5.4 FETI-DP in NGSolve III: Using Non-Point Constraints¶
num_procs = '40'
stop_cluster()
start_cluster(num_procs)
connect_cluster()
nref = 0
dim=3
ngmesh.Load('cube.vol')
for l in range(nref):
ngmesh.Refine()
comm = MPI_Init()
f += SymbolicLFI(x*y*v)
pardofs = fes.ParallelDofs()
if comm.rank==0:
[stdout:31]
global, ndof = 75403 , lodofs = 10355
avg DOFs per core: 2260.7
A new dual-primal space¶
pythonic = True
if pythonic:
faces = []
edges = []
for f1 in faces:
for f2 in faces:
if f1 is not f2:
if len(edge) > 1:
if not edge in edges:
vertices = set()
for e1 in edges:
for e2 in edges:
if e1 is not e2:
vertices = vertices.union(vs)
vertices = sorted(vertices)
vec = f.vec.CreateVector()
vec.local_vec[:] = 0.0
for v in vertices:
vec.local_vec[v] = 1
vec.Cumulate()
- we do not want any subdomain vertices do be included in the edges
- (for consistency) we want neither subdomain vertices nor subdomain edge-DOFs in the faces
if comm.rank==0:
[stdout:31]
# primal dofs global: 122
min, avg, max per rank: 4 12.425 25
Setting up the Edge-Constraint Matrix¶
ParallelDofs for w¶
if comm.rank==0:
[stdout:31]
# edge constraints global: 227
min, avg, max: 9 17.025 29
Getting the Dual-Primal Inverse¶
DPSpace_Inverse needs:
- the original matrix matrix
- a freedofs-BitArray
- a BitArray for the point-constraints
- the constraint matrix, and paralleldofs for \(w\)
- the inversetype to use for local problems
- the inversetype to use for the global coarse grid problem
c_points=primal_dofs, \
invtype_glob='masterinverse')
num_procs = '100'
stop_cluster()
connect_cluster()
def load_mesh(nref=0):
ngmesh.Refine()
return Mesh(ngmesh)
comm = MPI_Init()
if comm.rank==0:
return [fes, a, f]
def setup_FETIDP(fes, a):
if comm.rank==0:
if comm.rank==0:
F = B @ A_dp_inv @ B.T
A = a.mat.local_mat
def prep(B, Ainv, f):
rhs.data = (B @ Ainv) * f.vec
return rhs
t = comm.WTime()
return comm.WTime() - t
def post(B, Ainv, gfu, lam):
hv = B.CreateRowVector()
hv.data = f.vec - B.T * lam
gfu.vec.data = Ainv * hv
jump = lam.CreateVector()
jump.data = B * gfu.vec
norm_jump = Norm(jump)
if comm.rank==0:
comm = MPI_Init()
mesh = load_mesh(nref=1)
rhs = B.CreateColVector()
lam = B.CreateColVector()
prep(B, A_dp_inv, f)
if comm.rank==0:
print('')
t = solve(F, Fhat, rhs, lam)
if comm.rank==0:
print('\ntime solve: ', t)
post(B, A_dp_inv, gfu, lam)
[stdout:16]
avg DOFs per core: 6607.56
# of global primal dofs: 399
it = 0 err = 0.12130848690672913
it = 1 err = 0.02390767825931742
it = 2 err = 0.00825023321167997
it = 3 err = 0.002729895619289229
it = 4 err = 0.0008641121927087105
it = 5 err = 0.0003048442822355854
it = 6 err = 9.712889856412031e-05
it = 7 err = 3.3730326402392145e-05
it = 8 err = 1.0925387588517252e-05
it = 9 err = 3.32252185091653e-06
it = 10 err = 1.067131618337071e-06
it = 11 err = 3.318060576723047e-07
time solve: 0.5276237779762596
dofs per core and second: 10933.491326199415
norm jump u: 2.0337283556173004e-06
%%px --target 1
SparseCholesky<d,d,d>::MultAdd : 1.095705270767212
SparseCholesky<d,d,d>::MultAdd fac1 : 0.6547586917877197
if t_chol['time'] == maxt:
[stdout:2]
timers from rank 13 :
SparseCholesky<d,d,d>::MultAdd : 1.214454174041748
SparseCholesky<d,d,d>::MultAdd fac1 : 0.7252676486968994
SparseCholesky<d,d,d>::MultAdd fac2 : 0.47362494468688965
SparseCholesky - total : 0.42598485946655273
stop_cluster()
