This page was generated from unit-5.1-mpi_ngsolve/mpi_basics.ipynb.
5.1 Basics of MPI-parallel NGSolve¶
num_procs = '20'
stop_cluster()
start_cluster(num_procs)
connect_cluster()
Using MPI through NGSolve¶
Getting Started¶
comm = MPI_Init()
[stdout:0] Hello from rank 13 of 20
[stdout:1] Hello from rank 2 of 20
[stdout:2] Hello from rank 15 of 20
[stdout:3] Hello from rank 7 of 20
[stdout:4] Hello from rank 14 of 20
[stdout:5] Hello from rank 6 of 20
[stdout:6] Hello from rank 12 of 20
[stdout:7] Hello from rank 19 of 20
[stdout:8] Hello from rank 18 of 20
[stdout:9] Hello from rank 3 of 20
[stdout:10] Hello from rank 5 of 20
[stdout:11] Hello from rank 17 of 20
[stdout:12] Hello from rank 8 of 20
[stdout:13] Hello from rank 16 of 20
[stdout:14] Hello from rank 10 of 20
[stdout:15] Hello from rank 4 of 20
[stdout:16] Hello from rank 0 of 20
[stdout:17] Hello from rank 11 of 20
[stdout:18] Hello from rank 9 of 20
[stdout:19] Hello from rank 1 of 20
Additionally, “comm” provides:
time measurement
barriers
computing sums, minima, maxima
t = comm.WTime()
s2 = comm.Sum(1)
t = comm.Max(comm.WTime()-t)
if comm.rank==0:
[stdout:16] There are 20 of us, which took us 0.017204 seconds to figure out
Distributed Meshes¶
mesh = Mesh('square.vol')
[stdout:0] rank 13's part of the mesh has 4 elements, 4 faces, 9 edges and 6 vertices
[stdout:1] rank 2's part of the mesh has 2 elements, 2 faces, 6 edges and 5 vertices
[stdout:2] rank 15's part of the mesh has 3 elements, 3 faces, 8 edges and 6 vertices
[stdout:3] rank 7's part of the mesh has 2 elements, 2 faces, 7 edges and 6 vertices
[stdout:4] rank 14's part of the mesh has 3 elements, 3 faces, 7 edges and 5 vertices
[stdout:5] rank 6's part of the mesh has 3 elements, 3 faces, 7 edges and 5 vertices
[stdout:6] rank 12's part of the mesh has 4 elements, 4 faces, 9 edges and 6 vertices
[stdout:7] rank 19's part of the mesh has 3 elements, 3 faces, 10 edges and 7 vertices
[stdout:8] rank 18's part of the mesh has 2 elements, 2 faces, 8 edges and 7 vertices
[stdout:9] rank 3's part of the mesh has 3 elements, 3 faces, 8 edges and 6 vertices
[stdout:10] rank 5's part of the mesh has 3 elements, 3 faces, 10 edges and 7 vertices
[stdout:11] rank 17's part of the mesh has 3 elements, 3 faces, 9 edges and 9 vertices
[stdout:12] rank 8's part of the mesh has 3 elements, 3 faces, 7 edges and 5 vertices
[stdout:13] rank 16's part of the mesh has 4 elements, 4 faces, 9 edges and 6 vertices
[stdout:14] rank 10's part of the mesh has 2 elements, 2 faces, 5 edges and 4 vertices
[stdout:15] rank 4's part of the mesh has 3 elements, 3 faces, 8 edges and 7 vertices
[stdout:16] rank 0's part of the mesh has 0 elements, 0 faces, 0 edges and 0 vertices
[stdout:17] rank 11's part of the mesh has 2 elements, 2 faces, 6 edges and 5 vertices
[stdout:18] rank 9's part of the mesh has 3 elements, 3 faces, 7 edges and 5 vertices
[stdout:19] rank 1's part of the mesh has 4 elements, 4 faces, 10 edges and 7 vertices
%%px --targets 0:5
[stdout:0]
rank 13 Boundaries: ('bottom', 'right', 'top', 'left')
[stdout:1]
rank 2 Boundaries: ('bottom', 'right', 'top', 'left')
[stdout:2]
rank 15 Boundaries: ('bottom', 'right', 'top', 'left')
[stdout:3]
rank 7 Boundaries: ('bottom', 'right', 'top', 'left')
[stdout:4]
rank 14 Boundaries: ('bottom', 'right', 'top', 'left')
Distributed Finite Element Spaces¶
[stdout:0] fes on rank 13 has 28 DOFs, globally we have 283
[stdout:1] fes on rank 2 has 19 DOFs, globally we have 283
[stdout:2] fes on rank 15 has 25 DOFs, globally we have 283
[stdout:3] fes on rank 7 has 22 DOFs, globally we have 283
[stdout:4] fes on rank 14 has 22 DOFs, globally we have 283
[stdout:5] fes on rank 6 has 22 DOFs, globally we have 283
[stdout:6] fes on rank 12 has 28 DOFs, globally we have 283
[stdout:7] fes on rank 19 has 30 DOFs, globally we have 283
[stdout:8] fes on rank 18 has 25 DOFs, globally we have 283
[stdout:9] fes on rank 3 has 25 DOFs, globally we have 283
[stdout:10] fes on rank 5 has 30 DOFs, globally we have 283
[stdout:11] fes on rank 17 has 30 DOFs, globally we have 283
[stdout:12] fes on rank 8 has 22 DOFs, globally we have 283
[stdout:13] fes on rank 16 has 28 DOFs, globally we have 283
[stdout:14] fes on rank 10 has 16 DOFs, globally we have 283
[stdout:15] fes on rank 4 has 26 DOFs, globally we have 283
[stdout:16] fes on rank 0 has 0 DOFs, globally we have 283
[stdout:17] fes on rank 11 has 19 DOFs, globally we have 283
[stdout:18] fes on rank 9 has 22 DOFs, globally we have 283
[stdout:19] fes on rank 1 has 31 DOFs, globally we have 283
nd2 = comm.Sum(fes.ndof)
if comm.rank==0:
[stdout:16] Strangely, the sum of all local DOFs is 470 != 283
Some base functions have to be shared across subdomains. Each subdomain takes the place of a makro Finite Element.
