Parabolic model problem
$$\text{find } u:[0,T] \to H_{0,D}^1 \quad \int_{\Omega} \partial_t u v + \int_{\Omega} \varepsilon \nabla u \nabla v + b \cdot \nabla u v = \int f v \quad \forall v \in H_{0,D}^1, \quad u(t=0) = u_0$$
with a suitable advective field $b$ (the wind).
In [1]:
%gui tk
import tkinter
We generate geometry $(-1,1)^2$, mesh (Dirichlet boundaries everywhere):
In [2]:
geo.AddRectangle( (-1, -1), (1, 1), bcs = ("bottom", "right", "top", "left"))
u = fes.TrialFunction()
v = fes.TestFunction()
time = 0.0
dt = 0.001
bcs =  ('bottom', 'right', 'top', 'left')
We define the field $b$ (the wind) as $b(x,y) = (2y(1-x^2),-2x(1-y^2))$.
In [3]:
Draw(b,mesh,"wind")
We define and assemble bilinear forms for convection-diffusion stiffness and mass matrix separately.
Note that we choose a non-symmetric memory layout for the mass matrix so that a and m have the same sparsity pattern.
In [4]:
a += SymbolicBFI (0.01*grad(u)*grad(v) + b*grad(u)*v)
m += SymbolicBFI (u*v)
We want to use a simple implicit Euler time stepping method, i.e.
$$ (M + \Delta t A) u^{n+1} = M u^n + f^{n+1} $$
or in an incremental form:
$$ (M + \Delta t A) (u^{n+1} - u^n) = - \Delta t A u^n + f^{n+1}. $$
The incremental form has the advantage that $u^{n+1} - u^n$ has homogeneous boundary conditions (unless boundary conditions are time-dependent).
For the time stepping method we want to set up linear combinations of matrices.
In [5]:
print(mstar)
Row 0:   0: 0.00520833   4: 0.00260417   31: 0.00260417   89: -0.000520833   90: 8.68056e-05   91: -0.000520833   92: 8.68056e-05   107: -0.000260417   108: -1.28749e-19   553: 0.000173611
Row 1:   1: 0.00520833   10: 0.00260417   11: 0.00260417   93: -0.000520833   94: 8.68056e-05   95: -0.000520833   96: 8.68056e-05   141: -0.000260417   142: 1.28749e-19   557: 0.000173611
Row 2:   2: 0.00520833   17: 0.00260417   18: 0.00260417   97: -0.000520833   98: 8.68056e-05   99: -0.000520833   100: 8.68056e-05   181: -0.000260417   182: 1.28749e-19   561: 0.000173611
Row 3:   3: 0.00520833   24: 0.00260417   25: 0.00260417   101: -0.000520833   102: 8.68056e-05   103: -0.000520833   104: 8.68056e-05   221: -0.000260417   222: 1.28749e-19   565: 0.000173611
Row 4:   0: 0.00260417   4: 0.0163738   5: 0.00229828   31: 0.0058886   32: 0.00558272   89: -0.000520833   90: -8.68056e-05   91: -0.000260417   92: -1.42302e-19   105: -0.000459656   106: 7.66094e-05   107: -0.00117772   108: 0.000196287   109: -0.00111654   110: 0.000186091   113: -0.000229828   114: -1.15196e-19   261: -0.000328444   262: 1.69407e-19   553: 0.000173611   554: 0.000153219   569: 0.000218962
Row 5:   4: 0.00229828   5: 0.0142215   6: 0.00235821   32: 0.00475257   44: 0.00481249   105: -0.000459656   106: -7.66094e-05   109: -0.000229828   110: -1.24514e-19   111: -0.000471641   112: 7.86068e-05   113: -0.000950513   114: 0.000158419   115: -0.000962498   116: 0.000160416   121: -0.000235821   122: -1.18585e-19   265: -0.000245428   266: 1.25361e-19   554: 0.000153219   573: 0.000157214   584: 0.000163619
Row 6:   5: 0.00235821   6: 0.0140022   7: 0.00225885   33: 0.00464288   44: 0.00474223   111: -0.000471641   112: -7.86068e-05   115: -0.000235821   116: -1.27902e-19   117: -0.000451771   118: 7.52951e-05   119: -0.000928575   120: 0.000154763   121: -0.000948446   122: 0.000158074   125: -0.000225885   126: -1.15196e-19   271: -0.000238402   272: -1.21973e-19   555: 0.00015059   573: 0.000157214   582: 0.000158935
Row 7:   6: 0.00225885   7: 0.0136816   8: 0.00228517   33: 0.00455563   45: 0.00458194   117: -0.000451771   118: -7.52951e-05   119: -0.000225885   120: -1.2282e-19   123: -0.000457033   124: 7.61722e-05   125: -0.000911126   126: 0.000151854   127: -0.000916389   128: 0.000152731   133: -0.000228517   134: -1.15196e-19   273: -0.000229678   274: 1.15196e-19   555: 0.00015059   574: 0.000152344   589: 0.000153119
Row 8:   7: 0.00228517   8: 0.0138903   9: 0.00237377   34: 0.00465998   45: 0.00457138   123: -0.000457033   124: -7.61722e-05   127: -0.000228517   128: -1.23667e-19   129: -0.000474754   130: 7.91257e-05   131: -0.000931996   132: 0.000155333   133: -0.000914276   134: 0.000152379   137: -0.000237377   138: -1.25361e-19   279: -0.000228621   280: -1.15196e-19   556: 0.000158251   574: 0.000152344   578: 0.000152414
Row 9:   8: 0.00237377   9: 0.0132999   10: 0.00223318   34: 0.00441679   46: 0.0042762   129: -0.000474754   130: -7.91257e-05   131: -0.000237377   132: -1.29596e-19   135: -0.000446635   136: 7.44392e-05   137: -0.000883358   138: 0.000147226   139: -0.00085524   140: 0.00014254   145: -0.000223318   146: -1.11808e-19   281: -0.000204302   282: 1.05032e-19   556: 0.000158251   575: 0.000148878   590: 0.000136201
Row 10:   1: 0.00260417   9: 0.00223318   10: 0.021583   11: 0.00593425   35: 0.00595416   46: 0.00485725   93: -0.000520833   94: -8.68056e-05   95: -0.000260417   96: -3.38813e-21   135: -0.000446635   136: -7.44392e-05   139: -0.000223318   140: -1.2282e-19   141: -0.00118685   142: 0.000197808   143: -0.00119083   144: 0.000198472   145: -0.000971451   146: 0.000161908   149: -0.000333008   150: -1.69407e-19   287: -0.000262408   288: -1.32137e-19   557: 0.000173611   570: 0.000222005   575: 0.000148878   609: 0.000174938
Row 11:   1: 0.00260417   10: 0.00593425   11: 0.0164725   12: 0.00230202   35: 0.00563211   93: -0.000260417   94: -1.42302e-19   95: -0.000520833   96: -8.68056e-05   141: -0.00118685   142: -0.000197808   143: -0.000333008   144: -1.82959e-19   147: -0.000460405   148: 7.67341e-05   149: -0.00112642   150: 0.000187737   153: -0.000230202   154: -1.18585e-19   557: 0.000173611   558: 0.000153468   570: 0.000222005
Row 12:   11: 0.00230202   12: 0.0143342   13: 0.00237096   35: 0.00479613   47: 0.00486507   147: -0.000460405   148: -7.67341e-05   149: -0.000230202   150: -1.23667e-19   151: -0.000474192   152: 7.9032e-05   153: -0.000959226   154: 0.000159871   155: -0.000973014   156: 0.000162169   161: -0.000237096   162: -1.18585e-19   289: -0.000249411   290: 1.28749e-19   558: 0.000153468   576: 0.000158064   602: 0.000166274
Row 13:   12: 0.00237096   13: 0.0138437   14: 0.0021948   36: 0.00455091   47: 0.00472707   151: -0.000474192   152: -7.9032e-05   155: -0.000237096   156: -1.29596e-19   157: -0.000438961   158: 7.31601e-05   159: -0.000910182   160: 0.000151697   161: -0.000945413   162: 0.000157569   165: -0.00021948   166: -1.11808e-19   293: -0.00023561   294: -1.21973e-19   559: 0.00014632   576: 0.000158064   588: 0.000157074
Row 14:   13: 0.0021948   14: 0.0130092   15: 0.00212498   36: 0.0043796   48: 0.00430978   157: -0.000438961   158: -7.31601e-05   159: -0.00021948   160: -1.19432e-19   163: -0.000424997   164: 7.08328e-05   165: -0.00087592   166: 0.000145987   167: -0.000861955   168: 0.000143659   173: -0.000212498   174: -1.0842e-19   295: -0.000218479   296: 1.15196e-19   559: 0.00014632   577: 0.000141666   591: 0.000145653
Row 15:   14: 0.00212498   15: 0.0129094   16: 0.00220475   37: 0.00432972   48: 0.00424995   163: -0.000424997   164: -7.08328e-05   167: -0.000212498   168: -1.16891e-19   169: -0.000440949   170: 7.34916e-05   171: -0.000865943   172: 0.000144324   173: -0.00084999   174: 0.000141665   177: -0.000220475   178: -1.15196e-19   301: -0.000212497   302: -1.0842e-19   560: 0.000146983   577: 0.000141666   597: 0.000141665
Row 16:   15: 0.00220475   16: 0.0125009   17: 0.0021434   37: 0.00410704   49: 0.00404569   169: -0.000440949   170: -7.34916e-05   171: -0.000220475   172: -1.19432e-19   175: -0.00042868   176: 7.14466e-05   177: -0.000821408   178: 0.000136901   179: -0.000809138   180: 0.000134856   185: -0.00021434   186: -1.11808e-19   303: -0.000190229   304: 9.82558e-20   560: 0.000146983   579: 0.000142893   592: 0.000126819
Row 17:   2: 0.00260417   16: 0.0021434   17: 0.0210621   18: 0.00585676   38: 0.00578346   49: 0.00467426   97: -0.000520833   98: -8.68056e-05   99: -0.000260417   100: -3.38813e-21   175: -0.00042868   176: -7.14466e-05   179: -0.00021434   180: -1.17738e-19   181: -0.00117135   182: 0.000195225   183: -0.00115669   184: 0.000192782   185: -0.000934852   186: 0.000155809   189: -0.00032526   190: -1.6263e-19   309: -0.000253086   310: -1.28749e-19   561: 0.000173611   571: 0.00021684   579: 0.000142893   611: 0.000168724
Row 18:   2: 0.00260417   17: 0.00585676   18: 0.0162883   19: 0.00228738   38: 0.00553997   97: -0.000260417   98: -1.42302e-19   99: -0.000520833   100: -8.68056e-05   181: -0.00117135   182: -0.000195225   183: -0.00032526   184: -1.77877e-19   187: -0.000457476   188: 7.62459e-05   189: -0.00110799   190: 0.000184666   193: -0.000228738   194: -1.18585e-19   561: 0.000173611   562: 0.000152492   571: 0.00021684
Row 19:   18: 0.00228738   19: 0.0143341   20: 0.00238991   38: 0.00477716   50: 0.00487969   187: -0.000457476   188: -7.62459e-05   189: -0.000228738   190: -1.25361e-19   191: -0.000477982   192: 7.96636e-05   193: -0.000955432   194: 0.000159239   195: -0.000975938   196: 0.000162656   201: -0.000238991   202: -1.18585e-19   311: -0.000248978   312: 1.28749e-19   562: 0.000152492   580: 0.000159327   603: 0.000165986
Row 20:   19: 0.00238991   20: 0.0143452   21: 0.00232874   39: 0.00478268   50: 0.00484385   191: -0.000477982   192: -7.96636e-05   195: -0.000238991   196: -1.29596e-19   197: -0.000465749   198: 7.76248e-05   199: -0.000956536   200: 0.000159423   201: -0.000968769   202: 0.000161462   205: -0.000232874   206: -1.21973e-19   315: -0.000245394   316: -1.28749e-19   563: 0.00015525   580: 0.000159327   598: 0.000163596
Row 21:   20: 0.00232874   21: 0.0140201   22: 0.00232374   39: 0.00468632   51: 0.00468132   197: -0.000465749   198: -7.76248e-05   199: -0.000232874   200: -1.26208e-19   203: -0.000464748   204: 7.7458e-05   205: -0.000937265   206: 0.000156211   207: -0.000936264   208: 0.000156044   213: -0.000232374   214: -1.18585e-19   317: -0.000235758   318: 1.21973e-19   563: 0.00015525   581: 0.000154916   593: 0.000157172
Row 22:   21: 0.00232374   22: 0.0139707   23: 0.00235233   40: 0.00466161   51: 0.00463302   203: -0.000464748   204: -7.7458e-05   207: -0.000232374   208: -1.27055e-19   209: -0.000470467   210: 7.84111e-05   211: -0.000932321   212: 0.000155387   213: -0.000926603   214: 0.000154434   217: -0.000235233   218: -1.21973e-19   323: -0.000230927   324: -1.18585e-19   564: 0.000156822   581: 0.000154916   599: 0.000153952
Row 23:   22: 0.00235233   23: 0.0131126   24: 0.00219508   40: 0.00436123   52: 0.00420399   209: -0.000470467   210: -7.84111e-05   211: -0.000235233   212: -1.27902e-19   215: -0.000439017   216: 7.31695e-05   217: -0.000872247   218: 0.000145374   219: -0.000840797   220: 0.000140133   225: -0.000219508   226: -1.11808e-19   325: -0.00020089   326: 1.05032e-19   564: 0.000156822   583: 0.000146339   594: 0.000133927
Row 24:   3: 0.00260417   23: 0.00219508   24: 0.0212547   25: 0.00585915   41: 0.00582808   52: 0.00476818   101: -0.000520833   102: -8.68056e-05   103: -0.000260417   104: -3.38813e-21   215: -0.000439017   216: -7.31695e-05   219: -0.000219508   220: -1.19432e-19   221: -0.00117183   222: 0.000195305   223: -0.00116562   224: 0.000194269   225: -0.000953636   226: 0.000158939   229: -0.000325499   230: -1.69407e-19   331: -0.00025731   332: -1.32137e-19   565: 0.000173611   572: 0.000216999   583: 0.000146339   619: 0.00017154
Row 25:   3: 0.00260417   24: 0.00585915   25: 0.016254   26: 0.00226785   41: 0.00552283   101: -0.000260417   102: -1.42302e-19   103: -0.000520833   104: -8.68056e-05   221: -0.00117183   222: -0.000195305   223: -0.000325499   224: -1.77877e-19   227: -0.000453569   228: 7.55949e-05   229: -0.00110457   230: 0.000184094   233: -0.000226785   234: -1.15196e-19   565: 0.000173611   566: 0.00015119   572: 0.000216999
Row 26:   25: 0.00226785   26: 0.0138853   27: 0.00228072   41: 0.00466194   53: 0.00467481   227: -0.000453569   228: -7.55949e-05   229: -0.000226785   230: -1.2282e-19   231: -0.000456144   232: 7.60239e-05   233: -0.000932388   234: 0.000155398   235: -0.000934963   236: 0.000155827   241: -0.000228072   242: -1.18585e-19   333: -0.00023941   334: 1.21973e-19   566: 0.00015119   585: 0.000152048   601: 0.000159606
Row 27:   26: 0.00228072   27: 0.0134621   28: 0.00215531   42: 0.00445032   53: 0.00457573   231: -0.000456144   232: -7.60239e-05   235: -0.000228072   236: -1.2282e-19   237: -0.000431062   238: 7.18436e-05   239: -0.000890065   240: 0.000148344   241: -0.000915147   242: 0.000152524   245: -0.000215531   246: -1.0842e-19   337: -0.000229502   338: -1.15196e-19   567: 0.000143687   585: 0.000152048   604: 0.000153001
Row 28:   27: 0.00215531   28: 0.0130849   29: 0.00218893   42: 0.00435354   54: 0.00438717   237: -0.000431062   238: -7.18436e-05   239: -0.000215531   240: -1.17738e-19   243: -0.000437786   244: 7.29644e-05   245: -0.000870709   246: 0.000145118   247: -0.000877433   248: 0.000146239   253: -0.000218893   254: -1.11808e-19   339: -0.000219824   340: 1.11808e-19   567: 0.000143687   586: 0.000145929   595: 0.000146549
Row 29:   28: 0.00218893   29: 0.0133995   30: 0.00230402   43: 0.00451081   54: 0.00439572   243: -0.000437786   244: -7.29644e-05   247: -0.000218893   248: -1.18585e-19   249: -0.000460804   250: 7.68007e-05   251: -0.000902162   252: 0.00015036   253: -0.000879144   254: 0.000146524   257: -0.000230402   258: -1.18585e-19   345: -0.000220679   346: -1.15196e-19   568: 0.000153601   586: 0.000145929   600: 0.000147119
Row 30:   29: 0.00230402   30: 0.0129629   31: 0.00218734   43: 0.00429412   55: 0.00417744   249: -0.000460804   250: -7.68007e-05   251: -0.000230402   252: -1.24514e-19   255: -0.000437468   256: 7.29113e-05   257: -0.000858824   258: 0.000143137   259: -0.000835488   260: 0.000139248   263: -0.000218734   264: -1.11808e-19   347: -0.00019901   348: 1.05032e-19   568: 0.000153601   587: 0.000145823   596: 0.000132673
Row 31:   0: 0.00260417   4: 0.0058886   30: 0.00218734   31: 0.021317   32: 0.00586698   55: 0.00476988   89: -0.000260417   90: -3.38813e-21   91: -0.000520833   92: -8.68056e-05   107: -0.00117772   108: -0.000196287   109: -0.000328444   110: -1.01644e-20   255: -0.000437468   256: -7.29113e-05   259: -0.000218734   260: -1.20279e-19   261: -0.0011734   262: 0.000195566   263: -0.000953976   264: 0.000158996   267: -0.000258254   268: -1.32137e-19   553: 0.000173611   569: 0.000218962   587: 0.000145823   627: 0.000172169
Row 32:   4: 0.00558272   5: 0.00475257   31: 0.00586698   32: 0.0316705   44: 0.00527279   55: 0.00497975   67: 0.00521572   105: -0.000229828   106: -5.0822e-21   107: -0.000328444   108: -1.81265e-19   109: -0.00111654   110: -0.000186091   113: -0.000950513   114: -0.000158419   115: -0.000245428   116: -5.0822e-21   261: -0.0011734   262: -0.000195566   263: -0.000258254   264: -1.42302e-19   265: -0.00105456   266: 0.00017576   267: -0.00099595   268: 0.000165992   269: -0.00104314   270: 0.000173857   355: -0.00028185   356: -1.42302e-19   391: -0.000239721   392: 1.25361e-19   554: 0.000153219   569: 0.000218962   584: 0.000163619   623: 0.0001879   627: 0.000172169   632: 0.000159814
Row 33:   6: 0.00464288   7: 0.00455563   33: 0.0273626   44: 0.0046814   45: 0.00448984   61: 0.00444425   66: 0.00454856   117: -0.000225885   118: -8.47033e-21   119: -0.000928575   120: -0.000154763   121: -0.000238402   122: -1.30443e-19   125: -0.000911126   126: -0.000151854   127: -0.000229678   128: -8.47033e-21   271: -0.00093628   272: 0.000156047   273: -0.000897969   274: 0.000149661   275: -0.000888851   276: 0.000148142   277: -0.000909713   278: 0.000151619   353: -0.000229738   354: 1.15196e-19   357: -0.000219307   358: -1.15196e-19   431: -0.000225119   432: -1.15196e-19   555: 0.00015059   582: 0.000158935   589: 0.000153119   612: 0.000146204   621: 0.000153158   622: 0.000150079
Row 34:   8: 0.00465998   9: 0.00441679   34: 0.0282066   45: 0.00459044   46: 0.00442359   57: 0.00509607   63: 0.00501973   129: -0.000237377   130: -5.0822e-21   131: -0.000931996   132: -0.000155333   133: -0.000228621   134: -1.2282e-19   137: -0.000883358   138: -0.000147226   139: -0.000204302   140: -3.38813e-21   279: -0.000918089   280: 0.000153015   281: -0.000884718   282: 0.000147453   283: -0.00101921   284: 0.000169869   285: -0.00100395   286: 0.000167324   359: -0.000230423   360: 1.18585e-19   361: -0.000238057   362: -1.25361e-19   401: -0.00027155   402: -1.38913e-19   556: 0.000158251   578: 0.000152414   590: 0.000136201   606: 0.000158705   615: 0.000153615   616: 0.000181033
Row 35:   10: 0.00595416   11: 0.00563211   12: 0.00479613   35: 0.0321497   46: 0.00508905   47: 0.00535371   57: 0.00532457   141: -0.000333008   142: -1.01644e-20   143: -0.00119083   144: -0.000198472   145: -0.000262408   146: -1.42302e-19   147: -0.000230202   148: -5.0822e-21   149: -0.00112642   150: -0.000187737   153: -0.000959226   154: -0.000159871   155: -0.000249411   156: -6.77626e-21   287: -0.00101781   288: 0.000169635   289: -0.00107074   290: 0.000178457   291: -0.00106491   292: 0.000177486   361: -0.000246497   362: 1.21973e-19   363: -0.00028596   364: -1.49078e-19   558: 0.000153468   570: 0.000222005   602: 0.000166274   609: 0.000174938   630: 0.000164331   637: 0.00019064
Row 36:   13: 0.00455091   14: 0.0043796   36: 0.0266468   47: 0.0047088   48: 0.00424451   59: 0.00423499   68: 0.00452796   157: -0.00021948   158: -6.77626e-21   159: -0.000910182   160: -0.000151697   161: -0.00023561   162: -1.28749e-19   165: -0.00087592   166: -0.000145987   167: -0.000218479   168: -5.0822e-21   293: -0.000941759   294: 0.00015696   295: -0.000848903   296: 0.000141484   297: -0.000846999   298: 0.000141166   299: -0.000905593   300: 0.000150932   365: -0.000235269   366: 1.18585e-19   367: -0.000205972   368: -1.0842e-19   415: -0.000217527   416: -1.0842e-19   559: 0.00014632   588: 0.000157074   591: 0.000145653   608: 0.000137315   628: 0.000156846   629: 0.000145018
Row 37:   15: 0.00432972   16: 0.00410704   37: 0.0258685   48: 0.00416669   49: 0.00415419   60: 0.00466053   69: 0.00445034   169: -0.000220475   170: -6.77626e-21   171: -0.000865943   172: -0.000144324   173: -0.000212497   174: -1.16891e-19   177: -0.000821408   178: -0.000136901   179: -0.000190229   180: -5.0822e-21   301: -0.000833337   302: 0.00013889   303: -0.000830838   304: 0.000138473   305: -0.000932106   306: 0.000155351   307: -0.000890069   308: 0.000148345   369: -0.000204172   370: 1.05032e-19   371: -0.00022519   372: -1.15196e-19   425: -0.000240863   426: -1.21973e-19   560: 0.000146983   592: 0.000126819   597: 0.000141665   634: 0.000136115   642: 0.000150127   643: 0.000160575
Row 38:   17: 0.00578346   18: 0.00553997   19: 0.00477716   38: 0.0313612   49: 0.0048697   50: 0.00527093   60: 0.00511998   181: -0.00032526   182: -6.77626e-21   183: -0.00115669   184: -0.000192782   185: -0.000253086   186: -1.37219e-19   187: -0.000228738   188: -6.77626e-21   189: -0.00110799   190: -0.000184666   193: -0.000955432   194: -0.000159239   195: -0.000248978   196: -8.47033e-21   309: -0.000973941   310: 0.000162323   311: -0.00105419   312: 0.000175698   313: -0.001024   314: 0.000170666   371: -0.000233884   372: 1.18585e-19   373: -0.000278114   374: -1.42302e-19   562: 0.000152492   571: 0.00021684   603: 0.000165986   610: 0.000185409   611: 0.000168724   631: 0.000155923
Row 39:   20: 0.00478268   21: 0.00468632   39: 0.0284262   50: 0.00484376   51: 0.00467636   58: 0.00468303   62: 0.00475407   197: -0.000232874   198: -3.38813e-21   199: -0.000956536   200: -0.000159423   201: -0.000245394   202: -1.32137e-19   205: -0.000937265   206: -0.000156211   207: -0.000235758   208: -8.47033e-21   315: -0.000968753   316: 0.000161459   317: -0.000935272   318: 0.000155879   319: -0.000936606   320: 0.000156101   321: -0.000950815   322: 0.000158469   375: -0.000238983   376: 1.21973e-19   377: -0.000231878   378: -1.18585e-19   407: -0.000236425   408: -1.18585e-19   563: 0.00015525   593: 0.000157172   598: 0.000163596   607: 0.000154585   613: 0.000159322   614: 0.000157617
Row 40:   22: 0.00466161   23: 0.00436123   40: 0.0278942   51: 0.00459698   52: 0.00432534   65: 0.00498889   70: 0.00496015   209: -0.000235233   210: -6.77626e-21   211: -0.000932321   212: -0.000155387   213: -0.000230927   214: -1.27055e-19   217: -0.000872247   218: -0.000145374   219: -0.00020089   220: -3.38813e-21   323: -0.000919395   324: 0.000153233   325: -0.000865069   326: 0.000144178   327: -0.000997777   328: 0.000166296   329: -0.000992029   330: 0.000165338   379: -0.00022877   380: 1.15196e-19   381: -0.000231644   382: -1.15196e-19   451: -0.000267245   452: -1.38913e-19   564: 0.000156822   594: 0.000133927   599: 0.000153952   620: 0.000154429   640: 0.000152513   645: 0.000178163
Row 41:   24: 0.00582808   25: 0.00552283   26: 0.00466194   41: 0.0312511   52: 0.00494464   53: 0.0051581   65: 0.00513554   221: -0.000325499   222: -1.01644e-20   223: -0.00116562   224: -0.000194269   225: -0.00025731   226: -1.42302e-19   227: -0.000226785   228: -8.47033e-21   229: -0.00110457   230: -0.000184094   233: -0.000932388   234: -0.000155398   235: -0.00023941   236: -6.77626e-21   331: -0.000988928   332: 0.000164821   333: -0.00103162   334: 0.000171937   335: -0.00102711   336: 0.000171185   381: -0.000237154   382: 1.18585e-19   385: -0.0002764   386: -1.38913e-19   566: 0.00015119   572: 0.000216999   601: 0.000159606   619: 0.00017154   625: 0.000158103   626: 0.000184267
Row 42:   27: 0.00445032   28: 0.00435354   42: 0.0261316   53: 0.00448035   54: 0.00427953   56: 0.00423189   64: 0.00433593   237: -0.000215531   238: -5.0822e-21   239: -0.000890065   240: -0.000148344   241: -0.000229502   242: -1.24514e-19   245: -0.000870709   246: -0.000145118   247: -0.000219824   248: -6.77626e-21   337: -0.00089607   338: 0.000149345   339: -0.000855906   340: 0.000142651   341: -0.000846379   342: 0.000141063   343: -0.000867186   344: 0.000144531   383: -0.000218533   384: 1.11808e-19   387: -0.00020813   388: -1.0842e-19   393: -0.00021506   394: -1.11808e-19   567: 0.000143687   595: 0.000146549   604: 0.000153001   605: 0.000138753   617: 0.000145689   618: 0.000143373
Row 43:   29: 0.00451081   30: 0.00429412   43: 0.0273317   54: 0.00442687   55: 0.0043015   67: 0.00494489   71: 0.00485356   249: -0.000230402   250: -5.0822e-21   251: -0.000902162   252: -0.00015036   253: -0.000220679   254: -1.21126e-19   257: -0.000858824   258: -0.000143137   259: -0.00019901   260: -3.38813e-21   345: -0.000885373   346: 0.000147562   347: -0.000860301   348: 0.000143383   349: -0.000988978   350: 0.00016483   351: -0.000970712   352: 0.000161785   389: -0.000222008   390: 1.15196e-19   391: -0.000231141   392: -1.18585e-19   461: -0.000263348   462: -1.32137e-19   568: 0.000153601   596: 0.000132673   600: 0.000147119   644: 0.000148005   647: 0.000154094   648: 0.000175565
Row 44:   5: 0.00481249   6: 0.00474223   32: 0.00527279   33: 0.0046814   44: 0.0298921   66: 0.00493104   67: 0.00545217   111: -0.000235821   112: -8.47033e-21   113: -0.000245428   114: -1.35525e-19   115: -0.000962498   116: -0.000160416   119: -0.000238402   120: -1.01644e-20   121: -0.000948446   122: -0.000158074   265: -0.00105456   266: -0.00017576   269: -0.00028185   270: -1.52466e-19   271: -0.00093628   272: -0.000156047   277: -0.000229738   278: -3.38813e-21   353: -0.000986208   354: 0.000164368   355: -0.00109043   356: 0.000181739   455: -0.000263367   456: -1.35525e-19   573: 0.000157214   582: 0.000158935   584: 0.000163619   621: 0.000153158   623: 0.0001879   624: 0.000175578
Row 45:   7: 0.00458194   8: 0.00457138   33: 0.00448984   34: 0.00459044   45: 0.0272516   61: 0.00445339   63: 0.00456456   123: -0.000228517   124: -3.38813e-21   125: -0.000229678   126: -1.24514e-19   127: -0.000916389   128: -0.000152731   131: -0.000228621   132: -3.38813e-21   133: -0.000914276   134: -0.000152379   273: -0.000897969   274: -0.000149661   275: -0.000219307   276: -1.19432e-19   279: -0.000918089   280: -0.000153015   285: -0.000230423   286: -3.38813e-21   357: -0.000890679   358: 0.000148446   359: -0.000912912   360: 0.000152152   429: -0.000226033   430: 1.21973e-19   574: 0.000152344   578: 0.000152414   589: 0.000153119   612: 0.000146204   615: 0.000153615   636: 0.000150689
Row 46:   9: 0.0042762   10: 0.00485725   34: 0.00442359   35: 0.00508905   46: 0.0234916   57: 0.00484554   135: -0.000223318   136: -6.77626e-21   137: -0.000204302   138: -1.10961e-19   139: -0.00085524   140: -0.00014254   143: -0.000262408   144: -8.47033e-21   145: -0.000971451   146: -0.000161908   281: -0.000884718   282: -0.000147453   283: -0.000238057   284: -1.29596e-19   287: -0.00101781   288: -0.000169635   291: -0.000246497   292: -1.01644e-20   361: -0.000969108   362: 0.000161518   575: 0.000148878   590: 0.000136201   606: 0.000158705   609: 0.000174938   630: 0.000164331
Row 47:   12: 0.00486507   13: 0.00472707   35: 0.00535371   36: 0.0047088   47: 0.030371   57: 0.00561162   68: 0.00510471   151: -0.000237096   152: -5.0822e-21   153: -0.000249411   154: -1.35525e-19   155: -0.000973014   156: -0.000162169   159: -0.00023561   160: -5.0822e-21   161: -0.000945413   162: -0.000157569   289: -0.00107074   290: -0.000178457   291: -0.00028596   292: -1.57548e-19   293: -0.000941759   294: -0.00015696   299: -0.000235269   300: -8.47033e-21   363: -0.00112232   364: 0.000187054   365: -0.00102094   366: 0.000170157   403: -0.000275202   404: 1.38913e-19   576: 0.000158064   588: 0.000157074   602: 0.000166274   628: 0.000156846   637: 0.00019064   641: 0.000183468
Row 48:   14: 0.00430978   15: 0.00424995   36: 0.00424451   37: 0.00416669   48: 0.0252491   59: 0.00414807   69: 0.00413007   163: -0.000212498   164: -3.38813e-21   165: -0.000218479   166: -1.20279e-19   167: -0.000861955   168: -0.000143659   171: -0.000212497   172: -5.0822e-21   173: -0.00084999   174: -0.000141665   295: -0.000848903   296: -0.000141484   297: -0.000205972   298: -1.12655e-19   301: -0.000833337   302: -0.00013889   307: -0.000204172   308: -3.38813e-21   367: -0.000829615   368: 0.000138269   369: -0.000826014   370: 0.000137669   417: -0.000208835   418: 1.11808e-19   577: 0.000141666   591: 0.000145653   597: 0.000141665   608: 0.000137315   633: 0.000139224   634: 0.000136115
Row 49:   16: 0.00404569   17: 0.00467426   37: 0.00415419   38: 0.0048697   49: 0.0223346   60: 0.00459074   175: -0.00021434   176: -5.0822e-21   177: -0.000190229   178: -1.03338e-19   179: -0.000809138   180: -0.000134856   183: -0.000253086   184: -5.0822e-21   185: -0.000934852   186: -0.000155809   303: -0.000830838   304: -0.000138473   305: -0.00022519   306: -1.2282e-19   309: -0.000973941   310: -0.000162323   313: -0.000233884   314: -3.38813e-21   371: -0.000918148   372: 0.000153025   579: 0.000142893   592: 0.000126819   611: 0.000168724   631: 0.000155923   642: 0.000150127
