1.2 CoefficientFunctions¶
define a
CoefficientFunction,evaluate
Define a function¶
myfunc = x*(1-x)
<ngsolve.fem.CoefficientFunction at 0x7f1d775388e0>
<ngsolve.fem.CoefficientFunction at 0x7f1d7caa1468>
Visualize the function¶
Evaluate the function¶
mip = mesh(0.2, 0.2)
myfunc(mip)
0.16000000000000003
for p,v in zip(pts, vals):
%(p[0], p[1], v))
plt.plot(px,vals)
plt.xlabel('x')
print(myfunc)
coef coordinate x, real
coef 1, real
Integrate a function¶
Integrate(myfunc, mesh)
0.16666666666666602
Differentiate a function¶
diff_myfunc = myfunc.Diff(x)
print(diff_myfunc)
coef 1, real
coef 1, real
coef 0, real
coef 1, real
Parameters in functions¶
k = Parameter(1.0)
f = sin(k*y)
Draw(f, mesh, "f")
k.Set(10)
Draw(f, mesh, "f")
print(f)
coef coordinate y, real
f.Diff(k)
<ngsolve.fem.CoefficientFunction at 0x7f1d76b73678>
Interpolate a function¶
fes = H1(mesh, order=1)
u = GridFunction(fes)
u.Set(myfunc)
The
It then projects
Draw(vecfun, mesh, "vecfun")
u.Set(myfunc)
gradu = grad(u)
Compiled CoefficientFunction¶
print(myfunc)
coef 1, real
print(myfunc_compiled)
Compiled CF:
Step 0: coordinate x
Step 1: 1
Step 2: binary operation '-'
input: 1 0
Step 3: binary operation '*'
input: 0 2
f0 = myfunc
f1 = f0*y
f2 = f1*f1 + f1*f0 + f0*f0
final = f3 + f3 + f3
finalc = final.Compile()
1.41 ms ± 123 µs per loop (mean ± std. dev. of 7 runs, 1000 loops each)
178 µs ± 9.08 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
128 µs ± 8.14 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
print(finalc)
Compiled CF:
Step 1: 1
input: 1 0
input: 0 2
Step 4: coordinate y
Step 5: binary operation '*'
input: 3 4
Step 6: binary operation '*'
input: 5 5
Step 7: binary operation '*'
input: 5 3
Step 8: binary operation '+'
input: 6 7
Step 9: binary operation '*'
input: 3 3
Step 10: binary operation '+'
input: 8 9
Step 11: binary operation '*'
input: 10 10
Step 12: binary operation '*'
input: 11 10
Step 13: binary operation '*'
input: 3 3
Step 14: binary operation '*'
input: 12 13
Step 15: binary operation '*'
input: 10 10
Step 16: binary operation '*'
input: 3 15
Step 17: binary operation '+'
input: 14 16
Step 18: binary operation '*'
input: 3 3
Step 19: binary operation '+'
input: 17 18
Step 20: binary operation '*'
input: 5 5
Step 21: binary operation '+'
input: 19 20
Step 22: binary operation '*'
input: 10 10
Step 23: binary operation '+'
input: 21 22
Step 24: binary operation '+'
input: 23 23
Step 25: binary operation '+'
input: 24 23
print(final)
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
