-07 CG iteration 37, residual = 4.6744762830305875e-07 CG iteration 38, residual = 4.871900222792222e-07 CG iteration 39, residual = 5.024991254256286e-07 CG iteration 40, residual = 5.153626930220074e-07 CG iteration 41, residual = 4.6952520772485864e-07 CG iteration 42, residual = 4.4154630934355745e-07 CG iteration 43, residual = 4.065913286016486e-07 CG iteration 44, residual = 3.110147788098351e-07 CG iteration 45, residual = 2.2593010929629386e-07 CG iteration 46, residual = 1.7775726985654165e-07 CG iteration 47, residual = 1.340632778972497e-07 CG iteration 48, residual = 9.772218534414981e-08 CG iteration 49, residual = 7.634811158237477e-08 CG iteration 50, residual = 6.629684641042421e-08 CG iteration 51, residual = 5.31516774247558e-08 CG iteration 52, residual = 5.351859704489737e-08 CG iteration 53, residual = 5.78846889823926e-08 CG iteration 54, residual = 6.228731685395157e-08 CG iteration 55, residual = 5.854713580053559e-08 CG iteration 56, residual = 5.3252264282158094e-08 CG iteration 57, residual = 4.684499780480687e-08 CG iteration 58, residual = 4.074919511653098e-08 CG iteration 59, residual = 3.212046732238423e-08 CG iteration 60, residual = 2.317841897396856e-08 CG iteration 61, residual = 1.6437060632261116e-08 CG iteration 62, residual = 1.2375984051506147e-08 CG iteration 63, residual = 9.015574752213276e-09 CG iteration 64, residual = 7.380815803862294e-09 CG iteration 65, residual = 6.251477938074552e-09 CG iteration 66, residual = 5.309531724516055e-09 CG iteration 67, residual = 4.7436952116937925e-09 CG iteration 68, residual = 4.670876285494703e-09 CG iteration 69, residual = 4.7987050223391125e-09 CG iteration 70, residual = 5.165189530651792e-09 CG iteration 71, residual = 4.9712230444805764e-09 CG iteration 72, residual = 4.454588903460429e-09 CG iteration 73, residual = 3.7017977456199185e-09 CG iteration 74, residual = 2.865240327828223e-09 CG iteration 75, residual = 2.1508780843757938e-09 CG iteration 76, residual = 1.6695609487286063e-09 CG iteration 77, residual = 1.206627470450266e-09 CG iteration 78, residual = 9.673964096737804e-10 CG iteration 79, residual = 7.463274729751711e-10 CG iteration 80, residual = 5.896934199688659e-10 CG iteration 81, residual = 4.80589135305542e-10 CG iteration 82, residual = 4.03568302666251e-10 CG iteration 83, residual = 3.652524528876453e-10 CG iteration 84, residual = 3.820052461822441e-10 CG iteration 85, residual = 3.73820775086239e-10 CG iteration 86, residual = 4.000182811495793e-10 CG iteration 87, residual = 3.9080442890683617e-10 CG iteration 88, residual = 3.7378376642690186e-10 CG iteration 89, residual = 3.3454993094736147e-10 CG iteration 90, residual = 2.7407845430884504e-10 CG iteration 91, residual = 2.151093774094584e-10 CG iteration 92, residual = 1.579989973810733e-10 CG iteration 93, residual = 1.1686987174084624e-10 CG iteration 94, residual = 8.910126190410332e-11 CG iteration 95, residual = 7.265188500596543e-11 CG iteration 96, residual = 5.981033026734256e-11 CG iteration 97, residual = 4.8073612942247536e-11 CG iteration 98, residual = 4.45559726268082e-11 CG iteration 99, residual = 4.092678042581251e-11 CG iteration 100, residual = 4.08575928988359e-11 CG iteration 101, residual = 4.0375160994562566e-11 CG iteration 102, residual = 4.534300756674283e-11 CG iteration 103, residual = 4.1766430058524355e-11 CG iteration 104, residual = 4.131724716650939e-11 CG iteration 105, residual = 3.537333329123969e-11 CG iteration 106, residual = 3.179997173468708e-11 CG converged in 106 iterations to residual 3.179997173468708e-11
0CG iteration 1, residual = 0.0035053975194496044
CG iteration 2, residual = 0.0002822322160843943 CG iteration 3, residual = 0.000240196509405923 CG iteration 4, residual = 0.00024288531680424476 CG iteration 5, residual = 0.00015419728363136006 CG iteration 6, residual = 7.785448071641783e-05 CG iteration 7, residual = 5.009703418723029e-05 CG iteration 8, residual = 4.675907553452885e-05 CG iteration 9, residual = 3.376347155713625e-05 CG iteration 10, residual = 2.5682225303015667e-05 CG iteration 11, residual = 3.319644640349678e-05 CG iteration 12, residual = 4.018278246306371e-05 CG iteration 13, residual = 3.6748706556582916e-05 CG iteration 14, residual = 3.685830005231227e-05 CG iteration 15, residual = 3.277530180259381e-05 CG iteration 16, residual = 2.3160620041953624e-05 CG iteration 17, residual = 1.4853019360758254e-05 CG iteration 18, residual = 1.1111341746195791e-05 CG iteration 19, residual = 1.0158624312113796e-05 CG iteration 20, residual = 8.233168902326498e-06 CG iteration 21, residual = 6.448599612606545e-06 CG iteration 22, residual = 6.331860453770461e-06 CG iteration 23, residual = 5.674551809190057e-06 CG iteration 24, residual = 5.618014147605852e-06 CG iteration 25, residual = 6.087611447783765e-06 CG iteration 26, residual = 6.498352886585876e-06 CG iteration 27, residual = 6.0189519019273505e-06 CG iteration 28, residual = 4.687559775162932e-06 CG iteration 29, residual = 3.59689564777813e-06 CG iteration 30, residual = 2.4757407524555685e-06 CG iteration 31, residual = 1.910828020548234e-06 CG iteration 32, residual = 1.4858028590521678e-06 CG iteration 33, residual = 1.1194453680966317e-06 CG iteration 34, residual = 7.606435130266568e-07 CG iteration 35, residual = 5.730822931849924e-07 CG iteration 36, residual = 4.995452729704887e-07 CG iteration 37, residual = 4.6283853362264297e-07 CG iteration 38, residual = 4.830218759079232e-07 CG iteration 39, residual = 4.985423617534478e-07 CG iteration 40, residual = 5.121983960778873e-07 CG iteration 41, residual = 4.6507881876837194e-07 CG iteration 42, residual = 4.372303489054457e-07 CG iteration 43, residual = 4.028829881325922e-07 CG iteration 44, residual = 3.08272633064608e-07 CG iteration 45, residual = 2.2413247234696063e-07 CG iteration 46, residual = 1.761603006861517e-07 CG iteration 47, residual = 1.3256309399960684e-07 CG iteration 48, residual = 9.655609598808055e-08 CG iteration 49, residual = 7.549524753339161e-08 CG iteration 50, residual = 6.57460469607192e-08 CG iteration 51, residual = 5.277034190696689e-08 CG iteration 52, residual = 5.300431712124942e-08 CG iteration 53, residual = 5.718328533874679e-08 CG iteration 54, residual = 6.165326122290104e-08 CG iteration 55, residual = 5.79927134045009e-08 CG iteration 56, residual = 5.2762883341080137e-08 CG iteration 57, residual = 4.63399105459643e-08 CG iteration 58, residual = 4.030544966936915e-08 CG iteration 59, residual = 3.1855458853747057e-08 CG iteration 60, residual = 2.306432344523002e-08 CG iteration 61, residual = 1.6372991773015176e-08 CG iteration 62, residual = 1.2297949629458822e-08 CG iteration 63, residual = 8.943333005658524e-09 CG iteration 64, residual = 7.310998189813659e-09 CG iteration 65, residual = 6.183804420828091e-09 CG iteration 66, residual = 5.2619092362298e-09 CG iteration 67, residual = 4.697721886952324e-09 CG iteration 68, residual = 4.632692888397711e-09 CG iteration 69, residual = 4.748092307118702e-09 CG iteration 70, residual = 5.105486083361721e-09 CG iteration 71, residual = 4.927087221722954e-09 CG iteration 72, residual = 4.4281898266880495e-09 CG iteration 73, residual = 3.6763456508203947e-09 CG iteration 74, residual = 2.845680579617973e-09 CG iteration 75, residual = 2.134512812949707e-09 CG iteration 76, residual = 1.660300984872995e-09 CG iteration 77, residual = 1.199739923426847e-09 CG iteration 78, residual = 9.613991353514773e-10 CG iteration 79, residual = 7.424387293357345e-10 CG iteration 80, residual = 5.887187922189456e-10 CG iteration 81, residual = 4.7961188315689e-10 CG iteration 82, residual = 4.0116287515484343e-10 CG iteration 83, residual = 3.643802768765076e-10 CG iteration 84, residual = 3.811385655128112e-10 CG iteration 85, residual = 3.728167628890719e-10 CG iteration 86, residual = 4.001422635783293e-10 CG iteration 87, residual = 3.906085480684764e-10 CG iteration 88, residual = 3.725268937632893e-10 CG iteration 89, residual = 3.327341864743003e-10 CG iteration 90, residual = 2.7377242409284795e-10 CG iteration 91, residual = 2.1413103289918502e-10 CG iteration 92, residual = 1.575920047824593e-10 CG iteration 93, residual = 1.1655970865090408e-10 CG iteration 94, residual = 8.854868494493672e-11 CG iteration 95, residual = 7.236597296042923e-11 CG iteration 96, residual = 5.96866825737044e-11 CG iteration 97, residual = 4.8017594743288207e-11 CG iteration 98, residual = 4.446824411016334e-11 CG iteration 99, residual = 4.1025144701103625e-11 CG iteration 100, residual = 4.080781651597987e-11 CG iteration 101, residual = 4.0304077397374116e-11 CG iteration 102, residual = 4.52915872359784e-11 CG iteration 103, residual = 4.171076692570568e-11 CG iteration 104, residual = 4.1386287436880715e-11 CG iteration 105, residual = 3.524081428542747e-11 CG iteration 106, residual = 3.172974283068946e-11 CG converged in 106 iterations to residual 3.172974283068946e-11
0.001CG iteration 1, residual = 0.003505069429221998
CG iteration 2, residual = 0.00028106054221934773 CG iteration 3, residual = 0.00023789567798713961 CG iteration 4, residual = 0.0002412799007959158 CG iteration 5, residual = 0.0001539333045769327 CG iteration 6, residual = 7.751747251745792e-05 CG iteration 7, residual = 4.94874868880815e-05 CG iteration 8, residual = 4.6118245892993204e-05 CG iteration 9, residual = 3.343954392797848e-05 CG iteration 10, residual = 2.541792828941187e-05 CG iteration 11, residual = 3.2869048314071195e-05 CG iteration 12, residual = 3.993363570291145e-05 CG iteration 13, residual = 3.655520278059141e-05 CG iteration 14, residual = 3.664980391062579e-05 CG iteration 15, residual = 3.256968913299164e-05 CG iteration 16, residual = 2.3005413787996554e-05 CG iteration 17, residual = 1.4767004121205355e-05 CG iteration 18, residual = 1.1025127125762825e-05 CG iteration 19, residual = 1.0041500181813037e-05 CG iteration 20, residual = 8.158900225084393e-06 CG iteration 21, residual = 6.405900189866536e-06 CG iteration 22, residual = 6.27428187719717e-06 CG iteration 23, residual = 5.614415335191318e-06 CG iteration 24, residual = 5.553435534519984e-06 CG iteration 25, residual = 6.002624732611839e-06 CG iteration 26, residual = 6.405330940093095e-06 CG iteration 27, residual = 5.952460343247484e-06 CG iteration 28, residual = 4.646441114193769e-06 CG iteration 29, residual = 3.5606331752857504e-06 CG iteration 30, residual = 2.438732376190039e-06 CG iteration 31, residual = 1.877796843483612e-06 CG iteration 32, residual = 1.4662453658450506e-06 CG iteration 33, residual = 1.1075766817086964e-06 CG iteration 34, residual = 7.530362112094879e-07 CG iteration 35, residual = 5.676806732893912e-07 CG iteration 36, residual = 4.951567974005424e-07 CG iteration 37, residual = 4.5840574350261824e-07 CG iteration 38, residual = 4.789950220628856e-07 CG iteration 39, residual = 4.946905323906564e-07 CG iteration 40, residual = 5.091474396834185e-07 CG iteration 41, residual = 4.6085002944662613e-07 CG iteration 42, residual = 4.330880105892388e-07 CG iteration 43, residual = 3.9927380899428327e-07 CG iteration 44, residual = 3.0561624885569794e-07 CG iteration 45, residual = 2.2240938596302147e-07 CG iteration 46, residual = 1.7461891384172402e-07 CG iteration 47, residual = 1.3110504960389346e-07 CG iteration 48, residual = 9.542906157101544e-08 CG iteration 49, residual = 7.466614882866072e-08 CG iteration 50, residual = 6.520708538748794e-08 CG iteration 51, residual = 5.2411882954751333e-08 CG iteration 52, residual = 5.252240112662126e-08 CG iteration 53, residual = 5.651093203415559e-08 CG iteration 54, residual = 6.103794585672805e-08 CG iteration 55, residual = 5.74637338446785e-08 CG iteration 56, residual = 5.229912261141477e-08 CG iteration 57, residual = 4.585435348208778e-08 CG iteration 58, residual = 3.98781982848155e-08 CG iteration 59, residual = 3.1600504756310974e-08 CG iteration 60, residual = 2.2953277498776614e-08 CG iteration 61, residual = 1.6311926437642456e-08 CG iteration 62, residual = 1.2223734533706026e-08 CG iteration 63, residual = 8.87420604682335e-09 CG iteration 64, residual = 7.243635805562636e-09 CG iteration 65, residual = 6.118399084656097e-09 CG iteration 66, residual = 5.21625536596163e-09 CG iteration 67, residual = 4.654192515304299e-09 CG iteration 68, residual = 4.596915975769929e-09 CG iteration 69, residual = 4.7007240287658956e-09 CG iteration 70, residual = 5.04930715727089e-09 CG iteration 71, residual = 4.884989352952451e-09 CG iteration 72, residual = 4.402849110484059e-09 CG iteration 73, residual = 3.652257954196086e-09 CG iteration 74, residual = 2.827504381766682e-09 CG iteration 75, residual = 2.1189817360733e-09 CG iteration 76, residual = 1.6513346850291587e-09 CG iteration 77, residual = 1.1933361338323822e-09 CG iteration 78, residual = 9.556903224889162e-10 CG iteration 79, residual = 7.386744273616934e-10 CG iteration 80, residual = 5.878367055490674e-10 CG iteration 81, residual = 4.787403545639366e-10 CG iteration 82, residual = 3.989644132938918e-10 CG iteration 83, residual = 3.636616093169148e-10 CG iteration 84, residual = 3.8029266400462805e-10 CG iteration 85, residual = 3.7201832763422703e-10 CG iteration 86, residual = 4.004388145283234e-10 CG iteration 87, residual = 3.9054418851413715e-10 CG iteration 88, residual = 3.714236355693029e-10 CG iteration 89, residual = 3.310267195742627e-10 CG iteration 90, residual = 2.7349502122526933e-10 CG iteration 91, residual = 2.131806013042655e-10 CG iteration 92, residual = 1.5724346194289886e-10 CG iteration 93, residual = 1.1628984930587078e-10 CG iteration 94, residual = 8.803790609901075e-11 CG iteration 95, residual = 7.210560738815653e-11 CG iteration 96, residual = 5.95803384068091e-11 CG iteration 97, residual = 4.7981185778832996e-11 CG iteration 98, residual = 4.439604116098158e-11 CG iteration 99, residual = 4.114063930463009e-11 CG iteration 100, residual = 4.0774555853526326e-11 CG iteration 101, residual = 4.026162305803593e-11 CG iteration 102, residual = 4.5243956608192545e-11 CG iteration 103, residual = 4.167562766190987e-11 CG iteration 104, residual = 4.146272352617181e-11 CG iteration 105, residual = 3.512639590949981e-11 CG iteration 106, residual = 3.1666528830867264e-11 CG converged in 106 iterations to residual 3.1666528830867264e-11
0.002CG iteration 1, residual = 0.0035047489040554193
CG iteration 2, residual = 0.00027994387104024086 CG iteration 3, residual = 0.00023571949420094678 CG iteration 4, residual = 0.0002397500730371937 CG iteration 5, residual = 0.0001536913783477332 CG iteration 6, residual = 7.719887886654385e-05 CG iteration 7, residual = 4.890158486370472e-05 CG iteration 8, residual = 4.550094502677626e-05 CG iteration 9, residual = 3.313321000910539e-05 CG iteration 10, residual = 2.5174553657510466e-05 CG iteration 11, residual = 3.257164338581296e-05 CG iteration 12, residual = 3.9715715260836773e-05 CG iteration 13, residual = 3.6386006468403036e-05 CG iteration 14, residual = 3.6457297015747345e-05 CG iteration 15, residual = 3.237285226723261e-05 CG iteration 16, residual = 2.2855771059550234e-05 CG iteration 17, residual = 1.4683892926465781e-05 CG iteration 18, residual = 1.0942657121431599e-05 CG iteration 19, residual = 9.928806355657007e-06 CG iteration 20, residual = 8.086384871252998e-06 CG iteration 21, residual = 6.363514901070838e-06 CG iteration 22, residual = 6.217284236188048e-06 CG iteration 23, residual = 5.555489335607877e-06 CG iteration 24, residual = 5.490431175999478e-06 CG iteration 25, residual = 5.919911197900817e-06 CG iteration 26, residual = 6.314856527876842e-06 CG iteration 27, residual = 5.887268466696952e-06 CG iteration 28, residual = 4.606050545832688e-06 CG iteration 29, residual = 3.525603997393599e-06 CG iteration 30, residual = 2.403206086120506e-06 CG iteration 31, residual = 1.8457479130163429e-06 CG iteration 32, residual = 1.4470019628517482e-06 CG iteration 33, residual = 1.0959371083556243e-06 CG iteration 34, residual = 7.457167096698458e-07 CG iteration 35, residual = 5.625092641822414e-07 CG iteration 36, residual = 4.909403026356549e-07 CG iteration 37, residual = 4.541364488776506e-07 CG iteration 38, residual = 4.750965591990912e-07 CG iteration 39, residual = 4.909356933053042e-07 CG iteration 40, residual = 5.061991222884059e-07 CG iteration 41, residual = 4.568204679272184e-07 CG iteration 42, residual = 4.2910973340228003e-07 CG iteration 43, residual = 3.957598767605904e-07 CG iteration 44, residual = 3.030378450056209e-07 CG iteration 45, residual = 2.2075282859388275e-07 CG iteration 46, residual = 1.7312793979943923e-07 CG iteration 47, residual = 1.2968700009321911e-07 CG iteration 48, residual = 9.433875164356348e-08 CG iteration 49, residual = 7.385903384190036e-08 CG iteration 50, residual = 6.467873413835462e-08 CG iteration 51, residual = 5.207411509715072e-08 CG iteration 52, residual = 5.206972200493804e-08 CG iteration 53, residual = 5.586551947843103e-08 CG iteration 54, residual = 6.044005251676895e-08 CG iteration 55, residual = 5.6957518273623894e-08 CG iteration 56, residual = 5.18583756542817e-08 CG iteration 57, residual = 4.5386883416402006e-08 CG iteration 58, residual = 3.9466521545851445e-08 CG iteration 59, residual = 3.1354643957674694e-08 CG iteration 60, residual = 2.2844644742961446e-08 CG iteration 61, residual = 1.6253431932473665e-08 CG iteration 62, residual = 1.2152850484308981e-08 CG iteration 63, residual = 8.807799076946422e-09 CG iteration 64, residual = 7.1784591450561315e-09 CG iteration 65, residual = 6.0550171434249845e-09 CG iteration 66, residual = 5.172336852523284e-09 CG iteration 67, residual = 4.6128398195456475e-09 CG iteration 68, residual = 4.5632226579528675e-09 CG iteration 69, residual = 4.656198323781482e-09 CG iteration 70, residual = 4.996312827237177e-09 CG iteration 71, residual = 4.844690185613131e-09 CG iteration 72, residual = 4.3782863208532496e-09 CG iteration 73, residual = 3.6292900480315537e-09 CG iteration 74, residual = 2.810566959128775e-09 CG iteration 75, residual = 2.1041923824576485e-09 CG iteration 76, residual = 1.6425892714340587e-09 CG iteration 77, residual = 1.1873443240860118e-09 CG iteration 78, residual = 9.502167808112344e-10 CG iteration 79, residual = 7.35000143907866e-10 CG iteration 80, residual = 5.869929463707243e-10 CG iteration 81, residual = 4.77918589822197e-10 CG iteration 82, residual = 3.96920822472242e-10 CG iteration 83, residual = 3.630330940763259e-10 CG iteration 84, residual = 3.7940217404806196e-10 CG iteration 85, residual = 3.7135001672806894e-10 CG iteration 86, residual = 4.0081633921128235e-10 CG iteration 87, residual = 3.9054026768308116e-10 CG iteration 88, residual = 3.7041838653279984e-10 CG iteration 89, residual = 3.2938461144297684e-10 CG iteration 90, residual = 2.7321539455207495e-10 CG iteration 91, residual = 2.1223990872938406e-10 CG iteration 92, residual = 1.5693877821738902e-10 CG iteration 93, residual = 1.160489772809092e-10 CG iteration 94, residual = 8.756060390812702e-11 CG iteration 95, residual = 7.186360108008316e-11 CG iteration 96, residual = 5.948332733783813e-11 CG iteration 97, residual = 4.795660359840926e-11 CG iteration 98, residual = 4.433146559945352e-11 CG iteration 99, residual = 4.126320117482507e-11 CG iteration 100, residual = 4.0747769602199253e-11 CG iteration 101, residual = 4.023736398461378e-11 CG iteration 102, residual = 4.5189454203045636e-11 CG iteration 103, residual = 4.1651675577092756e-11 CG iteration 104, residual = 4.153801852956013e-11 CG iteration 105, residual = 3.502507154825672e-11 CG converged in 105 iterations to residual 3.502507154825672e-11
0.003CG iteration 1, residual = 0.0035044352096447137
CG iteration 2, residual = 0.00027887861982526797 CG iteration 3, residual = 0.00023366012814947729 CG iteration 4, residual = 0.00023829252047818738 CG iteration 5, residual = 0.00015346990406351553 CG iteration 6, residual = 7.689721470862992e-05 CG iteration 7, residual = 4.833765704863179e-05 CG iteration 8, residual = 4.49056914944228e-05 CG iteration 9, residual = 3.2843267357853545e-05 CG iteration 10, residual = 2.49505225981182e-05 CG iteration 11, residual = 3.230194260929783e-05 CG iteration 12, residual = 3.952665954288422e-05 CG iteration 13, residual = 3.623894648915114e-05 CG iteration 14, residual = 3.627894111046302e-05 CG iteration 15, residual = 3.218355472843034e-05 CG iteration 16, residual = 2.271090620533988e-05 CG iteration 17, residual = 1.4603203904905763e-05 CG iteration 18, residual = 1.0863516505100013e-05 CG iteration 19, residual = 9.820220872502563e-06 CG iteration 20, residual = 8.01550309737791e-06 CG iteration 21, residual = 6.321370620534526e-06 CG iteration 22, residual = 6.160790752389794e-06 CG iteration 23, residual = 5.497676757733302e-06 CG iteration 24, residual = 5.4289085938009924e-06 CG iteration 25, residual = 5.839401984330761e-06 CG iteration 26, residual = 6.226874046147835e-06 CG iteration 27, residual = 5.82333288408689e-06 CG iteration 28, residual = 4.566334435718276e-06 CG iteration 29, residual = 3.4917375271671935e-06 CG iteration 30, residual = 2.369086819989441e-06 CG iteration 31, residual = 1.8146584983366236e-06 CG iteration 32, residual = 1.4280831204427283e-06 CG iteration 33, residual = 1.0845180193008263e-06 CG iteration 34, residual = 7.386628248835331e-07 CG iteration 35, residual = 5.575547357465516e-07 CG iteration 36, residual = 4.868889789039748e-07 CG iteration 37, residual = 4.5001909473737347e-07 CG iteration 38, residual = 4.7131520415309923e-07 CG iteration 39, residual = 4.872709686708619e-07 CG iteration 40, residual = 5.033440508553877e-07 CG iteration 41, residual = 4.5297383299655966e-07 CG iteration 42, residual = 4.252867951436837e-07 CG iteration 43, residual = 3.923374388766666e-07 CG iteration 44, residual = 3.0053047135181314e-07 CG iteration 45, residual = 2.1915568042194174e-07 CG iteration 46, residual = 1.7168258168857638e-07 CG iteration 47, residual = 1.2830688197087425e-07 CG iteration 48, residual = 9.32830888701507e-08 CG iteration 49, residual = 7.307242105641872e-08 CG iteration 50, residual = 6.415998318030244e-08 CG iteration 51, residual = 5.17550904523058e-08 CG iteration 52, residual = 5.164348110494081e-08 CG iteration 53, residual = 5.524520416916024e-08 CG iteration 54, residual = 5.985848518594062e-08 CG iteration 55, residual = 5.647172261757484e-08 CG iteration 56, residual = 5.143831020763856e-08 CG iteration 57, residual = 4.493621214303288e-08 CG iteration 58, residual = 3.906957668827595e-08 CG iteration 59, residual = 3.1117006058392276e-08 CG iteration 60, residual = 2.2737883585434634e-08 CG iteration 61, residual = 1.619712811430309e-08 CG iteration 62, residual = 1.2084839769841062e-08 CG iteration 63, residual = 8.743755708862071e-09 CG iteration 64, residual = 7.1152385653053645e-09 CG iteration 65, residual = 5.9934460486939614e-09 CG iteration 66, residual = 5.1299516690381646e-09 CG iteration 67, residual = 4.573432935544219e-09 CG iteration 68, residual = 4.531334229818659e-09 CG iteration 69, residual = 4.6141675042160854e-09 CG iteration 70, residual = 4.946201283735129e-09 CG iteration 71, residual = 4.805982418652936e-09 CG iteration 72, residual = 4.354263243606125e-09 CG iteration 73, residual = 3.6072291910892472e-09 CG iteration 74, residual = 2.7947357549286636e-09 CG iteration 75, residual = 2.0900636860108535e-09 CG iteration 76, residual = 1.634005293019107e-09 CG iteration 77, residual = 1.1817015602227224e-09 CG iteration 78, residual = 9.449326301011053e-10 CG iteration 79, residual = 7.313885541146668e-10 CG iteration 80, residual = 5.8614219898894e-10 CG iteration 81, residual = 4.771009415241608e-10 CG iteration 82, residual = 3.949898116386339e-10 CG iteration 83, residual = 3.6244321111290836e-10 CG iteration 84, residual = 3.784180988217163e-10 CG iteration 85, residual = 3.7075201554171186e-10 CG iteration 86, residual = 4.012000701343499e-10 CG iteration 87, residual = 3.9054191782393364e-10 CG iteration 88, residual = 3.6946824339504623e-10 CG iteration 89, residual = 3.27774983612681e-10 CG iteration 90, residual = 2.729095338763625e-10 CG iteration 91, residual = 2.1129562313943145e-10 CG iteration 92, residual = 1.5666633305205834e-10 CG iteration 93, residual = 1.1582780260343197e-10 CG iteration 94, residual = 8.71104328478386e-11 CG iteration 95, residual = 7.163458686082378e-11 CG iteration 96, residual = 5.938935811960182e-11 CG iteration 97, residual = 4.793783470373457e-11 CG iteration 98, residual = 4.426860397392846e-11 CG iteration 99, residual = 4.138493750171279e-11 CG iteration 100, residual = 4.071999576542644e-11 CG iteration 101, residual = 4.022338715070843e-11 CG iteration 102, residual = 4.512033239498895e-11 CG iteration 103, residual = 4.1632031900924635e-11 CG iteration 104, residual = 4.160557973414918e-11 CG iteration 105, residual = 3.4933147424173465e-11 CG converged in 105 iterations to residual 3.4933147424173465e-11
0.004CG iteration 1, residual = 0.0035041276695032863
CG iteration 2, residual = 0.00027786146015016083 CG iteration 3, residual = 0.00023171028976420334 CG iteration 4, residual = 0.00023690402893825787 CG iteration 5, residual = 0.00015326739765366546 CG iteration 6, residual = 7.661111530151657e-05 CG iteration 7, residual = 4.7794162674647445e-05 CG iteration 8, residual = 4.433110109831922e-05 CG iteration 9, residual = 3.2568601551521497e-05 CG iteration 10, residual = 2.4744379099087373e-05 CG iteration 11, residual = 3.20578095012576e-05 CG iteration 12, residual = 3.9364241070174535e-05 CG iteration 13, residual = 3.611198722657991e-05 CG iteration 14, residual = 3.6113023598348994e-05 CG iteration 15, residual = 3.200066798666322e-05 CG iteration 16, residual = 2.2570118325755856e-05 CG iteration 17, residual = 1.4524518054691725e-05 CG iteration 18, residual = 1.0787343727302606e-05 CG iteration 19, residual = 9.715460630611676e-06 CG iteration 20, residual = 7.946161589481538e-06 CG iteration 21, residual = 6.279423697078049e-06 CG iteration 22, residual = 6.104755094594807e-06 CG iteration 23, residual = 5.440907408745209e-06 CG iteration 24, residual = 5.368802083997483e-06 CG iteration 25, residual = 5.761050124575672e-06 CG iteration 26, residual = 6.141342899963371e-06 CG iteration 27, residual = 5.7606257319428525e-06 CG iteration 28, residual = 4.527251027629788e-06 CG iteration 29, residual = 3.4589677661886444e-06 CG iteration 30, residual = 2.3363026764479787e-06 CG iteration 31, residual = 1.7845056967954585e-06 CG iteration 32, residual = 1.4094984410020962e-06 CG iteration 33, residual = 1.0733121259043688e-06 CG iteration 34, residual = 7.318545717928748e-07 CG iteration 35, residual = 5.528046126254618e-07 CG iteration 36, residual = 4.829961848620558e-07 CG iteration 37, residual = 4.4604328455565053e-07 CG iteration 38, residual = 4.676411592613413e-07 CG iteration 39, residual = 4.836904572173412e-07 CG iteration 40, residual = 5.005740482463729e-07 CG iteration 41, residual = 4.492957195368192e-07 CG iteration 42, residual = 4.216112289688609e-07 CG iteration 43, residual = 3.890028841488497e-07 CG iteration 44, residual = 2.9808794250461833e-07 CG iteration 45, residual = 2.17611638372491e-07 CG iteration 46, residual = 1.7027839611877688e-07 CG iteration 47, residual = 1.2696272114761584e-07 CG iteration 48, residual = 9.226022306908841e-08 CG iteration 49, residual = 7.23050873652753e-08 CG iteration 50, residual = 6.365001653539499e-08 CG iteration 51, residual = 5.145308372573062e-08 CG iteration 52, residual = 5.1241180392138694e-08 CG iteration 53, residual = 5.464837404382584e-08 CG iteration 54, residual = 5.929234039972449e-08 CG iteration 55, residual = 5.6004316692165226e-08 CG iteration 56, residual = 5.103684801818051e-08 CG iteration 57, residual = 4.4501189088468e-08 CG iteration 58, residual = 3.8686594356531636e-08 CG iteration 59, residual = 3.0886810740339515e-08 CG iteration 60, residual = 2.2632537531973986e-08 CG iteration 61, residual = 1.6142681182092998e-08 CG iteration 62, residual = 1.2019277425795552e-08 CG iteration 63, residual = 8.681757169132844e-09 CG iteration 64, residual = 7.053779061586199e-09 CG iteration 65, residual = 5.9335025904518e-09 CG iteration 66, residual = 5.0889274392918775e-09 CG iteration 67, residual = 4.5357739284260096e-09 CG iteration 68, residual = 4.501011527107419e-09 CG iteration 69, residual = 4.574333509538189e-09 CG iteration 70, residual = 4.898706513939895e-09 CG iteration 71, residual = 4.768687425591106e-09 CG iteration 72, residual = 4.330580609170087e-09 CG iteration 73, residual = 3.5858929666204425e-09 CG iteration 74, residual = 2.779890175168584e-09 CG iteration 75, residual = 2.0765247729340656e-09 CG iteration 76, residual = 1.6255351051831419e-09 CG iteration 77, residual = 1.1763532243625113e-09 CG iteration 78, residual = 9.397988662813264e-10 CG iteration 79, residual = 7.278184853658155e-10 CG iteration 80, residual = 5.852471712169377e-10 CG iteration 81, residual = 4.762511349816934e-10 CG iteration 82, residual = 3.93137680143792e-10 CG iteration 83, residual = 3.618508333871003e-10 CG iteration 84, residual = 3.773058677435892e-10 CG iteration 85, residual = 3.7017814009808924e-10 CG iteration 86, residual = 4.015301333555892e-10 CG iteration 87, residual = 3.9050828718514554e-10 CG iteration 88, residual = 3.6854112960738334e-10 CG iteration 89, residual = 3.261735575020012e-10 CG iteration 90, residual = 2.725593055340416e-10 CG iteration 91, residual = 2.1033852186830153e-10 CG iteration 92, residual = 1.5641702839133362e-10 CG iteration 93, residual = 1.1561875854874115e-10 CG iteration 94, residual = 8.668268614938788e-11 CG iteration 95, residual = 7.141468783452711e-11 CG iteration 96, residual = 5.929357399458352e-11 CG iteration 97, residual = 4.792036413811318e-11 CG iteration 98, residual = 4.420317078011177e-11 CG iteration 99, residual = 4.149978020371205e-11 CG iteration 100, residual = 4.068591679555166e-11 CG iteration 101, residual = 4.0213829863874664e-11 CG iteration 102, residual = 4.503126903220395e-11 CG iteration 103, residual = 4.1611822561346126e-11 CG iteration 104, residual = 4.1660454120345504e-11 CG iteration 105, residual = 3.484797624395548e-11 CG converged in 105 iterations to residual 3.484797624395548e-11
0.005CG iteration 1, residual = 0.0035038256605811795
CG iteration 2, residual = 0.0002768892998197786 CG iteration 3, residual = 0.00022986319121994173 CG iteration 4, residual = 0.0002355814876072362 CG iteration 5, residual = 0.00015308248299314908 CG iteration 6, residual = 7.633932751778355e-05 CG iteration 7, residual = 4.7269682187091584e-05 CG iteration 8, residual = 4.3775881807378724e-05 CG iteration 9, residual = 3.230818025056714e-05 CG iteration 10, residual = 2.4554781425669125e-05 CG iteration 11, residual = 3.183725290314136e-05 CG iteration 12, residual = 3.922636289183665e-05 CG iteration 13, residual = 3.600322461289103e-05 CG iteration 14, residual = 3.5957955760737055e-05 CG iteration 15, residual = 3.1823168130994624e-05 CG iteration 16, residual = 2.243278683484235e-05 CG iteration 17, residual = 1.4447474667503015e-05 CG iteration 18, residual = 1.071382563537109e-05 CG iteration 19, residual = 9.614277110470246e-06 CG iteration 20, residual = 7.878289233550735e-06 CG iteration 21, residual = 6.237654646227429e-06 CG iteration 22, residual = 6.04915565255801e-06 CG iteration 23, residual = 5.385132997526055e-06 CG iteration 24, residual = 5.31006706030628e-06 CG iteration 25, residual = 5.684824798830281e-06 CG iteration 26, residual = 6.058233390458791e-06 CG iteration 27, residual = 5.699131231264064e-06 CG iteration 28, residual = 4.488768110172435e-06 CG iteration 29, residual = 3.4272328027385185e-06 CG iteration 30, residual = 2.304784861363209e-06 CG iteration 31, residual = 1.755266336201249e-06 CG iteration 32, residual = 1.3912564787909776e-06 CG iteration 33, residual = 1.0623133202936147e-06 CG iteration 34, residual = 7.252740036331562e-07 CG iteration 35, residual = 5.482472186919502e-07 CG iteration 36, residual = 4.792554431190545e-07 CG iteration 37, residual = 4.42199682608775e-07 CG iteration 38, residual = 4.640659758870376e-07 CG iteration 39, residual = 4.801891417525163e-07 CG iteration 40, residual = 4.978820576346787e-07 CG iteration 41, residual = 4.457734410753023e-07 CG iteration 42, residual = 4.1807574322002984e-07 CG iteration 43, residual = 3.8575272729733547e-07 CG iteration 44, residual = 2.9570476779426863e-07 CG iteration 45, residual = 2.1611513276028984e-07 CG iteration 46, residual = 1.6891127508427736e-07 CG iteration 47, residual = 1.2565263891879758e-07 CG iteration 48, residual = 9.126850516084458e-08 CG iteration 49, residual = 7.155602920489478e-08 CG iteration 50, residual = 6.314818937144577e-08 CG iteration 51, residual = 5.1166575186131815e-08 CG iteration 52, residual = 5.086059476302579e-08 CG iteration 53, residual = 5.40736171208941e-08 CG iteration 54, residual = 5.8740878739149184e-08 CG iteration 55, residual = 5.555355890714011e-08 CG iteration 56, residual = 5.0652144099958096e-08 CG iteration 57, residual = 4.408078585645104e-08 CG iteration 58, residual = 3.831687340130186e-08 CG iteration 59, residual = 3.066336444212935e-08 CG iteration 60, residual = 2.2528225930242947e-08 CG iteration 61, residual = 1.6089797855285105e-08 CG iteration 62, residual = 1.195577205920849e-08 CG iteration 63, residual = 8.621520868469892e-09 CG iteration 64, residual = 6.9939155849065115e-09 CG iteration 65, residual = 5.8750299023592615e-09 CG iteration 66, residual = 5.049119254206532e-09 CG iteration 67, residual = 4.499694236680749e-09 CG iteration 68, residual = 4.472050519021072e-09 CG iteration 69, residual = 4.536443045073999e-09 CG iteration 70, residual = 4.853595385347888e-09 CG iteration 71, residual = 4.732651992062005e-09 CG iteration 72, residual = 4.307074638236133e-09 CG iteration 73, residual = 3.5651272352784777e-09 CG iteration 74, residual = 2.7659211153758746e-09 CG iteration 75, residual = 2.063513803171767e-09 CG iteration 76, residual = 1.6171413383091029e-09 CG iteration 77, residual = 1.1712523631411175e-09 CG iteration 78, residual = 9.34782831506758e-10 CG iteration 79, residual = 7.242739949873015e-10 CG iteration 80, residual = 5.842777052913203e-10 CG iteration 81, residual = 4.753412657929106e-10 CG iteration 82, residual = 3.9133812012559064e-10 CG iteration 83, residual = 3.612238098741856e-10 CG iteration 84, residual = 3.7604330410910406e-10 CG iteration 85, residual = 3.6959384289305024e-10 CG iteration 86, residual = 4.017596279793326e-10 CG iteration 87, residual = 3.904103395203695e-10 CG iteration 88, residual = 3.676139377351832e-10 CG iteration 89, residual = 3.245632270068751e-10 CG iteration 90, residual = 2.7215150142709294e-10 CG iteration 91, residual = 2.0936276782491604e-10 CG iteration 92, residual = 1.5618384717674707e-10 CG iteration 93, residual = 1.15415719037375e-10 CG iteration 94, residual = 8.627398056833222e-11 CG iteration 95, residual = 7.120120256083172e-11 CG iteration 96, residual = 5.919231608994868e-11 CG iteration 97, residual = 4.790091590368312e-11 CG iteration 98, residual = 4.4132174954380714e-11 CG iteration 99, residual = 4.1603158858677335e-11 CG iteration 100, residual = 4.064194704729783e-11 CG iteration 101, residual = 4.020444822397888e-11
</pre>
end{sphinxVerbatim}
[2KCG iteration 2, residual = 0.0002834627490531965 [2KCG iteration 3, residual = 0.00024263039834510451 [2KCG iteration 4, residual = 0.00024456972709674564 [2KCG iteration 5, residual = 0.00015448504295567455 [2KCG iteration 6, residual = 7.821151803176524e-05 [2KCG iteration 7, residual = 5.073203767271228e-05 [2KCG iteration 8, residual = 4.7425017756223996e-05 [2KCG iteration 9, residual = 3.410628962677873e-05 [2KCG iteration 10, residual = 2.5969155301851343e-05 [2KCG iteration 11, residual = 3.355628610785994e-05 [2KCG iteration 12, residual = 4.0465654275392375e-05 [2KCG iteration 13, residual = 3.696882793422592e-05 [2KCG iteration 14, residual = 3.7084750141514266e-05 [2KCG iteration 15, residual = 3.299103712798381e-05 [2KCG iteration 16, residual = 2.3322264029912498e-05 [2KCG iteration 17, residual = 1.4942487703727611e-05 [2KCG iteration 18, residual = 1.1201775298738749e-05 [2KCG iteration 19, residual = 1.0280543927546932e-05 [2KCG iteration 20, residual = 8.309341542074007e-06 [2KCG iteration 21, residual = 6.491721486633316e-06 [2KCG iteration 22, residual = 6.390133425069827e-06 [2KCG iteration 23, residual = 5.736028117624518e-06 [2KCG iteration 24, residual = 5.6842926631273295e-06 [2KCG iteration 25, residual = 6.174968765275747e-06 [2KCG iteration 26, residual = 6.593997695038199e-06 [2KCG iteration 27, residual = 6.086805914560082e-06 [2KCG iteration 28, residual = 4.729474748314116e-06 [2KCG iteration 29, residual = 3.6344671905966728e-06 [2KCG iteration 30, residual = 2.5143094857132473e-06 [2KCG iteration 31, residual = 1.9448641889355736e-06 [2KCG iteration 32, residual = 1.505663381611971e-06 [2KCG iteration 33, residual = 1.1315533131770621e-06 [2KCG iteration 34, residual = 7.68563152419886e-07 [2KCG iteration 35, residual = 5.787283688098449e-07 [2KCG iteration 36, residual = 5.041127194998003e-07 [2KCG iteration 37, residual = 4.6744762830305875e-07 [2KCG iteration 38, residual = 4.871900222792222e-07 [2KCG iteration 39, residual = 5.024991254256286e-07 [2KCG iteration 40, residual = 5.153626930220074e-07 [2KCG iteration 41, residual = 4.6952520772485864e-07 [2KCG iteration 42, residual = 4.4154630934355745e-07 [2KCG iteration 43, residual = 4.065913286016486e-07 [2KCG iteration 44, residual = 3.110147788098351e-07 [2KCG iteration 45, residual = 2.2593010929629386e-07 [2KCG iteration 46, residual = 1.7775726985654165e-07 [2KCG iteration 47, residual = 1.340632778972497e-07 [2KCG iteration 48, residual = 9.772218534414981e-08 [2KCG iteration 49, residual = 7.634811158237477e-08 [2KCG iteration 50, residual = 6.629684641042421e-08 [2KCG iteration 51, residual = 5.31516774247558e-08 [2KCG iteration 52, residual = 5.351859704489737e-08 [2KCG iteration 53, residual = 5.78846889823926e-08 [2KCG iteration 54, residual = 6.228731685395157e-08 [2KCG iteration 55, residual = 5.854713580053559e-08 [2KCG iteration 56, residual = 5.3252264282158094e-08 [2KCG iteration 57, residual = 4.684499780480687e-08 [2KCG iteration 58, residual = 4.074919511653098e-08 [2KCG iteration 59, residual = 3.212046732238423e-08 [2KCG iteration 60, residual = 2.317841897396856e-08 [2KCG iteration 61, residual = 1.6437060632261116e-08 [2KCG iteration 62, residual = 1.2375984051506147e-08 [2KCG iteration 63, residual = 9.015574752213276e-09 [2KCG iteration 64, residual = 7.380815803862294e-09 [2KCG iteration 65, residual = 6.251477938074552e-09 [2KCG iteration 66, residual = 5.309531724516055e-09 [2KCG iteration 67, residual = 4.7436952116937925e-09 [2KCG iteration 68, residual = 4.670876285494703e-09 [2KCG iteration 69, residual = 4.7987050223391125e-09 [2KCG iteration 70, residual = 5.165189530651792e-09 [2KCG iteration 71, residual = 4.9712230444805764e-09 [2KCG iteration 72, residual = 4.454588903460429e-09 [2KCG iteration 73, residual = 3.7017977456199185e-09 [2KCG iteration 74, residual = 2.865240327828223e-09 [2KCG iteration 75, residual = 2.1508780843757938e-09 [2KCG iteration 76, residual = 1.6695609487286063e-09 [2KCG iteration 77, residual = 1.206627470450266e-09 [2KCG iteration 78, residual = 9.673964096737804e-10 [2KCG iteration 79, residual = 7.463274729751711e-10 [2KCG iteration 80, residual = 5.896934199688659e-10 [2KCG iteration 81, residual = 4.80589135305542e-10 [2KCG iteration 82, residual = 4.03568302666251e-10 [2KCG iteration 83, residual = 3.652524528876453e-10 [2KCG iteration 84, residual = 3.820052461822441e-10 [2KCG iteration 85, residual = 3.73820775086239e-10 [2KCG iteration 86, residual = 4.000182811495793e-10 [2KCG iteration 87, residual = 3.9080442890683617e-10 [2KCG iteration 88, residual = 3.7378376642690186e-10 [2KCG iteration 89, residual = 3.3454993094736147e-10 [2KCG iteration 90, residual = 2.7407845430884504e-10 [2KCG iteration 91, residual = 2.151093774094584e-10 [2KCG iteration 92, residual = 1.579989973810733e-10 [2KCG iteration 93, residual = 1.1686987174084624e-10 [2KCG iteration 94, residual = 8.910126190410332e-11 [2KCG iteration 95, residual = 7.265188500596543e-11 [2KCG iteration 96, residual = 5.981033026734256e-11 [2KCG iteration 97, residual = 4.8073612942247536e-11 [2KCG iteration 98, residual = 4.45559726268082e-11 [2KCG iteration 99, residual = 4.092678042581251e-11 [2KCG iteration 100, residual = 4.08575928988359e-11 [2KCG iteration 101, residual = 4.0375160994562566e-11 [2KCG iteration 102, residual = 4.534300756674283e-11 [2KCG iteration 103, residual = 4.1766430058524355e-11 [2KCG iteration 104, residual = 4.131724716650939e-11 [2KCG iteration 105, residual = 3.537333329123969e-11 [2KCG iteration 106, residual = 3.179997173468708e-11 [2KCG converged in 106 iterations to residual 3.179997173468708e-11
0[2KCG iteration 1, residual = 0.0035053975194496044
[2KCG iteration 2, residual = 0.0002822322160843943 [2KCG iteration 3, residual = 0.000240196509405923 [2KCG iteration 4, residual = 0.00024288531680424476 [2KCG iteration 5, residual = 0.00015419728363136006 [2KCG iteration 6, residual = 7.785448071641783e-05 [2KCG iteration 7, residual = 5.009703418723029e-05 [2KCG iteration 8, residual = 4.675907553452885e-05 [2KCG iteration 9, residual = 3.376347155713625e-05 [2KCG iteration 10, residual = 2.5682225303015667e-05 [2KCG iteration 11, residual = 3.319644640349678e-05 [2KCG iteration 12, residual = 4.018278246306371e-05 [2KCG iteration 13, residual = 3.6748706556582916e-05 [2KCG iteration 14, residual = 3.685830005231227e-05 [2KCG iteration 15, residual = 3.277530180259381e-05 [2KCG iteration 16, residual = 2.3160620041953624e-05 [2KCG iteration 17, residual = 1.4853019360758254e-05 [2KCG iteration 18, residual = 1.1111341746195791e-05 [2KCG iteration 19, residual = 1.0158624312113796e-05 [2KCG iteration 20, residual = 8.233168902326498e-06 [2KCG iteration 21, residual = 6.448599612606545e-06 [2KCG iteration 22, residual = 6.331860453770461e-06 [2KCG iteration 23, residual = 5.674551809190057e-06 [2KCG iteration 24, residual = 5.618014147605852e-06 [2KCG iteration 25, residual = 6.087611447783765e-06 [2KCG iteration 26, residual = 6.498352886585876e-06 [2KCG iteration 27, residual = 6.0189519019273505e-06 [2KCG iteration 28, residual = 4.687559775162932e-06 [2KCG iteration 29, residual = 3.59689564777813e-06 [2KCG iteration 30, residual = 2.4757407524555685e-06 [2KCG iteration 31, residual = 1.910828020548234e-06 [2KCG iteration 32, residual = 1.4858028590521678e-06 [2KCG iteration 33, residual = 1.1194453680966317e-06 [2KCG iteration 34, residual = 7.606435130266568e-07 [2KCG iteration 35, residual = 5.730822931849924e-07 [2KCG iteration 36, residual = 4.995452729704887e-07 [2KCG iteration 37, residual = 4.6283853362264297e-07 [2KCG iteration 38, residual = 4.830218759079232e-07 [2KCG iteration 39, residual = 4.985423617534478e-07 [2KCG iteration 40, residual = 5.121983960778873e-07 [2KCG iteration 41, residual = 4.6507881876837194e-07 [2KCG iteration 42, residual = 4.372303489054457e-07 [2KCG iteration 43, residual = 4.028829881325922e-07 [2KCG iteration 44, residual = 3.08272633064608e-07 [2KCG iteration 45, residual = 2.2413247234696063e-07 [2KCG iteration 46, residual = 1.761603006861517e-07 [2KCG iteration 47, residual = 1.3256309399960684e-07 [2KCG iteration 48, residual = 9.655609598808055e-08 [2KCG iteration 49, residual = 7.549524753339161e-08 [2KCG iteration 50, residual = 6.57460469607192e-08 [2KCG iteration 51, residual = 5.277034190696689e-08 [2KCG iteration 52, residual = 5.300431712124942e-08 [2KCG iteration 53, residual = 5.718328533874679e-08 [2KCG iteration 54, residual = 6.165326122290104e-08 [2KCG iteration 55, residual = 5.79927134045009e-08 [2KCG iteration 56, residual = 5.2762883341080137e-08 [2KCG iteration 57, residual = 4.63399105459643e-08 [2KCG iteration 58, residual = 4.030544966936915e-08 [2KCG iteration 59, residual = 3.1855458853747057e-08 [2KCG iteration 60, residual = 2.306432344523002e-08 [2KCG iteration 61, residual = 1.6372991773015176e-08 [2KCG iteration 62, residual = 1.2297949629458822e-08 [2KCG iteration 63, residual = 8.943333005658524e-09 [2KCG iteration 64, residual = 7.310998189813659e-09 [2KCG iteration 65, residual = 6.183804420828091e-09 [2KCG iteration 66, residual = 5.2619092362298e-09 [2KCG iteration 67, residual = 4.697721886952324e-09 [2KCG iteration 68, residual = 4.632692888397711e-09 [2KCG iteration 69, residual = 4.748092307118702e-09 [2KCG iteration 70, residual = 5.105486083361721e-09 [2KCG iteration 71, residual = 4.927087221722954e-09 [2KCG iteration 72, residual = 4.4281898266880495e-09 [2KCG iteration 73, residual = 3.6763456508203947e-09 [2KCG iteration 74, residual = 2.845680579617973e-09 [2KCG iteration 75, residual = 2.134512812949707e-09 [2KCG iteration 76, residual = 1.660300984872995e-09 [2KCG iteration 77, residual = 1.199739923426847e-09 [2KCG iteration 78, residual = 9.613991353514773e-10 [2KCG iteration 79, residual = 7.424387293357345e-10 [2KCG iteration 80, residual = 5.887187922189456e-10 [2KCG iteration 81, residual = 4.7961188315689e-10 [2KCG iteration 82, residual = 4.0116287515484343e-10 [2KCG iteration 83, residual = 3.643802768765076e-10 [2KCG iteration 84, residual = 3.811385655128112e-10 [2KCG iteration 85, residual = 3.728167628890719e-10 [2KCG iteration 86, residual = 4.001422635783293e-10 [2KCG iteration 87, residual = 3.906085480684764e-10 [2KCG iteration 88, residual = 3.725268937632893e-10 [2KCG iteration 89, residual = 3.327341864743003e-10 [2KCG iteration 90, residual = 2.7377242409284795e-10 [2KCG iteration 91, residual = 2.1413103289918502e-10 [2KCG iteration 92, residual = 1.575920047824593e-10 [2KCG iteration 93, residual = 1.1655970865090408e-10 [2KCG iteration 94, residual = 8.854868494493672e-11 [2KCG iteration 95, residual = 7.236597296042923e-11 [2KCG iteration 96, residual = 5.96866825737044e-11 [2KCG iteration 97, residual = 4.8017594743288207e-11 [2KCG iteration 98, residual = 4.446824411016334e-11 [2KCG iteration 99, residual = 4.1025144701103625e-11 [2KCG iteration 100, residual = 4.080781651597987e-11 [2KCG iteration 101, residual = 4.0304077397374116e-11 [2KCG iteration 102, residual = 4.52915872359784e-11 [2KCG iteration 103, residual = 4.171076692570568e-11 [2KCG iteration 104, residual = 4.1386287436880715e-11 [2KCG iteration 105, residual = 3.524081428542747e-11 [2KCG iteration 106, residual = 3.172974283068946e-11 [2KCG converged in 106 iterations to residual 3.172974283068946e-11
