Schäfer-Turek benchmark¶
mesh.Curve(3); Draw(mesh)
# viscosity
nu = 0.001
k = 3
Q = H1(mesh,order=k-1)
X = V*Q
with boundary conditions:
- the inflow boundary data (‘inlet’) with mean value \(1\)
- “do-nothing” boundary conditions on the ouflow (‘outlet’) and
- homogeneous Dirichlet conditions on all other boundaries (‘wall’).
gfu = GridFunction(X)
velocity = gfu.components[0]
sceneu = Draw(velocity,mesh,"u",order=3)
scenep = Draw(gfu.components[1],mesh,"p",order=3)
# parabolic inflow at bc=1:
sceneu.Redraw()
scenep.Redraw()
inflow profile plot:¶
%matplotlib inline
bvs = 6*s*(0.41-s)/(0.41)**2
plt.plot(s, bvs)
plt.grid(True)
(u,p), (v,q) = X.TnT()
a = BilinearForm(X)
a += stokes
f = LinearForm(X)
sceneu.Redraw()
scenep.Redraw()
IMEX time discretization¶
dt = 0.001
mstar = BilinearForm(X)
mstar.Assemble()
conv = LinearForm(X)
tend = 0
tend += 1
while t < tend-0.5*dt:
    print ("\rt=", t, end="")
    conv.Assemble()
    t = t + dt
    sceneu.Redraw()
t= 0.9990000000000008
drag_x_test = GridFunction(X)
drag_y_test = GridFunction(X)
time_vals = []
drag_x_vals = []
drag_y_vals = []
# restoring initial data
tend = 0
tend += 1
    conv.Assemble()
    t = t + dt
    time_vals.append( t )
    #print(drag)
# Plot drag force over time
# Plot lift force over time
