6.1.3 Reissner-Mindlin plate
To avoid shear locking when the thickness t becomes small several methods and elements have been proposed. We discuss two approaches:
Set up benchmark example with exact solution. Young modulus E, Poisson ratio ν, shear correction factor κ and corresponding Lamè parameters μ and λ. Geometry parameters are given by thickness t and radius R.
E, nu, k = 10.92, 0.3, 5/6
mu  = E/(2*(1+nu))
lam = E*nu/(1-nu**2)
#shearing modulus
G = E/(2*(1+nu))
t = 0.1
R = 5
#force
fz = 1
order = 1
sg = SplineGeometry()
mesh.Curve(order)
r = sqrt(x**2+y**2)
xi = r/R
Db = E*t**3/(12*(1-nu**2))
clamped = True
#Draw(w_s_ex, mesh, "w_s_ex")
Draw(w_c_ex, mesh, "w_c_ex")
if clamped:
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.VectorH1'>, maybe there is a typo?
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.H1'>, maybe there is a typo?
WARNING: kwarg 'autoupdate' is an undocumented flags option for class <class 'ngsolve.comp.FESpace'>, maybe there is a typo?
t312Ω2με(β):ε(δβ)+λdiv(β)div(δβ)dx+tκGΩ(uβ)(δuδβ)dx=Ωfδudx,(δu,δβ).
Adding interpolation (reduction) operator R:[H01(Ω)]2H(curl). Spaces are chosen according to [Brezzi, Fortin and Stenberg. Error analysis of mixed-interpolated elements for Reissner-Mindlin plates. Mathematical Models and Methods in Applied Sciences 1, 2 (1991), 125-151.]
t312Ω2με(β):ε(δβ)+λdiv(β)div(δβ)dx+tκGΩR(uβ)R(δuδβ)dx=Ωfδudx,(δu,δβ).
f += -fz*du*dx
def SolveBVP():
    fes.Update()
    gfsol.Update()
        gfsol.vec.data = inv * f.vec
l = []
for i in range(5):
    print("i = ", i)
    SolveBVP()
    if clamped:
    print("err = ", err)
    l.append ( (fes.ndof, err ))
i =  0
err =  0.5595598334579744
i =  1
err =  0.11654484017074333
i =  2
err =  0.021448789398216872
i =  3
err =  0.00485653556028109
i =  4
err =  0.0011748158836307264
plt.yscale('log')
plt.xscale('log')
plt.xlabel("ndof")
plt.ylabel("relative error")
ndof,err = zip(*l)
plt.plot(ndof,err, "-*")
plt.ion()
../../_images/i-tutorials_unit-6.1.3-rmplate_Reissner_Mindlin_plate_19_0.png
TDNNS method
def CMatInv(mat, E, nu):
mesh.Curve(order)
Instead of using Lagrangian elements together with an interpolation operator we can directly use H(curl) for the roation β.
order=1
if clamped:
Use the TDNNS method with the stress (bending) tensor σ as proposed in [Pechstein and Schöberl. The TDNNS method for Reissner-Mindlin plates. Numerische Mathematik 137, 3 (2017), 713-740] L(u,β,σ)=6t3σC12+σ,β+tkG2uβ2Ωfudxσ,β:=TTTσ:βdxTσnnβnds
f += -fz*du*dx
def SolveBVP():
    fes.Update()
    gfsol.Update()
l = []
for i in range(5):
    print("i = ", i)
    SolveBVP()
    if clamped:
i =  0
err =  0.4806915268060298
i =  1
err =  0.1660840390786989
i =  2
err =  0.04302102327870844
i =  3
err =  0.011002228686409238
i =  4
err =  0.0028879335138407747
plt.yscale('log')
plt.xscale('log')
plt.xlabel("ndof")
ndof,err = zip(*l)
plt.ion()
../../_images/i-tutorials_unit-6.1.3-rmplate_Reissner_Mindlin_plate_31_0.png
