For a problem of the form $$ \partial_t u + A u + C u = 0 $$ We consider the operator splitting:
In this example we consider the Navier-Stokes problem again (cf. 3.2) and want to combine
The weak form is: Find $(u,p):[0,T] \to (H_{0,D}^1)^d \times L^2$, s.t.
\begin{align} \int_{\Omega} \partial_t u \cdot v + \int_{\Omega} \nu \nabla u \nabla v + u \cdot \nabla u v - \int_{\Omega} \operatorname{div}(v) p &= \int f v && \forall v \in (H_{0,D}^1)^d, \\ - \int_{\Omega} \operatorname{div}(u) q &= 0 && \forall q \in L^2, \\ \quad u(t=0) & = u_0 \end{align}Again, we consider the benchmark setup from http://www.featflow.de/en/benchmarks/cfdbenchmarking/flow/dfg_benchmark2_re100.html . The geometry is a 2D channel with a circular obstacle which is positioned (only slightly) off the center of the channel. The geometry:
The left part (red) is the inflow boundary, The right part (green) is the outflow boundary. The viscosity is set to $\nu = 10^{-3}$.
%gui tk
import tkinter
geo.AddRectangle( (0, 0), (2, 0.41), bcs = ("wall", "outlet", "wall", "inlet") )
geo.AddCircle ( (0.2, 0.2), r=0.05, leftdomain = 0, rightdomain = 1, bc = "cyl" )
mesh = Mesh( geo.GenerateMesh(maxh = 0.08) )
order = 3
mesh.Curve(order)
V2 = FESpace ( "vectorfacet", mesh, order = order, dirichlet = "wall|cyl|inlet" )
V = FESpace ([V1,V2,Q])
v, vhat, q = V.TestFunction()
The bilinear form to the HDG discretized Stokes problem is:
\begin{align*} K_h((u_T,u_F,p),(v_T,v_F,q) := & \displaystyle \sum_{T\in\mathcal{T}} \left\{ \int_{T} \nu {\nabla} {u_T} \! : \! {\nabla} {v_T} \ d {x} \right. \\ & \qquad \left. - \int_{\partial T} \nu \frac{\partial {u_T}}{\partial {n} } [ v ]_t \ d {s} - \int_{\partial T} \nu \frac{\partial {v_T}}{\partial {n} } [ u ]_t \ d {s} + \int_{\partial T} \nu \frac{\lambda k^2}{h} [u]_t [v]_t \ d {s} \right\}\\ & - \int_{\Omega} \operatorname{div}(u) q \ d {x} - \int_{\Omega} \operatorname{div}(v) p \ d {x} \end{align*}where $[\cdot]_t$ is the tangential projection of the jump $(\cdot)_T - (\cdot)_F$.
The mass matrix is simply
\begin{align*} M_h((u_T,u_F,p),(v_T,v_F,q) := \int_{\Omega} u_T \cdot v_T d {x} \end{align*}nu = 0.001
alpha = 4
gradu = CoefficientFunction ( (grad(u),), dims=(2,2) )
gradv = CoefficientFunction ( (grad(v),), dims=(2,2) )
def tang(vec):
return vec - (vec*n)*n
a += SymbolicBFI ( nu*InnerProduct ( gradu, gradv) )
a += SymbolicBFI ( nu*InnerProduct ( gradu.trans * n, tang(vhat-v) ), element_boundary=True )
a += SymbolicBFI ( nu*InnerProduct ( gradv.trans * n, tang(uhat-u) ), element_boundary=True )
a += SymbolicBFI ( nu*alpha*order*order/h * InnerProduct ( tang(vhat-v), tang(uhat-u) ), element_boundary=True )
a += SymbolicBFI ( -div(u)*q -div(v)*p )
m += SymbolicBFI( u * v )
f = LinearForm ( V )
gfu = GridFunction(V)
U0 = 1.5
gfu.vec.data += invstokes * res
In the operator split approach we want to apply only operator applications for the convection part. Further, we want to do this in a usual DG setting. As a model problem we use the following procedure:
We do not assemble the matrices as we will only need the matrix-vector applications of $M_m$, $M_m^T$ and $M_{DG}^{-1}$.
VL2 = L2(mesh, dim=mesh.dim, order=order, flags = { "dgjumps" : True } )
uL2 = VL2.TrialFunction() # 1 x dim matrix
vL2 = VL2.TestFunction()
gfuL2 = GridFunction(VL2)
bfmixed = BilinearForm ( V, VL2, flags = { "nonassemble" : True } )
bfmixed += SymbolicBFI ( vL2*u )
bfmixedT = BilinearForm ( VL2, V, flags = { "nonassemble" : True } )
bfmixedT += SymbolicBFI ( uL2*v )
For the convection operation we use a standard Upwind scheme. Again, we do not set up the matrix as we are only interested in operator applications. For the advection velocity we use the $H(div)$-conforming velocity (which is point-wise divergence free).
vel = gfu.components[0]
convL2 = BilinearForm(VL2, flags = { "nonassemble" : True } )
convL2 += SymbolicBFI( (-InnerProduct(grad(vL2).trans * vel, uL2.trans)) )
un = InnerProduct(vel,n)
convL2 += SymbolicBFI( InnerProduct (upwindL2, vL2-vL2.Other()), VOL, skeleton=True )
convL2 += SymbolicBFI( InnerProduct (upwindL2, vL2), BND, skeleton=True )
We now define the solution of the convection problem for an initial data $u$ in the HDG space. The return value ("res") is $M_m \hat{u}$ where $\hat{u}$ is the solution of several explicit Euler steps of the convection problem $$ \partial_t \hat{u} = - M_{DG}^{-1} C \hat{u} $$
def SolveConvectionSteps(gfuvec, res, tau, steps):
bfmixed.Apply (gfuvec, gfuL2.vec)
VL2.SolveM(CoefficientFunction(1), gfuL2.vec)
conv_applied = gfuL2.vec.CreateVector()
for i in range(steps):
convL2.Apply(gfuL2.vec,conv_applied)
VL2.SolveM(CoefficientFunction(1), conv_applied)
gfuL2.vec.data -= tau/steps * conv_applied
#Redraw()
bfmixedT.Apply (gfuL2.vec, res)
#SolveConvectionSteps(gfu,res,0.01,1)
#Draw(gfuL2, mesh, "velocity(L2)")
#Draw(Norm(gfuL2), mesh, "absvel(L2)")
# initial values again:
tend = 1
substeps = 10
tau = 0.01
SolveConvectionSteps(gfu.vec, res, tau, substeps)
res.data -= mstar * gfu.vec
gfu.vec.data += inv * res
t += tau
print ("t=", t)
