This page was generated from unit-5.2-fetidp_point2d/feti-dp-i.ipynb.
5.2 FETI-DP in NGSolve I: Working with Point-Constraints¶
We need access to sub-assembled matrices for each subdomain, which is exactly how matrices are stored in NGSolve.
In fact, we can just reuse these local matrices for the dual-primal space.
We do not need to concern ourselfs with finding any sort of global enumeration in the dual-primal space, because NGSolve does not work with one. We only need ParallelDofs for the dual-primal space.
Use the cells at the bottom of this file to experiment with bigger computations!¶
num_procs = '40'
stop_cluster()
start_cluster(num_procs)
connect_cluster()
comm = MPI_Init()
nref = 1
ngmesh.Load('squaref.vol')
for l in range(nref):
    ngmesh.Refine()
comm = MPI_Init()
f += SymbolicLFI(x*y*v)
if comm.rank==0:
[stdout:10]
avg DOFs per core:  4823.075
Finding the primal DOFs¶
if comm.rank==0:
[stdout:10]
# primal dofs global:  56
Setting up the Dual-Primal-Space Matrix¶
This means that we need:
local stiffness matrices:
ParallelDofs
if comm.rank==0:
[stdout:10]
The ParallelMatrix for the DP-Space¶
The Jump-Operator \(B\)¶
In order for CreateRowVector to be properly defined, the jump-operator has to be told in which space the "u-vectors" live.
This is done by setting "u_pardofs". If none are given, or they are explicitely given as "None", B assumes a fully discontinuous u-space.
if comm.rank==0:
elif comm.rank<10:
Forming the Schur-Complement¶
We can very easily define the (negative) Schur-Complement \(F = B~A_{\scriptscriptstyle DP}^{-1}~B^T\) with the "@"-operator.
"@" can concatenate any operators of "BaseMatrix" type. They have to provide a Mult method as well as CreateRow/ColVector, which is needed to construct vectors to store intermediate vectors.
F = B @ A_dp_inv @ B.T
if comm.rank==0:
    print('type F: ', type(F))
The Preconditioner¶
A = a.mat.local_mat
Multiplicity Scaling¶
class ScaledMat(BaseMatrix):
    def __init__ (self, A, vals):
        self.A = A
    def CreateRowVector(self):
    def CreateColVector(self):
    def Mult(self, x, y):
        y.data = self.A * x
        for k in self.scaledofs:
            y[k[0]] *= k[1]
Prepare RHS¶
hv = B.CreateRowVector()
rhs = B.CreateColVector()
lam = B.CreateColVector()
hv.data = A_dp_inv * f.vec
rhs.data = B * hv
Solve for \(\lambda\) - without scaling¶
tsolve1 = -comm.WTime()
tsolve1 += comm.WTime()
if comm.rank==0:
[stdout:10]
Solve for \(\lambda\) - with scaling¶
tsolve2 = -comm.WTime()
tsolve2 += comm.WTime()
if comm.rank==0:
[stdout:10]
A faster dual-primal Inverse¶
from dd_toolbox import Op2SPM
        self.Aglob = Aglob
        self.A = Aglob.local_mat
        pardofs = Aglob.col_pardofs
        return self.CreateRowVector()
    def Mult(self, b, u):
        b.Distribute()
                           'sparsecholesky', 'mumps')
F2 = B @ A_dp_inv2 @ B.T
Solve for \(\lambda\)¶
if comm.rank==0:
    print('')
if comm.rank==0:
    print('')
tsolve3 = -comm.WTime()
tsolve3 += comm.WTime()
if comm.rank==0:
[stdout:10]
Reconstruct \(u\)¶
hv.data = f.vec - B.T * lam
gfu.vec.data = A_dp_inv * hv
jump = lam.CreateVector()
jump.data = B * gfu.vec
norm_jump = Norm(jump)
if comm.rank==0:
%%px --target 1
if t_chol['time'] == maxt:
[stdout:36]
stop_cluster()
Experiment Below!¶
num_procs = '80'
connect_cluster()
def load_mesh(nref=0):
        ngmesh.Refine()
    return Mesh(ngmesh)
    comm = MPI_Init()
    if comm.rank==0:
    return [fes, a, f]
def setup_FETIDP(fes, a):
    if comm.rank==0:
    if comm.rank==0:
    A = a.mat.local_mat
def prep(B, Ainv, f):
    rhs.data = (B @ Ainv) * f.vec
    return rhs
    t = comm.WTime()
    return comm.WTime() - t
def post(B, Ainv, gfu, lam):
    gfu.vec.data = Ainv * hv
    if comm.rank==0:
comm = MPI_Init()
mesh = load_mesh(nref=1)
prep(B, A_dp_inv2, f)
if comm.rank==0:
    print('')
if comm.rank==0:
    print('')
if comm.rank==0:
    print('')
if comm.rank==0:
    print('time solve v2: ', t2)
    print('time solve v3: ', t3)
post(B, A_dp_inv2, gfu, lam)
[stdout:1]
avg DOFs per core:  2441.0875
# primal dofs global:  125
%%px --target 1
[stdout:12]
timers from rank  14 :
stop_cluster()