0.001[2KCG iteration 1, residual = 0.003505069429221998
[2KCG iteration 2, residual = 0.00028106054221934773 [2KCG iteration 3, residual = 0.00023789567798713961 [2KCG iteration 4, residual = 0.0002412799007959158 [2KCG iteration 5, residual = 0.0001539333045769327 [2KCG iteration 6, residual = 7.751747251745792e-05 [2KCG iteration 7, residual = 4.94874868880815e-05 [2KCG iteration 8, residual = 4.6118245892993204e-05 [2KCG iteration 9, residual = 3.343954392797848e-05 [2KCG iteration 10, residual = 2.541792828941187e-05 [2KCG iteration 11, residual = 3.2869048314071195e-05 [2KCG iteration 12, residual = 3.993363570291145e-05 [2KCG iteration 13, residual = 3.655520278059141e-05 [2KCG iteration 14, residual = 3.664980391062579e-05 [2KCG iteration 15, residual = 3.256968913299164e-05 [2KCG iteration 16, residual = 2.3005413787996554e-05 [2KCG iteration 17, residual = 1.4767004121205355e-05 [2KCG iteration 18, residual = 1.1025127125762825e-05 [2KCG iteration 19, residual = 1.0041500181813037e-05 [2KCG iteration 20, residual = 8.158900225084393e-06 [2KCG iteration 21, residual = 6.405900189866536e-06 [2KCG iteration 22, residual = 6.27428187719717e-06 [2KCG iteration 23, residual = 5.614415335191318e-06 [2KCG iteration 24, residual = 5.553435534519984e-06 [2KCG iteration 25, residual = 6.002624732611839e-06 [2KCG iteration 26, residual = 6.405330940093095e-06 [2KCG iteration 27, residual = 5.952460343247484e-06 [2KCG iteration 28, residual = 4.646441114193769e-06 [2KCG iteration 29, residual = 3.5606331752857504e-06 [2KCG iteration 30, residual = 2.438732376190039e-06 [2KCG iteration 31, residual = 1.877796843483612e-06 [2KCG iteration 32, residual = 1.4662453658450506e-06 [2KCG iteration 33, residual = 1.1075766817086964e-06 [2KCG iteration 34, residual = 7.530362112094879e-07 [2KCG iteration 35, residual = 5.676806732893912e-07 [2KCG iteration 36, residual = 4.951567974005424e-07 [2KCG iteration 37, residual = 4.5840574350261824e-07 [2KCG iteration 38, residual = 4.789950220628856e-07 [2KCG iteration 39, residual = 4.946905323906564e-07 [2KCG iteration 40, residual = 5.091474396834185e-07 [2KCG iteration 41, residual = 4.6085002944662613e-07 [2KCG iteration 42, residual = 4.330880105892388e-07 [2KCG iteration 43, residual = 3.9927380899428327e-07 [2KCG iteration 44, residual = 3.0561624885569794e-07 [2KCG iteration 45, residual = 2.2240938596302147e-07 [2KCG iteration 46, residual = 1.7461891384172402e-07 [2KCG iteration 47, residual = 1.3110504960389346e-07 [2KCG iteration 48, residual = 9.542906157101544e-08 [2KCG iteration 49, residual = 7.466614882866072e-08 [2KCG iteration 50, residual = 6.520708538748794e-08 [2KCG iteration 51, residual = 5.2411882954751333e-08 [2KCG iteration 52, residual = 5.252240112662126e-08 [2KCG iteration 53, residual = 5.651093203415559e-08 [2KCG iteration 54, residual = 6.103794585672805e-08 [2KCG iteration 55, residual = 5.74637338446785e-08 [2KCG iteration 56, residual = 5.229912261141477e-08 [2KCG iteration 57, residual = 4.585435348208778e-08 [2KCG iteration 58, residual = 3.98781982848155e-08 [2KCG iteration 59, residual = 3.1600504756310974e-08 [2KCG iteration 60, residual = 2.2953277498776614e-08 [2KCG iteration 61, residual = 1.6311926437642456e-08 [2KCG iteration 62, residual = 1.2223734533706026e-08 [2KCG iteration 63, residual = 8.87420604682335e-09 [2KCG iteration 64, residual = 7.243635805562636e-09 [2KCG iteration 65, residual = 6.118399084656097e-09 [2KCG iteration 66, residual = 5.21625536596163e-09 [2KCG iteration 67, residual = 4.654192515304299e-09 [2KCG iteration 68, residual = 4.596915975769929e-09 [2KCG iteration 69, residual = 4.7007240287658956e-09 [2KCG iteration 70, residual = 5.04930715727089e-09 [2KCG iteration 71, residual = 4.884989352952451e-09 [2KCG iteration 72, residual = 4.402849110484059e-09 [2KCG iteration 73, residual = 3.652257954196086e-09 [2KCG iteration 74, residual = 2.827504381766682e-09 [2KCG iteration 75, residual = 2.1189817360733e-09 [2KCG iteration 76, residual = 1.6513346850291587e-09 [2KCG iteration 77, residual = 1.1933361338323822e-09 [2KCG iteration 78, residual = 9.556903224889162e-10 [2KCG iteration 79, residual = 7.386744273616934e-10 [2KCG iteration 80, residual = 5.878367055490674e-10 [2KCG iteration 81, residual = 4.787403545639366e-10 [2KCG iteration 82, residual = 3.989644132938918e-10 [2KCG iteration 83, residual = 3.636616093169148e-10 [2KCG iteration 84, residual = 3.8029266400462805e-10 [2KCG iteration 85, residual = 3.7201832763422703e-10 [2KCG iteration 86, residual = 4.004388145283234e-10 [2KCG iteration 87, residual = 3.9054418851413715e-10 [2KCG iteration 88, residual = 3.714236355693029e-10 [2KCG iteration 89, residual = 3.310267195742627e-10 [2KCG iteration 90, residual = 2.7349502122526933e-10 [2KCG iteration 91, residual = 2.131806013042655e-10 [2KCG iteration 92, residual = 1.5724346194289886e-10 [2KCG iteration 93, residual = 1.1628984930587078e-10 [2KCG iteration 94, residual = 8.803790609901075e-11 [2KCG iteration 95, residual = 7.210560738815653e-11 [2KCG iteration 96, residual = 5.95803384068091e-11 [2KCG iteration 97, residual = 4.7981185778832996e-11 [2KCG iteration 98, residual = 4.439604116098158e-11 [2KCG iteration 99, residual = 4.114063930463009e-11 [2KCG iteration 100, residual = 4.0774555853526326e-11 [2KCG iteration 101, residual = 4.026162305803593e-11 [2KCG iteration 102, residual = 4.5243956608192545e-11 [2KCG iteration 103, residual = 4.167562766190987e-11 [2KCG iteration 104, residual = 4.146272352617181e-11 [2KCG iteration 105, residual = 3.512639590949981e-11 [2KCG iteration 106, residual = 3.1666528830867264e-11 [2KCG converged in 106 iterations to residual 3.1666528830867264e-11
0.002[2KCG iteration 1, residual = 0.0035047489040554193
[2KCG iteration 2, residual = 0.00027994387104024086 [2KCG iteration 3, residual = 0.00023571949420094678 [2KCG iteration 4, residual = 0.0002397500730371937 [2KCG iteration 5, residual = 0.0001536913783477332 [2KCG iteration 6, residual = 7.719887886654385e-05 [2KCG iteration 7, residual = 4.890158486370472e-05 [2KCG iteration 8, residual = 4.550094502677626e-05 [2KCG iteration 9, residual = 3.313321000910539e-05 [2KCG iteration 10, residual = 2.5174553657510466e-05 [2KCG iteration 11, residual = 3.257164338581296e-05 [2KCG iteration 12, residual = 3.9715715260836773e-05 [2KCG iteration 13, residual = 3.6386006468403036e-05 [2KCG iteration 14, residual = 3.6457297015747345e-05 [2KCG iteration 15, residual = 3.237285226723261e-05 [2KCG iteration 16, residual = 2.2855771059550234e-05 [2KCG iteration 17, residual = 1.4683892926465781e-05 [2KCG iteration 18, residual = 1.0942657121431599e-05 [2KCG iteration 19, residual = 9.928806355657007e-06 [2KCG iteration 20, residual = 8.086384871252998e-06 [2KCG iteration 21, residual = 6.363514901070838e-06 [2KCG iteration 22, residual = 6.217284236188048e-06 [2KCG iteration 23, residual = 5.555489335607877e-06 [2KCG iteration 24, residual = 5.490431175999478e-06 [2KCG iteration 25, residual = 5.919911197900817e-06 [2KCG iteration 26, residual = 6.314856527876842e-06 [2KCG iteration 27, residual = 5.887268466696952e-06 [2KCG iteration 28, residual = 4.606050545832688e-06 [2KCG iteration 29, residual = 3.525603997393599e-06 [2KCG iteration 30, residual = 2.403206086120506e-06 [2KCG iteration 31, residual = 1.8457479130163429e-06 [2KCG iteration 32, residual = 1.4470019628517482e-06 [2KCG iteration 33, residual = 1.0959371083556243e-06 [2KCG iteration 34, residual = 7.457167096698458e-07 [2KCG iteration 35, residual = 5.625092641822414e-07 [2KCG iteration 36, residual = 4.909403026356549e-07 [2KCG iteration 37, residual = 4.541364488776506e-07 [2KCG iteration 38, residual = 4.750965591990912e-07 [2KCG iteration 39, residual = 4.909356933053042e-07 [2KCG iteration 40, residual = 5.061991222884059e-07 [2KCG iteration 41, residual = 4.568204679272184e-07 [2KCG iteration 42, residual = 4.2910973340228003e-07 [2KCG iteration 43, residual = 3.957598767605904e-07 [2KCG iteration 44, residual = 3.030378450056209e-07 [2KCG iteration 45, residual = 2.2075282859388275e-07 [2KCG iteration 46, residual = 1.7312793979943923e-07 [2KCG iteration 47, residual = 1.2968700009321911e-07 [2KCG iteration 48, residual = 9.433875164356348e-08 [2KCG iteration 49, residual = 7.385903384190036e-08 [2KCG iteration 50, residual = 6.467873413835462e-08 [2KCG iteration 51, residual = 5.207411509715072e-08 [2KCG iteration 52, residual = 5.206972200493804e-08 [2KCG iteration 53, residual = 5.586551947843103e-08 [2KCG iteration 54, residual = 6.044005251676895e-08 [2KCG iteration 55, residual = 5.6957518273623894e-08 [2KCG iteration 56, residual = 5.18583756542817e-08 [2KCG iteration 57, residual = 4.5386883416402006e-08 [2KCG iteration 58, residual = 3.9466521545851445e-08 [2KCG iteration 59, residual = 3.1354643957674694e-08 [2KCG iteration 60, residual = 2.2844644742961446e-08 [2KCG iteration 61, residual = 1.6253431932473665e-08 [2KCG iteration 62, residual = 1.2152850484308981e-08 [2KCG iteration 63, residual = 8.807799076946422e-09 [2KCG iteration 64, residual = 7.1784591450561315e-09 [2KCG iteration 65, residual = 6.0550171434249845e-09 [2KCG iteration 66, residual = 5.172336852523284e-09 [2KCG iteration 67, residual = 4.6128398195456475e-09 [2KCG iteration 68, residual = 4.5632226579528675e-09 [2KCG iteration 69, residual = 4.656198323781482e-09 [2KCG iteration 70, residual = 4.996312827237177e-09 [2KCG iteration 71, residual = 4.844690185613131e-09 [2KCG iteration 72, residual = 4.3782863208532496e-09 [2KCG iteration 73, residual = 3.6292900480315537e-09 [2KCG iteration 74, residual = 2.810566959128775e-09 [2KCG iteration 75, residual = 2.1041923824576485e-09 [2KCG iteration 76, residual = 1.6425892714340587e-09 [2KCG iteration 77, residual = 1.1873443240860118e-09 [2KCG iteration 78, residual = 9.502167808112344e-10 [2KCG iteration 79, residual = 7.35000143907866e-10 [2KCG iteration 80, residual = 5.869929463707243e-10 [2KCG iteration 81, residual = 4.77918589822197e-10 [2KCG iteration 82, residual = 3.96920822472242e-10 [2KCG iteration 83, residual = 3.630330940763259e-10 [2KCG iteration 84, residual = 3.7940217404806196e-10 [2KCG iteration 85, residual = 3.7135001672806894e-10 [2KCG iteration 86, residual = 4.0081633921128235e-10 [2KCG iteration 87, residual = 3.9054026768308116e-10 [2KCG iteration 88, residual = 3.7041838653279984e-10 [2KCG iteration 89, residual = 3.2938461144297684e-10 [2KCG iteration 90, residual = 2.7321539455207495e-10 [2KCG iteration 91, residual = 2.1223990872938406e-10 [2KCG iteration 92, residual = 1.5693877821738902e-10 [2KCG iteration 93, residual = 1.160489772809092e-10 [2KCG iteration 94, residual = 8.756060390812702e-11 [2KCG iteration 95, residual = 7.186360108008316e-11 [2KCG iteration 96, residual = 5.948332733783813e-11 [2KCG iteration 97, residual = 4.795660359840926e-11 [2KCG iteration 98, residual = 4.433146559945352e-11 [2KCG iteration 99, residual = 4.126320117482507e-11 [2KCG iteration 100, residual = 4.0747769602199253e-11 [2KCG iteration 101, residual = 4.023736398461378e-11 [2KCG iteration 102, residual = 4.5189454203045636e-11 [2KCG iteration 103, residual = 4.1651675577092756e-11 [2KCG iteration 104, residual = 4.153801852956013e-11 [2KCG iteration 105, residual = 3.502507154825672e-11 [2KCG converged in 105 iterations to residual 3.502507154825672e-11
0.003[2KCG iteration 1, residual = 0.0035044352096447137
[2KCG iteration 2, residual = 0.00027887861982526797 [2KCG iteration 3, residual = 0.00023366012814947729 [2KCG iteration 4, residual = 0.00023829252047818738 [2KCG iteration 5, residual = 0.00015346990406351553 [2KCG iteration 6, residual = 7.689721470862992e-05 [2KCG iteration 7, residual = 4.833765704863179e-05 [2KCG iteration 8, residual = 4.49056914944228e-05 [2KCG iteration 9, residual = 3.2843267357853545e-05 [2KCG iteration 10, residual = 2.49505225981182e-05 [2KCG iteration 11, residual = 3.230194260929783e-05 [2KCG iteration 12, residual = 3.952665954288422e-05 [2KCG iteration 13, residual = 3.623894648915114e-05 [2KCG iteration 14, residual = 3.627894111046302e-05 [2KCG iteration 15, residual = 3.218355472843034e-05 [2KCG iteration 16, residual = 2.271090620533988e-05 [2KCG iteration 17, residual = 1.4603203904905763e-05 [2KCG iteration 18, residual = 1.0863516505100013e-05 [2KCG iteration 19, residual = 9.820220872502563e-06 [2KCG iteration 20, residual = 8.01550309737791e-06 [2KCG iteration 21, residual = 6.321370620534526e-06 [2KCG iteration 22, residual = 6.160790752389794e-06 [2KCG iteration 23, residual = 5.497676757733302e-06 [2KCG iteration 24, residual = 5.4289085938009924e-06 [2KCG iteration 25, residual = 5.839401984330761e-06 [2KCG iteration 26, residual = 6.226874046147835e-06 [2KCG iteration 27, residual = 5.82333288408689e-06 [2KCG iteration 28, residual = 4.566334435718276e-06 [2KCG iteration 29, residual = 3.4917375271671935e-06 [2KCG iteration 30, residual = 2.369086819989441e-06 [2KCG iteration 31, residual = 1.8146584983366236e-06 [2KCG iteration 32, residual = 1.4280831204427283e-06 [2KCG iteration 33, residual = 1.0845180193008263e-06 [2KCG iteration 34, residual = 7.386628248835331e-07 [2KCG iteration 35, residual = 5.575547357465516e-07 [2KCG iteration 36, residual = 4.868889789039748e-07 [2KCG iteration 37, residual = 4.5001909473737347e-07 [2KCG iteration 38, residual = 4.7131520415309923e-07 [2KCG iteration 39, residual = 4.872709686708619e-07 [2KCG iteration 40, residual = 5.033440508553877e-07 [2KCG iteration 41, residual = 4.5297383299655966e-07 [2KCG iteration 42, residual = 4.252867951436837e-07 [2KCG iteration 43, residual = 3.923374388766666e-07 [2KCG iteration 44, residual = 3.0053047135181314e-07 [2KCG iteration 45, residual = 2.1915568042194174e-07 [2KCG iteration 46, residual = 1.7168258168857638e-07 [2KCG iteration 47, residual = 1.2830688197087425e-07 [2KCG iteration 48, residual = 9.32830888701507e-08 [2KCG iteration 49, residual = 7.307242105641872e-08 [2KCG iteration 50, residual = 6.415998318030244e-08 [2KCG iteration 51, residual = 5.17550904523058e-08 [2KCG iteration 52, residual = 5.164348110494081e-08 [2KCG iteration 53, residual = 5.524520416916024e-08 [2KCG iteration 54, residual = 5.985848518594062e-08 [2KCG iteration 55, residual = 5.647172261757484e-08 [2KCG iteration 56, residual = 5.143831020763856e-08 [2KCG iteration 57, residual = 4.493621214303288e-08 [2KCG iteration 58, residual = 3.906957668827595e-08 [2KCG iteration 59, residual = 3.1117006058392276e-08 [2KCG iteration 60, residual = 2.2737883585434634e-08 [2KCG iteration 61, residual = 1.619712811430309e-08 [2KCG iteration 62, residual = 1.2084839769841062e-08 [2KCG iteration 63, residual = 8.743755708862071e-09 [2KCG iteration 64, residual = 7.1152385653053645e-09 [2KCG iteration 65, residual = 5.9934460486939614e-09 [2KCG iteration 66, residual = 5.1299516690381646e-09 [2KCG iteration 67, residual = 4.573432935544219e-09 [2KCG iteration 68, residual = 4.531334229818659e-09 [2KCG iteration 69, residual = 4.6141675042160854e-09 [2KCG iteration 70, residual = 4.946201283735129e-09 [2KCG iteration 71, residual = 4.805982418652936e-09 [2KCG iteration 72, residual = 4.354263243606125e-09 [2KCG iteration 73, residual = 3.6072291910892472e-09 [2KCG iteration 74, residual = 2.7947357549286636e-09 [2KCG iteration 75, residual = 2.0900636860108535e-09 [2KCG iteration 76, residual = 1.634005293019107e-09 [2KCG iteration 77, residual = 1.1817015602227224e-09 [2KCG iteration 78, residual = 9.449326301011053e-10 [2KCG iteration 79, residual = 7.313885541146668e-10 [2KCG iteration 80, residual = 5.8614219898894e-10 [2KCG iteration 81, residual = 4.771009415241608e-10 [2KCG iteration 82, residual = 3.949898116386339e-10 [2KCG iteration 83, residual = 3.6244321111290836e-10 [2KCG iteration 84, residual = 3.784180988217163e-10 [2KCG iteration 85, residual = 3.7075201554171186e-10 [2KCG iteration 86, residual = 4.012000701343499e-10 [2KCG iteration 87, residual = 3.9054191782393364e-10 [2KCG iteration 88, residual = 3.6946824339504623e-10 [2KCG iteration 89, residual = 3.27774983612681e-10 [2KCG iteration 90, residual = 2.729095338763625e-10 [2KCG iteration 91, residual = 2.1129562313943145e-10 [2KCG iteration 92, residual = 1.5666633305205834e-10 [2KCG iteration 93, residual = 1.1582780260343197e-10 [2KCG iteration 94, residual = 8.71104328478386e-11 [2KCG iteration 95, residual = 7.163458686082378e-11 [2KCG iteration 96, residual = 5.938935811960182e-11 [2KCG iteration 97, residual = 4.793783470373457e-11 [2KCG iteration 98, residual = 4.426860397392846e-11 [2KCG iteration 99, residual = 4.138493750171279e-11 [2KCG iteration 100, residual = 4.071999576542644e-11 [2KCG iteration 101, residual = 4.022338715070843e-11 [2KCG iteration 102, residual = 4.512033239498895e-11 [2KCG iteration 103, residual = 4.1632031900924635e-11 [2KCG iteration 104, residual = 4.160557973414918e-11 [2KCG iteration 105, residual = 3.4933147424173465e-11 [2KCG converged in 105 iterations to residual 3.4933147424173465e-11
0.004[2KCG iteration 1, residual = 0.0035041276695032863
[2KCG iteration 2, residual = 0.00027786146015016083 [2KCG iteration 3, residual = 0.00023171028976420334 [2KCG iteration 4, residual = 0.00023690402893825787 [2KCG iteration 5, residual = 0.00015326739765366546 [2KCG iteration 6, residual = 7.661111530151657e-05 [2KCG iteration 7, residual = 4.7794162674647445e-05 [2KCG iteration 8, residual = 4.433110109831922e-05 [2KCG iteration 9, residual = 3.2568601551521497e-05 [2KCG iteration 10, residual = 2.4744379099087373e-05 [2KCG iteration 11, residual = 3.20578095012576e-05 [2KCG iteration 12, residual = 3.9364241070174535e-05 [2KCG iteration 13, residual = 3.611198722657991e-05 [2KCG iteration 14, residual = 3.6113023598348994e-05 [2KCG iteration 15, residual = 3.200066798666322e-05 [2KCG iteration 16, residual = 2.2570118325755856e-05 [2KCG iteration 17, residual = 1.4524518054691725e-05 [2KCG iteration 18, residual = 1.0787343727302606e-05 [2KCG iteration 19, residual = 9.715460630611676e-06 [2KCG iteration 20, residual = 7.946161589481538e-06 [2KCG iteration 21, residual = 6.279423697078049e-06 [2KCG iteration 22, residual = 6.104755094594807e-06 [2KCG iteration 23, residual = 5.440907408745209e-06 [2KCG iteration 24, residual = 5.368802083997483e-06 [2KCG iteration 25, residual = 5.761050124575672e-06 [2KCG iteration 26, residual = 6.141342899963371e-06 [2KCG iteration 27, residual = 5.7606257319428525e-06 [2KCG iteration 28, residual = 4.527251027629788e-06 [2KCG iteration 29, residual = 3.4589677661886444e-06 [2KCG iteration 30, residual = 2.3363026764479787e-06 [2KCG iteration 31, residual = 1.7845056967954585e-06 [2KCG iteration 32, residual = 1.4094984410020962e-06 [2KCG iteration 33, residual = 1.0733121259043688e-06 [2KCG iteration 34, residual = 7.318545717928748e-07 [2KCG iteration 35, residual = 5.528046126254618e-07 [2KCG iteration 36, residual = 4.829961848620558e-07 [2KCG iteration 37, residual = 4.4604328455565053e-07 [2KCG iteration 38, residual = 4.676411592613413e-07 [2KCG iteration 39, residual = 4.836904572173412e-07 [2KCG iteration 40, residual = 5.005740482463729e-07 [2KCG iteration 41, residual = 4.492957195368192e-07 [2KCG iteration 42, residual = 4.216112289688609e-07 [2KCG iteration 43, residual = 3.890028841488497e-07 [2KCG iteration 44, residual = 2.9808794250461833e-07 [2KCG iteration 45, residual = 2.17611638372491e-07 [2KCG iteration 46, residual = 1.7027839611877688e-07 [2KCG iteration 47, residual = 1.2696272114761584e-07 [2KCG iteration 48, residual = 9.226022306908841e-08 [2KCG iteration 49, residual = 7.23050873652753e-08 [2KCG iteration 50, residual = 6.365001653539499e-08 [2KCG iteration 51, residual = 5.145308372573062e-08 [2KCG iteration 52, residual = 5.1241180392138694e-08 [2KCG iteration 53, residual = 5.464837404382584e-08 [2KCG iteration 54, residual = 5.929234039972449e-08 [2KCG iteration 55, residual = 5.6004316692165226e-08 [2KCG iteration 56, residual = 5.103684801818051e-08 [2KCG iteration 57, residual = 4.4501189088468e-08 [2KCG iteration 58, residual = 3.8686594356531636e-08 [2KCG iteration 59, residual = 3.0886810740339515e-08 [2KCG iteration 60, residual = 2.2632537531973986e-08 [2KCG iteration 61, residual = 1.6142681182092998e-08 [2KCG iteration 62, residual = 1.2019277425795552e-08 [2KCG iteration 63, residual = 8.681757169132844e-09 [2KCG iteration 64, residual = 7.053779061586199e-09 [2KCG iteration 65, residual = 5.9335025904518e-09 [2KCG iteration 66, residual = 5.0889274392918775e-09 [2KCG iteration 67, residual = 4.5357739284260096e-09 [2KCG iteration 68, residual = 4.501011527107419e-09 [2KCG iteration 69, residual = 4.574333509538189e-09 [2KCG iteration 70, residual = 4.898706513939895e-09 [2KCG iteration 71, residual = 4.768687425591106e-09 [2KCG iteration 72, residual = 4.330580609170087e-09 [2KCG iteration 73, residual = 3.5858929666204425e-09 [2KCG iteration 74, residual = 2.779890175168584e-09 [2KCG iteration 75, residual = 2.0765247729340656e-09 [2KCG iteration 76, residual = 1.6255351051831419e-09 [2KCG iteration 77, residual = 1.1763532243625113e-09 [2KCG iteration 78, residual = 9.397988662813264e-10 [2KCG iteration 79, residual = 7.278184853658155e-10 [2KCG iteration 80, residual = 5.852471712169377e-10 [2KCG iteration 81, residual = 4.762511349816934e-10 [2KCG iteration 82, residual = 3.93137680143792e-10 [2KCG iteration 83, residual = 3.618508333871003e-10 [2KCG iteration 84, residual = 3.773058677435892e-10 [2KCG iteration 85, residual = 3.7017814009808924e-10 [2KCG iteration 86, residual = 4.015301333555892e-10 [2KCG iteration 87, residual = 3.9050828718514554e-10 [2KCG iteration 88, residual = 3.6854112960738334e-10 [2KCG iteration 89, residual = 3.261735575020012e-10 [2KCG iteration 90, residual = 2.725593055340416e-10 [2KCG iteration 91, residual = 2.1033852186830153e-10 [2KCG iteration 92, residual = 1.5641702839133362e-10 [2KCG iteration 93, residual = 1.1561875854874115e-10 [2KCG iteration 94, residual = 8.668268614938788e-11 [2KCG iteration 95, residual = 7.141468783452711e-11 [2KCG iteration 96, residual = 5.929357399458352e-11 [2KCG iteration 97, residual = 4.792036413811318e-11 [2KCG iteration 98, residual = 4.420317078011177e-11 [2KCG iteration 99, residual = 4.149978020371205e-11 [2KCG iteration 100, residual = 4.068591679555166e-11 [2KCG iteration 101, residual = 4.0213829863874664e-11 [2KCG iteration 102, residual = 4.503126903220395e-11 [2KCG iteration 103, residual = 4.1611822561346126e-11 [2KCG iteration 104, residual = 4.1660454120345504e-11 [2KCG iteration 105, residual = 3.484797624395548e-11 [2KCG converged in 105 iterations to residual 3.484797624395548e-11
0.005[2KCG iteration 1, residual = 0.0035038256605811795
[2KCG iteration 2, residual = 0.0002768892998197786 [2KCG iteration 3, residual = 0.00022986319121994173 [2KCG iteration 4, residual = 0.0002355814876072362 [2KCG iteration 5, residual = 0.00015308248299314908 [2KCG iteration 6, residual = 7.633932751778355e-05 [2KCG iteration 7, residual = 4.7269682187091584e-05 [2KCG iteration 8, residual = 4.3775881807378724e-05 [2KCG iteration 9, residual = 3.230818025056714e-05 [2KCG iteration 10, residual = 2.4554781425669125e-05 [2KCG iteration 11, residual = 3.183725290314136e-05 [2KCG iteration 12, residual = 3.922636289183665e-05 [2KCG iteration 13, residual = 3.600322461289103e-05 [2KCG iteration 14, residual = 3.5957955760737055e-05 [2KCG iteration 15, residual = 3.1823168130994624e-05 [2KCG iteration 16, residual = 2.243278683484235e-05 [2KCG iteration 17, residual = 1.4447474667503015e-05 [2KCG iteration 18, residual = 1.071382563537109e-05 [2KCG iteration 19, residual = 9.614277110470246e-06 [2KCG iteration 20, residual = 7.878289233550735e-06 [2KCG iteration 21, residual = 6.237654646227429e-06 [2KCG iteration 22, residual = 6.04915565255801e-06 [2KCG iteration 23, residual = 5.385132997526055e-06 [2KCG iteration 24, residual = 5.31006706030628e-06 [2KCG iteration 25, residual = 5.684824798830281e-06 [2KCG iteration 26, residual = 6.058233390458791e-06 [2KCG iteration 27, residual = 5.699131231264064e-06 [2KCG iteration 28, residual = 4.488768110172435e-06 [2KCG iteration 29, residual = 3.4272328027385185e-06 [2KCG iteration 30, residual = 2.304784861363209e-06 [2KCG iteration 31, residual = 1.755266336201249e-06 [2KCG iteration 32, residual = 1.3912564787909776e-06 [2KCG iteration 33, residual = 1.0623133202936147e-06 [2KCG iteration 34, residual = 7.252740036331562e-07 [2KCG iteration 35, residual = 5.482472186919502e-07 [2KCG iteration 36, residual = 4.792554431190545e-07 [2KCG iteration 37, residual = 4.42199682608775e-07 [2KCG iteration 38, residual = 4.640659758870376e-07 [2KCG iteration 39, residual = 4.801891417525163e-07 [2KCG iteration 40, residual = 4.978820576346787e-07 [2KCG iteration 41, residual = 4.457734410753023e-07 [2KCG iteration 42, residual = 4.1807574322002984e-07 [2KCG iteration 43, residual = 3.8575272729733547e-07 [2KCG iteration 44, residual = 2.9570476779426863e-07 [2KCG iteration 45, residual = 2.1611513276028984e-07 [2KCG iteration 46, residual = 1.6891127508427736e-07 [2KCG iteration 47, residual = 1.2565263891879758e-07 [2KCG iteration 48, residual = 9.126850516084458e-08 [2KCG iteration 49, residual = 7.155602920489478e-08 [2KCG iteration 50, residual = 6.314818937144577e-08 [2KCG iteration 51, residual = 5.1166575186131815e-08 [2KCG iteration 52, residual = 5.086059476302579e-08 [2KCG iteration 53, residual = 5.40736171208941e-08 [2KCG iteration 54, residual = 5.8740878739149184e-08 [2KCG iteration 55, residual = 5.555355890714011e-08 [2KCG iteration 56, residual = 5.0652144099958096e-08 [2KCG iteration 57, residual = 4.408078585645104e-08 [2KCG iteration 58, residual = 3.831687340130186e-08 [2KCG iteration 59, residual = 3.066336444212935e-08 [2KCG iteration 60, residual = 2.2528225930242947e-08 [2KCG iteration 61, residual = 1.6089797855285105e-08 [2KCG iteration 62, residual = 1.195577205920849e-08 [2KCG iteration 63, residual = 8.621520868469892e-09 [2KCG iteration 64, residual = 6.9939155849065115e-09 [2KCG iteration 65, residual = 5.8750299023592615e-09 [2KCG iteration 66, residual = 5.049119254206532e-09 [2KCG iteration 67, residual = 4.499694236680749e-09 [2KCG iteration 68, residual = 4.472050519021072e-09 [2KCG iteration 69, residual = 4.536443045073999e-09 [2KCG iteration 70, residual = 4.853595385347888e-09 [2KCG iteration 71, residual = 4.732651992062005e-09 [2KCG iteration 72, residual = 4.307074638236133e-09 [2KCG iteration 73, residual = 3.5651272352784777e-09 [2KCG iteration 74, residual = 2.7659211153758746e-09 [2KCG iteration 75, residual = 2.063513803171767e-09 [2KCG iteration 76, residual = 1.6171413383091029e-09 [2KCG iteration 77, residual = 1.1712523631411175e-09 [2KCG iteration 78, residual = 9.34782831506758e-10 [2KCG iteration 79, residual = 7.242739949873015e-10 [2KCG iteration 80, residual = 5.842777052913203e-10 [2KCG iteration 81, residual = 4.753412657929106e-10 [2KCG iteration 82, residual = 3.9133812012559064e-10 [2KCG iteration 83, residual = 3.612238098741856e-10 [2KCG iteration 84, residual = 3.7604330410910406e-10 [2KCG iteration 85, residual = 3.6959384289305024e-10 [2KCG iteration 86, residual = 4.017596279793326e-10 [2KCG iteration 87, residual = 3.904103395203695e-10 [2KCG iteration 88, residual = 3.676139377351832e-10 [2KCG iteration 89, residual = 3.245632270068751e-10 [2KCG iteration 90, residual = 2.7215150142709294e-10 [2KCG iteration 91, residual = 2.0936276782491604e-10 [2KCG iteration 92, residual = 1.5618384717674707e-10 [2KCG iteration 93, residual = 1.15415719037375e-10 [2KCG iteration 94, residual = 8.627398056833222e-11 [2KCG iteration 95, residual = 7.120120256083172e-11 [2KCG iteration 96, residual = 5.919231608994868e-11 [2KCG iteration 97, residual = 4.790091590368312e-11 [2KCG iteration 98, residual = 4.4132174954380714e-11 [2KCG iteration 99, residual = 4.1603158858677335e-11 [2KCG iteration 100, residual = 4.064194704729783e-11 [2KCG iteration 101, residual = 4.020444822397888e-11
CG iteration 102, residual = 4.491890083548554e-11CG iteration 103, residual = 4.158775606693585e-11 CG iteration 104, residual = 4.16990352423163e-11 CG iteration 105, residual = 3.476771620809102e-11 CG converged in 105 iterations to residual 3.476771620809102e-11
0.006CG iteration 1, residual = 0.0035035286092153983
CG iteration 2, residual = 0.0002759592659158552 CG iteration 3, residual = 0.00022811251166428826 CG iteration 4, residual = 0.00023432189229639745 CG iteration 5, residual = 0.00015291388367031714 CG iteration 6, residual = 7.608070162937595e-05 CG iteration 7, residual = 4.676290863563044e-05 CG iteration 8, residual = 4.3238828738860816e-05 CG iteration 9, residual = 3.2061047572677145e-05 CG iteration 10, residual = 2.4380494082994025e-05 CG iteration 11, residual = 3.1638419683314215e-05 CG iteration 12, residual = 3.911105449774653e-05 CG iteration 13, residual = 3.591088177022004e-05 CG iteration 14, residual = 3.581227011835114e-05 CG iteration 15, residual = 3.1650131825174315e-05 CG iteration 16, residual = 2.2298366569356726e-05 CG iteration 17, residual = 1.4371766605575064e-05 CG iteration 18, residual = 1.0642692400951325e-05 CG iteration 19, residual = 9.516452282229669e-06 CG iteration 20, residual = 7.811833195399216e-06 CG iteration 21, residual = 6.196063315645717e-06 CG iteration 22, residual = 5.993990376103824e-06 CG iteration 23, residual = 5.330322701594737e-06 CG iteration 24, residual = 5.252675137312832e-06 CG iteration 25, residual = 5.61070648885272e-06 CG iteration 26, residual = 5.9775232134393985e-06 CG iteration 27, residual = 5.638842675863878e-06 CG iteration 28, residual = 4.4508610238964495e-06 CG iteration 29, residual = 3.3964743955239902e-06 CG iteration 30, residual = 2.274467631116681e-06 CG iteration 31, residual = 1.7269169414786294e-06 CG iteration 32, residual = 1.373364630837313e-06 CG iteration 33, residual = 1.0515165296803114e-06 CG iteration 34, residual = 7.189050515935929e-07 CG iteration 35, residual = 5.438716233758866e-07 CG iteration 36, residual = 4.756604378214835e-07 CG iteration 37, residual = 4.3847991528172406e-07 CG iteration 38, residual = 4.6058241642949027e-07 CG iteration 39, residual = 4.767627997232533e-07 CG iteration 40, residual = 4.95262044715101e-07 CG iteration 41, residual = 4.42395853612247e-07 CG iteration 42, residual = 4.1467364439422626e-07 CG iteration 43, residual = 3.8258359584324623e-07 CG iteration 44, residual = 2.933760798654151e-07 CG iteration 45, residual = 2.1466124723103842e-07 CG iteration 46, residual = 1.6757742857147824e-07 CG iteration 47, residual = 1.2437485561369194e-07 CG iteration 48, residual = 9.030646202962386e-08 CG iteration 49, residual = 7.082442706051283e-08 CG iteration 50, residual = 6.265400596378523e-08 CG iteration 51, residual = 5.0894231982704554e-08 CG iteration 52, residual = 5.0499744235947116e-08 CG iteration 53, residual = 5.351969270638638e-08 CG iteration 54, residual = 5.820349772337298e-08 CG iteration 55, residual = 5.5117967756895774e-08 CG iteration 56, residual = 5.028256529294944e-08 CG iteration 57, residual = 4.367408240272757e-08 CG iteration 58, residual = 3.795977464173624e-08 CG iteration 59, residual = 3.044605495724445e-08 CG iteration 60, residual = 2.2424635176091383e-08 CG iteration 61, residual = 1.6038220155098253e-08 CG iteration 62, residual = 1.1893965771682426e-08 CG iteration 63, residual = 8.56279852037611e-09 CG iteration 64, residual = 6.935508892583012e-09 CG iteration 65, residual = 5.817894552963938e-09 CG iteration 66, residual = 5.010407142859323e-09 CG iteration 67, residual = 4.4650511762360824e-09 CG iteration 68, residual = 4.444278225099155e-09 CG iteration 69, residual = 4.5002826999199245e-09 CG iteration 70, residual = 4.810664449390959e-09 CG iteration 71, residual = 4.697745190745741e-09 CG iteration 72, residual = 4.283613575719898e-09 CG iteration 73, residual = 3.5448037819647495e-09 CG iteration 74, residual = 2.7527303185519133e-09 CG iteration 75, residual = 2.050976891615919e-09 CG iteration 76, residual = 1.6087954298603223e-09 CG iteration 77, residual = 1.1663589716767435e-09 CG iteration 78, residual = 9.298576244709202e-10 CG iteration 79, residual = 7.207435056123458e-10 CG iteration 80, residual = 5.832099143743078e-10 CG iteration 81, residual = 4.743507806195524e-10 CG iteration 82, residual = 3.895710819914277e-10 CG iteration 83, residual = 3.605376349771006e-10 CG iteration 84, residual = 3.7461862047532905e-10 CG iteration 85, residual = 3.689743252280977e-10 CG iteration 86, residual = 4.018528148128414e-10 CG iteration 87, residual = 3.902287771787478e-10 CG iteration 88, residual = 3.6667080429631193e-10 CG iteration 89, residual = 3.229327307581091e-10 CG iteration 90, residual = 2.716769573189225e-10 CG iteration 91, residual = 2.0836524130977212e-10 CG iteration 92, residual = 1.5596144423770754e-10 CG iteration 93, residual = 1.1521374987253797e-10 CG iteration 94, residual = 8.588197755183394e-11 CG iteration 95, residual = 7.099232289246309e-11 CG iteration 96, residual = 5.908291014586183e-11 CG iteration 97, residual = 4.787721809887845e-11 CG iteration 98, residual = 4.405362718263661e-11 CG iteration 99, residual = 4.1691711312690595e-11 CG iteration 100, residual = 4.058586580834294e-11 CG iteration 101, residual = 4.01922449446999e-11 CG iteration 102, residual = 4.47814089101807e-11 CG iteration 103, residual = 4.1557756436049456e-11 CG iteration 104, residual = 4.1718802268427074e-11 CG iteration 105, residual = 3.4691128105411784e-11 CG converged in 105 iterations to residual 3.4691128105411784e-11
- 0.007
</pre>
- 0.007
end{sphinxVerbatim}
[2KCG iteration 103, residual = 4.158775606693585e-11 [2KCG iteration 104, residual = 4.16990352423163e-11 [2KCG iteration 105, residual = 3.476771620809102e-11 [2KCG converged in 105 iterations to residual 3.476771620809102e-11
0.006[2KCG iteration 1, residual = 0.0035035286092153983
[2KCG iteration 2, residual = 0.0002759592659158552 [2KCG iteration 3, residual = 0.00022811251166428826 [2KCG iteration 4, residual = 0.00023432189229639745 [2KCG iteration 5, residual = 0.00015291388367031714 [2KCG iteration 6, residual = 7.608070162937595e-05 [2KCG iteration 7, residual = 4.676290863563044e-05 [2KCG iteration 8, residual = 4.3238828738860816e-05 [2KCG iteration 9, residual = 3.2061047572677145e-05 [2KCG iteration 10, residual = 2.4380494082994025e-05 [2KCG iteration 11, residual = 3.1638419683314215e-05 [2KCG iteration 12, residual = 3.911105449774653e-05 [2KCG iteration 13, residual = 3.591088177022004e-05 [2KCG iteration 14, residual = 3.581227011835114e-05 [2KCG iteration 15, residual = 3.1650131825174315e-05 [2KCG iteration 16, residual = 2.2298366569356726e-05 [2KCG iteration 17, residual = 1.4371766605575064e-05 [2KCG iteration 18, residual = 1.0642692400951325e-05 [2KCG iteration 19, residual = 9.516452282229669e-06 [2KCG iteration 20, residual = 7.811833195399216e-06 [2KCG iteration 21, residual = 6.196063315645717e-06 [2KCG iteration 22, residual = 5.993990376103824e-06 [2KCG iteration 23, residual = 5.330322701594737e-06 [2KCG iteration 24, residual = 5.252675137312832e-06 [2KCG iteration 25, residual = 5.61070648885272e-06 [2KCG iteration 26, residual = 5.9775232134393985e-06 [2KCG iteration 27, residual = 5.638842675863878e-06 [2KCG iteration 28, residual = 4.4508610238964495e-06 [2KCG iteration 29, residual = 3.3964743955239902e-06 [2KCG iteration 30, residual = 2.274467631116681e-06 [2KCG iteration 31, residual = 1.7269169414786294e-06 [2KCG iteration 32, residual = 1.373364630837313e-06 [2KCG iteration 33, residual = 1.0515165296803114e-06 [2KCG iteration 34, residual = 7.189050515935929e-07 [2KCG iteration 35, residual = 5.438716233758866e-07 [2KCG iteration 36, residual = 4.756604378214835e-07 [2KCG iteration 37, residual = 4.3847991528172406e-07 [2KCG iteration 38, residual = 4.6058241642949027e-07 [2KCG iteration 39, residual = 4.767627997232533e-07 [2KCG iteration 40, residual = 4.95262044715101e-07 [2KCG iteration 41, residual = 4.42395853612247e-07 [2KCG iteration 42, residual = 4.1467364439422626e-07 [2KCG iteration 43, residual = 3.8258359584324623e-07 [2KCG iteration 44, residual = 2.933760798654151e-07 [2KCG iteration 45, residual = 2.1466124723103842e-07 [2KCG iteration 46, residual = 1.6757742857147824e-07 [2KCG iteration 47, residual = 1.2437485561369194e-07 [2KCG iteration 48, residual = 9.030646202962386e-08 [2KCG iteration 49, residual = 7.082442706051283e-08 [2KCG iteration 50, residual = 6.265400596378523e-08 [2KCG iteration 51, residual = 5.0894231982704554e-08 [2KCG iteration 52, residual = 5.0499744235947116e-08 [2KCG iteration 53, residual = 5.351969270638638e-08 [2KCG iteration 54, residual = 5.820349772337298e-08 [2KCG iteration 55, residual = 5.5117967756895774e-08 [2KCG iteration 56, residual = 5.028256529294944e-08 [2KCG iteration 57, residual = 4.367408240272757e-08 [2KCG iteration 58, residual = 3.795977464173624e-08 [2KCG iteration 59, residual = 3.044605495724445e-08 [2KCG iteration 60, residual = 2.2424635176091383e-08 [2KCG iteration 61, residual = 1.6038220155098253e-08 [2KCG iteration 62, residual = 1.1893965771682426e-08 [2KCG iteration 63, residual = 8.56279852037611e-09 [2KCG iteration 64, residual = 6.935508892583012e-09 [2KCG iteration 65, residual = 5.817894552963938e-09 [2KCG iteration 66, residual = 5.010407142859323e-09 [2KCG iteration 67, residual = 4.4650511762360824e-09 [2KCG iteration 68, residual = 4.444278225099155e-09 [2KCG iteration 69, residual = 4.5002826999199245e-09 [2KCG iteration 70, residual = 4.810664449390959e-09 [2KCG iteration 71, residual = 4.697745190745741e-09 [2KCG iteration 72, residual = 4.283613575719898e-09 [2KCG iteration 73, residual = 3.5448037819647495e-09 [2KCG iteration 74, residual = 2.7527303185519133e-09 [2KCG iteration 75, residual = 2.050976891615919e-09 [2KCG iteration 76, residual = 1.6087954298603223e-09 [2KCG iteration 77, residual = 1.1663589716767435e-09 [2KCG iteration 78, residual = 9.298576244709202e-10 [2KCG iteration 79, residual = 7.207435056123458e-10 [2KCG iteration 80, residual = 5.832099143743078e-10 [2KCG iteration 81, residual = 4.743507806195524e-10 [2KCG iteration 82, residual = 3.895710819914277e-10 [2KCG iteration 83, residual = 3.605376349771006e-10 [2KCG iteration 84, residual = 3.7461862047532905e-10 [2KCG iteration 85, residual = 3.689743252280977e-10 [2KCG iteration 86, residual = 4.018528148128414e-10 [2KCG iteration 87, residual = 3.902287771787478e-10 [2KCG iteration 88, residual = 3.6667080429631193e-10 [2KCG iteration 89, residual = 3.229327307581091e-10 [2KCG iteration 90, residual = 2.716769573189225e-10 [2KCG iteration 91, residual = 2.0836524130977212e-10 [2KCG iteration 92, residual = 1.5596144423770754e-10 [2KCG iteration 93, residual = 1.1521374987253797e-10 [2KCG iteration 94, residual = 8.588197755183394e-11 [2KCG iteration 95, residual = 7.099232289246309e-11 [2KCG iteration 96, residual = 5.908291014586183e-11 [2KCG iteration 97, residual = 4.787721809887845e-11 [2KCG iteration 98, residual = 4.405362718263661e-11 [2KCG iteration 99, residual = 4.1691711312690595e-11 [2KCG iteration 100, residual = 4.058586580834294e-11 [2KCG iteration 101, residual = 4.01922449446999e-11 [2KCG iteration 102, residual = 4.47814089101807e-11 [2KCG iteration 103, residual = 4.1557756436049456e-11 [2KCG iteration 104, residual = 4.1718802268427074e-11 [2KCG iteration 105, residual = 3.4691128105411784e-11 [2KCG converged in 105 iterations to residual 3.4691128105411784e-11
0.007
CG iteration 1, residual = 0.0035032359873999218CG iteration 2, residual = 0.0002750686889839861 CG iteration 3, residual = 0.00022645236424686792 CG iteration 4, residual = 0.00023312234756122418 CG iteration 5, residual = 0.00015276041542403374 CG iteration 6, residual = 7.58341835750697e-05 CG iteration 7, residual = 4.627263953922736e-05 CG iteration 8, residual = 4.2718819246877436e-05 CG iteration 9, residual = 3.182631877961638e-05 CG iteration 10, residual = 2.4220380243662486e-05 CG iteration 11, residual = 3.14595874060773e-05 CG iteration 12, residual = 3.901646734101507e-05 CG iteration 13, residual = 3.583330431608987e-05 CG iteration 14, residual = 3.567461702883674e-05 CG iteration 15, residual = 3.148073165334667e-05 CG iteration 16, residual = 2.2166382579100016e-05 CG iteration 17, residual = 1.4297135535467055e-05 CG iteration 18, residual = 1.0573712703047232e-05 CG iteration 19, residual = 9.421794754359285e-06 CG iteration 20, residual = 7.746755350505863e-06 CG iteration 21, residual = 6.154664551594531e-06 CG iteration 22, residual = 5.939272197933574e-06 CG iteration 23, residual = 5.276459266215908e-06 CG iteration 24, residual = 5.196609925346973e-06 CG iteration 25, residual = 5.538682965668864e-06 CG iteration 26, residual = 5.8991945328587934e-06 CG iteration 27, residual = 5.5797598330275944e-06 CG iteration 28, residual = 4.413510979296905e-06 CG iteration 29, residual = 3.3666376298208826e-06 CG iteration 30, residual = 2.2452882326391113e-06 CG iteration 31, residual = 1.6994337509772435e-06 CG iteration 32, residual = 1.3558290849669754e-06 CG iteration 33, residual = 1.0409175827035707e-06 CG iteration 34, residual = 7.127333667075153e-07 CG iteration 35, residual = 5.396675907606964e-07 CG iteration 36, residual = 4.72205013666961e-07 CG iteration 37, residual = 4.348764740884112e-07 CG iteration 38, residual = 4.5718431911457165e-07 CG iteration 39, residual = 4.7340791628123507e-07 CG iteration 40, residual = 4.927088993136339e-07 CG iteration 41, residual = 4.391531850458396e-07 CG iteration 42, residual = 4.113987651382028e-07 CG iteration 43, residual = 3.794922193124094e-07 CG iteration 44, residual = 2.9109756499676567e-07 CG iteration 45, residual = 2.1324564399383787e-07 CG iteration 46, residual = 1.6627336811097583e-07 CG iteration 47, residual = 1.2312769234805485e-07 CG iteration 48, residual = 8.937277307671138e-08 CG iteration 49, residual = 7.010961372645455e-08 CG iteration 50, residual = 6.21670988648115e-08 CG iteration 51, residual = 5.0634889041096177e-08 CG iteration 52, residual = 5.0156867412009396e-08 CG iteration 53, residual = 5.2985505712223207e-08 CG iteration 54, residual = 5.767970697812972e-08 CG iteration 55, residual = 5.469629239853854e-08 CG iteration 56, residual = 4.9926669275049873e-08 CG iteration 57, residual = 4.328025477804508e-08 CG iteration 58, residual = 3.7614714219434755e-08 CG iteration 59, residual = 3.0234344869510815e-08 CG iteration 60, residual = 2.2321510508821452e-08 CG iteration 61, residual = 1.5987720699066844e-08 CG iteration 62, residual = 1.1833533384634566e-08 CG iteration 63, residual = 8.50537395544075e-09 CG iteration 64, residual = 6.878441894899852e-09 CG iteration 65, residual = 5.761983764233123e-09 CG iteration 66, residual = 4.972693356531784e-09 CG iteration 67, residual = 4.431724591050761e-09 CG iteration 68, residual = 4.417548960891507e-09 CG iteration 69, residual = 4.4656741528393045e-09 CG iteration 70, residual = 4.769736626048566e-09 CG iteration 71, residual = 4.663855446559244e-09 CG iteration 72, residual = 4.260094290167396e-09 CG iteration 73, residual = 3.5248177941134233e-09 CG iteration 74, residual = 2.740229622904957e-09 CG iteration 75, residual = 2.038867122976052e-09 CG iteration 76, residual = 1.6004762546549356e-09 CG iteration 77, residual = 1.1616392509062596e-09 CG iteration 78, residual = 9.250014804195558e-10 CG iteration 79, residual = 7.17219017068161e-10 CG iteration 80, residual = 5.820253707439526e-10 CG iteration 81, residual = 4.732654767325132e-10 CG iteration 82, residual = 3.8782173115184395e-10 CG iteration 83, residual = 3.5977423876347744e-10 CG iteration 84, residual = 3.7302851759288413e-10 CG iteration 85, residual = 3.6830280755487837e-10 CG iteration 86, residual = 4.017834658377652e-10 CG iteration 87, residual = 3.899521576963381e-10 CG iteration 88, residual = 3.6570157552701856e-10 CG iteration 89, residual = 3.2127546788038833e-10 CG iteration 90, residual = 2.711297721736933e-10 CG iteration 91, residual = 2.0734495014581667e-10 CG iteration 92, residual = 1.5574578367531602e-10 CG iteration 93, residual = 1.1500890018830262e-10 CG iteration 94, residual = 8.550514624459791e-11 CG iteration 95, residual = 7.078689243544217e-11 CG iteration 96, residual = 5.896348311675296e-11 CG iteration 97, residual = 4.784779869934026e-11 CG iteration 98, residual = 4.396629412487457e-11 CG iteration 99, residual = 4.176303901853545e-11 CG iteration 100, residual = 4.051650400264211e-11 CG iteration 101, residual = 4.0175161381866904e-11 CG iteration 102, residual = 4.4618167406670105e-11 CG iteration 103, residual = 4.1520657896185674e-11 CG iteration 104, residual = 4.1718098506166706e-11 CG iteration 105, residual = 3.461741248001953e-11 CG converged in 105 iterations to residual 3.461741248001953e-11
