2.10 Dual basis functions¶
We use dual basis functions to define interpolation operators, define transfer operators between different finite element spaces, and auxiliary space preconditioners.
Canonical interpolation¶
The NGSolve 'Set' function does local projection, and simple averaging. In particular, this does not respect point values in mesh vertices.
func = x*x*x*x
gfu.Set(func)
Draw (gfu)
print (gfu.vec)
 -0.0223792
 0.991843
 0.977621
 -0.00815655
 3.34984
 2.19912
 3.34984
       2
 0.00660131
 1.39013e-14
 0.00660131
 -3.19744e-14
 3.34984
 -1.80088
 -2.17601
 1.82399
Most NGSolve finite element spaces provide now a "dual" operator, which delivers the moments (i.e. the dual space basis functions) instead of function values. The integrals over faces, edges and also vertices are defined by co-dimension 1 (=BND), co-dimension 2 (=BBND) or co-dimension 3 (=BBBND) integrals over the volume elements. We define a variational problem for canonical interpolation:
vdual = v.Operator("dual")
    u*vdual*dx(element_vb=BBND)
print (gfu.vec)
Draw (gfu);
       1
       2
     3.6
       2
 -6.93335e-32
 -1.66533e-15
     3.6
      -2
      -2
       2
The vertex degrees of freedom vanish for edge and element basis functions, and the edge degrees of freedom vanish for element basis functions, but not vice-versa. Thus, the obtained matrix A is block-triangular:
import scipy.sparse as sp
plt.spy(A)
/usr/lib/python3/dist-packages/scipy/__init__.py:146: UserWarning: A NumPy version >=1.17.3 and <1.25.0 is required for this version of SciPy (detected version 1.26.2
print (vblocks)
print (eblocks)
print (fblocks)
vinv.Smooth(gfu.vec, f.vec)
einv.Smooth(gfu.vec, f.vec)
finv.Smooth(gfu.vec, f.vec)
print (gfu.vec)
[(0,), (1,), (2,), (3,)]
[(14,), (15,)]
       1
       2
     3.6
       2
 -6.93335e-32
 -1.66533e-15
     3.6
      -2
      -2
       2
feshdiv = HDiv(mesh, order=2)
gfuh1 = GridFunction(fesh1)
gfuh1.Set ( (x*x,y*y) )
ahdiv = BilinearForm(feshdiv)
u,v = feshdiv.TnT()
uh1 = fesh1.TrialFunction()
ahdiv.Assemble()
amixed.Assemble()
Draw (gfuh1)
Draw (gfuhdiv)
        self.mat = mat
    def CreateRowVector(self):
    def CreateColVector(self):
    def Mult(self, x, y):
        # y[:] = 0
        y.data = self.einv * x
        y.data += finv * self.res
    def MultTrans(self, x, y):
        y.data = self.finv.T * x
        y.data += einv.T * self.res
The DG discretization:
order=4
u,v = fesDG.TnT()
aDG = BilinearForm(fesDG)
jump_u = u-u.Other()
jump_v = v-v.Other()
alpha = 4
aDG += grad(u)*grad(v) * dx
aDG.Assemble()
fDG = LinearForm(fesDG)
fDG += 1*v * dx
fDG.Assemble()
gfuDG = GridFunction(fesDG)
u,v = fesH1.TnT()
aH1 = BilinearForm(fesH1)
aH1 += grad(u)*grad(v)*dx
aH1.Assemble()
<ngsolve.comp.BilinearForm at 0x7f184a477530>
           maxsteps=200)
Draw (gfuDG)
CG iteration 1, residual = 0.2532119733219237
CG iteration 2, residual = 0.03283242148303782
CG iteration 3, residual = 0.008130862525680582
CG iteration 4, residual = 0.0034342488110603404
CG iteration 5, residual = 0.0011783456811530469
CG iteration 6, residual = 0.0009046659695335802
CG iteration 7, residual = 0.000916100208852208
CG iteration 8, residual = 0.0010697558880604435
CG iteration 9, residual = 0.0007971399933259297
CG iteration 10, residual = 0.0006627896366674045
