Poisson Equation in Parallel¶
netgen drawsolution.py
On my notebook I have created the profile once by the command
ipython profile create –parallel –profile=mpi
Since I have only two physical cores, I edited the file .ipython/profile_mpi/ipcluster_config.py to allow for oversubscription:
c.MPILauncher.mpi_args = [‘–oversubscribe’]
I start the cluster via
ipcluster start –engines=MPI -n 4 –profile=mpi
In jupyter, we can then connect to the cluster via a Client object of ipyparallel.
c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
help (Client)
Help on class Client in module ipyparallel.client.client:
class Client(traitlets.traitlets.HasTraits)
| Client(*args, **kw)
| A semi-synchronous client to an IPython parallel cluster
| Parameters
| url_file : str
| The path to ipcontroller-client.json.
| This JSON file should contain all the information needed to connect to a cluster,
| and is likely the only argument needed.
| Connection information for the Hub's registration. If a json connector
| file is given, then likely no further configuration is necessary.
| [Default: use profile]
| profile : bytes
| The name of the Cluster profile to be used to find connector information.
| If run from an IPython application, the default profile will be the same
| as the running application, otherwise it will be 'default'.
| cluster_id : str
| String id to added to runtime files, to prevent name collisions when using
| multiple clusters with a single profile simultaneously.
| When set, will look for files named like: 'ipcontroller-<cluster_id>-client.json'
| Since this is text inserted into filenames, typical recommendations apply:
| Simple character strings are ideal, and spaces are not recommended (but
| should generally work)
| context : zmq.Context
| Pass an existing zmq.Context instance, otherwise the client will create its own.
| debug : bool
| flag for lots of message printing for debug purposes
| timeout : float
| time (in seconds) to wait for connection replies from the Hub
| [Default: 10]
| Other Parameters
| sshserver : str
| A string of the form passed to ssh, i.e. 'server.tld' or 'user@server.tld:port'
| If keyfile or password is specified, and this is not, it will default to
| the ip given in addr.
| sshkey : str; path to ssh private key file
| This specifies a key to be used in ssh login, default None.
| Regular default ssh keys will be used without specifying this argument.
| password : str
| Your ssh password to sshserver. Note that if this is left None,
| you will be prompted for it if passwordless key based login is unavailable.
| paramiko : bool
| flag for whether to use paramiko instead of shell ssh for tunneling.
| [default: True on win32, False else]
| Attributes
| ids : list of int engine IDs
| requesting the ids attribute always synchronizes
| the registration state. To request ids without synchronization,
| use semi-private _ids attributes.
| history : list of msg_ids
| a list of msg_ids, keeping track of all the execution
| messages you have submitted in order.
| outstanding : set of msg_ids
| a set of msg_ids that have been submitted, but whose
| results have not yet been received.
| results : dict
| a dict of all our results, keyed by msg_id
| block : bool
| determines default behavior when block not specified
| in execution methods
| Method resolution order:
| Client
| traitlets.traitlets.HasDescriptors
| builtins.object
| Methods defined here:
| __del__(self)
| cleanup sockets, but _not_ context.
| __getitem__(self, key)
| index access returns DirectView multiplexer objects
| Must be int, slice, or list/tuple/xrange of ints
| __init__(self, url_file=None, profile=None, profile_dir=None, ipython_dir=None, context=None, debug=False, sshserver=None, sshkey=None, password=None, paramiko=None, timeout=10, cluster_id=None, **extra_args)
| Initialize self. See help(type(self)) for accurate signature.
| __iter__(self)
| Since we define getitem, Client is iterable
| but unless we also define __iter__, it won't work correctly unless engine IDs
| start at zero and are continuous.
| __len__(self)
| len(client) returns # of engines.
| abort(self, jobs=None, targets=None, block=None)
| Abort specific jobs from the execution queues of target(s).
| This is a mechanism to prevent jobs that have already been submitted
| from executing.
| Parameters
| jobs : msg_id, list of msg_ids, or AsyncResult
| The jobs to be aborted
| If unspecified/None: abort all outstanding jobs.
| activate(self, targets='all', suffix='')
| Create a DirectView and register it with IPython magics
| Defines the magics `%px, %autopx, %pxresult, %%px`
| Parameters
| targets: int, list of ints, or 'all'
| The engines on which the view's magics will run
| suffix: str [default: '']
| The suffix, if any, for the magics. This allows you to have
| multiple views associated with parallel magics at the same time.