0.008CG iteration 1, residual = 0.0035029473093459783
CG iteration 2, residual = 0.00027421508828574895 CG iteration 3, residual = 0.0002248772653238142 CG iteration 4, residual = 0.00023198006782189888 CG iteration 5, residual = 0.00015262097917500205 CG iteration 6, residual = 7.559880769776822e-05 CG iteration 7, residual = 4.5797769220984376e-05 CG iteration 8, residual = 4.221480814326149e-05 CG iteration 9, residual = 3.16031752680329e-05 CG iteration 10, residual = 2.4073394628486208e-05 CG iteration 11, residual = 3.129915705600602e-05 CG iteration 12, residual = 3.894087005586668e-05 CG iteration 13, residual = 3.5768955400890746e-05 CG iteration 14, residual = 3.554376064098869e-05 CG iteration 15, residual = 3.131423099735442e-05 CG iteration 16, residual = 2.2036424734971373e-05 CG iteration 17, residual = 1.4223367207566257e-05 CG iteration 18, residual = 1.0506689208018065e-05 CG iteration 19, residual = 9.330136209376993e-06 CG iteration 20, residual = 7.683029090267576e-06 CG iteration 21, residual = 6.113484379101787e-06 CG iteration 22, residual = 5.885025042106566e-06 CG iteration 23, residual = 5.223535627293794e-06 CG iteration 24, residual = 5.141863494891891e-06 CG iteration 25, residual = 5.468746038120987e-06 CG iteration 26, residual = 5.823231590571083e-06 CG iteration 27, residual = 5.521886736257287e-06 CG iteration 28, residual = 4.376703651602523e-06 CG iteration 29, residual = 3.3376706339162312e-06 CG iteration 30, residual = 2.2171868406254252e-06 CG iteration 31, residual = 1.672792767758826e-06 CG iteration 32, residual = 1.3386548104688302e-06 CG iteration 33, residual = 1.0305130862973242e-06 CG iteration 34, residual = 7.067461662344357e-07 CG iteration 35, residual = 5.356255310302682e-07 CG iteration 36, residual = 4.688831749196208e-07 CG iteration 37, residual = 4.313826219592502e-07 CG iteration 38, residual = 4.5386646784034543e-07 CG iteration 39, residual = 4.701216001725784e-07 CG iteration 40, residual = 4.902183377831884e-07 CG iteration 41, residual = 4.360368729060584e-07 CG iteration 42, residual = 4.082453977406901e-07 CG iteration 43, residual = 3.7647542010234853e-07 CG iteration 44, residual = 2.8886539696181395e-07 CG iteration 45, residual = 2.1186449522204714e-07 CG iteration 46, residual = 1.6499589119050878e-07 CG iteration 47, residual = 1.2190957117306952e-07 CG iteration 48, residual = 8.846624889507519e-08 CG iteration 49, residual = 6.941104636979199e-08 CG iteration 50, residual = 6.16872094581884e-08 CG iteration 51, residual = 5.038753013625115e-08 CG iteration 52, residual = 4.983039656755185e-08 CG iteration 53, residual = 5.247008390976361e-08 CG iteration 54, residual = 5.716910591605958e-08 CG iteration 55, residual = 5.428748353079821e-08 CG iteration 56, residual = 4.958318439890501e-08 CG iteration 57, residual = 4.2898564243225053e-08 CG iteration 58, residual = 3.7281157005313506e-08 CG iteration 59, residual = 3.002776440243458e-08 CG iteration 60, residual = 2.2218648428225986e-08 CG iteration 61, residual = 1.5938098508875774e-08 CG iteration 62, residual = 1.1774181206313143e-08 CG iteration 63, residual = 8.449060758946971e-09 CG iteration 64, residual = 6.8226164561097e-09 CG iteration 65, residual = 5.707202811527226e-09 CG iteration 66, residual = 4.935899609900094e-09 CG iteration 67, residual = 4.3996137150213855e-09 CG iteration 68, residual = 4.391740918202749e-09 CG iteration 69, residual = 4.432469584793771e-09 CG iteration 70, residual = 4.7306579228107756e-09 CG iteration 71, residual = 4.63088783505528e-09 CG iteration 72, residual = 4.2364390075792334e-09 CG iteration 73, residual = 3.5050852931117586e-09 CG iteration 74, residual = 2.728340144892914e-09 CG iteration 75, residual = 2.02714366584515e-09 CG iteration 76, residual = 1.592168881157063e-09 CG iteration 77, residual = 1.1570648721675374e-09 CG iteration 78, residual = 9.201971457713231e-10 CG iteration 79, residual = 7.136954050056955e-10 CG iteration 80, residual = 5.807103619722854e-10 CG iteration 81, residual = 4.720765466601165e-10 CG iteration 82, residual = 3.8607951071626393e-10 CG iteration 83, residual = 3.589209146651929e-10 CG iteration 84, residual = 3.712764386207167e-10 CG iteration 85, residual = 3.675689850300504e-10 CG iteration 86, residual = 4.015333966656753e-10 CG iteration 87, residual = 3.8957523752270005e-10 CG iteration 88, residual = 3.647004879233403e-10 CG iteration 89, residual = 3.195884739008916e-10 CG iteration 90, residual = 2.705066388725217e-10 CG iteration 91, residual = 2.0630252575756308e-10 CG iteration 92, residual = 1.5553382737966527e-10 CG iteration 93, residual = 1.1479803337485627e-10 CG iteration 94, residual = 8.51425676423377e-11 CG iteration 95, residual = 7.058420709798289e-11 CG iteration 96, residual = 5.883281062765201e-11 CG iteration 97, residual = 4.7811812655496756e-11 CG iteration 98, residual = 4.386949899726627e-11 CG iteration 99, residual = 4.181550718924521e-11 CG iteration 100, residual = 4.0433484816714e-11 CG iteration 101, residual = 4.015183055311352e-11 CG iteration 102, residual = 4.442945542946559e-11 CG iteration 103, residual = 4.147595921683343e-11 CG iteration 104, residual = 4.1695949275600026e-11 CG iteration 105, residual = 3.454608343928488e-11 CG converged in 105 iterations to residual 3.454608343928488e-11
0.009000000000000001CG iteration 1, residual = 0.003502662128308906
CG iteration 2, residual = 0.0002733961580586486 CG iteration 3, residual = 0.00022338210572804754 CG iteration 4, residual = 0.00023089237760424321 CG iteration 5, residual = 0.00015249455460110268 CG iteration 6, residual = 7.537368993756873e-05 CG iteration 7, residual = 4.533728160404172e-05 CG iteration 8, residual = 4.1725823073207305e-05 CG iteration 9, residual = 3.139085985595972e-05 CG iteration 10, residual = 2.393857682546425e-05 CG iteration 11, residual = 3.115564588412961e-05 CG iteration 12, residual = 3.8882643454023555e-05 CG iteration 13, residual = 3.571641054249972e-05 CG iteration 14, residual = 3.5418574322292915e-05 CG iteration 15, residual = 3.11499785767884e-05 CG iteration 16, residual = 2.1908142273651232e-05 CG iteration 17, residual = 1.4150286856343285e-05 CG iteration 18, residual = 1.0441454373612276e-05 CG iteration 19, residual = 9.241328153343562e-06 CG iteration 20, residual = 7.620636514060706e-06 CG iteration 21, residual = 6.072556690728821e-06 CG iteration 22, residual = 5.831280401798344e-06 CG iteration 23, residual = 5.171552035305625e-06 CG iteration 24, residual = 5.088433456712848e-06 CG iteration 25, residual = 5.400888980615864e-06 CG iteration 26, residual = 5.749618803588539e-06 CG iteration 27, residual = 5.4652298426785685e-06 CG iteration 28, residual = 4.340428019234299e-06 CG iteration 29, residual = 3.3095243448734007e-06 CG iteration 30, residual = 2.190106491957804e-06 CG iteration 31, residual = 1.6469698341651686e-06 CG iteration 32, residual = 1.3218455801476592e-06 CG iteration 33, residual = 1.0203003121202036e-06 CG iteration 34, residual = 7.00932086123721e-07 CG iteration 35, residual = 5.317364541652891e-07 CG iteration 36, residual = 4.656890837965646e-07 CG iteration 37, residual = 4.27992304135359e-07 CG iteration 38, residual = 4.5062446893638635e-07 CG iteration 39, residual = 4.669015030866264e-07 CG iteration 40, residual = 4.877868075538506e-07 CG iteration 41, residual = 4.330394123302469e-07 CG iteration 42, residual = 4.052082334687157e-07 CG iteration 43, residual = 3.735301057074921e-07 CG iteration 44, residual = 2.8667617571282414e-07 CG iteration 45, residual = 2.1051442106783963e-07 CG iteration 46, residual = 1.6374206646701922e-07 CG iteration 47, residual = 1.2071901392849428e-07 CG iteration 48, residual = 8.758581227070713e-08 CG iteration 49, residual = 6.872828228155403e-08 CG iteration 50, residual = 6.121417001051295e-08 CG iteration 51, residual = 5.0151269636358754e-08 CG iteration 52, residual = 4.9518934666061526e-08 CG iteration 53, residual = 5.197255796328209e-08 CG iteration 54, residual = 5.6671364045801356e-08 CG iteration 55, residual = 5.3890665508027054e-08 CG iteration 56, residual = 4.9250990673525076e-08 CG iteration 57, residual = 4.252834758552273e-08 CG iteration 58, residual = 3.695861035805556e-08 CG iteration 59, residual = 2.9825904130623685e-08 CG iteration 60, residual = 2.2115889751929245e-08 CG iteration 61, residual = 1.5889175302468954e-08 CG iteration 62, residual = 1.1715645518288366e-08 CG iteration 63, residual = 8.39369983330021e-09 CG iteration 64, residual = 6.76795060428918e-09 CG iteration 65, residual = 5.653472630808413e-09 CG iteration 66, residual = 4.899964384419662e-09 CG iteration 67, residual = 4.36863428578233e-09 CG iteration 68, residual = 4.3667530691064595e-09 CG iteration 69, residual = 4.400547372777094e-09 CG iteration 70, residual = 4.693294291888226e-09 CG iteration 71, residual = 4.598761635503694e-09 CG iteration 72, residual = 4.212592221491459e-09 CG iteration 73, residual = 3.4855406098705326e-09 CG iteration 74, residual = 2.716991435767891e-09 CG iteration 75, residual = 2.0157709857331386e-09 CG iteration 76, residual = 1.5838634669316474e-09 CG iteration 77, residual = 1.1526122729912733e-09 CG iteration 78, residual = 9.154312669559457e-10 CG iteration 79, residual = 7.101698092202335e-10 CG iteration 80, residual = 5.792552227597966e-10 CG iteration 81, residual = 4.707796861428189e-10 CG iteration 82, residual = 3.8433731491573193e-10 CG iteration 83, residual = 3.579693878043894e-10 CG iteration 84, residual = 3.6937100778945984e-10 CG iteration 85, residual = 3.6676767617863585e-10 CG iteration 86, residual = 4.0109118363130003e-10 CG iteration 87, residual = 3.8909755012045603e-10 CG iteration 88, residual = 3.6366506316000883e-10 CG iteration 89, residual = 3.178715557809716e-10 CG iteration 90, residual = 2.698062845955147e-10 CG iteration 91, residual = 2.0523980313080055e-10 CG iteration 92, residual = 1.5532327398883304e-10 CG iteration 93, residual = 1.1457869356614805e-10 CG iteration 94, residual = 8.479377607996318e-11 CG iteration 95, residual = 7.038385540779504e-11 CG iteration 96, residual = 5.869019302609398e-11 CG iteration 97, residual = 4.776889816676659e-11 CG iteration 98, residual = 4.376296421659705e-11 CG iteration 99, residual = 4.1848085749968565e-11 CG iteration 100, residual = 4.033701382625414e-11 CG iteration 101, residual = 4.012138383792075e-11 CG iteration 102, residual = 4.42162262547217e-11 CG iteration 103, residual = 4.142363082579474e-11 CG iteration 104, residual = 4.165191524769749e-11 CG iteration 105, residual = 3.4476873407271355e-11 CG converged in 105 iterations to residual 3.4476873407271355e-11
0.01CG iteration 1, residual = 0.003502380033659947
CG iteration 2, residual = 0.0002726097547274006 CG iteration 3, residual = 0.00022196212399513062 CG iteration 4, residual = 0.00022985671101846778 CG iteration 5, residual = 0.00015238019421120615 CG iteration 6, residual = 7.51580214644945e-05 CG iteration 7, residual = 4.489024345630351e-05 CG iteration 8, residual = 4.125096006274376e-05 CG iteration 9, residual = 3.1188672355801257e-05 CG iteration 10, residual = 2.3815045030688157e-05 CG iteration 11, residual = 3.102768042903796e-05 CG iteration 12, residual = 3.8840275375384565e-05 CG iteration 13, residual = 3.567435232037147e-05 CG iteration 14, residual = 3.529803567288964e-05 CG iteration 15, residual = 3.098740277435999e-05 CG iteration 16, residual = 2.178123838138312e-05 CG iteration 17, residual = 1.4077754782036818e-05 CG iteration 18, residual = 1.0377866592549592e-05 CG iteration 19, residual = 9.15523899098614e-06 CG iteration 20, residual = 7.559566003024353e-06 CG iteration 21, residual = 6.031920425364622e-06 CG iteration 22, residual = 5.778074456705057e-06 CG iteration 23, residual = 5.120513647492993e-06 CG iteration 24, residual = 5.036320597265847e-06 CG iteration 25, residual = 5.3351045557967205e-06 CG iteration 26, residual = 5.678339295681478e-06 CG iteration 27, residual = 5.409796523785784e-06 CG iteration 28, residual = 4.304675414434872e-06 CG iteration 29, residual = 3.2821523140029275e-06 CG iteration 30, residual = 2.16399301725177e-06 CG iteration 31, residual = 1.6219407202713273e-06 CG iteration 32, residual = 1.305404014784963e-06 CG iteration 33, residual = 1.0102770918937598e-06 CG iteration 34, residual = 6.952810406774719e-07 CG iteration 35, residual = 5.279919258485627e-07 CG iteration 36, residual = 4.6261705797398864e-07 CG iteration 37, residual = 4.2470006467965734e-07 CG iteration 38, residual = 4.474546361639796e-07 CG iteration 39, residual = 4.6374574311293387e-07 CG iteration 40, residual = 4.854113950682164e-07 CG iteration 41, residual = 4.3015421549360216e-07 CG iteration 42, residual = 4.0228230786784797e-07 CG iteration 43, residual = 3.706532621228378e-07 CG iteration 44, residual = 2.8452687164637306e-07 CG iteration 45, residual = 2.091924343535237e-07 CG iteration 46, residual = 1.6250921970407998e-07 CG iteration 47, residual = 1.195546400800841e-07 CG iteration 48, residual = 8.67304815438121e-08 CG iteration 49, residual = 6.806095808529461e-08 CG iteration 50, residual = 6.074788727692672e-08 CG iteration 51, residual = 4.992533526311685e-08 CG iteration 52, residual = 4.922123442452049e-08 CG iteration 53, residual = 5.1492144047914836e-08 CG iteration 54, residual = 5.618620389650547e-08 CG iteration 55, residual = 5.350511030635357e-08 CG iteration 56, residual = 4.8929102090289054e-08 CG iteration 57, residual = 4.216900848468387e-08 CG iteration 58, residual = 3.6646618410066895e-08 CG iteration 59, residual = 2.962840786650546e-08 CG iteration 60, residual = 2.2013113312900614e-08 CG iteration 61, residual = 1.584079223593435e-08 CG iteration 62, residual = 1.1657690914791463e-08 CG iteration 63, residual = 8.3391569628211e-09 CG iteration 64, residual = 6.714376104798902e-09 CG iteration 65, residual = 5.600727643483912e-09 CG iteration 66, residual = 4.864840368271474e-09 CG iteration 67, residual = 4.338715932158479e-09 CG iteration 68, residual = 4.342502375382904e-09 CG iteration 69, residual = 4.369808111949748e-09 CG iteration 70, residual = 4.65752869454865e-09 CG iteration 71, residual = 4.567408146305653e-09 CG iteration 72, residual = 4.188517803401357e-09 CG iteration 73, residual = 3.466133970012487e-09 CG iteration 74, residual = 2.706120641551398e-09 CG iteration 75, residual = 2.0047181531239997e-09 CG iteration 76, residual = 1.5755542961540034e-09 CG iteration 77, residual = 1.1482620000222128e-09 CG iteration 78, residual = 9.106938082531891e-10 CG iteration 79, residual = 7.066411097478733e-10 CG iteration 80, residual = 5.776537437209587e-10 CG iteration 81, residual = 4.69374276835515e-10 CG iteration 82, residual = 3.825907714019758e-10 CG iteration 83, residual = 3.569150181599826e-10 CG iteration 84, residual = 3.6732466575182557e-10 CG iteration 85, residual = 3.658976601011072e-10 CG iteration 86, residual = 4.0045105468152646e-10 CG iteration 87, residual = 3.8852220904930823e-10 CG iteration 88, residual = 3.6259520276500023e-10 CG iteration 89, residual = 3.161265750436436e-10 CG iteration 90, residual = 2.690290121302419e-10 CG iteration 91, residual = 2.041594773250882e-10 CG iteration 92, residual = 1.551123446744987e-10 CG iteration 93, residual = 1.1434900221904848e-10 CG iteration 94, residual = 8.445863289708183e-11 CG iteration 95, residual = 7.018559436622032e-11 CG iteration 96, residual = 5.853535617300854e-11 CG iteration 97, residual = 4.771905868863811e-11 CG iteration 98, residual = 4.3646690210442704e-11 CG iteration 99, residual = 4.1860225192276064e-11 CG iteration 100, residual = 4.0227712164506265e-11 CG iteration 101, residual = 4.0083302726709826e-11 CG iteration 102, residual = 4.3979925392114605e-11 CG iteration 103, residual = 4.136396618022225e-11 CG iteration 104, residual = 4.15859759730723e-11 CG iteration 105, residual = 3.440966273646705e-11 CG converged in 105 iterations to residual 3.440966273646705e-11
0.011CG iteration 1, residual = 0.0035021006481831423
CG iteration 2, residual = 0.0002718538850112676 CG iteration 3, residual = 0.00022061288143513896 CG iteration 4, residual = 0.00022887061058604906 CG iteration 5, residual = 0.00015227701787613745 CG iteration 6, residual = 7.495106273327453e-05 CG iteration 7, residual = 4.445579806910077e-05 CG iteration 8, residual = 4.078937925034008e-05 CG iteration 9, residual = 3.099596542376602e-05 CG iteration 10, residual = 2.370199019382273e-05 CG iteration 11, residual = 3.091398975415892e-05 CG iteration 12, residual = 3.881235546069116e-05 CG iteration 13, residual = 3.564156498739677e-05 CG iteration 14, residual = 3.518122123281789e-05 CG iteration 15, residual = 3.082600585773836e-05 CG iteration 16, residual = 2.1655464902414863e-05 CG iteration 17, residual = 1.4005662160599732e-05 CG iteration 18, residual = 1.0315806681086997e-05 CG iteration 19, residual = 9.071751426288473e-06 CG iteration 20, residual = 7.499810160848459e-06 CG iteration 21, residual = 5.991617208328718e-06 CG iteration 22, residual = 5.725445691060445e-06 CG iteration 23, residual = 5.070428548884417e-06 CG iteration 24, residual = 4.985527006059895e-06 CG iteration 25, residual = 5.271383549085767e-06 CG iteration 26, residual = 5.609373808803841e-06 CG iteration 27, residual = 5.35559385621884e-06 CG iteration 28, residual = 4.269438756887526e-06 CG iteration 29, residual = 3.2555105438158077e-06 CG iteration 30, residual = 2.1387949694167225e-06 CG iteration 31, residual = 1.5976812188602249e-06 CG iteration 32, residual = 1.2893316429280249e-06 CG iteration 33, residual = 1.0004417211922102e-06 CG iteration 34, residual = 6.897840901520908e-07 CG iteration 35, residual = 5.243840255815522e-07 CG iteration 36, residual = 4.5966156721433035e-07 CG iteration 37, residual = 4.2150096931744257e-07 CG iteration 38, residual = 4.443538848404053e-07 CG iteration 39, residual = 4.6065283290989485e-07 CG iteration 40, residual = 4.830897381517374e-07 CG iteration 41, residual = 4.2737548313313355e-07 CG iteration 42, residual = 3.9946295197687025e-07 CG iteration 43, residual = 3.67841948321673e-07 CG iteration 44, residual = 2.824147757925146e-07 CG iteration 45, residual = 2.0789589173131395e-07 CG iteration 46, residual = 1.6129492035737293e-07 CG iteration 47, residual = 1.1841516378549959e-07 CG iteration 48, residual = 8.589935624350219e-08 CG iteration 49, residual = 6.740877210708025e-08 CG iteration 50, residual = 6.028832767446454e-08 CG iteration 51, residual = 4.970905209269985e-08 CG iteration 52, residual = 4.8936179458979007e-08 CG iteration 53, residual = 5.102812884013203e-08 CG iteration 54, residual = 5.5713386456216665e-08 CG iteration 55, residual = 5.31302137097767e-08 CG iteration 56, residual = 4.861665040072241e-08 CG iteration 57, residual = 4.182000980003601e-08 CG iteration 58, residual = 3.634475696645311e-08 CG iteration 59, residual = 2.943496592670783e-08 CG iteration 60, residual = 2.1910230283046187e-08 CG iteration 61, residual = 1.579280705863876e-08 CG iteration 62, residual = 1.1600108590182874e-08 CG iteration 63, residual = 8.285320437518471e-09 CG iteration 64, residual = 6.661836354283547e-09 CG iteration 65, residual = 5.548913798710975e-09 CG iteration 66, residual = 4.830492081865183e-09 CG iteration 67, residual = 4.309799842489668e-09 CG iteration 68, residual = 4.3189212813063876e-09 CG iteration 69, residual = 4.34017099180728e-09 CG iteration 70, residual = 4.6232584139824476e-09 CG iteration 71, residual = 4.536768760591724e-09 CG iteration 72, residual = 4.1641963248542626e-09 CG iteration 73, residual = 3.4468292324947447e-09 CG iteration 74, residual = 2.695671688819309e-09 CG iteration 75, residual = 1.993958240361938e-09 CG iteration 76, residual = 1.5672389546203053e-09 CG iteration 77, residual = 1.1439981083103573e-09 CG iteration 78, residual = 9.05977509128941e-10 CG iteration 79, residual = 7.031094857182288e-10 CG iteration 80, residual = 5.759026539780105e-10 CG iteration 81, residual = 4.678626497775045e-10 CG iteration 82, residual = 3.808376264542449e-10 CG iteration 83, residual = 3.5575612731972905e-10 CG iteration 84, residual = 3.651525015082508e-10 CG iteration 85, residual = 3.649606900982716e-10 CG iteration 86, residual = 3.996119365176216e-10 CG iteration 87, residual = 3.878549171145828e-10 CG iteration 88, residual = 3.6149246063681875e-10 CG iteration 89, residual = 3.1435686308988997e-10 CG iteration 90, residual = 2.6817632997375236e-10 CG iteration 91, residual = 2.030648268865617e-10 CG iteration 92, residual = 1.5489961084429493e-10 CG iteration 93, residual = 1.1410757889948257e-10 CG iteration 94, residual = 8.413722687782915e-11 CG iteration 95, residual = 6.998925591764334e-11 CG iteration 96, residual = 5.836837258353117e-11 CG iteration 97, residual = 4.766256685598284e-11 CG iteration 98, residual = 4.352086418731618e-11 CG iteration 99, residual = 4.1851760926394275e-11 CG iteration 100, residual = 4.0106485777204574e-11 CG iteration 101, residual = 4.0037307193660567e-11 CG iteration 102, residual = 4.372234857654242e-11 CG iteration 103, residual = 4.12974688667988e-11 CG iteration 104, residual = 4.1498438218304036e-11 CG iteration 105, residual = 3.4344428616270596e-11 CG converged in 105 iterations to residual 3.4344428616270596e-11
0.012CG iteration 1, residual = 0.003501823625579205
CG iteration 2, residual = 0.00027112669487369836 CG iteration 3, residual = 0.0002193302389428321 CG iteration 4, residual = 0.0002279317255169991 CG iteration 5, residual = 0.0001521842077793224 CG iteration 6, residual = 7.475213794151359e-05 CG iteration 7, residual = 4.4033159352930974e-05 CG iteration 8, residual = 4.034030081079748e-05 CG iteration 9, residual = 3.081214067504058e-05 CG iteration 10, residual = 2.3598670550077958e-05 CG iteration 11, residual = 3.0813398932172186e-05 CG iteration 12, residual = 3.879756990550251e-05 CG iteration 13, residual = 3.561692905294034e-05 CG iteration 14, residual = 3.5067300981213654e-05 CG iteration 15, residual = 3.066535819580435e-05 CG iteration 16, residual = 2.1530617241070337e-05 CG iteration 17, residual = 1.3933927115873773e-05 CG iteration 18, residual = 1.0255174709565047e-05 CG iteration 19, residual = 8.990760179047885e-06 CG iteration 20, residual = 7.441364098960439e-06 CG iteration 21, residual = 5.9516894169745045e-06 CG iteration 22, residual = 5.673432967197086e-06 CG iteration 23, residual = 5.021306158952579e-06 CG iteration 24, residual = 4.936054631686886e-06 CG iteration 25, residual = 5.20971373602664e-06 CG iteration 26, residual = 5.5426999407631535e-06 CG iteration 27, residual = 5.302627678762933e-06 CG iteration 28, residual = 4.2347119438163035e-06 CG iteration 29, residual = 3.2295573495736015e-06 CG iteration 30, residual = 2.1144635491603968e-06 CG iteration 31, residual = 1.5741672413055565e-06 CG iteration 32, residual = 1.273628970498558e-06 CG iteration 33, residual = 9.907928713446467e-07 CG iteration 34, residual = 6.844333167405182e-07 CG iteration 35, residual = 5.209053070412949e-07 CG iteration 36, residual = 4.568172292716986e-07 CG iteration 37, residual = 4.183905350569671e-07 CG iteration 38, residual = 4.4131963560200954e-07 CG iteration 39, residual = 4.576216131012646e-07 CG iteration 40, residual = 4.808199436674436e-07 CG iteration 41, residual = 4.2469808835652473e-07 CG iteration 42, residual = 3.9674574928339127e-07 CG iteration 43, residual = 3.650932917435777e-07 CG iteration 44, residual = 2.803374559541772e-07 CG iteration 45, residual = 2.066224509224966e-07 CG iteration 46, residual = 1.6009696873251533e-07 CG iteration 47, residual = 1.1729939039471745e-07 CG iteration 48, residual = 8.509160483344586e-08 CG iteration 49, residual = 6.677146958087672e-08 CG iteration 50, residual = 5.983550400462125e-08 CG iteration 51, residual = 4.9501827926878836e-08 CG iteration 52, residual = 4.8662767458564916e-08 CG iteration 53, residual = 5.057985666690043e-08 CG iteration 54, residual = 5.525269896621186e-08 CG iteration 55, residual = 5.2765473895518296e-08 CG iteration 56, residual = 4.8312870384956525e-08 CG iteration 57, residual = 4.148086667179793e-08 CG iteration 58, residual = 3.6052629039443766e-08 CG iteration 59, residual = 2.9245308899146918e-08 CG iteration 60, residual = 2.1807179098499005e-08 CG iteration 61, residual = 1.5745091645161814e-08 CG iteration 62, residual = 1.1542714638801533e-08 CG iteration 63, residual = 8.2320987751037e-09 CG iteration 64, residual = 6.610284555352033e-09 CG iteration 65, residual = 5.497986826115493e-09 CG iteration 66, residual = 4.796893717798364e-09 CG iteration 67, residual = 4.281836710299465e-09 CG iteration 68, residual = 4.2959554665570075e-09 CG iteration 69, residual = 4.311570536153215e-09 CG iteration 70, residual = 4.590392637442209e-09 CG iteration 71, residual = 4.506793293092738e-09 CG iteration 72, residual = 4.139622593754485e-09 CG iteration 73, residual = 3.427601807994836e-09 CG iteration 74, residual = 2.68559451219286e-09 CG iteration 75, residual = 1.9834677999340544e-09 CG iteration 76, residual = 1.5589176327259367e-09 CG iteration 77, residual = 1.1398076209992974e-09 CG iteration 78, residual = 9.012773879072101e-10 CG iteration 79, residual = 6.995760501495214e-10 CG iteration 80, residual = 5.740011716221412e-10 CG iteration 81, residual = 4.662494314676563e-10 CG iteration 82, residual = 3.790772248368334e-10 CG iteration 83, residual = 3.544934347107961e-10 CG iteration 84, residual = 3.628712722973217e-10 CG iteration 85, residual = 3.639606675860761e-10 CG iteration 86, residual = 3.985766377780696e-10 CG iteration 87, residual = 3.8710315812219294e-10 CG iteration 88, residual = 3.603594688402203e-10 CG iteration 89, residual = 3.125667511748389e-10 CG iteration 90, residual = 2.6725065802865616e-10 CG iteration 91, residual = 2.0195949400980511e-10 CG iteration 92, residual = 1.5468385853990342e-10 CG iteration 93, residual = 1.1385348064905098e-10 CG iteration 94, residual = 8.382979641242175e-11 CG iteration 95, residual = 6.979467914754399e-11 CG iteration 96, residual = 5.8189598636404564e-11 CG iteration 97, residual = 4.75998866472958e-11 CG iteration 98, residual = 4.3385793062574054e-11 CG iteration 99, residual = 4.1822840010817786e-11 CG iteration 100, residual = 3.9974424158511716e-11 CG iteration 101, residual = 3.9983273211595324e-11 CG iteration 102, residual = 4.344553143752583e-11 CG iteration 103, residual = 4.1224767751237936e-11 CG iteration 104, residual = 4.138986422904719e-11 CG iteration 105, residual = 3.428120859428714e-11 CG converged in 105 iterations to residual 3.428120859428714e-11
0.013000000000000001CG iteration 1, residual = 0.003501548648159748
CG iteration 2, residual = 0.0002704264592622838 CG iteration 3, residual = 0.00021811033544112253 CG iteration 4, residual = 0.00022703780953112904 CG iteration 5, residual = 0.00015210100375310912 CG iteration 6, residual = 7.456062987193971e-05 CG iteration 7, residual = 4.362160633201494e-05 CG iteration 8, residual = 3.9903001076014705e-05 CG iteration 9, residual = 3.063664505348078e-05 CG iteration 10, residual = 2.350440652013465e-05 CG iteration 11, residual = 3.072482279871859e-05 CG iteration 12, residual = 3.8794696246496974e-05 CG iteration 13, residual = 3.559941588503412e-05 CG iteration 14, residual = 3.495553271665735e-05 CG iteration 15, residual = 3.05050925532204e-05 CG iteration 16, residual = 2.140652951072415e-05 CG iteration 17, residual = 1.3862491076386607e-05 CG iteration 18, residual = 1.0195887165127287e-05 CG iteration 19, residual = 8.912170001007604e-06 CG iteration 20, residual = 7.384224038094785e-06 CG iteration 21, residual = 5.912178631573665e-06 CG iteration 22, residual = 5.622074006380485e-06 CG iteration 23, residual = 4.973155979270232e-06 CG iteration 24, residual = 4.8879042054468016e-06 CG iteration 25, residual = 5.150079209172899e-06 CG iteration 26, residual = 5.478291658121387e-06 CG iteration 27, residual = 5.25090188236447e-06 CG iteration 28, residual = 4.2004893728416185e-06 CG iteration 29, residual = 3.2042532397751472e-06 CG iteration 30, residual = 2.090952527439466e-06 CG iteration 31, residual = 1.551374910223987e-06 CG iteration 32, residual = 1.258295555994245e-06 CG iteration 33, residual = 9.813295091722776e-07 CG iteration 34, residual = 6.792217091456914e-07 CG iteration 35, residual = 5.175487607196566e-07 CG iteration 36, residual = 4.5407880531646507e-07 CG iteration 37, residual = 4.1536466681422267e-07 CG iteration 38, residual = 4.3834972801640943e-07 CG iteration 39, residual = 4.546511913024332e-07 CG iteration 40, residual = 4.786005110996278e-07 CG iteration 41, residual = 4.221174725883125e-07 CG iteration 42, residual = 3.9412649815848124e-07 CG iteration 43, residual = 3.624044847465726e-07 CG iteration 44, residual = 2.782927185961125e-07 CG iteration 45, residual = 2.0537003353780187e-07 CG iteration 46, residual = 1.5891338364458233e-07 CG iteration 47, residual = 1.1620621255413033e-07 CG iteration 48, residual = 8.43064543632355e-08 CG iteration 49, residual = 6.614883035818763e-08 CG iteration 50, residual = 5.93894636822828e-08 CG iteration 51, residual = 4.9303140091337144e-08 CG iteration 52, residual = 4.840009528839753e-08 CG iteration 53, residual = 5.014671860607761e-08 CG iteration 54, residual = 5.4803944880450886e-08 CG iteration 55, residual = 5.241047246081415e-08 CG iteration 56, residual = 4.801708660050267e-08 CG iteration 57, residual = 4.115114034841986e-08 CG iteration 58, residual = 3.576986099936148e-08 CG iteration 59, residual = 2.905920197099866e-08 CG iteration 60, residual = 2.1703920954893522e-08 CG iteration 61, residual = 1.5697529868941565e-08 CG iteration 62, residual = 1.1485348407301095e-08 CG iteration 63, residual = 8.179418566704779e-09 CG iteration 64, residual = 6.559682135748078e-09 CG iteration 65, residual = 5.447910687718864e-09 CG iteration 66, residual = 4.7640272088525614e-09 CG iteration 67, residual = 4.2547849462157744e-09 CG iteration 68, residual = 4.273561836531771e-09 CG iteration 69, residual = 4.283953704925025e-09 CG iteration 70, residual = 4.558850313502563e-09 CG iteration 71, residual = 4.477438544833983e-09 CG iteration 72, residual = 4.114803401790865e-09 CG iteration 73, residual = 3.4084367698639873e-09 CG iteration 74, residual = 2.6758443341368156e-09 CG iteration 75, residual = 1.9732264161541544e-09 CG iteration 76, residual = 1.5505925439194304e-09 CG iteration 77, residual = 1.1356800496121974e-09 CG iteration 78, residual = 8.965902956062222e-10 CG iteration 79, residual = 6.960425530052373e-10 CG iteration 80, residual = 5.719506146087113e-10 CG iteration 81, residual = 4.645409712829188e-10 CG iteration 82, residual = 3.773100750381153e-10 CG iteration 83, residual = 3.5312958822183303e-10 CG iteration 84, residual = 3.6049859742515556e-10 CG iteration 85, residual = 3.6290295862509457e-10 CG iteration 86, residual = 3.973511480132965e-10 CG iteration 87, residual = 3.862755465509669e-10 CG iteration 88, residual = 3.591994923527484e-10 CG iteration 89, residual = 3.107611978194337e-10 CG iteration 90, residual = 2.6625509601791987e-10 CG iteration 91, residual = 2.0084731183035902e-10 CG iteration 92, residual = 1.5446398453711415e-10 CG iteration 93, residual = 1.1358615492334435e-10 CG iteration 94, residual = 8.353666894921782e-11 CG iteration 95, residual = 6.960166373733907e-11 CG iteration 96, residual = 5.7999624026959105e-11 CG iteration 97, residual = 4.753161050250706e-11 CG iteration 98, residual = 4.3241855465365475e-11 CG iteration 99, residual = 4.177386483077848e-11 CG iteration 100, residual = 3.9832722713471927e-11 CG iteration 101, residual = 3.992117312998736e-11 CG iteration 102, residual = 4.315166375702307e-11 CG iteration 103, residual = 4.1146553675481946e-11 CG iteration 104, residual = 4.126101576180805e-11 CG iteration 105, residual = 3.4220074951956934e-11 CG converged in 105 iterations to residual 3.4220074951956934e-11
0.014CG iteration 1, residual = 0.0035012754247166528
CG iteration 2, residual = 0.00026975157258901606 CG iteration 3, residual = 0.0002169495678562328 CG iteration 4, residual = 0.0002261867183080457 CG iteration 5, residual = 0.0001520266989698739 CG iteration 6, residual = 7.437597509908908e-05 CG iteration 7, residual = 4.322047801850365e-05 CG iteration 8, residual = 3.947680885419888e-05 CG iteration 9, residual = 3.0468967444215667e-05 CG iteration 10, residual = 2.3418575959258167e-05 CG iteration 11, residual = 3.064725999007974e-05 CG iteration 12, residual = 3.880259822309396e-05 CG iteration 13, residual = 3.5588082373962224e-05 CG iteration 14, residual = 3.4845256397659454e-05 CG iteration 15, residual = 3.0344898533038263e-05
</pre>
end{sphinxVerbatim}
[2KCG iteration 2, residual = 0.0002750686889839861 [2KCG iteration 3, residual = 0.00022645236424686792 [2KCG iteration 4, residual = 0.00023312234756122418 [2KCG iteration 5, residual = 0.00015276041542403374 [2KCG iteration 6, residual = 7.58341835750697e-05 [2KCG iteration 7, residual = 4.627263953922736e-05 [2KCG iteration 8, residual = 4.2718819246877436e-05 [2KCG iteration 9, residual = 3.182631877961638e-05 [2KCG iteration 10, residual = 2.4220380243662486e-05 [2KCG iteration 11, residual = 3.14595874060773e-05 [2KCG iteration 12, residual = 3.901646734101507e-05 [2KCG iteration 13, residual = 3.583330431608987e-05 [2KCG iteration 14, residual = 3.567461702883674e-05 [2KCG iteration 15, residual = 3.148073165334667e-05 [2KCG iteration 16, residual = 2.2166382579100016e-05 [2KCG iteration 17, residual = 1.4297135535467055e-05 [2KCG iteration 18, residual = 1.0573712703047232e-05 [2KCG iteration 19, residual = 9.421794754359285e-06 [2KCG iteration 20, residual = 7.746755350505863e-06 [2KCG iteration 21, residual = 6.154664551594531e-06 [2KCG iteration 22, residual = 5.939272197933574e-06 [2KCG iteration 23, residual = 5.276459266215908e-06 [2KCG iteration 24, residual = 5.196609925346973e-06 [2KCG iteration 25, residual = 5.538682965668864e-06 [2KCG iteration 26, residual = 5.8991945328587934e-06 [2KCG iteration 27, residual = 5.5797598330275944e-06 [2KCG iteration 28, residual = 4.413510979296905e-06 [2KCG iteration 29, residual = 3.3666376298208826e-06 [2KCG iteration 30, residual = 2.2452882326391113e-06 [2KCG iteration 31, residual = 1.6994337509772435e-06 [2KCG iteration 32, residual = 1.3558290849669754e-06 [2KCG iteration 33, residual = 1.0409175827035707e-06 [2KCG iteration 34, residual = 7.127333667075153e-07 [2KCG iteration 35, residual = 5.396675907606964e-07 [2KCG iteration 36, residual = 4.72205013666961e-07 [2KCG iteration 37, residual = 4.348764740884112e-07 [2KCG iteration 38, residual = 4.5718431911457165e-07 [2KCG iteration 39, residual = 4.7340791628123507e-07 [2KCG iteration 40, residual = 4.927088993136339e-07 [2KCG iteration 41, residual = 4.391531850458396e-07 [2KCG iteration 42, residual = 4.113987651382028e-07 [2KCG iteration 43, residual = 3.794922193124094e-07 [2KCG iteration 44, residual = 2.9109756499676567e-07 [2KCG iteration 45, residual = 2.1324564399383787e-07 [2KCG iteration 46, residual = 1.6627336811097583e-07 [2KCG iteration 47, residual = 1.2312769234805485e-07 [2KCG iteration 48, residual = 8.937277307671138e-08 [2KCG iteration 49, residual = 7.010961372645455e-08 [2KCG iteration 50, residual = 6.21670988648115e-08 [2KCG iteration 51, residual = 5.0634889041096177e-08 [2KCG iteration 52, residual = 5.0156867412009396e-08 [2KCG iteration 53, residual = 5.2985505712223207e-08 [2KCG iteration 54, residual = 5.767970697812972e-08 [2KCG iteration 55, residual = 5.469629239853854e-08 [2KCG iteration 56, residual = 4.9926669275049873e-08 [2KCG iteration 57, residual = 4.328025477804508e-08 [2KCG iteration 58, residual = 3.7614714219434755e-08 [2KCG iteration 59, residual = 3.0234344869510815e-08 [2KCG iteration 60, residual = 2.2321510508821452e-08 [2KCG iteration 61, residual = 1.5987720699066844e-08 [2KCG iteration 62, residual = 1.1833533384634566e-08 [2KCG iteration 63, residual = 8.50537395544075e-09 [2KCG iteration 64, residual = 6.878441894899852e-09 [2KCG iteration 65, residual = 5.761983764233123e-09 [2KCG iteration 66, residual = 4.972693356531784e-09 [2KCG iteration 67, residual = 4.431724591050761e-09 [2KCG iteration 68, residual = 4.417548960891507e-09 [2KCG iteration 69, residual = 4.4656741528393045e-09 [2KCG iteration 70, residual = 4.769736626048566e-09 [2KCG iteration 71, residual = 4.663855446559244e-09 [2KCG iteration 72, residual = 4.260094290167396e-09 [2KCG iteration 73, residual = 3.5248177941134233e-09 [2KCG iteration 74, residual = 2.740229622904957e-09 [2KCG iteration 75, residual = 2.038867122976052e-09 [2KCG iteration 76, residual = 1.6004762546549356e-09 [2KCG iteration 77, residual = 1.1616392509062596e-09 [2KCG iteration 78, residual = 9.250014804195558e-10 [2KCG iteration 79, residual = 7.17219017068161e-10 [2KCG iteration 80, residual = 5.820253707439526e-10 [2KCG iteration 81, residual = 4.732654767325132e-10 [2KCG iteration 82, residual = 3.8782173115184395e-10 [2KCG iteration 83, residual = 3.5977423876347744e-10 [2KCG iteration 84, residual = 3.7302851759288413e-10 [2KCG iteration 85, residual = 3.6830280755487837e-10 [2KCG iteration 86, residual = 4.017834658377652e-10 [2KCG iteration 87, residual = 3.899521576963381e-10 [2KCG iteration 88, residual = 3.6570157552701856e-10 [2KCG iteration 89, residual = 3.2127546788038833e-10 [2KCG iteration 90, residual = 2.711297721736933e-10 [2KCG iteration 91, residual = 2.0734495014581667e-10 [2KCG iteration 92, residual = 1.5574578367531602e-10 [2KCG iteration 93, residual = 1.1500890018830262e-10 [2KCG iteration 94, residual = 8.550514624459791e-11 [2KCG iteration 95, residual = 7.078689243544217e-11 [2KCG iteration 96, residual = 5.896348311675296e-11 [2KCG iteration 97, residual = 4.784779869934026e-11 [2KCG iteration 98, residual = 4.396629412487457e-11 [2KCG iteration 99, residual = 4.176303901853545e-11 [2KCG iteration 100, residual = 4.051650400264211e-11 [2KCG iteration 101, residual = 4.0175161381866904e-11 [2KCG iteration 102, residual = 4.4618167406670105e-11 [2KCG iteration 103, residual = 4.1520657896185674e-11 [2KCG iteration 104, residual = 4.1718098506166706e-11 [2KCG iteration 105, residual = 3.461741248001953e-11 [2KCG converged in 105 iterations to residual 3.461741248001953e-11
0.008[2KCG iteration 1, residual = 0.0035029473093459783
[2KCG iteration 2, residual = 0.00027421508828574895 [2KCG iteration 3, residual = 0.0002248772653238142 [2KCG iteration 4, residual = 0.00023198006782189888 [2KCG iteration 5, residual = 0.00015262097917500205 [2KCG iteration 6, residual = 7.559880769776822e-05 [2KCG iteration 7, residual = 4.5797769220984376e-05 [2KCG iteration 8, residual = 4.221480814326149e-05 [2KCG iteration 9, residual = 3.16031752680329e-05 [2KCG iteration 10, residual = 2.4073394628486208e-05 [2KCG iteration 11, residual = 3.129915705600602e-05 [2KCG iteration 12, residual = 3.894087005586668e-05 [2KCG iteration 13, residual = 3.5768955400890746e-05 [2KCG iteration 14, residual = 3.554376064098869e-05 [2KCG iteration 15, residual = 3.131423099735442e-05 [2KCG iteration 16, residual = 2.2036424734971373e-05 [2KCG iteration 17, residual = 1.4223367207566257e-05 [2KCG iteration 18, residual = 1.0506689208018065e-05 [2KCG iteration 19, residual = 9.330136209376993e-06 [2KCG iteration 20, residual = 7.683029090267576e-06 [2KCG iteration 21, residual = 6.113484379101787e-06 [2KCG iteration 22, residual = 5.885025042106566e-06 [2KCG iteration 23, residual = 5.223535627293794e-06 [2KCG iteration 24, residual = 5.141863494891891e-06 [2KCG iteration 25, residual = 5.468746038120987e-06 [2KCG iteration 26, residual = 5.823231590571083e-06 [2KCG iteration 27, residual = 5.521886736257287e-06 [2KCG iteration 28, residual = 4.376703651602523e-06 [2KCG iteration 29, residual = 3.3376706339162312e-06 [2KCG iteration 30, residual = 2.2171868406254252e-06 [2KCG iteration 31, residual = 1.672792767758826e-06 [2KCG iteration 32, residual = 1.3386548104688302e-06 [2KCG iteration 33, residual = 1.0305130862973242e-06 [2KCG iteration 34, residual = 7.067461662344357e-07 [2KCG iteration 35, residual = 5.356255310302682e-07 [2KCG iteration 36, residual = 4.688831749196208e-07 [2KCG iteration 37, residual = 4.313826219592502e-07 [2KCG iteration 38, residual = 4.5386646784034543e-07 [2KCG iteration 39, residual = 4.701216001725784e-07 [2KCG iteration 40, residual = 4.902183377831884e-07 [2KCG iteration 41, residual = 4.360368729060584e-07 [2KCG iteration 42, residual = 4.082453977406901e-07 [2KCG iteration 43, residual = 3.7647542010234853e-07 [2KCG iteration 44, residual = 2.8886539696181395e-07 [2KCG iteration 45, residual = 2.1186449522204714e-07 [2KCG iteration 46, residual = 1.6499589119050878e-07 [2KCG iteration 47, residual = 1.2190957117306952e-07 [2KCG iteration 48, residual = 8.846624889507519e-08 [2KCG iteration 49, residual = 6.941104636979199e-08 [2KCG iteration 50, residual = 6.16872094581884e-08 [2KCG iteration 51, residual = 5.038753013625115e-08 [2KCG iteration 52, residual = 4.983039656755185e-08 [2KCG iteration 53, residual = 5.247008390976361e-08 [2KCG iteration 54, residual = 5.716910591605958e-08 [2KCG iteration 55, residual = 5.428748353079821e-08 [2KCG iteration 56, residual = 4.958318439890501e-08 [2KCG iteration 57, residual = 4.2898564243225053e-08 [2KCG iteration 58, residual = 3.7281157005313506e-08 [2KCG iteration 59, residual = 3.002776440243458e-08 [2KCG iteration 60, residual = 2.2218648428225986e-08 [2KCG iteration 61, residual = 1.5938098508875774e-08 [2KCG iteration 62, residual = 1.1774181206313143e-08 [2KCG iteration 63, residual = 8.449060758946971e-09 [2KCG iteration 64, residual = 6.8226164561097e-09 [2KCG iteration 65, residual = 5.707202811527226e-09 [2KCG iteration 66, residual = 4.935899609900094e-09 [2KCG iteration 67, residual = 4.3996137150213855e-09 [2KCG iteration 68, residual = 4.391740918202749e-09 [2KCG iteration 69, residual = 4.432469584793771e-09 [2KCG iteration 70, residual = 4.7306579228107756e-09 [2KCG iteration 71, residual = 4.63088783505528e-09 [2KCG iteration 72, residual = 4.2364390075792334e-09 [2KCG iteration 73, residual = 3.5050852931117586e-09 [2KCG iteration 74, residual = 2.728340144892914e-09 [2KCG iteration 75, residual = 2.02714366584515e-09 [2KCG iteration 76, residual = 1.592168881157063e-09 [2KCG iteration 77, residual = 1.1570648721675374e-09 [2KCG iteration 78, residual = 9.201971457713231e-10 [2KCG iteration 79, residual = 7.136954050056955e-10 [2KCG iteration 80, residual = 5.807103619722854e-10 [2KCG iteration 81, residual = 4.720765466601165e-10 [2KCG iteration 82, residual = 3.8607951071626393e-10 [2KCG iteration 83, residual = 3.589209146651929e-10 [2KCG iteration 84, residual = 3.712764386207167e-10 [2KCG iteration 85, residual = 3.675689850300504e-10 [2KCG iteration 86, residual = 4.015333966656753e-10 [2KCG iteration 87, residual = 3.8957523752270005e-10 [2KCG iteration 88, residual = 3.647004879233403e-10 [2KCG iteration 89, residual = 3.195884739008916e-10 [2KCG iteration 90, residual = 2.705066388725217e-10 [2KCG iteration 91, residual = 2.0630252575756308e-10 [2KCG iteration 92, residual = 1.5553382737966527e-10 [2KCG iteration 93, residual = 1.1479803337485627e-10 [2KCG iteration 94, residual = 8.51425676423377e-11 [2KCG iteration 95, residual = 7.058420709798289e-11 [2KCG iteration 96, residual = 5.883281062765201e-11 [2KCG iteration 97, residual = 4.7811812655496756e-11 [2KCG iteration 98, residual = 4.386949899726627e-11 [2KCG iteration 99, residual = 4.181550718924521e-11 [2KCG iteration 100, residual = 4.0433484816714e-11 [2KCG iteration 101, residual = 4.015183055311352e-11 [2KCG iteration 102, residual = 4.442945542946559e-11 [2KCG iteration 103, residual = 4.147595921683343e-11 [2KCG iteration 104, residual = 4.1695949275600026e-11 [2KCG iteration 105, residual = 3.454608343928488e-11 [2KCG converged in 105 iterations to residual 3.454608343928488e-11
0.009000000000000001[2KCG iteration 1, residual = 0.003502662128308906
