We choose \(f\) as
Let us set up the geometry.
# Generate the geometry
geo.AddCircle((0,0), r = 2.5)
mesh.Curve(2)
<ngsolve.comp.Mesh at 0x7f8c63839e00>
#gfset.vec[:]=0
#gfset.Set((0.2*x,0))
#mesh.SetDeformation(gfset)
a =4.0/5.0
b = 2
gfset = GridFunction(VEC)
gfX = GridFunction(VEC)
Draw(gfset)
Shape derivative¶
# Test and trial functions
PHI, PSI = VEC.TnT()
# shape derivative
dJOmega = LinearForm(VEC)
Bilinear form¶
aX = BilinearForm(VEC)
The first optimisation step¶
Here
Now we note that \(\varphi \mapsto \varphi\circ(\mbox{id}+X_n)^{-1}\) maps the finite element space on \((\mbox{id}+X_n)(\Omega_0)\) to the finite element space on \(\Omega_0\). Therefore the following are equvalent:
# assemble on deformed domain
aX.Assemble()
dJOmega.Assemble()
mesh.UnsetDeformation()
# unset deformation
# compute X_0
alpha = 20.0 / Norm(gfX.vec)
gfset.vec[:]=0
scene = Draw(gfset)
# input("A")
#draw deformed shape
# input("B")
current cost 63.58544060305382
Gradient norm 442.05184362948427
cost after gradient step: 5.043649318663175
Optimisation loop¶
import time
iter_max = 50
gfset.vec[:] = 0
converged = False
# input("A")
for k in range(iter_max):
Jold = Integrate(f, mesh)
# assemble bilinear form
aX.Assemble()
# assemble shape derivative
dJOmega.Assemble()
# step size control
gfset_old.data = gfset.vec
Jnew = Jold + 1
while Jnew > Jold:
gfset.vec.data = gfset_old
Jnew = Integrate(f, mesh)
if Jnew > Jold:
print("reducing step size")
alpha = 0.9*alpha
alpha = alpha*1.5
break
time.sleep(0.1)
Jold = Jnew
cost at iteration 0 : 63.58544060305382
step size: 0.165
cost at iteration 1 : -0.7382553000138545
step size: 0.2475
cost at iteration 2 : -0.8176876285984291
cost at iteration 3 : -0.9325785868476248
step size: 0.556875
cost at iteration 4 : -1.0701613164084456
step size: 0.8353125
cost at iteration 5 : -1.1521934750329594
step size: 1.25296875
cost at iteration 6 : -1.1547483082895464
reducing step size
reducing step size
step size: 1.52235703125
cost at iteration 7 : -1.154955094622594
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4982276723046877
cost at iteration 8 : -1.1550472206937452
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3270326873287925
cost at iteration 9 : -1.155453494676608
reducing step size
reducing step size
reducing step size
step size: 1.4511102435940346
cost at iteration 10 : -1.1555977964371116
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4281101462330694
cost at iteration 11 : -1.1556257735480633
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4054746004152756
cost at iteration 12 : -1.1558550657345563
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3831978279986936
cost at iteration 13 : -1.1559610148052597
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3612741424249144
cost at iteration 14 : -1.1561635400235297
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3396979472674797
cost at iteration 15 : -1.156193676380524
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.1866173613229614
cost at iteration 16 : -1.156357024476493
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0510285285313932
cost at iteration 17 : -1.156434437642301
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.034369726354171
cost at iteration 18 : -1.1564637024518876
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0179749661914572
cost at iteration 19 : -1.1564751304725112
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0018400629773228
cost at iteration 20 : -1.156511537322834
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9859608979791321
cost at iteration 21 : -1.156564232383649
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9703334177461629
cost at iteration 22 : -1.1566297010931148
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9549536330748863
cost at iteration 23 : -1.1566995703949992
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9398176179906492
cost at iteration 24 : -1.156765520852471
reducing step size
reducing step size
reducing step size
step size: 1.027690565272775
cost at iteration 25 : -1.1567676713081918
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0114016698132016
cost at iteration 26 : -1.1567784490425266
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9953709533466624
cost at iteration 27 : -1.156798428862847
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9795943237361178
cost at iteration 28 : -1.1568250029634704
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9640677537049005
cost at iteration 29 : -1.1568556930569593