| e.g. ``rc.activate(targets=0, suffix='0')`` will give you
| the magics ``%px0``, ``%pxresult0``, etc. for running magics just
| on engine 0.
| become_dask(self, targets='all', port=0, nanny=False, scheduler_args=None, **worker_args)
| Turn the IPython cluster into a dask.distributed cluster
| Parameters
| targets: target spec (default: all)
| Which engines to turn into dask workers.
| port: int (default: random)
| Which port
| nanny: bool (default: False)
| Whether to start workers as subprocesses instead of in the engine process.
| Using a nanny allows restarting the worker processes via ``executor.restart``.
| scheduler_args: dict
| Keyword arguments (e.g. ip) to pass to the distributed.Scheduler constructor.
| **worker_args:
| Any additional keyword arguments (e.g. ncores) are passed to the distributed.Worker constructor.
| Returns
| client = distributed.Client
| A dask.distributed.Client connected to the dask cluster.
| become_distributed = become_dask(self, targets='all', port=0, nanny=False, scheduler_args=None, **worker_args)
| clear(self, targets=None, block=None)
| Clear the namespace in target(s).
| close(self, linger=None)
| Close my zmq Sockets
| If `linger`, set the zmq LINGER socket option,
| which allows discarding of messages.
| db_query(self, query, keys=None)
| Query the Hub's TaskRecord database
| This will return a list of task record dicts that match `query`
| Parameters
| query : mongodb query dict
| The search dict. See mongodb query docs for details.
| keys : list of strs [optional]
| The subset of keys to be returned. The default is to fetch everything but buffers.
| 'msg_id' will *always* be included.
| direct_view(self, targets='all', **kwargs)
| construct a DirectView object.
| If no targets are specified, create a DirectView using all engines.
| rc.direct_view('all') is distinguished from rc[:] in that 'all' will
| evaluate the target engines at each execution, whereas rc[:] will connect to
| all *current* engines, and that list will not change.
| That is, 'all' will always use all engines, whereas rc[:] will not use
| engines added after the DirectView is constructed.
| Parameters
| targets: list,slice,int,etc. [default: use all engines]
| The engines to use for the View
| kwargs: passed to DirectView
| executor(self, targets=None)
| Construct a PEP-3148 Executor with a LoadBalancedView
| Parameters
| The subset of engines across which to load-balance execution
| Returns
| executor: Executor
| The Executor object
| get_result(self, indices_or_msg_ids=None, block=None, owner=True)
| Retrieve a result by msg_id or history index, wrapped in an AsyncResult object.
| If the client already has the results, no request to the Hub will be made.
| This is a convenient way to construct AsyncResult objects, which are wrappers
| that include metadata about execution, and allow for awaiting results that
| were not submitted by this Client.
| It can also be a convenient way to retrieve the metadata associated with
| blocking execution, since it always retrieves
| Examples
| In [10]: r = client.apply()
| Parameters
| indices_or_msg_ids : integer history index, str msg_id, AsyncResult,
| or a list of same.
| The indices or msg_ids of indices to be retrieved
| block : bool
| Whether to wait for the result to be done
| owner : bool [default: True]
| Whether this AsyncResult should own the result.
| If so, calling `ar.get()` will remove data from the
| client's result and metadata cache.
| There should only be one owner of any given msg_id.
| Returns
| AsyncResult
| A single AsyncResult object will always be returned.
| AsyncHubResult
| A subclass of AsyncResult that retrieves results from the Hub
| hub_history(self)
| Get the Hub's history
| Just like the Client, the Hub has a history, which is a list of msg_ids.
| This will contain the history of all clients, and, depending on configuration,
| may contain history across multiple cluster sessions.
| Any msg_id returned here is a valid argument to `get_result`.
| Returns
| msg_ids : list of strs
| list of all msg_ids, ordered by task submission time.
| load_balanced_view(self, targets=None, **kwargs)
| If no arguments are specified, create a LoadBalancedView
| using all engines.
| Parameters
| kwargs: passed to LoadBalancedView
| purge_everything(self)
| Clears all content from previous Tasks from both the hub and the local client
| In addition to calling `purge_results("all")` it also deletes the history and
| other bookkeeping lists.
| purge_hub_results(self, jobs=[], targets=[])
| Tell the Hub to forget results.
| Individual results can be purged by msg_id, or the entire
| history of specific targets can be purged.
| Use `purge_results('all')` to scrub everything from the Hub's db.
| Parameters
| jobs : str or list of str or AsyncResult objects
| the msg_ids whose results should be forgotten.