Row 50:   19: 0.00487969   20: 0.00484385   38: 0.00527093   39: 0.00484376   50: 0.0304892   60: 0.00552116   62: 0.00512985   191: -0.000238991   192: -8.47033e-21   193: -0.000248978   194: -1.35525e-19   195: -0.000975938   196: -0.000162656   199: -0.000245394   200: -6.77626e-21   201: -0.000968769   202: -0.000161462   311: -0.00105419   312: -0.000175698   313: -0.000278114   314: -1.50772e-19   315: -0.000968753   316: -0.000161459   321: -0.000238983   322: -1.01644e-20   373: -0.00110423   374: 0.000184039   375: -0.00102597   376: 0.000170995   423: -0.000274002   424: 1.38913e-19   580: 0.000159327   598: 0.000163596   603: 0.000165986   610: 0.000185409   613: 0.000159322   638: 0.000182668
Row 51:   21: 0.00468132   22: 0.00463302   39: 0.00467636   40: 0.00459698   51: 0.0278813   58: 0.00466237   70: 0.00463129   203: -0.000232374   204: -5.0822e-21   205: -0.000235758   206: -1.29596e-19   207: -0.000936264   208: -0.000156044   211: -0.000230927   212: -5.0822e-21   213: -0.000926603   214: -0.000154434   317: -0.000935272   318: -0.000155879   319: -0.000231878   320: -1.27055e-19   323: -0.000919395   324: -0.000153233   329: -0.00022877   330: -6.77626e-21   377: -0.000932474   378: 0.000155412   379: -0.000926258   380: 0.000154376   409: -0.000234359   410: 1.21973e-19   581: 0.000154916   593: 0.000157172   599: 0.000153952   607: 0.000154585   639: 0.000156239   640: 0.000152513
Row 52:   23: 0.00420399   24: 0.00476818   40: 0.00432534   41: 0.00494464   52: 0.0229301   65: 0.00468798   215: -0.000219508   216: -3.38813e-21   217: -0.00020089   218: -1.09267e-19   219: -0.000840797   220: -0.000140133   223: -0.00025731   224: -3.38813e-21   225: -0.000953636   226: -0.000158939   325: -0.000865069   326: -0.000144178   327: -0.000231644   328: -1.26208e-19   331: -0.000988928   332: -0.000164821   335: -0.000237154   336: -8.47033e-21   381: -0.000937597   382: 0.000156266   583: 0.000146339   594: 0.000133927   619: 0.00017154   620: 0.000154429   625: 0.000158103
Row 53:   26: 0.00467481   27: 0.00457573   41: 0.0051581   42: 0.00448035   53: 0.0289194   64: 0.00472588   65: 0.00530456   231: -0.000228072   232: -6.77626e-21   233: -0.00023941   234: -1.30443e-19   235: -0.000934963   236: -0.000155827   239: -0.000229502   240: -3.38813e-21   241: -0.000915147   242: -0.000152524   333: -0.00103162   334: -0.000171937   335: -0.0002764   336: -1.52466e-19   337: -0.00089607   338: -0.000149345   343: -0.000218533   344: -5.0822e-21   383: -0.000945177   384: 0.000157529   385: -0.00106091   386: 0.000176819   445: -0.000254055   446: -1.28749e-19   585: 0.000152048   601: 0.000159606   604: 0.000153001   617: 0.000145689   626: 0.000184267   635: 0.00016937
Row 54:   28: 0.00438717   29: 0.00439572   42: 0.00427953   43: 0.00442687   54: 0.026094   56: 0.00423297   71: 0.00437176   243: -0.000218893   244: -3.38813e-21   245: -0.000219824   246: -1.21126e-19   247: -0.000877433   248: -0.000146239   251: -0.000220679   252: -6.77626e-21   253: -0.000879144   254: -0.000146524   339: -0.000855906   340: -0.000142651   341: -0.00020813   342: -1.14349e-19   345: -0.000885373   346: -0.000147562   351: -0.000222008   352: -5.0822e-21   387: -0.000846595   388: 0.000141099   389: -0.000874352   390: 0.000145725   395: -0.000215168   396: 1.11808e-19   586: 0.000145929   595: 0.000146549   600: 0.000147119   605: 0.000138753   644: 0.000148005   646: 0.000143445
Row 55:   30: 0.00417744   31: 0.00476988   32: 0.00497975   43: 0.0043015   55: 0.0229372   67: 0.00470862   255: -0.000218734   256: -3.38813e-21   257: -0.00019901   258: -1.09267e-19   259: -0.000835488   260: -0.000139248   261: -0.000258254   262: -8.47033e-21   263: -0.000953976   264: -0.000158996   267: -0.00099595   268: -0.000165992   269: -0.000239721   270: -6.77626e-21   347: -0.000860301   348: -0.000143383   349: -0.000231141   350: -1.25361e-19   391: -0.000941724   392: 0.000156954   587: 0.000145823   596: 0.000132673   627: 0.000172169   632: 0.000159814   647: 0.000154094
Row 56:   42: 0.00423189   54: 0.00423297   56: 0.0242349   64: 0.00391886   71: 0.00435232   72: 0.00396559   75: 0.00353321   339: -0.00020813   340: -5.0822e-21   341: -0.000846379   342: -0.000141063   343: -0.00021506   344: -1.17738e-19   387: -0.000846595   388: -0.000141099   389: -0.000215168   390: -3.38813e-21   393: -0.000783772   394: 0.000130629   395: -0.000870464   396: 0.000145077   397: -0.000793118   398: 0.000132186   399: -0.000706643   400: 0.000117774   447: -0.000176827   448: 9.14796e-20   477: -0.000220064   478: -1.11808e-19   481: -0.000176495   482: -9.14796e-20   605: 0.000138753   618: 0.000143373   646: 0.000143445   649: 0.000146709   653: 0.000117884   654: 0.000117663
Row 57:   34: 0.00509607   35: 0.00532457   46: 0.00484554   47: 0.00561162   57: 0.0371921   63: 0.00542756   68: 0.00546337   74: 0.00542342   281: -0.000238057   282: -6.77626e-21   283: -0.00101921   284: -0.000169869   285: -0.00027155   286: -1.49078e-19   287: -0.000246497   288: -1.34678e-19   289: -0.00028596   290: -6.77626e-21   291: -0.00106491   292: -0.000177486   361: -0.000969108   362: -0.000161518   363: -0.00112232   364: -0.000187054   365: -0.000275202   366: -3.38813e-21   401: -0.00108551   402: 0.000180919   403: -0.00109267   404: 0.000182112   405: -0.00108468   406: 0.000180781   441: -0.000271206   442: 1.42302e-19   465: -0.000271136   466: -1.38913e-19   606: 0.000158705   616: 0.000181033   630: 0.000164331   637: 0.00019064   641: 0.000183468   651: 0.000180804   652: 0.000180757
Row 58:   39: 0.00468303   51: 0.00466237   58: 0.0276996   62: 0.00468683   70: 0.00467345   73: 0.00450061   83: 0.00449334   317: -0.000231878   318: -3.38813e-21   319: -0.000936606   320: -0.000156101   321: -0.000236425   322: -1.28749e-19   377: -0.000932474   378: -0.000155412   379: -0.000234359   380: -6.77626e-21   407: -0.000937367   408: 0.000156228   409: -0.000934689   410: 0.000155782   411: -0.000900123   412: 0.00015002   413: -0.000898668   414: 0.000149778   439: -0.000232259   440: 1.21973e-19   473: -0.000232986   474: -1.18585e-19   491: -0.000217076   492: -1.15196e-19   607: 0.000154585   614: 0.000157617   639: 0.000156239   650: 0.000155324   672: 0.000154839   674: 0.000144717
Row 59:   36: 0.00423499   48: 0.00414807   59: 0.0237923   68: 0.00433386   69: 0.00380286   76: 0.00341423   81: 0.00385832   295: -0.000205972   296: -3.38813e-21   297: -0.000846999   298: -0.000141166   299: -0.000217527   300: -1.18585e-19   367: -0.000829615   368: -0.000138269   369: -0.000208835   370: -3.38813e-21   415: -0.000866772   416: 0.000144462   417: -0.000760572   418: 0.000126762   419: -0.000682846   420: 0.000113808   421: -0.000771664   422: 0.000128611   467: -0.000215859   468: 1.11808e-19   469: -0.00017145   470: -8.47033e-20   509: -0.000169973   510: -8.80914e-20   608: 0.000137315   629: 0.000145018   633: 0.000139224   655: 0.0001143   666: 0.000143906   668: 0.000113315
Row 60:   37: 0.00466053   38: 0.00511998   49: 0.00459074   50: 0.00552116   60: 0.0349119   62: 0.00524315   69: 0.00484091   77: 0.00493542   303: -0.00022519   304: -8.47033e-21   305: -0.000932106   306: -0.000155351   307: -0.000240863   308: -1.30443e-19   309: -0.000233884   310: -1.28749e-19   311: -0.000278114   312: -1.01644e-20   313: -0.001024   314: -0.000170666   371: -0.000918148   372: -0.000153025   373: -0.00110423   374: -0.000184039   375: -0.000274002   376: -8.47033e-21   423: -0.00104863   424: 0.000174772   425: -0.000968183   426: 0.000161364   427: -0.000987084   428: 0.000164514   437: -0.000250313   438: -1.25361e-19   471: -0.000243229   472: 1.18585e-19   610: 0.000185409   631: 0.000155923   638: 0.000182668   642: 0.000150127   643: 0.000160575   656: 0.000162153   658: 0.000166875
Row 61:   33: 0.00444425   45: 0.00445339   61: 0.0255334   63: 0.00454504   66: 0.00417377   78: 0.00377739   79: 0.00413952   273: -0.000219307   274: -6.77626e-21   275: -0.000888851   276: -0.000148142   277: -0.000225119   278: -1.2282e-19   357: -0.000890679   358: -0.000148446   359: -0.000226033   360: -3.38813e-21   429: -0.000909008   430: 0.000151501   431: -0.000834754   432: 0.000139126   433: -0.000755477   434: 0.000125913   435: -0.000827903   436: 0.000137984   443: -0.000228471   444: -1.18585e-19   457: -0.000192258   458: 9.82558e-20   517: -0.00018548   518: 9.48677e-20   612: 0.000146204   622: 0.000150079   636: 0.000150689   659: 0.000128172   660: 0.000152314   661: 0.000123653
Row 62:   39: 0.00475407   50: 0.00512985   58: 0.00468683   60: 0.00524315   62: 0.0289909   77: 0.00467879   83: 0.00449825   315: -0.000238983   316: -1.3129e-19   319: -0.000236425   320: -5.0822e-21   321: -0.000950815   322: -0.000158469   373: -0.000274002   374: -1.49078e-19   375: -0.00102597   376: -0.000170995   407: -0.000937367   408: -0.000156228   413: -0.000232259   414: -3.38813e-21   423: -0.00104863   424: -0.000174772   427: -0.000250313   428: -1.36372e-19   437: -0.000935759   438: 0.00015596   439: -0.00089965   440: 0.000149942   513: -0.000217566   514: 1.15196e-19   613: 0.000159322   614: 0.000157617   638: 0.000182668   658: 0.000166875   672: 0.000154839   673: 0.000145044
Row 63:   34: 0.00501973   45: 0.00456456   57: 0.00542756   61: 0.00454504   63: 0.029113   74: 0.00499172   79: 0.00456437   279: -0.000230423   280: -1.26208e-19   283: -0.00027155   284: -6.77626e-21   285: -0.00100395   286: -0.000167324   357: -0.000226033   358: -1.23667e-19   359: -0.000912912   360: -0.000152152   401: -0.00108551   402: -0.000180919   405: -0.000271206   406: -6.77626e-21   429: -0.000909008   430: -0.000151501   435: -0.000228471   436: -1.24514e-19   441: -0.000998344   442: 0.000166391   443: -0.000912874   444: 0.000152146   497: -0.000227966   498: -1.18585e-19   615: 0.000153615   616: 0.000181033   636: 0.000150689   651: 0.000180804   660: 0.000152314   662: 0.000151977
Row 64:   42: 0.00433593   53: 0.00472588   56: 0.00391886   64: 0.0258768   65: 0.00504652   75: 0.00355593   80: 0.00429363   337: -0.000218533   338: -1.19432e-19   341: -0.00021506   342: -6.77626e-21   343: -0.000867186   344: -0.000144531   383: -0.000945177   384: -0.000157529   385: -0.000254055   386: -1.38913e-19   393: -0.000783772   394: -0.000130629   399: -0.000176827   400: -3.38813e-21   445: -0.0010093   446: 0.000168217   447: -0.000711186   448: 0.000118531   449: -0.000858727   450: 0.000143121   453: -0.000250597   454: 1.28749e-19   503: -0.000178767   504: -9.48677e-20   617: 0.000145689   618: 0.000143373   635: 0.00016937   653: 0.000117884   663: 0.000167065   665: 0.000119178
Row 65:   40: 0.00498889   41: 0.00513554   52: 0.00468798   53: 0.00530456   64: 0.00504652   65: 0.0354096   70: 0.00520628   80: 0.0050398   325: -0.000231644   326: -6.77626e-21   327: -0.000997777   328: -0.000166296   329: -0.000267245   330: -1.4569e-19   331: -0.000237154   332: -1.28749e-19   333: -0.0002764   334: -8.47033e-21   335: -0.00102711   336: -0.000171185   381: -0.000937597   382: -0.000156266   383: -0.000254055   384: -8.47033e-21   385: -0.00106091   386: -0.000176819   445: -0.0010093   446: -0.000168217   449: -0.000250597   450: -1.01644e-20   451: -0.00104126   452: 0.000173543   453: -0.00100796   454: 0.000167993   475: -0.000253384   476: 1.28749e-19   620: 0.000154429   625: 0.000158103   626: 0.000184267   635: 0.00016937   645: 0.000178163   663: 0.000167065   664: 0.000168922
Row 66:   33: 0.00454856   44: 0.00493104   61: 0.00417377   66: 0.027271   67: 0.00525498   78: 0.00383195   82: 0.00453068   271: -0.000229738   272: -1.25361e-19   275: -0.000225119   276: -3.38813e-21   277: -0.000909713   278: -0.000151619   353: -0.000986208   354: -0.000164368   355: -0.000263367   356: -1.43996e-19   431: -0.000834754   432: -0.000139126   433: -0.000192258   434: -3.38813e-21   455: -0.001051   456: 0.000175166   457: -0.00076639   458: 0.000127732   459: -0.000906135   460: 0.000151023   463: -0.000262131   464: 1.32137e-19   519: -0.000190936   520: -9.82558e-20   621: 0.000153158   622: 0.000150079   624: 0.000175578   659: 0.000128172   671: 0.000174754   676: 0.000127291
Row 67:   32: 0.00521572   43: 0.00494489   44: 0.00545217   55: 0.00470862   66: 0.00525498   67: 0.0360169   71: 0.00522634   82: 0.00521417   265: -0.00028185   266: -6.77626e-21   267: -0.000239721   268: -1.30443e-19   269: -0.00104314   270: -0.000173857   347: -0.000231141   348: -1.69407e-21   349: -0.000988978   350: -0.00016483   351: -0.000263348   352: -1.4569e-19   353: -0.000263367   354: -1.69407e-21   355: -0.00109043   356: -0.000181739   391: -0.000941724   392: -0.000156954   455: -0.001051   456: -0.000175166   459: -0.000262131   460: -5.0822e-21   461: -0.00104527   462: 0.000174211   463: -0.00104283   464: 0.000173806   479: -0.000259286   480: 1.32137e-19   623: 0.0001879   624: 0.000175578   632: 0.000159814   647: 0.000154094   648: 0.000175565   669: 0.000172857   671: 0.000174754
Row 68:   36: 0.00452796   47: 0.00510471   57: 0.00546337   59: 0.00433386   68: 0.028705   74: 0.00491393   81: 0.00436116   293: -0.000235269   294: -1.27902e-19   297: -0.000217527   298: -5.0822e-21   299: -0.000905593   300: -0.000150932   363: -0.000275202   364: -1.49078e-19   365: -0.00102094   366: -0.000170157   403: -0.00109267   404: -0.000182112   405: -0.000271136   406: -1.47384e-19   415: -0.000866772   416: -0.000144462   421: -0.000215859   422: -6.77626e-21   465: -0.000982786   466: 0.000163798   467: -0.000872232   468: 0.000145372   499: -0.000220257   500: 1.11808e-19   628: 0.000156846   629: 0.000145018   641: 0.000183468   652: 0.000180757   666: 0.000143906   667: 0.000146838
Row 69:   37: 0.00445034   48: 0.00413007   59: 0.00380286   60: 0.00484091   69: 0.0248257   76: 0.00344186   77: 0.00415964   301: -0.000204172   302: -1.10961e-19   305: -0.000240863   306: -5.0822e-21   307: -0.000890069   308: -0.000148345   367: -0.000208835   368: -1.13502e-19   369: -0.000826014   370: -0.000137669   417: -0.000760572   418: -0.000126762   419: -0.00017145   420: -9.31736e-20   425: -0.000968183   426: -0.000161364   427: -0.000243229   428: -6.77626e-21   469: -0.000688372   470: 0.000114729   471: -0.000831929   472: 0.000138655   507: -0.000172736   508: 8.80914e-20   633: 0.000139224   634: 0.000136115   643: 0.000160575   655: 0.0001143   656: 0.000162153   657: 0.000115157
Row 70:   40: 0.00496015   51: 0.00463129   58: 0.00467345   65: 0.00520628   70: 0.0287159   73: 0.00452039   80: 0.00472437   323: -0.00022877   324: -1.23667e-19   327: -0.000267245   328: -8.47033e-21   329: -0.000992029   330: -0.000165338   377: -0.000234359   378: -1.27902e-19   379: -0.000926258   380: -0.000154376   409: -0.000934689   410: -0.000155782   411: -0.000232986   412: -1.27055e-19   451: -0.00104126   452: -0.000173543   453: -0.000253384   454: -5.0822e-21   473: -0.000904078   474: 0.00015068   475: -0.000944874   476: 0.000157479   489: -0.000219053   490: 1.11808e-19   639: 0.000156239   640: 0.000152513   645: 0.000178163   650: 0.000155324   664: 0.000168922   675: 0.000146036
Row 71:   43: 0.00485356   54: 0.00437176   56: 0.00435232   67: 0.00522634   71: 0.0279483   72: 0.00437604   82: 0.00476826   345: -0.000222008   346: -1.21126e-19   349: -0.000263348   350: -3.38813e-21   351: -0.000970712   352: -0.000161785   387: -0.000215168   388: -1.16891e-19   389: -0.000874352   390: -0.000145725   395: -0.000870464   396: -0.000145077   397: -0.000220064   398: -1.20279e-19   461: -0.00104527   462: -0.000174211   463: -0.000259286   464: -6.77626e-21   477: -0.000875208   478: 0.000145868   479: -0.000953652   480: 0.000158942   483: -0.00021754   484: 1.0842e-19   644: 0.000148005   646: 0.000143445   648: 0.000175565   649: 0.000146709   669: 0.000172857   670: 0.000145027
Row 72:   56: 0.00396559   71: 0.00437604   72: 0.0256201   75: 0.00353135   82: 0.00463296   84: 0.00421152   86: 0.00490268   395: -0.000220064   396: -6.77626e-21   397: -0.000793118   398: -0.000132186   399: -0.000176495   400: -9.74088e-20   477: -0.000875208   478: -0.000145868   479: -0.00021754   480: -3.38813e-21   481: -0.000706269   482: 0.000117712   483: -0.000926592   484: 0.000154432   485: -0.000842304   486: 0.000140384   487: -0.000980536   488: 0.000163423   505: -0.00017664   506: 9.14796e-20   533: -0.000245756   534: -1.25361e-19   539: -0.000244512   540: 1.28749e-19   649: 0.000146709   654: 0.000117663   670: 0.000145027   679: 0.00011776   682: 0.000163837   683: 0.000163008
Row 73:   58: 0.00450061   70: 0.00452039   73: 0.0264991   80: 0.00439381   83: 0.00441745   84: 0.00431173   88: 0.00435514   409: -0.000232986   410: -1.01644e-20   411: -0.000900123   412: -0.00015002   413: -0.000217076   414: -1.18585e-19   473: -0.000904078   474: -0.00015068   475: -0.000219053   476: -6.77626e-21   489: -0.000878763   490: 0.00014646   491: -0.000883491   492: 0.000147248   493: -0.000862345   494: 0.000143724   495: -0.000871029   496: 0.000145171   527: -0.000220328   528: -1.11808e-19   537: -0.00022467   538: 1.15196e-19   541: -0.000210845   542: -1.05032e-19   650: 0.000155324   674: 0.000144717   675: 0.000146036   677: 0.000146885   690: 0.000140563   691: 0.00014978
Row 74:   57: 0.00542342   63: 0.00499172   68: 0.00491393   74: 0.0287476   79: 0.00454306   81: 0.00440731   87: 0.00446814   401: -0.000271206   402: -1.47384e-19   403: -0.000271136   404: -6.77626e-21   405: -0.00108468   406: -0.000180781   441: -0.000998344   442: -0.000166391   443: -0.000227966   444: -1.24514e-19   465: -0.000982786   466: -0.000163798   467: -0.000220257   468: -6.77626e-21   497: -0.000908612   498: 0.000151435   499: -0.000881463   500: 0.00014691   501: -0.000893629   502: 0.000148938   525: -0.00022634   526: 1.15196e-19   531: -0.000220474   532: -1.15196e-19   651: 0.000180804   652: 0.000180757   662: 0.000151977   667: 0.000146838   686: 0.000150894   688: 0.000146983
Row 75:   56: 0.00353321   64: 0.00355593   72: 0.00353135   75: 0.0177617   80: 0.00358124   84: 0.00355997   393: -0.000176827   394: -9.65618e-20   397: -0.000176495   398: -5.0822e-21   399: -0.000706643   400: -0.000117774   447: -0.000711186   448: -0.000118531   449: -0.000178767   450: -9.82558e-20   481: -0.000706269   482: -0.000117712   485: -0.00017664   486: -5.0822e-21   503: -0.000716248   504: 0.000119375   505: -0.000711995   506: 0.000118666   527: -0.000179357   528: 9.14796e-20   653: 0.000117884   654: 0.000117663   665: 0.000119178   678: 0.000119572   679: 0.00011776
Row 76:   59: 0.00341423   69: 0.00344186   76: 0.0171106   77: 0.00344168   81: 0.00339911   85: 0.00341371   417: -0.00017145   418: -3.38813e-21   419: -0.000682846   420: -0.000113808   421: -0.000169973   422: -9.23266e-20   469: -0.000688372   470: -0.000114729   471: -0.000172736   472: -5.0822e-21   507: -0.000688336   508: 0.000114723   509: -0.000679822   510: 0.000113304   511: -0.000682741   512: 0.00011379   515: -0.000171432   516: -8.80914e-20   529: -0.000169938   530: 8.80914e-20   655: 0.0001143   657: 0.000115157   668: 0.000113315   680: 0.000114288   689: 0.000113292
Row 77:   60: 0.00493542   62: 0.00467879   69: 0.00415964   76: 0.00344168   77: 0.0253487   83: 0.00429723   85: 0.00383589   423: -0.000250313   424: -1.01644e-20   425: -0.000243229   426: -1.33831e-19   427: -0.000987084   428: -0.000164514   437: -0.000935759   438: -0.00015596   439: -0.000217566   440: -3.38813e-21   469: -0.000172736   470: -9.40207e-20   471: -0.000831929   472: -0.000138655   507: -0.000688336   508: -0.000114723   511: -0.000171432   512: -9.31736e-20   513: -0.000859447   514: 0.000143241   515: -0.000767179   516: 0.000127863   535: -0.000212157   536: -1.05032e-19   656: 0.000162153   657: 0.000115157   658: 0.000166875   673: 0.000145044   680: 0.000114288   681: 0.000141438
Row 78:   61: 0.00377739   66: 0.00383195   78: 0.0199429   79: 0.00397845   82: 0.00407043   86: 0.00428471   431: -0.000192258   432: -1.05032e-19   433: -0.000755477   434: -0.000125913   435: -0.00018548   436: -6.77626e-21   457: -0.00076639   458: -0.000127732   459: -0.000190936   460: -1.04185e-19   517: -0.00079569   518: 0.000132615   519: -0.000814086   520: 0.000135681   521: -0.000856943   522: 0.000142824   523: -0.000212365   524: -1.0842e-19   533: -0.000216107   534: 1.0842e-19   659: 0.000128172   661: 0.000123653   676: 0.000127291   684: 0.000144071   685: 0.000141576
Row 79:   61: 0.00413952   63: 0.00456437   74: 0.00454306   78: 0.00397845   79: 0.026528   86: 0.00458141   87: 0.00472116   429: -0.000228471   430: -3.38813e-21   433: -0.00018548   434: -1.00797e-19   435: -0.000827903   436: -0.000137984   441: -0.000227966   442: -6.77626e-21   443: -0.000912874   444: -0.000152146   497: -0.000908612   498: -0.000151435   501: -0.00022634   502: -6.77626e-21   517: -0.00079569   518: -0.000132615   521: -0.000212365   522: -1.16044e-19   523: -0.000916281   524: 0.000152714   525: -0.000944233   526: 0.000157372   547: -0.000245776   548: 1.28749e-19   660: 0.000152314   661: 0.000123653   662: 0.000151977   685: 0.000141576   686: 0.000150894   687: 0.000163851
Row 80:   64: 0.00429363   65: 0.0050398   70: 0.00472437   73: 0.00439381   75: 0.00358124   80: 0.0260297   84: 0.00399686   445: -0.000250597   446: -1.37219e-19   447: -0.000178767   448: -5.0822e-21   449: -0.000858727   450: -0.000143121   451: -0.000253384   452: -1.38913e-19   453: -0.00100796   454: -0.000167993   473: -0.000219053   474: -1.20279e-19   475: -0.000944874   476: -0.000157479   489: -0.000878763   490: -0.00014646   493: -0.000220328   494: -1.20279e-19   503: -0.000716248   504: -0.000119375   505: -0.000179357   506: -5.0822e-21   527: -0.000799371   528: 0.000133229   663: 0.000167065   664: 0.000168922   665: 0.000119178   675: 0.000146036   677: 0.000146885   678: 0.000119572
Row 81:   59: 0.00385832   68: 0.00436116   74: 0.00440731   76: 0.00339911   81: 0.0241521   85: 0.00381043   87: 0.00431579   415: -0.000215859   416: -1.18585e-19   419: -0.000169973   420: -5.0822e-21   421: -0.000771664   422: -0.000128611   465: -0.000220257   466: -1.21126e-19   467: -0.000872232   468: -0.000145372   499: -0.000881463   500: -0.00014691   501: -0.000220474   502: -1.20279e-19   509: -0.000679822   510: -0.000113304   511: -0.000169938   512: -5.0822e-21   529: -0.000762086   530: 0.000127014   531: -0.000863158   532: 0.00014386   543: -0.000211105   544: -1.0842e-19   666: 0.000143906   667: 0.000146838   668: 0.000113315   688: 0.000146983   689: 0.000113292   694: 0.000140737
Row 82:   66: 0.00453068   67: 0.00521417   71: 0.00476826   72: 0.00463296   78: 0.00407043   82: 0.0278351   86: 0.00461862   455: -0.000262131   456: -1.43996e-19   457: -0.000190936   458: -5.0822e-21   459: -0.000906135   460: -0.000151023   461: -0.000259286   462: -1.43996e-19   463: -0.00104283   464: -0.000173806   477: -0.00021754   478: -1.18585e-19   479: -0.000953652   480: -0.000158942   483: -0.000926592   484: -0.000154432   487: -0.000245756   488: -1.33831e-19   519: -0.000814086   520: -0.000135681   521: -0.000216107   522: -8.47033e-21   533: -0.000923725   534: 0.000153954   669: 0.000172857   670: 0.000145027   671: 0.000174754   676: 0.000127291   682: 0.000163837   684: 0.000144071
Row 83:   58: 0.00449334   62: 0.00449825   73: 0.00441745   77: 0.00429723   83: 0.026186   85: 0.00417732   88: 0.00430245   407: -0.000232259   408: -1.26208e-19   411: -0.000217076   412: -5.0822e-21   413: -0.000898668   414: -0.000149778   437: -0.000217566   438: -1.19432e-19   439: -0.00089965   440: -0.000149942   491: -0.000883491   492: -0.000147248   495: -0.00022467   496: -5.0822e-21   513: -0.000859447   514: -0.000143241   515: -0.000212157   516: -1.14349e-19   535: -0.000835464   536: 0.000139244   537: -0.00086049   538: 0.000143415   545: -0.000205575   546: 1.01644e-19   672: 0.000154839   673: 0.000145044   674: 0.000144717   681: 0.000141438   691: 0.00014978   693: 0.00013705
Row 84:   72: 0.00421152   73: 0.00431173   75: 0.00355997   80: 0.00399686   84: 0.0253502   86: 0.00480337   88: 0.0044667   481: -0.00017664   482: -9.57147e-20   485: -0.000842304   486: -0.000140384   487: -0.000244512   488: -3.38813e-21   489: -0.000220328   490: -5.0822e-21   493: -0.000862345   494: -0.000143724   495: -0.000210845   496: -1.13502e-19   503: -0.000179357   504: -9.74088e-20   505: -0.000711995   506: -0.000118666   527: -0.000799371   528: -0.000133229   539: -0.000960675   540: 0.000160112   541: -0.00089334   542: 0.00014889   549: -0.000235825   550: -1.18585e-19   677: 0.000146885   678: 0.000119572   679: 0.00011776   683: 0.000163008   690: 0.000140563   692: 0.000157217
Row 85:   76: 0.00341371   77: 0.00383589   81: 0.00381043   83: 0.00417732   85: 0.0235707   87: 0.0041943   88: 0.004139   507: -0.000171432   508: -5.0822e-21   509: -0.000169938   510: -9.23266e-20   511: -0.000682741   512: -0.00011379   513: -0.000212157   514: -8.47033e-21   515: -0.000767179   516: -0.000127863   529: -0.000762086   530: -0.000127014   531: -0.000211105   532: -1.14349e-19   535: -0.000835464   536: -0.000139244   537: -0.000205575   538: -6.77626e-21   543: -0.00083886   544: 0.00013981   545: -0.000827801   546: 0.000137967   551: -0.000208325   552: 1.0842e-19   680: 0.000114288   681: 0.000141438   689: 0.000113292   693: 0.00013705   694: 0.000140737   696: 0.000138883
Row 86:   72: 0.00490268   78: 0.00428471   79: 0.00458141   82: 0.00461862   84: 0.00480337   86: 0.0330992   87: 0.00500395   88: 0.00490444   483: -0.000245756   484: -6.77626e-21   485: -0.000244512   486: -1.32984e-19   487: -0.000980536   488: -0.000163423   517: -0.000212365   518: -6.77626e-21   519: -0.000216107   520: -1.17738e-19   521: -0.000856943   522: -0.000142824   523: -0.000916281   524: -0.000152714   525: -0.000245776   526: -5.0822e-21   533: -0.000923725   534: -0.000153954   539: -0.000960675   540: -0.000160112   541: -0.000235825   542: -1.28749e-19   547: -0.00100079   548: 0.000166798   549: -0.000980887   550: 0.000163481   551: -0.000254619   552: -1.25361e-19   682: 0.000163837   683: 0.000163008   684: 0.000144071   685: 0.000141576   687: 0.000163851   692: 0.000157217   695: 0.000169746
Row 87:   74: 0.00446814   79: 0.00472116   81: 0.00431579   85: 0.0041943   86: 0.00500395   87: 0.0273328   88: 0.00462944   497: -0.00022634   498: -1.23667e-19   499: -0.000220474   500: -5.0822e-21   501: -0.000893629   502: -0.000148938   523: -0.000245776   524: -1.34678e-19   525: -0.000944233   526: -0.000157372   529: -0.000211105   530: -5.0822e-21   531: -0.000863158   532: -0.00014386   543: -0.00083886   544: -0.00013981   545: -0.000208325   546: -6.77626e-21   547: -0.00100079   548: -0.000166798   549: -0.000254619   550: -1.38913e-19   551: -0.000925887   552: 0.000154315   686: 0.000150894   687: 0.000163851   688: 0.000146983   694: 0.000140737   695: 0.000169746   696: 0.000138883