[2KCG iteration 2, residual = 0.0002733961580586486 [2KCG iteration 3, residual = 0.00022338210572804754 [2KCG iteration 4, residual = 0.00023089237760424321 [2KCG iteration 5, residual = 0.00015249455460110268 [2KCG iteration 6, residual = 7.537368993756873e-05 [2KCG iteration 7, residual = 4.533728160404172e-05 [2KCG iteration 8, residual = 4.1725823073207305e-05 [2KCG iteration 9, residual = 3.139085985595972e-05 [2KCG iteration 10, residual = 2.393857682546425e-05 [2KCG iteration 11, residual = 3.115564588412961e-05 [2KCG iteration 12, residual = 3.8882643454023555e-05 [2KCG iteration 13, residual = 3.571641054249972e-05 [2KCG iteration 14, residual = 3.5418574322292915e-05 [2KCG iteration 15, residual = 3.11499785767884e-05 [2KCG iteration 16, residual = 2.1908142273651232e-05 [2KCG iteration 17, residual = 1.4150286856343285e-05 [2KCG iteration 18, residual = 1.0441454373612276e-05 [2KCG iteration 19, residual = 9.241328153343562e-06 [2KCG iteration 20, residual = 7.620636514060706e-06 [2KCG iteration 21, residual = 6.072556690728821e-06 [2KCG iteration 22, residual = 5.831280401798344e-06 [2KCG iteration 23, residual = 5.171552035305625e-06 [2KCG iteration 24, residual = 5.088433456712848e-06 [2KCG iteration 25, residual = 5.400888980615864e-06 [2KCG iteration 26, residual = 5.749618803588539e-06 [2KCG iteration 27, residual = 5.4652298426785685e-06 [2KCG iteration 28, residual = 4.340428019234299e-06 [2KCG iteration 29, residual = 3.3095243448734007e-06 [2KCG iteration 30, residual = 2.190106491957804e-06 [2KCG iteration 31, residual = 1.6469698341651686e-06 [2KCG iteration 32, residual = 1.3218455801476592e-06 [2KCG iteration 33, residual = 1.0203003121202036e-06 [2KCG iteration 34, residual = 7.00932086123721e-07 [2KCG iteration 35, residual = 5.317364541652891e-07 [2KCG iteration 36, residual = 4.656890837965646e-07 [2KCG iteration 37, residual = 4.27992304135359e-07 [2KCG iteration 38, residual = 4.5062446893638635e-07 [2KCG iteration 39, residual = 4.669015030866264e-07 [2KCG iteration 40, residual = 4.877868075538506e-07 [2KCG iteration 41, residual = 4.330394123302469e-07 [2KCG iteration 42, residual = 4.052082334687157e-07 [2KCG iteration 43, residual = 3.735301057074921e-07 [2KCG iteration 44, residual = 2.8667617571282414e-07 [2KCG iteration 45, residual = 2.1051442106783963e-07 [2KCG iteration 46, residual = 1.6374206646701922e-07 [2KCG iteration 47, residual = 1.2071901392849428e-07 [2KCG iteration 48, residual = 8.758581227070713e-08 [2KCG iteration 49, residual = 6.872828228155403e-08 [2KCG iteration 50, residual = 6.121417001051295e-08 [2KCG iteration 51, residual = 5.0151269636358754e-08 [2KCG iteration 52, residual = 4.9518934666061526e-08 [2KCG iteration 53, residual = 5.197255796328209e-08 [2KCG iteration 54, residual = 5.6671364045801356e-08 [2KCG iteration 55, residual = 5.3890665508027054e-08 [2KCG iteration 56, residual = 4.9250990673525076e-08 [2KCG iteration 57, residual = 4.252834758552273e-08 [2KCG iteration 58, residual = 3.695861035805556e-08 [2KCG iteration 59, residual = 2.9825904130623685e-08 [2KCG iteration 60, residual = 2.2115889751929245e-08 [2KCG iteration 61, residual = 1.5889175302468954e-08 [2KCG iteration 62, residual = 1.1715645518288366e-08 [2KCG iteration 63, residual = 8.39369983330021e-09 [2KCG iteration 64, residual = 6.76795060428918e-09 [2KCG iteration 65, residual = 5.653472630808413e-09 [2KCG iteration 66, residual = 4.899964384419662e-09 [2KCG iteration 67, residual = 4.36863428578233e-09 [2KCG iteration 68, residual = 4.3667530691064595e-09 [2KCG iteration 69, residual = 4.400547372777094e-09 [2KCG iteration 70, residual = 4.693294291888226e-09 [2KCG iteration 71, residual = 4.598761635503694e-09 [2KCG iteration 72, residual = 4.212592221491459e-09 [2KCG iteration 73, residual = 3.4855406098705326e-09 [2KCG iteration 74, residual = 2.716991435767891e-09 [2KCG iteration 75, residual = 2.0157709857331386e-09 [2KCG iteration 76, residual = 1.5838634669316474e-09 [2KCG iteration 77, residual = 1.1526122729912733e-09 [2KCG iteration 78, residual = 9.154312669559457e-10 [2KCG iteration 79, residual = 7.101698092202335e-10 [2KCG iteration 80, residual = 5.792552227597966e-10 [2KCG iteration 81, residual = 4.707796861428189e-10 [2KCG iteration 82, residual = 3.8433731491573193e-10 [2KCG iteration 83, residual = 3.579693878043894e-10 [2KCG iteration 84, residual = 3.6937100778945984e-10 [2KCG iteration 85, residual = 3.6676767617863585e-10 [2KCG iteration 86, residual = 4.0109118363130003e-10 [2KCG iteration 87, residual = 3.8909755012045603e-10 [2KCG iteration 88, residual = 3.6366506316000883e-10 [2KCG iteration 89, residual = 3.178715557809716e-10 [2KCG iteration 90, residual = 2.698062845955147e-10 [2KCG iteration 91, residual = 2.0523980313080055e-10 [2KCG iteration 92, residual = 1.5532327398883304e-10 [2KCG iteration 93, residual = 1.1457869356614805e-10 [2KCG iteration 94, residual = 8.479377607996318e-11 [2KCG iteration 95, residual = 7.038385540779504e-11 [2KCG iteration 96, residual = 5.869019302609398e-11 [2KCG iteration 97, residual = 4.776889816676659e-11 [2KCG iteration 98, residual = 4.376296421659705e-11 [2KCG iteration 99, residual = 4.1848085749968565e-11 [2KCG iteration 100, residual = 4.033701382625414e-11 [2KCG iteration 101, residual = 4.012138383792075e-11 [2KCG iteration 102, residual = 4.42162262547217e-11 [2KCG iteration 103, residual = 4.142363082579474e-11 [2KCG iteration 104, residual = 4.165191524769749e-11 [2KCG iteration 105, residual = 3.4476873407271355e-11 [2KCG converged in 105 iterations to residual 3.4476873407271355e-11
0.01[2KCG iteration 1, residual = 0.003502380033659947
[2KCG iteration 2, residual = 0.0002726097547274006 [2KCG iteration 3, residual = 0.00022196212399513062 [2KCG iteration 4, residual = 0.00022985671101846778 [2KCG iteration 5, residual = 0.00015238019421120615 [2KCG iteration 6, residual = 7.51580214644945e-05 [2KCG iteration 7, residual = 4.489024345630351e-05 [2KCG iteration 8, residual = 4.125096006274376e-05 [2KCG iteration 9, residual = 3.1188672355801257e-05 [2KCG iteration 10, residual = 2.3815045030688157e-05 [2KCG iteration 11, residual = 3.102768042903796e-05 [2KCG iteration 12, residual = 3.8840275375384565e-05 [2KCG iteration 13, residual = 3.567435232037147e-05 [2KCG iteration 14, residual = 3.529803567288964e-05 [2KCG iteration 15, residual = 3.098740277435999e-05 [2KCG iteration 16, residual = 2.178123838138312e-05 [2KCG iteration 17, residual = 1.4077754782036818e-05 [2KCG iteration 18, residual = 1.0377866592549592e-05 [2KCG iteration 19, residual = 9.15523899098614e-06 [2KCG iteration 20, residual = 7.559566003024353e-06 [2KCG iteration 21, residual = 6.031920425364622e-06 [2KCG iteration 22, residual = 5.778074456705057e-06 [2KCG iteration 23, residual = 5.120513647492993e-06 [2KCG iteration 24, residual = 5.036320597265847e-06 [2KCG iteration 25, residual = 5.3351045557967205e-06 [2KCG iteration 26, residual = 5.678339295681478e-06 [2KCG iteration 27, residual = 5.409796523785784e-06 [2KCG iteration 28, residual = 4.304675414434872e-06 [2KCG iteration 29, residual = 3.2821523140029275e-06 [2KCG iteration 30, residual = 2.16399301725177e-06 [2KCG iteration 31, residual = 1.6219407202713273e-06 [2KCG iteration 32, residual = 1.305404014784963e-06 [2KCG iteration 33, residual = 1.0102770918937598e-06 [2KCG iteration 34, residual = 6.952810406774719e-07 [2KCG iteration 35, residual = 5.279919258485627e-07 [2KCG iteration 36, residual = 4.6261705797398864e-07 [2KCG iteration 37, residual = 4.2470006467965734e-07 [2KCG iteration 38, residual = 4.474546361639796e-07 [2KCG iteration 39, residual = 4.6374574311293387e-07 [2KCG iteration 40, residual = 4.854113950682164e-07 [2KCG iteration 41, residual = 4.3015421549360216e-07 [2KCG iteration 42, residual = 4.0228230786784797e-07 [2KCG iteration 43, residual = 3.706532621228378e-07 [2KCG iteration 44, residual = 2.8452687164637306e-07 [2KCG iteration 45, residual = 2.091924343535237e-07 [2KCG iteration 46, residual = 1.6250921970407998e-07 [2KCG iteration 47, residual = 1.195546400800841e-07 [2KCG iteration 48, residual = 8.67304815438121e-08 [2KCG iteration 49, residual = 6.806095808529461e-08 [2KCG iteration 50, residual = 6.074788727692672e-08 [2KCG iteration 51, residual = 4.992533526311685e-08 [2KCG iteration 52, residual = 4.922123442452049e-08 [2KCG iteration 53, residual = 5.1492144047914836e-08 [2KCG iteration 54, residual = 5.618620389650547e-08 [2KCG iteration 55, residual = 5.350511030635357e-08 [2KCG iteration 56, residual = 4.8929102090289054e-08 [2KCG iteration 57, residual = 4.216900848468387e-08 [2KCG iteration 58, residual = 3.6646618410066895e-08 [2KCG iteration 59, residual = 2.962840786650546e-08 [2KCG iteration 60, residual = 2.2013113312900614e-08 [2KCG iteration 61, residual = 1.584079223593435e-08 [2KCG iteration 62, residual = 1.1657690914791463e-08 [2KCG iteration 63, residual = 8.3391569628211e-09 [2KCG iteration 64, residual = 6.714376104798902e-09 [2KCG iteration 65, residual = 5.600727643483912e-09 [2KCG iteration 66, residual = 4.864840368271474e-09 [2KCG iteration 67, residual = 4.338715932158479e-09 [2KCG iteration 68, residual = 4.342502375382904e-09 [2KCG iteration 69, residual = 4.369808111949748e-09 [2KCG iteration 70, residual = 4.65752869454865e-09 [2KCG iteration 71, residual = 4.567408146305653e-09 [2KCG iteration 72, residual = 4.188517803401357e-09 [2KCG iteration 73, residual = 3.466133970012487e-09 [2KCG iteration 74, residual = 2.706120641551398e-09 [2KCG iteration 75, residual = 2.0047181531239997e-09 [2KCG iteration 76, residual = 1.5755542961540034e-09 [2KCG iteration 77, residual = 1.1482620000222128e-09 [2KCG iteration 78, residual = 9.106938082531891e-10 [2KCG iteration 79, residual = 7.066411097478733e-10 [2KCG iteration 80, residual = 5.776537437209587e-10 [2KCG iteration 81, residual = 4.69374276835515e-10 [2KCG iteration 82, residual = 3.825907714019758e-10 [2KCG iteration 83, residual = 3.569150181599826e-10 [2KCG iteration 84, residual = 3.6732466575182557e-10 [2KCG iteration 85, residual = 3.658976601011072e-10 [2KCG iteration 86, residual = 4.0045105468152646e-10 [2KCG iteration 87, residual = 3.8852220904930823e-10 [2KCG iteration 88, residual = 3.6259520276500023e-10 [2KCG iteration 89, residual = 3.161265750436436e-10 [2KCG iteration 90, residual = 2.690290121302419e-10 [2KCG iteration 91, residual = 2.041594773250882e-10 [2KCG iteration 92, residual = 1.551123446744987e-10 [2KCG iteration 93, residual = 1.1434900221904848e-10 [2KCG iteration 94, residual = 8.445863289708183e-11 [2KCG iteration 95, residual = 7.018559436622032e-11 [2KCG iteration 96, residual = 5.853535617300854e-11 [2KCG iteration 97, residual = 4.771905868863811e-11 [2KCG iteration 98, residual = 4.3646690210442704e-11 [2KCG iteration 99, residual = 4.1860225192276064e-11 [2KCG iteration 100, residual = 4.0227712164506265e-11 [2KCG iteration 101, residual = 4.0083302726709826e-11 [2KCG iteration 102, residual = 4.3979925392114605e-11 [2KCG iteration 103, residual = 4.136396618022225e-11 [2KCG iteration 104, residual = 4.15859759730723e-11 [2KCG iteration 105, residual = 3.440966273646705e-11 [2KCG converged in 105 iterations to residual 3.440966273646705e-11
0.011[2KCG iteration 1, residual = 0.0035021006481831423
[2KCG iteration 2, residual = 0.0002718538850112676 [2KCG iteration 3, residual = 0.00022061288143513896 [2KCG iteration 4, residual = 0.00022887061058604906 [2KCG iteration 5, residual = 0.00015227701787613745 [2KCG iteration 6, residual = 7.495106273327453e-05 [2KCG iteration 7, residual = 4.445579806910077e-05 [2KCG iteration 8, residual = 4.078937925034008e-05 [2KCG iteration 9, residual = 3.099596542376602e-05 [2KCG iteration 10, residual = 2.370199019382273e-05 [2KCG iteration 11, residual = 3.091398975415892e-05 [2KCG iteration 12, residual = 3.881235546069116e-05 [2KCG iteration 13, residual = 3.564156498739677e-05 [2KCG iteration 14, residual = 3.518122123281789e-05 [2KCG iteration 15, residual = 3.082600585773836e-05 [2KCG iteration 16, residual = 2.1655464902414863e-05 [2KCG iteration 17, residual = 1.4005662160599732e-05 [2KCG iteration 18, residual = 1.0315806681086997e-05 [2KCG iteration 19, residual = 9.071751426288473e-06 [2KCG iteration 20, residual = 7.499810160848459e-06 [2KCG iteration 21, residual = 5.991617208328718e-06 [2KCG iteration 22, residual = 5.725445691060445e-06 [2KCG iteration 23, residual = 5.070428548884417e-06 [2KCG iteration 24, residual = 4.985527006059895e-06 [2KCG iteration 25, residual = 5.271383549085767e-06 [2KCG iteration 26, residual = 5.609373808803841e-06 [2KCG iteration 27, residual = 5.35559385621884e-06 [2KCG iteration 28, residual = 4.269438756887526e-06 [2KCG iteration 29, residual = 3.2555105438158077e-06 [2KCG iteration 30, residual = 2.1387949694167225e-06 [2KCG iteration 31, residual = 1.5976812188602249e-06 [2KCG iteration 32, residual = 1.2893316429280249e-06 [2KCG iteration 33, residual = 1.0004417211922102e-06 [2KCG iteration 34, residual = 6.897840901520908e-07 [2KCG iteration 35, residual = 5.243840255815522e-07 [2KCG iteration 36, residual = 4.5966156721433035e-07 [2KCG iteration 37, residual = 4.2150096931744257e-07 [2KCG iteration 38, residual = 4.443538848404053e-07 [2KCG iteration 39, residual = 4.6065283290989485e-07 [2KCG iteration 40, residual = 4.830897381517374e-07 [2KCG iteration 41, residual = 4.2737548313313355e-07 [2KCG iteration 42, residual = 3.9946295197687025e-07 [2KCG iteration 43, residual = 3.67841948321673e-07 [2KCG iteration 44, residual = 2.824147757925146e-07 [2KCG iteration 45, residual = 2.0789589173131395e-07 [2KCG iteration 46, residual = 1.6129492035737293e-07 [2KCG iteration 47, residual = 1.1841516378549959e-07 [2KCG iteration 48, residual = 8.589935624350219e-08 [2KCG iteration 49, residual = 6.740877210708025e-08 [2KCG iteration 50, residual = 6.028832767446454e-08 [2KCG iteration 51, residual = 4.970905209269985e-08 [2KCG iteration 52, residual = 4.8936179458979007e-08 [2KCG iteration 53, residual = 5.102812884013203e-08 [2KCG iteration 54, residual = 5.5713386456216665e-08 [2KCG iteration 55, residual = 5.31302137097767e-08 [2KCG iteration 56, residual = 4.861665040072241e-08 [2KCG iteration 57, residual = 4.182000980003601e-08 [2KCG iteration 58, residual = 3.634475696645311e-08 [2KCG iteration 59, residual = 2.943496592670783e-08 [2KCG iteration 60, residual = 2.1910230283046187e-08 [2KCG iteration 61, residual = 1.579280705863876e-08 [2KCG iteration 62, residual = 1.1600108590182874e-08 [2KCG iteration 63, residual = 8.285320437518471e-09 [2KCG iteration 64, residual = 6.661836354283547e-09 [2KCG iteration 65, residual = 5.548913798710975e-09 [2KCG iteration 66, residual = 4.830492081865183e-09 [2KCG iteration 67, residual = 4.309799842489668e-09 [2KCG iteration 68, residual = 4.3189212813063876e-09 [2KCG iteration 69, residual = 4.34017099180728e-09 [2KCG iteration 70, residual = 4.6232584139824476e-09 [2KCG iteration 71, residual = 4.536768760591724e-09 [2KCG iteration 72, residual = 4.1641963248542626e-09 [2KCG iteration 73, residual = 3.4468292324947447e-09 [2KCG iteration 74, residual = 2.695671688819309e-09 [2KCG iteration 75, residual = 1.993958240361938e-09 [2KCG iteration 76, residual = 1.5672389546203053e-09 [2KCG iteration 77, residual = 1.1439981083103573e-09 [2KCG iteration 78, residual = 9.05977509128941e-10 [2KCG iteration 79, residual = 7.031094857182288e-10 [2KCG iteration 80, residual = 5.759026539780105e-10 [2KCG iteration 81, residual = 4.678626497775045e-10 [2KCG iteration 82, residual = 3.808376264542449e-10 [2KCG iteration 83, residual = 3.5575612731972905e-10 [2KCG iteration 84, residual = 3.651525015082508e-10 [2KCG iteration 85, residual = 3.649606900982716e-10 [2KCG iteration 86, residual = 3.996119365176216e-10 [2KCG iteration 87, residual = 3.878549171145828e-10 [2KCG iteration 88, residual = 3.6149246063681875e-10 [2KCG iteration 89, residual = 3.1435686308988997e-10 [2KCG iteration 90, residual = 2.6817632997375236e-10 [2KCG iteration 91, residual = 2.030648268865617e-10 [2KCG iteration 92, residual = 1.5489961084429493e-10 [2KCG iteration 93, residual = 1.1410757889948257e-10 [2KCG iteration 94, residual = 8.413722687782915e-11 [2KCG iteration 95, residual = 6.998925591764334e-11 [2KCG iteration 96, residual = 5.836837258353117e-11 [2KCG iteration 97, residual = 4.766256685598284e-11 [2KCG iteration 98, residual = 4.352086418731618e-11 [2KCG iteration 99, residual = 4.1851760926394275e-11 [2KCG iteration 100, residual = 4.0106485777204574e-11 [2KCG iteration 101, residual = 4.0037307193660567e-11 [2KCG iteration 102, residual = 4.372234857654242e-11 [2KCG iteration 103, residual = 4.12974688667988e-11 [2KCG iteration 104, residual = 4.1498438218304036e-11 [2KCG iteration 105, residual = 3.4344428616270596e-11 [2KCG converged in 105 iterations to residual 3.4344428616270596e-11
0.012[2KCG iteration 1, residual = 0.003501823625579205
[2KCG iteration 2, residual = 0.00027112669487369836 [2KCG iteration 3, residual = 0.0002193302389428321 [2KCG iteration 4, residual = 0.0002279317255169991 [2KCG iteration 5, residual = 0.0001521842077793224 [2KCG iteration 6, residual = 7.475213794151359e-05 [2KCG iteration 7, residual = 4.4033159352930974e-05 [2KCG iteration 8, residual = 4.034030081079748e-05 [2KCG iteration 9, residual = 3.081214067504058e-05 [2KCG iteration 10, residual = 2.3598670550077958e-05 [2KCG iteration 11, residual = 3.0813398932172186e-05 [2KCG iteration 12, residual = 3.879756990550251e-05 [2KCG iteration 13, residual = 3.561692905294034e-05 [2KCG iteration 14, residual = 3.5067300981213654e-05 [2KCG iteration 15, residual = 3.066535819580435e-05 [2KCG iteration 16, residual = 2.1530617241070337e-05 [2KCG iteration 17, residual = 1.3933927115873773e-05 [2KCG iteration 18, residual = 1.0255174709565047e-05 [2KCG iteration 19, residual = 8.990760179047885e-06 [2KCG iteration 20, residual = 7.441364098960439e-06 [2KCG iteration 21, residual = 5.9516894169745045e-06 [2KCG iteration 22, residual = 5.673432967197086e-06 [2KCG iteration 23, residual = 5.021306158952579e-06 [2KCG iteration 24, residual = 4.936054631686886e-06 [2KCG iteration 25, residual = 5.20971373602664e-06 [2KCG iteration 26, residual = 5.5426999407631535e-06 [2KCG iteration 27, residual = 5.302627678762933e-06 [2KCG iteration 28, residual = 4.2347119438163035e-06 [2KCG iteration 29, residual = 3.2295573495736015e-06 [2KCG iteration 30, residual = 2.1144635491603968e-06 [2KCG iteration 31, residual = 1.5741672413055565e-06 [2KCG iteration 32, residual = 1.273628970498558e-06 [2KCG iteration 33, residual = 9.907928713446467e-07 [2KCG iteration 34, residual = 6.844333167405182e-07 [2KCG iteration 35, residual = 5.209053070412949e-07 [2KCG iteration 36, residual = 4.568172292716986e-07 [2KCG iteration 37, residual = 4.183905350569671e-07 [2KCG iteration 38, residual = 4.4131963560200954e-07 [2KCG iteration 39, residual = 4.576216131012646e-07 [2KCG iteration 40, residual = 4.808199436674436e-07 [2KCG iteration 41, residual = 4.2469808835652473e-07 [2KCG iteration 42, residual = 3.9674574928339127e-07 [2KCG iteration 43, residual = 3.650932917435777e-07 [2KCG iteration 44, residual = 2.803374559541772e-07 [2KCG iteration 45, residual = 2.066224509224966e-07 [2KCG iteration 46, residual = 1.6009696873251533e-07 [2KCG iteration 47, residual = 1.1729939039471745e-07 [2KCG iteration 48, residual = 8.509160483344586e-08 [2KCG iteration 49, residual = 6.677146958087672e-08 [2KCG iteration 50, residual = 5.983550400462125e-08 [2KCG iteration 51, residual = 4.9501827926878836e-08 [2KCG iteration 52, residual = 4.8662767458564916e-08 [2KCG iteration 53, residual = 5.057985666690043e-08 [2KCG iteration 54, residual = 5.525269896621186e-08 [2KCG iteration 55, residual = 5.2765473895518296e-08 [2KCG iteration 56, residual = 4.8312870384956525e-08 [2KCG iteration 57, residual = 4.148086667179793e-08 [2KCG iteration 58, residual = 3.6052629039443766e-08 [2KCG iteration 59, residual = 2.9245308899146918e-08 [2KCG iteration 60, residual = 2.1807179098499005e-08 [2KCG iteration 61, residual = 1.5745091645161814e-08 [2KCG iteration 62, residual = 1.1542714638801533e-08 [2KCG iteration 63, residual = 8.2320987751037e-09 [2KCG iteration 64, residual = 6.610284555352033e-09 [2KCG iteration 65, residual = 5.497986826115493e-09 [2KCG iteration 66, residual = 4.796893717798364e-09 [2KCG iteration 67, residual = 4.281836710299465e-09 [2KCG iteration 68, residual = 4.2959554665570075e-09 [2KCG iteration 69, residual = 4.311570536153215e-09 [2KCG iteration 70, residual = 4.590392637442209e-09 [2KCG iteration 71, residual = 4.506793293092738e-09 [2KCG iteration 72, residual = 4.139622593754485e-09 [2KCG iteration 73, residual = 3.427601807994836e-09 [2KCG iteration 74, residual = 2.68559451219286e-09 [2KCG iteration 75, residual = 1.9834677999340544e-09 [2KCG iteration 76, residual = 1.5589176327259367e-09 [2KCG iteration 77, residual = 1.1398076209992974e-09 [2KCG iteration 78, residual = 9.012773879072101e-10 [2KCG iteration 79, residual = 6.995760501495214e-10 [2KCG iteration 80, residual = 5.740011716221412e-10 [2KCG iteration 81, residual = 4.662494314676563e-10 [2KCG iteration 82, residual = 3.790772248368334e-10 [2KCG iteration 83, residual = 3.544934347107961e-10 [2KCG iteration 84, residual = 3.628712722973217e-10 [2KCG iteration 85, residual = 3.639606675860761e-10 [2KCG iteration 86, residual = 3.985766377780696e-10 [2KCG iteration 87, residual = 3.8710315812219294e-10 [2KCG iteration 88, residual = 3.603594688402203e-10 [2KCG iteration 89, residual = 3.125667511748389e-10 [2KCG iteration 90, residual = 2.6725065802865616e-10 [2KCG iteration 91, residual = 2.0195949400980511e-10 [2KCG iteration 92, residual = 1.5468385853990342e-10 [2KCG iteration 93, residual = 1.1385348064905098e-10 [2KCG iteration 94, residual = 8.382979641242175e-11 [2KCG iteration 95, residual = 6.979467914754399e-11 [2KCG iteration 96, residual = 5.8189598636404564e-11 [2KCG iteration 97, residual = 4.75998866472958e-11 [2KCG iteration 98, residual = 4.3385793062574054e-11 [2KCG iteration 99, residual = 4.1822840010817786e-11 [2KCG iteration 100, residual = 3.9974424158511716e-11 [2KCG iteration 101, residual = 3.9983273211595324e-11 [2KCG iteration 102, residual = 4.344553143752583e-11 [2KCG iteration 103, residual = 4.1224767751237936e-11 [2KCG iteration 104, residual = 4.138986422904719e-11 [2KCG iteration 105, residual = 3.428120859428714e-11 [2KCG converged in 105 iterations to residual 3.428120859428714e-11
0.013000000000000001[2KCG iteration 1, residual = 0.003501548648159748
[2KCG iteration 2, residual = 0.0002704264592622838 [2KCG iteration 3, residual = 0.00021811033544112253 [2KCG iteration 4, residual = 0.00022703780953112904 [2KCG iteration 5, residual = 0.00015210100375310912 [2KCG iteration 6, residual = 7.456062987193971e-05 [2KCG iteration 7, residual = 4.362160633201494e-05 [2KCG iteration 8, residual = 3.9903001076014705e-05 [2KCG iteration 9, residual = 3.063664505348078e-05 [2KCG iteration 10, residual = 2.350440652013465e-05 [2KCG iteration 11, residual = 3.072482279871859e-05 [2KCG iteration 12, residual = 3.8794696246496974e-05 [2KCG iteration 13, residual = 3.559941588503412e-05 [2KCG iteration 14, residual = 3.495553271665735e-05 [2KCG iteration 15, residual = 3.05050925532204e-05 [2KCG iteration 16, residual = 2.140652951072415e-05 [2KCG iteration 17, residual = 1.3862491076386607e-05 [2KCG iteration 18, residual = 1.0195887165127287e-05 [2KCG iteration 19, residual = 8.912170001007604e-06 [2KCG iteration 20, residual = 7.384224038094785e-06 [2KCG iteration 21, residual = 5.912178631573665e-06 [2KCG iteration 22, residual = 5.622074006380485e-06 [2KCG iteration 23, residual = 4.973155979270232e-06 [2KCG iteration 24, residual = 4.8879042054468016e-06 [2KCG iteration 25, residual = 5.150079209172899e-06 [2KCG iteration 26, residual = 5.478291658121387e-06 [2KCG iteration 27, residual = 5.25090188236447e-06 [2KCG iteration 28, residual = 4.2004893728416185e-06 [2KCG iteration 29, residual = 3.2042532397751472e-06 [2KCG iteration 30, residual = 2.090952527439466e-06 [2KCG iteration 31, residual = 1.551374910223987e-06 [2KCG iteration 32, residual = 1.258295555994245e-06 [2KCG iteration 33, residual = 9.813295091722776e-07 [2KCG iteration 34, residual = 6.792217091456914e-07 [2KCG iteration 35, residual = 5.175487607196566e-07 [2KCG iteration 36, residual = 4.5407880531646507e-07 [2KCG iteration 37, residual = 4.1536466681422267e-07 [2KCG iteration 38, residual = 4.3834972801640943e-07 [2KCG iteration 39, residual = 4.546511913024332e-07 [2KCG iteration 40, residual = 4.786005110996278e-07 [2KCG iteration 41, residual = 4.221174725883125e-07 [2KCG iteration 42, residual = 3.9412649815848124e-07 [2KCG iteration 43, residual = 3.624044847465726e-07 [2KCG iteration 44, residual = 2.782927185961125e-07 [2KCG iteration 45, residual = 2.0537003353780187e-07 [2KCG iteration 46, residual = 1.5891338364458233e-07 [2KCG iteration 47, residual = 1.1620621255413033e-07 [2KCG iteration 48, residual = 8.43064543632355e-08 [2KCG iteration 49, residual = 6.614883035818763e-08 [2KCG iteration 50, residual = 5.93894636822828e-08 [2KCG iteration 51, residual = 4.9303140091337144e-08 [2KCG iteration 52, residual = 4.840009528839753e-08 [2KCG iteration 53, residual = 5.014671860607761e-08 [2KCG iteration 54, residual = 5.4803944880450886e-08 [2KCG iteration 55, residual = 5.241047246081415e-08 [2KCG iteration 56, residual = 4.801708660050267e-08 [2KCG iteration 57, residual = 4.115114034841986e-08 [2KCG iteration 58, residual = 3.576986099936148e-08 [2KCG iteration 59, residual = 2.905920197099866e-08 [2KCG iteration 60, residual = 2.1703920954893522e-08 [2KCG iteration 61, residual = 1.5697529868941565e-08 [2KCG iteration 62, residual = 1.1485348407301095e-08 [2KCG iteration 63, residual = 8.179418566704779e-09 [2KCG iteration 64, residual = 6.559682135748078e-09 [2KCG iteration 65, residual = 5.447910687718864e-09 [2KCG iteration 66, residual = 4.7640272088525614e-09 [2KCG iteration 67, residual = 4.2547849462157744e-09 [2KCG iteration 68, residual = 4.273561836531771e-09 [2KCG iteration 69, residual = 4.283953704925025e-09 [2KCG iteration 70, residual = 4.558850313502563e-09 [2KCG iteration 71, residual = 4.477438544833983e-09 [2KCG iteration 72, residual = 4.114803401790865e-09 [2KCG iteration 73, residual = 3.4084367698639873e-09 [2KCG iteration 74, residual = 2.6758443341368156e-09 [2KCG iteration 75, residual = 1.9732264161541544e-09 [2KCG iteration 76, residual = 1.5505925439194304e-09 [2KCG iteration 77, residual = 1.1356800496121974e-09 [2KCG iteration 78, residual = 8.965902956062222e-10 [2KCG iteration 79, residual = 6.960425530052373e-10 [2KCG iteration 80, residual = 5.719506146087113e-10 [2KCG iteration 81, residual = 4.645409712829188e-10 [2KCG iteration 82, residual = 3.773100750381153e-10 [2KCG iteration 83, residual = 3.5312958822183303e-10 [2KCG iteration 84, residual = 3.6049859742515556e-10 [2KCG iteration 85, residual = 3.6290295862509457e-10 [2KCG iteration 86, residual = 3.973511480132965e-10 [2KCG iteration 87, residual = 3.862755465509669e-10 [2KCG iteration 88, residual = 3.591994923527484e-10 [2KCG iteration 89, residual = 3.107611978194337e-10 [2KCG iteration 90, residual = 2.6625509601791987e-10 [2KCG iteration 91, residual = 2.0084731183035902e-10 [2KCG iteration 92, residual = 1.5446398453711415e-10 [2KCG iteration 93, residual = 1.1358615492334435e-10 [2KCG iteration 94, residual = 8.353666894921782e-11 [2KCG iteration 95, residual = 6.960166373733907e-11 [2KCG iteration 96, residual = 5.7999624026959105e-11 [2KCG iteration 97, residual = 4.753161050250706e-11 [2KCG iteration 98, residual = 4.3241855465365475e-11 [2KCG iteration 99, residual = 4.177386483077848e-11 [2KCG iteration 100, residual = 3.9832722713471927e-11 [2KCG iteration 101, residual = 3.992117312998736e-11 [2KCG iteration 102, residual = 4.315166375702307e-11 [2KCG iteration 103, residual = 4.1146553675481946e-11 [2KCG iteration 104, residual = 4.126101576180805e-11 [2KCG iteration 105, residual = 3.4220074951956934e-11 [2KCG converged in 105 iterations to residual 3.4220074951956934e-11
0.014[2KCG iteration 1, residual = 0.0035012754247166528
[2KCG iteration 2, residual = 0.00026975157258901606 [2KCG iteration 3, residual = 0.0002169495678562328 [2KCG iteration 4, residual = 0.0002261867183080457 [2KCG iteration 5, residual = 0.0001520266989698739 [2KCG iteration 6, residual = 7.437597509908908e-05 [2KCG iteration 7, residual = 4.322047801850365e-05 [2KCG iteration 8, residual = 3.947680885419888e-05 [2KCG iteration 9, residual = 3.0468967444215667e-05 [2KCG iteration 10, residual = 2.3418575959258167e-05 [2KCG iteration 11, residual = 3.064725999007974e-05 [2KCG iteration 12, residual = 3.880259822309396e-05 [2KCG iteration 13, residual = 3.5588082373962224e-05 [2KCG iteration 14, residual = 3.4845256397659454e-05 [2KCG iteration 15, residual = 3.0344898533038263e-05
CG iteration 16, residual = 2.1283069968562773e-05CG iteration 17, residual = 1.379131542907579e-05 CG iteration 18, residual = 1.0137874431575838e-05 CG iteration 19, residual = 8.835893970439848e-06 CG iteration 20, residual = 7.328386194982939e-06 CG iteration 21, residual = 5.873124429118635e-06 CG iteration 22, residual = 5.571404227744219e-06 CG iteration 23, residual = 4.925986637910203e-06 CG iteration 24, residual = 4.841074475233745e-06 CG iteration 25, residual = 5.092459998174884e-06 CG iteration 26, residual = 5.416119036974821e-06 CG iteration 27, residual = 5.2004179013547245e-06 CG iteration 28, residual = 4.1667655766022685e-06 CG iteration 29, residual = 3.1795608110097975e-06 CG iteration 30, residual = 2.068218164949624e-06 CG iteration 31, residual = 1.5292806459766922e-06 CG iteration 32, residual = 1.2433300880940953e-06 CG iteration 33, residual = 9.720508243083965e-07 CG iteration 34, residual = 6.741430557784576e-07 CG iteration 35, residual = 5.143077788884362e-07 CG iteration 36, residual = 4.514411951515217e-07 CG iteration 37, residual = 4.1241960107453426e-07 CG iteration 38, residual = 4.354423440047844e-07 CG iteration 39, residual = 4.5174088704884387e-07 CG iteration 40, residual = 4.764302625125126e-07 CG iteration 41, residual = 4.1962955325595173e-07 CG iteration 42, residual = 3.9160117944764005e-07 CG iteration 43, residual = 3.5977278198051743e-07 CG iteration 44, residual = 2.76278576128983e-07 CG iteration 45, residual = 2.041367929261953e-07 CG iteration 46, residual = 1.5774239051601768e-07 CG iteration 47, residual = 1.1513460605022517e-07 CG iteration 48, residual = 8.354318180230176e-08 CG iteration 49, residual = 6.554065880217675e-08 CG iteration 50, residual = 5.89502784100418e-08 CG iteration 51, residual = 4.911252366459265e-08 CG iteration 52, residual = 4.8147345893102396e-08 CG iteration 53, residual = 4.9728143341154705e-08 CG iteration 54, residual = 5.4366935783148394e-08 CG iteration 55, residual = 5.206485783756618e-08 CG iteration 56, residual = 4.77287015665875e-08 CG iteration 57, residual = 4.083043266659396e-08 CG iteration 58, residual = 3.54960992983666e-08 CG iteration 59, residual = 2.887643983527735e-08 CG iteration 60, residual = 2.1600435835941932e-08 CG iteration 61, residual = 1.565001578463119e-08 CG iteration 62, residual = 1.1427870921579511e-08 CG iteration 63, residual = 8.127222461127802e-09 CG iteration 64, residual = 6.509997379605593e-09 CG iteration 65, residual = 5.398656215629369e-09 CG iteration 66, residual = 4.731880526344753e-09 CG iteration 67, residual = 4.22860914003013e-09 CG iteration 68, residual = 4.251706728793238e-09 CG iteration 69, residual = 4.25727734750628e-09 CG iteration 70, residual = 4.528558280003848e-09 CG iteration 71, residual = 4.448667089246351e-09 CG iteration 72, residual = 4.089755476431256e-09 CG iteration 73, residual = 3.389327160416289e-09 CG iteration 74, residual = 2.666381003512745e-09 CG iteration 75, residual = 1.9632163221267805e-09 CG iteration 76, residual = 1.5422674447445054e-09 CG iteration 77, residual = 1.1316069725125517e-09 CG iteration 78, residual = 8.919145213715295e-10 CG iteration 79, residual = 6.925111445885801e-10 CG iteration 80, residual = 5.697540641415492e-10 CG iteration 81, residual = 4.6274484678470056e-10 CG iteration 82, residual = 3.7553749045307455e-10 CG iteration 83, residual = 3.5166877441859497e-10 CG iteration 84, residual = 3.5805230895754917e-10 CG iteration 85, residual = 3.617938354372564e-10 CG iteration 86, residual = 3.95944033754149e-10 CG iteration 87, residual = 3.8538131126364744e-10 CG iteration 88, residual = 3.5801609030319e-10 CG iteration 89, residual = 3.0894549776696846e-10 CG iteration 90, residual = 2.6519324282474704e-10 CG iteration 91, residual = 1.997321702647435e-10 CG iteration 92, residual = 1.5423891962955264e-10 CG iteration 93, residual = 1.1330540187348595e-10 CG iteration 94, residual = 8.325821400541303e-11 CG iteration 95, residual = 6.940994077489148e-11 CG iteration 96, residual = 5.7799230253765245e-11 CG iteration 97, residual = 4.745840858240284e-11 CG iteration 98, residual = 4.3089468576653125e-11 CG iteration 99, residual = 4.170544915705664e-11 CG iteration 100, residual = 3.9682623779701164e-11 CG iteration 101, residual = 3.985103383415137e-11 CG iteration 102, residual = 4.2843022527666446e-11 CG iteration 103, residual = 4.1063532426688054e-11 CG iteration 104, residual = 4.111281046499317e-11 CG iteration 105, residual = 3.416111700780233e-11 CG converged in 105 iterations to residual 3.416111700780233e-11
0.015CG iteration 1, residual = 0.003501003688552644
CG iteration 2, residual = 0.00026910053990292893 CG iteration 3, residual = 0.00021584457252678241 CG iteration 4, residual = 0.00022537640664181373 CG iteration 5, residual = 0.00015196063595981812 CG iteration 6, residual = 7.419765954073645e-05 CG iteration 7, residual = 4.2829168646680205e-05 CG iteration 8, residual = 3.906110194660634e-05 CG iteration 9, residual = 3.030863551734353e-05 CG iteration 10, residual = 2.3340609736847855e-05 CG iteration 11, residual = 3.057978727330174e-05 CG iteration 12, residual = 3.8820220749934246e-05 CG iteration 13, residual = 3.558206569372887e-05 CG iteration 14, residual = 3.4735888511865027e-05 CG iteration 15, residual = 3.018451722337141e-05 CG iteration 16, residual = 2.1160136762217003e-05
</pre>
end{sphinxVerbatim}
[2KCG iteration 17, residual = 1.379131542907579e-05 [2KCG iteration 18, residual = 1.0137874431575838e-05 [2KCG iteration 19, residual = 8.835893970439848e-06 [2KCG iteration 20, residual = 7.328386194982939e-06 [2KCG iteration 21, residual = 5.873124429118635e-06 [2KCG iteration 22, residual = 5.571404227744219e-06 [2KCG iteration 23, residual = 4.925986637910203e-06 [2KCG iteration 24, residual = 4.841074475233745e-06 [2KCG iteration 25, residual = 5.092459998174884e-06 [2KCG iteration 26, residual = 5.416119036974821e-06 [2KCG iteration 27, residual = 5.2004179013547245e-06 [2KCG iteration 28, residual = 4.1667655766022685e-06 [2KCG iteration 29, residual = 3.1795608110097975e-06 [2KCG iteration 30, residual = 2.068218164949624e-06 [2KCG iteration 31, residual = 1.5292806459766922e-06 [2KCG iteration 32, residual = 1.2433300880940953e-06 [2KCG iteration 33, residual = 9.720508243083965e-07 [2KCG iteration 34, residual = 6.741430557784576e-07 [2KCG iteration 35, residual = 5.143077788884362e-07 [2KCG iteration 36, residual = 4.514411951515217e-07 [2KCG iteration 37, residual = 4.1241960107453426e-07 [2KCG iteration 38, residual = 4.354423440047844e-07 [2KCG iteration 39, residual = 4.5174088704884387e-07 [2KCG iteration 40, residual = 4.764302625125126e-07 [2KCG iteration 41, residual = 4.1962955325595173e-07 [2KCG iteration 42, residual = 3.9160117944764005e-07 [2KCG iteration 43, residual = 3.5977278198051743e-07 [2KCG iteration 44, residual = 2.76278576128983e-07 [2KCG iteration 45, residual = 2.041367929261953e-07 [2KCG iteration 46, residual = 1.5774239051601768e-07 [2KCG iteration 47, residual = 1.1513460605022517e-07 [2KCG iteration 48, residual = 8.354318180230176e-08 [2KCG iteration 49, residual = 6.554065880217675e-08 [2KCG iteration 50, residual = 5.89502784100418e-08 [2KCG iteration 51, residual = 4.911252366459265e-08 [2KCG iteration 52, residual = 4.8147345893102396e-08 [2KCG iteration 53, residual = 4.9728143341154705e-08 [2KCG iteration 54, residual = 5.4366935783148394e-08 [2KCG iteration 55, residual = 5.206485783756618e-08 [2KCG iteration 56, residual = 4.77287015665875e-08 [2KCG iteration 57, residual = 4.083043266659396e-08 [2KCG iteration 58, residual = 3.54960992983666e-08 [2KCG iteration 59, residual = 2.887643983527735e-08 [2KCG iteration 60, residual = 2.1600435835941932e-08 [2KCG iteration 61, residual = 1.565001578463119e-08 [2KCG iteration 62, residual = 1.1427870921579511e-08 [2KCG iteration 63, residual = 8.127222461127802e-09 [2KCG iteration 64, residual = 6.509997379605593e-09 [2KCG iteration 65, residual = 5.398656215629369e-09 [2KCG iteration 66, residual = 4.731880526344753e-09 [2KCG iteration 67, residual = 4.22860914003013e-09 [2KCG iteration 68, residual = 4.251706728793238e-09 [2KCG iteration 69, residual = 4.25727734750628e-09 [2KCG iteration 70, residual = 4.528558280003848e-09 [2KCG iteration 71, residual = 4.448667089246351e-09 [2KCG iteration 72, residual = 4.089755476431256e-09 [2KCG iteration 73, residual = 3.389327160416289e-09 [2KCG iteration 74, residual = 2.666381003512745e-09 [2KCG iteration 75, residual = 1.9632163221267805e-09 [2KCG iteration 76, residual = 1.5422674447445054e-09 [2KCG iteration 77, residual = 1.1316069725125517e-09 [2KCG iteration 78, residual = 8.919145213715295e-10 [2KCG iteration 79, residual = 6.925111445885801e-10 [2KCG iteration 80, residual = 5.697540641415492e-10 [2KCG iteration 81, residual = 4.6274484678470056e-10 [2KCG iteration 82, residual = 3.7553749045307455e-10 [2KCG iteration 83, residual = 3.5166877441859497e-10 [2KCG iteration 84, residual = 3.5805230895754917e-10 [2KCG iteration 85, residual = 3.617938354372564e-10 [2KCG iteration 86, residual = 3.95944033754149e-10 [2KCG iteration 87, residual = 3.8538131126364744e-10 [2KCG iteration 88, residual = 3.5801609030319e-10 [2KCG iteration 89, residual = 3.0894549776696846e-10 [2KCG iteration 90, residual = 2.6519324282474704e-10 [2KCG iteration 91, residual = 1.997321702647435e-10 [2KCG iteration 92, residual = 1.5423891962955264e-10 [2KCG iteration 93, residual = 1.1330540187348595e-10 [2KCG iteration 94, residual = 8.325821400541303e-11 [2KCG iteration 95, residual = 6.940994077489148e-11 [2KCG iteration 96, residual = 5.7799230253765245e-11 [2KCG iteration 97, residual = 4.745840858240284e-11 [2KCG iteration 98, residual = 4.3089468576653125e-11 [2KCG iteration 99, residual = 4.170544915705664e-11 [2KCG iteration 100, residual = 3.9682623779701164e-11 [2KCG iteration 101, residual = 3.985103383415137e-11 [2KCG iteration 102, residual = 4.2843022527666446e-11 [2KCG iteration 103, residual = 4.1063532426688054e-11 [2KCG iteration 104, residual = 4.111281046499317e-11 [2KCG iteration 105, residual = 3.416111700780233e-11 [2KCG converged in 105 iterations to residual 3.416111700780233e-11
0.015[2KCG iteration 1, residual = 0.003501003688552644
[2KCG iteration 2, residual = 0.00026910053990292893 [2KCG iteration 3, residual = 0.00021584457252678241 [2KCG iteration 4, residual = 0.00022537640664181373 [2KCG iteration 5, residual = 0.00015196063595981812 [2KCG iteration 6, residual = 7.419765954073645e-05 [2KCG iteration 7, residual = 4.2829168646680205e-05 [2KCG iteration 8, residual = 3.906110194660634e-05 [2KCG iteration 9, residual = 3.030863551734353e-05 [2KCG iteration 10, residual = 2.3340609736847855e-05 [2KCG iteration 11, residual = 3.057978727330174e-05 [2KCG iteration 12, residual = 3.8820220749934246e-05 [2KCG iteration 13, residual = 3.558206569372887e-05 [2KCG iteration 14, residual = 3.4735888511865027e-05 [2KCG iteration 15, residual = 3.018451722337141e-05 [2KCG iteration 16, residual = 2.1160136762217003e-05
CG iteration 17, residual = 1.3720378473718314e-05CG iteration 18, residual = 1.0081078567536558e-05 CG iteration 19, residual = 8.761852041144736e-06 CG iteration 20, residual = 7.273845921450485e-06 CG iteration 21, residual = 5.834563477371868e-06 CG iteration 22, residual = 5.521455897045731e-06 CG iteration 23, residual = 4.879805188070319e-06 CG iteration 24, residual = 4.7955616970648215e-06 CG iteration 25, residual = 5.0368319241337685e-06 CG iteration 26, residual = 5.356148188582378e-06 CG iteration 27, residual = 5.1511743760165325e-06 CG iteration 28, residual = 4.133534950744866e-06 CG iteration 29, residual = 3.155444653550036e-06 CG iteration 30, residual = 2.0462191288422454e-06 CG iteration 31, residual = 1.5078612450879973e-06 CG iteration 32, residual = 1.2287304633079764e-06 CG iteration 33, residual = 9.629561638497155e-07 CG iteration 34, residual = 6.691918464790142e-07 CG iteration 35, residual = 5.11176122926403e-07 CG iteration 36, residual = 4.488994324880371e-07 CG iteration 37, residual = 4.0955185646470935e-07 CG iteration 38, residual = 4.325959408336078e-07 CG iteration 39, residual = 4.488901827652406e-07 CG iteration 40, residual = 4.7430827914506717e-07 CG iteration 41, residual = 4.1723064264119773e-07 CG iteration 42, residual = 3.8916592885603954e-07 CG iteration 43, residual = 3.571954986338259e-07 CG iteration 44, residual = 2.742932191390765e-07 CG iteration 45, residual = 2.0292108648425786e-07 CG iteration 46, residual = 1.565824098582166e-07 CG iteration 47, residual = 1.1408362549989792e-07 CG iteration 48, residual = 8.280110683252189e-08 CG iteration 49, residual = 6.494677556792294e-08 CG iteration 50, residual = 5.851803522364796e-08 CG iteration 51, residual = 4.8929561102427814e-08 CG iteration 52, residual = 4.790377685816714e-08 CG iteration 53, residual = 4.932358958579545e-08 CG iteration 54, residual = 5.39414850530249e-08 CG iteration 55, residual = 5.1728330977699596e-08 CG iteration 56, residual = 4.744718531610499e-08 CG iteration 57, residual = 4.051838112184153e-08 CG iteration 58, residual = 3.523100771024585e-08 CG iteration 59, residual = 2.8696842165631107e-08 CG iteration 60, residual = 2.1496719035592212e-08 CG iteration 61, residual = 1.560245208861204e-08 CG iteration 62, residual = 1.1370163397586533e-08 CG iteration 63, residual = 8.075467294616568e-09 CG iteration 64, residual = 6.461204242094219e-09 CG iteration 65, residual = 5.350199921114948e-09 CG iteration 66, residual = 4.7004462031874535e-09 CG iteration 67, residual = 4.20327875372649e-09 CG iteration 68, residual = 4.230364316344367e-09 CG iteration 69, residual = 4.231505991278815e-09 CG iteration 70, residual = 4.499449651500523e-09 CG iteration 71, residual = 4.420446261443633e-09 CG iteration 72, residual = 4.0645036290462695e-09 CG iteration 73, residual = 3.37027248820501e-09 CG iteration 74, residual = 2.6571683961971647e-09 CG iteration 75, residual = 1.9534220740219337e-09 CG iteration 76, residual = 1.5339472423344943e-09 CG iteration 77, residual = 1.127581667475511e-09 CG iteration 78, residual = 8.872494490975546e-10 CG iteration 79, residual = 6.889841915045716e-10 CG iteration 80, residual = 5.674160727831443e-10 CG iteration 81, residual = 4.608694419967108e-10 CG iteration 82, residual = 3.7376129742139923e-10 CG iteration 83, residual = 3.501163946490125e-10 CG iteration 84, residual = 3.5554994089033096e-10 CG iteration 85, residual = 3.6064002628910424e-10 CG iteration 86, residual = 3.9436591536369633e-10 CG iteration 87, residual = 3.8442989133052494e-10 CG iteration 88, residual = 3.5681286389417633e-10 CG iteration 89, residual = 3.0712505838488086e-10 CG iteration 90, residual = 2.6406905639807614e-10 CG iteration 91, residual = 1.9861791302436304e-10 CG iteration 92, residual = 1.5400757512579364e-10 CG iteration 93, residual = 1.1301134256610059e-10 CG iteration 94, residual = 8.299480667787761e-11 CG iteration 95, residual = 6.921915761133321e-11 CG iteration 96, residual = 5.7589355584808635e-11 CG iteration 97, residual = 4.738098783384326e-11 CG iteration 98, residual = 4.2929066339362315e-11 CG iteration 99, residual = 4.161838290359843e-11 CG iteration 100, residual = 3.952537221831324e-11 CG iteration 101, residual = 3.977290866629629e-11 CG iteration 102, residual = 4.2521919266808065e-11 CG iteration 103, residual = 4.0976389832833345e-11 CG iteration 104, residual = 4.094628785163466e-11 CG iteration 105, residual = 3.410442911028546e-11 CG converged in 105 iterations to residual 3.410442911028546e-11
0.016CG iteration 1, residual = 0.0035007331956602755
