%gui tk
import tkinter
Schäfer-Turek benchmark¶
mesh.Curve(3)
# viscosity
nu = 0.001
k = 3
Q = H1(mesh,order=k-1)
X = FESpace([V,Q])
The VectorH1
spaces with convenience operators for identity, grad
and div
with boundary conditions: * the inflow boundary data ('inlet') with mean value \(1\)
- "do-nothing" boundary conditions on the ouflow ('outlet') and
- homogeneous Dirichlet conditions on all other boundaries ('wall').
gfu = GridFunction(X)
velocity = CoefficientFunction (gfu.components[0])
Draw(velocity,mesh,"u")
Draw(gfu.components[1],mesh,"p")
# parabolic inflow at bc=1:
inflow profile plot:¶
try :
import matplotlib
%matplotlib inline
bvs = 6*s*(0.41-s)/(0.41)**2
plt.plot(s, bvs)
plt.xlabel('y')
plt.ylabel('$u_x(0,y)$')
plt.title('inflow profile')
plt.grid(True)
except ImportError:
pass
u,p = X.TrialFunction()
v,q = X.TestFunction()
a = BilinearForm(X)
stokes = nu*InnerProduct(grad(u),grad(v))-div(u)*q-div(v)*p
a += SymbolicBFI(stokes)
f = LinearForm(X)
IMEX time discretization¶
and
We prefer the incremental form (as it homogenizes the boundary conditions):
dt = 0.001
# matrix for implicit Euler
mstar = BilinearForm(X)
mstar += SymbolicBFI(InnerProduct(u,v) + dt*stokes)
mstar.Assemble()
velocity = gfu.components[0]
absvelocity = Norm(velocity)
conv = LinearForm(X)
conv += SymbolicLFI(InnerProduct(grad(gfu.components[0])*velocity,v))
tend = 0
tend += 1
while t < tend-0.5*dt:
print ("\rt=", t, end="")
conv.Assemble()
t = t + dt
t= 0.999000000000000876
drag_x_test = GridFunction(X)
drag_y_test = GridFunction(X)
time_vals = []
drag_x_vals = []
drag_y_vals = []
# restoring initial data
tend = 0
tend += 1
conv.Assemble()
t = t + dt
time_vals.append( t )
#print(drag)
try:
import matplotlib
%matplotlib inline
plt.xlabel('time')
plt.ylabel('drag')
plt.title('drag')
plt.grid(True)
plt.xlabel('time')
plt.ylabel('lift')
plt.title('lift')
plt.grid(True)
except:
pass
