$$\text{find } u:[0,T] \to H_{0,D}^1 \quad \int_{\Omega} \partial_t u v + \int_{\Omega} \varepsilon \nabla u \nabla v + b \cdot \nabla u v = \int f v \quad \forall v \in H_{0,D}^1, \quad u(t=0) = u_0$$with a suitable advective field $b$ (the wind).
%gui tk
import tkinter
We generate geometry $(-1,1)^2$, mesh (Dirichlet boundaries everywhere):
geo.AddRectangle( (-1, -1), (1, 1), bcs = ("bottom", "right", "top", "left"))
u = fes.TrialFunction()
v = fes.TestFunction()
time = 0.0
dt = 0.001
bcs = ('bottom', 'right', 'top', 'left')
We define the field $b$ (the wind) as $b(x,y) = (2y(1-x^2),-2x(1-y^2))$.
Draw(b,mesh,"wind")
We define and assemble bilinear forms for convection-diffusion stiffness and mass matrix separately.
Note that we choose a non-symmetric memory layout for the mass matrix so that a and m have the same sparsity pattern.
a += SymbolicBFI (0.01*grad(u)*grad(v) + b*grad(u)*v)
m += SymbolicBFI (u*v)
We want to use a simple implicit Euler time stepping method, i.e.
$$ (M + \Delta t A) u^{n+1} = M u^n + f^{n+1} $$or in an incremental form:
$$ (M + \Delta t A) (u^{n+1} - u^n) = - \Delta t A u^n + f^{n+1}. $$The incremental form has the advantage that $u^{n+1} - u^n$ has homogeneous boundary conditions (unless boundary conditions are time-dependent).
For the time stepping method we want to set up linear combinations of matrices.
print(mstar)
Row 0: 0: 0.00520833 4: 0.00260417 31: 0.00260417 89: -0.000520833 90: 8.68056e-05 91: -0.000520833 92: 8.68056e-05 107: -0.000260417 108: -1.28749e-19 553: 0.000173611 Row 1: 1: 0.00520833 10: 0.00260417 11: 0.00260417 93: -0.000520833 94: 8.68056e-05 95: -0.000520833 96: 8.68056e-05 141: -0.000260417 142: 1.28749e-19 557: 0.000173611 Row 2: 2: 0.00520833 17: 0.00260417 18: 0.00260417 97: -0.000520833 98: 8.68056e-05 99: -0.000520833 100: 8.68056e-05 181: -0.000260417 182: 1.28749e-19 561: 0.000173611 Row 3: 3: 0.00520833 24: 0.00260417 25: 0.00260417 101: -0.000520833 102: 8.68056e-05 103: -0.000520833 104: 8.68056e-05 221: -0.000260417 222: 1.28749e-19 565: 0.000173611 Row 4: 0: 0.00260417 4: 0.0163738 5: 0.00229828 31: 0.0058886 32: 0.00558272 89: -0.000520833 90: -8.68056e-05 91: -0.000260417 92: -1.42302e-19 105: -0.000459656 106: 7.66094e-05 107: -0.00117772 108: 0.000196287 109: -0.00111654 110: 0.000186091 113: -0.000229828 114: -1.15196e-19 261: -0.000328444 262: 1.69407e-19 553: 0.000173611 554: 0.000153219 569: 0.000218962 Row 5: 4: 0.00229828 5: 0.0142215 6: 0.00235821 32: 0.00475257 44: 0.00481249 105: -0.000459656 106: -7.66094e-05 109: -0.000229828 110: -1.24514e-19 111: -0.000471641 112: 7.86068e-05 113: -0.000950513 114: 0.000158419 115: -0.000962498 116: 0.000160416 121: -0.000235821 122: -1.18585e-19 265: -0.000245428 266: 1.25361e-19 554: 0.000153219 573: 0.000157214 584: 0.000163619 Row 6: 5: 0.00235821 6: 0.0140022 7: 0.00225885 33: 0.00464288 44: 0.00474223 111: -0.000471641 112: -7.86068e-05 115: -0.000235821 116: -1.27902e-19 117: -0.000451771 118: 7.52951e-05 119: -0.000928575 120: 0.000154763 121: -0.000948446 122: 0.000158074 125: -0.000225885 126: -1.15196e-19 271: -0.000238402 272: -1.21973e-19 555: 0.00015059 573: 0.000157214 582: 0.000158935 Row 7: 6: 0.00225885 7: 0.0136816 8: 0.00228517 33: 0.00455563 45: 0.00458194 117: -0.000451771 118: -7.52951e-05 119: -0.000225885 120: -1.2282e-19 123: -0.000457033 124: 7.61722e-05 125: -0.000911126 126: 0.000151854 127: -0.000916389 128: 0.000152731 133: -0.000228517 134: -1.15196e-19 273: -0.000229678 274: 1.15196e-19 555: 0.00015059 574: 0.000152344 589: 0.000153119 Row 8: 7: 0.00228517 8: 0.0138903 9: 0.00237377 34: 0.00465998 45: 0.00457138 123: -0.000457033 124: -7.61722e-05 127: -0.000228517 128: -1.23667e-19 129: -0.000474754 130: 7.91257e-05 131: -0.000931996 132: 0.000155333 133: -0.000914276 134: 0.000152379 137: -0.000237377 138: -1.25361e-19 279: -0.000228621 280: -1.15196e-19 556: 0.000158251 574: 0.000152344 578: 0.000152414 Row 9: 8: 0.00237377 9: 0.0132999 10: 0.00223318 34: 0.00441679 46: 0.0042762 129: -0.000474754 130: -7.91257e-05 131: -0.000237377 132: -1.29596e-19 135: -0.000446635 136: 7.44392e-05 137: -0.000883358 138: 0.000147226 139: -0.00085524 140: 0.00014254 145: -0.000223318 146: -1.11808e-19 281: -0.000204302 282: 1.05032e-19 556: 0.000158251 575: 0.000148878 590: 0.000136201 Row 10: 1: 0.00260417 9: 0.00223318 10: 0.021583 11: 0.00593425 35: 0.00595416 46: 0.00485725 93: -0.000520833 94: -8.68056e-05 95: -0.000260417 96: -3.38813e-21 135: -0.000446635 136: -7.44392e-05 139: -0.000223318 140: -1.2282e-19 141: -0.00118685 142: 0.000197808 143: -0.00119083 144: 0.000198472 145: -0.000971451 146: 0.000161908 149: -0.000333008 150: -1.69407e-19 287: -0.000262408 288: -1.32137e-19 557: 0.000173611 570: 0.000222005 575: 0.000148878 609: 0.000174938 Row 11: 1: 0.00260417 10: 0.00593425 11: 0.0164725 12: 0.00230202 35: 0.00563211 93: -0.000260417 94: -1.42302e-19 95: -0.000520833 96: -8.68056e-05 141: -0.00118685 142: -0.000197808 143: -0.000333008 144: -1.82959e-19 147: -0.000460405 148: 7.67341e-05 149: -0.00112642 150: 0.000187737 153: -0.000230202 154: -1.18585e-19 557: 0.000173611 558: 0.000153468 570: 0.000222005 Row 12: 11: 0.00230202 12: 0.0143342 13: 0.00237096 35: 0.00479613 47: 0.00486507 147: -0.000460405 148: -7.67341e-05 149: -0.000230202 150: -1.23667e-19 151: -0.000474192 152: 7.9032e-05 153: -0.000959226 154: 0.000159871 155: -0.000973014 156: 0.000162169 161: -0.000237096 162: -1.18585e-19 289: -0.000249411 290: 1.28749e-19 558: 0.000153468 576: 0.000158064 602: 0.000166274 Row 13: 12: 0.00237096 13: 0.0138437 14: 0.0021948 36: 0.00455091 47: 0.00472707 151: -0.000474192 152: -7.9032e-05 155: -0.000237096 156: -1.29596e-19 157: -0.000438961 158: 7.31601e-05 159: -0.000910182 160: 0.000151697 161: -0.000945413 162: 0.000157569 165: -0.00021948 166: -1.11808e-19 293: -0.00023561 294: -1.21973e-19 559: 0.00014632 576: 0.000158064 588: 0.000157074 Row 14: 13: 0.0021948 14: 0.0130092 15: 0.00212498 36: 0.0043796 48: 0.00430978 157: -0.000438961 158: -7.31601e-05 159: -0.00021948 160: -1.19432e-19 163: -0.000424997 164: 7.08328e-05 165: -0.00087592 166: 0.000145987 167: -0.000861955 168: 0.000143659 173: -0.000212498 174: -1.0842e-19 295: -0.000218479 296: 1.15196e-19 559: 0.00014632 577: 0.000141666 591: 0.000145653 Row 15: 14: 0.00212498 15: 0.0129094 16: 0.00220475 37: 0.00432972 48: 0.00424995 163: -0.000424997 164: -7.08328e-05 167: -0.000212498 168: -1.16891e-19 169: -0.000440949 170: 7.34916e-05 171: -0.000865943 172: 0.000144324 173: -0.00084999 174: 0.000141665 177: -0.000220475 178: -1.15196e-19 301: -0.000212497 302: -1.0842e-19 560: 0.000146983 577: 0.000141666 597: 0.000141665 Row 16: 15: 0.00220475 16: 0.0125009 17: 0.0021434 37: 0.00410704 49: 0.00404569 169: -0.000440949 170: -7.34916e-05 171: -0.000220475 172: -1.19432e-19 175: -0.00042868 176: 7.14466e-05 177: -0.000821408 178: 0.000136901 179: -0.000809138 180: 0.000134856 185: -0.00021434 186: -1.11808e-19 303: -0.000190229 304: 9.82558e-20 560: 0.000146983 579: 0.000142893 592: 0.000126819 Row 17: 2: 0.00260417 16: 0.0021434 17: 0.0210621 18: 0.00585676 38: 0.00578346 49: 0.00467426 97: -0.000520833 98: -8.68056e-05 99: -0.000260417 100: -3.38813e-21 175: -0.00042868 176: -7.14466e-05 179: -0.00021434 180: -1.17738e-19 181: -0.00117135 182: 0.000195225 183: -0.00115669 184: 0.000192782 185: -0.000934852 186: 0.000155809 189: -0.00032526 190: -1.6263e-19 309: -0.000253086 310: -1.28749e-19 561: 0.000173611 571: 0.00021684 579: 0.000142893 611: 0.000168724 Row 18: 2: 0.00260417 17: 0.00585676 18: 0.0162883 19: 0.00228738 38: 0.00553997 97: -0.000260417 98: -1.42302e-19 99: -0.000520833 100: -8.68056e-05 181: -0.00117135 182: -0.000195225 183: -0.00032526 184: -1.77877e-19 187: -0.000457476 188: 7.62459e-05 189: -0.00110799 190: 0.000184666 193: -0.000228738 194: -1.18585e-19 561: 0.000173611 562: 0.000152492 571: 0.00021684 Row 19: 18: 0.00228738 19: 0.0143341 20: 0.00238991 38: 0.00477716 50: 0.00487969 187: -0.000457476 188: -7.62459e-05 189: -0.000228738 190: -1.25361e-19 191: -0.000477982 192: 7.96636e-05 193: -0.000955432 194: 0.000159239 195: -0.000975938 196: 0.000162656 201: -0.000238991 202: -1.18585e-19 311: -0.000248978 312: 1.28749e-19 562: 0.000152492 580: 0.000159327 603: 0.000165986 Row 20: 19: 0.00238991 20: 0.0143452 21: 0.00232874 39: 0.00478268 50: 0.00484385 191: -0.000477982 192: -7.96636e-05 195: -0.000238991 196: -1.29596e-19 197: -0.000465749 198: 7.76248e-05 199: -0.000956536 200: 0.000159423 201: -0.000968769 202: 0.000161462 205: -0.000232874 206: -1.21973e-19 315: -0.000245394 316: -1.28749e-19 563: 0.00015525 580: 0.000159327 598: 0.000163596 Row 21: 20: 0.00232874 21: 0.0140201 22: 0.00232374 39: 0.00468632 51: 0.00468132 197: -0.000465749 198: -7.76248e-05 199: -0.000232874 200: -1.26208e-19 203: -0.000464748 204: 7.7458e-05 205: -0.000937265 206: 0.000156211 207: -0.000936264 208: 0.000156044 213: -0.000232374 214: -1.18585e-19 317: -0.000235758 318: 1.21973e-19 563: 0.00015525 581: 0.000154916 593: 0.000157172 Row 22: 21: 0.00232374 22: 0.0139707 23: 0.00235233 40: 0.00466161 51: 0.00463302 203: -0.000464748 204: -7.7458e-05 207: -0.000232374 208: -1.27055e-19 209: -0.000470467 210: 7.84111e-05 211: -0.000932321 212: 0.000155387 213: -0.000926603 214: 0.000154434 217: -0.000235233 218: -1.21973e-19 323: -0.000230927 324: -1.18585e-19 564: 0.000156822 581: 0.000154916 599: 0.000153952 Row 23: 22: 0.00235233 23: 0.0131126 24: 0.00219508 40: 0.00436123 52: 0.00420399 209: -0.000470467 210: -7.84111e-05 211: -0.000235233 212: -1.27902e-19 215: -0.000439017 216: 7.31695e-05 217: -0.000872247 218: 0.000145374 219: -0.000840797 220: 0.000140133 225: -0.000219508 226: -1.11808e-19 325: -0.00020089 326: 1.05032e-19 564: 0.000156822 583: 0.000146339 594: 0.000133927 Row 24: 3: 0.00260417 23: 0.00219508 24: 0.0212547 25: 0.00585915 41: 0.00582808 52: 0.00476818 101: -0.000520833 102: -8.68056e-05 103: -0.000260417 104: -3.38813e-21 215: -0.000439017 216: -7.31695e-05 219: -0.000219508 220: -1.19432e-19 221: -0.00117183 222: 0.000195305 223: -0.00116562 224: 0.000194269 225: -0.000953636 226: 0.000158939 229: -0.000325499 230: -1.69407e-19 331: -0.00025731 332: -1.32137e-19 565: 0.000173611 572: 0.000216999 583: 0.000146339 619: 0.00017154 Row 25: 3: 0.00260417 24: 0.00585915 25: 0.016254 26: 0.00226785 41: 0.00552283 101: -0.000260417 102: -1.42302e-19 103: -0.000520833 104: -8.68056e-05 221: -0.00117183 222: -0.000195305 223: -0.000325499 224: -1.77877e-19 227: -0.000453569 228: 7.55949e-05 229: -0.00110457 230: 0.000184094 233: -0.000226785 234: -1.15196e-19 565: 0.000173611 566: 0.00015119 572: 0.000216999 Row 26: 25: 0.00226785 26: 0.0138853 27: 0.00228072 41: 0.00466194 53: 0.00467481 227: -0.000453569 228: -7.55949e-05 229: -0.000226785 230: -1.2282e-19 231: -0.000456144 232: 7.60239e-05 233: -0.000932388 234: 0.000155398 235: -0.000934963 236: 0.000155827 241: -0.000228072 242: -1.18585e-19 333: -0.00023941 334: 1.21973e-19 566: 0.00015119 585: 0.000152048 601: 0.000159606 Row 27: 26: 0.00228072 27: 0.0134621 28: 0.00215531 42: 0.00445032 53: 0.00457573 231: -0.000456144 232: -7.60239e-05 235: -0.000228072 236: -1.2282e-19 237: -0.000431062 238: 7.18436e-05 239: -0.000890065 240: 0.000148344 241: -0.000915147 242: 0.000152524 245: -0.000215531 246: -1.0842e-19 337: -0.000229502 338: -1.15196e-19 567: 0.000143687 585: 0.000152048 604: 0.000153001 Row 28: 27: 0.00215531 28: 0.0130849 29: 0.00218893 42: 0.00435354 54: 0.00438717 237: -0.000431062 238: -7.18436e-05 239: -0.000215531 240: -1.17738e-19 243: -0.000437786 244: 7.29644e-05 245: -0.000870709 246: 0.000145118 247: -0.000877433 248: 0.000146239 253: -0.000218893 254: -1.11808e-19 339: -0.000219824 340: 1.11808e-19 567: 0.000143687 586: 0.000145929 595: 0.000146549 Row 29: 28: 0.00218893 29: 0.0133995 30: 0.00230402 43: 0.00451081 54: 0.00439572 243: -0.000437786 244: -7.29644e-05 247: -0.000218893 248: -1.18585e-19 249: -0.000460804 250: 7.68007e-05 251: -0.000902162 252: 0.00015036 253: -0.000879144 254: 0.000146524 257: -0.000230402 258: -1.18585e-19 345: -0.000220679 346: -1.15196e-19 568: 0.000153601 586: 0.000145929 600: 0.000147119 Row 30: 29: 0.00230402 30: 0.0129629 31: 0.00218734 43: 0.00429412 55: 0.00417744 249: -0.000460804 250: -7.68007e-05 251: -0.000230402 252: -1.24514e-19 255: -0.000437468 256: 7.29113e-05 257: -0.000858824 258: 0.000143137 259: -0.000835488 260: 0.000139248 263: -0.000218734 264: -1.11808e-19 347: -0.00019901 348: 1.05032e-19 568: 0.000153601 587: 0.000145823 596: 0.000132673 Row 31: 0: 0.00260417 4: 0.0058886 30: 0.00218734 31: 0.021317 32: 0.00586698 55: 0.00476988 89: -0.000260417 90: -3.38813e-21 91: -0.000520833 92: -8.68056e-05 107: -0.00117772 108: -0.000196287 109: -0.000328444 110: -1.01644e-20 255: -0.000437468 256: -7.29113e-05 259: -0.000218734 260: -1.20279e-19 261: -0.0011734 262: 0.000195566 263: -0.000953976 264: 0.000158996 267: -0.000258254 268: -1.32137e-19 553: 0.000173611 569: 0.000218962 587: 0.000145823 627: 0.000172169 Row 32: 4: 0.00558272 5: 0.00475257 31: 0.00586698 32: 0.0316705 44: 0.00527279 55: 0.00497975 67: 0.00521572 105: -0.000229828 106: -5.0822e-21 107: -0.000328444 108: -1.81265e-19 109: -0.00111654 110: -0.000186091 113: -0.000950513 114: -0.000158419 115: -0.000245428 116: -5.0822e-21 261: -0.0011734 262: -0.000195566 263: -0.000258254 264: -1.42302e-19 265: -0.00105456 266: 0.00017576 267: -0.00099595 268: 0.000165992 269: -0.00104314 270: 0.000173857 355: -0.00028185 356: -1.42302e-19 391: -0.000239721 392: 1.25361e-19 554: 0.000153219 569: 0.000218962 584: 0.000163619 623: 0.0001879 627: 0.000172169 632: 0.000159814 Row 33: 6: 0.00464288 7: 0.00455563 33: 0.0273626 44: 0.0046814 45: 0.00448984 61: 0.00444425 66: 0.00454856 117: -0.000225885 118: -8.47033e-21 119: -0.000928575 120: -0.000154763 121: -0.000238402 122: -1.30443e-19 125: -0.000911126 126: -0.000151854 127: -0.000229678 128: -8.47033e-21 271: -0.00093628 272: 0.000156047 273: -0.000897969 274: 0.000149661 275: -0.000888851 276: 0.000148142 277: -0.000909713 278: 0.000151619 353: -0.000229738 354: 1.15196e-19 357: -0.000219307 358: -1.15196e-19 431: -0.000225119 432: -1.15196e-19 555: 0.00015059 582: 0.000158935 589: 0.000153119 612: 0.000146204 621: 0.000153158 622: 0.000150079 Row 34: 8: 0.00465998 9: 0.00441679 34: 0.0282066 45: 0.00459044 46: 0.00442359 57: 0.00509607 63: 0.00501973 129: -0.000237377 130: -5.0822e-21 131: -0.000931996 132: -0.000155333 133: -0.000228621 134: -1.2282e-19 137: -0.000883358 138: -0.000147226 139: -0.000204302 140: -3.38813e-21 279: -0.000918089 280: 0.000153015 281: -0.000884718 282: 0.000147453 283: -0.00101921 284: 0.000169869 285: -0.00100395 286: 0.000167324 359: -0.000230423 360: 1.18585e-19 361: -0.000238057 362: -1.25361e-19 401: -0.00027155 402: -1.38913e-19 556: 0.000158251 578: 0.000152414 590: 0.000136201 606: 0.000158705 615: 0.000153615 616: 0.000181033 Row 35: 10: 0.00595416 11: 0.00563211 12: 0.00479613 35: 0.0321497 46: 0.00508905 47: 0.00535371 57: 0.00532457 141: -0.000333008 142: -1.01644e-20 143: -0.00119083 144: -0.000198472 145: -0.000262408 146: -1.42302e-19 147: -0.000230202 148: -5.0822e-21 149: -0.00112642 150: -0.000187737 153: -0.000959226 154: -0.000159871 155: -0.000249411 156: -6.77626e-21 287: -0.00101781 288: 0.000169635 289: -0.00107074 290: 0.000178457 291: -0.00106491 292: 0.000177486 361: -0.000246497 362: 1.21973e-19 363: -0.00028596 364: -1.49078e-19 558: 0.000153468 570: 0.000222005 602: 0.000166274 609: 0.000174938 630: 0.000164331 637: 0.00019064 Row 36: 13: 0.00455091 14: 0.0043796 36: 0.0266468 47: 0.0047088 48: 0.00424451 59: 0.00423499 68: 0.00452796 157: -0.00021948 158: -6.77626e-21 159: -0.000910182 160: -0.000151697 161: -0.00023561 162: -1.28749e-19 165: -0.00087592 166: -0.000145987 167: -0.000218479 168: -5.0822e-21 293: -0.000941759 294: 0.00015696 295: -0.000848903 296: 0.000141484 297: -0.000846999 298: 0.000141166 299: -0.000905593 300: 0.000150932 365: -0.000235269 366: 1.18585e-19 367: -0.000205972 368: -1.0842e-19 415: -0.000217527 416: -1.0842e-19 559: 0.00014632 588: 0.000157074 591: 0.000145653 608: 0.000137315 628: 0.000156846 629: 0.000145018 Row 37: 15: 0.00432972 16: 0.00410704 37: 0.0258685 48: 0.00416669 49: 0.00415419 60: 0.00466053 69: 0.00445034 169: -0.000220475 170: -6.77626e-21 171: -0.000865943 172: -0.000144324 173: -0.000212497 174: -1.16891e-19 177: -0.000821408 178: -0.000136901 179: -0.000190229 180: -5.0822e-21 301: -0.000833337 302: 0.00013889 303: -0.000830838 304: 0.000138473 305: -0.000932106 306: 0.000155351 307: -0.000890069 308: 0.000148345 369: -0.000204172 370: 1.05032e-19 371: -0.00022519 372: -1.15196e-19 425: -0.000240863 426: -1.21973e-19 560: 0.000146983 592: 0.000126819 597: 0.000141665 634: 0.000136115 642: 0.000150127 643: 0.000160575 Row 38: 17: 0.00578346 18: 0.00553997 19: 0.00477716 38: 0.0313612 49: 0.0048697 50: 0.00527093 60: 0.00511998 181: -0.00032526 182: -6.77626e-21 183: -0.00115669 184: -0.000192782 185: -0.000253086 186: -1.37219e-19 187: -0.000228738 188: -6.77626e-21 189: -0.00110799 190: -0.000184666 193: -0.000955432 194: -0.000159239 195: -0.000248978 196: -8.47033e-21 309: -0.000973941 310: 0.000162323 311: -0.00105419 312: 0.000175698 313: -0.001024 314: 0.000170666 371: -0.000233884 372: 1.18585e-19 373: -0.000278114 374: -1.42302e-19 562: 0.000152492 571: 0.00021684 603: 0.000165986 610: 0.000185409 611: 0.000168724 631: 0.000155923 Row 39: 20: 0.00478268 21: 0.00468632 39: 0.0284262 50: 0.00484376 51: 0.00467636 58: 0.00468303 62: 0.00475407 197: -0.000232874 198: -3.38813e-21 199: -0.000956536 200: -0.000159423 201: -0.000245394 202: -1.32137e-19 205: -0.000937265 206: -0.000156211 207: -0.000235758 208: -8.47033e-21 315: -0.000968753 316: 0.000161459 317: -0.000935272 318: 0.000155879 319: -0.000936606 320: 0.000156101 321: -0.000950815 322: 0.000158469 375: -0.000238983 376: 1.21973e-19 377: -0.000231878 378: -1.18585e-19 407: -0.000236425 408: -1.18585e-19 563: 0.00015525 593: 0.000157172 598: 0.000163596 607: 0.000154585 613: 0.000159322 614: 0.000157617 Row 40: 22: 0.00466161 23: 0.00436123 40: 0.0278942 51: 0.00459698 52: 0.00432534 65: 0.00498889 70: 0.00496015 209: -0.000235233 210: -6.77626e-21 211: -0.000932321 212: -0.000155387 213: -0.000230927 214: -1.27055e-19 217: -0.000872247 218: -0.000145374 219: -0.00020089 220: -3.38813e-21 323: -0.000919395 324: 0.000153233 325: -0.000865069 326: 0.000144178 327: -0.000997777 328: 0.000166296 329: -0.000992029 330: 0.000165338 379: -0.00022877 380: 1.15196e-19 381: -0.000231644 382: -1.15196e-19 451: -0.000267245 452: -1.38913e-19 564: 0.000156822 594: 0.000133927 599: 0.000153952 620: 0.000154429 640: 0.000152513 645: 0.000178163 Row 41: 24: 0.00582808 25: 0.00552283 26: 0.00466194 41: 0.0312511 52: 0.00494464 53: 0.0051581 65: 0.00513554 221: -0.000325499 222: -1.01644e-20 223: -0.00116562 224: -0.000194269 225: -0.00025731 226: -1.42302e-19 227: -0.000226785 228: -8.47033e-21 229: -0.00110457 230: -0.000184094 233: -0.000932388 234: -0.000155398 235: -0.00023941 236: -6.77626e-21 331: -0.000988928 332: 0.000164821 333: -0.00103162 334: 0.000171937 335: -0.00102711 336: 0.000171185 381: -0.000237154 382: 1.18585e-19 385: -0.0002764 386: -1.38913e-19 566: 0.00015119 572: 0.000216999 601: 0.000159606 619: 0.00017154 625: 0.000158103 626: 0.000184267 Row 42: 27: 0.00445032 28: 0.00435354 42: 0.0261316 53: 0.00448035 54: 0.00427953 56: 0.00423189 64: 0.00433593 237: -0.000215531 238: -5.0822e-21 239: -0.000890065 240: -0.000148344 241: -0.000229502 242: -1.24514e-19 245: -0.000870709 246: -0.000145118 247: -0.000219824 248: -6.77626e-21 337: -0.00089607 338: 0.000149345 339: -0.000855906 340: 0.000142651 341: -0.000846379 342: 0.000141063 343: -0.000867186 344: 0.000144531 383: -0.000218533 384: 1.11808e-19 387: -0.00020813 388: -1.0842e-19 393: -0.00021506 394: -1.11808e-19 567: 0.000143687 595: 0.000146549 604: 0.000153001 605: 0.000138753 617: 0.000145689 618: 0.000143373 Row 43: 29: 0.00451081 30: 0.00429412 43: 0.0273317 54: 0.00442687 55: 0.0043015 67: 0.00494489 71: 0.00485356 249: -0.000230402 250: -5.0822e-21 251: -0.000902162 252: -0.00015036 253: -0.000220679 254: -1.21126e-19 257: -0.000858824 258: -0.000143137 259: -0.00019901 260: -3.38813e-21 345: -0.000885373 346: 0.000147562 347: -0.000860301 348: 0.000143383 349: -0.000988978 350: 0.00016483 351: -0.000970712 352: 0.000161785 389: -0.000222008 390: 1.15196e-19 391: -0.000231141 392: -1.18585e-19 461: -0.000263348 462: -1.32137e-19 568: 0.000153601 596: 0.000132673 600: 0.000147119 644: 0.000148005 647: 0.000154094 648: 0.000175565 Row 44: 5: 0.00481249 6: 0.00474223 32: 0.00527279 33: 0.0046814 44: 0.0298921 66: 0.00493104 67: 0.00545217 111: -0.000235821 112: -8.47033e-21 113: -0.000245428 114: -1.35525e-19 115: -0.000962498 116: -0.000160416 119: -0.000238402 120: -1.01644e-20 121: -0.000948446 122: -0.000158074 265: -0.00105456 266: -0.00017576 269: -0.00028185 270: -1.52466e-19 271: -0.00093628 272: -0.000156047 277: -0.000229738 278: -3.38813e-21 353: -0.000986208 354: 0.000164368 355: -0.00109043 356: 0.000181739 455: -0.000263367 456: -1.35525e-19 573: 0.000157214 582: 0.000158935 584: 0.000163619 621: 0.000153158 623: 0.0001879 624: 0.000175578 Row 45: 7: 0.00458194 8: 0.00457138 33: 0.00448984 34: 0.00459044 45: 0.0272516 61: 0.00445339 63: 0.00456456 123: -0.000228517 124: -3.38813e-21 125: -0.000229678 126: -1.24514e-19 127: -0.000916389 128: -0.000152731 131: -0.000228621 132: -3.38813e-21 133: -0.000914276 134: -0.000152379 273: -0.000897969 274: -0.000149661 275: -0.000219307 276: -1.19432e-19 279: -0.000918089 280: -0.000153015 285: -0.000230423 286: -3.38813e-21 357: -0.000890679 358: 0.000148446 359: -0.000912912 360: 0.000152152 429: -0.000226033 430: 1.21973e-19 574: 0.000152344 578: 0.000152414 589: 0.000153119 612: 0.000146204 615: 0.000153615 636: 0.000150689 Row 46: 9: 0.0042762 10: 0.00485725 34: 0.00442359 35: 0.00508905 46: 0.0234916 57: 0.00484554 135: -0.000223318 136: -6.77626e-21 137: -0.000204302 138: -1.10961e-19 139: -0.00085524 140: -0.00014254 143: -0.000262408 144: -8.47033e-21 145: -0.000971451 146: -0.000161908 281: -0.000884718 282: -0.000147453 283: -0.000238057 284: -1.29596e-19 287: -0.00101781 288: -0.000169635 291: -0.000246497 292: -1.01644e-20 361: -0.000969108 362: 0.000161518 575: 0.000148878 590: 0.000136201 606: 0.000158705 609: 0.000174938 630: 0.000164331 Row 47: 12: 0.00486507 13: 0.00472707 35: 0.00535371 36: 0.0047088 47: 0.030371 57: 0.00561162 68: 0.00510471 151: -0.000237096 152: -5.0822e-21 153: -0.000249411 154: -1.35525e-19 155: -0.000973014 156: -0.000162169 159: -0.00023561 160: -5.0822e-21 161: -0.000945413 162: -0.000157569 289: -0.00107074 290: -0.000178457 291: -0.00028596 292: -1.57548e-19 293: -0.000941759 294: -0.00015696 299: -0.000235269 300: -8.47033e-21 363: -0.00112232 364: 0.000187054 365: -0.00102094 366: 0.000170157 403: -0.000275202 404: 1.38913e-19 576: 0.000158064 588: 0.000157074 602: 0.000166274 628: 0.000156846 637: 0.00019064 641: 0.000183468 Row 48: 14: 0.00430978 15: 0.00424995 36: 0.00424451 37: 0.00416669 48: 0.0252491 59: 0.00414807 69: 0.00413007 163: -0.000212498 164: -3.38813e-21 165: -0.000218479 166: -1.20279e-19 167: -0.000861955 168: -0.000143659 171: -0.000212497 172: -5.0822e-21 173: -0.00084999 174: -0.000141665 295: -0.000848903 296: -0.000141484 297: -0.000205972 298: -1.12655e-19 301: -0.000833337 302: -0.00013889 307: -0.000204172 308: -3.38813e-21 367: -0.000829615 368: 0.000138269 369: -0.000826014 370: 0.000137669 417: -0.000208835 418: 1.11808e-19 577: 0.000141666 591: 0.000145653 597: 0.000141665 608: 0.000137315 633: 0.000139224 634: 0.000136115 Row 49: 16: 0.00404569 17: 0.00467426 37: 0.00415419 38: 0.0048697 49: 0.0223346 60: 0.00459074 175: -0.00021434 176: -5.0822e-21 177: -0.000190229 178: -1.03338e-19 179: -0.000809138 180: -0.000134856 183: -0.000253086 184: -5.0822e-21 185: -0.000934852 186: -0.000155809 303: -0.000830838 304: -0.000138473 305: -0.00022519 306: -1.2282e-19 309: -0.000973941 310: -0.000162323 313: -0.000233884 314: -3.38813e-21 371: -0.000918148 372: 0.000153025 579: 0.000142893 592: 0.000126819 611: 0.000168724 631: 0.000155923 642: 0.000150127 Row 50: 19: 0.00487969 20: 0.00484385 38: 0.00527093 39: 0.00484376 50: 0.0304892 60: 0.00552116 62: 0.00512985 191: -0.000238991 192: -8.47033e-21 193: -0.000248978 194: -1.35525e-19 195: -0.000975938 196: -0.000162656 199: -0.000245394 200: -6.77626e-21 201: -0.000968769 202: -0.000161462 311: -0.00105419 312: -0.000175698 313: -0.000278114 314: -1.50772e-19 315: -0.000968753 316: -0.000161459 321: -0.000238983 322: -1.01644e-20 373: -0.00110423 374: 0.000184039 375: -0.00102597 376: 0.000170995 423: -0.000274002 424: 1.38913e-19 580: 0.000159327 598: 0.000163596 603: 0.000165986 610: 0.000185409 613: 0.000159322 638: 0.000182668 Row 51: 21: 0.00468132 22: 0.00463302 39: 0.00467636 40: 0.00459698 51: 0.0278813 58: 0.00466237 70: 0.00463129 203: -0.000232374 204: -5.0822e-21 205: -0.000235758 206: -1.29596e-19 207: -0.000936264 208: -0.000156044 211: -0.000230927 212: -5.0822e-21 213: -0.000926603 214: -0.000154434 317: -0.000935272 318: -0.000155879 319: -0.000231878 320: -1.27055e-19 323: -0.000919395 324: -0.000153233 329: -0.00022877 330: -6.77626e-21 377: -0.000932474 378: 0.000155412 379: -0.000926258 380: 0.000154376 409: -0.000234359 410: 1.21973e-19 581: 0.000154916 593: 0.000157172 599: 0.000153952 607: 0.000154585 639: 0.000156239 640: 0.000152513 Row 52: 23: 0.00420399 24: 0.00476818 40: 0.00432534 41: 0.00494464 52: 0.0229301 65: 0.00468798 215: -0.000219508 216: -3.38813e-21 217: -0.00020089 218: -1.09267e-19 219: -0.000840797 220: -0.000140133 223: -0.00025731 224: -3.38813e-21 225: -0.000953636 226: -0.000158939 325: -0.000865069 326: -0.000144178 327: -0.000231644 328: -1.26208e-19 331: -0.000988928 332: -0.000164821 335: -0.000237154 336: -8.47033e-21 381: -0.000937597 382: 0.000156266 583: 0.000146339 594: 0.000133927 619: 0.00017154 620: 0.000154429 625: 0.000158103 Row 53: 26: 0.00467481 27: 0.00457573 41: 0.0051581 42: 0.00448035 53: 0.0289194 64: 0.00472588 65: 0.00530456 231: -0.000228072 232: -6.77626e-21 233: -0.00023941 234: -1.30443e-19 235: -0.000934963 236: -0.000155827 239: -0.000229502 240: -3.38813e-21 241: -0.000915147 242: -0.000152524 333: -0.00103162 334: -0.000171937 335: -0.0002764 336: -1.52466e-19 337: -0.00089607 338: -0.000149345 343: -0.000218533 344: -5.0822e-21 383: -0.000945177 384: 0.000157529 385: -0.00106091 386: 0.000176819 445: -0.000254055 446: -1.28749e-19 585: 0.000152048 601: 0.000159606 604: 0.000153001 617: 0.000145689 626: 0.000184267 635: 0.00016937 Row 54: 28: 0.00438717 29: 0.00439572 42: 0.00427953 43: 0.00442687 54: 0.026094 56: 0.00423297 71: 0.00437176 243: -0.000218893 244: -3.38813e-21 245: -0.000219824 246: -1.21126e-19 247: -0.000877433 248: -0.000146239 251: -0.000220679 252: -6.77626e-21 253: -0.000879144 254: -0.000146524 339: -0.000855906 340: -0.000142651 341: -0.00020813 342: -1.14349e-19 345: -0.000885373 346: -0.000147562 351: -0.000222008 352: -5.0822e-21 387: -0.000846595 388: 0.000141099 389: -0.000874352 390: 0.000145725 395: -0.000215168 396: 1.11808e-19 586: 0.000145929 595: 0.000146549 600: 0.000147119 605: 0.000138753 644: 0.000148005 646: 0.000143445 Row 55: 30: 0.00417744 31: 0.00476988 32: 0.00497975 43: 0.0043015 55: 0.0229372 67: 0.00470862 255: -0.000218734 256: -3.38813e-21 257: -0.00019901 258: -1.09267e-19 259: -0.000835488 260: -0.000139248 261: -0.000258254 262: -8.47033e-21 263: -0.000953976 264: -0.000158996 267: -0.00099595 268: -0.000165992 269: -0.000239721 270: -6.77626e-21 347: -0.000860301 348: -0.000143383 349: -0.000231141 350: -1.25361e-19 391: -0.000941724 392: 0.000156954 587: 0.000145823 596: 0.000132673 627: 0.000172169 632: 0.000159814 647: 0.000154094 Row 56: 42: 0.00423189 54: 0.00423297 56: 0.0242349 64: 0.00391886 71: 0.00435232 72: 0.00396559 75: 0.00353321 339: -0.00020813 340: -5.0822e-21 341: -0.000846379 342: -0.000141063 343: -0.00021506 344: -1.17738e-19 387: -0.000846595 388: -0.000141099 389: -0.000215168 390: -3.38813e-21 393: -0.000783772 394: 0.000130629 395: -0.000870464 396: 0.000145077 397: -0.000793118 398: 0.000132186 399: -0.000706643 400: 0.000117774 447: -0.000176827 448: 9.14796e-20 477: -0.000220064 478: -1.11808e-19 481: -0.000176495 482: -9.14796e-20 605: 0.000138753 618: 0.000143373 646: 0.000143445 649: 0.000146709 653: 0.000117884 654: 0.000117663 Row 57: 34: 0.00509607 35: 0.00532457 46: 0.00484554 47: 0.00561162 57: 0.0371921 63: 0.00542756 68: 0.00546337 74: 0.00542342 281: -0.000238057 282: -6.77626e-21 283: -0.00101921 284: -0.000169869 285: -0.00027155 286: -1.49078e-19 287: -0.000246497 288: -1.34678e-19 289: -0.00028596 290: -6.77626e-21 291: -0.00106491 292: -0.000177486 361: -0.000969108 362: -0.000161518 363: -0.00112232 364: -0.000187054 365: -0.000275202 366: -3.38813e-21 401: -0.00108551 402: 0.000180919 403: -0.00109267 404: 0.000182112 405: -0.00108468 406: 0.000180781 441: -0.000271206 442: 1.42302e-19 465: -0.000271136 466: -1.38913e-19 606: 0.000158705 616: 0.000181033 630: 0.000164331 637: 0.00019064 641: 0.000183468 651: 0.000180804 652: 0.000180757 Row 58: 39: 0.00468303 51: 0.00466237 58: 0.0276996 62: 0.00468683 70: 0.00467345 73: 0.00450061 83: 0.00449334 317: -0.000231878 318: -3.38813e-21 319: -0.000936606 320: -0.000156101 321: -0.000236425 322: -1.28749e-19 377: -0.000932474 378: -0.000155412 379: -0.000234359 380: -6.77626e-21 407: -0.000937367 408: 0.000156228 409: -0.000934689 410: 0.000155782 411: -0.000900123 412: 0.00015002 413: -0.000898668 414: 0.000149778 439: -0.000232259 440: 1.21973e-19 473: -0.000232986 474: -1.18585e-19 491: -0.000217076 492: -1.15196e-19 607: 0.000154585 614: 0.000157617 639: 0.000156239 650: 0.000155324 672: 0.000154839 674: 0.000144717 Row 59: 36: 0.00423499 48: 0.00414807 59: 0.0237923 68: 0.00433386 69: 0.00380286 76: 0.00341423 81: 0.00385832 295: -0.000205972 296: -3.38813e-21 297: -0.000846999 298: -0.000141166 299: -0.000217527 300: -1.18585e-19 367: -0.000829615 368: -0.000138269 369: -0.000208835 370: -3.38813e-21 415: -0.000866772 416: 0.000144462 417: -0.000760572 418: 0.000126762 419: -0.000682846 420: 0.000113808 421: -0.000771664 422: 0.000128611 467: -0.000215859 468: 1.11808e-19 469: -0.00017145 470: -8.47033e-20 509: -0.000169973 510: -8.80914e-20 608: 0.000137315 629: 0.000145018 633: 0.000139224 655: 0.0001143 666: 0.000143906 668: 0.000113315 Row 60: 37: 0.00466053 38: 0.00511998 49: 0.00459074 50: 0.00552116 60: 0.0349119 62: 0.00524315 69: 0.00484091 77: 0.00493542 303: -0.00022519 304: -8.47033e-21 305: -0.000932106 306: -0.000155351 307: -0.000240863 308: -1.30443e-19 309: -0.000233884 310: -1.28749e-19 311: -0.000278114 312: -1.01644e-20 313: -0.001024 314: -0.000170666 371: -0.000918148 372: -0.000153025 373: -0.00110423 374: -0.000184039 375: -0.000274002 376: -8.47033e-21 423: -0.00104863 424: 0.000174772 425: -0.000968183 426: 0.000161364 427: -0.000987084 428: 0.000164514 437: -0.000250313 438: -1.25361e-19 471: -0.000243229 472: 1.18585e-19 610: 0.000185409 631: 0.000155923 638: 0.000182668 642: 0.000150127 643: 0.000160575 656: 0.000162153 658: 0.000166875 Row 61: 33: 0.00444425 45: 0.00445339 61: 0.0255334 63: 0.00454504 66: 0.00417377 78: 0.00377739 79: 0.00413952 273: -0.000219307 274: -6.77626e-21 275: -0.000888851 276: -0.000148142 277: -0.000225119 278: -1.2282e-19 357: -0.000890679 358: -0.000148446 359: -0.000226033 360: -3.38813e-21 429: -0.000909008 430: 0.000151501 431: -0.000834754 432: 0.000139126 433: -0.000755477 434: 0.000125913 435: -0.000827903 436: 0.000137984 443: -0.000228471 444: -1.18585e-19 457: -0.000192258 458: 9.82558e-20 517: -0.00018548 518: 9.48677e-20 612: 0.000146204 622: 0.000150079 636: 0.000150689 659: 0.000128172 660: 0.000152314 661: 0.000123653 Row 62: 39: 0.00475407 50: 0.00512985 58: 0.00468683 60: 0.00524315 62: 0.0289909 77: 0.00467879 83: 0.00449825 315: -0.000238983 316: -1.3129e-19 319: -0.000236425 320: -5.0822e-21 321: -0.000950815 322: -0.000158469 373: -0.000274002 374: -1.49078e-19 375: -0.00102597 376: -0.000170995 407: -0.000937367 408: -0.000156228 413: -0.000232259 414: -3.38813e-21 423: -0.00104863 424: -0.000174772 427: -0.000250313 428: -1.36372e-19 437: -0.000935759 438: 0.00015596 439: -0.00089965 440: 0.000149942 513: -0.000217566 514: 1.15196e-19 613: 0.000159322 614: 0.000157617 638: 0.000182668 658: 0.000166875 672: 0.000154839 673: 0.000145044 Row 63: 34: 0.00501973 45: 0.00456456 57: 0.00542756 61: 0.00454504 63: 0.029113 74: 0.00499172 79: 0.00456437 279: -0.000230423 280: -1.26208e-19 283: -0.00027155 284: -6.77626e-21 285: -0.00100395 286: -0.000167324 357: -0.000226033 358: -1.23667e-19 359: -0.000912912 360: -0.000152152 401: -0.00108551 402: -0.000180919 405: -0.000271206 406: -6.77626e-21 429: -0.000909008 430: -0.000151501 435: -0.000228471 436: -1.24514e-19 441: -0.000998344 442: 0.000166391 443: -0.000912874 444: 0.000152146 497: -0.000227966 498: -1.18585e-19 615: 0.000153615 616: 0.000181033 636: 0.000150689 651: 0.000180804 660: 0.000152314 662: 0.000151977 Row 64: 42: 0.00433593 53: 0.00472588 56: 0.00391886 64: 0.0258768 65: 0.00504652 75: 0.00355593 80: 0.00429363 337: -0.000218533 338: -1.19432e-19 341: -0.00021506 342: -6.77626e-21 343: -0.000867186 344: -0.000144531 383: -0.000945177 384: -0.000157529 385: -0.000254055 386: -1.38913e-19 393: -0.000783772 394: -0.000130629 399: -0.000176827 400: -3.38813e-21 445: -0.0010093 446: 0.000168217 447: -0.000711186 448: 0.000118531 449: -0.000858727 450: 0.000143121 453: -0.000250597 454: 1.28749e-19 503: -0.000178767 504: -9.48677e-20 617: 0.000145689 618: 0.000143373 635: 0.00016937 653: 0.000117884 663: 0.000167065 665: 0.000119178 Row 65: 40: 0.00498889 41: 0.00513554 52: 0.00468798 53: 0.00530456 64: 0.00504652 65: 0.0354096 70: 0.00520628 80: 0.0050398 325: -0.000231644 326: -6.77626e-21 327: -0.000997777 328: -0.000166296 329: -0.000267245 330: -1.4569e-19 331: -0.000237154 332: -1.28749e-19 333: -0.0002764 334: -8.47033e-21 335: -0.00102711 336: -0.000171185 381: -0.000937597 382: -0.000156266 383: -0.000254055 384: -8.47033e-21 385: -0.00106091 386: -0.000176819 445: -0.0010093 446: -0.000168217 449: -0.000250597 450: -1.01644e-20 451: -0.00104126 452: 0.000173543 453: -0.00100796 454: 0.000167993 475: -0.000253384 476: 1.28749e-19 620: 0.000154429 625: 0.000158103 626: 0.000184267 635: 0.00016937 645: 0.000178163 663: 0.000167065 664: 0.000168922 Row 66: 33: 0.00454856 44: 0.00493104 61: 0.00417377 66: 0.027271 67: 0.00525498 78: 0.00383195 82: 0.00453068 271: -0.000229738 272: -1.25361e-19 275: -0.000225119 276: -3.38813e-21 277: -0.000909713 278: -0.000151619 353: -0.000986208 354: -0.000164368 355: -0.000263367 356: -1.43996e-19 431: -0.000834754 432: -0.000139126 433: -0.000192258 434: -3.38813e-21 455: -0.001051 456: 0.000175166 457: -0.00076639 458: 0.000127732 459: -0.000906135 460: 0.000151023 463: -0.000262131 464: 1.32137e-19 519: -0.000190936 520: -9.82558e-20 621: 0.000153158 622: 0.000150079 624: 0.000175578 659: 0.000128172 671: 0.000174754 676: 0.000127291 Row 67: 32: 0.00521572 43: 0.00494489 44: 0.00545217 55: 0.00470862 66: 0.00525498 67: 0.0360169 71: 0.00522634 82: 0.00521417 265: -0.00028185 266: -6.77626e-21 267: -0.000239721 268: -1.30443e-19 269: -0.00104314 270: -0.000173857 347: -0.000231141 348: -1.69407e-21 349: -0.000988978 350: -0.00016483 351: -0.000263348 352: -1.4569e-19 353: -0.000263367 354: -1.69407e-21 355: -0.00109043 356: -0.000181739 391: -0.000941724 392: -0.000156954 455: -0.001051 456: -0.000175166 459: -0.000262131 460: -5.0822e-21 461: -0.00104527 462: 0.000174211 463: -0.00104283 464: 0.000173806 479: -0.000259286 480: 1.32137e-19 623: 0.0001879 624: 0.000175578 632: 0.000159814 647: 0.000154094 648: 0.000175565 669: 0.000172857 671: 0.000174754 Row 68: 36: 0.00452796 47: 0.00510471 57: 0.00546337 59: 0.00433386 68: 0.028705 74: 0.00491393 81: 0.00436116 293: -0.000235269 294: -1.27902e-19 297: -0.000217527 298: -5.0822e-21 299: -0.000905593 300: -0.000150932 363: -0.000275202 364: -1.49078e-19 365: -0.00102094 366: -0.000170157 403: -0.00109267 404: -0.000182112 405: -0.000271136 406: -1.47384e-19 415: -0.000866772 416: -0.000144462 421: -0.000215859 422: -6.77626e-21 465: -0.000982786 466: 0.000163798 467: -0.000872232 468: 0.000145372 499: -0.000220257 500: 1.11808e-19 628: 0.000156846 629: 0.000145018 641: 0.000183468 652: 0.000180757 666: 0.000143906 667: 0.000146838 Row 69: 37: 0.00445034 48: 0.00413007 59: 0.00380286 60: 0.00484091 69: 0.0248257 76: 0.00344186 77: 0.00415964 301: -0.000204172 302: -1.10961e-19 305: -0.000240863 306: -5.0822e-21 307: -0.000890069 308: -0.000148345 367: -0.000208835 368: -1.13502e-19 369: -0.000826014 370: -0.000137669 417: -0.000760572 418: -0.000126762 419: -0.00017145 420: -9.31736e-20 425: -0.000968183 426: -0.000161364 427: -0.000243229 428: -6.77626e-21 469: -0.000688372 470: 0.000114729 471: -0.000831929 472: 0.000138655 507: -0.000172736 508: 8.80914e-20 633: 0.000139224 634: 0.000136115 643: 0.000160575 655: 0.0001143 656: 0.000162153 657: 0.000115157 Row 70: 40: 0.00496015 51: 0.00463129 58: 0.00467345 65: 0.00520628 70: 0.0287159 73: 0.00452039 80: 0.00472437 323: -0.00022877 324: -1.23667e-19 327: -0.000267245 328: -8.47033e-21 329: -0.000992029 330: -0.000165338 377: -0.000234359 378: -1.27902e-19 379: -0.000926258 380: -0.000154376 409: -0.000934689 410: -0.000155782 411: -0.000232986 412: -1.27055e-19 451: -0.00104126 452: -0.000173543 453: -0.000253384 454: -5.0822e-21 473: -0.000904078 474: 0.00015068 475: -0.000944874 476: 0.000157479 489: -0.000219053 490: 1.11808e-19 639: 0.000156239 640: 0.000152513 645: 0.000178163 650: 0.000155324 664: 0.000168922 675: 0.000146036 Row 71: 43: 0.00485356 54: 0.00437176 56: 0.00435232 67: 0.00522634 71: 0.0279483 72: 0.00437604 82: 0.00476826 345: -0.000222008 346: -1.21126e-19 349: -0.000263348 350: -3.38813e-21 351: -0.000970712 352: -0.000161785 387: -0.000215168 388: -1.16891e-19 389: -0.000874352 390: -0.000145725 395: -0.000870464 396: -0.000145077 397: -0.000220064 398: -1.20279e-19 461: -0.00104527 462: -0.000174211 463: -0.000259286 464: -6.77626e-21 477: -0.000875208 478: 0.000145868 479: -0.000953652 480: 0.000158942 483: -0.00021754 484: 1.0842e-19 644: 0.000148005 646: 0.000143445 648: 0.000175565 649: 0.000146709 669: 0.000172857 670: 0.000145027 Row 72: 56: 0.00396559 71: 0.00437604 72: 0.0256201 75: 0.00353135 82: 0.00463296 84: 0.00421152 86: 0.00490268 395: -0.000220064 396: -6.77626e-21 397: -0.000793118 398: -0.000132186 399: -0.000176495 400: -9.74088e-20 477: -0.000875208 478: -0.000145868 479: -0.00021754 480: -3.38813e-21 481: -0.000706269 482: 0.000117712 483: -0.000926592 484: 0.000154432 485: -0.000842304 486: 0.000140384 487: -0.000980536 488: 0.000163423 505: -0.00017664 506: 9.14796e-20 533: -0.000245756 534: -1.25361e-19 539: -0.000244512 540: 1.28749e-19 649: 0.000146709 654: 0.000117663 670: 0.000145027 679: 0.00011776 682: 0.000163837 683: 0.000163008 Row 73: 58: 0.00450061 70: 0.00452039 73: 0.0264991 80: 0.00439381 83: 0.00441745 84: 0.00431173 88: 0.00435514 409: -0.000232986 410: -1.01644e-20 411: -0.000900123 412: -0.00015002 413: -0.000217076 414: -1.18585e-19 473: -0.000904078 474: -0.00015068 475: -0.000219053 476: -6.77626e-21 489: -0.000878763 490: 0.00014646 491: -0.000883491 492: 0.000147248 493: -0.000862345 494: 0.000143724 495: -0.000871029 496: 0.000145171 527: -0.000220328 528: -1.11808e-19 537: -0.00022467 538: 1.15196e-19 541: -0.000210845 542: -1.05032e-19 650: 0.000155324 674: 0.000144717 675: 0.000146036 677: 0.000146885 690: 0.000140563 691: 0.00014978 Row 74: 57: 0.00542342 63: 0.00499172 68: 0.00491393 74: 0.0287476 79: 0.00454306 81: 0.00440731 87: 0.00446814 401: -0.000271206 402: -1.47384e-19 403: -0.000271136 404: -6.77626e-21 405: -0.00108468 406: -0.000180781 441: -0.000998344 442: -0.000166391 443: -0.000227966 444: -1.24514e-19 465: -0.000982786 466: -0.000163798 467: -0.000220257 468: -6.77626e-21 497: -0.000908612 498: 0.000151435 499: -0.000881463 500: 0.00014691 501: -0.000893629 502: 0.000148938 525: -0.00022634 526: 1.15196e-19 531: -0.000220474 532: -1.15196e-19 651: 0.000180804 652: 0.000180757 662: 0.000151977 667: 0.000146838 686: 0.000150894 688: 0.000146983 Row 75: 56: 0.00353321 64: 0.00355593 72: 0.00353135 75: 0.0177617 80: 0.00358124 84: 0.00355997 393: -0.000176827 394: -9.65618e-20 397: -0.000176495 398: -5.0822e-21 399: -0.000706643 400: -0.000117774 447: -0.000711186 448: -0.000118531 449: -0.000178767 450: -9.82558e-20 481: -0.000706269 482: -0.000117712 485: -0.00017664 486: -5.0822e-21 503: -0.000716248 504: 0.000119375 505: -0.000711995 506: 0.000118666 527: -0.000179357 528: 9.14796e-20 653: 0.000117884 654: 0.000117663 665: 0.000119178 678: 0.000119572 679: 0.00011776 Row 76: 59: 0.00341423 69: 0.00344186 76: 0.0171106 77: 0.00344168 81: 0.00339911 85: 0.00341371 417: -0.00017145 418: -3.38813e-21 419: -0.000682846 420: -0.000113808 421: -0.000169973 422: -9.23266e-20 469: -0.000688372 470: -0.000114729 471: -0.000172736 472: -5.0822e-21 507: -0.000688336 508: 0.000114723 509: -0.000679822 510: 0.000113304 511: -0.000682741 512: 0.00011379 515: -0.000171432 516: -8.80914e-20 529: -0.000169938 530: 8.80914e-20 655: 0.0001143 657: 0.000115157 668: 0.000113315 680: 0.000114288 689: 0.000113292 Row 77: 60: 0.00493542 62: 0.00467879 69: 0.00415964 76: 0.00344168 77: 0.0253487 83: 0.00429723 85: 0.00383589 423: -0.000250313 424: -1.01644e-20 425: -0.000243229 426: -1.33831e-19 427: -0.000987084 428: -0.000164514 437: -0.000935759 438: -0.00015596 439: -0.000217566 440: -3.38813e-21 469: -0.000172736 470: -9.40207e-20 471: -0.000831929 472: -0.000138655 507: -0.000688336 508: -0.000114723 511: -0.000171432 512: -9.31736e-20 513: -0.000859447 514: 0.000143241 515: -0.000767179 516: 0.000127863 535: -0.000212157 536: -1.05032e-19 656: 0.000162153 657: 0.000115157 658: 0.000166875 673: 0.000145044 680: 0.000114288 681: 0.000141438 Row 78: 61: 0.00377739 66: 0.00383195 78: 0.0199429 79: 0.00397845 82: 0.00407043 86: 0.00428471 431: -0.000192258 432: -1.05032e-19 433: -0.000755477 434: -0.000125913 435: -0.00018548 436: -6.77626e-21 457: -0.00076639 458: -0.000127732 459: -0.000190936 460: -1.04185e-19 517: -0.00079569 518: 0.000132615 519: -0.000814086 520: 0.000135681 521: -0.000856943 522: 0.000142824 523: -0.000212365 524: -1.0842e-19 533: -0.000216107 534: 1.0842e-19 659: 0.000128172 661: 0.000123653 676: 0.000127291 684: 0.000144071 685: 0.000141576 Row 79: 61: 0.00413952 63: 0.00456437 74: 0.00454306 78: 0.00397845 79: 0.026528 86: 0.00458141 87: 0.00472116 429: -0.000228471 430: -3.38813e-21 433: -0.00018548 434: -1.00797e-19 435: -0.000827903 436: -0.000137984 441: -0.000227966 442: -6.77626e-21 443: -0.000912874 444: -0.000152146 497: -0.000908612 498: -0.000151435 501: -0.00022634 502: -6.77626e-21 517: -0.00079569 518: -0.000132615 521: -0.000212365 522: -1.16044e-19 523: -0.000916281 524: 0.000152714 525: -0.000944233 526: 0.000157372 547: -0.000245776 548: 1.28749e-19 660: 0.000152314 661: 0.000123653 662: 0.000151977 685: 0.000141576 686: 0.000150894 687: 0.000163851 Row 80: 64: 0.00429363 65: 0.0050398 70: 0.00472437 73: 0.00439381 75: 0.00358124 80: 0.0260297 84: 0.00399686 445: -0.000250597 446: -1.37219e-19 447: -0.000178767 448: -5.0822e-21 449: -0.000858727 450: -0.000143121 451: -0.000253384 452: -1.38913e-19 453: -0.00100796 454: -0.000167993 473: -0.000219053 474: -1.20279e-19 475: -0.000944874 476: -0.000157479 489: -0.000878763 490: -0.00014646 493: -0.000220328 494: -1.20279e-19 503: -0.000716248 504: -0.000119375 505: -0.000179357 506: -5.0822e-21 527: -0.000799371 528: 0.000133229 663: 0.000167065 664: 0.000168922 665: 0.000119178 675: 0.000146036 677: 0.000146885 678: 0.000119572 Row 81: 59: 0.00385832 68: 0.00436116 74: 0.00440731 76: 0.00339911 81: 0.0241521 85: 0.00381043 87: 0.00431579 415: -0.000215859 416: -1.18585e-19 419: -0.000169973 420: -5.0822e-21 421: -0.000771664 422: -0.000128611 465: -0.000220257 466: -1.21126e-19 467: -0.000872232 468: -0.000145372 499: -0.000881463 500: -0.00014691 501: -0.000220474 502: -1.20279e-19 509: -0.000679822 510: -0.000113304 511: -0.000169938 512: -5.0822e-21 529: -0.000762086 530: 0.000127014 531: -0.000863158 532: 0.00014386 543: -0.000211105 544: -1.0842e-19 666: 0.000143906 667: 0.000146838 668: 0.000113315 688: 0.000146983 689: 0.000113292 694: 0.000140737 Row 82: 66: 0.00453068 67: 0.00521417 71: 0.00476826 72: 0.00463296 78: 0.00407043 82: 0.0278351 86: 0.00461862 455: -0.000262131 456: -1.43996e-19 457: -0.000190936 458: -5.0822e-21 459: -0.000906135 460: -0.000151023 461: -0.000259286 462: -1.43996e-19 463: -0.00104283 464: -0.000173806 477: -0.00021754 478: -1.18585e-19 479: -0.000953652 480: -0.000158942 483: -0.000926592 484: -0.000154432 487: -0.000245756 488: -1.33831e-19 519: -0.000814086 520: -0.000135681 521: -0.000216107 522: -8.47033e-21 533: -0.000923725 534: 0.000153954 669: 0.000172857 670: 0.000145027 671: 0.000174754 676: 0.000127291 682: 0.000163837 684: 0.000144071 Row 83: 58: 0.00449334 62: 0.00449825 73: 0.00441745 77: 0.00429723 83: 0.026186 85: 0.00417732 88: 0.00430245 407: -0.000232259 408: -1.26208e-19 411: -0.000217076 412: -5.0822e-21 413: -0.000898668 414: -0.000149778 437: -0.000217566 438: -1.19432e-19 439: -0.00089965 440: -0.000149942 491: -0.000883491 492: -0.000147248 495: -0.00022467 496: -5.0822e-21 513: -0.000859447 514: -0.000143241 515: -0.000212157 516: -1.14349e-19 535: -0.000835464 536: 0.000139244 537: -0.00086049 538: 0.000143415 545: -0.000205575 546: 1.01644e-19 672: 0.000154839 673: 0.000145044 674: 0.000144717 681: 0.000141438 691: 0.00014978 693: 0.00013705 Row 84: 72: 0.00421152 73: 0.00431173 75: 0.00355997 80: 0.00399686 84: 0.0253502 86: 0.00480337 88: 0.0044667 481: -0.00017664 482: -9.57147e-20 485: -0.000842304 486: -0.000140384 487: -0.000244512 488: -3.38813e-21 489: -0.000220328 490: -5.0822e-21 493: -0.000862345 494: -0.000143724 495: -0.000210845 496: -1.13502e-19 503: -0.000179357 504: -9.74088e-20 505: -0.000711995 506: -0.000118666 527: -0.000799371 528: -0.000133229 539: -0.000960675 540: 0.000160112 541: -0.00089334 542: 0.00014889 549: -0.000235825 550: -1.18585e-19 677: 0.000146885 678: 0.000119572 679: 0.00011776 683: 0.000163008 690: 0.000140563 692: 0.000157217 Row 85: 76: 0.00341371 77: 0.00383589 81: 0.00381043 83: 0.00417732 85: 0.0235707 87: 0.0041943 88: 0.004139 507: -0.000171432 508: -5.0822e-21 509: -0.000169938 510: -9.23266e-20 511: -0.000682741 512: -0.00011379 513: -0.000212157 514: -8.47033e-21 515: -0.000767179 516: -0.000127863 529: -0.000762086 530: -0.000127014 531: -0.000211105 532: -1.14349e-19 535: -0.000835464 536: -0.000139244 537: -0.000205575 538: -6.77626e-21 543: -0.00083886 544: 0.00013981 545: -0.000827801 546: 0.000137967 551: -0.000208325 552: 1.0842e-19 680: 0.000114288 681: 0.000141438 689: 0.000113292 693: 0.00013705 694: 0.000140737 696: 0.000138883 Row 86: 72: 0.00490268 78: 0.00428471 79: 0.00458141 82: 0.00461862 84: 0.00480337 86: 0.0330992 87: 0.00500395 88: 0.00490444 483: -0.000245756 484: -6.77626e-21 485: -0.000244512 486: -1.32984e-19 487: -0.000980536 488: -0.000163423 517: -0.000212365 518: -6.77626e-21 519: -0.000216107 520: -1.17738e-19 521: -0.000856943 522: -0.000142824 523: -0.000916281 524: -0.000152714 525: -0.000245776 526: -5.0822e-21 533: -0.000923725 534: -0.000153954 539: -0.000960675 540: -0.000160112 541: -0.000235825 542: -1.28749e-19 547: -0.00100079 548: 0.000166798 549: -0.000980887 550: 0.000163481 551: -0.000254619 552: -1.25361e-19 682: 0.000163837 683: 0.000163008 684: 0.000144071 685: 0.000141576 687: 0.000163851 692: 0.000157217 695: 0.000169746 Row 87: 74: 0.00446814 79: 0.00472116 81: 0.00431579 85: 0.0041943 86: 0.00500395 87: 0.0273328 88: 0.00462944 497: -0.00022634 498: -1.23667e-19 499: -0.000220474 500: -5.0822e-21 501: -0.000893629 502: -0.000148938 523: -0.000245776 524: -1.34678e-19 525: -0.000944233 526: -0.000157372 529: -0.000211105 530: -5.0822e-21 531: -0.000863158 532: -0.00014386 543: -0.00083886 544: -0.00013981 545: -0.000208325 546: -6.77626e-21 547: -0.00100079 548: -0.000166798 549: -0.000254619 550: -1.38913e-19 551: -0.000925887 552: 0.000154315 686: 0.000150894 687: 0.000163851 688: 0.000146983 694: 0.000140737 695: 0.000169746 696: 0.000138883 Row 88: 73: 0.00435514 83: 0.00430245 84: 0.0044667 85: 0.004139 86: 0.00490444 87: 0.00462944 88: 0.0267972 491: -0.00022467 492: -1.2282e-19 493: -0.000210845 494: -6.77626e-21 495: -0.000871029 496: -0.000145171 535: -0.000205575 536: -1.13502e-19 537: -0.00086049 538: -0.000143415 539: -0.000235825 540: -1.01644e-20 541: -0.00089334 542: -0.00014889 543: -0.000208325 544: -1.13502e-19 545: -0.000827801 546: -0.000137967 547: -0.000254619 548: -5.0822e-21 549: -0.000980887 550: -0.000163481 551: -0.000925887 552: -0.000154315 690: 0.000140563 691: 0.00014978 692: 0.000157217 693: 0.00013705 695: 0.000169746 696: 0.000138883 Row 89: 0: -0.000520833 4: -0.000520833 31: -0.000260417 89: 8.68056e-05 90: 4.23516e-22 91: 4.34028e-05 92: -6.2004e-06 107: 4.34028e-05 108: -6.2004e-06 553: -2.48016e-05 Row 90: 0: 8.68056e-05 4: -8.68056e-05 31: -3.38813e-21 89: 4.23516e-22 90: 9.3006e-06 91: -6.2004e-06 92: 3.1002e-06 107: 6.2004e-06 108: -3.1002e-06 553: -1.27963e-21 Row 91: 0: -0.000520833 4: -0.000260417 31: -0.000520833 89: 4.34028e-05 90: -6.2004e-06 91: 8.68056e-05 92: 2.00641e-20 107: 4.34028e-05 108: 6.2004e-06 553: -2.48016e-05 Row 92: 0: 8.68056e-05 4: -1.42302e-19 31: -8.68056e-05 89: -6.2004e-06 90: 3.1002e-06 91: 2.00641e-20 92: 9.3006e-06 107: 6.2004e-06 108: 3.1002e-06 553: -1.11173e-20 Row 93: 1: -0.000520833 10: -0.000520833 11: -0.000260417 93: 8.68056e-05 94: 2.00641e-20 95: 4.34028e-05 96: -6.2004e-06 141: 4.34028e-05 142: -6.2004e-06 557: -2.48016e-05 Row 94: 1: 8.68056e-05 10: -8.68056e-05 11: -1.42302e-19 93: 2.00641e-20 94: 9.3006e-06 95: -6.2004e-06 96: 3.1002e-06 141: 6.2004e-06 142: -3.1002e-06 557: -1.13291e-20 Row 95: 1: -0.000520833 10: -0.000260417 11: -0.000520833 93: 4.34028e-05 94: -6.2004e-06 95: 8.68056e-05 96: 4.23516e-22 141: 4.34028e-05 142: 6.2004e-06 557: -2.48016e-05 Row 96: 1: 8.68056e-05 10: -3.38813e-21 11: -8.68056e-05 93: -6.2004e-06 94: 3.1002e-06 95: 4.23516e-22 96: 9.3006e-06 141: 6.2004e-06 142: 3.1002e-06 557: -1.50092e-21 Row 97: 2: -0.000520833 17: -0.000520833 18: -0.000260417 97: 8.68056e-05 98: 2.00641e-20 99: 4.34028e-05 100: -6.2004e-06 181: 4.34028e-05 182: -6.2004e-06 561: -2.48016e-05 Row 98: 2: 8.68056e-05 17: -8.68056e-05 18: -1.42302e-19 97: 2.00641e-20 98: 9.3006e-06 99: -6.2004e-06 100: 3.1002e-06 181: 6.2004e-06 182: -3.1002e-06 561: -1.13291e-20 Row 99: 2: -0.000520833 17: -0.000260417 18: -0.000520833 97: 4.34028e-05 98: -6.2004e-06 99: 8.68056e-05 100: 4.23516e-22 181: 4.34028e-05 182: 6.2004e-06 561: -2.48016e-05 Row 100: 2: 8.68056e-05 17: -3.38813e-21 18: -8.68056e-05 97: -6.2004e-06 98: 3.1002e-06 99: 4.23516e-22 100: 9.3006e-06 181: 6.2004e-06 182: 3.1002e-06 561: -1.50092e-21 Row 101: 3: -0.000520833 24: -0.000520833 25: -0.000260417 101: 8.68056e-05 102: 2.00641e-20 103: 4.34028e-05 104: -6.2004e-06 221: 4.34028e-05 222: -6.2004e-06 565: -2.48016e-05 Row 102: 3: 8.68056e-05 24: -8.68056e-05 25: -1.42302e-19 101: 2.00641e-20 102: 9.3006e-06 103: -6.2004e-06 104: 3.1002e-06 221: 6.2004e-06 222: -3.1002e-06 565: -1.13291e-20 Row 103: 3: -0.000520833 24: -0.000260417 25: -0.000520833 101: 4.34028e-05 102: -6.2004e-06 103: 8.68056e-05 104: 4.23516e-22 221: 4.34028e-05 222: 6.2004e-06 565: -2.48016e-05 Row 104: 3: 8.68056e-05 24: -3.38813e-21 25: -8.68056e-05 101: -6.2004e-06 102: 3.1002e-06 103: 4.23516e-22 104: 9.3006e-06 221: 6.2004e-06 222: 3.1002e-06 565: -1.50092e-21 Row 105: 4: -0.000459656 5: -0.000459656 32: -0.000229828 105: 7.66094e-05 106: 0 109: 3.83047e-05 110: -5.4721e-06 113: 3.83047e-05 114: -5.4721e-06 554: -2.18884e-05 Row 106: 4: 7.66094e-05 5: -7.66094e-05 32: -5.0822e-21 105: 0 106: 8.20815e-06 109: -5.4721e-06 110: 2.73605e-06 113: 5.4721e-06 114: -2.73605e-06 554: -1.01322e-21 Row 107: 0: -0.000260417 4: -0.00117772 31: -0.00117772 32: -0.000328444 89: 4.34028e-05 90: 6.2004e-06 91: 4.34028e-05 92: 6.2004e-06 107: 0.000196287 108: 4.7328e-20 109: 5.47406e-05 110: -7.82009e-06 261: 5.47406e-05 262: -7.82009e-06 553: -2.48016e-05 569: -3.12803e-05 Row 108: 0: -1.28749e-19 4: 0.000196287 31: -0.000196287 32: -1.81265e-19 89: -6.2004e-06 90: -3.1002e-06 91: 6.2004e-06 92: 3.1002e-06 107: 4.7328e-20 108: 2.10307e-05 109: -7.82009e-06 110: 3.91004e-06 261: 7.82009e-06 262: -3.91004e-06 553: -1.01644e-20 569: -1.46113e-20 Row 109: 4: -0.00111654 5: -0.000229828 31: -0.000328444 32: -0.00111654 105: 3.83047e-05 106: -5.4721e-06 107: 5.47406e-05 108: -7.82009e-06 109: 0.000186091 110: 1.70465e-20 113: 3.83047e-05 114: 5.4721e-06 261: 5.47406e-05 262: 7.82009e-06 554: -2.18884e-05 569: -3.12803e-05 Row 110: 4: 0.000186091 5: -1.24514e-19 31: -1.01644e-20 32: -0.000186091 105: -5.4721e-06 106: 2.73605e-06 107: -7.82009e-06 108: 3.91004e-06 109: 1.70465e-20 110: 1.99383e-05 113: 5.4721e-06 114: 2.73605e-06 261: 7.82009e-06 262: 3.91004e-06 554: -9.95264e-21 569: -1.60029e-21 Row 111: 5: -0.000471641 6: -0.000471641 44: -0.000235821 111: 7.86068e-05 112: 4.23516e-22 115: 3.93034e-05 116: -5.61477e-06 121: 3.93034e-05 122: -5.61477e-06 573: -2.24591e-05 Row 112: 5: 7.86068e-05 6: -7.86068e-05 44: -8.47033e-21 111: 4.23516e-22 112: 8.42216e-06 115: -5.61477e-06 116: 2.80739e-06 121: 5.61477e-06 122: -2.80739e-06 573: -1.05159e-21 Row 113: 4: -0.000229828 5: -0.000950513 32: -0.000950513 44: -0.000245428 105: 3.83047e-05 106: 5.4721e-06 109: 3.83047e-05 110: 5.4721e-06 113: 0.000158419 114: 3.71106e-20 115: 4.09047e-05 116: -5.84353e-06 265: 4.09047e-05 266: -5.84353e-06 554: -2.18884e-05 584: -2.33741e-05 Row 114: 4: -1.15196e-19 5: 0.000158419 32: -0.000158419 44: -1.35525e-19 105: -5.4721e-06 106: -2.73605e-06 109: 5.4721e-06 110: 2.73605e-06 113: 3.71106e-20 114: 1.69734e-05 115: -5.84353e-06 116: 2.92177e-06 265: 5.84353e-06 266: -2.92177e-06 554: -8.89385e-21 584: -1.0482e-20 Row 115: 5: -0.000962498 6: -0.000235821 32: -0.000245428 44: -0.000962498 111: 3.93034e-05 112: -5.61477e-06 113: 4.09047e-05 114: -5.84353e-06 115: 0.000160416 116: 1.86877e-20 121: 3.93034e-05 122: 5.61477e-06 265: 4.09047e-05 266: 5.84353e-06 573: -2.24591e-05 584: -2.33741e-05 Row 116: 5: 0.000160416 6: -1.27902e-19 32: -5.0822e-21 44: -0.000160416 111: -5.61477e-06 112: 2.80739e-06 113: -5.84353e-06 114: 2.92177e-06 115: 1.86877e-20 116: 1.71875e-05 121: 5.61477e-06 122: 2.80739e-06 265: 5.84353e-06 266: 2.92177e-06 573: -9.95264e-21 584: -1.31778e-21 Row 117: 6: -0.000451771 7: -0.000451771 33: -0.000225885 117: 7.52951e-05 118: -4.23516e-22 119: 3.76476e-05 120: -5.37822e-06 125: 3.76476e-05 126: -5.37822e-06 555: -2.15129e-05 Row 118: 6: 7.52951e-05 7: -7.52951e-05 33: -8.47033e-21 117: -4.23516e-22 118: 8.06733e-06 119: -5.37822e-06 120: 2.68911e-06 125: 5.37822e-06 126: -2.68911e-06 555: -8.80202e-22 Row 119: 6: -0.000928575 7: -0.000225885 33: -0.000928575 44: -0.000238402 117: 3.76476e-05 118: -5.37822e-06 119: 0.000154763 120: 1.64113e-20 121: 3.97337e-05 122: -5.67624e-06 125: 3.76476e-05 126: 5.37822e-06 271: 3.97337e-05 272: -5.67624e-06 555: -2.15129e-05 582: -2.2705e-05 Row 120: 6: 0.000154763 7: -1.2282e-19 33: -0.000154763 44: -1.01644e-20 117: -5.37822e-06 118: 2.68911e-06 119: 1.64113e-20 120: 1.65817e-05 121: -5.67624e-06 122: 2.83812e-06 125: 5.37822e-06 126: 2.68911e-06 271: 5.67624e-06 272: -2.83812e-06 555: -9.84676e-21 582: -1.05341e-21 Row 121: 5: -0.000235821 6: -0.000948446 33: -0.000238402 44: -0.000948446 111: 3.93034e-05 112: 5.61477e-06 115: 3.93034e-05 116: 5.61477e-06 119: 3.97337e-05 120: -5.67624e-06 121: 0.000158074 122: 3.4993e-20 271: 3.97337e-05 272: 5.67624e-06 573: -2.24591e-05 582: -2.2705e-05 Row 122: 5: -1.18585e-19 6: 0.000158074 33: -1.30443e-19 44: -0.000158074 111: -5.61477e-06 112: -2.80739e-06 115: 5.61477e-06 116: 2.80739e-06 119: -5.67624e-06 120: 2.83812e-06 121: 3.4993e-20 122: 1.69365e-05 271: 5.67624e-06 272: 2.83812e-06 573: -9.21148e-21 582: -1.01644e-20 Row 123: 7: -0.000457033 8: -0.000457033 45: -0.000228517 123: 7.61722e-05 124: 0 127: 3.80861e-05 128: -5.44087e-06 133: 3.80861e-05 134: -5.44087e-06 574: -2.17635e-05 Row 124: 7: 7.61722e-05 8: -7.61722e-05 45: -3.38813e-21 123: 0 124: 8.16131e-06 127: -5.44087e-06 128: 2.72044e-06 133: 5.44087e-06 134: -2.72044e-06 574: -1.0179e-21 Row 125: 6: -0.000225885 7: -0.000911126 33: -0.000911126 45: -0.000229678 117: 3.76476e-05 118: 5.37822e-06 119: 3.76476e-05 120: 5.37822e-06 125: 0.000151854 126: 3.62107e-20 127: 3.82796e-05 128: -5.46852e-06 273: 3.82796e-05 274: -5.46852e-06 555: -2.15129e-05 589: -2.18741e-05 Row 126: 6: -1.15196e-19 7: 0.000151854 33: -0.000151854 45: -1.24514e-19 117: -5.37822e-06 118: -2.68911e-06 119: 5.37822e-06 120: 2.68911e-06 125: 3.62107e-20 126: 1.62701e-05 127: -5.46852e-06 128: 2.73426e-06 273: 5.46852e-06 274: -2.73426e-06 555: -8.89385e-21 589: -9.95264e-21 Row 127: 7: -0.000916389 8: -0.000228517 33: -0.000229678 45: -0.000916389 123: 3.80861e-05 124: -5.44087e-06 125: 3.82796e-05 126: -5.46852e-06 127: 0.000152731 128: 1.70995e-20 133: 3.80861e-05 134: 5.44087e-06 273: 3.82796e-05 274: 5.46852e-06 574: -2.17635e-05 589: -2.18741e-05 Row 128: 7: 0.000152731 8: -1.23667e-19 33: -8.47033e-21 45: -0.000152731 123: -5.44087e-06 124: 2.72044e-06 125: -5.46852e-06 126: 2.73426e-06 127: 1.70995e-20 128: 1.63641e-05 133: 5.44087e-06 134: 2.72044e-06 273: 5.46852e-06 274: 2.73426e-06 574: -9.95264e-21 589: -1.2278e-21 Row 129: 8: -0.000474754 9: -0.000474754 34: -0.000237377 129: 7.91257e-05 130: -4.23516e-22 131: 3.95628e-05 132: -5.65183e-06 137: 3.95628e-05 138: -5.65183e-06 556: -2.26073e-05 Row 130: 8: 7.91257e-05 9: -7.91257e-05 34: -5.0822e-21 129: -4.23516e-22 130: 8.47775e-06 131: -5.65183e-06 132: 2.82592e-06 137: 5.65183e-06 138: -2.82592e-06 556: -1.21399e-21 Row 131: 8: -0.000931996 9: -0.000237377 34: -0.000931996 45: -0.000228621 129: 3.95628e-05 130: -5.65183e-06 131: 0.000155333 132: 1.81053e-20 133: 3.81035e-05 134: -5.44336e-06 137: 3.95628e-05 138: 5.65183e-06 279: 3.81035e-05 280: -5.44336e-06 556: -2.26073e-05 578: -2.17735e-05 Row 132: 8: 0.000155333 9: -1.29596e-19 34: -0.000155333 45: -3.38813e-21 129: -5.65183e-06 130: 2.82592e-06 131: 1.81053e-20 132: 1.66428e-05 133: -5.44336e-06 134: 2.72168e-06 137: 5.65183e-06 138: 2.82592e-06 279: 5.44336e-06 280: -2.72168e-06 556: -1.01644e-20 578: -9.57355e-22 Row 133: 7: -0.000228517 8: -0.000914276 34: -0.000228621 45: -0.000914276 123: 3.80861e-05 124: 5.44087e-06 127: 3.80861e-05 128: 5.44087e-06 131: 3.81035e-05 132: -5.44336e-06 133: 0.000152379 134: 3.62107e-20 279: 3.81035e-05 280: 5.44336e-06 574: -2.17635e-05 578: -2.17735e-05 Row 134: 7: -1.15196e-19 8: 0.000152379 34: -1.2282e-19 45: -0.000152379 123: -5.44087e-06 124: -2.72044e-06 127: 5.44087e-06 128: 2.72044e-06 131: -5.44336e-06 132: 2.72168e-06 133: 3.62107e-20 134: 1.63264e-05 279: 5.44336e-06 280: 2.72168e-06 574: -8.68209e-21 578: -9.95264e-21 Row 135: 9: -0.000446635 10: -0.000446635 46: -0.000223318 135: 7.44392e-05 136: -4.23516e-22 139: 3.72196e-05 140: -5.31709e-06 145: 3.72196e-05 146: -5.31709e-06 575: -2.12683e-05 Row 136: 9: 7.44392e-05 10: -7.44392e-05 46: -6.77626e-21 135: -4.23516e-22 136: 7.97563e-06 139: -5.31709e-06 140: 2.65854e-06 145: 5.31709e-06 146: -2.65854e-06 575: -9.74759e-22 Row 137: 8: -0.000237377 9: -0.000883358 34: -0.000883358 46: -0.000204302 129: 3.95628e-05 130: 5.65183e-06 131: 3.95628e-05 132: 5.65183e-06 137: 0.000147226 138: 3.45695e-20 139: 3.40504e-05 140: -4.86434e-06 281: 3.40504e-05 282: -4.86434e-06 556: -2.26073e-05 590: -1.94574e-05 Row 138: 8: -1.25361e-19 9: 0.000147226 34: -0.000147226 46: -1.10961e-19 129: -5.65183e-06 130: -2.82592e-06 131: 5.65183e-06 132: 2.82592e-06 137: 3.45695e-20 138: 1.57743e-05 139: -4.86434e-06 140: 2.43217e-06 281: 4.86434e-06 282: -2.43217e-06 556: -9.42324e-21 590: -8.78797e-21 Row 139: 9: -0.00085524 10: -0.000223318 34: -0.000204302 46: -0.00085524 135: 3.72196e-05 136: -5.31709e-06 137: 3.40504e-05 138: -4.86434e-06 139: 0.00014254 140: 1.78406e-20 145: 3.72196e-05 146: 5.31709e-06 281: 3.40504e-05 282: 4.86434e-06 575: -2.12683e-05 590: -1.94574e-05 Row 140: 9: 0.00014254 10: -1.2282e-19 34: -3.38813e-21 46: -0.00014254 135: -5.31709e-06 136: 2.65854e-06 137: -4.86434e-06 138: 2.43217e-06 139: 1.78406e-20 140: 1.52721e-05 145: 5.31709e-06 146: 2.65854e-06 281: 4.86434e-06 282: 2.43217e-06 575: -9.52912e-21 590: -9.5929e-22 Row 141: 1: -0.000260417 10: -0.00118685 11: -0.00118685 35: -0.000333008 93: 4.34028e-05 94: 6.2004e-06 95: 4.34028e-05 96: 6.2004e-06 141: 0.000197808 142: -2.28699e-20 143: 5.55014e-05 144: -7.92876e-06 149: 5.55014e-05 150: -7.92876e-06 557: -2.48016e-05 570: -3.17151e-05 Row 142: 1: 1.28749e-19 10: 0.000197808 11: -0.000197808 35: -1.01644e-20 93: -6.2004e-06 94: -3.1002e-06 95: 6.2004e-06 96: 3.1002e-06 141: -2.28699e-20 142: 2.11937e-05 143: -7.92876e-06 144: 3.96438e-06 149: 7.92876e-06 150: -3.96438e-06 557: 1.03762e-20 570: -1.59924e-21 Row 143: 10: -0.00119083 11: -0.000333008 35: -0.00119083 46: -0.000262408 141: 5.55014e-05 142: -7.92876e-06 143: 0.000198472 144: 2.48816e-20 145: 4.37346e-05 146: -6.2478e-06 149: 5.55014e-05 150: 7.92876e-06 287: 4.37346e-05 288: -6.2478e-06 570: -3.17151e-05 609: -2.49912e-05 Row 144: 10: 0.000198472 11: -1.82959e-19 35: -0.000198472 46: -8.47033e-21 141: -7.92876e-06 142: 3.96438e-06 143: 2.48816e-20 144: 2.12649e-05 145: -6.2478e-06 146: 3.1239e-06 149: 7.92876e-06 150: 3.96438e-06 287: 6.2478e-06 288: -3.1239e-06 570: -1.41878e-20 609: -1.2154e-21 Row 145: 9: -0.000223318 10: -0.000971451 35: -0.000262408 46: -0.000971451 135: 3.72196e-05 136: 5.31709e-06 139: 3.72196e-05 140: 5.31709e-06 143: 4.37346e-05 144: -6.2478e-06 145: 0.000161908 146: 3.74283e-20 287: 4.37346e-05 288: 6.2478e-06 575: -2.12683e-05 609: -2.49912e-05 Row 146: 9: -1.11808e-19 10: 0.000161908 35: -1.42302e-19 46: -0.000161908 135: -5.31709e-06 136: -2.65854e-06 139: 5.31709e-06 140: 2.65854e-06 143: -6.2478e-06 144: 3.1239e-06 145: 3.74283e-20 146: 1.73473e-05 287: 6.2478e-06 288: 3.1239e-06 575: -8.99973e-21 609: -1.11173e-20 Row 147: 11: -0.000460405 12: -0.000460405 35: -0.000230202 147: 7.67341e-05 148: -8.47033e-22 149: 3.83671e-05 150: -5.48101e-06 153: 3.83671e-05 154: -5.48101e-06 558: -2.1924e-05 Row 148: 11: 7.67341e-05 12: -7.67341e-05 35: -5.0822e-21 147: -8.47033e-22 148: 8.22151e-06 149: -5.48101e-06 150: 2.7405e-06 153: 5.48101e-06 154: -2.7405e-06 558: -9.46847e-22 Row 149: 10: -0.000333008 11: -0.00112642 12: -0.000230202 35: -0.00112642 141: 5.55014e-05 142: 7.92876e-06 143: 5.55014e-05 144: 7.92876e-06 147: 3.83671e-05 148: -5.48101e-06 149: 0.000187737 150: 4.19281e-20 153: 3.83671e-05 154: 5.48101e-06 558: -2.1924e-05 570: -3.17151e-05 Row 150: 10: -1.69407e-19 11: 0.000187737 12: -1.23667e-19 35: -0.000187737 141: -7.92876e-06 142: -3.96438e-06 143: 7.92876e-06 144: 3.96438e-06 147: -5.48101e-06 148: 2.7405e-06 149: 4.19281e-20 150: 2.01147e-05 153: 5.48101e-06 154: 2.7405e-06 558: -9.95264e-21 570: -1.33408e-20 Row 151: 12: -0.000474192 13: -0.000474192 47: -0.000237096 151: 7.9032e-05 152: 0 155: 3.9516e-05 156: -5.64515e-06 161: 3.9516e-05 162: -5.64515e-06 576: -2.25806e-05 Row 152: 12: 7.9032e-05 13: -7.9032e-05 47: -5.0822e-21 151: 0 152: 8.46772e-06 155: -5.64515e-06 156: 2.82257e-06 161: 5.64515e-06 162: -2.82257e-06 576: -1.10787e-21 Row 153: 11: -0.000230202 12: -0.000959226 35: -0.000959226 47: -0.000249411 147: 3.83671e-05 148: 5.48101e-06 149: 3.83671e-05 150: 5.48101e-06 153: 0.000159871 154: 3.48342e-20 155: 4.15684e-05 156: -5.93835e-06 289: 4.15684e-05 290: -5.93835e-06 558: -2.1924e-05 602: -2.37534e-05 Row 154: 11: -1.18585e-19 12: 0.000159871 35: -0.000159871 47: -1.35525e-19 147: -5.48101e-06 148: -2.7405e-06 149: 5.48101e-06 150: 2.7405e-06 153: 3.48342e-20 154: 1.7129e-05 155: -5.93835e-06 156: 2.96917e-06 289: 5.93835e-06 290: -2.96917e-06 558: -8.99973e-21 602: -1.07997e-20 Row 155: 12: -0.000973014 13: -0.000237096 35: -0.000249411 47: -0.000973014 151: 3.9516e-05 152: -5.64515e-06 153: 4.15684e-05 154: -5.93835e-06 155: 0.000162169 156: 1.73642e-20 161: 3.9516e-05 162: 5.64515e-06 289: 4.15684e-05 290: 5.93835e-06 576: -2.25806e-05 602: -2.37534e-05 Row 156: 12: 0.000162169 13: -1.29596e-19 35: -6.77626e-21 47: -0.000162169 151: -5.64515e-06 152: 2.82257e-06 153: -5.93835e-06 154: 2.96917e-06 155: 1.73642e-20 156: 1.73752e-05 161: 5.64515e-06 162: 2.82257e-06 289: 5.93835e-06 290: 2.96917e-06 576: -1.0482e-20 602: -1.29252e-21 Row 157: 13: -0.000438961 14: -0.000438961 36: -0.00021948 157: 7.31601e-05 158: -4.23516e-22 159: 3.65801e-05 160: -5.22572e-06 165: 3.65801e-05 166: -5.22572e-06 559: -2.09029e-05 Row 158: 13: 7.31601e-05 14: -7.31601e-05 36: -6.77626e-21 157: -4.23516e-22 158: 7.83859e-06 159: -5.22572e-06 160: 2.61286e-06 165: 5.22572e-06 166: -2.61286e-06 559: -8.06128e-22 Row 159: 13: -0.000910182 14: -0.00021948 36: -0.000910182 47: -0.00023561 157: 3.65801e-05 158: -5.22572e-06 159: 0.000151697 160: 1.72583e-20 161: 3.92684e-05 162: -5.60977e-06 165: 3.65801e-05 166: 5.22572e-06 293: 3.92684e-05 294: -5.60977e-06 559: -2.09029e-05 588: -2.24391e-05 Row 160: 13: 0.000151697 14: -1.19432e-19 36: -0.000151697 47: -5.0822e-21 157: -5.22572e-06 158: 2.61286e-06 159: 1.72583e-20 160: 1.62532e-05 161: -5.60977e-06 162: 2.80489e-06 165: 5.22572e-06 166: 2.61286e-06 293: 5.60977e-06 294: -2.80489e-06 559: -9.31736e-21 588: -1.14258e-21 Row 161: 12: -0.000237096 13: -0.000945413 36: -0.00023561 47: -0.000945413 151: 3.9516e-05 152: 5.64515e-06 155: 3.9516e-05 156: 5.64515e-06 159: 3.92684e-05 160: -5.60977e-06 161: 0.000157569 162: 3.43048e-20 293: 3.92684e-05 294: 5.60977e-06 576: -2.25806e-05 588: -2.24391e-05 Row 162: 12: -1.18585e-19 13: 0.000157569 36: -1.28749e-19 47: -0.000157569 151: -5.64515e-06 152: -2.82257e-06 155: 5.64515e-06 156: 2.82257e-06 159: -5.60977e-06 160: 2.80489e-06 161: 3.43048e-20 162: 1.68824e-05 293: 5.60977e-06 294: 2.80489e-06 576: -9.42324e-21 588: -1.03762e-20 Row 163: 14: -0.000424997 15: -0.000424997 48: -0.000212498 163: 7.08328e-05 164: 0 167: 3.54164e-05 168: -5.05948e-06 173: 3.54164e-05 174: -5.05948e-06 577: -2.02379e-05 Row 164: 14: 7.08328e-05 15: -7.08328e-05 48: -3.38813e-21 163: 0 164: 7.58922e-06 167: -5.05948e-06 168: 2.52974e-06 173: 5.05948e-06 174: -2.52974e-06 577: -9.29052e-22 Row 165: 13: -0.00021948 14: -0.00087592 36: -0.00087592 48: -0.000218479 157: 3.65801e-05 158: 5.22572e-06 159: 3.65801e-05 160: 5.22572e-06 165: 0.000145987 166: 3.38284e-20 167: 3.64132e-05 168: -5.20189e-06 295: 3.64132e-05 296: -5.20189e-06 559: -2.09029e-05 591: -2.08076e-05 Row 166: 13: -1.11808e-19 14: 0.000145987 36: -0.000145987 48: -1.20279e-19 157: -5.22572e-06 158: -2.61286e-06 159: 5.22572e-06 160: 2.61286e-06 165: 3.38284e-20 166: 1.56414e-05 167: -5.20189e-06 168: 2.60095e-06 295: 5.20189e-06 296: -2.60095e-06 559: -8.47033e-21 591: -9.42324e-21 Row 167: 14: -0.000861955 15: -0.000212498 36: -0.000218479 48: -0.000861955 163: 3.54164e-05 164: -5.05948e-06 165: 3.64132e-05 166: -5.20189e-06 167: 0.000143659 168: 1.5776e-20 173: 3.54164e-05 174: 5.05948e-06 295: 3.64132e-05 296: 5.20189e-06 577: -2.02379e-05 591: -2.08076e-05 Row 168: 14: 0.000143659 15: -1.16891e-19 36: -5.0822e-21 48: -0.000143659 163: -5.05948e-06 164: 2.52974e-06 165: -5.20189e-06 166: 2.60095e-06 167: 1.5776e-20 168: 1.53921e-05 173: 5.05948e-06 174: 2.52974e-06 295: 5.20189e-06 296: 2.60095e-06 577: -8.99973e-21 591: -1.19931e-21 Row 169: 15: -0.000440949 16: -0.000440949 37: -0.000220475 169: 7.34916e-05 170: -4.23516e-22 171: 3.67458e-05 172: -5.2494e-06 177: 3.67458e-05 178: -5.2494e-06 560: -2.09976e-05 Row 170: 15: 7.34916e-05 16: -7.34916e-05 37: -6.77626e-21 169: -4.23516e-22 170: 7.87409e-06 171: -5.2494e-06 172: 2.6247e-06 177: 5.2494e-06 178: -2.6247e-06 560: -1.01694e-21 Row 171: 15: -0.000865943 16: -0.000220475 37: -0.000865943 48: -0.000212497 169: 3.67458e-05 170: -5.2494e-06 171: 0.000144324 172: 1.69936e-20 173: 3.54161e-05 174: -5.05945e-06 177: 3.67458e-05 178: 5.2494e-06 301: 3.54161e-05 302: -5.05945e-06 560: -2.09976e-05 597: -2.02378e-05 Row 172: 15: 0.000144324 16: -1.19432e-19 37: -0.000144324 48: -5.0822e-21 169: -5.2494e-06 170: 2.6247e-06 171: 1.69936e-20 172: 1.54633e-05 173: -5.05945e-06 174: 2.52972e-06 177: 5.2494e-06 178: 2.6247e-06 301: 5.05945e-06 302: -2.52972e-06 560: -9.21148e-21 597: -9.05794e-22 Row 173: 14: -0.000212498 15: -0.00084999 37: -0.000212497 48: -0.00084999 163: 3.54164e-05 164: 5.05948e-06 167: 3.54164e-05 168: 5.05948e-06 171: 3.54161e-05 172: -5.05945e-06 173: 0.000141665 174: 3.35107e-20 301: 3.54161e-05 302: 5.05945e-06 577: -2.02379e-05 597: -2.02378e-05 Row 174: 14: -1.0842e-19 15: 0.000141665 37: -1.16891e-19 48: -0.000141665 163: -5.05948e-06 164: -2.52974e-06 167: 5.05948e-06 168: 2.52974e-06 171: -5.05945e-06 172: 2.52972e-06 173: 3.35107e-20 174: 1.51784e-05 301: 5.05945e-06 302: 2.52972e-06 577: -8.04681e-21 597: -8.99973e-21 Row 175: 16: -0.00042868 17: -0.00042868 49: -0.00021434 175: 7.14466e-05 176: 4.23516e-22 179: 3.57233e-05 180: -5.10333e-06 185: 3.57233e-05 186: -5.10333e-06 579: -2.04133e-05 Row 176: 16: 7.14466e-05 17: -7.14466e-05 49: -5.0822e-21 175: 4.23516e-22 176: 7.65499e-06 179: -5.10333e-06 180: 2.55166e-06 185: 5.10333e-06 186: -2.55166e-06 579: -9.35689e-22 Row 177: 15: -0.000220475 16: -0.000821408 37: -0.000821408 49: -0.000190229 169: 3.67458e-05 170: 5.2494e-06 171: 3.67458e-05 172: 5.2494e-06 177: 0.000136901 178: 3.28755e-20 179: 3.17049e-05 180: -4.52927e-06 303: 3.17049e-05 304: -4.52927e-06 560: -2.09976e-05 592: -1.81171e-05 Row 178: 15: -1.15196e-19 16: 0.000136901 37: -0.000136901 49: -1.03338e-19 169: -5.2494e-06 170: -2.6247e-06 171: 5.2494e-06 172: 2.6247e-06 177: 3.28755e-20 178: 1.4668e-05 179: -4.52927e-06 180: 2.26463e-06 303: 4.52927e-06 304: -2.26463e-06 560: -8.78797e-21 592: -8.47033e-21 Row 179: 16: -0.000809138 17: -0.00021434 37: -0.000190229 49: -0.000809138 175: 3.57233e-05 176: -5.10333e-06 177: 3.17049e-05 178: -4.52927e-06 179: 0.000134856 180: 1.59348e-20 185: 3.57233e-05 186: 5.10333e-06 303: 3.17049e-05 304: 4.52927e-06 579: -2.04133e-05 592: -1.81171e-05 Row 180: 16: 0.000134856 17: -1.17738e-19 37: -5.0822e-21 49: -0.000134856 175: -5.10333e-06 176: 2.55166e-06 177: -4.52927e-06 178: 2.26463e-06 179: 1.59348e-20 180: 1.44489e-05 185: 5.10333e-06 186: 2.55166e-06 303: 4.52927e-06 304: 2.26463e-06 579: -9.31736e-21 592: -9.42087e-22 Row 181: 2: -0.000260417 17: -0.00117135 18: -0.00117135 38: -0.00032526 97: 4.34028e-05 98: 6.2004e-06 99: 4.34028e-05 100: 6.2004e-06 181: 0.000195225 182: -2.20229e-20 183: 5.42099e-05 184: -7.74428e-06 189: 5.42099e-05 190: -7.74428e-06 561: -2.48016e-05 571: -3.09771e-05 Row 182: 2: 1.28749e-19 17: 0.000195225 18: -0.000195225 38: -6.77626e-21 97: -6.2004e-06 98: -3.1002e-06 99: 6.2004e-06 100: 3.1002e-06 181: -2.20229e-20 182: 2.0917e-05 183: -7.74428e-06 184: 3.87214e-06 189: 7.74428e-06 190: -3.87214e-06 561: 1.03762e-20 571: -1.24845e-21 Row 183: 17: -0.00115669 18: -0.00032526 38: -0.00115669 49: -0.000253086 181: 5.42099e-05 182: -7.74428e-06 183: 0.000192782 184: 2.47757e-20 185: 4.21811e-05 186: -6.02587e-06 189: 5.42099e-05 190: 7.74428e-06 309: 4.21811e-05 310: -6.02587e-06 571: -3.09771e-05 611: -2.41035e-05 Row 184: 17: 0.000192782 18: -1.77877e-19 38: -0.000192782 49: -5.0822e-21 181: -7.74428e-06 182: 3.87214e-06 183: 2.47757e-20 184: 2.06552e-05 185: -6.02587e-06 186: 3.01293e-06 189: 7.74428e-06 190: 3.87214e-06 309: 6.02587e-06 310: -3.01293e-06 571: -1.41878e-20 611: -1.07568e-21 Row 185: 16: -0.00021434 17: -0.000934852 38: -0.000253086 49: -0.000934852 175: 3.57233e-05 176: 5.10333e-06 179: 3.57233e-05 180: 5.10333e-06 183: 4.21811e-05 184: -6.02587e-06 185: 0.000155809 186: 3.4993e-20 309: 4.21811e-05 310: 6.02587e-06 579: -2.04133e-05 611: -2.41035e-05 Row 186: 16: -1.11808e-19 17: 0.000155809 38: -1.37219e-19 49: -0.000155809 175: -5.10333e-06 176: -2.55166e-06 179: 5.10333e-06 180: 2.55166e-06 183: -6.02587e-06 184: 3.01293e-06 185: 3.4993e-20 186: 1.66938e-05 309: 6.02587e-06 310: 3.01293e-06 579: -8.47033e-21 611: -1.09055e-20 Row 187: 18: -0.000457476 19: -0.000457476 38: -0.000228738 187: 7.62459e-05 188: 4.23516e-22 189: 3.8123e-05 190: -5.44614e-06 193: 3.8123e-05 194: -5.44614e-06 562: -2.17846e-05 Row 188: 18: 7.62459e-05 19: -7.62459e-05 38: -6.77626e-21 187: 4.23516e-22 188: 8.16921e-06 189: -5.44614e-06 190: 2.72307e-06 193: 5.44614e-06 194: -2.72307e-06 562: -1.20088e-21 Row 189: 17: -0.00032526 18: -0.00110799 19: -0.000228738 38: -0.00110799 181: 5.42099e-05 182: 7.74428e-06 183: 5.42099e-05 184: 7.74428e-06 187: 3.8123e-05 188: -5.44614e-06 189: 0.000184666 190: 4.25634e-20 193: 3.8123e-05 194: 5.44614e-06 562: -2.17846e-05 571: -3.09771e-05 Row 190: 17: -1.6263e-19 18: 0.000184666 19: -1.25361e-19 38: -0.000184666 181: -7.74428e-06 182: -3.87214e-06 183: 7.74428e-06 184: 3.87214e-06 187: -5.44614e-06 188: 2.72307e-06 189: 4.25634e-20 190: 1.97856e-05 193: 5.44614e-06 194: 2.72307e-06 562: -9.74088e-21 571: -1.27055e-20 Row 191: 19: -0.000477982 20: -0.000477982 50: -0.000238991 191: 7.96636e-05 192: 0 195: 3.98318e-05 196: -5.69026e-06 201: 3.98318e-05 202: -5.69026e-06 580: -2.2761e-05 Row 192: 19: 7.96636e-05 20: -7.96636e-05 50: -8.47033e-21 191: 0 192: 8.53538e-06 195: -5.69026e-06 196: 2.84513e-06 201: 5.69026e-06 202: -2.84513e-06 580: -9.75323e-22 Row 193: 18: -0.000228738 19: -0.000955432 38: -0.000955432 50: -0.000248978 187: 3.8123e-05 188: 5.44614e-06 189: 3.8123e-05 190: 5.44614e-06 193: 0.000159239 194: 3.5893e-20 195: 4.14964e-05 196: -5.92806e-06 311: 4.14964e-05 312: -5.92806e-06 562: -2.17846e-05 603: -2.37122e-05 Row 194: 18: -1.18585e-19 19: 0.000159239 38: -0.000159239 50: -1.35525e-19 187: -5.44614e-06 188: -2.72307e-06 189: 5.44614e-06 190: 2.72307e-06 193: 3.5893e-20 194: 1.70613e-05 195: -5.92806e-06 196: 2.96403e-06 311: 5.92806e-06 312: -2.96403e-06 562: -8.99973e-21 603: -1.06938e-20 Row 195: 19: -0.000975938 20: -0.000238991 38: -0.000248978 50: -0.000975938 191: 3.98318e-05 192: -5.69026e-06 193: 4.14964e-05 194: -5.92806e-06 195: 0.000162656 196: 1.8423e-20 201: 3.98318e-05 202: 5.69026e-06 311: 4.14964e-05 312: 5.92806e-06 580: -2.2761e-05 603: -2.37122e-05 Row 196: 19: 0.000162656 20: -1.29596e-19 38: -8.47033e-21 50: -0.000162656 191: -5.69026e-06 192: 2.84513e-06 193: -5.92806e-06 194: 2.96403e-06 195: 1.8423e-20 196: 1.74275e-05 201: 5.69026e-06 202: 2.84513e-06 311: 5.92806e-06 312: 2.96403e-06 580: -1.02703e-20 603: -1.32496e-21 Row 197: 20: -0.000465749 21: -0.000465749 39: -0.000232874 197: 7.76248e-05 198: 0 199: 3.88124e-05 200: -5.54463e-06 205: 3.88124e-05 206: -5.54463e-06 563: -2.21785e-05 Row 198: 20: 7.76248e-05 21: -7.76248e-05 39: -3.38813e-21 197: 0 198: 8.31694e-06 199: -5.54463e-06 200: 2.77231e-06 205: 5.54463e-06 206: -2.77231e-06 563: -1.22986e-21 Row 199: 20: -0.000956536 21: -0.000232874 39: -0.000956536 50: -0.000245394 197: 3.88124e-05 198: -5.54463e-06 199: 0.000159423 200: 1.65171e-20 201: 4.0899e-05 202: -5.84271e-06 205: 3.88124e-05 206: 5.54463e-06 315: 4.0899e-05 316: -5.84271e-06 563: -2.21785e-05 598: -2.33708e-05 Row 200: 20: 0.000159423 21: -1.26208e-19 39: -0.000159423 50: -6.77626e-21 197: -5.54463e-06 198: 2.77231e-06 199: 1.65171e-20 200: 1.7081e-05 201: -5.84271e-06 202: 2.92136e-06 205: 5.54463e-06 206: 2.77231e-06 315: 5.84271e-06 316: -2.92136e-06 563: -9.95264e-21 598: -9.25353e-22 Row 201: 19: -0.000238991 20: -0.000968769 39: -0.000245394 50: -0.000968769 191: 3.98318e-05 192: 5.69026e-06 195: 3.98318e-05 196: 5.69026e-06 199: 4.0899e-05 200: -5.84271e-06 201: 0.000161462 202: 3.68459e-20 315: 4.0899e-05 316: 5.84271e-06 580: -2.2761e-05 598: -2.33708e-05 Row 202: 19: -1.18585e-19 20: 0.000161462 39: -1.32137e-19 50: -0.000161462 191: -5.69026e-06 192: -2.84513e-06 195: 5.69026e-06 196: 2.84513e-06 199: -5.84271e-06 200: 2.92136e-06 201: 3.68459e-20 202: 1.72994e-05 315: 5.84271e-06 316: 2.92136e-06 580: -9.31736e-21 598: -1.05879e-20 Row 203: 21: -0.000464748 22: -0.000464748 51: -0.000232374 203: 7.7458e-05 204: -4.23516e-22 207: 3.8729e-05 208: -5.53272e-06 213: 3.8729e-05 214: -5.53272e-06 581: -2.21309e-05 Row 204: 21: 7.7458e-05 22: -7.7458e-05 51: -5.0822e-21 203: -4.23516e-22 204: 8.29908e-06 207: -5.53272e-06 208: 2.76636e-06 213: 5.53272e-06 214: -2.76636e-06 581: -9.86042e-22 Row 205: 20: -0.000232874 21: -0.000937265 39: -0.000937265 51: -0.000235758 197: 3.88124e-05 198: 5.54463e-06 199: 3.88124e-05 200: 5.54463e-06 205: 0.000156211 206: 3.63695e-20 207: 3.9293e-05 208: -5.61328e-06 317: 3.9293e-05 318: -5.61328e-06 563: -2.21785e-05 593: -2.24531e-05 Row 206: 20: -1.21973e-19 21: 0.000156211 39: -0.000156211 51: -1.29596e-19 197: -5.54463e-06 198: -2.77231e-06 199: 5.54463e-06 200: 2.77231e-06 205: 3.63695e-20 206: 1.67369e-05 207: -5.61328e-06 208: 2.80664e-06 317: 5.61328e-06 318: -2.80664e-06 563: -9.1056e-21 593: -1.01644e-20 Row 207: 21: -0.000936264 22: -0.000232374 39: -0.000235758 51: -0.000936264 203: 3.8729e-05 204: -5.53272e-06 205: 3.9293e-05 206: -5.61328e-06 207: 0.000156044 208: 1.77348e-20 213: 3.8729e-05 214: 5.53272e-06 317: 3.9293e-05 318: 5.61328e-06 581: -2.21309e-05 593: -2.24531e-05 Row 208: 21: 0.000156044 22: -1.27055e-19 39: -8.47033e-21 51: -0.000156044 203: -5.53272e-06 204: 2.76636e-06 205: -5.61328e-06 206: 2.80664e-06 207: 1.77348e-20 208: 1.6719e-05 213: 5.53272e-06 214: 2.76636e-06 317: 5.61328e-06 318: 2.80664e-06 581: -1.01644e-20 593: -1.14921e-21 Row 209: 22: -0.000470467 23: -0.000470467 40: -0.000235233 209: 7.84111e-05 210: 4.23516e-22 211: 3.92056e-05 212: -5.60079e-06 217: 3.92056e-05 218: -5.60079e-06 564: -2.24032e-05 Row 210: 22: 7.84111e-05 23: -7.84111e-05 40: -6.77626e-21 209: 4.23516e-22 210: 8.40119e-06 211: -5.60079e-06 212: 2.8004e-06 217: 5.60079e-06 218: -2.8004e-06 564: -1.12026e-21 Row 211: 22: -0.000932321 23: -0.000235233 40: -0.000932321 51: -0.000230927 209: 3.92056e-05 210: -5.60079e-06 211: 0.000155387 212: 1.81053e-20 213: 3.84879e-05 214: -5.49827e-06 217: 3.92056e-05 218: 5.60079e-06 323: 3.84879e-05 324: -5.49827e-06 564: -2.24032e-05 599: -2.19931e-05 Row 212: 22: 0.000155387 23: -1.27902e-19 40: -0.000155387 51: -5.0822e-21 209: -5.60079e-06 210: 2.8004e-06 211: 1.81053e-20 212: 1.66486e-05 213: -5.49827e-06 214: 2.74914e-06 217: 5.60079e-06 218: 2.8004e-06 323: 5.49827e-06 324: -2.74914e-06 564: -9.84676e-21 599: -8.98413e-22 Row 213: 21: -0.000232374 22: -0.000926603 40: -0.000230927 51: -0.000926603 203: 3.8729e-05 204: 5.53272e-06 207: 3.8729e-05 208: 5.53272e-06 211: 3.84879e-05 212: -5.49827e-06 213: 0.000154434 214: 3.49401e-20 323: 3.84879e-05 324: 5.49827e-06 581: -2.21309e-05 599: -2.19931e-05 Row 214: 21: -1.18585e-19 22: 0.000154434 40: -1.27055e-19 51: -0.000154434 203: -5.53272e-06 204: -2.76636e-06 207: 5.53272e-06 208: 2.76636e-06 211: -5.49827e-06 212: 2.74914e-06 213: 3.49401e-20 214: 1.65465e-05 323: 5.49827e-06 324: 2.74914e-06 581: -9.42324e-21 599: -9.95264e-21 Row 215: 23: -0.000439017 24: -0.000439017 52: -0.000219508 215: 7.31695e-05 216: -4.23516e-22 219: 3.65847e-05 220: -5.22639e-06 225: 3.65847e-05 226: -5.22639e-06 583: -2.09056e-05 Row 216: 23: 7.31695e-05 24: -7.31695e-05 52: -3.38813e-21 215: -4.23516e-22 216: 7.83959e-06 219: -5.22639e-06 220: 2.6132e-06 225: 5.22639e-06 226: -2.6132e-06 583: -9.02727e-22 Row 217: 22: -0.000235233 23: -0.000872247 40: -0.000872247 52: -0.00020089 209: 3.92056e-05 210: 5.60079e-06 211: 3.92056e-05 212: 5.60079e-06 217: 0.000145374 218: 3.36696e-20 219: 3.34817e-05 220: -4.7831e-06 325: 3.34817e-05 326: -4.7831e-06 564: -2.24032e-05 594: -1.91324e-05 Row 218: 22: -1.21973e-19 23: 0.000145374 40: -0.000145374 52: -1.09267e-19 209: -5.60079e-06 210: -2.8004e-06 211: 5.60079e-06 212: 2.8004e-06 217: 3.36696e-20 218: 1.55758e-05 219: -4.7831e-06 220: 2.39155e-06 325: 4.7831e-06 326: -2.39155e-06 564: -9.31736e-21 594: -8.89385e-21 Row 219: 23: -0.000840797 24: -0.000219508 40: -0.00020089 52: -0.000840797 215: 3.65847e-05 216: -5.22639e-06 217: 3.34817e-05 218: -4.7831e-06 219: 0.000140133 220: 1.65171e-20 225: 3.65847e-05 226: 5.22639e-06 325: 3.34817e-05 326: 4.7831e-06 583: -2.09056e-05 594: -1.91324e-05 Row 220: 23: 0.000140133 24: -1.19432e-19 40: -3.38813e-21 52: -0.000140133 215: -5.22639e-06 216: 2.6132e-06 217: -4.7831e-06 218: 2.39155e-06 219: 1.65171e-20 220: 1.50142e-05 225: 5.22639e-06 226: 2.6132e-06 325: 4.7831e-06 326: 2.39155e-06 583: -9.31736e-21 594: -1.13497e-21 Row 221: 3: -0.000260417 24: -0.00117183 25: -0.00117183 41: -0.000325499 101: 4.34028e-05 102: 6.2004e-06 103: 4.34028e-05 104: 6.2004e-06 221: 0.000195305 222: -2.03288e-20 223: 5.42498e-05 224: -7.74997e-06 229: 5.42498e-05 230: -7.74997e-06 565: -2.48016e-05 572: -3.09999e-05 Row 222: 3: 1.28749e-19 24: 0.000195305 25: -0.000195305 41: -1.01644e-20 101: -6.2004e-06 102: -3.1002e-06 103: 6.2004e-06 104: 3.1002e-06 221: -2.03288e-20 222: 2.09255e-05 223: -7.74997e-06 224: 3.87498e-06 229: 7.74997e-06 230: -3.87498e-06 565: 1.03762e-20 572: -1.65219e-21 Row 223: 24: -0.00116562 25: -0.000325499 41: -0.00116562 52: -0.00025731 221: 5.42498e-05 222: -7.74997e-06 223: 0.000194269 224: 2.47757e-20 225: 4.2885e-05 226: -6.12642e-06 229: 5.42498e-05 230: 7.74997e-06 331: 4.2885e-05 332: -6.12642e-06 572: -3.09999e-05 619: -2.45057e-05 Row 224: 24: 0.000194269 25: -1.77877e-19 41: -0.000194269 52: -3.38813e-21 221: -7.74997e-06 222: 3.87498e-06 223: 2.47757e-20 224: 2.08146e-05 225: -6.12642e-06 226: 3.06321e-06 229: 7.74997e-06 230: 3.87498e-06 331: 6.12642e-06 332: -3.06321e-06 572: -1.3976e-20 619: -1.11427e-21 Row 225: 23: -0.000219508 24: -0.000953636 41: -0.00025731 52: -0.000953636 215: 3.65847e-05 216: 5.22639e-06 219: 3.65847e-05 220: 5.22639e-06 223: 4.2885e-05 224: -6.12642e-06 225: 0.000158939 226: 3.69518e-20 331: 4.2885e-05 332: 6.12642e-06 583: -2.09056e-05 619: -2.45057e-05 Row 226: 23: -1.11808e-19 24: 0.000158939 41: -1.42302e-19 52: -0.000158939 215: -5.22639e-06 216: -2.6132e-06 219: 5.22639e-06 220: 2.6132e-06 223: -6.12642e-06 224: 3.06321e-06 225: 3.69518e-20 226: 1.70292e-05 331: 6.12642e-06 332: 3.06321e-06 583: -8.47033e-21 619: -1.11173e-20 Row 227: 25: -0.000453569 26: -0.000453569 41: -0.000226785 227: 7.55949e-05 228: 0 229: 3.77974e-05 230: -5.39964e-06 233: 3.77974e-05 234: -5.39964e-06 566: -2.15985e-05 Row 228: 25: 7.55949e-05 26: -7.55949e-05 41: -8.47033e-21 227: 0 228: 8.09945e-06 229: -5.39964e-06 230: 2.69982e-06 233: 5.39964e-06 234: -2.69982e-06 566: -1.02997e-21 Row 229: 24: -0.000325499 25: -0.00110457 26: -0.000226785 41: -0.00110457 221: 5.42498e-05 222: 7.74997e-06 223: 5.42498e-05 224: 7.74997e-06 227: 3.77974e-05 228: -5.39964e-06 229: 0.000184094 230: 4.24575e-20 233: 3.77974e-05 234: 5.39964e-06 566: -2.15985e-05 572: -3.09999e-05 Row 230: 24: -1.69407e-19 25: 0.000184094 26: -1.2282e-19 41: -0.000184094 221: -7.74997e-06 222: -3.87498e-06 223: 7.74997e-06 224: 3.87498e-06 227: -5.39964e-06 228: 2.69982e-06 229: 4.24575e-20 230: 1.97244e-05 233: 5.39964e-06 234: 2.69982e-06 566: -9.635e-21 572: -1.24937e-20 Row 231: 26: -0.000456144 27: -0.000456144 53: -0.000228072 231: 7.60239e-05 232: -8.47033e-22 235: 3.8012e-05 236: -5.43028e-06 241: 3.8012e-05 242: -5.43028e-06 585: -2.17211e-05 Row 232: 26: 7.60239e-05 27: -7.60239e-05 53: -6.77626e-21 231: -8.47033e-22 232: 8.14542e-06 235: -5.43028e-06 236: 2.71514e-06 241: 5.43028e-06 242: -2.71514e-06 585: -9.56313e-22 Row 233: 25: -0.000226785 26: -0.000932388 41: -0.000932388 53: -0.00023941 227: 3.77974e-05 228: 5.39964e-06 229: 3.77974e-05 230: 5.39964e-06 233: 0.000155398 234: 3.54166e-20 235: 3.99016e-05 236: -5.70023e-06 333: 3.99016e-05 334: -5.70023e-06 566: -2.15985e-05 601: -2.28009e-05 Row 234: 25: -1.15196e-19 26: 0.000155398 41: -0.000155398 53: -1.30443e-19 227: -5.39964e-06 228: -2.69982e-06 229: 5.39964e-06 230: 2.69982e-06 233: 3.54166e-20 234: 1.66498e-05 235: -5.70023e-06 236: 2.85011e-06 333: 5.70023e-06 334: -2.85011e-06 566: -8.78797e-21 601: -1.05879e-20 Row 235: 26: -0.000934963 27: -0.000228072 41: -0.00023941 53: -0.000934963 231: 3.8012e-05 232: -5.43028e-06 233: 3.99016e-05 234: -5.70023e-06 235: 0.000155827 236: 1.6623e-20 241: 3.8012e-05 242: 5.43028e-06 333: 3.99016e-05 334: 5.70023e-06 585: -2.17211e-05 601: -2.28009e-05 Row 236: 26: 0.000155827 27: -1.2282e-19 41: -6.77626e-21 53: -0.000155827 231: -5.43028e-06 232: 2.71514e-06 233: -5.70023e-06 234: 2.85011e-06 235: 1.6623e-20 236: 1.66958e-05 241: 5.43028e-06 242: 2.71514e-06 333: 5.70023e-06 334: 2.85011e-06 585: -9.74088e-21 601: -1.32113e-21 Row 237: 27: -0.000431062 28: -0.000431062 42: -0.000215531 237: 7.18436e-05 238: 0 239: 3.59218e-05 240: -5.13169e-06 245: 3.59218e-05 246: -5.13169e-06 567: -2.05267e-05 Row 238: 27: 7.18436e-05 28: -7.18436e-05 42: -5.0822e-21 237: 0 238: 7.69753e-06 239: -5.13169e-06 240: 2.56584e-06 245: 5.13169e-06 246: -2.56584e-06 567: -1.06523e-21 Row 239: 27: -0.000890065 28: -0.000215531 42: -0.000890065 53: -0.000229502 237: 3.59218e-05 238: -5.13169e-06 239: 0.000148344 240: 1.61466e-20 241: 3.82503e-05 242: -5.46433e-06 245: 3.59218e-05 246: 5.13169e-06 337: 3.82503e-05 338: -5.46433e-06 567: -2.05267e-05 604: -2.18573e-05 Row 240: 27: 0.000148344 28: -1.17738e-19 42: -0.000148344 53: -3.38813e-21 237: -5.13169e-06 238: 2.56584e-06 239: 1.61466e-20 240: 1.5894e-05 241: -5.46433e-06 242: 2.73216e-06 245: 5.13169e-06 246: 2.56584e-06 337: 5.46433e-06 338: -2.73216e-06 567: -9.1056e-21 604: -9.14871e-22 Row 241: 26: -0.000228072 27: -0.000915147 42: -0.000229502 53: -0.000915147 231: 3.8012e-05 232: 5.43028e-06 235: 3.8012e-05 236: 5.43028e-06 239: 3.82503e-05 240: -5.46433e-06 241: 0.000152524 242: 3.65283e-20 337: 3.82503e-05 338: 5.46433e-06 585: -2.17211e-05 604: -2.18573e-05 Row 242: 26: -1.18585e-19 27: 0.000152524 42: -1.24514e-19 53: -0.000152524 231: -5.43028e-06 232: -2.71514e-06 235: 5.43028e-06 236: 2.71514e-06 239: -5.46433e-06 240: 2.73216e-06 241: 3.65283e-20 242: 1.63419e-05 337: 5.46433e-06 338: 2.73216e-06 585: -8.68209e-21 604: -9.84676e-21 Row 243: 28: -0.000437786 29: -0.000437786 54: -0.000218893 243: 7.29644e-05 244: 0 247: 3.64822e-05 248: -5.21174e-06 253: 3.64822e-05 254: -5.21174e-06 586: -2.0847e-05 Row 244: 28: 7.29644e-05 29: -7.29644e-05 54: -3.38813e-21 243: 0 244: 7.81761e-06 247: -5.21174e-06 248: 2.60587e-06 253: 5.21174e-06 254: -2.60587e-06 586: -1.04191e-21 Row 245: 27: -0.000215531 28: -0.000870709 42: -0.000870709 54: -0.000219824 237: 3.59218e-05 238: 5.13169e-06 239: 3.59218e-05 240: 5.13169e-06 245: 0.000145118 246: 3.42519e-20 247: 3.66373e-05 248: -5.23389e-06 339: 3.66373e-05 340: -5.23389e-06 567: -2.05267e-05 595: -2.09356e-05 Row 246: 27: -1.0842e-19 28: 0.000145118 42: -0.000145118 54: -1.21126e-19 237: -5.13169e-06 238: -2.56584e-06 239: 5.13169e-06 240: 2.56584e-06 245: 3.42519e-20 246: 1.55484e-05 247: -5.23389e-06 248: 2.61695e-06 339: 5.23389e-06 340: -2.61695e-06 567: -8.68209e-21 595: -9.52912e-21 Row 247: 28: -0.000877433 29: -0.000218893 42: -0.000219824 54: -0.000877433 243: 3.64822e-05 244: -5.21174e-06 245: 3.66373e-05 246: -5.23389e-06 247: 0.000146239 248: 1.56701e-20 253: 3.64822e-05 254: 5.21174e-06 339: 3.66373e-05 340: 5.23389e-06 586: -2.0847e-05 595: -2.09356e-05 Row 248: 28: 0.000146239 29: -1.18585e-19 42: -6.77626e-21 54: -0.000146239 243: -5.21174e-06 244: 2.60587e-06 245: -5.23389e-06 246: 2.61695e-06 247: 1.56701e-20 248: 1.56684e-05 253: 5.21174e-06 254: 2.60587e-06 339: 5.23389e-06 340: 2.61695e-06 586: -9.42324e-21 595: -1.22357e-21 Row 249: 29: -0.000460804 30: -0.000460804 43: -0.000230402 249: 7.68007e-05 250: 0 251: 3.84003e-05 252: -5.48576e-06 257: 3.84003e-05 258: -5.48576e-06 568: -2.19431e-05 Row 250: 29: 7.68007e-05 30: -7.68007e-05 43: -5.0822e-21 249: 0 250: 8.22865e-06 251: -5.48576e-06 252: 2.74288e-06 257: 5.48576e-06 258: -2.74288e-06 568: -9.32262e-22 Row 251: 29: -0.000902162 30: -0.000230402 43: -0.000902162 54: -0.000220679 249: 3.84003e-05 250: -5.48576e-06 251: 0.00015036 252: 1.82112e-20 253: 3.67798e-05 254: -5.25426e-06 257: 3.84003e-05 258: 5.48576e-06 345: 3.67798e-05 346: -5.25426e-06 568: -2.19431e-05 600: -2.1017e-05 Row 252: 29: 0.00015036 30: -1.24514e-19 43: -0.00015036 54: -6.77626e-21 249: -5.48576e-06 250: 2.74288e-06 251: 1.82112e-20 252: 1.611e-05 253: -5.25426e-06 254: 2.62713e-06 257: 5.48576e-06 258: 2.74288e-06 345: 5.25426e-06 346: -2.62713e-06 568: -9.95264e-21 600: -8.31921e-22 Row 253: 28: -0.000218893 29: -0.000879144 43: -0.000220679 54: -0.000879144 243: 3.64822e-05 244: 5.21174e-06 247: 3.64822e-05 248: 5.21174e-06 251: 3.67798e-05 252: -5.25426e-06 253: 0.000146524 254: 3.18167e-20 345: 3.67798e-05 346: 5.25426e-06 586: -2.0847e-05 600: -2.1017e-05 Row 254: 28: -1.11808e-19 29: 0.000146524 43: -1.21126e-19 54: -0.000146524 243: -5.21174e-06 244: -2.60587e-06 247: 5.21174e-06 248: 2.60587e-06 251: -5.25426e-06 252: 2.62713e-06 253: 3.18167e-20 254: 1.5699e-05 345: 5.25426e-06 346: 2.62713e-06 586: -8.25857e-21 600: -9.31736e-21 Row 255: 30: -0.000437468 31: -0.000437468 55: -0.000218734 255: 7.29113e-05 256: 0 259: 3.64557e-05 260: -5.20795e-06 263: 3.64557e-05 264: -5.20795e-06 587: -2.08318e-05 Row 256: 30: 7.29113e-05 31: -7.29113e-05 55: -3.38813e-21 255: 0 256: 7.81193e-06 259: -5.20795e-06 260: 2.60398e-06 263: 5.20795e-06 264: -2.60398e-06 587: -1.0832e-21 Row 257: 29: -0.000230402 30: -0.000858824 43: -0.000858824 55: -0.00019901 249: 3.84003e-05 250: 5.48576e-06 251: 3.84003e-05 252: 5.48576e-06 257: 0.000143137 258: 3.25578e-20 259: 3.31683e-05 260: -4.73833e-06 347: 3.31683e-05 348: -4.73833e-06 568: -2.19431e-05 596: -1.89533e-05 Row 258: 29: -1.18585e-19 30: 0.000143137 43: -0.000143137 55: -1.09267e-19 249: -5.48576e-06 250: -2.74288e-06 251: 5.48576e-06 252: 2.74288e-06 257: 3.25578e-20 258: 1.53361e-05 259: -4.73833e-06 260: 2.36916e-06 347: 4.73833e-06 348: -2.36916e-06 568: -9.1056e-21 596: -8.57621e-21 Row 259: 30: -0.000835488 31: -0.000218734 43: -0.00019901 55: -0.000835488 255: 3.64557e-05 256: -5.20795e-06 257: 3.31683e-05 258: -4.73833e-06 259: 0.000139248 260: 1.67818e-20 263: 3.64557e-05 264: 5.20795e-06 347: 3.31683e-05 348: 4.73833e-06 587: -2.08318e-05 596: -1.89533e-05 Row 260: 30: 0.000139248 31: -1.20279e-19 43: -3.38813e-21 55: -0.000139248 255: -5.20795e-06 256: 2.60398e-06 257: -4.73833e-06 258: 2.36916e-06 259: 1.67818e-20 260: 1.49194e-05 263: 5.20795e-06 264: 2.60398e-06 347: 4.73833e-06 348: 2.36916e-06 587: -9.42324e-21 596: -8.12576e-22 Row 261: 4: -0.000328444 31: -0.0011734 32: -0.0011734 55: -0.000258254 107: 5.47406e-05 108: 7.82009e-06 109: 5.47406e-05 110: 7.82009e-06 261: 0.000195566 262: -2.49875e-20 263: 4.30423e-05 264: -6.14891e-06 267: 4.30423e-05 268: -6.14891e-06 569: -3.12803e-05 627: -2.45956e-05 Row 262: 4: 1.69407e-19 31: 0.000195566 32: -0.000195566 55: -8.47033e-21 107: -7.82009e-06 108: -3.91004e-06 109: 7.82009e-06 110: 3.91004e-06 261: -2.49875e-20 262: 2.09535e-05 263: -6.14891e-06 264: 3.07445e-06 267: 6.14891e-06 268: -3.07445e-06 569: 1.3129e-20 627: -1.02295e-21 Row 263: 30: -0.000218734 31: -0.000953976 32: -0.000258254 55: -0.000953976 255: 3.64557e-05 256: 5.20795e-06 259: 3.64557e-05 260: 5.20795e-06 261: 4.30423e-05 262: -6.14891e-06 263: 0.000158996 264: 3.73753e-20 267: 4.30423e-05 268: 6.14891e-06 587: -2.08318e-05 627: -2.45956e-05 Row 264: 30: -1.11808e-19 31: 0.000158996 32: -1.42302e-19 55: -0.000158996 255: -5.20795e-06 256: -2.60398e-06 259: 5.20795e-06 260: 2.60398e-06 261: -6.14891e-06 262: 3.07445e-06 263: 3.73753e-20 264: 1.70353e-05 267: 6.14891e-06 268: 3.07445e-06 587: -8.89385e-21 627: -1.10114e-20 Row 265: 5: -0.000245428 32: -0.00105456 44: -0.00105456 67: -0.00028185 113: 4.09047e-05 114: 5.84353e-06 115: 4.09047e-05 116: 5.84353e-06 265: 0.00017576 266: -1.86347e-20 269: 4.69751e-05 270: -6.71072e-06 355: 4.69751e-05 356: -6.71072e-06 584: -2.33741e-05 623: -2.68429e-05 Row 266: 5: 1.25361e-19 32: 0.00017576 44: -0.00017576 67: -6.77626e-21 113: -5.84353e-06 114: -2.92177e-06 115: 5.84353e-06 116: 2.92177e-06 265: -1.86347e-20 266: 1.88314e-05 269: -6.71072e-06 270: 3.35536e-06 355: 6.71072e-06 356: -3.35536e-06 584: 9.74088e-21 623: -1.22942e-21 Row 267: 31: -0.000258254 32: -0.00099595 55: -0.00099595 67: -0.000239721 261: 4.30423e-05 262: 6.14891e-06 263: 4.30423e-05 264: 6.14891e-06 267: 0.000165992 268: 3.944e-20 269: 3.99535e-05 270: -5.70765e-06 391: 3.99535e-05 392: -5.70765e-06 627: -2.45956e-05 632: -2.28306e-05 Row 268: 31: -1.32137e-19 32: 0.000165992 55: -0.000165992 67: -1.30443e-19 261: -6.14891e-06 262: -3.07445e-06 263: 6.14891e-06 264: 3.07445e-06 267: 3.944e-20 268: 1.77848e-05 269: -5.70765e-06 270: 2.85382e-06 391: 5.70765e-06 392: -2.85382e-06 627: -9.95264e-21 632: -1.03762e-20 Row 269: 32: -0.00104314 44: -0.00028185 55: -0.000239721 67: -0.00104314 265: 4.69751e-05 266: -6.71072e-06 267: 3.99535e-05 268: -5.70765e-06 269: 0.000173857 270: 2.1017e-20 355: 4.69751e-05 356: 6.71072e-06 391: 3.99535e-05 392: 5.70765e-06 623: -2.68429e-05 632: -2.28306e-05 Row 270: 32: 0.000173857 44: -1.52466e-19 55: -6.77626e-21 67: -0.000173857 265: -6.71072e-06 266: 3.35536e-06 267: -5.70765e-06 268: 2.85382e-06 269: 2.1017e-20 270: 1.86276e-05 355: 6.71072e-06 356: 3.35536e-06 391: 5.70765e-06 392: 2.85382e-06 623: -1.21761e-20 632: -1.32113e-21 Row 271: 6: -0.000238402 33: -0.00093628 44: -0.00093628 66: -0.000229738 119: 3.97337e-05 120: 5.67624e-06 121: 3.97337e-05 122: 5.67624e-06 271: 0.000156047 272: 3.56283e-20 277: 3.82896e-05 278: -5.46994e-06 353: 3.82896e-05 354: -5.46994e-06 582: -2.2705e-05 621: -2.18798e-05 Row 272: 6: -1.21973e-19 33: 0.000156047 44: -0.000156047 66: -1.25361e-19 119: -5.67624e-06 120: -2.83812e-06 121: 5.67624e-06 122: 2.83812e-06 271: 3.56283e-20 272: 1.67193e-05 277: -5.46994e-06 278: 2.73497e-06 353: 5.46994e-06 354: -2.73497e-06 582: -9.21148e-21 621: -9.95264e-21 Row 273: 7: -0.000229678 33: -0.000897969 45: -0.000897969 61: -0.000219307 125: 3.82796e-05 126: 5.46852e-06 127: 3.82796e-05 128: 5.46852e-06 273: 0.000149661 274: -1.69407e-20 275: 3.65511e-05 276: -5.22159e-06 357: 3.65511e-05 358: -5.22159e-06 589: -2.18741e-05 612: -2.08864e-05 Row 274: 7: 1.15196e-19 33: 0.000149661 45: -0.000149661 61: -6.77626e-21 125: -5.46852e-06 126: -2.73426e-06 127: 5.46852e-06 128: 2.73426e-06 273: -1.69407e-20 274: 1.60352e-05 275: -5.22159e-06 276: 2.61079e-06 357: 5.22159e-06 358: -2.61079e-06 589: 8.89385e-21 612: -9.25172e-22 Row 275: 33: -0.000888851 45: -0.000219307 61: -0.000888851 66: -0.000225119 273: 3.65511e-05 274: -5.22159e-06 275: 0.000148142 276: 1.68877e-20 277: 3.75198e-05 278: -5.35997e-06 357: 3.65511e-05 358: 5.22159e-06 431: 3.75198e-05 432: -5.35997e-06 612: -2.08864e-05 622: -2.14399e-05 Row 276: 33: 0.000148142 45: -1.19432e-19 61: -0.000148142 66: -3.38813e-21 273: -5.22159e-06 274: 2.61079e-06 275: 1.68877e-20 276: 1.58723e-05 277: -5.35997e-06 278: 2.67999e-06 357: 5.22159e-06 358: 2.61079e-06 431: 5.35997e-06 432: -2.67999e-06 612: -9.31736e-21 622: -8.65147e-22 Row 277: 33: -0.000909713 44: -0.000229738 61: -0.000225119 66: -0.000909713 271: 3.82896e-05 272: -5.46994e-06 275: 3.75198e-05 276: -5.35997e-06 277: 0.000151619 278: 1.69936e-20 353: 3.82896e-05 354: 5.46994e-06 431: 3.75198e-05 432: 5.35997e-06 621: -2.18798e-05 622: -2.14399e-05 Row 278: 33: 0.000151619 44: -3.38813e-21 61: -1.2282e-19 66: -0.000151619 271: -5.46994e-06 272: 2.73497e-06 275: -5.35997e-06 276: 2.67999e-06 277: 1.69936e-20 278: 1.62449e-05 353: 5.46994e-06 354: 2.73497e-06 431: 5.35997e-06 432: 2.67999e-06 621: -1.12883e-21 622: -9.635e-21 Row 279: 8: -0.000228621 34: -0.000918089 45: -0.000918089 63: -0.000230423 131: 3.81035e-05 132: 5.44336e-06 133: 3.81035e-05 134: 5.44336e-06 279: 0.000153015 280: 3.44107e-20 285: 3.84038e-05 286: -5.48626e-06 359: 3.84038e-05 360: -5.48626e-06 578: -2.17735e-05 615: -2.19451e-05 Row 280: 8: -1.15196e-19 34: 0.000153015 45: -0.000153015 63: -1.26208e-19 131: -5.44336e-06 132: -2.72168e-06 133: 5.44336e-06 134: 2.72168e-06 279: 3.44107e-20 280: 1.63944e-05 285: -5.48626e-06 286: 2.74313e-06 359: 5.48626e-06 360: -2.74313e-06 578: -8.89385e-21 615: -1.00585e-20 Row 281: 9: -0.000204302 34: -0.000884718 46: -0.000884718 57: -0.000238057 137: 3.40504e-05 138: 4.86434e-06 139: 3.40504e-05 140: 4.86434e-06 281: 0.000147453 282: -1.69407e-20 283: 3.96761e-05 284: -5.66802e-06 361: 3.96761e-05 362: -5.66802e-06 590: -1.94574e-05 606: -2.26721e-05 Row 282: 9: 1.05032e-19 34: 0.000147453 46: -0.000147453 57: -6.77626e-21 137: -4.86434e-06 138: -2.43217e-06 139: 4.86434e-06 140: 2.43217e-06 281: -1.69407e-20 282: 1.57985e-05 283: -5.66802e-06 284: 2.83401e-06 361: 5.66802e-06 362: -2.83401e-06 590: 8.04681e-21 606: -9.92299e-22 Row 283: 34: -0.00101921 46: -0.000238057 57: -0.00101921 63: -0.00027155 281: 3.96761e-05 282: -5.66802e-06 283: 0.000169869 284: 1.84759e-20 285: 4.52583e-05 286: -6.46547e-06 361: 3.96761e-05 362: 5.66802e-06 401: 4.52583e-05 402: -6.46547e-06 606: -2.26721e-05 616: -2.58619e-05 Row 284: 34: 0.000169869 46: -1.29596e-19 57: -0.000169869 63: -6.77626e-21 281: -5.66802e-06 282: 2.83401e-06 283: 1.84759e-20 284: 1.82002e-05 285: -6.46547e-06 286: 3.23274e-06 361: 5.66802e-06 362: 2.83401e-06 401: 6.46547e-06 402: -3.23274e-06 606: -1.01644e-20 616: -1.33946e-21 Row 285: 34: -0.00100395 45: -0.000230423 57: -0.00027155 63: -0.00100395 279: 3.84038e-05 280: -5.48626e-06 283: 4.52583e-05 284: -6.46547e-06 285: 0.000167324 286: 2.13346e-20 359: 3.84038e-05 360: 5.48626e-06 401: 4.52583e-05 402: 6.46547e-06 615: -2.19451e-05 616: -2.58619e-05 Row 286: 34: 0.000167324 45: -3.38813e-21 57: -1.49078e-19 63: -0.000167324 279: -5.48626e-06 280: 2.74313e-06 283: -6.46547e-06 284: 3.23274e-06 285: 2.13346e-20 286: 1.79276e-05 359: 5.48626e-06 360: 2.74313e-06 401: 6.46547e-06 402: 3.23274e-06 615: -9.96003e-22 616: -1.15408e-20 Row 287: 10: -0.000262408 35: -0.00101781 46: -0.00101781 57: -0.000246497 143: 4.37346e-05 144: 6.2478e-06 145: 4.37346e-05 146: 6.2478e-06 287: 0.000169635 288: 4.10282e-20 291: 4.10829e-05 292: -5.86898e-06 361: 4.10829e-05 362: -5.86898e-06 609: -2.49912e-05 630: -2.34759e-05 Row 288: 10: -1.32137e-19 35: 0.000169635 46: -0.000169635 57: -1.34678e-19 143: -6.2478e-06 144: -3.1239e-06 145: 6.2478e-06 146: 3.1239e-06 287: 4.10282e-20 288: 1.81752e-05 291: -5.86898e-06 292: 2.93449e-06 361: 5.86898e-06 362: -2.93449e-06 609: -1.03762e-20 630: -1.10114e-20 Row 289: 12: -0.000249411 35: -0.00107074 47: -0.00107074 57: -0.00028596 153: 4.15684e-05 154: 5.93835e-06 155: 4.15684e-05 156: 5.93835e-06 289: 0.000178457 290: -1.86347e-20 291: 4.766e-05 292: -6.80857e-06 363: 4.766e-05 364: -6.80857e-06 602: -2.37534e-05 637: -2.72343e-05 Row 290: 12: 1.28749e-19 35: 0.000178457 47: -0.000178457 57: -6.77626e-21 153: -5.93835e-06 154: -2.96917e-06 155: 5.93835e-06 156: 2.96917e-06 289: -1.86347e-20 290: 1.91204e-05 291: -6.80857e-06 292: 3.40429e-06 363: 6.80857e-06 364: -3.40429e-06 602: 9.74088e-21 637: -1.09855e-21 Row 291: 35: -0.00106491 46: -0.000246497 47: -0.00028596 57: -0.00106491 287: 4.10829e-05 288: -5.86898e-06 289: 4.766e-05 290: -6.80857e-06 291: 0.000177486 292: 2.20758e-20 361: 4.10829e-05 362: 5.86898e-06 363: 4.766e-05 364: 6.80857e-06 630: -2.34759e-05 637: -2.72343e-05 Row 292: 35: 0.000177486 46: -1.01644e-20 47: -1.57548e-19 57: -0.000177486 287: -5.86898e-06 288: 2.93449e-06 289: -6.80857e-06 290: 3.40429e-06 291: 2.20758e-20 292: 1.90163e-05 361: 5.86898e-06 362: 2.93449e-06 363: 6.80857e-06 364: 3.40429e-06 630: -1.05858e-21 637: -1.24937e-20 Row 293: 13: -0.00023561 36: -0.000941759 47: -0.000941759 68: -0.000235269 159: 3.92684e-05 160: 5.60977e-06 161: 3.92684e-05 162: 5.60977e-06 293: 0.00015696 294: 3.52577e-20 299: 3.92115e-05 300: -5.60165e-06 365: 3.92115e-05 366: -5.60165e-06 588: -2.24391e-05 628: -2.24066e-05 Row 294: 13: -1.21973e-19 36: 0.00015696 47: -0.00015696 68: -1.27902e-19 159: -5.60977e-06 160: -2.80489e-06 161: 5.60977e-06 162: 2.80489e-06 293: 3.52577e-20 294: 1.68171e-05 299: -5.60165e-06 300: 2.80082e-06 365: 5.60165e-06 366: -2.80082e-06 588: -9.52912e-21 628: -1.00585e-20 Row 295: 14: -0.000218479 36: -0.000848903 48: -0.000848903 59: -0.000205972 165: 3.64132e-05 166: 5.20189e-06 167: 3.64132e-05 168: 5.20189e-06 295: 0.000141484 296: -1.69407e-20 297: 3.43287e-05 298: -4.90409e-06 367: 3.43287e-05 368: -4.90409e-06 591: -2.08076e-05 608: -1.96164e-05 Row 296: 14: 1.15196e-19 36: 0.000141484 48: -0.000141484 59: -3.38813e-21 165: -5.20189e-06 166: -2.60095e-06 167: 5.20189e-06 168: 2.60095e-06 295: -1.69407e-20 296: 1.5159e-05 297: -4.90409e-06 298: 2.45205e-06 367: 4.90409e-06 368: -2.45205e-06 591: 8.78797e-21 608: -8.42681e-22 Row 297: 36: -0.000846999 48: -0.000205972 59: -0.000846999 68: -0.000217527 295: 3.43287e-05 296: -4.90409e-06 297: 0.000141166 298: 1.55642e-20 299: 3.62545e-05 300: -5.17922e-06 367: 3.43287e-05 368: 4.90409e-06 415: 3.62545e-05 416: -5.17922e-06 608: -1.96164e-05 629: -2.07169e-05 Row 298: 36: 0.000141166 48: -1.12655e-19 59: -0.000141166 68: -5.0822e-21 295: -4.90409e-06 296: 2.45205e-06 297: 1.55642e-20 298: 1.5125e-05 299: -5.17922e-06 300: 2.58961e-06 367: 4.90409e-06 368: 2.45205e-06 415: 5.17922e-06 416: -2.58961e-06 608: -8.68209e-21 629: -9.50785e-22 Row 299: 36: -0.000905593 47: -0.000235269 59: -0.000217527 68: -0.000905593 293: 3.92115e-05 294: -5.60165e-06 297: 3.62545e-05 298: -5.17922e-06 299: 0.000150932 300: 1.61466e-20 365: 3.92115e-05 366: 5.60165e-06 415: 3.62545e-05 416: 5.17922e-06 628: -2.24066e-05 629: -2.07169e-05 Row 300: 36: 0.000150932 47: -8.47033e-21 59: -1.18585e-19 68: -0.000150932 293: -5.60165e-06 294: 2.80082e-06 297: -5.17922e-06 298: 2.58961e-06 299: 1.61466e-20 300: 1.61713e-05 365: 5.60165e-06 366: 2.80082e-06 415: 5.17922e-06 416: 2.58961e-06 628: -1.04999e-21 629: -9.52912e-21 Row 301: 15: -0.000212497 37: -0.000833337 48: -0.000833337 69: -0.000204172 171: 3.54161e-05 172: 5.05945e-06 173: 3.54161e-05 174: 5.05945e-06 301: 0.00013889 302: 3.25049e-20 307: 3.40286e-05 308: -4.86123e-06 369: 3.40286e-05 370: -4.86123e-06 597: -2.02378e-05 634: -1.94449e-05 Row 302: 15: -1.0842e-19 37: 0.00013889 48: -0.00013889 69: -1.10961e-19 171: -5.05945e-06 172: -2.52972e-06 173: 5.05945e-06 174: 2.52972e-06 301: 3.25049e-20 302: 1.4881e-05 307: -4.86123e-06 308: 2.43062e-06 369: 4.86123e-06 370: -2.43062e-06 597: -8.57621e-21 634: -8.89385e-21 Row 303: 16: -0.000190229 37: -0.000830838 49: -0.000830838 60: -0.00022519 177: 3.17049e-05 178: 4.52927e-06 179: 3.17049e-05 180: 4.52927e-06 303: 0.000138473 304: -1.52466e-20 305: 3.75317e-05 306: -5.36167e-06 371: 3.75317e-05 372: -5.36167e-06 592: -1.81171e-05 642: -2.14467e-05 Row 304: 16: 9.82558e-20 37: 0.000138473 49: -0.000138473 60: -8.47033e-21 177: -4.52927e-06 178: -2.26463e-06 179: 4.52927e-06 180: 2.26463e-06 303: -1.52466e-20 304: 1.48364e-05 305: -5.36167e-06 306: 2.68083e-06 371: 5.36167e-06 372: -2.68083e-06 592: 7.72918e-21 642: -1.00337e-21 Row 305: 37: -0.000932106 49: -0.00022519 60: -0.000932106 69: -0.000240863 303: 3.75317e-05 304: -5.36167e-06 305: 0.000155351 306: 1.74171e-20 307: 4.01438e-05 308: -5.73483e-06 371: 3.75317e-05 372: 5.36167e-06 425: 4.01438e-05 426: -5.73483e-06 642: -2.14467e-05 643: -2.29393e-05 Row 306: 37: 0.000155351 49: -1.2282e-19 60: -0.000155351 69: -5.0822e-21 303: -5.36167e-06 304: 2.68083e-06 305: 1.74171e-20 306: 1.66447e-05 307: -5.73483e-06 308: 2.86741e-06 371: 5.36167e-06 372: 2.68083e-06 425: 5.73483e-06 426: -2.86741e-06 642: -9.635e-21 643: -1.16082e-21 Row 307: 37: -0.000890069 48: -0.000204172 60: -0.000240863 69: -0.000890069 301: 3.40286e-05 302: -4.86123e-06 305: 4.01438e-05 306: -5.73483e-06 307: 0.000148345 308: 1.88994e-20 369: 3.40286e-05 370: 4.86123e-06 425: 4.01438e-05 426: 5.73483e-06 634: -1.94449e-05 643: -2.29393e-05 Row 308: 37: 0.000148345 48: -3.38813e-21 60: -1.30443e-19 69: -0.000148345 301: -4.86123e-06 302: 2.43062e-06 305: -5.73483e-06 306: 2.86741e-06 307: 1.88994e-20 308: 1.58941e-05 369: 4.86123e-06 370: 2.43062e-06 425: 5.73483e-06 426: 2.86741e-06 634: -1.10829e-21 643: -1.0482e-20 Row 309: 17: -0.000253086 38: -0.000973941 49: -0.000973941 60: -0.000233884 183: 4.21811e-05 184: 6.02587e-06 185: 4.21811e-05 186: 6.02587e-06 309: 0.000162323 310: 3.70577e-20 313: 3.89807e-05 314: -5.56867e-06 371: 3.89807e-05 372: -5.56867e-06 611: -2.41035e-05 631: -2.22747e-05 Row 310: 17: -1.28749e-19 38: 0.000162323 49: -0.000162323 60: -1.28749e-19 183: -6.02587e-06 184: -3.01293e-06 185: 6.02587e-06 186: 3.01293e-06 309: 3.70577e-20 310: 1.73918e-05 313: -5.56867e-06 314: 2.78433e-06 371: 5.56867e-06 372: -2.78433e-06 611: -9.74088e-21 631: -1.03762e-20 Row 311: 19: -0.000248978 38: -0.00105419 50: -0.00105419 60: -0.000278114 193: 4.14964e-05 194: 5.92806e-06 195: 4.14964e-05 196: 5.92806e-06 311: 0.000175698 312: -2.20229e-20 313: 4.63524e-05 314: -6.62177e-06 373: 4.63524e-05 374: -6.62177e-06 603: -2.37122e-05 610: -2.64871e-05 Row 312: 19: 1.28749e-19 38: 0.000175698 50: -0.000175698 60: -1.01644e-20 193: -5.92806e-06 194: -2.96403e-06 195: 5.92806e-06 196: 2.96403e-06 311: -2.20229e-20 312: 1.88247e-05 313: -6.62177e-06 314: 3.31088e-06 373: 6.62177e-06 374: -3.31088e-06 603: 9.95264e-21 610: -1.3333e-21 Row 313: 38: -0.001024 49: -0.000233884 50: -0.000278114 60: -0.001024 309: 3.89807e-05 310: -5.56867e-06 311: 4.63524e-05 312: -6.62177e-06 313: 0.000170666 314: 2.00112e-20 371: 3.89807e-05 372: 5.56867e-06 373: 4.63524e-05 374: 6.62177e-06 610: -2.64871e-05 631: -2.22747e-05 Row 314: 38: 0.000170666 49: -3.38813e-21 50: -1.50772e-19 60: -0.000170666 309: -5.56867e-06 310: 2.78433e-06 311: -6.62177e-06 312: 3.31088e-06 313: 2.00112e-20 314: 1.82857e-05 371: 5.56867e-06 372: 2.78433e-06 373: 6.62177e-06 374: 3.31088e-06 610: -1.11173e-20 631: -1.16774e-21 Row 315: 20: -0.000245394 39: -0.000968753 50: -0.000968753 62: -0.000238983 199: 4.0899e-05 200: 5.84271e-06 201: 4.0899e-05 202: 5.84271e-06 315: 0.000161459 316: 3.71636e-20 321: 3.98304e-05 322: -5.69006e-06 375: 3.98304e-05 376: -5.69006e-06 598: -2.33708e-05 613: -2.27602e-05 Row 316: 20: -1.28749e-19 39: 0.000161459 50: -0.000161459 62: -1.3129e-19 199: -5.84271e-06 200: -2.92136e-06 201: 5.84271e-06 202: 2.92136e-06 315: 3.71636e-20 316: 1.72992e-05 321: -5.69006e-06 322: 2.84503e-06 375: 5.69006e-06 376: -2.84503e-06 598: -9.52912e-21 613: -1.02703e-20 Row 317: 21: -0.000235758 39: -0.000935272 51: -0.000935272 58: -0.000231878 205: 3.9293e-05 206: 5.61328e-06 207: 3.9293e-05 208: 5.61328e-06 317: 0.000155879 318: -1.82112e-20 319: 3.86464e-05 320: -5.52091e-06 377: 3.86464e-05 378: -5.52091e-06 593: -2.24531e-05 607: -2.20836e-05 Row 318: 21: 1.21973e-19 39: 0.000155879 51: -0.000155879 58: -3.38813e-21 205: -5.61328e-06 206: -2.80664e-06 207: 5.61328e-06 208: 2.80664e-06 317: -1.82112e-20 318: 1.67013e-05 319: -5.52091e-06 320: 2.76045e-06 377: 5.52091e-06 378: -2.76045e-06 593: 9.42324e-21 607: -8.65891e-22 Row 319: 39: -0.000936606 51: -0.000231878 58: -0.000936606 62: -0.000236425 317: 3.86464e-05 318: -5.52091e-06 319: 0.000156101 320: 1.76818e-20 321: 3.94041e-05 322: -5.62916e-06 377: 3.86464e-05 378: 5.52091e-06 407: 3.94041e-05 408: -5.62916e-06 607: -2.20836e-05 614: -2.25166e-05 Row 320: 39: 0.000156101 51: -1.27055e-19 58: -0.000156101 62: -5.0822e-21 317: -5.52091e-06 318: 2.76045e-06 319: 1.76818e-20 320: 1.67251e-05 321: -5.62916e-06 322: 2.81458e-06 377: 5.52091e-06 378: 2.76045e-06 407: 5.62916e-06 408: -2.81458e-06 607: -1.01644e-20 614: -9.74957e-22 Row 321: 39: -0.000950815 50: -0.000238983 58: -0.000236425 62: -0.000950815 315: 3.98304e-05 316: -5.69006e-06 319: 3.94041e-05 320: -5.62916e-06 321: 0.000158469 322: 1.81053e-20 375: 3.98304e-05 376: 5.69006e-06 407: 3.94041e-05 408: 5.62916e-06 613: -2.27602e-05 614: -2.25166e-05 Row 322: 39: 0.000158469 50: -1.01644e-20 58: -1.28749e-19 62: -0.000158469 315: -5.69006e-06 316: 2.84503e-06 319: -5.62916e-06 320: 2.81458e-06 321: 1.81053e-20 322: 1.69788e-05 375: 5.69006e-06 376: 2.84503e-06 407: 5.62916e-06 408: 2.81458e-06 613: -1.02356e-21 614: -1.00585e-20 Row 323: 22: -0.000230927 40: -0.000919395 51: -0.000919395 70: -0.00022877 211: 3.84879e-05 212: 5.49827e-06 213: 3.84879e-05 214: 5.49827e-06 323: 0.000153233 324: 3.60518e-20 329: 3.81284e-05 330: -5.44691e-06 379: 3.81284e-05 380: -5.44691e-06 599: -2.19931e-05 640: -2.17876e-05 Row 324: 22: -1.18585e-19 40: 0.000153233 51: -0.000153233 70: -1.23667e-19 211: -5.49827e-06 212: -2.74914e-06 213: 5.49827e-06 214: 2.74914e-06 323: 3.60518e-20 324: 1.64178e-05 329: -5.44691e-06 330: 2.72346e-06 379: 5.44691e-06 380: -2.72346e-06 599: -9.1056e-21 640: -9.84676e-21 Row 325: 23: -0.00020089 40: -0.000865069 52: -0.000865069 65: -0.000231644 217: 3.34817e-05 218: 4.7831e-06 219: 3.34817e-05 220: 4.7831e-06 325: 0.000144178 326: -1.27055e-20 327: 3.86074e-05 328: -5.51534e-06 381: 3.86074e-05 382: -5.51534e-06 594: -1.91324e-05 620: -2.20614e-05 Row 326: 23: 1.05032e-19 40: 0.000144178 52: -0.000144178 65: -6.77626e-21 217: -4.7831e-06 218: -2.39155e-06 219: 4.7831e-06 220: 2.39155e-06 325: -1.27055e-20 326: 1.54477e-05 327: -5.51534e-06 328: 2.75767e-06 381: 5.51534e-06 382: -2.75767e-06 594: 8.04681e-21 620: -9.46629e-22 Row 327: 40: -0.000997777 52: -0.000231644 65: -0.000997777 70: -0.000267245 325: 3.86074e-05 326: -5.51534e-06 327: 0.000166296 328: 1.72054e-20 329: 4.45408e-05 330: -6.36296e-06 381: 3.86074e-05 382: 5.51534e-06 451: 4.45408e-05 452: -6.36296e-06 620: -2.20614e-05 645: -2.54519e-05 Row 328: 40: 0.000166296 52: -1.26208e-19 65: -0.000166296 70: -8.47033e-21 325: -5.51534e-06 326: 2.75767e-06 327: 1.72054e-20 328: 1.78175e-05 329: -6.36296e-06 330: 3.18148e-06 381: 5.51534e-06 382: 2.75767e-06 451: 6.36296e-06 452: -3.18148e-06 620: -9.95264e-21 645: -1.30388e-21 Row 329: 40: -0.000992029 51: -0.00022877 65: -0.000267245 70: -0.000992029 323: 3.81284e-05 324: -5.44691e-06 327: 4.45408e-05 328: -6.36296e-06 329: 0.000165338 330: 2.017e-20 379: 3.81284e-05 380: 5.44691e-06 451: 4.45408e-05 452: 6.36296e-06 640: -2.17876e-05 645: -2.54519e-05 Row 330: 40: 0.000165338 51: -6.77626e-21 65: -1.4569e-19 70: -0.000165338 323: -5.44691e-06 324: 2.72346e-06 327: -6.36296e-06 328: 3.18148e-06 329: 2.017e-20 330: 1.77148e-05 379: 5.44691e-06 380: 2.72346e-06 451: 6.36296e-06 452: 3.18148e-06 640: -1.23601e-21 645: -1.14349e-20 Row 331: 24: -0.00025731 41: -0.000988928 52: -0.000988928 65: -0.000237154 223: 4.2885e-05 224: 6.12642e-06 225: 4.2885e-05 226: 6.12642e-06 331: 0.000164821 332: 3.47813e-20 335: 3.95257e-05 336: -5.64652e-06 381: 3.95257e-05 382: -5.64652e-06 619: -2.45057e-05 625: -2.25861e-05 Row 332: 24: -1.32137e-19 41: 0.000164821 52: -0.000164821 65: -1.28749e-19 223: -6.12642e-06 224: -3.06321e-06 225: 6.12642e-06 226: 3.06321e-06 331: 3.47813e-20 332: 1.76594e-05 335: -5.64652e-06 336: 2.82326e-06 381: 5.64652e-06 382: -2.82326e-06 619: -1.00585e-20 625: -1.03762e-20 Row 333: 26: -0.00023941 41: -0.00103162 53: -0.00103162 65: -0.0002764 233: 3.99016e-05 234: 5.70023e-06 235: 3.99016e-05 236: 5.70023e-06 333: 0.000171937 334: -1.86347e-20 335: 4.60667e-05 336: -6.58096e-06 385: 4.60667e-05 386: -6.58096e-06 601: -2.28009e-05 626: -2.63238e-05 Row 334: 26: 1.21973e-19 41: 0.000171937 53: -0.000171937 65: -8.47033e-21 233: -5.70023e-06 234: -2.85011e-06 235: 5.70023e-06 236: 2.85011e-06 333: -1.86347e-20 334: 1.84218e-05 335: -6.58096e-06 336: 3.29048e-06 385: 6.58096e-06 386: -3.29048e-06 601: 9.31736e-21 626: -1.31299e-21 Row 335: 41: -0.00102711 52: -0.000237154 53: -0.0002764 65: -0.00102711 331: 3.95257e-05 332: -5.64652e-06 333: 4.60667e-05 334: -6.58096e-06 335: 0.000171185 336: 2.17582e-20 381: 3.95257e-05 382: 5.64652e-06 385: 4.60667e-05 386: 6.58096e-06 625: -2.25861e-05 626: -2.63238e-05 Row 336: 41: 0.000171185 52: -8.47033e-21 53: -1.52466e-19 65: -0.000171185 331: -5.64652e-06 332: 2.82326e-06 333: -6.58096e-06 334: 3.29048e-06 335: 2.17582e-20 336: 1.83412e-05 381: 5.64652e-06 382: 2.82326e-06 385: 6.58096e-06 386: 3.29048e-06 625: -1.26203e-21 626: -1.18585e-20 Row 337: 27: -0.000229502 42: -0.00089607 53: -0.00089607 64: -0.000218533 239: 3.82503e-05 240: 5.46433e-06 241: 3.82503e-05 242: 5.46433e-06 337: 0.000149345 338: 3.53636e-20 343: 3.64222e-05 344: -5.20317e-06 383: 3.64222e-05 384: -5.20317e-06 604: -2.18573e-05 617: -2.08127e-05 Row 338: 27: -1.15196e-19 42: 0.000149345 53: -0.000149345 64: -1.19432e-19 239: -5.46433e-06 240: -2.73216e-06 241: 5.46433e-06 242: 2.73216e-06 337: 3.53636e-20 338: 1.60012e-05 343: -5.20317e-06 344: 2.60158e-06 383: 5.20317e-06 384: -2.60158e-06 604: -9.31736e-21 617: -9.52912e-21 Row 339: 28: -0.000219824 42: -0.000855906 54: -0.000855906 56: -0.00020813 245: 3.66373e-05 246: 5.23389e-06 247: 3.66373e-05 248: 5.23389e-06 339: 0.000142651 340: -1.86347e-20 341: 3.46883e-05 342: -4.95547e-06 387: 3.46883e-05 388: -4.95547e-06 595: -2.09356e-05 605: -1.98219e-05 Row 340: 28: 1.11808e-19 42: 0.000142651 54: -0.000142651 56: -5.0822e-21 245: -5.23389e-06 246: -2.61695e-06 247: 5.23389e-06 248: 2.61695e-06 339: -1.86347e-20 340: 1.5284e-05 341: -4.95547e-06 342: 2.47773e-06 387: 4.95547e-06 388: -2.47773e-06 595: 8.99973e-21 605: -8.9921e-22 Row 341: 42: -0.000846379 54: -0.00020813 56: -0.000846379 64: -0.00021506 339: 3.46883e-05 340: -4.95547e-06 341: 0.000141063 342: 1.59877e-20 343: 3.58433e-05 344: -5.12047e-06 387: 3.46883e-05 388: 4.95547e-06 393: 3.58433e-05 394: -5.12047e-06 605: -1.98219e-05 618: -2.04819e-05 Row 342: 42: 0.000141063 54: -1.14349e-19 56: -0.000141063 64: -6.77626e-21 339: -4.95547e-06 340: 2.47773e-06 341: 1.59877e-20 342: 1.51139e-05 343: -5.12047e-06 344: 2.56023e-06 387: 4.95547e-06 388: 2.47773e-06 393: 5.12047e-06 394: -2.56023e-06 605: -8.89385e-21 618: -1.05026e-21 Row 343: 42: -0.000867186 53: -0.000218533 56: -0.00021506 64: -0.000867186 337: 3.64222e-05 338: -5.20317e-06 341: 3.58433e-05 342: -5.12047e-06 343: 0.000144531 344: 1.65701e-20 383: 3.64222e-05 384: 5.20317e-06 393: 3.58433e-05 394: 5.12047e-06 617: -2.08127e-05 618: -2.04819e-05 Row 344: 42: 0.000144531 53: -5.0822e-21 56: -1.17738e-19 64: -0.000144531 337: -5.20317e-06 338: 2.60158e-06 341: -5.12047e-06 342: 2.56023e-06 343: 1.65701e-20 344: 1.54855e-05 383: 5.20317e-06 384: 2.60158e-06 393: 5.12047e-06 394: 2.56023e-06 617: -1.16518e-21 618: -9.1056e-21 Row 345: 29: -0.000220679 43: -0.000885373 54: -0.000885373 71: -0.000222008 251: 3.67798e-05 252: 5.25426e-06 253: 3.67798e-05 254: 5.25426e-06 345: 0.000147562 346: 3.40401e-20 351: 3.70013e-05 352: -5.2859e-06 389: 3.70013e-05 390: -5.2859e-06 600: -2.1017e-05 644: -2.11436e-05 Row 346: 29: -1.15196e-19 43: 0.000147562 54: -0.000147562 71: -1.21126e-19 251: -5.25426e-06 252: -2.62713e-06 253: 5.25426e-06 254: 2.62713e-06 345: 3.40401e-20 346: 1.58102e-05 351: -5.2859e-06 352: 2.64295e-06 389: 5.2859e-06 390: -2.64295e-06 600: -8.47033e-21 644: -9.635e-21 Row 347: 30: -0.00019901 43: -0.000860301 55: -0.000860301 67: -0.000231141 257: 3.31683e-05 258: 4.73833e-06 259: 3.31683e-05 260: 4.73833e-06 347: 0.000143383 348: -1.48231e-20 349: 3.85235e-05 350: -5.50335e-06 391: 3.85235e-05 392: -5.50335e-06 596: -1.89533e-05 647: -2.20134e-05 Row 348: 30: 1.05032e-19 43: 0.000143383 55: -0.000143383 67: -1.69407e-21 257: -4.73833e-06 258: -2.36916e-06 259: 4.73833e-06 260: 2.36916e-06 347: -1.48231e-20 348: 1.53625e-05 349: -5.50335e-06 350: 2.75168e-06 391: 5.50335e-06 392: -2.75168e-06 596: 7.94093e-21 647: -1.01474e-21 Row 349: 43: -0.000988978 55: -0.000231141 67: -0.000988978 71: -0.000263348 347: 3.85235e-05 348: -5.50335e-06 349: 0.00016483 350: 1.82112e-20 351: 4.38913e-05 352: -6.27019e-06 391: 3.85235e-05 392: 5.50335e-06 461: 4.38913e-05 462: -6.27019e-06 647: -2.20134e-05 648: -2.50808e-05 Row 350: 43: 0.00016483 55: -1.25361e-19 67: -0.00016483 71: -3.38813e-21 347: -5.50335e-06 348: 2.75168e-06 349: 1.82112e-20 350: 1.76603e-05 351: -6.27019e-06 352: 3.1351e-06 391: 5.50335e-06 392: 2.75168e-06 461: 6.27019e-06 462: -3.1351e-06 647: -1.01644e-20 648: -1.07536e-21 Row 351: 43: -0.000970712 54: -0.000222008 67: -0.000263348 71: -0.000970712 345: 3.70013e-05 346: -5.2859e-06 349: 4.38913e-05 350: -6.27019e-06 351: 0.000161785 352: 2.017e-20 389: 3.70013e-05 390: 5.2859e-06 461: 4.38913e-05 462: 6.27019e-06 644: -2.11436e-05 648: -2.50808e-05 Row 352: 43: 0.000161785 54: -5.0822e-21 67: -1.4569e-19 71: -0.000161785 345: -5.2859e-06 346: 2.64295e-06 349: -6.27019e-06 350: 3.1351e-06 351: 2.017e-20 352: 1.73341e-05 389: 5.2859e-06 390: 2.64295e-06 461: 6.27019e-06 462: 3.1351e-06 644: -9.85995e-22 648: -1.14349e-20 Row 353: 33: -0.000229738 44: -0.000986208 66: -0.000986208 67: -0.000263367 271: 3.82896e-05 272: 5.46994e-06 277: 3.82896e-05 278: 5.46994e-06 353: 0.000164368 354: -1.90582e-20 355: 4.38944e-05 356: -6.27063e-06 455: 4.38944e-05 456: -6.27063e-06 621: -2.18798e-05 624: -2.50825e-05 Row 354: 33: 1.15196e-19 44: 0.000164368 66: -0.000164368 67: -1.69407e-21 271: -5.46994e-06 272: -2.73497e-06 277: 5.46994e-06 278: 2.73497e-06 353: -1.90582e-20 354: 1.76109e-05 355: -6.27063e-06 356: 3.13532e-06 455: 6.27063e-06 456: -3.13532e-06 621: 9.21148e-21 624: -1.10515e-21 Row 355: 32: -0.00028185 44: -0.00109043 66: -0.000263367 67: -0.00109043 265: 4.69751e-05 266: 6.71072e-06 269: 4.69751e-05 270: 6.71072e-06 353: 4.38944e-05 354: -6.27063e-06 355: 0.000181739 356: 4.04458e-20 455: 4.38944e-05 456: 6.27063e-06 623: -2.68429e-05 624: -2.50825e-05 Row 356: 32: -1.42302e-19 44: 0.000181739 66: -1.43996e-19 67: -0.000181739 265: -6.71072e-06 266: -3.35536e-06 269: 6.71072e-06 270: 3.35536e-06 353: -6.27063e-06 354: 3.13532e-06 355: 4.04458e-20 356: 1.9472e-05 455: 6.27063e-06 456: 3.13532e-06 623: -1.07997e-20 624: -1.13291e-20 Row 357: 33: -0.000219307 45: -0.000890679 61: -0.000890679 63: -0.000226033 273: 3.65511e-05 274: 5.22159e-06 275: 3.65511e-05 276: 5.22159e-06 357: 0.000148446 358: 3.42519e-20 359: 3.76721e-05 360: -5.38173e-06 429: 3.76721e-05 430: -5.38173e-06 612: -2.08864e-05 636: -2.15269e-05 Row 358: 33: -1.15196e-19 45: 0.000148446 61: -0.000148446 63: -1.23667e-19 273: -5.22159e-06 274: -2.61079e-06 275: 5.22159e-06 276: 2.61079e-06 357: 3.42519e-20 358: 1.5905e-05 359: -5.38173e-06 360: 2.69087e-06 429: 5.38173e-06 430: -2.69087e-06 612: -8.47033e-21 636: -9.52912e-21 Row 359: 34: -0.000230423 45: -0.000912912 61: -0.000226033 63: -0.000912912 279: 3.84038e-05 280: 5.48626e-06 285: 3.84038e-05 286: 5.48626e-06 357: 3.76721e-05 358: -5.38173e-06 359: 0.000152152 360: -1.86347e-20 429: 3.76721e-05 430: 5.38173e-06 615: -2.19451e-05 636: -2.15269e-05 Row 360: 34: 1.18585e-19 45: 0.000152152 61: -3.38813e-21 63: -0.000152152 279: -5.48626e-06 280: -2.74313e-06 285: 5.48626e-06 286: 2.74313e-06 357: -5.38173e-06 358: 2.69087e-06 359: -1.86347e-20 360: 1.6302e-05 429: 5.38173e-06 430: 2.69087e-06 615: 8.89385e-21 636: -1.15619e-21 Row 361: 34: -0.000238057 35: -0.000246497 46: -0.000969108 57: -0.000969108 281: 3.96761e-05 282: 5.66802e-06 283: 3.96761e-05 284: 5.66802e-06 287: 4.10829e-05 288: 5.86898e-06 291: 4.10829e-05 292: 5.86898e-06 361: 0.000161518 362: 0 606: -2.26721e-05 630: -2.34759e-05 Row 362: 34: -1.25361e-19 35: 1.21973e-19 46: 0.000161518 57: -0.000161518 281: -5.66802e-06 282: -2.83401e-06 283: 5.66802e-06 284: 2.83401e-06 287: -5.86898e-06 288: -2.93449e-06 291: 5.86898e-06 292: 2.93449e-06 361: 0 362: 1.73055e-05 606: -9.635e-21 630: 9.52912e-21 Row 363: 35: -0.00028596 47: -0.00112232 57: -0.00112232 68: -0.000275202 289: 4.766e-05 290: 6.80857e-06 291: 4.766e-05 292: 6.80857e-06 363: 0.000187054 364: 4.16105e-20 365: 4.5867e-05 366: -6.55242e-06 403: 4.5867e-05 404: -6.55242e-06 637: -2.72343e-05 641: -2.62097e-05 Row 364: 35: -1.49078e-19 47: 0.000187054 57: -0.000187054 68: -1.49078e-19 289: -6.80857e-06 290: -3.40429e-06 291: 6.80857e-06 292: 3.40429e-06 363: 4.16105e-20 364: 2.00415e-05 365: -6.55242e-06 366: 3.27621e-06 403: 6.55242e-06 404: -3.27621e-06 637: -1.10114e-20 641: -1.19643e-20 Row 365: 36: -0.000235269 47: -0.00102094 57: -0.000275202 68: -0.00102094 293: 3.92115e-05 294: 5.60165e-06 299: 3.92115e-05 300: 5.60165e-06 363: 4.5867e-05 364: -6.55242e-06 365: 0.000170157 366: -1.99053e-20 403: 4.5867e-05 404: 6.55242e-06 628: -2.24066e-05 641: -2.62097e-05 Row 366: 36: 1.18585e-19 47: 0.000170157 57: -3.38813e-21 68: -0.000170157 293: -5.60165e-06 294: -2.80082e-06 299: 5.60165e-06 300: 2.80082e-06 363: -6.55242e-06 364: 3.27621e-06 365: -1.99053e-20 366: 1.82311e-05 403: 6.55242e-06 404: 3.27621e-06 628: 8.99973e-21 641: -1.47477e-21 Row 367: 36: -0.000205972 48: -0.000829615 59: -0.000829615 69: -0.000208835 295: 3.43287e-05 296: 4.90409e-06 297: 3.43287e-05 298: 4.90409e-06 367: 0.000138269 368: 3.26108e-20 369: 3.48059e-05 370: -4.97227e-06 417: 3.48059e-05 418: -4.97227e-06 608: -1.96164e-05 633: -1.98891e-05 Row 368: 36: -1.0842e-19 48: 0.000138269 59: -0.000138269 69: -1.13502e-19 295: -4.90409e-06 296: -2.45205e-06 297: 4.90409e-06 298: 2.45205e-06 367: 3.26108e-20 368: 1.48146e-05 369: -4.97227e-06 370: 2.48614e-06 417: 4.97227e-06 418: -2.48614e-06 608: -8.04681e-21 633: -9.1056e-21 Row 369: 37: -0.000204172 48: -0.000826014 59: -0.000208835 69: -0.000826014 301: 3.40286e-05 302: 4.86123e-06 307: 3.40286e-05 308: 4.86123e-06 367: 3.48059e-05 368: -4.97227e-06 369: 0.000137669 370: -1.52466e-20 417: 3.48059e-05 418: 4.97227e-06 633: -1.98891e-05 634: -1.94449e-05 Row 370: 37: 1.05032e-19 48: 0.000137669 59: -3.38813e-21 69: -0.000137669 301: -4.86123e-06 302: -2.43062e-06 307: 4.86123e-06 308: 2.43062e-06 367: -4.97227e-06 368: 2.48614e-06 369: -1.52466e-20 370: 1.47503e-05 417: 4.97227e-06 418: 2.48614e-06 633: -9.56159e-22 634: 8.04681e-21 Row 371: 37: -0.00022519 38: -0.000233884 49: -0.000918148 60: -0.000918148 303: 3.75317e-05 304: 5.36167e-06 305: 3.75317e-05 306: 5.36167e-06 309: 3.89807e-05 310: 5.56867e-06 313: 3.89807e-05 314: 5.56867e-06 371: 0.000153025 372: 0 631: -2.22747e-05 642: -2.14467e-05 Row 372: 37: -1.15196e-19 38: 1.18585e-19 49: 0.000153025 60: -0.000153025 303: -5.36167e-06 304: -2.68083e-06 305: 5.36167e-06 306: 2.68083e-06 309: -5.56867e-06 310: -2.78433e-06 313: 5.56867e-06 314: 2.78433e-06 371: 0 372: 1.63955e-05 631: 9.1056e-21 642: -8.78797e-21 Row 373: 38: -0.000278114 50: -0.00110423 60: -0.00110423 62: -0.000274002 311: 4.63524e-05 312: 6.62177e-06 313: 4.63524e-05 314: 6.62177e-06 373: 0.000184039 374: 4.16105e-20 375: 4.5667e-05 376: -6.52386e-06 423: 4.5667e-05 424: -6.52386e-06 610: -2.64871e-05 638: -2.60954e-05 Row 374: 38: -1.42302e-19 50: 0.000184039 60: -0.000184039 62: -1.49078e-19 311: -6.62177e-06 312: -3.31088e-06 313: 6.62177e-06 314: 3.31088e-06 373: 4.16105e-20 374: 1.97184e-05 375: -6.52386e-06 376: 3.26193e-06 423: 6.52386e-06 424: -3.26193e-06 610: -1.07997e-20 638: -1.18585e-20 Row 375: 39: -0.000238983 50: -0.00102597 60: -0.000274002 62: -0.00102597 315: 3.98304e-05 316: 5.69006e-06 321: 3.98304e-05 322: 5.69006e-06 373: 4.5667e-05 374: -6.52386e-06 375: 0.000170995 376: -1.90582e-20 423: 4.5667e-05 424: 6.52386e-06 613: -2.27602e-05 638: -2.60954e-05 Row 376: 39: 1.21973e-19 50: 0.000170995 60: -8.47033e-21 62: -0.000170995 315: -5.69006e-06 316: -2.84503e-06 321: 5.69006e-06 322: 2.84503e-06 373: -6.52386e-06 374: 3.26193e-06 375: -1.90582e-20 376: 1.83209e-05 423: 6.52386e-06 424: 3.26193e-06 613: 9.52912e-21 638: -1.68169e-21 Row 377: 39: -0.000231878 51: -0.000932474 58: -0.000932474 70: -0.000234359 317: 3.86464e-05 318: 5.52091e-06 319: 3.86464e-05 320: 5.52091e-06 377: 0.000155412 378: 3.28225e-20 379: 3.90598e-05 380: -5.57998e-06 409: 3.90598e-05 410: -5.57998e-06 607: -2.20836e-05 639: -2.23199e-05 Row 378: 39: -1.18585e-19 51: 0.000155412 58: -0.000155412 70: -1.27902e-19 317: -5.52091e-06 318: -2.76045e-06 319: 5.52091e-06 320: 2.76045e-06 377: 3.28225e-20 378: 1.66513e-05 379: -5.57998e-06 380: 2.78999e-06 409: 5.57998e-06 410: -2.78999e-06 607: -9.1056e-21 639: -1.00585e-20 Row 379: 40: -0.00022877 51: -0.000926258 58: -0.000234359 70: -0.000926258 323: 3.81284e-05 324: 5.44691e-06 329: 3.81284e-05 330: 5.44691e-06 377: 3.90598e-05 378: -5.57998e-06 379: 0.000154376 380: -1.77877e-20 409: 3.90598e-05 410: 5.57998e-06 639: -2.23199e-05 640: -2.17876e-05 Row 380: 40: 1.15196e-19 51: 0.000154376 58: -6.77626e-21 70: -0.000154376 323: -5.44691e-06 324: -2.72346e-06 329: 5.44691e-06 330: 2.72346e-06 377: -5.57998e-06 378: 2.78999e-06 379: -1.77877e-20 380: 1.65403e-05 409: 5.57998e-06 410: 2.78999e-06 639: -1.0968e-21 640: 9.1056e-21 Row 381: 40: -0.000231644 41: -0.000237154 52: -0.000937597 65: -0.000937597 325: 3.86074e-05 326: 5.51534e-06 327: 3.86074e-05 328: 5.51534e-06 331: 3.95257e-05 332: 5.64652e-06 335: 3.95257e-05 336: 5.64652e-06 381: 0.000156266 382: -1.69407e-21 620: -2.20614e-05 625: -2.25861e-05 Row 382: 40: -1.15196e-19 41: 1.18585e-19 52: 0.000156266 65: -0.000156266 325: -5.51534e-06 326: -2.75767e-06 327: 5.51534e-06 328: 2.75767e-06 331: -5.64652e-06 332: -2.82326e-06 335: 5.64652e-06 336: 2.82326e-06 381: -1.69407e-21 382: 1.67428e-05 620: -9.31736e-21 625: 9.635e-21 Row 383: 42: -0.000218533 53: -0.000945177 64: -0.000945177 65: -0.000254055 337: 3.64222e-05 338: 5.20317e-06 343: 3.64222e-05 344: 5.20317e-06 383: 0.000157529 384: -1.60936e-20 385: 4.23426e-05 386: -6.04894e-06 445: 4.23426e-05 446: -6.04894e-06 617: -2.08127e-05 635: -2.41957e-05 Row 384: 42: 1.11808e-19 53: 0.000157529 64: -0.000157529 65: -8.47033e-21 337: -5.20317e-06 338: -2.60158e-06 343: 5.20317e-06 344: 2.60158e-06 383: -1.60936e-20 384: 1.68782e-05 385: -6.04894e-06 386: 3.02447e-06 445: 6.04894e-06 446: -3.02447e-06 617: 8.47033e-21 635: -1.15649e-21 Row 385: 41: -0.0002764 53: -0.00106091 64: -0.000254055 65: -0.00106091 333: 4.60667e-05 334: 6.58096e-06 335: 4.60667e-05 336: 6.58096e-06 383: 4.23426e-05 384: -6.04894e-06 385: 0.000176819 386: 3.90165e-20 445: 4.23426e-05 446: 6.04894e-06 626: -2.63238e-05 635: -2.41957e-05 Row 386: 41: -1.38913e-19 53: 0.000176819 64: -1.38913e-19 65: -0.000176819 333: -6.58096e-06 334: -3.29048e-06 335: 6.58096e-06 336: 3.29048e-06 383: -6.04894e-06 384: 3.02447e-06 385: 3.90165e-20 386: 1.89448e-05 445: 6.04894e-06 446: 3.02447e-06 626: -1.10114e-20 635: -1.07997e-20 Row 387: 42: -0.00020813 54: -0.000846595 56: -0.000846595 71: -0.000215168 339: 3.46883e-05 340: 4.95547e-06 341: 3.46883e-05 342: 4.95547e-06 387: 0.000141099 388: 3.17108e-20 389: 3.58613e-05 390: -5.12305e-06 395: 3.58613e-05 396: -5.12305e-06 605: -1.98219e-05 646: -2.04922e-05 Row 388: 42: -1.0842e-19 54: 0.000141099 56: -0.000141099 71: -1.16891e-19 339: -4.95547e-06 340: -2.47773e-06 341: 4.95547e-06 342: 2.47773e-06 387: 3.17108e-20 388: 1.51178e-05 389: -5.12305e-06 390: 2.56152e-06 395: 5.12305e-06 396: -2.56152e-06 605: -8.25857e-21 646: -9.42324e-21 Row 389: 43: -0.000222008 54: -0.000874352 56: -0.000215168 71: -0.000874352 345: 3.70013e-05 346: 5.2859e-06 351: 3.70013e-05 352: 5.2859e-06 387: 3.58613e-05 388: -5.12305e-06 389: 0.000145725 390: -1.73642e-20 395: 3.58613e-05 396: 5.12305e-06 644: -2.11436e-05 646: -2.04922e-05 Row 390: 43: 1.15196e-19 54: 0.000145725 56: -3.38813e-21 71: -0.000145725 345: -5.2859e-06 346: -2.64295e-06 351: 5.2859e-06 352: 2.64295e-06 387: -5.12305e-06 388: 2.56152e-06 389: -1.73642e-20 390: 1.56134e-05 395: 5.12305e-06 396: 2.56152e-06 644: 8.99973e-21 646: -1.04859e-21 Row 391: 32: -0.000239721 43: -0.000231141 55: -0.000941724 67: -0.000941724 267: 3.99535e-05 268: 5.70765e-06 269: 3.99535e-05 270: 5.70765e-06 347: 3.85235e-05 348: 5.50335e-06 349: 3.85235e-05 350: 5.50335e-06 391: 0.000156954 392: -1.69407e-21 632: -2.28306e-05 647: -2.20134e-05 Row 392: 32: 1.25361e-19 43: -1.18585e-19 55: 0.000156954 67: -0.000156954 267: -5.70765e-06 268: -2.85382e-06 269: 5.70765e-06 270: 2.85382e-06 347: -5.50335e-06 348: -2.75168e-06 349: 5.50335e-06 350: 2.75168e-06 391: -1.69407e-21 392: 1.68165e-05 632: 9.1056e-21 647: -9.1056e-21 Row 393: 42: -0.00021506 56: -0.000783772 64: -0.000783772 75: -0.000176827 341: 3.58433e-05 342: 5.12047e-06 343: 3.58433e-05 344: 5.12047e-06 393: 0.000130629 394: 3.02285e-20 399: 2.94711e-05 400: -4.21016e-06 447: 