Row 88:   73: 0.00435514   83: 0.00430245   84: 0.0044667   85: 0.004139   86: 0.00490444   87: 0.00462944   88: 0.0267972   491: -0.00022467   492: -1.2282e-19   493: -0.000210845   494: -6.77626e-21   495: -0.000871029   496: -0.000145171   535: -0.000205575   536: -1.13502e-19   537: -0.00086049   538: -0.000143415   539: -0.000235825   540: -1.01644e-20   541: -0.00089334   542: -0.00014889   543: -0.000208325   544: -1.13502e-19   545: -0.000827801   546: -0.000137967   547: -0.000254619   548: -5.0822e-21   549: -0.000980887   550: -0.000163481   551: -0.000925887   552: -0.000154315   690: 0.000140563   691: 0.00014978   692: 0.000157217   693: 0.00013705   695: 0.000169746   696: 0.000138883
Row 89:   0: -0.000520833   4: -0.000520833   31: -0.000260417   89: 8.68056e-05   90: 4.23516e-22   91: 4.34028e-05   92: -6.2004e-06   107: 4.34028e-05   108: -6.2004e-06   553: -2.48016e-05
Row 90:   0: 8.68056e-05   4: -8.68056e-05   31: -3.38813e-21   89: 4.23516e-22   90: 9.3006e-06   91: -6.2004e-06   92: 3.1002e-06   107: 6.2004e-06   108: -3.1002e-06   553: -1.27963e-21
Row 91:   0: -0.000520833   4: -0.000260417   31: -0.000520833   89: 4.34028e-05   90: -6.2004e-06   91: 8.68056e-05   92: 2.00641e-20   107: 4.34028e-05   108: 6.2004e-06   553: -2.48016e-05
Row 92:   0: 8.68056e-05   4: -1.42302e-19   31: -8.68056e-05   89: -6.2004e-06   90: 3.1002e-06   91: 2.00641e-20   92: 9.3006e-06   107: 6.2004e-06   108: 3.1002e-06   553: -1.11173e-20
Row 93:   1: -0.000520833   10: -0.000520833   11: -0.000260417   93: 8.68056e-05   94: 2.00641e-20   95: 4.34028e-05   96: -6.2004e-06   141: 4.34028e-05   142: -6.2004e-06   557: -2.48016e-05
Row 94:   1: 8.68056e-05   10: -8.68056e-05   11: -1.42302e-19   93: 2.00641e-20   94: 9.3006e-06   95: -6.2004e-06   96: 3.1002e-06   141: 6.2004e-06   142: -3.1002e-06   557: -1.13291e-20
Row 95:   1: -0.000520833   10: -0.000260417   11: -0.000520833   93: 4.34028e-05   94: -6.2004e-06   95: 8.68056e-05   96: 4.23516e-22   141: 4.34028e-05   142: 6.2004e-06   557: -2.48016e-05
Row 96:   1: 8.68056e-05   10: -3.38813e-21   11: -8.68056e-05   93: -6.2004e-06   94: 3.1002e-06   95: 4.23516e-22   96: 9.3006e-06   141: 6.2004e-06   142: 3.1002e-06   557: -1.50092e-21
Row 97:   2: -0.000520833   17: -0.000520833   18: -0.000260417   97: 8.68056e-05   98: 2.00641e-20   99: 4.34028e-05   100: -6.2004e-06   181: 4.34028e-05   182: -6.2004e-06   561: -2.48016e-05
Row 98:   2: 8.68056e-05   17: -8.68056e-05   18: -1.42302e-19   97: 2.00641e-20   98: 9.3006e-06   99: -6.2004e-06   100: 3.1002e-06   181: 6.2004e-06   182: -3.1002e-06   561: -1.13291e-20
Row 99:   2: -0.000520833   17: -0.000260417   18: -0.000520833   97: 4.34028e-05   98: -6.2004e-06   99: 8.68056e-05   100: 4.23516e-22   181: 4.34028e-05   182: 6.2004e-06   561: -2.48016e-05
Row 100:   2: 8.68056e-05   17: -3.38813e-21   18: -8.68056e-05   97: -6.2004e-06   98: 3.1002e-06   99: 4.23516e-22   100: 9.3006e-06   181: 6.2004e-06   182: 3.1002e-06   561: -1.50092e-21
Row 101:   3: -0.000520833   24: -0.000520833   25: -0.000260417   101: 8.68056e-05   102: 2.00641e-20   103: 4.34028e-05   104: -6.2004e-06   221: 4.34028e-05   222: -6.2004e-06   565: -2.48016e-05
Row 102:   3: 8.68056e-05   24: -8.68056e-05   25: -1.42302e-19   101: 2.00641e-20   102: 9.3006e-06   103: -6.2004e-06   104: 3.1002e-06   221: 6.2004e-06   222: -3.1002e-06   565: -1.13291e-20
Row 103:   3: -0.000520833   24: -0.000260417   25: -0.000520833   101: 4.34028e-05   102: -6.2004e-06   103: 8.68056e-05   104: 4.23516e-22   221: 4.34028e-05   222: 6.2004e-06   565: -2.48016e-05
Row 104:   3: 8.68056e-05   24: -3.38813e-21   25: -8.68056e-05   101: -6.2004e-06   102: 3.1002e-06   103: 4.23516e-22   104: 9.3006e-06   221: 6.2004e-06   222: 3.1002e-06   565: -1.50092e-21
Row 105:   4: -0.000459656   5: -0.000459656   32: -0.000229828   105: 7.66094e-05   106: 0   109: 3.83047e-05   110: -5.4721e-06   113: 3.83047e-05   114: -5.4721e-06   554: -2.18884e-05
Row 106:   4: 7.66094e-05   5: -7.66094e-05   32: -5.0822e-21   105: 0   106: 8.20815e-06   109: -5.4721e-06   110: 2.73605e-06   113: 5.4721e-06   114: -2.73605e-06   554: -1.01322e-21
Row 107:   0: -0.000260417   4: -0.00117772   31: -0.00117772   32: -0.000328444   89: 4.34028e-05   90: 6.2004e-06   91: 4.34028e-05   92: 6.2004e-06   107: 0.000196287   108: 4.7328e-20   109: 5.47406e-05   110: -7.82009e-06   261: 5.47406e-05   262: -7.82009e-06   553: -2.48016e-05   569: -3.12803e-05
Row 108:   0: -1.28749e-19   4: 0.000196287   31: -0.000196287   32: -1.81265e-19   89: -6.2004e-06   90: -3.1002e-06   91: 6.2004e-06   92: 3.1002e-06   107: 4.7328e-20   108: 2.10307e-05   109: -7.82009e-06   110: 3.91004e-06   261: 7.82009e-06   262: -3.91004e-06   553: -1.01644e-20   569: -1.46113e-20
Row 109:   4: -0.00111654   5: -0.000229828   31: -0.000328444   32: -0.00111654   105: 3.83047e-05   106: -5.4721e-06   107: 5.47406e-05   108: -7.82009e-06   109: 0.000186091   110: 1.70465e-20   113: 3.83047e-05   114: 5.4721e-06   261: 5.47406e-05   262: 7.82009e-06   554: -2.18884e-05   569: -3.12803e-05
Row 110:   4: 0.000186091   5: -1.24514e-19   31: -1.01644e-20   32: -0.000186091   105: -5.4721e-06   106: 2.73605e-06   107: -7.82009e-06   108: 3.91004e-06   109: 1.70465e-20   110: 1.99383e-05   113: 5.4721e-06   114: 2.73605e-06   261: 7.82009e-06   262: 3.91004e-06   554: -9.95264e-21   569: -1.60029e-21
Row 111:   5: -0.000471641   6: -0.000471641   44: -0.000235821   111: 7.86068e-05   112: 4.23516e-22   115: 3.93034e-05   116: -5.61477e-06   121: 3.93034e-05   122: -5.61477e-06   573: -2.24591e-05
Row 112:   5: 7.86068e-05   6: -7.86068e-05   44: -8.47033e-21   111: 4.23516e-22   112: 8.42216e-06   115: -5.61477e-06   116: 2.80739e-06   121: 5.61477e-06   122: -2.80739e-06   573: -1.05159e-21
Row 113:   4: -0.000229828   5: -0.000950513   32: -0.000950513   44: -0.000245428   105: 3.83047e-05   106: 5.4721e-06   109: 3.83047e-05   110: 5.4721e-06   113: 0.000158419   114: 3.71106e-20   115: 4.09047e-05   116: -5.84353e-06   265: 4.09047e-05   266: -5.84353e-06   554: -2.18884e-05   584: -2.33741e-05
Row 114:   4: -1.15196e-19   5: 0.000158419   32: -0.000158419   44: -1.35525e-19   105: -5.4721e-06   106: -2.73605e-06   109: 5.4721e-06   110: 2.73605e-06   113: 3.71106e-20   114: 1.69734e-05   115: -5.84353e-06   116: 2.92177e-06   265: 5.84353e-06   266: -2.92177e-06   554: -8.89385e-21   584: -1.0482e-20
Row 115:   5: -0.000962498   6: -0.000235821   32: -0.000245428   44: -0.000962498   111: 3.93034e-05   112: -5.61477e-06   113: 4.09047e-05   114: -5.84353e-06   115: 0.000160416   116: 1.86877e-20   121: 3.93034e-05   122: 5.61477e-06   265: 4.09047e-05   266: 5.84353e-06   573: -2.24591e-05   584: -2.33741e-05
Row 116:   5: 0.000160416   6: -1.27902e-19   32: -5.0822e-21   44: -0.000160416   111: -5.61477e-06   112: 2.80739e-06   113: -5.84353e-06   114: 2.92177e-06   115: 1.86877e-20   116: 1.71875e-05   121: 5.61477e-06   122: 2.80739e-06   265: 5.84353e-06   266: 2.92177e-06   573: -9.95264e-21   584: -1.31778e-21
Row 117:   6: -0.000451771   7: -0.000451771   33: -0.000225885   117: 7.52951e-05   118: -4.23516e-22   119: 3.76476e-05   120: -5.37822e-06   125: 3.76476e-05   126: -5.37822e-06   555: -2.15129e-05
Row 118:   6: 7.52951e-05   7: -7.52951e-05   33: -8.47033e-21   117: -4.23516e-22   118: 8.06733e-06   119: -5.37822e-06   120: 2.68911e-06   125: 5.37822e-06   126: -2.68911e-06   555: -8.80202e-22
Row 119:   6: -0.000928575   7: -0.000225885   33: -0.000928575   44: -0.000238402   117: 3.76476e-05   118: -5.37822e-06   119: 0.000154763   120: 1.64113e-20   121: 3.97337e-05   122: -5.67624e-06   125: 3.76476e-05   126: 5.37822e-06   271: 3.97337e-05   272: -5.67624e-06   555: -2.15129e-05   582: -2.2705e-05
Row 120:   6: 0.000154763   7: -1.2282e-19   33: -0.000154763   44: -1.01644e-20   117: -5.37822e-06   118: 2.68911e-06   119: 1.64113e-20   120: 1.65817e-05   121: -5.67624e-06   122: 2.83812e-06   125: 5.37822e-06   126: 2.68911e-06   271: 5.67624e-06   272: -2.83812e-06   555: -9.84676e-21   582: -1.05341e-21
Row 121:   5: -0.000235821   6: -0.000948446   33: -0.000238402   44: -0.000948446   111: 3.93034e-05   112: 5.61477e-06   115: 3.93034e-05   116: 5.61477e-06   119: 3.97337e-05   120: -5.67624e-06   121: 0.000158074   122: 3.4993e-20   271: 3.97337e-05   272: 5.67624e-06   573: -2.24591e-05   582: -2.2705e-05
Row 122:   5: -1.18585e-19   6: 0.000158074   33: -1.30443e-19   44: -0.000158074   111: -5.61477e-06   112: -2.80739e-06   115: 5.61477e-06   116: 2.80739e-06   119: -5.67624e-06   120: 2.83812e-06   121: 3.4993e-20   122: 1.69365e-05   271: 5.67624e-06   272: 2.83812e-06   573: -9.21148e-21   582: -1.01644e-20
Row 123:   7: -0.000457033   8: -0.000457033   45: -0.000228517   123: 7.61722e-05   124: 0   127: 3.80861e-05   128: -5.44087e-06   133: 3.80861e-05   134: -5.44087e-06   574: -2.17635e-05
Row 124:   7: 7.61722e-05   8: -7.61722e-05   45: -3.38813e-21   123: 0   124: 8.16131e-06   127: -5.44087e-06   128: 2.72044e-06   133: 5.44087e-06   134: -2.72044e-06   574: -1.0179e-21
Row 125:   6: -0.000225885   7: -0.000911126   33: -0.000911126   45: -0.000229678   117: 3.76476e-05   118: 5.37822e-06   119: 3.76476e-05   120: 5.37822e-06   125: 0.000151854   126: 3.62107e-20   127: 3.82796e-05   128: -5.46852e-06   273: 3.82796e-05   274: -5.46852e-06   555: -2.15129e-05   589: -2.18741e-05
Row 126:   6: -1.15196e-19   7: 0.000151854   33: -0.000151854   45: -1.24514e-19   117: -5.37822e-06   118: -2.68911e-06   119: 5.37822e-06   120: 2.68911e-06   125: 3.62107e-20   126: 1.62701e-05   127: -5.46852e-06   128: 2.73426e-06   273: 5.46852e-06   274: -2.73426e-06   555: -8.89385e-21   589: -9.95264e-21
Row 127:   7: -0.000916389   8: -0.000228517   33: -0.000229678   45: -0.000916389   123: 3.80861e-05   124: -5.44087e-06   125: 3.82796e-05   126: -5.46852e-06   127: 0.000152731   128: 1.70995e-20   133: 3.80861e-05   134: 5.44087e-06   273: 3.82796e-05   274: 5.46852e-06   574: -2.17635e-05   589: -2.18741e-05
Row 128:   7: 0.000152731   8: -1.23667e-19   33: -8.47033e-21   45: -0.000152731   123: -5.44087e-06   124: 2.72044e-06   125: -5.46852e-06   126: 2.73426e-06   127: 1.70995e-20   128: 1.63641e-05   133: 5.44087e-06   134: 2.72044e-06   273: 5.46852e-06   274: 2.73426e-06   574: -9.95264e-21   589: -1.2278e-21
Row 129:   8: -0.000474754   9: -0.000474754   34: -0.000237377   129: 7.91257e-05   130: -4.23516e-22   131: 3.95628e-05   132: -5.65183e-06   137: 3.95628e-05   138: -5.65183e-06   556: -2.26073e-05
Row 130:   8: 7.91257e-05   9: -7.91257e-05   34: -5.0822e-21   129: -4.23516e-22   130: 8.47775e-06   131: -5.65183e-06   132: 2.82592e-06   137: 5.65183e-06   138: -2.82592e-06   556: -1.21399e-21
Row 131:   8: -0.000931996   9: -0.000237377   34: -0.000931996   45: -0.000228621   129: 3.95628e-05   130: -5.65183e-06   131: 0.000155333   132: 1.81053e-20   133: 3.81035e-05   134: -5.44336e-06   137: 3.95628e-05   138: 5.65183e-06   279: 3.81035e-05   280: -5.44336e-06   556: -2.26073e-05   578: -2.17735e-05
Row 132:   8: 0.000155333   9: -1.29596e-19   34: -0.000155333   45: -3.38813e-21   129: -5.65183e-06   130: 2.82592e-06   131: 1.81053e-20   132: 1.66428e-05   133: -5.44336e-06   134: 2.72168e-06   137: 5.65183e-06   138: 2.82592e-06   279: 5.44336e-06   280: -2.72168e-06   556: -1.01644e-20   578: -9.57355e-22
Row 133:   7: -0.000228517   8: -0.000914276   34: -0.000228621   45: -0.000914276   123: 3.80861e-05   124: 5.44087e-06   127: 3.80861e-05   128: 5.44087e-06   131: 3.81035e-05   132: -5.44336e-06   133: 0.000152379   134: 3.62107e-20   279: 3.81035e-05   280: 5.44336e-06   574: -2.17635e-05   578: -2.17735e-05
Row 134:   7: -1.15196e-19   8: 0.000152379   34: -1.2282e-19   45: -0.000152379   123: -5.44087e-06   124: -2.72044e-06   127: 5.44087e-06   128: 2.72044e-06   131: -5.44336e-06   132: 2.72168e-06   133: 3.62107e-20   134: 1.63264e-05   279: 5.44336e-06   280: 2.72168e-06   574: -8.68209e-21   578: -9.95264e-21
Row 135:   9: -0.000446635   10: -0.000446635   46: -0.000223318   135: 7.44392e-05   136: -4.23516e-22   139: 3.72196e-05   140: -5.31709e-06   145: 3.72196e-05   146: -5.31709e-06   575: -2.12683e-05
Row 136:   9: 7.44392e-05   10: -7.44392e-05   46: -6.77626e-21   135: -4.23516e-22   136: 7.97563e-06   139: -5.31709e-06   140: 2.65854e-06   145: 5.31709e-06   146: -2.65854e-06   575: -9.74759e-22
Row 137:   8: -0.000237377   9: -0.000883358   34: -0.000883358   46: -0.000204302   129: 3.95628e-05   130: 5.65183e-06   131: 3.95628e-05   132: 5.65183e-06   137: 0.000147226   138: 3.45695e-20   139: 3.40504e-05   140: -4.86434e-06   281: 3.40504e-05   282: -4.86434e-06   556: -2.26073e-05   590: -1.94574e-05
Row 138:   8: -1.25361e-19   9: 0.000147226   34: -0.000147226   46: -1.10961e-19   129: -5.65183e-06   130: -2.82592e-06   131: 5.65183e-06   132: 2.82592e-06   137: 3.45695e-20   138: 1.57743e-05   139: -4.86434e-06   140: 2.43217e-06   281: 4.86434e-06   282: -2.43217e-06   556: -9.42324e-21   590: -8.78797e-21
Row 139:   9: -0.00085524   10: -0.000223318   34: -0.000204302   46: -0.00085524   135: 3.72196e-05   136: -5.31709e-06   137: 3.40504e-05   138: -4.86434e-06   139: 0.00014254   140: 1.78406e-20   145: 3.72196e-05   146: 5.31709e-06   281: 3.40504e-05   282: 4.86434e-06   575: -2.12683e-05   590: -1.94574e-05
Row 140:   9: 0.00014254   10: -1.2282e-19   34: -3.38813e-21   46: -0.00014254   135: -5.31709e-06   136: 2.65854e-06   137: -4.86434e-06   138: 2.43217e-06   139: 1.78406e-20   140: 1.52721e-05   145: 5.31709e-06   146: 2.65854e-06   281: 4.86434e-06   282: 2.43217e-06   575: -9.52912e-21   590: -9.5929e-22
Row 141:   1: -0.000260417   10: -0.00118685   11: -0.00118685   35: -0.000333008   93: 4.34028e-05   94: 6.2004e-06   95: 4.34028e-05   96: 6.2004e-06   141: 0.000197808   142: -2.28699e-20   143: 5.55014e-05   144: -7.92876e-06   149: 5.55014e-05   150: -7.92876e-06   557: -2.48016e-05   570: -3.17151e-05
Row 142:   1: 1.28749e-19   10: 0.000197808   11: -0.000197808   35: -1.01644e-20   93: -6.2004e-06   94: -3.1002e-06   95: 6.2004e-06   96: 3.1002e-06   141: -2.28699e-20   142: 2.11937e-05   143: -7.92876e-06   144: 3.96438e-06   149: 7.92876e-06   150: -3.96438e-06   557: 1.03762e-20   570: -1.59924e-21
Row 143:   10: -0.00119083   11: -0.000333008   35: -0.00119083   46: -0.000262408   141: 5.55014e-05   142: -7.92876e-06   143: 0.000198472   144: 2.48816e-20   145: 4.37346e-05   146: -6.2478e-06   149: 5.55014e-05   150: 7.92876e-06   287: 4.37346e-05   288: -6.2478e-06   570: -3.17151e-05   609: -2.49912e-05
Row 144:   10: 0.000198472   11: -1.82959e-19   35: -0.000198472   46: -8.47033e-21   141: -7.92876e-06   142: 3.96438e-06   143: 2.48816e-20   144: 2.12649e-05   145: -6.2478e-06   146: 3.1239e-06   149: 7.92876e-06   150: 3.96438e-06   287: 6.2478e-06   288: -3.1239e-06   570: -1.41878e-20   609: -1.2154e-21
Row 145:   9: -0.000223318   10: -0.000971451   35: -0.000262408   46: -0.000971451   135: 3.72196e-05   136: 5.31709e-06   139: 3.72196e-05   140: 5.31709e-06   143: 4.37346e-05   144: -6.2478e-06   145: 0.000161908   146: 3.74283e-20   287: 4.37346e-05   288: 6.2478e-06   575: -2.12683e-05   609: -2.49912e-05
Row 146:   9: -1.11808e-19   10: 0.000161908   35: -1.42302e-19   46: -0.000161908   135: -5.31709e-06   136: -2.65854e-06   139: 5.31709e-06   140: 2.65854e-06   143: -6.2478e-06   144: 3.1239e-06   145: 3.74283e-20   146: 1.73473e-05   287: 6.2478e-06   288: 3.1239e-06   575: -8.99973e-21   609: -1.11173e-20
Row 147:   11: -0.000460405   12: -0.000460405   35: -0.000230202   147: 7.67341e-05   148: -8.47033e-22   149: 3.83671e-05   150: -5.48101e-06   153: 3.83671e-05   154: -5.48101e-06   558: -2.1924e-05
Row 148:   11: 7.67341e-05   12: -7.67341e-05   35: -5.0822e-21   147: -8.47033e-22   148: 8.22151e-06   149: -5.48101e-06   150: 2.7405e-06   153: 5.48101e-06   154: -2.7405e-06   558: -9.46847e-22
Row 149:   10: -0.000333008   11: -0.00112642   12: -0.000230202   35: -0.00112642   141: 5.55014e-05   142: 7.92876e-06   143: 5.55014e-05   144: 7.92876e-06   147: 3.83671e-05   148: -5.48101e-06   149: 0.000187737   150: 4.19281e-20   153: 3.83671e-05   154: 5.48101e-06   558: -2.1924e-05   570: -3.17151e-05
Row 150:   10: -1.69407e-19   11: 0.000187737   12: -1.23667e-19   35: -0.000187737   141: -7.92876e-06   142: -3.96438e-06   143: 7.92876e-06   144: 3.96438e-06   147: -5.48101e-06   148: 2.7405e-06   149: 4.19281e-20   150: 2.01147e-05   153: 5.48101e-06   154: 2.7405e-06   558: -9.95264e-21   570: -1.33408e-20
Row 151:   12: -0.000474192   13: -0.000474192   47: -0.000237096   151: 7.9032e-05   152: 0   155: 3.9516e-05   156: -5.64515e-06   161: 3.9516e-05   162: -5.64515e-06   576: -2.25806e-05
Row 152:   12: 7.9032e-05   13: -7.9032e-05   47: -5.0822e-21   151: 0   152: 8.46772e-06   155: -5.64515e-06   156: 2.82257e-06   161: 5.64515e-06   162: -2.82257e-06   576: -1.10787e-21
Row 153:   11: -0.000230202   12: -0.000959226   35: -0.000959226   47: -0.000249411   147: 3.83671e-05   148: 5.48101e-06   149: 3.83671e-05   150: 5.48101e-06   153: 0.000159871   154: 3.48342e-20   155: 4.15684e-05   156: -5.93835e-06   289: 4.15684e-05   290: -5.93835e-06   558: -2.1924e-05   602: -2.37534e-05
Row 154:   11: -1.18585e-19   12: 0.000159871   35: -0.000159871   47: -1.35525e-19   147: -5.48101e-06   148: -2.7405e-06   149: 5.48101e-06   150: 2.7405e-06   153: 3.48342e-20   154: 1.7129e-05   155: -5.93835e-06   156: 2.96917e-06   289: 5.93835e-06   290: -2.96917e-06   558: -8.99973e-21   602: -1.07997e-20
Row 155:   12: -0.000973014   13: -0.000237096   35: -0.000249411   47: -0.000973014   151: 3.9516e-05   152: -5.64515e-06   153: 4.15684e-05   154: -5.93835e-06   155: 0.000162169   156: 1.73642e-20   161: 3.9516e-05   162: 5.64515e-06   289: 4.15684e-05   290: 5.93835e-06   576: -2.25806e-05   602: -2.37534e-05
Row 156:   12: 0.000162169   13: -1.29596e-19   35: -6.77626e-21   47: -0.000162169   151: -5.64515e-06   152: 2.82257e-06   153: -5.93835e-06   154: 2.96917e-06   155: 1.73642e-20   156: 1.73752e-05   161: 5.64515e-06   162: 2.82257e-06   289: 5.93835e-06   290: 2.96917e-06   576: -1.0482e-20   602: -1.29252e-21
Row 157:   13: -0.000438961   14: -0.000438961   36: -0.00021948   157: 7.31601e-05   158: -4.23516e-22   159: 3.65801e-05   160: -5.22572e-06   165: 3.65801e-05   166: -5.22572e-06   559: -2.09029e-05
Row 158:   13: 7.31601e-05   14: -7.31601e-05   36: -6.77626e-21   157: -4.23516e-22   158: 7.83859e-06   159: -5.22572e-06   160: 2.61286e-06   165: 5.22572e-06   166: -2.61286e-06   559: -8.06128e-22
Row 159:   13: -0.000910182   14: -0.00021948   36: -0.000910182   47: -0.00023561   157: 3.65801e-05   158: -5.22572e-06   159: 0.000151697   160: 1.72583e-20   161: 3.92684e-05   162: -5.60977e-06   165: 3.65801e-05   166: 5.22572e-06   293: 3.92684e-05   294: -5.60977e-06   559: -2.09029e-05   588: -2.24391e-05
Row 160:   13: 0.000151697   14: -1.19432e-19   36: -0.000151697   47: -5.0822e-21   157: -5.22572e-06   158: 2.61286e-06   159: 1.72583e-20   160: 1.62532e-05   161: -5.60977e-06   162: 2.80489e-06   165: 5.22572e-06   166: 2.61286e-06   293: 5.60977e-06   294: -2.80489e-06   559: -9.31736e-21   588: -1.14258e-21
Row 161:   12: -0.000237096   13: -0.000945413   36: -0.00023561   47: -0.000945413   151: 3.9516e-05   152: 5.64515e-06   155: 3.9516e-05   156: 5.64515e-06   159: 3.92684e-05   160: -5.60977e-06   161: 0.000157569   162: 3.43048e-20   293: 3.92684e-05   294: 5.60977e-06   576: -2.25806e-05   588: -2.24391e-05
Row 162:   12: -1.18585e-19   13: 0.000157569   36: -1.28749e-19   47: -0.000157569   151: -5.64515e-06   152: -2.82257e-06   155: 5.64515e-06   156: 2.82257e-06   159: -5.60977e-06   160: 2.80489e-06   161: 3.43048e-20   162: 1.68824e-05   293: 5.60977e-06   294: 2.80489e-06   576: -9.42324e-21   588: -1.03762e-20
Row 163:   14: -0.000424997   15: -0.000424997   48: -0.000212498   163: 7.08328e-05   164: 0   167: 3.54164e-05   168: -5.05948e-06   173: 3.54164e-05   174: -5.05948e-06   577: -2.02379e-05
Row 164:   14: 7.08328e-05   15: -7.08328e-05   48: -3.38813e-21   163: 0   164: 7.58922e-06   167: -5.05948e-06   168: 2.52974e-06   173: 5.05948e-06   174: -2.52974e-06   577: -9.29052e-22
Row 165:   13: -0.00021948   14: -0.00087592   36: -0.00087592   48: -0.000218479   157: 3.65801e-05   158: 5.22572e-06   159: 3.65801e-05   160: 5.22572e-06   165: 0.000145987   166: 3.38284e-20   167: 3.64132e-05   168: -5.20189e-06   295: 3.64132e-05   296: -5.20189e-06   559: -2.09029e-05   591: -2.08076e-05
Row 166:   13: -1.11808e-19   14: 0.000145987   36: -0.000145987   48: -1.20279e-19   157: -5.22572e-06   158: -2.61286e-06   159: 5.22572e-06   160: 2.61286e-06   165: 3.38284e-20   166: 1.56414e-05   167: -5.20189e-06   168: 2.60095e-06   295: 5.20189e-06   296: -2.60095e-06   559: -8.47033e-21   591: -9.42324e-21
Row 167:   14: -0.000861955   15: -0.000212498   36: -0.000218479   48: -0.000861955   163: 3.54164e-05   164: -5.05948e-06   165: 3.64132e-05   166: -5.20189e-06   167: 0.000143659   168: 1.5776e-20   173: 3.54164e-05   174: 5.05948e-06   295: 3.64132e-05   296: 5.20189e-06   577: -2.02379e-05   591: -2.08076e-05
Row 168:   14: 0.000143659   15: -1.16891e-19   36: -5.0822e-21   48: -0.000143659   163: -5.05948e-06   164: 2.52974e-06   165: -5.20189e-06   166: 2.60095e-06   167: 1.5776e-20   168: 1.53921e-05   173: 5.05948e-06   174: 2.52974e-06   295: 5.20189e-06   296: 2.60095e-06   577: -8.99973e-21   591: -1.19931e-21
Row 169:   15: -0.000440949   16: -0.000440949   37: -0.000220475   169: 7.34916e-05   170: -4.23516e-22   171: 3.67458e-05   172: -5.2494e-06   177: 3.67458e-05   178: -5.2494e-06   560: -2.09976e-05
Row 170:   15: 7.34916e-05   16: -7.34916e-05   37: -6.77626e-21   169: -4.23516e-22   170: 7.87409e-06   171: -5.2494e-06   172: 2.6247e-06   177: 5.2494e-06   178: -2.6247e-06   560: -1.01694e-21
Row 171:   15: -0.000865943   16: -0.000220475   37: -0.000865943   48: -0.000212497   169: 3.67458e-05   170: -5.2494e-06   171: 0.000144324   172: 1.69936e-20   173: 3.54161e-05   174: -5.05945e-06   177: 3.67458e-05   178: 5.2494e-06   301: 3.54161e-05   302: -5.05945e-06   560: -2.09976e-05   597: -2.02378e-05
Row 172:   15: 0.000144324   16: -1.19432e-19   37: -0.000144324   48: -5.0822e-21   169: -5.2494e-06   170: 2.6247e-06   171: 1.69936e-20   172: 1.54633e-05   173: -5.05945e-06   174: 2.52972e-06   177: 5.2494e-06   178: 2.6247e-06   301: 5.05945e-06   302: -2.52972e-06   560: -9.21148e-21   597: -9.05794e-22
Row 173:   14: -0.000212498   15: -0.00084999   37: -0.000212497   48: -0.00084999   163: 3.54164e-05   164: 5.05948e-06   167: 3.54164e-05   168: 5.05948e-06   171: 3.54161e-05   172: -5.05945e-06   173: 0.000141665   174: 3.35107e-20   301: 3.54161e-05   302: 5.05945e-06   577: -2.02379e-05   597: -2.02378e-05
Row 174:   14: -1.0842e-19   15: 0.000141665   37: -1.16891e-19   48: -0.000141665   163: -5.05948e-06   164: -2.52974e-06   167: 5.05948e-06   168: 2.52974e-06   171: -5.05945e-06   172: 2.52972e-06   173: 3.35107e-20   174: 1.51784e-05   301: 5.05945e-06   302: 2.52972e-06   577: -8.04681e-21   597: -8.99973e-21
Row 175:   16: -0.00042868   17: -0.00042868   49: -0.00021434   175: 7.14466e-05   176: 4.23516e-22   179: 3.57233e-05   180: -5.10333e-06   185: 3.57233e-05   186: -5.10333e-06   579: -2.04133e-05
Row 176:   16: 7.14466e-05   17: -7.14466e-05   49: -5.0822e-21   175: 4.23516e-22   176: 7.65499e-06   179: -5.10333e-06   180: 2.55166e-06   185: 5.10333e-06   186: -2.55166e-06   579: -9.35689e-22
Row 177:   15: -0.000220475   16: -0.000821408   37: -0.000821408   49: -0.000190229   169: 3.67458e-05   170: 5.2494e-06   171: 3.67458e-05   172: 5.2494e-06   177: 0.000136901   178: 3.28755e-20   179: 3.17049e-05   180: -4.52927e-06   303: 3.17049e-05   304: -4.52927e-06   560: -2.09976e-05   592: -1.81171e-05
Row 178:   15: -1.15196e-19   16: 0.000136901   37: -0.000136901   49: -1.03338e-19   169: -5.2494e-06   170: -2.6247e-06   171: 5.2494e-06   172: 2.6247e-06   177: 3.28755e-20   178: 1.4668e-05   179: -4.52927e-06   180: 2.26463e-06   303: 4.52927e-06   304: -2.26463e-06   560: -8.78797e-21   592: -8.47033e-21
Row 179:   16: -0.000809138   17: -0.00021434   37: -0.000190229   49: -0.000809138   175: 3.57233e-05   176: -5.10333e-06   177: 3.17049e-05   178: -4.52927e-06   179: 0.000134856   180: 1.59348e-20   185: 3.57233e-05   186: 5.10333e-06   303: 3.17049e-05   304: 4.52927e-06   579: -2.04133e-05   592: -1.81171e-05
Row 180:   16: 0.000134856   17: -1.17738e-19   37: -5.0822e-21   49: -0.000134856   175: -5.10333e-06   176: 2.55166e-06   177: -4.52927e-06   178: 2.26463e-06   179: 1.59348e-20   180: 1.44489e-05   185: 5.10333e-06   186: 2.55166e-06   303: 4.52927e-06   304: 2.26463e-06   579: -9.31736e-21   592: -9.42087e-22
Row 181:   2: -0.000260417   17: -0.00117135   18: -0.00117135   38: -0.00032526   97: 4.34028e-05   98: 6.2004e-06   99: 4.34028e-05   100: 6.2004e-06   181: 0.000195225   182: -2.20229e-20   183: 5.42099e-05   184: -7.74428e-06   189: 5.42099e-05   190: -7.74428e-06   561: -2.48016e-05   571: -3.09771e-05
Row 182:   2: 1.28749e-19   17: 0.000195225   18: -0.000195225   38: -6.77626e-21   97: -6.2004e-06   98: -3.1002e-06   99: 6.2004e-06   100: 3.1002e-06   181: -2.20229e-20   182: 2.0917e-05   183: -7.74428e-06   184: 3.87214e-06   189: 7.74428e-06   190: -3.87214e-06   561: 1.03762e-20   571: -1.24845e-21
Row 183:   17: -0.00115669   18: -0.00032526   38: -0.00115669   49: -0.000253086   181: 5.42099e-05   182: -7.74428e-06   183: 0.000192782   184: 2.47757e-20   185: 4.21811e-05   186: -6.02587e-06   189: 5.42099e-05   190: 7.74428e-06   309: 4.21811e-05   310: -6.02587e-06   571: -3.09771e-05   611: -2.41035e-05
Row 184:   17: 0.000192782   18: -1.77877e-19   38: -0.000192782   49: -5.0822e-21   181: -7.74428e-06   182: 3.87214e-06   183: 2.47757e-20   184: 2.06552e-05   185: -6.02587e-06   186: 3.01293e-06   189: 7.74428e-06   190: 3.87214e-06   309: 6.02587e-06   310: -3.01293e-06   571: -1.41878e-20   611: -1.07568e-21
Row 185:   16: -0.00021434   17: -0.000934852   38: -0.000253086   49: -0.000934852   175: 3.57233e-05   176: 5.10333e-06   179: 3.57233e-05   180: 5.10333e-06   183: 4.21811e-05   184: -6.02587e-06   185: 0.000155809   186: 3.4993e-20   309: 4.21811e-05   310: 6.02587e-06   579: -2.04133e-05   611: -2.41035e-05
Row 186:   16: -1.11808e-19   17: 0.000155809   38: -1.37219e-19   49: -0.000155809   175: -5.10333e-06   176: -2.55166e-06   179: 5.10333e-06   180: 2.55166e-06   183: -6.02587e-06   184: 3.01293e-06   185: 3.4993e-20   186: 1.66938e-05   309: 6.02587e-06   310: 3.01293e-06   579: -8.47033e-21   611: -1.09055e-20
Row 187:   18: -0.000457476   19: -0.000457476   38: -0.000228738   187: 7.62459e-05   188: 4.23516e-22   189: 3.8123e-05   190: -5.44614e-06   193: 3.8123e-05   194: -5.44614e-06   562: -2.17846e-05
Row 188:   18: 7.62459e-05   19: -7.62459e-05   38: -6.77626e-21   187: 4.23516e-22   188: 8.16921e-06   189: -5.44614e-06   190: 2.72307e-06   193: 5.44614e-06   194: -2.72307e-06   562: -1.20088e-21
