In NGSolve, CoefficientFunctions are representations of functions defined on the computational domain $\Omega$. Examples are expressions of coordinate variables $x, y, z$ and functions that are constant on subdomains. Much of the magic behind the seamless integration of NGSolve with python lies in CoefficientFunctions. This tutorial introduces you to them.
%gui tk
myfunc = x*(1-x)
mip = mesh(0.2, 0.2)
myfunc(mip)
Note that myfunc(0.2,0.3) does not work: You need to give points in the form of MappedIntegrationPoints like mip above. The mesh knows how to produce them.
for p,v in zip(pts, vals):
%(p[0], p[1], v))
plt.plot(px,vals)
plt.xlabel('x')
CoefficientFunction¶We may Set a GridFunction using a CoefficientFunction:
fes = H1(mesh, order=1)
u = GridFunction(fes)
u.Set(myfunc)
Draw(u) # Cf.: Draw(myfunc, mesh, "firstfun")
The Set method interpolates myfunc to obtain the grid function u.
Set does an Oswald-type interpolation as follows:
myfunc in $L^2$ on each mesh element;CoefficientFunction¶We can numerically integrate the function using the mesh:
Integrate(myfunc, mesh)
There is no facility to directly differentiate a CoefficientFunction. But you can interpolate it into a GridFunction and then differentiate the GridFunction.
u.Set(myfunc)
gradu = grad(u)
gradu[0]
Draw(gradu[0], mesh, 'dx_firstfun')
Obviously the accuracy of this process can be improved for smooth functions by using higher order finite element spaces.
CoefficientFunctions¶Above, gradu provided an example of a vector-valued coefficient function. To visualize it, click on Visual menu in GUI and check Draw Surface Vectors.
You can also define vector coefficient expressions directly:
Draw(vecfun, mesh, "vecfun")
print(myfunc)