2.94711e-05 448: -4.21016e-06 618: -2.04819e-05 653: -1.68406e-05 Row 394: 42: -1.11808e-19 56: 0.000130629 64: -0.000130629 75: -9.65618e-20 341: -5.12047e-06 342: -2.56023e-06 343: 5.12047e-06 344: 2.56023e-06 393: 3.02285e-20 394: 1.39959e-05 399: -4.21016e-06 400: 2.10508e-06 447: 4.21016e-06 448: -2.10508e-06 618: -8.25857e-21 653: -7.72918e-21 Row 395: 54: -0.000215168 56: -0.000870464 71: -0.000870464 72: -0.000220064 387: 3.58613e-05 388: 5.12305e-06 389: 3.58613e-05 390: 5.12305e-06 395: 0.000145077 396: -1.69407e-20 397: 3.66774e-05 398: -5.23962e-06 477: 3.66774e-05 478: -5.23962e-06 646: -2.04922e-05 649: -2.09585e-05 Row 396: 54: 1.11808e-19 56: 0.000145077 71: -0.000145077 72: -6.77626e-21 387: -5.12305e-06 388: -2.56152e-06 389: 5.12305e-06 390: 2.56152e-06 395: -1.69407e-20 396: 1.5544e-05 397: -5.23962e-06 398: 2.61981e-06 477: 5.23962e-06 478: -2.61981e-06 646: 8.78797e-21 649: -1.01002e-21 Row 397: 56: -0.000793118 71: -0.000220064 72: -0.000793118 75: -0.000176495 395: 3.66774e-05 396: -5.23962e-06 397: 0.000132186 398: 1.73112e-20 399: 2.94158e-05 400: -4.20226e-06 477: 3.66774e-05 478: 5.23962e-06 481: 2.94158e-05 482: -4.20226e-06 649: -2.09585e-05 654: -1.6809e-05 Row 398: 56: 0.000132186 71: -1.20279e-19 72: -0.000132186 75: -5.0822e-21 395: -5.23962e-06 396: 2.61981e-06 397: 1.73112e-20 398: 1.41628e-05 399: -4.20226e-06 400: 2.10113e-06 477: 5.23962e-06 478: 2.61981e-06 481: 4.20226e-06 482: -2.10113e-06 649: -9.42324e-21 654: -6.42452e-22 Row 399: 56: -0.000706643 64: -0.000176827 72: -0.000176495 75: -0.000706643 393: 2.94711e-05 394: -4.21016e-06 397: 2.94158e-05 398: -4.20226e-06 399: 0.000117774 400: 1.33937e-20 447: 2.94711e-05 448: 4.21016e-06 481: 2.94158e-05 482: 4.20226e-06 653: -1.68406e-05 654: -1.6809e-05 Row 400: 56: 0.000117774 64: -3.38813e-21 72: -9.74088e-20 75: -0.000117774 393: -4.21016e-06 394: 2.10508e-06 397: -4.20226e-06 398: 2.10113e-06 399: 1.33937e-20 400: 1.26186e-05 447: 4.21016e-06 448: 2.10508e-06 481: 4.20226e-06 482: 2.10113e-06 653: -8.72298e-22 654: -7.51742e-21 Row 401: 34: -0.00027155 57: -0.00108551 63: -0.00108551 74: -0.000271206 283: 4.52583e-05 284: 6.46547e-06 285: 4.52583e-05 286: 6.46547e-06 401: 0.000180919 402: 3.87518e-20 405: 4.5201e-05 406: -6.45729e-06 441: 4.5201e-05 442: -6.45729e-06 616: -2.58619e-05 651: -2.58292e-05 Row 402: 34: -1.38913e-19 57: 0.000180919 63: -0.000180919 74: -1.47384e-19 283: -6.46547e-06 284: -3.23274e-06 285: 6.46547e-06 286: 3.23274e-06 401: 3.87518e-20 402: 1.93841e-05 405: -6.45729e-06 406: 3.22864e-06 441: 6.45729e-06 442: -3.22864e-06 616: -1.05879e-20 651: -1.19643e-20 Row 403: 47: -0.000275202 57: -0.00109267 68: -0.00109267 74: -0.000271136 363: 4.5867e-05 364: 6.55242e-06 365: 4.5867e-05 366: 6.55242e-06 403: 0.000182112 404: -1.99053e-20 405: 4.51893e-05 406: -6.45561e-06 465: 4.51893e-05 466: -6.45561e-06 641: -2.62097e-05 652: -2.58224e-05 Row 404: 47: 1.38913e-19 57: 0.000182112 68: -0.000182112 74: -6.77626e-21 363: -6.55242e-06 364: -3.27621e-06 365: 6.55242e-06 366: 3.27621e-06 403: -1.99053e-20 404: 1.9512e-05 405: -6.45561e-06 406: 3.2278e-06 465: 6.45561e-06 466: -3.2278e-06 641: 1.07997e-20 652: -1.27809e-21 Row 405: 57: -0.00108468 63: -0.000271206 68: -0.000271136 74: -0.00108468 401: 4.5201e-05 402: -6.45729e-06 403: 4.51893e-05 404: -6.45561e-06 405: 0.000180781 406: 2.02229e-20 441: 4.5201e-05 442: 6.45729e-06 465: 4.51893e-05 466: 6.45561e-06 651: -2.58292e-05 652: -2.58224e-05 Row 406: 57: 0.000180781 63: -6.77626e-21 68: -1.47384e-19 74: -0.000180781 401: -6.45729e-06 402: 3.22864e-06 403: -6.45561e-06 404: 3.2278e-06 405: 2.02229e-20 406: 1.93693e-05 441: 6.45729e-06 442: 3.22864e-06 465: 6.45561e-06 466: 3.2278e-06 651: -1.59915e-21 652: -1.15408e-20 Row 407: 39: -0.000236425 58: -0.000937367 62: -0.000937367 83: -0.000232259 319: 3.94041e-05 320: 5.62916e-06 321: 3.94041e-05 322: 5.62916e-06 407: 0.000156228 408: 3.37225e-20 413: 3.87098e-05 414: -5.52997e-06 439: 3.87098e-05 440: -5.52997e-06 614: -2.25166e-05 672: -2.21199e-05 Row 408: 39: -1.18585e-19 58: 0.000156228 62: -0.000156228 83: -1.26208e-19 319: -5.62916e-06 320: -2.81458e-06 321: 5.62916e-06 322: 2.81458e-06 407: 3.37225e-20 408: 1.67387e-05 413: -5.52997e-06 414: 2.76498e-06 439: 5.52997e-06 440: -2.76498e-06 614: -9.31736e-21 672: -9.84676e-21 Row 409: 51: -0.000234359 58: -0.000934689 70: -0.000934689 73: -0.000232986 377: 3.90598e-05 378: 5.57998e-06 379: 3.90598e-05 380: 5.57998e-06 409: 0.000155782 410: -1.86347e-20 411: 3.88309e-05 412: -5.54728e-06 473: 3.88309e-05 474: -5.54728e-06 639: -2.23199e-05 650: -2.21891e-05 Row 410: 51: 1.21973e-19 58: 0.000155782 70: -0.000155782 73: -1.01644e-20 377: -5.57998e-06 378: -2.78999e-06 379: 5.57998e-06 380: 2.78999e-06 409: -1.86347e-20 410: 1.66909e-05 411: -5.54728e-06 412: 2.77364e-06 473: 5.54728e-06 474: -2.77364e-06 639: 8.89385e-21 650: -8.99897e-22 Row 411: 58: -0.000900123 70: -0.000232986 73: -0.000900123 83: -0.000217076 409: 3.88309e-05 410: -5.54728e-06 411: 0.00015002 412: 1.75759e-20 413: 3.61793e-05 414: -5.16847e-06 473: 3.88309e-05 474: 5.54728e-06 491: 3.61793e-05 492: -5.16847e-06 650: -2.21891e-05 674: -2.06739e-05 Row 412: 58: 0.00015002 70: -1.27055e-19 73: -0.00015002 83: -5.0822e-21 409: -5.54728e-06 410: 2.77364e-06 411: 1.75759e-20 412: 1.60736e-05 413: -5.16847e-06 414: 2.58423e-06 473: 5.54728e-06 474: 2.77364e-06 491: 5.16847e-06 492: -2.58423e-06 650: -1.00585e-20 674: -9.27555e-22 Row 413: 58: -0.000898668 62: -0.000232259 73: -0.000217076 83: -0.000898668 407: 3.87098e-05 408: -5.52997e-06 411: 3.61793e-05 412: -5.16847e-06 413: 0.000149778 414: 1.69936e-20 439: 3.87098e-05 440: 5.52997e-06 491: 3.61793e-05 492: 5.16847e-06 672: -2.21199e-05 674: -2.06739e-05 Row 414: 58: 0.000149778 62: -3.38813e-21 73: -1.18585e-19 83: -0.000149778 407: -5.52997e-06 408: 2.76498e-06 411: -5.16847e-06 412: 2.58423e-06 413: 1.69936e-20 414: 1.60477e-05 439: 5.52997e-06 440: 2.76498e-06 491: 5.16847e-06 492: 2.58423e-06 672: -1.17434e-21 674: -9.52912e-21 Row 415: 36: -0.000217527 59: -0.000866772 68: -0.000866772 81: -0.000215859 297: 3.62545e-05 298: 5.17922e-06 299: 3.62545e-05 300: 5.17922e-06 415: 0.000144462 416: 3.21343e-20 421: 3.59765e-05 422: -5.1395e-06 467: 3.59765e-05 468: -5.1395e-06 629: -2.07169e-05 666: -2.0558e-05 Row 416: 36: -1.0842e-19 59: 0.000144462 68: -0.000144462 81: -1.18585e-19 297: -5.17922e-06 298: -2.58961e-06 299: 5.17922e-06 300: 2.58961e-06 415: 3.21343e-20 416: 1.54781e-05 421: -5.1395e-06 422: 2.56975e-06 467: 5.1395e-06 468: -2.56975e-06 629: -8.57621e-21 666: -9.31736e-21 Row 417: 48: -0.000208835 59: -0.000760572 69: -0.000760572 76: -0.00017145 367: 3.48059e-05 368: 4.97227e-06 369: 3.48059e-05 370: 4.97227e-06 417: 0.000126762 418: -1.69407e-20 419: 2.85751e-05 420: -4.08215e-06 469: 2.85751e-05 470: -4.08215e-06 633: -1.98891e-05 655: -1.63286e-05 Row 418: 48: 1.11808e-19 59: 0.000126762 69: -0.000126762 76: -3.38813e-21 367: -4.97227e-06 368: -2.48614e-06 369: 4.97227e-06 370: 2.48614e-06 417: -1.69407e-20 418: 1.35816e-05 419: -4.08215e-06 420: 2.04108e-06 469: 4.08215e-06 470: -2.04108e-06 633: 8.25857e-21 655: -7.48248e-22 Row 419: 59: -0.000682846 69: -0.00017145 76: -0.000682846 81: -0.000169973 417: 2.85751e-05 418: -4.08215e-06 419: 0.000113808 420: 1.33408e-20 421: 2.83288e-05 422: -4.04697e-06 469: 2.85751e-05 470: 4.08215e-06 509: 2.83288e-05 510: -4.04697e-06 655: -1.63286e-05 668: -1.61879e-05 Row 420: 59: 0.000113808 69: -9.31736e-20 76: -0.000113808 81: -5.0822e-21 417: -4.08215e-06 418: 2.04108e-06 419: 1.33408e-20 420: 1.21937e-05 421: -4.04697e-06 422: 2.02349e-06 469: 4.08215e-06 470: 2.04108e-06 509: 4.04697e-06 510: -2.02349e-06 655: -7.30566e-21 668: -7.50892e-22 Row 421: 59: -0.000771664 68: -0.000215859 76: -0.000169973 81: -0.000771664 415: 3.59765e-05 416: -5.1395e-06 419: 2.83288e-05 420: -4.04697e-06 421: 0.000128611 422: 1.29702e-20 467: 3.59765e-05 468: 5.1395e-06 509: 2.83288e-05 510: 4.04697e-06 666: -2.0558e-05 668: -1.61879e-05 Row 422: 59: 0.000128611 68: -6.77626e-21 76: -9.23266e-20 81: -0.000128611 415: -5.1395e-06 416: 2.56975e-06 419: -4.04697e-06 420: 2.02349e-06 421: 1.29702e-20 422: 1.37797e-05 467: 5.1395e-06 468: 2.56975e-06 509: 4.04697e-06 510: 2.02349e-06 666: -1.11554e-21 668: -7.19978e-21 Row 423: 50: -0.000274002 60: -0.00104863 62: -0.00104863 77: -0.000250313 373: 4.5667e-05 374: 6.52386e-06 375: 4.5667e-05 376: 6.52386e-06 423: 0.000174772 424: -2.11758e-20 427: 4.17188e-05 428: -5.95983e-06 437: 4.17188e-05 438: -5.95983e-06 638: -2.60954e-05 658: -2.38393e-05 Row 424: 50: 1.38913e-19 60: 0.000174772 62: -0.000174772 77: -1.01644e-20 373: -6.52386e-06 374: -3.26193e-06 375: 6.52386e-06 376: 3.26193e-06 423: -2.11758e-20 424: 1.87255e-05 427: -5.95983e-06 428: 2.97992e-06 437: 5.95983e-06 438: -2.97992e-06 638: 1.07997e-20 658: -1.03041e-21 Row 425: 37: -0.000240863 60: -0.000968183 69: -0.000968183 77: -0.000243229 305: 4.01438e-05 306: 5.73483e-06 307: 4.01438e-05 308: 5.73483e-06 425: 0.000161364 426: 3.47284e-20 427: 4.05381e-05 428: -5.79116e-06 471: 4.05381e-05 472: -5.79116e-06 643: -2.29393e-05 656: -2.31646e-05 Row 426: 37: -1.21973e-19 60: 0.000161364 69: -0.000161364 77: -1.33831e-19 305: -5.73483e-06 306: -2.86741e-06 307: 5.73483e-06 308: 2.86741e-06 425: 3.47284e-20 426: 1.7289e-05 427: -5.79116e-06 428: 2.89558e-06 471: 5.79116e-06 472: -2.89558e-06 643: -9.31736e-21 656: -1.03762e-20 Row 427: 60: -0.000987084 62: -0.000250313 69: -0.000243229 77: -0.000987084 423: 4.17188e-05 424: -5.95983e-06 425: 4.05381e-05 426: -5.79116e-06 427: 0.000164514 428: 1.91641e-20 437: 4.17188e-05 438: 5.95983e-06 471: 4.05381e-05 472: 5.79116e-06 656: -2.31646e-05 658: -2.38393e-05 Row 428: 60: 0.000164514 62: -1.36372e-19 69: -6.77626e-21 77: -0.000164514 423: -5.95983e-06 424: 2.97992e-06 425: -5.79116e-06 426: 2.89558e-06 427: 1.91641e-20 428: 1.76265e-05 437: 5.95983e-06 438: 2.97992e-06 471: 5.79116e-06 472: 2.89558e-06 656: -1.32118e-21 658: -1.0482e-20 Row 429: 45: -0.000226033 61: -0.000909008 63: -0.000909008 79: -0.000228471 357: 3.76721e-05 358: 5.38173e-06 359: 3.76721e-05 360: 5.38173e-06 429: 0.000151501 430: -1.82112e-20 435: 3.80786e-05 436: -5.43979e-06 443: 3.80786e-05 444: -5.43979e-06 636: -2.15269e-05 660: -2.17592e-05 Row 430: 45: 1.21973e-19 61: 0.000151501 63: -0.000151501 79: -3.38813e-21 357: -5.38173e-06 358: -2.69087e-06 359: 5.38173e-06 360: 2.69087e-06 429: -1.82112e-20 430: 1.62323e-05 435: -5.43979e-06 436: 2.7199e-06 443: 5.43979e-06 444: -2.7199e-06 636: 8.78797e-21 660: -1.08483e-21 Row 431: 33: -0.000225119 61: -0.000834754 66: -0.000834754 78: -0.000192258 275: 3.75198e-05 276: 5.35997e-06 277: 3.75198e-05 278: 5.35997e-06 431: 0.000139126 432: 3.11814e-20 433: 3.20431e-05 434: -4.57758e-06 457: 3.20431e-05 458: -4.57758e-06 622: -2.14399e-05 659: -1.83103e-05 Row 432: 33: -1.15196e-19 61: 0.000139126 66: -0.000139126 78: -1.05032e-19 275: -5.35997e-06 276: -2.67999e-06 277: 5.35997e-06 278: 2.67999e-06 431: 3.11814e-20 432: 1.49063e-05 433: -4.57758e-06 434: 2.28879e-06 457: 4.57758e-06 458: -2.28879e-06 622: -8.47033e-21 659: -8.25857e-21 Row 433: 61: -0.000755477 66: -0.000192258 78: -0.000755477 79: -0.00018548 431: 3.20431e-05 432: -4.57758e-06 433: 0.000125913 434: 1.38172e-20 435: 3.09134e-05 436: -4.41619e-06 457: 3.20431e-05 458: 4.57758e-06 517: 3.09134e-05 518: -4.41619e-06 659: -1.83103e-05 661: -1.76648e-05 Row 434: 61: 0.000125913 66: -3.38813e-21 78: -0.000125913 79: -1.00797e-19 431: -4.57758e-06 432: 2.28879e-06 433: 1.38172e-20 434: 1.34907e-05 435: -4.41619e-06 436: 2.2081e-06 457: 4.57758e-06 458: 2.28879e-06 517: 4.41619e-06 518: -2.2081e-06 659: -9.77634e-22 661: -7.94093e-21 Row 435: 61: -0.000827903 63: -0.000228471 78: -0.00018548 79: -0.000827903 429: 3.80786e-05 430: -5.43979e-06 433: 3.09134e-05 434: -4.41619e-06 435: 0.000137984 436: 1.70465e-20 443: 3.80786e-05 444: 5.43979e-06 517: 3.09134e-05 518: 4.41619e-06 660: -2.17592e-05 661: -1.76648e-05 Row 436: 61: 0.000137984 63: -1.24514e-19 78: -6.77626e-21 79: -0.000137984 429: -5.43979e-06 430: 2.7199e-06 433: -4.41619e-06 434: 2.2081e-06 435: 1.70465e-20 436: 1.4784e-05 443: 5.43979e-06 444: 2.7199e-06 517: 4.41619e-06 518: 2.2081e-06 660: -9.74088e-21 661: -9.80977e-22 Row 437: 60: -0.000250313 62: -0.000935759 77: -0.000935759 83: -0.000217566 423: 4.17188e-05 424: 5.95983e-06 427: 4.17188e-05 428: 5.95983e-06 437: 0.00015596 438: 3.66871e-20 439: 3.62611e-05 440: -5.18015e-06 513: 3.62611e-05 514: -5.18015e-06 658: -2.38393e-05 673: -2.07206e-05 Row 438: 60: -1.25361e-19 62: 0.00015596 77: -0.00015596 83: -1.19432e-19 423: -5.95983e-06 424: -2.97992e-06 427: 5.95983e-06 428: 2.97992e-06 437: 3.66871e-20 438: 1.671e-05 439: -5.18015e-06 440: 2.59008e-06 513: 5.18015e-06 514: -2.59008e-06 658: -9.74088e-21 673: -9.52912e-21 Row 439: 58: -0.000232259 62: -0.00089965 77: -0.000217566 83: -0.00089965 407: 3.87098e-05 408: 5.52997e-06 413: 3.87098e-05 414: 5.52997e-06 437: 3.62611e-05 438: -5.18015e-06 439: 0.000149942 440: -1.73642e-20 513: 3.62611e-05 514: 5.18015e-06 672: -2.21199e-05 673: -2.07206e-05 Row 440: 58: 1.21973e-19 62: 0.000149942 77: -3.38813e-21 83: -0.000149942 407: -5.52997e-06 408: -2.76498e-06 413: 5.52997e-06 414: 2.76498e-06 437: -5.18015e-06 438: 2.59008e-06 439: -1.73642e-20 440: 1.60652e-05 513: 5.18015e-06 514: 2.59008e-06 672: 9.31736e-21 673: -1.09938e-21 Row 441: 57: -0.000271206 63: -0.000998344 74: -0.000998344 79: -0.000227966 401: 4.5201e-05 402: 6.45729e-06 405: 4.5201e-05 406: 6.45729e-06 441: 0.000166391 442: -2.20229e-20 443: 3.79943e-05 444: -5.42776e-06 497: 3.79943e-05 498: -5.42776e-06 651: -2.58292e-05 662: -2.1711e-05 Row 442: 57: 1.42302e-19 63: 0.000166391 74: -0.000166391 79: -6.77626e-21 401: -6.45729e-06 402: -3.22864e-06 405: 6.45729e-06 406: 3.22864e-06 441: -2.20229e-20 442: 1.78276e-05 443: -5.42776e-06 444: 2.71388e-06 497: 5.42776e-06 498: -2.71388e-06 651: 1.07997e-20 662: -8.39623e-22 Row 443: 61: -0.000228471 63: -0.000912874 74: -0.000227966 79: -0.000912874 429: 3.80786e-05 430: 5.43979e-06 435: 3.80786e-05 436: 5.43979e-06 441: 3.79943e-05 442: -5.42776e-06 443: 0.000152146 444: 3.57871e-20 497: 3.79943e-05 498: 5.42776e-06 660: -2.17592e-05 662: -2.1711e-05 Row 444: 61: -1.18585e-19 63: 0.000152146 74: -1.24514e-19 79: -0.000152146 429: -5.43979e-06 430: -2.7199e-06 435: 5.43979e-06 436: 2.7199e-06 441: -5.42776e-06 442: 2.71388e-06 443: 3.57871e-20 444: 1.63013e-05 497: 5.42776e-06 498: 2.71388e-06 660: -8.68209e-21 662: -9.84676e-21 Row 445: 53: -0.000254055 64: -0.0010093 65: -0.0010093 80: -0.000250597 383: 4.23426e-05 384: 6.04894e-06 385: 4.23426e-05 386: 6.04894e-06 445: 0.000168217 446: 3.92282e-20 449: 4.17661e-05 450: -5.96659e-06 453: 4.17661e-05 454: -5.96659e-06 635: -2.41957e-05 663: -2.38664e-05 Row 446: 53: -1.28749e-19 64: 0.000168217 65: -0.000168217 80: -1.37219e-19 383: -6.04894e-06 384: -3.02447e-06 385: 6.04894e-06 386: 3.02447e-06 445: 3.92282e-20 446: 1.80233e-05 449: -5.96659e-06 450: 2.98329e-06 453: 5.96659e-06 454: -2.98329e-06 635: -9.84676e-21 663: -1.11173e-20 Row 447: 56: -0.000176827 64: -0.000711186 75: -0.000711186 80: -0.000178767 393: 2.94711e-05 394: 4.21016e-06 399: 2.94711e-05 400: 4.21016e-06 447: 0.000118531 448: -1.3129e-20 449: 2.97944e-05 450: -4.25635e-06 503: 2.97944e-05 504: -4.25635e-06 653: -1.68406e-05 665: -1.70254e-05 Row 448: 56: 9.14796e-20 64: 0.000118531 75: -0.000118531 80: -5.0822e-21 393: -4.21016e-06 394: -2.10508e-06 399: 4.21016e-06 400: 2.10508e-06 447: -1.3129e-20 448: 1.26998e-05 449: -4.25635e-06 450: 2.12817e-06 503: 4.25635e-06 504: -2.12817e-06 653: 6.88214e-21 665: -8.83364e-22 Row 449: 64: -0.000858727 65: -0.000250597 75: -0.000178767 80: -0.000858727 445: 4.17661e-05 446: -5.96659e-06 447: 2.97944e-05 448: -4.25635e-06 449: 0.000143121 450: 1.43466e-20 453: 4.17661e-05 454: 5.96659e-06 503: 2.97944e-05 504: 4.25635e-06 663: -2.38664e-05 665: -1.70254e-05 Row 450: 64: 0.000143121 65: -1.01644e-20 75: -9.82558e-20 80: -0.000143121 445: -5.96659e-06 446: 2.98329e-06 447: -4.25635e-06 448: 2.12817e-06 449: 1.43466e-20 450: 1.53344e-05 453: 5.96659e-06 454: 2.98329e-06 503: 4.25635e-06 504: 2.12817e-06 663: -1.25054e-21 665: -7.51742e-21 Row 451: 40: -0.000267245 65: -0.00104126 70: -0.00104126 80: -0.000253384 327: 4.45408e-05 328: 6.36296e-06 329: 4.45408e-05 330: 6.36296e-06 451: 0.000173543 452: 4.00752e-20 453: 4.22306e-05 454: -6.03294e-06 475: 4.22306e-05 476: -6.03294e-06 645: -2.54519e-05 664: -2.41318e-05 Row 452: 40: -1.38913e-19 65: 0.000173543 70: -0.000173543 80: -1.38913e-19 327: -6.36296e-06 328: -3.18148e-06 329: 6.36296e-06 330: 3.18148e-06 451: 4.00752e-20 452: 1.85939e-05 453: -6.03294e-06 454: 3.01647e-06 475: 6.03294e-06 476: -3.01647e-06 645: -1.03762e-20 664: -1.09055e-20 Row 453: 64: -0.000250597 65: -0.00100796 70: -0.000253384 80: -0.00100796 445: 4.17661e-05 446: 5.96659e-06 449: 4.17661e-05 450: 5.96659e-06 451: 4.22306e-05 452: -6.03294e-06 453: 0.000167993 454: -2.28699e-20 475: 4.22306e-05 476: 6.03294e-06 663: -2.38664e-05 664: -2.41318e-05 Row 454: 64: 1.28749e-19 65: 0.000167993 70: -5.0822e-21 80: -0.000167993 445: -5.96659e-06 446: -2.98329e-06 449: 5.96659e-06 450: 2.98329e-06 451: -6.03294e-06 452: 3.01647e-06 453: -2.28699e-20 454: 1.79993e-05 475: 6.03294e-06 476: 3.01647e-06 663: 1.02703e-20 664: -1.35543e-21 Row 455: 44: -0.000263367 66: -0.001051 67: -0.001051 82: -0.000262131 353: 4.38944e-05 354: 6.27063e-06 355: 4.38944e-05 356: 6.27063e-06 455: 0.000175166 456: 4.04988e-20 459: 4.36886e-05 460: -6.24122e-06 463: 4.36886e-05 464: -6.24122e-06 624: -2.50825e-05 671: -2.49649e-05 Row 456: 44: -1.35525e-19 66: 0.000175166 67: -0.000175166 82: -1.43996e-19 353: -6.27063e-06 354: -3.13532e-06 355: 6.27063e-06 356: 3.13532e-06 455: 4.04988e-20 456: 1.87678e-05 459: -6.24122e-06 460: 3.12061e-06 463: 6.24122e-06 464: -3.12061e-06 624: -1.01644e-20 671: -1.13291e-20 Row 457: 61: -0.000192258 66: -0.00076639 78: -0.00076639 82: -0.000190936 431: 3.20431e-05 432: 4.57758e-06 433: 3.20431e-05 434: 4.57758e-06 457: 0.000127732 458: -1.60936e-20 459: 3.18227e-05 460: -4.5461e-06 519: 3.18227e-05 520: -4.5461e-06 659: -1.83103e-05 676: -1.81844e-05 Row 458: 61: 9.82558e-20 66: 0.000127732 78: -0.000127732 82: -5.0822e-21 431: -4.57758e-06 432: -2.28879e-06 433: 4.57758e-06 434: 2.28879e-06 457: -1.60936e-20 458: 1.36855e-05 459: -4.5461e-06 460: 2.27305e-06 519: 4.5461e-06 520: -2.27305e-06 659: 7.72918e-21 676: -9.55124e-22 Row 459: 66: -0.000906135 67: -0.000262131 78: -0.000190936 82: -0.000906135 455: 4.36886e-05 456: -6.24122e-06 457: 3.18227e-05 458: -4.5461e-06 459: 0.000151023 460: 1.58819e-20 463: 4.36886e-05 464: 6.24122e-06 519: 3.18227e-05 520: 4.5461e-06 671: -2.49649e-05 676: -1.81844e-05 Row 460: 66: 0.000151023 67: -5.0822e-21 78: -1.04185e-19 82: -0.000151023 455: -6.24122e-06 456: 3.12061e-06 457: -4.5461e-06 458: 2.27305e-06 459: 1.58819e-20 460: 1.6181e-05 463: 6.24122e-06 464: 3.12061e-06 519: 4.5461e-06 520: 2.27305e-06 671: -1.39356e-21 676: -8.04681e-21 Row 461: 43: -0.000263348 67: -0.00104527 71: -0.00104527 82: -0.000259286 349: 4.38913e-05 350: 6.27019e-06 351: 4.38913e-05 352: 6.27019e-06 461: 0.000174211 462: 3.91223e-20 463: 4.32143e-05 464: -6.17347e-06 479: 4.32143e-05 480: -6.17347e-06 648: -2.50808e-05 669: -2.46939e-05 Row 462: 43: -1.32137e-19 67: 0.000174211 71: -0.000174211 82: -1.43996e-19 349: -6.27019e-06 350: -3.1351e-06 351: 6.27019e-06 352: 3.1351e-06 461: 3.91223e-20 462: 1.86655e-05 463: -6.17347e-06 464: 3.08674e-06 479: 6.17347e-06 480: -3.08674e-06 648: -1.05879e-20 669: -1.12232e-20 Row 463: 66: -0.000262131 67: -0.00104283 71: -0.000259286 82: -0.00104283 455: 4.36886e-05 456: 6.24122e-06 459: 4.36886e-05 460: 6.24122e-06 461: 4.32143e-05 462: -6.17347e-06 463: 0.000173806 464: -1.99053e-20 479: 4.32143e-05 480: 6.17347e-06 669: -2.46939e-05 671: -2.49649e-05 Row 464: 66: 1.32137e-19 67: 0.000173806 71: -6.77626e-21 82: -0.000173806 455: -6.24122e-06 456: -3.12061e-06 459: 6.24122e-06 460: 3.12061e-06 461: -6.17347e-06 462: 3.08674e-06 463: -1.99053e-20 464: 1.8622e-05 479: 6.17347e-06 480: 3.08674e-06 669: -1.17421e-21 671: 1.02703e-20 Row 465: 57: -0.000271136 68: -0.000982786 74: -0.000982786 81: -0.000220257 403: 4.51893e-05 404: 6.45561e-06 405: 4.51893e-05 406: 6.45561e-06 465: 0.000163798 466: 3.5893e-20 467: 3.67095e-05 468: -5.24422e-06 499: 3.67095e-05 500: -5.24422e-06 652: -2.58224e-05 667: -2.09769e-05 Row 466: 57: -1.38913e-19 68: 0.000163798 74: -0.000163798 81: -1.21126e-19 403: -6.45561e-06 404: -3.2278e-06 405: 6.45561e-06 406: 3.2278e-06 465: 3.5893e-20 466: 1.75497e-05 467: -5.24422e-06 468: 2.62211e-06 499: 5.24422e-06 500: -2.62211e-06 652: -1.05879e-20 667: -9.74088e-21 Row 467: 59: -0.000215859 68: -0.000872232 74: -0.000220257 81: -0.000872232 415: 3.59765e-05 416: 5.1395e-06 421: 3.59765e-05 422: 5.1395e-06 465: 3.67095e-05 466: -5.24422e-06 467: 0.000145372 468: -1.56701e-20 499: 3.67095e-05 500: 5.24422e-06 666: -2.0558e-05 667: -2.09769e-05 Row 468: 59: 1.11808e-19 68: 0.000145372 74: -6.77626e-21 81: -0.000145372 415: -5.1395e-06 416: -2.56975e-06 421: 5.1395e-06 422: 2.56975e-06 465: -5.24422e-06 466: 2.62211e-06 467: -1.56701e-20 468: 1.55756e-05 499: 5.24422e-06 500: 2.62211e-06 666: 8.57621e-21 667: -1.18203e-21 Row 469: 59: -0.00017145 69: -0.000688372 76: -0.000688372 77: -0.000172736 417: 2.85751e-05 418: 4.08215e-06 419: 2.85751e-05 420: 4.08215e-06 469: 0.000114729 470: 2.69992e-20 471: 2.87893e-05 472: -4.11275e-06 507: 2.87893e-05 508: -4.11275e-06 655: -1.63286e-05 657: -1.6451e-05 Row 470: 59: -8.47033e-20 69: 0.000114729 76: -0.000114729 77: -9.40207e-20 417: -4.08215e-06 418: -2.04108e-06 419: 4.08215e-06 420: 2.04108e-06 469: 2.69992e-20 470: 1.22924e-05 471: -4.11275e-06 472: 2.05638e-06 507: 4.11275e-06 508: -2.05638e-06 655: -6.77626e-21 657: -7.30566e-21 Row 471: 60: -0.000243229 69: -0.000831929 76: -0.000172736 77: -0.000831929 425: 4.05381e-05 426: 5.79116e-06 427: 4.05381e-05 428: 5.79116e-06 469: 2.87893e-05 470: -4.11275e-06 471: 0.000138655 472: -1.99053e-20 507: 2.87893e-05 508: 4.11275e-06 656: -2.31646e-05 657: -1.6451e-05 Row 472: 60: 1.18585e-19 69: 0.000138655 76: -5.0822e-21 77: -0.000138655 425: -5.79116e-06 426: -2.89558e-06 427: 5.79116e-06 428: 2.89558e-06 469: -4.11275e-06 470: 2.05638e-06 471: -1.99053e-20 472: 1.48559e-05 507: 4.11275e-06 508: 2.05638e-06 656: 9.95264e-21 657: -9.59613e-22 Row 473: 58: -0.000232986 70: -0.000904078 73: -0.000904078 80: -0.000219053 409: 3.88309e-05 410: 5.54728e-06 411: 3.88309e-05 412: 5.54728e-06 473: 0.00015068 474: 3.34049e-20 475: 3.65089e-05 476: -5.21555e-06 489: 3.65089e-05 490: -5.21555e-06 650: -2.21891e-05 675: -2.08622e-05 Row 474: 58: -1.18585e-19 70: 0.00015068 73: -0.00015068 80: -1.20279e-19 409: -5.54728e-06 410: -2.77364e-06 411: 5.54728e-06 412: 2.77364e-06 473: 3.34049e-20 474: 1.61442e-05 475: -5.21555e-06 476: 2.60778e-06 489: 5.21555e-06 490: -2.60778e-06 650: -8.89385e-21 675: -9.42324e-21 Row 475: 65: -0.000253384 70: -0.000944874 73: -0.000219053 80: -0.000944874 451: 4.22306e-05 452: 6.03294e-06 453: 4.22306e-05 454: 6.03294e-06 473: 3.65089e-05 474: -5.21555e-06 475: 0.000157479 476: -1.77877e-20 489: 3.65089e-05 490: 5.21555e-06 664: -2.41318e-05 675: -2.08622e-05 Row 476: 65: 1.28749e-19 70: 0.000157479 73: -6.77626e-21 80: -0.000157479 451: -6.03294e-06 452: -3.01647e-06 453: 6.03294e-06 454: 3.01647e-06 473: -5.21555e-06 474: 2.60778e-06 475: -1.77877e-20 476: 1.68727e-05 489: 5.21555e-06 490: 2.60778e-06 664: 9.74088e-21 675: -1.20145e-21 Row 477: 56: -0.000220064 71: -0.000875208 72: -0.000875208 82: -0.00021754 395: 3.66774e-05 396: 5.23962e-06 397: 3.66774e-05 398: 5.23962e-06 477: 0.000145868 478: 3.30872e-20 479: 3.62567e-05 480: -5.17952e-06 483: 3.62567e-05 484: -5.17952e-06 649: -2.09585e-05 670: -2.07181e-05 Row 478: 56: -1.11808e-19 71: 0.000145868 72: -0.000145868 82: -1.18585e-19 395: -5.23962e-06 396: -2.61981e-06 397: 5.23962e-06 398: 2.61981e-06 477: 3.30872e-20 478: 1.56287e-05 479: -5.17952e-06 480: 2.58976e-06 483: 5.17952e-06 484: -2.58976e-06 649: -8.68209e-21 670: -9.52912e-21 Row 479: 67: -0.000259286 71: -0.000953652 72: -0.00021754 82: -0.000953652 461: 4.32143e-05 462: 6.17347e-06 463: 4.32143e-05 464: 6.17347e-06 477: 3.62567e-05 478: -5.17952e-06 479: 0.000158942 480: -2.07523e-20 483: 3.62567e-05 484: 5.17952e-06 669: -2.46939e-05 670: -2.07181e-05 Row 480: 67: 1.32137e-19 71: 0.000158942 72: -3.38813e-21 82: -0.000158942 461: -6.17347e-06 462: -3.08674e-06 463: 6.17347e-06 464: 3.08674e-06 477: -5.17952e-06 478: 2.58976e-06 479: -2.07523e-20 480: 1.70295e-05 483: 5.17952e-06 484: 2.58976e-06 669: 1.06938e-20 670: -1.07255e-21 Row 481: 56: -0.000176495 72: -0.000706269 75: -0.000706269 84: -0.00017664 397: 2.94158e-05 398: 4.20226e-06 399: 2.94158e-05 400: 4.20226e-06 481: 0.000117712 482: 2.65227e-20 485: 2.944e-05 486: -4.20571e-06 505: 2.944e-05 506: -4.20571e-06 654: -1.6809e-05 679: -1.68229e-05 Row 482: 56: -9.14796e-20 72: 0.000117712 75: -0.000117712 84: -9.57147e-20 397: -4.20226e-06 398: -2.10113e-06 399: 4.20226e-06 400: 2.10113e-06 481: 2.65227e-20 482: 1.2612e-05 485: -4.20571e-06 486: 2.10286e-06 505: 4.20571e-06 506: -2.10286e-06 654: -6.98802e-21 679: -7.72918e-21 Row 483: 71: -0.00021754 72: -0.000926592 82: -0.000926592 86: -0.000245756 477: 3.62567e-05 478: 5.17952e-06 479: 3.62567e-05 480: 5.17952e-06 483: 0.000154432 484: -1.73642e-20 487: 4.09593e-05 488: -5.85133e-06 533: 4.09593e-05 534: -5.85133e-06 670: -2.07181e-05 682: -2.34053e-05 Row 484: 71: 1.0842e-19 72: 0.000154432 82: -0.000154432 86: -6.77626e-21 477: -5.17952e-06 478: -2.58976e-06 479: 5.17952e-06 480: 2.58976e-06 483: -1.73642e-20 484: 1.65463e-05 487: -5.85133e-06 488: 2.92566e-06 533: 5.85133e-06 534: -2.92566e-06 670: 8.47033e-21 682: -1.0622e-21 Row 485: 72: -0.000842304 75: -0.00017664 84: -0.000842304 86: -0.000244512 481: 2.944e-05 482: -4.20571e-06 485: 0.000140384 486: 1.8423e-20 487: 4.0752e-05 488: -5.82172e-06 505: 2.944e-05 506: 4.20571e-06 539: 4.0752e-05 540: -5.82172e-06 679: -1.68229e-05 683: -2.32869e-05 Row 486: 72: 0.000140384 75: -5.0822e-21 84: -0.000140384 86: -1.32984e-19 481: -4.20571e-06 482: 2.10286e-06 485: 1.8423e-20 486: 1.50411e-05 487: -5.82172e-06 488: 2.91086e-06 505: 4.20571e-06 506: 2.10286e-06 539: 5.82172e-06 540: -2.91086e-06 679: -8.6112e-22 683: -1.09055e-20 Row 487: 72: -0.000980536 82: -0.000245756 84: -0.000244512 86: -0.000980536 483: 4.09593e-05 484: -5.85133e-06 485: 4.0752e-05 486: -5.82172e-06 487: 0.000163423 488: 1.87406e-20 533: 4.09593e-05 534: 5.85133e-06 539: 4.0752e-05 540: 5.82172e-06 682: -2.34053e-05 683: -2.32869e-05 Row 488: 72: 0.000163423 82: -1.33831e-19 84: -3.38813e-21 86: -0.000163423 483: -5.85133e-06 484: 2.92566e-06 485: -5.82172e-06 486: 2.91086e-06 487: 1.87406e-20 488: 1.75096e-05 533: 5.85133e-06 534: 2.92566e-06 539: 5.82172e-06 540: 2.91086e-06 682: -1.01644e-20 683: -1.14236e-21 Row 489: 70: -0.000219053 73: -0.000878763 80: -0.000878763 84: -0.000220328 473: 3.65089e-05 474: 5.21555e-06 475: 3.65089e-05 476: 5.21555e-06 489: 0.00014646 490: -1.94818e-20 493: 3.67214e-05 494: -5.24591e-06 527: 3.67214e-05 528: -5.24591e-06 675: -2.08622e-05 677: -2.09836e-05 Row 490: 70: 1.11808e-19 73: 0.00014646 80: -0.00014646 84: -5.0822e-21 473: -5.21555e-06 474: -2.60778e-06 475: 5.21555e-06 476: 2.60778e-06 489: -1.94818e-20 490: 1.56922e-05 493: -5.24591e-06 494: 2.62295e-06 527: 5.24591e-06 528: -2.62295e-06 675: 8.78797e-21 677: -9.09796e-22 Row 491: 58: -0.000217076 73: -0.000883491 83: -0.000883491 88: -0.00022467 411: 3.61793e-05 412: 5.16847e-06 413: 3.61793e-05 414: 5.16847e-06 491: 0.000147248 492: 3.37754e-20 495: 3.74449e-05 496: -5.34928e-06 537: 3.74449e-05 538: -5.34928e-06 674: -2.06739e-05 691: -2.13971e-05 Row 492: 58: -1.15196e-19 73: 0.000147248 83: -0.000147248 88: -1.2282e-19 411: -5.16847e-06 412: -2.58423e-06 413: 5.16847e-06 414: 2.58423e-06 491: 3.37754e-20 492: 1.57766e-05 495: -5.34928e-06 496: 2.67464e-06 537: 5.34928e-06 538: -2.67464e-06 674: -8.57621e-21 691: -9.74088e-21 Row 493: 73: -0.000862345 80: -0.000220328 84: -0.000862345 88: -0.000210845 489: 3.67214e-05 490: -5.24591e-06 493: 0.000143724 494: 1.61995e-20 495: 3.51408e-05 496: -5.02011e-06 527: 3.67214e-05 528: 5.24591e-06 541: 3.51408e-05 542: -5.02011e-06 677: -2.09836e-05 690: -2.00804e-05 Row 494: 73: 0.000143724 80: -1.20279e-19 84: -0.000143724 88: -6.77626e-21 489: -5.24591e-06 490: 2.62295e-06 493: 1.61995e-20 494: 1.5399e-05 495: -5.02011e-06 496: 2.51005e-06 527: 5.24591e-06 528: 2.62295e-06 541: 5.02011e-06 542: -2.51005e-06 677: -9.31736e-21 690: -7.87299e-22 Row 495: 73: -0.000871029 83: -0.00022467 84: -0.000210845 88: -0.000871029 491: 3.74449e-05 492: -5.34928e-06 493: 3.51408e-05 494: -5.02011e-06 495: 0.000145171 496: 1.72583e-20 537: 3.74449e-05 538: 5.34928e-06 541: 3.51408e-05 542: 5.02011e-06 690: -2.00804e-05 691: -2.13971e-05 Row 496: 73: 0.000145171 83: -5.0822e-21 84: -1.13502e-19 88: -0.000145171 491: -5.34928e-06 492: 2.67464e-06 493: -5.02011e-06 494: 2.51005e-06 495: 1.72583e-20 496: 1.55541e-05 537: 5.34928e-06 538: 2.67464e-06 541: 5.02011e-06 542: 2.51005e-06 690: -8.89385e-21 691: -1.02269e-21 Row 497: 63: -0.000227966 74: -0.000908612 79: -0.000908612 87: -0.00022634 441: 3.79943e-05 442: 5.42776e-06 443: 3.79943e-05 444: 5.42776e-06 497: 0.000151435 498: 3.43578e-20 501: 3.77234e-05 502: -5.38906e-06 525: 3.77234e-05 526: -5.38906e-06 662: -2.1711e-05 686: -2.15562e-05 Row 498: 63: -1.18585e-19 74: 0.000151435 79: -0.000151435 87: -1.23667e-19 441: -5.42776e-06 442: -2.71388e-06 443: 5.42776e-06 444: 2.71388e-06 497: 3.43578e-20 498: 1.62252e-05 501: -5.38906e-06 502: 2.69453e-06 525: 5.38906e-06 526: -2.69453e-06 662: -8.89385e-21 686: -9.74088e-21 Row 499: 68: -0.000220257 74: -0.000881463 81: -0.000881463 87: -0.000220474 465: 3.67095e-05 466: 5.24422e-06 467: 3.67095e-05 468: 5.24422e-06 499: 0.00014691 500: -1.69407e-20 501: 3.67457e-05 502: -5.24938e-06 531: 3.67457e-05 532: -5.24938e-06 667: -2.09769e-05 688: -2.09975e-05 Row 500: 68: 1.11808e-19 74: 0.00014691 81: -0.00014691 87: -5.0822e-21 465: -5.24422e-06 466: -2.62211e-06 467: 5.24422e-06 468: 2.62211e-06 499: -1.69407e-20 500: 1.57404e-05 501: -5.24938e-06 502: 2.62469e-06 531: 5.24938e-06 532: -2.62469e-06 667: 8.89385e-21 688: -1.06453e-21 Row 501: 74: -0.000893629 79: -0.00022634 81: -0.000220474 87: -0.000893629 497: 3.77234e-05 498: -5.38906e-06 499: 3.67457e-05 500: -5.24938e-06 501: 0.000148938 502: 1.56701e-20 525: 3.77234e-05 526: 5.38906e-06 531: 3.67457e-05 532: 5.24938e-06 686: -2.15562e-05 688: -2.09975e-05 Row 502: 74: 0.000148938 79: -6.77626e-21 81: -1.20279e-19 87: -0.000148938 497: -5.38906e-06 498: 2.69453e-06 499: -5.24938e-06 500: 2.62469e-06 501: 1.56701e-20 502: 1.59577e-05 525: 5.38906e-06 526: 2.69453e-06 531: 5.24938e-06 532: 2.62469e-06 686: -1.05437e-21 688: -9.42324e-21 Row 503: 64: -0.000178767 75: -0.000716248 80: -0.000716248 84: -0.000179357 447: 2.97944e-05 448: 4.25635e-06 449: 2.97944e-05 450: 4.25635e-06 503: 0.000119375 504: 2.69462e-20 505: 2.98929e-05 506: -4.27041e-06 527: 2.98929e-05 528: -4.27041e-06 665: -1.70254e-05 678: -1.70817e-05 Row 504: 64: -9.48677e-20 75: 0.000119375 80: -0.000119375 84: -9.74088e-20 447: -4.25635e-06 448: -2.12817e-06 449: 4.25635e-06 450: 2.12817e-06 503: 2.69462e-20 504: 1.27901e-05 505: -4.27041e-06 506: 2.13521e-06 527: 4.27041e-06 528: -2.13521e-06 665: -6.98802e-21 678: -7.72918e-21 Row 505: 72: -0.00017664 75: -0.000711995 80: -0.000179357 84: -0.000711995 481: 2.944e-05 482: 4.20571e-06 485: 2.944e-05 486: 4.20571e-06 503: 2.98929e-05 504: -4.27041e-06 505: 0.000118666 506: -1.43996e-20 527: 2.98929e-05 528: 4.27041e-06 678: -1.70817e-05 679: -1.68229e-05 Row 506: 72: 9.14796e-20 75: 0.000118666 80: -5.0822e-21 84: -0.000118666 481: -4.20571e-06 482: -2.10286e-06 485: 4.20571e-06 486: 2.10286e-06 503: -4.27041e-06 504: 2.13521e-06 505: -1.43996e-20 506: 1.27142e-05 527: 4.27041e-06 528: 2.13521e-06 678: -1.02421e-21 679: 6.98802e-21 Row 507: 69: -0.000172736 76: -0.000688336 77: -0.000688336 85: -0.000171432 469: 2.87893e-05 470: 4.11275e-06 471: 2.87893e-05 472: 4.11275e-06 507: 0.000114723 508: -1.35525e-20 511: 2.8572e-05 512: -4.08172e-06 515: 2.8572e-05 516: -4.08172e-06 657: -1.6451e-05 680: -1.63269e-05 Row 508: 69: 8.80914e-20 76: 0.000114723 77: -0.000114723 85: -5.0822e-21 469: -4.11275e-06 470: -2.05638e-06 471: 4.11275e-06 472: 2.05638e-06 507: -1.35525e-20 508: 1.22917e-05 511: -4.08172e-06 512: 2.04086e-06 515: 4.08172e-06 516: -2.04086e-06 657: 6.67038e-21 680: -7.10701e-22 Row 509: 59: -0.000169973 76: -0.000679822 81: -0.000679822 85: -0.000169938 419: 2.83288e-05 420: 4.04697e-06 421: 2.83288e-05 422: 4.04697e-06 509: 0.000113304 510: 2.5358e-20 511: 2.83231e-05 512: -4.04615e-06 529: 2.83231e-05 530: -4.04615e-06 668: -1.61879e-05 689: -1.61846e-05 Row 510: 59: -8.80914e-20 76: 0.000113304 81: -0.000113304 85: -9.23266e-20 419: -4.04697e-06 420: -2.02349e-06 421: 4.04697e-06 422: 2.02349e-06 509: 2.5358e-20 510: 1.21397e-05 511: -4.04615e-06 512: 2.02308e-06 529: 4.04615e-06 530: -2.02308e-06 668: -6.56451e-21 689: -7.41154e-21 Row 511: 76: -0.000682741 77: -0.000171432 81: -0.000169938 85: -0.000682741 507: 2.8572e-05 508: -4.08172e-06 509: 2.83231e-05 510: -4.04615e-06 511: 0.00011379 512: 1.34466e-20 515: 2.8572e-05 516: 4.08172e-06 529: 2.83231e-05 530: 4.04615e-06 680: -1.63269e-05 689: -1.61846e-05 Row 512: 76: 0.00011379 77: -9.31736e-20 81: -5.0822e-21 85: -0.00011379 507: -4.08172e-06 508: 2.04086e-06 509: -4.04615e-06 510: 2.02308e-06 511: 1.34466e-20 512: 1.21918e-05 515: 4.08172e-06 516: 2.04086e-06 529: 4.04615e-06 530: 2.02308e-06 680: -7.30566e-21 689: -7.95905e-22 Row 513: 62: -0.000217566 77: -0.000859447 83: -0.000859447 85: -0.000212157 437: 3.62611e-05 438: 5.18015e-06 439: 3.62611e-05 440: 5.18015e-06 513: 0.000143241 514: -1.86347e-20 515: 3.53595e-05 516: -5.05136e-06 535: 3.53595e-05 536: -5.05136e-06 673: -2.07206e-05 681: -2.02054e-05 Row 514: 62: 1.15196e-19 77: 0.000143241 83: -0.000143241 85: -8.47033e-21 437: -5.18015e-06 438: -2.59008e-06 439: 5.18015e-06 440: 2.59008e-06 513: -1.86347e-20 514: 1.53473e-05 515: -5.05136e-06 516: 2.52568e-06 535: 5.05136e-06 536: -2.52568e-06 673: 8.25857e-21 681: -9.7042e-22 Row 515: 76: -0.000171432 77: -0.000767179 83: -0.000212157 85: -0.000767179 507: 2.8572e-05 508: 4.08172e-06 511: 2.8572e-05 512: 4.08172e-06 513: 3.53595e-05 514: -5.05136e-06 515: 0.000127863 516: 2.87991e-20 535: 3.53595e-05 536: 5.05136e-06 680: -1.63269e-05 681: -2.02054e-05 Row 516: 76: -8.80914e-20 77: 0.000127863 83: -1.14349e-19 85: -0.000127863 507: -4.08172e-06 508: -2.04086e-06 511: 4.08172e-06 512: 2.04086e-06 513: -5.05136e-06 514: 2.52568e-06 515: 2.87991e-20 516: 1.36996e-05 535: 5.05136e-06 536: 2.52568e-06 680: -6.35275e-21 681: -9.31736e-21 Row 517: 61: -0.00018548 78: -0.00079569 79: -0.00079569 86: -0.000212365 433: 3.09134e-05 434: 4.41619e-06 435: 3.09134e-05 436: 4.41619e-06 517: 0.000132615 518: -1.52466e-20 521: 3.53941e-05 522: -5.0563e-06 523: 3.53941e-05 524: -5.0563e-06 661: -1.76648e-05 685: -2.02252e-05 Row 518: 61: 9.48677e-20 78: 0.000132615 79: -0.000132615 86: -6.77626e-21 433: -4.41619e-06 434: -2.2081e-06 435: 4.41619e-06 436: 2.2081e-06 517: -1.52466e-20 518: 1.42087e-05 521: -5.0563e-06 522: 2.52815e-06 523: 5.0563e-06 524: -2.52815e-06 661: 7.19978e-21 685: -9.73181e-22 Row 519: 66: -0.000190936 78: -0.000814086 82: -0.000814086 86: -0.000216107 457: 3.18227e-05 458: 4.5461e-06 459: 3.18227e-05 460: 4.5461e-06 519: 0.000135681 520: 3.20284e-20 521: 3.60178e-05 522: -5.1454e-06 533: 3.60178e-05 534: -5.1454e-06 676: -1.81844e-05 684: -2.05816e-05 Row 520: 66: -9.82558e-20 78: 0.000135681 82: -0.000135681 86: -1.17738e-19 457: -4.5461e-06 458: -2.27305e-06 459: 4.5461e-06 460: 2.27305e-06 519: 3.20284e-20 520: 1.45372e-05 521: -5.1454e-06 522: 2.5727e-06 533: 5.1454e-06 534: -2.5727e-06 676: -7.30566e-21 684: -9.42324e-21 Row 521: 78: -0.000856943 79: -0.000212365 82: -0.000216107 86: -0.000856943 517: 3.53941e-05 518: -5.0563e-06 519: 3.60178e-05 520: -5.1454e-06 521: 0.000142824 522: 1.59348e-20 523: 3.53941e-05 524: 5.0563e-06 533: 3.60178e-05 534: 5.1454e-06 684: -2.05816e-05 685: -2.02252e-05 Row 522: 78: 0.000142824 79: -1.16044e-19 82: -8.47033e-21 86: -0.000142824 517: -5.0563e-06 518: 2.52815e-06 519: -5.1454e-06 520: 2.5727e-06 521: 1.59348e-20 522: 1.53025e-05 523: 5.0563e-06 524: 2.52815e-06 533: 5.1454e-06 534: 2.5727e-06 684: -1.27997e-21 685: -9.1056e-21 Row 523: 78: -0.000212365 79: -0.000916281 86: -0.000916281 87: -0.000245776 517: 3.53941e-05 518: 5.0563e-06 521: 3.53941e-05 522: 5.0563e-06 523: 0.000152714 524: 3.47813e-20 525: 4.09627e-05 526: -5.85181e-06 547: 4.09627e-05 548: -5.85181e-06 685: -2.02252e-05 687: -2.34072e-05 Row 524: 78: -1.0842e-19 79: 0.000152714 86: -0.000152714 87: -1.34678e-19 517: -5.0563e-06 518: -2.52815e-06 521: 5.0563e-06 522: 2.52815e-06 523: 3.47813e-20 524: 1.63622e-05 525: -5.85181e-06 526: 2.9259e-06 547: 5.85181e-06 548: -2.9259e-06 685: -8.25857e-21 687: -1.05879e-20 Row 525: 74: -0.00022634 79: -0.000944233 86: -0.000245776 87: -0.000944233 497: 3.77234e-05 498: 5.38906e-06 501: 3.77234e-05 502: 5.38906e-06 523: 4.09627e-05 524: -5.85181e-06 525: 0.000157372 526: -1.69407e-20 547: 4.09627e-05 548: 5.85181e-06 686: -2.15562e-05 687: -2.34072e-05 Row 526: 74: 1.15196e-19 79: 0.000157372 86: -5.0822e-21 87: -0.000157372 497: -5.38906e-06 498: -2.69453e-06 501: 5.38906e-06 502: 2.69453e-06 523: -5.85181e-06 524: 2.9259e-06 525: -1.69407e-20 526: 1.68613e-05 547: 5.85181e-06 548: 2.9259e-06 686: 9.1056e-21 687: -1.1763e-21 Row 527: 73: -0.000220328 75: -0.000179357 80: -0.000799371 84: -0.000799371 489: 3.67214e-05 490: 5.24591e-06 493: 3.67214e-05 494: 5.24591e-06 503: 2.98929e-05 504: 4.27041e-06 505: 2.98929e-05 506: 4.27041e-06 527: 0.000133229 528: 1.69407e-21 677: -2.09836e-05 678: -1.70817e-05 Row 528: 73: -1.11808e-19 75: 9.14796e-20 80: 0.000133229 84: -0.000133229 489: -5.24591e-06 490: -2.62295e-06 493: 5.24591e-06 494: 2.62295e-06 503: -4.27041e-06 504: -2.13521e-06 505: 4.27041e-06 506: 2.13521e-06 527: 1.69407e-21 528: 1.42745e-05 677: -8.68209e-21 678: 6.98802e-21 Row 529: 76: -0.000169938 81: -0.000762086 85: -0.000762086 87: -0.000211105 509: 2.83231e-05 510: 4.04615e-06 511: 2.83231e-05 512: 4.04615e-06 529: 0.000127014 530: -1.3129e-20 531: 3.51841e-05 532: -5.0263e-06 543: 3.51841e-05 544: -5.0263e-06 689: -1.61846e-05 694: -2.01052e-05 Row 530: 76: 8.80914e-20 81: 0.000127014 85: -0.000127014 87: -5.0822e-21 509: -4.04615e-06 510: -2.02308e-06 511: 4.04615e-06 512: 2.02308e-06 529: -1.3129e-20 530: 1.36087e-05 531: -5.0263e-06 532: 2.51315e-06 543: 5.0263e-06 544: -2.51315e-06 689: 6.98802e-21 694: -8.72046e-22 Row 531: 74: -0.000220474 81: -0.000863158 85: -0.000211105 87: -0.000863158 499: 3.67457e-05 500: 5.24938e-06 501: 3.67457e-05 502: 5.24938e-06 529: 3.51841e-05 530: -5.0263e-06 531: 0.00014386 532: 3.1499e-20 543: 3.51841e-05 544: 5.0263e-06 688: -2.09975e-05 694: -2.01052e-05 Row 532: 74: -1.15196e-19 81: 0.00014386 85: -1.14349e-19 87: -0.00014386 499: -5.24938e-06 500: -2.62469e-06 501: 5.24938e-06 502: 2.62469e-06 529: -5.0263e-06 530: 2.51315e-06 531: 3.1499e-20 532: 1.54135e-05 543: 5.0263e-06 544: 2.51315e-06 688: -8.78797e-21 694: -9.21148e-21 Row 533: 72: -0.000245756 78: -0.000216107 82: -0.000923725 86: -0.000923725 483: 4.09593e-05 484: 5.85133e-06 487: 4.09593e-05 488: 5.85133e-06 519: 3.60178e-05 520: 5.1454e-06 521: 3.60178e-05 522: 5.1454e-06 533: 0.000153954 534: 0 682: -2.34053e-05 684: -2.05816e-05 Row 534: 72: -1.25361e-19 78: 1.0842e-19 82: 0.000153954 86: -0.000153954 483: -5.85133e-06 484: -2.92566e-06 487: 5.85133e-06 488: 2.92566e-06 519: -5.1454e-06 520: -2.5727e-06 521: 5.1454e-06 522: 2.5727e-06 533: 0 534: 1.64951e-05 682: -9.31736e-21 684: 8.47033e-21 Row 535: 77: -0.000212157 83: -0.000835464 85: -0.000835464 88: -0.000205575 513: 3.53595e-05 514: 5.05136e-06 515: 3.53595e-05 516: 5.05136e-06 535: 0.000139244 536: 3.19755e-20 537: 3.42625e-05 538: -4.89465e-06 545: 3.42625e-05 546: -4.89465e-06 681: -2.02054e-05 693: -1.95786e-05 Row 536: 77: -1.05032e-19 83: 0.000139244 85: -0.000139244 88: -1.13502e-19 513: -5.05136e-06 514: -2.52568e-06 515: 5.05136e-06 516: 2.52568e-06 535: 3.19755e-20 536: 1.4919e-05 537: -4.89465e-06 538: 2.44732e-06 545: 4.89465e-06 546: -2.44732e-06 681: -8.36445e-21 693: -8.89385e-21 Row 537: 73: -0.00022467 83: -0.00086049 85: -0.000205575 88: -0.00086049 491: 3.74449e-05 492: 5.34928e-06 495: 3.74449e-05 496: 5.34928e-06 535: 3.42625e-05 536: -4.89465e-06 537: 0.000143415 538: -1.69407e-20 545: 3.42625e-05 546: 4.89465e-06 691: -2.13971e-05 693: -1.95786e-05 Row 538: 73: 1.15196e-19 83: 0.000143415 85: -6.77626e-21 88: -0.000143415 491: -5.34928e-06 492: -2.67464e-06 495: 5.34928e-06 496: 2.67464e-06 535: -4.89465e-06 536: 2.44732e-06 537: -1.69407e-20 538: 1.53659e-05 545: 4.89465e-06 546: 2.44732e-06 691: 8.89385e-21 693: -1.04085e-21 Row 539: 72: -0.000244512 84: -0.000960675 86: -0.000960675 88: -0.000235825 485: 4.0752e-05 486: 5.82172e-06 487: 4.0752e-05 488: 5.82172e-06 539: 0.000160112 540: -1.86347e-20 541: 3.93042e-05 542: -5.61489e-06 549: 3.93042e-05 550: -5.61489e-06 683: -2.32869e-05 692: -2.24595e-05 Row 540: 72: 1.28749e-19 84: 0.000160112 86: -0.000160112 88: -1.01644e-20 485: -5.82172e-06 486: -2.91086e-06 487: 5.82172e-06 488: 2.91086e-06 539: -1.86347e-20 540: 1.71549e-05 541: -5.61489e-06 542: 2.80744e-06 549: 5.61489e-06 550: -2.80744e-06 683: 9.74088e-21 692: -1.07301e-21 Row 541: 73: -0.000210845 84: -0.00089334 86: -0.000235825 88: -0.00089334 493: 3.51408e-05 494: 5.02011e-06 495: 3.51408e-05 496: 5.02011e-06 539: 3.93042e-05 540: -5.61489e-06 541: 0.00014889 542: 3.51519e-20 549: 3.93042e-05 550: 5.61489e-06 690: -2.00804e-05 692: -2.24595e-05 Row 542: 73: -1.05032e-19 84: 0.00014889 86: -1.28749e-19 88: -0.00014889 493: -5.02011e-06 494: -2.51005e-06 495: 5.02011e-06 496: 2.51005e-06 539: -5.61489e-06 540: 2.80744e-06 541: 3.51519e-20 542: 1.59525e-05 549: 5.61489e-06 550: 2.80744e-06 690: -8.04681e-21 692: -1.02703e-20 Row 543: 81: -0.000211105 85: -0.00083886 87: -0.00083886 88: -0.000208325 529: 3.51841e-05 530: 5.0263e-06 531: 3.51841e-05 532: 5.0263e-06 543: 0.00013981 544: 3.3246e-20 545: 3.47209e-05 546: -4.96012e-06 551: 3.47209e-05 552: -4.96012e-06 694: -2.01052e-05 696: -1.98405e-05 Row 544: 81: -1.0842e-19 85: 0.00013981 87: -0.00013981 88: -1.13502e-19 529: -5.0263e-06 530: -2.51315e-06 531: 5.0263e-06 532: 2.51315e-06 543: 3.3246e-20 544: 1.49796e-05 545: -4.96012e-06 546: 2.48006e-06 551: 4.96012e-06 552: -2.48006e-06 694: -8.25857e-21 696: -9.1056e-21 