Row 189:   17: -0.00032526   18: -0.00110799   19: -0.000228738   38: -0.00110799   181: 5.42099e-05   182: 7.74428e-06   183: 5.42099e-05   184: 7.74428e-06   187: 3.8123e-05   188: -5.44614e-06   189: 0.000184666   190: 4.25634e-20   193: 3.8123e-05   194: 5.44614e-06   562: -2.17846e-05   571: -3.09771e-05
Row 190:   17: -1.6263e-19   18: 0.000184666   19: -1.25361e-19   38: -0.000184666   181: -7.74428e-06   182: -3.87214e-06   183: 7.74428e-06   184: 3.87214e-06   187: -5.44614e-06   188: 2.72307e-06   189: 4.25634e-20   190: 1.97856e-05   193: 5.44614e-06   194: 2.72307e-06   562: -9.74088e-21   571: -1.27055e-20
Row 191:   19: -0.000477982   20: -0.000477982   50: -0.000238991   191: 7.96636e-05   192: 0   195: 3.98318e-05   196: -5.69026e-06   201: 3.98318e-05   202: -5.69026e-06   580: -2.2761e-05
Row 192:   19: 7.96636e-05   20: -7.96636e-05   50: -8.47033e-21   191: 0   192: 8.53538e-06   195: -5.69026e-06   196: 2.84513e-06   201: 5.69026e-06   202: -2.84513e-06   580: -9.75323e-22
Row 193:   18: -0.000228738   19: -0.000955432   38: -0.000955432   50: -0.000248978   187: 3.8123e-05   188: 5.44614e-06   189: 3.8123e-05   190: 5.44614e-06   193: 0.000159239   194: 3.5893e-20   195: 4.14964e-05   196: -5.92806e-06   311: 4.14964e-05   312: -5.92806e-06   562: -2.17846e-05   603: -2.37122e-05
Row 194:   18: -1.18585e-19   19: 0.000159239   38: -0.000159239   50: -1.35525e-19   187: -5.44614e-06   188: -2.72307e-06   189: 5.44614e-06   190: 2.72307e-06   193: 3.5893e-20   194: 1.70613e-05   195: -5.92806e-06   196: 2.96403e-06   311: 5.92806e-06   312: -2.96403e-06   562: -8.99973e-21   603: -1.06938e-20
Row 195:   19: -0.000975938   20: -0.000238991   38: -0.000248978   50: -0.000975938   191: 3.98318e-05   192: -5.69026e-06   193: 4.14964e-05   194: -5.92806e-06   195: 0.000162656   196: 1.8423e-20   201: 3.98318e-05   202: 5.69026e-06   311: 4.14964e-05   312: 5.92806e-06   580: -2.2761e-05   603: -2.37122e-05
Row 196:   19: 0.000162656   20: -1.29596e-19   38: -8.47033e-21   50: -0.000162656   191: -5.69026e-06   192: 2.84513e-06   193: -5.92806e-06   194: 2.96403e-06   195: 1.8423e-20   196: 1.74275e-05   201: 5.69026e-06   202: 2.84513e-06   311: 5.92806e-06   312: 2.96403e-06   580: -1.02703e-20   603: -1.32496e-21
Row 197:   20: -0.000465749   21: -0.000465749   39: -0.000232874   197: 7.76248e-05   198: 0   199: 3.88124e-05   200: -5.54463e-06   205: 3.88124e-05   206: -5.54463e-06   563: -2.21785e-05
Row 198:   20: 7.76248e-05   21: -7.76248e-05   39: -3.38813e-21   197: 0   198: 8.31694e-06   199: -5.54463e-06   200: 2.77231e-06   205: 5.54463e-06   206: -2.77231e-06   563: -1.22986e-21
Row 199:   20: -0.000956536   21: -0.000232874   39: -0.000956536   50: -0.000245394   197: 3.88124e-05   198: -5.54463e-06   199: 0.000159423   200: 1.65171e-20   201: 4.0899e-05   202: -5.84271e-06   205: 3.88124e-05   206: 5.54463e-06   315: 4.0899e-05   316: -5.84271e-06   563: -2.21785e-05   598: -2.33708e-05
Row 200:   20: 0.000159423   21: -1.26208e-19   39: -0.000159423   50: -6.77626e-21   197: -5.54463e-06   198: 2.77231e-06   199: 1.65171e-20   200: 1.7081e-05   201: -5.84271e-06   202: 2.92136e-06   205: 5.54463e-06   206: 2.77231e-06   315: 5.84271e-06   316: -2.92136e-06   563: -9.95264e-21   598: -9.25353e-22
Row 201:   19: -0.000238991   20: -0.000968769   39: -0.000245394   50: -0.000968769   191: 3.98318e-05   192: 5.69026e-06   195: 3.98318e-05   196: 5.69026e-06   199: 4.0899e-05   200: -5.84271e-06   201: 0.000161462   202: 3.68459e-20   315: 4.0899e-05   316: 5.84271e-06   580: -2.2761e-05   598: -2.33708e-05
Row 202:   19: -1.18585e-19   20: 0.000161462   39: -1.32137e-19   50: -0.000161462   191: -5.69026e-06   192: -2.84513e-06   195: 5.69026e-06   196: 2.84513e-06   199: -5.84271e-06   200: 2.92136e-06   201: 3.68459e-20   202: 1.72994e-05   315: 5.84271e-06   316: 2.92136e-06   580: -9.31736e-21   598: -1.05879e-20
Row 203:   21: -0.000464748   22: -0.000464748   51: -0.000232374   203: 7.7458e-05   204: -4.23516e-22   207: 3.8729e-05   208: -5.53272e-06   213: 3.8729e-05   214: -5.53272e-06   581: -2.21309e-05
Row 204:   21: 7.7458e-05   22: -7.7458e-05   51: -5.0822e-21   203: -4.23516e-22   204: 8.29908e-06   207: -5.53272e-06   208: 2.76636e-06   213: 5.53272e-06   214: -2.76636e-06   581: -9.86042e-22
Row 205:   20: -0.000232874   21: -0.000937265   39: -0.000937265   51: -0.000235758   197: 3.88124e-05   198: 5.54463e-06   199: 3.88124e-05   200: 5.54463e-06   205: 0.000156211   206: 3.63695e-20   207: 3.9293e-05   208: -5.61328e-06   317: 3.9293e-05   318: -5.61328e-06   563: -2.21785e-05   593: -2.24531e-05
Row 206:   20: -1.21973e-19   21: 0.000156211   39: -0.000156211   51: -1.29596e-19   197: -5.54463e-06   198: -2.77231e-06   199: 5.54463e-06   200: 2.77231e-06   205: 3.63695e-20   206: 1.67369e-05   207: -5.61328e-06   208: 2.80664e-06   317: 5.61328e-06   318: -2.80664e-06   563: -9.1056e-21   593: -1.01644e-20
Row 207:   21: -0.000936264   22: -0.000232374   39: -0.000235758   51: -0.000936264   203: 3.8729e-05   204: -5.53272e-06   205: 3.9293e-05   206: -5.61328e-06   207: 0.000156044   208: 1.77348e-20   213: 3.8729e-05   214: 5.53272e-06   317: 3.9293e-05   318: 5.61328e-06   581: -2.21309e-05   593: -2.24531e-05
Row 208:   21: 0.000156044   22: -1.27055e-19   39: -8.47033e-21   51: -0.000156044   203: -5.53272e-06   204: 2.76636e-06   205: -5.61328e-06   206: 2.80664e-06   207: 1.77348e-20   208: 1.6719e-05   213: 5.53272e-06   214: 2.76636e-06   317: 5.61328e-06   318: 2.80664e-06   581: -1.01644e-20   593: -1.14921e-21
Row 209:   22: -0.000470467   23: -0.000470467   40: -0.000235233   209: 7.84111e-05   210: 4.23516e-22   211: 3.92056e-05   212: -5.60079e-06   217: 3.92056e-05   218: -5.60079e-06   564: -2.24032e-05
Row 210:   22: 7.84111e-05   23: -7.84111e-05   40: -6.77626e-21   209: 4.23516e-22   210: 8.40119e-06   211: -5.60079e-06   212: 2.8004e-06   217: 5.60079e-06   218: -2.8004e-06   564: -1.12026e-21
Row 211:   22: -0.000932321   23: -0.000235233   40: -0.000932321   51: -0.000230927   209: 3.92056e-05   210: -5.60079e-06   211: 0.000155387   212: 1.81053e-20   213: 3.84879e-05   214: -5.49827e-06   217: 3.92056e-05   218: 5.60079e-06   323: 3.84879e-05   324: -5.49827e-06   564: -2.24032e-05   599: -2.19931e-05
Row 212:   22: 0.000155387   23: -1.27902e-19   40: -0.000155387   51: -5.0822e-21   209: -5.60079e-06   210: 2.8004e-06   211: 1.81053e-20   212: 1.66486e-05   213: -5.49827e-06   214: 2.74914e-06   217: 5.60079e-06   218: 2.8004e-06   323: 5.49827e-06   324: -2.74914e-06   564: -9.84676e-21   599: -8.98413e-22
Row 213:   21: -0.000232374   22: -0.000926603   40: -0.000230927   51: -0.000926603   203: 3.8729e-05   204: 5.53272e-06   207: 3.8729e-05   208: 5.53272e-06   211: 3.84879e-05   212: -5.49827e-06   213: 0.000154434   214: 3.49401e-20   323: 3.84879e-05   324: 5.49827e-06   581: -2.21309e-05   599: -2.19931e-05
Row 214:   21: -1.18585e-19   22: 0.000154434   40: -1.27055e-19   51: -0.000154434   203: -5.53272e-06   204: -2.76636e-06   207: 5.53272e-06   208: 2.76636e-06   211: -5.49827e-06   212: 2.74914e-06   213: 3.49401e-20   214: 1.65465e-05   323: 5.49827e-06   324: 2.74914e-06   581: -9.42324e-21   599: -9.95264e-21
Row 215:   23: -0.000439017   24: -0.000439017   52: -0.000219508   215: 7.31695e-05   216: -4.23516e-22   219: 3.65847e-05   220: -5.22639e-06   225: 3.65847e-05   226: -5.22639e-06   583: -2.09056e-05
Row 216:   23: 7.31695e-05   24: -7.31695e-05   52: -3.38813e-21   215: -4.23516e-22   216: 7.83959e-06   219: -5.22639e-06   220: 2.6132e-06   225: 5.22639e-06   226: -2.6132e-06   583: -9.02727e-22
Row 217:   22: -0.000235233   23: -0.000872247   40: -0.000872247   52: -0.00020089   209: 3.92056e-05   210: 5.60079e-06   211: 3.92056e-05   212: 5.60079e-06   217: 0.000145374   218: 3.36696e-20   219: 3.34817e-05   220: -4.7831e-06   325: 3.34817e-05   326: -4.7831e-06   564: -2.24032e-05   594: -1.91324e-05
Row 218:   22: -1.21973e-19   23: 0.000145374   40: -0.000145374   52: -1.09267e-19   209: -5.60079e-06   210: -2.8004e-06   211: 5.60079e-06   212: 2.8004e-06   217: 3.36696e-20   218: 1.55758e-05   219: -4.7831e-06   220: 2.39155e-06   325: 4.7831e-06   326: -2.39155e-06   564: -9.31736e-21   594: -8.89385e-21
Row 219:   23: -0.000840797   24: -0.000219508   40: -0.00020089   52: -0.000840797   215: 3.65847e-05   216: -5.22639e-06   217: 3.34817e-05   218: -4.7831e-06   219: 0.000140133   220: 1.65171e-20   225: 3.65847e-05   226: 5.22639e-06   325: 3.34817e-05   326: 4.7831e-06   583: -2.09056e-05   594: -1.91324e-05
Row 220:   23: 0.000140133   24: -1.19432e-19   40: -3.38813e-21   52: -0.000140133   215: -5.22639e-06   216: 2.6132e-06   217: -4.7831e-06   218: 2.39155e-06   219: 1.65171e-20   220: 1.50142e-05   225: 5.22639e-06   226: 2.6132e-06   325: 4.7831e-06   326: 2.39155e-06   583: -9.31736e-21   594: -1.13497e-21
Row 221:   3: -0.000260417   24: -0.00117183   25: -0.00117183   41: -0.000325499   101: 4.34028e-05   102: 6.2004e-06   103: 4.34028e-05   104: 6.2004e-06   221: 0.000195305   222: -2.03288e-20   223: 5.42498e-05   224: -7.74997e-06   229: 5.42498e-05   230: -7.74997e-06   565: -2.48016e-05   572: -3.09999e-05
Row 222:   3: 1.28749e-19   24: 0.000195305   25: -0.000195305   41: -1.01644e-20   101: -6.2004e-06   102: -3.1002e-06   103: 6.2004e-06   104: 3.1002e-06   221: -2.03288e-20   222: 2.09255e-05   223: -7.74997e-06   224: 3.87498e-06   229: 7.74997e-06   230: -3.87498e-06   565: 1.03762e-20   572: -1.65219e-21
Row 223:   24: -0.00116562   25: -0.000325499   41: -0.00116562   52: -0.00025731   221: 5.42498e-05   222: -7.74997e-06   223: 0.000194269   224: 2.47757e-20   225: 4.2885e-05   226: -6.12642e-06   229: 5.42498e-05   230: 7.74997e-06   331: 4.2885e-05   332: -6.12642e-06   572: -3.09999e-05   619: -2.45057e-05
Row 224:   24: 0.000194269   25: -1.77877e-19   41: -0.000194269   52: -3.38813e-21   221: -7.74997e-06   222: 3.87498e-06   223: 2.47757e-20   224: 2.08146e-05   225: -6.12642e-06   226: 3.06321e-06   229: 7.74997e-06   230: 3.87498e-06   331: 6.12642e-06   332: -3.06321e-06   572: -1.3976e-20   619: -1.11427e-21
Row 225:   23: -0.000219508   24: -0.000953636   41: -0.00025731   52: -0.000953636   215: 3.65847e-05   216: 5.22639e-06   219: 3.65847e-05   220: 5.22639e-06   223: 4.2885e-05   224: -6.12642e-06   225: 0.000158939   226: 3.69518e-20   331: 4.2885e-05   332: 6.12642e-06   583: -2.09056e-05   619: -2.45057e-05
Row 226:   23: -1.11808e-19   24: 0.000158939   41: -1.42302e-19   52: -0.000158939   215: -5.22639e-06   216: -2.6132e-06   219: 5.22639e-06   220: 2.6132e-06   223: -6.12642e-06   224: 3.06321e-06   225: 3.69518e-20   226: 1.70292e-05   331: 6.12642e-06   332: 3.06321e-06   583: -8.47033e-21   619: -1.11173e-20
Row 227:   25: -0.000453569   26: -0.000453569   41: -0.000226785   227: 7.55949e-05   228: 0   229: 3.77974e-05   230: -5.39964e-06   233: 3.77974e-05   234: -5.39964e-06   566: -2.15985e-05
Row 228:   25: 7.55949e-05   26: -7.55949e-05   41: -8.47033e-21   227: 0   228: 8.09945e-06   229: -5.39964e-06   230: 2.69982e-06   233: 5.39964e-06   234: -2.69982e-06   566: -1.02997e-21
Row 229:   24: -0.000325499   25: -0.00110457   26: -0.000226785   41: -0.00110457   221: 5.42498e-05   222: 7.74997e-06   223: 5.42498e-05   224: 7.74997e-06   227: 3.77974e-05   228: -5.39964e-06   229: 0.000184094   230: 4.24575e-20   233: 3.77974e-05   234: 5.39964e-06   566: -2.15985e-05   572: -3.09999e-05
Row 230:   24: -1.69407e-19   25: 0.000184094   26: -1.2282e-19   41: -0.000184094   221: -7.74997e-06   222: -3.87498e-06   223: 7.74997e-06   224: 3.87498e-06   227: -5.39964e-06   228: 2.69982e-06   229: 4.24575e-20   230: 1.97244e-05   233: 5.39964e-06   234: 2.69982e-06   566: -9.635e-21   572: -1.24937e-20
Row 231:   26: -0.000456144   27: -0.000456144   53: -0.000228072   231: 7.60239e-05   232: -8.47033e-22   235: 3.8012e-05   236: -5.43028e-06   241: 3.8012e-05   242: -5.43028e-06   585: -2.17211e-05
Row 232:   26: 7.60239e-05   27: -7.60239e-05   53: -6.77626e-21   231: -8.47033e-22   232: 8.14542e-06   235: -5.43028e-06   236: 2.71514e-06   241: 5.43028e-06   242: -2.71514e-06   585: -9.56313e-22
Row 233:   25: -0.000226785   26: -0.000932388   41: -0.000932388   53: -0.00023941   227: 3.77974e-05   228: 5.39964e-06   229: 3.77974e-05   230: 5.39964e-06   233: 0.000155398   234: 3.54166e-20   235: 3.99016e-05   236: -5.70023e-06   333: 3.99016e-05   334: -5.70023e-06   566: -2.15985e-05   601: -2.28009e-05
Row 234:   25: -1.15196e-19   26: 0.000155398   41: -0.000155398   53: -1.30443e-19   227: -5.39964e-06   228: -2.69982e-06   229: 5.39964e-06   230: 2.69982e-06   233: 3.54166e-20   234: 1.66498e-05   235: -5.70023e-06   236: 2.85011e-06   333: 5.70023e-06   334: -2.85011e-06   566: -8.78797e-21   601: -1.05879e-20
Row 235:   26: -0.000934963   27: -0.000228072   41: -0.00023941   53: -0.000934963   231: 3.8012e-05   232: -5.43028e-06   233: 3.99016e-05   234: -5.70023e-06   235: 0.000155827   236: 1.6623e-20   241: 3.8012e-05   242: 5.43028e-06   333: 3.99016e-05   334: 5.70023e-06   585: -2.17211e-05   601: -2.28009e-05
Row 236:   26: 0.000155827   27: -1.2282e-19   41: -6.77626e-21   53: -0.000155827   231: -5.43028e-06   232: 2.71514e-06   233: -5.70023e-06   234: 2.85011e-06   235: 1.6623e-20   236: 1.66958e-05   241: 5.43028e-06   242: 2.71514e-06   333: 5.70023e-06   334: 2.85011e-06   585: -9.74088e-21   601: -1.32113e-21
Row 237:   27: -0.000431062   28: -0.000431062   42: -0.000215531   237: 7.18436e-05   238: 0   239: 3.59218e-05   240: -5.13169e-06   245: 3.59218e-05   246: -5.13169e-06   567: -2.05267e-05
Row 238:   27: 7.18436e-05   28: -7.18436e-05   42: -5.0822e-21   237: 0   238: 7.69753e-06   239: -5.13169e-06   240: 2.56584e-06   245: 5.13169e-06   246: -2.56584e-06   567: -1.06523e-21
Row 239:   27: -0.000890065   28: -0.000215531   42: -0.000890065   53: -0.000229502   237: 3.59218e-05   238: -5.13169e-06   239: 0.000148344   240: 1.61466e-20   241: 3.82503e-05   242: -5.46433e-06   245: 3.59218e-05   246: 5.13169e-06   337: 3.82503e-05   338: -5.46433e-06   567: -2.05267e-05   604: -2.18573e-05
Row 240:   27: 0.000148344   28: -1.17738e-19   42: -0.000148344   53: -3.38813e-21   237: -5.13169e-06   238: 2.56584e-06   239: 1.61466e-20   240: 1.5894e-05   241: -5.46433e-06   242: 2.73216e-06   245: 5.13169e-06   246: 2.56584e-06   337: 5.46433e-06   338: -2.73216e-06   567: -9.1056e-21   604: -9.14871e-22
Row 241:   26: -0.000228072   27: -0.000915147   42: -0.000229502   53: -0.000915147   231: 3.8012e-05   232: 5.43028e-06   235: 3.8012e-05   236: 5.43028e-06   239: 3.82503e-05   240: -5.46433e-06   241: 0.000152524   242: 3.65283e-20   337: 3.82503e-05   338: 5.46433e-06   585: -2.17211e-05   604: -2.18573e-05
Row 242:   26: -1.18585e-19   27: 0.000152524   42: -1.24514e-19   53: -0.000152524   231: -5.43028e-06   232: -2.71514e-06   235: 5.43028e-06   236: 2.71514e-06   239: -5.46433e-06   240: 2.73216e-06   241: 3.65283e-20   242: 1.63419e-05   337: 5.46433e-06   338: 2.73216e-06   585: -8.68209e-21   604: -9.84676e-21
Row 243:   28: -0.000437786   29: -0.000437786   54: -0.000218893   243: 7.29644e-05   244: 0   247: 3.64822e-05   248: -5.21174e-06   253: 3.64822e-05   254: -5.21174e-06   586: -2.0847e-05
Row 244:   28: 7.29644e-05   29: -7.29644e-05   54: -3.38813e-21   243: 0   244: 7.81761e-06   247: -5.21174e-06   248: 2.60587e-06   253: 5.21174e-06   254: -2.60587e-06   586: -1.04191e-21
Row 245:   27: -0.000215531   28: -0.000870709   42: -0.000870709   54: -0.000219824   237: 3.59218e-05   238: 5.13169e-06   239: 3.59218e-05   240: 5.13169e-06   245: 0.000145118   246: 3.42519e-20   247: 3.66373e-05   248: -5.23389e-06   339: 3.66373e-05   340: -5.23389e-06   567: -2.05267e-05   595: -2.09356e-05
Row 246:   27: -1.0842e-19   28: 0.000145118   42: -0.000145118   54: -1.21126e-19   237: -5.13169e-06   238: -2.56584e-06   239: 5.13169e-06   240: 2.56584e-06   245: 3.42519e-20   246: 1.55484e-05   247: -5.23389e-06   248: 2.61695e-06   339: 5.23389e-06   340: -2.61695e-06   567: -8.68209e-21   595: -9.52912e-21
Row 247:   28: -0.000877433   29: -0.000218893   42: -0.000219824   54: -0.000877433   243: 3.64822e-05   244: -5.21174e-06   245: 3.66373e-05   246: -5.23389e-06   247: 0.000146239   248: 1.56701e-20   253: 3.64822e-05   254: 5.21174e-06   339: 3.66373e-05   340: 5.23389e-06   586: -2.0847e-05   595: -2.09356e-05
Row 248:   28: 0.000146239   29: -1.18585e-19   42: -6.77626e-21   54: -0.000146239   243: -5.21174e-06   244: 2.60587e-06   245: -5.23389e-06   246: 2.61695e-06   247: 1.56701e-20   248: 1.56684e-05   253: 5.21174e-06   254: 2.60587e-06   339: 5.23389e-06   340: 2.61695e-06   586: -9.42324e-21   595: -1.22357e-21
Row 249:   29: -0.000460804   30: -0.000460804   43: -0.000230402   249: 7.68007e-05   250: 0   251: 3.84003e-05   252: -5.48576e-06   257: 3.84003e-05   258: -5.48576e-06   568: -2.19431e-05
Row 250:   29: 7.68007e-05   30: -7.68007e-05   43: -5.0822e-21   249: 0   250: 8.22865e-06   251: -5.48576e-06   252: 2.74288e-06   257: 5.48576e-06   258: -2.74288e-06   568: -9.32262e-22
Row 251:   29: -0.000902162   30: -0.000230402   43: -0.000902162   54: -0.000220679   249: 3.84003e-05   250: -5.48576e-06   251: 0.00015036   252: 1.82112e-20   253: 3.67798e-05   254: -5.25426e-06   257: 3.84003e-05   258: 5.48576e-06   345: 3.67798e-05   346: -5.25426e-06   568: -2.19431e-05   600: -2.1017e-05
Row 252:   29: 0.00015036   30: -1.24514e-19   43: -0.00015036   54: -6.77626e-21   249: -5.48576e-06   250: 2.74288e-06   251: 1.82112e-20   252: 1.611e-05   253: -5.25426e-06   254: 2.62713e-06   257: 5.48576e-06   258: 2.74288e-06   345: 5.25426e-06   346: -2.62713e-06   568: -9.95264e-21   600: -8.31921e-22
Row 253:   28: -0.000218893   29: -0.000879144   43: -0.000220679   54: -0.000879144   243: 3.64822e-05   244: 5.21174e-06   247: 3.64822e-05   248: 5.21174e-06   251: 3.67798e-05   252: -5.25426e-06   253: 0.000146524   254: 3.18167e-20   345: 3.67798e-05   346: 5.25426e-06   586: -2.0847e-05   600: -2.1017e-05
Row 254:   28: -1.11808e-19   29: 0.000146524   43: -1.21126e-19   54: -0.000146524   243: -5.21174e-06   244: -2.60587e-06   247: 5.21174e-06   248: 2.60587e-06   251: -5.25426e-06   252: 2.62713e-06   253: 3.18167e-20   254: 1.5699e-05   345: 5.25426e-06   346: 2.62713e-06   586: -8.25857e-21   600: -9.31736e-21
Row 255:   30: -0.000437468   31: -0.000437468   55: -0.000218734   255: 7.29113e-05   256: 0   259: 3.64557e-05   260: -5.20795e-06   263: 3.64557e-05   264: -5.20795e-06   587: -2.08318e-05
Row 256:   30: 7.29113e-05   31: -7.29113e-05   55: -3.38813e-21   255: 0   256: 7.81193e-06   259: -5.20795e-06   260: 2.60398e-06   263: 5.20795e-06   264: -2.60398e-06   587: -1.0832e-21
Row 257:   29: -0.000230402   30: -0.000858824   43: -0.000858824   55: -0.00019901   249: 3.84003e-05   250: 5.48576e-06   251: 3.84003e-05   252: 5.48576e-06   257: 0.000143137   258: 3.25578e-20   259: 3.31683e-05   260: -4.73833e-06   347: 3.31683e-05   348: -4.73833e-06   568: -2.19431e-05   596: -1.89533e-05
Row 258:   29: -1.18585e-19   30: 0.000143137   43: -0.000143137   55: -1.09267e-19   249: -5.48576e-06   250: -2.74288e-06   251: 5.48576e-06   252: 2.74288e-06   257: 3.25578e-20   258: 1.53361e-05   259: -4.73833e-06   260: 2.36916e-06   347: 4.73833e-06   348: -2.36916e-06   568: -9.1056e-21   596: -8.57621e-21
Row 259:   30: -0.000835488   31: -0.000218734   43: -0.00019901   55: -0.000835488   255: 3.64557e-05   256: -5.20795e-06   257: 3.31683e-05   258: -4.73833e-06   259: 0.000139248   260: 1.67818e-20   263: 3.64557e-05   264: 5.20795e-06   347: 3.31683e-05   348: 4.73833e-06   587: -2.08318e-05   596: -1.89533e-05
Row 260:   30: 0.000139248   31: -1.20279e-19   43: -3.38813e-21   55: -0.000139248   255: -5.20795e-06   256: 2.60398e-06   257: -4.73833e-06   258: 2.36916e-06   259: 1.67818e-20   260: 1.49194e-05   263: 5.20795e-06   264: 2.60398e-06   347: 4.73833e-06   348: 2.36916e-06   587: -9.42324e-21   596: -8.12576e-22
Row 261:   4: -0.000328444   31: -0.0011734   32: -0.0011734   55: -0.000258254   107: 5.47406e-05   108: 7.82009e-06   109: 5.47406e-05   110: 7.82009e-06   261: 0.000195566   262: -2.49875e-20   263: 4.30423e-05   264: -6.14891e-06   267: 4.30423e-05   268: -6.14891e-06   569: -3.12803e-05   627: -2.45956e-05
Row 262:   4: 1.69407e-19   31: 0.000195566   32: -0.000195566   55: -8.47033e-21   107: -7.82009e-06   108: -3.91004e-06   109: 7.82009e-06   110: 3.91004e-06   261: -2.49875e-20   262: 2.09535e-05   263: -6.14891e-06   264: 3.07445e-06   267: 6.14891e-06   268: -3.07445e-06   569: 1.3129e-20   627: -1.02295e-21
Row 263:   30: -0.000218734   31: -0.000953976   32: -0.000258254   55: -0.000953976   255: 3.64557e-05   256: 5.20795e-06   259: 3.64557e-05   260: 5.20795e-06   261: 4.30423e-05   262: -6.14891e-06   263: 0.000158996   264: 3.73753e-20   267: 4.30423e-05   268: 6.14891e-06   587: -2.08318e-05   627: -2.45956e-05
Row 264:   30: -1.11808e-19   31: 0.000158996   32: -1.42302e-19   55: -0.000158996   255: -5.20795e-06   256: -2.60398e-06   259: 5.20795e-06   260: 2.60398e-06   261: -6.14891e-06   262: 3.07445e-06   263: 3.73753e-20   264: 1.70353e-05   267: 6.14891e-06   268: 3.07445e-06   587: -8.89385e-21   627: -1.10114e-20
Row 265:   5: -0.000245428   32: -0.00105456   44: -0.00105456   67: -0.00028185   113: 4.09047e-05   114: 5.84353e-06   115: 4.09047e-05   116: 5.84353e-06   265: 0.00017576   266: -1.86347e-20   269: 4.69751e-05   270: -6.71072e-06   355: 4.69751e-05   356: -6.71072e-06   584: -2.33741e-05   623: -2.68429e-05
Row 266:   5: 1.25361e-19   32: 0.00017576   44: -0.00017576   67: -6.77626e-21   113: -5.84353e-06   114: -2.92177e-06   115: 5.84353e-06   116: 2.92177e-06   265: -1.86347e-20   266: 1.88314e-05   269: -6.71072e-06   270: 3.35536e-06   355: 6.71072e-06   356: -3.35536e-06   584: 9.74088e-21   623: -1.22942e-21
Row 267:   31: -0.000258254   32: -0.00099595   55: -0.00099595   67: -0.000239721   261: 4.30423e-05   262: 6.14891e-06   263: 4.30423e-05   264: 6.14891e-06   267: 0.000165992   268: 3.944e-20   269: 3.99535e-05   270: -5.70765e-06   391: 3.99535e-05   392: -5.70765e-06   627: -2.45956e-05   632: -2.28306e-05
Row 268:   31: -1.32137e-19   32: 0.000165992   55: -0.000165992   67: -1.30443e-19   261: -6.14891e-06   262: -3.07445e-06   263: 6.14891e-06   264: 3.07445e-06   267: 3.944e-20   268: 1.77848e-05   269: -5.70765e-06   270: 2.85382e-06   391: 5.70765e-06   392: -2.85382e-06   627: -9.95264e-21   632: -1.03762e-20
Row 269:   32: -0.00104314   44: -0.00028185   55: -0.000239721   67: -0.00104314   265: 4.69751e-05   266: -6.71072e-06   267: 3.99535e-05   268: -5.70765e-06   269: 0.000173857   270: 2.1017e-20   355: 4.69751e-05   356: 6.71072e-06   391: 3.99535e-05   392: 5.70765e-06   623: -2.68429e-05   632: -2.28306e-05
Row 270:   32: 0.000173857   44: -1.52466e-19   55: -6.77626e-21   67: -0.000173857   265: -6.71072e-06   266: 3.35536e-06   267: -5.70765e-06   268: 2.85382e-06   269: 2.1017e-20   270: 1.86276e-05   355: 6.71072e-06   356: 3.35536e-06   391: 5.70765e-06   392: 2.85382e-06   623: -1.21761e-20   632: -1.32113e-21
Row 271:   6: -0.000238402   33: -0.00093628   44: -0.00093628   66: -0.000229738   119: 3.97337e-05   120: 5.67624e-06   121: 3.97337e-05   122: 5.67624e-06   271: 0.000156047   272: 3.56283e-20   277: 3.82896e-05   278: -5.46994e-06   353: 3.82896e-05   354: -5.46994e-06   582: -2.2705e-05   621: -2.18798e-05
Row 272:   6: -1.21973e-19   33: 0.000156047   44: -0.000156047   66: -1.25361e-19   119: -5.67624e-06   120: -2.83812e-06   121: 5.67624e-06   122: 2.83812e-06   271: 3.56283e-20   272: 1.67193e-05   277: -5.46994e-06   278: 2.73497e-06   353: 5.46994e-06   354: -2.73497e-06   582: -9.21148e-21   621: -9.95264e-21
Row 273:   7: -0.000229678   33: -0.000897969   45: -0.000897969   61: -0.000219307   125: 3.82796e-05   126: 5.46852e-06   127: 3.82796e-05   128: 5.46852e-06   273: 0.000149661   274: -1.69407e-20   275: 3.65511e-05   276: -5.22159e-06   357: 3.65511e-05   358: -5.22159e-06   589: -2.18741e-05   612: -2.08864e-05
Row 274:   7: 1.15196e-19   33: 0.000149661   45: -0.000149661   61: -6.77626e-21   125: -5.46852e-06   126: -2.73426e-06   127: 5.46852e-06   128: 2.73426e-06   273: -1.69407e-20   274: 1.60352e-05   275: -5.22159e-06   276: 2.61079e-06   357: 5.22159e-06   358: -2.61079e-06   589: 8.89385e-21   612: -9.25172e-22
Row 275:   33: -0.000888851   45: -0.000219307   61: -0.000888851   66: -0.000225119   273: 3.65511e-05   274: -5.22159e-06   275: 0.000148142   276: 1.68877e-20   277: 3.75198e-05   278: -5.35997e-06   357: 3.65511e-05   358: 5.22159e-06   431: 3.75198e-05   432: -5.35997e-06   612: -2.08864e-05   622: -2.14399e-05
Row 276:   33: 0.000148142   45: -1.19432e-19   61: -0.000148142   66: -3.38813e-21   273: -5.22159e-06   274: 2.61079e-06   275: 1.68877e-20   276: 1.58723e-05   277: -5.35997e-06   278: 2.67999e-06   357: 5.22159e-06   358: 2.61079e-06   431: 5.35997e-06   432: -2.67999e-06   612: -9.31736e-21   622: -8.65147e-22
Row 277:   33: -0.000909713   44: -0.000229738   61: -0.000225119   66: -0.000909713   271: 3.82896e-05   272: -5.46994e-06   275: 3.75198e-05   276: -5.35997e-06   277: 0.000151619   278: 1.69936e-20   353: 3.82896e-05   354: 5.46994e-06   431: 3.75198e-05   432: 5.35997e-06   621: -2.18798e-05   622: -2.14399e-05
Row 278:   33: 0.000151619   44: -3.38813e-21   61: -1.2282e-19   66: -0.000151619   271: -5.46994e-06   272: 2.73497e-06   275: -5.35997e-06   276: 2.67999e-06   277: 1.69936e-20   278: 1.62449e-05   353: 5.46994e-06   354: 2.73497e-06   431: 5.35997e-06   432: 2.67999e-06   621: -1.12883e-21   622: -9.635e-21
Row 279:   8: -0.000228621   34: -0.000918089   45: -0.000918089   63: -0.000230423   131: 3.81035e-05   132: 5.44336e-06   133: 3.81035e-05   134: 5.44336e-06   279: 0.000153015   280: 3.44107e-20   285: 3.84038e-05   286: -5.48626e-06   359: 3.84038e-05   360: -5.48626e-06   578: -2.17735e-05   615: -2.19451e-05
Row 280:   8: -1.15196e-19   34: 0.000153015   45: -0.000153015   63: -1.26208e-19   131: -5.44336e-06   132: -2.72168e-06   133: 5.44336e-06   134: 2.72168e-06   279: 3.44107e-20   280: 1.63944e-05   285: -5.48626e-06   286: 2.74313e-06   359: 5.48626e-06   360: -2.74313e-06   578: -8.89385e-21   615: -1.00585e-20
Row 281:   9: -0.000204302   34: -0.000884718   46: -0.000884718   57: -0.000238057   137: 3.40504e-05   138: 4.86434e-06   139: 3.40504e-05   140: 4.86434e-06   281: 0.000147453   282: -1.69407e-20   283: 3.96761e-05   284: -5.66802e-06   361: 3.96761e-05   362: -5.66802e-06   590: -1.94574e-05   606: -2.26721e-05
Row 282:   9: 1.05032e-19   34: 0.000147453   46: -0.000147453   57: -6.77626e-21   137: -4.86434e-06   138: -2.43217e-06   139: 4.86434e-06   140: 2.43217e-06   281: -1.69407e-20   282: 1.57985e-05   283: -5.66802e-06   284: 2.83401e-06   361: 5.66802e-06   362: -2.83401e-06   590: 8.04681e-21   606: -9.92299e-22
Row 283:   34: -0.00101921   46: -0.000238057   57: -0.00101921   63: -0.00027155   281: 3.96761e-05   282: -5.66802e-06   283: 0.000169869   284: 1.84759e-20   285: 4.52583e-05   286: -6.46547e-06   361: 3.96761e-05   362: 5.66802e-06   401: 4.52583e-05   402: -6.46547e-06   606: -2.26721e-05   616: -2.58619e-05
