6.1.2 Surface PDEs¶
Surface Poisson equation¶
Homogeneous Dirichlet data¶
finitesphere = sphere * bot
mesh.Curve(2)
u, v = fes.TnT()
print(fes.FreeDofs())
50: 11111111111111111111111111111111111111111111111110
100: 01101101101101101101101101101101101101101101101101
150: 10110110111111111111111111111111111111111111111111
350: 1111111111111111111111
force = sin(x)*y*exp(z)
f += force*v*ds
<ngsolve.comp.LinearForm at 0x7f3e2c6418f0>
Solving is done as usual
Draw(gfu, mesh, "u")
Inhomogeneous Dirichlet data¶
r = f.vec.CreateVector()
Draw(gfu)
a += grad(u)*grad(v)*ds
<ipython-input-1-afcf4da53a20> in <module>
2 a.Assemble()
The second class is given by
Space |
Surface Space |
L2 |
SurfaceL2 |
HDiv |
HDivSurface |
HDivDiv |
HDivDivSurface |
FacetFESpace |
FacetSurface |
