This page was generated from unit-2.1.4-bddc/bddc.ipynb.
2.1.4 Element-wise BDDC Preconditioner¶
Let us start with a simple description of the element-wise BDDC in the context of Lagrange finite element space \(V\). Here the BDDC preconditioner is constructed on an auxiliary space \(\widetilde{V}\) obtained by connecting only element vertices (leaving edge and face shape functions discontinuous). Although larger, the auxiliary space allows local elimination of edge and face variables. Hence an analogue of the original matrix \(A\) on this space, named \(\widetilde A\), is less expensive to invert. This inverse is used to construct a preconditioner for \(A\) as follows:
Here, \(R\) is the averaging operator for the discontinuous edge and face variables.
SetHeapSize(100*1000*1000)
Built-in options¶
Effect of condensation¶
    c = Preconditioner(a, "bddc")
lams = TestPreconditioner(5)
 1.00054
 1.03405
 1.09891
  4.48943
 4.60085
 4.79194
 1.00023
 1.02753
 1.08363
  4.06546
 4.12581
 4.22957
Tuning the auxiliary space¶
wb_fulledges  |
wb_withedges  |
2D  |
3D  |
True  |
any value  |
all  |
all  |
False/Undefined  |
Undefined  |
none  |
first  |
False/Undefined  |
False  |
none  |
none  |
False/Undefined  |
True  |
first  |
first  |
                          wb_withedges=False)
 1.00106
 1.07034
 1.22031
  25.4058
  25.406
 26.9095
Customize¶
fes = H1(mesh, order=10)
for ed in mesh.edges:
    dofs = fes.GetDofNrs(ed)
    for d in dofs:
max(lams)/min(lams)
9.989385163105972
max(lams)/min(lams)
13.974958343966495
p = 5
         wb_withedges=False)
print("NDOF = ", fes.ndof)
f += v*dx
               pre=pre, maxsteps=500)
Draw(gfu)
NDOF =  839901
WARNING: kwarg 'coarsetype' is an undocumented flags option for class <class 'ngsolve.comp.Preconditioner'>, maybe there is a typo?
CG iteration 1, residual = 0.721795311536073
CG iteration 2, residual = 0.3050248203792489
CG iteration 3, residual = 0.274905524314227
CG iteration 4, residual = 0.32548361283332405
CG iteration 5, residual = 0.31977261202262147
CG iteration 6, residual = 0.24005556840618233
CG iteration 7, residual = 0.1837356649859674
CG iteration 8, residual = 0.1488759660178082
CG iteration 9, residual = 0.11776205172130365
CG iteration 10, residual = 0.09415746715001201
CG iteration 11, residual = 0.0700361921158144
CG iteration 12, residual = 0.05337434710285167
CG iteration 13, residual = 0.04417390984849428
CG iteration 14, residual = 0.0361702555138032
CG iteration 15, residual = 0.027632823230957865
CG iteration 16, residual = 0.021697513734227618
CG iteration 17, residual = 0.018137178359608177
CG iteration 18, residual = 0.014942565945605458
CG iteration 19, residual = 0.011867869904081698
CG iteration 20, residual = 0.008882592897356042
CG iteration 21, residual = 0.0068628010773285255
CG iteration 22, residual = 0.005164356408633731
CG iteration 23, residual = 0.003953665409810004
CG iteration 24, residual = 0.0030361178842279557
CG iteration 25, residual = 0.002382480626937583
CG iteration 26, residual = 0.001890013420182115
CG iteration 27, residual = 0.0015173967401730364
CG iteration 28, residual = 0.0011513838097701216
CG iteration 29, residual = 0.0009015669397151701
CG iteration 30, residual = 0.0007164959640586661
CG iteration 31, residual = 0.0005663664655473015
CG iteration 32, residual = 0.0004327728364206831
CG iteration 33, residual = 0.00033534779198470964
CG iteration 34, residual = 0.00026236876368010035
CG iteration 35, residual = 0.0002025651066229909
CG iteration 36, residual = 0.00016357418064306126
CG iteration 37, residual = 0.00013001522985554335
CG iteration 38, residual = 9.82793584558556e-05
CG iteration 39, residual = 7.620034796382566e-05
CG iteration 40, residual = 6.005682339732856e-05
CG iteration 41, residual = 4.736199375016172e-05
CG iteration 42, residual = 3.7069212392418045e-05
CG iteration 43, residual = 2.8770109497736518e-05
CG iteration 44, residual = 2.2259449032377583e-05
