3.2 Incompressible Navier-Stokes equations
Find (u,p):[0,T](H0,D1)d×L2, s.t. Ωtuv+Ωνuv+uuvΩdiv(v)p=fvv(H0,D1)d,Ωdiv(u)q=0qL2,u(t=0)=u0
Schäfer-Turek benchmark
We consider the benchmark setup of from http://www.featflow.de/en/benchmarks/cfdbenchmarking/flow/dfg_benchmark2_re100.html . The geometry is a 2D channel with a circular obstacle which is positioned (only slightly) off the center of the channel. The geometry: title
The viscosity is set to ν=103.
mesh.Curve(3); Draw(mesh)
# viscosity
nu = 0.001
Taylor-Hood velocity-pressure pair
We use a Taylor-Hood discretization of degree k. The finite element space for the (vectorial) velocity u and the pressure p are:
uV={vH1(Ω)|v|TPk(T)}2pQ={qH1(Ω)|q|TPk1(T)}
k = 3
Q = H1(mesh,order=k-1)
X = V*Q
Stokes problem for initial values
Find uV, pQ so that Ωνu:vΩdiv(v)p=fvvV,Ωdiv(u)q=0qQ,
with boundary conditions:
  • the inflow boundary data (‘inlet’) with mean value 1
ux(0,y)=6y(0.41y)/(0.41)2,00.41ux(0,y)dy=1uy(0,y)=0
  • “do-nothing” boundary conditions on the ouflow (‘outlet’) and
  • homogeneous Dirichlet conditions on all other boundaries (‘wall’).
gfu = GridFunction(X)
velocity = gfu.components[0]
sceneu = Draw(velocity,mesh,"u",order=3)
scenep = Draw(gfu.components[1],mesh,"p",order=3)
# parabolic inflow at bc=1:
sceneu.Redraw()
scenep.Redraw()
inflow profile plot:
%matplotlib inline
bvs = 6*s*(0.41-s)/(0.41)**2
plt.plot(s, bvs)
plt.grid(True)
../../_images/i-tutorials_unit-3.2-navierstokes_navierstokes_10_0.png
a((u,p),(v,q)):=Ωνu:vdiv(v)pdiv(u)q
(u,p), (v,q) = X.TnT()
a = BilinearForm(X)
a += stokes
f = LinearForm(X)
sceneu.Redraw()
scenep.Redraw()
IMEX time discretization
Find (un+1,pn+1)X=V×Q, s.t. for all (v,q)X=V×Q
m(un+1,v)+Δt  a((un+1,pn+1),(v,q))M = m(un,v)Δt  c(un;un,v)
with m(u,v)=uv
and c(w,u,v)=wuv
We prefer the incremental form (as it homogenizes the boundary conditions): m(δun+1,v)+Δt  a((δun+1,δpn+1),(v,q)) = Δt(a((un,pn),(v,q))c(un;un,v))
dt = 0.001
mstar = BilinearForm(X)
mstar.Assemble()
conv = LinearForm(X)
tend = 0
tend += 1
while t < tend-0.5*dt:
    print ("\rt=", t, end="")
    conv.Assemble()
    t = t + dt
    sceneu.Redraw()
t= 0.9990000000000008
Supplementary 1: Computing stresses
F=(FD,FL)=Γcylσn=Γcyl(νun+pI)n
cD=2u¯LFD,cL=2u¯LFL.
where u¯=1 is the mean inflow velocity and L=0.41 is the channel width.
drag_x_test = GridFunction(X)
drag_y_test = GridFunction(X)
time_vals = []
drag_x_vals = []
drag_y_vals = []
# restoring initial data
tend = 0
tend += 1
    conv.Assemble()
    t = t + dt
    time_vals.append( t )
    #print(drag)
# Plot drag force over time
../../_images/i-tutorials_unit-3.2-navierstokes_navierstokes_29_0.png
# Plot lift force over time
../../_images/i-tutorials_unit-3.2-navierstokes_navierstokes_30_0.png