Row 545: 83: -0.000205575 85: -0.000827801 87: -0.000208325 88: -0.000827801 535: 3.42625e-05 536: 4.89465e-06 537: 3.42625e-05 538: 4.89465e-06 543: 3.47209e-05 544: -4.96012e-06 545: 0.000137967 546: -1.77877e-20 551: 3.47209e-05 552: 4.96012e-06 693: -1.95786e-05 696: -1.98405e-05 Row 546: 83: 1.01644e-19 85: 0.000137967 87: -6.77626e-21 88: -0.000137967 535: -4.89465e-06 536: -2.44732e-06 537: 4.89465e-06 538: 2.44732e-06 543: -4.96012e-06 544: 2.48006e-06 545: -1.77877e-20 546: 1.47822e-05 551: 4.96012e-06 552: 2.48006e-06 693: 8.25857e-21 696: -1.17865e-21 Row 547: 79: -0.000245776 86: -0.00100079 87: -0.00100079 88: -0.000254619 523: 4.09627e-05 524: 5.85181e-06 525: 4.09627e-05 526: 5.85181e-06 547: 0.000166798 548: -1.82112e-20 549: 4.24364e-05 550: -6.06235e-06 551: 4.24364e-05 552: -6.06235e-06 687: -2.34072e-05 695: -2.42494e-05 Row 548: 79: 1.28749e-19 86: 0.000166798 87: -0.000166798 88: -5.0822e-21 523: -5.85181e-06 524: -2.9259e-06 525: 5.85181e-06 526: 2.9259e-06 547: -1.82112e-20 548: 1.78712e-05 549: -6.06235e-06 550: 3.03117e-06 551: 6.06235e-06 552: -3.03117e-06 687: 1.00585e-20 695: -1.06261e-21 Row 549: 84: -0.000235825 86: -0.000980887 87: -0.000254619 88: -0.000980887 539: 3.93042e-05 540: 5.61489e-06 541: 3.93042e-05 542: 5.61489e-06 547: 4.24364e-05 548: -6.06235e-06 549: 0.000163481 550: 3.73224e-20 551: 4.24364e-05 552: 6.06235e-06 692: -2.24595e-05 695: -2.42494e-05 Row 550: 84: -1.18585e-19 86: 0.000163481 87: -1.38913e-19 88: -0.000163481 539: -5.61489e-06 540: -2.80744e-06 541: 5.61489e-06 542: 2.80744e-06 547: -6.06235e-06 548: 3.03117e-06 549: 3.73224e-20 550: 1.75158e-05 551: 6.06235e-06 552: 3.03117e-06 692: -9.31736e-21 695: -1.10114e-20 Row 551: 85: -0.000208325 86: -0.000254619 87: -0.000925887 88: -0.000925887 543: 3.47209e-05 544: 4.96012e-06 545: 3.47209e-05 546: 4.96012e-06 547: 4.24364e-05 548: 6.06235e-06 549: 4.24364e-05 550: 6.06235e-06 551: 0.000154315 552: 3.38813e-21 695: -2.42494e-05 696: -1.98405e-05 Row 552: 85: 1.0842e-19 86: -1.25361e-19 87: 0.000154315 88: -0.000154315 543: -4.96012e-06 544: -2.48006e-06 545: 4.96012e-06 546: 2.48006e-06 547: -6.06235e-06 548: -3.03117e-06 549: 6.06235e-06 550: 3.03117e-06 551: 3.38813e-21 552: 1.65337e-05 695: -1.01644e-20 696: 8.04681e-21 Row 553: 0: 0.000173611 4: 0.000173611 31: 0.000173611 89: -2.48016e-05 90: -1.27963e-21 91: -2.48016e-05 92: -1.11173e-20 107: -2.48016e-05 108: -1.01644e-20 553: 1.24008e-05 Row 554: 4: 0.000153219 5: 0.000153219 32: 0.000153219 105: -2.18884e-05 106: -1.01322e-21 109: -2.18884e-05 110: -9.95264e-21 113: -2.18884e-05 114: -8.89385e-21 554: 1.09442e-05 Row 555: 6: 0.00015059 7: 0.00015059 33: 0.00015059 117: -2.15129e-05 118: -8.80202e-22 119: -2.15129e-05 120: -9.84676e-21 125: -2.15129e-05 126: -8.89385e-21 555: 1.07564e-05 Row 556: 8: 0.000158251 9: 0.000158251 34: 0.000158251 129: -2.26073e-05 130: -1.21399e-21 131: -2.26073e-05 132: -1.01644e-20 137: -2.26073e-05 138: -9.42324e-21 556: 1.13037e-05 Row 557: 1: 0.000173611 10: 0.000173611 11: 0.000173611 93: -2.48016e-05 94: -1.13291e-20 95: -2.48016e-05 96: -1.50092e-21 141: -2.48016e-05 142: 1.03762e-20 557: 1.24008e-05 Row 558: 11: 0.000153468 12: 0.000153468 35: 0.000153468 147: -2.1924e-05 148: -9.46847e-22 149: -2.1924e-05 150: -9.95264e-21 153: -2.1924e-05 154: -8.99973e-21 558: 1.0962e-05 Row 559: 13: 0.00014632 14: 0.00014632 36: 0.00014632 157: -2.09029e-05 158: -8.06128e-22 159: -2.09029e-05 160: -9.31736e-21 165: -2.09029e-05 166: -8.47033e-21 559: 1.04514e-05 Row 560: 15: 0.000146983 16: 0.000146983 37: 0.000146983 169: -2.09976e-05 170: -1.01694e-21 171: -2.09976e-05 172: -9.21148e-21 177: -2.09976e-05 178: -8.78797e-21 560: 1.04988e-05 Row 561: 2: 0.000173611 17: 0.000173611 18: 0.000173611 97: -2.48016e-05 98: -1.13291e-20 99: -2.48016e-05 100: -1.50092e-21 181: -2.48016e-05 182: 1.03762e-20 561: 1.24008e-05 Row 562: 18: 0.000152492 19: 0.000152492 38: 0.000152492 187: -2.17846e-05 188: -1.20088e-21 189: -2.17846e-05 190: -9.74088e-21 193: -2.17846e-05 194: -8.99973e-21 562: 1.08923e-05 Row 563: 20: 0.00015525 21: 0.00015525 39: 0.00015525 197: -2.21785e-05 198: -1.22986e-21 199: -2.21785e-05 200: -9.95264e-21 205: -2.21785e-05 206: -9.1056e-21 563: 1.10893e-05 Row 564: 22: 0.000156822 23: 0.000156822 40: 0.000156822 209: -2.24032e-05 210: -1.12026e-21 211: -2.24032e-05 212: -9.84676e-21 217: -2.24032e-05 218: -9.31736e-21 564: 1.12016e-05 Row 565: 3: 0.000173611 24: 0.000173611 25: 0.000173611 101: -2.48016e-05 102: -1.13291e-20 103: -2.48016e-05 104: -1.50092e-21 221: -2.48016e-05 222: 1.03762e-20 565: 1.24008e-05 Row 566: 25: 0.00015119 26: 0.00015119 41: 0.00015119 227: -2.15985e-05 228: -1.02997e-21 229: -2.15985e-05 230: -9.635e-21 233: -2.15985e-05 234: -8.78797e-21 566: 1.07993e-05 Row 567: 27: 0.000143687 28: 0.000143687 42: 0.000143687 237: -2.05267e-05 238: -1.06523e-21 239: -2.05267e-05 240: -9.1056e-21 245: -2.05267e-05 246: -8.68209e-21 567: 1.02634e-05 Row 568: 29: 0.000153601 30: 0.000153601 43: 0.000153601 249: -2.19431e-05 250: -9.32262e-22 251: -2.19431e-05 252: -9.95264e-21 257: -2.19431e-05 258: -9.1056e-21 568: 1.09715e-05 Row 569: 4: 0.000218962 31: 0.000218962 32: 0.000218962 107: -3.12803e-05 108: -1.46113e-20 109: -3.12803e-05 110: -1.60029e-21 261: -3.12803e-05 262: 1.3129e-20 569: 1.56402e-05 Row 570: 10: 0.000222005 11: 0.000222005 35: 0.000222005 141: -3.17151e-05 142: -1.59924e-21 143: -3.17151e-05 144: -1.41878e-20 149: -3.17151e-05 150: -1.33408e-20 570: 1.58575e-05 Row 571: 17: 0.00021684 18: 0.00021684 38: 0.00021684 181: -3.09771e-05 182: -1.24845e-21 183: -3.09771e-05 184: -1.41878e-20 189: -3.09771e-05 190: -1.27055e-20 571: 1.54886e-05 Row 572: 24: 0.000216999 25: 0.000216999 41: 0.000216999 221: -3.09999e-05 222: -1.65219e-21 223: -3.09999e-05 224: -1.3976e-20 229: -3.09999e-05 230: -1.24937e-20 572: 1.54999e-05 Row 573: 5: 0.000157214 6: 0.000157214 44: 0.000157214 111: -2.24591e-05 112: -1.05159e-21 115: -2.24591e-05 116: -9.95264e-21 121: -2.24591e-05 122: -9.21148e-21 573: 1.12295e-05 Row 574: 7: 0.000152344 8: 0.000152344 45: 0.000152344 123: -2.17635e-05 124: -1.0179e-21 127: -2.17635e-05 128: -9.95264e-21 133: -2.17635e-05 134: -8.68209e-21 574: 1.08817e-05 Row 575: 9: 0.000148878 10: 0.000148878 46: 0.000148878 135: -2.12683e-05 136: -9.74759e-22 139: -2.12683e-05 140: -9.52912e-21 145: -2.12683e-05 146: -8.99973e-21 575: 1.06342e-05 Row 576: 12: 0.000158064 13: 0.000158064 47: 0.000158064 151: -2.25806e-05 152: -1.10787e-21 155: -2.25806e-05 156: -1.0482e-20 161: -2.25806e-05 162: -9.42324e-21 576: 1.12903e-05 Row 577: 14: 0.000141666 15: 0.000141666 48: 0.000141666 163: -2.02379e-05 164: -9.29052e-22 167: -2.02379e-05 168: -8.99973e-21 173: -2.02379e-05 174: -8.04681e-21 577: 1.0119e-05 Row 578: 8: 0.000152414 34: 0.000152414 45: 0.000152414 131: -2.17735e-05 132: -9.57355e-22 133: -2.17735e-05 134: -9.95264e-21 279: -2.17735e-05 280: -8.89385e-21 578: 1.08867e-05 Row 579: 16: 0.000142893 17: 0.000142893 49: 0.000142893 175: -2.04133e-05 176: -9.35689e-22 179: -2.04133e-05 180: -9.31736e-21 185: -2.04133e-05 186: -8.47033e-21 579: 1.02067e-05 Row 580: 19: 0.000159327 20: 0.000159327 50: 0.000159327 191: -2.2761e-05 192: -9.75323e-22 195: -2.2761e-05 196: -1.02703e-20 201: -2.2761e-05 202: -9.31736e-21 580: 1.13805e-05 Row 581: 21: 0.000154916 22: 0.000154916 51: 0.000154916 203: -2.21309e-05 204: -9.86042e-22 207: -2.21309e-05 208: -1.01644e-20 213: -2.21309e-05 214: -9.42324e-21 581: 1.10654e-05 Row 582: 6: 0.000158935 33: 0.000158935 44: 0.000158935 119: -2.2705e-05 120: -1.05341e-21 121: -2.2705e-05 122: -1.01644e-20 271: -2.2705e-05 272: -9.21148e-21 582: 1.13525e-05 Row 583: 23: 0.000146339 24: 0.000146339 52: 0.000146339 215: -2.09056e-05 216: -9.02727e-22 219: -2.09056e-05 220: -9.31736e-21 225: -2.09056e-05 226: -8.47033e-21 583: 1.04528e-05 Row 584: 5: 0.000163619 32: 0.000163619 44: 0.000163619 113: -2.33741e-05 114: -1.0482e-20 115: -2.33741e-05 116: -1.31778e-21 265: -2.33741e-05 266: 9.74088e-21 584: 1.16871e-05 Row 585: 26: 0.000152048 27: 0.000152048 53: 0.000152048 231: -2.17211e-05 232: -9.56313e-22 235: -2.17211e-05 236: -9.74088e-21 241: -2.17211e-05 242: -8.68209e-21 585: 1.08606e-05 Row 586: 28: 0.000145929 29: 0.000145929 54: 0.000145929 243: -2.0847e-05 244: -1.04191e-21 247: -2.0847e-05 248: -9.42324e-21 253: -2.0847e-05 254: -8.25857e-21 586: 1.04235e-05 Row 587: 30: 0.000145823 31: 0.000145823 55: 0.000145823 255: -2.08318e-05 256: -1.0832e-21 259: -2.08318e-05 260: -9.42324e-21 263: -2.08318e-05 264: -8.89385e-21 587: 1.04159e-05 Row 588: 13: 0.000157074 36: 0.000157074 47: 0.000157074 159: -2.24391e-05 160: -1.14258e-21 161: -2.24391e-05 162: -1.03762e-20 293: -2.24391e-05 294: -9.52912e-21 588: 1.12195e-05 Row 589: 7: 0.000153119 33: 0.000153119 45: 0.000153119 125: -2.18741e-05 126: -9.95264e-21 127: -2.18741e-05 128: -1.2278e-21 273: -2.18741e-05 274: 8.89385e-21 589: 1.0937e-05 Row 590: 9: 0.000136201 34: 0.000136201 46: 0.000136201 137: -1.94574e-05 138: -8.78797e-21 139: -1.94574e-05 140: -9.5929e-22 281: -1.94574e-05 282: 8.04681e-21 590: 9.72868e-06 Row 591: 14: 0.000145653 36: 0.000145653 48: 0.000145653 165: -2.08076e-05 166: -9.42324e-21 167: -2.08076e-05 168: -1.19931e-21 295: -2.08076e-05 296: 8.78797e-21 591: 1.04038e-05 Row 592: 16: 0.000126819 37: 0.000126819 49: 0.000126819 177: -1.81171e-05 178: -8.47033e-21 179: -1.81171e-05 180: -9.42087e-22 303: -1.81171e-05 304: 7.72918e-21 592: 9.05853e-06 Row 593: 21: 0.000157172 39: 0.000157172 51: 0.000157172 205: -2.24531e-05 206: -1.01644e-20 207: -2.24531e-05 208: -1.14921e-21 317: -2.24531e-05 318: 9.42324e-21 593: 1.12266e-05 Row 594: 23: 0.000133927 40: 0.000133927 52: 0.000133927 217: -1.91324e-05 218: -8.89385e-21 219: -1.91324e-05 220: -1.13497e-21 325: -1.91324e-05 326: 8.04681e-21 594: 9.5662e-06 Row 595: 28: 0.000146549 42: 0.000146549 54: 0.000146549 245: -2.09356e-05 246: -9.52912e-21 247: -2.09356e-05 248: -1.22357e-21 339: -2.09356e-05 340: 8.99973e-21 595: 1.04678e-05 Row 596: 30: 0.000132673 43: 0.000132673 55: 0.000132673 257: -1.89533e-05 258: -8.57621e-21 259: -1.89533e-05 260: -8.12576e-22 347: -1.89533e-05 348: 7.94093e-21 596: 9.47665e-06 Row 597: 15: 0.000141665 37: 0.000141665 48: 0.000141665 171: -2.02378e-05 172: -9.05794e-22 173: -2.02378e-05 174: -8.99973e-21 301: -2.02378e-05 302: -8.57621e-21 597: 1.01189e-05 Row 598: 20: 0.000163596 39: 0.000163596 50: 0.000163596 199: -2.33708e-05 200: -9.25353e-22 201: -2.33708e-05 202: -1.05879e-20 315: -2.33708e-05 316: -9.52912e-21 598: 1.16854e-05 Row 599: 22: 0.000153952 40: 0.000153952 51: 0.000153952 211: -2.19931e-05 212: -8.98413e-22 213: -2.19931e-05 214: -9.95264e-21 323: -2.19931e-05 324: -9.1056e-21 599: 1.09965e-05 Row 600: 29: 0.000147119 43: 0.000147119 54: 0.000147119 251: -2.1017e-05 252: -8.31921e-22 253: -2.1017e-05 254: -9.31736e-21 345: -2.1017e-05 346: -8.47033e-21 600: 1.05085e-05 Row 601: 26: 0.000159606 41: 0.000159606 53: 0.000159606 233: -2.28009e-05 234: -1.05879e-20 235: -2.28009e-05 236: -1.32113e-21 333: -2.28009e-05 334: 9.31736e-21 601: 1.14005e-05 Row 602: 12: 0.000166274 35: 0.000166274 47: 0.000166274 153: -2.37534e-05 154: -1.07997e-20 155: -2.37534e-05 156: -1.29252e-21 289: -2.37534e-05 290: 9.74088e-21 602: 1.18767e-05 Row 603: 19: 0.000165986 38: 0.000165986 50: 0.000165986 193: -2.37122e-05 194: -1.06938e-20 195: -2.37122e-05 196: -1.32496e-21 311: -2.37122e-05 312: 9.95264e-21 603: 1.18561e-05 Row 604: 27: 0.000153001 42: 0.000153001 53: 0.000153001 239: -2.18573e-05 240: -9.14871e-22 241: -2.18573e-05 242: -9.84676e-21 337: -2.18573e-05 338: -9.31736e-21 604: 1.09287e-05 Row 605: 42: 0.000138753 54: 0.000138753 56: 0.000138753 339: -1.98219e-05 340: -8.9921e-22 341: -1.98219e-05 342: -8.89385e-21 387: -1.98219e-05 388: -8.25857e-21 605: 9.91093e-06 Row 606: 34: 0.000158705 46: 0.000158705 57: 0.000158705 281: -2.26721e-05 282: -9.92299e-22 283: -2.26721e-05 284: -1.01644e-20 361: -2.26721e-05 362: -9.635e-21 606: 1.1336e-05 Row 607: 39: 0.000154585 51: 0.000154585 58: 0.000154585 317: -2.20836e-05 318: -8.65891e-22 319: -2.20836e-05 320: -1.01644e-20 377: -2.20836e-05 378: -9.1056e-21 607: 1.10418e-05 Row 608: 36: 0.000137315 48: 0.000137315 59: 0.000137315 295: -1.96164e-05 296: -8.42681e-22 297: -1.96164e-05 298: -8.68209e-21 367: -1.96164e-05 368: -8.04681e-21 608: 9.80819e-06 Row 609: 10: 0.000174938 35: 0.000174938 46: 0.000174938 143: -2.49912e-05 144: -1.2154e-21 145: -2.49912e-05 146: -1.11173e-20 287: -2.49912e-05 288: -1.03762e-20 609: 1.24956e-05 Row 610: 38: 0.000185409 50: 0.000185409 60: 0.000185409 311: -2.64871e-05 312: -1.3333e-21 313: -2.64871e-05 314: -1.11173e-20 373: -2.64871e-05 374: -1.07997e-20 610: 1.32435e-05 Row 611: 17: 0.000168724 38: 0.000168724 49: 0.000168724 183: -2.41035e-05 184: -1.07568e-21 185: -2.41035e-05 186: -1.09055e-20 309: -2.41035e-05 310: -9.74088e-21 611: 1.20517e-05 Row 612: 33: 0.000146204 45: 0.000146204 61: 0.000146204 273: -2.08864e-05 274: -9.25172e-22 275: -2.08864e-05 276: -9.31736e-21 357: -2.08864e-05 358: -8.47033e-21 612: 1.04432e-05 Row 613: 39: 0.000159322 50: 0.000159322 62: 0.000159322 315: -2.27602e-05 316: -1.02703e-20 321: -2.27602e-05 322: -1.02356e-21 375: -2.27602e-05 376: 9.52912e-21 613: 1.13801e-05 Row 614: 39: 0.000157617 58: 0.000157617 62: 0.000157617 319: -2.25166e-05 320: -9.74957e-22 321: -2.25166e-05 322: -1.00585e-20 407: -2.25166e-05 408: -9.31736e-21 614: 1.12583e-05 Row 615: 34: 0.000153615 45: 0.000153615 63: 0.000153615 279: -2.19451e-05 280: -1.00585e-20 285: -2.19451e-05 286: -9.96003e-22 359: -2.19451e-05 360: 8.89385e-21 615: 1.09725e-05 Row 616: 34: 0.000181033 57: 0.000181033 63: 0.000181033 283: -2.58619e-05 284: -1.33946e-21 285: -2.58619e-05 286: -1.15408e-20 401: -2.58619e-05 402: -1.05879e-20 616: 1.29309e-05 Row 617: 42: 0.000145689 53: 0.000145689 64: 0.000145689 337: -2.08127e-05 338: -9.52912e-21 343: -2.08127e-05 344: -1.16518e-21 383: -2.08127e-05 384: 8.47033e-21 617: 1.04063e-05 Row 618: 42: 0.000143373 56: 0.000143373 64: 0.000143373 341: -2.04819e-05 342: -1.05026e-21 343: -2.04819e-05 344: -9.1056e-21 393: -2.04819e-05 394: -8.25857e-21 618: 1.02409e-05 Row 619: 24: 0.00017154 41: 0.00017154 52: 0.00017154 223: -2.45057e-05 224: -1.11427e-21 225: -2.45057e-05 226: -1.11173e-20 331: -2.45057e-05 332: -1.00585e-20 619: 1.22528e-05 Row 620: 40: 0.000154429 52: 0.000154429 65: 0.000154429 325: -2.20614e-05 326: -9.46629e-22 327: -2.20614e-05 328: -9.95264e-21 381: -2.20614e-05 382: -9.31736e-21 620: 1.10307e-05 Row 621: 33: 0.000153158 44: 0.000153158 66: 0.000153158 271: -2.18798e-05 272: -9.95264e-21 277: -2.18798e-05 278: -1.12883e-21 353: -2.18798e-05 354: 9.21148e-21 621: 1.09399e-05 Row 622: 33: 0.000150079 61: 0.000150079 66: 0.000150079 275: -2.14399e-05 276: -8.65147e-22 277: -2.14399e-05 278: -9.635e-21 431: -2.14399e-05 432: -8.47033e-21 622: 1.07199e-05 Row 623: 32: 0.0001879 44: 0.0001879 67: 0.0001879 265: -2.68429e-05 266: -1.22942e-21 269: -2.68429e-05 270: -1.21761e-20 355: -2.68429e-05 356: -1.07997e-20 623: 1.34214e-05 Row 624: 44: 0.000175578 66: 0.000175578 67: 0.000175578 353: -2.50825e-05 354: -1.10515e-21 355: -2.50825e-05 356: -1.13291e-20 455: -2.50825e-05 456: -1.01644e-20 624: 1.25413e-05 Row 625: 41: 0.000158103 52: 0.000158103 65: 0.000158103 331: -2.25861e-05 332: -1.03762e-20 335: -2.25861e-05 336: -1.26203e-21 381: -2.25861e-05 382: 9.635e-21 625: 1.1293e-05 Row 626: 41: 0.000184267 53: 0.000184267 65: 0.000184267 333: -2.63238e-05 334: -1.31299e-21 335: -2.63238e-05 336: -1.18585e-20 385: -2.63238e-05 386: -1.10114e-20 626: 1.31619e-05 Row 627: 31: 0.000172169 32: 0.000172169 55: 0.000172169 261: -2.45956e-05 262: -1.02295e-21 263: -2.45956e-05 264: -1.10114e-20 267: -2.45956e-05 268: -9.95264e-21 627: 1.22978e-05 Row 628: 36: 0.000156846 47: 0.000156846 68: 0.000156846 293: -2.24066e-05 294: -1.00585e-20 299: -2.24066e-05 300: -1.04999e-21 365: -2.24066e-05 366: 8.99973e-21 628: 1.12033e-05 Row 629: 36: 0.000145018 59: 0.000145018 68: 0.000145018 297: -2.07169e-05 298: -9.50785e-22 299: -2.07169e-05 300: -9.52912e-21 415: -2.07169e-05 416: -8.57621e-21 629: 1.03584e-05 Row 630: 35: 0.000164331 46: 0.000164331 57: 0.000164331 287: -2.34759e-05 288: -1.10114e-20 291: -2.34759e-05 292: -1.05858e-21 361: -2.34759e-05 362: 9.52912e-21 630: 1.1738e-05 Row 631: 38: 0.000155923 49: 0.000155923 60: 0.000155923 309: -2.22747e-05 310: -1.03762e-20 313: -2.22747e-05 314: -1.16774e-21 371: -2.22747e-05 372: 9.1056e-21 631: 1.11373e-05 Row 632: 32: 0.000159814 55: 0.000159814 67: 0.000159814 267: -2.28306e-05 268: -1.03762e-20 269: -2.28306e-05 270: -1.32113e-21 391: -2.28306e-05 392: 9.1056e-21 632: 1.14153e-05 Row 633: 48: 0.000139224 59: 0.000139224 69: 0.000139224 367: -1.98891e-05 368: -9.1056e-21 369: -1.98891e-05 370: -9.56159e-22 417: -1.98891e-05 418: 8.25857e-21 633: 9.94455e-06 Row 634: 37: 0.000136115 48: 0.000136115 69: 0.000136115 301: -1.94449e-05 302: -8.89385e-21 307: -1.94449e-05 308: -1.10829e-21 369: -1.94449e-05 370: 8.04681e-21 634: 9.72246e-06 Row 635: 53: 0.00016937 64: 0.00016937 65: 0.00016937 383: -2.41957e-05 384: -1.15649e-21 385: -2.41957e-05 386: -1.07997e-20 445: -2.41957e-05 446: -9.84676e-21 635: 1.20979e-05 Row 636: 45: 0.000150689 61: 0.000150689 63: 0.000150689 357: -2.15269e-05 358: -9.52912e-21 359: -2.15269e-05 360: -1.15619e-21 429: -2.15269e-05 430: 8.78797e-21 636: 1.07635e-05 Row 637: 35: 0.00019064 47: 0.00019064 57: 0.00019064 289: -2.72343e-05 290: -1.09855e-21 291: -2.72343e-05 292: -1.24937e-20 363: -2.72343e-05 364: -1.10114e-20 637: 1.36171e-05 Row 638: 50: 0.000182668 60: 0.000182668 62: 0.000182668 373: -2.60954e-05 374: -1.18585e-20 375: -2.60954e-05 376: -1.68169e-21 423: -2.60954e-05 424: 1.07997e-20 638: 1.30477e-05 Row 639: 51: 0.000156239 58: 0.000156239 70: 0.000156239 377: -2.23199e-05 378: -1.00585e-20 379: -2.23199e-05 380: -1.0968e-21 409: -2.23199e-05 410: 8.89385e-21 639: 1.116e-05 Row 640: 40: 0.000152513 51: 0.000152513 70: 0.000152513 323: -2.17876e-05 324: -9.84676e-21 329: -2.17876e-05 330: -1.23601e-21 379: -2.17876e-05 380: 9.1056e-21 640: 1.08938e-05 Row 641: 47: 0.000183468 57: 0.000183468 68: 0.000183468 363: -2.62097e-05 364: -1.19643e-20 365: -2.62097e-05 366: -1.47477e-21 403: -2.62097e-05 404: 1.07997e-20 641: 1.31048e-05 Row 642: 37: 0.000150127 49: 0.000150127 60: 0.000150127 303: -2.14467e-05 304: -1.00337e-21 305: -2.14467e-05 306: -9.635e-21 371: -2.14467e-05 372: -8.78797e-21 642: 1.07233e-05 Row 643: 37: 0.000160575 60: 0.000160575 69: 0.000160575 305: -2.29393e-05 306: -1.16082e-21 307: -2.29393e-05 308: -1.0482e-20 425: -2.29393e-05 426: -9.31736e-21 643: 1.14697e-05 Row 644: 43: 0.000148005 54: 0.000148005 71: 0.000148005 345: -2.11436e-05 346: -9.635e-21 351: -2.11436e-05 352: -9.85995e-22 389: -2.11436e-05 390: 8.99973e-21 644: 1.05718e-05 Row 645: 40: 0.000178163 65: 0.000178163 70: 0.000178163 327: -2.54519e-05 328: -1.30388e-21 329: -2.54519e-05 330: -1.14349e-20 451: -2.54519e-05 452: -1.03762e-20 645: 1.27259e-05 Row 646: 54: 0.000143445 56: 0.000143445 71: 0.000143445 387: -2.04922e-05 388: -9.42324e-21 389: -2.04922e-05 390: -1.04859e-21 395: -2.04922e-05 396: 8.78797e-21 646: 1.02461e-05 Row 647: 43: 0.000154094 55: 0.000154094 67: 0.000154094 347: -2.20134e-05 348: -1.01474e-21 349: -2.20134e-05 350: -1.01644e-20 391: -2.20134e-05 392: -9.1056e-21 647: 1.10067e-05 Row 648: 43: 0.000175565 67: 0.000175565 71: 0.000175565 349: -2.50808e-05 350: -1.07536e-21 351: -2.50808e-05 352: -1.14349e-20 461: -2.50808e-05 462: -1.05879e-20 648: 1.25404e-05 Row 649: 56: 0.000146709 71: 0.000146709 72: 0.000146709 395: -2.09585e-05 396: -1.01002e-21 397: -2.09585e-05 398: -9.42324e-21 477: -2.09585e-05 478: -8.68209e-21 649: 1.04792e-05 Row 650: 58: 0.000155324 70: 0.000155324 73: 0.000155324 409: -2.21891e-05 410: -8.99897e-22 411: -2.21891e-05 412: -1.00585e-20 473: -2.21891e-05 474: -8.89385e-21 650: 1.10946e-05 Row 651: 57: 0.000180804 63: 0.000180804 74: 0.000180804 401: -2.58292e-05 402: -1.19643e-20 405: -2.58292e-05 406: -1.59915e-21 441: -2.58292e-05 442: 1.07997e-20 651: 1.29146e-05 Row 652: 57: 0.000180757 68: 0.000180757 74: 0.000180757 403: -2.58224e-05 404: -1.27809e-21 405: -2.58224e-05 406: -1.15408e-20 465: -2.58224e-05 466: -1.05879e-20 652: 1.29112e-05 Row 653: 56: 0.000117884 64: 0.000117884 75: 0.000117884 393: -1.68406e-05 394: -7.72918e-21 399: -1.68406e-05 400: -8.72298e-22 447: -1.68406e-05 448: 6.88214e-21 653: 8.42031e-06 Row 654: 56: 0.000117663 72: 0.000117663 75: 0.000117663 397: -1.6809e-05 398: -6.42452e-22 399: -1.6809e-05 400: -7.51742e-21 481: -1.6809e-05 482: -6.98802e-21 654: 8.40451e-06 Row 655: 59: 0.0001143 69: 0.0001143 76: 0.0001143 417: -1.63286e-05 418: -7.48248e-22 419: -1.63286e-05 420: -7.30566e-21 469: -1.63286e-05 470: -6.77626e-21 655: 8.1643e-06 Row 656: 60: 0.000162153 69: 0.000162153 77: 0.000162153 425: -2.31646e-05 426: -1.03762e-20 427: -2.31646e-05 428: -1.32118e-21 471: -2.31646e-05 472: 9.95264e-21 656: 1.15823e-05 Row 657: 69: 0.000115157 76: 0.000115157 77: 0.000115157 469: -1.6451e-05 470: -7.30566e-21 471: -1.6451e-05 472: -9.59613e-22 507: -1.6451e-05 508: 6.67038e-21 657: 8.22551e-06 Row 658: 60: 0.000166875 62: 0.000166875 77: 0.000166875 423: -2.38393e-05 424: -1.03041e-21 427: -2.38393e-05 428: -1.0482e-20 437: -2.38393e-05 438: -9.74088e-21 658: 1.19197e-05 Row 659: 61: 0.000128172 66: 0.000128172 78: 0.000128172 431: -1.83103e-05 432: -8.25857e-21 433: -1.83103e-05 434: -9.77634e-22 457: -1.83103e-05 458: 7.72918e-21 659: 9.15517e-06 Row 660: 61: 0.000152314 63: 0.000152314 79: 0.000152314 429: -2.17592e-05 430: -1.08483e-21 435: -2.17592e-05 436: -9.74088e-21 443: -2.17592e-05 444: -8.68209e-21 660: 1.08796e-05 Row 661: 61: 0.000123653 78: 0.000123653 79: 0.000123653 433: -1.76648e-05 434: -7.94093e-21 435: -1.76648e-05 436: -9.80977e-22 517: -1.76648e-05 518: 7.19978e-21 661: 8.83239e-06 Row 662: 63: 0.000151977 74: 0.000151977 79: 0.000151977 441: -2.1711e-05 442: -8.39623e-22 443: -2.1711e-05 444: -9.84676e-21 497: -2.1711e-05 498: -8.89385e-21 662: 1.08555e-05 Row 663: 64: 0.000167065 65: 0.000167065 80: 0.000167065 445: -2.38664e-05 446: -1.11173e-20 449: -2.38664e-05 450: -1.25054e-21 453: -2.38664e-05 454: 1.02703e-20 663: 1.19332e-05 Row 664: 65: 0.000168922 70: 0.000168922 80: 0.000168922 451: -2.41318e-05 452: -1.09055e-20 453: -2.41318e-05 454: -1.35543e-21 475: -2.41318e-05 476: 9.74088e-21 664: 1.20659e-05 Row 665: 64: 0.000119178 75: 0.000119178 80: 0.000119178 447: -1.70254e-05 448: -8.83364e-22 449: -1.70254e-05 450: -7.51742e-21 503: -1.70254e-05 504: -6.98802e-21 665: 8.51269e-06 Row 666: 59: 0.000143906 68: 0.000143906 81: 0.000143906 415: -2.0558e-05 416: -9.31736e-21 421: -2.0558e-05 422: -1.11554e-21 467: -2.0558e-05 468: 8.57621e-21 666: 1.0279e-05 Row 667: 68: 0.000146838 74: 0.000146838 81: 0.000146838 465: -2.09769e-05 466: -9.74088e-21 467: -2.09769e-05 468: -1.18203e-21 499: -2.09769e-05 500: 8.89385e-21 667: 1.04884e-05 Row 668: 59: 0.000113315 76: 0.000113315 81: 0.000113315 419: -1.61879e-05 420: -7.50892e-22 421: -1.61879e-05 422: -7.19978e-21 509: -1.61879e-05 510: -6.56451e-21 668: 8.09394e-06 Row 669: 67: 0.000172857 71: 0.000172857 82: 0.000172857 461: -2.46939e-05 462: -1.12232e-20 463: -2.46939e-05 464: -1.17421e-21 479: -2.46939e-05 480: 1.06938e-20 669: 1.23469e-05 Row 670: 71: 0.000145027 72: 0.000145027 82: 0.000145027 477: -2.07181e-05 478: -9.52912e-21 479: -2.07181e-05 480: -1.07255e-21 483: -2.07181e-05 484: 8.47033e-21 670: 1.0359e-05 Row 671: 66: 0.000174754 67: 0.000174754 82: 0.000174754 455: -2.49649e-05 456: -1.13291e-20 459: -2.49649e-05 460: -1.39356e-21 463: -2.49649e-05 464: 1.02703e-20 671: 1.24824e-05 Row 672: 58: 0.000154839 62: 0.000154839 83: 0.000154839 407: -2.21199e-05 408: -9.84676e-21 413: -2.21199e-05 414: -1.17434e-21 439: -2.21199e-05 440: 9.31736e-21 672: 1.10599e-05 Row 673: 62: 0.000145044 77: 0.000145044 83: 0.000145044 437: -2.07206e-05 438: -9.52912e-21 439: -2.07206e-05 440: -1.09938e-21 513: -2.07206e-05 514: 8.25857e-21 673: 1.03603e-05 Row 674: 58: 0.000144717 73: 0.000144717 83: 0.000144717 411: -2.06739e-05 412: -9.27555e-22 413: -2.06739e-05 414: -9.52912e-21 491: -2.06739e-05 492: -8.57621e-21 674: 1.03369e-05 Row 675: 70: 0.000146036 73: 0.000146036 80: 0.000146036 473: -2.08622e-05 474: -9.42324e-21 475: -2.08622e-05 476: -1.20145e-21 489: -2.08622e-05 490: 8.78797e-21 675: 1.04311e-05 Row 676: 66: 0.000127291 78: 0.000127291 82: 0.000127291 457: -1.81844e-05 458: -9.55124e-22 459: -1.81844e-05 460: -8.04681e-21 519: -1.81844e-05 520: -7.30566e-21 676: 9.0922e-06 Row 677: 73: 0.000146885 80: 0.000146885 84: 0.000146885 489: -2.09836e-05 490: -9.09796e-22 493: -2.09836e-05 494: -9.31736e-21 527: -2.09836e-05 528: -8.68209e-21 677: 1.04918e-05 Row 678: 75: 0.000119572 80: 0.000119572 84: 0.000119572 503: -1.70817e-05 504: -7.72918e-21 505: -1.70817e-05 506: -1.02421e-21 527: -1.70817e-05 528: 6.98802e-21 678: 8.54083e-06 Row 679: 72: 0.00011776 75: 0.00011776 84: 0.00011776 481: -1.68229e-05 482: -7.72918e-21 485: -1.68229e-05 486: -8.6112e-22 505: -1.68229e-05 506: 6.98802e-21 679: 8.41143e-06 Row 680: 76: 0.000114288 77: 0.000114288 85: 0.000114288 507: -1.63269e-05 508: -7.10701e-22 511: -1.63269e-05 512: -7.30566e-21 515: -1.63269e-05 516: -6.35275e-21 680: 8.16344e-06 Row 681: 77: 0.000141438 83: 0.000141438 85: 0.000141438 513: -2.02054e-05 514: -9.7042e-22 515: -2.02054e-05 516: -9.31736e-21 535: -2.02054e-05 536: -8.36445e-21 681: 1.01027e-05 Row 682: 72: 0.000163837 82: 0.000163837 86: 0.000163837 483: -2.34053e-05 484: -1.0622e-21 487: -2.34053e-05 488: -1.01644e-20 533: -2.34053e-05 534: -9.31736e-21 682: 1.17027e-05 Row 683: 72: 0.000163008 84: 0.000163008 86: 0.000163008 485: -2.32869e-05 486: -1.09055e-20 487: -2.32869e-05 488: -1.14236e-21 539: -2.32869e-05 540: 9.74088e-21 683: 1.16434e-05 Row 684: 78: 0.000144071 82: 0.000144071 86: 0.000144071 519: -2.05816e-05 520: -9.42324e-21 521: -2.05816e-05 522: -1.27997e-21 533: -2.05816e-05 534: 8.47033e-21 684: 1.02908e-05 Row 685: 78: 0.000141576 79: 0.000141576 86: 0.000141576 517: -2.02252e-05 518: -9.73181e-22 521: -2.02252e-05 522: -9.1056e-21 523: -2.02252e-05 524: -8.25857e-21 685: 1.01126e-05 Row 686: 74: 0.000150894 79: 0.000150894 87: 0.000150894 497: -2.15562e-05 498: -9.74088e-21 501: -2.15562e-05 502: -1.05437e-21 525: -2.15562e-05 526: 9.1056e-21 686: 1.07781e-05 Row 687: 79: 0.000163851 86: 0.000163851 87: 0.000163851 523: -2.34072e-05 524: -1.05879e-20 525: -2.34072e-05 526: -1.1763e-21 547: -2.34072e-05 548: 1.00585e-20 687: 1.17036e-05 Row 688: 74: 0.000146983 81: 0.000146983 87: 0.000146983 499: -2.09975e-05 500: -1.06453e-21 501: -2.09975e-05 502: -9.42324e-21 531: -2.09975e-05 532: -8.78797e-21 688: 1.04988e-05 Row 689: 76: 0.000113292 81: 0.000113292 85: 0.000113292 509: -1.61846e-05 510: -7.41154e-21 511: -1.61846e-05 512: -7.95905e-22 529: -1.61846e-05 530: 6.98802e-21 689: 8.0923e-06 Row 690: 73: 0.000140563 84: 0.000140563 88: 0.000140563 493: -2.00804e-05 494: -7.87299e-22 495: -2.00804e-05 496: -8.89385e-21 541: -2.00804e-05 542: -8.04681e-21 690: 1.00402e-05 Row 691: 73: 0.00014978 83: 0.00014978 88: 0.00014978 491: -2.13971e-05 492: -9.74088e-21 495: -2.13971e-05 496: -1.02269e-21 537: -2.13971e-05 538: 8.89385e-21 691: 1.06986e-05 Row 692: 84: 0.000157217 86: 0.000157217 88: 0.000157217 539: -2.24595e-05 540: -1.07301e-21 541: -2.24595e-05 542: -1.02703e-20 549: -2.24595e-05 550: -9.31736e-21 692: 1.12298e-05 Row 693: 83: 0.00013705 85: 0.00013705 88: 0.00013705 535: -1.95786e-05 536: -8.89385e-21 537: -1.95786e-05 538: -1.04085e-21 545: -1.95786e-05 546: 8.25857e-21 693: 9.7893e-06 Row 694: 81: 0.000140737 85: 0.000140737 87: 0.000140737 529: -2.01052e-05 530: -8.72046e-22 531: -2.01052e-05 532: -9.21148e-21 543: -2.01052e-05 544: -8.25857e-21 694: 1.00526e-05 Row 695: 86: 0.000169746 87: 0.000169746 88: 0.000169746 547: -2.42494e-05 548: -1.06261e-21 549: -2.42494e-05 550: -1.10114e-20 551: -2.42494e-05 552: -1.01644e-20 695: 1.21247e-05 Row 696: 85: 0.000138883 87: 0.000138883 88: 0.000138883 543: -1.98405e-05 544: -9.1056e-21 545: -1.98405e-05 546: -1.17865e-21 551: -1.98405e-05 552: 8.04681e-21 696: 9.92025e-06
print(mstar.AsVector())
0.00520833 0.00260417 0.00260417 -0.000520833 8.68056e-05 -0.000520833 8.68056e-05 -0.000260417 -1.28749e-19 0.000173611 0.00520833 0.00260417 0.00260417 -0.000520833 8.68056e-05 -0.000520833 8.68056e-05 -0.000260417 1.28749e-19 0.000173611 0.00520833 0.00260417 0.00260417 -0.000520833 8.68056e-05 -0.000520833 8.68056e-05 -0.000260417 1.28749e-19 0.000173611 0.00520833 0.00260417 0.00260417 -0.000520833 8.68056e-05 -0.000520833 8.68056e-05 -0.000260417 1.28749e-19 0.000173611 0.00260417 0.0163738 0.00229828 0.0058886 0.00558272 -0.000520833 -8.68056e-05 -0.000260417 -1.42302e-19 -0.000459656 7.66094e-05 -0.00117772 0.000196287 -0.00111654 0.000186091 -0.000229828 -1.15196e-19 -0.000328444 1.69407e-19 0.000173611 0.000153219 0.000218962 0.00229828 0.0142215 0.00235821 0.00475257 0.00481249 -0.000459656 -7.66094e-05 -0.000229828 -1.24514e-19 -0.000471641 7.86068e-05 -0.000950513 0.000158419 -0.000962498 0.000160416 -0.000235821 -1.18585e-19 -0.000245428 1.25361e-19 0.000153219 0.000157214 0.000163619 0.00235821 0.0140022 0.00225885 0.00464288 0.00474223 -0.000471641 -7.86068e-05 -0.000235821 -1.27902e-19 -0.000451771 7.52951e-05 -0.000928575 0.000154763 -0.000948446 0.000158074 -0.000225885 -1.15196e-19 -0.000238402 -1.21973e-19 0.00015059 0.000157214 0.000158935 0.00225885 0.0136816 0.00228517 0.00455563 0.00458194 -0.000451771 -7.52951e-05 -0.000225885 -1.2282e-19 -0.000457033 7.61722e-05 -0.000911126 0.000151854 -0.000916389 0.000152731 -0.000228517 -1.15196e-19 -0.000229678 1.15196e-19 0.00015059 0.000152344 0.000153119 0.00228517 0.0138903 0.00237377 0.00465998 0.00457138 -0.000457033 -7.61722e-05 -0.000228517 -1.23667e-19 -0.000474754 7.91257e-05 -0.000931996 0.000155333 -0.000914276 0.000152379 -0.000237377 -1.25361e-19 -0.000228621 -1.15196e-19 0.000158251 0.000152344 0.000152414 0.00237377 0.0132999 0.00223318 0.00441679 0.0042762 -0.000474754 -7.91257e-05 -0.000237377 -1.29596e-19 -0.000446635 7.44392e-05 -0.000883358 0.000147226 -0.00085524 0.00014254 -0.000223318 -1.11808e-19 -0.000204302 1.05032e-19 0.000158251 0.000148878 0.000136201 0.00260417 0.00223318 0.021583 0.00593425 0.00595416 0.00485725 -0.000520833 -8.68056e-05 -0.000260417 -3.38813e-21 -0.000446635 -7.44392e-05 -0.000223318 -1.2282e-19 -0.00118685 0.000197808 -0.00119083 0.000198472 -0.000971451 0.000161908 -0.000333008 -1.69407e-19 -0.000262408 -1.32137e-19 0.000173611 0.000222005 0.000148878 0.000174938 0.00260417 0.00593425 0.0164725 0.00230202 0.00563211 -0.000260417 -1.42302e-19 -0.000520833 -8.68056e-05 -0.00118685 -0.000197808 -0.000333008 -1.82959e-19 -0.000460405 7.67341e-05 -0.00112642 0.000187737 -0.000230202 -1.18585e-19 0.000173611 0.000153468 0.000222005 0.00230202 0.0143342 0.00237096 0.00479613 0.00486507 -0.000460405 -7.67341e-05 -0.000230202 -1.23667e-19 -0.000474192 7.9032e-05 -0.000959226 0.000159871 -0.000973014 0.000162169 -0.000237096 -1.18585e-19 -0.000249411 1.28749e-19 0.000153468 0.000158064 0.000166274 0.00237096 0.0138437 0.0021948 0.00455091 0.00472707 -0.000474192 -7.9032e-05 -0.000237096 -1.29596e-19 -0.000438961 7.31601e-05 -0.000910182 0.000151697 -0.000945413 0.000157569 -0.00021948 -1.11808e-19 -0.00023561 -1.21973e-19 0.00014632 0.000158064 0.000157074 0.0021948 0.0130092 0.00212498 0.0043796 0.00430978 -0.000438961 -7.31601e-05 -0.00021948 -1.19432e-19 -0.000424997 7.08328e-05 -0.00087592 0.000145987 -0.000861955 0.000143659 -0.000212498 -1.0842e-19 -0.000218479 1.15196e-19 0.00014632 0.000141666 0.000145653 0.00212498 0.0129094 0.00220475 0.00432972 0.00424995 -0.000424997 -7.08328e-05 -0.000212498 -1.16891e-19 -0.000440949 7.34916e-05 -0.000865943 0.000144324 -0.00084999 0.000141665 -0.000220475 -1.15196e-19 -0.000212497 -1.0842e-19 0.000146983 0.000141666 0.000141665 0.00220475 0.0125009 0.0021434 0.00410704 0.00404569 -0.000440949 -7.34916e-05 -0.000220475 -1.19432e-19 -0.00042868 7.14466e-05 -0.000821408 0.000136901 -0.000809138 0.000134856 -0.00021434 -1.11808e-19 -0.000190229 9.82558e-20 0.000146983 0.000142893 0.000126819 0.00260417 0.0021434 0.0210621 0.00585676 0.00578346 0.00467426 -0.000520833 -8.68056e-05 -0.000260417 -3.38813e-21 -0.00042868 -7.14466e-05 -0.00021434 -1.17738e-19 -0.00117135 0.000195225 -0.00115669 0.000192782 -0.000934852 0.000155809 -0.00032526 -1.6263e-19 -0.000253086 -1.28749e-19 0.000173611 0.00021684 0.000142893 0.000168724 0.00260417 0.00585676 0.0162883 0.00228738 0.00553997 -0.000260417 -1.42302e-19 -0.000520833 -8.68056e-05 -0.00117135 -0.000195225 -0.00032526 -1.77877e-19 -0.000457476 7.62459e-05 -0.00110799 0.000184666 -0.000228738 -1.18585e-19 0.000173611 0.000152492 0.00021684 0.00228738 0.0143341 0.00238991 0.00477716 0.00487969 -0.000457476 -7.62459e-05 -0.000228738 -1.25361e-19 -0.000477982 7.96636e-05 -0.000955432 0.000159239 -0.000975938 0.000162656 -0.000238991 -1.18585e-19 -0.000248978 1.28749e-19 0.000152492 0.000159327 0.000165986 0.00238991 0.0143452 0.00232874 0.00478268 0.00484385 -0.000477982 -7.96636e-05 -0.000238991 -1.29596e-19 -0.000465749 7.76248e-05 -0.000956536 0.000159423 -0.000968769 0.000161462 -0.000232874 -1.21973e-19 -0.000245394 -1.28749e-19 0.00015525 0.000159327 0.000163596 0.00232874 0.0140201 0.00232374 0.00468632 0.00468132 -0.000465749 -7.76248e-05 -0.000232874 -1.26208e-19 -0.000464748 7.7458e-05 -0.000937265 0.000156211 -0.000936264 0.000156044 -0.000232374 -1.18585e-19 -0.000235758 1.21973e-19 0.00015525 0.000154916 0.000157172 0.00232374 0.0139707 0.00235233 0.00466161 0.00463302 -0.000464748 -7.7458e-05 -0.000232374 -1.27055e-19 -0.000470467 7.84111e-05 -0.000932321 0.000155387 -0.000926603 0.000154434 -0.000235233 -1.21973e-19 -0.000230927 -1.18585e-19 0.000156822 0.000154916 0.000153952 0.00235233 0.0131126 0.00219508 0.00436123 0.00420399 -0.000470467 -7.84111e-05 -0.000235233 -1.27902e-19 -0.000439017 7.31695e-05 -0.000872247 0.000145374 -0.000840797 0.000140133 -0.000219508 -1.11808e-19 -0.00020089 1.05032e-19 0.000156822 0.000146339 0.000133927 0.00260417 0.00219508 0.0212547 0.00585915 0.00582808 0.00476818 -0.000520833 -8.68056e-05 -0.000260417 -3.38813e-21 -0.000439017 -7.31695e-05 -0.000219508 -1.19432e-19 -0.00117183 0.000195305 -0.00116562 0.000194269 -0.000953636 0.000158939 -0.000325499 -1.69407e-19 -0.00025731 -1.32137e-19 0.000173611 0.000216999 0.000146339 0.00017154 0.00260417 0.00585915 0.016254 0.00226785 0.00552283 -0.000260417 -1.42302e-19 -0.000520833 -8.68056e-05 -0.00117183 -0.000195305 -0.000325499 -1.77877e-19 -0.000453569 7.55949e-05 -0.00110457 0.000184094 -0.000226785 -1.15196e-19 0.000173611 0.00015119 0.000216999 0.00226785 0.0138853 0.00228072 0.00466194 0.00467481 -0.000453569 -7.55949e-05 -0.000226785 -1.2282e-19 -0.000456144 7.60239e-05 -0.000932388 0.000155398 -0.000934963 0.000155827 -0.000228072 -1.18585e-19 -0.00023941 1.21973e-19 0.00015119 0.000152048 0.000159606 0.00228072 0.0134621 0.00215531 0.00445032 0.00457573 -0.000456144 -7.60239e-05 -0.000228072 -1.2282e-19 -0.000431062 7.18436e-05 -0.000890065 0.000148344 -0.000915147 0.000152524 -0.000215531 -1.0842e-19 -0.000229502 -1.15196e-19 0.000143687 0.000152048 0.000153001 0.00215531 0.0130849 0.00218893 0.00435354 0.00438717 -0.000431062 -7.18436e-05 -0.000215531 -1.17738e-19 -0.000437786 7.29644e-05 -0.000870709 0.000145118 -0.000877433 0.000146239 -0.000218893 -1.11808e-19 -0.000219824 1.11808e-19 0.000143687 0.000145929 0.000146549 0.00218893 0.0133995 0.00230402 0.00451081 0.00439572 -0.000437786 -7.29644e-05 -0.000218893 -1.18585e-19 -0.000460804 7.68007e-05 -0.000902162 0.00015036 -0.000879144 0.000146524 -0.000230402 -1.18585e-19 -0.000220679 -1.15196e-19 0.000153601 0.000145929 0.000147119 0.00230402 0.0129629 0.00218734 0.00429412 0.00417744 -0.000460804 -7.68007e-05 -0.000230402 -1.24514e-19 -0.000437468 7.29113e-05 -0.000858824 0.000143137 -0.000835488 0.000139248 -0.000218734 -1.11808e-19 -0.00019901 1.05032e-19 0.000153601 0.000145823 0.000132673 0.00260417 0.0058886 0.00218734 0.021317 0.00586698 0.00476988 -0.000260417 -3.38813e-21 -0.000520833 -8.68056e-05 -0.00117772 -0.000196287 -0.000328444 -1.01644e-20 -0.000437468 -7.29113e-05 -0.000218734 -1.20279e-19 -0.0011734 0.000195566 -0.000953976 0.000158996 -0.000258254 -1.32137e-19 0.000173611 0.000218962 0.000145823 0.000172169 0.00558272 0.00475257 0.00586698 0.0316705 0.00527279 0.00497975 0.00521572 -0.000229828 -5.0822e-21 -0.000328444 -1.81265e-19 -0.00111654 -0.000186091 -0.000950513 -0.000158419 -0.000245428 -5.0822e-21 -0.0011734 -0.000195566 -0.000258254 -1.42302e-19 -0.00105456 0.00017576 -0.00099595 0.000165992 -0.00104314 0.000173857 -0.00028185 -1.42302e-19 -0.000239721 1.25361e-19 0.000153219 0.000218962 0.000163619 0.0001879 0.000172169 0.000159814 0.00464288 0.00455563 0.0273626 0.0046814 0.00448984 0.00444425 0.00454856 -0.000225885 -8.47033e-21 -0.000928575 -0.000154763 -0.000238402 -1.30443e-19 -0.000911126 -0.000151854 -0.000229678 -8.47033e-21 -0.00093628 0.000156047 -0.000897969 0.000149661 -0.000888851 0.000148142 -0.000909713 0.000151619 -0.000229738 1.15196e-19 -0.000219307 -1.15196e-19 -0.000225119 -1.15196e-19 0.00015059 0.000158935 0.000153119 0.000146204 0.000153158 0.000150079 0.00465998 0.00441679 0.0282066 0.00459044 0.00442359 0.00509607 0.00501973 -0.000237377 -5.0822e-21 -0.000931996 -0.000155333 -0.000228621 -1.2282e-19 -0.000883358 -0.000147226 -0.000204302 -3.38813e-21 -0.000918089 0.000153015 -0.000884718 0.000147453 -0.00101921 0.000169869 -0.00100395 0.000167324 -0.000230423 1.18585e-19 -0.000238057 -1.25361e-19 -0.00027155 -1.38913e-19 0.000158251 0.000152414 0.000136201 0.000158705 0.000153615 0.000181033 0.00595416 0.00563211 0.00479613 0.0321497 0.00508905 0.00535371 0.00532457 -0.000333008 -1.01644e-20 -0.00119083 -0.000198472 -0.000262408 -1.42302e-19 -0.000230202 -5.0822e-21 -0.00112642 -0.000187737 -0.000959226 -0.000159871 -0.000249411 -6.77626e-21 -0.00101781 0.000169635 -0.00107074 0.000178457 -0.00106491 0.000177486 -0.000246497 1.21973e-19 -0.00028596 -1.49078e-19 0.000153468 0.000222005 0.000166274 0.000174938 0.000164331 0.00019064 0.00455091 0.0043796 0.0266468 0.0047088 0.00424451 0.00423499 0.00452796 -0.00021948 -6.77626e-21 -0.000910182 -0.000151697 -0.00023561 -1.28749e-19 -0.00087592 -0.000145987 -0.000218479 -5.0822e-21 -0.000941759 0.00015696 -0.000848903 0.000141484 -0.000846999 0.000141166 -0.000905593 0.000150932 -0.000235269 1.18585e-19 -0.000205972 -1.0842e-19 -0.000217527 -1.0842e-19 0.00014632 0.000157074 0.000145653 0.000137315 0.000156846 0.000145018 0.00432972 0.00410704 0.0258685 0.00416669 0.00415419 0.00466053 0.00445034 -0.000220475 -6.77626e-21 -0.000865943 -0.000144324 -0.000212497 -1.16891e-19 -0.000821408 -0.000136901 -0.000190229 -5.0822e-21 -0.000833337 0.00013889 -0.000830838 0.000138473 -0.000932106 0.000155351 -0.000890069 0.000148345 -0.000204172 1.05032e-19 -0.00022519 -1.15196e-19 -0.000240863 -1.21973e-19 0.000146983 0.000126819 0.000141665 0.000136115 0.000150127 0.000160575 0.00578346 0.00553997 0.00477716 0.0313612 0.0048697 0.00527093 0.00511998 -0.00032526 -6.77626e-21 -0.00115669 -0.000192782 -0.000253086 -1.37219e-19 -0.000228738 -6.77626e-21 -0.00110799 -0.000184666 -0.000955432 -0.000159239 -0.000248978 -8.47033e-21 -0.000973941 0.000162323 -0.00105419 0.000175698 -0.001024 0.000170666 -0.000233884 1.18585e-19 -0.000278114 -1.42302e-19 0.000152492 0.00021684 0.000165986 0.000185409 0.000168724 0.000155923 0.00478268 0.00468632 0.0284262 0.00484376 0.00467636 0.00468303 0.00475407 -0.000232874 -3.38813e-21 -0.000956536 -0.000159423 -0.000245394 -1.32137e-19 -0.000937265 -0.000156211 -0.000235758 -8.47033e-21 -0.000968753 0.000161459 -0.000935272 0.000155879 -0.000936606 0.000156101 -0.000950815 0.000158469 -0.000238983 1.21973e-19 -0.000231878 -1.18585e-19 -0.000236425 -1.18585e-19 0.00015525 0.000157172 0.000163596 0.000154585 0.000159322 0.000157617 0.00466161 0.00436123 0.0278942 0.00459698 0.00432534 0.00498889 0.00496015 -0.000235233 -6.77626e-21 -0.000932321 -0.000155387 -0.000230927 -1.27055e-19 -0.000872247 -0.000145374 -0.00020089 -3.38813e-21 -0.000919395 0.000153233 -0.000865069 0.000144178 -0.000997777 0.000166296 -0.000992029 0.000165338 -0.00022877 1.15196e-19 -0.000231644 -1.15196e-19 -0.000267245 -1.38913e-19 0.000156822 0.000133927 0.000153952 0.000154429 0.000152513 0.000178163 0.00582808 0.00552283 0.00466194 0.0312511 0.00494464 0.0051581 0.00513554 -0.000325499 -1.01644e-20 -0.00116562 -0.000194269 -0.00025731 -1.42302e-19 -0.000226785 -8.47033e-21 -0.00110457 -0.000184094 -0.000932388 -0.000155398 -0.00023941 -6.77626e-21 -0.000988928 0.000164821 -0.00103162 0.000171937 -0.00102711 0.000171185 -0.000237154 1.18585e-19 -0.0002764 -1.38913e-19 0.00015119 0.000216999 0.000159606 0.00017154 0.000158103 0.000184267 0.00445032 0.00435354 0.0261316 0.00448035 0.00427953 0.00423189 0.00433593 -0.000215531 -5.0822e-21 -0.000890065 -0.000148344 -0.000229502 -1.24514e-19 -0.000870709 -0.000145118 -0.000219824 -6.77626e-21 -0.00089607 0.000149345 -0.000855906 0.000142651 -0.000846379 0.000141063 -0.000867186 0.000144531 -0.000218533 1.11808e-19 -0.00020813 -1.0842e-19 -0.00021506 -1.11808e-19 0.000143687 0.000146549 0.000153001 0.000138753 0.000145689 0.000143373 0.00451081 0.00429412 0.0273317 0.00442687 0.0043015 0.00494489 0.00485356 -0.000230402 -5.0822e-21 -0.000902162 -0.00015036 -0.000220679 -1.21126e-19 -0.000858824 -0.000143137 -0.00019901 -3.38813e-21 -0.000885373 0.000147562 -0.000860301 0.000143383 -0.000988978 0.00016483 -0.000970712 0.000161785 -0.000222008 1.15196e-19 -0.000231141 -1.18585e-19 -0.000263348 -1.32137e-19 0.000153601 0.000132673 0.000147119 0.000148005 0.000154094 0.000175565 0.00481249 0.00474223 0.00527279 0.0046814 0.0298921 0.00493104 0.00545217 -0.000235821 -8.47033e-21 -0.000245428 -1.35525e-19 -0.000962498 -0.000160416 -0.000238402 -1.01644e-20 -0.000948446 -0.000158074 -0.00105456 -0.00017576 -0.00028185 -1.52466e-19 -0.00093628 -0.000156047 -0.000229738 -3.38813e-21 -0.000986208 0.000164368 -0.00109043 0.000181739 -0.000263367 -1.35525e-19 0.000157214 0.000158935 0.000163619 0.000153158 0.0001879 0.000175578 0.00458194 0.00457138 0.00448984 0.00459044 0.0272516 0.00445339 0.00456456 -0.000228517 -3.38813e-21 -0.000229678 -1.24514e-19 -0.000916389 -0.000152731 -0.000228621 -3.38813e-21 -0.000914276 -0.000152379 -0.000897969 -0.000149661 -0.000219307 -1.19432e-19 -0.000918089 -0.000153015 -0.000230423 -3.38813e-21 -0.000890679 0.000148446 -0.000912912 0.000152152 -0.000226033 1.21973e-19 0.000152344 0.000152414 0.000153119 0.000146204 0.000153615 0.000150689 