This page was generated from jupyter-files/unit-5.3-fetidp_point3d/feti-dp-ii.ipynb.
5.3 FETI-DP in NGSolve II: Point-Constraints in 3D¶
In [1]:
user_id = 'lukas'
num_procs = '40'
In [2]:
In [ ]:
stop_cluster(user_id)
In [3]:
connect_cluster(user_id)
In [4]:
nref = 0
dim=3
ngmesh.Load('cube.vol')
for l in range(nref):
ngmesh.Refine()
comm = MPI_Init()
pardofs = fes.ParallelDofs()
f += SymbolicLFI(x*y*v)
if comm.rank==0:
[stdout:16]
global, ndof = 75403 , lodofs = 10355
avg DOFs per core: 2260.7
Finding the primal DOFs¶
In [5]:
pythonic = True
if pythonic:
faces = []
edges = []
for f1 in faces:
for f2 in faces:
if f1 is not f2:
if len(edge) > 1:
if not edge in edges:
vertices = set()
for e1 in edges:
for e2 in edges:
if e1 is not e2:
vertices = vertices.union(vs)
vertices = sorted(vertices)
There is one problem left to consider. In order for a DOF to be included in “vertices” on some rank, that rank has to posess two edges that contain it. This is not always the case.
In [6]:
vec = f.vec.CreateVector()
vec.local_vec[:] = 0.0
for v in vertices:
vec.local_vec[v] = 1
vec.Cumulate()
if comm.rank==0:
[stdout:16]
# primal dofs global: 122
min, avg, max per rank: 4 12.425 25
In [7]:
Everything else works the same - experiment below!!¶
In [8]:
user_id = 'lukas'
num_procs = '100'
In [9]:
def load_mesh(nref=0):
ngmesh.Refine()
return Mesh(ngmesh)
comm = MPI_Init()
if comm.rank==0:
return [fes, a, f]
def setup_FETIDP(fes, a):
if comm.rank==0:
if comm.rank==0:
invtype_glob='masterinverse')
F = B @ A_dp_inv @ B.T
A = a.mat.local_mat
def prep(B, Ainv, f):
rhs.data = (B @ Ainv) * f.vec
return rhs
t = comm.WTime()
return comm.WTime() - t
def post(B, Ainv, gfu, lam):
hv = B.CreateRowVector()
hv.data = f.vec - B.T * lam
gfu.vec.data = Ainv * hv
jump = lam.CreateVector()
jump.data = B * gfu.vec
norm_jump = Norm(jump)
if comm.rank==0:
In [10]:
comm = MPI_Init()
mesh = load_mesh(nref=1)
rhs = B.CreateColVector()
lam = B.CreateColVector()
prep(B, A_dp_inv, f)
if comm.rank==0:
t1 = solve(F, Fhat, rhs, lam)
if comm.rank==0:
print('time to solve: ', t1)
t2 = solve(F, Fhat2, rhs, lam)
if comm.rank==0:
post(B, A_dp_inv, gfu, lam)
[stdout:26]
avg DOFs per core: 6607.56
# of global primal dofs: 399
it = 0 err = 1.3828932193544856
it = 1 err = 0.3093351749153988
it = 2 err = 0.18687127840143788
it = 3 err = 0.15982668754855409
it = 4 err = 0.10617262264774008
it = 5 err = 0.08636099359688607
it = 6 err = 0.06534050969841254
it = 7 err = 0.04057663450962983
it = 8 err = 0.029795216503713105
it = 9 err = 0.019191776032195372
it = 10 err = 0.013409312593594812
it = 11 err = 0.010581447400156284
it = 12 err = 0.008496811350847722
it = 13 err = 0.005343556967304746
it = 14 err = 0.004037091662300088
it = 15 err = 0.0031488610707263364
it = 16 err = 0.001955640666077683
it = 17 err = 0.0013252053330392102
it = 18 err = 0.0008350370464745804
it = 19 err = 0.0005929073126342288
it = 20 err = 0.0004345439005536961
it = 21 err = 0.00030177509231099235
it = 22 err = 0.000235125851517741
it = 23 err = 0.0001333039960992988
it = 24 err = 0.00010897281470394863
it = 25 err = 5.7947863178417394e-05
it = 26 err = 5.0436899032635396e-05
it = 27 err = 2.833460785216941e-05
it = 28 err = 2.4503685663038197e-05
it = 29 err = 1.5454634417623603e-05
it = 30 err = 1.1090913251083186e-05
it = 31 err = 7.673508671528517e-06
it = 32 err = 4.6991810256279215e-06
it = 33 err = 3.5467908187332595e-06
it = 34 err = 2.124001011194309e-06
it = 35 err = 1.7687264029974105e-06
time to solve: 0.6880253719864413
it = 0 err = 0.5664618015376661
it = 1 err = 0.1224428346506882
it = 2 err = 0.06781240811871787
it = 3 err = 0.05441728733297438
it = 4 err = 0.030540989185688594
it = 5 err = 0.021651861416661526
it = 6 err = 0.015835176581462645
it = 7 err = 0.009189106784938087
it = 8 err = 0.00665121993521837
it = 9 err = 0.004076599182832595
it = 10 err = 0.0025245723947087415
it = 11 err = 0.001596301148038511
it = 12 err = 0.0012419381581669539
it = 13 err = 0.0008223671367012567
it = 14 err = 0.00041055052407066705
it = 15 err = 0.00030352885324448577
it = 16 err = 0.00021292551429473027
it = 17 err = 0.00010535909369377514
it = 18 err = 7.858092529530714e-05
it = 19 err = 4.1265575251836e-05
it = 20 err = 2.8532679697126992e-05
it = 21 err = 1.6665576448624424e-05
it = 22 err = 9.268060980115929e-06
it = 23 err = 7.031947818198997e-06
it = 24 err = 3.1407801205245272e-06
it = 25 err = 2.5144714637266164e-06
it = 26 err = 1.287853499441041e-06
it = 27 err = 8.333768290606212e-07
time solve without scaling: 0.6880253719864413
time solve with scaling: 0.7163726490689442
norm jump u: 9.990814869240256e-06
In [11]:
%%px --target 1
SparseCholesky<d,d,d>::MultAdd : 0.8205492496490479
In [12]:
if t_chol['time'] == maxt:
[stdout:31]
timers from rank 13 :
SparseCholesky<d,d,d>::MultAdd : 1.209223747253418
SparseCholesky<d,d,d>::MultAdd fac1 : 0.7094001770019531
SparseCholesky<d,d,d>::MultAdd fac2 : 0.4826033115386963
SparseCholesky - total : 0.41616296768188477
In [13]:
