This page was generated from unit-2.1.3-bddc/bddc.ipynb.
Let us start with a simple description of the element-wise BDDC in the context of Lagrange finite element space \(V\). Here the BDDC preconditoner is constructed on an auxiliary space \(\widetilde{V}\) obtained by connecting only element vertices (leaving edge and face shape functions discontinuous). Although larger, the auxiliary space allows local elimination of edge and face variables. Hence an analogue of the original matrix \(A\) on this space, named \(\widetilde A\), is less expensive to invert. This inverse is used to construct a preconditioner for \(A\) as follows:
SetHeapSize(100*1000*1000)
Built-in options¶
Effect of condensation¶
c = Preconditioner(a, "bddc")
lams = TestPreconditioner(5)
1.00374
1.10078
1.29559
22.8683
27.2387
29.5068
1.00153
1.04077
1.13375
7.44898
8.13299
8.95809
Tuning the auxiliary space¶
wb_fulledges |
wb_withedges |
2D |
3D |
True |
any value |
all |
all |
False/Undefined |
Undefined |
none |
first |
False/Undefined |
False |
none |
none |
False/Undefined |
True |
first |
first |
wb_withedges=False)
1.00425
1.08049
1.32286
30.4513
32.3987
32.9451
Customize¶
fes = H1(mesh, order=10)
for ed in mesh.edges:
dofs = fes.GetDofNrs(ed)
for d in dofs:
max(lams)/min(lams)
24.44038706141732
max(lams)/min(lams)
38.069056750527814
p = 5
wb_withedges=False)
print("NDOF = ", fes.ndof)
f += v*dx
pre=pre, maxsteps=500)
Draw(gfu)
NDOF = 1146726
iteration 0 error = 0.7088026163329622
iteration 1 error = 0.2880387511317821
iteration 2 error = 0.2777052954298467
iteration 3 error = 0.28802115597527217
iteration 4 error = 0.3164988880660468
iteration 5 error = 0.24220430465893777
iteration 6 error = 0.1867133286752495
iteration 7 error = 0.15495818469657255
iteration 8 error = 0.12157075847321219
iteration 9 error = 0.0987121640912445
iteration 10 error = 0.07416484530918528
iteration 11 error = 0.05802375878310729
iteration 12 error = 0.047176229204210954
iteration 13 error = 0.03860496800095335
iteration 14 error = 0.031240378784601876
iteration 15 error = 0.024430544031740237
iteration 16 error = 0.018837944758251603
iteration 17 error = 0.01532146344857354
iteration 18 error = 0.012652466572130235
iteration 19 error = 0.009977256307324586
iteration 20 error = 0.007662956312706297
iteration 21 error = 0.006046504457885159
iteration 22 error = 0.004849160002900024
iteration 23 error = 0.0038808045883691774
iteration 24 error = 0.003115986975566744
iteration 25 error = 0.002485046994135082
iteration 26 error = 0.0020242534581958738
iteration 27 error = 0.0016357764353589505
iteration 28 error = 0.0013030494365250808
iteration 29 error = 0.0010391487389604284
iteration 30 error = 0.0008384547772049004
iteration 31 error = 0.0006795122070749139
iteration 32 error = 0.0005456748810311364
iteration 33 error = 0.0004300879747222369
iteration 34 error = 0.0003398012012380738
iteration 35 error = 0.00027362415288402026
iteration 36 error = 0.00022117517545390878
iteration 37 error = 0.0001772558761296194
iteration 38 error = 0.000138937891991195
iteration 39 error = 0.00011084631248865267
iteration 40 error = 8.892396977116252e-05
iteration 41 error = 7.07418082208448e-05
iteration 42 error = 5.697276421962551e-05
iteration 43 error = 4.600926412017712e-05
iteration 44 error = 3.712567923766873e-05
iteration 45 error = 2.9812585948505525e-05
iteration 46 error = 2.366327350134894e-05
iteration 47 error = 1.8937964599754393e-05
iteration 48 error = 1.575398180039847e-05
iteration 49 error = 1.2649637838706808e-05