CG iteration 2, residual = 0.00026847196870938766 CG iteration 3, residual = 0.00021479220795323918 CG iteration 4, residual = 0.00022460492536767422 CG iteration 5, residual = 0.00015190220292986438 CG iteration 6, residual = 7.402521433454168e-05 CG iteration 7, residual = 4.244712324733997e-05 CG iteration 8, residual = 3.865530385884956e-05 CG iteration 9, residual = 3.0155212790775684e-05 CG iteration 10, residual = 2.3269987627815142e-05 CG iteration 11, residual = 3.0521554172054045e-05 CG iteration 12, residual = 3.88465850288125e-05 CG iteration 13, residual = 3.558057819220283e-05 CG iteration 14, residual = 3.4626916532234714e-05 CG iteration 15, residual = 3.0023736091307316e-05 CG iteration 16, residual = 2.1037654003244632e-05 CG iteration 17, residual = 1.364967267485448e-05 CG iteration 18, residual = 1.0025451361585392e-05 CG iteration 19, residual = 8.689969820408403e-06 CG iteration 20, residual = 7.2205970631917335e-06 CG iteration 21, residual = 5.7965288876047305e-06 CG iteration 22, residual = 5.472257539180393e-06 CG iteration 23, residual = 4.834616621087196e-06 CG iteration 24, residual = 4.751359336887825e-06 CG iteration 25, residual = 4.983166636779819e-06 CG iteration 26, residual = 5.29834133145188e-06 CG iteration 27, residual = 5.10316695891717e-06 CG iteration 28, residual = 4.100791559269805e-06 CG iteration 29, residual = 3.1318712648564646e-06 CG iteration 30, residual = 2.024916406942397e-06 CG iteration 31, residual = 1.487093949434298e-06 CG iteration 32, residual = 1.2144938619691762e-06 CG iteration 33, residual = 9.54044974074901e-07 CG iteration 34, residual = 6.643631825604382e-07 CG iteration 35, residual = 5.08147893030071e-07 CG iteration 36, residual = 4.464486805199639e-07 CG iteration 37, residual = 4.0675819098026104e-07 CG iteration 38, residual = 4.29809193274338e-07 CG iteration 39, residual = 4.460986807832931e-07 CG iteration 40, residual = 4.722338447355998e-07 CG iteration 41, residual = 4.1491737720219007e-07 CG iteration 42, residual = 3.8681701374278096e-07 CG iteration 43, residual = 3.5467000949641855e-07 CG iteration 44, residual = 2.723349930642448e-07 CG iteration 45, residual = 2.0172145187116722e-07 CG iteration 46, residual = 1.5543204609144128e-07 CG iteration 47, residual = 1.1305239997038482e-07 CG iteration 48, residual = 8.207958588633842e-08 CG iteration 49, residual = 6.436701099723498e-08 CG iteration 50, residual = 5.8092828824897026e-08 CG iteration 51, residual = 4.8753873196024153e-08 CG iteration 52, residual = 4.7668710481632465e-08 CG iteration 53, residual = 4.893253990609414e-08 CG iteration 54, residual = 5.3527403066053766e-08 CG iteration 55, residual = 5.140063315260353e-08 CG iteration 56, residual = 4.717206623217991e-08 CG iteration 57, residual = 4.0214654475864654e-08 CG iteration 58, residual = 3.4974265024721386e-08 CG iteration 59, residual = 2.8520249631515595e-08 CG iteration 60, residual = 2.1392778132582488e-08 CG iteration 61, residual = 1.5554748829673704e-08 CG iteration 62, residual = 1.1312125836646122e-08 CG iteration 63, residual = 8.024122367362901e-09 CG iteration 64, residual = 6.413281322280139e-09 CG iteration 65, residual = 5.3025229605631516e-09 CG iteration 66, residual = 4.669720070618245e-09 CG iteration 67, residual = 4.178767024706176e-09 CG iteration 68, residual = 4.2095151905040355e-09 CG iteration 69, residual = 4.2066099451941185e-09 CG iteration 70, residual = 4.4714624508854515e-09 CG iteration 71, residual = 4.392747331337371e-09 CG iteration 72, residual = 4.039079089813899e-09 CG iteration 73, residual = 3.3512774071519293e-09 CG iteration 74, residual = 2.6481738787792426e-09 CG iteration 75, residual = 1.943830275017003e-09 CG iteration 76, residual = 1.5256376757701614e-09 CG iteration 77, residual = 1.1235987934232147e-09 CG iteration 78, residual = 8.82595263466332e-10 CG iteration 79, residual = 6.854641378083223e-10 CG iteration 80, residual = 5.649424101611164e-10 CG iteration 81, residual = 4.5892359285047796e-10 CG iteration 82, residual = 3.7198360166809e-10 CG iteration 83, residual = 3.4847879488448607e-10 CG iteration 84, residual = 3.5300833833241335e-10 CG iteration 85, residual = 3.594483586319962e-10 CG iteration 86, residual = 3.926290110687531e-10 CG iteration 87, residual = 3.8343062452525745e-10 CG iteration 88, residual = 3.5559327409027004e-10 CG iteration 89, residual = 3.053052313160387e-10 CG iteration 90, residual = 2.6288674540268123e-10 CG iteration 91, residual = 1.9750825962594497e-10 CG iteration 92, residual = 1.537688091115366e-10 CG iteration 93, residual = 1.1270439053357734e-10 CG iteration 94, residual = 8.27467991955853e-11 CG iteration 95, residual = 6.902887399405843e-11 CG iteration 96, residual = 5.7371064575334604e-11 CG iteration 97, residual = 4.730005896030211e-11 CG iteration 98, residual = 4.2761086276952945e-11 CG iteration 99, residual = 4.151360273871223e-11 CG iteration 100, residual = 3.936218228000607e-11 CG iteration 101, residual = 3.968685996899888e-11 CG iteration 102, residual = 4.2190658133456135e-11 CG iteration 103, residual = 4.0885765816868945e-11 CG iteration 104, residual = 4.076258266020783e-11 CG iteration 105, residual = 3.405010262573133e-11 CG converged in 105 iterations to residual 3.405010262573133e-11
0.017CG iteration 1, residual = 0.0035004637230376143
CG iteration 2, residual = 0.0002678645613925381 CG iteration 3, residual = 0.00021378953879856594 CG iteration 4, residual = 0.0002238704181200924 CG iteration 5, residual = 0.00015185083036029884 CG iteration 6, residual = 7.3858212020731e-05 CG iteration 7, residual = 4.2073833542658956e-05 CG iteration 8, residual = 3.8258880702200375e-05 CG iteration 9, residual = 3.000829590031622e-05 CG iteration 10, residual = 2.3206234497526605e-05 CG iteration 11, residual = 3.0471777887379656e-05 CG iteration 12, residual = 3.888078382248407e-05 CG iteration 13, residual = 3.5582902435367474e-05 CG iteration 14, residual = 3.451789350862345e-05 CG iteration 15, residual = 2.9862384155580684e-05 CG iteration 16, residual = 2.0915568173091894e-05 CG iteration 17, residual = 1.3579202202476354e-05 CG iteration 18, residual = 9.970952641555279e-06 CG iteration 19, residual = 8.620177550217569e-06 CG iteration 20, residual = 7.168631506569559e-06 CG iteration 21, residual = 5.7590497866337655e-06 CG iteration 22, residual = 5.423833571537591e-06 CG iteration 23, residual = 4.7904235572995885e-06 CG iteration 24, residual = 4.7084579407597625e-06 CG iteration 25, residual = 4.931431790287915e-06 CG iteration 26, residual = 5.2426569762042175e-06 CG iteration 27, residual = 5.056388239913798e-06 CG iteration 28, residual = 4.068529003388338e-06 CG iteration 29, residual = 3.108808968836604e-06 CG iteration 30, residual = 2.0042732198197555e-06 CG iteration 31, residual = 1.4669565056686366e-06 CG iteration 32, residual = 1.2006168213860513e-06 CG iteration 33, residual = 9.453167489464185e-07 CG iteration 34, residual = 6.59652694899186e-07 CG iteration 35, residual = 5.052175003115568e-07 CG iteration 36, residual = 4.440842279940822e-07 CG iteration 37, residual = 4.040355655108097e-07 CG iteration 38, residual = 4.2708094440555135e-07 CG iteration 39, residual = 4.4336606629403494e-07 CG iteration 40, residual = 4.702063955231843e-07 CG iteration 41, residual = 4.1268665659725973e-07 CG iteration 42, residual = 3.8455081392852347e-07 CG iteration 43, residual = 3.5219374877169744e-07 CG iteration 44, residual = 2.7040237880049424e-07 CG iteration 45, residual = 2.0053658660550325e-07 CG iteration 46, residual = 1.5429007666737061e-07 CG iteration 47, residual = 1.1204012859229277e-07 CG iteration 48, residual = 8.13780072347048e-08 CG iteration 49, residual = 6.380119988535457e-08 CG iteration 50, residual = 5.767475511192732e-08 CG iteration 51, residual = 4.858511128438801e-08 CG iteration 52, residual = 4.744152521027891e-08 CG iteration 53, residual = 4.855449578050247e-08 CG iteration 54, residual = 5.312449373682227e-08 CG iteration 55, residual = 5.108153568827667e-08 CG iteration 56, residual = 4.690292307715924e-08 CG iteration 57, residual = 3.991894885287886e-08 CG iteration 58, residual = 3.472556313529518e-08 CG iteration 59, residual = 2.8346520416105443e-08 CG iteration 60, residual = 2.1288630376029657e-08 CG iteration 61, residual = 1.5506822344393532e-08 CG iteration 62, residual = 1.1253675700537333e-08 CG iteration 63, residual = 7.973167864056538e-09 CG iteration 64, residual = 6.366210972304682e-09 CG iteration 65, residual = 5.255610244223652e-09 CG iteration 66, residual = 4.639700194127765e-09 CG iteration 67, residual = 4.1550500578852225e-09 CG iteration 68, residual = 4.189145108169495e-09 CG iteration 69, residual = 4.182563695608077e-09 CG iteration 70, residual = 4.444538467552277e-09 CG iteration 71, residual = 4.365544840733314e-09 CG iteration 72, residual = 4.013518019728877e-09 CG iteration 73, residual = 3.332350565414217e-09 CG iteration 74, residual = 2.6393678347275616e-09 CG iteration 75, residual = 1.9344293416999057e-09 CG iteration 76, residual = 1.517345058769454e-09 CG iteration 77, residual = 1.119654116053648e-09 CG iteration 78, residual = 8.779527026697897e-10 CG iteration 79, residual = 6.819534044722841e-10 CG iteration 80, residual = 5.623398400346102e-10 CG iteration 81, residual = 4.569162935460036e-10 CG iteration 82, residual = 3.7020660545358793e-10 CG iteration 83, residual = 3.467630389027665e-10 CG iteration 84, residual = 3.5044336897844125e-10 CG iteration 85, residual = 3.582254820985328e-10 CG iteration 86, residual = 3.9074673725494274e-10 CG iteration 87, residual = 3.823925116822062e-10 CG iteration 88, residual = 3.5436051495645367e-10 CG iteration 89, residual = 3.034911890089008e-10 CG iteration 90, residual = 2.6165068529194794e-10 CG iteration 91, residual = 1.964067473096308e-10 CG iteration 92, residual = 1.535214094763801e-10 CG iteration 93, residual = 1.1238522477551103e-10 CG iteration 94, residual = 8.251449856686948e-11 CG iteration 95, residual = 6.883856715892686e-11 CG iteration 96, residual = 5.714552076712561e-11 CG iteration 97, residual = 4.7216309776469777e-11 CG iteration 98, residual = 4.258596273478263e-11 CG iteration 99, residual = 4.139216645125402e-11 CG iteration 100, residual = 3.9194213139549445e-11 CG iteration 101, residual = 3.959294980504733e-11 CG iteration 102, residual = 4.185150230163987e-11 CG iteration 103, residual = 4.079223505243692e-11 CG iteration 104, residual = 4.056290384722825e-11 CG iteration 105, residual = 3.399822064357001e-11 CG converged in 105 iterations to residual 3.399822064357001e-11
0.018000000000000002CG iteration 1, residual = 0.003500195067129859
CG iteration 2, residual = 0.0002672771081996773 CG iteration 3, residual = 0.00021283382105538565 CG iteration 4, residual = 0.00022317111797377545 CG iteration 5, residual = 0.00015180598785780654 CG iteration 6, residual = 7.369626301211169e-05 CG iteration 7, residual = 4.170883414219223e-05 CG iteration 8, residual = 3.787133827905374e-05 CG iteration 9, residual = 2.9867512065166115e-05 CG iteration 10, residual = 2.3148916762472193e-05 CG iteration 11, residual = 3.0429738509132495e-05 CG iteration 12, residual = 3.8921976907207034e-05 CG iteration 13, residual = 3.5588386426018936e-05 CG iteration 14, residual = 3.440843283391508e-05 CG iteration 15, residual = 2.9700327459156413e-05 CG iteration 16, residual = 2.079384485947761e-05 CG iteration 17, residual = 1.350898074855908e-05 CG iteration 18, residual = 9.91754881470016e-06 CG iteration 19, residual = 8.552409266664977e-06 CG iteration 20, residual = 7.1179388836489685e-06 CG iteration 21, residual = 5.722151071643258e-06 CG iteration 22, residual = 5.376204119011149e-06 CG iteration 23, residual = 4.747226081852187e-06 CG iteration 24, residual = 4.6668451368876035e-06 CG iteration 25, residual = 4.881591320353026e-06 CG iteration 26, residual = 5.189050194126394e-06 CG iteration 27, residual = 5.0108277672929844e-06 CG iteration 28, residual = 4.03674034197978e-06 CG iteration 29, residual = 3.086227839246918e-06 CG iteration 30, residual = 1.984254931124881e-06 CG iteration 31, residual = 1.447427214810992e-06 CG iteration 32, residual = 1.1870953053704643e-06 CG iteration 33, residual = 9.367709850892174e-07 CG iteration 34, residual = 6.550564697438401e-07 CG iteration 35, residual = 5.023796412655621e-07 CG iteration 36, residual = 4.418014859228068e-07 CG iteration 37, residual = 4.0138111322980155e-07 CG iteration 38, residual = 4.2441016443958086e-07 CG iteration 39, residual = 4.406920760137403e-07 CG iteration 40, residual = 4.6822547674765513e-07 CG iteration 41, residual = 4.105355916017849e-07 CG iteration 42, residual = 3.8236380611986044e-07 CG iteration 43, residual = 3.4976421056074444e-07 CG iteration 44, residual = 2.6849397673140793e-07 CG iteration 45, residual = 1.9936533056244152e-07 CG iteration 46, residual = 1.5315544146804e-07 CG iteration 47, residual = 1.110460762137788e-07 CG iteration 48, residual = 8.069578695014903e-08 CG iteration 49, residual = 6.324917740569165e-08 CG iteration 50, residual = 5.726390581303033e-08 CG iteration 51, residual = 4.8422950630798294e-08 CG iteration 52, residual = 4.722164829996291e-08 CG iteration 53, residual = 4.818897374853017e-08 CG iteration 54, residual = 5.27325522098671e-08 CG iteration 55, residual = 5.07708314485264e-08 CG iteration 56, residual = 4.663937811676006e-08 CG iteration 57, residual = 3.963098428152172e-08 CG iteration 58, residual = 3.448460546336334e-08 CG iteration 59, residual = 2.8175527194746234e-08 CG iteration 60, residual = 2.118430044153484e-08 CG iteration 61, residual = 1.545859439410772e-08 CG iteration 62, residual = 1.1194746658629123e-08 CG iteration 63, residual = 7.922593413119037e-09 CG iteration 64, residual = 6.3199785239834826e-09 CG iteration 65, residual = 5.209449674285097e-09 CG iteration 66, residual = 4.610385992126006e-09 CG iteration 67, residual = 4.1321060855172405e-09 CG iteration 68, residual = 4.1692438900403095e-09 CG iteration 69, residual = 4.15934457015755e-09 CG iteration 70, residual = 4.418622323386571e-09 CG iteration 71, residual = 4.33881608442608e-09 CG iteration 72, residual = 3.9878601899999555e-09 CG iteration 73, residual = 3.31350361023992e-09 CG iteration 74, residual = 2.630723251294511e-09 CG iteration 75, residual = 1.9252093062366813e-09 CG iteration 76, residual = 1.5090760725274065e-09 CG iteration 77, residual = 1.1157442721576286e-09 CG iteration 78, residual = 8.733228544443966e-10 CG iteration 79, residual = 6.784543208743132e-10 CG iteration 80, residual = 5.596159234889895e-10 CG iteration 81, residual = 4.54856457451483e-10 CG iteration 82, residual = 3.6843246852043055e-10 CG iteration 83, residual = 3.449767162071073e-10 CG iteration 84, residual = 3.4786972040383056e-10 CG iteration 85, residual = 3.569776596613292e-10 CG iteration 86, residual = 3.8873335656586656e-10 CG iteration 87, residual = 3.813240426440975e-10 CG iteration 88, residual = 3.5311743107471296e-10 CG iteration 89, residual = 3.016878374075642e-10 CG iteration 90, residual = 2.603653528633211e-10 CG iteration 91, residual = 1.9531668871933762e-10 CG iteration 92, residual = 1.5326409106194643e-10 CG iteration 93, residual = 1.1205476297084693e-10 CG iteration 94, residual = 8.229814880121013e-11 CG iteration 95, residual = 6.864764392351253e-11 CG iteration 96, residual = 5.691396166834114e-11 CG iteration 97, residual = 4.713038374730669e-11 CG iteration 98, residual = 4.2404124820873386e-11 CG iteration 99, residual = 4.12552296131489e-11 CG iteration 100, residual = 3.9022551067146e-11 CG iteration 101, residual = 3.949123693256504e-11 CG iteration 102, residual = 4.15066467638617e-11 CG iteration 103, residual = 4.069629251932634e-11 CG iteration 104, residual = 4.034851781060643e-11 CG iteration 105, residual = 3.3948854436133415e-11 CG converged in 105 iterations to residual 3.3948854436133415e-11
0.019CG iteration 1, residual = 0.0034999270423870465
CG iteration 2, residual = 0.00026670848074857034 CG iteration 3, residual = 0.0002119224882995443 CG iteration 4, residual = 0.00022250534401227912 CG iteration 5, residual = 0.00015176718124535366 CG iteration 6, residual = 7.353901233331884e-05 CG iteration 7, residual = 4.135169902115991e-05 CG iteration 8, residual = 3.749221934578758e-05 CG iteration 9, residual = 2.9732516737255144e-05 CG iteration 10, residual = 2.309763910937324e-05 CG iteration 11, residual = 3.0394774511316688e-05 CG iteration 12, residual = 3.8969386716074296e-05 CG iteration 13, residual = 3.5596439012634774e-05 CG iteration 14, residual = 3.4298203215419504e-05 CG iteration 15, residual = 2.9537464853919973e-05 CG iteration 16, residual = 2.0672465815049427e-05 CG iteration 17, residual = 1.3439029603513566e-05 CG iteration 18, residual = 9.865211615565612e-06 CG iteration 19, residual = 8.486602113752598e-06 CG iteration 20, residual = 7.068506408055065e-06 CG iteration 21, residual = 5.685853314607451e-06 CG iteration 22, residual = 5.329384975515119e-06 CG iteration 23, residual = 4.705021696284856e-06 CG iteration 24, residual = 4.626505738189833e-06 CG iteration 25, residual = 4.833605791386804e-06 CG iteration 26, residual = 5.137472944672058e-06 CG iteration 27, residual = 4.966472145047962e-06 CG iteration 28, residual = 4.00541805345153e-06 CG iteration 29, residual = 3.0640996260703793e-06 CG iteration 30, residual = 1.964828956647638e-06 CG iteration 31, residual = 1.428484972276837e-06 CG iteration 32, residual = 1.1739247696678483e-06 CG iteration 33, residual = 9.284071429173136e-07 CG iteration 34, residual = 6.505709818754667e-07 CG iteration 35, residual = 4.996292745651332e-07 CG iteration 36, residual = 4.395959850356657e-07 CG iteration 37, residual = 3.987921143600849e-07 CG iteration 38, residual = 4.217959168918857e-07 CG iteration 39, residual = 4.3807647225104524e-07 CG iteration 40, residual = 4.6629070536672243e-07 CG iteration 41, residual = 4.084614600968492e-07 CG iteration 42, residual = 3.8025255156011496e-07 CG iteration 43, residual = 3.4737894993399213e-07 CG iteration 44, residual = 2.6660849369658747e-07 CG iteration 45, residual = 1.982066509377647e-07 CG iteration 46, residual = 1.520272324637382e-07 CG iteration 47, residual = 1.1006956913192132e-07 CG iteration 48, residual = 8.003236559231639e-08 CG iteration 49, residual = 6.27107760060723e-08 CG iteration 50, residual = 5.686036412823204e-08 CG iteration 51, residual = 4.8267084867132316e-08 CG iteration 52, residual = 4.7008549567423665e-08 CG iteration 53, residual = 4.783550250967815e-08 CG iteration 54, residual = 5.2351363525239674e-08 CG iteration 55, residual = 5.0468327877930506e-08 CG iteration 56, residual = 4.6381091239905164e-08 CG iteration 57, residual = 3.935050164220023e-08 CG iteration 58, residual = 3.4251105666719125e-08 CG iteration 59, residual = 2.800715453062127e-08 CG iteration 60, residual = 2.1079818518891628e-08 CG iteration 61, residual = 1.5409991482451766e-08 CG iteration 62, residual = 1.1135287398186477e-08 CG iteration 63, residual = 7.872396777595949e-09 CG iteration 64, residual = 6.274571616633777e-09 CG iteration 65, residual = 5.164031499607439e-09 CG iteration 66, residual = 4.581777519934093e-09 CG iteration 67, residual = 4.1099148742635584e-09 CG iteration 68, residual = 4.149804457875563e-09 CG iteration 69, residual = 4.136931644798902e-09 CG iteration 70, residual = 4.393660727603292e-09 CG iteration 71, residual = 4.312540715495237e-09 CG iteration 72, residual = 3.962147819172545e-09 CG iteration 73, residual = 3.294750334403484e-09 CG iteration 74, residual = 2.6222153646627506e-09 CG iteration 75, residual = 1.916161648159845e-09 CG iteration 76, residual = 1.5008375990001874e-09 CG iteration 77, residual = 1.1118665677339187e-09 CG iteration 78, residual = 8.687069916641797e-10 CG iteration 79, residual = 6.749690825879903e-10 CG iteration 80, residual = 5.567788440342331e-10 CG iteration 81, residual = 4.527527262771175e-10 CG iteration 82, residual = 3.6666320666021457e-10 CG iteration 83, residual = 3.431277777770593e-10 CG iteration 84, residual = 3.453007682566507e-10 CG iteration 85, residual = 3.5571061684562586e-10 CG iteration 86, residual = 3.8660366745600587e-10 CG iteration 87, residual = 3.802330718508536e-10 CG iteration 88, residual = 3.5186646967030477e-10 CG iteration 89, residual = 2.998997575245889e-10 CG iteration 90, residual = 2.5903527458326295e-10 CG iteration 91, residual = 1.9424114199384675e-10 CG iteration 92, residual = 1.5299550455627173e-10 CG iteration 93, residual = 1.1171413419658109e-10 CG iteration 94, residual = 8.209791653693687e-11 CG iteration 95, residual = 6.845545809397776e-11 CG iteration 96, residual = 5.667767548705256e-11 CG iteration 97, residual = 4.704286278095046e-11 CG iteration 98, residual = 4.221599768214049e-11 CG iteration 99, residual = 4.11040236082526e-11 CG iteration 100, residual = 3.8848196676802886e-11 CG iteration 101, residual = 3.938177849842627e-11 CG iteration 102, residual = 4.115819628770823e-11 CG iteration 103, residual = 4.059834277557624e-11 CG iteration 104, residual = 4.012073472513115e-11 CG iteration 105, residual = 3.3902060947529143e-11 CG converged in 105 iterations to residual 3.3902060947529143e-11
0.02CG iteration 1, residual = 0.0034996594799287504
CG iteration 2, residual = 0.00026615762602093913 CG iteration 3, residual = 0.00021105313895443048 CG iteration 4, residual = 0.00022187149786234104 CG iteration 5, residual = 0.00015173394987096393 CG iteration 6, residual = 7.338613661185809e-05 CG iteration 7, residual = 4.1002038262805865e-05 CG iteration 8, residual = 3.71211010455754e-05 CG iteration 9, residual = 2.9602991423072655e-05 CG iteration 10, residual = 2.3052041456051596e-05 CG iteration 11, residual = 3.0366278522542788e-05 CG iteration 12, residual = 3.9022294181001045e-05 CG iteration 13, residual = 3.56065254999373e-05 CG iteration 14, residual = 3.4186923874620416e-05 CG iteration 15, residual = 2.9373724102095797e-05 CG iteration 16, residual = 2.0551426325479998e-05 CG iteration 17, residual = 1.3369375974652548e-05 CG iteration 18, residual = 9.813917039132864e-06 CG iteration 19, residual = 8.422695789496116e-06 CG iteration 20, residual = 7.020318816929297e-06 CG iteration 21, residual = 5.6501727866653536e-06 CG iteration 22, residual = 5.283387680983901e-06 CG iteration 23, residual = 4.663805360464564e-06 CG iteration 24, residual = 4.587421918849668e-06 CG iteration 25, residual = 4.787432788293015e-06 CG iteration 26, residual = 5.0878744411877296e-06 CG iteration 27, residual = 4.9233051887608835e-06 CG iteration 28, residual = 3.974554030313985e-06 CG iteration 29, residual = 3.0423976840576575e-06 CG iteration 30, residual = 1.9459646725840257e-06 CG iteration 31, residual = 1.4101092988602082e-06 CG iteration 32, residual = 1.1611002230480228e-06 CG iteration 33, residual = 9.202246135601186e-07 CG iteration 34, residual = 6.461930347270887e-07 CG iteration 35, residual = 4.969616001239697e-07 CG iteration 36, residual = 4.3746337401663865e-07 CG iteration 37, residual = 3.962659757918066e-07 CG iteration 38, residual = 4.1923733137222486e-07 CG iteration 39, residual = 4.355190219900336e-07 CG iteration 40, residual = 4.6440173862697035e-07 CG iteration 41, residual = 4.0646167031588026e-07 CG iteration 42, residual = 3.7821368652825186e-07 CG iteration 43, residual = 3.450355845001474e-07 CG iteration 44, residual = 2.6474473244991885e-07 CG iteration 45, residual = 1.970596292954957e-07 CG iteration 46, residual = 1.509046836207586e-07 CG iteration 47, residual = 1.0910999092827506e-07 CG iteration 48, residual = 7.938720548510523e-08 CG iteration 49, residual = 6.218582311519425e-08 CG iteration 50, residual = 5.646420128277262e-08 CG iteration 51, residual = 4.811722140772708e-08 CG iteration 52, residual = 4.6801736109489034e-08 CG iteration 53, residual = 4.7493620843548114e-08 CG iteration 54, residual = 5.198070209614141e-08 CG iteration 55, residual = 5.017384142141455e-08 CG iteration 56, residual = 4.612775497470792e-08 CG iteration 57, residual = 3.907725998235276e-08 CG iteration 58, residual = 3.4024786586659565e-08 CG iteration 59, residual = 2.7841296645372385e-08 CG iteration 60, residual = 2.097521869472937e-08 CG iteration 61, residual = 1.5360944334322987e-08 CG iteration 62, residual = 1.1075260489052106e-08 CG iteration 63, residual = 7.822582669748077e-09 CG iteration 64, residual = 6.229979612376278e-09 CG iteration 65, residual = 5.119347775229027e-09 CG iteration 66, residual = 4.5538749014761746e-09 CG iteration 67, residual = 4.088457260025916e-09 CG iteration 68, residual = 4.130822000037821e-09 CG iteration 69, residual = 4.11530486907705e-09 CG iteration 70, residual = 4.369601901663486e-09 CG iteration 71, residual = 4.286700455474559e-09 CG iteration 72, residual = 3.936424558365315e-09 CG iteration 73, residual = 3.276105949848945e-09 CG iteration 74, residual = 2.613821360334551e-09 CG iteration 75, residual = 1.9072791502271585e-09 CG iteration 76, residual = 1.492636586420555e-09 CG iteration 77, residual = 1.108018805482745e-09 CG iteration 78, residual = 8.641064435559002e-10 CG iteration 79, residual = 6.714997303277321e-10 CG iteration 80, residual = 5.538372513200745e-10 CG iteration 81, residual = 4.5061332153463253e-10 CG iteration 82, residual = 3.6490062238679794e-10 CG iteration 83, residual = 3.412243942829032e-10 CG iteration 84, residual = 3.427485020852321e-10 CG iteration 85, residual = 3.5442944028903533e-10 CG iteration 86, residual = 3.8437273055741163e-10 CG iteration 87, residual = 3.7912673366938005e-10 CG iteration 88, residual = 3.506096599280824e-10 CG iteration 89, residual = 2.9813116985142727e-10 CG iteration 90, residual = 2.5766498502894294e-10 CG iteration 91, residual = 1.931828905748042e-10 CG iteration 92, residual = 1.5271425495267052e-10 CG iteration 93, residual = 1.1136465087936655e-10 CG iteration 94, residual = 8.191387919682405e-11 CG iteration 95, residual = 6.826133169603524e-11 CG iteration 96, residual = 5.6437979371713083e-11 CG iteration 97, residual = 4.695425356877513e-11 CG iteration 98, residual = 4.2022006026802e-11 CG iteration 99, residual = 4.0939834517357255e-11 CG iteration 100, residual = 3.867205607311241e-11 CG iteration 101, residual = 3.926463518629345e-11 CG iteration 102, residual = 4.080814764993497e-11 CG iteration 103, residual = 4.049869216714212e-11 CG iteration 104, residual = 3.988089709920761e-11 CG iteration 105, residual = 3.3857880766492275e-11 CG converged in 105 iterations to residual 3.3857880766492275e-11
0.021CG iteration 1, residual = 0.003499392226307487
CG iteration 2, residual = 0.0002656235608075457 CG iteration 3, residual = 0.00021022352449486694 CG iteration 4, residual = 0.00022126806022626654 CG iteration 5, residual = 0.0001517058641189097 CG iteration 6, residual = 7.32373413042507e-05 CG iteration 7, residual = 4.065949504735404e-05 CG iteration 8, residual = 3.6757592503281485e-05 CG iteration 9, residual = 2.947864166701894e-05 CG iteration 10, residual = 2.3011796138068018e-05 CG iteration 11, residual = 3.0343693361377137e-05 CG iteration 12, residual = 3.908003477770683e-05 CG iteration 13, residual = 3.5618163468946736e-05 CG iteration 14, residual = 3.407435999161058e-05 CG iteration 15, residual = 2.9209058292756795e-05 CG iteration 16, residual = 2.0430732870753615e-05 CG iteration 17, residual = 1.3300051527628116e-05 CG iteration 18, residual = 9.763644437914473e-06 CG iteration 19, residual = 8.360632104181607e-06 CG iteration 20, residual = 6.9733583970698e-06 CG iteration 21, residual = 5.61512157638372e-06 CG iteration 22, residual = 5.238219686896261e-06 CG iteration 23, residual = 4.623569602979263e-06 CG iteration 24, residual = 4.549573442724841e-06 CG iteration 25, residual = 4.7430273322240205e-06 CG iteration 26, residual = 5.040201537796052e-06 CG iteration 27, residual = 4.881308124900821e-06 CG iteration 28, residual = 3.944139599103232e-06 CG iteration 29, residual = 3.021096902895716e-06 CG iteration 30, residual = 1.9276333235092873e-06 CG iteration 31, residual = 1.3922803633486663e-06 CG iteration 32, residual = 1.1486162839855576e-06 CG iteration 33, residual = 9.122226912228274e-07 CG iteration 34, residual = 6.419197070531168e-07 CG iteration 35, residual = 4.943720403421837e-07 CG iteration 36, residual = 4.353994185297953e-07 CG iteration 37, residual = 3.9380021501164483e-07 CG iteration 38, residual = 4.167335822599322e-07 CG iteration 39, residual = 4.3301948055033643e-07 CG iteration 40, residual = 4.6255824806419825e-07 CG iteration 41, residual = 4.0453373055864344e-07 CG iteration 42, residual = 3.762439153235578e-07 CG iteration 43, residual = 3.4273179637875274e-07 CG iteration 44, residual = 2.62901583198526e-07 CG iteration 45, residual = 1.9592345036451122e-07 CG iteration 46, residual = 1.4978716105669024e-07 CG iteration 47, residual = 1.0816677842864059e-07 CG iteration 48, residual = 7.875978847471648e-08 CG iteration 49, residual = 6.167413952052847e-08 CG iteration 50, residual = 5.607547389782901e-08 CG iteration 51, residual = 4.7973077734766046e-08 CG iteration 52, residual = 4.660074787462056e-08 CG iteration 53, residual = 4.71628762312285e-08 CG iteration 54, residual = 5.1620331850365464e-08 CG iteration 55, residual = 4.988719314613679e-08 CG iteration 56, residual = 4.587909030247122e-08 CG iteration 57, residual = 3.88110341643019e-08 CG iteration 58, residual = 3.380537939396533e-08 CG iteration 59, residual = 2.767785552466412e-08 CG iteration 60, residual = 2.087053759596765e-08 CG iteration 61, residual = 1.5311387518565136e-08 CG iteration 62, residual = 1.1014641294784786e-08 CG iteration 63, residual = 7.7731616809207e-09 CG iteration 64, residual = 6.186193087290327e-09 CG iteration 65, residual = 5.075391915535106e-09 CG iteration 66, residual = 4.526677891324867e-09 CG iteration 67, residual = 4.06771479225344e-09 CG iteration 68, residual = 4.112293255461905e-09 CG iteration 69, residual = 4.0944443851223265e-09 CG iteration 70, residual = 4.346395155995504e-09 CG iteration 71, residual = 4.2612788907795844e-09 CG iteration 72, residual = 3.910734614993407e-09 CG iteration 73, residual = 3.2575864746623013e-09 CG iteration 74, residual = 2.6055201253986017e-09 CG iteration 75, residual = 1.8985557734021666e-09 CG iteration 76, residual = 1.4844799402502883e-09 CG iteration 77, residual = 1.1041991377921551e-09 CG iteration 78, residual = 8.595224985603431e-10 CG iteration 79, residual = 6.680481454458048e-10 CG iteration 80, residual = 5.508001209973992e-10 CG iteration 81, residual = 4.4844593267789534e-10 CG iteration 82, residual = 3.631462627749216e-10 CG iteration 83, residual = 3.392748327225723e-10 CG iteration 84, residual = 3.4022349721751535e-10 CG iteration 85, residual = 3.531385181341105e-10 CG iteration 86, residual = 3.820556285280273e-10 CG iteration 87, residual = 3.780113893267728e-10 CG iteration 88, residual = 3.4934861348812464e-10 CG iteration 89, residual = 2.9638591659686173e-10 CG iteration 90, residual = 2.5625899268598754e-10 CG iteration 91, residual = 1.9214443057750597e-10 CG iteration 92, residual = 1.524189275246452e-10 CG iteration 93, residual = 1.1100778003124254e-10 CG iteration 94, residual = 8.174601503475498e-11 CG iteration 95, residual = 6.806457868312794e-11 CG iteration 96, residual = 5.619619910441268e-11 CG iteration 97, residual = 4.6864976951375665e-11 CG iteration 98, residual = 4.182257901232309e-11 CG iteration 99, residual = 4.076398266640114e-11 CG iteration 100, residual = 3.849493502284744e-11 CG iteration 101, residual = 3.913987874684194e-11 CG iteration 102, residual = 4.045837555075076e-11 CG iteration 103, residual = 4.0397543504992014e-11 CG iteration 104, residual = 3.963036985033604e-11 CG iteration 105, residual = 3.381633617744213e-11 CG converged in 105 iterations to residual 3.381633617744213e-11
0.022CG iteration 1, residual = 0.0034991251423631686
CG iteration 2, residual = 0.0002651053665723844 CG iteration 3, residual = 0.0002094315385236896 CG iteration 4, residual = 0.00022069358743942097 CG iteration 5, residual = 0.00015168252310812937 CG iteration 6, residual = 7.309235814134801e-05 CG iteration 7, residual = 4.032374287087178e-05 CG iteration 8, residual = 3.6401332574308736e-05 CG iteration 9, residual = 2.9359195185675956e-05 CG iteration 10, residual = 2.2976605305843597e-05 CG iteration 11, residual = 3.032650832532775e-05 CG iteration 12, residual = 3.914199477504823e-05 CG iteration 13, residual = 3.5630918811061024e-05 CG iteration 14, residual = 3.396031840470617e-05 CG iteration 15, residual = 2.904344256678665e-05 CG iteration 16, residual = 2.0310401061058686e-05 CG iteration 17, residual = 1.3231091131363677e-05 CG iteration 18, residual = 9.714375763065734e-06 CG iteration 19, residual = 8.300354632689676e-06 CG iteration 20, residual = 6.927605076144969e-06 CG iteration 21, residual = 5.580707779331482e-06 CG iteration 22, residual = 5.193884587226574e-06 CG iteration 23, residual = 4.584304681433868e-06 CG iteration 24, residual = 4.512937925406394e-06 CG iteration 25, residual = 4.7003423040047864e-06 CG iteration 26, residual = 4.99439912361814e-06 CG iteration 27, residual = 4.840459820532774e-06 CG iteration 28, residual = 3.91416555943783e-06 CG iteration 29, residual = 3.0001736386833535e-06 CG iteration 30, residual = 1.909807930554776e-06 CG iteration 31, residual = 1.3749789975463694e-06 CG iteration 32, residual = 1.1364672329842508e-06 CG iteration 33, residual = 9.044005506032427e-07 CG iteration 34, residual = 6.37748305730149e-07 CG iteration 35, residual = 4.918562234339331e-07 CG iteration 36, residual = 4.3340000099785405e-07 CG iteration 37, residual = 3.9139244779966845e-07 CG iteration 38, residual = 4.1428387252735143e-07 CG iteration 39, residual = 4.305775793492394e-07 CG iteration 40, residual = 4.607598984663823e-07
</pre>
end{sphinxVerbatim}
[2KCG iteration 18, residual = 1.0081078567536558e-05 [2KCG iteration 19, residual = 8.761852041144736e-06 [2KCG iteration 20, residual = 7.273845921450485e-06 [2KCG iteration 21, residual = 5.834563477371868e-06 [2KCG iteration 22, residual = 5.521455897045731e-06 [2KCG iteration 23, residual = 4.879805188070319e-06 [2KCG iteration 24, residual = 4.7955616970648215e-06 [2KCG iteration 25, residual = 5.0368319241337685e-06 [2KCG iteration 26, residual = 5.356148188582378e-06 [2KCG iteration 27, residual = 5.1511743760165325e-06 [2KCG iteration 28, residual = 4.133534950744866e-06 [2KCG iteration 29, residual = 3.155444653550036e-06 [2KCG iteration 30, residual = 2.0462191288422454e-06 [2KCG iteration 31, residual = 1.5078612450879973e-06 [2KCG iteration 32, residual = 1.2287304633079764e-06 [2KCG iteration 33, residual = 9.629561638497155e-07 [2KCG iteration 34, residual = 6.691918464790142e-07 [2KCG iteration 35, residual = 5.11176122926403e-07 [2KCG iteration 36, residual = 4.488994324880371e-07 [2KCG iteration 37, residual = 4.0955185646470935e-07 [2KCG iteration 38, residual = 4.325959408336078e-07 [2KCG iteration 39, residual = 4.488901827652406e-07 [2KCG iteration 40, residual = 4.7430827914506717e-07 [2KCG iteration 41, residual = 4.1723064264119773e-07 [2KCG iteration 42, residual = 3.8916592885603954e-07 [2KCG iteration 43, residual = 3.571954986338259e-07 [2KCG iteration 44, residual = 2.742932191390765e-07 [2KCG iteration 45, residual = 2.0292108648425786e-07 [2KCG iteration 46, residual = 1.565824098582166e-07 [2KCG iteration 47, residual = 1.1408362549989792e-07 [2KCG iteration 48, residual = 8.280110683252189e-08 [2KCG iteration 49, residual = 6.494677556792294e-08 [2KCG iteration 50, residual = 5.851803522364796e-08 [2KCG iteration 51, residual = 4.8929561102427814e-08 [2KCG iteration 52, residual = 4.790377685816714e-08 [2KCG iteration 53, residual = 4.932358958579545e-08 [2KCG iteration 54, residual = 5.39414850530249e-08 [2KCG iteration 55, residual = 5.1728330977699596e-08 [2KCG iteration 56, residual = 4.744718531610499e-08 [2KCG iteration 57, residual = 4.051838112184153e-08 [2KCG iteration 58, residual = 3.523100771024585e-08 [2KCG iteration 59, residual = 2.8696842165631107e-08 [2KCG iteration 60, residual = 2.1496719035592212e-08 [2KCG iteration 61, residual = 1.560245208861204e-08 [2KCG iteration 62, residual = 1.1370163397586533e-08 [2KCG iteration 63, residual = 8.075467294616568e-09 [2KCG iteration 64, residual = 6.461204242094219e-09 [2KCG iteration 65, residual = 5.350199921114948e-09 [2KCG iteration 66, residual = 4.7004462031874535e-09 [2KCG iteration 67, residual = 4.20327875372649e-09 [2KCG iteration 68, residual = 4.230364316344367e-09 [2KCG iteration 69, residual = 4.231505991278815e-09 [2KCG iteration 70, residual = 4.499449651500523e-09 [2KCG iteration 71, residual = 4.420446261443633e-09 [2KCG iteration 72, residual = 4.0645036290462695e-09 [2KCG iteration 73, residual = 3.37027248820501e-09 [2KCG iteration 74, residual = 2.6571683961971647e-09 [2KCG iteration 75, residual = 1.9534220740219337e-09 [2KCG iteration 76, residual = 1.5339472423344943e-09 [2KCG iteration 77, residual = 1.127581667475511e-09 [2KCG iteration 78, residual = 8.872494490975546e-10 [2KCG iteration 79, residual = 6.889841915045716e-10 [2KCG iteration 80, residual = 5.674160727831443e-10 [2KCG iteration 81, residual = 4.608694419967108e-10 [2KCG iteration 82, residual = 3.7376129742139923e-10 [2KCG iteration 83, residual = 3.501163946490125e-10 [2KCG iteration 84, residual = 3.5554994089033096e-10 [2KCG iteration 85, residual = 3.6064002628910424e-10 [2KCG iteration 86, residual = 3.9436591536369633e-10 [2KCG iteration 87, residual = 3.8442989133052494e-10 [2KCG iteration 88, residual = 3.5681286389417633e-10 [2KCG iteration 89, residual = 3.0712505838488086e-10 [2KCG iteration 90, residual = 2.6406905639807614e-10 [2KCG iteration 91, residual = 1.9861791302436304e-10 [2KCG iteration 92, residual = 1.5400757512579364e-10 [2KCG iteration 93, residual = 1.1301134256610059e-10 [2KCG iteration 94, residual = 8.299480667787761e-11 [2KCG iteration 95, residual = 6.921915761133321e-11 [2KCG iteration 96, residual = 5.7589355584808635e-11 [2KCG iteration 97, residual = 4.738098783384326e-11 [2KCG iteration 98, residual = 4.2929066339362315e-11 [2KCG iteration 99, residual = 4.161838290359843e-11 [2KCG iteration 100, residual = 3.952537221831324e-11 [2KCG iteration 101, residual = 3.977290866629629e-11 [2KCG iteration 102, residual = 4.2521919266808065e-11 [2KCG iteration 103, residual = 4.0976389832833345e-11 [2KCG iteration 104, residual = 4.094628785163466e-11 [2KCG iteration 105, residual = 3.410442911028546e-11 [2KCG converged in 105 iterations to residual 3.410442911028546e-11
0.016[2KCG iteration 1, residual = 0.0035007331956602755
[2KCG iteration 2, residual = 0.00026847196870938766 [2KCG iteration 3, residual = 0.00021479220795323918 [2KCG iteration 4, residual = 0.00022460492536767422 [2KCG iteration 5, residual = 0.00015190220292986438 [2KCG iteration 6, residual = 7.402521433454168e-05 [2KCG iteration 7, residual = 4.244712324733997e-05 [2KCG iteration 8, residual = 3.865530385884956e-05 [2KCG iteration 9, residual = 3.0155212790775684e-05 [2KCG iteration 10, residual = 2.3269987627815142e-05 [2KCG iteration 11, residual = 3.0521554172054045e-05 [2KCG iteration 12, residual = 3.88465850288125e-05 [2KCG iteration 13, residual = 3.558057819220283e-05 [2KCG iteration 14, residual = 3.4626916532234714e-05 [2KCG iteration 15, residual = 3.0023736091307316e-05 [2KCG iteration 16, residual = 2.1037654003244632e-05 [2KCG iteration 17, residual = 1.364967267485448e-05 [2KCG iteration 18, residual = 1.0025451361585392e-05 [2KCG iteration 19, residual = 8.689969820408403e-06 [2KCG iteration 20, residual = 7.2205970631917335e-06 [2KCG iteration 21, residual = 5.7965288876047305e-06 [2KCG iteration 22, residual = 5.472257539180393e-06 [2KCG iteration 23, residual = 4.834616621087196e-06 [2KCG iteration 24, residual = 4.751359336887825e-06 [2KCG iteration 25, residual = 4.983166636779819e-06 [2KCG iteration 26, residual = 5.29834133145188e-06 [2KCG iteration 27, residual = 5.10316695891717e-06 [2KCG iteration 28, residual = 4.100791559269805e-06 [2KCG iteration 29, residual = 3.1318712648564646e-06 [2KCG iteration 30, residual = 2.024916406942397e-06 [2KCG iteration 31, residual = 1.487093949434298e-06 [2KCG iteration 32, residual = 1.2144938619691762e-06 [2KCG iteration 33, residual = 9.54044974074901e-07 [2KCG iteration 34, residual = 6.643631825604382e-07 [2KCG iteration 35, residual = 5.08147893030071e-07 [2KCG iteration 36, residual = 4.464486805199639e-07 [2KCG iteration 37, residual = 4.0675819098026104e-07 [2KCG iteration 38, residual = 4.29809193274338e-07 [2KCG iteration 39, residual = 4.460986807832931e-07 [2KCG iteration 40, residual = 4.722338447355998e-07 [2KCG iteration 41, residual = 4.1491737720219007e-07 [2KCG iteration 42, residual = 3.8681701374278096e-07 [2KCG iteration 43, residual = 3.5467000949641855e-07 [2KCG iteration 44, residual = 2.723349930642448e-07 [2KCG iteration 45, residual = 2.0172145187116722e-07 [2KCG iteration 46, residual = 1.5543204609144128e-07 [2KCG iteration 47, residual = 1.1305239997038482e-07 [2KCG iteration 48, residual = 8.207958588633842e-08 [2KCG iteration 49, residual = 6.436701099723498e-08 [2KCG iteration 50, residual = 5.8092828824897026e-08 [2KCG iteration 51, residual = 4.8753873196024153e-08 [2KCG iteration 52, residual = 4.7668710481632465e-08 [2KCG iteration 53, residual = 4.893253990609414e-08 [2KCG iteration 54, residual = 5.3527403066053766e-08 [2KCG iteration 55, residual = 5.140063315260353e-08 [2KCG iteration 56, residual = 4.717206623217991e-08 [2KCG iteration 57, residual = 4.0214654475864654e-08 [2KCG iteration 58, residual = 3.4974265024721386e-08 [2KCG iteration 59, residual = 2.8520249631515595e-08 [2KCG iteration 60, residual = 2.1392778132582488e-08 [2KCG iteration 61, residual = 1.5554748829673704e-08 [2KCG iteration 62, residual = 1.1312125836646122e-08 [2KCG iteration 63, residual = 8.024122367362901e-09 [2KCG iteration 64, residual = 6.413281322280139e-09 [2KCG iteration 65, residual = 5.3025229605631516e-09 [2KCG iteration 66, residual = 4.669720070618245e-09 [2KCG iteration 67, residual = 4.178767024706176e-09 [2KCG iteration 68, residual = 4.2095151905040355e-09 [2KCG iteration 69, residual = 4.2066099451941185e-09 [2KCG iteration 70, residual = 4.4714624508854515e-09 [2KCG iteration 71, residual = 4.392747331337371e-09 [2KCG iteration 72, residual = 4.039079089813899e-09 [2KCG iteration 73, residual = 3.3512774071519293e-09 [2KCG iteration 74, residual = 2.6481738787792426e-09 [2KCG iteration 75, residual = 1.943830275017003e-09 [2KCG iteration 76, residual = 1.5256376757701614e-09 [2KCG iteration 77, residual = 1.1235987934232147e-09 [2KCG iteration 78, residual = 8.82595263466332e-10 [2KCG iteration 79, residual = 6.854641378083223e-10 [2KCG iteration 80, residual = 5.649424101611164e-10 [2KCG iteration 81, residual = 4.5892359285047796e-10 [2KCG iteration 82, residual = 3.7198360166809e-10 [2KCG iteration 83, residual = 3.4847879488448607e-10 [2KCG iteration 84, residual = 3.5300833833241335e-10 [2KCG iteration 85, residual = 3.594483586319962e-10 [2KCG iteration 86, residual = 3.926290110687531e-10 [2KCG iteration 87, residual = 3.8343062452525745e-10 [2KCG iteration 88, residual = 3.5559327409027004e-10 [2KCG iteration 89, residual = 3.053052313160387e-10 [2KCG iteration 90, residual = 2.6288674540268123e-10 [2KCG iteration 91, residual = 1.9750825962594497e-10 [2KCG iteration 92, residual = 1.537688091115366e-10 [2KCG iteration 93, residual = 1.1270439053357734e-10 [2KCG iteration 94, residual = 8.27467991955853e-11 [2KCG iteration 95, residual = 6.902887399405843e-11 [2KCG iteration 96, residual = 5.7371064575334604e-11 [2KCG iteration 97, residual = 4.730005896030211e-11 [2KCG iteration 98, residual = 4.2761086276952945e-11 [2KCG iteration 99, residual = 4.151360273871223e-11 [2KCG iteration 100, residual = 3.936218228000607e-11 [2KCG iteration 101, residual = 3.968685996899888e-11 [2KCG iteration 102, residual = 4.2190658133456135e-11 [2KCG iteration 103, residual = 4.0885765816868945e-11 [2KCG iteration 104, residual = 4.076258266020783e-11 [2KCG iteration 105, residual = 3.405010262573133e-11 [2KCG converged in 105 iterations to residual 3.405010262573133e-11
0.017[2KCG iteration 1, residual = 0.0035004637230376143
[2KCG iteration 2, residual = 0.0002678645613925381 [2KCG iteration 3, residual = 0.00021378953879856594 [2KCG iteration 4, residual = 0.0002238704181200924 [2KCG iteration 5, residual = 0.00015185083036029884 [2KCG iteration 6, residual = 7.3858212020731e-05 [2KCG iteration 7, residual = 4.2073833542658956e-05 [2KCG iteration 8, residual = 3.8258880702200375e-05 [2KCG iteration 9, residual = 3.000829590031622e-05 [2KCG iteration 10, residual = 2.3206234497526605e-05 [2KCG iteration 11, residual = 3.0471777887379656e-05 [2KCG iteration 12, residual = 3.888078382248407e-05 [2KCG iteration 13, residual = 3.5582902435367474e-05 [2KCG iteration 14, residual = 3.451789350862345e-05 [2KCG iteration 15, residual = 2.9862384155580684e-05 [2KCG iteration 16, residual = 2.0915568173091894e-05 [2KCG iteration 17, residual = 1.3579202202476354e-05 [2KCG iteration 18, residual = 9.970952641555279e-06 [2KCG iteration 19, residual = 8.620177550217569e-06 [2KCG iteration 20, residual = 7.168631506569559e-06 [2KCG iteration 21, residual = 5.7590497866337655e-06 [2KCG iteration 22, residual = 5.423833571537591e-06 [2KCG iteration 23, residual = 4.7904235572995885e-06 [2KCG iteration 24, residual = 4.7084579407597625e-06 [2KCG iteration 25, residual = 4.931431790287915e-06 [2KCG iteration 26, residual = 5.2426569762042175e-06 [2KCG iteration 27, residual = 5.056388239913798e-06 [2KCG iteration 28, residual = 4.068529003388338e-06 [2KCG iteration 29, residual = 3.108808968836604e-06 [2KCG iteration 30, residual = 2.0042732198197555e-06 [2KCG iteration 31, residual = 1.4669565056686366e-06 [2KCG iteration 32, residual = 1.2006168213860513e-06 [2KCG iteration 33, residual = 9.453167489464185e-07 [2KCG iteration 34, residual = 6.59652694899186e-07 [2KCG iteration 35, residual = 5.052175003115568e-07 [2KCG iteration 36, residual = 4.440842279940822e-07 [2KCG iteration 37, residual = 4.040355655108097e-07 [2KCG iteration 38, residual = 4.2708094440555135e-07 [2KCG iteration 39, residual = 4.4336606629403494e-07 [2KCG iteration 40, residual = 4.702063955231843e-07 [2KCG iteration 41, residual = 4.1268665659725973e-07 [2KCG iteration 42, residual = 3.8455081392852347e-07 [2KCG iteration 43, residual = 3.5219374877169744e-07 [2KCG iteration 44, residual = 2.7040237880049424e-07 [2KCG iteration 45, residual = 2.0053658660550325e-07 [2KCG iteration 46, residual = 1.5429007666737061e-07 [2KCG iteration 47, residual = 1.1204012859229277e-07 [2KCG iteration 48, residual = 8.13780072347048e-08 [2KCG iteration 49, residual = 6.380119988535457e-08 [2KCG iteration 50, residual = 5.767475511192732e-08 [2KCG iteration 51, residual = 4.858511128438801e-08 [2KCG iteration 52, residual = 4.744152521027891e-08 [2KCG iteration 53, residual = 4.855449578050247e-08 [2KCG iteration 54, residual = 5.312449373682227e-08 [2KCG iteration 55, residual = 5.108153568827667e-08 [2KCG iteration 56, residual = 4.690292307715924e-08 [2KCG iteration 57, residual = 3.991894885287886e-08 [2KCG iteration 58, residual = 3.472556313529518e-08 [2KCG iteration 59, residual = 2.8346520416105443e-08 [2KCG iteration 60, residual = 2.1288630376029657e-08 [2KCG iteration 61, residual = 1.5506822344393532e-08 [2KCG iteration 62, residual = 1.1253675700537333e-08 [2KCG iteration 63, residual = 7.973167864056538e-09 [2KCG iteration 64, residual = 6.366210972304682e-09 [2KCG iteration 65, residual = 5.255610244223652e-09 [2KCG iteration 66, residual = 4.639700194127765e-09 [2KCG iteration 67, residual = 4.1550500578852225e-09 [2KCG iteration 68, residual = 4.189145108169495e-09 [2KCG iteration 69, residual = 4.182563695608077e-09 [2KCG iteration 70, residual = 4.444538467552277e-09 [2KCG iteration 71, residual = 4.365544840733314e-09 [2KCG iteration 72, residual = 4.013518019728877e-09 [2KCG iteration 73, residual = 3.332350565414217e-09 [2KCG iteration 74, residual = 2.6393678347275616e-09 [2KCG iteration 75, residual = 1.9344293416999057e-09 [2KCG iteration 76, residual = 1.517345058769454e-09 [2KCG iteration 77, residual = 1.119654116053648e-09 [2KCG iteration 78, residual = 8.779527026697897e-10 [2KCG iteration 79, residual = 6.819534044722841e-10 [2KCG iteration 80, residual = 5.623398400346102e-10 [2KCG iteration 81, residual = 4.569162935460036e-10 [2KCG iteration 82, residual = 3.7020660545358793e-10 [2KCG iteration 83, residual = 3.467630389027665e-10 [2KCG iteration 84, residual = 3.5044336897844125e-10 [2KCG iteration 85, residual = 3.582254820985328e-10 [2KCG iteration 86, residual = 3.9074673725494274e-10 [2KCG iteration 87, residual = 3.823925116822062e-10 [2KCG iteration 88, residual = 3.5436051495645367e-10 [2KCG iteration 89, residual = 3.034911890089008e-10 [2KCG iteration 90, residual = 2.6165068529194794e-10 [2KCG iteration 91, residual = 1.964067473096308e-10 [2KCG iteration 92, residual = 1.535214094763801e-10 [2KCG iteration 93, residual = 1.1238522477551103e-10 [2KCG iteration 94, residual = 8.251449856686948e-11 [2KCG iteration 95, residual = 6.883856715892686e-11 [2KCG iteration 96, residual = 5.714552076712561e-11 [2KCG iteration 97, residual = 4.7216309776469777e-11 [2KCG iteration 98, residual = 4.258596273478263e-11 [2KCG iteration 99, residual = 4.139216645125402e-11 [2KCG iteration 100, residual = 3.9194213139549445e-11 [2KCG iteration 101, residual = 3.959294980504733e-11 [2KCG iteration 102, residual = 4.185150230163987e-11 [2KCG iteration 103, residual = 4.079223505243692e-11 [2KCG iteration 104, residual = 4.056290384722825e-11 [2KCG iteration 105, residual = 3.399822064357001e-11 [2KCG converged in 105 iterations to residual 3.399822064357001e-11
