netgen drawsolution.py
For proper parallel execution, Netgen/NGSolve must be configured with -DUSE_MPI=ON. Recent binaries for Linux and Mac are built with MPI support (?). If you are unsure, when your Netgen/NGSolve supports MPI, look for outputs like "Including MPI version 3.1" during Netgen startup.
We start an MPI server:
from mpi4py.MPI import COMM_WORLD as comm
print (comm.rank, comm.size)
[stdout:0] 0 4
[stdout:2] 2 4
[stdout:1] 1 4
[stdout:3] 3 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:0] 0
[stdout:2] 81
[stdout:3] 76
[stdout:1] 75
inv = CGSolver(a.mat, pre.mat, printrates=comm.rank==0, maxiter=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:0] CG iteration 1, residual = 0.05344510152082692
CG iteration 2, residual = 0.07335467296659272
CG iteration 3, residual = 0.0610674694260373
CG iteration 4, residual = 0.04965686429236397
CG iteration 5, residual = 0.0452518184441288
CG iteration 6, residual = 0.030277964847912075
CG iteration 7, residual = 0.025794422842119066
CG iteration 8, residual = 0.017216403495970298
CG iteration 9, residual = 0.013130605571425603
CG iteration 10, residual = 0.011297762804869443
CG iteration 11, residual = 0.007418438464791829
CG iteration 12, residual = 0.0035092287200178354
CG iteration 13, residual = 0.0019971399098125554
CG iteration 14, residual = 0.0013761297598940663
CG iteration 15, residual = 0.000903922060558815
CG iteration 16, residual = 0.0006240512390656086
CG iteration 17, residual = 0.00044459028698273437
CG iteration 18, residual = 0.0003262241057823474
CG iteration 19, residual = 0.00020591309657151647
CG iteration 20, residual = 0.00015650517646013305
CG iteration 21, residual = 0.00010903505272621296
CG iteration 22, residual = 8.232416345564249e-05
CG iteration 23, residual = 6.313011393893972e-05
CG iteration 24, residual = 4.178559306769995e-05
CG iteration 25, residual = 2.6252835270900835e-05
CG iteration 26, residual = 1.8512831482037585e-05
CG iteration 27, residual = 1.3059431765666551e-05
CG iteration 28, residual = 8.758234489197777e-06
CG iteration 29, residual = 6.0270880532180526e-06
CG iteration 30, residual = 3.7875628716913018e-06
CG iteration 31, residual = 2.2069510885417045e-06
CG iteration 32, residual = 1.8184727625440557e-06
CG iteration 33, residual = 1.478287578601823e-06
CG iteration 34, residual = 9.112034138773395e-07
CG iteration 35, residual = 4.883620238470982e-07
CG iteration 36, residual = 3.038142976567947e-07
CG iteration 37, residual = 2.0211650398256315e-07
CG iteration 38, residual = 1.3967366378247875e-07
CG iteration 39, residual = 1.0549244104497372e-07
CG iteration 40, residual = 7.33917909937771e-08
CG iteration 41, residual = 4.690200695356063e-08
CG iteration 42, residual = 2.8297041322593687e-08
CG iteration 43, residual = 1.8878461321128183e-08
CG iteration 44, residual = 1.4036272475489988e-08
CG iteration 45, residual = 9.18169543187263e-09
CG iteration 46, residual = 5.659420341758749e-09
CG iteration 47, residual = 3.2619329154731113e-09
CG iteration 48, residual = 2.319436388138599e-09
CG iteration 49, residual = 1.6791808348364218e-09
CG iteration 50, residual = 1.100074455943685e-09
CG iteration 51, residual = 6.905317008951446e-10
CG iteration 52, residual = 4.4057048090158657e-10
gfu = c[:]["gfu"]
Draw (gfu[0]);
Draw (gfu[3]);
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2 = c[:]["gfL2"]
Draw (gfL2[0]);
