5.0 MPI-Parallelization with NGSolve¶
- How do we start a distributed computation
- mpirun/mpiexec
- batch systems
- jupyter-magic
- Basics of MPI-parallel NGSolve
- distrubuted meshes
- distributed Finite Element Spaces
- distributed Linear Algebra
- solvers & preconditioners
Within an MPI job, each process in a computation is given a "rank", a numer from 0…np, which is used as it’s identifier.
Communication happens within so-called 'mpi-communicators', which are contexts within which messages can be exchanged.
Directly - mpiexec¶
Jupyter-Magic¶
connectme.py usrmtg_user_data
Download those and call
How to use it¶
We can start a "cluster" of python-processes. The cluster will be identified by some "user_id". While it is running, it will allocate N cores (in this case 5), to this specific cluster.
num_procs = '5'
start_cluster(num_procs)
connect_cluster()
%%px --targets 3:5
stop_cluster()
Batch System¶
** sbatch slurm_file **
The Rest of the talk:¶
- Basics: Distributed Meshes, Finite Element Spcaces and Lienar Algebra
- FETI-DP I: Point Constraints in 2d
- FETI-DP II: Point Constraints in 3d
- FETI-DP III: Point- and Edgeconstraints
- FETI-DP IV: Inexact FETI-DP