Row 284:   34: 0.000169869   46: -1.29596e-19   57: -0.000169869   63: -6.77626e-21   281: -5.66802e-06   282: 2.83401e-06   283: 1.84759e-20   284: 1.82002e-05   285: -6.46547e-06   286: 3.23274e-06   361: 5.66802e-06   362: 2.83401e-06   401: 6.46547e-06   402: -3.23274e-06   606: -1.01644e-20   616: -1.33946e-21
Row 285:   34: -0.00100395   45: -0.000230423   57: -0.00027155   63: -0.00100395   279: 3.84038e-05   280: -5.48626e-06   283: 4.52583e-05   284: -6.46547e-06   285: 0.000167324   286: 2.13346e-20   359: 3.84038e-05   360: 5.48626e-06   401: 4.52583e-05   402: 6.46547e-06   615: -2.19451e-05   616: -2.58619e-05
Row 286:   34: 0.000167324   45: -3.38813e-21   57: -1.49078e-19   63: -0.000167324   279: -5.48626e-06   280: 2.74313e-06   283: -6.46547e-06   284: 3.23274e-06   285: 2.13346e-20   286: 1.79276e-05   359: 5.48626e-06   360: 2.74313e-06   401: 6.46547e-06   402: 3.23274e-06   615: -9.96003e-22   616: -1.15408e-20
Row 287:   10: -0.000262408   35: -0.00101781   46: -0.00101781   57: -0.000246497   143: 4.37346e-05   144: 6.2478e-06   145: 4.37346e-05   146: 6.2478e-06   287: 0.000169635   288: 4.10282e-20   291: 4.10829e-05   292: -5.86898e-06   361: 4.10829e-05   362: -5.86898e-06   609: -2.49912e-05   630: -2.34759e-05
Row 288:   10: -1.32137e-19   35: 0.000169635   46: -0.000169635   57: -1.34678e-19   143: -6.2478e-06   144: -3.1239e-06   145: 6.2478e-06   146: 3.1239e-06   287: 4.10282e-20   288: 1.81752e-05   291: -5.86898e-06   292: 2.93449e-06   361: 5.86898e-06   362: -2.93449e-06   609: -1.03762e-20   630: -1.10114e-20
Row 289:   12: -0.000249411   35: -0.00107074   47: -0.00107074   57: -0.00028596   153: 4.15684e-05   154: 5.93835e-06   155: 4.15684e-05   156: 5.93835e-06   289: 0.000178457   290: -1.86347e-20   291: 4.766e-05   292: -6.80857e-06   363: 4.766e-05   364: -6.80857e-06   602: -2.37534e-05   637: -2.72343e-05
Row 290:   12: 1.28749e-19   35: 0.000178457   47: -0.000178457   57: -6.77626e-21   153: -5.93835e-06   154: -2.96917e-06   155: 5.93835e-06   156: 2.96917e-06   289: -1.86347e-20   290: 1.91204e-05   291: -6.80857e-06   292: 3.40429e-06   363: 6.80857e-06   364: -3.40429e-06   602: 9.74088e-21   637: -1.09855e-21
Row 291:   35: -0.00106491   46: -0.000246497   47: -0.00028596   57: -0.00106491   287: 4.10829e-05   288: -5.86898e-06   289: 4.766e-05   290: -6.80857e-06   291: 0.000177486   292: 2.20758e-20   361: 4.10829e-05   362: 5.86898e-06   363: 4.766e-05   364: 6.80857e-06   630: -2.34759e-05   637: -2.72343e-05
Row 292:   35: 0.000177486   46: -1.01644e-20   47: -1.57548e-19   57: -0.000177486   287: -5.86898e-06   288: 2.93449e-06   289: -6.80857e-06   290: 3.40429e-06   291: 2.20758e-20   292: 1.90163e-05   361: 5.86898e-06   362: 2.93449e-06   363: 6.80857e-06   364: 3.40429e-06   630: -1.05858e-21   637: -1.24937e-20
Row 293:   13: -0.00023561   36: -0.000941759   47: -0.000941759   68: -0.000235269   159: 3.92684e-05   160: 5.60977e-06   161: 3.92684e-05   162: 5.60977e-06   293: 0.00015696   294: 3.52577e-20   299: 3.92115e-05   300: -5.60165e-06   365: 3.92115e-05   366: -5.60165e-06   588: -2.24391e-05   628: -2.24066e-05
Row 294:   13: -1.21973e-19   36: 0.00015696   47: -0.00015696   68: -1.27902e-19   159: -5.60977e-06   160: -2.80489e-06   161: 5.60977e-06   162: 2.80489e-06   293: 3.52577e-20   294: 1.68171e-05   299: -5.60165e-06   300: 2.80082e-06   365: 5.60165e-06   366: -2.80082e-06   588: -9.52912e-21   628: -1.00585e-20
Row 295:   14: -0.000218479   36: -0.000848903   48: -0.000848903   59: -0.000205972   165: 3.64132e-05   166: 5.20189e-06   167: 3.64132e-05   168: 5.20189e-06   295: 0.000141484   296: -1.69407e-20   297: 3.43287e-05   298: -4.90409e-06   367: 3.43287e-05   368: -4.90409e-06   591: -2.08076e-05   608: -1.96164e-05
Row 296:   14: 1.15196e-19   36: 0.000141484   48: -0.000141484   59: -3.38813e-21   165: -5.20189e-06   166: -2.60095e-06   167: 5.20189e-06   168: 2.60095e-06   295: -1.69407e-20   296: 1.5159e-05   297: -4.90409e-06   298: 2.45205e-06   367: 4.90409e-06   368: -2.45205e-06   591: 8.78797e-21   608: -8.42681e-22
Row 297:   36: -0.000846999   48: -0.000205972   59: -0.000846999   68: -0.000217527   295: 3.43287e-05   296: -4.90409e-06   297: 0.000141166   298: 1.55642e-20   299: 3.62545e-05   300: -5.17922e-06   367: 3.43287e-05   368: 4.90409e-06   415: 3.62545e-05   416: -5.17922e-06   608: -1.96164e-05   629: -2.07169e-05
Row 298:   36: 0.000141166   48: -1.12655e-19   59: -0.000141166   68: -5.0822e-21   295: -4.90409e-06   296: 2.45205e-06   297: 1.55642e-20   298: 1.5125e-05   299: -5.17922e-06   300: 2.58961e-06   367: 4.90409e-06   368: 2.45205e-06   415: 5.17922e-06   416: -2.58961e-06   608: -8.68209e-21   629: -9.50785e-22
Row 299:   36: -0.000905593   47: -0.000235269   59: -0.000217527   68: -0.000905593   293: 3.92115e-05   294: -5.60165e-06   297: 3.62545e-05   298: -5.17922e-06   299: 0.000150932   300: 1.61466e-20   365: 3.92115e-05   366: 5.60165e-06   415: 3.62545e-05   416: 5.17922e-06   628: -2.24066e-05   629: -2.07169e-05
Row 300:   36: 0.000150932   47: -8.47033e-21   59: -1.18585e-19   68: -0.000150932   293: -5.60165e-06   294: 2.80082e-06   297: -5.17922e-06   298: 2.58961e-06   299: 1.61466e-20   300: 1.61713e-05   365: 5.60165e-06   366: 2.80082e-06   415: 5.17922e-06   416: 2.58961e-06   628: -1.04999e-21   629: -9.52912e-21
Row 301:   15: -0.000212497   37: -0.000833337   48: -0.000833337   69: -0.000204172   171: 3.54161e-05   172: 5.05945e-06   173: 3.54161e-05   174: 5.05945e-06   301: 0.00013889   302: 3.25049e-20   307: 3.40286e-05   308: -4.86123e-06   369: 3.40286e-05   370: -4.86123e-06   597: -2.02378e-05   634: -1.94449e-05
Row 302:   15: -1.0842e-19   37: 0.00013889   48: -0.00013889   69: -1.10961e-19   171: -5.05945e-06   172: -2.52972e-06   173: 5.05945e-06   174: 2.52972e-06   301: 3.25049e-20   302: 1.4881e-05   307: -4.86123e-06   308: 2.43062e-06   369: 4.86123e-06   370: -2.43062e-06   597: -8.57621e-21   634: -8.89385e-21
Row 303:   16: -0.000190229   37: -0.000830838   49: -0.000830838   60: -0.00022519   177: 3.17049e-05   178: 4.52927e-06   179: 3.17049e-05   180: 4.52927e-06   303: 0.000138473   304: -1.52466e-20   305: 3.75317e-05   306: -5.36167e-06   371: 3.75317e-05   372: -5.36167e-06   592: -1.81171e-05   642: -2.14467e-05
Row 304:   16: 9.82558e-20   37: 0.000138473   49: -0.000138473   60: -8.47033e-21   177: -4.52927e-06   178: -2.26463e-06   179: 4.52927e-06   180: 2.26463e-06   303: -1.52466e-20   304: 1.48364e-05   305: -5.36167e-06   306: 2.68083e-06   371: 5.36167e-06   372: -2.68083e-06   592: 7.72918e-21   642: -1.00337e-21
Row 305:   37: -0.000932106   49: -0.00022519   60: -0.000932106   69: -0.000240863   303: 3.75317e-05   304: -5.36167e-06   305: 0.000155351   306: 1.74171e-20   307: 4.01438e-05   308: -5.73483e-06   371: 3.75317e-05   372: 5.36167e-06   425: 4.01438e-05   426: -5.73483e-06   642: -2.14467e-05   643: -2.29393e-05
Row 306:   37: 0.000155351   49: -1.2282e-19   60: -0.000155351   69: -5.0822e-21   303: -5.36167e-06   304: 2.68083e-06   305: 1.74171e-20   306: 1.66447e-05   307: -5.73483e-06   308: 2.86741e-06   371: 5.36167e-06   372: 2.68083e-06   425: 5.73483e-06   426: -2.86741e-06   642: -9.635e-21   643: -1.16082e-21
Row 307:   37: -0.000890069   48: -0.000204172   60: -0.000240863   69: -0.000890069   301: 3.40286e-05   302: -4.86123e-06   305: 4.01438e-05   306: -5.73483e-06   307: 0.000148345   308: 1.88994e-20   369: 3.40286e-05   370: 4.86123e-06   425: 4.01438e-05   426: 5.73483e-06   634: -1.94449e-05   643: -2.29393e-05
Row 308:   37: 0.000148345   48: -3.38813e-21   60: -1.30443e-19   69: -0.000148345   301: -4.86123e-06   302: 2.43062e-06   305: -5.73483e-06   306: 2.86741e-06   307: 1.88994e-20   308: 1.58941e-05   369: 4.86123e-06   370: 2.43062e-06   425: 5.73483e-06   426: 2.86741e-06   634: -1.10829e-21   643: -1.0482e-20
Row 309:   17: -0.000253086   38: -0.000973941   49: -0.000973941   60: -0.000233884   183: 4.21811e-05   184: 6.02587e-06   185: 4.21811e-05   186: 6.02587e-06   309: 0.000162323   310: 3.70577e-20   313: 3.89807e-05   314: -5.56867e-06   371: 3.89807e-05   372: -5.56867e-06   611: -2.41035e-05   631: -2.22747e-05
Row 310:   17: -1.28749e-19   38: 0.000162323   49: -0.000162323   60: -1.28749e-19   183: -6.02587e-06   184: -3.01293e-06   185: 6.02587e-06   186: 3.01293e-06   309: 3.70577e-20   310: 1.73918e-05   313: -5.56867e-06   314: 2.78433e-06   371: 5.56867e-06   372: -2.78433e-06   611: -9.74088e-21   631: -1.03762e-20
Row 311:   19: -0.000248978   38: -0.00105419   50: -0.00105419   60: -0.000278114   193: 4.14964e-05   194: 5.92806e-06   195: 4.14964e-05   196: 5.92806e-06   311: 0.000175698   312: -2.20229e-20   313: 4.63524e-05   314: -6.62177e-06   373: 4.63524e-05   374: -6.62177e-06   603: -2.37122e-05   610: -2.64871e-05
Row 312:   19: 1.28749e-19   38: 0.000175698   50: -0.000175698   60: -1.01644e-20   193: -5.92806e-06   194: -2.96403e-06   195: 5.92806e-06   196: 2.96403e-06   311: -2.20229e-20   312: 1.88247e-05   313: -6.62177e-06   314: 3.31088e-06   373: 6.62177e-06   374: -3.31088e-06   603: 9.95264e-21   610: -1.3333e-21
Row 313:   38: -0.001024   49: -0.000233884   50: -0.000278114   60: -0.001024   309: 3.89807e-05   310: -5.56867e-06   311: 4.63524e-05   312: -6.62177e-06   313: 0.000170666   314: 2.00112e-20   371: 3.89807e-05   372: 5.56867e-06   373: 4.63524e-05   374: 6.62177e-06   610: -2.64871e-05   631: -2.22747e-05
Row 314:   38: 0.000170666   49: -3.38813e-21   50: -1.50772e-19   60: -0.000170666   309: -5.56867e-06   310: 2.78433e-06   311: -6.62177e-06   312: 3.31088e-06   313: 2.00112e-20   314: 1.82857e-05   371: 5.56867e-06   372: 2.78433e-06   373: 6.62177e-06   374: 3.31088e-06   610: -1.11173e-20   631: -1.16774e-21
Row 315:   20: -0.000245394   39: -0.000968753   50: -0.000968753   62: -0.000238983   199: 4.0899e-05   200: 5.84271e-06   201: 4.0899e-05   202: 5.84271e-06   315: 0.000161459   316: 3.71636e-20   321: 3.98304e-05   322: -5.69006e-06   375: 3.98304e-05   376: -5.69006e-06   598: -2.33708e-05   613: -2.27602e-05
Row 316:   20: -1.28749e-19   39: 0.000161459   50: -0.000161459   62: -1.3129e-19   199: -5.84271e-06   200: -2.92136e-06   201: 5.84271e-06   202: 2.92136e-06   315: 3.71636e-20   316: 1.72992e-05   321: -5.69006e-06   322: 2.84503e-06   375: 5.69006e-06   376: -2.84503e-06   598: -9.52912e-21   613: -1.02703e-20
Row 317:   21: -0.000235758   39: -0.000935272   51: -0.000935272   58: -0.000231878   205: 3.9293e-05   206: 5.61328e-06   207: 3.9293e-05   208: 5.61328e-06   317: 0.000155879   318: -1.82112e-20   319: 3.86464e-05   320: -5.52091e-06   377: 3.86464e-05   378: -5.52091e-06   593: -2.24531e-05   607: -2.20836e-05
Row 318:   21: 1.21973e-19   39: 0.000155879   51: -0.000155879   58: -3.38813e-21   205: -5.61328e-06   206: -2.80664e-06   207: 5.61328e-06   208: 2.80664e-06   317: -1.82112e-20   318: 1.67013e-05   319: -5.52091e-06   320: 2.76045e-06   377: 5.52091e-06   378: -2.76045e-06   593: 9.42324e-21   607: -8.65891e-22
Row 319:   39: -0.000936606   51: -0.000231878   58: -0.000936606   62: -0.000236425   317: 3.86464e-05   318: -5.52091e-06   319: 0.000156101   320: 1.76818e-20   321: 3.94041e-05   322: -5.62916e-06   377: 3.86464e-05   378: 5.52091e-06   407: 3.94041e-05   408: -5.62916e-06   607: -2.20836e-05   614: -2.25166e-05
Row 320:   39: 0.000156101   51: -1.27055e-19   58: -0.000156101   62: -5.0822e-21   317: -5.52091e-06   318: 2.76045e-06   319: 1.76818e-20   320: 1.67251e-05   321: -5.62916e-06   322: 2.81458e-06   377: 5.52091e-06   378: 2.76045e-06   407: 5.62916e-06   408: -2.81458e-06   607: -1.01644e-20   614: -9.74957e-22
Row 321:   39: -0.000950815   50: -0.000238983   58: -0.000236425   62: -0.000950815   315: 3.98304e-05   316: -5.69006e-06   319: 3.94041e-05   320: -5.62916e-06   321: 0.000158469   322: 1.81053e-20   375: 3.98304e-05   376: 5.69006e-06   407: 3.94041e-05   408: 5.62916e-06   613: -2.27602e-05   614: -2.25166e-05
Row 322:   39: 0.000158469   50: -1.01644e-20   58: -1.28749e-19   62: -0.000158469   315: -5.69006e-06   316: 2.84503e-06   319: -5.62916e-06   320: 2.81458e-06   321: 1.81053e-20   322: 1.69788e-05   375: 5.69006e-06   376: 2.84503e-06   407: 5.62916e-06   408: 2.81458e-06   613: -1.02356e-21   614: -1.00585e-20
Row 323:   22: -0.000230927   40: -0.000919395   51: -0.000919395   70: -0.00022877   211: 3.84879e-05   212: 5.49827e-06   213: 3.84879e-05   214: 5.49827e-06   323: 0.000153233   324: 3.60518e-20   329: 3.81284e-05   330: -5.44691e-06   379: 3.81284e-05   380: -5.44691e-06   599: -2.19931e-05   640: -2.17876e-05
Row 324:   22: -1.18585e-19   40: 0.000153233   51: -0.000153233   70: -1.23667e-19   211: -5.49827e-06   212: -2.74914e-06   213: 5.49827e-06   214: 2.74914e-06   323: 3.60518e-20   324: 1.64178e-05   329: -5.44691e-06   330: 2.72346e-06   379: 5.44691e-06   380: -2.72346e-06   599: -9.1056e-21   640: -9.84676e-21
Row 325:   23: -0.00020089   40: -0.000865069   52: -0.000865069   65: -0.000231644   217: 3.34817e-05   218: 4.7831e-06   219: 3.34817e-05   220: 4.7831e-06   325: 0.000144178   326: -1.27055e-20   327: 3.86074e-05   328: -5.51534e-06   381: 3.86074e-05   382: -5.51534e-06   594: -1.91324e-05   620: -2.20614e-05
Row 326:   23: 1.05032e-19   40: 0.000144178   52: -0.000144178   65: -6.77626e-21   217: -4.7831e-06   218: -2.39155e-06   219: 4.7831e-06   220: 2.39155e-06   325: -1.27055e-20   326: 1.54477e-05   327: -5.51534e-06   328: 2.75767e-06   381: 5.51534e-06   382: -2.75767e-06   594: 8.04681e-21   620: -9.46629e-22
Row 327:   40: -0.000997777   52: -0.000231644   65: -0.000997777   70: -0.000267245   325: 3.86074e-05   326: -5.51534e-06   327: 0.000166296   328: 1.72054e-20   329: 4.45408e-05   330: -6.36296e-06   381: 3.86074e-05   382: 5.51534e-06   451: 4.45408e-05   452: -6.36296e-06   620: -2.20614e-05   645: -2.54519e-05
Row 328:   40: 0.000166296   52: -1.26208e-19   65: -0.000166296   70: -8.47033e-21   325: -5.51534e-06   326: 2.75767e-06   327: 1.72054e-20   328: 1.78175e-05   329: -6.36296e-06   330: 3.18148e-06   381: 5.51534e-06   382: 2.75767e-06   451: 6.36296e-06   452: -3.18148e-06   620: -9.95264e-21   645: -1.30388e-21
Row 329:   40: -0.000992029   51: -0.00022877   65: -0.000267245   70: -0.000992029   323: 3.81284e-05   324: -5.44691e-06   327: 4.45408e-05   328: -6.36296e-06   329: 0.000165338   330: 2.017e-20   379: 3.81284e-05   380: 5.44691e-06   451: 4.45408e-05   452: 6.36296e-06   640: -2.17876e-05   645: -2.54519e-05
Row 330:   40: 0.000165338   51: -6.77626e-21   65: -1.4569e-19   70: -0.000165338   323: -5.44691e-06   324: 2.72346e-06   327: -6.36296e-06   328: 3.18148e-06   329: 2.017e-20   330: 1.77148e-05   379: 5.44691e-06   380: 2.72346e-06   451: 6.36296e-06   452: 3.18148e-06   640: -1.23601e-21   645: -1.14349e-20
Row 331:   24: -0.00025731   41: -0.000988928   52: -0.000988928   65: -0.000237154   223: 4.2885e-05   224: 6.12642e-06   225: 4.2885e-05   226: 6.12642e-06   331: 0.000164821   332: 3.47813e-20   335: 3.95257e-05   336: -5.64652e-06   381: 3.95257e-05   382: -5.64652e-06   619: -2.45057e-05   625: -2.25861e-05
Row 332:   24: -1.32137e-19   41: 0.000164821   52: -0.000164821   65: -1.28749e-19   223: -6.12642e-06   224: -3.06321e-06   225: 6.12642e-06   226: 3.06321e-06   331: 3.47813e-20   332: 1.76594e-05   335: -5.64652e-06   336: 2.82326e-06   381: 5.64652e-06   382: -2.82326e-06   619: -1.00585e-20   625: -1.03762e-20
Row 333:   26: -0.00023941   41: -0.00103162   53: -0.00103162   65: -0.0002764   233: 3.99016e-05   234: 5.70023e-06   235: 3.99016e-05   236: 5.70023e-06   333: 0.000171937   334: -1.86347e-20   335: 4.60667e-05   336: -6.58096e-06   385: 4.60667e-05   386: -6.58096e-06   601: -2.28009e-05   626: -2.63238e-05
Row 334:   26: 1.21973e-19   41: 0.000171937   53: -0.000171937   65: -8.47033e-21   233: -5.70023e-06   234: -2.85011e-06   235: 5.70023e-06   236: 2.85011e-06   333: -1.86347e-20   334: 1.84218e-05   335: -6.58096e-06   336: 3.29048e-06   385: 6.58096e-06   386: -3.29048e-06   601: 9.31736e-21   626: -1.31299e-21
Row 335:   41: -0.00102711   52: -0.000237154   53: -0.0002764   65: -0.00102711   331: 3.95257e-05   332: -5.64652e-06   333: 4.60667e-05   334: -6.58096e-06   335: 0.000171185   336: 2.17582e-20   381: 3.95257e-05   382: 5.64652e-06   385: 4.60667e-05   386: 6.58096e-06   625: -2.25861e-05   626: -2.63238e-05
Row 336:   41: 0.000171185   52: -8.47033e-21   53: -1.52466e-19   65: -0.000171185   331: -5.64652e-06   332: 2.82326e-06   333: -6.58096e-06   334: 3.29048e-06   335: 2.17582e-20   336: 1.83412e-05   381: 5.64652e-06   382: 2.82326e-06   385: 6.58096e-06   386: 3.29048e-06   625: -1.26203e-21   626: -1.18585e-20
Row 337:   27: -0.000229502   42: -0.00089607   53: -0.00089607   64: -0.000218533   239: 3.82503e-05   240: 5.46433e-06   241: 3.82503e-05   242: 5.46433e-06   337: 0.000149345   338: 3.53636e-20   343: 3.64222e-05   344: -5.20317e-06   383: 3.64222e-05   384: -5.20317e-06   604: -2.18573e-05   617: -2.08127e-05
Row 338:   27: -1.15196e-19   42: 0.000149345   53: -0.000149345   64: -1.19432e-19   239: -5.46433e-06   240: -2.73216e-06   241: 5.46433e-06   242: 2.73216e-06   337: 3.53636e-20   338: 1.60012e-05   343: -5.20317e-06   344: 2.60158e-06   383: 5.20317e-06   384: -2.60158e-06   604: -9.31736e-21   617: -9.52912e-21
Row 339:   28: -0.000219824   42: -0.000855906   54: -0.000855906   56: -0.00020813   245: 3.66373e-05   246: 5.23389e-06   247: 3.66373e-05   248: 5.23389e-06   339: 0.000142651   340: -1.86347e-20   341: 3.46883e-05   342: -4.95547e-06   387: 3.46883e-05   388: -4.95547e-06   595: -2.09356e-05   605: -1.98219e-05
Row 340:   28: 1.11808e-19   42: 0.000142651   54: -0.000142651   56: -5.0822e-21   245: -5.23389e-06   246: -2.61695e-06   247: 5.23389e-06   248: 2.61695e-06   339: -1.86347e-20   340: 1.5284e-05   341: -4.95547e-06   342: 2.47773e-06   387: 4.95547e-06   388: -2.47773e-06   595: 8.99973e-21   605: -8.9921e-22
Row 341:   42: -0.000846379   54: -0.00020813   56: -0.000846379   64: -0.00021506   339: 3.46883e-05   340: -4.95547e-06   341: 0.000141063   342: 1.59877e-20   343: 3.58433e-05   344: -5.12047e-06   387: 3.46883e-05   388: 4.95547e-06   393: 3.58433e-05   394: -5.12047e-06   605: -1.98219e-05   618: -2.04819e-05
Row 342:   42: 0.000141063   54: -1.14349e-19   56: -0.000141063   64: -6.77626e-21   339: -4.95547e-06   340: 2.47773e-06   341: 1.59877e-20   342: 1.51139e-05   343: -5.12047e-06   344: 2.56023e-06   387: 4.95547e-06   388: 2.47773e-06   393: 5.12047e-06   394: -2.56023e-06   605: -8.89385e-21   618: -1.05026e-21
Row 343:   42: -0.000867186   53: -0.000218533   56: -0.00021506   64: -0.000867186   337: 3.64222e-05   338: -5.20317e-06   341: 3.58433e-05   342: -5.12047e-06   343: 0.000144531   344: 1.65701e-20   383: 3.64222e-05   384: 5.20317e-06   393: 3.58433e-05   394: 5.12047e-06   617: -2.08127e-05   618: -2.04819e-05
Row 344:   42: 0.000144531   53: -5.0822e-21   56: -1.17738e-19   64: -0.000144531   337: -5.20317e-06   338: 2.60158e-06   341: -5.12047e-06   342: 2.56023e-06   343: 1.65701e-20   344: 1.54855e-05   383: 5.20317e-06   384: 2.60158e-06   393: 5.12047e-06   394: 2.56023e-06   617: -1.16518e-21   618: -9.1056e-21
Row 345:   29: -0.000220679   43: -0.000885373   54: -0.000885373   71: -0.000222008   251: 3.67798e-05   252: 5.25426e-06   253: 3.67798e-05   254: 5.25426e-06   345: 0.000147562   346: 3.40401e-20   351: 3.70013e-05   352: -5.2859e-06   389: 3.70013e-05   390: -5.2859e-06   600: -2.1017e-05   644: -2.11436e-05
Row 346:   29: -1.15196e-19   43: 0.000147562   54: -0.000147562   71: -1.21126e-19   251: -5.25426e-06   252: -2.62713e-06   253: 5.25426e-06   254: 2.62713e-06   345: 3.40401e-20   346: 1.58102e-05   351: -5.2859e-06   352: 2.64295e-06   389: 5.2859e-06   390: -2.64295e-06   600: -8.47033e-21   644: -9.635e-21
Row 347:   30: -0.00019901   43: -0.000860301   55: -0.000860301   67: -0.000231141   257: 3.31683e-05   258: 4.73833e-06   259: 3.31683e-05   260: 4.73833e-06   347: 0.000143383   348: -1.48231e-20   349: 3.85235e-05   350: -5.50335e-06   391: 3.85235e-05   392: -5.50335e-06   596: -1.89533e-05   647: -2.20134e-05
Row 348:   30: 1.05032e-19   43: 0.000143383   55: -0.000143383   67: -1.69407e-21   257: -4.73833e-06   258: -2.36916e-06   259: 4.73833e-06   260: 2.36916e-06   347: -1.48231e-20   348: 1.53625e-05   349: -5.50335e-06   350: 2.75168e-06   391: 5.50335e-06   392: -2.75168e-06   596: 7.94093e-21   647: -1.01474e-21
Row 349:   43: -0.000988978   55: -0.000231141   67: -0.000988978   71: -0.000263348   347: 3.85235e-05   348: -5.50335e-06   349: 0.00016483   350: 1.82112e-20   351: 4.38913e-05   352: -6.27019e-06   391: 3.85235e-05   392: 5.50335e-06   461: 4.38913e-05   462: -6.27019e-06   647: -2.20134e-05   648: -2.50808e-05
Row 350:   43: 0.00016483   55: -1.25361e-19   67: -0.00016483   71: -3.38813e-21   347: -5.50335e-06   348: 2.75168e-06   349: 1.82112e-20   350: 1.76603e-05   351: -6.27019e-06   352: 3.1351e-06   391: 5.50335e-06   392: 2.75168e-06   461: 6.27019e-06   462: -3.1351e-06   647: -1.01644e-20   648: -1.07536e-21
Row 351:   43: -0.000970712   54: -0.000222008   67: -0.000263348   71: -0.000970712   345: 3.70013e-05   346: -5.2859e-06   349: 4.38913e-05   350: -6.27019e-06   351: 0.000161785   352: 2.017e-20   389: 3.70013e-05   390: 5.2859e-06   461: 4.38913e-05   462: 6.27019e-06   644: -2.11436e-05   648: -2.50808e-05
Row 352:   43: 0.000161785   54: -5.0822e-21   67: -1.4569e-19   71: -0.000161785   345: -5.2859e-06   346: 2.64295e-06   349: -6.27019e-06   350: 3.1351e-06   351: 2.017e-20   352: 1.73341e-05   389: 5.2859e-06   390: 2.64295e-06   461: 6.27019e-06   462: 3.1351e-06   644: -9.85995e-22   648: -1.14349e-20
Row 353:   33: -0.000229738   44: -0.000986208   66: -0.000986208   67: -0.000263367   271: 3.82896e-05   272: 5.46994e-06   277: 3.82896e-05   278: 5.46994e-06   353: 0.000164368   354: -1.90582e-20   355: 4.38944e-05   356: -6.27063e-06   455: 4.38944e-05   456: -6.27063e-06   621: -2.18798e-05   624: -2.50825e-05
Row 354:   33: 1.15196e-19   44: 0.000164368   66: -0.000164368   67: -1.69407e-21   271: -5.46994e-06   272: -2.73497e-06   277: 5.46994e-06   278: 2.73497e-06   353: -1.90582e-20   354: 1.76109e-05   355: -6.27063e-06   356: 3.13532e-06   455: 6.27063e-06   456: -3.13532e-06   621: 9.21148e-21   624: -1.10515e-21
Row 355:   32: -0.00028185   44: -0.00109043   66: -0.000263367   67: -0.00109043   265: 4.69751e-05   266: 6.71072e-06   269: 4.69751e-05   270: 6.71072e-06   353: 4.38944e-05   354: -6.27063e-06   355: 0.000181739   356: 4.04458e-20   455: 4.38944e-05   456: 6.27063e-06   623: -2.68429e-05   624: -2.50825e-05
Row 356:   32: -1.42302e-19   44: 0.000181739   66: -1.43996e-19   67: -0.000181739   265: -6.71072e-06   266: -3.35536e-06   269: 6.71072e-06   270: 3.35536e-06   353: -6.27063e-06   354: 3.13532e-06   355: 4.04458e-20   356: 1.9472e-05   455: 6.27063e-06   456: 3.13532e-06   623: -1.07997e-20   624: -1.13291e-20
Row 357:   33: -0.000219307   45: -0.000890679   61: -0.000890679   63: -0.000226033   273: 3.65511e-05   274: 5.22159e-06   275: 3.65511e-05   276: 5.22159e-06   357: 0.000148446   358: 3.42519e-20   359: 3.76721e-05   360: -5.38173e-06   429: 3.76721e-05   430: -5.38173e-06   612: -2.08864e-05   636: -2.15269e-05
Row 358:   33: -1.15196e-19   45: 0.000148446   61: -0.000148446   63: -1.23667e-19   273: -5.22159e-06   274: -2.61079e-06   275: 5.22159e-06   276: 2.61079e-06   357: 3.42519e-20   358: 1.5905e-05   359: -5.38173e-06   360: 2.69087e-06   429: 5.38173e-06   430: -2.69087e-06   612: -8.47033e-21   636: -9.52912e-21
Row 359:   34: -0.000230423   45: -0.000912912   61: -0.000226033   63: -0.000912912   279: 3.84038e-05   280: 5.48626e-06   285: 3.84038e-05   286: 5.48626e-06   357: 3.76721e-05   358: -5.38173e-06   359: 0.000152152   360: -1.86347e-20   429: 3.76721e-05   430: 5.38173e-06   615: -2.19451e-05   636: -2.15269e-05
Row 360:   34: 1.18585e-19   45: 0.000152152   61: -3.38813e-21   63: -0.000152152   279: -5.48626e-06   280: -2.74313e-06   285: 5.48626e-06   286: 2.74313e-06   357: -5.38173e-06   358: 2.69087e-06   359: -1.86347e-20   360: 1.6302e-05   429: 5.38173e-06   430: 2.69087e-06   615: 8.89385e-21   636: -1.15619e-21
Row 361:   34: -0.000238057   35: -0.000246497   46: -0.000969108   57: -0.000969108   281: 3.96761e-05   282: 5.66802e-06   283: 3.96761e-05   284: 5.66802e-06   287: 4.10829e-05   288: 5.86898e-06   291: 4.10829e-05   292: 5.86898e-06   361: 0.000161518   362: 0   606: -2.26721e-05   630: -2.34759e-05
Row 362:   34: -1.25361e-19   35: 1.21973e-19   46: 0.000161518   57: -0.000161518   281: -5.66802e-06   282: -2.83401e-06   283: 5.66802e-06   284: 2.83401e-06   287: -5.86898e-06   288: -2.93449e-06   291: 5.86898e-06   292: 2.93449e-06   361: 0   362: 1.73055e-05   606: -9.635e-21   630: 9.52912e-21
Row 363:   35: -0.00028596   47: -0.00112232   57: -0.00112232   68: -0.000275202   289: 4.766e-05   290: 6.80857e-06   291: 4.766e-05   292: 6.80857e-06   363: 0.000187054   364: 4.16105e-20   365: 4.5867e-05   366: -6.55242e-06   403: 4.5867e-05   404: -6.55242e-06   637: -2.72343e-05   641: -2.62097e-05
Row 364:   35: -1.49078e-19   47: 0.000187054   57: -0.000187054   68: -1.49078e-19   289: -6.80857e-06   290: -3.40429e-06   291: 6.80857e-06   292: 3.40429e-06   363: 4.16105e-20   364: 2.00415e-05   365: -6.55242e-06   366: 3.27621e-06   403: 6.55242e-06   404: -3.27621e-06   637: -1.10114e-20   641: -1.19643e-20
Row 365:   36: -0.000235269   47: -0.00102094   57: -0.000275202   68: -0.00102094   293: 3.92115e-05   294: 5.60165e-06   299: 3.92115e-05   300: 5.60165e-06   363: 4.5867e-05   364: -6.55242e-06   365: 0.000170157   366: -1.99053e-20   403: 4.5867e-05   404: 6.55242e-06   628: -2.24066e-05   641: -2.62097e-05
Row 366:   36: 1.18585e-19   47: 0.000170157   57: -3.38813e-21   68: -0.000170157   293: -5.60165e-06   294: -2.80082e-06   299: 5.60165e-06   300: 2.80082e-06   363: -6.55242e-06   364: 3.27621e-06   365: -1.99053e-20   366: 1.82311e-05   403: 6.55242e-06   404: 3.27621e-06   628: 8.99973e-21   641: -1.47477e-21
Row 367:   36: -0.000205972   48: -0.000829615   59: -0.000829615   69: -0.000208835   295: 3.43287e-05   296: 4.90409e-06   297: 3.43287e-05   298: 4.90409e-06   367: 0.000138269   368: 3.26108e-20   369: 3.48059e-05   370: -4.97227e-06   417: 3.48059e-05   418: -4.97227e-06   608: -1.96164e-05   633: -1.98891e-05
Row 368:   36: -1.0842e-19   48: 0.000138269   59: -0.000138269   69: -1.13502e-19   295: -4.90409e-06   296: -2.45205e-06   297: 4.90409e-06   298: 2.45205e-06   367: 3.26108e-20   368: 1.48146e-05   369: -4.97227e-06   370: 2.48614e-06   417: 4.97227e-06   418: -2.48614e-06   608: -8.04681e-21   633: -9.1056e-21
Row 369:   37: -0.000204172   48: -0.000826014   59: -0.000208835   69: -0.000826014   301: 3.40286e-05   302: 4.86123e-06   307: 3.40286e-05   308: 4.86123e-06   367: 3.48059e-05   368: -4.97227e-06   369: 0.000137669   370: -1.52466e-20   417: 3.48059e-05   418: 4.97227e-06   633: -1.98891e-05   634: -1.94449e-05