CG iteration 45, residual = 1.6972553778944975e-05
CG iteration 46, residual = 1.3339826042666144e-05
CG iteration 47, residual = 1.0603311215525566e-05
CG iteration 48, residual = 8.358173607170556e-06
CG iteration 49, residual = 6.421571181067149e-06
CG iteration 50, residual = 5.002154307923296e-06
CG iteration 51, residual = 3.9251934348426155e-06
CG iteration 52, residual = 3.2507726458048995e-06
CG iteration 53, residual = 2.8875457395768094e-06
CG iteration 54, residual = 2.1088210086146935e-06
CG iteration 55, residual = 1.6599724028029384e-06
CG iteration 56, residual = 1.2836468983663216e-06
CG iteration 57, residual = 9.705292652866658e-07
CG iteration 58, residual = 7.565040070221954e-07
CG iteration 59, residual = 5.908946954115054e-07
CG iteration 60, residual = 4.715131313500878e-07
CG iteration 61, residual = 4.2008178474156337e-07
CG iteration 62, residual = 3.2425366702823994e-07
CG iteration 63, residual = 2.430916512779962e-07
CG iteration 64, residual = 1.8660972813021617e-07
CG iteration 65, residual = 1.4662408310670435e-07
CG iteration 66, residual = 1.1712634141464733e-07
CG iteration 67, residual = 9.820589992689195e-08
CG iteration 68, residual = 8.291389628415612e-08
CG iteration 69, residual = 6.32389434070888e-08
CG iteration 70, residual = 4.847670135390706e-08
CG iteration 71, residual = 3.705275822445814e-08
CG iteration 72, residual = 2.8281705580484077e-08
CG iteration 73, residual = 2.1749582577744562e-08
CG iteration 74, residual = 1.6588037835311124e-08
CG iteration 75, residual = 1.2866392531862413e-08
CG iteration 76, residual = 9.922601010330138e-09
CG iteration 77, residual = 7.684698545897614e-09
CG iteration 78, residual = 5.878719837221976e-09
CG iteration 79, residual = 4.627362768006876e-09
CG iteration 80, residual = 3.7947521226005585e-09
CG iteration 81, residual = 3.1645356820672928e-09
CG iteration 82, residual = 2.424101938524715e-09
CG iteration 83, residual = 1.826783356506388e-09
CG iteration 84, residual = 1.4362675528247627e-09
CG iteration 85, residual = 1.087516322635841e-09
CG iteration 86, residual = 8.26506857432254e-10
CG iteration 87, residual = 6.490280126146812e-10
CG iteration 88, residual = 5.013804907474708e-10
CG iteration 89, residual = 3.8800638759863304e-10
CG iteration 90, residual = 2.9675740613269335e-10
CG iteration 91, residual = 2.2618979268356935e-10
CG iteration 92, residual = 1.7835526575498935e-10
CG iteration 93, residual = 1.5156687347447966e-10
CG iteration 94, residual = 1.337319924987424e-10
CG iteration 95, residual = 9.650227740806794e-11
CG iteration 96, residual = 7.214723548586326e-11
CG iteration 97, residual = 5.5422360245784395e-11
CG iteration 98, residual = 4.312890915697792e-11
CG iteration 99, residual = 3.323840884789733e-11
CG iteration 100, residual = 2.5439028868515163e-11
CG iteration 101, residual = 1.941833154448012e-11
CG iteration 102, residual = 1.5212044533118537e-11
CG iteration 103, residual = 1.2647684530305675e-11
CG iteration 104, residual = 1.035145486651841e-11
CG iteration 105, residual = 8.14252033038907e-12
CG iteration 106, residual = 6.944674988688776e-12
CG iteration 107, residual = 5.397083765394746e-12
CG iteration 108, residual = 4.079971893501438e-12
CG iteration 109, residual = 3.0635228097716016e-12
CG iteration 110, residual = 2.369665756783857e-12
CG iteration 111, residual = 1.9344478595877803e-12
CG iteration 112, residual = 1.733988186351572e-12
CG iteration 113, residual = 1.3156481006225726e-12
CG iteration 114, residual = 9.657770635115981e-13
CG iteration 115, residual = 7.303717956621037e-13
CG iteration 116, residual = 5.559041176984949e-13
Postscript¶
fes = fes_ho*fes_lo*fes_lam
               - 1*uho*dx
solvers.Newton(a=a, u=gfu)
Draw(gfu.components[0],deformation=True, settings={"camera": {"transformations": [{"type": "rotateX", "angle": -45}]}})
Newton iteration  0
err =  0.39346141669994983
Newton iteration  1
err =  1.8488788182878563e-15