iteration 50 error = 1.003458691378735e-05
iteration 51 error = 8.090254963984338e-06
iteration 52 error = 6.538438231747872e-06
iteration 53 error = 5.214029556524986e-06
iteration 54 error = 4.201981675453009e-06
iteration 55 error = 3.35217759044089e-06
iteration 56 error = 2.723618065380085e-06
iteration 57 error = 2.185819445969736e-06
iteration 58 error = 1.7606523917523128e-06
iteration 59 error = 1.408294912692138e-06
iteration 60 error = 1.1415548401682886e-06
iteration 61 error = 9.30089529534606e-07
iteration 62 error = 7.445918014516059e-07
iteration 63 error = 5.947741160153919e-07
iteration 64 error = 4.773915337235815e-07
iteration 65 error = 3.828424341762492e-07
iteration 66 error = 3.050932627773345e-07
iteration 67 error = 2.4247086375975486e-07
iteration 68 error = 1.9624162260115836e-07
iteration 69 error = 1.5727742871551489e-07
iteration 70 error = 1.254934308417717e-07
iteration 71 error = 1.0086334388482721e-07
iteration 72 error = 8.087399757505533e-08
iteration 73 error = 6.499696557770997e-08
iteration 74 error = 5.187430254832745e-08
iteration 75 error = 4.217152525989542e-08
iteration 76 error = 3.3878054899928585e-08
iteration 77 error = 2.7485521398486036e-08
iteration 78 error = 2.2551040201448242e-08
iteration 79 error = 1.8684102941855268e-08
iteration 80 error = 1.4932413483213692e-08
iteration 81 error = 1.2002294992630794e-08
iteration 82 error = 9.591293658252395e-09
iteration 83 error = 7.618596444585864e-09
iteration 84 error = 6.120472413059393e-09
iteration 85 error = 4.8905585599097136e-09
iteration 86 error = 3.9510819328379815e-09
iteration 87 error = 3.180642096506572e-09
iteration 88 error = 2.5060153022632155e-09
iteration 89 error = 1.9898481489791143e-09
iteration 90 error = 1.6083027847985985e-09
iteration 91 error = 1.2998309527845715e-09
iteration 92 error = 1.0364080833468496e-09
iteration 93 error = 8.397852060490159e-10
iteration 94 error = 6.695899303440501e-10
iteration 95 error = 5.406177154897033e-10
iteration 96 error = 4.3188478945899653e-10
iteration 97 error = 3.412250148379627e-10
iteration 98 error = 2.760645397117658e-10
iteration 99 error = 2.201213851961198e-10
iteration 100 error = 1.7605272857384957e-10
iteration 101 error = 1.412236135274814e-10
iteration 102 error = 1.1463481979294935e-10
iteration 103 error = 9.159091090745161e-11
iteration 104 error = 7.346532264211043e-11
iteration 105 error = 5.83223795378958e-11
iteration 106 error = 4.6391119297381964e-11
iteration 107 error = 3.7444880775838955e-11
iteration 108 error = 2.988367116372467e-11
iteration 109 error = 2.4019512546551548e-11
iteration 110 error = 1.9280078802156997e-11
iteration 111 error = 1.5443280603460424e-11
iteration 112 error = 1.2365285158995687e-11
iteration 113 error = 1.0039531904718748e-11
iteration 114 error = 7.985483923543628e-12
iteration 115 error = 6.3818552299796965e-12
iteration 116 error = 5.093669164586701e-12
iteration 117 error = 4.025703538485406e-12
iteration 118 error = 3.2410638638496467e-12
iteration 119 error = 2.6385524014990052e-12
iteration 120 error = 2.147086788028059e-12
iteration 121 error = 1.7578594716261973e-12
iteration 122 error = 1.414764259226634e-12
iteration 123 error = 1.1165188954179682e-12
iteration 124 error = 8.943043209493137e-13
iteration 125 error = 7.194822961451338e-13
iteration 126 error = 5.747221292927254e-13
Postscript¶
fes = FESpace([fes_ho, fes_lo, fes_lam])
- 1*uho*dx
solvers.Newton(a=a, u=gfu)
Draw(gfu.components[0])
Newton iteration 0
err = 0.3929793997717297
Newton iteration 1
err = 3.956677249565376e-15