CG iteration 11, residual = 0.0005095344857658781
CG iteration 12, residual = 0.00042466444937132926
CG iteration 13, residual = 0.0003261702302928008
CG iteration 14, residual = 0.00034395529498089107
CG iteration 15, residual = 0.00027105251267776437
CG iteration 16, residual = 0.0002333688165618062
CG iteration 17, residual = 0.00017983771681640421
CG iteration 18, residual = 0.00013566763832044724
CG iteration 19, residual = 8.96996583630819e-05
CG iteration 20, residual = 7.58890643878234e-05
CG iteration 21, residual = 6.938043743084345e-05
CG iteration 22, residual = 6.381887596483333e-05
CG iteration 23, residual = 5.1802080191084895e-05
CG iteration 24, residual = 4.381763129367677e-05
CG iteration 25, residual = 3.6407249876793836e-05
CG iteration 26, residual = 2.9808360832851394e-05
CG iteration 27, residual = 2.9223985181307222e-05
CG iteration 28, residual = 2.908952039243108e-05
CG iteration 29, residual = 2.6390001567258028e-05
CG iteration 30, residual = 2.0442446246667756e-05
CG iteration 31, residual = 1.7799471861373268e-05
CG iteration 32, residual = 1.4280353976732058e-05
CG iteration 33, residual = 1.1724086434440519e-05
CG iteration 34, residual = 1.0399082092347682e-05
CG iteration 35, residual = 9.357450254587377e-06
CG iteration 36, residual = 8.046132496256155e-06
CG iteration 37, residual = 6.434972748061578e-06
CG iteration 38, residual = 4.977423074804003e-06
CG iteration 39, residual = 4.189516701918238e-06
CG iteration 40, residual = 3.879825859447346e-06
CG iteration 41, residual = 3.4249941633553082e-06
CG iteration 42, residual = 3.1039505254081494e-06
CG iteration 43, residual = 2.6848114735436483e-06
CG iteration 44, residual = 2.1289592891351334e-06
CG iteration 45, residual = 1.7175875308398687e-06
CG iteration 46, residual = 1.5033515289258833e-06
CG iteration 47, residual = 1.4944954266967648e-06
CG iteration 48, residual = 1.4120180027628047e-06
CG iteration 49, residual = 1.186066878709251e-06
CG iteration 50, residual = 9.384364837569825e-07
CG iteration 51, residual = 7.855316166902334e-07
CG iteration 52, residual = 6.514966222954105e-07
CG iteration 53, residual = 5.847843124222763e-07
CG iteration 54, residual = 5.642748143010098e-07
CG iteration 55, residual = 4.856169352654685e-07
CG iteration 56, residual = 3.649036054484345e-07
CG iteration 57, residual = 2.873227625307465e-07
CG iteration 58, residual = 2.524271052094064e-07
CG iteration 59, residual = 2.1120183910233848e-07
CG iteration 60, residual = 1.8157945371823859e-07
CG iteration 61, residual = 1.6765792567393337e-07
CG iteration 62, residual = 1.353430987382327e-07
CG iteration 63, residual = 1.0740625460954846e-07
CG iteration 64, residual = 8.692499337659955e-08
CG iteration 65, residual = 6.991024642038257e-08
CG iteration 66, residual = 6.16682084855959e-08
CG iteration 67, residual = 5.426467057609544e-08
CG iteration 68, residual = 4.49261663046703e-08
CG iteration 69, residual = 3.427094557093681e-08
CG iteration 70, residual = 2.7367952358732957e-08
CG iteration 71, residual = 2.2107937585506133e-08
CG iteration 72, residual = 1.8685912951580074e-08
CG iteration 73, residual = 1.7316902148532555e-08
CG iteration 74, residual = 1.5508098318231457e-08
CG iteration 75, residual = 1.3238529365866558e-08