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9487872798086778
cost at iteration 30 : -1.1568865442400496
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9337490014237104
cost at iteration 31 : -1.1569150632990812
reducing step size
reducing step size
reducing step size
step size: 1.0210545330568275
cost at iteration 32 : -1.1569198549179136
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0048708187078768
cost at iteration 33 : -1.15692778724364
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.988943616231357
cost at iteration 34 : -1.156938362321561
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.97326885991409
cost at iteration 35 : -1.1569509591157165
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9578425484844518
cost at iteration 36 : -1.1569642145231311
reducing step size
reducing step size
reducing step size
step size: 1.047400826767748
cost at iteration 37 : -1.1569647976305986
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0307995236634793
cost at iteration 38 : -1.1569668723577835
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0144613512134133
cost at iteration 39 : -1.156971132204393
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9983821387966807
cost at iteration 40 : -1.156977460360057
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9825577818967535
cost at iteration 41 : -1.1569856919266508
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.96698424105369
cost at iteration 42 : -1.1569949177533807
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9516575408329891
cost at iteration 43 : -1.1570044550911744
reducing step size
reducing step size
reducing step size
step size: 1.0406375209008738
cost at iteration 44 : -1.1570056477226338
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0241434161945948
cost at iteration 45 : -1.1570079849271222
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0079107430479106
cost at iteration 46 : -1.1570115458839176
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9919353577706012
cost at iteration 47 : -1.1570164247726291
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9762131823499371
cost at iteration 48 : -1.1570221572034933
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9607402034096908
cost at iteration 49 : -1.1570284025356303
reducing step size
reducing step size
reducing step size
step size: 1.050569412428497
Using SciPy optimize toolbox¶
ngsglobals.msg_level = 1
mesh.Curve(2)
a =4.0/5.0
b = 2
# element order
order = 1
PHI = VEC.TrialFunction()
PSI = VEC.TestFunction()
gfset.Set((0,0))
# only for new gui
#if scene:
# scene.setDeformation(True)
#Draw(gfset,mesh,"gfset")
Curve elements, order = 2
Shape derivative¶
fX = LinearForm(VEC)
# analytic shape derivative
Define the bilinear form
# Cauchy-Riemann descent CR
CR = False
# bilinear form for gradient
if CR == True:
gamma = 100
aX.Assemble()
def J(x_):
gfset.Set((0,0))
# x_ NumPy vector
cost_c = Integrate (f, mesh)
return cost_c
gfset.Set((0,0))
# x_ NumPy vector
fX.Assemble()
if euclid == True:
gfX.vec.data = fX.vec
gfX.vec.data = invaX * fX.vec
xk_ = np.copy(x0)
# maximal iteration
it_max = 50
nfval_total = 0
print('\n')
for i in range(1, it_max):
# compute descent direction
pk = -gradJ_(xk_)
# eval cost function
fold = J_(xk_)
# perform armijo stepsize
if CR == True:
alpha0 = 0.15
alpha0 = 0.11
nfval_total += nfval
xk_ = xk_ - step * grad_xk
break
elif i == it_max-1:
gfset.vec[:]=0
Iteration 1 | Cost 63.58544060305382 | grad norm 442.05184362948427
Iteration 2 | Cost -0.7382553000138548 | grad norm 4.797321601018455
Iteration 3 | Cost -0.7857735477702836 | grad norm 4.812294575740791
Iteration 4 | Cost -0.8340109759042181 | grad norm 4.780144423275227
Iteration 5 | Cost -0.881983893823349 | grad norm 4.692239115470677
Iteration 6 | Cost -0.9285224314563473 | grad norm 4.5416445721269705
Iteration 7 | Cost -0.9723566047005454 | grad norm 4.324713174006836
Iteration 8 | Cost -1.0122540076018296 | grad norm 4.0426845384291346
Iteration 9 | Cost -1.0471892473177822 | grad norm 3.7026495061938505
Iteration 10 | Cost -1.0765050767054933 | grad norm 3.3181634341605646
Iteration 11 | Cost -1.1000167253818887 | grad norm 2.90732492212311
Iteration 12 | Cost -1.1180154448826773 | grad norm 2.490754022058955
Iteration 13 | Cost -1.1311721937086696 | grad norm 2.0883910113681714
Iteration 14 | Cost -1.140374856628482 | grad norm 1.716495522576629
Iteration 15 | Cost -1.1465562052233915 | grad norm 1.3862619992896077
Iteration 16 | Cost -1.150562263853099 | grad norm 1.1029047823734224
