netgen drawsolution.py
On my notebook I have created the profile once by the command
ipython profile create –parallel –profile=mpi
Since I have only two physical cores, I edited the file .ipython/profile_mpi/ipcluster_config.py to allow for oversubscription:
c.MPILauncher.mpi_args = [‘–oversubscribe’]
I start the cluster via
ipcluster start –engines=MPI -n 4 –profile=mpi
In jupyter, we can then connect to the cluster via a Client object of ipyparallel.
c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
from mpi4py import MPI
comm = MPI.COMM_WORLD
print (comm.rank, comm.size)
[stdout:0] 0 4
[stdout:1] 1 4
[stdout:2] 2 4
[stdout:3] 3 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:0] 0
[stdout:1] 76
[stdout:2] 81
[stdout:3] 75
inv = CGSolver(a.mat, pre.mat, printing=comm.rank==0, maxsteps=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:0]
iteration 0 error = 0.0531207003733573
iteration 1 error = 0.07374408660622353
iteration 2 error = 0.06613575382258267
iteration 3 error = 0.050564282985203636
iteration 4 error = 0.048118728884873806
iteration 5 error = 0.03171133576546557
iteration 6 error = 0.026339954640005568
iteration 7 error = 0.018867600495310295
iteration 8 error = 0.013856359824532939
iteration 9 error = 0.011508956583247314
iteration 10 error = 0.008869710488825623
iteration 11 error = 0.004854287485627618
iteration 12 error = 0.0022162679463868917
iteration 13 error = 0.0015615896552425461
iteration 14 error = 0.0011065170423390227
iteration 15 error = 0.0007171571458209736
iteration 16 error = 0.0005251131240243119
iteration 17 error = 0.0003498383890375572
iteration 18 error = 0.00022463539798289107
iteration 19 error = 0.0001592318115618978
iteration 20 error = 0.00012412243193313203
iteration 21 error = 8.768140471147995e-05
iteration 22 error = 5.820850555540186e-05
iteration 23 error = 4.0545678293521785e-05
iteration 24 error = 3.0221249909169026e-05
iteration 25 error = 2.2281511256913374e-05
iteration 26 error = 1.5466555984921558e-05
iteration 27 error = 1.0276039906232418e-05
iteration 28 error = 6.856538971345466e-06
iteration 29 error = 4.775824481043984e-06
iteration 30 error = 3.1094353975493638e-06
iteration 31 error = 2.3089701477004328e-06
iteration 32 error = 1.6644528884649143e-06
iteration 33 error = 1.1420780176195701e-06
iteration 34 error = 7.667709514061564e-07
iteration 35 error = 4.84508000920897e-07
iteration 36 error = 3.5489460115407914e-07
iteration 37 error = 2.4269630502781234e-07
iteration 38 error = 1.602381789666031e-07
iteration 39 error = 1.0291374085372436e-07
iteration 40 error = 6.809889912101377e-08
iteration 41 error = 4.6562019125914776e-08
iteration 42 error = 3.428059952981986e-08
iteration 43 error = 2.3419466928295808e-08
iteration 44 error = 1.4564354581502244e-08
iteration 45 error = 8.733217166602041e-09
iteration 46 error = 5.68444400280555e-09
iteration 47 error = 4.13662431175638e-09
iteration 48 error = 2.9795076726748737e-09
iteration 49 error = 2.0124741677440948e-09
iteration 50 error = 1.2237905564761206e-09
iteration 51 error = 7.854711295756273e-10
iteration 52 error = 6.170296480271633e-10
iteration 53 error = 4.909037899676716e-10
gfu = c[:]["gfu"]
Draw (gfu[0])
Draw (gfu[3])
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2 = c[:]["gfL2"]
Draw (gfL2[0])