0.0042762 0.00485725 0.00442359 0.00508905 0.0234916 0.00484554 -0.000223318 -6.77626e-21 -0.000204302 -1.10961e-19 -0.00085524 -0.00014254 -0.000262408 -8.47033e-21 -0.000971451 -0.000161908 -0.000884718 -0.000147453 -0.000238057 -1.29596e-19 -0.00101781 -0.000169635 -0.000246497 -1.01644e-20 -0.000969108 0.000161518 0.000148878 0.000136201 0.000158705 0.000174938 0.000164331 0.00486507 0.00472707 0.00535371 0.0047088 0.030371 0.00561162 0.00510471 -0.000237096 -5.0822e-21 -0.000249411 -1.35525e-19 -0.000973014 -0.000162169 -0.00023561 -5.0822e-21 -0.000945413 -0.000157569 -0.00107074 -0.000178457 -0.00028596 -1.57548e-19 -0.000941759 -0.00015696 -0.000235269 -8.47033e-21 -0.00112232 0.000187054 -0.00102094 0.000170157 -0.000275202 1.38913e-19 0.000158064 0.000157074 0.000166274 0.000156846 0.00019064 0.000183468 0.00430978 0.00424995 0.00424451 0.00416669 0.0252491 0.00414807 0.00413007 -0.000212498 -3.38813e-21 -0.000218479 -1.20279e-19 -0.000861955 -0.000143659 -0.000212497 -5.0822e-21 -0.00084999 -0.000141665 -0.000848903 -0.000141484 -0.000205972 -1.12655e-19 -0.000833337 -0.00013889 -0.000204172 -3.38813e-21 -0.000829615 0.000138269 -0.000826014 0.000137669 -0.000208835 1.11808e-19 0.000141666 0.000145653 0.000141665 0.000137315 0.000139224 0.000136115 0.00404569 0.00467426 0.00415419 0.0048697 0.0223346 0.00459074 -0.00021434 -5.0822e-21 -0.000190229 -1.03338e-19 -0.000809138 -0.000134856 -0.000253086 -5.0822e-21 -0.000934852 -0.000155809 -0.000830838 -0.000138473 -0.00022519 -1.2282e-19 -0.000973941 -0.000162323 -0.000233884 -3.38813e-21 -0.000918148 0.000153025 0.000142893 0.000126819 0.000168724 0.000155923 0.000150127 0.00487969 0.00484385 0.00527093 0.00484376 0.0304892 0.00552116 0.00512985 -0.000238991 -8.47033e-21 -0.000248978 -1.35525e-19 -0.000975938 -0.000162656 -0.000245394 -6.77626e-21 -0.000968769 -0.000161462 -0.00105419 -0.000175698 -0.000278114 -1.50772e-19 -0.000968753 -0.000161459 -0.000238983 -1.01644e-20 -0.00110423 0.000184039 -0.00102597 0.000170995 -0.000274002 1.38913e-19 0.000159327 0.000163596 0.000165986 0.000185409 0.000159322 0.000182668 0.00468132 0.00463302 0.00467636 0.00459698 0.0278813 0.00466237 0.00463129 -0.000232374 -5.0822e-21 -0.000235758 -1.29596e-19 -0.000936264 -0.000156044 -0.000230927 -5.0822e-21 -0.000926603 -0.000154434 -0.000935272 -0.000155879 -0.000231878 -1.27055e-19 -0.000919395 -0.000153233 -0.00022877 -6.77626e-21 -0.000932474 0.000155412 -0.000926258 0.000154376 -0.000234359 1.21973e-19 0.000154916 0.000157172 0.000153952 0.000154585 0.000156239 0.000152513 0.00420399 0.00476818 0.00432534 0.00494464 0.0229301 0.00468798 -0.000219508 -3.38813e-21 -0.00020089 -1.09267e-19 -0.000840797 -0.000140133 -0.00025731 -3.38813e-21 -0.000953636 -0.000158939 -0.000865069 -0.000144178 -0.000231644 -1.26208e-19 -0.000988928 -0.000164821 -0.000237154 -8.47033e-21 -0.000937597 0.000156266 0.000146339 0.000133927 0.00017154 0.000154429 0.000158103 0.00467481 0.00457573 0.0051581 0.00448035 0.0289194 0.00472588 0.00530456 -0.000228072 -6.77626e-21 -0.00023941 -1.30443e-19 -0.000934963 -0.000155827 -0.000229502 -3.38813e-21 -0.000915147 -0.000152524 -0.00103162 -0.000171937 -0.0002764 -1.52466e-19 -0.00089607 -0.000149345 -0.000218533 -5.0822e-21 -0.000945177 0.000157529 -0.00106091 0.000176819 -0.000254055 -1.28749e-19 0.000152048 0.000159606 0.000153001 0.000145689 0.000184267 0.00016937 0.00438717 0.00439572 0.00427953 0.00442687 0.026094 0.00423297 0.00437176 -0.000218893 -3.38813e-21 -0.000219824 -1.21126e-19 -0.000877433 -0.000146239 -0.000220679 -6.77626e-21 -0.000879144 -0.000146524 -0.000855906 -0.000142651 -0.00020813 -1.14349e-19 -0.000885373 -0.000147562 -0.000222008 -5.0822e-21 -0.000846595 0.000141099 -0.000874352 0.000145725 -0.000215168 1.11808e-19 0.000145929 0.000146549 0.000147119 0.000138753 0.000148005 0.000143445 0.00417744 0.00476988 0.00497975 0.0043015 0.0229372 0.00470862 -0.000218734 -3.38813e-21 -0.00019901 -1.09267e-19 -0.000835488 -0.000139248 -0.000258254 -8.47033e-21 -0.000953976 -0.000158996 -0.00099595 -0.000165992 -0.000239721 -6.77626e-21 -0.000860301 -0.000143383 -0.000231141 -1.25361e-19 -0.000941724 0.000156954 0.000145823 0.000132673 0.000172169 0.000159814 0.000154094 0.00423189 0.00423297 0.0242349 0.00391886 0.00435232 0.00396559 0.00353321 -0.00020813 -5.0822e-21 -0.000846379 -0.000141063 -0.00021506 -1.17738e-19 -0.000846595 -0.000141099 -0.000215168 -3.38813e-21 -0.000783772 0.000130629 -0.000870464 0.000145077 -0.000793118 0.000132186 -0.000706643 0.000117774 -0.000176827 9.14796e-20 -0.000220064 -1.11808e-19 -0.000176495 -9.14796e-20 0.000138753 0.000143373 0.000143445 0.000146709 0.000117884 0.000117663 0.00509607 0.00532457 0.00484554 0.00561162 0.0371921 0.00542756 0.00546337 0.00542342 -0.000238057 -6.77626e-21 -0.00101921 -0.000169869 -0.00027155 -1.49078e-19 -0.000246497 -1.34678e-19 -0.00028596 -6.77626e-21 -0.00106491 -0.000177486 -0.000969108 -0.000161518 -0.00112232 -0.000187054 -0.000275202 -3.38813e-21 -0.00108551 0.000180919 -0.00109267 0.000182112 -0.00108468 0.000180781 -0.000271206 1.42302e-19 -0.000271136 -1.38913e-19 0.000158705 0.000181033 0.000164331 0.00019064 0.000183468 0.000180804 0.000180757 0.00468303 0.00466237 0.0276996 0.00468683 0.00467345 0.00450061 0.00449334 -0.000231878 -3.38813e-21 -0.000936606 -0.000156101 -0.000236425 -1.28749e-19 -0.000932474 -0.000155412 -0.000234359 -6.77626e-21 -0.000937367 0.000156228 -0.000934689 0.000155782 -0.000900123 0.00015002 -0.000898668 0.000149778 -0.000232259 1.21973e-19 -0.000232986 -1.18585e-19 -0.000217076 -1.15196e-19 0.000154585 0.000157617 0.000156239 0.000155324 0.000154839 0.000144717 0.00423499 0.00414807 0.0237923 0.00433386 0.00380286 0.00341423 0.00385832 -0.000205972 -3.38813e-21 -0.000846999 -0.000141166 -0.000217527 -1.18585e-19 -0.000829615 -0.000138269 -0.000208835 -3.38813e-21 -0.000866772 0.000144462 -0.000760572 0.000126762 -0.000682846 0.000113808 -0.000771664 0.000128611 -0.000215859 1.11808e-19 -0.00017145 -8.47033e-20 -0.000169973 -8.80914e-20 0.000137315 0.000145018 0.000139224 0.0001143 0.000143906 0.000113315 0.00466053 0.00511998 0.00459074 0.00552116 0.0349119 0.00524315 0.00484091 0.00493542 -0.00022519 -8.47033e-21 -0.000932106 -0.000155351 -0.000240863 -1.30443e-19 -0.000233884 -1.28749e-19 -0.000278114 -1.01644e-20 -0.001024 -0.000170666 -0.000918148 -0.000153025 -0.00110423 -0.000184039 -0.000274002 -8.47033e-21 -0.00104863 0.000174772 -0.000968183 0.000161364 -0.000987084 0.000164514 -0.000250313 -1.25361e-19 -0.000243229 1.18585e-19 0.000185409 0.000155923 0.000182668 0.000150127 0.000160575 0.000162153 0.000166875 0.00444425 0.00445339 0.0255334 0.00454504 0.00417377 0.00377739 0.00413952 -0.000219307 -6.77626e-21 -0.000888851 -0.000148142 -0.000225119 -1.2282e-19 -0.000890679 -0.000148446 -0.000226033 -3.38813e-21 -0.000909008 0.000151501 -0.000834754 0.000139126 -0.000755477 0.000125913 -0.000827903 0.000137984 -0.000228471 -1.18585e-19 -0.000192258 9.82558e-20 -0.00018548 9.48677e-20 0.000146204 0.000150079 0.000150689 0.000128172 0.000152314 0.000123653 0.00475407 0.00512985 0.00468683 0.00524315 0.0289909 0.00467879 0.00449825 -0.000238983 -1.3129e-19 -0.000236425 -5.0822e-21 -0.000950815 -0.000158469 -0.000274002 -1.49078e-19 -0.00102597 -0.000170995 -0.000937367 -0.000156228 -0.000232259 -3.38813e-21 -0.00104863 -0.000174772 -0.000250313 -1.36372e-19 -0.000935759 0.00015596 -0.00089965 0.000149942 -0.000217566 1.15196e-19 0.000159322 0.000157617 0.000182668 0.000166875 0.000154839 0.000145044 0.00501973 0.00456456 0.00542756 0.00454504 0.029113 0.00499172 0.00456437 -0.000230423 -1.26208e-19 -0.00027155 -6.77626e-21 -0.00100395 -0.000167324 -0.000226033 -1.23667e-19 -0.000912912 -0.000152152 -0.00108551 -0.000180919 -0.000271206 -6.77626e-21 -0.000909008 -0.000151501 -0.000228471 -1.24514e-19 -0.000998344 0.000166391 -0.000912874 0.000152146 -0.000227966 -1.18585e-19 0.000153615 0.000181033 0.000150689 0.000180804 0.000152314 0.000151977 0.00433593 0.00472588 0.00391886 0.0258768 0.00504652 0.00355593 0.00429363 -0.000218533 -1.19432e-19 -0.00021506 -6.77626e-21 -0.000867186 -0.000144531 -0.000945177 -0.000157529 -0.000254055 -1.38913e-19 -0.000783772 -0.000130629 -0.000176827 -3.38813e-21 -0.0010093 0.000168217 -0.000711186 0.000118531 -0.000858727 0.000143121 -0.000250597 1.28749e-19 -0.000178767 -9.48677e-20 0.000145689 0.000143373 0.00016937 0.000117884 0.000167065 0.000119178 0.00498889 0.00513554 0.00468798 0.00530456 0.00504652 0.0354096 0.00520628 0.0050398 -0.000231644 -6.77626e-21 -0.000997777 -0.000166296 -0.000267245 -1.4569e-19 -0.000237154 -1.28749e-19 -0.0002764 -8.47033e-21 -0.00102711 -0.000171185 -0.000937597 -0.000156266 -0.000254055 -8.47033e-21 -0.00106091 -0.000176819 -0.0010093 -0.000168217 -0.000250597 -1.01644e-20 -0.00104126 0.000173543 -0.00100796 0.000167993 -0.000253384 1.28749e-19 0.000154429 0.000158103 0.000184267 0.00016937 0.000178163 0.000167065 0.000168922 0.00454856 0.00493104 0.00417377 0.027271 0.00525498 0.00383195 0.00453068 -0.000229738 -1.25361e-19 -0.000225119 -3.38813e-21 -0.000909713 -0.000151619 -0.000986208 -0.000164368 -0.000263367 -1.43996e-19 -0.000834754 -0.000139126 -0.000192258 -3.38813e-21 -0.001051 0.000175166 -0.00076639 0.000127732 -0.000906135 0.000151023 -0.000262131 1.32137e-19 -0.000190936 -9.82558e-20 0.000153158 0.000150079 0.000175578 0.000128172 0.000174754 0.000127291 0.00521572 0.00494489 0.00545217 0.00470862 0.00525498 0.0360169 0.00522634 0.00521417 -0.00028185 -6.77626e-21 -0.000239721 -1.30443e-19 -0.00104314 -0.000173857 -0.000231141 -1.69407e-21 -0.000988978 -0.00016483 -0.000263348 -1.4569e-19 -0.000263367 -1.69407e-21 -0.00109043 -0.000181739 -0.000941724 -0.000156954 -0.001051 -0.000175166 -0.000262131 -5.0822e-21 -0.00104527 0.000174211 -0.00104283 0.000173806 -0.000259286 1.32137e-19 0.0001879 0.000175578 0.000159814 0.000154094 0.000175565 0.000172857 0.000174754 0.00452796 0.00510471 0.00546337 0.00433386 0.028705 0.00491393 0.00436116 -0.000235269 -1.27902e-19 -0.000217527 -5.0822e-21 -0.000905593 -0.000150932 -0.000275202 -1.49078e-19 -0.00102094 -0.000170157 -0.00109267 -0.000182112 -0.000271136 -1.47384e-19 -0.000866772 -0.000144462 -0.000215859 -6.77626e-21 -0.000982786 0.000163798 -0.000872232 0.000145372 -0.000220257 1.11808e-19 0.000156846 0.000145018 0.000183468 0.000180757 0.000143906 0.000146838 0.00445034 0.00413007 0.00380286 0.00484091 0.0248257 0.00344186 0.00415964 -0.000204172 -1.10961e-19 -0.000240863 -5.0822e-21 -0.000890069 -0.000148345 -0.000208835 -1.13502e-19 -0.000826014 -0.000137669 -0.000760572 -0.000126762 -0.00017145 -9.31736e-20 -0.000968183 -0.000161364 -0.000243229 -6.77626e-21 -0.000688372 0.000114729 -0.000831929 0.000138655 -0.000172736 8.80914e-20 0.000139224 0.000136115 0.000160575 0.0001143 0.000162153 0.000115157 0.00496015 0.00463129 0.00467345 0.00520628 0.0287159 0.00452039 0.00472437 -0.00022877 -1.23667e-19 -0.000267245 -8.47033e-21 -0.000992029 -0.000165338 -0.000234359 -1.27902e-19 -0.000926258 -0.000154376 -0.000934689 -0.000155782 -0.000232986 -1.27055e-19 -0.00104126 -0.000173543 -0.000253384 -5.0822e-21 -0.000904078 0.00015068 -0.000944874 0.000157479 -0.000219053 1.11808e-19 0.000156239 0.000152513 0.000178163 0.000155324 0.000168922 0.000146036 0.00485356 0.00437176 0.00435232 0.00522634 0.0279483 0.00437604 0.00476826 -0.000222008 -1.21126e-19 -0.000263348 -3.38813e-21 -0.000970712 -0.000161785 -0.000215168 -1.16891e-19 -0.000874352 -0.000145725 -0.000870464 -0.000145077 -0.000220064 -1.20279e-19 -0.00104527 -0.000174211 -0.000259286 -6.77626e-21 -0.000875208 0.000145868 -0.000953652 0.000158942 -0.00021754 1.0842e-19 0.000148005 0.000143445 0.000175565 0.000146709 0.000172857 0.000145027 0.00396559 0.00437604 0.0256201 0.00353135 0.00463296 0.00421152 0.00490268 -0.000220064 -6.77626e-21 -0.000793118 -0.000132186 -0.000176495 -9.74088e-20 -0.000875208 -0.000145868 -0.00021754 -3.38813e-21 -0.000706269 0.000117712 -0.000926592 0.000154432 -0.000842304 0.000140384 -0.000980536 0.000163423 -0.00017664 9.14796e-20 -0.000245756 -1.25361e-19 -0.000244512 1.28749e-19 0.000146709 0.000117663 0.000145027 0.00011776 0.000163837 0.000163008 0.00450061 0.00452039 0.0264991 0.00439381 0.00441745 0.00431173 0.00435514 -0.000232986 -1.01644e-20 -0.000900123 -0.00015002 -0.000217076 -1.18585e-19 -0.000904078 -0.00015068 -0.000219053 -6.77626e-21 -0.000878763 0.00014646 -0.000883491 0.000147248 -0.000862345 0.000143724 -0.000871029 0.000145171 -0.000220328 -1.11808e-19 -0.00022467 1.15196e-19 -0.000210845 -1.05032e-19 0.000155324 0.000144717 0.000146036 0.000146885 0.000140563 0.00014978 0.00542342 0.00499172 0.00491393 0.0287476 0.00454306 0.00440731 0.00446814 -0.000271206 -1.47384e-19 -0.000271136 -6.77626e-21 -0.00108468 -0.000180781 -0.000998344 -0.000166391 -0.000227966 -1.24514e-19 -0.000982786 -0.000163798 -0.000220257 -6.77626e-21 -0.000908612 0.000151435 -0.000881463 0.00014691 -0.000893629 0.000148938 -0.00022634 1.15196e-19 -0.000220474 -1.15196e-19 0.000180804 0.000180757 0.000151977 0.000146838 0.000150894 0.000146983 0.00353321 0.00355593 0.00353135 0.0177617 0.00358124 0.00355997 -0.000176827 -9.65618e-20 -0.000176495 -5.0822e-21 -0.000706643 -0.000117774 -0.000711186 -0.000118531 -0.000178767 -9.82558e-20 -0.000706269 -0.000117712 -0.00017664 -5.0822e-21 -0.000716248 0.000119375 -0.000711995 0.000118666 -0.000179357 9.14796e-20 0.000117884 0.000117663 0.000119178 0.000119572 0.00011776 0.00341423 0.00344186 0.0171106 0.00344168 0.00339911 0.00341371 -0.00017145 -3.38813e-21 -0.000682846 -0.000113808 -0.000169973 -9.23266e-20 -0.000688372 -0.000114729 -0.000172736 -5.0822e-21 -0.000688336 0.000114723 -0.000679822 0.000113304 -0.000682741 0.00011379 -0.000171432 -8.80914e-20 -0.000169938 8.80914e-20 0.0001143 0.000115157 0.000113315 0.000114288 0.000113292 0.00493542 0.00467879 0.00415964 0.00344168 0.0253487 0.00429723 0.00383589 -0.000250313 -1.01644e-20 -0.000243229 -1.33831e-19 -0.000987084 -0.000164514 -0.000935759 -0.00015596 -0.000217566 -3.38813e-21 -0.000172736 -9.40207e-20 -0.000831929 -0.000138655 -0.000688336 -0.000114723 -0.000171432 -9.31736e-20 -0.000859447 0.000143241 -0.000767179 0.000127863 -0.000212157 -1.05032e-19 0.000162153 0.000115157 0.000166875 0.000145044 0.000114288 0.000141438 0.00377739 0.00383195 0.0199429 0.00397845 0.00407043 0.00428471 -0.000192258 -1.05032e-19 -0.000755477 -0.000125913 -0.00018548 -6.77626e-21 -0.00076639 -0.000127732 -0.000190936 -1.04185e-19 -0.00079569 0.000132615 -0.000814086 0.000135681 -0.000856943 0.000142824 -0.000212365 -1.0842e-19 -0.000216107 1.0842e-19 0.000128172 0.000123653 0.000127291 0.000144071 0.000141576 0.00413952 0.00456437 0.00454306 0.00397845 0.026528 0.00458141 0.00472116 -0.000228471 -3.38813e-21 -0.00018548 -1.00797e-19 -0.000827903 -0.000137984 -0.000227966 -6.77626e-21 -0.000912874 -0.000152146 -0.000908612 -0.000151435 -0.00022634 -6.77626e-21 -0.00079569 -0.000132615 -0.000212365 -1.16044e-19 -0.000916281 0.000152714 -0.000944233 0.000157372 -0.000245776 1.28749e-19 0.000152314 0.000123653 0.000151977 0.000141576 0.000150894 0.000163851 0.00429363 0.0050398 0.00472437 0.00439381 0.00358124 0.0260297 0.00399686 -0.000250597 -1.37219e-19 -0.000178767 -5.0822e-21 -0.000858727 -0.000143121 -0.000253384 -1.38913e-19 -0.00100796 -0.000167993 -0.000219053 -1.20279e-19 -0.000944874 -0.000157479 -0.000878763 -0.00014646 -0.000220328 -1.20279e-19 -0.000716248 -0.000119375 -0.000179357 -5.0822e-21 -0.000799371 0.000133229 0.000167065 0.000168922 0.000119178 0.000146036 0.000146885 0.000119572 0.00385832 0.00436116 0.00440731 0.00339911 0.0241521 0.00381043 0.00431579 -0.000215859 -1.18585e-19 -0.000169973 -5.0822e-21 -0.000771664 -0.000128611 -0.000220257 -1.21126e-19 -0.000872232 -0.000145372 -0.000881463 -0.00014691 -0.000220474 -1.20279e-19 -0.000679822 -0.000113304 -0.000169938 -5.0822e-21 -0.000762086 0.000127014 -0.000863158 0.00014386 -0.000211105 -1.0842e-19 0.000143906 0.000146838 0.000113315 0.000146983 0.000113292 0.000140737 0.00453068 0.00521417 0.00476826 0.00463296 0.00407043 0.0278351 0.00461862 -0.000262131 -1.43996e-19 -0.000190936 -5.0822e-21 -0.000906135 -0.000151023 -0.000259286 -1.43996e-19 -0.00104283 -0.000173806 -0.00021754 -1.18585e-19 -0.000953652 -0.000158942 -0.000926592 -0.000154432 -0.000245756 -1.33831e-19 -0.000814086 -0.000135681 -0.000216107 -8.47033e-21 -0.000923725 0.000153954 0.000172857 0.000145027 0.000174754 0.000127291 0.000163837 0.000144071 0.00449334 0.00449825 0.00441745 0.00429723 0.026186 0.00417732 0.00430245 -0.000232259 -1.26208e-19 -0.000217076 -5.0822e-21 -0.000898668 -0.000149778 -0.000217566 -1.19432e-19 -0.00089965 -0.000149942 -0.000883491 -0.000147248 -0.00022467 -5.0822e-21 -0.000859447 -0.000143241 -0.000212157 -1.14349e-19 -0.000835464 0.000139244 -0.00086049 0.000143415 -0.000205575 1.01644e-19 0.000154839 0.000145044 0.000144717 0.000141438 0.00014978 0.00013705 0.00421152 0.00431173 0.00355997 0.00399686 0.0253502 0.00480337 0.0044667 -0.00017664 -9.57147e-20 -0.000842304 -0.000140384 -0.000244512 -3.38813e-21 -0.000220328 -5.0822e-21 -0.000862345 -0.000143724 -0.000210845 -1.13502e-19 -0.000179357 -9.74088e-20 -0.000711995 -0.000118666 -0.000799371 -0.000133229 -0.000960675 0.000160112 -0.00089334 0.00014889 -0.000235825 -1.18585e-19 0.000146885 0.000119572 0.00011776 0.000163008 0.000140563 0.000157217 0.00341371 0.00383589 0.00381043 0.00417732 0.0235707 0.0041943 0.004139 -0.000171432 -5.0822e-21 -0.000169938 -9.23266e-20 -0.000682741 -0.00011379 -0.000212157 -8.47033e-21 -0.000767179 -0.000127863 -0.000762086 -0.000127014 -0.000211105 -1.14349e-19 -0.000835464 -0.000139244 -0.000205575 -6.77626e-21 -0.00083886 0.00013981 -0.000827801 0.000137967 -0.000208325 1.0842e-19 0.000114288 0.000141438 0.000113292 0.00013705 0.000140737 0.000138883 0.00490268 0.00428471 0.00458141 0.00461862 0.00480337 0.0330992 0.00500395 0.00490444 -0.000245756 -6.77626e-21 -0.000244512 -1.32984e-19 -0.000980536 -0.000163423 -0.000212365 -6.77626e-21 -0.000216107 -1.17738e-19 -0.000856943 -0.000142824 -0.000916281 -0.000152714 -0.000245776 -5.0822e-21 -0.000923725 -0.000153954 -0.000960675 -0.000160112 -0.000235825 -1.28749e-19 -0.00100079 0.000166798 -0.000980887 0.000163481 -0.000254619 -1.25361e-19 0.000163837 0.000163008 0.000144071 0.000141576 0.000163851 0.000157217 0.000169746 0.00446814 0.00472116 0.00431579 0.0041943 0.00500395 0.0273328 0.00462944 -0.00022634 -1.23667e-19 -0.000220474 -5.0822e-21 -0.000893629 -0.000148938 -0.000245776 -1.34678e-19 -0.000944233 -0.000157372 -0.000211105 -5.0822e-21 -0.000863158 -0.00014386 -0.00083886 -0.00013981 -0.000208325 -6.77626e-21 -0.00100079 -0.000166798 -0.000254619 -1.38913e-19 -0.000925887 0.000154315 0.000150894 0.000163851 0.000146983 0.000140737 0.000169746 0.000138883 0.00435514 0.00430245 0.0044667 0.004139 0.00490444 0.00462944 0.0267972 -0.00022467 -1.2282e-19 -0.000210845 -6.77626e-21 -0.000871029 -0.000145171 -0.000205575 -1.13502e-19 -0.00086049 -0.000143415 -0.000235825 -1.01644e-20 -0.00089334 -0.00014889 -0.000208325 -1.13502e-19 -0.000827801 -0.000137967 -0.000254619 -5.0822e-21 -0.000980887 -0.000163481 -0.000925887 -0.000154315 0.000140563 0.00014978 0.000157217 0.00013705 0.000169746 0.000138883 -0.000520833 -0.000520833 -0.000260417 8.68056e-05 4.23516e-22 4.34028e-05 -6.2004e-06 4.34028e-05 -6.2004e-06 -2.48016e-05 8.68056e-05 -8.68056e-05 -3.38813e-21 4.23516e-22 9.3006e-06 -6.2004e-06 3.1002e-06 6.2004e-06 -3.1002e-06 -1.27963e-21 -0.000520833 -0.000260417 -0.000520833 4.34028e-05 -6.2004e-06 8.68056e-05 2.00641e-20 4.34028e-05 6.2004e-06 -2.48016e-05 8.68056e-05 -1.42302e-19 -8.68056e-05 -6.2004e-06 3.1002e-06 2.00641e-20 9.3006e-06 6.2004e-06 3.1002e-06 -1.11173e-20 -0.000520833 -0.000520833 -0.000260417 8.68056e-05 2.00641e-20 4.34028e-05 -6.2004e-06 4.34028e-05 -6.2004e-06 -2.48016e-05 8.68056e-05 -8.68056e-05 -1.42302e-19 2.00641e-20 9.3006e-06 -6.2004e-06 3.1002e-06 6.2004e-06 -3.1002e-06 -1.13291e-20 -0.000520833 -0.000260417 -0.000520833 4.34028e-05 -6.2004e-06 8.68056e-05 4.23516e-22 4.34028e-05 6.2004e-06 -2.48016e-05 8.68056e-05 -3.38813e-21 -8.68056e-05 -6.2004e-06 3.1002e-06 4.23516e-22 9.3006e-06 6.2004e-06 3.1002e-06 -1.50092e-21 -0.000520833 -0.000520833 -0.000260417 8.68056e-05 2.00641e-20 4.34028e-05 -6.2004e-06 4.34028e-05 -6.2004e-06 -2.48016e-05 8.68056e-05 -8.68056e-05 -1.42302e-19 2.00641e-20 9.3006e-06 -6.2004e-06 3.1002e-06 6.2004e-06 -3.1002e-06 -1.13291e-20 -0.000520833 -0.000260417 -0.000520833 4.34028e-05 -6.2004e-06 8.68056e-05 4.23516e-22 4.34028e-05 6.2004e-06 -2.48016e-05 8.68056e-05 -3.38813e-21 -8.68056e-05 -6.2004e-06 3.1002e-06 4.23516e-22 9.3006e-06 6.2004e-06 3.1002e-06 -1.50092e-21 -0.000520833 -0.000520833 -0.000260417 8.68056e-05 2.00641e-20 4.34028e-05 -6.2004e-06 4.34028e-05 -6.2004e-06 -2.48016e-05 8.68056e-05 -8.68056e-05 -1.42302e-19 2.00641e-20 9.3006e-06 -6.2004e-06 3.1002e-06 6.2004e-06 -3.1002e-06 -1.13291e-20 -0.000520833 -0.000260417 -0.000520833 4.34028e-05 -6.2004e-06 8.68056e-05 4.23516e-22 4.34028e-05 6.2004e-06 -2.48016e-05 8.68056e-05 -3.38813e-21 -8.68056e-05 -6.2004e-06 3.1002e-06 4.23516e-22 9.3006e-06 6.2004e-06 3.1002e-06 -1.50092e-21 -0.000459656 -0.000459656 -0.000229828 7.66094e-05 0 3.83047e-05 -5.4721e-06 3.83047e-05 -5.4721e-06 -2.18884e-05 7.66094e-05 -7.66094e-05 -5.0822e-21 0 8.20815e-06 -5.4721e-06 2.73605e-06 5.4721e-06 -2.73605e-06 -1.01322e-21 -0.000260417 -0.00117772 -0.00117772 -0.000328444 4.34028e-05 6.2004e-06 4.34028e-05 6.2004e-06 0.000196287 4.7328e-20 5.47406e-05 -7.82009e-06 5.47406e-05 -7.82009e-06 -2.48016e-05 -3.12803e-05 -1.28749e-19 0.000196287 -0.000196287 -1.81265e-19 -6.2004e-06 -3.1002e-06 6.2004e-06 3.1002e-06 4.7328e-20 2.10307e-05 -7.82009e-06 3.91004e-06 7.82009e-06 -3.91004e-06 -1.01644e-20 -1.46113e-20 -0.00111654 -0.000229828 -0.000328444 -0.00111654 3.83047e-05 -5.4721e-06 5.47406e-05 -7.82009e-06 0.000186091 1.70465e-20 3.83047e-05 5.4721e-06 5.47406e-05 7.82009e-06 -2.18884e-05 -3.12803e-05 0.000186091 -1.24514e-19 -1.01644e-20 -0.000186091 -5.4721e-06 2.73605e-06 -7.82009e-06 3.91004e-06 1.70465e-20 1.99383e-05 5.4721e-06 2.73605e-06 7.82009e-06 3.91004e-06 -9.95264e-21 -1.60029e-21 -0.000471641 -0.000471641 -0.000235821 7.86068e-05 4.23516e-22 3.93034e-05 -5.61477e-06 3.93034e-05 -5.61477e-06 -2.24591e-05 7.86068e-05 -7.86068e-05 -8.47033e-21 4.23516e-22 8.42216e-06 -5.61477e-06 2.80739e-06 5.61477e-06 -2.80739e-06 -1.05159e-21 -0.000229828 -0.000950513 -0.000950513 -0.000245428 3.83047e-05 5.4721e-06 3.83047e-05 5.4721e-06 0.000158419 3.71106e-20 4.09047e-05 -5.84353e-06 4.09047e-05 -5.84353e-06 -2.18884e-05 -2.33741e-05 -1.15196e-19 0.000158419 -0.000158419 -1.35525e-19 -5.4721e-06 -2.73605e-06 5.4721e-06 2.73605e-06 3.71106e-20 1.69734e-05 -5.84353e-06 2.92177e-06 5.84353e-06 -2.92177e-06 -8.89385e-21 -1.0482e-20 -0.000962498 -0.000235821 -0.000245428 -0.000962498 3.93034e-05 -5.61477e-06 4.09047e-05 -5.84353e-06 0.000160416 1.86877e-20 3.93034e-05 5.61477e-06 4.09047e-05 5.84353e-06 -2.24591e-05 -2.33741e-05 0.000160416 -1.27902e-19 -5.0822e-21 -0.000160416 -5.61477e-06 2.80739e-06 -5.84353e-06 2.92177e-06 1.86877e-20 1.71875e-05 5.61477e-06 2.80739e-06 5.84353e-06 2.92177e-06 -9.95264e-21 -1.31778e-21 -0.000451771 -0.000451771 -0.000225885 7.52951e-05 -4.23516e-22 3.76476e-05 -5.37822e-06 3.76476e-05 -5.37822e-06 -2.15129e-05 7.52951e-05 -7.52951e-05 -8.47033e-21 -4.23516e-22 8.06733e-06 -5.37822e-06 2.68911e-06 5.37822e-06 -2.68911e-06 -8.80202e-22 -0.000928575 -0.000225885 -0.000928575 -0.000238402 3.76476e-05 -5.37822e-06 0.000154763 1.64113e-20 3.97337e-05 -5.67624e-06 3.76476e-05 5.37822e-06 3.97337e-05 -5.67624e-06 -2.15129e-05 -2.2705e-05 0.000154763 -1.2282e-19 -0.000154763 -1.01644e-20 -5.37822e-06 2.68911e-06 1.64113e-20 1.65817e-05 -5.67624e-06 2.83812e-06 5.37822e-06 2.68911e-06 5.67624e-06 -2.83812e-06 -9.84676e-21 -1.05341e-21 -0.000235821 -0.000948446 -0.000238402 -0.000948446 3.93034e-05 5.61477e-06 3.93034e-05 5.61477e-06 3.97337e-05 -5.67624e-06 0.000158074 3.4993e-20 3.97337e-05 5.67624e-06 -2.24591e-05 -2.2705e-05 -1.18585e-19 0.000158074 -1.30443e-19 -0.000158074 -5.61477e-06 -2.80739e-06 5.61477e-06 2.80739e-06 -5.67624e-06 2.83812e-06 3.4993e-20 1.69365e-05 5.67624e-06 2.83812e-06 -9.21148e-21 -1.01644e-20 -0.000457033 -0.000457033 -0.000228517 7.61722e-05 0 3.80861e-05 -5.44087e-06 3.80861e-05 -5.44087e-06 -2.17635e-05 7.61722e-05 -7.61722e-05 -3.38813e-21 0 8.16131e-06 -5.44087e-06 2.72044e-06 5.44087e-06 -2.72044e-06 -1.0179e-21 -0.000225885 -0.000911126 -0.000911126 -0.000229678 3.76476e-05 5.37822e-06 3.76476e-05 5.37822e-06 0.000151854 3.62107e-20 3.82796e-05 -5.46852e-06 3.82796e-05 -5.46852e-06 -2.15129e-05 -2.18741e-05 -1.15196e-19 0.000151854 -0.000151854 -1.24514e-19 -5.37822e-06 -2.68911e-06 5.37822e-06 2.68911e-06 3.62107e-20 1.62701e-05 -5.46852e-06 2.73426e-06 5.46852e-06 -2.73426e-06 -8.89385e-21 -9.95264e-21 -0.000916389 -0.000228517 -0.000229678 -0.000916389 3.80861e-05 -5.44087e-06 3.82796e-05 -5.46852e-06 0.000152731 1.70995e-20 3.80861e-05 5.44087e-06 3.82796e-05 5.46852e-06 -2.17635e-05 -2.18741e-05 0.000152731 -1.23667e-19 -8.47033e-21 -0.000152731 -5.44087e-06 2.72044e-06 -5.46852e-06 2.73426e-06 1.70995e-20 1.63641e-05 5.44087e-06 2.72044e-06 5.46852e-06 2.73426e-06 -9.95264e-21 -1.2278e-21 -0.000474754 -0.000474754 -0.000237377 7.91257e-05 -4.23516e-22 3.95628e-05 -5.65183e-06 3.95628e-05 -5.65183e-06 -2.26073e-05 7.91257e-05 -7.91257e-05 -5.0822e-21 -4.23516e-22 8.47775e-06 -5.65183e-06 2.82592e-06 5.65183e-06 -2.82592e-06 -1.21399e-21 -0.000931996 -0.000237377 -0.000931996 -0.000228621 3.95628e-05 -5.65183e-06 0.000155333 1.81053e-20 3.81035e-05 -5.44336e-06 3.95628e-05 5.65183e-06 3.81035e-05 -5.44336e-06 -2.26073e-05 -2.17735e-05 0.000155333 -1.29596e-19 -0.000155333 -3.38813e-21 -5.65183e-06 2.82592e-06 1.81053e-20 1.66428e-05 -5.44336e-06 2.72168e-06 5.65183e-06 2.82592e-06 5.44336e-06 -2.72168e-06 -1.01644e-20 -9.57355e-22 -0.000228517 -0.000914276 -0.000228621 -0.000914276 3.80861e-05 5.44087e-06 3.80861e-05 5.44087e-06 3.81035e-05 -5.44336e-06 0.000152379 3.62107e-20 3.81035e-05 5.44336e-06 -2.17635e-05 -2.17735e-05 -1.15196e-19 0.000152379 -1.2282e-19 -0.000152379 -5.44087e-06 -2.72044e-06 5.44087e-06 2.72044e-06 -5.44336e-06 2.72168e-06 3.62107e-20 1.63264e-05 5.44336e-06 2.72168e-06 -8.68209e-21 -9.95264e-21 -0.000446635 -0.000446635 -0.000223318 7.44392e-05 -4.23516e-22 3.72196e-05 -5.31709e-06 3.72196e-05 -5.31709e-06 -2.12683e-05 7.44392e-05 -7.44392e-05 -6.77626e-21 -4.23516e-22 7.97563e-06 -5.31709e-06 2.65854e-06 5.31709e-06 -2.65854e-06 -9.74759e-22 -0.000237377 -0.000883358 -0.000883358 -0.000204302 3.95628e-05 5.65183e-06 3.95628e-05 5.65183e-06 0.000147226 3.45695e-20 3.40504e-05 -4.86434e-06 3.40504e-05 -4.86434e-06 -2.26073e-05 -1.94574e-05 -1.25361e-19 0.000147226 -0.000147226 -1.10961e-19 -5.65183e-06 -2.82592e-06 5.65183e-06 2.82592e-06 3.45695e-20 1.57743e-05 -4.86434e-06 2.43217e-06 4.86434e-06 -2.43217e-06 -9.42324e-21 -8.78797e-21 -0.00085524 -0.000223318 -0.000204302 -0.00085524 3.72196e-05 -5.31709e-06 3.40504e-05 -4.86434e-06 0.00014254 1.78406e-20 3.72196e-05 5.31709e-06 3.40504e-05 4.86434e-06 -2.12683e-05 -1.94574e-05 0.00014254 -1.2282e-19 -3.38813e-21 -0.00014254 -5.31709e-06 2.65854e-06 -4.86434e-06 2.43217e-06 1.78406e-20 1.52721e-05 5.31709e-06 2.65854e-06 4.86434e-06 2.43217e-06 -9.52912e-21 -9.5929e-22 -0.000260417 -0.00118685 -0.00118685 -0.000333008 4.34028e-05 6.2004e-06 4.34028e-05 6.2004e-06 0.000197808 -2.28699e-20 5.55014e-05 -7.92876e-06 5.55014e-05 -7.92876e-06 -2.48016e-05 -3.17151e-05 1.28749e-19 0.000197808 -0.000197808 -1.01644e-20 -6.2004e-06 -3.1002e-06 6.2004e-06 3.1002e-06 -2.28699e-20 2.11937e-05 -7.92876e-06 3.96438e-06 7.92876e-06 -3.96438e-06 1.03762e-20 -1.59924e-21 -0.00119083 -0.000333008 -0.00119083 -0.000262408 5.55014e-05 -7.92876e-06 0.000198472 2.48816e-20 4.37346e-05 -6.2478e-06 5.55014e-05 7.92876e-06 4.37346e-05 -6.2478e-06 -3.17151e-05 -2.49912e-05 0.000198472 -1.82959e-19 -0.000198472 -8.47033e-21 -7.92876e-06 3.96438e-06 2.48816e-20 2.12649e-05 -6.2478e-06 3.1239e-06 7.92876e-06 3.96438e-06 6.2478e-06 -3.1239e-06 -1.41878e-20 -1.2154e-21 -0.000223318 -0.000971451 -0.000262408 -0.000971451 3.72196e-05 5.31709e-06 3.72196e-05 5.31709e-06 4.37346e-05 -6.2478e-06 0.000161908 3.74283e-20 4.37346e-05 6.2478e-06 -2.12683e-05 -2.49912e-05 -1.11808e-19 0.000161908 -1.42302e-19 -0.000161908 -5.31709e-06 -2.65854e-06 5.31709e-06 2.65854e-06 -6.2478e-06 3.1239e-06 3.74283e-20 1.73473e-05 6.2478e-06 3.1239e-06 -8.99973e-21 -1.11173e-20 -0.000460405 -0.000460405 -0.000230202 7.67341e-05 -8.47033e-22 3.83671e-05 -5.48101e-06 3.83671e-05 -5.48101e-06 -2.1924e-05 7.67341e-05 -7.67341e-05 -5.0822e-21 -8.47033e-22 8.22151e-06 -5.48101e-06 2.7405e-06 5.48101e-06 -2.7405e-06 -9.46847e-22 -0.000333008 -0.00112642 -0.000230202 -0.00112642 5.55014e-05 7.92876e-06 5.55014e-05 7.92876e-06 3.83671e-05 -5.48101e-06 0.000187737 4.19281e-20 3.83671e-05 5.48101e-06 -2.1924e-05 -3.17151e-05 -1.69407e-19 0.000187737 -1.23667e-19 -0.000187737 -7.92876e-06 -3.96438e-06 7.92876e-06 3.96438e-06 -5.48101e-06 2.7405e-06 4.19281e-20 2.01147e-05 5.48101e-06 2.7405e-06 -9.95264e-21 -1.33408e-20 -0.000474192 -0.000474192 -0.000237096 7.9032e-05 0 3.9516e-05 -5.64515e-06 3.9516e-05 -5.64515e-06 -2.25806e-05 7.9032e-05 -7.9032e-05 -5.0822e-21 0 8.46772e-06 -5.64515e-06 2.82257e-06 5.64515e-06 -2.82257e-06 -1.10787e-21 -0.000230202 -0.000959226 -0.000959226 -0.000249411 3.83671e-05 5.48101e-06 3.83671e-05 5.48101e-06 0.000159871 3.48342e-20 4.15684e-05 -5.93835e-06 4.15684e-05 -5.93835e-06 -2.1924e-05 -2.37534e-05 -1.18585e-19 0.000159871 -0.000159871 -1.35525e-19 -5.48101e-06 -2.7405e-06 5.48101e-06 2.7405e-06 3.48342e-20 1.7129e-05 -5.93835e-06 2.96917e-06 5.93835e-06 -2.96917e-06 -8.99973e-21 -1.07997e-20 -0.000973014 -0.000237096 -0.000249411 -0.000973014 3.9516e-05 -5.64515e-06 4.15684e-05 -5.93835e-06 0.000162169 1.73642e-20 3.9516e-05 5.64515e-06 4.15684e-05 5.93835e-06 -2.25806e-05 -2.37534e-05 0.000162169 -1.29596e-19 -6.77626e-21 -0.000162169 -5.64515e-06 2.82257e-06 -5.93835e-06 2.96917e-06 1.73642e-20 1.73752e-05 5.64515e-06 2.82257e-06 5.93835e-06 2.96917e-06 -1.0482e-20 -1.29252e-21 -0.000438961 -0.000438961 -0.00021948 7.31601e-05 -4.23516e-22 3.65801e-05 -5.22572e-06 3.65801e-05 -5.22572e-06 -2.09029e-05 7.31601e-05 -7.31601e-05 -6.77626e-21 -4.23516e-22 7.83859e-06 -5.22572e-06 2.61286e-06 5.22572e-06 -2.61286e-06 -8.06128e-22 -0.000910182 -0.00021948 -0.000910182 -0.00023561 3.65801e-05 -5.22572e-06 0.000151697 1.72583e-20 3.92684e-05 -5.60977e-06 3.65801e-05 5.22572e-06 3.92684e-05 -5.60977e-06 -2.09029e-05 -2.24391e-05 0.000151697 -1.19432e-19 -0.000151697 -5.0822e-21 -5.22572e-06 2.61286e-06 1.72583e-20 1.62532e-05 -5.60977e-06 2.80489e-06 5.22572e-06 2.61286e-06 5.60977e-06 -2.80489e-06 -9.31736e-21 -1.14258e-21 -0.000237096 -0.000945413 -0.00023561 -0.000945413 3.9516e-05 5.64515e-06 3.9516e-05 5.64515e-06 3.92684e-05 -5.60977e-06 0.000157569 3.43048e-20 3.92684e-05 5.60977e-06 -2.25806e-05 -2.24391e-05 -1.18585e-19 0.000157569 -1.28749e-19 -0.000157569 -5.64515e-06 -2.82257e-06 5.64515e-06 2.82257e-06 -5.60977e-06 2.80489e-06 3.43048e-20 1.68824e-05 5.60977e-06 2.80489e-06 -9.42324e-21 -1.03762e-20 -0.000424997 -0.000424997 -0.000212498 7.08328e-05 0 3.54164e-05 -5.05948e-06 3.54164e-05 -5.05948e-06 -2.02379e-05 7.08328e-05 -7.08328e-05 -3.38813e-21 0 7.58922e-06 -5.05948e-06 2.52974e-06 5.05948e-06 -2.52974e-06 -9.29052e-22 -0.00021948 -0.00087592 -0.00087592 -0.000218479 3.65801e-05 5.22572e-06 3.65801e-05 5.22572e-06 0.000145987 3.38284e-20 3.64132e-05 -5.20189e-06 3.64132e-05 -5.20189e-06 -2.09029e-05 -2.08076e-05 -1.11808e-19 0.000145987 -0.000145987 -1.20279e-19 -5.22572e-06 -2.61286e-06 5.22572e-06 2.61286e-06 3.38284e-20 1.56414e-05 -5.20189e-06 2.60095e-06 5.20189e-06 -2.60095e-06 -8.47033e-21 -9.42324e-21 -0.000861955 -0.000212498 -0.000218479 -0.000861955 3.54164e-05 -5.05948e-06 3.64132e-05 -5.20189e-06 0.000143659 1.5776e-20 3.54164e-05 5.05948e-06 3.64132e-05 5.20189e-06 -2.02379e-05 -2.08076e-05 0.000143659 -1.16891e-19 -5.0822e-21 -0.000143659 -5.05948e-06 2.52974e-06 -5.20189e-06 2.60095e-06 1.5776e-20 1.53921e-05 5.05948e-06 2.52974e-06 5.20189e-06 2.60095e-06 -8.99973e-21 -1.19931e-21 -0.000440949 -0.000440949 -0.000220475 7.34916e-05 -4.23516e-22 3.67458e-05 -5.2494e-06 3.67458e-05 -5.2494e-06 -2.09976e-05 7.34916e-05 -7.34916e-05 -6.77626e-21 -4.23516e-22 7.87409e-06 -5.2494e-06 2.6247e-06 5.2494e-06 -2.6247e-06 -1.01694e-21 -0.000865943 -0.000220475 -0.000865943 -0.000212497 3.67458e-05 -5.2494e-06 0.000144324 1.69936e-20 3.54161e-05 -5.05945e-06 3.67458e-05 5.2494e-06 3.54161e-05 -5.05945e-06 -2.09976e-05 -2.02378e-05 0.000144324 -1.19432e-19 -0.000144324 -5.0822e-21 -5.2494e-06 2.6247e-06 1.69936e-20 1.54633e-05 -5.05945e-06 2.52972e-06 5.2494e-06 2.6247e-06 5.05945e-06 -2.52972e-06 -9.21148e-21 -9.05794e-22 -0.000212498 -0.00084999 -0.000212497 -0.00084999 3.54164e-05 5.05948e-06 3.54164e-05 5.05948e-06 3.54161e-05 -5.05945e-06 0.000141665 3.35107e-20 3.54161e-05 5.05945e-06 -2.02379e-05 -2.02378e-05 -1.0842e-19 0.000141665 -1.16891e-19 -0.000141665 -5.05948e-06 -2.52974e-06 5.05948e-06 2.52974e-06 -5.05945e-06 2.52972e-06 3.35107e-20 1.51784e-05 5.05945e-06 2.52972e-06 -8.04681e-21 -8.99973e-21 -0.00042868 -0.00042868 -0.00021434 7.14466e-05 4.23516e-22 3.57233e-05 -5.10333e-06 3.57233e-05 -5.10333e-06 -2.04133e-05 7.14466e-05 -7.14466e-05 -5.0822e-21 4.23516e-22 7.65499e-06 -5.10333e-06 2.55166e-06 5.10333e-06 -2.55166e-06 -9.35689e-22 -0.000220475 -0.000821408 -0.000821408 -0.000190229 3.67458e-05 5.2494e-06 3.67458e-05 5.2494e-06 0.000136901 3.28755e-20 3.17049e-05 -4.52927e-06 3.17049e-05 -4.52927e-06 -2.09976e-05 -1.81171e-05 -1.15196e-19 0.000136901 -0.000136901 -1.03338e-19 -5.2494e-06 -2.6247e-06 5.2494e-06 2.6247e-06 3.28755e-20 1.4668e-05 -4.52927e-06 2.26463e-06 4.52927e-06 -2.26463e-06 -8.78797e-21 -8.47033e-21 -0.000809138 -0.00021434 -0.000190229 -0.000809138 3.57233e-05 -5.10333e-06 3.17049e-05 -4.52927e-06 0.000134856 1.59348e-20 3.57233e-05 5.10333e-06 3.17049e-05 4.52927e-06 -2.04133e-05 -1.81171e-05 0.000134856 -1.17738e-19 -5.0822e-21 -0.000134856 -5.10333e-06 2.55166e-06 -4.52927e-06 2.26463e-06 1.59348e-20 1.44489e-05 5.10333e-06 2.55166e-06 4.52927e-06 2.26463e-06 -9.31736e-21 -9.42087e-22 -0.000260417 -0.00117135 -0.00117135 -0.00032526 4.34028e-05 6.2004e-06 4.34028e-05 6.2004e-06 0.000195225 -2.20229e-20 5.42099e-05 -7.74428e-06 5.42099e-05 -7.74428e-06 -2.48016e-05 -3.09771e-05 1.28749e-19 0.000195225 -0.000195225 -6.77626e-21 -6.2004e-06 -3.1002e-06 6.2004e-06 3.1002e-06 -2.20229e-20 2.0917e-05 -7.74428e-06 3.87214e-06 7.74428e-06 -3.87214e-06 1.03762e-20 -1.24845e-21 -0.00115669 -0.00032526 -0.00115669 -0.000253086 5.42099e-05 -7.74428e-06 0.000192782 2.47757e-20 4.21811e-05 -6.02587e-06 5.42099e-05 7.74428e-06 4.21811e-05 -6.02587e-06 -3.09771e-05 -2.41035e-05 0.000192782 -1.77877e-19 -0.000192782 -5.0822e-21 -7.74428e-06 3.87214e-06 2.47757e-20 2.06552e-05 -6.02587e-06 3.01293e-06 7.74428e-06 3.87214e-06 6.02587e-06 -3.01293e-06 -1.41878e-20 -1.07568e-21 -0.00021434 -0.000934852 -0.000253086 -0.000934852 3.57233e-05 5.10333e-06 3.57233e-05 5.10333e-06 4.21811e-05 -6.02587e-06 0.000155809 3.4993e-20 4.21811e-05 6.02587e-06 -2.04133e-05 -2.41035e-05 -1.11808e-19 0.000155809 -1.37219e-19 -0.000155809 -5.10333e-06 -2.55166e-06 5.10333e-06 2.55166e-06 -6.02587e-06 3.01293e-06 3.4993e-20 1.66938e-05 6.02587e-06 3.01293e-06 -8.47033e-21 -1.09055e-20 -0.000457476 -0.000457476 -0.000228738 7.62459e-05 4.23516e-22 3.8123e-05 -5.44614e-06 3.8123e-05 -5.44614e-06 -2.17846e-05 7.62459e-05 -7.62459e-05 -6.77626e-21 4.23516e-22 8.16921e-06 -5.44614e-06 2.72307e-06 5.44614e-06 -2.72307e-06 -1.20088e-21 -0.00032526 -0.00110799 -0.000228738 -0.00110799 5.42099e-05 7.74428e-06 5.42099e-05 7.74428e-06 3.8123e-05 -5.44614e-06 0.000184666 4.25634e-20 3.8123e-05 5.44614e-06 -2.17846e-05 -3.09771e-05 -1.6263e-19 0.000184666 -1.25361e-19 -0.000184666 -7.74428e-06 -3.87214e-06 7.74428e-06 3.87214e-06 -5.44614e-06 2.72307e-06 4.25634e-20 1.97856e-05 5.44614e-06 2.72307e-06 -9.74088e-21 -1.27055e-20 -0.000477982 -0.000477982 -0.000238991 7.96636e-05 0 3.98318e-05 -5.69026e-06 3.98318e-05 -5.69026e-06 -2.2761e-05 7.96636e-05 -7.96636e-05 -8.47033e-21 0 8.53538e-06 -5.69026e-06 2.84513e-06 5.69026e-06 -2.84513e-06 -9.75323e-22 -0.000228738 -0.000955432 -0.000955432 -0.000248978 3.8123e-05 5.44614e-06 3.8123e-05 5.44614e-06 0.000159239 3.5893e-20 4.14964e-05 -5.92806e-06 4.14964e-05 -5.92806e-06 -2.17846e-05 -2.37122e-05 -1.18585e-19 0.000159239 -0.000159239 -1.35525e-19 -5.44614e-06 -2.72307e-06 5.44614e-06 2.72307e-06 3.5893e-20 1.70613e-05 -5.92806e-06 2.96403e-06 5.92806e-06 -2.96403e-06 -8.99973e-21 -1.06938e-20 -0.000975938 -0.000238991 -0.000248978 -0.000975938 3.98318e-05 -5.69026e-06 4.14964e-05 -5.92806e-06 0.000162656 1.8423e-20 3.98318e-05 5.69026e-06 4.14964e-05 5.92806e-06 -2.2761e-05 -2.37122e-05 0.000162656 -1.29596e-19 -8.47033e-21 -0.000162656 -5.69026e-06 2.84513e-06 -5.92806e-06 2.96403e-06 1.8423e-20 1.74275e-05 5.69026e-06 2.84513e-06 5.92806e-06 2.96403e-06 -1.02703e-20 -1.32496e-21 -0.000465749 -0.000465749 -0.000232874 7.76248e-05 0 3.88124e-05 -5.54463e-06 3.88124e-05 -5.54463e-06 -2.21785e-05 7.76248e-05 -7.76248e-05 -3.38813e-21 0 8.31694e-06 -5.54463e-06 2.77231e-06 5.54463e-06 -2.77231e-06 -1.22986e-21 -0.000956536 -0.000232874 -0.000956536 -0.000245394 3.88124e-05 -5.54463e-06 0.000159423 1.65171e-20 4.0899e-05 -5.84271e-06 3.88124e-05 5.54463e-06 4.0899e-05 -5.84271e-06 -2.21785e-05 -2.33708e-05 0.000159423 -1.26208e-19 -0.000159423 -6.77626e-21 -5.54463e-06 2.77231e-06 1.65171e-20 1.7081e-05 -5.84271e-06 2.92136e-06 5.54463e-06 2.77231e-06 5.84271e-06 -2.92136e-06 -9.95264e-21 -9.25353e-22 -0.000238991 -0.000968769 -0.000245394 -0.000968769 3.98318e-05 5.69026e-06 3.98318e-05 5.69026e-06 4.0899e-05 -5.84271e-06 0.000161462 3.68459e-20 4.0899e-05 5.84271e-06 -2.2761e-05 -2.33708e-05 -1.18585e-19 0.000161462 -1.32137e-19 -0.000161462 -5.69026e-06 -2.84513e-06 5.69026e-06 2.84513e-06 -5.84271e-06 2.92136e-06 3.68459e-20 1.72994e-05 5.84271e-06 2.92136e-06 -9.31736e-21 -1.05879e-20 -0.000464748 -0.000464748 -0.000232374 7.7458e-05 -4.23516e-22 3.8729e-05 -5.53272e-06 3.8729e-05 -5.53272e-06 -2.21309e-05 7.7458e-05 -7.7458e-05 -5.0822e-21 -4.23516e-22 8.29908e-06 -5.53272e-06 2.76636e-06 5.53272e-06 -2.76636e-06 -9.86042e-22 -0.000232874 -0.000937265 -0.000937265 -0.000235758 3.88124e-05 5.54463e-06 3.88124e-05 5.54463e-06 0.000156211 3.63695e-20 3.9293e-05 -5.61328e-06 3.9293e-05 -5.61328e-06 -2.21785e-05 -2.24531e-05 -1.21973e-19 0.000156211 -0.000156211 -1.29596e-19 -5.54463e-06 -2.77231e-06 5.54463e-06 2.77231e-06 3.63695e-20 1.67369e-05 -5.61328e-06 2.80664e-06 5.61328e-06 -2.80664e-06 -9.1056e-21 -1.01644e-20 -0.000936264 -0.000232374 -0.000235758 -0.000936264 3.8729e-05 -5.53272e-06 3.9293e-05 -5.61328e-06 0.000156044 1.77348e-20 3.8729e-05 5.53272e-06 3.9293e-05 5.61328e-06 -2.21309e-05 -2.24531e-05 0.000156044 -1.27055e-19 -8.47033e-21 -0.000156044 -5.53272e-06 2.76636e-06 -5.61328e-06 2.80664e-06 1.77348e-20 1.6719e-05 5.53272e-06 2.76636e-06 5.61328e-06 2.80664e-06 -1.01644e-20 -1.14921e-21 -0.000470467 -0.000470467 -0.000235233 7.84111e-05 4.23516e-22 3.92056e-05 -5.60079e-06 3.92056e-05 -5.60079e-06 -2.24032e-05 7.84111e-05 -7.84111e-05 -6.77626e-21 4.23516e-22 8.40119e-06 -5.60079e-06 2.8004e-06 5.60079e-06 -2.8004e-06 -1.12026e-21 -0.000932321 -0.000235233 -0.000932321 -0.000230927 3.92056e-05 -5.60079e-06 0.000155387 1.81053e-20 3.84879e-05 -5.49827e-06 3.92056e-05 5.60079e-06 3.84879e-05 -5.49827e-06 -2.24032e-05 -2.19931e-05 0.000155387 -1.27902e-19 -0.000155387 -5.0822e-21 -5.60079e-06 2.8004e-06 1.81053e-20 1.66486e-05 -5.49827e-06 2.74914e-06 5.60079e-06 2.8004e-06 5.49827e-06 -2.74914e-06 -9.84676e-21 -8.98413e-22 -0.000232374 -0.000926603 -0.000230927 -0.000926603 3.8729e-05 5.53272e-06 3.8729e-05 5.53272e-06 3.84879e-05 -5.49827e-06 0.000154434 3.49401e-20 3.84879e-05 5.49827e-06 -2.21309e-05 -2.19931e-05 -1.18585e-19 0.000154434 -1.27055e-19 -0.000154434 -5.53272e-06 -2.76636e-06 5.53272e-06 2.76636e-06 -5.49827e-06 2.74914e-06 3.49401e-20 1.65465e-05 5.49827e-06 2.74914e-06 -9.42324e-21 -9.95264e-21 -0.000439017 -0.000439017 -0.000219508 7.31695e-05 -4.23516e-22 3.65847e-05 -5.22639e-06 3.65847e-05 -5.22639e-06 -2.09056e-05 7.31695e-05 -7.31695e-05 -3.38813e-21 -4.23516e-22 7.83959e-06 -5.22639e-06 2.6132e-06 5.22639e-06 -2.6132e-06 -9.02727e-22 -0.000235233 -0.000872247 -0.000872247 -0.00020089 3.92056e-05 5.60079e-06 3.92056e-05 5.60079e-06 0.000145374 3.36696e-20 3.34817e-05 -4.7831e-06 3.34817e-05 -4.7831e-06 -2.24032e-05 -1.91324e-05 -1.21973e-19 0.000145374 -0.000145374 -1.09267e-19 -5.60079e-06 -2.8004e-06 5.60079e-06 2.8004e-06 3.36696e-20 1.55758e-05 -4.7831e-06 2.39155e-06 4.7831e-06 -2.39155e-06 -9.31736e-21 -8.89385e-21 -0.000840797 -0.000219508 -0.00020089 -0.000840797 3.65847e-05 -5.22639e-06 3.34817e-05 -4.7831e-06 0.000140133 1.65171e-20 3.65847e-05 5.22639e-06 3.34817e-05 4.7831e-06 -2.09056e-05 -1.91324e-05 0.000140133 -1.19432e-19 -3.38813e-21 -0.000140133 -5.22639e-06 2.6132e-06 -4.7831e-06 2.39155e-06 1.65171e-20 1.50142e-05 5.22639e-06 2.6132e-06 4.7831e-06 2.39155e-06 -9.31736e-21 -1.13497e-21 -0.000260417 -0.00117183 -0.00117183 -0.000325499 4.34028e-05 6.2004e-06 4.34028e-05 6.2004e-06 0.000195305 -2.03288e-20 5.42498e-05 -7.74997e-06 5.42498e-05 -7.74997e-06 -2.48016e-05 -3.09999e-05 1.28749e-19 0.000195305 -0.000195305 -1.01644e-20 -6.2004e-06 -3.1002e-06 6.2004e-06 3.1002e-06 -2.03288e-20 2.09255e-05 -7.74997e-06 3.87498e-06 7.74997e-06 -3.87498e-06 1.03762e-20 -1.65219e-21 -0.00116562 -0.000325499 -0.00116562 -0.00025731 5.42498e-05 -7.74997e-06 0.000194269 2.47757e-20 4.2885e-05 -6.12642e-06 5.42498e-05 7.74997e-06 4.2885e-05 -6.12642e-06 -3.09999e-05 -2.45057e-05 0.000194269 -1.77877e-19 -0.000194269 -3.38813e-21 -7.74997e-06 3.87498e-06 2.47757e-20 2.08146e-05 -6.12642e-06 3.06321e-06 7.74997e-06 3.87498e-06 6.12642e-06 -3.06321e-06 -1.3976e-20 -1.11427e-21 -0.000219508 -0.000953636 -0.00025731 -0.000953636 3.65847e-05 5.22639e-06 3.65847e-05 5.22639e-06 4.2885e-05 -6.12642e-06 0.000158939 3.69518e-20 4.2885e-05 6.12642e-06 -2.09056e-05 -2.45057e-05 -1.11808e-19 0.000158939 -1.42302e-19 -0.000158939 -5.22639e-06 -2.6132e-06 5.22639e-06 2.6132e-06 -6.12642e-06 3.06321e-06 3.69518e-20 1.70292e-05 6.12642e-06 3.06321e-06 -8.47033e-21 -1.11173e-20 -0.000453569 -0.000453569 -0.000226785 7.55949e-05 0 3.77974e-05 -5.39964e-06 3.77974e-05 -5.39964e-06 -2.15985e-05 7.55949e-05 -7.55949e-05 -8.47033e-21 0 8.09945e-06 -5.39964e-06 2.69982e-06 