Incompressible Navier-Stokes equations
Find $(u,p):[0,T] \to (H_{0,D}^1)^d \times L^2$, s.t.
\begin{align} \int_{\Omega} \partial_t u \cdot v + \int_{\Omega} \nu \nabla u \nabla v + u \cdot \nabla u v - \int_{\Omega} \operatorname{div}(v) p &= \int f v && \forall v \in (H_{0,D}^1)^d, \\ - \int_{\Omega} \operatorname{div}(u) q &= 0 && \forall q \in L^2, \\ \quad u(t=0) & = u_0 \end{align}
In [1]:
%gui tk
import tkinter
We again consider the benchmark setup of from http://www.featflow.de/en/benchmarks/cfdbenchmarking/flow/dfg_benchmark2_re100.html . The geometry is a 2D channel with a circular obstacle which is positioned (only slightly) off the center of the channel. The geometry: title
The left part (red) is the inflow boundary,
The right part (green) is the outflow boundary.
The viscosity is set to $\nu = 10^{-3}$.
In [2]:
geo.AddRectangle( (0, 0), (2, 0.41),
                 bcs = ("wall", "outlet", "wall", "inlet"))
geo.AddCircle ( (0.2, 0.2), r=0.05,
               leftdomain=0, rightdomain=1, bc="cyl")
mesh.Curve(3)
# viscosity
nu = 0.001
bcs =  ('wall', 'outlet', 'wall', 'inlet')
We use a Taylor-Hood discretization of degree $k$. The finite element space for the velocity components $u_x$ and $u_y$ and the pressure are:
\begin{align} u_x,u_y \in V &= \{ v \in H^1(\Omega) | v|_T \in \mathcal{P}^k(T) \} \\ p \in Q &= \{ q \in H^1(\Omega) | q|_T \in \mathcal{P}^{k-1}(T) \} \end{align}
In [3]:
k = 3
V = H1(mesh,order=k, dirichlet="wall|cyl|inlet")
Q = H1(mesh,order=k-1)
X = FESpace([V,V,Q])
As initial data we use the solution to the Stokes problem:
Find $u=(u_x,u_y) \in V \times V$, $p \in Q$ so that
\begin{align} \int_{\Omega} \nu \nabla u \nabla v - \int_{\Omega} \operatorname{div}(v) p &= \int f v && \forall v \in V \times V, \\ - \int_{\Omega} \operatorname{div}(u) q &= 0 && \forall q \in Q, \end{align}
with boundary conditions:
  • the inflow boundary data ('inlet') with mean value $1$
  • "do-nothing" boundary conditions on the outflow ('outlet') and
  • homogeneous Dirichlet conditions on all other boundaries ('wall').
In [4]:
u = GridFunction(X)
velocity = CoefficientFunction (u.components[0:2])
Draw(velocity,mesh,"u")
Draw(u.components[2],mesh,"p")
# parabolic inflow at bc=1:
u.components[0].Set(uin, definedon=mesh.Boundaries("inlet"))
import matplotlib
%matplotlib inline
bvs = 6*s*(0.41-s)/(0.41)**2
plt.plot(s, bvs)
plt.xlabel('y')
plt.ylabel('$u_x(0,y)$')
plt.title('inflow profile')
plt.grid(True)
$$ a((u,p),(v,q)) := \int_{\Omega} \nu \nabla u \nabla v - \operatorname{div}(v) p - \operatorname{div}(u) q $$
In [5]:
ux,uy,p = X.TrialFunction()
vx,vy,q = X.TestFunction()
stokes = nu*grad(ux)*grad(vx)+nu*grad(uy)*grad(vy) \
         -div_u*q-div_v*p
a = BilinearForm(X)
a += SymbolicBFI(stokes)
f = LinearForm(X)
res.data = f.vec - a.mat*u.vec
u.vec.data += inv_stokes * res
Find $(u^{n+1},p^{n+1}) \in X = V \times V \times Q$, s.t. for all $(v,q) \in X = V \times V \times Q$ \begin{equation} \underbrace{m(u^{n+1},v) + \Delta t ~\cdot~a((u^{n+1},p^{n+1}),(v,q))}_{ \to M^\ast} ~=~ m(u^{n},v) - \Delta t c(u^{n}; u^{n},v) \end{equation}
with \begin{equation} m(u,v) = \int u \cdot v \end{equation} and \begin{equation} c(w,u,v) = \int w \cdot \nabla u \cdot v \end{equation}
We prefer the incremental form (as it homogenizes the boundary conditions): \begin{equation} m(\Delta u^{n+1},v) + \Delta t ~\cdot~a((\Delta u^{n+1},p^{n+1}),(v,q)) ~=~ \Delta t (-a((u^{n},p^n),(v,q)) -c(u^{n}; u^{n},v)) \end{equation}
In [6]:
dt = 0.001
# matrix for implicit Euler
mstar = BilinearForm(X)
mstar += SymbolicBFI(ux*vx+uy*vy + dt*stokes)
mstar.Assemble()
conv = LinearForm(X)
conv += SymbolicLFI(velocity*grad(u.components[0])*vx)
conv += SymbolicLFI(velocity*grad(u.components[1])*vy)
In [7]:
tend = 0
In [8]:
tend += 1
while t < tend-0.5*dt:
    print ("\rt=", t, end="")
    conv.Assemble()
    res.data = a.mat * u.vec + conv.vec
    u.vec.data -= dt * inv * res
    t = t + dt
t= 0.9990000000000008
Supplementary 1: Computing stresses
The force acting on the obstacle is $$ F_{\circ} = (F_D,F_L) = \int_{\Gamma_{cyl}} \sigma_n = \int_{\Gamma_{cyl}} (-\nu \frac{\partial u}{\partial n} + p I) \cdot n $$
The drag/lift coefficients are $$ c_D = \frac{2 }{\bar{u} L} F_D, \quad c_L = \frac{2 }{\bar{u} L} F_L. $$ where $\bar{u} = 1$ is the mean inflow velocity and $L = 0.41$ is the channel width.
In [9]:
drag_x_test = GridFunction(X)
drag_x_test.components[0].Set(CoefficientFunction(-20.0), definedon=mesh.Boundaries("cyl"))
drag_y_test = GridFunction(X)
drag_y_test.components[1].Set(CoefficientFunction(-20.0), definedon=mesh.Boundaries("cyl"))
In [10]:
time_vals = []
drag_x_vals = []
drag_y_vals = []
In [11]:
# restoring initial data
tend = 0
Remarks:
  • you can call the following block several times to continue a simulation and collect more data
  • note that you can reset the array without rerunning the simulation
  • below you can plot the gathered drag and lift values
In [12]:
tend += 1
    conv.Assemble()
    t = t + dt
    time_vals.append( t )
    #print(drag)
In [13]:
import matplotlib
%matplotlib inline
plt.xlabel('time')
plt.ylabel('drag')
plt.title('drag')
plt.grid(True)
plt.xlabel('time')
plt.ylabel('lift')
plt.title('lift')
plt.grid(True)