| targets : int/str/list of ints/strs
| The targets, by int_id, whose entire history is to be purged.
| default : None
| purge_local_results(self, jobs=[], targets=[])
| Clears the client caches of results and their metadata.
| Use `purge_local_results('all')` to scrub everything from the Clients's
| results and metadata caches.
| After this call all `AsyncResults` are invalid and should be discarded.
| If you must "reget" the results, you can still do so by using
| `client.get_result(msg_id)` or `client.get_result(asyncresult)`. This will
| redownload the results from the hub if they are still available
| (i.e `client.purge_hub_results(...)` has not been called.
| Parameters
| the msg_ids whose results should be purged.
| targets : int/list of ints
| The engines, by integer ID, whose entire result histories are to be purged.
| Raises
| RuntimeError : if any of the tasks to be purged are still outstanding.
| purge_results(self, jobs=[], targets=[])
| Clears the cached results from both the hub and the local client
| Use `purge_results('all')` to scrub every cached result from both the Hub's and
| the Client's db.
| Equivalent to calling both `purge_hub_results()` and `purge_client_results()` with
| the same arguments.
| Parameters
| default : None
| queue_status(self, targets='all', verbose=False)
| Fetch the status of engine queues.
| Parameters
| the engines whose states are to be queried.
| default : all
| verbose : bool
| Whether to return lengths only, or lists of ids for each element
| resubmit(self, indices_or_msg_ids=None, metadata=None, block=None)
| Resubmit one or more tasks.
| in-flight tasks may not be resubmitted.
| Parameters
| indices_or_msg_ids : integer history index, str msg_id, or list of either
| block : bool
| Returns
| AsyncHubResult
| result_status(self, msg_ids, status_only=True)
| Check on the status of the result(s) of the apply request with `msg_ids`.
| If status_only is False, then the actual results will be retrieved, else
| only the status of the results will be checked.
| Parameters
| msg_ids : list of msg_ids
| if int:
| Passed as index to self.history for convenience.
| status_only : bool (default: True)
| if False:
| Retrieve the actual results of completed tasks.
| Returns
| results : dict
| There will always be the keys 'pending' and 'completed', which will
| be lists of msg_ids that are incomplete or complete. If `status_only`
| is False, then completed results will be keyed by their `msg_id`.
| send_apply_request(self, socket, f, args=None, kwargs=None, metadata=None, track=False, ident=None)
| construct and send an apply message via a socket.
| This is the principal method with which all engine execution is performed by views.
| send_execute_request(self, socket, code, silent=True, metadata=None, ident=None)
| construct and send an execute request via a socket.
| shutdown(self, targets='all', restart=False, hub=False, block=None)
| Terminates one or more engine processes, optionally including the hub.
| Parameters
| targets: list of ints or 'all' [default: all]
| Which engines to shutdown.
| hub: bool [default: False]
| Whether to include the Hub. hub=True implies targets='all'.
| block: bool [default: self.block]
| Whether to wait for clean shutdown replies or not.
| restart: bool [default: False]
| NOT IMPLEMENTED
| whether to restart engines after shutting them down.
| spin(self)
| DEPRECATED, DOES NOTHING
| spin_thread(self, interval=1)
| stop_dask(self, targets='all')
| Stop the distributed Scheduler and Workers started by become_dask.
| Parameters
| Which engines to stop dask workers on.
| stop_distributed = stop_dask(self, targets='all')
| stop_spin_thread(self)
| wait(self, jobs=None, timeout=-1)
| waits on one or more `jobs`, for up to `timeout` seconds.
| Parameters
| jobs : int, str, or list of ints and/or strs, or one or more AsyncResult objects
| ints are indices to self.history
| strs are msg_ids
| default: wait on all outstanding messages
| timeout : float
| a time in seconds, after which to give up.
| default is -1, which means no timeout
| Returns
| True : when all msg_ids are done
| False : timeout reached, some msg_ids still outstanding
| wait_interactive(self, jobs=None, interval=1.0, timeout=-1.0)
| Wait interactively for jobs
| If no job is specified, will wait for all outstanding jobs to complete.
| Static methods defined here:
| __new__(self, *args, **kw)
| Readonly properties defined here:
| ids
| Always up-to-date ids property.
| Data descriptors defined here:
| block
| A boolean (True, False) trait.
| debug
| history
| An instance of a Python list.
| metadata
| A trait whose value must be an instance of a specified class.
| The value can also be an instance of a subclass of the specified class.
| Subclasses can declare default classes by overriding the klass attribute
| outstanding
| An instance of a Python set.