5.39964e-06 -2.69982e-06 -1.02997e-21 -0.000325499 -0.00110457 -0.000226785 -0.00110457 5.42498e-05 7.74997e-06 5.42498e-05 7.74997e-06 3.77974e-05 -5.39964e-06 0.000184094 4.24575e-20 3.77974e-05 5.39964e-06 -2.15985e-05 -3.09999e-05 -1.69407e-19 0.000184094 -1.2282e-19 -0.000184094 -7.74997e-06 -3.87498e-06 7.74997e-06 3.87498e-06 -5.39964e-06 2.69982e-06 4.24575e-20 1.97244e-05 5.39964e-06 2.69982e-06 -9.635e-21 -1.24937e-20 -0.000456144 -0.000456144 -0.000228072 7.60239e-05 -8.47033e-22 3.8012e-05 -5.43028e-06 3.8012e-05 -5.43028e-06 -2.17211e-05 7.60239e-05 -7.60239e-05 -6.77626e-21 -8.47033e-22 8.14542e-06 -5.43028e-06 2.71514e-06 5.43028e-06 -2.71514e-06 -9.56313e-22 -0.000226785 -0.000932388 -0.000932388 -0.00023941 3.77974e-05 5.39964e-06 3.77974e-05 5.39964e-06 0.000155398 3.54166e-20 3.99016e-05 -5.70023e-06 3.99016e-05 -5.70023e-06 -2.15985e-05 -2.28009e-05 -1.15196e-19 0.000155398 -0.000155398 -1.30443e-19 -5.39964e-06 -2.69982e-06 5.39964e-06 2.69982e-06 3.54166e-20 1.66498e-05 -5.70023e-06 2.85011e-06 5.70023e-06 -2.85011e-06 -8.78797e-21 -1.05879e-20 -0.000934963 -0.000228072 -0.00023941 -0.000934963 3.8012e-05 -5.43028e-06 3.99016e-05 -5.70023e-06 0.000155827 1.6623e-20 3.8012e-05 5.43028e-06 3.99016e-05 5.70023e-06 -2.17211e-05 -2.28009e-05 0.000155827 -1.2282e-19 -6.77626e-21 -0.000155827 -5.43028e-06 2.71514e-06 -5.70023e-06 2.85011e-06 1.6623e-20 1.66958e-05 5.43028e-06 2.71514e-06 5.70023e-06 2.85011e-06 -9.74088e-21 -1.32113e-21 -0.000431062 -0.000431062 -0.000215531 7.18436e-05 0 3.59218e-05 -5.13169e-06 3.59218e-05 -5.13169e-06 -2.05267e-05 7.18436e-05 -7.18436e-05 -5.0822e-21 0 7.69753e-06 -5.13169e-06 2.56584e-06 5.13169e-06 -2.56584e-06 -1.06523e-21 -0.000890065 -0.000215531 -0.000890065 -0.000229502 3.59218e-05 -5.13169e-06 0.000148344 1.61466e-20 3.82503e-05 -5.46433e-06 3.59218e-05 5.13169e-06 3.82503e-05 -5.46433e-06 -2.05267e-05 -2.18573e-05 0.000148344 -1.17738e-19 -0.000148344 -3.38813e-21 -5.13169e-06 2.56584e-06 1.61466e-20 1.5894e-05 -5.46433e-06 2.73216e-06 5.13169e-06 2.56584e-06 5.46433e-06 -2.73216e-06 -9.1056e-21 -9.14871e-22 -0.000228072 -0.000915147 -0.000229502 -0.000915147 3.8012e-05 5.43028e-06 3.8012e-05 5.43028e-06 3.82503e-05 -5.46433e-06 0.000152524 3.65283e-20 3.82503e-05 5.46433e-06 -2.17211e-05 -2.18573e-05 -1.18585e-19 0.000152524 -1.24514e-19 -0.000152524 -5.43028e-06 -2.71514e-06 5.43028e-06 2.71514e-06 -5.46433e-06 2.73216e-06 3.65283e-20 1.63419e-05 5.46433e-06 2.73216e-06 -8.68209e-21 -9.84676e-21 -0.000437786 -0.000437786 -0.000218893 7.29644e-05 0 3.64822e-05 -5.21174e-06 3.64822e-05 -5.21174e-06 -2.0847e-05 7.29644e-05 -7.29644e-05 -3.38813e-21 0 7.81761e-06 -5.21174e-06 2.60587e-06 5.21174e-06 -2.60587e-06 -1.04191e-21 -0.000215531 -0.000870709 -0.000870709 -0.000219824 3.59218e-05 5.13169e-06 3.59218e-05 5.13169e-06 0.000145118 3.42519e-20 3.66373e-05 -5.23389e-06 3.66373e-05 -5.23389e-06 -2.05267e-05 -2.09356e-05 -1.0842e-19 0.000145118 -0.000145118 -1.21126e-19 -5.13169e-06 -2.56584e-06 5.13169e-06 2.56584e-06 3.42519e-20 1.55484e-05 -5.23389e-06 2.61695e-06 5.23389e-06 -2.61695e-06 -8.68209e-21 -9.52912e-21 -0.000877433 -0.000218893 -0.000219824 -0.000877433 3.64822e-05 -5.21174e-06 3.66373e-05 -5.23389e-06 0.000146239 1.56701e-20 3.64822e-05 5.21174e-06 3.66373e-05 5.23389e-06 -2.0847e-05 -2.09356e-05 0.000146239 -1.18585e-19 -6.77626e-21 -0.000146239 -5.21174e-06 2.60587e-06 -5.23389e-06 2.61695e-06 1.56701e-20 1.56684e-05 5.21174e-06 2.60587e-06 5.23389e-06 2.61695e-06 -9.42324e-21 -1.22357e-21 -0.000460804 -0.000460804 -0.000230402 7.68007e-05 0 3.84003e-05 -5.48576e-06 3.84003e-05 -5.48576e-06 -2.19431e-05 7.68007e-05 -7.68007e-05 -5.0822e-21 0 8.22865e-06 -5.48576e-06 2.74288e-06 5.48576e-06 -2.74288e-06 -9.32262e-22 -0.000902162 -0.000230402 -0.000902162 -0.000220679 3.84003e-05 -5.48576e-06 0.00015036 1.82112e-20 3.67798e-05 -5.25426e-06 3.84003e-05 5.48576e-06 3.67798e-05 -5.25426e-06 -2.19431e-05 -2.1017e-05 0.00015036 -1.24514e-19 -0.00015036 -6.77626e-21 -5.48576e-06 2.74288e-06 1.82112e-20 1.611e-05 -5.25426e-06 2.62713e-06 5.48576e-06 2.74288e-06 5.25426e-06 -2.62713e-06 -9.95264e-21 -8.31921e-22 -0.000218893 -0.000879144 -0.000220679 -0.000879144 3.64822e-05 5.21174e-06 3.64822e-05 5.21174e-06 3.67798e-05 -5.25426e-06 0.000146524 3.18167e-20 3.67798e-05 5.25426e-06 -2.0847e-05 -2.1017e-05 -1.11808e-19 0.000146524 -1.21126e-19 -0.000146524 -5.21174e-06 -2.60587e-06 5.21174e-06 2.60587e-06 -5.25426e-06 2.62713e-06 3.18167e-20 1.5699e-05 5.25426e-06 2.62713e-06 -8.25857e-21 -9.31736e-21 -0.000437468 -0.000437468 -0.000218734 7.29113e-05 0 3.64557e-05 -5.20795e-06 3.64557e-05 -5.20795e-06 -2.08318e-05 7.29113e-05 -7.29113e-05 -3.38813e-21 0 7.81193e-06 -5.20795e-06 2.60398e-06 5.20795e-06 -2.60398e-06 -1.0832e-21 -0.000230402 -0.000858824 -0.000858824 -0.00019901 3.84003e-05 5.48576e-06 3.84003e-05 5.48576e-06 0.000143137 3.25578e-20 3.31683e-05 -4.73833e-06 3.31683e-05 -4.73833e-06 -2.19431e-05 -1.89533e-05 -1.18585e-19 0.000143137 -0.000143137 -1.09267e-19 -5.48576e-06 -2.74288e-06 5.48576e-06 2.74288e-06 3.25578e-20 1.53361e-05 -4.73833e-06 2.36916e-06 4.73833e-06 -2.36916e-06 -9.1056e-21 -8.57621e-21 -0.000835488 -0.000218734 -0.00019901 -0.000835488 3.64557e-05 -5.20795e-06 3.31683e-05 -4.73833e-06 0.000139248 1.67818e-20 3.64557e-05 5.20795e-06 3.31683e-05 4.73833e-06 -2.08318e-05 -1.89533e-05 0.000139248 -1.20279e-19 -3.38813e-21 -0.000139248 -5.20795e-06 2.60398e-06 -4.73833e-06 2.36916e-06 1.67818e-20 1.49194e-05 5.20795e-06 2.60398e-06 4.73833e-06 2.36916e-06 -9.42324e-21 -8.12576e-22 -0.000328444 -0.0011734 -0.0011734 -0.000258254 5.47406e-05 7.82009e-06 5.47406e-05 7.82009e-06 0.000195566 -2.49875e-20 4.30423e-05 -6.14891e-06 4.30423e-05 -6.14891e-06 -3.12803e-05 -2.45956e-05 1.69407e-19 0.000195566 -0.000195566 -8.47033e-21 -7.82009e-06 -3.91004e-06 7.82009e-06 3.91004e-06 -2.49875e-20 2.09535e-05 -6.14891e-06 3.07445e-06 6.14891e-06 -3.07445e-06 1.3129e-20 -1.02295e-21 -0.000218734 -0.000953976 -0.000258254 -0.000953976 3.64557e-05 5.20795e-06 3.64557e-05 5.20795e-06 4.30423e-05 -6.14891e-06 0.000158996 3.73753e-20 4.30423e-05 6.14891e-06 -2.08318e-05 -2.45956e-05 -1.11808e-19 0.000158996 -1.42302e-19 -0.000158996 -5.20795e-06 -2.60398e-06 5.20795e-06 2.60398e-06 -6.14891e-06 3.07445e-06 3.73753e-20 1.70353e-05 6.14891e-06 3.07445e-06 -8.89385e-21 -1.10114e-20 -0.000245428 -0.00105456 -0.00105456 -0.00028185 4.09047e-05 5.84353e-06 4.09047e-05 5.84353e-06 0.00017576 -1.86347e-20 4.69751e-05 -6.71072e-06 4.69751e-05 -6.71072e-06 -2.33741e-05 -2.68429e-05 1.25361e-19 0.00017576 -0.00017576 -6.77626e-21 -5.84353e-06 -2.92177e-06 5.84353e-06 2.92177e-06 -1.86347e-20 1.88314e-05 -6.71072e-06 3.35536e-06 6.71072e-06 -3.35536e-06 9.74088e-21 -1.22942e-21 -0.000258254 -0.00099595 -0.00099595 -0.000239721 4.30423e-05 6.14891e-06 4.30423e-05 6.14891e-06 0.000165992 3.944e-20 3.99535e-05 -5.70765e-06 3.99535e-05 -5.70765e-06 -2.45956e-05 -2.28306e-05 -1.32137e-19 0.000165992 -0.000165992 -1.30443e-19 -6.14891e-06 -3.07445e-06 6.14891e-06 3.07445e-06 3.944e-20 1.77848e-05 -5.70765e-06 2.85382e-06 5.70765e-06 -2.85382e-06 -9.95264e-21 -1.03762e-20 -0.00104314 -0.00028185 -0.000239721 -0.00104314 4.69751e-05 -6.71072e-06 3.99535e-05 -5.70765e-06 0.000173857 2.1017e-20 4.69751e-05 6.71072e-06 3.99535e-05 5.70765e-06 -2.68429e-05 -2.28306e-05 0.000173857 -1.52466e-19 -6.77626e-21 -0.000173857 -6.71072e-06 3.35536e-06 -5.70765e-06 2.85382e-06 2.1017e-20 1.86276e-05 6.71072e-06 3.35536e-06 5.70765e-06 2.85382e-06 -1.21761e-20 -1.32113e-21 -0.000238402 -0.00093628 -0.00093628 -0.000229738 3.97337e-05 5.67624e-06 3.97337e-05 5.67624e-06 0.000156047 3.56283e-20 3.82896e-05 -5.46994e-06 3.82896e-05 -5.46994e-06 -2.2705e-05 -2.18798e-05 -1.21973e-19 0.000156047 -0.000156047 -1.25361e-19 -5.67624e-06 -2.83812e-06 5.67624e-06 2.83812e-06 3.56283e-20 1.67193e-05 -5.46994e-06 2.73497e-06 5.46994e-06 -2.73497e-06 -9.21148e-21 -9.95264e-21 -0.000229678 -0.000897969 -0.000897969 -0.000219307 3.82796e-05 5.46852e-06 3.82796e-05 5.46852e-06 0.000149661 -1.69407e-20 3.65511e-05 -5.22159e-06 3.65511e-05 -5.22159e-06 -2.18741e-05 -2.08864e-05 1.15196e-19 0.000149661 -0.000149661 -6.77626e-21 -5.46852e-06 -2.73426e-06 5.46852e-06 2.73426e-06 -1.69407e-20 1.60352e-05 -5.22159e-06 2.61079e-06 5.22159e-06 -2.61079e-06 8.89385e-21 -9.25172e-22 -0.000888851 -0.000219307 -0.000888851 -0.000225119 3.65511e-05 -5.22159e-06 0.000148142 1.68877e-20 3.75198e-05 -5.35997e-06 3.65511e-05 5.22159e-06 3.75198e-05 -5.35997e-06 -2.08864e-05 -2.14399e-05 0.000148142 -1.19432e-19 -0.000148142 -3.38813e-21 -5.22159e-06 2.61079e-06 1.68877e-20 1.58723e-05 -5.35997e-06 2.67999e-06 5.22159e-06 2.61079e-06 5.35997e-06 -2.67999e-06 -9.31736e-21 -8.65147e-22 -0.000909713 -0.000229738 -0.000225119 -0.000909713 3.82896e-05 -5.46994e-06 3.75198e-05 -5.35997e-06 0.000151619 1.69936e-20 3.82896e-05 5.46994e-06 3.75198e-05 5.35997e-06 -2.18798e-05 -2.14399e-05 0.000151619 -3.38813e-21 -1.2282e-19 -0.000151619 -5.46994e-06 2.73497e-06 -5.35997e-06 2.67999e-06 1.69936e-20 1.62449e-05 5.46994e-06 2.73497e-06 5.35997e-06 2.67999e-06 -1.12883e-21 -9.635e-21 -0.000228621 -0.000918089 -0.000918089 -0.000230423 3.81035e-05 5.44336e-06 3.81035e-05 5.44336e-06 0.000153015 3.44107e-20 3.84038e-05 -5.48626e-06 3.84038e-05 -5.48626e-06 -2.17735e-05 -2.19451e-05 -1.15196e-19 0.000153015 -0.000153015 -1.26208e-19 -5.44336e-06 -2.72168e-06 5.44336e-06 2.72168e-06 3.44107e-20 1.63944e-05 -5.48626e-06 2.74313e-06 5.48626e-06 -2.74313e-06 -8.89385e-21 -1.00585e-20 -0.000204302 -0.000884718 -0.000884718 -0.000238057 3.40504e-05 4.86434e-06 3.40504e-05 4.86434e-06 0.000147453 -1.69407e-20 3.96761e-05 -5.66802e-06 3.96761e-05 -5.66802e-06 -1.94574e-05 -2.26721e-05 1.05032e-19 0.000147453 -0.000147453 -6.77626e-21 -4.86434e-06 -2.43217e-06 4.86434e-06 2.43217e-06 -1.69407e-20 1.57985e-05 -5.66802e-06 2.83401e-06 5.66802e-06 -2.83401e-06 8.04681e-21 -9.92299e-22 -0.00101921 -0.000238057 -0.00101921 -0.00027155 3.96761e-05 -5.66802e-06 0.000169869 1.84759e-20 4.52583e-05 -6.46547e-06 3.96761e-05 5.66802e-06 4.52583e-05 -6.46547e-06 -2.26721e-05 -2.58619e-05 0.000169869 -1.29596e-19 -0.000169869 -6.77626e-21 -5.66802e-06 2.83401e-06 1.84759e-20 1.82002e-05 -6.46547e-06 3.23274e-06 5.66802e-06 2.83401e-06 6.46547e-06 -3.23274e-06 -1.01644e-20 -1.33946e-21 -0.00100395 -0.000230423 -0.00027155 -0.00100395 3.84038e-05 -5.48626e-06 4.52583e-05 -6.46547e-06 0.000167324 2.13346e-20 3.84038e-05 5.48626e-06 4.52583e-05 6.46547e-06 -2.19451e-05 -2.58619e-05 0.000167324 -3.38813e-21 -1.49078e-19 -0.000167324 -5.48626e-06 2.74313e-06 -6.46547e-06 3.23274e-06 2.13346e-20 1.79276e-05 5.48626e-06 2.74313e-06 6.46547e-06 3.23274e-06 -9.96003e-22 -1.15408e-20 -0.000262408 -0.00101781 -0.00101781 -0.000246497 4.37346e-05 6.2478e-06 4.37346e-05 6.2478e-06 0.000169635 4.10282e-20 4.10829e-05 -5.86898e-06 4.10829e-05 -5.86898e-06 -2.49912e-05 -2.34759e-05 -1.32137e-19 0.000169635 -0.000169635 -1.34678e-19 -6.2478e-06 -3.1239e-06 6.2478e-06 3.1239e-06 4.10282e-20 1.81752e-05 -5.86898e-06 2.93449e-06 5.86898e-06 -2.93449e-06 -1.03762e-20 -1.10114e-20 -0.000249411 -0.00107074 -0.00107074 -0.00028596 4.15684e-05 5.93835e-06 4.15684e-05 5.93835e-06 0.000178457 -1.86347e-20 4.766e-05 -6.80857e-06 4.766e-05 -6.80857e-06 -2.37534e-05 -2.72343e-05 1.28749e-19 0.000178457 -0.000178457 -6.77626e-21 -5.93835e-06 -2.96917e-06 5.93835e-06 2.96917e-06 -1.86347e-20 1.91204e-05 -6.80857e-06 3.40429e-06 6.80857e-06 -3.40429e-06 9.74088e-21 -1.09855e-21 -0.00106491 -0.000246497 -0.00028596 -0.00106491 4.10829e-05 -5.86898e-06 4.766e-05 -6.80857e-06 0.000177486 2.20758e-20 4.10829e-05 5.86898e-06 4.766e-05 6.80857e-06 -2.34759e-05 -2.72343e-05 0.000177486 -1.01644e-20 -1.57548e-19 -0.000177486 -5.86898e-06 2.93449e-06 -6.80857e-06 3.40429e-06 2.20758e-20 1.90163e-05 5.86898e-06 2.93449e-06 6.80857e-06 3.40429e-06 -1.05858e-21 -1.24937e-20 -0.00023561 -0.000941759 -0.000941759 -0.000235269 3.92684e-05 5.60977e-06 3.92684e-05 5.60977e-06 0.00015696 3.52577e-20 3.92115e-05 -5.60165e-06 3.92115e-05 -5.60165e-06 -2.24391e-05 -2.24066e-05 -1.21973e-19 0.00015696 -0.00015696 -1.27902e-19 -5.60977e-06 -2.80489e-06 5.60977e-06 2.80489e-06 3.52577e-20 1.68171e-05 -5.60165e-06 2.80082e-06 5.60165e-06 -2.80082e-06 -9.52912e-21 -1.00585e-20 -0.000218479 -0.000848903 -0.000848903 -0.000205972 3.64132e-05 5.20189e-06 3.64132e-05 5.20189e-06 0.000141484 -1.69407e-20 3.43287e-05 -4.90409e-06 3.43287e-05 -4.90409e-06 -2.08076e-05 -1.96164e-05 1.15196e-19 0.000141484 -0.000141484 -3.38813e-21 -5.20189e-06 -2.60095e-06 5.20189e-06 2.60095e-06 -1.69407e-20 1.5159e-05 -4.90409e-06 2.45205e-06 4.90409e-06 -2.45205e-06 8.78797e-21 -8.42681e-22 -0.000846999 -0.000205972 -0.000846999 -0.000217527 3.43287e-05 -4.90409e-06 0.000141166 1.55642e-20 3.62545e-05 -5.17922e-06 3.43287e-05 4.90409e-06 3.62545e-05 -5.17922e-06 -1.96164e-05 -2.07169e-05 0.000141166 -1.12655e-19 -0.000141166 -5.0822e-21 -4.90409e-06 2.45205e-06 1.55642e-20 1.5125e-05 -5.17922e-06 2.58961e-06 4.90409e-06 2.45205e-06 5.17922e-06 -2.58961e-06 -8.68209e-21 -9.50785e-22 -0.000905593 -0.000235269 -0.000217527 -0.000905593 3.92115e-05 -5.60165e-06 3.62545e-05 -5.17922e-06 0.000150932 1.61466e-20 3.92115e-05 5.60165e-06 3.62545e-05 5.17922e-06 -2.24066e-05 -2.07169e-05 0.000150932 -8.47033e-21 -1.18585e-19 -0.000150932 -5.60165e-06 2.80082e-06 -5.17922e-06 2.58961e-06 1.61466e-20 1.61713e-05 5.60165e-06 2.80082e-06 5.17922e-06 2.58961e-06 -1.04999e-21 -9.52912e-21 -0.000212497 -0.000833337 -0.000833337 -0.000204172 3.54161e-05 5.05945e-06 3.54161e-05 5.05945e-06 0.00013889 3.25049e-20 3.40286e-05 -4.86123e-06 3.40286e-05 -4.86123e-06 -2.02378e-05 -1.94449e-05 -1.0842e-19 0.00013889 -0.00013889 -1.10961e-19 -5.05945e-06 -2.52972e-06 5.05945e-06 2.52972e-06 3.25049e-20 1.4881e-05 -4.86123e-06 2.43062e-06 4.86123e-06 -2.43062e-06 -8.57621e-21 -8.89385e-21 -0.000190229 -0.000830838 -0.000830838 -0.00022519 3.17049e-05 4.52927e-06 3.17049e-05 4.52927e-06 0.000138473 -1.52466e-20 3.75317e-05 -5.36167e-06 3.75317e-05 -5.36167e-06 -1.81171e-05 -2.14467e-05 9.82558e-20 0.000138473 -0.000138473 -8.47033e-21 -4.52927e-06 -2.26463e-06 4.52927e-06 2.26463e-06 -1.52466e-20 1.48364e-05 -5.36167e-06 2.68083e-06 5.36167e-06 -2.68083e-06 7.72918e-21 -1.00337e-21 -0.000932106 -0.00022519 -0.000932106 -0.000240863 3.75317e-05 -5.36167e-06 0.000155351 1.74171e-20 4.01438e-05 -5.73483e-06 3.75317e-05 5.36167e-06 4.01438e-05 -5.73483e-06 -2.14467e-05 -2.29393e-05 0.000155351 -1.2282e-19 -0.000155351 -5.0822e-21 -5.36167e-06 2.68083e-06 1.74171e-20 1.66447e-05 -5.73483e-06 2.86741e-06 5.36167e-06 2.68083e-06 5.73483e-06 -2.86741e-06 -9.635e-21 -1.16082e-21 -0.000890069 -0.000204172 -0.000240863 -0.000890069 3.40286e-05 -4.86123e-06 4.01438e-05 -5.73483e-06 0.000148345 1.88994e-20 3.40286e-05 4.86123e-06 4.01438e-05 5.73483e-06 -1.94449e-05 -2.29393e-05 0.000148345 -3.38813e-21 -1.30443e-19 -0.000148345 -4.86123e-06 2.43062e-06 -5.73483e-06 2.86741e-06 1.88994e-20 1.58941e-05 4.86123e-06 2.43062e-06 5.73483e-06 2.86741e-06 -1.10829e-21 -1.0482e-20 -0.000253086 -0.000973941 -0.000973941 -0.000233884 4.21811e-05 6.02587e-06 4.21811e-05 6.02587e-06 0.000162323 3.70577e-20 3.89807e-05 -5.56867e-06 3.89807e-05 -5.56867e-06 -2.41035e-05 -2.22747e-05 -1.28749e-19 0.000162323 -0.000162323 -1.28749e-19 -6.02587e-06 -3.01293e-06 6.02587e-06 3.01293e-06 3.70577e-20 1.73918e-05 -5.56867e-06 2.78433e-06 5.56867e-06 -2.78433e-06 -9.74088e-21 -1.03762e-20 -0.000248978 -0.00105419 -0.00105419 -0.000278114 4.14964e-05 5.92806e-06 4.14964e-05 5.92806e-06 0.000175698 -2.20229e-20 4.63524e-05 -6.62177e-06 4.63524e-05 -6.62177e-06 -2.37122e-05 -2.64871e-05 1.28749e-19 0.000175698 -0.000175698 -1.01644e-20 -5.92806e-06 -2.96403e-06 5.92806e-06 2.96403e-06 -2.20229e-20 1.88247e-05 -6.62177e-06 3.31088e-06 6.62177e-06 -3.31088e-06 9.95264e-21 -1.3333e-21 -0.001024 -0.000233884 -0.000278114 -0.001024 3.89807e-05 -5.56867e-06 4.63524e-05 -6.62177e-06 0.000170666 2.00112e-20 3.89807e-05 5.56867e-06 4.63524e-05 6.62177e-06 -2.64871e-05 -2.22747e-05 0.000170666 -3.38813e-21 -1.50772e-19 -0.000170666 -5.56867e-06 2.78433e-06 -6.62177e-06 3.31088e-06 2.00112e-20 1.82857e-05 5.56867e-06 2.78433e-06 6.62177e-06 3.31088e-06 -1.11173e-20 -1.16774e-21 -0.000245394 -0.000968753 -0.000968753 -0.000238983 4.0899e-05 5.84271e-06 4.0899e-05 5.84271e-06 0.000161459 3.71636e-20 3.98304e-05 -5.69006e-06 3.98304e-05 -5.69006e-06 -2.33708e-05 -2.27602e-05 -1.28749e-19 0.000161459 -0.000161459 -1.3129e-19 -5.84271e-06 -2.92136e-06 5.84271e-06 2.92136e-06 3.71636e-20 1.72992e-05 -5.69006e-06 2.84503e-06 5.69006e-06 -2.84503e-06 -9.52912e-21 -1.02703e-20 -0.000235758 -0.000935272 -0.000935272 -0.000231878 3.9293e-05 5.61328e-06 3.9293e-05 5.61328e-06 0.000155879 -1.82112e-20 3.86464e-05 -5.52091e-06 3.86464e-05 -5.52091e-06 -2.24531e-05 -2.20836e-05 1.21973e-19 0.000155879 -0.000155879 -3.38813e-21 -5.61328e-06 -2.80664e-06 5.61328e-06 2.80664e-06 -1.82112e-20 1.67013e-05 -5.52091e-06 2.76045e-06 5.52091e-06 -2.76045e-06 9.42324e-21 -8.65891e-22 -0.000936606 -0.000231878 -0.000936606 -0.000236425 3.86464e-05 -5.52091e-06 0.000156101 1.76818e-20 3.94041e-05 -5.62916e-06 3.86464e-05 5.52091e-06 3.94041e-05 -5.62916e-06 -2.20836e-05 -2.25166e-05 0.000156101 -1.27055e-19 -0.000156101 -5.0822e-21 -5.52091e-06 2.76045e-06 1.76818e-20 1.67251e-05 -5.62916e-06 2.81458e-06 5.52091e-06 2.76045e-06 5.62916e-06 -2.81458e-06 -1.01644e-20 -9.74957e-22 -0.000950815 -0.000238983 -0.000236425 -0.000950815 3.98304e-05 -5.69006e-06 3.94041e-05 -5.62916e-06 0.000158469 1.81053e-20 3.98304e-05 5.69006e-06 3.94041e-05 5.62916e-06 -2.27602e-05 -2.25166e-05 0.000158469 -1.01644e-20 -1.28749e-19 -0.000158469 -5.69006e-06 2.84503e-06 -5.62916e-06 2.81458e-06 1.81053e-20 1.69788e-05 5.69006e-06 2.84503e-06 5.62916e-06 2.81458e-06 -1.02356e-21 -1.00585e-20 -0.000230927 -0.000919395 -0.000919395 -0.00022877 3.84879e-05 5.49827e-06 3.84879e-05 5.49827e-06 0.000153233 3.60518e-20 3.81284e-05 -5.44691e-06 3.81284e-05 -5.44691e-06 -2.19931e-05 -2.17876e-05 -1.18585e-19 0.000153233 -0.000153233 -1.23667e-19 -5.49827e-06 -2.74914e-06 5.49827e-06 2.74914e-06 3.60518e-20 1.64178e-05 -5.44691e-06 2.72346e-06 5.44691e-06 -2.72346e-06 -9.1056e-21 -9.84676e-21 -0.00020089 -0.000865069 -0.000865069 -0.000231644 3.34817e-05 4.7831e-06 3.34817e-05 4.7831e-06 0.000144178 -1.27055e-20 3.86074e-05 -5.51534e-06 3.86074e-05 -5.51534e-06 -1.91324e-05 -2.20614e-05 1.05032e-19 0.000144178 -0.000144178 -6.77626e-21 -4.7831e-06 -2.39155e-06 4.7831e-06 2.39155e-06 -1.27055e-20 1.54477e-05 -5.51534e-06 2.75767e-06 5.51534e-06 -2.75767e-06 8.04681e-21 -9.46629e-22 -0.000997777 -0.000231644 -0.000997777 -0.000267245 3.86074e-05 -5.51534e-06 0.000166296 1.72054e-20 4.45408e-05 -6.36296e-06 3.86074e-05 5.51534e-06 4.45408e-05 -6.36296e-06 -2.20614e-05 -2.54519e-05 0.000166296 -1.26208e-19 -0.000166296 -8.47033e-21 -5.51534e-06 2.75767e-06 1.72054e-20 1.78175e-05 -6.36296e-06 3.18148e-06 5.51534e-06 2.75767e-06 6.36296e-06 -3.18148e-06 -9.95264e-21 -1.30388e-21 -0.000992029 -0.00022877 -0.000267245 -0.000992029 3.81284e-05 -5.44691e-06 4.45408e-05 -6.36296e-06 0.000165338 2.017e-20 3.81284e-05 5.44691e-06 4.45408e-05 6.36296e-06 -2.17876e-05 -2.54519e-05 0.000165338 -6.77626e-21 -1.4569e-19 -0.000165338 -5.44691e-06 2.72346e-06 -6.36296e-06 3.18148e-06 2.017e-20 1.77148e-05 5.44691e-06 2.72346e-06 6.36296e-06 3.18148e-06 -1.23601e-21 -1.14349e-20 -0.00025731 -0.000988928 -0.000988928 -0.000237154 4.2885e-05 6.12642e-06 4.2885e-05 6.12642e-06 0.000164821 3.47813e-20 3.95257e-05 -5.64652e-06 3.95257e-05 -5.64652e-06 -2.45057e-05 -2.25861e-05 -1.32137e-19 0.000164821 -0.000164821 -1.28749e-19 -6.12642e-06 -3.06321e-06 6.12642e-06 3.06321e-06 3.47813e-20 1.76594e-05 -5.64652e-06 2.82326e-06 5.64652e-06 -2.82326e-06 -1.00585e-20 -1.03762e-20 -0.00023941 -0.00103162 -0.00103162 -0.0002764 3.99016e-05 5.70023e-06 3.99016e-05 5.70023e-06 0.000171937 -1.86347e-20 4.60667e-05 -6.58096e-06 4.60667e-05 -6.58096e-06 -2.28009e-05 -2.63238e-05 1.21973e-19 0.000171937 -0.000171937 -8.47033e-21 -5.70023e-06 -2.85011e-06 5.70023e-06 2.85011e-06 -1.86347e-20 1.84218e-05 -6.58096e-06 3.29048e-06 6.58096e-06 -3.29048e-06 9.31736e-21 -1.31299e-21 -0.00102711 -0.000237154 -0.0002764 -0.00102711 3.95257e-05 -5.64652e-06 4.60667e-05 -6.58096e-06 0.000171185 2.17582e-20 3.95257e-05 5.64652e-06 4.60667e-05 6.58096e-06 -2.25861e-05 -2.63238e-05 0.000171185 -8.47033e-21 -1.52466e-19 -0.000171185 -5.64652e-06 2.82326e-06 -6.58096e-06 3.29048e-06 2.17582e-20 1.83412e-05 5.64652e-06 2.82326e-06 6.58096e-06 3.29048e-06 -1.26203e-21 -1.18585e-20 -0.000229502 -0.00089607 -0.00089607 -0.000218533 3.82503e-05 5.46433e-06 3.82503e-05 5.46433e-06 0.000149345 3.53636e-20 3.64222e-05 -5.20317e-06 3.64222e-05 -5.20317e-06 -2.18573e-05 -2.08127e-05 -1.15196e-19 0.000149345 -0.000149345 -1.19432e-19 -5.46433e-06 -2.73216e-06 5.46433e-06 2.73216e-06 3.53636e-20 1.60012e-05 -5.20317e-06 2.60158e-06 5.20317e-06 -2.60158e-06 -9.31736e-21 -9.52912e-21 -0.000219824 -0.000855906 -0.000855906 -0.00020813 3.66373e-05 5.23389e-06 3.66373e-05 5.23389e-06 0.000142651 -1.86347e-20 3.46883e-05 -4.95547e-06 3.46883e-05 -4.95547e-06 -2.09356e-05 -1.98219e-05 1.11808e-19 0.000142651 -0.000142651 -5.0822e-21 -5.23389e-06 -2.61695e-06 5.23389e-06 2.61695e-06 -1.86347e-20 1.5284e-05 -4.95547e-06 2.47773e-06 4.95547e-06 -2.47773e-06 8.99973e-21 -8.9921e-22 -0.000846379 -0.00020813 -0.000846379 -0.00021506 3.46883e-05 -4.95547e-06 0.000141063 1.59877e-20 3.58433e-05 -5.12047e-06 3.46883e-05 4.95547e-06 3.58433e-05 -5.12047e-06 -1.98219e-05 -2.04819e-05 0.000141063 -1.14349e-19 -0.000141063 -6.77626e-21 -4.95547e-06 2.47773e-06 1.59877e-20 1.51139e-05 -5.12047e-06 2.56023e-06 4.95547e-06 2.47773e-06 5.12047e-06 -2.56023e-06 -8.89385e-21 -1.05026e-21 -0.000867186 -0.000218533 -0.00021506 -0.000867186 3.64222e-05 -5.20317e-06 3.58433e-05 -5.12047e-06 0.000144531 1.65701e-20 3.64222e-05 5.20317e-06 3.58433e-05 5.12047e-06 -2.08127e-05 -2.04819e-05 0.000144531 -5.0822e-21 -1.17738e-19 -0.000144531 -5.20317e-06 2.60158e-06 -5.12047e-06 2.56023e-06 1.65701e-20 1.54855e-05 5.20317e-06 2.60158e-06 5.12047e-06 2.56023e-06 -1.16518e-21 -9.1056e-21 -0.000220679 -0.000885373 -0.000885373 -0.000222008 3.67798e-05 5.25426e-06 3.67798e-05 5.25426e-06 0.000147562 3.40401e-20 3.70013e-05 -5.2859e-06 3.70013e-05 -5.2859e-06 -2.1017e-05 -2.11436e-05 -1.15196e-19 0.000147562 -0.000147562 -1.21126e-19 -5.25426e-06 -2.62713e-06 5.25426e-06 2.62713e-06 3.40401e-20 1.58102e-05 -5.2859e-06 2.64295e-06 5.2859e-06 -2.64295e-06 -8.47033e-21 -9.635e-21 -0.00019901 -0.000860301 -0.000860301 -0.000231141 3.31683e-05 4.73833e-06 3.31683e-05 4.73833e-06 0.000143383 -1.48231e-20 3.85235e-05 -5.50335e-06 3.85235e-05 -5.50335e-06 -1.89533e-05 -2.20134e-05 1.05032e-19 0.000143383 -0.000143383 -1.69407e-21 -4.73833e-06 -2.36916e-06 4.73833e-06 2.36916e-06 -1.48231e-20 1.53625e-05 -5.50335e-06 2.75168e-06 5.50335e-06 -2.75168e-06 7.94093e-21 -1.01474e-21 -0.000988978 -0.000231141 -0.000988978 -0.000263348 3.85235e-05 -5.50335e-06 0.00016483 1.82112e-20 4.38913e-05 -6.27019e-06 3.85235e-05 5.50335e-06 4.38913e-05 -6.27019e-06 -2.20134e-05 -2.50808e-05 0.00016483 -1.25361e-19 -0.00016483 -3.38813e-21 -5.50335e-06 2.75168e-06 1.82112e-20 1.76603e-05 -6.27019e-06 3.1351e-06 5.50335e-06 2.75168e-06 6.27019e-06 -3.1351e-06 -1.01644e-20 -1.07536e-21 -0.000970712 -0.000222008 -0.000263348 -0.000970712 3.70013e-05 -5.2859e-06 4.38913e-05 -6.27019e-06 0.000161785 2.017e-20 3.70013e-05 5.2859e-06 4.38913e-05 6.27019e-06 -2.11436e-05 -2.50808e-05 0.000161785 -5.0822e-21 -1.4569e-19 -0.000161785 -5.2859e-06 2.64295e-06 -6.27019e-06 3.1351e-06 2.017e-20 1.73341e-05 5.2859e-06 2.64295e-06 6.27019e-06 3.1351e-06 -9.85995e-22 -1.14349e-20 -0.000229738 -0.000986208 -0.000986208 -0.000263367 3.82896e-05 5.46994e-06 3.82896e-05 5.46994e-06 0.000164368 -1.90582e-20 4.38944e-05 -6.27063e-06 4.38944e-05 -6.27063e-06 -2.18798e-05 -2.50825e-05 1.15196e-19 0.000164368 -0.000164368 -1.69407e-21 -5.46994e-06 -2.73497e-06 5.46994e-06 2.73497e-06 -1.90582e-20 1.76109e-05 -6.27063e-06 3.13532e-06 6.27063e-06 -3.13532e-06 9.21148e-21 -1.10515e-21 -0.00028185 -0.00109043 -0.000263367 -0.00109043 4.69751e-05 6.71072e-06 4.69751e-05 6.71072e-06 4.38944e-05 -6.27063e-06 0.000181739 4.04458e-20 4.38944e-05 6.27063e-06 -2.68429e-05 -2.50825e-05 -1.42302e-19 0.000181739 -1.43996e-19 -0.000181739 -6.71072e-06 -3.35536e-06 6.71072e-06 3.35536e-06 -6.27063e-06 3.13532e-06 4.04458e-20 1.9472e-05 6.27063e-06 3.13532e-06 -1.07997e-20 -1.13291e-20 -0.000219307 -0.000890679 -0.000890679 -0.000226033 3.65511e-05 5.22159e-06 3.65511e-05 5.22159e-06 0.000148446 3.42519e-20 3.76721e-05 -5.38173e-06 3.76721e-05 -5.38173e-06 -2.08864e-05 -2.15269e-05 -1.15196e-19 0.000148446 -0.000148446 -1.23667e-19 -5.22159e-06 -2.61079e-06 5.22159e-06 2.61079e-06 3.42519e-20 1.5905e-05 -5.38173e-06 2.69087e-06 5.38173e-06 -2.69087e-06 -8.47033e-21 -9.52912e-21 -0.000230423 -0.000912912 -0.000226033 -0.000912912 3.84038e-05 5.48626e-06 3.84038e-05 5.48626e-06 3.76721e-05 -5.38173e-06 0.000152152 -1.86347e-20 3.76721e-05 5.38173e-06 -2.19451e-05 -2.15269e-05 1.18585e-19 0.000152152 -3.38813e-21 -0.000152152 -5.48626e-06 -2.74313e-06 5.48626e-06 2.74313e-06 -5.38173e-06 2.69087e-06 -1.86347e-20 1.6302e-05 5.38173e-06 2.69087e-06 8.89385e-21 -1.15619e-21 -0.000238057 -0.000246497 -0.000969108 -0.000969108 3.96761e-05 5.66802e-06 3.96761e-05 5.66802e-06 4.10829e-05 5.86898e-06 4.10829e-05 5.86898e-06 0.000161518 0 -2.26721e-05 -2.34759e-05 -1.25361e-19 1.21973e-19 0.000161518 -0.000161518 -5.66802e-06 -2.83401e-06 5.66802e-06 2.83401e-06 -5.86898e-06 -2.93449e-06 5.86898e-06 2.93449e-06 0 1.73055e-05 -9.635e-21 9.52912e-21 -0.00028596 -0.00112232 -0.00112232 -0.000275202 4.766e-05 6.80857e-06 4.766e-05 6.80857e-06 0.000187054 4.16105e-20 4.5867e-05 -6.55242e-06 4.5867e-05 -6.55242e-06 -2.72343e-05 -2.62097e-05 -1.49078e-19 0.000187054 -0.000187054 -1.49078e-19 -6.80857e-06 -3.40429e-06 6.80857e-06 3.40429e-06 4.16105e-20 2.00415e-05 -6.55242e-06 3.27621e-06 6.55242e-06 -3.27621e-06 -1.10114e-20 -1.19643e-20 -0.000235269 -0.00102094 -0.000275202 -0.00102094 3.92115e-05 5.60165e-06 3.92115e-05 5.60165e-06 4.5867e-05 -6.55242e-06 0.000170157 -1.99053e-20 4.5867e-05 6.55242e-06 -2.24066e-05 -2.62097e-05 1.18585e-19 0.000170157 -3.38813e-21 -0.000170157 -5.60165e-06 -2.80082e-06 5.60165e-06 2.80082e-06 -6.55242e-06 3.27621e-06 -1.99053e-20 1.82311e-05 6.55242e-06 3.27621e-06 8.99973e-21 -1.47477e-21 -0.000205972 -0.000829615 -0.000829615 -0.000208835 3.43287e-05 4.90409e-06 3.43287e-05 4.90409e-06 0.000138269 3.26108e-20 3.48059e-05 -4.97227e-06 3.48059e-05 -4.97227e-06 -1.96164e-05 -1.98891e-05 -1.0842e-19 0.000138269 -0.000138269 -1.13502e-19 -4.90409e-06 -2.45205e-06 4.90409e-06 2.45205e-06 3.26108e-20 1.48146e-05 -4.97227e-06 2.48614e-06 4.97227e-06 -2.48614e-06 -8.04681e-21 -9.1056e-21 -0.000204172 -0.000826014 -0.000208835 -0.000826014 3.40286e-05 4.86123e-06 3.40286e-05 4.86123e-06 3.48059e-05 -4.97227e-06 0.000137669 -1.52466e-20 3.48059e-05 4.97227e-06 -1.98891e-05 -1.94449e-05 1.05032e-19 0.000137669 -3.38813e-21 -0.000137669 -4.86123e-06 -2.43062e-06 4.86123e-06 2.43062e-06 -4.97227e-06 2.48614e-06 -1.52466e-20 1.47503e-05 4.97227e-06 2.48614e-06 -9.56159e-22 8.04681e-21 -0.00022519 -0.000233884 -0.000918148 -0.000918148 3.75317e-05 5.36167e-06 3.75317e-05 5.36167e-06 3.89807e-05 5.56867e-06 3.89807e-05 5.56867e-06 0.000153025 0 -2.22747e-05 -2.14467e-05 -1.15196e-19 1.18585e-19 0.000153025 -0.000153025 -5.36167e-06 -2.68083e-06 5.36167e-06 2.68083e-06 -5.56867e-06 -2.78433e-06 5.56867e-06 2.78433e-06 0 1.63955e-05 9.1056e-21 -8.78797e-21 -0.000278114 -0.00110423 -0.00110423 -0.000274002 4.63524e-05 6.62177e-06 4.63524e-05 6.62177e-06 0.000184039 4.16105e-20 4.5667e-05 -6.52386e-06 4.5667e-05 -6.52386e-06 -2.64871e-05 -2.60954e-05 -1.42302e-19 0.000184039 -0.000184039 -1.49078e-19 -6.62177e-06 -3.31088e-06 6.62177e-06 3.31088e-06 4.16105e-20 1.97184e-05 -6.52386e-06 3.26193e-06 6.52386e-06 -3.26193e-06 -1.07997e-20 -1.18585e-20 -0.000238983 -0.00102597 -0.000274002 -0.00102597 3.98304e-05 5.69006e-06 3.98304e-05 5.69006e-06 4.5667e-05 -6.52386e-06 0.000170995 -1.90582e-20 4.5667e-05 6.52386e-06 -2.27602e-05 -2.60954e-05 1.21973e-19 0.000170995 -8.47033e-21 -0.000170995 -5.69006e-06 -2.84503e-06 5.69006e-06 2.84503e-06 -6.52386e-06 3.26193e-06 -1.90582e-20 1.83209e-05 6.52386e-06 3.26193e-06 9.52912e-21 -1.68169e-21 -0.000231878 -0.000932474 -0.000932474 -0.000234359 3.86464e-05 5.52091e-06 3.86464e-05 5.52091e-06 0.000155412 3.28225e-20 3.90598e-05 -5.57998e-06 3.90598e-05 -5.57998e-06 -2.20836e-05 -2.23199e-05 -1.18585e-19 0.000155412 -0.000155412 -1.27902e-19 -5.52091e-06 -2.76045e-06 5.52091e-06 2.76045e-06 3.28225e-20 1.66513e-05 -5.57998e-06 2.78999e-06 5.57998e-06 -2.78999e-06 -9.1056e-21 -1.00585e-20 -0.00022877 -0.000926258 -0.000234359 -0.000926258 3.81284e-05 5.44691e-06 3.81284e-05 5.44691e-06 3.90598e-05 -5.57998e-06 0.000154376 -1.77877e-20 3.90598e-05 5.57998e-06 -2.23199e-05 -2.17876e-05 1.15196e-19 0.000154376 -6.77626e-21 -0.000154376 -5.44691e-06 -2.72346e-06 5.44691e-06 2.72346e-06 -5.57998e-06 2.78999e-06 -1.77877e-20 1.65403e-05 5.57998e-06 2.78999e-06 -1.0968e-21 9.1056e-21 -0.000231644 -0.000237154 -0.000937597 -0.000937597 3.86074e-05 5.51534e-06 3.86074e-05 5.51534e-06 3.95257e-05 5.64652e-06 3.95257e-05 5.64652e-06 0.000156266 -1.69407e-21 -2.20614e-05 -2.25861e-05 -1.15196e-19 1.18585e-19 0.000156266 -0.000156266 -5.51534e-06 -2.75767e-06 5.51534e-06 2.75767e-06 -5.64652e-06 -2.82326e-06 5.64652e-06 2.82326e-06 -1.69407e-21 1.67428e-05 -9.31736e-21 9.635e-21 -0.000218533 -0.000945177 -0.000945177 -0.000254055 3.64222e-05 5.20317e-06 3.64222e-05 5.20317e-06 0.000157529 -1.60936e-20 4.23426e-05 -6.04894e-06 4.23426e-05 -6.04894e-06 -2.08127e-05 -2.41957e-05 1.11808e-19 0.000157529 -0.000157529 -8.47033e-21 -5.20317e-06 -2.60158e-06 5.20317e-06 2.60158e-06 -1.60936e-20 1.68782e-05 -6.04894e-06 3.02447e-06 6.04894e-06 -3.02447e-06 8.47033e-21 -1.15649e-21 -0.0002764 -0.00106091 -0.000254055 -0.00106091 4.60667e-05 6.58096e-06 4.60667e-05 6.58096e-06 4.23426e-05 -6.04894e-06 0.000176819 3.90165e-20 4.23426e-05 6.04894e-06 -2.63238e-05 -2.41957e-05 -1.38913e-19 0.000176819 -1.38913e-19 -0.000176819 -6.58096e-06 -3.29048e-06 6.58096e-06 3.29048e-06 -6.04894e-06 3.02447e-06 3.90165e-20 1.89448e-05 6.04894e-06 3.02447e-06 -1.10114e-20 -1.07997e-20 -0.00020813 -0.000846595 -0.000846595 -0.000215168 3.46883e-05 4.95547e-06 3.46883e-05 4.95547e-06 0.000141099 3.17108e-20 3.58613e-05 -5.12305e-06 3.58613e-05 -5.12305e-06 -1.98219e-05 -2.04922e-05 -1.0842e-19 0.000141099 -0.000141099 -1.16891e-19 -4.95547e-06 -2.47773e-06 4.95547e-06 2.47773e-06 3.17108e-20 1.51178e-05 -5.12305e-06 2.56152e-06 5.12305e-06 -2.56152e-06 -8.25857e-21 -9.42324e-21 -0.000222008 -0.000874352 -0.000215168 -0.000874352 3.70013e-05 5.2859e-06 3.70013e-05 5.2859e-06 3.58613e-05 -5.12305e-06 0.000145725 -1.73642e-20 3.58613e-05 5.12305e-06 -2.11436e-05 -2.04922e-05 1.15196e-19 0.000145725 -3.38813e-21 -0.000145725 -5.2859e-06 -2.64295e-06 5.2859e-06 2.64295e-06 -5.12305e-06 2.56152e-06 -1.73642e-20 1.56134e-05 5.12305e-06 2.56152e-06 8.99973e-21 -1.04859e-21 -0.000239721 -0.000231141 -0.000941724 -0.000941724 3.99535e-05 5.70765e-06 3.99535e-05 5.70765e-06 3.85235e-05 5.50335e-06 3.85235e-05 5.50335e-06 0.000156954 -1.69407e-21 -2.28306e-05 -2.20134e-05 1.25361e-19 -1.18585e-19 0.000156954 -0.000156954 -5.70765e-06 -2.85382e-06 5.70765e-06 2.85382e-06 -5.50335e-06 -2.75168e-06 5.50335e-06 2.75168e-06 -1.69407e-21 1.68165e-05 9.1056e-21 -9.1056e-21 -0.00021506 -0.000783772 -0.000783772 -0.000176827 3.58433e-05 5.12047e-06 3.58433e-05 5.12047e-06 0.000130629 3.02285e-20 2.94711e-05 -4.21016e-06 2.94711e-05 -4.21016e-06 -2.04819e-05 -1.68406e-05 -1.11808e-19 0.000130629 -0.000130629 -9.65618e-20 -5.12047e-06 -2.56023e-06 5.12047e-06 2.56023e-06 3.02285e-20 1.39959e-05 -4.21016e-06 2.10508e-06 4.21016e-06 -2.10508e-06 -8.25857e-21 -7.72918e-21 -0.000215168 -0.000870464 -0.000870464 -0.000220064 3.58613e-05 5.12305e-06 3.58613e-05 5.12305e-06 0.000145077 -1.69407e-20 3.66774e-05 -5.23962e-06 3.66774e-05 -5.23962e-06 -2.04922e-05 -2.09585e-05 1.11808e-19 0.000145077 -0.000145077 -6.77626e-21 -5.12305e-06 -2.56152e-06 5.12305e-06 2.56152e-06 -1.69407e-20 1.5544e-05 -5.23962e-06 2.61981e-06 5.23962e-06 -2.61981e-06 8.78797e-21 -1.01002e-21 -0.000793118 -0.000220064 -0.000793118 -0.000176495 3.66774e-05 -5.23962e-06 0.000132186 1.73112e-20 2.94158e-05 -4.20226e-06 3.66774e-05 5.23962e-06 2.94158e-05 -4.20226e-06 -2.09585e-05 -1.6809e-05 0.000132186 -1.20279e-19 -0.000132186 -5.0822e-21 -5.23962e-06 2.61981e-06 1.73112e-20 1.41628e-05 -4.20226e-06 2.10113e-06 5.23962e-06 2.61981e-06 4.20226e-06 -2.10113e-06 -9.42324e-21 -6.42452e-22 -0.000706643 -0.000176827 -0.000176495 -0.000706643 2.94711e-05 -4.21016e-06 2.94158e-05 -4.20226e-06 0.000117774 1.33937e-20 2.94711e-05 4.21016e-06 2.94158e-05 4.20226e-06 -1.68406e-05 -1.6809e-05 0.000117774 -3.38813e-21 -9.74088e-20 -0.000117774 -4.21016e-06 2.10508e-06 -4.20226e-06 2.10113e-06 1.33937e-20 1.26186e-05 4.21016e-06 2.10508e-06 4.20226e-06 2.10113e-06 -8.72298e-22 -7.51742e-21 -0.00027155 -0.00108551 -0.00108551 -0.000271206 4.52583e-05 6.46547e-06 4.52583e-05 6.46547e-06 0.000180919 3.87518e-20 4.5201e-05 -6.45729e-06 4.5201e-05 -6.45729e-06 -2.58619e-05 -2.58292e-05 -1.38913e-19 0.000180919 -0.000180919 -1.47384e-19 -6.46547e-06 -3.23274e-06 6.46547e-06 3.23274e-06 3.87518e-20 1.93841e-05 -6.45729e-06 3.22864e-06 6.45729e-06 -3.22864e-06 -1.05879e-20 -1.19643e-20 -0.000275202 -0.00109267 -0.00109267 -0.000271136 4.5867e-05 6.55242e-06 4.5867e-05 6.55242e-06 0.000182112 -1.99053e-20 4.51893e-05 -6.45561e-06 4.51893e-05 -6.45561e-06 -2.62097e-05 -2.58224e-05 1.38913e-19 0.000182112 -0.000182112 -6.77626e-21 -6.55242e-06 -3.27621e-06 6.55242e-06 3.27621e-06 -1.99053e-20 1.9512e-05 -6.45561e-06 3.2278e-06 6.45561e-06 -3.2278e-06 1.07997e-20 -1.27809e-21 -0.00108468 -0.000271206 -0.000271136 -0.00108468 4.5201e-05 -6.45729e-06 4.51893e-05 -6.45561e-06 0.000180781 2.02229e-20 4.5201e-05 6.45729e-06 4.51893e-05 6.45561e-06 -2.58292e-05 -2.58224e-05 0.000180781 -6.77626e-21 -1.47384e-19 -0.000180781 -6.45729e-06 3.22864e-06 -6.45561e-06 3.2278e-06 2.02229e-20 1.93693e-05 6.45729e-06 3.22864e-06 6.45561e-06 3.2278e-06 -1.59915e-21 -1.15408e-20 -0.000236425 -0.000937367 -0.000937367 -0.000232259 3.94041e-05 5.62916e-06 3.94041e-05 5.62916e-06 0.000156228 3.37225e-20 3.87098e-05 -5.52997e-06 3.87098e-05 -5.52997e-06 -2.25166e-05 -2.21199e-05 -1.18585e-19 0.000156228 -0.000156228 -1.26208e-19 -5.62916e-06 -2.81458e-06 5.62916e-06 2.81458e-06 3.37225e-20 1.67387e-05 -5.52997e-06 2.76498e-06 5.52997e-06 -2.76498e-06 -9.31736e-21 -9.84676e-21 -0.000234359 -0.000934689 -0.000934689 -0.000232986 3.90598e-05 5.57998e-06 3.90598e-05 5.57998e-06 0.000155782 -1.86347e-20 3.88309e-05 -5.54728e-06 3.88309e-05 -5.54728e-06 -2.23199e-05 -2.21891e-05 1.21973e-19 0.000155782 -0.000155782 -1.01644e-20 -5.57998e-06 -2.78999e-06 5.57998e-06 2.78999e-06 -1.86347e-20 1.66909e-05 -5.54728e-06 2.77364e-06 5.54728e-06 -2.77364e-06 8.89385e-21 -8.99897e-22 -0.000900123 -0.000232986 -0.000900123 -0.000217076 3.88309e-05 -5.54728e-06 0.00015002 1.75759e-20 3.61793e-05 -5.16847e-06 3.88309e-05 5.54728e-06 3.61793e-05 -5.16847e-06 -2.21891e-05 -2.06739e-05 0.00015002 -1.27055e-19 -0.00015002 -5.0822e-21 -5.54728e-06 2.77364e-06 1.75759e-20 1.60736e-05 -5.16847e-06 2.58423e-06 5.54728e-06 2.77364e-06 5.16847e-06 -2.58423e-06 -1.00585e-20 -9.27555e-22 -0.000898668 -0.000232259 -0.000217076 -0.000898668 3.87098e-05 -5.52997e-06 3.61793e-05 -5.16847e-06 0.000149778 1.69936e-20 3.87098e-05 5.52997e-06 3.61793e-05 5.16847e-06 -2.21199e-05 -2.06739e-05 0.000149778 -3.38813e-21 -1.18585e-19 -0.000149778 -5.52997e-06 2.76498e-06 -5.16847e-06 2.58423e-06 1.69936e-20 1.60477e-05 5.52997e-06 2.76498e-06 5.16847e-06 2.58423e-06 -1.17434e-21 -9.52912e-21 -0.000217527 -0.000866772 -0.000866772 -0.000215859 3.62545e-05 5.17922e-06 3.62545e-05 5.17922e-06 0.000144462 3.21343e-20 3.59765e-05 -5.1395e-06 3.59765e-05 -5.1395e-06 -2.07169e-05 -2.0558e-05 -1.0842e-19 0.000144462 -0.000144462 -1.18585e-19 -5.17922e-06 -2.58961e-06 5.17922e-06 2.58961e-06 3.21343e-20 1.54781e-05 -5.1395e-06 2.56975e-06 5.1395e-06 -2.56975e-06 -8.57621e-21 -9.31736e-21 -0.000208835 -0.000760572 -0.000760572 -0.00017145 3.48059e-05 4.97227e-06 3.48059e-05 4.97227e-06 0.000126762 -1.69407e-20 2.85751e-05 -4.08215e-06 2.85751e-05 -4.08215e-06 -1.98891e-05 -1.63286e-05 1.11808e-19 0.000126762 -0.000126762 -3.38813e-21 -4.97227e-06 -2.48614e-06 4.97227e-06 2.48614e-06 -1.69407e-20 1.35816e-05 -4.08215e-06 2.04108e-06 4.08215e-06 -2.04108e-06 8.25857e-21 -7.48248e-22 -0.000682846 -0.00017145 -0.000682846 -0.000169973 2.85751e-05 -4.08215e-06 0.000113808 1.33408e-20 2.83288e-05 -4.04697e-06 2.85751e-05 4.08215e-06 2.83288e-05 -4.04697e-06 -1.63286e-05 -1.61879e-05 0.000113808 -9.31736e-20 -0.000113808 -5.0822e-21 -4.08215e-06 2.04108e-06 1.33408e-20 1.21937e-05 -4.04697e-06 2.02349e-06 4.08215e-06 2.04108e-06 4.04697e-06 -2.02349e-06 -7.30566e-21 -7.50892e-22 -0.000771664 -0.000215859 -0.000169973 -0.000771664 3.59765e-05 -5.1395e-06 2.83288e-05 -4.04697e-06 0.000128611 1.29702e-20 3.59765e-05 5.1395e-06 2.83288e-05 4.04697e-06 -2.0558e-05 -1.61879e-05 0.000128611 -6.77626e-21 -9.23266e-20 -0.000128611 -5.1395e-06 2.56975e-06 -4.04697e-06 2.02349e-06 1.29702e-20 1.37797e-05 5.1395e-06 2.56975e-06 4.04697e-06 2.02349e-06 -1.11554e-21 -7.19978e-21 -0.000274002 -0.00104863 -0.00104863 -0.000250313 4.5667e-05 6.52386e-06 4.5667e-05 6.52386e-06 0.000174772 -2.11758e-20 4.17188e-05 -5.95983e-06 4.17188e-05 -5.95983e-06 -2.60954e-05 -2.38393e-05 1.38913e-19 0.000174772 -0.000174772 -1.01644e-20 -6.52386e-06 -3.26193e-06 6.52386e-06 3.26193e-06 -2.11758e-20 1.87255e-05 -5.95983e-06 2.97992e-06 5.95983e-06 -2.97992e-06 1.07997e-20 -1.03041e-21 -0.000240863 -0.000968183 -0.000968183 -0.000243229 4.01438e-05 5.73483e-06 4.01438e-05 5.73483e-06 0.000161364 3.47284e-20 4.05381e-05 -5.79116e-06 4.05381e-05 -5.79116e-06 -2.29393e-05 -2.31646e-05 -1.21973e-19 0.000161364 -0.000161364 -1.33831e-19 -5.73483e-06 -2.86741e-06 5.73483e-06 2.86741e-06 3.47284e-20 1.7289e-05 -5.79116e-06 2.89558e-06 5.79116e-06 -2.89558e-06 -9.31736e-21 -1.03762e-20 -0.000987084 -0.000250313 -0.000243229 -0.000987084 4.17188e-05 -5.95983e-06 4.05381e-05 -5.79116e-06 0.000164514 1.91641e-20 4.17188e-05 5.95983e-06 4.05381e-05 5.79116e-06 -2.31646e-05 -2.38393e-05 0.000164514 -1.36372e-19 -6.77626e-21 -0.000164514 -5.95983e-06 2.97992e-06 -5.79116e-06 2.89558e-06 1.91641e-20 1.76265e-05 5.95983e-06 2.97992e-06 5.79116e-06 2.89558e-06 -1.32118e-21 -1.0482e-20 -0.000226033 -0.000909008 -0.000909008 -0.000228471 3.76721e-05 5.38173e-06 3.76721e-05 5.38173e-06 0.000151501 -1.82112e-20 3.80786e-05 -5.43979e-06 3.80786e-05 -5.43979e-06 -2.15269e-05 -2.17592e-05 1.21973e-19 0.000151501 -0.000151501 -3.38813e-21 -5.38173e-06 -2.69087e-06 5.38173e-06 2.69087e-06 -1.82112e-20 1.62323e-05 -5.43979e-06 2.7199e-06 5.43979e-06 -2.7199e-06 8.78797e-21 -1.08483e-21 -0.000225119 -0.000834754 -0.000834754 -0.000192258 3.75198e-05 5.35997e-06 3.75198e-05 5.35997e-06 0.000139126 3.11814e-20 3.20431e-05 -4.57758e-06 3.20431e-05 -4.57758e-06 -2.14399e-05 -1.83103e-05 -1.15196e-19 0.000139126 -0.000139126 -1.05032e-19 -5.35997e-06 -2.67999e-06 5.35997e-06 2.67999e-06 3.11814e-20 1.49063e-05 -4.57758e-06 2.28879e-06 4.57758e-06 -2.28879e-06 -8.47033e-21 -8.25857e-21 -0.000755477 -0.000192258 -0.000755477 -0.00018548 3.20431e-05 -4.57758e-06 0.000125913 1.38172e-20 3.09134e-05 -4.41619e-06 3.20431e-05 4.57758e-06 3.09134e-05 -4.41619e-06 -1.83103e-05 -1.76648e-05 0.000125913 -3.38813e-21 -0.000125913 -1.00797e-19 -4.57758e-06 2.28879e-06 1.38172e-20 1.34907e-05 -4.41619e-06 2.2081e-06 4.57758e-06 2.28879e-06 4.41619e-06 -2.2081e-06 -9.77634e-22 -7.94093e-21 -0.000827903 -0.000228471 -0.00018548 -0.000827903 3.80786e-05 -5.43979e-06 3.09134e-05 -4.41619e-06 0.000137984 1.70465e-20 3.80786e-05 5.43979e-06 3.09134e-05 4.41619e-06 -2.17592e-05 -1.76648e-05 0.000137984 -1.24514e-19 -6.77626e-21 -0.000137984 -5.43979e-06 2.7199e-06 -4.41619e-06 2.2081e-06 1.70465e-20 1.4784e-05 5.43979e-06 2.7199e-06 4.41619e-06 2.2081e-06 -9.74088e-21 -9.80977e-22 -0.000250313 -0.000935759 -0.000935759 -0.000217566 4.17188e-05 5.95983e-06 4.17188e-05 5.95983e-06 0.00015596 3.66871e-20 3.62611e-05 -5.18015e-06 3.62611e-05 -5.18015e-06 -2.38393e-05 -2.07206e-05 -1.25361e-19 0.00015596 -0.00015596 -1.19432e-19 -5.95983e-06 -2.97992e-06 5.95983e-06 2.97992e-06 3.66871e-20 1.671e-05 -5.18015e-06 2.59008e-06 5.18015e-06 -2.59008e-06 -9.74088e-21 -9.52912e-21 -0.000232259 -0.00089965 -0.000217566 -0.00089965 3.87098e-05 5.52997e-06 3.87098e-05 5.52997e-06 3.62611e-05 -5.18015e-06 0.000149942 -1.73642e-20 3.62611e-05 5.18015e-06 -2.21199e-05 -2.07206e-05 1.21973e-19 0.000149942 -3.38813e-21 -0.000149942 -5.52997e-06 -2.76498e-06 5.52997e-06 2.76498e-06 -5.18015e-06 2.59008e-06 -1.73642e-20 1.60652e-05 5.18015e-06 2.59008e-06 9.31736e-21 -1.09938e-21 -0.000271206 -0.000998344 -0.000998344 -0.000227966 4.5201e-05 6.45729e-06 4.5201e-05 6.45729e-06 0.000166391 -2.20229e-20 3.79943e-05 -5.42776e-06 3.79943e-05 -5.42776e-06 -2.58292e-05 -2.1711e-05 1.42302e-19 0.000166391 -0.000166391 -6.77626e-21 -6.45729e-06 -3.22864e-06 6.45729e-06 3.22864e-06 -2.20229e-20 1.78276e-05 -5.42776e-06 2.71388e-06 5.42776e-06 -2.71388e-06 1.07997e-20 -8.39623e-22 -0.000228471 -0.000912874 -0.000227966 -0.000912874 3.80786e-05 5.43979e-06 3.80786e-05 5.43979e-06 3.79943e-05 -5.42776e-06 0.000152146 3.57871e-20 3.79943e-05 5.42776e-06 -2.17592e-05 -2.1711e-05 -1.18585e-19 0.000152146 -1.24514e-19 -0.000152146 -5.43979e-06 -2.7199e-06 5.43979e-06 2.7199e-06 -5.42776e-06 2.71388e-06 3.57871e-20 1.63013e-05 5.42776e-06 2.71388e-06 -8.68209e-21 -9.84676e-21 -0.000254055 -0.0010093 -0.0010093 -0.000250597 4.23426e-05 6.04894e-06 4.23426e-05 6.04894e-06 0.000168217 3.92282e-20 4.17661e-05 -5.96659e-06 4.17661e-05 -5.96659e-06 -2.41957e-05 -2.38664e-05 -1.28749e-19 0.000168217 -0.000168217 -1.37219e-19 -6.04894e-06 -3.02447e-06 6.04894e-06 3.02447e-06 3.92282e-20 1.80233e-05 -5.96659e-06 2.98329e-06 5.96659e-06 -2.98329e-06 -9.84676e-21 -1.11173e-20 -0.000176827 -0.000711186 -0.000711186 -0.000178767 2.94711e-05 4.21016e-06 2.94711e-05 4.21016e-06 0.000118531 -1.3129e-20 2.97944e-05 -4.25635e-06 2.97944e-05 -4.25635e-06 -1.68406e-05 -1.70254e-05 9.14796e-20 0.000118531 -0.000118531 -5.0822e-21 -4.21016e-06 -2.10508e-06 4.21016e-06 2.10508e-06 -1.3129e-20 1.26998e-05 -4.25635e-06 2.12817e-06 4.25635e-06 -2.12817e-06 6.88214e-21 -8.83364e-22 -0.000858727 -0.000250597 -0.000178767 -0.000858727 4.17661e-05 -5.96659e-06 2.97944e-05 -4.25635e-06 0.000143121 1.43466e-20 4.17661e-05 5.96659e-06 2.97944e-05 4.25635e-06 -2.38664e-05 -1.70254e-05 0.000143121 -1.01644e-20 -9.82558e-20 -0.000143121 -5.96659e-06 2.98329e-06 -4.25635e-06 2.12817e-06 1.43466e-20 1.53344e-05 5.96659e-06 2.98329e-06 4.25635e-06 2.12817e-06 -1.25054e-21 -7.51742e-21 -0.000267245 -0.00104126 -0.00104126 -0.000253384 4.45408e-05 6.36296e-06 4.45408e-05 6.36296e-06 0.000173543 4.00752e-20 4.22306e-05 -6.03294e-06 4.22306e-05 -6.03294e-06 -2.54519e-05 -2.41318e-05 -1.38913e-19 0.000173543 -0.000173543 -1.38913e-19 -6.36296e-06 -3.18148e-06 6.36296e-06 3.18148e-06 4.00752e-20 1.85939e-05 -6.03294e-06 3.01647e-06 6.03294e-06 -3.01647e-06 -1.03762e-20 -1.09055e-20 -0.000250597 -0.00100796 -0.000253384 -0.00100796 4.17661e-05 5.96659e-06 4.17661e-05 5.96659e-06 4.22306e-05 -6.03294e-06 0.000167993 -2.28699e-20 4.22306e-05 6.03294e-06 -2.38664e-05 -2.41318e-05 1.28749e-19 0.000167993 -5.0822e-21 -0.000167993 -5.96659e-06 -2.98329e-06 5.96659e-06 2.98329e-06 -6.03294e-06 3.01647e-06 -2.28699e-20 1.79993e-05 6.03294e-06 3.01647e-06 1.02703e-20 -1.35543e-21 -0.000263367 -0.001051 -0.001051 -0.000262131 4.38944e-05 6.27063e-06 4.38944e-05 6.27063e-06 0.000175166 4.04988e-20 4.36886e-05 -6.24122e-06 4.36886e-05 -6.24122e-06 -2.50825e-05 -2.49649e-05 -1.35525e-19 0.000175166 -0.000175166 -1.43996e-19 -6.27063e-06 -3.13532e-06 6.27063e-06 3.13532e-06 4.04988e-20 1.87678e-05 -6.24122e-06 3.12061e-06 6.24122e-06 -3.12061e-06 -1.01644e-20 -1.13291e-20 -0.000192258 -0.00076639 -0.00076639 -0.000190936 3.20431e-05 4.57758e-06 3.20431e-05 4.57758e-06 0.000127732 -1.60936e-20 3.18227e-05 -4.5461e-06 3.18227e-05 -4.5461e-06 -1.83103e-05 -1.81844e-05 9.82558e-20 0.000127732 -0.000127732 -5.0822e-21 -4.57758e-06 -2.28879e-06 4.57758e-06 2.28879e-06 -1.60936e-20 1.36855e-05 -4.5461e-06 2.27305e-06 4.5461e-06 -2.27305e-06 7.72918e-21 -9.55124e-22 -0.000906135 -0.000262131 -0.000190936 -0.000906135 4.36886e-05 -6.24122e-06 3.18227e-05 -4.5461e-06 0.000151023 1.58819e-20 4.36886e-05 6.24122e-06 3.18227e-05 4.5461e-06 -2.49649e-05 -1.81844e-05 0.000151023 -5.0822e-21 -1.04185e-19 -0.000151023 -6.24122e-06 3.12061e-06 -4.5461e-06 2.27305e-06 1.58819e-20 1.6181e-05 6.24122e-06 3.12061e-06 4.5461e-06 2.27305e-06 -1.39356e-21 -8.04681e-21 -0.000263348 -0.00104527 -0.00104527 -0.000259286 4.38913e-05 6.27019e-06 4.38913e-05 6.27019e-06 0.000174211 3.91223e-20 4.32143e-05 -6.17347e-06 4.32143e-05 -6.17347e-06 -2.50808e-05 -2.46939e-05 -1.32137e-19 0.000174211 -0.000174211 -1.43996e-19 -6.27019e-06 -3.1351e-06 6.27019e-06 3.1351e-06 3.91223e-20 1.86655e-05 -6.17347e-06 3.08674e-06 6.17347e-06 -3.08674e-06 -1.05879e-20 -1.12232e-20 -0.000262131 -0.00104283 -0.000259286 -0.00104283 4.36886e-05 6.24122e-06 4.36886e-05 6.24122e-06 4.32143e-05 -6.17347e-06 0.000173806 -1.99053e-20 4.32143e-05 6.17347e-06 -2.46939e-05 -2.49649e-05 1.32137e-19 0.000173806 -6.77626e-21 -0.000173806 -6.24122e-06 -3.12061e-06 6.24122e-06 3.12061e-06 -6.17347e-06 3.08674e-06 -1.99053e-20 1.8622e-05 6.17347e-06 3.08674e-06 -1.17421e-21 1.02703e-20 -0.000271136 -0.000982786 -0.000982786 -0.000220257 4.51893e-05 6.45561e-06 4.51893e-05 6.45561e-06 0.000163798 3.5893e-20 3.67095e-05 -5.24422e-06 3.67095e-05 -5.24422e-06 -2.58224e-05 -2.09769e-05 -1.38913e-19 0.000163798 -0.000163798 -1.21126e-19 -6.45561e-06 -3.2278e-06 6.45561e-06 3.2278e-06 3.5893e-20 1.75497e-05 -5.24422e-06 2.62211e-06 5.24422e-06 -2.62211e-06 -1.05879e-20 -9.74088e-21 -0.000215859 -0.000872232 -0.000220257 -0.000872232 3.59765e-05 5.1395e-06 3.59765e-05 5.1395e-06 3.67095e-05 -5.24422e-06 0.000145372 -1.56701e-20 3.67095e-05 5.24422e-06 -2.0558e-05 -2.09769e-05 1.11808e-19 0.000145372 -6.77626e-21 -0.000145372 -5.1395e-06 -2.56975e-06 5.1395e-06 2.56975e-06 -5.24422e-06 2.62211e-06 -1.56701e-20 1.55756e-05 5.24422e-06 2.62211e-06 8.57621e-21 -1.18203e-21 -0.00017145 -0.000688372 -0.000688372 -0.000172736 2.85751e-05 4.08215e-06 2.85751e-05 4.08215e-06 0.000114729 2.69992e-20 2.87893e-05 -4.11275e-06 2.87893e-05 -4.11275e-06 -1.63286e-05 -1.6451e-05 -8.47033e-20 0.000114729 -0.000114729 -9.40207e-20 -4.08215e-06 -2.04108e-06 4.08215e-06 2.04108e-06 2.69992e-20 1.22924e-05 -4.11275e-06 2.05638e-06 4.11275e-06 -2.05638e-06 -6.77626e-21 -7.30566e-21 -0.000243229 -0.000831929 -0.000172736 -0.000831929 4.05381e-05 5.79116e-06 4.05381e-05 5.79116e-06 2.87893e-05 -4.11275e-06 0.000138655 -1.99053e-20 2.87893e-05 4.11275e-06 -2.31646e-05 -1.6451e-05 1.18585e-19 0.000138655 -5.0822e-21 -0.000138655 -5.79116e-06 -2.89558e-06 5.79116e-06 2.89558e-06 -4.11275e-06 2.05638e-06 -1.99053e-20 1.48559e-05 4.11275e-06 2.05638e-06 9.95264e-21 -9.59613e-22 -0.000232986 -0.000904078 -0.000904078 -0.000219053 3.88309e-05 5.54728e-06 3.88309e-05 5.54728e-06 0.00015068 3.34049e-20 3.65089e-05 -5.21555e-06 3.65089e-05 -5.21555e-06 -2.21891e-05 -2.08622e-05 -1.18585e-19 0.00015068 -0.00015068 -1.20279e-19 -5.54728e-06 -2.77364e-06 5.54728e-06 2.77364e-06 3.34049e-20 1.61442e-05 -5.21555e-06 2.60778e-06 5.21555e-06 -2.60778e-06 -8.89385e-21 -9.42324e-21 -0.000253384 -0.000944874 -0.000219053 -0.000944874 4.22306e-05 6.03294e-06 4.22306e-05 6.03294e-06 3.65089e-05 -5.21555e-06 0.000157479 -1.77877e-20 3.65089e-05 5.21555e-06 -2.41318e-05 -2.08622e-05 1.28749e-19 0.000157479 -6.77626e-21 -0.000157479 -6.03294e-06 -3.01647e-06 6.03294e-06 3.01647e-06 -5.21555e-06 2.60778e-06 -1.77877e-20 1.68727e-05 5.21555e-06 2.60778e-06 9.74088e-21 -1.20145e-21 -0.000220064 -0.000875208 -0.000875208 -0.00021754 3.66774e-05 5.23962e-06 3.66774e-05 5.23962e-06 0.000145868 3.30872e-20 3.62567e-05 -5.17952e-06 3.62567e-05 -5.17952e-06 -2.09585e-05 -2.07181e-05 -1.11808e-19 0.000145868 -0.000145868 -1.18585e-19 -5.23962e-06 -2.61981e-06 5.23962e-06 2.61981e-06 3.30872e-20 1.56287e-05 -5.17952e-06 2.58976e-06 5.17952e-06 -2.58976e-06 -8.68209e-21 -9.52912e-21 -0.000259286 -0.000953652 -0.00021754 -0.000953652 4.32143e-05 6.17347e-06 4.32143e-05 6.17347e-06 3.62567e-05 -5.17952e-06 0.000158942 -2.07523e-20 3.62567e-05 5.17952e-06 -2.46939e-05 -2.07181e-05 1.32137e-19 0.000158942 -3.38813e-21 -0.000158942 -6.17347e-06 -3.08674e-06 6.17347e-06 3.08674e-06 -5.17952e-06 2.58976e-06 -2.07523e-20 1.70295e-05 5.17952e-06 2.58976e-06 1.06938e-20 -1.07255e-21 -0.000176495 -0.000706269 -0.000706269 -0.00017664 2.94158e-05 4.20226e-06 2.94158e-05 4.20226e-06 0.000117712 2.65227e-20 2.944e-05 -4.20571e-06 2.944e-05 -4.20571e-06 -1.6809e-05 -1.68229e-05 -9.14796e-20 0.000117712 -0.000117712 -9.57147e-20 -4.20226e-06 -2.10113e-06 4.20226e-06 2.10113e-06 2.65227e-20 1.2612e-05 -4.20571e-06 2.10286e-06 4.20571e-06 -2.10286e-06 -6.98802e-21 -7.72918e-21 -0.00021754 -0.000926592 -0.000926592 -0.000245756 3.62567e-05 5.17952e-06 3.62567e-05 5.17952e-06 0.000154432 -1.73642e-20 4.09593e-05 -5.85133e-06 4.09593e-05 -5.85133e-06 -2.07181e-05 -2.34053e-05 1.0842e-19 0.000154432 -0.000154432 -6.77626e-21 -5.17952e-06 -2.58976e-06 5.17952e-06 2.58976e-06 -1.73642e-20 1.65463e-05 -5.85133e-06 2.92566e-06 5.85133e-06 -2.92566e-06 8.47033e-21 -1.0622e-21 -0.000842304 -0.00017664 -0.000842304 -0.000244512 2.944e-05 -4.20571e-06 0.000140384 1.8423e-20 4.0752e-05 -5.82172e-06 2.944e-05 4.20571e-06 4.0752e-05 -5.82172e-06 -1.68229e-05 -2.32869e-05 0.000140384 -5.0822e-21 -0.000140384 -1.32984e-19 -4.20571e-06 2.10286e-06 1.8423e-20 1.50411e-05 -5.82172e-06 2.91086e-06 4.20571e-06 2.10286e-06 5.82172e-06 -2.91086e-06 -8.6112e-22 -1.09055e-20 -0.000980536 -0.000245756 -0.000244512 -0.000980536 4.09593e-05 -5.85133e-06 4.0752e-05 -5.82172e-06 0.000163423 1.87406e-20 4.09593e-05 5.85133e-06 4.0752e-05 5.82172e-06 -2.34053e-05 -2.32869e-05 0.000163423 -1.33831e-19 -3.38813e-21 -0.000163423 -5.85133e-06 2.92566e-06 -5.82172e-06 2.91086e-06 1.87406e-20 1.75096e-05 5.85133e-06 2.92566e-06 5.82172e-06 2.91086e-06 -1.01644e-20 -1.14236e-21 -0.000219053 -0.000878763 -0.000878763 -0.000220328 3.65089e-05 5.21555e-06 3.65089e-05 5.21555e-06 0.00014646 -1.94818e-20 3.67214e-05 -5.24591e-06 3.67214e-05 -5.24591e-06 -2.08622e-05 -2.09836e-05 1.11808e-19 0.00014646 -0.00014646 -5.0822e-21 -5.21555e-06 -2.60778e-06 5.21555e-06 2.60778e-06 -1.94818e-20 1.56922e-05 -5.24591e-06 2.62295e-06 5.24591e-06 -2.62295e-06 8.78797e-21 -9.09796e-22 -0.000217076 -0.000883491 -0.000883491 -0.00022467 3.61793e-05 5.16847e-06 3.61793e-05 5.16847e-06 0.000147248 3.37754e-20 3.74449e-05 -5.34928e-06 3.74449e-05 -5.34928e-06 -2.06739e-05 -2.13971e-05 -1.15196e-19 0.000147248 -0.000147248 -1.2282e-19 -5.16847e-06 -2.58423e-06 5.16847e-06 2.58423e-06 3.37754e-20 1.57766e-05 -5.34928e-06 2.67464e-06 5.34928e-06 -2.67464e-06 -8.57621e-21 -9.74088e-21 -0.000862345 -0.000220328 -0.000862345 -0.000210845 3.67214e-05 -5.24591e-06 0.000143724 1.61995e-20 3.51408e-05 -5.02011e-06 3.67214e-05 5.24591e-06 3.51408e-05 -5.02011e-06 -2.09836e-05 -2.00804e-05 0.000143724 -1.20279e-19 -0.000143724 -6.77626e-21 -5.24591e-06 2.62295e-06 1.61995e-20 1.5399e-05 -5.02011e-06 2.51005e-06 5.24591e-06 2.62295e-06 5.02011e-06 -2.51005e-06 -9.31736e-21 -7.87299e-22 -0.000871029 -0.00022467 -0.000210845 -0.000871029 3.74449e-05 -5.34928e-06 3.51408e-05 -5.02011e-06 0.000145171 1.72583e-20 3.74449e-05 5.34928e-06 3.51408e-05 5.02011e-06 -2.00804e-05 -2.13971e-05 0.000145171 -5.0822e-21 -1.13502e-19 -0.000145171 -5.34928e-06 2.67464e-06 -5.02011e-06 2.51005e-06 1.72583e-20 1.55541e-05 5.34928e-06 2.67464e-06 5.02011e-06 2.51005e-06 -8.89385e-21 -1.02269e-21 -0.000227966 -0.000908612 -0.000908612 -0.00022634 3.79943e-05 5.42776e-06 3.79943e-05 5.42776e-06 0.000151435 3.43578e-20 3.77234e-05 -5.38906e-06 3.77234e-05 -5.38906e-06 -2.1711e-05 -2.15562e-05 -1.18585e-19 0.000151435 -0.000151435 -1.23667e-19 -5.42776e-06 -2.71388e-06 5.42776e-06 2.71388e-06 3.43578e-20 1.62252e-05 -5.38906e-06 2.69453e-06 5.38906e-06 -2.69453e-06 -8.89385e-21 -9.74088e-21 -0.000220257 -0.000881463 -0.000881463 -0.000220474 3.67095e-05 5.24422e-06 3.67095e-05 5.24422e-06 0.00014691 -1.69407e-20 3.67457e-05 -5.24938e-06 3.67457e-05 -5.24938e-06 -2.09769e-05 -2.09975e-05 1.11808e-19 0.00014691 -0.00014691 -5.0822e-21 -5.24422e-06 -2.62211e-06 5.24422e-06 2.62211e-06 -1.69407e-20 1.57404e-05 -5.24938e-06 2.62469e-06 5.24938e-06 -2.62469e-06 8.89385e-21 -1.06453e-21 -0.000893629 -0.00022634 -0.000220474 -0.000893629 3.77234e-05 -5.38906e-06 3.67457e-05 -5.24938e-06 0.000148938 1.56701e-20 3.77234e-05 5.38906e-06 3.67457e-05 5.24938e-06 -2.15562e-05 -2.09975e-05 0.000148938 -6.77626e-21 -1.20279e-19 -0.000148938 -5.38906e-06 2.69453e-06 -5.24938e-06 2.62469e-06 1.56701e-20 1.59577e-05 5.38906e-06 2.69453e-06 5.24938e-06 2.62469e-06 -1.05437e-21 -9.42324e-21 -0.000178767 -0.000716248 -0.000716248 -0.000179357 2.97944e-05 4.25635e-06 2.97944e-05 4.25635e-06 0.000119375 2.69462e-20 2.98929e-05 -4.27041e-06 2.98929e-05 -4.27041e-06 -1.70254e-05 -1.70817e-05 -9.48677e-20 0.000119375 -0.000119375 -9.74088e-20 -4.25635e-06 -2.12817e-06 4.25635e-06 2.12817e-06 2.69462e-20 1.27901e-05 -4.27041e-06 2.13521e-06 4.27041e-06 -2.13521e-06 -6.98802e-21 -7.72918e-21 -0.00017664 -0.000711995 -0.000179357 -0.000711995 2.944e-05 4.20571e-06 2.944e-05 4.20571e-06 2.98929e-05 -4.27041e-06 0.000118666 -1.43996e-20 2.98929e-05 4.27041e-06 -1.70817e-05 -1.68229e-05 9.14796e-20 0.000118666 -5.0822e-21 -0.000118666 -4.20571e-06 -2.10286e-06 4.20571e-06 2.10286e-06 -4.27041e-06 2.13521e-06 -1.43996e-20 1.27142e-05 4.27041e-06 2.13521e-06 -1.02421e-21 6.98802e-21 -0.000172736 -0.000688336 -0.000688336 -0.000171432 2.87893e-05 4.11275e-06 2.87893e-05 4.11275e-06 0.000114723 -1.35525e-20 2.8572e-05 -4.08172e-06 2.8572e-05 -4.08172e-06 -1.6451e-05 -1.63269e-05 8.80914e-20 0.000114723 -0.000114723 -5.0822e-21 -4.11275e-06 -2.05638e-06 4.11275e-06 2.05638e-06 -1.35525e-20 1.22917e-05 -4.08172e-06 2.04086e-06 4.08172e-06 -2.04086e-06 6.67038e-21 -7.10701e-22 -0.000169973 -0.000679822 -0.000679822 -0.000169938 2.83288e-05 4.04697e-06 2.83288e-05 4.04697e-06 0.000113304 2.5358e-20 2.83231e-05 -4.04615e-06 2.83231e-05 -4.04615e-06 -1.61879e-05 -1.61846e-05 -8.80914e-20 0.000113304 -0.000113304 -9.23266e-20 -4.04697e-06 -2.02349e-06 4.04697e-06 2.02349e-06 2.5358e-20 1.21397e-05 -4.04615e-06 2.02308e-06 4.04615e-06 -2.02308e-06 -6.56451e-21 -7.41154e-21 -0.000682741 -0.000171432 -0.000169938 -0.000682741 2.8572e-05 -4.08172e-06 2.83231e-05 -4.04615e-06 0.00011379 1.34466e-20 2.8572e-05 4.08172e-06 2.83231e-05 4.04615e-06 -1.63269e-05 -1.61846e-05 0.00011379 -9.31736e-20 -5.0822e-21 -0.00011379 -4.08172e-06 2.04086e-06 -4.04615e-06 2.02308e-06 1.34466e-20 1.21918e-05 4.08172e-06 2.04086e-06 4.04615e-06 2.02308e-06 -7.30566e-21 -7.95905e-22 -0.000217566 -0.000859447 -0.000859447 -0.000212157 3.62611e-05 5.18015e-06 3.62611e-05 5.18015e-06 0.000143241 -1.86347e-20 3.53595e-05 -5.05136e-06 3.53595e-05 -5.05136e-06 -2.07206e-05 -2.02054e-05 1.15196e-19 0.000143241 -0.000143241 -8.47033e-21 -5.18015e-06 -2.59008e-06 5.18015e-06 2.59008e-06 -1.86347e-20 1.53473e-05 -5.05136e-06 2.52568e-06 5.05136e-06 -2.52568e-06 8.25857e-21 -9.7042e-22 -0.000171432 -0.000767179 -0.000212157 -0.000767179 2.8572e-05 4.08172e-06 2.8572e-05 4.08172e-06 3.53595e-05 -5.05136e-06 0.000127863 2.87991e-20 3.53595e-05 5.05136e-06 -1.63269e-05 -2.02054e-05 -8.80914e-20 0.000127863 -1.14349e-19 -0.000127863 -4.08172e-06 -2.04086e-06 4.08172e-06 2.04086e-06 -5.05136e-06 2.52568e-06 2.87991e-20 1.36996e-05 5.05136e-06 2.52568e-06 -6.35275e-21 -9.31736e-21 -0.00018548 -0.00079569 -0.00079569 -0.000212365 3.09134e-05 4.41619e-06 3.09134e-05 4.41619e-06 0.000132615 -1.52466e-20 3.53941e-05 -5.0563e-06 3.53941e-05 -5.0563e-06 -1.76648e-05 -2.02252e-05 9.48677e-20 0.000132615 -0.000132615 -6.77626e-21 -4.41619e-06 -2.2081e-06 4.41619e-06 2.2081e-06 -1.52466e-20 1.42087e-05 -5.0563e-06 2.52815e-06 5.0563e-06 -2.52815e-06 7.19978e-21 -9.73181e-22 -0.000190936 -0.000814086 -0.000814086 -0.000216107 3.18227e-05 4.5461e-06 3.18227e-05 4.5461e-06 0.000135681 3.20284e-20 3.60178e-05 -5.1454e-06 3.60178e-05 -5.1454e-06 -1.81844e-05 -2.05816e-05 -9.82558e-20 0.000135681 -0.000135681 -1.17738e-19 -4.5461e-06 -2.27305e-06 4.5461e-06 2.27305e-06 3.20284e-20 1.45372e-05 -5.1454e-06 2.5727e-06 5.1454e-06 -2.5727e-06 -7.30566e-21 -9.42324e-21 -0.000856943 -0.000212365 -0.000216107 -0.000856943 3.53941e-05 -5.0563e-06 3.60178e-05 -5.1454e-06 0.000142824 1.59348e-20 3.53941e-05 5.0563e-06 3.60178e-05 5.1454e-06 -2.05816e-05 -2.02252e-05 0.000142824 -1.16044e-19 -8.47033e-21 -0.000142824 -5.0563e-06 2.52815e-06 -5.1454e-06 2.5727e-06 1.59348e-20 1.53025e-05 5.0563e-06 2.52815e-06 5.1454e-06 2.5727e-06 -1.27997e-21 -9.1056e-21 -0.000212365 -0.000916281 -0.000916281 -0.000245776 3.53941e-05 5.0563e-06 3.53941e-05 5.0563e-06 0.000152714 3.47813e-20 4.09627e-05 -5.85181e-06 4.09627e-05 -5.85181e-06 -2.02252e-05 -2.34072e-05 -1.0842e-19 0.000152714 -0.000152714 -1.34678e-19 -5.0563e-06 -2.52815e-06 5.0563e-06 2.52815e-06 3.47813e-20 1.63622e-05 -5.85181e-06 2.9259e-06 5.85181e-06 -2.9259e-06 -8.25857e-21 -1.05879e-20 -0.00022634 -0.000944233 -0.000245776 -0.000944233 3.77234e-05 5.38906e-06 3.77234e-05 5.38906e-06 4.09627e-05 -5.85181e-06 0.000157372 -1.69407e-20 4.09627e-05 5.85181e-06 -2.15562e-05 -2.34072e-05 1.15196e-19 0.000157372 -5.0822e-21 -0.000157372 -5.38906e-06 -2.69453e-06 5.38906e-06 2.69453e-06 -5.85181e-06 2.9259e-06 -1.69407e-20 1.68613e-05 5.85181e-06 2.9259e-06 9.1056e-21 -1.1763e-21 -0.000220328 -0.000179357 -0.000799371 -0.000799371 3.67214e-05 5.24591e-06 3.67214e-05 5.24591e-06 2.98929e-05 4.27041e-06 2.98929e-05 4.27041e-06 0.000133229 1.69407e-21 -2.09836e-05 -1.70817e-05 -1.11808e-19 9.14796e-20 0.000133229 -0.000133229 -5.24591e-06 -2.62295e-06 5.24591e-06 2.62295e-06 -4.27041e-06 -2.13521e-06 4.27041e-06 2.13521e-06 1.69407e-21 1.42745e-05 -8.68209e-21 6.98802e-21 -0.000169938 -0.000762086 -0.000762086 -0.000211105 2.83231e-05 4.04615e-06 2.83231e-05 4.04615e-06 0.000127014 -1.3129e-20 3.51841e-05 -5.0263e-06 3.51841e-05 -5.0263e-06 -1.61846e-05 -2.01052e-05 8.80914e-20 0.000127014 -0.000127014 -5.0822e-21 -4.04615e-06 -2.02308e-06 4.04615e-06 2.02308e-06 -1.3129e-20 1.36087e-05 -5.0263e-06 2.51315e-06 5.0263e-06 -2.51315e-06 6.98802e-21 -8.72046e-22 -0.000220474 -0.000863158 -0.000211105 -0.000863158 3.67457e-05 5.24938e-06 3.67457e-05 5.24938e-06 3.51841e-05 -5.0263e-06 0.00014386 3.1499e-20 3.51841e-05 5.0263e-06 -2.09975e-05 -2.01052e-05 -1.15196e-19 0.00014386 -1.14349e-19 -0.00014386 -5.24938e-06 -2.62469e-06 5.24938e-06 2.62469e-06 -5.0263e-06 2.51315e-06 3.1499e-20 1.54135e-05 5.0263e-06 2.51315e-06 -8.78797e-21 -9.21148e-21 -0.000245756 -0.000216107 -0.000923725 -0.000923725 4.09593e-05 5.85133e-06 4.09593e-05 5.85133e-06 3.60178e-05 5.1454e-06 3.60178e-05 5.1454e-06 0.000153954 0 -2.34053e-05 -2.05816e-05 -1.25361e-19 1.0842e-19 0.000153954 -0.000153954 -5.85133e-06 -2.92566e-06 5.85133e-06 2.92566e-06 -5.1454e-06 -2.5727e-06 5.1454e-06 2.5727e-06 0 1.64951e-05 -9.31736e-21 8.47033e-21 -0.000212157 -0.000835464 -0.000835464 -0.000205575 3.53595e-05 5.05136e-06 3.53595e-05 5.05136e-06 0.000139244 3.19755e-20 3.42625e-05 -4.89465e-06 3.42625e-05 -4.89465e-06 -2.02054e-05 -1.95786e-05 -1.05032e-19 0.000139244 -0.000139244 -1.13502e-19 -5.05136e-06 -2.52568e-06 5.05136e-06 2.52568e-06 3.19755e-20 1.4919e-05 -4.89465e-06 2.44732e-06 4.89465e-06 -2.44732e-06 -8.36445e-21 -8.89385e-21 -0.00022467 -0.00086049 -0.000205575 -0.00086049 3.74449e-05 5.34928e-06 3.74449e-05 5.34928e-06 3.42625e-05 -4.89465e-06 0.000143415 -1.69407e-20 3.42625e-05 4.89465e-06 -2.13971e-05 -1.95786e-05 1.15196e-19 0.000143415 -6.77626e-21 -0.000143415 -5.34928e-06 -2.67464e-06 5.34928e-06 2.67464e-06 -4.89465e-06 2.44732e-06 -1.69407e-20 1.53659e-05 4.89465e-06 2.44732e-06 8.89385e-21 -1.04085e-21 -0.000244512 -0.000960675 -0.000960675 -0.000235825 4.0752e-05 5.82172e-06 4.0752e-05 5.82172e-06 0.000160112 -1.86347e-20 3.93042e-05 -5.61489e-06 3.93042e-05 -5.61489e-06 -2.32869e-05 -2.24595e-05 1.28749e-19 0.000160112 -0.000160112 -1.01644e-20 -5.82172e-06 -2.91086e-06 5.82172e-06 2.91086e-06 -1.86347e-20 1.71549e-05 -5.61489e-06 2.80744e-06 5.61489e-06 -2.80744e-06 9.74088e-21 -1.07301e-21 -0.000210845 -0.00089334 -0.000235825 -0.00089334 3.51408e-05 5.02011e-06 3.51408e-05 5.02011e-06 3.93042e-05 -5.61489e-06 0.00014889 3.51519e-20 3.93042e-05 5.61489e-06 -2.00804e-05 -2.24595e-05 -1.05032e-19 0.00014889 -1.28749e-19 -0.00014889 -5.02011e-06 -2.51005e-06 5.02011e-06 2.51005e-06 -5.61489e-06 2.80744e-06 3.51519e-20 1.59525e-05 5.61489e-06 2.80744e-06 -8.04681e-21 -1.02703e-20 -0.000211105 -0.00083886 -0.00083886 -0.000208325 3.51841e-05 5.0263e-06 3.51841e-05 5.0263e-06 0.00013981 3.3246e-20 3.47209e-05 -4.96012e-06 3.47209e-05 -4.96012e-06 -2.01052e-05 -1.98405e-05 -1.0842e-19 0.00013981 -0.00013981 -1.13502e-19 -5.0263e-06 -2.51315e-06 5.0263e-06 2.51315e-06 3.3246e-20 1.49796e-05 -4.96012e-06 2.48006e-06 4.96012e-06 -2.48006e-06 -8.25857e-21 -9.1056e-21 -0.000205575 -0.000827801 -0.000208325 -0.000827801 3.42625e-05 4.89465e-06 3.42625e-05 4.89465e-06 3.47209e-05 -4.96012e-06 0.000137967 -1.77877e-20 3.47209e-05 4.96012e-06 -1.95786e-05 -1.98405e-05 1.01644e-19 0.000137967 -6.77626e-21 -0.000137967 -4.89465e-06 -2.44732e-06 4.89465e-06 2.44732e-06 -4.96012e-06 2.48006e-06 -1.77877e-20 1.47822e-05 4.96012e-06 2.48006e-06 8.25857e-21 -1.17865e-21 -0.000245776 -0.00100079 -0.00100079 -0.000254619 4.09627e-05 5.85181e-06 4.09627e-05 5.85181e-06 0.000166798 -1.82112e-20 4.24364e-05 -6.06235e-06 4.24364e-05 -6.06235e-06 -2.34072e-05 -2.42494e-05 1.28749e-19 0.000166798 -0.000166798 -5.0822e-21 -5.85181e-06 -2.9259e-06 5.85181e-06 2.9259e-06 -1.82112e-20 1.78712e-05 -6.06235e-06 3.03117e-06 6.06235e-06 -3.03117e-06 1.00585e-20 -1.06261e-21 -0.000235825 -0.000980887 -0.000254619 -0.000980887 3.93042e-05 5.61489e-06 3.93042e-05 5.61489e-06 4.24364e-05 -6.06235e-06 0.000163481 3.73224e-20 4.24364e-05 6.06235e-06 -2.24595e-05 -2.42494e-05 -1.18585e-19 0.000163481 -1.38913e-19 -0.000163481 -5.61489e-06 -2.80744e-06 5.61489e-06 2.80744e-06 -6.06235e-06 3.03117e-06 3.73224e-20 1.75158e-05 6.06235e-06 3.03117e-06 -9.31736e-21 -1.10114e-20 -0.000208325 -0.000254619 -0.000925887 -0.000925887 3.47209e-05 4.96012e-06 3.47209e-05 4.96012e-06 4.24364e-05 6.06235e-06 4.24364e-05 6.06235e-06 0.000154315 3.38813e-21 -2.42494e-05 -1.98405e-05 1.0842e-19 -1.25361e-19 0.000154315 -0.000154315 -4.96012e-06 -2.48006e-06 4.96012e-06 2.48006e-06 -6.06235e-06 -3.03117e-06 6.06235e-06 3.03117e-06 3.38813e-21 1.65337e-05 -1.01644e-20 8.04681e-21 0.000173611 0.000173611 0.000173611 -2.48016e-05 -1.27963e-21 -2.48016e-05 -1.11173e-20 -2.48016e-05 -1.01644e-20 1.24008e-05 0.000153219 0.000153219 0.000153219 -2.18884e-05 -1.01322e-21 -2.18884e-05 -9.95264e-21 -2.18884e-05 -8.89385e-21 1.09442e-05 0.00015059 0.00015059 0.00015059 -2.15129e-05 -8.80202e-22 -2.15129e-05 -9.84676e-21 -2.15129e-05 -8.89385e-21 1.07564e-05 0.000158251 0.000158251 0.000158251 -2.26073e-05 -1.21399e-21 -2.26073e-05 -1.01644e-20 -2.26073e-05 -9.42324e-21 1.13037e-05 0.000173611 0.000173611 0.000173611 -2.48016e-05 -1.13291e-20 -2.48016e-05 -1.50092e-21 -2.48016e-05 1.03762e-20 1.24008e-05 0.000153468 0.000153468 0.000153468 -2.1924e-05 -9.46847e-22 -2.1924e-05 -9.95264e-21 -2.1924e-05 -8.99973e-21 1.0962e-05 0.00014632 0.00014632 0.00014632 -2.09029e-05 -8.06128e-22 -2.09029e-05 -9.31736e-21 -2.09029e-05 -8.47033e-21 1.04514e-05 0.000146983 0.000146983 0.000146983 -2.09976e-05 -1.01694e-21 -2.09976e-05 -9.21148e-21 -2.09976e-05 -8.78797e-21 1.04988e-05 0.000173611 0.000173611 0.000173611 -2.48016e-05 -1.13291e-20 -2.48016e-05 -1.50092e-21 -2.48016e-05 1.03762e-20 1.24008e-05 0.000152492 0.000152492 0.000152492 -2.17846e-05 -1.20088e-21 -2.17846e-05 -9.74088e-21 -2.17846e-05 -8.99973e-21 1.08923e-05 0.00015525 0.00015525 0.00015525 -2.21785e-05 -1.22986e-21 -2.21785e-05 -9.95264e-21 -2.21785e-05 -9.1056e-21 1.10893e-05 0.000156822 0.000156822 0.000156822 -2.24032e-05 -1.12026e-21 -2.24032e-05 -9.84676e-21 -2.24032e-05 -9.31736e-21 1.12016e-05 0.000173611 0.000173611 0.000173611 -2.48016e-05 -1.13291e-20 -2.48016e-05 -1.50092e-21 -2.48016e-05 1.03762e-20 1.24008e-05 0.00015119 0.00015119 0.00015119 -2.15985e-05 -1.02997e-21 -2.15985e-05 -9.635e-21 -2.15985e-05 -8.78797e-21 1.07993e-05 0.000143687 0.000143687 0.000143687 -2.05267e-05 -1.06523e-21 -2.05267e-05 -9.1056e-21 -2.05267e-05 -8.68209e-21 1.02634e-05 0.000153601 0.000153601 0.000153601 -2.19431e-05 -9.32262e-22 -2.19431e-05 -9.95264e-21 -2.19431e-05 -9.1056e-21 1.09715e-05 0.000218962 0.000218962 0.000218962 -3.12803e-05 -1.46113e-20 -3.12803e-05 -1.60029e-21 -3.12803e-05 1.3129e-20 1.56402e-05 0.000222005 0.000222005 0.000222005 -3.17151e-05 -1.59924e-21 -3.17151e-05 -1.41878e-20 -3.17151e-05 -1.33408e-20 1.58575e-05 0.00021684 0.00021684 0.00021684 -3.09771e-05 -1.24845e-21 -3.09771e-05 -1.41878e-20 -3.09771e-05 -1.27055e-20 1.54886e-05 0.000216999 0.000216999 0.000216999 -3.09999e-05 -1.65219e-21 -3.09999e-05 -1.3976e-20 -3.09999e-05 -1.24937e-20 1.54999e-05 0.000157214 0.000157214 0.000157214 -2.24591e-05 -1.05159e-21 -2.24591e-05 -9.95264e-21 -2.24591e-05 -9.21148e-21 1.12295e-05 0.000152344 0.000152344 0.000152344 -2.17635e-05 -1.0179e-21 -2.17635e-05 -9.95264e-21 -2.17635e-05 -8.68209e-21 1.08817e-05 0.000148878 0.000148878 0.000148878 -2.12683e-05 -9.74759e-22 -2.12683e-05 -9.52912e-21 -2.12683e-05 -8.99973e-21 1.06342e-05 0.000158064 0.000158064 0.000158064 -2.25806e-05 -1.10787e-21 -2.25806e-05 -1.0482e-20 -2.25806e-05 -9.42324e-21 1.12903e-05 0.000141666 0.000141666 0.000141666 -2.02379e-05 -9.29052e-22 -2.02379e-05 -8.99973e-21 -2.02379e-05 -8.04681e-21 1.0119e-05 0.000152414 0.000152414 0.000152414 -2.17735e-05 -9.57355e-22 -2.17735e-05 -9.95264e-21 -2.17735e-05 -8.89385e-21 1.08867e-05 0.000142893 0.000142893 0.000142893 -2.04133e-05 -9.35689e-22 -2.04133e-05 -9.31736e-21 -2.04133e-05 -8.47033e-21 1.02067e-05 0.000159327 0.000159327 0.000159327 -2.2761e-05 -9.75323e-22 -2.2761e-05 -1.02703e-20 -2.2761e-05 -9.31736e-21 1.13805e-05 0.000154916 0.000154916 0.000154916 -2.21309e-05 -9.86042e-22 -2.21309e-05 -1.01644e-20 -2.21309e-05 -9.42324e-21 1.10654e-05 0.000158935 0.000158935 0.000158935 -2.2705e-05 -1.05341e-21 -2.2705e-05 -1.01644e-20 -2.2705e-05 -9.21148e-21 1.13525e-05 0.000146339 0.000146339 0.000146339 -2.09056e-05 -9.02727e-22 -2.09056e-05 -9.31736e-21 -2.09056e-05 -8.47033e-21 1.04528e-05 0.000163619 0.000163619 0.000163619 -2.33741e-05 -1.0482e-20 -2.33741e-05 -1.31778e-21 -2.33741e-05 9.74088e-21 1.16871e-05 0.000152048 0.000152048 0.000152048 -2.17211e-05 -9.56313e-22 -2.17211e-05 -9.74088e-21 -2.17211e-05 -8.68209e-21 1.08606e-05 0.000145929 0.000145929 0.000145929 -2.0847e-05 -1.04191e-21 -2.0847e-05 -9.42324e-21 -2.0847e-05 -8.25857e-21 1.04235e-05 0.000145823 0.000145823 0.000145823 -2.08318e-05 -1.0832e-21 -2.08318e-05 -9.42324e-21 -2.08318e-05 -8.89385e-21 1.04159e-05 0.000157074 0.000157074 0.000157074 -2.24391e-05 -1.14258e-21 -2.24391e-05 -1.03762e-20 -2.24391e-05 -9.52912e-21 1.12195e-05 0.000153119 0.000153119 0.000153119 -2.18741e-05 -9.95264e-21 -2.18741e-05 -1.2278e-21 -2.18741e-05 8.89385e-21 1.0937e-05 0.000136201 0.000136201 0.000136201 -1.94574e-05 -8.78797e-21 -1.94574e-05 -9.5929e-22 -1.94574e-05 8.04681e-21 9.72868e-06 0.000145653 0.000145653 0.000145653 -2.08076e-05 -9.42324e-21 -2.08076e-05 -1.19931e-21 -2.08076e-05 8.78797e-21 1.04038e-05 0.000126819 0.000126819 0.000126819 -1.81171e-05 -8.47033e-21 -1.81171e-05 -9.42087e-22 -1.81171e-05 7.72918e-21 9.05853e-06 0.000157172 0.000157172 0.000157172 -2.24531e-05 -1.01644e-20 -2.24531e-05 -1.14921e-21 -2.24531e-05 9.42324e-21 1.12266e-05 0.000133927 0.000133927 0.000133927 -1.91324e-05 -8.89385e-21 -1.91324e-05 -1.13497e-21 -1.91324e-05 8.04681e-21 9.5662e-06 0.000146549 0.000146549 0.000146549 -2.09356e-05 -9.52912e-21 -2.09356e-05 -1.22357e-21 -2.09356e-05 8.99973e-21 1.04678e-05 0.000132673 0.000132673 0.000132673 -1.89533e-05 -8.57621e-21 -1.89533e-05 -8.12576e-22 -1.89533e-05 7.94093e-21 9.47665e-06 0.000141665 0.000141665 0.000141665 -2.02378e-05 -9.05794e-22 -2.02378e-05 -8.99973e-21 -2.02378e-05 -8.57621e-21 1.01189e-05 0.000163596 0.000163596 0.000163596 -2.33708e-05 -9.25353e-22 -2.33708e-05 -1.05879e-20 -2.33708e-05 -9.52912e-21 1.16854e-05 0.000153952 0.000153952 0.000153952 -2.19931e-05 -8.98413e-22 -2.19931e-05 -9.95264e-21 -2.19931e-05 -9.1056e-21 1.09965e-05 0.000147119 0.000147119 0.000147119 -2.1017e-05 -8.31921e-22 -2.1017e-05 -9.31736e-21 -2.1017e-05 -8.47033e-21 1.05085e-05 0.000159606 0.000159606 0.000159606 -2.28009e-05 -1.05879e-20 -2.28009e-05 -1.32113e-21 -2.28009e-05 9.31736e-21 1.14005e-05 0.000166274 0.000166274 0.000166274 -2.37534e-05 -1.07997e-20 -2.37534e-05 -1.29252e-21 -2.37534e-05 9.74088e-21 1.18767e-05 0.000165986 0.000165986 0.000165986 -2.37122e-05 -1.06938e-20 -2.37122e-05 -1.32496e-21 -2.37122e-05 9.95264e-21 1.18561e-05 0.000153001 0.000153001 0.000153001 -2.18573e-05 -9.14871e-22 -2.18573e-05 -9.84676e-21 -2.18573e-05 -9.31736e-21 1.09287e-05 0.000138753 0.000138753 0.000138753 -1.98219e-05 -8.9921e-22 -1.98219e-05 -8.89385e-21 -1.98219e-05 -8.25857e-21 9.91093e-06 0.000158705 0.000158705 0.000158705 -2.26721e-05 -9.92299e-22 -2.26721e-05 -1.01644e-20 -2.26721e-05 -9.635e-21 1.1336e-05 0.000154585 0.000154585 0.000154585 -2.20836e-05 -8.65891e-22 -2.20836e-05 -1.01644e-20 -2.20836e-05 -9.1056e-21 1.10418e-05 0.000137315 0.000137315 0.000137315 -1.96164e-05 -8.42681e-22 -1.96164e-05 -8.68209e-21 -1.96164e-05 -8.04681e-21 9.80819e-06 0.000174938 0.000174938 0.000174938 -2.49912e-05 -1.2154e-21 -2.49912e-05 -1.11173e-20 -2.49912e-05 -1.03762e-20 1.24956e-05 0.000185409 0.000185409 0.000185409 -2.64871e-05 -1.3333e-21 -2.64871e-05 -1.11173e-20 -2.64871e-05 -1.07997e-20 1.32435e-05 0.000168724 0.000168724 0.000168724 -2.41035e-05 -1.07568e-21 -2.41035e-05 -1.09055e-20 -2.41035e-05 -9.74088e-21 1.20517e-05 0.000146204 0.000146204 0.000146204 -2.08864e-05 -9.25172e-22 -2.08864e-05 -9.31736e-21 -2.08864e-05 -8.47033e-21 1.04432e-05 0.000159322 0.000159322 0.000159322 -2.27602e-05 -1.02703e-20 -2.27602e-05 -1.02356e-21 -2.27602e-05 9.52912e-21 1.13801e-05 0.000157617 0.000157617 0.000157617 -2.25166e-05 -9.74957e-22 -2.25166e-05 -1.00585e-20 -2.25166e-05 -9.31736e-21 1.12583e-05 0.000153615 0.000153615 0.000153615 -2.19451e-05 -1.00585e-20 -2.19451e-05 -9.96003e-22 -2.19451e-05 8.89385e-21 1.09725e-05 0.000181033 0.000181033 0.000181033 -2.58619e-05 -1.33946e-21 -2.58619e-05 -1.15408e-20 -2.58619e-05 -1.05879e-20 1.29309e-05 0.000145689 0.000145689 0.000145689 -2.08127e-05 -9.52912e-21 -2.08127e-05 -1.16518e-21 -2.08127e-05 8.47033e-21 1.04063e-05 0.000143373 0.000143373 0.000143373 -2.04819e-05 -1.05026e-21 -2.04819e-05 -9.1056e-21 -2.04819e-05 -8.25857e-21 1.02409e-05 0.00017154 0.00017154 0.00017154 -2.45057e-05 -1.11427e-21 -2.45057e-05 -1.11173e-20 -2.45057e-05 -1.00585e-20 1.22528e-05 0.000154429 0.000154429 0.000154429 -2.20614e-05 -9.46629e-22 -2.20614e-05 -9.95264e-21 -2.20614e-05 -9.31736e-21 1.10307e-05 0.000153158 0.000153158 0.000153158 -2.18798e-05 -9.95264e-21 -2.18798e-05 -1.12883e-21 -2.18798e-05 9.21148e-21 1.09399e-05 0.000150079 0.000150079 0.000150079 -2.14399e-05 -8.65147e-22 -2.14399e-05 -9.635e-21 -2.14399e-05 -8.47033e-21 1.07199e-05 0.0001879 0.0001879 0.0001879 -2.68429e-05 -1.22942e-21 -2.68429e-05 -1.21761e-20 -2.68429e-05 -1.07997e-20 1.34214e-05 0.000175578 0.000175578 0.000175578 -2.50825e-05 -1.10515e-21 -2.50825e-05 -1.13291e-20 -2.50825e-05 -1.01644e-20 1.25413e-05 0.000158103 0.000158103 0.000158103 -2.25861e-05 -1.03762e-20 -2.25861e-05 -1.26203e-21 -2.25861e-05 9.635e-21 1.1293e-05 0.000184267 0.000184267 0.000184267 -2.63238e-05 -1.31299e-21 -2.63238e-05 -1.18585e-20 -2.63238e-05 -1.10114e-20 1.31619e-05 0.000172169 0.000172169 0.000172169 -2.45956e-05 -1.02295e-21 -2.45956e-05 -1.10114e-20 -2.45956e-05 -9.95264e-21 1.22978e-05 0.000156846 0.000156846 0.000156846 -2.24066e-05 -1.00585e-20 -2.24066e-05 -1.04999e-21 -2.24066e-05 8.99973e-21 1.12033e-05 0.000145018 0.000145018 0.000145018 -2.07169e-05 -9.50785e-22 -2.07169e-05 -9.52912e-21 -2.07169e-05 -8.57621e-21 1.03584e-05 0.000164331 0.000164331 0.000164331 -2.34759e-05 -1.10114e-20 -2.34759e-05 -1.05858e-21 -2.34759e-05 9.52912e-21 1.1738e-05 0.000155923 0.000155923 0.000155923 -2.22747e-05 -1.03762e-20 -2.22747e-05 -1.16774e-21 -2.22747e-05 9.1056e-21 1.11373e-05 0.000159814 0.000159814 0.000159814 -2.28306e-05 -1.03762e-20 -2.28306e-05 -1.32113e-21 -2.28306e-05 9.1056e-21 1.14153e-05 0.000139224 0.000139224 0.000139224 -1.98891e-05 -9.1056e-21 -1.98891e-05 -9.56159e-22 -1.98891e-05 8.25857e-21 9.94455e-06 0.000136115 0.000136115 0.000136115 -1.94449e-05 -8.89385e-21 -1.94449e-05 -1.10829e-21 -1.94449e-05 8.04681e-21 9.72246e-06 0.00016937 0.00016937 0.00016937 -2.41957e-05 -1.15649e-21 -2.41957e-05 -1.07997e-20 -2.41957e-05 -9.84676e-21 1.20979e-05 0.000150689 0.000150689 0.000150689 -2.15269e-05 -9.52912e-21 -2.15269e-05 -1.15619e-21 -2.15269e-05 8.78797e-21 1.07635e-05 0.00019064 0.00019064 0.00019064 -2.72343e-05 -1.09855e-21 -2.72343e-05 -1.24937e-20 -2.72343e-05 -1.10114e-20 1.36171e-05 0.000182668 0.000182668 0.000182668 -2.60954e-05 -1.18585e-20 -2.60954e-05 -1.68169e-21 -2.60954e-05 1.07997e-20 1.30477e-05 0.000156239 0.000156239 0.000156239 -2.23199e-05 -1.00585e-20 -2.23199e-05 -1.0968e-21 -2.23199e-05 8.89385e-21 1.116e-05 0.000152513 0.000152513 0.000152513 -2.17876e-05 -9.84676e-21 -2.17876e-05 -1.23601e-21 -2.17876e-05 9.1056e-21 1.08938e-05 0.000183468 0.000183468 0.000183468 -2.62097e-05 -1.19643e-20 -2.62097e-05 -1.47477e-21 -2.62097e-05 1.07997e-20 1.31048e-05 0.000150127 0.000150127 0.000150127 -2.14467e-05 -1.00337e-21 -2.14467e-05 -9.635e-21 -2.14467e-05 -8.78797e-21 1.07233e-05 0.000160575 0.000160575 0.000160575 -2.29393e-05 -1.16082e-21 -2.29393e-05 -1.0482e-20 -2.29393e-05 -9.31736e-21 1.14697e-05 0.000148005 0.000148005 0.000148005 -2.11436e-05 -9.635e-21 -2.11436e-05 -9.85995e-22 -2.11436e-05 8.99973e-21 1.05718e-05 0.000178163 0.000178163 0.000178163 -2.54519e-05 -1.30388e-21 -2.54519e-05 -1.14349e-20 -2.54519e-05 -1.03762e-20 1.27259e-05 0.000143445 0.000143445 0.000143445 -2.04922e-05 -9.42324e-21 -2.04922e-05 -1.04859e-21 -2.04922e-05 8.78797e-21 1.02461e-05 0.000154094 0.000154094 0.000154094 -2.20134e-05 -1.01474e-21 -2.20134e-05 -1.01644e-20 -2.20134e-05 -9.1056e-21 1.10067e-05 0.000175565 0.000175565 0.000175565 -2.50808e-05 -1.07536e-21 -2.50808e-05 -1.14349e-20 -2.50808e-05 -1.05879e-20 1.25404e-05 0.000146709 0.000146709 0.000146709 -2.09585e-05 -1.01002e-21 -2.09585e-05 -9.42324e-21 -2.09585e-05 -8.68209e-21 1.04792e-05 0.000155324 0.000155324 0.000155324 -2.21891e-05 -8.99897e-22 -2.21891e-05 -1.00585e-20 -2.21891e-05 -8.89385e-21 1.10946e-05 0.000180804 0.000180804 0.000180804 -2.58292e-05 -1.19643e-20 -2.58292e-05 -1.59915e-21 -2.58292e-05 1.07997e-20 1.29146e-05 0.000180757 0.000180757 0.000180757 -2.58224e-05 -1.27809e-21 -2.58224e-05 -1.15408e-20 -2.58224e-05 -1.05879e-20 1.29112e-05 0.000117884 0.000117884 0.000117884 -1.68406e-05 -7.72918e-21 -1.68406e-05 -8.72298e-22 -1.68406e-05 6.88214e-21 8.42031e-06 0.000117663 0.000117663 0.000117663 -1.6809e-05 -6.42452e-22 -1.6809e-05 -7.51742e-21 -1.6809e-05 -6.98802e-21 8.40451e-06 0.0001143 0.0001143 0.0001143 -1.63286e-05 -7.48248e-22 -1.63286e-05 -7.30566e-21 -1.63286e-05 -6.77626e-21 8.1643e-06 0.000162153 0.000162153 0.000162153 -2.31646e-05 -1.03762e-20 -2.31646e-05 -1.32118e-21 -2.31646e-05 9.95264e-21 1.15823e-05 0.000115157 0.000115157 0.000115157 -1.6451e-05 -7.30566e-21 -1.6451e-05 -9.59613e-22 -1.6451e-05 6.67038e-21 8.22551e-06 0.000166875 0.000166875 0.000166875 -2.38393e-05 -1.03041e-21 -2.38393e-05 -1.0482e-20 -2.38393e-05 -9.74088e-21 1.19197e-05 0.000128172 0.000128172 0.000128172 -1.83103e-05 -8.25857e-21 -1.83103e-05 -9.77634e-22 -1.83103e-05 7.72918e-21 9.15517e-06 0.000152314 0.000152314 0.000152314 -2.17592e-05 -1.08483e-21 -2.17592e-05 -9.74088e-21 -2.17592e-05 -8.68209e-21 1.08796e-05 0.000123653 0.000123653 0.000123653 -1.76648e-05 -7.94093e-21 -1.76648e-05 -9.80977e-22 -1.76648e-05 7.19978e-21 8.83239e-06 0.000151977 0.000151977 0.000151977 -2.1711e-05 -8.39623e-22 -2.1711e-05 -9.84676e-21 -2.1711e-05 -8.89385e-21 1.08555e-05 0.000167065 0.000167065 0.000167065 -2.38664e-05 -1.11173e-20 -2.38664e-05 -1.25054e-21 -2.38664e-05 1.02703e-20 1.19332e-05 0.000168922 0.000168922 0.000168922 -2.41318e-05 -1.09055e-20 -2.41318e-05 -1.35543e-21 -2.41318e-05 9.74088e-21 1.20659e-05 0.000119178 0.000119178 0.000119178 -1.70254e-05 -8.83364e-22 -1.70254e-05 -7.51742e-21 -1.70254e-05 -6.98802e-21 8.51269e-06 0.000143906 0.000143906 0.000143906 -2.0558e-05 -9.31736e-21 -2.0558e-05 -1.11554e-21 -2.0558e-05 8.57621e-21 1.0279e-05 0.000146838 0.000146838 0.000146838 -2.09769e-05 -9.74088e-21 -2.09769e-05 -1.18203e-21 -2.09769e-05 8.89385e-21 1.04884e-05 0.000113315 0.000113315 0.000113315 -1.61879e-05 -7.50892e-22 -1.61879e-05 -7.19978e-21 -1.61879e-05 -6.56451e-21 8.09394e-06 0.000172857 0.000172857 0.000172857 -2.46939e-05 -1.12232e-20 -2.46939e-05 -1.17421e-21 -2.46939e-05 1.06938e-20 1.23469e-05 0.000145027 0.000145027 0.000145027 -2.07181e-05 -9.52912e-21 -2.07181e-05 -1.07255e-21 -2.07181e-05 8.47033e-21 1.0359e-05 0.000174754 0.000174754 0.000174754 -2.49649e-05 -1.13291e-20 -2.49649e-05 -1.39356e-21 -2.49649e-05 1.02703e-20 1.24824e-05 0.000154839 0.000154839 0.000154839 -2.21199e-05 -9.84676e-21 -2.21199e-05 -1.17434e-21 -2.21199e-05 9.31736e-21 1.10599e-05 0.000145044 0.000145044 0.000145044 -2.07206e-05 -9.52912e-21 -2.07206e-05 -1.09938e-21 -2.07206e-05 8.25857e-21 1.03603e-05 0.000144717 0.000144717 0.000144717 -2.06739e-05 -9.27555e-22 -2.06739e-05 -9.52912e-21 -2.06739e-05 -8.57621e-21 1.03369e-05 0.000146036 0.000146036 0.000146036 -2.08622e-05 -9.42324e-21 -2.08622e-05 -1.20145e-21 -2.08622e-05 8.78797e-21 1.04311e-05 0.000127291 0.000127291 0.000127291 -1.81844e-05 -9.55124e-22 -1.81844e-05 -8.04681e-21 -1.81844e-05 -7.30566e-21 9.0922e-06 0.000146885 0.000146885 0.000146885 -2.09836e-05 -9.09796e-22 -2.09836e-05 -9.31736e-21 -2.09836e-05 -8.68209e-21 1.04918e-05 0.000119572 0.000119572 0.000119572 -1.70817e-05 -7.72918e-21 -1.70817e-05 -1.02421e-21 -1.70817e-05 6.98802e-21 8.54083e-06 0.00011776 0.00011776 0.00011776 -1.68229e-05 -7.72918e-21 -1.68229e-05 -8.6112e-22 -1.68229e-05 6.98802e-21 8.41143e-06 0.000114288 0.000114288 0.000114288 -1.63269e-05 -7.10701e-22 -1.63269e-05 -7.30566e-21 -1.63269e-05 -6.35275e-21 8.16344e-06 0.000141438 0.000141438 0.000141438 -2.02054e-05 -9.7042e-22 -2.02054e-05 -9.31736e-21 -2.02054e-05 -8.36445e-21 1.01027e-05 0.000163837 0.000163837 0.000163837 -2.34053e-05 -1.0622e-21 -2.34053e-05 -1.01644e-20 -2.34053e-05 -9.31736e-21 1.17027e-05 0.000163008 0.000163008 0.000163008 -2.32869e-05 -1.09055e-20 -2.32869e-05 -1.14236e-21 -2.32869e-05 9.74088e-21 1.16434e-05 0.000144071 0.000144071 0.000144071 -2.05816e-05 -9.42324e-21 -2.05816e-05 -1.27997e-21 -2.05816e-05 8.47033e-21 1.02908e-05 0.000141576 0.000141576 0.000141576 -2.02252e-05 -9.73181e-22 -2.02252e-05 -9.1056e-21 -2.02252e-05 -8.25857e-21 1.01126e-05 0.000150894 0.000150894 0.000150894 -2.15562e-05 -9.74088e-21 -2.15562e-05 -1.05437e-21 -2.15562e-05 9.1056e-21 1.07781e-05 0.000163851 0.000163851 0.000163851 -2.34072e-05 -1.05879e-20 -2.34072e-05 -1.1763e-21 -2.34072e-05 1.00585e-20 1.17036e-05 0.000146983 0.000146983 0.000146983 -2.09975e-05 -1.06453e-21 -2.09975e-05 -9.42324e-21 -2.09975e-05 -8.78797e-21 1.04988e-05 0.000113292 0.000113292 0.000113292 -1.61846e-05 -7.41154e-21 -1.61846e-05 -7.95905e-22 -1.61846e-05 6.98802e-21 8.0923e-06 0.000140563 0.000140563 0.000140563 -2.00804e-05 -7.87299e-22 -2.00804e-05 -8.89385e-21 -2.00804e-05 -8.04681e-21 1.00402e-05 0.00014978 0.00014978 0.00014978 -2.13971e-05 -9.74088e-21 -2.13971e-05 -1.02269e-21 -2.13971e-05 8.89385e-21 1.06986e-05 0.000157217 0.000157217 0.000157217 -2.24595e-05 -1.07301e-21 -2.24595e-05 -1.02703e-20 -2.24595e-05 -9.31736e-21 1.12298e-05 0.00013705 0.00013705 0.00013705 -1.95786e-05 -8.89385e-21 -1.95786e-05 -1.04085e-21 -1.95786e-05 8.25857e-21 9.7893e-06 0.000140737 0.000140737 0.000140737 -2.01052e-05 -8.72046e-22 -2.01052e-05 -9.21148e-21 -2.01052e-05 -8.25857e-21 1.00526e-05 0.000169746 0.000169746 0.000169746 -2.42494e-05 -1.06261e-21 -2.42494e-05 -1.10114e-20 -2.42494e-05 -1.01644e-20 1.21247e-05 0.000138883 0.000138883 0.000138883 -1.98405e-05 -9.1056e-21 -1.98405e-05 -1.17865e-21 -1.98405e-05 8.04681e-21 9.92025e-06
Using the vector we can build the linear combination of the matrices $A$ and $M$:
We set the r.h.s. $f = exp(-6 ((x+\frac12)^2+y^2)) - exp(-6 ((x-\frac12)^2+y^2))$
Draw(gaussp,mesh,"f")
f += SymbolicLFI(gaussp*v)
and the initial data: $u_0 = (1-y^2)x$
gfu.Set((1-y*y)*x)
Draw(gfu,mesh,"u")
res = gfu.vec.CreateVector()
t_intermediate += dt
print("")
time+=t_intermediate
9.999999999999897
Next, we want to consider time-dependent r.h.s. data $f=f(t)$:
To this end, we introduce a parameter t representing the time.
A Parameter is a constant CoefficientFunction the value of which can be changed with the Set-function.
t = Parameter(0.0)
omega=1
tt = 0
Draw(gausspt,mesh,"ft")
time = 0.0
while time < 10 - 0.5 * dt:
t.Set(time)
tt = time
#gausspt = exp(-6*((x+sin(omega*tt))*(x+sin(omega*tt))+y*y))-exp(-6*((x-sin(omega*tt))*(x-sin(omega*tt))+y*y))
time += 1e-4
ft = LinearForm(fes)
ft += SymbolicLFI(gausspt*v)
time = 0.0
t.Set(0.0)
gfu.Set((1-y*y)*x)
Draw(gfu,mesh,"u")
tstep = 20 # time that we want to step over within one block-run
t.Set(time+t_intermediate+dt)
ft.Assemble()
print("")
20.00000000000146
Now, we want to consider changing boundary conditions $u|_{\partial \Omega} = u_D(t)$ and set $f=0$.
We use the simple implicit Euler time stepping method again for this problem. Now, we directly use the non-incremental form: $$ (M + \Delta t A) u^{n+1} = M u^n $$ We homogenize w.r.t. to the boundary conditions, i.e. we split $u^{n+1} = u^{n+1}_0 + u^{n+1}_D$ where $u^{n+1}_D$ is some function in the FESpace with the correct boundary condition and $u^{n+1}_0$ is the sought for function with zero boundary values:
$$ \underbrace{(M + \Delta t A)}_{M^\ast} u^{n+1}_0 = M u^n - \underbrace{(M + \Delta t A)}_{M^\ast} u^{n+1}_D $$uD = CoefficientFunction( [(1-x*x)*IfPos(sin(0.3*pi*t),sin(0.3*pi*t),0),0,0,0])
time = 0.0
t.Set(0.0)
gfu.Set(uD,BND)
Draw(gfu,mesh,"u")
# visualization stuff
visoptions.mminval = 0.0
visoptions.mmaxval = 0.2
visoptions.deformation = 0
visoptions.autoscale = 0
#non-incremental form
res.data = m.mat * gfu.vec
gfu.Set(uD,BND)
res.data -= mstar * gfu.vec
print("")
9.999999999999897
We consider more sophisticated time integration methods, SDIRK methods. To simplify presentation we set $f=0$.
SDIRK methods for the semi-discrete problem $\frac{d}{dt} u = M^{-1} F(u) = -M^{-1} \cdot A u$ are of the form: $$ u^{n+1} = u^n + \Delta t M^{-1} \sum_{i=0}^{s-1} b_i k_i $$ with $$ k_i = - A u_i \quad \text{ where $u_i$ is the solution to } \quad (M + a^\ast \Delta t A) u_i = M u^n - \Delta t \sum_{i=0}^{i-1} a_{ij} k_j, \quad i=0,..,s-1. $$ The coefficients a,b and c are stored in the butcher tableau: $$ \begin{array}{c|cccc} c_0 & a_{00} & 0 & \ddots& \\ c_1 & a_{10} & a_{11} & 0 & \ddots \\ \vdots & \vdots & \vdots & \ddots & 0\\ c_{s-1} & a_{s-1,0} & a_{s-1,1} & \dots& a_{s-1,s-1} \\ \hline & b_{0} & b_1 & \dots& b_{s-1} \\ \end{array} $$ For an SDIRK method we have $a^\ast = a_{ii},~i=0,..,s-1$.
We can use for example the 2 stage SDIRK (order 3) method $$ \begin{array}{c|cc} p & p & 0 \\ 1-p & 1-2p & p \\ \hline & 1/2 & 1/2 \\ \end{array} $$ with $p = \frac{3 - \sqrt{3}}{6}$.
stages = 1
a = [[1]]
b = [1]
c = [1]
astar = 1
class sdirk2: #order 3
p = (3 - sqrt(3))/6
stages = 2
a = [[p, 0],
[1 - 2*p, p]]
b = [1/2, 1/2]
c = [p, 1 - p]
astar = p
class sdirk5: #order 4
stages = 5
a = [[1/4, 0, 0, 0, 0],
[1/2, 1/4, 0, 0, 0],
[17/50,-1/25, 1/4, 0, 0],
c = [1/4, 3/4, 11/20, 1/2, 1]
astar = 1/4
butchertab = sdirk2()
rhsi = gfu.vec.CreateVector()
Mu0 = gfu.vec.CreateVector()
ui = gfu.vec.CreateVector()
We have to update the $M^\ast$ matrix and reset initial data
time = 0.0
t.Set(0.0)
gfu.Set(uD,BND)
Draw(gfu,mesh,"u")
Mu0.data = m.mat * gfu.vec
rhsi.data = Mu0
for j in range(0,i):
gfu.Set(uD,BND)
ui.data = gfu.vec
rhsi.data -= mstar * ui
ui.data += invmstar * rhsi
# compute k[i] from ui
k[i].data = - a.mat * ui
t.Set(time+t_intermediate)
# Adding up the ks:
gfu.Set(uD,BND)
Mu0.data -= m.mat * gfu.vec
gfu.vec.data += invmass * Mu0
print("")
9.999999999999897
names=["sol"],
filename="vtk_example1",
subdivision=3)
vtk.Do()
vtk.Do()
And time dependent data:
vtk.Do()
gfu.Set((1-y*y)*x)
time = 0
i = 0
i += 1
if (i%10 == 0):
vtk.Do()
print("")
1.0000000000000007