Row 370:   37: 1.05032e-19   48: 0.000137669   59: -3.38813e-21   69: -0.000137669   301: -4.86123e-06   302: -2.43062e-06   307: 4.86123e-06   308: 2.43062e-06   367: -4.97227e-06   368: 2.48614e-06   369: -1.52466e-20   370: 1.47503e-05   417: 4.97227e-06   418: 2.48614e-06   633: -9.56159e-22   634: 8.04681e-21
Row 371:   37: -0.00022519   38: -0.000233884   49: -0.000918148   60: -0.000918148   303: 3.75317e-05   304: 5.36167e-06   305: 3.75317e-05   306: 5.36167e-06   309: 3.89807e-05   310: 5.56867e-06   313: 3.89807e-05   314: 5.56867e-06   371: 0.000153025   372: 0   631: -2.22747e-05   642: -2.14467e-05
Row 372:   37: -1.15196e-19   38: 1.18585e-19   49: 0.000153025   60: -0.000153025   303: -5.36167e-06   304: -2.68083e-06   305: 5.36167e-06   306: 2.68083e-06   309: -5.56867e-06   310: -2.78433e-06   313: 5.56867e-06   314: 2.78433e-06   371: 0   372: 1.63955e-05   631: 9.1056e-21   642: -8.78797e-21
Row 373:   38: -0.000278114   50: -0.00110423   60: -0.00110423   62: -0.000274002   311: 4.63524e-05   312: 6.62177e-06   313: 4.63524e-05   314: 6.62177e-06   373: 0.000184039   374: 4.16105e-20   375: 4.5667e-05   376: -6.52386e-06   423: 4.5667e-05   424: -6.52386e-06   610: -2.64871e-05   638: -2.60954e-05
Row 374:   38: -1.42302e-19   50: 0.000184039   60: -0.000184039   62: -1.49078e-19   311: -6.62177e-06   312: -3.31088e-06   313: 6.62177e-06   314: 3.31088e-06   373: 4.16105e-20   374: 1.97184e-05   375: -6.52386e-06   376: 3.26193e-06   423: 6.52386e-06   424: -3.26193e-06   610: -1.07997e-20   638: -1.18585e-20
Row 375:   39: -0.000238983   50: -0.00102597   60: -0.000274002   62: -0.00102597   315: 3.98304e-05   316: 5.69006e-06   321: 3.98304e-05   322: 5.69006e-06   373: 4.5667e-05   374: -6.52386e-06   375: 0.000170995   376: -1.90582e-20   423: 4.5667e-05   424: 6.52386e-06   613: -2.27602e-05   638: -2.60954e-05
Row 376:   39: 1.21973e-19   50: 0.000170995   60: -8.47033e-21   62: -0.000170995   315: -5.69006e-06   316: -2.84503e-06   321: 5.69006e-06   322: 2.84503e-06   373: -6.52386e-06   374: 3.26193e-06   375: -1.90582e-20   376: 1.83209e-05   423: 6.52386e-06   424: 3.26193e-06   613: 9.52912e-21   638: -1.68169e-21
Row 377:   39: -0.000231878   51: -0.000932474   58: -0.000932474   70: -0.000234359   317: 3.86464e-05   318: 5.52091e-06   319: 3.86464e-05   320: 5.52091e-06   377: 0.000155412   378: 3.28225e-20   379: 3.90598e-05   380: -5.57998e-06   409: 3.90598e-05   410: -5.57998e-06   607: -2.20836e-05   639: -2.23199e-05
Row 378:   39: -1.18585e-19   51: 0.000155412   58: -0.000155412   70: -1.27902e-19   317: -5.52091e-06   318: -2.76045e-06   319: 5.52091e-06   320: 2.76045e-06   377: 3.28225e-20   378: 1.66513e-05   379: -5.57998e-06   380: 2.78999e-06   409: 5.57998e-06   410: -2.78999e-06   607: -9.1056e-21   639: -1.00585e-20
Row 379:   40: -0.00022877   51: -0.000926258   58: -0.000234359   70: -0.000926258   323: 3.81284e-05   324: 5.44691e-06   329: 3.81284e-05   330: 5.44691e-06   377: 3.90598e-05   378: -5.57998e-06   379: 0.000154376   380: -1.77877e-20   409: 3.90598e-05   410: 5.57998e-06   639: -2.23199e-05   640: -2.17876e-05
Row 380:   40: 1.15196e-19   51: 0.000154376   58: -6.77626e-21   70: -0.000154376   323: -5.44691e-06   324: -2.72346e-06   329: 5.44691e-06   330: 2.72346e-06   377: -5.57998e-06   378: 2.78999e-06   379: -1.77877e-20   380: 1.65403e-05   409: 5.57998e-06   410: 2.78999e-06   639: -1.0968e-21   640: 9.1056e-21
Row 381:   40: -0.000231644   41: -0.000237154   52: -0.000937597   65: -0.000937597   325: 3.86074e-05   326: 5.51534e-06   327: 3.86074e-05   328: 5.51534e-06   331: 3.95257e-05   332: 5.64652e-06   335: 3.95257e-05   336: 5.64652e-06   381: 0.000156266   382: -1.69407e-21   620: -2.20614e-05   625: -2.25861e-05
Row 382:   40: -1.15196e-19   41: 1.18585e-19   52: 0.000156266   65: -0.000156266   325: -5.51534e-06   326: -2.75767e-06   327: 5.51534e-06   328: 2.75767e-06   331: -5.64652e-06   332: -2.82326e-06   335: 5.64652e-06   336: 2.82326e-06   381: -1.69407e-21   382: 1.67428e-05   620: -9.31736e-21   625: 9.635e-21
Row 383:   42: -0.000218533   53: -0.000945177   64: -0.000945177   65: -0.000254055   337: 3.64222e-05   338: 5.20317e-06   343: 3.64222e-05   344: 5.20317e-06   383: 0.000157529   384: -1.60936e-20   385: 4.23426e-05   386: -6.04894e-06   445: 4.23426e-05   446: -6.04894e-06   617: -2.08127e-05   635: -2.41957e-05
Row 384:   42: 1.11808e-19   53: 0.000157529   64: -0.000157529   65: -8.47033e-21   337: -5.20317e-06   338: -2.60158e-06   343: 5.20317e-06   344: 2.60158e-06   383: -1.60936e-20   384: 1.68782e-05   385: -6.04894e-06   386: 3.02447e-06   445: 6.04894e-06   446: -3.02447e-06   617: 8.47033e-21   635: -1.15649e-21
Row 385:   41: -0.0002764   53: -0.00106091   64: -0.000254055   65: -0.00106091   333: 4.60667e-05   334: 6.58096e-06   335: 4.60667e-05   336: 6.58096e-06   383: 4.23426e-05   384: -6.04894e-06   385: 0.000176819   386: 3.90165e-20   445: 4.23426e-05   446: 6.04894e-06   626: -2.63238e-05   635: -2.41957e-05
Row 386:   41: -1.38913e-19   53: 0.000176819   64: -1.38913e-19   65: -0.000176819   333: -6.58096e-06   334: -3.29048e-06   335: 6.58096e-06   336: 3.29048e-06   383: -6.04894e-06   384: 3.02447e-06   385: 3.90165e-20   386: 1.89448e-05   445: 6.04894e-06   446: 3.02447e-06   626: -1.10114e-20   635: -1.07997e-20
Row 387:   42: -0.00020813   54: -0.000846595   56: -0.000846595   71: -0.000215168   339: 3.46883e-05   340: 4.95547e-06   341: 3.46883e-05   342: 4.95547e-06   387: 0.000141099   388: 3.17108e-20   389: 3.58613e-05   390: -5.12305e-06   395: 3.58613e-05   396: -5.12305e-06   605: -1.98219e-05   646: -2.04922e-05
Row 388:   42: -1.0842e-19   54: 0.000141099   56: -0.000141099   71: -1.16891e-19   339: -4.95547e-06   340: -2.47773e-06   341: 4.95547e-06   342: 2.47773e-06   387: 3.17108e-20   388: 1.51178e-05   389: -5.12305e-06   390: 2.56152e-06   395: 5.12305e-06   396: -2.56152e-06   605: -8.25857e-21   646: -9.42324e-21
Row 389:   43: -0.000222008   54: -0.000874352   56: -0.000215168   71: -0.000874352   345: 3.70013e-05   346: 5.2859e-06   351: 3.70013e-05   352: 5.2859e-06   387: 3.58613e-05   388: -5.12305e-06   389: 0.000145725   390: -1.73642e-20   395: 3.58613e-05   396: 5.12305e-06   644: -2.11436e-05   646: -2.04922e-05
Row 390:   43: 1.15196e-19   54: 0.000145725   56: -3.38813e-21   71: -0.000145725   345: -5.2859e-06   346: -2.64295e-06   351: 5.2859e-06   352: 2.64295e-06   387: -5.12305e-06   388: 2.56152e-06   389: -1.73642e-20   390: 1.56134e-05   395: 5.12305e-06   396: 2.56152e-06   644: 8.99973e-21   646: -1.04859e-21
Row 391:   32: -0.000239721   43: -0.000231141   55: -0.000941724   67: -0.000941724   267: 3.99535e-05   268: 5.70765e-06   269: 3.99535e-05   270: 5.70765e-06   347: 3.85235e-05   348: 5.50335e-06   349: 3.85235e-05   350: 5.50335e-06   391: 0.000156954   392: -1.69407e-21   632: -2.28306e-05   647: -2.20134e-05
Row 392:   32: 1.25361e-19   43: -1.18585e-19   55: 0.000156954   67: -0.000156954   267: -5.70765e-06   268: -2.85382e-06   269: 5.70765e-06   270: 2.85382e-06   347: -5.50335e-06   348: -2.75168e-06   349: 5.50335e-06   350: 2.75168e-06   391: -1.69407e-21   392: 1.68165e-05   632: 9.1056e-21   647: -9.1056e-21
Row 393:   42: -0.00021506   56: -0.000783772   64: -0.000783772   75: -0.000176827   341: 3.58433e-05   342: 5.12047e-06   343: 3.58433e-05   344: 5.12047e-06   393: 0.000130629   394: 3.02285e-20   399: 2.94711e-05   400: -4.21016e-06   447: 2.94711e-05   448: -4.21016e-06   618: -2.04819e-05   653: -1.68406e-05
Row 394:   42: -1.11808e-19   56: 0.000130629   64: -0.000130629   75: -9.65618e-20   341: -5.12047e-06   342: -2.56023e-06   343: 5.12047e-06   344: 2.56023e-06   393: 3.02285e-20   394: 1.39959e-05   399: -4.21016e-06   400: 2.10508e-06   447: 4.21016e-06   448: -2.10508e-06   618: -8.25857e-21   653: -7.72918e-21
Row 395:   54: -0.000215168   56: -0.000870464   71: -0.000870464   72: -0.000220064   387: 3.58613e-05   388: 5.12305e-06   389: 3.58613e-05   390: 5.12305e-06   395: 0.000145077   396: -1.69407e-20   397: 3.66774e-05   398: -5.23962e-06   477: 3.66774e-05   478: -5.23962e-06   646: -2.04922e-05   649: -2.09585e-05
Row 396:   54: 1.11808e-19   56: 0.000145077   71: -0.000145077   72: -6.77626e-21   387: -5.12305e-06   388: -2.56152e-06   389: 5.12305e-06   390: 2.56152e-06   395: -1.69407e-20   396: 1.5544e-05   397: -5.23962e-06   398: 2.61981e-06   477: 5.23962e-06   478: -2.61981e-06   646: 8.78797e-21   649: -1.01002e-21
Row 397:   56: -0.000793118   71: -0.000220064   72: -0.000793118   75: -0.000176495   395: 3.66774e-05   396: -5.23962e-06   397: 0.000132186   398: 1.73112e-20   399: 2.94158e-05   400: -4.20226e-06   477: 3.66774e-05   478: 5.23962e-06   481: 2.94158e-05   482: -4.20226e-06   649: -2.09585e-05   654: -1.6809e-05
Row 398:   56: 0.000132186   71: -1.20279e-19   72: -0.000132186   75: -5.0822e-21   395: -5.23962e-06   396: 2.61981e-06   397: 1.73112e-20   398: 1.41628e-05   399: -4.20226e-06   400: 2.10113e-06   477: 5.23962e-06   478: 2.61981e-06   481: 4.20226e-06   482: -2.10113e-06   649: -9.42324e-21   654: -6.42452e-22
Row 399:   56: -0.000706643   64: -0.000176827   72: -0.000176495   75: -0.000706643   393: 2.94711e-05   394: -4.21016e-06   397: 2.94158e-05   398: -4.20226e-06   399: 0.000117774   400: 1.33937e-20   447: 2.94711e-05   448: 4.21016e-06   481: 2.94158e-05   482: 4.20226e-06   653: -1.68406e-05   654: -1.6809e-05
Row 400:   56: 0.000117774   64: -3.38813e-21   72: -9.74088e-20   75: -0.000117774   393: -4.21016e-06   394: 2.10508e-06   397: -4.20226e-06   398: 2.10113e-06   399: 1.33937e-20   400: 1.26186e-05   447: 4.21016e-06   448: 2.10508e-06   481: 4.20226e-06   482: 2.10113e-06   653: -8.72298e-22   654: -7.51742e-21
Row 401:   34: -0.00027155   57: -0.00108551   63: -0.00108551   74: -0.000271206   283: 4.52583e-05   284: 6.46547e-06   285: 4.52583e-05   286: 6.46547e-06   401: 0.000180919   402: 3.87518e-20   405: 4.5201e-05   406: -6.45729e-06   441: 4.5201e-05   442: -6.45729e-06   616: -2.58619e-05   651: -2.58292e-05
Row 402:   34: -1.38913e-19   57: 0.000180919   63: -0.000180919   74: -1.47384e-19   283: -6.46547e-06   284: -3.23274e-06   285: 6.46547e-06   286: 3.23274e-06   401: 3.87518e-20   402: 1.93841e-05   405: -6.45729e-06   406: 3.22864e-06   441: 6.45729e-06   442: -3.22864e-06   616: -1.05879e-20   651: -1.19643e-20
Row 403:   47: -0.000275202   57: -0.00109267   68: -0.00109267   74: -0.000271136   363: 4.5867e-05   364: 6.55242e-06   365: 4.5867e-05   366: 6.55242e-06   403: 0.000182112   404: -1.99053e-20   405: 4.51893e-05   406: -6.45561e-06   465: 4.51893e-05   466: -6.45561e-06   641: -2.62097e-05   652: -2.58224e-05
Row 404:   47: 1.38913e-19   57: 0.000182112   68: -0.000182112   74: -6.77626e-21   363: -6.55242e-06   364: -3.27621e-06   365: 6.55242e-06   366: 3.27621e-06   403: -1.99053e-20   404: 1.9512e-05   405: -6.45561e-06   406: 3.2278e-06   465: 6.45561e-06   466: -3.2278e-06   641: 1.07997e-20   652: -1.27809e-21
Row 405:   57: -0.00108468   63: -0.000271206   68: -0.000271136   74: -0.00108468   401: 4.5201e-05   402: -6.45729e-06   403: 4.51893e-05   404: -6.45561e-06   405: 0.000180781   406: 2.02229e-20   441: 4.5201e-05   442: 6.45729e-06   465: 4.51893e-05   466: 6.45561e-06   651: -2.58292e-05   652: -2.58224e-05
Row 406:   57: 0.000180781   63: -6.77626e-21   68: -1.47384e-19   74: -0.000180781   401: -6.45729e-06   402: 3.22864e-06   403: -6.45561e-06   404: 3.2278e-06   405: 2.02229e-20   406: 1.93693e-05   441: 6.45729e-06   442: 3.22864e-06   465: 6.45561e-06   466: 3.2278e-06   651: -1.59915e-21   652: -1.15408e-20
Row 407:   39: -0.000236425   58: -0.000937367   62: -0.000937367   83: -0.000232259   319: 3.94041e-05   320: 5.62916e-06   321: 3.94041e-05   322: 5.62916e-06   407: 0.000156228   408: 3.37225e-20   413: 3.87098e-05   414: -5.52997e-06   439: 3.87098e-05   440: -5.52997e-06   614: -2.25166e-05   672: -2.21199e-05
Row 408:   39: -1.18585e-19   58: 0.000156228   62: -0.000156228   83: -1.26208e-19   319: -5.62916e-06   320: -2.81458e-06   321: 5.62916e-06   322: 2.81458e-06   407: 3.37225e-20   408: 1.67387e-05   413: -5.52997e-06   414: 2.76498e-06   439: 5.52997e-06   440: -2.76498e-06   614: -9.31736e-21   672: -9.84676e-21
Row 409:   51: -0.000234359   58: -0.000934689   70: -0.000934689   73: -0.000232986   377: 3.90598e-05   378: 5.57998e-06   379: 3.90598e-05   380: 5.57998e-06   409: 0.000155782   410: -1.86347e-20   411: 3.88309e-05   412: -5.54728e-06   473: 3.88309e-05   474: -5.54728e-06   639: -2.23199e-05   650: -2.21891e-05
Row 410:   51: 1.21973e-19   58: 0.000155782   70: -0.000155782   73: -1.01644e-20   377: -5.57998e-06   378: -2.78999e-06   379: 5.57998e-06   380: 2.78999e-06   409: -1.86347e-20   410: 1.66909e-05   411: -5.54728e-06   412: 2.77364e-06   473: 5.54728e-06   474: -2.77364e-06   639: 8.89385e-21   650: -8.99897e-22
Row 411:   58: -0.000900123   70: -0.000232986   73: -0.000900123   83: -0.000217076   409: 3.88309e-05   410: -5.54728e-06   411: 0.00015002   412: 1.75759e-20   413: 3.61793e-05   414: -5.16847e-06   473: 3.88309e-05   474: 5.54728e-06   491: 3.61793e-05   492: -5.16847e-06   650: -2.21891e-05   674: -2.06739e-05
Row 412:   58: 0.00015002   70: -1.27055e-19   73: -0.00015002   83: -5.0822e-21   409: -5.54728e-06   410: 2.77364e-06   411: 1.75759e-20   412: 1.60736e-05   413: -5.16847e-06   414: 2.58423e-06   473: 5.54728e-06   474: 2.77364e-06   491: 5.16847e-06   492: -2.58423e-06   650: -1.00585e-20   674: -9.27555e-22
Row 413:   58: -0.000898668   62: -0.000232259   73: -0.000217076   83: -0.000898668   407: 3.87098e-05   408: -5.52997e-06   411: 3.61793e-05   412: -5.16847e-06   413: 0.000149778   414: 1.69936e-20   439: 3.87098e-05   440: 5.52997e-06   491: 3.61793e-05   492: 5.16847e-06   672: -2.21199e-05   674: -2.06739e-05
Row 414:   58: 0.000149778   62: -3.38813e-21   73: -1.18585e-19   83: -0.000149778   407: -5.52997e-06   408: 2.76498e-06   411: -5.16847e-06   412: 2.58423e-06   413: 1.69936e-20   414: 1.60477e-05   439: 5.52997e-06   440: 2.76498e-06   491: 5.16847e-06   492: 2.58423e-06   672: -1.17434e-21   674: -9.52912e-21
Row 415:   36: -0.000217527   59: -0.000866772   68: -0.000866772   81: -0.000215859   297: 3.62545e-05   298: 5.17922e-06   299: 3.62545e-05   300: 5.17922e-06   415: 0.000144462   416: 3.21343e-20   421: 3.59765e-05   422: -5.1395e-06   467: 3.59765e-05   468: -5.1395e-06   629: -2.07169e-05   666: -2.0558e-05
Row 416:   36: -1.0842e-19   59: 0.000144462   68: -0.000144462   81: -1.18585e-19   297: -5.17922e-06   298: -2.58961e-06   299: 5.17922e-06   300: 2.58961e-06   415: 3.21343e-20   416: 1.54781e-05   421: -5.1395e-06   422: 2.56975e-06   467: 5.1395e-06   468: -2.56975e-06   629: -8.57621e-21   666: -9.31736e-21
Row 417:   48: -0.000208835   59: -0.000760572   69: -0.000760572   76: -0.00017145   367: 3.48059e-05   368: 4.97227e-06   369: 3.48059e-05   370: 4.97227e-06   417: 0.000126762   418: -1.69407e-20   419: 2.85751e-05   420: -4.08215e-06   469: 2.85751e-05   470: -4.08215e-06   633: -1.98891e-05   655: -1.63286e-05
Row 418:   48: 1.11808e-19   59: 0.000126762   69: -0.000126762   76: -3.38813e-21   367: -4.97227e-06   368: -2.48614e-06   369: 4.97227e-06   370: 2.48614e-06   417: -1.69407e-20   418: 1.35816e-05   419: -4.08215e-06   420: 2.04108e-06   469: 4.08215e-06   470: -2.04108e-06   633: 8.25857e-21   655: -7.48248e-22
Row 419:   59: -0.000682846   69: -0.00017145   76: -0.000682846   81: -0.000169973   417: 2.85751e-05   418: -4.08215e-06   419: 0.000113808   420: 1.33408e-20   421: 2.83288e-05   422: -4.04697e-06   469: 2.85751e-05   470: 4.08215e-06   509: 2.83288e-05   510: -4.04697e-06   655: -1.63286e-05   668: -1.61879e-05
Row 420:   59: 0.000113808   69: -9.31736e-20   76: -0.000113808   81: -5.0822e-21   417: -4.08215e-06   418: 2.04108e-06   419: 1.33408e-20   420: 1.21937e-05   421: -4.04697e-06   422: 2.02349e-06   469: 4.08215e-06   470: 2.04108e-06   509: 4.04697e-06   510: -2.02349e-06   655: -7.30566e-21   668: -7.50892e-22
Row 421:   59: -0.000771664   68: -0.000215859   76: -0.000169973   81: -0.000771664   415: 3.59765e-05   416: -5.1395e-06   419: 2.83288e-05   420: -4.04697e-06   421: 0.000128611   422: 1.29702e-20   467: 3.59765e-05   468: 5.1395e-06   509: 2.83288e-05   510: 4.04697e-06   666: -2.0558e-05   668: -1.61879e-05
Row 422:   59: 0.000128611   68: -6.77626e-21   76: -9.23266e-20   81: -0.000128611   415: -5.1395e-06   416: 2.56975e-06   419: -4.04697e-06   420: 2.02349e-06   421: 1.29702e-20   422: 1.37797e-05   467: 5.1395e-06   468: 2.56975e-06   509: 4.04697e-06   510: 2.02349e-06   666: -1.11554e-21   668: -7.19978e-21
Row 423:   50: -0.000274002   60: -0.00104863   62: -0.00104863   77: -0.000250313   373: 4.5667e-05   374: 6.52386e-06   375: 4.5667e-05   376: 6.52386e-06   423: 0.000174772   424: -2.11758e-20   427: 4.17188e-05   428: -5.95983e-06   437: 4.17188e-05   438: -5.95983e-06   638: -2.60954e-05   658: -2.38393e-05
Row 424:   50: 1.38913e-19   60: 0.000174772   62: -0.000174772   77: -1.01644e-20   373: -6.52386e-06   374: -3.26193e-06   375: 6.52386e-06   376: 3.26193e-06   423: -2.11758e-20   424: 1.87255e-05   427: -5.95983e-06   428: 2.97992e-06   437: 5.95983e-06   438: -2.97992e-06   638: 1.07997e-20   658: -1.03041e-21
Row 425:   37: -0.000240863   60: -0.000968183   69: -0.000968183   77: -0.000243229   305: 4.01438e-05   306: 5.73483e-06   307: 4.01438e-05   308: 5.73483e-06   425: 0.000161364   426: 3.47284e-20   427: 4.05381e-05   428: -5.79116e-06   471: 4.05381e-05   472: -5.79116e-06   643: -2.29393e-05   656: -2.31646e-05
Row 426:   37: -1.21973e-19   60: 0.000161364   69: -0.000161364   77: -1.33831e-19   305: -5.73483e-06   306: -2.86741e-06   307: 5.73483e-06   308: 2.86741e-06   425: 3.47284e-20   426: 1.7289e-05   427: -5.79116e-06   428: 2.89558e-06   471: 5.79116e-06   472: -2.89558e-06   643: -9.31736e-21   656: -1.03762e-20
Row 427:   60: -0.000987084   62: -0.000250313   69: -0.000243229   77: -0.000987084   423: 4.17188e-05   424: -5.95983e-06   425: 4.05381e-05   426: -5.79116e-06   427: 0.000164514   428: 1.91641e-20   437: 4.17188e-05   438: 5.95983e-06   471: 4.05381e-05   472: 5.79116e-06   656: -2.31646e-05   658: -2.38393e-05
Row 428:   60: 0.000164514   62: -1.36372e-19   69: -6.77626e-21   77: -0.000164514   423: -5.95983e-06   424: 2.97992e-06   425: -5.79116e-06   426: 2.89558e-06   427: 1.91641e-20   428: 1.76265e-05   437: 5.95983e-06   438: 2.97992e-06   471: 5.79116e-06   472: 2.89558e-06   656: -1.32118e-21   658: -1.0482e-20
Row 429:   45: -0.000226033   61: -0.000909008   63: -0.000909008   79: -0.000228471   357: 3.76721e-05   358: 5.38173e-06   359: 3.76721e-05   360: 5.38173e-06   429: 0.000151501   430: -1.82112e-20   435: 3.80786e-05   436: -5.43979e-06   443: 3.80786e-05   444: -5.43979e-06   636: -2.15269e-05   660: -2.17592e-05
Row 430:   45: 1.21973e-19   61: 0.000151501   63: -0.000151501   79: -3.38813e-21   357: -5.38173e-06   358: -2.69087e-06   359: 5.38173e-06   360: 2.69087e-06   429: -1.82112e-20   430: 1.62323e-05   435: -5.43979e-06   436: 2.7199e-06   443: 5.43979e-06   444: -2.7199e-06   636: 8.78797e-21   660: -1.08483e-21
Row 431:   33: -0.000225119   61: -0.000834754   66: -0.000834754   78: -0.000192258   275: 3.75198e-05   276: 5.35997e-06   277: 3.75198e-05   278: 5.35997e-06   431: 0.000139126   432: 3.11814e-20   433: 3.20431e-05   434: -4.57758e-06   457: 3.20431e-05   458: -4.57758e-06   622: -2.14399e-05   659: -1.83103e-05
Row 432:   33: -1.15196e-19   61: 0.000139126   66: -0.000139126   78: -1.05032e-19   275: -5.35997e-06   276: -2.67999e-06   277: 5.35997e-06   278: 2.67999e-06   431: 3.11814e-20   432: 1.49063e-05   433: -4.57758e-06   434: 2.28879e-06   457: 4.57758e-06   458: -2.28879e-06   622: -8.47033e-21   659: -8.25857e-21
Row 433:   61: -0.000755477   66: -0.000192258   78: -0.000755477   79: -0.00018548   431: 3.20431e-05   432: -4.57758e-06   433: 0.000125913   434: 1.38172e-20   435: 3.09134e-05   436: -4.41619e-06   457: 3.20431e-05   458: 4.57758e-06   517: 3.09134e-05   518: -4.41619e-06   659: -1.83103e-05   661: -1.76648e-05
Row 434:   61: 0.000125913   66: -3.38813e-21   78: -0.000125913   79: -1.00797e-19   431: -4.57758e-06   432: 2.28879e-06   433: 1.38172e-20   434: 1.34907e-05   435: -4.41619e-06   436: 2.2081e-06   457: 4.57758e-06   458: 2.28879e-06   517: 4.41619e-06   518: -2.2081e-06   659: -9.77634e-22   661: -7.94093e-21
Row 435:   61: -0.000827903   63: -0.000228471   78: -0.00018548   79: -0.000827903   429: 3.80786e-05   430: -5.43979e-06   433: 3.09134e-05   434: -4.41619e-06   435: 0.000137984   436: 1.70465e-20   443: 3.80786e-05   444: 5.43979e-06   517: 3.09134e-05   518: 4.41619e-06   660: -2.17592e-05   661: -1.76648e-05
Row 436:   61: 0.000137984   63: -1.24514e-19   78: -6.77626e-21   79: -0.000137984   429: -5.43979e-06   430: 2.7199e-06   433: -4.41619e-06   434: 2.2081e-06   435: 1.70465e-20   436: 1.4784e-05   443: 5.43979e-06   444: 2.7199e-06   517: 4.41619e-06   518: 2.2081e-06   660: -9.74088e-21   661: -9.80977e-22
Row 437:   60: -0.000250313   62: -0.000935759   77: -0.000935759   83: -0.000217566   423: 4.17188e-05   424: 5.95983e-06   427: 4.17188e-05   428: 5.95983e-06   437: 0.00015596   438: 3.66871e-20   439: 3.62611e-05   440: -5.18015e-06   513: 3.62611e-05   514: -5.18015e-06   658: -2.38393e-05   673: -2.07206e-05
Row 438:   60: -1.25361e-19   62: 0.00015596   77: -0.00015596   83: -1.19432e-19   423: -5.95983e-06   424: -2.97992e-06   427: 5.95983e-06   428: 2.97992e-06   437: 3.66871e-20   438: 1.671e-05   439: -5.18015e-06   440: 2.59008e-06   513: 5.18015e-06   514: -2.59008e-06   658: -9.74088e-21   673: -9.52912e-21
Row 439:   58: -0.000232259   62: -0.00089965   77: -0.000217566   83: -0.00089965   407: 3.87098e-05   408: 5.52997e-06   413: 3.87098e-05   414: 5.52997e-06   437: 3.62611e-05   438: -5.18015e-06   439: 0.000149942   440: -1.73642e-20   513: 3.62611e-05   514: 5.18015e-06   672: -2.21199e-05   673: -2.07206e-05
Row 440:   58: 1.21973e-19   62: 0.000149942   77: -3.38813e-21   83: -0.000149942   407: -5.52997e-06   408: -2.76498e-06   413: 5.52997e-06   414: 2.76498e-06   437: -5.18015e-06   438: 2.59008e-06   439: -1.73642e-20   440: 1.60652e-05   513: 5.18015e-06   514: 2.59008e-06   672: 9.31736e-21   673: -1.09938e-21
Row 441:   57: -0.000271206   63: -0.000998344   74: -0.000998344   79: -0.000227966   401: 4.5201e-05   402: 6.45729e-06   405: 4.5201e-05   406: 6.45729e-06   441: 0.000166391   442: -2.20229e-20   443: 3.79943e-05   444: -5.42776e-06   497: 3.79943e-05   498: -5.42776e-06   651: -2.58292e-05   662: -2.1711e-05
Row 442:   57: 1.42302e-19   63: 0.000166391   74: -0.000166391   79: -6.77626e-21   401: -6.45729e-06   402: -3.22864e-06   405: 6.45729e-06   406: 3.22864e-06   441: -2.20229e-20   442: 1.78276e-05   443: -5.42776e-06   444: 2.71388e-06   497: 5.42776e-06   498: -2.71388e-06   651: 1.07997e-20   662: -8.39623e-22
Row 443:   61: -0.000228471   63: -0.000912874   74: -0.000227966   79: -0.000912874   429: 3.80786e-05   430: 5.43979e-06   435: 3.80786e-05   436: 5.43979e-06   441: 3.79943e-05   442: -5.42776e-06   443: 0.000152146   444: 3.57871e-20   497: 3.79943e-05   498: 5.42776e-06   660: -2.17592e-05   662: -2.1711e-05
Row 444:   61: -1.18585e-19   63: 0.000152146   74: -1.24514e-19   79: -0.000152146   429: -5.43979e-06   430: -2.7199e-06   435: 5.43979e-06   436: 2.7199e-06   441: -5.42776e-06   442: 2.71388e-06   443: 3.57871e-20   444: 1.63013e-05   497: 5.42776e-06   498: 2.71388e-06   660: -8.68209e-21   662: -9.84676e-21
Row 445:   53: -0.000254055   64: -0.0010093   65: -0.0010093   80: -0.000250597   383: 4.23426e-05   384: 6.04894e-06   385: 4.23426e-05   386: 6.04894e-06   445: 0.000168217   446: 3.92282e-20   449: 4.17661e-05   450: -5.96659e-06   453: 4.17661e-05   454: -5.96659e-06   635: -2.41957e-05   663: -2.38664e-05
Row 446:   53: -1.28749e-19   64: 0.000168217   65: -0.000168217   80: -1.37219e-19   383: -6.04894e-06   384: -3.02447e-06   385: 6.04894e-06   386: 3.02447e-06   445: 3.92282e-20   446: 1.80233e-05   449: -5.96659e-06   450: 2.98329e-06   453: 5.96659e-06   454: -2.98329e-06   635: -9.84676e-21   663: -1.11173e-20
Row 447:   56: -0.000176827   64: -0.000711186   75: -0.000711186   80: -0.000178767   393: 2.94711e-05   394: 4.21016e-06   399: 2.94711e-05   400: 4.21016e-06   447: 0.000118531   448: -1.3129e-20   449: 2.97944e-05   450: -4.25635e-06   503: 2.97944e-05   504: -4.25635e-06   653: -1.68406e-05   665: -1.70254e-05
Row 448:   56: 9.14796e-20   64: 0.000118531   75: -0.000118531   80: -5.0822e-21   393: -4.21016e-06   394: -2.10508e-06   399: 4.21016e-06   400: 2.10508e-06   447: -1.3129e-20   448: 1.26998e-05   449: -4.25635e-06   450: 2.12817e-06   503: 4.25635e-06   504: -2.12817e-06   653: 6.88214e-21   665: -8.83364e-22
Row 449:   64: -0.000858727   65: -0.000250597   75: -0.000178767   80: -0.000858727   445: 4.17661e-05   446: -5.96659e-06   447: 2.97944e-05   448: -4.25635e-06   449: 0.000143121   450: 1.43466e-20   453: 4.17661e-05   454: 5.96659e-06   503: 2.97944e-05   504: 4.25635e-06   663: -2.38664e-05   665: -1.70254e-05
Row 450:   64: 0.000143121   65: -1.01644e-20   75: -9.82558e-20   80: -0.000143121   445: -5.96659e-06   446: 2.98329e-06   447: -4.25635e-06   448: 2.12817e-06   449: 1.43466e-20   450: 1.53344e-05   453: 5.96659e-06   454: 2.98329e-06   503: 4.25635e-06   504: 2.12817e-06   663: -1.25054e-21   665: -7.51742e-21
Row 451:   40: -0.000267245   65: -0.00104126   70: -0.00104126   80: -0.000253384   327: 4.45408e-05   328: 6.36296e-06   329: 4.45408e-05   330: 6.36296e-06   451: 0.000173543   452: 4.00752e-20   453: 4.22306e-05   454: -6.03294e-06   475: 4.22306e-05   476: -6.03294e-06   645: -2.54519e-05   664: -2.41318e-05
Row 452:   40: -1.38913e-19   65: 0.000173543   70: -0.000173543   80: -1.38913e-19   327: -6.36296e-06   328: -3.18148e-06   329: 6.36296e-06   330: 3.18148e-06   451: 4.00752e-20   452: 1.85939e-05   453: -6.03294e-06   454: 3.01647e-06   475: 6.03294e-06   476: -3.01647e-06   645: -1.03762e-20   664: -1.09055e-20
Row 453:   64: -0.000250597   65: -0.00100796   70: -0.000253384   80: -0.00100796   445: 4.17661e-05   446: 5.96659e-06   449: 4.17661e-05   450: 5.96659e-06   451: 4.22306e-05   452: -6.03294e-06   453: 0.000167993   454: -2.28699e-20   475: 4.22306e-05   476: 6.03294e-06   663: -2.38664e-05   664: -2.41318e-05
Row 454:   64: 1.28749e-19   65: 0.000167993   70: -5.0822e-21   80: -0.000167993   445: -5.96659e-06   446: -2.98329e-06   449: 5.96659e-06   450: 2.98329e-06   451: -6.03294e-06   452: 3.01647e-06   453: -2.28699e-20   454: 1.79993e-05   475: 6.03294e-06   476: 3.01647e-06   663: 1.02703e-20   664: -1.35543e-21