| profile
| A trait for unicode strings.
| results
| Methods inherited from traitlets.traitlets.HasTraits:
| __getstate__(self)
| __setstate__(self, state)
| add_traits(self, **traits)
| Dynamically add trait attributes to the HasTraits instance.
| has_trait(self, name)
| Returns True if the object has a trait with the specified name.
| hold_trait_notifications(self)
| Context manager for bundling trait change notifications and cross
| validation.
| Use this when doing multiple trait assignments (init, config), to avoid
| race conditions in trait notifiers requesting other trait values.
| All trait notifications will fire after all values have been assigned.
| notify_change(self, change)
| observe(self, handler, names=traitlets.All, type='change')
| Setup a handler to be called when a trait changes.
| This is used to setup dynamic notifications of trait changes.
| Parameters
| handler : callable
| A callable that is called when a trait changes. Its
| signature should be ``handler(change)``, where ``change`` is a
| dictionary. The change dictionary at least holds a 'type' key.
| * ``type``: the type of notification.
| Other keys may be passed depending on the value of 'type'. In the
| case where type is 'change', we also have the following keys:
| * ``owner`` : the HasTraits instance
| * ``old`` : the old value of the modified trait attribute
| * ``new`` : the new value of the modified trait attribute
| * ``name`` : the name of the modified trait attribute.
| names : list, str, All
| If names is All, the handler will apply to all traits. If a list
| of str, handler will apply to all names in the list. If a
| str, the handler will apply just to that name.
| type : str, All (default: 'change')
| The type of notification to filter by. If equal to All, then all
| notifications are passed to the observe handler.
| on_trait_change(self, handler=None, name=None, remove=False)
| DEPRECATED: Setup a handler to be called when a trait changes.
| Static handlers can be created by creating methods on a HasTraits
| subclass with the naming convention '_[traitname]_changed'. Thus,
| to create static handler for the trait 'a', create the method
| _a_changed(self, name, old, new) (fewer arguments can be used, see
| below).
| If `remove` is True and `handler` is not specified, all change
| handlers for the specified name are uninstalled.
| Parameters
| handler : callable, None
| signature can be handler(), handler(name), handler(name, new),
| handler(name, old, new), or handler(name, old, new, self).
| name : list, str, None
| If None, the handler will apply to all traits. If a list
| remove : bool
| If False (the default), then install the handler. If True
| then unintall it.
| set_trait(self, name, value)
| Forcibly sets trait attribute, including read-only attributes.
| setup_instance(self, *args, **kwargs)
| This is called **before** self.__init__ is called.
| trait_metadata(self, traitname, key, default=None)
| Get metadata values for trait by key.
| trait_names(self, **metadata)
| Get a list of all the names of this class' traits.
| traits(self, **metadata)
| Get a ``dict`` of all the traits of this class. The dictionary
| is keyed on the name and the values are the TraitType objects.
| The TraitTypes returned don't know anything about the values
| that the various HasTrait's instances are holding.
| The metadata kwargs allow functions to be passed in which
| filter traits based on metadata values. The functions should
| take a single value as an argument and return a boolean. If
| any function returns False, then the trait is not included in
| the output. If a metadata key doesn't exist, None will be passed
| to the function.
| unobserve(self, handler, names=traitlets.All, type='change')
| Remove a trait change handler.
| This is used to unregister handlers to trait change notifications.
| Parameters
| handler : callable
| The callable called when a trait attribute changes.
| names : list, str, All (default: All)
| The names of the traits for which the specified handler should be
| uninstalled. If names is All, the specified handler is uninstalled
| from the list of notifiers corresponding to all changes.
| type : str or All (default: 'change')
| The type of notification to filter by. If All, the specified handler
| is uninstalled from the list of notifiers corresponding to all types.
| unobserve_all(self, name=traitlets.All)
| Remove trait change handlers of any type for the specified name.
| If name is not specified, removes all trait notifiers.
| Class methods inherited from traitlets.traitlets.HasTraits:
| class_own_trait_events(name) from traitlets.traitlets.MetaHasTraits
| Get a dict of all event handlers defined on this class, not a parent.
| Works like ``event_handlers``, except for excluding traits from parents.
| class_own_traits(**metadata) from traitlets.traitlets.MetaHasTraits
| Get a dict of all the traitlets defined on this class, not a parent.
| Works like `class_traits`, except for excluding traits from parents.