Information about how the DOFs stick together on a global level are stored in the “ParallelDofs” object:
pd = fes.ParallelDofs()
%%px --target=3
print('---')
print('... and so forth ...')
print('\n')
if len(pd.Proc2Dof(p)):
I am rank 7
I share DOF 0 with ranks: [8]
I share DOF 3 with ranks: [5]
I share DOF 6 with ranks: []
I share DOF 7 with ranks: []
I share DOF 8 with ranks: [8]
I share DOF 9 with ranks: [8]
DOFs I share with rank 1 : [1, 2, 4, 10, 11]
DOFs I share with rank 2 : [1]
DOFs I share with rank 5 : [2, 3, 4, 5, 12, 13, 14, 15, 16, 17, 18, 19]
DOFs I share with rank 8 : [0, 4, 5, 8, 9]
DOFs I share with rank 17 : [1]
Locally, DOFs are numbered 0..ndoflocal-1.
There is no global enumeration!
The local numbering of DOFs is conistent across subdomain boundaries. (This just means that there exists some global enumeration of DOFs that is cinsistent with the local ones.)
Distributed Weak Formulations & Linear Algebra¶
%%px --target=1
Parallel Matrices and Vectors¶
Matrices¶
%%px --target=1,2
print('fes pardofs: ', fes.ParallelDofs())
[stdout:1]
lcoal fes ndof: 19
a.mat.row_pardofs: <ngsolve.la.ParallelDofs object at 0x2b5807f49c38>
a.mat.col_pardofs: <ngsolve.la.ParallelDofs object at 0x2b5807f49c38>
fes pardofs: <ngsolve.la.ParallelDofs object at 0x2b5807f49c38>
[stdout:2]
lcoal fes ndof: 25
a.mat.row_pardofs: <ngsolve.la.ParallelDofs object at 0x2b824beacc00>
a.mat.col_pardofs: <ngsolve.la.ParallelDofs object at 0x2b824beacc00>
fes pardofs: <ngsolve.la.ParallelDofs object at 0x2b824beacc00>
Note¶
Vectors¶
f += SymbolicLFI(x*y*v)
%%px --target 1
print('length of vector: ', len(gfu.vec))
print('dim local fes: ', fes.ndof)
print('dim global fes: ', fes.ndofglobal)
length of vector: 19
length of local vec: 19
dim local fes: 19
dim global fes: 283
Parallel Vectors additionally have a “ParallelStatus”, which can be:
Cumulated, whenhe local vectors \(v^i\) are just restrictions of the global vector \(v\):
Distributed, when, similarly to parallel matrices, the global vector is the sum of local contributions
%%px --target 1
print('status f vec: ', f.vec.GetParallelStatus())
print('')
print('status gfu vec: ', gfu.vec.GetParallelStatus())
status f vec: PARALLEL_STATUS.DISTRIBUTED
status vec.local_vec: PARALLEL_STATUS.NOT_PARALLEL
status gfu vec: PARALLEL_STATUS.CUMULATED
v = gfu.vec.CreateVector()
w = gfu.vec.CreateVector()
v[:] = 1.0
w.data = a.mat * v
%%px --target 1
status v: PARALLEL_STATUS.CUMULATED
status w: PARALLEL_STATUS.DISTRIBUTED
Solvers and Preconditioners with MPI¶
Not all solvers and preconditioners included in NGSolve also work with MPI, but many do: ### Direct Solvers - masterinverse: Collect the entire matrix on the “master” and invert sequentially there. - MUMPS inverse: Distributed parallel inverse, scalability is limited.
Preconditioners¶
BDDC
‘hypre’: Boomer AMG
‘hypre_ams’: Auxiliary Maxwell Space AMG
‘local’
[stdout:16]
it = 0 err = 0.1099777875557949
it = 1 err = 0.04115832958100785
it = 2 err = 0.01640413427737909
it = 3 err = 0.002399109415917421
it = 4 err = 0.002415741796640736
it = 5 err = 0.007649635824685178
it = 6 err = 0.005797037984086125
it = 7 err = 0.0018076379420930557
it = 8 err = 0.001549550034376465
it = 9 err = 0.003298447178932686
it = 10 err = 0.0016507909555561475
it = 11 err = 0.0006339283042538051
it = 12 err = 0.0002833425899718731
it = 13 err = 0.00010532173704651773
it = 14 err = 3.2319246923796026e-05
it = 15 err = 1.0179181507465682e-05
it = 16 err = 3.2057362836107735e-06
it = 17 err = 9.871239271369994e-07
it = 18 err = 2.7671426326565997e-07
stop_cluster()
