Mesh of (only) the surface:¶
sphere.name = "sphere"
geo = OCCGeometry(sphere)
order = 4
if order > 0:
mesh.Curve(order)
Tangential velocity field:¶
t = Parameter(0.)
Draw (b, mesh, "b")
eps = 5e-5
some local quantities¶
bn = InnerProduct(b,con)
Discretization¶
Surface FESpaces:¶
fes = fesl2*fesedge
u,uE = fes.TrialFunction()
v,vE = fes.TestFunction()
gradu = u.Trace().Deriv()
gradv = v.Trace().Deriv()
jumpu = u - uE
jumpv = v - vE
# diffusion
alpha = 10*(order+1)**2
a += eps*gradu * gradv * ds
a += - eps*dudn * jumpv * dr
a += - eps*dvdn * jumpu * dr
outflow |
inflow |
<ngsolve.comp.BilinearForm at 0x7f5a8f121530>
Mass matrix:¶
m = BilinearForm(fes)
m += u*v*ds
<ngsolve.comp.BilinearForm at 0x7f5a8f123470>
dt = 0.02
mstarinv = mstar.Inverse()
T = 8*pi
Time stepping¶
The time loop¶
t.Set(0)
for i in range(int(T/dt)):
sceneun.Redraw()
t.Set(t.Get()+dt)
Remark:¶