| class_trait_names(**metadata) from traitlets.traitlets.MetaHasTraits
| This method is just like the :meth:`trait_names` method,
| but is unbound.
| class_traits(**metadata) from traitlets.traitlets.MetaHasTraits
| This method is just like the :meth:`traits` method, but is unbound.
| to the function.
| trait_events(name=None) from traitlets.traitlets.MetaHasTraits
| Get a ``dict`` of all the event handlers of this class.
| Parameters
| name: str (default: None)
| The name of a trait of this class. If name is ``None`` then all
| the event handlers of this class will be returned instead.
| Returns
| The event handlers associated with a trait name, or all event handlers.
| Readonly properties inherited from traitlets.traitlets.HasTraits:
| cross_validation_lock
| A contextmanager for running a block with our cross validation lock set
| to True.
| At the end of the block, the lock's value is restored to its value
| prior to entering the block.
| Data descriptors inherited from traitlets.traitlets.HasDescriptors:
| __dict__
| dictionary for instance variables (if defined)
| __weakref__
| list of weak references to the object (if defined)
from mpi4py import MPI
comm = MPI.COMM_WORLD
print (comm.rank, comm.size)
[stdout:0] 0 4
[stdout:1] 1 4
[stdout:2] 2 4
[stdout:3] 3 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:0] 0
[stdout:1] 77
[stdout:2] 78
[stdout:3] 75
inv = CGSolver(a.mat, pre.mat, printing=comm.rank==0, maxsteps=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:0]
iteration 0 error = 0.053339234092911685
iteration 1 error = 0.0740460414310471
iteration 2 error = 0.06370425458795265
iteration 3 error = 0.04919124251788342
iteration 4 error = 0.04829652542142217
iteration 5 error = 0.031106912554491464
iteration 6 error = 0.0249356433981004
iteration 7 error = 0.01784194991245135
iteration 8 error = 0.013817492065755424
iteration 9 error = 0.011423769319077626
iteration 10 error = 0.00839386761852051
iteration 11 error = 0.004233406891736342
iteration 12 error = 0.0019377308491299874
iteration 13 error = 0.001408555531820299
iteration 14 error = 0.000991343797171786
iteration 15 error = 0.0006412217321541269
iteration 16 error = 0.00044876370080339955
iteration 17 error = 0.00029026903025157827
iteration 18 error = 0.00017121515214383354
iteration 19 error = 0.00013131363792643467
iteration 20 error = 0.00010180630781276401
iteration 21 error = 6.493748016473812e-05
iteration 22 error = 3.747328865245323e-05
iteration 23 error = 2.4894442492438547e-05
iteration 24 error = 1.8668022673771387e-05
iteration 25 error = 1.4656078306112323e-05
iteration 26 error = 1.00312807766201e-05
iteration 27 error = 6.195489468925556e-06
iteration 28 error = 3.8394953774092735e-06
iteration 29 error = 2.9619818216397206e-06
iteration 30 error = 2.191076333882794e-06
iteration 31 error = 1.5147554899846986e-06
iteration 32 error = 9.456591809733725e-07
iteration 33 error = 6.934293022267518e-07
iteration 34 error = 5.419825539015876e-07
iteration 35 error = 3.8073885692382817e-07
iteration 36 error = 2.610840714803283e-07
iteration 37 error = 1.6150747478403415e-07
iteration 38 error = 1.0843607023800082e-07
iteration 39 error = 8.266347488194315e-08
iteration 40 error = 6.401498304181558e-08
iteration 41 error = 4.089801380525814e-08
iteration 42 error = 2.518568909359594e-08
iteration 43 error = 1.7451968530291785e-08
iteration 44 error = 1.2422309974412238e-08
iteration 45 error = 8.990884037271554e-09
iteration 46 error = 5.8101609164032095e-09
iteration 47 error = 3.298163877994398e-09
iteration 48 error = 2.1285824956359945e-09
iteration 49 error = 1.5456064017184192e-09
iteration 50 error = 1.0303209026040304e-09
iteration 51 error = 6.846274435536751e-10
iteration 52 error = 4.5512272688861414e-10
Parallel pickling allows to serialize the distributed solution and transfer it to the client:
netgen.meshing.SetParallelPickling(True)
In the next bit of code, all processes of the client object c pickle their local gfu object. Setting SetParallelPickling(True) enables communication so that the process with rank=0 gets the whole mesh and the computed solution.
gfu = c[:]["gfu"]
Draw (gfu[0])
Draw (gfu[3])
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2 = c[:]["gfL2"]
Draw (gfL2[0])
