3.6 DG/HDG splitting¶
For a problem of the form
- 1.Step: Given \(u^0\), solve \(t^n \to t^{n+1}\): \(\quad \partial_t u + C u = 0 \Rightarrow u^{\frac12}\)
 - 2.Step: Given \(u^{\frac12}\), solve \(t^n \to t^{n+1}\): \(\quad \partial_t u + A u = 0 \Rightarrow u^{1}\)
In this example we consider the Navier-Stokes problem again (cf. 3.2) and want to combine
- an \(H(div)\) -conforming Hybrid DG method (which is a very good discretization for Stokes-type problems) and
 - a standard upwind DG method for the discretization of the convection
In [1]:
%gui tk
geo.AddRectangle( (0, 0), (2, 0.41), bcs = ("wall", "outlet", "wall", "inlet") )
geo.AddCircle ( (0.2, 0.2), r=0.05, leftdomain = 0, rightdomain = 1, bc = "cyl" )
mesh = Mesh( geo.GenerateMesh(maxh = 0.08) )
order = 3
mesh.Curve(order)
- \(BDM_k\): \(H(div)\) conforming FE space (degree k)
 - Vector facet space: facet functions of degree k (vector valued and only in tangential direction)
 - piecewise polynomials up to degree \(k-1\) for the pressure
HDG spaces¶
In [2]:
V2 = FESpace ( "vectorfacet", mesh, order = order, dirichlet = "wall|cyl|inlet" )
V = FESpace ([V1,V2,Q])
v, vhat, q = V.TestFunction()
Stokes discretization / initial conditions¶
The bilinear form to the HDG discretized Stokes problem is:
The mass matrix is simply
In [3]:
nu = 0.001
alpha = 4
gradu = CoefficientFunction ( (grad(u),), dims=(2,2) )
gradv = CoefficientFunction ( (grad(v),), dims=(2,2) )
def tang(vec):
    return vec - (vec*n)*n
a += SymbolicBFI ( nu*InnerProduct ( gradu, gradv) )
a += SymbolicBFI ( nu*InnerProduct ( gradu.trans * n,  tang(vhat-v) ), element_boundary=True )
a += SymbolicBFI ( nu*InnerProduct ( gradv.trans * n,  tang(uhat-u) ), element_boundary=True )
a += SymbolicBFI ( nu*alpha*order*order/h * InnerProduct ( tang(vhat-v),  tang(uhat-u) ), element_boundary=True )
a += SymbolicBFI ( -div(u)*q -div(v)*p )
m += SymbolicBFI( u * v )
f = LinearForm ( V )
In [4]:
gfu = GridFunction(V)
U0 = 1.5
gfu.vec.data += invstokes * res
Application of convection¶
- Given \((\mathbf{u},p)\) in HDG space: project into \(\hat{\mathbf{u}}\) in usual DG space
 - Solve \(\partial_t \hat{\mathbf{u}} = C \hat{\mathbf{u}}\) by explicit scheme (involves convection evaluations and mass matrix operations only)
 - Solve Unsteady Stokes step with r.h.s. from convection sub-problem. To this end evaluate mixed mass matrix \(\int \hat{\mathbf{u}} \cdot \mathbf{v}\) to obtain a functional on the HDG space
- \(M_m\) : \(HDG \times DG \to \mathbb{R}\)
 - \(M_m^T\) : \(DG \times HDG \to \mathbb{R}\)
 - \(M_{DG}\) : \(DG \times DG \to \mathbb{R}\) (block diagonal)
mixed mass matrices¶
In [5]:
VL2 = L2(mesh, dim=mesh.dim, order=order)
uL2 = VL2.TrialFunction()
vL2 = VL2.TestFunction()
gfuL2 = GridFunction(VL2)
bfmixed += SymbolicBFI ( vL2*u )
bfmixedT += SymbolicBFI ( uL2*v )
convection operator¶
- convection operation with standard Upwinding
 - No set up of the matrix (only interested in operator applications)
 - for the advection velocity we use the \(H(div)\)-conforming velocity (which is pointwise divergence free).
In [6]:
vel = gfu.components[0]
convL2 += SymbolicBFI( (-InnerProduct(grad(vL2).trans * vel, uL2.trans)) )
un = InnerProduct(vel,n)
convL2 += SymbolicBFI( InnerProduct (upwindL2, vL2-vL2.Other()), VOL, skeleton=True )
convL2 += SymbolicBFI( InnerProduct (upwindL2, vL2), BND, skeleton=True )
solution of convection steps¶
In [7]:
def SolveConvectionSteps(gfuvec, res, tau, steps):
    bfmixed.Apply (gfuvec, gfuL2.vec)
    VL2.SolveM(gfuL2.vec, CoefficientFunction(1))
    conv_applied = gfuL2.vec.CreateVector()
    for i in range(steps):
        convL2.Apply(gfuL2.vec,conv_applied)
        VL2.SolveM(conv_applied, CoefficientFunction(1))
        gfuL2.vec.data -= tau/steps * conv_applied
        #Redraw()
    bfmixedT.Apply (gfuL2.vec, res)
#SolveConvectionSteps(gfu,res,0.01,1)
#Draw(gfuL2, mesh, "velocity(L2)")
#Draw(Norm(gfuL2), mesh, "absvel(L2)")
Operator splitting method¶
In [8]:
# initial values again:
tend = 0
In [9]:
tend += 1
substeps = 10
tau = 0.01
    SolveConvectionSteps(gfu.vec, res, tau, substeps)
    res.data -= mstar * gfu.vec
    gfu.vec.data += inv * res
    t += tau
    print ("\r  t =", t, end="")
  t = 1.000000000000000775
