This page was generated from jupyter-files/unit-3.5-surfacehdg/surfacehdg.ipynb.
%gui tk
Mesh of (only) the surface:¶
order = 4
if order > 0:
mesh.Curve(order)
Tangential velocity field:¶
Draw (b, mesh, "b")
eps = 5e-5
some local quantities¶
bn = InnerProduct(b,con)
Discretization¶
Surface FESpaces:¶
u,uE = fes.TrialFunction()
v,vE = fes.TestFunction()
gradu = u.Trace().Deriv()
gradv = v.Trace().Deriv()
jumpu = u - uE
jumpv = v - vE
# diffusion
alpha = 10*(order+1)**2
a += SymbolicBFI(eps*gradu * gradv, VOL_or_BND = BND)
a += SymbolicBFI(- eps*dudn * jumpv,element_boundary=True, VOL_or_BND = BND)
a += SymbolicBFI(- eps*dvdn * jumpu,element_boundary=True, VOL_or_BND = BND)
a += SymbolicBFI(eps*alpha/h * jumpu * jumpv,element_boundary=True, VOL_or_BND = BND)
# convection (surface version of Egger+Schöberl formulation:
a += SymbolicBFI(- u * InnerProduct(b,gradv), VOL_or_BND = BND)
a += SymbolicBFI(IfPos(bn, bn*u, bn*uE) * v, element_boundary = True, VOL_or_BND = BND)
a += SymbolicBFI(IfPos(bn, bn, 0) * (uE - u) * vE, element_boundary = True, VOL_or_BND = BND)
Mass matrix:¶
m = BilinearForm(fes)
dt = 0.02
mstarinv = mstar.Inverse()
T = 8*pi
Time stepping¶
res = gfu.vec.CreateVector()
The time loop¶
for i in range(int(T/dt)):
res.data = m.mat * gfu.vec
gfu.vec.data = mstarinv * res
Remark:¶
- We can apply static condensation as in the volume