Row 455:   44: -0.000263367   66: -0.001051   67: -0.001051   82: -0.000262131   353: 4.38944e-05   354: 6.27063e-06   355: 4.38944e-05   356: 6.27063e-06   455: 0.000175166   456: 4.04988e-20   459: 4.36886e-05   460: -6.24122e-06   463: 4.36886e-05   464: -6.24122e-06   624: -2.50825e-05   671: -2.49649e-05
Row 456:   44: -1.35525e-19   66: 0.000175166   67: -0.000175166   82: -1.43996e-19   353: -6.27063e-06   354: -3.13532e-06   355: 6.27063e-06   356: 3.13532e-06   455: 4.04988e-20   456: 1.87678e-05   459: -6.24122e-06   460: 3.12061e-06   463: 6.24122e-06   464: -3.12061e-06   624: -1.01644e-20   671: -1.13291e-20
Row 457:   61: -0.000192258   66: -0.00076639   78: -0.00076639   82: -0.000190936   431: 3.20431e-05   432: 4.57758e-06   433: 3.20431e-05   434: 4.57758e-06   457: 0.000127732   458: -1.60936e-20   459: 3.18227e-05   460: -4.5461e-06   519: 3.18227e-05   520: -4.5461e-06   659: -1.83103e-05   676: -1.81844e-05
Row 458:   61: 9.82558e-20   66: 0.000127732   78: -0.000127732   82: -5.0822e-21   431: -4.57758e-06   432: -2.28879e-06   433: 4.57758e-06   434: 2.28879e-06   457: -1.60936e-20   458: 1.36855e-05   459: -4.5461e-06   460: 2.27305e-06   519: 4.5461e-06   520: -2.27305e-06   659: 7.72918e-21   676: -9.55124e-22
Row 459:   66: -0.000906135   67: -0.000262131   78: -0.000190936   82: -0.000906135   455: 4.36886e-05   456: -6.24122e-06   457: 3.18227e-05   458: -4.5461e-06   459: 0.000151023   460: 1.58819e-20   463: 4.36886e-05   464: 6.24122e-06   519: 3.18227e-05   520: 4.5461e-06   671: -2.49649e-05   676: -1.81844e-05
Row 460:   66: 0.000151023   67: -5.0822e-21   78: -1.04185e-19   82: -0.000151023   455: -6.24122e-06   456: 3.12061e-06   457: -4.5461e-06   458: 2.27305e-06   459: 1.58819e-20   460: 1.6181e-05   463: 6.24122e-06   464: 3.12061e-06   519: 4.5461e-06   520: 2.27305e-06   671: -1.39356e-21   676: -8.04681e-21
Row 461:   43: -0.000263348   67: -0.00104527   71: -0.00104527   82: -0.000259286   349: 4.38913e-05   350: 6.27019e-06   351: 4.38913e-05   352: 6.27019e-06   461: 0.000174211   462: 3.91223e-20   463: 4.32143e-05   464: -6.17347e-06   479: 4.32143e-05   480: -6.17347e-06   648: -2.50808e-05   669: -2.46939e-05
Row 462:   43: -1.32137e-19   67: 0.000174211   71: -0.000174211   82: -1.43996e-19   349: -6.27019e-06   350: -3.1351e-06   351: 6.27019e-06   352: 3.1351e-06   461: 3.91223e-20   462: 1.86655e-05   463: -6.17347e-06   464: 3.08674e-06   479: 6.17347e-06   480: -3.08674e-06   648: -1.05879e-20   669: -1.12232e-20
Row 463:   66: -0.000262131   67: -0.00104283   71: -0.000259286   82: -0.00104283   455: 4.36886e-05   456: 6.24122e-06   459: 4.36886e-05   460: 6.24122e-06   461: 4.32143e-05   462: -6.17347e-06   463: 0.000173806   464: -1.99053e-20   479: 4.32143e-05   480: 6.17347e-06   669: -2.46939e-05   671: -2.49649e-05
Row 464:   66: 1.32137e-19   67: 0.000173806   71: -6.77626e-21   82: -0.000173806   455: -6.24122e-06   456: -3.12061e-06   459: 6.24122e-06   460: 3.12061e-06   461: -6.17347e-06   462: 3.08674e-06   463: -1.99053e-20   464: 1.8622e-05   479: 6.17347e-06   480: 3.08674e-06   669: -1.17421e-21   671: 1.02703e-20
Row 465:   57: -0.000271136   68: -0.000982786   74: -0.000982786   81: -0.000220257   403: 4.51893e-05   404: 6.45561e-06   405: 4.51893e-05   406: 6.45561e-06   465: 0.000163798   466: 3.5893e-20   467: 3.67095e-05   468: -5.24422e-06   499: 3.67095e-05   500: -5.24422e-06   652: -2.58224e-05   667: -2.09769e-05
Row 466:   57: -1.38913e-19   68: 0.000163798   74: -0.000163798   81: -1.21126e-19   403: -6.45561e-06   404: -3.2278e-06   405: 6.45561e-06   406: 3.2278e-06   465: 3.5893e-20   466: 1.75497e-05   467: -5.24422e-06   468: 2.62211e-06   499: 5.24422e-06   500: -2.62211e-06   652: -1.05879e-20   667: -9.74088e-21
Row 467:   59: -0.000215859   68: -0.000872232   74: -0.000220257   81: -0.000872232   415: 3.59765e-05   416: 5.1395e-06   421: 3.59765e-05   422: 5.1395e-06   465: 3.67095e-05   466: -5.24422e-06   467: 0.000145372   468: -1.56701e-20   499: 3.67095e-05   500: 5.24422e-06   666: -2.0558e-05   667: -2.09769e-05
Row 468:   59: 1.11808e-19   68: 0.000145372   74: -6.77626e-21   81: -0.000145372   415: -5.1395e-06   416: -2.56975e-06   421: 5.1395e-06   422: 2.56975e-06   465: -5.24422e-06   466: 2.62211e-06   467: -1.56701e-20   468: 1.55756e-05   499: 5.24422e-06   500: 2.62211e-06   666: 8.57621e-21   667: -1.18203e-21
Row 469:   59: -0.00017145   69: -0.000688372   76: -0.000688372   77: -0.000172736   417: 2.85751e-05   418: 4.08215e-06   419: 2.85751e-05   420: 4.08215e-06   469: 0.000114729   470: 2.69992e-20   471: 2.87893e-05   472: -4.11275e-06   507: 2.87893e-05   508: -4.11275e-06   655: -1.63286e-05   657: -1.6451e-05
Row 470:   59: -8.47033e-20   69: 0.000114729   76: -0.000114729   77: -9.40207e-20   417: -4.08215e-06   418: -2.04108e-06   419: 4.08215e-06   420: 2.04108e-06   469: 2.69992e-20   470: 1.22924e-05   471: -4.11275e-06   472: 2.05638e-06   507: 4.11275e-06   508: -2.05638e-06   655: -6.77626e-21   657: -7.30566e-21
Row 471:   60: -0.000243229   69: -0.000831929   76: -0.000172736   77: -0.000831929   425: 4.05381e-05   426: 5.79116e-06   427: 4.05381e-05   428: 5.79116e-06   469: 2.87893e-05   470: -4.11275e-06   471: 0.000138655   472: -1.99053e-20   507: 2.87893e-05   508: 4.11275e-06   656: -2.31646e-05   657: -1.6451e-05
Row 472:   60: 1.18585e-19   69: 0.000138655   76: -5.0822e-21   77: -0.000138655   425: -5.79116e-06   426: -2.89558e-06   427: 5.79116e-06   428: 2.89558e-06   469: -4.11275e-06   470: 2.05638e-06   471: -1.99053e-20   472: 1.48559e-05   507: 4.11275e-06   508: 2.05638e-06   656: 9.95264e-21   657: -9.59613e-22
Row 473:   58: -0.000232986   70: -0.000904078   73: -0.000904078   80: -0.000219053   409: 3.88309e-05   410: 5.54728e-06   411: 3.88309e-05   412: 5.54728e-06   473: 0.00015068   474: 3.34049e-20   475: 3.65089e-05   476: -5.21555e-06   489: 3.65089e-05   490: -5.21555e-06   650: -2.21891e-05   675: -2.08622e-05
Row 474:   58: -1.18585e-19   70: 0.00015068   73: -0.00015068   80: -1.20279e-19   409: -5.54728e-06   410: -2.77364e-06   411: 5.54728e-06   412: 2.77364e-06   473: 3.34049e-20   474: 1.61442e-05   475: -5.21555e-06   476: 2.60778e-06   489: 5.21555e-06   490: -2.60778e-06   650: -8.89385e-21   675: -9.42324e-21
Row 475:   65: -0.000253384   70: -0.000944874   73: -0.000219053   80: -0.000944874   451: 4.22306e-05   452: 6.03294e-06   453: 4.22306e-05   454: 6.03294e-06   473: 3.65089e-05   474: -5.21555e-06   475: 0.000157479   476: -1.77877e-20   489: 3.65089e-05   490: 5.21555e-06   664: -2.41318e-05   675: -2.08622e-05
Row 476:   65: 1.28749e-19   70: 0.000157479   73: -6.77626e-21   80: -0.000157479   451: -6.03294e-06   452: -3.01647e-06   453: 6.03294e-06   454: 3.01647e-06   473: -5.21555e-06   474: 2.60778e-06   475: -1.77877e-20   476: 1.68727e-05   489: 5.21555e-06   490: 2.60778e-06   664: 9.74088e-21   675: -1.20145e-21
Row 477:   56: -0.000220064   71: -0.000875208   72: -0.000875208   82: -0.00021754   395: 3.66774e-05   396: 5.23962e-06   397: 3.66774e-05   398: 5.23962e-06   477: 0.000145868   478: 3.30872e-20   479: 3.62567e-05   480: -5.17952e-06   483: 3.62567e-05   484: -5.17952e-06   649: -2.09585e-05   670: -2.07181e-05
Row 478:   56: -1.11808e-19   71: 0.000145868   72: -0.000145868   82: -1.18585e-19   395: -5.23962e-06   396: -2.61981e-06   397: 5.23962e-06   398: 2.61981e-06   477: 3.30872e-20   478: 1.56287e-05   479: -5.17952e-06   480: 2.58976e-06   483: 5.17952e-06   484: -2.58976e-06   649: -8.68209e-21   670: -9.52912e-21
Row 479:   67: -0.000259286   71: -0.000953652   72: -0.00021754   82: -0.000953652   461: 4.32143e-05   462: 6.17347e-06   463: 4.32143e-05   464: 6.17347e-06   477: 3.62567e-05   478: -5.17952e-06   479: 0.000158942   480: -2.07523e-20   483: 3.62567e-05   484: 5.17952e-06   669: -2.46939e-05   670: -2.07181e-05
Row 480:   67: 1.32137e-19   71: 0.000158942   72: -3.38813e-21   82: -0.000158942   461: -6.17347e-06   462: -3.08674e-06   463: 6.17347e-06   464: 3.08674e-06   477: -5.17952e-06   478: 2.58976e-06   479: -2.07523e-20   480: 1.70295e-05   483: 5.17952e-06   484: 2.58976e-06   669: 1.06938e-20   670: -1.07255e-21
Row 481:   56: -0.000176495   72: -0.000706269   75: -0.000706269   84: -0.00017664   397: 2.94158e-05   398: 4.20226e-06   399: 2.94158e-05   400: 4.20226e-06   481: 0.000117712   482: 2.65227e-20   485: 2.944e-05   486: -4.20571e-06   505: 2.944e-05   506: -4.20571e-06   654: -1.6809e-05   679: -1.68229e-05
Row 482:   56: -9.14796e-20   72: 0.000117712   75: -0.000117712   84: -9.57147e-20   397: -4.20226e-06   398: -2.10113e-06   399: 4.20226e-06   400: 2.10113e-06   481: 2.65227e-20   482: 1.2612e-05   485: -4.20571e-06   486: 2.10286e-06   505: 4.20571e-06   506: -2.10286e-06   654: -6.98802e-21   679: -7.72918e-21
Row 483:   71: -0.00021754   72: -0.000926592   82: -0.000926592   86: -0.000245756   477: 3.62567e-05   478: 5.17952e-06   479: 3.62567e-05   480: 5.17952e-06   483: 0.000154432   484: -1.73642e-20   487: 4.09593e-05   488: -5.85133e-06   533: 4.09593e-05   534: -5.85133e-06   670: -2.07181e-05   682: -2.34053e-05
Row 484:   71: 1.0842e-19   72: 0.000154432   82: -0.000154432   86: -6.77626e-21   477: -5.17952e-06   478: -2.58976e-06   479: 5.17952e-06   480: 2.58976e-06   483: -1.73642e-20   484: 1.65463e-05   487: -5.85133e-06   488: 2.92566e-06   533: 5.85133e-06   534: -2.92566e-06   670: 8.47033e-21   682: -1.0622e-21
Row 485:   72: -0.000842304   75: -0.00017664   84: -0.000842304   86: -0.000244512   481: 2.944e-05   482: -4.20571e-06   485: 0.000140384   486: 1.8423e-20   487: 4.0752e-05   488: -5.82172e-06   505: 2.944e-05   506: 4.20571e-06   539: 4.0752e-05   540: -5.82172e-06   679: -1.68229e-05   683: -2.32869e-05
Row 486:   72: 0.000140384   75: -5.0822e-21   84: -0.000140384   86: -1.32984e-19   481: -4.20571e-06   482: 2.10286e-06   485: 1.8423e-20   486: 1.50411e-05   487: -5.82172e-06   488: 2.91086e-06   505: 4.20571e-06   506: 2.10286e-06   539: 5.82172e-06   540: -2.91086e-06   679: -8.6112e-22   683: -1.09055e-20
Row 487:   72: -0.000980536   82: -0.000245756   84: -0.000244512   86: -0.000980536   483: 4.09593e-05   484: -5.85133e-06   485: 4.0752e-05   486: -5.82172e-06   487: 0.000163423   488: 1.87406e-20   533: 4.09593e-05   534: 5.85133e-06   539: 4.0752e-05   540: 5.82172e-06   682: -2.34053e-05   683: -2.32869e-05
Row 488:   72: 0.000163423   82: -1.33831e-19   84: -3.38813e-21   86: -0.000163423   483: -5.85133e-06   484: 2.92566e-06   485: -5.82172e-06   486: 2.91086e-06   487: 1.87406e-20   488: 1.75096e-05   533: 5.85133e-06   534: 2.92566e-06   539: 5.82172e-06   540: 2.91086e-06   682: -1.01644e-20   683: -1.14236e-21
Row 489:   70: -0.000219053   73: -0.000878763   80: -0.000878763   84: -0.000220328   473: 3.65089e-05   474: 5.21555e-06   475: 3.65089e-05   476: 5.21555e-06   489: 0.00014646   490: -1.94818e-20   493: 3.67214e-05   494: -5.24591e-06   527: 3.67214e-05   528: -5.24591e-06   675: -2.08622e-05   677: -2.09836e-05
Row 490:   70: 1.11808e-19   73: 0.00014646   80: -0.00014646   84: -5.0822e-21   473: -5.21555e-06   474: -2.60778e-06   475: 5.21555e-06   476: 2.60778e-06   489: -1.94818e-20   490: 1.56922e-05   493: -5.24591e-06   494: 2.62295e-06   527: 5.24591e-06   528: -2.62295e-06   675: 8.78797e-21   677: -9.09796e-22
Row 491:   58: -0.000217076   73: -0.000883491   83: -0.000883491   88: -0.00022467   411: 3.61793e-05   412: 5.16847e-06   413: 3.61793e-05   414: 5.16847e-06   491: 0.000147248   492: 3.37754e-20   495: 3.74449e-05   496: -5.34928e-06   537: 3.74449e-05   538: -5.34928e-06   674: -2.06739e-05   691: -2.13971e-05
Row 492:   58: -1.15196e-19   73: 0.000147248   83: -0.000147248   88: -1.2282e-19   411: -5.16847e-06   412: -2.58423e-06   413: 5.16847e-06   414: 2.58423e-06   491: 3.37754e-20   492: 1.57766e-05   495: -5.34928e-06   496: 2.67464e-06   537: 5.34928e-06   538: -2.67464e-06   674: -8.57621e-21   691: -9.74088e-21
Row 493:   73: -0.000862345   80: -0.000220328   84: -0.000862345   88: -0.000210845   489: 3.67214e-05   490: -5.24591e-06   493: 0.000143724   494: 1.61995e-20   495: 3.51408e-05   496: -5.02011e-06   527: 3.67214e-05   528: 5.24591e-06   541: 3.51408e-05   542: -5.02011e-06   677: -2.09836e-05   690: -2.00804e-05
Row 494:   73: 0.000143724   80: -1.20279e-19   84: -0.000143724   88: -6.77626e-21   489: -5.24591e-06   490: 2.62295e-06   493: 1.61995e-20   494: 1.5399e-05   495: -5.02011e-06   496: 2.51005e-06   527: 5.24591e-06   528: 2.62295e-06   541: 5.02011e-06   542: -2.51005e-06   677: -9.31736e-21   690: -7.87299e-22
Row 495:   73: -0.000871029   83: -0.00022467   84: -0.000210845   88: -0.000871029   491: 3.74449e-05   492: -5.34928e-06   493: 3.51408e-05   494: -5.02011e-06   495: 0.000145171   496: 1.72583e-20   537: 3.74449e-05   538: 5.34928e-06   541: 3.51408e-05   542: 5.02011e-06   690: -2.00804e-05   691: -2.13971e-05
Row 496:   73: 0.000145171   83: -5.0822e-21   84: -1.13502e-19   88: -0.000145171   491: -5.34928e-06   492: 2.67464e-06   493: -5.02011e-06   494: 2.51005e-06   495: 1.72583e-20   496: 1.55541e-05   537: 5.34928e-06   538: 2.67464e-06   541: 5.02011e-06   542: 2.51005e-06   690: -8.89385e-21   691: -1.02269e-21
Row 497:   63: -0.000227966   74: -0.000908612   79: -0.000908612   87: -0.00022634   441: 3.79943e-05   442: 5.42776e-06   443: 3.79943e-05   444: 5.42776e-06   497: 0.000151435   498: 3.43578e-20   501: 3.77234e-05   502: -5.38906e-06   525: 3.77234e-05   526: -5.38906e-06   662: -2.1711e-05   686: -2.15562e-05
Row 498:   63: -1.18585e-19   74: 0.000151435   79: -0.000151435   87: -1.23667e-19   441: -5.42776e-06   442: -2.71388e-06   443: 5.42776e-06   444: 2.71388e-06   497: 3.43578e-20   498: 1.62252e-05   501: -5.38906e-06   502: 2.69453e-06   525: 5.38906e-06   526: -2.69453e-06   662: -8.89385e-21   686: -9.74088e-21
Row 499:   68: -0.000220257   74: -0.000881463   81: -0.000881463   87: -0.000220474   465: 3.67095e-05   466: 5.24422e-06   467: 3.67095e-05   468: 5.24422e-06   499: 0.00014691   500: -1.69407e-20   501: 3.67457e-05   502: -5.24938e-06   531: 3.67457e-05   532: -5.24938e-06   667: -2.09769e-05   688: -2.09975e-05
Row 500:   68: 1.11808e-19   74: 0.00014691   81: -0.00014691   87: -5.0822e-21   465: -5.24422e-06   466: -2.62211e-06   467: 5.24422e-06   468: 2.62211e-06   499: -1.69407e-20   500: 1.57404e-05   501: -5.24938e-06   502: 2.62469e-06   531: 5.24938e-06   532: -2.62469e-06   667: 8.89385e-21   688: -1.06453e-21
Row 501:   74: -0.000893629   79: -0.00022634   81: -0.000220474   87: -0.000893629   497: 3.77234e-05   498: -5.38906e-06   499: 3.67457e-05   500: -5.24938e-06   501: 0.000148938   502: 1.56701e-20   525: 3.77234e-05   526: 5.38906e-06   531: 3.67457e-05   532: 5.24938e-06   686: -2.15562e-05   688: -2.09975e-05
Row 502:   74: 0.000148938   79: -6.77626e-21   81: -1.20279e-19   87: -0.000148938   497: -5.38906e-06   498: 2.69453e-06   499: -5.24938e-06   500: 2.62469e-06   501: 1.56701e-20   502: 1.59577e-05   525: 5.38906e-06   526: 2.69453e-06   531: 5.24938e-06   532: 2.62469e-06   686: -1.05437e-21   688: -9.42324e-21
Row 503:   64: -0.000178767   75: -0.000716248   80: -0.000716248   84: -0.000179357   447: 2.97944e-05   448: 4.25635e-06   449: 2.97944e-05   450: 4.25635e-06   503: 0.000119375   504: 2.69462e-20   505: 2.98929e-05   506: -4.27041e-06   527: 2.98929e-05   528: -4.27041e-06   665: -1.70254e-05   678: -1.70817e-05
Row 504:   64: -9.48677e-20   75: 0.000119375   80: -0.000119375   84: -9.74088e-20   447: -4.25635e-06   448: -2.12817e-06   449: 4.25635e-06   450: 2.12817e-06   503: 2.69462e-20   504: 1.27901e-05   505: -4.27041e-06   506: 2.13521e-06   527: 4.27041e-06   528: -2.13521e-06   665: -6.98802e-21   678: -7.72918e-21
Row 505:   72: -0.00017664   75: -0.000711995   80: -0.000179357   84: -0.000711995   481: 2.944e-05   482: 4.20571e-06   485: 2.944e-05   486: 4.20571e-06   503: 2.98929e-05   504: -4.27041e-06   505: 0.000118666   506: -1.43996e-20   527: 2.98929e-05   528: 4.27041e-06   678: -1.70817e-05   679: -1.68229e-05
Row 506:   72: 9.14796e-20   75: 0.000118666   80: -5.0822e-21   84: -0.000118666   481: -4.20571e-06   482: -2.10286e-06   485: 4.20571e-06   486: 2.10286e-06   503: -4.27041e-06   504: 2.13521e-06   505: -1.43996e-20   506: 1.27142e-05   527: 4.27041e-06   528: 2.13521e-06   678: -1.02421e-21   679: 6.98802e-21
Row 507:   69: -0.000172736   76: -0.000688336   77: -0.000688336   85: -0.000171432   469: 2.87893e-05   470: 4.11275e-06   471: 2.87893e-05   472: 4.11275e-06   507: 0.000114723   508: -1.35525e-20   511: 2.8572e-05   512: -4.08172e-06   515: 2.8572e-05   516: -4.08172e-06   657: -1.6451e-05   680: -1.63269e-05
Row 508:   69: 8.80914e-20   76: 0.000114723   77: -0.000114723   85: -5.0822e-21   469: -4.11275e-06   470: -2.05638e-06   471: 4.11275e-06   472: 2.05638e-06   507: -1.35525e-20   508: 1.22917e-05   511: -4.08172e-06   512: 2.04086e-06   515: 4.08172e-06   516: -2.04086e-06   657: 6.67038e-21   680: -7.10701e-22
Row 509:   59: -0.000169973   76: -0.000679822   81: -0.000679822   85: -0.000169938   419: 2.83288e-05   420: 4.04697e-06   421: 2.83288e-05   422: 4.04697e-06   509: 0.000113304   510: 2.5358e-20   511: 2.83231e-05   512: -4.04615e-06   529: 2.83231e-05   530: -4.04615e-06   668: -1.61879e-05   689: -1.61846e-05
Row 510:   59: -8.80914e-20   76: 0.000113304   81: -0.000113304   85: -9.23266e-20   419: -4.04697e-06   420: -2.02349e-06   421: 4.04697e-06   422: 2.02349e-06   509: 2.5358e-20   510: 1.21397e-05   511: -4.04615e-06   512: 2.02308e-06   529: 4.04615e-06   530: -2.02308e-06   668: -6.56451e-21   689: -7.41154e-21
Row 511:   76: -0.000682741   77: -0.000171432   81: -0.000169938   85: -0.000682741   507: 2.8572e-05   508: -4.08172e-06   509: 2.83231e-05   510: -4.04615e-06   511: 0.00011379   512: 1.34466e-20   515: 2.8572e-05   516: 4.08172e-06   529: 2.83231e-05   530: 4.04615e-06   680: -1.63269e-05   689: -1.61846e-05
Row 512:   76: 0.00011379   77: -9.31736e-20   81: -5.0822e-21   85: -0.00011379   507: -4.08172e-06   508: 2.04086e-06   509: -4.04615e-06   510: 2.02308e-06   511: 1.34466e-20   512: 1.21918e-05   515: 4.08172e-06   516: 2.04086e-06   529: 4.04615e-06   530: 2.02308e-06   680: -7.30566e-21   689: -7.95905e-22
Row 513:   62: -0.000217566   77: -0.000859447   83: -0.000859447   85: -0.000212157   437: 3.62611e-05   438: 5.18015e-06   439: 3.62611e-05   440: 5.18015e-06   513: 0.000143241   514: -1.86347e-20   515: 3.53595e-05   516: -5.05136e-06   535: 3.53595e-05   536: -5.05136e-06   673: -2.07206e-05   681: -2.02054e-05
Row 514:   62: 1.15196e-19   77: 0.000143241   83: -0.000143241   85: -8.47033e-21   437: -5.18015e-06   438: -2.59008e-06   439: 5.18015e-06   440: 2.59008e-06   513: -1.86347e-20   514: 1.53473e-05   515: -5.05136e-06   516: 2.52568e-06   535: 5.05136e-06   536: -2.52568e-06   673: 8.25857e-21   681: -9.7042e-22
Row 515:   76: -0.000171432   77: -0.000767179   83: -0.000212157   85: -0.000767179   507: 2.8572e-05   508: 4.08172e-06   511: 2.8572e-05   512: 4.08172e-06   513: 3.53595e-05   514: -5.05136e-06   515: 0.000127863   516: 2.87991e-20   535: 3.53595e-05   536: 5.05136e-06   680: -1.63269e-05   681: -2.02054e-05
Row 516:   76: -8.80914e-20   77: 0.000127863   83: -1.14349e-19   85: -0.000127863   507: -4.08172e-06   508: -2.04086e-06   511: 4.08172e-06   512: 2.04086e-06   513: -5.05136e-06   514: 2.52568e-06   515: 2.87991e-20   516: 1.36996e-05   535: 5.05136e-06   536: 2.52568e-06   680: -6.35275e-21   681: -9.31736e-21
Row 517:   61: -0.00018548   78: -0.00079569   79: -0.00079569   86: -0.000212365   433: 3.09134e-05   434: 4.41619e-06   435: 3.09134e-05   436: 4.41619e-06   517: 0.000132615   518: -1.52466e-20   521: 3.53941e-05   522: -5.0563e-06   523: 3.53941e-05   524: -5.0563e-06   661: -1.76648e-05   685: -2.02252e-05
Row 518:   61: 9.48677e-20   78: 0.000132615   79: -0.000132615   86: -6.77626e-21   433: -4.41619e-06   434: -2.2081e-06   435: 4.41619e-06   436: 2.2081e-06   517: -1.52466e-20   518: 1.42087e-05   521: -5.0563e-06   522: 2.52815e-06   523: 5.0563e-06   524: -2.52815e-06   661: 7.19978e-21   685: -9.73181e-22
Row 519:   66: -0.000190936   78: -0.000814086   82: -0.000814086   86: -0.000216107   457: 3.18227e-05   458: 4.5461e-06   459: 3.18227e-05   460: 4.5461e-06   519: 0.000135681   520: 3.20284e-20   521: 3.60178e-05   522: -5.1454e-06   533: 3.60178e-05   534: -5.1454e-06   676: -1.81844e-05   684: -2.05816e-05
Row 520:   66: -9.82558e-20   78: 0.000135681   82: -0.000135681   86: -1.17738e-19   457: -4.5461e-06   458: -2.27305e-06   459: 4.5461e-06   460: 2.27305e-06   519: 3.20284e-20   520: 1.45372e-05   521: -5.1454e-06   522: 2.5727e-06   533: 5.1454e-06   534: -2.5727e-06   676: -7.30566e-21   684: -9.42324e-21
Row 521:   78: -0.000856943   79: -0.000212365   82: -0.000216107   86: -0.000856943   517: 3.53941e-05   518: -5.0563e-06   519: 3.60178e-05   520: -5.1454e-06   521: 0.000142824   522: 1.59348e-20   523: 3.53941e-05   524: 5.0563e-06   533: 3.60178e-05   534: 5.1454e-06   684: -2.05816e-05   685: -2.02252e-05
Row 522:   78: 0.000142824   79: -1.16044e-19   82: -8.47033e-21   86: -0.000142824   517: -5.0563e-06   518: 2.52815e-06   519: -5.1454e-06   520: 2.5727e-06   521: 1.59348e-20   522: 1.53025e-05   523: 5.0563e-06   524: 2.52815e-06   533: 5.1454e-06   534: 2.5727e-06   684: -1.27997e-21   685: -9.1056e-21
Row 523:   78: -0.000212365   79: -0.000916281   86: -0.000916281   87: -0.000245776   517: 3.53941e-05   518: 5.0563e-06   521: 3.53941e-05   522: 5.0563e-06   523: 0.000152714   524: 3.47813e-20   525: 4.09627e-05   526: -5.85181e-06   547: 4.09627e-05   548: -5.85181e-06   685: -2.02252e-05   687: -2.34072e-05
Row 524:   78: -1.0842e-19   79: 0.000152714   86: -0.000152714   87: -1.34678e-19   517: -5.0563e-06   518: -2.52815e-06   521: 5.0563e-06   522: 2.52815e-06   523: 3.47813e-20   524: 1.63622e-05   525: -5.85181e-06   526: 2.9259e-06   547: 5.85181e-06   548: -2.9259e-06   685: -8.25857e-21   687: -1.05879e-20
Row 525:   74: -0.00022634   79: -0.000944233   86: -0.000245776   87: -0.000944233   497: 3.77234e-05   498: 5.38906e-06   501: 3.77234e-05   502: 5.38906e-06   523: 4.09627e-05   524: -5.85181e-06   525: 0.000157372   526: -1.69407e-20   547: 4.09627e-05   548: 5.85181e-06   686: -2.15562e-05   687: -2.34072e-05
Row 526:   74: 1.15196e-19   79: 0.000157372   86: -5.0822e-21   87: -0.000157372   497: -5.38906e-06   498: -2.69453e-06   501: 5.38906e-06   502: 2.69453e-06   523: -5.85181e-06   524: 2.9259e-06   525: -1.69407e-20   526: 1.68613e-05   547: 5.85181e-06   548: 2.9259e-06   686: 9.1056e-21   687: -1.1763e-21
Row 527:   73: -0.000220328   75: -0.000179357   80: -0.000799371   84: -0.000799371   489: 3.67214e-05   490: 5.24591e-06   493: 3.67214e-05   494: 5.24591e-06   503: 2.98929e-05   504: 4.27041e-06   505: 2.98929e-05   506: 4.27041e-06   527: 0.000133229   528: 1.69407e-21   677: -2.09836e-05   678: -1.70817e-05
Row 528:   73: -1.11808e-19   75: 9.14796e-20   80: 0.000133229   84: -0.000133229   489: -5.24591e-06   490: -2.62295e-06   493: 5.24591e-06   494: 2.62295e-06   503: -4.27041e-06   504: -2.13521e-06   505: 4.27041e-06   506: 2.13521e-06   527: 1.69407e-21   528: 1.42745e-05   677: -8.68209e-21   678: 6.98802e-21
Row 529:   76: -0.000169938   81: -0.000762086   85: -0.000762086   87: -0.000211105   509: 2.83231e-05   510: 4.04615e-06   511: 2.83231e-05   512: 4.04615e-06   529: 0.000127014   530: -1.3129e-20   531: 3.51841e-05   532: -5.0263e-06   543: 3.51841e-05   544: -5.0263e-06   689: -1.61846e-05   694: -2.01052e-05
Row 530:   76: 8.80914e-20   81: 0.000127014   85: -0.000127014   87: -5.0822e-21   509: -4.04615e-06   510: -2.02308e-06   511: 4.04615e-06   512: 2.02308e-06   529: -1.3129e-20   530: 1.36087e-05   531: -5.0263e-06   532: 2.51315e-06   543: 5.0263e-06   544: -2.51315e-06   689: 6.98802e-21   694: -8.72046e-22
Row 531:   74: -0.000220474   81: -0.000863158   85: -0.000211105   87: -0.000863158   499: 3.67457e-05   500: 5.24938e-06   501: 3.67457e-05   502: 5.24938e-06   529: 3.51841e-05   530: -5.0263e-06   531: 0.00014386   532: 3.1499e-20   543: 3.51841e-05   544: 5.0263e-06   688: -2.09975e-05   694: -2.01052e-05
Row 532:   74: -1.15196e-19   81: 0.00014386   85: -1.14349e-19   87: -0.00014386   499: -5.24938e-06   500: -2.62469e-06   501: 5.24938e-06   502: 2.62469e-06   529: -5.0263e-06   530: 2.51315e-06   531: 3.1499e-20   532: 1.54135e-05   543: 5.0263e-06   544: 2.51315e-06   688: -8.78797e-21   694: -9.21148e-21
Row 533:   72: -0.000245756   78: -0.000216107   82: -0.000923725   86: -0.000923725   483: 4.09593e-05   484: 5.85133e-06   487: 4.09593e-05   488: 5.85133e-06   519: 3.60178e-05   520: 5.1454e-06   521: 3.60178e-05   522: 5.1454e-06   533: 0.000153954   534: 0   682: -2.34053e-05   684: -2.05816e-05
Row 534:   72: -1.25361e-19   78: 1.0842e-19   82: 0.000153954   86: -0.000153954   483: -5.85133e-06   484: -2.92566e-06   487: 5.85133e-06   488: 2.92566e-06   519: -5.1454e-06   520: -2.5727e-06   521: 5.1454e-06   522: 2.5727e-06   533: 0   534: 1.64951e-05   682: -9.31736e-21   684: 8.47033e-21
Row 535:   77: -0.000212157   83: -0.000835464   85: -0.000835464   88: -0.000205575   513: 3.53595e-05   514: 5.05136e-06   515: 3.53595e-05   516: 5.05136e-06   535: 0.000139244   536: 3.19755e-20   537: 3.42625e-05   538: -4.89465e-06   545: 3.42625e-05   546: -4.89465e-06   681: -2.02054e-05   693: -1.95786e-05
Row 536:   77: -1.05032e-19   83: 0.000139244   85: -0.000139244   88: -1.13502e-19   513: -5.05136e-06   514: -2.52568e-06   515: 5.05136e-06   516: 2.52568e-06   535: 3.19755e-20   536: 1.4919e-05   537: -4.89465e-06   538: 2.44732e-06   545: 4.89465e-06   546: -2.44732e-06   681: -8.36445e-21   693: -8.89385e-21
Row 537:   73: -0.00022467   83: -0.00086049   85: -0.000205575   88: -0.00086049   491: 3.74449e-05   492: 5.34928e-06   495: 3.74449e-05   496: 5.34928e-06   535: 3.42625e-05   536: -4.89465e-06   537: 0.000143415   538: -1.69407e-20   545: 3.42625e-05   546: 4.89465e-06   691: -2.13971e-05   693: -1.95786e-05
Row 538:   73: 1.15196e-19   83: 0.000143415   85: -6.77626e-21   88: -0.000143415   491: -5.34928e-06   492: -2.67464e-06   495: 5.34928e-06   496: 2.67464e-06   535: -4.89465e-06   536: 2.44732e-06   537: -1.69407e-20   538: 1.53659e-05   545: 4.89465e-06   546: 2.44732e-06   691: 8.89385e-21   693: -1.04085e-21
Row 539:   72: -0.000244512   84: -0.000960675   86: -0.000960675   88: -0.000235825   485: 4.0752e-05   486: 5.82172e-06   487: 4.0752e-05   488: 5.82172e-06   539: 0.000160112   540: -1.86347e-20   541: 3.93042e-05   542: -5.61489e-06   549: 3.93042e-05   550: -5.61489e-06   683: -2.32869e-05   692: -2.24595e-05
Row 540:   72: 1.28749e-19   84: 0.000160112   86: -0.000160112   88: -1.01644e-20   485: -5.82172e-06   486: -2.91086e-06   487: 5.82172e-06   488: 2.91086e-06   539: -1.86347e-20   540: 1.71549e-05   541: -5.61489e-06   542: 2.80744e-06   549: 5.61489e-06   550: -2.80744e-06   683: 9.74088e-21   692: -1.07301e-21
