3.6 DG/HDG splitting¶
For a problem of the form
from netgen import gui
order = 3
mesh.Curve(order)
HDG spaces¶
V = FESpace ([V1,V2,Q])
v, vhat, q = V.TestFunction()
nu = 0.001 # viscosity
def tang(vec):
return vec - (vec*n)*n
Stokes discretization¶
alpha = 4 # SIP parameter
a += nu * InnerProduct ( Grad(u), Grad(v)) * dx
a += nu * alpha*order*order/h * InnerProduct(tang(vhat-v), tang(uhat-u))*dS
a += (-div(u)*q -div(v)*p) * dx
<ngsolve.comp.BilinearForm at 0x7f8b2ff57630>
The mass matrix is simply
m += SymbolicBFI( u * v )
<ngsolve.comp.BilinearForm at 0x7f8b2ffbc530>
Initial conditions¶
gfu = GridFunction(V)
U0 = 1.5
Application of convection¶
mixed mass matrices¶
uL2, vL2 = VL2.TnT()
bfmixed += vL2*u*dx
bfmixedT += uL2*v*dx
convection operator¶
vel = gfu.components[0]
un = InnerProduct(vel,n)
def __init__(self,tau,steps):
def Mult(self, x, y):
for i in range(self.steps):
def CreateColVector(self):
return CreateVVector(self.h)
Setup of \(M^*\):
t = 0; tend = 0
tau = 0.01; substeps = 10
The time loop:
%%time
tend += 1
res = gfu.vec.CreateVector()
t += tau
print ("\r t =", t, end="")
t = 1.0000000000000007CPU times: user 9.7 s, sys: 45.9 ms, total: 9.75 s
Wall time: 9.71 s
ConvertL2Operator¶
def NewMult(self, x, y):
The time loop:
%%time
tend += 1
t += tau
t = 2.0000000000000013CPU times: user 9.51 s, sys: 78.3 ms, total: 9.58 s
Wall time: 9.52 s
