6.1.3 Reissner-Mindlin plate¶
To avoid shear locking when the thickness
Mixed Interpolation of Tensorial Components (MITC)¶
Set up benchmark example with exact solution. Young modulus
E, nu, k = 10.92, 0.3, 5/6
mu = E/(2*(1+nu))
lam = E*nu/(1-nu**2)
#shearing modulus
G = E/(2*(1+nu))
t = 0.1
R = 5
#force
fz = 1
order = 1
sg = SplineGeometry()
mesh.Curve(order)
r = sqrt(x**2+y**2)
xi = r/R
Db = E*t**3/(12*(1-nu**2))
clamped = True
#Draw(w_s_ex, mesh, "w_s_ex")
Draw(w_c_ex, mesh, "w_c_ex")
if clamped:
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.VectorH1'>, maybe there is a typo?
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.H1'>, maybe there is a typo?
Adding interpolation (reduction) operator
f += -fz*du*dx
def SolveBVP():
fes.Update()
gfsol.Update()
gfsol.vec.data = inv * f.vec
l = []
for i in range(5):
print("i = ", i)
SolveBVP()
if clamped:
print("err = ", err)
l.append ( (fes.ndof, err ))
i = 0
err = 0.5595598334579744
i = 1
err = 0.11654484017074333
i = 2
err = 0.021448789397333804
i = 3
err = 0.00485653555965195
i = 4
err = 0.0011748158844755877
plt.yscale('log')
plt.xscale('log')
plt.xlabel("ndof")
plt.ylabel("relative error")
ndof,err = zip(*l)
plt.plot(ndof,err, "-*")
plt.ion()
TDNNS method¶
def CMatInv(mat, E, nu):
mesh.Curve(order)
Instead of using Lagrangian elements together with an interpolation operator we can directly use H(curl) for the rotation
order=1
if clamped:
Use the TDNNS method with the stress (bending) tensor
f += -fz*du*dx
def SolveBVP():
fes.Update()
gfsol.Update()
l = []
for i in range(5):
print("i = ", i)
SolveBVP()
if clamped:
i = 0
err = 0.4806915268060298
i = 1
err = 0.1660840390786989
i = 2
err = 0.04302102327861157
i = 3
err = 0.01100222868646325
i = 4
err = 0.002887933514209067
plt.yscale('log')
plt.xscale('log')
plt.xlabel("ndof")
ndof,err = zip(*l)
plt.ion()