CG iteration 76, residual = 9.994763302413405e-09
CG iteration 77, residual = 7.883313340296864e-09
CG iteration 78, residual = 6.787391707705761e-09
CG iteration 79, residual = 6.2386312899251755e-09
CG iteration 80, residual = 5.761549942678083e-09
CG iteration 81, residual = 4.886605168755902e-09
CG iteration 82, residual = 3.748601507794972e-09
CG iteration 83, residual = 2.748450710450997e-09
CG iteration 84, residual = 2.280167902453853e-09
CG iteration 85, residual = 2.0226924127497514e-09
CG iteration 86, residual = 1.870225656493882e-09
CG iteration 87, residual = 1.5609299623708745e-09
CG iteration 88, residual = 1.226978329801002e-09
CG iteration 89, residual = 9.112900467015315e-10
CG iteration 90, residual = 7.127248837802485e-10
CG iteration 91, residual = 5.937509223166988e-10
CG iteration 92, residual = 5.514133749732149e-10
CG iteration 93, residual = 4.99861705592941e-10
CG iteration 94, residual = 4.1235246361362973e-10
CG iteration 95, residual = 3.2659093904527497e-10
CG iteration 96, residual = 2.59741697767188e-10
CG iteration 97, residual = 2.1776709811078984e-10
CG iteration 98, residual = 2.0062671288370197e-10
CG iteration 99, residual = 1.8661150677647312e-10
CG iteration 100, residual = 1.6294151882309048e-10
CG iteration 101, residual = 1.292305272795395e-10
CG iteration 102, residual = 1.0140602126749115e-10
CG iteration 103, residual = 8.173407188688868e-11
CG iteration 104, residual = 7.231423959194173e-11
CG iteration 105, residual = 6.684768165889317e-11
CG iteration 106, residual = 5.927649331931815e-11
CG iteration 107, residual = 4.760270249480972e-11
CG iteration 108, residual = 3.8318136650714166e-11
CG iteration 109, residual = 2.9784066186200715e-11
CG iteration 110, residual = 2.522649347861087e-11
CG iteration 111, residual = 2.386805858899227e-11
CG iteration 112, residual = 2.2875012916469928e-11
CG iteration 113, residual = 2.0107565538656508e-11
CG iteration 114, residual = 1.5540211933240994e-11
CG iteration 115, residual = 1.2320621983746366e-11
CG iteration 116, residual = 1.0375202881164575e-11
CG iteration 117, residual = 1.0171374838982774e-11
CG iteration 118, residual = 9.38724657679695e-12
CG iteration 119, residual = 8.512224847179786e-12
CG iteration 120, residual = 7.04037664257042e-12
CG iteration 121, residual = 5.349670207997328e-12
CG iteration 122, residual = 4.204000458221021e-12
CG iteration 123, residual = 3.834038585775854e-12
CG iteration 124, residual = 3.622087498071282e-12
CG iteration 125, residual = 3.068633621563561e-12
CG iteration 126, residual = 2.4624857466264912e-12
CG iteration 127, residual = 1.893749894533446e-12
CG iteration 128, residual = 1.544521266178747e-12
CG iteration 129, residual = 1.3365880429646455e-12
CG iteration 130, residual = 1.2596968251841935e-12
CG iteration 131, residual = 1.1246380127983996e-12
CG iteration 132, residual = 9.04419618085342e-13
CG iteration 133, residual = 6.755352967429438e-13
CG iteration 134, residual = 5.478309665192225e-13
CG iteration 135, residual = 4.587901465643357e-13
CG iteration 136, residual = 4.2075732254965443e-13
CG iteration 137, residual = 3.8906948954042277e-13
CG iteration 138, residual = 3.457298531169644e-13
CG iteration 139, residual = 2.6597876805310234e-13
CG iteration 140, residual = 2.111743198810676e-13
