6.1.3 Reissner-Mindlin plate¶
To avoid shear locking when the thickness \(t\) becomes small several methods and elements have been proposed. We discuss two approaches:
Mixed Interpolation of Tensorial Components (MITC)¶
Set up benchmark example with exact solution. Young modulus \(E\), Poisson ratio \(\nu\), shear correction factor \(\kappa\) and corresponding Lamè parameters \(\mu\) and \(\lambda\). Geometry parameters are given by thickness \(t\) and radius \(R\).
E, nu, k = 10.92, 0.3, 5/6
mu  = E/(2*(1+nu))
lam = E*nu/(1-nu**2)
#shearing modulus
G = E/(2*(1+nu))
t = 0.1
R = 5
#force
fz = 1
order = 1
sg = SplineGeometry()
mesh.Curve(order)
r = sqrt(x**2+y**2)
xi = r/R
Db = E*t**3/(12*(1-nu**2))
clamped = True
#Draw(w_s_ex, mesh, "w_s_ex")
Draw(w_c_ex, mesh, "w_c_ex")
if clamped:
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.VectorH1'>, maybe there is a typo?
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.H1'>, maybe there is a typo?
Adding interpolation (reduction) operator \(\boldsymbol{R}:[H^1_0(\Omega)]^2\to H(\text{curl})\). Spaces are chosen according to [Brezzi, Fortin and Stenberg. Error analysis of mixed-interpolated elements for Reissner-Mindlin plates. Mathematical Models and Methods in Applied Sciences 1, 2 (1991), 125-151.]
f += -fz*du*dx
def SolveBVP():
    fes.Update()
    gfsol.Update()
        gfsol.vec.data = inv * f.vec
l = []
for i in range(5):
    print("i = ", i)
    SolveBVP()
    if clamped:
    print("err = ", err)
    l.append ( (fes.ndof, err ))
i =  0
err =  0.5595598334579744
i =  1
err =  0.11654484017078312
i =  2
err =  0.02144878939779651
i =  3
err =  0.0048565355609730375
i =  4
err =  0.0011748158852093625
plt.yscale('log')
plt.xscale('log')
plt.xlabel("ndof")
plt.ylabel("relative error")
ndof,err = zip(*l)
plt.plot(ndof,err, "-*")
plt.ion()
TDNNS method¶
def CMatInv(mat, E, nu):
mesh.Curve(order)
Instead of using Lagrangian elements together with an interpolation operator we can directly use H(curl) for the rotation \(\beta\).
order=1
if clamped:
Use the TDNNS method with the stress (bending) tensor \(\boldsymbol{\sigma}\) as proposed in [Pechstein and Schöberl. The TDNNS method for Reissner-Mindlin plates. Numerische Mathematik 137, 3 (2017), 713-740] \begin{align*} &\mathcal{L}(u,\beta,\boldsymbol{\sigma})=-\frac{6}{t^3}\|\boldsymbol{\sigma}\|^2_{\mathcal{C}^{-1}} + \langle \boldsymbol{\sigma}, \nabla \beta\rangle + \frac{tkG}{2}\|\nabla u-\beta\|^2 -\int_{\Omega} f\cdot u\,dx\\ &\langle \boldsymbol{\sigma}, \nabla \beta\rangle:= \sum_{T\in\mathcal{T}}\int_T\boldsymbol{\sigma}:\nabla \beta\,dx -\int_{\partial T}\boldsymbol{\sigma}_{nn}\beta_n\,ds \end{align*}
f += -fz*du*dx
def SolveBVP():
    fes.Update()
    gfsol.Update()
l = []
for i in range(5):
    print("i = ", i)
    SolveBVP()
    if clamped:
i =  0
err =  0.4806915268060298
i =  1
err =  0.1660840390786989
i =  2
err =  0.04302102327861157
i =  3
err =  0.01100222868646325
i =  4
err =  0.002887933514209067
plt.yscale('log')
plt.xscale('log')
plt.xlabel("ndof")
ndof,err = zip(*l)
plt.ion()