0.018000000000000002[2KCG iteration 1, residual = 0.003500195067129859
[2KCG iteration 2, residual = 0.0002672771081996773 [2KCG iteration 3, residual = 0.00021283382105538565 [2KCG iteration 4, residual = 0.00022317111797377545 [2KCG iteration 5, residual = 0.00015180598785780654 [2KCG iteration 6, residual = 7.369626301211169e-05 [2KCG iteration 7, residual = 4.170883414219223e-05 [2KCG iteration 8, residual = 3.787133827905374e-05 [2KCG iteration 9, residual = 2.9867512065166115e-05 [2KCG iteration 10, residual = 2.3148916762472193e-05 [2KCG iteration 11, residual = 3.0429738509132495e-05 [2KCG iteration 12, residual = 3.8921976907207034e-05 [2KCG iteration 13, residual = 3.5588386426018936e-05 [2KCG iteration 14, residual = 3.440843283391508e-05 [2KCG iteration 15, residual = 2.9700327459156413e-05 [2KCG iteration 16, residual = 2.079384485947761e-05 [2KCG iteration 17, residual = 1.350898074855908e-05 [2KCG iteration 18, residual = 9.91754881470016e-06 [2KCG iteration 19, residual = 8.552409266664977e-06 [2KCG iteration 20, residual = 7.1179388836489685e-06 [2KCG iteration 21, residual = 5.722151071643258e-06 [2KCG iteration 22, residual = 5.376204119011149e-06 [2KCG iteration 23, residual = 4.747226081852187e-06 [2KCG iteration 24, residual = 4.6668451368876035e-06 [2KCG iteration 25, residual = 4.881591320353026e-06 [2KCG iteration 26, residual = 5.189050194126394e-06 [2KCG iteration 27, residual = 5.0108277672929844e-06 [2KCG iteration 28, residual = 4.03674034197978e-06 [2KCG iteration 29, residual = 3.086227839246918e-06 [2KCG iteration 30, residual = 1.984254931124881e-06 [2KCG iteration 31, residual = 1.447427214810992e-06 [2KCG iteration 32, residual = 1.1870953053704643e-06 [2KCG iteration 33, residual = 9.367709850892174e-07 [2KCG iteration 34, residual = 6.550564697438401e-07 [2KCG iteration 35, residual = 5.023796412655621e-07 [2KCG iteration 36, residual = 4.418014859228068e-07 [2KCG iteration 37, residual = 4.0138111322980155e-07 [2KCG iteration 38, residual = 4.2441016443958086e-07 [2KCG iteration 39, residual = 4.406920760137403e-07 [2KCG iteration 40, residual = 4.6822547674765513e-07 [2KCG iteration 41, residual = 4.105355916017849e-07 [2KCG iteration 42, residual = 3.8236380611986044e-07 [2KCG iteration 43, residual = 3.4976421056074444e-07 [2KCG iteration 44, residual = 2.6849397673140793e-07 [2KCG iteration 45, residual = 1.9936533056244152e-07 [2KCG iteration 46, residual = 1.5315544146804e-07 [2KCG iteration 47, residual = 1.110460762137788e-07 [2KCG iteration 48, residual = 8.069578695014903e-08 [2KCG iteration 49, residual = 6.324917740569165e-08 [2KCG iteration 50, residual = 5.726390581303033e-08 [2KCG iteration 51, residual = 4.8422950630798294e-08 [2KCG iteration 52, residual = 4.722164829996291e-08 [2KCG iteration 53, residual = 4.818897374853017e-08 [2KCG iteration 54, residual = 5.27325522098671e-08 [2KCG iteration 55, residual = 5.07708314485264e-08 [2KCG iteration 56, residual = 4.663937811676006e-08 [2KCG iteration 57, residual = 3.963098428152172e-08 [2KCG iteration 58, residual = 3.448460546336334e-08 [2KCG iteration 59, residual = 2.8175527194746234e-08 [2KCG iteration 60, residual = 2.118430044153484e-08 [2KCG iteration 61, residual = 1.545859439410772e-08 [2KCG iteration 62, residual = 1.1194746658629123e-08 [2KCG iteration 63, residual = 7.922593413119037e-09 [2KCG iteration 64, residual = 6.3199785239834826e-09 [2KCG iteration 65, residual = 5.209449674285097e-09 [2KCG iteration 66, residual = 4.610385992126006e-09 [2KCG iteration 67, residual = 4.1321060855172405e-09 [2KCG iteration 68, residual = 4.1692438900403095e-09 [2KCG iteration 69, residual = 4.15934457015755e-09 [2KCG iteration 70, residual = 4.418622323386571e-09 [2KCG iteration 71, residual = 4.33881608442608e-09 [2KCG iteration 72, residual = 3.9878601899999555e-09 [2KCG iteration 73, residual = 3.31350361023992e-09 [2KCG iteration 74, residual = 2.630723251294511e-09 [2KCG iteration 75, residual = 1.9252093062366813e-09 [2KCG iteration 76, residual = 1.5090760725274065e-09 [2KCG iteration 77, residual = 1.1157442721576286e-09 [2KCG iteration 78, residual = 8.733228544443966e-10 [2KCG iteration 79, residual = 6.784543208743132e-10 [2KCG iteration 80, residual = 5.596159234889895e-10 [2KCG iteration 81, residual = 4.54856457451483e-10 [2KCG iteration 82, residual = 3.6843246852043055e-10 [2KCG iteration 83, residual = 3.449767162071073e-10 [2KCG iteration 84, residual = 3.4786972040383056e-10 [2KCG iteration 85, residual = 3.569776596613292e-10 [2KCG iteration 86, residual = 3.8873335656586656e-10 [2KCG iteration 87, residual = 3.813240426440975e-10 [2KCG iteration 88, residual = 3.5311743107471296e-10 [2KCG iteration 89, residual = 3.016878374075642e-10 [2KCG iteration 90, residual = 2.603653528633211e-10 [2KCG iteration 91, residual = 1.9531668871933762e-10 [2KCG iteration 92, residual = 1.5326409106194643e-10 [2KCG iteration 93, residual = 1.1205476297084693e-10 [2KCG iteration 94, residual = 8.229814880121013e-11 [2KCG iteration 95, residual = 6.864764392351253e-11 [2KCG iteration 96, residual = 5.691396166834114e-11 [2KCG iteration 97, residual = 4.713038374730669e-11 [2KCG iteration 98, residual = 4.2404124820873386e-11 [2KCG iteration 99, residual = 4.12552296131489e-11 [2KCG iteration 100, residual = 3.9022551067146e-11 [2KCG iteration 101, residual = 3.949123693256504e-11 [2KCG iteration 102, residual = 4.15066467638617e-11 [2KCG iteration 103, residual = 4.069629251932634e-11 [2KCG iteration 104, residual = 4.034851781060643e-11 [2KCG iteration 105, residual = 3.3948854436133415e-11 [2KCG converged in 105 iterations to residual 3.3948854436133415e-11
0.019[2KCG iteration 1, residual = 0.0034999270423870465
[2KCG iteration 2, residual = 0.00026670848074857034 [2KCG iteration 3, residual = 0.0002119224882995443 [2KCG iteration 4, residual = 0.00022250534401227912 [2KCG iteration 5, residual = 0.00015176718124535366 [2KCG iteration 6, residual = 7.353901233331884e-05 [2KCG iteration 7, residual = 4.135169902115991e-05 [2KCG iteration 8, residual = 3.749221934578758e-05 [2KCG iteration 9, residual = 2.9732516737255144e-05 [2KCG iteration 10, residual = 2.309763910937324e-05 [2KCG iteration 11, residual = 3.0394774511316688e-05 [2KCG iteration 12, residual = 3.8969386716074296e-05 [2KCG iteration 13, residual = 3.5596439012634774e-05 [2KCG iteration 14, residual = 3.4298203215419504e-05 [2KCG iteration 15, residual = 2.9537464853919973e-05 [2KCG iteration 16, residual = 2.0672465815049427e-05 [2KCG iteration 17, residual = 1.3439029603513566e-05 [2KCG iteration 18, residual = 9.865211615565612e-06 [2KCG iteration 19, residual = 8.486602113752598e-06 [2KCG iteration 20, residual = 7.068506408055065e-06 [2KCG iteration 21, residual = 5.685853314607451e-06 [2KCG iteration 22, residual = 5.329384975515119e-06 [2KCG iteration 23, residual = 4.705021696284856e-06 [2KCG iteration 24, residual = 4.626505738189833e-06 [2KCG iteration 25, residual = 4.833605791386804e-06 [2KCG iteration 26, residual = 5.137472944672058e-06 [2KCG iteration 27, residual = 4.966472145047962e-06 [2KCG iteration 28, residual = 4.00541805345153e-06 [2KCG iteration 29, residual = 3.0640996260703793e-06 [2KCG iteration 30, residual = 1.964828956647638e-06 [2KCG iteration 31, residual = 1.428484972276837e-06 [2KCG iteration 32, residual = 1.1739247696678483e-06 [2KCG iteration 33, residual = 9.284071429173136e-07 [2KCG iteration 34, residual = 6.505709818754667e-07 [2KCG iteration 35, residual = 4.996292745651332e-07 [2KCG iteration 36, residual = 4.395959850356657e-07 [2KCG iteration 37, residual = 3.987921143600849e-07 [2KCG iteration 38, residual = 4.217959168918857e-07 [2KCG iteration 39, residual = 4.3807647225104524e-07 [2KCG iteration 40, residual = 4.6629070536672243e-07 [2KCG iteration 41, residual = 4.084614600968492e-07 [2KCG iteration 42, residual = 3.8025255156011496e-07 [2KCG iteration 43, residual = 3.4737894993399213e-07 [2KCG iteration 44, residual = 2.6660849369658747e-07 [2KCG iteration 45, residual = 1.982066509377647e-07 [2KCG iteration 46, residual = 1.520272324637382e-07 [2KCG iteration 47, residual = 1.1006956913192132e-07 [2KCG iteration 48, residual = 8.003236559231639e-08 [2KCG iteration 49, residual = 6.27107760060723e-08 [2KCG iteration 50, residual = 5.686036412823204e-08 [2KCG iteration 51, residual = 4.8267084867132316e-08 [2KCG iteration 52, residual = 4.7008549567423665e-08 [2KCG iteration 53, residual = 4.783550250967815e-08 [2KCG iteration 54, residual = 5.2351363525239674e-08 [2KCG iteration 55, residual = 5.0468327877930506e-08 [2KCG iteration 56, residual = 4.6381091239905164e-08 [2KCG iteration 57, residual = 3.935050164220023e-08 [2KCG iteration 58, residual = 3.4251105666719125e-08 [2KCG iteration 59, residual = 2.800715453062127e-08 [2KCG iteration 60, residual = 2.1079818518891628e-08 [2KCG iteration 61, residual = 1.5409991482451766e-08 [2KCG iteration 62, residual = 1.1135287398186477e-08 [2KCG iteration 63, residual = 7.872396777595949e-09 [2KCG iteration 64, residual = 6.274571616633777e-09 [2KCG iteration 65, residual = 5.164031499607439e-09 [2KCG iteration 66, residual = 4.581777519934093e-09 [2KCG iteration 67, residual = 4.1099148742635584e-09 [2KCG iteration 68, residual = 4.149804457875563e-09 [2KCG iteration 69, residual = 4.136931644798902e-09 [2KCG iteration 70, residual = 4.393660727603292e-09 [2KCG iteration 71, residual = 4.312540715495237e-09 [2KCG iteration 72, residual = 3.962147819172545e-09 [2KCG iteration 73, residual = 3.294750334403484e-09 [2KCG iteration 74, residual = 2.6222153646627506e-09 [2KCG iteration 75, residual = 1.916161648159845e-09 [2KCG iteration 76, residual = 1.5008375990001874e-09 [2KCG iteration 77, residual = 1.1118665677339187e-09 [2KCG iteration 78, residual = 8.687069916641797e-10 [2KCG iteration 79, residual = 6.749690825879903e-10 [2KCG iteration 80, residual = 5.567788440342331e-10 [2KCG iteration 81, residual = 4.527527262771175e-10 [2KCG iteration 82, residual = 3.6666320666021457e-10 [2KCG iteration 83, residual = 3.431277777770593e-10 [2KCG iteration 84, residual = 3.453007682566507e-10 [2KCG iteration 85, residual = 3.5571061684562586e-10 [2KCG iteration 86, residual = 3.8660366745600587e-10 [2KCG iteration 87, residual = 3.802330718508536e-10 [2KCG iteration 88, residual = 3.5186646967030477e-10 [2KCG iteration 89, residual = 2.998997575245889e-10 [2KCG iteration 90, residual = 2.5903527458326295e-10 [2KCG iteration 91, residual = 1.9424114199384675e-10 [2KCG iteration 92, residual = 1.5299550455627173e-10 [2KCG iteration 93, residual = 1.1171413419658109e-10 [2KCG iteration 94, residual = 8.209791653693687e-11 [2KCG iteration 95, residual = 6.845545809397776e-11 [2KCG iteration 96, residual = 5.667767548705256e-11 [2KCG iteration 97, residual = 4.704286278095046e-11 [2KCG iteration 98, residual = 4.221599768214049e-11 [2KCG iteration 99, residual = 4.11040236082526e-11 [2KCG iteration 100, residual = 3.8848196676802886e-11 [2KCG iteration 101, residual = 3.938177849842627e-11 [2KCG iteration 102, residual = 4.115819628770823e-11 [2KCG iteration 103, residual = 4.059834277557624e-11 [2KCG iteration 104, residual = 4.012073472513115e-11 [2KCG iteration 105, residual = 3.3902060947529143e-11 [2KCG converged in 105 iterations to residual 3.3902060947529143e-11
0.02[2KCG iteration 1, residual = 0.0034996594799287504
[2KCG iteration 2, residual = 0.00026615762602093913 [2KCG iteration 3, residual = 0.00021105313895443048 [2KCG iteration 4, residual = 0.00022187149786234104 [2KCG iteration 5, residual = 0.00015173394987096393 [2KCG iteration 6, residual = 7.338613661185809e-05 [2KCG iteration 7, residual = 4.1002038262805865e-05 [2KCG iteration 8, residual = 3.71211010455754e-05 [2KCG iteration 9, residual = 2.9602991423072655e-05 [2KCG iteration 10, residual = 2.3052041456051596e-05 [2KCG iteration 11, residual = 3.0366278522542788e-05 [2KCG iteration 12, residual = 3.9022294181001045e-05 [2KCG iteration 13, residual = 3.56065254999373e-05 [2KCG iteration 14, residual = 3.4186923874620416e-05 [2KCG iteration 15, residual = 2.9373724102095797e-05 [2KCG iteration 16, residual = 2.0551426325479998e-05 [2KCG iteration 17, residual = 1.3369375974652548e-05 [2KCG iteration 18, residual = 9.813917039132864e-06 [2KCG iteration 19, residual = 8.422695789496116e-06 [2KCG iteration 20, residual = 7.020318816929297e-06 [2KCG iteration 21, residual = 5.6501727866653536e-06 [2KCG iteration 22, residual = 5.283387680983901e-06 [2KCG iteration 23, residual = 4.663805360464564e-06 [2KCG iteration 24, residual = 4.587421918849668e-06 [2KCG iteration 25, residual = 4.787432788293015e-06 [2KCG iteration 26, residual = 5.0878744411877296e-06 [2KCG iteration 27, residual = 4.9233051887608835e-06 [2KCG iteration 28, residual = 3.974554030313985e-06 [2KCG iteration 29, residual = 3.0423976840576575e-06 [2KCG iteration 30, residual = 1.9459646725840257e-06 [2KCG iteration 31, residual = 1.4101092988602082e-06 [2KCG iteration 32, residual = 1.1611002230480228e-06 [2KCG iteration 33, residual = 9.202246135601186e-07 [2KCG iteration 34, residual = 6.461930347270887e-07 [2KCG iteration 35, residual = 4.969616001239697e-07 [2KCG iteration 36, residual = 4.3746337401663865e-07 [2KCG iteration 37, residual = 3.962659757918066e-07 [2KCG iteration 38, residual = 4.1923733137222486e-07 [2KCG iteration 39, residual = 4.355190219900336e-07 [2KCG iteration 40, residual = 4.6440173862697035e-07 [2KCG iteration 41, residual = 4.0646167031588026e-07 [2KCG iteration 42, residual = 3.7821368652825186e-07 [2KCG iteration 43, residual = 3.450355845001474e-07 [2KCG iteration 44, residual = 2.6474473244991885e-07 [2KCG iteration 45, residual = 1.970596292954957e-07 [2KCG iteration 46, residual = 1.509046836207586e-07 [2KCG iteration 47, residual = 1.0910999092827506e-07 [2KCG iteration 48, residual = 7.938720548510523e-08 [2KCG iteration 49, residual = 6.218582311519425e-08 [2KCG iteration 50, residual = 5.646420128277262e-08 [2KCG iteration 51, residual = 4.811722140772708e-08 [2KCG iteration 52, residual = 4.6801736109489034e-08 [2KCG iteration 53, residual = 4.7493620843548114e-08 [2KCG iteration 54, residual = 5.198070209614141e-08 [2KCG iteration 55, residual = 5.017384142141455e-08 [2KCG iteration 56, residual = 4.612775497470792e-08 [2KCG iteration 57, residual = 3.907725998235276e-08 [2KCG iteration 58, residual = 3.4024786586659565e-08 [2KCG iteration 59, residual = 2.7841296645372385e-08 [2KCG iteration 60, residual = 2.097521869472937e-08 [2KCG iteration 61, residual = 1.5360944334322987e-08 [2KCG iteration 62, residual = 1.1075260489052106e-08 [2KCG iteration 63, residual = 7.822582669748077e-09 [2KCG iteration 64, residual = 6.229979612376278e-09 [2KCG iteration 65, residual = 5.119347775229027e-09 [2KCG iteration 66, residual = 4.5538749014761746e-09 [2KCG iteration 67, residual = 4.088457260025916e-09 [2KCG iteration 68, residual = 4.130822000037821e-09 [2KCG iteration 69, residual = 4.11530486907705e-09 [2KCG iteration 70, residual = 4.369601901663486e-09 [2KCG iteration 71, residual = 4.286700455474559e-09 [2KCG iteration 72, residual = 3.936424558365315e-09 [2KCG iteration 73, residual = 3.276105949848945e-09 [2KCG iteration 74, residual = 2.613821360334551e-09 [2KCG iteration 75, residual = 1.9072791502271585e-09 [2KCG iteration 76, residual = 1.492636586420555e-09 [2KCG iteration 77, residual = 1.108018805482745e-09 [2KCG iteration 78, residual = 8.641064435559002e-10 [2KCG iteration 79, residual = 6.714997303277321e-10 [2KCG iteration 80, residual = 5.538372513200745e-10 [2KCG iteration 81, residual = 4.5061332153463253e-10 [2KCG iteration 82, residual = 3.6490062238679794e-10 [2KCG iteration 83, residual = 3.412243942829032e-10 [2KCG iteration 84, residual = 3.427485020852321e-10 [2KCG iteration 85, residual = 3.5442944028903533e-10 [2KCG iteration 86, residual = 3.8437273055741163e-10 [2KCG iteration 87, residual = 3.7912673366938005e-10 [2KCG iteration 88, residual = 3.506096599280824e-10 [2KCG iteration 89, residual = 2.9813116985142727e-10 [2KCG iteration 90, residual = 2.5766498502894294e-10 [2KCG iteration 91, residual = 1.931828905748042e-10 [2KCG iteration 92, residual = 1.5271425495267052e-10 [2KCG iteration 93, residual = 1.1136465087936655e-10 [2KCG iteration 94, residual = 8.191387919682405e-11 [2KCG iteration 95, residual = 6.826133169603524e-11 [2KCG iteration 96, residual = 5.6437979371713083e-11 [2KCG iteration 97, residual = 4.695425356877513e-11 [2KCG iteration 98, residual = 4.2022006026802e-11 [2KCG iteration 99, residual = 4.0939834517357255e-11 [2KCG iteration 100, residual = 3.867205607311241e-11 [2KCG iteration 101, residual = 3.926463518629345e-11 [2KCG iteration 102, residual = 4.080814764993497e-11 [2KCG iteration 103, residual = 4.049869216714212e-11 [2KCG iteration 104, residual = 3.988089709920761e-11 [2KCG iteration 105, residual = 3.3857880766492275e-11 [2KCG converged in 105 iterations to residual 3.3857880766492275e-11
0.021[2KCG iteration 1, residual = 0.003499392226307487
[2KCG iteration 2, residual = 0.0002656235608075457 [2KCG iteration 3, residual = 0.00021022352449486694 [2KCG iteration 4, residual = 0.00022126806022626654 [2KCG iteration 5, residual = 0.0001517058641189097 [2KCG iteration 6, residual = 7.32373413042507e-05 [2KCG iteration 7, residual = 4.065949504735404e-05 [2KCG iteration 8, residual = 3.6757592503281485e-05 [2KCG iteration 9, residual = 2.947864166701894e-05 [2KCG iteration 10, residual = 2.3011796138068018e-05 [2KCG iteration 11, residual = 3.0343693361377137e-05 [2KCG iteration 12, residual = 3.908003477770683e-05 [2KCG iteration 13, residual = 3.5618163468946736e-05 [2KCG iteration 14, residual = 3.407435999161058e-05 [2KCG iteration 15, residual = 2.9209058292756795e-05 [2KCG iteration 16, residual = 2.0430732870753615e-05 [2KCG iteration 17, residual = 1.3300051527628116e-05 [2KCG iteration 18, residual = 9.763644437914473e-06 [2KCG iteration 19, residual = 8.360632104181607e-06 [2KCG iteration 20, residual = 6.9733583970698e-06 [2KCG iteration 21, residual = 5.61512157638372e-06 [2KCG iteration 22, residual = 5.238219686896261e-06 [2KCG iteration 23, residual = 4.623569602979263e-06 [2KCG iteration 24, residual = 4.549573442724841e-06 [2KCG iteration 25, residual = 4.7430273322240205e-06 [2KCG iteration 26, residual = 5.040201537796052e-06 [2KCG iteration 27, residual = 4.881308124900821e-06 [2KCG iteration 28, residual = 3.944139599103232e-06 [2KCG iteration 29, residual = 3.021096902895716e-06 [2KCG iteration 30, residual = 1.9276333235092873e-06 [2KCG iteration 31, residual = 1.3922803633486663e-06 [2KCG iteration 32, residual = 1.1486162839855576e-06 [2KCG iteration 33, residual = 9.122226912228274e-07 [2KCG iteration 34, residual = 6.419197070531168e-07 [2KCG iteration 35, residual = 4.943720403421837e-07 [2KCG iteration 36, residual = 4.353994185297953e-07 [2KCG iteration 37, residual = 3.9380021501164483e-07 [2KCG iteration 38, residual = 4.167335822599322e-07 [2KCG iteration 39, residual = 4.3301948055033643e-07 [2KCG iteration 40, residual = 4.6255824806419825e-07 [2KCG iteration 41, residual = 4.0453373055864344e-07 [2KCG iteration 42, residual = 3.762439153235578e-07 [2KCG iteration 43, residual = 3.4273179637875274e-07 [2KCG iteration 44, residual = 2.62901583198526e-07 [2KCG iteration 45, residual = 1.9592345036451122e-07 [2KCG iteration 46, residual = 1.4978716105669024e-07 [2KCG iteration 47, residual = 1.0816677842864059e-07 [2KCG iteration 48, residual = 7.875978847471648e-08 [2KCG iteration 49, residual = 6.167413952052847e-08 [2KCG iteration 50, residual = 5.607547389782901e-08 [2KCG iteration 51, residual = 4.7973077734766046e-08 [2KCG iteration 52, residual = 4.660074787462056e-08 [2KCG iteration 53, residual = 4.71628762312285e-08 [2KCG iteration 54, residual = 5.1620331850365464e-08 [2KCG iteration 55, residual = 4.988719314613679e-08 [2KCG iteration 56, residual = 4.587909030247122e-08 [2KCG iteration 57, residual = 3.88110341643019e-08 [2KCG iteration 58, residual = 3.380537939396533e-08 [2KCG iteration 59, residual = 2.767785552466412e-08 [2KCG iteration 60, residual = 2.087053759596765e-08 [2KCG iteration 61, residual = 1.5311387518565136e-08 [2KCG iteration 62, residual = 1.1014641294784786e-08 [2KCG iteration 63, residual = 7.7731616809207e-09 [2KCG iteration 64, residual = 6.186193087290327e-09 [2KCG iteration 65, residual = 5.075391915535106e-09 [2KCG iteration 66, residual = 4.526677891324867e-09 [2KCG iteration 67, residual = 4.06771479225344e-09 [2KCG iteration 68, residual = 4.112293255461905e-09 [2KCG iteration 69, residual = 4.0944443851223265e-09 [2KCG iteration 70, residual = 4.346395155995504e-09 [2KCG iteration 71, residual = 4.2612788907795844e-09 [2KCG iteration 72, residual = 3.910734614993407e-09 [2KCG iteration 73, residual = 3.2575864746623013e-09 [2KCG iteration 74, residual = 2.6055201253986017e-09 [2KCG iteration 75, residual = 1.8985557734021666e-09 [2KCG iteration 76, residual = 1.4844799402502883e-09 [2KCG iteration 77, residual = 1.1041991377921551e-09 [2KCG iteration 78, residual = 8.595224985603431e-10 [2KCG iteration 79, residual = 6.680481454458048e-10 [2KCG iteration 80, residual = 5.508001209973992e-10 [2KCG iteration 81, residual = 4.4844593267789534e-10 [2KCG iteration 82, residual = 3.631462627749216e-10 [2KCG iteration 83, residual = 3.392748327225723e-10 [2KCG iteration 84, residual = 3.4022349721751535e-10 [2KCG iteration 85, residual = 3.531385181341105e-10 [2KCG iteration 86, residual = 3.820556285280273e-10 [2KCG iteration 87, residual = 3.780113893267728e-10 [2KCG iteration 88, residual = 3.4934861348812464e-10 [2KCG iteration 89, residual = 2.9638591659686173e-10 [2KCG iteration 90, residual = 2.5625899268598754e-10 [2KCG iteration 91, residual = 1.9214443057750597e-10 [2KCG iteration 92, residual = 1.524189275246452e-10 [2KCG iteration 93, residual = 1.1100778003124254e-10 [2KCG iteration 94, residual = 8.174601503475498e-11 [2KCG iteration 95, residual = 6.806457868312794e-11 [2KCG iteration 96, residual = 5.619619910441268e-11 [2KCG iteration 97, residual = 4.6864976951375665e-11 [2KCG iteration 98, residual = 4.182257901232309e-11 [2KCG iteration 99, residual = 4.076398266640114e-11 [2KCG iteration 100, residual = 3.849493502284744e-11 [2KCG iteration 101, residual = 3.913987874684194e-11 [2KCG iteration 102, residual = 4.045837555075076e-11 [2KCG iteration 103, residual = 4.0397543504992014e-11 [2KCG iteration 104, residual = 3.963036985033604e-11 [2KCG iteration 105, residual = 3.381633617744213e-11 [2KCG converged in 105 iterations to residual 3.381633617744213e-11
0.022[2KCG iteration 1, residual = 0.0034991251423631686
[2KCG iteration 2, residual = 0.0002651053665723844 [2KCG iteration 3, residual = 0.0002094315385236896 [2KCG iteration 4, residual = 0.00022069358743942097 [2KCG iteration 5, residual = 0.00015168252310812937 [2KCG iteration 6, residual = 7.309235814134801e-05 [2KCG iteration 7, residual = 4.032374287087178e-05 [2KCG iteration 8, residual = 3.6401332574308736e-05 [2KCG iteration 9, residual = 2.9359195185675956e-05 [2KCG iteration 10, residual = 2.2976605305843597e-05 [2KCG iteration 11, residual = 3.032650832532775e-05 [2KCG iteration 12, residual = 3.914199477504823e-05 [2KCG iteration 13, residual = 3.5630918811061024e-05 [2KCG iteration 14, residual = 3.396031840470617e-05 [2KCG iteration 15, residual = 2.904344256678665e-05 [2KCG iteration 16, residual = 2.0310401061058686e-05 [2KCG iteration 17, residual = 1.3231091131363677e-05 [2KCG iteration 18, residual = 9.714375763065734e-06 [2KCG iteration 19, residual = 8.300354632689676e-06 [2KCG iteration 20, residual = 6.927605076144969e-06 [2KCG iteration 21, residual = 5.580707779331482e-06 [2KCG iteration 22, residual = 5.193884587226574e-06 [2KCG iteration 23, residual = 4.584304681433868e-06 [2KCG iteration 24, residual = 4.512937925406394e-06 [2KCG iteration 25, residual = 4.7003423040047864e-06 [2KCG iteration 26, residual = 4.99439912361814e-06 [2KCG iteration 27, residual = 4.840459820532774e-06 [2KCG iteration 28, residual = 3.91416555943783e-06 [2KCG iteration 29, residual = 3.0001736386833535e-06 [2KCG iteration 30, residual = 1.909807930554776e-06 [2KCG iteration 31, residual = 1.3749789975463694e-06 [2KCG iteration 32, residual = 1.1364672329842508e-06 [2KCG iteration 33, residual = 9.044005506032427e-07 [2KCG iteration 34, residual = 6.37748305730149e-07 [2KCG iteration 35, residual = 4.918562234339331e-07 [2KCG iteration 36, residual = 4.3340000099785405e-07 [2KCG iteration 37, residual = 3.9139244779966845e-07 [2KCG iteration 38, residual = 4.1428387252735143e-07 [2KCG iteration 39, residual = 4.305775793492394e-07 [2KCG iteration 40, residual = 4.607598984663823e-07
CG iteration 41, residual = 4.026752246159263e-07CG iteration 42, residual = 3.743400053931674e-07 CG iteration 43, residual = 3.4046533448215793e-07 CG iteration 44, residual = 2.610780168563376e-07 CG iteration 45, residual = 1.947973922965001e-07 CG iteration 46, residual = 1.4867415344707222e-07 CG iteration 47, residual = 1.0723941780198438e-07 CG iteration 48, residual = 7.8149614076342e-08 CG iteration 49, residual = 6.11755382989113e-08 CG iteration 50, residual = 5.569422208624208e-08 CG iteration 51, residual = 4.783437845943873e-08 CG iteration 52, residual = 4.640515398052617e-08 CG iteration 53, residual = 4.6842824066595466e-08 CG iteration 54, residual = 5.12700069009314e-08 CG iteration 55, residual = 4.960820540248566e-08 CG iteration 56, residual = 4.5634843174238136e-08 CG iteration 57, residual = 3.855161281242868e-08 CG iteration 58, residual = 3.3592622899763045e-08 CG iteration 59, residual = 2.7516739321609202e-08 CG iteration 60, residual = 2.0765813262817226e-08 CG iteration 61, residual = 1.5261259197933392e-08 CG iteration 62, residual = 1.0953416923731341e-08 CG iteration 63, residual = 7.724149318187366e-09 CG iteration 64, residual = 6.1432033886997e-09 CG iteration 65, residual = 5.032158330692109e-09 CG iteration 66, residual = 4.50018555037981e-09 CG iteration 67, residual = 4.047669470758188e-09 CG iteration 68, residual = 4.0942159068033276e-09 CG iteration 69, residual = 4.074330016653423e-09 CG iteration 70, residual = 4.323990600878491e-09 CG iteration 71, residual = 4.23626133774326e-09 CG iteration 72, residual = 3.885122005276957e-09 CG iteration 73, residual = 3.2392082203011834e-09 CG iteration 74, residual = 2.597292049054133e-09 CG iteration 75, residual = 1.8899865466317463e-09 CG iteration 76, residual = 1.4763744340816227e-09 CG iteration 77, residual = 1.1004059418923093e-09 CG iteration 78, residual = 8.549563349345474e-10 CG iteration 79, residual = 6.646160579007124e-10 CG iteration 80, residual = 5.476766289316589e-10 CG iteration 81, residual = 4.4625763677265263e-10 CG iteration 82, residual = 3.6140140001198693e-10 CG iteration 83, residual = 3.3728734853878076e-10 CG iteration 84, residual = 3.3773492272214513e-10 CG iteration 85, residual = 3.5184151572340256e-10 CG iteration 86, residual = 3.796672569790714e-10 CG iteration 87, residual = 3.7689259879981535e-10 CG iteration 88, residual = 3.4808454131580965e-10 CG iteration 89, residual = 2.946674576093797e-10 CG iteration 90, residual = 2.548217510777428e-10 CG iteration 91, residual = 1.9112796401438504e-10 CG iteration 92, residual = 1.5210811936477555e-10 CG iteration 93, residual = 1.1064511404725328e-10 CG iteration 94, residual = 8.159419464009897e-11 CG iteration 95, residual = 6.786452988270309e-11 CG iteration 96, residual = 5.5953650308732496e-11 CG iteration 97, residual = 4.677535994283423e-11 CG iteration 98, residual = 4.161815577859002e-11 CG iteration 99, residual = 4.057780286896796e-11 CG iteration 100, residual = 3.831753551936331e-11 CG iteration 101, residual = 3.900760097304317e-11 CG iteration 102, residual = 4.011062179065174e-11 CG iteration 103, residual = 4.0294992970649684e-11 CG iteration 104, residual = 3.937053135710275e-11 CG iteration 105, residual = 3.377742899478914e-11 CG converged in 105 iterations to residual 3.377742899478914e-11
0.023CG iteration 1, residual = 0.0034988581021615723
CG iteration 2, residual = 0.0002646021847055455 CG iteration 3, residual = 0.0002086752066583068 CG iteration 4, residual = 0.00022014670807520223 CG iteration 5, residual = 0.00015166355256387366 CG iteration 6, residual = 7.295094277767807e-05 CG iteration 7, residual = 3.99944829781855e-05 CG iteration 8, residual = 3.605198773918122e-05 CG iteration 9, residual = 2.9244400142825446e-05 CG iteration 10, residual = 2.294619851772312e-05 CG iteration 11, residual = 3.0314255721558537e-05 CG iteration 12, residual = 3.9207607687608526e-05 CG iteration 13, residual = 3.56444019778679e-05 CG iteration 14, residual = 3.3844643570696135e-05 CG iteration 15, residual = 2.8876871139740936e-05 CG iteration 16, residual = 2.0190453827267397e-05 CG iteration 17, residual = 1.3162531787109296e-05 CG iteration 18, residual = 9.666094931121258e-06 CG iteration 19, residual = 8.241808444878573e-06 CG iteration 20, residual = 6.883036562571137e-06 CG iteration 21, residual = 5.5469357396962055e-06 CG iteration 22, residual = 5.150382395329695e-06 CG iteration 23, residual = 4.545998777136423e-06 CG iteration 24, residual = 4.477491115191744e-06 CG iteration 25, residual = 4.659328862592935e-06 CG iteration 26, residual = 4.950410513385545e-06 CG iteration 27, residual = 4.800737032451654e-06 CG iteration 28, residual = 3.884622237001901e-06 CG iteration 29, residual = 2.979605646554761e-06 CG iteration 30, residual = 1.8924632002720564e-06 CG iteration 31, residual = 1.358186704529132e-06 CG iteration 32, residual = 1.1246470606855332e-06 CG iteration 33, residual = 8.967572289783499e-07 CG iteration 34, residual = 6.336763242666049e-07 CG iteration 35, residual = 4.894099687192105e-07 CG iteration 36, residual = 4.3146112106687163e-07 CG iteration 37, residual = 3.8904037916000986e-07 CG iteration 38, residual = 4.118874219932432e-07 CG iteration 39, residual = 4.281930172719657e-07 CG iteration 40, residual = 4.5900633130727577e-07 CG iteration 41, residual = 4.0088379219026744e-07 CG iteration 42, residual = 3.7249878428084623e-07 CG iteration 43, residual = 3.382340170138856e-07
</pre>
end{sphinxVerbatim}
[2KCG iteration 42, residual = 3.743400053931674e-07 [2KCG iteration 43, residual = 3.4046533448215793e-07 [2KCG iteration 44, residual = 2.610780168563376e-07 [2KCG iteration 45, residual = 1.947973922965001e-07 [2KCG iteration 46, residual = 1.4867415344707222e-07 [2KCG iteration 47, residual = 1.0723941780198438e-07 [2KCG iteration 48, residual = 7.8149614076342e-08 [2KCG iteration 49, residual = 6.11755382989113e-08 [2KCG iteration 50, residual = 5.569422208624208e-08 [2KCG iteration 51, residual = 4.783437845943873e-08 [2KCG iteration 52, residual = 4.640515398052617e-08 [2KCG iteration 53, residual = 4.6842824066595466e-08 [2KCG iteration 54, residual = 5.12700069009314e-08 [2KCG iteration 55, residual = 4.960820540248566e-08 [2KCG iteration 56, residual = 4.5634843174238136e-08 [2KCG iteration 57, residual = 3.855161281242868e-08 [2KCG iteration 58, residual = 3.3592622899763045e-08 [2KCG iteration 59, residual = 2.7516739321609202e-08 [2KCG iteration 60, residual = 2.0765813262817226e-08 [2KCG iteration 61, residual = 1.5261259197933392e-08 [2KCG iteration 62, residual = 1.0953416923731341e-08 [2KCG iteration 63, residual = 7.724149318187366e-09 [2KCG iteration 64, residual = 6.1432033886997e-09 [2KCG iteration 65, residual = 5.032158330692109e-09 [2KCG iteration 66, residual = 4.50018555037981e-09 [2KCG iteration 67, residual = 4.047669470758188e-09 [2KCG iteration 68, residual = 4.0942159068033276e-09 [2KCG iteration 69, residual = 4.074330016653423e-09 [2KCG iteration 70, residual = 4.323990600878491e-09 [2KCG iteration 71, residual = 4.23626133774326e-09 [2KCG iteration 72, residual = 3.885122005276957e-09 [2KCG iteration 73, residual = 3.2392082203011834e-09 [2KCG iteration 74, residual = 2.597292049054133e-09 [2KCG iteration 75, residual = 1.8899865466317463e-09 [2KCG iteration 76, residual = 1.4763744340816227e-09 [2KCG iteration 77, residual = 1.1004059418923093e-09 [2KCG iteration 78, residual = 8.549563349345474e-10 [2KCG iteration 79, residual = 6.646160579007124e-10 [2KCG iteration 80, residual = 5.476766289316589e-10 [2KCG iteration 81, residual = 4.4625763677265263e-10 [2KCG iteration 82, residual = 3.6140140001198693e-10 [2KCG iteration 83, residual = 3.3728734853878076e-10 [2KCG iteration 84, residual = 3.3773492272214513e-10 [2KCG iteration 85, residual = 3.5184151572340256e-10 [2KCG iteration 86, residual = 3.796672569790714e-10 [2KCG iteration 87, residual = 3.7689259879981535e-10 [2KCG iteration 88, residual = 3.4808454131580965e-10 [2KCG iteration 89, residual = 2.946674576093797e-10 [2KCG iteration 90, residual = 2.548217510777428e-10 [2KCG iteration 91, residual = 1.9112796401438504e-10 [2KCG iteration 92, residual = 1.5210811936477555e-10 [2KCG iteration 93, residual = 1.1064511404725328e-10 [2KCG iteration 94, residual = 8.159419464009897e-11 [2KCG iteration 95, residual = 6.786452988270309e-11 [2KCG iteration 96, residual = 5.5953650308732496e-11 [2KCG iteration 97, residual = 4.677535994283423e-11 [2KCG iteration 98, residual = 4.161815577859002e-11 [2KCG iteration 99, residual = 4.057780286896796e-11 [2KCG iteration 100, residual = 3.831753551936331e-11 [2KCG iteration 101, residual = 3.900760097304317e-11 [2KCG iteration 102, residual = 4.011062179065174e-11 [2KCG iteration 103, residual = 4.0294992970649684e-11 [2KCG iteration 104, residual = 3.937053135710275e-11 [2KCG iteration 105, residual = 3.377742899478914e-11 [2KCG converged in 105 iterations to residual 3.377742899478914e-11
0.023[2KCG iteration 1, residual = 0.0034988581021615723
[2KCG iteration 2, residual = 0.0002646021847055455 [2KCG iteration 3, residual = 0.0002086752066583068 [2KCG iteration 4, residual = 0.00022014670807520223 [2KCG iteration 5, residual = 0.00015166355256387366 [2KCG iteration 6, residual = 7.295094277767807e-05 [2KCG iteration 7, residual = 3.99944829781855e-05 [2KCG iteration 8, residual = 3.605198773918122e-05 [2KCG iteration 9, residual = 2.9244400142825446e-05 [2KCG iteration 10, residual = 2.294619851772312e-05 [2KCG iteration 11, residual = 3.0314255721558537e-05 [2KCG iteration 12, residual = 3.9207607687608526e-05 [2KCG iteration 13, residual = 3.56444019778679e-05 [2KCG iteration 14, residual = 3.3844643570696135e-05 [2KCG iteration 15, residual = 2.8876871139740936e-05 [2KCG iteration 16, residual = 2.0190453827267397e-05 [2KCG iteration 17, residual = 1.3162531787109296e-05 [2KCG iteration 18, residual = 9.666094931121258e-06 [2KCG iteration 19, residual = 8.241808444878573e-06 [2KCG iteration 20, residual = 6.883036562571137e-06 [2KCG iteration 21, residual = 5.5469357396962055e-06 [2KCG iteration 22, residual = 5.150382395329695e-06 [2KCG iteration 23, residual = 4.545998777136423e-06 [2KCG iteration 24, residual = 4.477491115191744e-06 [2KCG iteration 25, residual = 4.659328862592935e-06 [2KCG iteration 26, residual = 4.950410513385545e-06 [2KCG iteration 27, residual = 4.800737032451654e-06 [2KCG iteration 28, residual = 3.884622237001901e-06 [2KCG iteration 29, residual = 2.979605646554761e-06 [2KCG iteration 30, residual = 1.8924632002720564e-06 [2KCG iteration 31, residual = 1.358186704529132e-06 [2KCG iteration 32, residual = 1.1246470606855332e-06 [2KCG iteration 33, residual = 8.967572289783499e-07 [2KCG iteration 34, residual = 6.336763242666049e-07 [2KCG iteration 35, residual = 4.894099687192105e-07 [2KCG iteration 36, residual = 4.3146112106687163e-07 [2KCG iteration 37, residual = 3.8904037916000986e-07 [2KCG iteration 38, residual = 4.118874219932432e-07 [2KCG iteration 39, residual = 4.281930172719657e-07 [2KCG iteration 40, residual = 4.5900633130727577e-07 [2KCG iteration 41, residual = 4.0088379219026744e-07 [2KCG iteration 42, residual = 3.7249878428084623e-07 [2KCG iteration 43, residual = 3.382340170138856e-07
CG iteration 44, residual = 2.5927307968907704e-07CG iteration 45, residual = 1.9368081814025373e-07 CG iteration 46, residual = 1.4756526269174903e-07 CG iteration 47, residual = 1.0632744080950316e-07 CG iteration 48, residual = 7.755619793333949e-08 CG iteration 49, residual = 6.068982419847682e-08 CG iteration 50, residual = 5.532046818438384e-08 CG iteration 51, residual = 4.7700853066661216e-08 CG iteration 52, residual = 4.621454968013655e-08 CG iteration 53, residual = 4.6533027354675124e-08 CG iteration 54, residual = 5.092947262475216e-08 CG iteration 55, residual = 4.9336699373388025e-08 CG iteration 56, residual = 4.539478163806252e-08 CG iteration 57, residual = 3.82987965283951e-08 CG iteration 58, residual = 3.338626300242165e-08 CG iteration 59, residual = 2.735786102411103e-08 CG iteration 60, residual = 2.0661084222957408e-08 CG iteration 61, residual = 1.5210500990795587e-08 CG iteration 62, residual = 1.0891585215130076e-08 CG iteration 63, residual = 7.675565139389973e-09 CG iteration 64, residual = 6.1010022505019045e-09 CG iteration 65, residual = 4.989642136614706e-09 CG iteration 66, residual = 4.47439601929969e-09 CG iteration 67, residual = 4.0283035594694906e-09 CG iteration 68, residual = 4.076588073931889e-09 CG iteration 69, residual = 4.0549409053415866e-09 CG iteration 70, residual = 4.30233897454419e-09 CG iteration 71, residual = 4.211634759802552e-09 CG iteration 72, residual = 3.85962992571114e-09 CG iteration 73, residual = 3.220987366995682e-09 CG iteration 74, residual = 2.5891188675511037e-09 CG iteration 75, residual = 1.881567467712478e-09 CG iteration 76, residual = 1.468326636153202e-09 CG iteration 77, residual = 1.0966377143891169e-09 CG iteration 78, residual = 8.504089753311674e-10 CG iteration 79, residual = 6.612050631104749e-10 CG iteration 80, residual = 5.444760384986183e-10 CG iteration 81, residual = 4.4405484502966203e-10 CG iteration 82, residual = 3.5966703062320047e-10 CG iteration 83, residual = 3.352700911427708e-10 CG iteration 84, residual = 3.352905769901081e-10 CG iteration 85, residual = 3.505413808582025e-10 CG iteration 86, residual = 3.772221446786016e-10 CG iteration 87, residual = 3.757751122593401e-10 CG iteration 88, residual = 3.468182830857938e-10 CG iteration 89, residual = 2.9297887655877483e-10 CG iteration 90, residual = 2.5335763379266104e-10 CG iteration 91, residual = 1.9013539652707753e-10 CG iteration 92, residual = 1.5178047461123438e-10 CG iteration 93, residual = 1.102783414794849e-10 CG iteration 94, residual = 8.145817363951375e-11 CG iteration 95, residual = 6.766055803178793e-11 CG iteration 96, residual = 5.571162128594709e-11 CG iteration 97, residual = 4.668563017148079e-11 CG iteration 98, residual = 4.140919103331786e-11 CG iteration 99, residual = 4.038262553621216e-11 CG iteration 100, residual = 3.814045429729577e-11 CG iteration 101, residual = 3.886792328495442e-11 CG iteration 102, residual = 3.9766487396455715e-11 CG iteration 103, residual = 4.019102917782134e-11 CG iteration 104, residual = 3.910276508541701e-11 CG iteration 105, residual = 3.3741137976274976e-11 CG converged in 105 iterations to residual 3.3741137976274976e-11
- 0.024CPU times: user 626 ms, sys: 2.76 ms, total: 629 ms
Wall time: 624 ms </pre>
Wall time: 624 ms end{sphinxVerbatim}
[2KCG iteration 45, residual = 1.9368081814025373e-07 [2KCG iteration 46, residual = 1.4756526269174903e-07 [2KCG iteration 47, residual = 1.0632744080950316e-07 [2KCG iteration 48, residual = 7.755619793333949e-08 [2KCG iteration 49, residual = 6.068982419847682e-08 [2KCG iteration 50, residual = 5.532046818438384e-08 [2KCG iteration 51, residual = 4.7700853066661216e-08 [2KCG iteration 52, residual = 4.621454968013655e-08 [2KCG iteration 53, residual = 4.6533027354675124e-08 [2KCG iteration 54, residual = 5.092947262475216e-08 [2KCG iteration 55, residual = 4.9336699373388025e-08 [2KCG iteration 56, residual = 4.539478163806252e-08 [2KCG iteration 57, residual = 3.82987965283951e-08 [2KCG iteration 58, residual = 3.338626300242165e-08 [2KCG iteration 59, residual = 2.735786102411103e-08 [2KCG iteration 60, residual = 2.0661084222957408e-08 [2KCG iteration 61, residual = 1.5210500990795587e-08 [2KCG iteration 62, residual = 1.0891585215130076e-08 [2KCG iteration 63, residual = 7.675565139389973e-09 [2KCG iteration 64, residual = 6.1010022505019045e-09 [2KCG iteration 65, residual = 4.989642136614706e-09 [2KCG iteration 66, residual = 4.47439601929969e-09 [2KCG iteration 67, residual = 4.0283035594694906e-09 [2KCG iteration 68, residual = 4.076588073931889e-09 [2KCG iteration 69, residual = 4.0549409053415866e-09 [2KCG iteration 70, residual = 4.30233897454419e-09 [2KCG iteration 71, residual = 4.211634759802552e-09 [2KCG iteration 72, residual = 3.85962992571114e-09 [2KCG iteration 73, residual = 3.220987366995682e-09 [2KCG iteration 74, residual = 2.5891188675511037e-09 [2KCG iteration 75, residual = 1.881567467712478e-09 [2KCG iteration 76, residual = 1.468326636153202e-09 [2KCG iteration 77, residual = 1.0966377143891169e-09 [2KCG iteration 78, residual = 8.504089753311674e-10 [2KCG iteration 79, residual = 6.612050631104749e-10 [2KCG iteration 80, residual = 5.444760384986183e-10 [2KCG iteration 81, residual = 4.4405484502966203e-10 [2KCG iteration 82, residual = 3.5966703062320047e-10 [2KCG iteration 83, residual = 3.352700911427708e-10 [2KCG iteration 84, residual = 3.352905769901081e-10 [2KCG iteration 85, residual = 3.505413808582025e-10 [2KCG iteration 86, residual = 3.772221446786016e-10 [2KCG iteration 87, residual = 3.757751122593401e-10 [2KCG iteration 88, residual = 3.468182830857938e-10 [2KCG iteration 89, residual = 2.9297887655877483e-10 [2KCG iteration 90, residual = 2.5335763379266104e-10 [2KCG iteration 91, residual = 1.9013539652707753e-10 [2KCG iteration 92, residual = 1.5178047461123438e-10 [2KCG iteration 93, residual = 1.102783414794849e-10 [2KCG iteration 94, residual = 8.145817363951375e-11 [2KCG iteration 95, residual = 6.766055803178793e-11 [2KCG iteration 96, residual = 5.571162128594709e-11 [2KCG iteration 97, residual = 4.668563017148079e-11 [2KCG iteration 98, residual = 4.140919103331786e-11 [2KCG iteration 99, residual = 4.038262553621216e-11 [2KCG iteration 100, residual = 3.814045429729577e-11 [2KCG iteration 101, residual = 3.886792328495442e-11 [2KCG iteration 102, residual = 3.9766487396455715e-11 [2KCG iteration 103, residual = 4.019102917782134e-11 [2KCG iteration 104, residual = 3.910276508541701e-11 [2KCG iteration 105, residual = 3.3741137976274976e-11 [2KCG converged in 105 iterations to residual 3.3741137976274976e-11
Wall time: 624 ms
Use
t = Parameter(0.0)
omega=1
time = 0.0
for i in range(7):
t.Set(3*i/6)
gff.Set(gausspt)
ft = LinearForm(fes)
ft += gausspt*v*dx
nsamples = 10):
if initial_cond:
gfu.Set(initial_cond)
cnt = 0; time = t0
while time < tend - 0.5 * dt:
t.Set(time)
ft.Assemble()
print("\r",time,end="")
if cnt % sample_int == 0:
cnt += 1; time = cnt * dt
return gfut
