from netgen import gui
Mesh of (only) the surface:¶
order = 4
if order > 0:
    mesh.Curve(order)
Tangential velocity field:¶
t = Parameter(0.)
Draw (b, mesh, "b")
eps = 5e-5
some local quantities¶
bn = InnerProduct(b,con)
Discretization¶
Surface FESpaces:¶
u,uE = fes.TrialFunction()
v,vE = fes.TestFunction()
gradu = u.Trace().Deriv()
gradv = v.Trace().Deriv()
jumpu = u - uE
jumpv = v - vE
\[  \sum_T \int_T \nabla u \nabla v
- \sum_T \int_{\partial T} n \nabla u (v-\widehat v)
- \sum_T \int_{\partial T} n \nabla u (u-\widehat u)
# diffusion
alpha = 10*(order+1)**2
a += eps*gradu * gradv * ds
a += - eps*dudn * jumpv * dr
a += - eps*dvdn * jumpu * dr
\[ \begin{align}\begin{aligned}    \sum_T \int_T - u \mathbf{w} \cdot \nabla v
  + \sum_T \int_{\partial T_{out}} (\mathbf{w} \cdot \mathbf{n}) (\hat{u} - u) \hat{v}\\with\end{aligned}\end{align} \]
\[\begin{split}u^{hyb-upw} = \left\{ \begin{array}{cll} u & \text{if } \mathbf{w} \cdot \mathbf{n} & (outflow),  \\ \hat{u} & \text{else}  & (inflow) . \end{array} \right.\end{split}\]
outflow  |
inflow  |
Mass matrix:¶
m = BilinearForm(fes)
dt = 0.02
mstarinv = mstar.Inverse()
T = 8*pi
Time stepping¶
res = gfu.vec.CreateVector()
The time loop¶
t.Set(0)
for i in range(int(T/dt)):
    res.data = m.mat * gfu.vec
    gfu.vec.data = mstarinv * res
    t.Set(t.Get()+dt)
Remark:¶
