Find (u,p):[0,T]→(H10,D)d×L2, s.t.
∫Ω∂tu⋅v+∫Ων∇u∇v+u⋅∇uv−∫Ωdiv(v)p=∫fv∀v∈(H10,D)d,−∫Ωdiv(u)q=0∀q∈L2,u(t=0)=u0import netgen.gui
%gui tk
import tkinter
We again consider the benchmark setup of from http://www.featflow.de/en/benchmarks/cfdbenchmarking/flow/dfg_benchmark2_re100.html . The geometry is a 2D channel with a circular obstacle which is positioned (only slightly) off the center of the channel. The geometry:
The left part (red) is the inflow boundary,
The right part (green) is the outflow boundary.
The viscosity is set to ν=10−3.
geo.AddRectangle( (0, 0), (2, 0.41),
bcs = ("wall", "outlet", "wall", "inlet"))
geo.AddCircle ( (0.2, 0.2), r=0.05,
leftdomain=0, rightdomain=1, bc="cyl")
mesh.Curve(3)
# viscosity
nu = 0.001
We use a Taylor-Hood discretization of degree k. The finite element space for the velocity components ux and uy and the pressure are:
ux,uy∈V={v∈H1(Ω)|v|T∈Pk(T)}p∈Q={q∈H1(Ω)|q|T∈Pk−1(T)}k = 3
V = H1(mesh,order=k, dirichlet="wall|cyl|inlet")
Q = H1(mesh,order=k-1)
X = FESpace([V,V,Q])
As initial data we use the solution to the Stokes problem:
Find u=(ux,uy)∈V×V, p∈Q so that
∫Ων∇u∇v−∫Ωdiv(v)p=∫fv∀v∈V×V,−∫Ωdiv(u)q=0∀q∈Q,with boundary conditions:
u = GridFunction(X)
velocity = CoefficientFunction (u.components[0:2])
Draw(velocity,mesh,"u")
Draw(u.components[2],mesh,"p")
# parabolic inflow at bc=1:
u.components[0].Set(uin, definedon=mesh.Boundaries("inlet"))
import matplotlib
%matplotlib inline
bvs = 6*s*(0.41-s)/(0.41)**2
plt.plot(s, bvs)
plt.xlabel('y')
plt.ylabel('$u_x(0,y)$')
plt.title('inflow profile')
plt.grid(True)
a((u,p),(v,q)):=∫Ων∇u∇v−div(v)p−div(u)qux,uy,p = X.TrialFunction()
vx,vy,q = X.TestFunction()
stokes = nu*grad(ux)*grad(vx)+nu*grad(uy)*grad(vy) \
-div_u*q-div_v*p
a = BilinearForm(X)
a += SymbolicBFI(stokes)
f = LinearForm(X)
res.data = f.vec - a.mat*u.vec
u.vec.data += inv_stokes * res
Find (un+1,pn+1)∈X=V×V×Q, s.t. for all (v,q)∈X=V×V×Q m(un+1,v)+Δt ⋅ a((un+1,pn+1),(v,q))⏟→M∗ = m(un,v)−Δtc(un;un,v)
with m(u,v)=∫u⋅v and c(w,u,v)=∫w⋅∇u⋅v
We prefer the incremental form (as it homogenizes the boundary conditions): m(Δun+1,v)+Δt ⋅ a((Δun+1,pn+1),(v,q)) = Δt(−a((un,pn),(v,q))−c(un;un,v))
dt = 0.001
# matrix for implicit Euler
mstar = BilinearForm(X)
mstar += SymbolicBFI(ux*vx+uy*vy + dt*stokes)
mstar.Assemble()
conv = LinearForm(X)
conv += SymbolicLFI(velocity*grad(u.components[0])*vx)
conv += SymbolicLFI(velocity*grad(u.components[1])*vy)
tend = 0
tend += 1
while t < tend-0.5*dt:
print ("\rt=", t, end="")
conv.Assemble()
res.data = a.mat * u.vec + conv.vec
u.vec.data -= dt * inv * res
t = t + dt
The force acting on the obstacle is F∘=(FD,FL)=∫Γcylσn=∫Γcyl(−ν∂u∂n+pI)⋅n
The drag/lift coefficients are cD=2ˉuLFD,cL=2ˉuLFL. where ˉu=1 is the mean inflow velocity and L=0.41 is the channel width.
drag_x_test = GridFunction(X)
drag_x_test.components[0].Set(CoefficientFunction(-20.0), definedon=mesh.Boundaries("cyl"))
drag_y_test = GridFunction(X)
drag_y_test.components[1].Set(CoefficientFunction(-20.0), definedon=mesh.Boundaries("cyl"))
time_vals = []
drag_x_vals = []
drag_y_vals = []
# restoring initial data
tend = 0
Remarks:
tend += 1
conv.Assemble()
t = t + dt
time_vals.append( t )
#print(drag)
import matplotlib
%matplotlib inline
plt.xlabel('time')
plt.ylabel('drag')
plt.title('drag')
plt.grid(True)
plt.xlabel('time')
plt.ylabel('lift')
plt.title('lift')
plt.grid(True)