%%time
- more-to-come:
0 0.001 0.002 0.003 0.004 0.005 0.006 0.007 0.008 0.009000000000000001 0.01 0.011 0.012 0.013000000000000001 0.014 0.015 0.016 0.017 0.018000000000000002 0.019 0.02 0.021 0.022 0.023 0.024 0.025 0.026000000000000002 0.027 0.028 0.029 0.03 0.031 0.032 0.033 0.034 0.035 0.036000000000000004 0.037 0.038 0.039 0.04 0.041 0.042 0.043000000000000003 0.044 0.045 0.046 0.047 0.048 0.049 0.05 0.051000000000000004 0.052000000000000005 0.053 0.054 0.055 0.056 0.057 0.058 0.059000000000000004 0.06 0.061 0.062 0.063 0.064 0.065 0.066 0.067 0.068 0.069 0.07 0.07100000000000001 0.07200000000000001 0.073 0.074 0.075 0.076 0.077 0.078 0.079 0.08 0.081 0.082 0.083 0.084 0.085 0.08600000000000001 0.08700000000000001 0.088 0.089 0.09 0.091 0.092 0.093 0.094 0.095 0.096 0.097 0.098 0.099 0.1 0.101 0.10200000000000001 0.10300000000000001 0.10400000000000001 0.105 0.106 0.107 0.108 0.109 0.11 0.111 0.112 0.113 0.114 0.115 0.116 0.117 0.11800000000000001 0.11900000000000001 0.12 0.121 0.122 0.123 0.124 0.125 0.126 0.127 0.128 0.129 0.13 0.131 0.132 0.133 0.134 0.135 0.136 0.137 0.138 0.139 0.14 0.14100000000000001 0.14200000000000002 0.14300000000000002 0.14400000000000002 0.145 0.146 0.147 0.148 0.149 0.15 0.151 0.152 0.153 0.154 0.155 0.156 0.157 0.158 0.159 0.16 0.161 0.162 0.163 0.164 0.165 0.166 0.167 0.168 0.169 0.17 0.171 0.17200000000000001 0.17300000000000001 0.17400000000000002 0.17500000000000002 0.176 0.177 0.178 0.179 0.18 0.181 0.182 0.183 0.184 0.185 0.186 0.187 0.188 0.189 0.19 0.191 0.192 0.193 0.194 0.195 0.196 0.197 0.198 0.199 0.2 0.201 0.202 0.203 0.20400000000000001 0.20500000000000002 0.20600000000000002 0.20700000000000002 0.20800000000000002 0.209 0.21 0.211 0.212 0.213 0.214 0.215 0.216 0.217 0.218 0.219 0.22 0.221 0.222 0.223 0.224 0.225 0.226 0.227 0.228 0.229 0.23 0.231 0.232 0.233 0.234 0.23500000000000001 0.23600000000000002 0.23700000000000002 0.23800000000000002 0.23900000000000002 0.24 0.241 0.242
</pre>
end{sphinxVerbatim}
- more-to-come:
0.243 0.244 0.245 0.246 0.247 0.248 0.249 0.25 0.251 0.252 0.253 0.254 0.255 0.256 0.257 0.258 0.259 0.26 0.261 0.262 0.263 0.264 0.265 0.266 0.267 0.268 0.269 0.27 0.271 0.272 0.273 0.274 0.275 0.276 0.277 0.278 0.279 0.28 0.281 0.28200000000000003 0.28300000000000003 0.28400000000000003 0.28500000000000003 0.28600000000000003 0.28700000000000003 0.28800000000000003 0.289 0.29 0.291 0.292 0.293 0.294 0.295 0.296 0.297 0.298 0.299 0.3 0.301 0.302 0.303 0.304 0.305 0.306 0.307 0.308 0.309 0.31 0.311 0.312 0.313 0.314 0.315 0.316 0.317 0.318 0.319 0.32 0.321 0.322 0.323 0.324 0.325 0.326 0.327 0.328 0.329 0.33 0.331 0.332 0.333 0.334 0.335 0.336 0.337 0.338 0.339 0.34 0.341 0.342 0.343 0.34400000000000003 0.34500000000000003 0.34600000000000003 0.34700000000000003 0.34800000000000003 0.34900000000000003 0.35000000000000003 0.35100000000000003 0.352 0.353 0.354 0.355 0.356 0.357 0.358 0.359 0.36 0.361 0.362 0.363 0.364 0.365 0.366 0.367 0.368 0.369 0.37 0.371 0.372 0.373 0.374 0.375 0.376 0.377 0.378 0.379 0.38 0.381 0.382 0.383 0.384 0.385 0.386 0.387 0.388 0.389 0.39 0.391 0.392 0.393 0.394 0.395 0.396 0.397 0.398 0.399 0.4 0.401 0.402 0.403 0.404 0.405 0.406 0.40700000000000003 0.40800000000000003 0.40900000000000003 0.41000000000000003 0.41100000000000003 0.41200000000000003 0.41300000000000003 0.41400000000000003 0.41500000000000004 0.41600000000000004 0.417 0.418 0.419 0.42 0.421 0.422 0.423 0.424 0.425 0.426 0.427 0.428 0.429 0.43 0.431 0.432 0.433 0.434 0.435 0.436 0.437 0.438 0.439 0.44 0.441 0.442 0.443 0.444 0.445 0.446 0.447 0.448 0.449 0.45 0.451 0.452 0.453 0.454 0.455 0.456 0.457 0.458 0.459 0.46 0.461 0.462 0.463 0.464 0.465 0.466 0.467 0.468 0.46900000000000003 0.47000000000000003 0.47100000000000003 0.47200000000000003 0.47300000000000003 0.47400000000000003 0.47500000000000003 0.47600000000000003 0.47700000000000004 0.47800000000000004
</pre>
end{sphinxVerbatim}
- more-to-come:
0.47900000000000004 0.48 0.481 0.482 0.483 0.484 0.485 0.486 0.487 0.488 0.489 0.49 0.491 0.492 0.493 0.494 0.495 0.496 0.497 0.498 0.499 0.5 0.501 0.502 0.503 0.504 0.505 0.506 0.507 0.508 0.509 0.51 0.511 0.512 0.513 0.514 0.515 0.516 0.517 0.518 0.519 0.52 0.521 0.522 0.523 0.524 0.525 0.526 0.527 0.528 0.529 0.53 0.531 0.532 0.533 0.534 0.535 0.536 0.537 0.538 0.539 0.54 0.541 0.542 0.543 0.544 0.545 0.546 0.547 0.548 0.549 0.55 0.551 0.552 0.553 0.554 0.555 0.556 0.557 0.558 0.559 0.56 0.561 0.562 0.5630000000000001 0.5640000000000001 0.5650000000000001 0.5660000000000001 0.5670000000000001 0.5680000000000001 0.5690000000000001 0.5700000000000001 0.5710000000000001 0.5720000000000001 0.5730000000000001 0.5740000000000001 0.5750000000000001 0.5760000000000001 0.577 0.578 0.579 0.58 0.581 0.582 0.583 0.584 0.585 0.586 0.587 0.588 0.589 0.59 0.591 0.592 0.593 0.594 0.595 0.596 0.597 0.598 0.599 0.6 0.601 0.602 0.603 0.604 0.605 0.606 0.607 0.608 0.609 0.61 0.611 0.612 0.613 0.614 0.615 0.616 0.617 0.618 0.619 0.62 0.621 0.622 0.623 0.624 0.625 0.626 0.627 0.628 0.629 0.63 0.631 0.632 0.633 0.634 0.635 0.636 0.637 0.638 0.639 0.64 0.641 0.642 0.643 0.644 0.645 0.646 0.647 0.648 0.649 0.65 0.651 0.652 0.653 0.654 0.655 0.656 0.657 0.658 0.659 0.66 0.661 0.662 0.663 0.664 0.665 0.666 0.667 0.668 0.669 0.67 0.671 0.672 0.673 0.674 0.675 0.676 0.677 0.678 0.679 0.68 0.681 0.682 0.683 0.684 0.685 0.686 0.687 0.6880000000000001 0.6890000000000001 0.6900000000000001 0.6910000000000001 0.6920000000000001 0.6930000000000001 0.6940000000000001 0.6950000000000001 0.6960000000000001 0.6970000000000001 0.6980000000000001 0.6990000000000001 0.7000000000000001 0.7010000000000001 0.7020000000000001 0.7030000000000001 0.704 0.705 0.706 0.707 0.708 0.709 0.71 0.711 0.712 0.713 0.714 0.715 0.716 0.717
</pre>
end{sphinxVerbatim}
- more-to-come:
0.718 0.719 0.72 0.721 0.722 0.723 0.724 0.725 0.726 0.727 0.728 0.729 0.73 0.731 0.732 0.733 0.734 0.735 0.736 0.737 0.738 0.739 0.74 0.741 0.742 0.743 0.744 0.745 0.746 0.747 0.748 0.749 0.75 0.751 0.752 0.753 0.754 0.755 0.756 0.757 0.758 0.759 0.76 0.761 0.762 0.763 0.764 0.765 0.766 0.767 0.768 0.769 0.77 0.771 0.772 0.773 0.774 0.775 0.776 0.777 0.778 0.779 0.78 0.781 0.782 0.783 0.784 0.785 0.786 0.787 0.788 0.789 0.79 0.791 0.792 0.793 0.794 0.795 0.796 0.797 0.798 0.799 0.8 0.801 0.802 0.803 0.804 0.805 0.806 0.807 0.808 0.809 0.81 0.811 0.812 0.8130000000000001 0.8140000000000001 0.8150000000000001 0.8160000000000001 0.8170000000000001 0.8180000000000001 0.8190000000000001 0.8200000000000001 0.8210000000000001 0.8220000000000001 0.8230000000000001 0.8240000000000001 0.8250000000000001 0.8260000000000001 0.8270000000000001 0.8280000000000001 0.8290000000000001 0.8300000000000001 0.8310000000000001 0.8320000000000001 0.833 0.834 0.835 0.836 0.837 0.838 0.839 0.84 0.841 0.842 0.843 0.844 0.845 0.846 0.847 0.848 0.849 0.85 0.851 0.852 0.853 0.854 0.855 0.856 0.857 0.858 0.859 0.86 0.861 0.862 0.863 0.864 0.865 0.866 0.867 0.868 0.869 0.87 0.871 0.872 0.873 0.874 0.875 0.876 0.877 0.878 0.879 0.88 0.881 0.882 0.883 0.884 0.885 0.886 0.887 0.888 0.889 0.89 0.891 0.892 0.893 0.894 0.895 0.896 0.897 0.898 0.899 0.9 0.901 0.902 0.903 0.904 0.905 0.906 0.907 0.908 0.909 0.91 0.911 0.912 0.913 0.914 0.915 0.916 0.917 0.918 0.919 0.92 0.921 0.922 0.923 0.924 0.925 0.926 0.927 0.928 0.929 0.93 0.931 0.932 0.933 0.934 0.935 0.936 0.937 0.9380000000000001 0.9390000000000001 0.9400000000000001 0.9410000000000001 0.9420000000000001 0.9430000000000001 0.9440000000000001 0.9450000000000001 0.9460000000000001 0.9470000000000001 0.9480000000000001 0.9490000000000001 0.9500000000000001 0.9510000000000001 0.9520000000000001 0.9530000000000001 0.9540000000000001 0.9550000000000001 0.9560000000000001 0.9570000000000001 0.9580000000000001 0.9590000000000001 0.96 0.961 0.962 0.963 0.964 0.965 0.966 0.967 0.968 0.969 0.97 0.971 0.972 0.973 0.974 0.975 0.976 0.977 0.978 0.979 0.98 0.981 0.982 0.983 0.984 0.985 0.986 0.987 0.988 0.989 0.99 0.991 0.992 0.993 0.994 0.995 0.996 0.997 0.998 0.999 1.0 1.0010000000000001 1.002 1.0030000000000001 1.004 1.0050000000000001 1.006 1.0070000000000001 1.008 1.0090000000000001 1.01
</pre>
end{sphinxVerbatim}
- more-to-come:
1.0110000000000001 1.012 1.0130000000000001 1.014 1.0150000000000001 1.016 1.0170000000000001 1.018 1.0190000000000001 1.02 1.0210000000000001 1.022 1.0230000000000001 1.024 1.025 1.026 1.027 1.028 1.029 1.03 1.031 1.032 1.033 1.034 1.035 1.036 1.037 1.038 1.039 1.04 1.041 1.042 1.043 1.044 1.045 1.046 1.047 1.048 1.049 1.05 1.051 1.052 1.053 1.054 1.055 1.056 1.057 1.058 1.059 1.06 1.061 1.062 1.063 1.064 1.065 1.066 1.067 1.068 1.069 1.07 1.071 1.072 1.073 1.074 1.075 1.076 1.077 1.078 1.079 1.08 1.081 1.082 1.083 1.084 1.085 1.086 1.087 1.088 1.089 1.09 1.091 1.092 1.093 1.094 1.095 1.096 1.097 1.098 1.099 1.1 1.101 1.102 1.103 1.104 1.105 1.106 1.107 1.108 1.109 1.11 1.111 1.112 1.113 1.114 1.115 1.116 1.117 1.118 1.119 1.12 1.121 1.122 1.123 1.124 1.125 1.1260000000000001 1.127 1.1280000000000001 1.129 1.1300000000000001 1.131 1.1320000000000001 1.133 1.1340000000000001 1.135 1.1360000000000001 1.137 1.1380000000000001 1.139 1.1400000000000001 1.141 1.1420000000000001 1.143 1.1440000000000001 1.145 1.1460000000000001 1.147 1.1480000000000001 1.149 1.1500000000000001 1.151 1.1520000000000001 1.153 1.154 1.155 1.156 1.157 1.158 1.159 1.16 1.161 1.162 1.163 1.164 1.165 1.166 1.167 1.168 1.169 1.17 1.171 1.172 1.173 1.174 1.175 1.176 1.177 1.178 1.179 1.18 1.181 1.182 1.183 1.184 1.185 1.186 1.187 1.188 1.189 1.19 1.191 1.192 1.193 1.194 1.195 1.196 1.197 1.198 1.199 1.2 1.201 1.202 1.203 1.204 1.205 1.206 1.207 1.208 1.209 1.21 1.211 1.212 1.213 1.214 1.215 1.216 1.217 1.218 1.219 1.22 1.221 1.222 1.223 1.224 1.225 1.226 1.227 1.228 1.229 1.23 1.231 1.232 1.233 1.234 1.235 1.236 1.237 1.238 1.239 1.24 1.241 1.242 1.243 1.244 1.245 1.246 1.247 1.248 1.249 1.25 1.2510000000000001 1.252 1.2530000000000001 1.254 1.2550000000000001 1.256 1.2570000000000001 1.258 1.2590000000000001 1.26 1.2610000000000001 1.262 1.2630000000000001 1.264 1.2650000000000001 1.266 1.2670000000000001 1.268 1.2690000000000001 1.27 1.2710000000000001 1.272 1.2730000000000001 1.274 1.2750000000000001 1.276 1.2770000000000001 1.278 1.2790000000000001 1.28 1.281 1.282 1.283 1.284 1.285 1.286 1.287 1.288 1.289 1.29 1.291 1.292 1.293 1.294 1.295 1.296 1.297 1.298 1.299 1.3 1.301 1.302 1.303
</pre>
end{sphinxVerbatim}
- more-to-come:
1.304 1.305 1.306 1.307 1.308 1.309 1.31 1.311 1.312 1.313 1.314 1.315 1.316 1.317 1.318 1.319 1.32 1.321 1.322 1.323 1.324 1.325 1.326 1.327 1.328 1.329 1.33 1.331 1.332 1.333 1.334 1.335 1.336 1.337 1.338 1.339 1.34 1.341 1.342 1.343 1.344 1.345 1.346 1.347 1.348 1.349 1.35 1.351 1.352 1.353 1.354 1.355 1.356 1.357 1.358 1.359 1.36 1.361 1.362 1.363 1.364 1.365 1.366 1.367 1.368 1.369 1.37 1.371 1.372 1.373 1.374 1.375 1.3760000000000001 1.377 1.3780000000000001 1.379 1.3800000000000001 1.381 1.3820000000000001 1.383 1.3840000000000001 1.385 1.3860000000000001 1.387 1.3880000000000001 1.389 1.3900000000000001 1.391 1.3920000000000001 1.393 1.3940000000000001 1.395 1.3960000000000001 1.397 1.3980000000000001 1.399 1.4000000000000001 1.401 1.4020000000000001 1.403 1.4040000000000001 1.405 1.4060000000000001 1.407 1.408 1.409 1.41 1.411 1.412 1.413 1.414 1.415 1.416 1.417 1.418 1.419 1.42 1.421 1.422 1.423 1.424 1.425 1.426 1.427 1.428 1.429 1.43 1.431 1.432 1.433 1.434 1.435 1.436 1.437 1.438 1.439 1.44 1.441 1.442 1.443 1.444 1.445 1.446 1.447 1.448 1.449 1.45 1.451 1.452 1.453 1.454 1.455 1.456 1.457 1.458 1.459 1.46 1.461 1.462 1.463 1.464 1.465 1.466 1.467 1.468 1.469 1.47 1.471 1.472 1.473 1.474 1.475 1.476 1.477 1.478 1.479 1.48 1.481 1.482 1.483 1.484 1.485 1.486 1.487 1.488 1.489 1.49 1.491 1.492 1.493 1.494 1.495 1.496 1.497 1.498 1.499 1.5 1.5010000000000001 1.502 1.5030000000000001 1.504 1.5050000000000001 1.506 1.5070000000000001 1.508 1.5090000000000001 1.51 1.5110000000000001 1.512 1.5130000000000001 1.514 1.5150000000000001 1.516 1.5170000000000001 1.518 1.5190000000000001 1.52 1.5210000000000001 1.522 1.5230000000000001 1.524 1.5250000000000001 1.526 1.5270000000000001 1.528 1.5290000000000001 1.53 1.5310000000000001 1.532 1.5330000000000001 1.534 1.5350000000000001 1.536 1.537 1.538 1.539 1.54 1.541 1.542 1.543 1.544 1.545 1.546 1.547 1.548 1.549 1.55 1.551 1.552 1.553 1.554 1.555 1.556 1.557 1.558 1.559 1.56 1.561 1.562 1.563 1.564 1.565 1.566 1.567 1.568 1.569 1.57 1.571 1.572 1.573 1.574 1.575 1.576 1.577 1.578 1.579 1.58 1.581 1.582 1.583 1.584 1.585 1.586 1.587 1.588 1.589 1.59 1.591 1.592 1.593 1.594 1.595
</pre>
end{sphinxVerbatim}
- more-to-come:
1.596 1.597 1.598 1.599 1.6 1.601 1.602 1.603 1.604 1.605 1.606 1.607 1.608 1.609 1.61 1.611 1.612 1.613 1.614 1.615 1.616 1.617 1.618 1.619 1.62 1.621 1.622 1.623 1.624 1.625 1.6260000000000001 1.627 1.6280000000000001 1.629 1.6300000000000001 1.631 1.6320000000000001 1.633 1.6340000000000001 1.635 1.6360000000000001 1.637 1.6380000000000001 1.639 1.6400000000000001 1.641 1.6420000000000001 1.643 1.6440000000000001 1.645 1.6460000000000001 1.647 1.6480000000000001 1.649 1.6500000000000001 1.651 1.6520000000000001 1.653 1.6540000000000001 1.655 1.6560000000000001 1.657 1.6580000000000001 1.659 1.6600000000000001 1.661 1.6620000000000001 1.663 1.6640000000000001 1.665 1.666 1.667 1.668 1.669 1.67 1.671 1.672 1.673 1.674 1.675 1.676 1.677 1.678 1.679 1.68 1.681 1.682 1.683 1.684 1.685 1.686 1.687 1.688 1.689 1.69 1.691 1.692 1.693 1.694 1.695 1.696 1.697 1.698 1.699 1.7 1.701 1.702 1.703 1.704 1.705 1.706 1.707 1.708 1.709 1.71 1.711 1.712 1.713 1.714 1.715 1.716 1.717 1.718 1.719 1.72 1.721 1.722 1.723 1.724 1.725 1.726 1.727 1.728 1.729 1.73 1.731 1.732 1.733 1.734 1.735 1.736 1.737 1.738 1.739 1.74 1.741 1.742 1.743 1.744 1.745 1.746 1.747 1.748 1.749 1.75 1.7510000000000001 1.752 1.7530000000000001 1.754 1.7550000000000001 1.756 1.7570000000000001 1.758 1.7590000000000001 1.76 1.7610000000000001 1.762 1.7630000000000001 1.764 1.7650000000000001 1.766 1.7670000000000001 1.768 1.7690000000000001 1.77 1.7710000000000001 1.772 1.7730000000000001 1.774 1.7750000000000001 1.776 1.7770000000000001 1.778 1.7790000000000001 1.78 1.7810000000000001 1.782 1.7830000000000001 1.784 1.7850000000000001 1.786 1.7870000000000001 1.788 1.7890000000000001 1.79 1.7910000000000001 1.792 1.793 1.794 1.795 1.796 1.797 1.798 1.799 1.8 1.801 1.802 1.803 1.804 1.805 1.806 1.807 1.808 1.809 1.81 1.811 1.812 1.813 1.814 1.815 1.816 1.817 1.818 1.819 1.82 1.821 1.822 1.823 1.824 1.825 1.826 1.827 1.828 1.829 1.83 1.831 1.832 1.833 1.834 1.835 1.836 1.837 1.838 1.839 1.84 1.841 1.842 1.843 1.844 1.845 1.846 1.847 1.848 1.849 1.85 1.851 1.852 1.853 1.854 1.855 1.856 1.857 1.858 1.859 1.86 1.861 1.862 1.863 1.864 1.865 1.866 1.867 1.868 1.869 1.87 1.871 1.872 1.873 1.874 1.875 1.8760000000000001 1.877 1.8780000000000001 1.879 1.8800000000000001 1.881 1.8820000000000001 1.883 1.8840000000000001 1.885 1.8860000000000001 1.887
</pre>
end{sphinxVerbatim}
- more-to-come:
1.8880000000000001 1.889 1.8900000000000001 1.891 1.8920000000000001 1.893 1.8940000000000001 1.895 1.8960000000000001 1.897 1.8980000000000001 1.899 1.9000000000000001 1.901 1.9020000000000001 1.903 1.9040000000000001 1.905 1.9060000000000001 1.907 1.9080000000000001 1.909 1.9100000000000001 1.911 1.9120000000000001 1.913 1.9140000000000001 1.915 1.9160000000000001 1.917 1.9180000000000001 1.919 1.92 1.921 1.922 1.923 1.924 1.925 1.926 1.927 1.928 1.929 1.93 1.931 1.932 1.933 1.934 1.935 1.936 1.937 1.938 1.939 1.94 1.941 1.942 1.943 1.944 1.945 1.946 1.947 1.948 1.949 1.95 1.951 1.952 1.953 1.954 1.955 1.956 1.957 1.958 1.959 1.96 1.961 1.962 1.963 1.964 1.965 1.966 1.967 1.968 1.969 1.97 1.971 1.972 1.973 1.974 1.975 1.976 1.977 1.978 1.979 1.98 1.981 1.982 1.983 1.984 1.985 1.986 1.987 1.988 1.989 1.99 1.991 1.992 1.993 1.994 1.995 1.996 1.997 1.998 1.999
</pre>
end{sphinxVerbatim}
CPU times: user 1.58 s, sys: 9.15 ms, total: 1.59 s
Wall time: 5.36 s
time = 0.0
t.Set(0.0)
gfu.Set(uD,BND)
nsamples = 10):
if initial_cond:
cnt = 0; time = t0
t.Set(time)
gfuD.Set(uD,BND)
return gfut
%%time
- more-to-come:
0 0.001 0.002 0.003 0.004 0.005 0.006 0.007 0.008 0.009000000000000001 0.01 0.011 0.012 0.013000000000000001 0.014 0.015 0.016 0.017 0.018000000000000002 0.019 0.02 0.021 0.022 0.023 0.024 0.025 0.026000000000000002 0.027 0.028 0.029 0.03 0.031 0.032 0.033 0.034 0.035 0.036000000000000004 0.037 0.038 0.039 0.04 0.041 0.042 0.043000000000000003 0.044 0.045 0.046 0.047 0.048 0.049 0.05 0.051000000000000004 0.052000000000000005 0.053 0.054 0.055 0.056 0.057 0.058 0.059000000000000004 0.06 0.061 0.062 0.063 0.064 0.065 0.066 0.067 0.068 0.069 0.07 0.07100000000000001 0.07200000000000001 0.073 0.074 0.075 0.076 0.077 0.078 0.079 0.08 0.081 0.082 0.083 0.084 0.085 0.08600000000000001 0.08700000000000001 0.088 0.089 0.09 0.091 0.092 0.093 0.094 0.095 0.096 0.097 0.098 0.099 0.1 0.101 0.10200000000000001 0.10300000000000001 0.10400000000000001 0.105 0.106 0.107 0.108 0.109 0.11 0.111 0.112 0.113 0.114 0.115 0.116 0.117 0.11800000000000001 0.11900000000000001 0.12 0.121 0.122 0.123 0.124 0.125 0.126 0.127 0.128 0.129 0.13 0.131 0.132 0.133 0.134 0.135 0.136 0.137 0.138 0.139 0.14 0.14100000000000001 0.14200000000000002 0.14300000000000002 0.14400000000000002 0.145 0.146 0.147 0.148 0.149 0.15 0.151 0.152 0.153 0.154 0.155 0.156 0.157 0.158 0.159 0.16 0.161 0.162 0.163 0.164 0.165 0.166 0.167 0.168 0.169 0.17 0.171 0.17200000000000001 0.17300000000000001 0.17400000000000002 0.17500000000000002 0.176 0.177 0.178 0.179 0.18 0.181 0.182 0.183 0.184 0.185 0.186 0.187 0.188 0.189 0.19 0.191 0.192 0.193 0.194 0.195 0.196 0.197 0.198 0.199 0.2 0.201 0.202 0.203 0.20400000000000001 0.20500000000000002 0.20600000000000002 0.20700000000000002 0.20800000000000002 0.209 0.21 0.211 0.212 0.213 0.214 0.215 0.216 0.217 0.218 0.219 0.22 0.221 0.222 0.223 0.224 0.225 0.226 0.227 0.228 0.229 0.23 0.231 0.232 0.233 0.234 0.23500000000000001 0.23600000000000002 0.23700000000000002 0.23800000000000002 0.23900000000000002 0.24 0.241 0.242 0.243 0.244 0.245 0.246 0.247 0.248 0.249 0.25 0.251 0.252 0.253 0.254 0.255 0.256 0.257 0.258 0.259 0.26 0.261 0.262 0.263 0.264 0.265 0.266 0.267 0.268 0.269 0.27 0.271 0.272 0.273 0.274 0.275 0.276 0.277 0.278 0.279 0.28 0.281 0.28200000000000003 0.28300000000000003 0.28400000000000003 0.28500000000000003 0.28600000000000003 0.28700000000000003 0.28800000000000003 0.289 0.29 0.291 0.292 0.293 0.294 0.295 0.296 0.297 0.298 0.299 0.3 0.301 0.302 0.303 0.304 0.305 0.306 0.307 0.308 0.309 0.31 0.311 0.312 0.313 0.314 0.315
</pre>
end{sphinxVerbatim}
- more-to-come:
</pre>
end{sphinxVerbatim}
- more-to-come:
0.435 0.436 0.437 0.438 0.439 0.44 0.441 0.442 0.443 0.444 0.445 0.446 0.447 0.448 0.449 0.45 0.451 0.452 0.453 0.454 0.455 0.456 0.457 0.458 0.459 0.46 0.461 0.462 0.463 0.464 0.465 0.466 0.467 0.468 0.46900000000000003 0.47000000000000003 0.47100000000000003 0.47200000000000003 0.47300000000000003 0.47400000000000003 0.47500000000000003 0.47600000000000003 0.47700000000000004 0.47800000000000004 0.47900000000000004 0.48 0.481 0.482 0.483 0.484 0.485 0.486 0.487 0.488 0.489 0.49 0.491 0.492 0.493 0.494 0.495 0.496 0.497 0.498 0.499 0.5 0.501 0.502 0.503 0.504 0.505 0.506 0.507 0.508 0.509 0.51 0.511 0.512 0.513 0.514 0.515 0.516 0.517 0.518 0.519 0.52 0.521 0.522 0.523 0.524 0.525 0.526 0.527 0.528 0.529 0.53 0.531 0.532 0.533 0.534 0.535 0.536 0.537 0.538 0.539 0.54 0.541 0.542 0.543 0.544 0.545 0.546 0.547 0.548 0.549 0.55 0.551 0.552 0.553 0.554 0.555 0.556 0.557 0.558 0.559 0.56 0.561 0.562 0.5630000000000001 0.5640000000000001 0.5650000000000001 0.5660000000000001 0.5670000000000001 0.5680000000000001 0.5690000000000001 0.5700000000000001 0.5710000000000001 0.5720000000000001 0.5730000000000001 0.5740000000000001 0.5750000000000001 0.5760000000000001 0.577 0.578 0.579 0.58 0.581 0.582 0.583 0.584 0.585 0.586 0.587 0.588 0.589 0.59 0.591 0.592 0.593 0.594 0.595 0.596 0.597 0.598 0.599 0.6 0.601 0.602 0.603 0.604 0.605 0.606 0.607 0.608 0.609 0.61 0.611 0.612 0.613 0.614 0.615 0.616 0.617 0.618 0.619 0.62 0.621 0.622 0.623 0.624 0.625 0.626 0.627 0.628 0.629 0.63 0.631 0.632 0.633 0.634 0.635 0.636 0.637 0.638 0.639 0.64 0.641 0.642 0.643 0.644 0.645 0.646 0.647 0.648 0.649 0.65 0.651 0.652 0.653 0.654 0.655 0.656 0.657 0.658 0.659 0.66 0.661 0.662 0.663 0.664 0.665 0.666 0.667 0.668 0.669 0.67 0.671 0.672 0.673 0.674 0.675 0.676 0.677 0.678 0.679 0.68 0.681 0.682 0.683 0.684 0.685 0.686 0.687 0.6880000000000001 0.6890000000000001 0.6900000000000001 0.6910000000000001 0.6920000000000001 0.6930000000000001 0.6940000000000001 0.6950000000000001 0.6960000000000001 0.6970000000000001 0.6980000000000001 0.6990000000000001 0.7000000000000001 0.7010000000000001 0.7020000000000001 0.7030000000000001 0.704 0.705 0.706 0.707 0.708 0.709 0.71 0.711 0.712 0.713 0.714 0.715 0.716 0.717 0.718 0.719 0.72 0.721 0.722 0.723 0.724 0.725 0.726 0.727 0.728 0.729 0.73 0.731 0.732 0.733 0.734 0.735 0.736 0.737 0.738 0.739 0.74 0.741 0.742 0.743 0.744 0.745 0.746 0.747
</pre>
end{sphinxVerbatim}
- more-to-come:
</pre>
end{sphinxVerbatim}
- more-to-come:
0.867 0.868 0.869 0.87 0.871 0.872 0.873 0.874 0.875 0.876 0.877 0.878 0.879 0.88 0.881 0.882 0.883 0.884 0.885 0.886 0.887 0.888 0.889 0.89 0.891 0.892 0.893 0.894 0.895 0.896 0.897 0.898 0.899 0.9 0.901 0.902 0.903 0.904 0.905 0.906 0.907 0.908 0.909 0.91 0.911 0.912 0.913 0.914 0.915 0.916 0.917 0.918 0.919 0.92 0.921 0.922 0.923 0.924 0.925 0.926 0.927 0.928 0.929 0.93 0.931 0.932 0.933 0.934 0.935 0.936 0.937 0.9380000000000001 0.9390000000000001 0.9400000000000001 0.9410000000000001 0.9420000000000001 0.9430000000000001 0.9440000000000001 0.9450000000000001 0.9460000000000001 0.9470000000000001 0.9480000000000001 0.9490000000000001 0.9500000000000001 0.9510000000000001 0.9520000000000001 0.9530000000000001 0.9540000000000001 0.9550000000000001 0.9560000000000001 0.9570000000000001 0.9580000000000001 0.9590000000000001 0.96 0.961 0.962 0.963 0.964 0.965 0.966 0.967 0.968 0.969 0.97 0.971 0.972 0.973 0.974 0.975 0.976 0.977 0.978 0.979 0.98 0.981 0.982 0.983 0.984 0.985 0.986 0.987 0.988 0.989 0.99 0.991 0.992 0.993 0.994 0.995 0.996 0.997 0.998 0.999 1.0 1.0010000000000001 1.002 1.0030000000000001 1.004 1.0050000000000001 1.006 1.0070000000000001 1.008 1.0090000000000001 1.01 1.0110000000000001 1.012 1.0130000000000001 1.014 1.0150000000000001 1.016 1.0170000000000001 1.018 1.0190000000000001 1.02 1.0210000000000001 1.022 1.0230000000000001 1.024 1.025 1.026 1.027 1.028 1.029 1.03 1.031 1.032 1.033 1.034 1.035 1.036 1.037 1.038 1.039 1.04 1.041 1.042 1.043 1.044 1.045 1.046 1.047 1.048 1.049 1.05 1.051 1.052 1.053 1.054 1.055 1.056 1.057 1.058 1.059 1.06 1.061 1.062 1.063 1.064 1.065 1.066 1.067 1.068 1.069 1.07 1.071 1.072 1.073 1.074 1.075 1.076 1.077 1.078 1.079 1.08 1.081 1.082 1.083 1.084 1.085 1.086 1.087 1.088 1.089 1.09 1.091 1.092 1.093 1.094 1.095 1.096 1.097 1.098 1.099 1.1 1.101 1.102 1.103 1.104 1.105 1.106 1.107 1.108 1.109 1.11 1.111 1.112 1.113 1.114 1.115 1.116 1.117 1.118 1.119 1.12 1.121 1.122 1.123 1.124 1.125 1.1260000000000001 1.127 1.1280000000000001 1.129 1.1300000000000001 1.131 1.1320000000000001 1.133 1.1340000000000001 1.135 1.1360000000000001 1.137 1.1380000000000001 1.139 1.1400000000000001 1.141 1.1420000000000001 1.143 1.1440000000000001 1.145 1.1460000000000001 1.147 1.1480000000000001 1.149 1.1500000000000001 1.151 1.1520000000000001 1.153 1.154 1.155 1.156 1.157 1.158 1.159 1.16 1.161 1.162 1.163 1.164 1.165 1.166 1.167 1.168 1.169 1.17 1.171 1.172 1.173 1.174 1.175 1.176 1.177
</pre>
end{sphinxVerbatim}
- more-to-come:
</pre>
end{sphinxVerbatim}
- more-to-come:
1.297 1.298 1.299 1.3 1.301 1.302 1.303 1.304 1.305 1.306 1.307 1.308 1.309 1.31 1.311 1.312 1.313 1.314 1.315 1.316 1.317 1.318 1.319 1.32 1.321 1.322 1.323 1.324 1.325 1.326 1.327 1.328 1.329 1.33 1.331 1.332 1.333 1.334 1.335 1.336 1.337 1.338 1.339 1.34 1.341 1.342 1.343 1.344 1.345 1.346 1.347 1.348 1.349 1.35 1.351 1.352 1.353 1.354 1.355 1.356 1.357 1.358 1.359 1.36 1.361 1.362 1.363 1.364 1.365 1.366 1.367 1.368 1.369 1.37 1.371 1.372 1.373 1.374 1.375 1.3760000000000001 1.377 1.3780000000000001 1.379 1.3800000000000001 1.381 1.3820000000000001 1.383 1.3840000000000001 1.385 1.3860000000000001 1.387 1.3880000000000001 1.389 1.3900000000000001 1.391 1.3920000000000001 1.393 1.3940000000000001 1.395 1.3960000000000001 1.397 1.3980000000000001 1.399 1.4000000000000001 1.401 1.4020000000000001 1.403 1.4040000000000001 1.405 1.4060000000000001 1.407 1.408 1.409 1.41 1.411 1.412 1.413 1.414 1.415 1.416 1.417 1.418 1.419 1.42 1.421 1.422 1.423 1.424 1.425 1.426 1.427 1.428 1.429 1.43 1.431 1.432 1.433 1.434 1.435 1.436 1.437 1.438 1.439 1.44 1.441 1.442 1.443 1.444 1.445 1.446 1.447 1.448 1.449 1.45 1.451 1.452 1.453 1.454 1.455 1.456 1.457 1.458 1.459 1.46 1.461 1.462 1.463 1.464 1.465 1.466 1.467 1.468 1.469 1.47 1.471 1.472 1.473 1.474 1.475 1.476 1.477 1.478 1.479 1.48 1.481 1.482 1.483 1.484 1.485 1.486 1.487 1.488 1.489 1.49 1.491 1.492 1.493 1.494 1.495 1.496 1.497 1.498 1.499 1.5 1.5010000000000001 1.502 1.5030000000000001 1.504 1.5050000000000001 1.506 1.5070000000000001 1.508 1.5090000000000001 1.51 1.5110000000000001 1.512 1.5130000000000001 1.514 1.5150000000000001 1.516 1.5170000000000001 1.518 1.5190000000000001 1.52 1.5210000000000001 1.522 1.5230000000000001 1.524 1.5250000000000001 1.526 1.5270000000000001 1.528 1.5290000000000001 1.53 1.5310000000000001 1.532 1.5330000000000001 1.534 1.5350000000000001 1.536 1.537 1.538 1.539 1.54 1.541 1.542 1.543 1.544 1.545 1.546 1.547 1.548 1.549 1.55 1.551 1.552 1.553 1.554 1.555 1.556 1.557 1.558 1.559 1.56 1.561 1.562 1.563 1.564 1.565 1.566 1.567 1.568 1.569 1.57 1.571 1.572 1.573 1.574 1.575 1.576 1.577 1.578 1.579 1.58 1.581 1.582 1.583 1.584 1.585 1.586 1.587 1.588 1.589 1.59 1.591 1.592 1.593 1.594 1.595 1.596 1.597 1.598 1.599 1.6 1.601 1.602 1.603 1.604 1.605 1.606 1.607 1.608 1.609 1.61 1.611 1.612 1.613 1.614 1.615
</pre>
end{sphinxVerbatim}
- more-to-come:
</pre>
end{sphinxVerbatim}
- more-to-come:
1.733 1.734 1.735 1.736 1.737 1.738 1.739 1.74 1.741 1.742 1.743 1.744 1.745 1.746 1.747 1.748 1.749 1.75 1.7510000000000001 1.752 1.7530000000000001 1.754 1.7550000000000001 1.756 1.7570000000000001 1.758 1.7590000000000001 1.76 1.7610000000000001 1.762 1.7630000000000001 1.764 1.7650000000000001 1.766 1.7670000000000001 1.768 1.7690000000000001 1.77 1.7710000000000001 1.772 1.7730000000000001 1.774 1.7750000000000001 1.776 1.7770000000000001 1.778 1.7790000000000001 1.78 1.7810000000000001 1.782 1.7830000000000001 1.784 1.7850000000000001 1.786 1.7870000000000001 1.788 1.7890000000000001 1.79 1.7910000000000001 1.792 1.793 1.794 1.795 1.796 1.797 1.798 1.799 1.8 1.801 1.802 1.803 1.804 1.805 1.806 1.807 1.808 1.809 1.81 1.811 1.812 1.813 1.814 1.815 1.816 1.817 1.818 1.819 1.82 1.821 1.822 1.823 1.824 1.825 1.826 1.827 1.828 1.829 1.83 1.831 1.832 1.833 1.834 1.835 1.836 1.837 1.838 1.839 1.84 1.841 1.842 1.843 1.844 1.845 1.846 1.847 1.848 1.849 1.85 1.851 1.852 1.853 1.854 1.855 1.856 1.857 1.858 1.859 1.86 1.861 1.862 1.863 1.864 1.865 1.866 1.867 1.868 1.869 1.87 1.871 1.872 1.873 1.874 1.875 1.8760000000000001 1.877 1.8780000000000001 1.879 1.8800000000000001 1.881 1.8820000000000001 1.883 1.8840000000000001 1.885 1.8860000000000001 1.887 1.8880000000000001 1.889 1.8900000000000001 1.891 1.8920000000000001 1.893 1.8940000000000001 1.895 1.8960000000000001 1.897 1.8980000000000001 1.899 1.9000000000000001 1.901 1.9020000000000001 1.903 1.9040000000000001 1.905 1.9060000000000001 1.907 1.9080000000000001 1.909 1.9100000000000001 1.911 1.9120000000000001 1.913 1.9140000000000001 1.915 1.9160000000000001 1.917 1.9180000000000001 1.919 1.92 1.921 1.922 1.923 1.924 1.925 1.926 1.927 1.928 1.929 1.93 1.931 1.932 1.933 1.934 1.935 1.936 1.937 1.938 1.939 1.94 1.941 1.942 1.943 1.944 1.945 1.946 1.947 1.948 1.949 1.95 1.951 1.952 1.953 1.954 1.955 1.956 1.957 1.958 1.959 1.96 1.961 1.962 1.963 1.964 1.965 1.966 1.967 1.968 1.969 1.97 1.971 1.972 1.973 1.974 1.975 1.976 1.977 1.978 1.979 1.98 1.981 1.982 1.983 1.984 1.985 1.986 1.987 1.988 1.989 1.99 1.991 1.992 1.993 1.994 1.995 1.996 1.997 1.998 1.999 2.0 2.001 2.0020000000000002 2.003 2.004 2.005 2.0060000000000002 2.007 2.008 2.009 2.0100000000000002 2.011 2.012 2.013 2.0140000000000002 2.015 2.016 2.017 2.0180000000000002 2.019 2.02 2.021 2.0220000000000002 2.023 2.024 2.025 2.0260000000000002 2.027 2.028 2.029 2.0300000000000002 2.031 2.032 2.033 2.0340000000000003 2.035 2.036 2.037 2.0380000000000003 2.039 2.04 2.041 2.0420000000000003 2.043 2.044 2.045 2.0460000000000003 2.047 2.048 2.049 2.05 2.051 2.052 2.053
</pre>
end{sphinxVerbatim}
- more-to-come:
2.054 2.055 2.056 2.057 2.058 2.059 2.06 2.061 2.062 2.063 2.064 2.065 2.066 2.067 2.068 2.069 2.07 2.071 2.072 2.073 2.074 2.075 2.076 2.077 2.078 2.079 2.08 2.081 2.082 2.083 2.084 2.085 2.086 2.087 2.088 2.089 2.09 2.091 2.092 2.093 2.094 2.095 2.096 2.097 2.098 2.099 2.1 2.101 2.102 2.103 2.104 2.105 2.106 2.107 2.108 2.109 2.11 2.111 2.112 2.113 2.114 2.115 2.116 2.117 2.118 2.119 2.12 2.121 2.122 2.123 2.124 2.125 2.126 2.1270000000000002 2.128 2.129 2.13 2.1310000000000002 2.132 2.133 2.134 2.1350000000000002 2.136 2.137 2.138 2.1390000000000002 2.14 2.141 2.142 2.1430000000000002 2.144 2.145 2.146 2.1470000000000002 2.148 2.149 2.15 2.1510000000000002 2.152 2.153 2.154 2.1550000000000002 2.156 2.157 2.158 2.1590000000000003 2.16 2.161 2.162 2.1630000000000003 2.164 2.165 2.166 2.1670000000000003 2.168 2.169 2.17 2.1710000000000003 2.172 2.173 2.174
</pre>
end{sphinxVerbatim}
- more-to-come:
2.1750000000000003 2.176 2.177 2.178 2.179 2.18 2.181 2.182 2.183 2.184 2.185 2.186 2.187 2.188 2.189 2.19 2.191 2.192 2.193 2.194 2.195 2.196 2.197 2.198 2.199 2.2 2.201 2.202 2.203 2.204 2.205 2.206 2.207 2.208 2.209 2.21 2.211 2.212 2.213 2.214 2.215 2.216 2.217 2.218 2.219 2.22 2.221 2.222 2.223 2.224 2.225 2.226 2.227 2.228 2.229 2.23 2.231 2.232 2.233 2.234 2.235 2.236 2.237 2.238 2.239 2.24 2.241 2.242 2.243 2.244 2.245 2.246 2.247 2.248 2.249 2.25 2.251 2.2520000000000002 2.253 2.254 2.255 2.2560000000000002 2.257 2.258 2.259 2.2600000000000002 2.261 2.262 2.263 2.2640000000000002 2.265 2.266 2.267 2.2680000000000002 2.269 2.27 2.271 2.2720000000000002 2.273 2.274 2.275 2.2760000000000002 2.277 2.278 2.279 2.2800000000000002 2.281 2.282 2.283 2.2840000000000003 2.285 2.286 2.287 2.2880000000000003 2.289 2.29 2.291 2.2920000000000003 2.293 2.294 2.295 2.2960000000000003 2.297 2.298 2.299 2.3000000000000003 2.301 2.302 2.303 2.3040000000000003 2.305 2.306 2.307 2.308 2.309 2.31 2.311 2.312 2.313 2.314 2.315 2.316 2.317 2.318 2.319 2.32 2.321 2.322 2.323 2.324 2.325 2.326 2.327 2.328 2.329 2.33 2.331 2.332 2.333 2.334 2.335 2.336 2.337 2.338 2.339 2.34 2.341 2.342 2.343 2.344 2.345 2.346 2.347 2.348 2.349 2.35 2.351 2.352 2.353 2.354 2.355 2.356 2.357 2.358 2.359 2.36 2.361 2.362 2.363 2.364 2.365 2.366 2.367 2.368 2.369 2.37 2.371 2.372 2.373 2.374 2.375 2.376 2.3770000000000002 2.378 2.379 2.38 2.3810000000000002 2.382 2.383 2.384 2.3850000000000002 2.386 2.387 2.388 2.3890000000000002 2.39 2.391 2.392 2.3930000000000002 2.394 2.395 2.396 2.3970000000000002 2.398 2.399 2.4 2.4010000000000002 2.402 2.403 2.404 2.4050000000000002 2.406 2.407 2.408 2.4090000000000003 2.41 2.411 2.412 2.4130000000000003 2.414 2.415 2.416 2.4170000000000003 2.418 2.419 2.42 2.4210000000000003 2.422 2.423 2.424 2.4250000000000003 2.426 2.427 2.428 2.4290000000000003 2.43 2.431 2.432 2.433 2.434 2.435 2.436 2.437 2.438 2.439 2.44 2.441 2.442 2.443 2.444 2.445 2.446 2.447 2.448 2.449 2.45 2.451 2.452 2.453 2.454 2.455 2.456 2.457 2.458 2.459 2.46 2.461 2.462 2.463 2.464 2.465 2.466 2.467 2.468 2.469 2.47 2.471 2.472 2.473 2.474 2.475 2.476 2.477 2.478 2.479 2.48 2.481 2.482 2.483 2.484 2.485 2.486 2.487 2.488 2.489 2.49 2.491 2.492 2.493 2.494 2.495 2.496 2.497 2.498 2.499 2.5 2.501 2.5020000000000002 2.503 2.504 2.505 2.5060000000000002 2.507 2.508 2.509 2.5100000000000002 2.511 2.512 2.513 2.5140000000000002 2.515 2.516 2.517 2.5180000000000002 2.519 2.52 2.521 2.5220000000000002 2.523 2.524 2.525 2.5260000000000002 2.527 2.528 2.529 2.5300000000000002 2.531 2.532 2.533 2.5340000000000003 2.535 2.536 2.537 2.5380000000000003 2.539 2.54 2.541 2.5420000000000003 2.543 2.544 2.545 2.5460000000000003 2.547 2.548 2.549 2.5500000000000003 2.551 2.552 2.553 2.5540000000000003 2.555 2.556 2.557 2.5580000000000003 2.559 2.56 2.561 2.562 2.563 2.564 2.565 2.566 2.567 2.568 2.569 2.57 2.571
</pre>
end{sphinxVerbatim}
- more-to-come:
2.572 2.573 2.574 2.575 2.576 2.577 2.578 2.579 2.58 2.581 2.582 2.583 2.584 2.585 2.586 2.587 2.588 2.589 2.59 2.591 2.592 2.593 2.594 2.595 2.596 2.597 2.598 2.599 2.6 2.601 2.602 2.603 2.604 2.605 2.606 2.607 2.608 2.609 2.61 2.611 2.612 2.613 2.614 2.615 2.616 2.617 2.618 2.619 2.62 2.621 2.622 2.623 2.624 2.625 2.626 2.6270000000000002 2.628 2.629 2.63 2.6310000000000002 2.632 2.633 2.634 2.6350000000000002 2.636 2.637 2.638 2.6390000000000002 2.64 2.641 2.642 2.6430000000000002 2.644 2.645 2.646 2.6470000000000002 2.648 2.649 2.65 2.6510000000000002 2.652 2.653 2.654 2.6550000000000002 2.656 2.657 2.658 2.6590000000000003 2.66 2.661 2.662 2.6630000000000003 2.664 2.665 2.666 2.6670000000000003 2.668 2.669 2.67 2.6710000000000003 2.672 2.673 2.674 2.6750000000000003 2.676 2.677 2.678 2.6790000000000003 2.68 2.681 2.682 2.6830000000000003 2.684 2.685 2.686 2.6870000000000003 2.688 2.689 2.69 2.691 2.692 2.693 2.694 2.695 2.696 2.697 2.698 2.699 2.7 2.701 2.702 2.703 2.704 2.705 2.706 2.707 2.708 2.709 2.71 2.711 2.712 2.713 2.714 2.715 2.716 2.717 2.718 2.719
</pre>
end{sphinxVerbatim}
- more-to-come:
2.72 2.721 2.722 2.723 2.724 2.725 2.726 2.727 2.728 2.729 2.73 2.731 2.732 2.733 2.734 2.735 2.736 2.737 2.738 2.739 2.74 2.741 2.742 2.743 2.744 2.745 2.746 2.747 2.748 2.749 2.75 2.751 2.7520000000000002 2.753 2.754 2.755 2.7560000000000002 2.757 2.758 2.759 2.7600000000000002 2.761 2.762 2.763 2.7640000000000002 2.765 2.766 2.767 2.7680000000000002 2.769 2.77 2.771 2.7720000000000002 2.773 2.774 2.775 2.7760000000000002 2.777 2.778 2.779 2.7800000000000002 2.781 2.782 2.783 2.7840000000000003 2.785 2.786 2.787 2.7880000000000003 2.789 2.79 2.791 2.7920000000000003 2.793 2.794 2.795 2.7960000000000003 2.797 2.798 2.799 2.8000000000000003 2.801 2.802 2.803 2.8040000000000003 2.805 2.806 2.807 2.8080000000000003 2.809 2.81 2.811 2.8120000000000003 2.813 2.814 2.815 2.816 2.817 2.818 2.819 2.82 2.821 2.822 2.823 2.824 2.825 2.826 2.827 2.828 2.829 2.83 2.831 2.832 2.833 2.834 2.835 2.836 2.837 2.838 2.839 2.84 2.841 2.842 2.843 2.844 2.845 2.846 2.847 2.848 2.849 2.85 2.851 2.852 2.853 2.854 2.855 2.856 2.857 2.858 2.859 2.86 2.861 2.862 2.863 2.864 2.865 2.866 2.867 2.868 2.869 2.87 2.871 2.872 2.873 2.874 2.875 2.876 2.8770000000000002 2.878 2.879 2.88 2.8810000000000002 2.882 2.883 2.884 2.8850000000000002 2.886 2.887 2.888 2.8890000000000002 2.89 2.891 2.892 2.8930000000000002 2.894 2.895 2.896 2.8970000000000002 2.898 2.899 2.9 2.9010000000000002 2.902 2.903 2.904 2.9050000000000002 2.906 2.907 2.908 2.9090000000000003 2.91 2.911 2.912 2.9130000000000003 2.914 2.915 2.916 2.9170000000000003 2.918 2.919 2.92 2.9210000000000003 2.922 2.923 2.924 2.9250000000000003 2.926 2.927 2.928 2.9290000000000003 2.93 2.931 2.932 2.9330000000000003 2.934 2.935 2.936 2.9370000000000003 2.938 2.939 2.94 2.9410000000000003 2.942 2.943 2.944 2.945 2.946 2.947 2.948 2.949 2.95 2.951 2.952 2.953 2.954 2.955 2.956 2.957 2.958 2.959 2.96 2.961 2.962 2.963 2.964 2.965 2.966 2.967 2.968 2.969 2.97 2.971 2.972 2.973 2.974 2.975 2.976 2.977 2.978 2.979 2.98 2.981 2.982 2.983 2.984 2.985 2.986 2.987 2.988 2.989 2.99 2.991 2.992 2.993 2.994 2.995 2.996 2.997 2.998 2.999 3.0 3.001 3.0020000000000002 3.003 3.004 3.005 3.0060000000000002 3.007 3.008 3.009 3.0100000000000002 3.011 3.012 3.013 3.0140000000000002 3.015 3.016 3.017 3.0180000000000002 3.019 3.02 3.021 3.0220000000000002 3.023 3.024 3.025 3.0260000000000002 3.027 3.028 3.029 3.0300000000000002 3.031 3.032 3.033 3.0340000000000003 3.035 3.036 3.037 3.0380000000000003 3.039 3.04 3.041 3.0420000000000003 3.043 3.044 3.045 3.0460000000000003 3.047 3.048 3.049 3.0500000000000003 3.051 3.052 3.053 3.0540000000000003 3.055 3.056 3.057 3.0580000000000003 3.059 3.06 3.061 3.0620000000000003 3.063 3.064 3.065 3.0660000000000003 3.067 3.068 3.069 3.0700000000000003 3.071 3.072 3.073 3.074 3.075 3.076 3.077 3.078 3.079 3.08 3.081 3.082 3.083 3.084 3.085 3.086 3.087 3.088 3.089 3.09 3.091 3.092 3.093 3.094 3.095 3.096 3.097 3.098 3.099 3.1 3.101 3.102 3.103 3.104 3.105 3.106 3.107 3.108 3.109 3.11 3.111 3.112 3.113 3.114 3.115 3.116 3.117
</pre>
end{sphinxVerbatim}
- more-to-come:
3.118 3.119 3.12 3.121 3.122 3.123 3.124 3.125 3.126 3.1270000000000002 3.128 3.129 3.13 3.1310000000000002 3.132 3.133 3.134 3.1350000000000002 3.136 3.137 3.138 3.1390000000000002 3.14 3.141 3.142 3.1430000000000002 3.144 3.145 3.146 3.1470000000000002 3.148 3.149 3.15 3.1510000000000002 3.152 3.153 3.154 3.1550000000000002 3.156 3.157 3.158 3.1590000000000003 3.16 3.161 3.162 3.1630000000000003 3.164 3.165 3.166 3.1670000000000003 3.168 3.169 3.17 3.1710000000000003 3.172 3.173 3.174 3.1750000000000003 3.176 3.177 3.178 3.1790000000000003 3.18 3.181 3.182 3.1830000000000003 3.184 3.185 3.186 3.1870000000000003 3.188 3.189 3.19 3.1910000000000003 3.192 3.193 3.194 3.1950000000000003 3.196 3.197 3.198 3.1990000000000003 3.2 3.201 3.202 3.203 3.204 3.205 3.206 3.207 3.208 3.209 3.21 3.211 3.212 3.213 3.214 3.215 3.216 3.217 3.218 3.219 3.22 3.221 3.222 3.223 3.224 3.225 3.226 3.227 3.228 3.229 3.23 3.231 3.232 3.233 3.234 3.235 3.236 3.237 3.238 3.239 3.24 3.241 3.242 3.243 3.244 3.245 3.246 3.247 3.248 3.249 3.25 3.251 3.2520000000000002 3.253 3.254 3.255 3.2560000000000002 3.257 3.258 3.259 3.2600000000000002 3.261 3.262 3.263
</pre>
end{sphinxVerbatim}
- more-to-come:
3.2640000000000002 3.265 3.266 3.267 3.2680000000000002 3.269 3.27 3.271 3.2720000000000002 3.273 3.274 3.275 3.2760000000000002 3.277 3.278 3.279 3.2800000000000002 3.281 3.282 3.283 3.2840000000000003 3.285 3.286 3.287 3.2880000000000003 3.289 3.29 3.291 3.2920000000000003 3.293 3.294 3.295 3.2960000000000003 3.297 3.298 3.299 3.3000000000000003 3.301 3.302 3.303 3.3040000000000003 3.305 3.306 3.307 3.3080000000000003 3.309 3.31 3.311 3.3120000000000003 3.313 3.314 3.315 3.3160000000000003 3.317 3.318 3.319 3.3200000000000003 3.321 3.322 3.323 3.3240000000000003 3.325 3.326 3.327 3.3280000000000003 3.329 3.33 3.331 3.332 3.333 3.334 3.335 3.336 3.337 3.338 3.339 3.34 3.341 3.342 3.343 3.344 3.345 3.346 3.347 3.348 3.349 3.35 3.351 3.352 3.353 3.354 3.355 3.356 3.357 3.358 3.359 3.36 3.361 3.362 3.363 3.364 3.365 3.366 3.367 3.368 3.369 3.37 3.371 3.372 3.373 3.374 3.375 3.376 3.3770000000000002 3.378 3.379 3.38 3.3810000000000002 3.382 3.383 3.384 3.3850000000000002 3.386 3.387 3.388 3.3890000000000002 3.39 3.391 3.392 3.3930000000000002 3.394 3.395 3.396 3.3970000000000002 3.398 3.399 3.4 3.4010000000000002 3.402 3.403 3.404 3.4050000000000002 3.406 3.407 3.408 3.4090000000000003 3.41 3.411 3.412 3.4130000000000003 3.414 3.415 3.416 3.4170000000000003 3.418 3.419 3.42 3.4210000000000003 3.422 3.423 3.424 3.4250000000000003 3.426 3.427 3.428 3.4290000000000003 3.43 3.431 3.432 3.4330000000000003 3.434 3.435 3.436 3.4370000000000003 3.438 3.439 3.44 3.4410000000000003 3.442 3.443 3.444 3.4450000000000003 3.446 3.447 3.448 3.4490000000000003 3.45 3.451 3.452 3.4530000000000003 3.454 3.455 3.456 3.457 3.458 3.459 3.46 3.461 3.462 3.463 3.464 3.465 3.466 3.467 3.468 3.469 3.47 3.471 3.472 3.473 3.474 3.475 3.476 3.477 3.478 3.479 3.48 3.481 3.482 3.483 3.484 3.485 3.486 3.487 3.488 3.489 3.49 3.491 3.492 3.493 3.494 3.495 3.496 3.497 3.498 3.499 3.5 3.501 3.5020000000000002 3.503 3.504 3.505 3.5060000000000002 3.507 3.508 3.509 3.5100000000000002 3.511 3.512 3.513 3.5140000000000002 3.515 3.516 3.517 3.5180000000000002 3.519 3.52 3.521 3.5220000000000002 3.523 3.524 3.525 3.5260000000000002 3.527 3.528 3.529 3.5300000000000002 3.531 3.532 3.533 3.5340000000000003 3.535 3.536 3.537 3.5380000000000003 3.539 3.54 3.541 3.5420000000000003 3.543 3.544 3.545 3.5460000000000003 3.547 3.548 3.549 3.5500000000000003 3.551 3.552 3.553 3.5540000000000003 3.555 3.556 3.557 3.5580000000000003 3.559 3.56 3.561 3.5620000000000003 3.563 3.564 3.565 3.5660000000000003 3.567 3.568 3.569 3.5700000000000003 3.571 3.572 3.573 3.5740000000000003 3.575 3.576 3.577 3.5780000000000003 3.579 3.58 3.581 3.5820000000000003 3.583 3.584 3.585 3.586 3.587 3.588 3.589 3.59 3.591 3.592 3.593 3.594 3.595 3.596 3.597 3.598 3.599 3.6 3.601 3.602 3.603 3.604 3.605 3.606 3.607 3.608 3.609 3.61 3.611 3.612 3.613 3.614 3.615 3.616 3.617 3.618 3.619 3.62 3.621 3.622 3.623 3.624 3.625 3.626 3.6270000000000002 3.628 3.629 3.63 3.6310000000000002 3.632 3.633 3.634 3.6350000000000002 3.636 3.637 3.638 3.6390000000000002 3.64 3.641 3.642 3.6430000000000002 3.644 3.645 3.646 3.6470000000000002 3.648 3.649 3.65 3.6510000000000002 3.652 3.653 3.654 3.6550000000000002 3.656 3.657 3.658 3.6590000000000003 3.66
</pre>
end{sphinxVerbatim}
- more-to-come:
3.661 3.662 3.6630000000000003 3.664 3.665 3.666 3.6670000000000003 3.668 3.669 3.67 3.6710000000000003 3.672 3.673 3.674 3.6750000000000003 3.676 3.677 3.678 3.6790000000000003 3.68 3.681 3.682 3.6830000000000003 3.684 3.685 3.686 3.6870000000000003 3.688 3.689 3.69 3.6910000000000003 3.692 3.693 3.694 3.6950000000000003 3.696 3.697 3.698 3.6990000000000003 3.7 3.701 3.702 3.7030000000000003 3.704 3.705 3.706 3.7070000000000003 3.708 3.709 3.71 3.7110000000000003 3.712 3.713 3.714 3.715 3.716 3.717 3.718 3.719 3.72 3.721 3.722 3.723 3.724 3.725 3.726 3.727 3.728 3.729 3.73 3.731 3.732 3.733 3.734 3.735 3.736 3.737 3.738 3.739 3.74 3.741 3.742 3.743 3.744 3.745 3.746 3.747 3.748 3.749 3.75 3.751 3.7520000000000002 3.753 3.754 3.755 3.7560000000000002 3.757 3.758 3.759 3.7600000000000002 3.761 3.762 3.763 3.7640000000000002 3.765 3.766 3.767 3.7680000000000002 3.769 3.77 3.771 3.7720000000000002 3.773 3.774 3.775 3.7760000000000002 3.777 3.778 3.779 3.7800000000000002 3.781 3.782 3.783 3.7840000000000003 3.785 3.786 3.787 3.7880000000000003 3.789 3.79 3.791 3.7920000000000003 3.793 3.794 3.795 3.7960000000000003 3.797 3.798 3.799 3.8000000000000003 3.801 3.802 3.803 3.8040000000000003 3.805 3.806 3.807 3.8080000000000003
</pre>
end{sphinxVerbatim}
- more-to-come:
3.809 3.81 3.811 3.8120000000000003 3.813 3.814 3.815 3.8160000000000003 3.817 3.818 3.819 3.8200000000000003 3.821 3.822 3.823 3.8240000000000003 3.825 3.826 3.827 3.8280000000000003 3.829 3.83 3.831 3.8320000000000003 3.833 3.834 3.835 3.8360000000000003 3.837 3.838 3.839 3.84 3.841 3.842 3.843 3.844 3.845 3.846 3.847 3.848 3.849 3.85 3.851 3.852 3.853 3.854 3.855 3.856 3.857 3.858 3.859 3.86 3.861 3.862 3.863 3.864 3.865 3.866 3.867 3.868 3.869 3.87 3.871 3.872 3.873 3.874 3.875 3.876 3.8770000000000002 3.878 3.879 3.88 3.8810000000000002 3.882 3.883 3.884 3.8850000000000002 3.886 3.887 3.888 3.8890000000000002 3.89 3.891 3.892 3.8930000000000002 3.894 3.895 3.896 3.8970000000000002 3.898 3.899 3.9 3.9010000000000002 3.902 3.903 3.904 3.9050000000000002 3.906 3.907 3.908 3.9090000000000003 3.91 3.911 3.912 3.9130000000000003 3.914 3.915 3.916 3.9170000000000003 3.918 3.919 3.92 3.9210000000000003 3.922 3.923 3.924 3.9250000000000003 3.926 3.927 3.928 3.9290000000000003 3.93 3.931 3.932 3.9330000000000003 3.934 3.935 3.936 3.9370000000000003 3.938 3.939 3.94 3.9410000000000003 3.942 3.943 3.944 3.9450000000000003 3.946 3.947 3.948 3.9490000000000003 3.95 3.951 3.952 3.9530000000000003 3.954 3.955 3.956 3.9570000000000003 3.958 3.959 3.96 3.9610000000000003 3.962 3.963 3.964 3.9650000000000003 3.966 3.967 3.968 3.969 3.97 3.971 3.972 3.973 3.974 3.975 3.976 3.977 3.978 3.979 3.98 3.981 3.982 3.983 3.984 3.985 3.986 3.987 3.988 3.989 3.99 3.991 3.992 3.993 3.994 3.995 3.996 3.997 3.998 3.999 4.0 4.001 4.002 4.003 4.0040000000000004 4.005 4.006 4.007 4.008 4.009 4.01 4.011 4.0120000000000005 4.013 4.014 4.015 4.016 4.017 4.018 4.019 4.0200000000000005 4.021 4.022 4.023 4.024 4.025 4.026 4.027 4.0280000000000005 4.029 4.03 4.031 4.032 4.033 4.034 4.035 4.0360000000000005 4.037 4.038 4.039 4.04 4.041 4.042 4.043 4.0440000000000005 4.045 4.046 4.047 4.048 4.049 4.05 4.051 4.0520000000000005 4.053 4.054 4.055 4.056 4.057 4.058 4.059 4.0600000000000005 4.061 4.062 4.063 4.064 4.065 4.066 4.067 4.0680000000000005 4.069 4.07 4.071 4.072 4.073 4.074 4.075 4.0760000000000005 4.077 4.078 4.079 4.08 4.081 4.082 4.083 4.0840000000000005 4.085 4.086 4.087 4.088 4.089 4.09 4.091 4.0920000000000005 4.093 4.094 4.095 4.096 4.097 4.098 4.099 4.1 4.101 4.102 4.103 4.104 4.105 4.106 4.107 4.108 4.109 4.11 4.111 4.112 4.113 4.114 4.115 4.116 4.117 4.118 4.119 4.12 4.121 4.122 4.123 4.124 4.125 4.126 4.127 4.128 4.1290000000000004 4.13 4.131 4.132 4.133 4.134 4.135 4.136 4.1370000000000005 4.138 4.139 4.14 4.141 4.142 4.143 4.144 4.1450000000000005 4.146 4.147 4.148 4.149 4.15 4.151 4.152 4.1530000000000005 4.154 4.155 4.156 4.157 4.158 4.159 4.16 4.1610000000000005 4.162 4.163 4.164 4.165 4.166 4.167 4.168 4.1690000000000005 4.17 4.171 4.172 4.173 4.174 4.175 4.176 4.1770000000000005 4.178 4.179 4.18 4.181 4.182 4.183 4.184 4.1850000000000005 4.186 4.187 4.188 4.189 4.19 4.191 4.192 4.1930000000000005 4.194 4.195 4.196 4.197 4.198 4.199 4.2 4.2010000000000005 4.202 4.203 4.204 4.205 4.206
</pre>
end{sphinxVerbatim}
- more-to-come:
4.207 4.208 4.2090000000000005 4.21 4.211 4.212 4.213 4.214 4.215 4.216 4.2170000000000005 4.218 4.219 4.22 4.221 4.222 4.223 4.224 4.225 4.226 4.227 4.228 4.229 4.23 4.231 4.232 4.233 4.234 4.235 4.236 4.237 4.238 4.239 4.24 4.241 4.242 4.243 4.244 4.245 4.246 4.247 4.248 4.249 4.25 4.251 4.252 4.253 4.2540000000000004 4.255 4.256 4.257 4.258 4.259 4.26 4.261 4.2620000000000005 4.263 4.264 4.265 4.266 4.267 4.268 4.269 4.2700000000000005 4.271 4.272 4.273 4.274 4.275 4.276 4.277 4.2780000000000005 4.279 4.28 4.281 4.282 4.283 4.284 4.285 4.2860000000000005 4.287 4.288 4.289 4.29 4.291 4.292 4.293 4.2940000000000005 4.295 4.296 4.297 4.298 4.299 4.3 4.301 4.3020000000000005 4.303 4.304 4.305 4.306 4.307 4.308 4.309 4.3100000000000005 4.311 4.312 4.313 4.314 4.315 4.316 4.317 4.3180000000000005 4.319 4.32 4.321 4.322 4.323 4.324 4.325 4.3260000000000005 4.327 4.328 4.329 4.33 4.331 4.332 4.333 4.3340000000000005 4.335 4.336 4.337 4.338 4.339 4.34 4.341 4.3420000000000005 4.343 4.344 4.345 4.346 4.347 4.348 4.349 4.3500000000000005 4.351 4.352 4.353 4.354
</pre>
end{sphinxVerbatim}
- more-to-come:
4.355 4.356 4.357 4.358 4.359 4.36 4.361 4.362 4.363 4.364 4.365 4.366 4.367 4.368 4.369 4.37 4.371 4.372 4.373 4.374 4.375 4.376 4.377 4.378 4.3790000000000004 4.38 4.381 4.382 4.383 4.384 4.385 4.386 4.3870000000000005 4.388 4.389 4.39 4.391 4.392 4.393 4.394 4.3950000000000005 4.396 4.397 4.398 4.399 4.4 4.401 4.402 4.4030000000000005 4.404 4.405 4.406 4.407 4.408 4.409 4.41 4.4110000000000005 4.412 4.413 4.414 4.415 4.416 4.417 4.418 4.4190000000000005 4.42 4.421 4.422 4.423 4.424 4.425 4.426 4.4270000000000005 4.428 4.429 4.43 4.431 4.432 4.433 4.434 4.4350000000000005 4.436 4.437 4.438 4.439 4.44 4.441 4.442 4.4430000000000005 4.444 4.445 4.446 4.447 4.448 4.449 4.45 4.4510000000000005 4.452 4.453 4.454 4.455 4.456 4.457 4.458 4.4590000000000005 4.46 4.461 4.462 4.463 4.464 4.465 4.466 4.4670000000000005 4.468 4.469 4.47 4.471 4.472 4.473 4.474 4.4750000000000005 4.476 4.477 4.478 4.479 4.48 4.481 4.482 4.483 4.484 4.485 4.486 4.487 4.488 4.489 4.49 4.491 4.492 4.493 4.494 4.495 4.496 4.497 4.498 4.499 4.5 4.501 4.502 4.503 4.5040000000000004 4.505 4.506 4.507 4.508 4.509 4.51 4.511 4.5120000000000005 4.513 4.514 4.515 4.516 4.517 4.518 4.519 4.5200000000000005 4.521 4.522 4.523 4.524 4.525 4.526 4.527 4.5280000000000005 4.529 4.53 4.531 4.532 4.533 4.534 4.535 4.5360000000000005 4.537 4.538 4.539 4.54 4.541 4.542 4.543 4.5440000000000005 4.545 4.546 4.547 4.548 4.549 4.55 4.551 4.5520000000000005 4.553 4.554 4.555 4.556 4.557 4.558 4.559 4.5600000000000005 4.561 4.562 4.563 4.564 4.565 4.566 4.567 4.5680000000000005 4.569 4.57 4.571 4.572 4.573 4.574 4.575 4.5760000000000005 4.577 4.578 4.579 4.58 4.581 4.582 4.583 4.5840000000000005 4.585 4.586 4.587 4.588 4.589 4.59 4.591 4.5920000000000005 4.593 4.594 4.595 4.596 4.597 4.598 4.599 4.6000000000000005 4.601 4.602 4.603 4.604 4.605 4.606 4.607 4.6080000000000005 4.609 4.61 4.611 4.612 4.613 4.614 4.615 4.616 4.617 4.618 4.619 4.62 4.621 4.622 4.623 4.624 4.625 4.626 4.627 4.628 4.6290000000000004 4.63 4.631 4.632 4.633 4.634 4.635 4.636 4.6370000000000005 4.638 4.639 4.64 4.641 4.642 4.643 4.644 4.6450000000000005 4.646 4.647 4.648 4.649 4.65 4.651 4.652 4.6530000000000005 4.654 4.655 4.656 4.657 4.658 4.659 4.66 4.6610000000000005 4.662 4.663 4.664 4.665 4.666 4.667 4.668 4.6690000000000005 4.67 4.671 4.672 4.673 4.674 4.675 4.676 4.6770000000000005 4.678 4.679 4.68 4.681 4.682 4.683 4.684 4.6850000000000005 4.686 4.687 4.688 4.689 4.69 4.691 4.692 4.6930000000000005 4.694 4.695 4.696 4.697 4.698 4.699 4.7 4.7010000000000005 4.702 4.703 4.704 4.705 4.706 4.707 4.708 4.7090000000000005 4.71 4.711 4.712 4.713 4.714 4.715 4.716 4.7170000000000005 4.718 4.719 4.72 4.721 4.722 4.723 4.724 4.7250000000000005 4.726 4.727 4.728 4.729 4.73 4.731 4.732 4.7330000000000005 4.734 4.735 4.736 4.737 4.738 4.739 4.74 4.741 4.742 4.743 4.744 4.745 4.746 4.747 4.748 4.749 4.75 4.751 4.752
</pre>
end{sphinxVerbatim}
- more-to-come:
4.753 4.7540000000000004 4.755 4.756 4.757 4.758 4.759 4.76 4.761 4.7620000000000005 4.763 4.764 4.765 4.766 4.767 4.768 4.769 4.7700000000000005 4.771 4.772 4.773 4.774 4.775 4.776 4.777 4.7780000000000005 4.779 4.78 4.781 4.782 4.783 4.784 4.785 4.7860000000000005 4.787 4.788 4.789 4.79 4.791 4.792 4.793 4.7940000000000005 4.795 4.796 4.797 4.798 4.799 4.8 4.801 4.8020000000000005 4.803 4.804 4.805 4.806 4.807 4.808 4.809 4.8100000000000005 4.811 4.812 4.813 4.814 4.815 4.816 4.817 4.8180000000000005 4.819 4.82 4.821 4.822 4.823 4.824 4.825 4.8260000000000005 4.827 4.828 4.829 4.83 4.831 4.832 4.833 4.8340000000000005 4.835 4.836 4.837 4.838 4.839 4.84 4.841 4.8420000000000005 4.843 4.844 4.845 4.846 4.847 4.848 4.849 4.8500000000000005 4.851 4.852 4.853 4.854 4.855 4.856 4.857 4.8580000000000005 4.859 4.86 4.861 4.862 4.863 4.864 4.865 4.866 4.867 4.868 4.869 4.87 4.871 4.872 4.873 4.874 4.875 4.876 4.877 4.878 4.8790000000000004 4.88 4.881 4.882 4.883 4.884 4.885 4.886 4.8870000000000005 4.888 4.889 4.89 4.891 4.892 4.893 4.894 4.8950000000000005 4.896 4.897 4.898 4.899 4.9
</pre>
end{sphinxVerbatim}
- more-to-come:
4.901 4.902 4.9030000000000005 4.904 4.905 4.906 4.907 4.908 4.909 4.91 4.9110000000000005 4.912 4.913 4.914 4.915 4.916 4.917 4.918 4.9190000000000005 4.92 4.921 4.922 4.923 4.924 4.925 4.926 4.9270000000000005 4.928 4.929 4.93 4.931 4.932 4.933 4.934 4.9350000000000005 4.936 4.937 4.938 4.939 4.94 4.941 4.942 4.9430000000000005 4.944 4.945 4.946 4.947 4.948 4.949 4.95 4.9510000000000005 4.952 4.953 4.954 4.955 4.956 4.957 4.958 4.9590000000000005 4.96 4.961 4.962 4.963 4.964 4.965 4.966 4.9670000000000005 4.968 4.969 4.97 4.971 4.972 4.973 4.974 4.9750000000000005 4.976 4.977 4.978 4.979 4.98 4.981 4.982 4.9830000000000005 4.984 4.985 4.986 4.987 4.988 4.989 4.99 4.9910000000000005 4.992 4.993 4.994 4.995 4.996 4.997 4.998 4.999 5.0 5.001 5.002 5.003 5.0040000000000004 5.005 5.006 5.007 5.008 5.009 5.01 5.011 5.0120000000000005 5.013 5.014 5.015 5.016 5.017 5.018 5.019 5.0200000000000005 5.021 5.022 5.023 5.024 5.025 5.026 5.027 5.0280000000000005 5.029 5.03 5.031 5.032 5.033 5.034 5.035 5.0360000000000005 5.037 5.038 5.039 5.04 5.041 5.042 5.043 5.0440000000000005 5.045 5.046 5.047 5.048 5.049 5.05 5.051 5.0520000000000005 5.053 5.054 5.055 5.056 5.057 5.058 5.059 5.0600000000000005 5.061 5.062 5.063 5.064 5.065 5.066 5.067 5.0680000000000005 5.069 5.07 5.071 5.072 5.073 5.074 5.075 5.0760000000000005 5.077 5.078 5.079 5.08 5.081 5.082 5.083 5.0840000000000005 5.085 5.086 5.087 5.088 5.089 5.09 5.091 5.0920000000000005 5.093 5.094 5.095 5.096 5.097 5.098 5.099 5.1000000000000005 5.101 5.102 5.103 5.104 5.105 5.106 5.107 5.1080000000000005 5.109 5.11 5.111 5.112 5.113 5.114 5.115 5.1160000000000005 5.117 5.118 5.119 5.12 5.121 5.122 5.123 5.124 5.125 5.126 5.127 5.128 5.1290000000000004 5.13 5.131 5.132 5.133 5.134 5.135 5.136 5.1370000000000005 5.138 5.139 5.14 5.141 5.142 5.143 5.144 5.1450000000000005 5.146 5.147 5.148 5.149 5.15 5.151 5.152 5.1530000000000005 5.154 5.155 5.156 5.157 5.158 5.159 5.16 5.1610000000000005 5.162 5.163 5.164 5.165 5.166 5.167 5.168 5.1690000000000005 5.17 5.171 5.172 5.173 5.174 5.175 5.176 5.1770000000000005 5.178 5.179 5.18 5.181 5.182 5.183 5.184 5.1850000000000005 5.186 5.187 5.188 5.189 5.19 5.191 5.192 5.1930000000000005 5.194 5.195 5.196 5.197 5.198 5.199 5.2 5.2010000000000005 5.202 5.203 5.204 5.205 5.206 5.207 5.208 5.2090000000000005 5.21 5.211 5.212 5.213 5.214 5.215 5.216 5.2170000000000005 5.218 5.219 5.22 5.221 5.222 5.223 5.224 5.2250000000000005 5.226 5.227 5.228 5.229 5.23 5.231 5.232 5.2330000000000005 5.234 5.235 5.236 5.237 5.238 5.239 5.24 5.2410000000000005 5.242 5.243 5.244 5.245 5.246 5.247 5.248 5.249 5.25 5.251 5.252 5.253 5.2540000000000004 5.255 5.256 5.257 5.258 5.259 5.26 5.261 5.2620000000000005 5.263 5.264 5.265 5.266 5.267 5.268 5.269 5.2700000000000005 5.271 5.272 5.273 5.274 5.275 5.276 5.277 5.2780000000000005 5.279 5.28 5.281 5.282 5.283 5.284 5.285 5.2860000000000005 5.287 5.288 5.289 5.29 5.291 5.292 5.293 5.2940000000000005 5.295 5.296 5.297 5.298
</pre>
end{sphinxVerbatim}
- more-to-come:
5.299 5.3 5.301 5.3020000000000005 5.303 5.304 5.305 5.306 5.307 5.308 5.309 5.3100000000000005 5.311 5.312 5.313 5.314 5.315 5.316 5.317 5.3180000000000005 5.319 5.32 5.321 5.322 5.323 5.324 5.325 5.3260000000000005 5.327 5.328 5.329 5.33 5.331 5.332 5.333 5.3340000000000005 5.335 5.336 5.337 5.338 5.339 5.34 5.341 5.3420000000000005 5.343 5.344 5.345 5.346 5.347 5.348 5.349 5.3500000000000005 5.351 5.352 5.353 5.354 5.355 5.356 5.357 5.3580000000000005 5.359 5.36 5.361 5.362 5.363 5.364 5.365 5.3660000000000005 5.367 5.368 5.369 5.37 5.371 5.372 5.373 5.3740000000000006 5.375 5.376 5.377 5.378 5.3790000000000004 5.38 5.381 5.382 5.383 5.384 5.385 5.386 5.3870000000000005 5.388 5.389 5.39 5.391 5.392 5.393 5.394 5.3950000000000005 5.396 5.397 5.398 5.399 5.4 5.401 5.402 5.4030000000000005 5.404 5.405 5.406 5.407 5.408 5.409 5.41 5.4110000000000005 5.412 5.413 5.414 5.415 5.416 5.417 5.418 5.4190000000000005 5.42 5.421 5.422 5.423 5.424 5.425 5.426 5.4270000000000005 5.428 5.429 5.43 5.431 5.432 5.433 5.434 5.4350000000000005 5.436 5.437 5.438 5.439 5.44 5.441 5.442 5.4430000000000005 5.444 5.445 5.446
</pre>
end{sphinxVerbatim}
- more-to-come:
5.447 5.448 5.449 5.45 5.4510000000000005 5.452 5.453 5.454 5.455 5.456 5.457 5.458 5.4590000000000005 5.46 5.461 5.462 5.463 5.464 5.465 5.466 5.4670000000000005 5.468 5.469 5.47 5.471 5.472 5.473 5.474 5.4750000000000005 5.476 5.477 5.478 5.479 5.48 5.481 5.482 5.4830000000000005 5.484 5.485 5.486 5.487 5.488 5.489 5.49 5.4910000000000005 5.492 5.493 5.494 5.495 5.496 5.497 5.498 5.4990000000000006 5.5 5.501 5.502 5.503 5.5040000000000004 5.505 5.506 5.507 5.508 5.509 5.51 5.511 5.5120000000000005 5.513 5.514 5.515 5.516 5.517 5.518 5.519 5.5200000000000005 5.521 5.522 5.523 5.524 5.525 5.526 5.527 5.5280000000000005 5.529 5.53 5.531 5.532 5.533 5.534 5.535 5.5360000000000005 5.537 5.538 5.539 5.54 5.541 5.542 5.543 5.5440000000000005 5.545 5.546 5.547 5.548 5.549 5.55 5.551 5.5520000000000005 5.553 5.554 5.555 5.556 5.557 5.558 5.559 5.5600000000000005 5.561 5.562 5.563 5.564 5.565 5.566 5.567 5.5680000000000005 5.569 5.57 5.571 5.572 5.573 5.574 5.575 5.5760000000000005 5.577 5.578 5.579 5.58 5.581 5.582 5.583 5.5840000000000005 5.585 5.586 5.587 5.588 5.589 5.59 5.591 5.5920000000000005 5.593 5.594 5.595 5.596 5.597 5.598 5.599 5.6000000000000005 5.601 5.602 5.603 5.604 5.605 5.606 5.607 5.6080000000000005 5.609 5.61 5.611 5.612 5.613 5.614 5.615 5.6160000000000005 5.617 5.618 5.619 5.62 5.621 5.622 5.623 5.6240000000000006 5.625 5.626 5.627 5.628 5.6290000000000004 5.63 5.631 5.632 5.633 5.634 5.635 5.636 5.6370000000000005 5.638 5.639 5.64 5.641 5.642 5.643 5.644 5.6450000000000005 5.646 5.647 5.648 5.649 5.65 5.651 5.652 5.6530000000000005 5.654 5.655 5.656 5.657 5.658 5.659 5.66 5.6610000000000005 5.662 5.663 5.664 5.665 5.666 5.667 5.668 5.6690000000000005 5.67 5.671 5.672 5.673 5.674 5.675 5.676 5.6770000000000005 5.678 5.679 5.68 5.681 5.682 5.683 5.684 5.6850000000000005 5.686 5.687 5.688 5.689 5.69 5.691 5.692 5.6930000000000005 5.694 5.695 5.696 5.697 5.698 5.699 5.7 5.7010000000000005 5.702 5.703 5.704 5.705 5.706 5.707 5.708 5.7090000000000005 5.71 5.711 5.712 5.713 5.714 5.715 5.716 5.7170000000000005 5.718 5.719 5.72 5.721 5.722 5.723 5.724 5.7250000000000005 5.726 5.727 5.728 5.729 5.73 5.731 5.732 5.7330000000000005 5.734 5.735 5.736 5.737 5.738 5.739 5.74 5.7410000000000005 5.742 5.743 5.744 5.745 5.746 5.747 5.748 5.7490000000000006 5.75 5.751 5.752 5.753 5.7540000000000004 5.755 5.756 5.757000000000001 5.758 5.759 5.76 5.761 5.7620000000000005 5.763 5.764 5.765 5.766 5.767 5.768 5.769 5.7700000000000005 5.771 5.772 5.773 5.774 5.775 5.776 5.777 5.7780000000000005 5.779 5.78 5.781 5.782 5.783 5.784 5.785 5.7860000000000005 5.787 5.788 5.789 5.79 5.791 5.792 5.793 5.7940000000000005 5.795 5.796 5.797 5.798 5.799 5.8 5.801 5.8020000000000005 5.803 5.804 5.805 5.806 5.807 5.808 5.809 5.8100000000000005 5.811 5.812 5.813 5.814 5.815 5.816 5.817 5.8180000000000005 5.819 5.82 5.821 5.822 5.823 5.824 5.825 5.8260000000000005 5.827 5.828 5.829 5.83 5.831 5.832 5.833 5.8340000000000005 5.835 5.836 5.837 5.838 5.839 5.84 5.841 5.8420000000000005 5.843 5.844
</pre>
end{sphinxVerbatim}
- more-to-come:
5.845 5.846 5.847 5.848 5.849 5.8500000000000005 5.851 5.852 5.853 5.854 5.855 5.856 5.857 5.8580000000000005 5.859 5.86 5.861 5.862 5.863 5.864 5.865 5.8660000000000005 5.867 5.868 5.869 5.87 5.871 5.872 5.873 5.8740000000000006 5.875 5.876 5.877 5.878 5.8790000000000004 5.88 5.881 5.882000000000001 5.883 5.884 5.885 5.886 5.8870000000000005 5.888 5.889 5.89 5.891 5.892 5.893 5.894 5.8950000000000005 5.896 5.897 5.898 5.899 5.9 5.901 5.902 5.9030000000000005 5.904 5.905 5.906 5.907 5.908 5.909 5.91 5.9110000000000005 5.912 5.913 5.914 5.915 5.916 5.917 5.918 5.9190000000000005 5.92 5.921 5.922 5.923 5.924 5.925 5.926 5.9270000000000005 5.928 5.929 5.93 5.931 5.932 5.933 5.934 5.9350000000000005 5.936 5.937 5.938 5.939 5.94 5.941 5.942 5.9430000000000005 5.944 5.945 5.946 5.947 5.948 5.949 5.95 5.9510000000000005 5.952 5.953 5.954 5.955 5.956 5.957 5.958 5.9590000000000005 5.96 5.961 5.962 5.963 5.964 5.965 5.966 5.9670000000000005 5.968 5.969 5.97 5.971 5.972 5.973 5.974 5.9750000000000005 5.976 5.977 5.978 5.979 5.98 5.981 5.982 5.9830000000000005 5.984 5.985 5.986 5.987 5.988 5.989 5.99
</pre>
end{sphinxVerbatim}
- more-to-come:
5.9910000000000005 5.992 5.993 5.994 5.995 5.996 5.997 5.998 5.9990000000000006 6.0 6.001 6.002 6.003 6.0040000000000004 6.005 6.006 6.007000000000001 6.008 6.009 6.01 6.011 6.0120000000000005 6.013 6.014 6.015000000000001 6.016 6.017 6.018 6.019 6.0200000000000005 6.021 6.022 6.023 6.024 6.025 6.026 6.027 6.0280000000000005 6.029 6.03 6.031 6.032 6.033 6.034 6.035 6.0360000000000005 6.037 6.038 6.039 6.04 6.041 6.042 6.043 6.0440000000000005 6.045 6.046 6.047 6.048 6.049 6.05 6.051 6.0520000000000005 6.053 6.054 6.055 6.056 6.057 6.058 6.059 6.0600000000000005 6.061 6.062 6.063 6.064 6.065 6.066 6.067 6.0680000000000005 6.069 6.07 6.071 6.072 6.073 6.074 6.075 6.0760000000000005 6.077 6.078 6.079 6.08 6.081 6.082 6.083 6.0840000000000005 6.085 6.086 6.087 6.088 6.089 6.09 6.091 6.0920000000000005 6.093 6.094 6.095 6.096 6.097 6.098 6.099 6.1000000000000005 6.101 6.102 6.103 6.104 6.105 6.106 6.107 6.1080000000000005 6.109 6.11 6.111 6.112 6.113 6.114 6.115 6.1160000000000005 6.117 6.118 6.119 6.12 6.121 6.122 6.123 6.1240000000000006 6.125 6.126 6.127 6.128 6.1290000000000004 6.13 6.131 6.132000000000001 6.133 6.134 6.135 6.136 6.1370000000000005 6.138 6.139 6.140000000000001 6.141 6.142 6.143 6.144 6.1450000000000005 6.146 6.147 6.148 6.149 6.15 6.151 6.152 6.1530000000000005 6.154 6.155 6.156 6.157 6.158 6.159 6.16 6.1610000000000005 6.162 6.163 6.164 6.165 6.166 6.167 6.168 6.1690000000000005 6.17 6.171 6.172 6.173 6.174 6.175 6.176 6.1770000000000005 6.178 6.179 6.18 6.181 6.182 6.183 6.184 6.1850000000000005 6.186 6.187 6.188 6.189 6.19 6.191 6.192 6.1930000000000005 6.194 6.195 6.196 6.197 6.198 6.199 6.2 6.2010000000000005 6.202 6.203 6.204 6.205 6.206 6.207 6.208 6.2090000000000005 6.21 6.211 6.212 6.213 6.214 6.215 6.216 6.2170000000000005 6.218 6.219 6.22 6.221 6.222 6.223 6.224 6.2250000000000005 6.226 6.227 6.228 6.229 6.23 6.231 6.232 6.2330000000000005 6.234 6.235 6.236 6.237 6.238 6.239 6.24 6.2410000000000005 6.242 6.243 6.244 6.245 6.246 6.247 6.248 6.2490000000000006 6.25 6.251 6.252 6.253 6.2540000000000004 6.255 6.256 6.257000000000001 6.258 6.259 6.26 6.261 6.2620000000000005 6.263 6.264 6.265000000000001 6.266 6.267 6.268 6.269 6.2700000000000005 6.271 6.272 6.273 6.274 6.275 6.276 6.277 6.2780000000000005 6.279 6.28 6.281 6.282 6.283 6.284 6.285 6.2860000000000005 6.287 6.288 6.289 6.29 6.291 6.292 6.293 6.2940000000000005 6.295 6.296 6.297 6.298 6.299 6.3 6.301 6.3020000000000005 6.303 6.304 6.305 6.306 6.307 6.308 6.309 6.3100000000000005 6.311 6.312 6.313 6.314 6.315 6.316 6.317 6.3180000000000005 6.319 6.32 6.321 6.322 6.323 6.324 6.325 6.3260000000000005 6.327 6.328 6.329 6.33 6.331 6.332 6.333 6.3340000000000005 6.335 6.336 6.337 6.338 6.339 6.34 6.341 6.3420000000000005 6.343 6.344 6.345 6.346 6.347 6.348 6.349 6.3500000000000005 6.351 6.352 6.353 6.354 6.355 6.356 6.357 6.3580000000000005 6.359 6.36 6.361 6.362 6.363 6.364 6.365 6.3660000000000005 6.367 6.368 6.369 6.37 6.371 6.372 6.373 6.3740000000000006 6.375 6.376 6.377 6.378 6.3790000000000004 6.38 6.381 6.382000000000001 6.383 6.384 6.385 6.386 6.3870000000000005 6.388 6.389 6.390000000000001
</pre>
end{sphinxVerbatim}
- more-to-come:
6.391 6.392 6.393 6.394 6.3950000000000005 6.396 6.397 6.398000000000001 6.399 6.4 6.401 6.402 6.4030000000000005 6.404 6.405 6.406 6.407 6.408 6.409 6.41 6.4110000000000005 6.412 6.413 6.414 6.415 6.416 6.417 6.418 6.4190000000000005 6.42 6.421 6.422 6.423 6.424 6.425 6.426 6.4270000000000005 6.428 6.429 6.43 6.431 6.432 6.433 6.434 6.4350000000000005 6.436 6.437 6.438 6.439 6.44 6.441 6.442 6.4430000000000005 6.444 6.445 6.446 6.447 6.448 6.449 6.45 6.4510000000000005 6.452 6.453 6.454 6.455 6.456 6.457 6.458 6.4590000000000005 6.46 6.461 6.462 6.463 6.464 6.465 6.466 6.4670000000000005 6.468 6.469 6.47 6.471 6.472 6.473 6.474 6.4750000000000005 6.476 6.477 6.478 6.479 6.48 6.481 6.482 6.4830000000000005 6.484 6.485 6.486 6.487 6.488 6.489 6.49 6.4910000000000005 6.492 6.493 6.494 6.495 6.496 6.497 6.498 6.4990000000000006 6.5 6.501 6.502 6.503 6.5040000000000004 6.505 6.506 6.507000000000001 6.508 6.509 6.51 6.511 6.5120000000000005 6.513 6.514 6.515000000000001 6.516 6.517 6.518 6.519 6.5200000000000005 6.521 6.522 6.523000000000001 6.524 6.525 6.526 6.527 6.5280000000000005 6.529 6.53 6.531 6.532 6.533 6.534 6.535
</pre>
end{sphinxVerbatim}
- more-to-come:
6.5360000000000005 6.537 6.538 6.539 6.54 6.541 6.542 6.543 6.5440000000000005 6.545 6.546 6.547 6.548 6.549 6.55 6.551 6.5520000000000005 6.553 6.554 6.555 6.556 6.557 6.558 6.559 6.5600000000000005 6.561 6.562 6.563 6.564 6.565 6.566 6.567 6.5680000000000005 6.569 6.57 6.571 6.572 6.573 6.574 6.575 6.5760000000000005 6.577 6.578 6.579 6.58 6.581 6.582 6.583 6.5840000000000005 6.585 6.586 6.587 6.588 6.589 6.59 6.591 6.5920000000000005 6.593 6.594 6.595 6.596 6.597 6.598 6.599 6.6000000000000005 6.601 6.602 6.603 6.604 6.605 6.606 6.607 6.6080000000000005 6.609 6.61 6.611 6.612 6.613 6.614 6.615 6.6160000000000005 6.617 6.618 6.619 6.62 6.621 6.622 6.623 6.6240000000000006 6.625 6.626 6.627 6.628 6.6290000000000004 6.63 6.631 6.632000000000001 6.633 6.634 6.635 6.636 6.6370000000000005 6.638 6.639 6.640000000000001 6.641 6.642 6.643 6.644 6.6450000000000005 6.646 6.647 6.648000000000001 6.649 6.65 6.651 6.652 6.6530000000000005 6.654 6.655 6.656000000000001 6.657 6.658 6.659 6.66 6.6610000000000005 6.662 6.663 6.664 6.665 6.666 6.667 6.668 6.6690000000000005 6.67 6.671 6.672 6.673 6.674 6.675 6.676 6.6770000000000005 6.678 6.679 6.68 6.681 6.682 6.683 6.684 6.6850000000000005 6.686 6.687 6.688 6.689 6.69 6.691 6.692 6.6930000000000005 6.694 6.695 6.696 6.697 6.698 6.699 6.7 6.7010000000000005 6.702 6.703 6.704 6.705 6.706 6.707 6.708 6.7090000000000005 6.71 6.711 6.712 6.713 6.714 6.715 6.716 6.7170000000000005 6.718 6.719 6.72 6.721 6.722 6.723 6.724 6.7250000000000005 6.726 6.727 6.728 6.729 6.73 6.731 6.732 6.7330000000000005 6.734 6.735 6.736 6.737 6.738 6.739 6.74 6.7410000000000005 6.742 6.743 6.744 6.745 6.746 6.747 6.748 6.7490000000000006 6.75 6.751 6.752 6.753 6.7540000000000004 6.755 6.756 6.757000000000001 6.758 6.759 6.76 6.761 6.7620000000000005 6.763 6.764 6.765000000000001 6.766 6.767 6.768 6.769 6.7700000000000005 6.771 6.772 6.773000000000001 6.774 6.775 6.776 6.777 6.7780000000000005 6.779 6.78 6.781000000000001 6.782 6.783 6.784 6.785 6.7860000000000005 6.787 6.788 6.789 6.79 6.791 6.792 6.793 6.7940000000000005 6.795 6.796 6.797 6.798 6.799 6.8 6.801 6.8020000000000005 6.803 6.804 6.805 6.806 6.807 6.808 6.809 6.8100000000000005 6.811 6.812 6.813 6.814 6.815 6.816 6.817 6.8180000000000005 6.819 6.82 6.821 6.822 6.823 6.824 6.825 6.8260000000000005 6.827 6.828 6.829 6.83 6.831 6.832 6.833 6.8340000000000005 6.835 6.836 6.837 6.838 6.839 6.84 6.841 6.8420000000000005 6.843 6.844 6.845 6.846 6.847 6.848 6.849 6.8500000000000005 6.851 6.852 6.853 6.854 6.855 6.856 6.857 6.8580000000000005 6.859 6.86 6.861 6.862 6.863 6.864 6.865 6.8660000000000005 6.867 6.868 6.869 6.87 6.871 6.872 6.873 6.8740000000000006 6.875 6.876 6.877 6.878 6.8790000000000004 6.88 6.881 6.882000000000001 6.883 6.884 6.885 6.886 6.8870000000000005 6.888 6.889 6.890000000000001 6.891 6.892 6.893 6.894 6.8950000000000005 6.896 6.897 6.898000000000001 6.899 6.9 6.901 6.902 6.9030000000000005 6.904 6.905 6.906000000000001 6.907 6.908 6.909 6.91 6.9110000000000005 6.912 6.913 6.914 6.915 6.916 6.917 6.918 6.9190000000000005 6.92 6.921 6.922 6.923 6.924 6.925 6.926 6.9270000000000005 6.928 6.929 6.93 6.931 6.932 6.933 6.934 6.9350000000000005 6.936 6.937 6.938 6.939
</pre>
end{sphinxVerbatim}
- more-to-come:
6.94 6.941 6.942 6.9430000000000005 6.944 6.945 6.946 6.947 6.948 6.949 6.95 6.9510000000000005 6.952 6.953 6.954 6.955 6.956 6.957 6.958 6.9590000000000005 6.96 6.961 6.962 6.963 6.964 6.965 6.966 6.9670000000000005 6.968 6.969 6.97 6.971 6.972 6.973 6.974 6.9750000000000005 6.976 6.977 6.978 6.979 6.98 6.981 6.982 6.9830000000000005 6.984 6.985 6.986 6.987 6.988 6.989 6.99 6.9910000000000005 6.992 6.993 6.994 6.995 6.996 6.997 6.998 6.9990000000000006 7.0 7.001 7.002 7.003 7.0040000000000004 7.005 7.006 7.007000000000001 7.008 7.009 7.01 7.011 7.0120000000000005 7.013 7.014 7.015000000000001 7.016 7.017 7.018 7.019 7.0200000000000005 7.021 7.022 7.023000000000001 7.024 7.025 7.026 7.027 7.0280000000000005 7.029 7.03 7.031000000000001 7.032 7.033 7.034 7.035 7.0360000000000005 7.037 7.038 7.039000000000001 7.04 7.041 7.042 7.043 7.0440000000000005 7.045 7.046 7.047 7.048 7.049 7.05 7.051 7.0520000000000005 7.053 7.054 7.055 7.056 7.057 7.058 7.059 7.0600000000000005 7.061 7.062 7.063 7.064 7.065 7.066 7.067 7.0680000000000005 7.069 7.07 7.071 7.072 7.073 7.074 7.075 7.0760000000000005 7.077 7.078 7.079 7.08 7.081 7.082 7.083 7.0840000000000005 7.085
</pre>
end{sphinxVerbatim}
- more-to-come:
7.086 7.087 7.088 7.089 7.09 7.091 7.0920000000000005 7.093 7.094 7.095 7.096 7.097 7.098 7.099 7.1000000000000005 7.101 7.102 7.103 7.104 7.105 7.106 7.107 7.1080000000000005 7.109 7.11 7.111 7.112 7.113 7.114 7.115 7.1160000000000005 7.117 7.118 7.119 7.12 7.121 7.122 7.123 7.1240000000000006 7.125 7.126 7.127 7.128 7.1290000000000004 7.13 7.131 7.132000000000001 7.133 7.134 7.135 7.136 7.1370000000000005 7.138 7.139 7.140000000000001 7.141 7.142 7.143 7.144 7.1450000000000005 7.146 7.147 7.148000000000001 7.149 7.15 7.151 7.152 7.1530000000000005 7.154 7.155 7.156000000000001 7.157 7.158 7.159 7.16 7.1610000000000005 7.162 7.163 7.164000000000001 7.165 7.166 7.167 7.168 7.1690000000000005 7.17 7.171 7.172 7.173 7.174 7.175 7.176 7.1770000000000005 7.178 7.179 7.18 7.181 7.182 7.183 7.184 7.1850000000000005 7.186 7.187 7.188 7.189 7.19 7.191 7.192 7.1930000000000005 7.194 7.195 7.196 7.197 7.198 7.199 7.2 7.2010000000000005 7.202 7.203 7.204 7.205 7.206 7.207 7.208 7.2090000000000005 7.21 7.211 7.212 7.213 7.214 7.215 7.216 7.2170000000000005 7.218 7.219 7.22 7.221 7.222 7.223 7.224 7.2250000000000005 7.226 7.227 7.228 7.229 7.23 7.231 7.232 7.2330000000000005 7.234 7.235 7.236 7.237 7.238 7.239 7.24 7.2410000000000005 7.242 7.243 7.244 7.245 7.246 7.247 7.248 7.2490000000000006 7.25 7.251 7.252 7.253 7.2540000000000004 7.255 7.256 7.257000000000001 7.258 7.259 7.26 7.261 7.2620000000000005 7.263 7.264 7.265000000000001 7.266 7.267 7.268 7.269 7.2700000000000005 7.271 7.272 7.273000000000001 7.274 7.275 7.276 7.277 7.2780000000000005 7.279 7.28 7.281000000000001 7.282 7.283 7.284 7.285 7.2860000000000005 7.287 7.288 7.289000000000001 7.29 7.291 7.292 7.293 7.2940000000000005 7.295 7.296 7.297 7.298 7.299 7.3 7.301 7.3020000000000005 7.303 7.304 7.305 7.306 7.307 7.308 7.309 7.3100000000000005 7.311 7.312 7.313 7.314 7.315 7.316 7.317 7.3180000000000005 7.319 7.32 7.321 7.322 7.323 7.324 7.325 7.3260000000000005 7.327 7.328 7.329 7.33 7.331 7.332 7.333 7.3340000000000005 7.335 7.336 7.337 7.338 7.339 7.34 7.341 7.3420000000000005 7.343 7.344 7.345 7.346 7.347 7.348 7.349 7.3500000000000005 7.351 7.352 7.353 7.354 7.355 7.356 7.357 7.3580000000000005 7.359 7.36 7.361 7.362 7.363 7.364 7.365 7.3660000000000005 7.367 7.368 7.369 7.37 7.371 7.372 7.373 7.3740000000000006 7.375 7.376 7.377 7.378 7.3790000000000004 7.38 7.381 7.382000000000001 7.383 7.384 7.385 7.386 7.3870000000000005 7.388 7.389 7.390000000000001 7.391 7.392 7.393 7.394 7.3950000000000005 7.396 7.397 7.398000000000001 7.399 7.4 7.401 7.402 7.4030000000000005 7.404 7.405 7.406000000000001 7.407 7.408 7.409 7.41 7.4110000000000005 7.412 7.413 7.414000000000001 7.415 7.416 7.417 7.418 7.4190000000000005 7.42 7.421 7.422000000000001 7.423 7.424 7.425 7.426 7.4270000000000005 7.428 7.429 7.43 7.431 7.432 7.433 7.434 7.4350000000000005 7.436 7.437 7.438 7.439 7.44 7.441 7.442 7.4430000000000005 7.444 7.445 7.446 7.447 7.448 7.449 7.45 7.4510000000000005 7.452 7.453 7.454 7.455 7.456 7.457 7.458 7.4590000000000005 7.46 7.461 7.462 7.463 7.464 7.465 7.466 7.4670000000000005 7.468 7.469 7.47 7.471 7.472 7.473 7.474 7.4750000000000005 7.476 7.477 7.478 7.479 7.48 7.481 7.482 7.4830000000000005 7.484 7.485
</pre>
end{sphinxVerbatim}
- more-to-come:
7.486 7.487 7.488 7.489 7.49 7.4910000000000005 7.492 7.493 7.494 7.495 7.496 7.497 7.498 7.4990000000000006 7.5 7.501 7.502 7.503 7.5040000000000004 7.505 7.506 7.507000000000001 7.508 7.509 7.51 7.511 7.5120000000000005 7.513 7.514 7.515000000000001 7.516 7.517 7.518 7.519 7.5200000000000005 7.521 7.522 7.523000000000001 7.524 7.525 7.526 7.527 7.5280000000000005 7.529 7.53 7.531000000000001 7.532 7.533 7.534 7.535 7.5360000000000005 7.537 7.538 7.539000000000001 7.54 7.541 7.542 7.543 7.5440000000000005 7.545 7.546 7.547000000000001 7.548 7.549 7.55 7.551 7.5520000000000005 7.553 7.554 7.555 7.556 7.557 7.558 7.559 7.5600000000000005 7.561 7.562 7.563 7.564 7.565 7.566 7.567 7.5680000000000005 7.569 7.57 7.571 7.572 7.573 7.574 7.575 7.5760000000000005 7.577 7.578 7.579 7.58 7.581 7.582 7.583 7.5840000000000005 7.585 7.586 7.587 7.588 7.589 7.59 7.591 7.5920000000000005 7.593 7.594 7.595 7.596 7.597 7.598 7.599 7.6000000000000005 7.601 7.602 7.603 7.604 7.605 7.606 7.607 7.6080000000000005 7.609 7.61 7.611 7.612 7.613 7.614 7.615 7.6160000000000005 7.617 7.618 7.619 7.62 7.621 7.622 7.623 7.6240000000000006 7.625 7.626 7.627 7.628 7.6290000000000004 7.63
</pre>
end{sphinxVerbatim}
- more-to-come:
7.631 7.632000000000001 7.633 7.634 7.635 7.636 7.6370000000000005 7.638 7.639 7.640000000000001 7.641 7.642 7.643 7.644 7.6450000000000005 7.646 7.647 7.648000000000001 7.649 7.65 7.651 7.652 7.6530000000000005 7.654 7.655 7.656000000000001 7.657 7.658 7.659 7.66 7.6610000000000005 7.662 7.663 7.664000000000001 7.665 7.666 7.667 7.668 7.6690000000000005 7.67 7.671 7.672000000000001 7.673 7.674 7.675 7.676 7.6770000000000005 7.678 7.679 7.68 7.681 7.682 7.683 7.684 7.6850000000000005 7.686 7.687 7.688 7.689 7.69 7.691 7.692 7.6930000000000005 7.694 7.695 7.696 7.697 7.698 7.699 7.7 7.7010000000000005 7.702 7.703 7.704 7.705 7.706 7.707 7.708 7.7090000000000005 7.71 7.711 7.712 7.713 7.714 7.715 7.716 7.7170000000000005 7.718 7.719 7.72 7.721 7.722 7.723 7.724 7.7250000000000005 7.726 7.727 7.728 7.729 7.73 7.731 7.732 7.7330000000000005 7.734 7.735 7.736 7.737 7.738 7.739 7.74 7.7410000000000005 7.742 7.743 7.744 7.745 7.746 7.747 7.748 7.7490000000000006 7.75 7.751 7.752 7.753 7.7540000000000004 7.755 7.756 7.757000000000001 7.758 7.759 7.76 7.761 7.7620000000000005 7.763 7.764 7.765000000000001 7.766 7.767 7.768 7.769 7.7700000000000005 7.771 7.772 7.773000000000001 7.774 7.775 7.776 7.777 7.7780000000000005 7.779 7.78 7.781000000000001 7.782 7.783 7.784 7.785 7.7860000000000005 7.787 7.788 7.789000000000001 7.79 7.791 7.792 7.793 7.7940000000000005 7.795 7.796 7.797000000000001 7.798 7.799 7.8 7.801 7.8020000000000005 7.803 7.804 7.805000000000001 7.806 7.807 7.808 7.809 7.8100000000000005 7.811 7.812 7.813 7.814 7.815 7.816 7.817 7.8180000000000005 7.819 7.82 7.821 7.822 7.823 7.824 7.825 7.8260000000000005 7.827 7.828 7.829 7.83 7.831 7.832 7.833 7.8340000000000005 7.835 7.836 7.837 7.838 7.839 7.84 7.841 7.8420000000000005 7.843 7.844 7.845 7.846 7.847 7.848 7.849 7.8500000000000005 7.851 7.852 7.853 7.854 7.855 7.856 7.857 7.8580000000000005 7.859 7.86 7.861 7.862 7.863 7.864 7.865 7.8660000000000005 7.867 7.868 7.869 7.87 7.871 7.872 7.873 7.8740000000000006 7.875 7.876 7.877 7.878 7.8790000000000004 7.88 7.881 7.882000000000001 7.883 7.884 7.885 7.886 7.8870000000000005 7.888 7.889 7.890000000000001 7.891 7.892 7.893 7.894 7.8950000000000005 7.896 7.897 7.898000000000001 7.899 7.9 7.901 7.902 7.9030000000000005 7.904 7.905 7.906000000000001 7.907 7.908 7.909 7.91 7.9110000000000005 7.912 7.913 7.914000000000001 7.915 7.916 7.917 7.918 7.9190000000000005 7.92 7.921 7.922000000000001 7.923 7.924 7.925 7.926 7.9270000000000005 7.928 7.929 7.930000000000001 7.931 7.932 7.933 7.934 7.9350000000000005 7.936 7.937 7.938 7.939 7.94 7.941 7.942 7.9430000000000005 7.944 7.945 7.946 7.947 7.948 7.949 7.95 7.9510000000000005 7.952 7.953 7.954 7.955 7.956 7.957 7.958 7.9590000000000005 7.96 7.961 7.962 7.963 7.964 7.965 7.966 7.9670000000000005 7.968 7.969 7.97 7.971 7.972 7.973 7.974 7.9750000000000005 7.976 7.977 7.978 7.979 7.98 7.981 7.982 7.9830000000000005 7.984 7.985 7.986 7.987 7.988 7.989 7.99 7.9910000000000005 7.992 7.993 7.994 7.995 7.996 7.997 7.998 7.9990000000000006 8.0 8.001 8.002 8.003 8.004 8.005 8.006 8.007 8.008000000000001 8.009 8.01 8.011000000000001 8.012 8.013 8.014 8.015 8.016 8.017 8.018 8.019 8.02 8.021 8.022 8.023 8.024000000000001 8.025 8.026 8.027000000000001 8.028 8.029 8.03 8.031 8.032 8.033 8.034
</pre>
end{sphinxVerbatim}
- more-to-come:
8.035 8.036 8.037 8.038 8.039 8.040000000000001 8.041 8.042 8.043000000000001 8.044 8.045 8.046 8.047 8.048 8.049 8.05 8.051 8.052 8.053 8.054 8.055 8.056000000000001 8.057 8.058 8.059000000000001 8.06 8.061 8.062 8.063 8.064 8.065 8.066 8.067 8.068 8.069 8.07 8.071 8.072000000000001 8.073 8.074 8.075 8.076 8.077 8.078 8.079 8.08 8.081 8.082 8.083 8.084 8.085 8.086 8.087 8.088000000000001 8.089 8.09 8.091 8.092 8.093 8.094 8.095 8.096 8.097 8.098 8.099 8.1 8.101 8.102 8.103 8.104000000000001 8.105 8.106 8.107 8.108 8.109 8.11 8.111 8.112 8.113 8.114 8.115 8.116 8.117 8.118 8.119 8.120000000000001 8.121 8.122 8.123 8.124 8.125 8.126 8.127 8.128 8.129 8.13 8.131 8.132 8.133000000000001 8.134 8.135 8.136000000000001 8.137 8.138 8.139 8.14 8.141 8.142 8.143 8.144 8.145 8.146 8.147 8.148 8.149000000000001 8.15 8.151 8.152000000000001 8.153 8.154 8.155 8.156 8.157 8.158 8.159 8.16 8.161 8.162 8.163 8.164 8.165000000000001 8.166 8.167 8.168000000000001 8.169 8.17 8.171 8.172 8.173 8.174 8.175 8.176 8.177 8.178 8.179
</pre>
end{sphinxVerbatim}
- more-to-come:
8.18 8.181000000000001 8.182 8.183 8.184000000000001 8.185 8.186 8.187 8.188 8.189 8.19 8.191 8.192 8.193 8.194 8.195 8.196 8.197000000000001 8.198 8.199 8.2 8.201 8.202 8.203 8.204 8.205 8.206 8.207 8.208 8.209 8.21 8.211 8.212 8.213000000000001 8.214 8.215 8.216 8.217 8.218 8.219 8.22 8.221 8.222 8.223 8.224 8.225 8.226 8.227 8.228 8.229000000000001 8.23 8.231 8.232 8.233 8.234 8.235 8.236 8.237 8.238 8.239 8.24 8.241 8.242 8.243 8.244 8.245000000000001 8.246 8.247 8.248 8.249 8.25 8.251 8.252 8.253 8.254 8.255 8.256 8.257 8.258000000000001 8.259 8.26 8.261000000000001 8.262 8.263 8.264 8.265 8.266 8.267 8.268 8.269 8.27 8.271 8.272 8.273 8.274000000000001 8.275 8.276 8.277000000000001 8.278 8.279 8.28 8.281 8.282 8.283 8.284 8.285 8.286 8.287 8.288 8.289 8.290000000000001 8.291 8.292 8.293000000000001 8.294 8.295 8.296 8.297 8.298 8.299 8.3 8.301 8.302 8.303 8.304 8.305 8.306000000000001 8.307 8.308 8.309000000000001 8.31 8.311 8.312 8.313 8.314 8.315 8.316 8.317 8.318 8.319 8.32 8.321 8.322000000000001 8.323 8.324 8.325 8.326 8.327 8.328 8.329 8.33 8.331 8.332 8.333 8.334 8.335 8.336 8.337 8.338000000000001 8.339 8.34 8.341 8.342 8.343 8.344 8.345 8.346 8.347 8.348 8.349 8.35 8.351 8.352 8.353 8.354000000000001 8.355 8.356 8.357 8.358 8.359 8.36 8.361 8.362 8.363 8.364 8.365 8.366 8.367 8.368 8.369 8.370000000000001 8.371 8.372 8.373 8.374 8.375 8.376 8.377 8.378 8.379 8.38 8.381 8.382 8.383000000000001 8.384 8.385 8.386000000000001 8.387 8.388 8.389 8.39 8.391 8.392 8.393 8.394 8.395 8.396 8.397 8.398 8.399000000000001 8.4 8.401 8.402000000000001 8.403 8.404 8.405 8.406 8.407 8.408 8.409 8.41 8.411 8.412 8.413 8.414 8.415000000000001 8.416 8.417 8.418000000000001 8.419 8.42 8.421 8.422 8.423 8.424 8.425 8.426 8.427 8.428 8.429 8.43 8.431000000000001 8.432 8.433 8.434000000000001 8.435 8.436 8.437 8.438 8.439 8.44 8.441 8.442 8.443 8.444 8.445 8.446 8.447000000000001 8.448 8.449 8.45 8.451 8.452 8.453 8.454 8.455 8.456 8.457 8.458 8.459 8.46 8.461 8.462 8.463000000000001 8.464 8.465 8.466 8.467 8.468 8.469 8.47 8.471 8.472 8.473 8.474 8.475 8.476 8.477 8.478 8.479000000000001 8.48 8.481 8.482 8.483 8.484 8.485 8.486 8.487 8.488 8.489 8.49 8.491 8.492 8.493 8.494 8.495000000000001 8.496 8.497 8.498 8.499 8.5 8.501 8.502 8.503 8.504 8.505 8.506 8.507 8.508000000000001 8.509 8.51 8.511000000000001 8.512 8.513 8.514 8.515 8.516 8.517 8.518 8.519 8.52 8.521 8.522 8.523 8.524000000000001 8.525 8.526 8.527000000000001 8.528 8.529 8.53 8.531 8.532 8.533 8.534 8.535 8.536 8.537 8.538 8.539 8.540000000000001 8.541 8.542 8.543000000000001 8.544 8.545 8.546 8.547 8.548 8.549 8.55 8.551 8.552 8.553 8.554 8.555 8.556000000000001 8.557 8.558 8.559000000000001 8.56 8.561 8.562 8.563 8.564 8.565 8.566 8.567 8.568 8.569 8.57 8.571 8.572000000000001 8.573 8.574 8.575000000000001 8.576 8.577 8.578 8.579 8.58
</pre>
end{sphinxVerbatim}
- more-to-come:
8.581 8.582 8.583 8.584 8.585 8.586 8.587 8.588000000000001 8.589 8.59 8.591 8.592 8.593 8.594 8.595 8.596 8.597 8.598 8.599 8.6 8.601 8.602 8.603 8.604000000000001 8.605 8.606 8.607 8.608 8.609 8.61 8.611 8.612 8.613 8.614 8.615 8.616 8.617 8.618 8.619 8.620000000000001 8.621 8.622 8.623 8.624 8.625 8.626 8.627 8.628 8.629 8.63 8.631 8.632 8.633000000000001 8.634 8.635 8.636000000000001 8.637 8.638 8.639 8.64 8.641 8.642 8.643 8.644 8.645 8.646 8.647 8.648 8.649000000000001 8.65 8.651 8.652000000000001 8.653 8.654 8.655 8.656 8.657 8.658 8.659 8.66 8.661 8.662 8.663 8.664 8.665000000000001 8.666 8.667 8.668000000000001 8.669 8.67 8.671 8.672 8.673 8.674 8.675 8.676 8.677 8.678 8.679 8.68 8.681000000000001 8.682 8.683 8.684000000000001 8.685 8.686 8.687 8.688 8.689 8.69 8.691 8.692 8.693 8.694 8.695 8.696 8.697000000000001 8.698 8.699 8.700000000000001 8.701 8.702 8.703 8.704 8.705 8.706 8.707 8.708 8.709 8.71 8.711 8.712 8.713000000000001 8.714 8.715 8.716 8.717 8.718 8.719 8.72 8.721 8.722 8.723 8.724 8.725
</pre>
end{sphinxVerbatim}
- more-to-come:
8.726 8.727 8.728 8.729000000000001 8.73 8.731 8.732 8.733 8.734 8.735 8.736 8.737 8.738 8.739 8.74 8.741 8.742 8.743 8.744 8.745000000000001 8.746 8.747 8.748 8.749 8.75 8.751 8.752 8.753 8.754 8.755 8.756 8.757 8.758000000000001 8.759 8.76 8.761000000000001 8.762 8.763 8.764 8.765 8.766 8.767 8.768 8.769 8.77 8.771 8.772 8.773 8.774000000000001 8.775 8.776 8.777000000000001 8.778 8.779 8.78 8.781 8.782 8.783 8.784 8.785 8.786 8.787 8.788 8.789 8.790000000000001 8.791 8.792 8.793000000000001 8.794 8.795 8.796 8.797 8.798 8.799 8.8 8.801 8.802 8.803 8.804 8.805 8.806000000000001 8.807 8.808 8.809000000000001 8.81 8.811 8.812 8.813 8.814 8.815 8.816 8.817 8.818 8.819 8.82 8.821 8.822000000000001 8.823 8.824 8.825000000000001 8.826 8.827 8.828 8.829 8.83 8.831 8.832 8.833 8.834 8.835 8.836 8.837 8.838000000000001 8.839 8.84 8.841 8.842 8.843 8.844 8.845 8.846 8.847 8.848 8.849 8.85 8.851 8.852 8.853 8.854000000000001 8.855 8.856 8.857 8.858 8.859 8.86 8.861 8.862 8.863 8.864 8.865 8.866 8.867 8.868 8.869 8.870000000000001 8.871 8.872 8.873 8.874 8.875 8.876 8.877 8.878 8.879 8.88 8.881 8.882 8.883000000000001 8.884 8.885 8.886000000000001 8.887 8.888 8.889 8.89 8.891 8.892 8.893 8.894 8.895 8.896 8.897 8.898 8.899000000000001 8.9 8.901 8.902000000000001 8.903 8.904 8.905 8.906 8.907 8.908 8.909 8.91 8.911 8.912 8.913 8.914 8.915000000000001 8.916 8.917 8.918000000000001 8.919 8.92 8.921 8.922 8.923 8.924 8.925 8.926 8.927 8.928 8.929 8.93 8.931000000000001 8.932 8.933 8.934000000000001 8.935 8.936 8.937 8.938 8.939 8.94 8.941 8.942 8.943 8.944 8.945 8.946 8.947000000000001 8.948 8.949 8.950000000000001 8.951 8.952 8.953 8.954 8.955 8.956 8.957 8.958 8.959 8.96 8.961 8.962 8.963000000000001 8.964 8.965 8.966 8.967 8.968 8.969 8.97 8.971 8.972 8.973 8.974 8.975 8.976 8.977 8.978 8.979000000000001 8.98 8.981 8.982 8.983 8.984 8.985 8.986 8.987 8.988 8.989 8.99 8.991 8.992 8.993 8.994 8.995000000000001 8.996 8.997 8.998 8.999 9.0 9.001 9.002 9.003 9.004 9.005 9.006 9.007 9.008000000000001 9.009 9.01 9.011000000000001 9.012 9.013 9.014 9.015 9.016 9.017 9.018 9.019 9.02 9.021 9.022 9.023 9.024000000000001 9.025 9.026 9.027000000000001 9.028 9.029 9.03 9.031 9.032 9.033 9.034 9.035 9.036 9.037 9.038 9.039 9.040000000000001 9.041 9.042 9.043000000000001 9.044 9.045 9.046 9.047 9.048 9.049 9.05 9.051 9.052 9.053 9.054 9.055 9.056000000000001 9.057 9.058 9.059000000000001 9.06 9.061 9.062 9.063 9.064 9.065 9.066 9.067 9.068 9.069 9.07 9.071 9.072000000000001 9.073 9.074 9.075000000000001 9.076 9.077 9.078 9.079 9.08 9.081 9.082 9.083 9.084 9.085 9.086 9.087 9.088000000000001 9.089 9.09 9.091 9.092 9.093 9.094 9.095 9.096 9.097 9.098 9.099 9.1 9.101 9.102 9.103 9.104000000000001 9.105 9.106 9.107 9.108 9.109 9.11 9.111 9.112 9.113 9.114 9.115 9.116 9.117 9.118 9.119 9.120000000000001 9.121 9.122 9.123 9.124 9.125
</pre>
end{sphinxVerbatim}
- more-to-come:
9.126 9.127 9.128 9.129 9.13 9.131 9.132 9.133000000000001 9.134 9.135 9.136000000000001 9.137 9.138 9.139 9.14 9.141 9.142 9.143 9.144 9.145 9.146 9.147 9.148 9.149000000000001 9.15 9.151 9.152000000000001 9.153 9.154 9.155 9.156 9.157 9.158 9.159 9.16 9.161 9.162 9.163 9.164 9.165000000000001 9.166 9.167 9.168000000000001 9.169 9.17 9.171 9.172 9.173 9.174 9.175 9.176 9.177 9.178 9.179 9.18 9.181000000000001 9.182 9.183 9.184000000000001 9.185 9.186 9.187 9.188 9.189 9.19 9.191 9.192 9.193 9.194 9.195 9.196 9.197000000000001 9.198 9.199 9.200000000000001 9.201 9.202 9.203 9.204 9.205 9.206 9.207 9.208 9.209 9.21 9.211 9.212 9.213000000000001 9.214 9.215 9.216000000000001 9.217 9.218 9.219 9.22 9.221 9.222 9.223 9.224 9.225 9.226 9.227 9.228 9.229000000000001 9.23 9.231 9.232 9.233 9.234 9.235 9.236 9.237 9.238 9.239 9.24 9.241 9.242 9.243 9.244 9.245000000000001 9.246 9.247 9.248 9.249 9.25 9.251 9.252 9.253 9.254 9.255 9.256 9.257 9.258000000000001 9.259 9.26 9.261000000000001 9.262 9.263 9.264 9.265 9.266 9.267 9.268 9.269 9.27
</pre>
end{sphinxVerbatim}
- more-to-come:
9.271 9.272 9.273 9.274000000000001 9.275 9.276 9.277000000000001 9.278 9.279 9.28 9.281 9.282 9.283 9.284 9.285 9.286 9.287 9.288 9.289 9.290000000000001 9.291 9.292 9.293000000000001 9.294 9.295 9.296 9.297 9.298 9.299 9.3 9.301 9.302 9.303 9.304 9.305 9.306000000000001 9.307 9.308 9.309000000000001 9.31 9.311 9.312 9.313 9.314 9.315 9.316 9.317 9.318 9.319 9.32 9.321 9.322000000000001 9.323 9.324 9.325000000000001 9.326 9.327 9.328 9.329 9.33 9.331 9.332 9.333 9.334 9.335 9.336 9.337 9.338000000000001 9.339 9.34 9.341000000000001 9.342 9.343 9.344 9.345 9.346 9.347 9.348 9.349 9.35 9.351 9.352 9.353 9.354000000000001 9.355 9.356 9.357 9.358 9.359 9.36 9.361 9.362 9.363 9.364 9.365 9.366 9.367 9.368 9.369 9.370000000000001 9.371 9.372 9.373 9.374 9.375 9.376 9.377 9.378 9.379 9.38 9.381 9.382 9.383000000000001 9.384 9.385 9.386000000000001 9.387 9.388 9.389 9.39 9.391 9.392 9.393 9.394 9.395 9.396 9.397 9.398 9.399000000000001 9.4 9.401 9.402000000000001 9.403 9.404 9.405 9.406 9.407 9.408 9.409 9.41 9.411 9.412 9.413 9.414 9.415000000000001 9.416 9.417 9.418000000000001 9.419 9.42 9.421 9.422 9.423 9.424 9.425 9.426 9.427 9.428 9.429 9.43 9.431000000000001 9.432 9.433 9.434000000000001 9.435 9.436 9.437 9.438 9.439 9.44 9.441 9.442 9.443 9.444 9.445 9.446 9.447000000000001 9.448 9.449 9.450000000000001 9.451 9.452 9.453 9.454 9.455 9.456 9.457 9.458 9.459 9.46 9.461 9.462 9.463000000000001 9.464 9.465 9.466000000000001 9.467 9.468 9.469 9.47 9.471 9.472 9.473 9.474 9.475 9.476 9.477 9.478 9.479000000000001 9.48 9.481 9.482 9.483 9.484 9.485 9.486 9.487 9.488 9.489 9.49 9.491 9.492 9.493 9.494 9.495000000000001 9.496 9.497 9.498 9.499 9.5 9.501 9.502 9.503 9.504 9.505 9.506 9.507 9.508000000000001 9.509 9.51 9.511000000000001 9.512 9.513 9.514 9.515 9.516 9.517 9.518 9.519 9.52 9.521 9.522 9.523 9.524000000000001 9.525 9.526 9.527000000000001 9.528 9.529 9.53 9.531 9.532 9.533 9.534 9.535 9.536 9.537 9.538 9.539 9.540000000000001 9.541 9.542 9.543000000000001 9.544 9.545 9.546 9.547 9.548 9.549 9.55 9.551 9.552 9.553 9.554 9.555 9.556000000000001 9.557 9.558 9.559000000000001 9.56 9.561 9.562 9.563 9.564 9.565 9.566 9.567 9.568 9.569 9.57 9.571 9.572000000000001 9.573 9.574 9.575000000000001 9.576 9.577 9.578 9.579 9.58 9.581 9.582 9.583 9.584 9.585 9.586 9.587 9.588000000000001 9.589 9.59 9.591000000000001 9.592 9.593 9.594 9.595 9.596 9.597 9.598 9.599 9.6 9.601 9.602 9.603 9.604000000000001 9.605 9.606 9.607 9.608 9.609 9.61 9.611 9.612 9.613 9.614 9.615 9.616 9.617 9.618 9.619 9.620000000000001 9.621 9.622 9.623 9.624 9.625 9.626 9.627 9.628 9.629 9.63 9.631 9.632 9.633000000000001 9.634 9.635 9.636000000000001 9.637 9.638 9.639 9.64 9.641 9.642 9.643 9.644 9.645 9.646 9.647 9.648 9.649000000000001 9.65 9.651 9.652000000000001 9.653 9.654 9.655 9.656 9.657 9.658 9.659 9.66 9.661 9.662 9.663 9.664 9.665000000000001 9.666 9.667 9.668000000000001 9.669 9.67 9.671
</pre>
end{sphinxVerbatim}
- more-to-come:
9.672 9.673 9.674 9.675 9.676 9.677 9.678 9.679 9.68 9.681000000000001 9.682 9.683 9.684000000000001 9.685 9.686 9.687 9.688 9.689 9.69 9.691 9.692 9.693 9.694 9.695 9.696 9.697000000000001 9.698 9.699 9.700000000000001 9.701 9.702 9.703 9.704 9.705 9.706 9.707 9.708 9.709 9.71 9.711 9.712 9.713000000000001 9.714 9.715 9.716000000000001 9.717 9.718 9.719 9.72 9.721 9.722 9.723 9.724 9.725 9.726 9.727 9.728 9.729000000000001 9.73 9.731 9.732 9.733 9.734 9.735 9.736 9.737 9.738 9.739 9.74 9.741 9.742 9.743 9.744 9.745000000000001 9.746 9.747 9.748 9.749 9.75 9.751 9.752 9.753 9.754 9.755 9.756 9.757 9.758000000000001 9.759 9.76 9.761000000000001 9.762 9.763 9.764 9.765 9.766 9.767 9.768 9.769 9.77 9.771 9.772 9.773 9.774000000000001 9.775 9.776 9.777000000000001 9.778 9.779 9.78 9.781 9.782 9.783 9.784 9.785 9.786 9.787 9.788 9.789 9.790000000000001 9.791 9.792 9.793000000000001 9.794 9.795 9.796 9.797 9.798 9.799 9.8 9.801 9.802 9.803 9.804 9.805 9.806000000000001 9.807 9.808 9.809000000000001 9.81 9.811 9.812 9.813 9.814 9.815 9.816
</pre>
end{sphinxVerbatim}
- more-to-come:
9.817 9.818 9.819 9.82 9.821 9.822000000000001 9.823 9.824 9.825000000000001 9.826 9.827 9.828 9.829 9.83 9.831 9.832 9.833 9.834 9.835 9.836 9.837 9.838000000000001 9.839 9.84 9.841000000000001 9.842 9.843 9.844 9.845 9.846 9.847 9.848 9.849 9.85 9.851 9.852 9.853 9.854000000000001 9.855 9.856 9.857 9.858 9.859 9.86 9.861 9.862 9.863 9.864 9.865 9.866 9.867 9.868 9.869 9.870000000000001 9.871 9.872 9.873 9.874 9.875 9.876 9.877 9.878 9.879 9.88 9.881 9.882 9.883000000000001 9.884 9.885 9.886000000000001 9.887 9.888 9.889 9.89 9.891 9.892 9.893 9.894 9.895 9.896 9.897 9.898 9.899000000000001 9.9 9.901 9.902000000000001 9.903 9.904 9.905 9.906 9.907 9.908 9.909 9.91 9.911 9.912 9.913 9.914 9.915000000000001 9.916 9.917 9.918000000000001 9.919 9.92 9.921 9.922 9.923 9.924 9.925 9.926 9.927 9.928 9.929 9.93 9.931000000000001 9.932 9.933 9.934000000000001 9.935 9.936 9.937 9.938 9.939 9.94 9.941 9.942 9.943 9.944 9.945 9.946 9.947000000000001 9.948 9.949 9.950000000000001 9.951 9.952 9.953 9.954 9.955 9.956 9.957 9.958 9.959 9.96 9.961 9.962 9.963000000000001 9.964 9.965 9.966000000000001 9.967 9.968 9.969 9.97 9.971 9.972 9.973 9.974 9.975 9.976 9.977 9.978 9.979000000000001 9.98 9.981 9.982000000000001 9.983 9.984 9.985 9.986 9.987 9.988 9.989 9.99 9.991 9.992 9.993 9.994 9.995000000000001 9.996 9.997 9.998 9.999
</pre>
end{sphinxVerbatim}
CPU times: user 3.98 s, sys: 49 ms, total: 4.02 s
Wall time: 7.71 s
stages = 1
a = [[1]]
b = [1]
c = [1]
astar = 1
Midpoint rule:
stages = 1
a = [[0.5]]
b = [1]
c = [0.5]
astar = 0.5
class sdirk2: #order 3
p = (3 - sqrt(3))/6
stages = 2
a = [[p, 0],
[1 - 2*p, p]]
b = [1/2, 1/2]
c = [p, 1 - p]
astar = p
class sdirk5: #order 4
stages = 5
a = [[1/4, 0, 0, 0, 0],
[1/2, 1/4, 0, 0, 0],
[17/50,-1/25, 1/4, 0, 0],
c = [1/4, 3/4, 11/20, 1/2, 1]
astar = 1/4
initial_cond = None, t0 = 0, tend = 2,
nsamples = 10):
if initial_cond:
gfu.Set(initial_cond)
cnt = 0; time = t0
while time < tend - 0.5 * dt:
Mu0.data = m.mat * gfu.vec
rhsi.data = Mu0
for j in range(0,i):
gfu.Set(uD,BND)
ui.data += invmstar * rhsi
k[i].data = - a.mat * ui
t.Set(time+dt)
gfu.Set(uD,BND)
Mu0.data -= m.mat * gfu.vec
gfu.vec.data += invmass * Mu0
print("\r",time,end="")
if cnt % sample_int == 0:
cnt += 1; time = cnt * dt
return gfut
[33]:
order = 3,
- more-to-come:
0 0.25 0.5 0.75 1.0 1.25 1.5 1.75 2.0 2.25 2.5 2.75 3.0 3.25 3.5 3.75 4.0 4.25 4.5 4.75 5.0 5.25 5.5 5.75 6.0
</pre>
end{sphinxVerbatim}
- more-to-come:
6.25 6.5 6.75 7.0 7.25 7.5 7.75 8.0 8.25 8.5 8.75 9.0 9.25 9.5 9.75
</pre>
end{sphinxVerbatim}
[33]:
Tasks