Iteration 17 | Cost -1.1530807854465164 | grad norm 0.8667776120942267
Iteration 18 | Cost -1.1546254652064152 | grad norm 0.6747350037169477
Iteration 19 | Cost -1.155555089885781 | grad norm 0.521601956642585
Iteration 20 | Cost -1.15610728312894 | grad norm 0.4014078557589178
Iteration 21 | Cost -1.1564329962973245 | grad norm 0.3082390241864366
Iteration 22 | Cost -1.1566250721363829 | grad norm 0.236729388003623
Iteration 23 | Cost -1.1567392179253135 | grad norm 0.18227782886365923
Iteration 24 | Cost -1.1568082424509445 | grad norm 0.14108836193150684
Iteration 25 | Cost -1.1568512059762208 | grad norm 0.11011137545386489
Iteration 26 | Cost -1.1568790758609946 | grad norm 0.08694123443763045
Iteration 27 | Cost -1.1568981259972182 | grad norm 0.06970013095634099
Iteration 28 | Cost -1.1569119356095627 | grad norm 0.05693106530543911
Iteration 29 | Cost -1.1569225483311438 | grad norm 0.04750596065756907
Iteration 30 | Cost -1.1569311374304097 | grad norm 0.040553631098362235
Iteration 31 | Cost -1.156938383007384 | grad norm 0.03540610663423864
Iteration 32 | Cost -1.1569446865801067 | grad norm 0.03155866160652364
Iteration 33 | Cost -1.1569502911220542 | grad norm 0.028637951437263578
Iteration 34 | Cost -1.156955349068707 | grad norm 0.026374404372481768
Iteration 35 | Cost -1.1569599604966179 | grad norm 0.024577686706996647
Iteration 36 | Cost -1.156964194534456 | grad norm 0.023115688255964162
Iteration 37 | Cost -1.156968101815988 | grad norm 0.021897623641615804
Iteration 38 | Cost -1.1569717214195943 | grad norm 0.020861264507975198
Iteration 39 | Cost -1.1569750846830889 | grad norm 0.019963767959634886
Iteration 40 | Cost -1.156978217692618 | grad norm 0.019175836787548774
Iteration 41 | Cost -1.1569811421514762 | grad norm 0.01847543606004201
Iteration 42 | Cost -1.1569838777622021 | grad norm 0.017849514376677995
Iteration 43 | Cost -1.1569864401815315 | grad norm 0.017283661655752045
Iteration 44 | Cost -1.1569888459059847 | grad norm 0.016770895179239378
Iteration 45 | Cost -1.156991108604262 | grad norm 0.016304608148209974
Iteration 46 | Cost -1.1569932403960685 | grad norm 0.01587952159300805
Iteration 47 | Cost -1.1569952522869715 | grad norm 0.015492096337398344
Iteration 48 | Cost -1.1569971536572254 | grad norm 0.015137178273958808
Iteration 49 | Cost -1.1569989538206762 | grad norm 0.014812385966536876
gradient norm: 0.014515001787420401
n evals f: 49
f val: -1.1569989538206762
L-BFGS method¶
In the BFGS method we replace
by
# options for optimiser
options = {"maxiter":1000,
"disp":True,
"gtol":1e-10}
RUNNING THE L-BFGS-B CODE
Machine precision = 2.220D-16
N = 7784 M = 10
At iterate 0 f= -1.15700D+00 |proj g|= 9.63930D-04
At iterate 1 f= -1.15700D+00 |proj g|= 1.78236D-03
At iterate 2 f= -1.15703D+00 |proj g|= 1.16772D-03
At iterate 3 f= -1.15706D+00 |proj g|= 3.35736D-03
ys=-2.003E-04 -gs= 2.740E-03 BFGS update SKIPPED
At iterate 4 f= -1.15707D+00 |proj g|= 2.24781D-03
At iterate 5 f= -1.15709D+00 |proj g|= 9.32024D-04
At iterate 6 f= -1.15709D+00 |proj g|= 1.21605D-03
At iterate 7 f= -1.15709D+00 |proj g|= 1.26745D-03
At iterate 8 f= -1.15709D+00 |proj g|= 1.29862D-03
At iterate 9 f= -1.15709D+00 |proj g|= 1.33023D-03
At iterate 10 f= -1.15710D+00 |proj g|= 1.52938D-03
At iterate 11 f= -1.15710D+00 |proj g|= 4.54617D-04
At iterate 12 f= -1.15710D+00 |proj g|= 4.52943D-04
At iterate 13 f= -1.15711D+00 |proj g|= 7.05745D-04
At iterate 14 f= -1.15711D+00 |proj g|= 7.05745D-04
fun: -1.1571110014730501
hess_inv: <7784x7784 LbfgsInvHessProduct with dtype=float64>
jac: array([ 2.14530782e-06, -6.07237181e-04, 6.13396109e-04, ...,
-5.29467877e-06, 6.19934625e-06, -5.11621928e-06])
message: b'CONVERGENCE: REL_REDUCTION_OF_F_<=_FACTR*EPSMCH'
nfev: 108
nit: 14
status: 0
success: True
x: array([-5.01427824e-04, 6.98499222e-01, -6.98449755e-01, ...,
4.66153980e-03, -1.54412643e-03, 4.61902413e-03])
F = final function value
7784 14 108 2 1 0 7.057D-04 -1.157D+00
F = -1.1571110014730501
Cauchy time 3.357E-04 seconds.
Subspace minimization time 5.630E-03 seconds.
Line search time 2.599E+01 seconds.
Total User time 2.625E+01 seconds.
This may lead to overly streched or even degenerated triangles. One way to improve this is to modify the above equation by
The two equations \(BX = 0\) are precisely the Cauchy-Riemann equations \(-\partial_x X_1 + \partial_y X_2=0\) and \(\partial_y X_1 + \partial_x X_2\). So the bigger \(\gamma\) the more angle preserving is the gradient. So by adding the B term we enforce conformaty with strengh \(\gamma\).
alpha = 100
