1.2 CoefficientFunctions
In NGSolve, CoefficientFunctions are representations of functions defined on the computational domain \(\Omega\). Examples are expressions of coordinate variables \(x, y, z\) and functions that are constant on subdomains. Much of the magic behind the seamless integration of NGSolve with python lies in CoefficientFunctions. This tutorial introduces you to them.
%gui tk
Define a function
myfunc = x*(1-x)
myfunc   # You have just created a CoefficientFunction
<ngsolve.fem.CoefficientFunction at 0x7f6e44cfad00>
x        # This is a built-in CoefficientFunction
<ngsolve.fem.CoefficientFunction at 0x7f6e44cfa518>
Draw the function
Evaluate the function
mip = mesh(0.2, 0.2)
myfunc(mip)
0.16000000000000003
Note that myfunc(0.2,0.3) does not work: You need to give points in the form of MappedIntegrationPoints like mip above. The mesh knows how to produce them.
Examining functions on sets of points
for p,v in zip(pts, vals):
         %(p[0], p[1], v))
plt.plot(px,vals)
plt.xlabel('x')
<Figure size 640x480 with 1 Axes>
Interpolate a CoefficientFunction
fes = H1(mesh, order=1)
u = GridFunction(fes)
u.Set(myfunc)
Draw(u)         # Cf.: Draw(myfunc, mesh, "firstfun")
  • The Set method interpolates myfunc to obtain the grid function u.
  • Set does an Oswald-type interpolation as follows:
    • It first zeros the grid function;
    • It then projects myfunc in \(L^2\) on each mesh element;
    • It then averages dofs on element interfaces for conformity.
Integrate a CoefficientFunction
Integrate(myfunc, mesh)
0.166666666666666
Differentiate
There is no facility to directly differentiate a CoefficientFunction. But you can interpolate it into a GridFunction and then differentiate the GridFunction.
u.Set(myfunc)
gradu = grad(u)
gradu[0]
<ngsolve.fem.CoefficientFunction at 0x7f6deaab8518>
Draw(gradu[0], mesh, 'dx_firstfun')
Obviously the accuracy of this process can be improved for smooth functions by using higher order finite element spaces.
Vector-valued CoefficientFunctions
Above, gradu provided an example of a vector-valued coefficient function. To visualize it, click on Visual menu in GUI and check Draw Surface Vectors.
You can also define vector coefficient expressions directly:
Draw(vecfun, mesh, "vecfun")
Expression tree
print(myfunc)
  coef coordinate x, real
    coef N5ngfem27ConstantCoefficientFunctionE, real