Row 541:   73: -0.000210845   84: -0.00089334   86: -0.000235825   88: -0.00089334   493: 3.51408e-05   494: 5.02011e-06   495: 3.51408e-05   496: 5.02011e-06   539: 3.93042e-05   540: -5.61489e-06   541: 0.00014889   542: 3.51519e-20   549: 3.93042e-05   550: 5.61489e-06   690: -2.00804e-05   692: -2.24595e-05
Row 542:   73: -1.05032e-19   84: 0.00014889   86: -1.28749e-19   88: -0.00014889   493: -5.02011e-06   494: -2.51005e-06   495: 5.02011e-06   496: 2.51005e-06   539: -5.61489e-06   540: 2.80744e-06   541: 3.51519e-20   542: 1.59525e-05   549: 5.61489e-06   550: 2.80744e-06   690: -8.04681e-21   692: -1.02703e-20
Row 543:   81: -0.000211105   85: -0.00083886   87: -0.00083886   88: -0.000208325   529: 3.51841e-05   530: 5.0263e-06   531: 3.51841e-05   532: 5.0263e-06   543: 0.00013981   544: 3.3246e-20   545: 3.47209e-05   546: -4.96012e-06   551: 3.47209e-05   552: -4.96012e-06   694: -2.01052e-05   696: -1.98405e-05
Row 544:   81: -1.0842e-19   85: 0.00013981   87: -0.00013981   88: -1.13502e-19   529: -5.0263e-06   530: -2.51315e-06   531: 5.0263e-06   532: 2.51315e-06   543: 3.3246e-20   544: 1.49796e-05   545: -4.96012e-06   546: 2.48006e-06   551: 4.96012e-06   552: -2.48006e-06   694: -8.25857e-21   696: -9.1056e-21
Row 545:   83: -0.000205575   85: -0.000827801   87: -0.000208325   88: -0.000827801   535: 3.42625e-05   536: 4.89465e-06   537: 3.42625e-05   538: 4.89465e-06   543: 3.47209e-05   544: -4.96012e-06   545: 0.000137967   546: -1.77877e-20   551: 3.47209e-05   552: 4.96012e-06   693: -1.95786e-05   696: -1.98405e-05
Row 546:   83: 1.01644e-19   85: 0.000137967   87: -6.77626e-21   88: -0.000137967   535: -4.89465e-06   536: -2.44732e-06   537: 4.89465e-06   538: 2.44732e-06   543: -4.96012e-06   544: 2.48006e-06   545: -1.77877e-20   546: 1.47822e-05   551: 4.96012e-06   552: 2.48006e-06   693: 8.25857e-21   696: -1.17865e-21
Row 547:   79: -0.000245776   86: -0.00100079   87: -0.00100079   88: -0.000254619   523: 4.09627e-05   524: 5.85181e-06   525: 4.09627e-05   526: 5.85181e-06   547: 0.000166798   548: -1.82112e-20   549: 4.24364e-05   550: -6.06235e-06   551: 4.24364e-05   552: -6.06235e-06   687: -2.34072e-05   695: -2.42494e-05
Row 548:   79: 1.28749e-19   86: 0.000166798   87: -0.000166798   88: -5.0822e-21   523: -5.85181e-06   524: -2.9259e-06   525: 5.85181e-06   526: 2.9259e-06   547: -1.82112e-20   548: 1.78712e-05   549: -6.06235e-06   550: 3.03117e-06   551: 6.06235e-06   552: -3.03117e-06   687: 1.00585e-20   695: -1.06261e-21
Row 549:   84: -0.000235825   86: -0.000980887   87: -0.000254619   88: -0.000980887   539: 3.93042e-05   540: 5.61489e-06   541: 3.93042e-05   542: 5.61489e-06   547: 4.24364e-05   548: -6.06235e-06   549: 0.000163481   550: 3.73224e-20   551: 4.24364e-05   552: 6.06235e-06   692: -2.24595e-05   695: -2.42494e-05
Row 550:   84: -1.18585e-19   86: 0.000163481   87: -1.38913e-19   88: -0.000163481   539: -5.61489e-06   540: -2.80744e-06   541: 5.61489e-06   542: 2.80744e-06   547: -6.06235e-06   548: 3.03117e-06   549: 3.73224e-20   550: 1.75158e-05   551: 6.06235e-06   552: 3.03117e-06   692: -9.31736e-21   695: -1.10114e-20
Row 551:   85: -0.000208325   86: -0.000254619   87: -0.000925887   88: -0.000925887   543: 3.47209e-05   544: 4.96012e-06   545: 3.47209e-05   546: 4.96012e-06   547: 4.24364e-05   548: 6.06235e-06   549: 4.24364e-05   550: 6.06235e-06   551: 0.000154315   552: 3.38813e-21   695: -2.42494e-05   696: -1.98405e-05
Row 552:   85: 1.0842e-19   86: -1.25361e-19   87: 0.000154315   88: -0.000154315   543: -4.96012e-06   544: -2.48006e-06   545: 4.96012e-06   546: 2.48006e-06   547: -6.06235e-06   548: -3.03117e-06   549: 6.06235e-06   550: 3.03117e-06   551: 3.38813e-21   552: 1.65337e-05   695: -1.01644e-20   696: 8.04681e-21
Row 553:   0: 0.000173611   4: 0.000173611   31: 0.000173611   89: -2.48016e-05   90: -1.27963e-21   91: -2.48016e-05   92: -1.11173e-20   107: -2.48016e-05   108: -1.01644e-20   553: 1.24008e-05
Row 554:   4: 0.000153219   5: 0.000153219   32: 0.000153219   105: -2.18884e-05   106: -1.01322e-21   109: -2.18884e-05   110: -9.95264e-21   113: -2.18884e-05   114: -8.89385e-21   554: 1.09442e-05
Row 555:   6: 0.00015059   7: 0.00015059   33: 0.00015059   117: -2.15129e-05   118: -8.80202e-22   119: -2.15129e-05   120: -9.84676e-21   125: -2.15129e-05   126: -8.89385e-21   555: 1.07564e-05
Row 556:   8: 0.000158251   9: 0.000158251   34: 0.000158251   129: -2.26073e-05   130: -1.21399e-21   131: -2.26073e-05   132: -1.01644e-20   137: -2.26073e-05   138: -9.42324e-21   556: 1.13037e-05
Row 557:   1: 0.000173611   10: 0.000173611   11: 0.000173611   93: -2.48016e-05   94: -1.13291e-20   95: -2.48016e-05   96: -1.50092e-21   141: -2.48016e-05   142: 1.03762e-20   557: 1.24008e-05
Row 558:   11: 0.000153468   12: 0.000153468   35: 0.000153468   147: -2.1924e-05   148: -9.46847e-22   149: -2.1924e-05   150: -9.95264e-21   153: -2.1924e-05   154: -8.99973e-21   558: 1.0962e-05
Row 559:   13: 0.00014632   14: 0.00014632   36: 0.00014632   157: -2.09029e-05   158: -8.06128e-22   159: -2.09029e-05   160: -9.31736e-21   165: -2.09029e-05   166: -8.47033e-21   559: 1.04514e-05
Row 560:   15: 0.000146983   16: 0.000146983   37: 0.000146983   169: -2.09976e-05   170: -1.01694e-21   171: -2.09976e-05   172: -9.21148e-21   177: -2.09976e-05   178: -8.78797e-21   560: 1.04988e-05
Row 561:   2: 0.000173611   17: 0.000173611   18: 0.000173611   97: -2.48016e-05   98: -1.13291e-20   99: -2.48016e-05   100: -1.50092e-21   181: -2.48016e-05   182: 1.03762e-20   561: 1.24008e-05
Row 562:   18: 0.000152492   19: 0.000152492   38: 0.000152492   187: -2.17846e-05   188: -1.20088e-21   189: -2.17846e-05   190: -9.74088e-21   193: -2.17846e-05   194: -8.99973e-21   562: 1.08923e-05
Row 563:   20: 0.00015525   21: 0.00015525   39: 0.00015525   197: -2.21785e-05   198: -1.22986e-21   199: -2.21785e-05   200: -9.95264e-21   205: -2.21785e-05   206: -9.1056e-21   563: 1.10893e-05
Row 564:   22: 0.000156822   23: 0.000156822   40: 0.000156822   209: -2.24032e-05   210: -1.12026e-21   211: -2.24032e-05   212: -9.84676e-21   217: -2.24032e-05   218: -9.31736e-21   564: 1.12016e-05
Row 565:   3: 0.000173611   24: 0.000173611   25: 0.000173611   101: -2.48016e-05   102: -1.13291e-20   103: -2.48016e-05   104: -1.50092e-21   221: -2.48016e-05   222: 1.03762e-20   565: 1.24008e-05
Row 566:   25: 0.00015119   26: 0.00015119   41: 0.00015119   227: -2.15985e-05   228: -1.02997e-21   229: -2.15985e-05   230: -9.635e-21   233: -2.15985e-05   234: -8.78797e-21   566: 1.07993e-05
Row 567:   27: 0.000143687   28: 0.000143687   42: 0.000143687   237: -2.05267e-05   238: -1.06523e-21   239: -2.05267e-05   240: -9.1056e-21   245: -2.05267e-05   246: -8.68209e-21   567: 1.02634e-05
Row 568:   29: 0.000153601   30: 0.000153601   43: 0.000153601   249: -2.19431e-05   250: -9.32262e-22   251: -2.19431e-05   252: -9.95264e-21   257: -2.19431e-05   258: -9.1056e-21   568: 1.09715e-05
Row 569:   4: 0.000218962   31: 0.000218962   32: 0.000218962   107: -3.12803e-05   108: -1.46113e-20   109: -3.12803e-05   110: -1.60029e-21   261: -3.12803e-05   262: 1.3129e-20   569: 1.56402e-05
Row 570:   10: 0.000222005   11: 0.000222005   35: 0.000222005   141: -3.17151e-05   142: -1.59924e-21   143: -3.17151e-05   144: -1.41878e-20   149: -3.17151e-05   150: -1.33408e-20   570: 1.58575e-05
Row 571:   17: 0.00021684   18: 0.00021684   38: 0.00021684   181: -3.09771e-05   182: -1.24845e-21   183: -3.09771e-05   184: -1.41878e-20   189: -3.09771e-05   190: -1.27055e-20   571: 1.54886e-05
Row 572:   24: 0.000216999   25: 0.000216999   41: 0.000216999   221: -3.09999e-05   222: -1.65219e-21   223: -3.09999e-05   224: -1.3976e-20   229: -3.09999e-05   230: -1.24937e-20   572: 1.54999e-05
Row 573:   5: 0.000157214   6: 0.000157214   44: 0.000157214   111: -2.24591e-05   112: -1.05159e-21   115: -2.24591e-05   116: -9.95264e-21   121: -2.24591e-05   122: -9.21148e-21   573: 1.12295e-05
Row 574:   7: 0.000152344   8: 0.000152344   45: 0.000152344   123: -2.17635e-05   124: -1.0179e-21   127: -2.17635e-05   128: -9.95264e-21   133: -2.17635e-05   134: -8.68209e-21   574: 1.08817e-05
Row 575:   9: 0.000148878   10: 0.000148878   46: 0.000148878   135: -2.12683e-05   136: -9.74759e-22   139: -2.12683e-05   140: -9.52912e-21   145: -2.12683e-05   146: -8.99973e-21   575: 1.06342e-05
Row 576:   12: 0.000158064   13: 0.000158064   47: 0.000158064   151: -2.25806e-05   152: -1.10787e-21   155: -2.25806e-05   156: -1.0482e-20   161: -2.25806e-05   162: -9.42324e-21   576: 1.12903e-05
Row 577:   14: 0.000141666   15: 0.000141666   48: 0.000141666   163: -2.02379e-05   164: -9.29052e-22   167: -2.02379e-05   168: -8.99973e-21   173: -2.02379e-05   174: -8.04681e-21   577: 1.0119e-05
Row 578:   8: 0.000152414   34: 0.000152414   45: 0.000152414   131: -2.17735e-05   132: -9.57355e-22   133: -2.17735e-05   134: -9.95264e-21   279: -2.17735e-05   280: -8.89385e-21   578: 1.08867e-05
Row 579:   16: 0.000142893   17: 0.000142893   49: 0.000142893   175: -2.04133e-05   176: -9.35689e-22   179: -2.04133e-05   180: -9.31736e-21   185: -2.04133e-05   186: -8.47033e-21   579: 1.02067e-05
Row 580:   19: 0.000159327   20: 0.000159327   50: 0.000159327   191: -2.2761e-05   192: -9.75323e-22   195: -2.2761e-05   196: -1.02703e-20   201: -2.2761e-05   202: -9.31736e-21   580: 1.13805e-05
Row 581:   21: 0.000154916   22: 0.000154916   51: 0.000154916   203: -2.21309e-05   204: -9.86042e-22   207: -2.21309e-05   208: -1.01644e-20   213: -2.21309e-05   214: -9.42324e-21   581: 1.10654e-05
Row 582:   6: 0.000158935   33: 0.000158935   44: 0.000158935   119: -2.2705e-05   120: -1.05341e-21   121: -2.2705e-05   122: -1.01644e-20   271: -2.2705e-05   272: -9.21148e-21   582: 1.13525e-05
Row 583:   23: 0.000146339   24: 0.000146339   52: 0.000146339   215: -2.09056e-05   216: -9.02727e-22   219: -2.09056e-05   220: -9.31736e-21   225: -2.09056e-05   226: -8.47033e-21   583: 1.04528e-05
Row 584:   5: 0.000163619   32: 0.000163619   44: 0.000163619   113: -2.33741e-05   114: -1.0482e-20   115: -2.33741e-05   116: -1.31778e-21   265: -2.33741e-05   266: 9.74088e-21   584: 1.16871e-05
Row 585:   26: 0.000152048   27: 0.000152048   53: 0.000152048   231: -2.17211e-05   232: -9.56313e-22   235: -2.17211e-05   236: -9.74088e-21   241: -2.17211e-05   242: -8.68209e-21   585: 1.08606e-05
Row 586:   28: 0.000145929   29: 0.000145929   54: 0.000145929   243: -2.0847e-05   244: -1.04191e-21   247: -2.0847e-05   248: -9.42324e-21   253: -2.0847e-05   254: -8.25857e-21   586: 1.04235e-05
Row 587:   30: 0.000145823   31: 0.000145823   55: 0.000145823   255: -2.08318e-05   256: -1.0832e-21   259: -2.08318e-05   260: -9.42324e-21   263: -2.08318e-05   264: -8.89385e-21   587: 1.04159e-05
Row 588:   13: 0.000157074   36: 0.000157074   47: 0.000157074   159: -2.24391e-05   160: -1.14258e-21   161: -2.24391e-05   162: -1.03762e-20   293: -2.24391e-05   294: -9.52912e-21   588: 1.12195e-05
Row 589:   7: 0.000153119   33: 0.000153119   45: 0.000153119   125: -2.18741e-05   126: -9.95264e-21   127: -2.18741e-05   128: -1.2278e-21   273: -2.18741e-05   274: 8.89385e-21   589: 1.0937e-05
Row 590:   9: 0.000136201   34: 0.000136201   46: 0.000136201   137: -1.94574e-05   138: -8.78797e-21   139: -1.94574e-05   140: -9.5929e-22   281: -1.94574e-05   282: 8.04681e-21   590: 9.72868e-06
Row 591:   14: 0.000145653   36: 0.000145653   48: 0.000145653   165: -2.08076e-05   166: -9.42324e-21   167: -2.08076e-05   168: -1.19931e-21   295: -2.08076e-05   296: 8.78797e-21   591: 1.04038e-05
Row 592:   16: 0.000126819   37: 0.000126819   49: 0.000126819   177: -1.81171e-05   178: -8.47033e-21   179: -1.81171e-05   180: -9.42087e-22   303: -1.81171e-05   304: 7.72918e-21   592: 9.05853e-06
Row 593:   21: 0.000157172   39: 0.000157172   51: 0.000157172   205: -2.24531e-05   206: -1.01644e-20   207: -2.24531e-05   208: -1.14921e-21   317: -2.24531e-05   318: 9.42324e-21   593: 1.12266e-05
Row 594:   23: 0.000133927   40: 0.000133927   52: 0.000133927   217: -1.91324e-05   218: -8.89385e-21   219: -1.91324e-05   220: -1.13497e-21   325: -1.91324e-05   326: 8.04681e-21   594: 9.5662e-06
Row 595:   28: 0.000146549   42: 0.000146549   54: 0.000146549   245: -2.09356e-05   246: -9.52912e-21   247: -2.09356e-05   248: -1.22357e-21   339: -2.09356e-05   340: 8.99973e-21   595: 1.04678e-05
Row 596:   30: 0.000132673   43: 0.000132673   55: 0.000132673   257: -1.89533e-05   258: -8.57621e-21   259: -1.89533e-05   260: -8.12576e-22   347: -1.89533e-05   348: 7.94093e-21   596: 9.47665e-06
Row 597:   15: 0.000141665   37: 0.000141665   48: 0.000141665   171: -2.02378e-05   172: -9.05794e-22   173: -2.02378e-05   174: -8.99973e-21   301: -2.02378e-05   302: -8.57621e-21   597: 1.01189e-05
Row 598:   20: 0.000163596   39: 0.000163596   50: 0.000163596   199: -2.33708e-05   200: -9.25353e-22   201: -2.33708e-05   202: -1.05879e-20   315: -2.33708e-05   316: -9.52912e-21   598: 1.16854e-05
Row 599:   22: 0.000153952   40: 0.000153952   51: 0.000153952   211: -2.19931e-05   212: -8.98413e-22   213: -2.19931e-05   214: -9.95264e-21   323: -2.19931e-05   324: -9.1056e-21   599: 1.09965e-05
Row 600:   29: 0.000147119   43: 0.000147119   54: 0.000147119   251: -2.1017e-05   252: -8.31921e-22   253: -2.1017e-05   254: -9.31736e-21   345: -2.1017e-05   346: -8.47033e-21   600: 1.05085e-05
Row 601:   26: 0.000159606   41: 0.000159606   53: 0.000159606   233: -2.28009e-05   234: -1.05879e-20   235: -2.28009e-05   236: -1.32113e-21   333: -2.28009e-05   334: 9.31736e-21   601: 1.14005e-05
Row 602:   12: 0.000166274   35: 0.000166274   47: 0.000166274   153: -2.37534e-05   154: -1.07997e-20   155: -2.37534e-05   156: -1.29252e-21   289: -2.37534e-05   290: 9.74088e-21   602: 1.18767e-05
Row 603:   19: 0.000165986   38: 0.000165986   50: 0.000165986   193: -2.37122e-05   194: -1.06938e-20   195: -2.37122e-05   196: -1.32496e-21   311: -2.37122e-05   312: 9.95264e-21   603: 1.18561e-05
Row 604:   27: 0.000153001   42: 0.000153001   53: 0.000153001   239: -2.18573e-05   240: -9.14871e-22   241: -2.18573e-05   242: -9.84676e-21   337: -2.18573e-05   338: -9.31736e-21   604: 1.09287e-05
Row 605:   42: 0.000138753   54: 0.000138753   56: 0.000138753   339: -1.98219e-05   340: -8.9921e-22   341: -1.98219e-05   342: -8.89385e-21   387: -1.98219e-05   388: -8.25857e-21   605: 9.91093e-06
Row 606:   34: 0.000158705   46: 0.000158705   57: 0.000158705   281: -2.26721e-05   282: -9.92299e-22   283: -2.26721e-05   284: -1.01644e-20   361: -2.26721e-05   362: -9.635e-21   606: 1.1336e-05
Row 607:   39: 0.000154585   51: 0.000154585   58: 0.000154585   317: -2.20836e-05   318: -8.65891e-22   319: -2.20836e-05   320: -1.01644e-20   377: -2.20836e-05   378: -9.1056e-21   607: 1.10418e-05
Row 608:   36: 0.000137315   48: 0.000137315   59: 0.000137315   295: -1.96164e-05   296: -8.42681e-22   297: -1.96164e-05   298: -8.68209e-21   367: -1.96164e-05   368: -8.04681e-21   608: 9.80819e-06
Row 609:   10: 0.000174938   35: 0.000174938   46: 0.000174938   143: -2.49912e-05   144: -1.2154e-21   145: -2.49912e-05   146: -1.11173e-20   287: -2.49912e-05   288: -1.03762e-20   609: 1.24956e-05
Row 610:   38: 0.000185409   50: 0.000185409   60: 0.000185409   311: -2.64871e-05   312: -1.3333e-21   313: -2.64871e-05   314: -1.11173e-20   373: -2.64871e-05   374: -1.07997e-20   610: 1.32435e-05
Row 611:   17: 0.000168724   38: 0.000168724   49: 0.000168724   183: -2.41035e-05   184: -1.07568e-21   185: -2.41035e-05   186: -1.09055e-20   309: -2.41035e-05   310: -9.74088e-21   611: 1.20517e-05
Row 612:   33: 0.000146204   45: 0.000146204   61: 0.000146204   273: -2.08864e-05   274: -9.25172e-22   275: -2.08864e-05   276: -9.31736e-21   357: -2.08864e-05   358: -8.47033e-21   612: 1.04432e-05
Row 613:   39: 0.000159322   50: 0.000159322   62: 0.000159322   315: -2.27602e-05   316: -1.02703e-20   321: -2.27602e-05   322: -1.02356e-21   375: -2.27602e-05   376: 9.52912e-21   613: 1.13801e-05
Row 614:   39: 0.000157617   58: 0.000157617   62: 0.000157617   319: -2.25166e-05   320: -9.74957e-22   321: -2.25166e-05   322: -1.00585e-20   407: -2.25166e-05   408: -9.31736e-21   614: 1.12583e-05
Row 615:   34: 0.000153615   45: 0.000153615   63: 0.000153615   279: -2.19451e-05   280: -1.00585e-20   285: -2.19451e-05   286: -9.96003e-22   359: -2.19451e-05   360: 8.89385e-21   615: 1.09725e-05
Row 616:   34: 0.000181033   57: 0.000181033   63: 0.000181033   283: -2.58619e-05   284: -1.33946e-21   285: -2.58619e-05   286: -1.15408e-20   401: -2.58619e-05   402: -1.05879e-20   616: 1.29309e-05
Row 617:   42: 0.000145689   53: 0.000145689   64: 0.000145689   337: -2.08127e-05   338: -9.52912e-21   343: -2.08127e-05   344: -1.16518e-21   383: -2.08127e-05   384: 8.47033e-21   617: 1.04063e-05
Row 618:   42: 0.000143373   56: 0.000143373   64: 0.000143373   341: -2.04819e-05   342: -1.05026e-21   343: -2.04819e-05   344: -9.1056e-21   393: -2.04819e-05   394: -8.25857e-21   618: 1.02409e-05
Row 619:   24: 0.00017154   41: 0.00017154   52: 0.00017154   223: -2.45057e-05   224: -1.11427e-21   225: -2.45057e-05   226: -1.11173e-20   331: -2.45057e-05   332: -1.00585e-20   619: 1.22528e-05
Row 620:   40: 0.000154429   52: 0.000154429   65: 0.000154429   325: -2.20614e-05   326: -9.46629e-22   327: -2.20614e-05   328: -9.95264e-21   381: -2.20614e-05   382: -9.31736e-21   620: 1.10307e-05
Row 621:   33: 0.000153158   44: 0.000153158   66: 0.000153158   271: -2.18798e-05   272: -9.95264e-21   277: -2.18798e-05   278: -1.12883e-21   353: -2.18798e-05   354: 9.21148e-21   621: 1.09399e-05
Row 622:   33: 0.000150079   61: 0.000150079   66: 0.000150079   275: -2.14399e-05   276: -8.65147e-22   277: -2.14399e-05   278: -9.635e-21   431: -2.14399e-05   432: -8.47033e-21   622: 1.07199e-05
Row 623:   32: 0.0001879   44: 0.0001879   67: 0.0001879   265: -2.68429e-05   266: -1.22942e-21   269: -2.68429e-05   270: -1.21761e-20   355: -2.68429e-05   356: -1.07997e-20   623: 1.34214e-05
Row 624:   44: 0.000175578   66: 0.000175578   67: 0.000175578   353: -2.50825e-05   354: -1.10515e-21   355: -2.50825e-05   356: -1.13291e-20   455: -2.50825e-05   456: -1.01644e-20   624: 1.25413e-05
Row 625:   41: 0.000158103   52: 0.000158103   65: 0.000158103   331: -2.25861e-05   332: -1.03762e-20   335: -2.25861e-05   336: -1.26203e-21   381: -2.25861e-05   382: 9.635e-21   625: 1.1293e-05
Row 626:   41: 0.000184267   53: 0.000184267   65: 0.000184267   333: -2.63238e-05   334: -1.31299e-21   335: -2.63238e-05   336: -1.18585e-20   385: -2.63238e-05   386: -1.10114e-20   626: 1.31619e-05
Row 627:   31: 0.000172169   32: 0.000172169   55: 0.000172169   261: -2.45956e-05   262: -1.02295e-21   263: -2.45956e-05   264: -1.10114e-20   267: -2.45956e-05   268: -9.95264e-21   627: 1.22978e-05
Row 628:   36: 0.000156846   47: 0.000156846   68: 0.000156846   293: -2.24066e-05   294: -1.00585e-20   299: -2.24066e-05   300: -1.04999e-21   365: -2.24066e-05   366: 8.99973e-21   628: 1.12033e-05
Row 629:   36: 0.000145018   59: 0.000145018   68: 0.000145018   297: -2.07169e-05   298: -9.50785e-22   299: -2.07169e-05   300: -9.52912e-21   415: -2.07169e-05   416: -8.57621e-21   629: 1.03584e-05
Row 630:   35: 0.000164331   46: 0.000164331   57: 0.000164331   287: -2.34759e-05   288: -1.10114e-20   291: -2.34759e-05   292: -1.05858e-21   361: -2.34759e-05   362: 9.52912e-21   630: 1.1738e-05
Row 631:   38: 0.000155923   49: 0.000155923   60: 0.000155923   309: -2.22747e-05   310: -1.03762e-20   313: -2.22747e-05   314: -1.16774e-21   371: -2.22747e-05   372: 9.1056e-21   631: 1.11373e-05
Row 632:   32: 0.000159814   55: 0.000159814   67: 0.000159814   267: -2.28306e-05   268: -1.03762e-20   269: -2.28306e-05   270: -1.32113e-21   391: -2.28306e-05   392: 9.1056e-21   632: 1.14153e-05
Row 633:   48: 0.000139224   59: 0.000139224   69: 0.000139224   367: -1.98891e-05   368: -9.1056e-21   369: -1.98891e-05   370: -9.56159e-22   417: -1.98891e-05   418: 8.25857e-21   633: 9.94455e-06
Row 634:   37: 0.000136115   48: 0.000136115   69: 0.000136115   301: -1.94449e-05   302: -8.89385e-21   307: -1.94449e-05   308: -1.10829e-21   369: -1.94449e-05   370: 8.04681e-21   634: 9.72246e-06
Row 635:   53: 0.00016937   64: 0.00016937   65: 0.00016937   383: -2.41957e-05   384: -1.15649e-21   385: -2.41957e-05   386: -1.07997e-20   445: -2.41957e-05   446: -9.84676e-21   635: 1.20979e-05
Row 636:   45: 0.000150689   61: 0.000150689   63: 0.000150689   357: -2.15269e-05   358: -9.52912e-21   359: -2.15269e-05   360: -1.15619e-21   429: -2.15269e-05   430: 8.78797e-21   636: 1.07635e-05
Row 637:   35: 0.00019064   47: 0.00019064   57: 0.00019064   289: -2.72343e-05   290: -1.09855e-21   291: -2.72343e-05   292: -1.24937e-20   363: -2.72343e-05   364: -1.10114e-20   637: 1.36171e-05
Row 638:   50: 0.000182668   60: 0.000182668   62: 0.000182668   373: -2.60954e-05   374: -1.18585e-20   375: -2.60954e-05   376: -1.68169e-21   423: -2.60954e-05   424: 1.07997e-20   638: 1.30477e-05
Row 639:   51: 0.000156239   58: 0.000156239   70: 0.000156239   377: -2.23199e-05   378: -1.00585e-20   379: -2.23199e-05   380: -1.0968e-21   409: -2.23199e-05   410: 8.89385e-21   639: 1.116e-05
Row 640:   40: 0.000152513   51: 0.000152513   70: 0.000152513   323: -2.17876e-05   324: -9.84676e-21   329: -2.17876e-05   330: -1.23601e-21   379: -2.17876e-05   380: 9.1056e-21   640: 1.08938e-05
Row 641:   47: 0.000183468   57: 0.000183468   68: 0.000183468   363: -2.62097e-05   364: -1.19643e-20   365: -2.62097e-05   366: -1.47477e-21   403: -2.62097e-05   404: 1.07997e-20   641: 1.31048e-05
Row 642:   37: 0.000150127   49: 0.000150127   60: 0.000150127   303: -2.14467e-05   304: -1.00337e-21   305: -2.14467e-05   306: -9.635e-21   371: -2.14467e-05   372: -8.78797e-21   642: 1.07233e-05
Row 643:   37: 0.000160575   60: 0.000160575   69: 0.000160575   305: -2.29393e-05   306: -1.16082e-21   307: -2.29393e-05   308: -1.0482e-20   425: -2.29393e-05   426: -9.31736e-21   643: 1.14697e-05
Row 644:   43: 0.000148005   54: 0.000148005   71: 0.000148005   345: -2.11436e-05   346: -9.635e-21   351: -2.11436e-05   352: -9.85995e-22   389: -2.11436e-05   390: 8.99973e-21   644: 1.05718e-05
Row 645:   40: 0.000178163   65: 0.000178163   70: 0.000178163   327: -2.54519e-05   328: -1.30388e-21   329: -2.54519e-05   330: -1.14349e-20   451: -2.54519e-05   452: -1.03762e-20   645: 1.27259e-05
Row 646:   54: 0.000143445   56: 0.000143445   71: 0.000143445   387: -2.04922e-05   388: -9.42324e-21   389: -2.04922e-05   390: -1.04859e-21   395: -2.04922e-05   396: 8.78797e-21   646: 1.02461e-05
Row 647:   43: 0.000154094   55: 0.000154094   67: 0.000154094   347: -2.20134e-05   348: -1.01474e-21   349: -2.20134e-05   350: -1.01644e-20   391: -2.20134e-05   392: -9.1056e-21   647: 1.10067e-05
Row 648:   43: 0.000175565   67: 0.000175565   71: 0.000175565   349: -2.50808e-05   350: -1.07536e-21   351: -2.50808e-05   352: -1.14349e-20   461: -2.50808e-05   462: -1.05879e-20   648: 1.25404e-05
Row 649:   56: 0.000146709   71: 0.000146709   72: 0.000146709   395: -2.09585e-05   396: -1.01002e-21   397: -2.09585e-05   398: -9.42324e-21   477: -2.09585e-05   478: -8.68209e-21   649: 1.04792e-05
Row 650:   58: 0.000155324   70: 0.000155324   73: 0.000155324   409: -2.21891e-05   410: -8.99897e-22   411: -2.21891e-05   412: -1.00585e-20   473: -2.21891e-05   474: -8.89385e-21   650: 1.10946e-05
Row 651:   57: 0.000180804   63: 0.000180804   74: 0.000180804   401: -2.58292e-05   402: -1.19643e-20   405: -2.58292e-05   406: -1.59915e-21   441: -2.58292e-05   442: 1.07997e-20   651: 1.29146e-05
Row 652:   57: 0.000180757   68: 0.000180757   74: 0.000180757   403: -2.58224e-05   404: -1.27809e-21   405: -2.58224e-05   406: -1.15408e-20   465: -2.58224e-05   466: -1.05879e-20   652: 1.29112e-05
Row 653:   56: 0.000117884   64: 0.000117884   75: 0.000117884   393: -1.68406e-05   394: -7.72918e-21   399: -1.68406e-05   400: -8.72298e-22   447: -1.68406e-05   448: 6.88214e-21   653: 8.42031e-06
Row 654:   56: 0.000117663   72: 0.000117663   75: 0.000117663   397: -1.6809e-05   398: -6.42452e-22   399: -1.6809e-05   400: -7.51742e-21   481: -1.6809e-05   482: -6.98802e-21   654: 8.40451e-06
Row 655:   59: 0.0001143   69: 0.0001143   76: 0.0001143   417: -1.63286e-05   418: -7.48248e-22   419: -1.63286e-05   420: -7.30566e-21   469: -1.63286e-05   470: -6.77626e-21   655: 8.1643e-06
Row 656:   60: 0.000162153   69: 0.000162153   77: 0.000162153   425: -2.31646e-05   426: -1.03762e-20   427: -2.31646e-05   428: -1.32118e-21   471: -2.31646e-05   472: 9.95264e-21   656: 1.15823e-05
Row 657:   69: 0.000115157   76: 0.000115157   77: 0.000115157   469: -1.6451e-05   470: -7.30566e-21   471: -1.6451e-05   472: -9.59613e-22   507: -1.6451e-05   508: 6.67038e-21   657: 8.22551e-06
Row 658:   60: 0.000166875   62: 0.000166875   77: 0.000166875   423: -2.38393e-05   424: -1.03041e-21   427: -2.38393e-05   428: -1.0482e-20   437: -2.38393e-05   438: -9.74088e-21   658: 1.19197e-05
Row 659:   61: 0.000128172   66: 0.000128172   78: 0.000128172   431: -1.83103e-05   432: -8.25857e-21   433: -1.83103e-05   434: -9.77634e-22   457: -1.83103e-05   458: 7.72918e-21   659: 9.15517e-06
Row 660:   61: 0.000152314   63: 0.000152314   79: 0.000152314   429: -2.17592e-05   430: -1.08483e-21   435: -2.17592e-05   436: -9.74088e-21   443: -2.17592e-05   444: -8.68209e-21   660: 1.08796e-05
Row 661:   61: 0.000123653   78: 0.000123653   79: 0.000123653   433: -1.76648e-05   434: -7.94093e-21   435: -1.76648e-05   436: -9.80977e-22   517: -1.76648e-05   518: 7.19978e-21   661: 8.83239e-06
Row 662:   63: 0.000151977   74: 0.000151977   79: 0.000151977   441: -2.1711e-05   442: -8.39623e-22   443: -2.1711e-05   444: -9.84676e-21   497: -2.1711e-05   498: -8.89385e-21   662: 1.08555e-05
Row 663:   64: 0.000167065   65: 0.000167065   80: 0.000167065   445: -2.38664e-05   446: -1.11173e-20   449: -2.38664e-05   450: -1.25054e-21   453: -2.38664e-05   454: 1.02703e-20   663: 1.19332e-05
Row 664:   65: 0.000168922   70: 0.000168922   80: 0.000168922   451: -2.41318e-05   452: -1.09055e-20   453: -2.41318e-05   454: -1.35543e-21   475: -2.41318e-05   476: 9.74088e-21   664: 1.20659e-05
Row 665:   64: 0.000119178   75: 0.000119178   80: 0.000119178   447: -1.70254e-05   448: -8.83364e-22   449: -1.70254e-05   450: -7.51742e-21   503: -1.70254e-05   504: -6.98802e-21   665: 8.51269e-06
Row 666:   59: 0.000143906   68: 0.000143906   81: 0.000143906   415: -2.0558e-05   416: -9.31736e-21   421: -2.0558e-05   422: -1.11554e-21   467: -2.0558e-05   468: 8.57621e-21   666: 1.0279e-05
Row 667:   68: 0.000146838   74: 0.000146838   81: 0.000146838   465: -2.09769e-05   466: -9.74088e-21   467: -2.09769e-05   468: -1.18203e-21   499: -2.09769e-05   500: 8.89385e-21   667: 1.04884e-05
Row 668:   59: 0.000113315   76: 0.000113315   81: 0.000113315   419: -1.61879e-05   420: -7.50892e-22   421: -1.61879e-05   422: -7.19978e-21   509: -1.61879e-05   510: -6.56451e-21   668: 8.09394e-06
Row 669:   67: 0.000172857   71: 0.000172857   82: 0.000172857   461: -2.46939e-05   462: -1.12232e-20   463: -2.46939e-05   464: -1.17421e-21   479: -2.46939e-05   480: 1.06938e-20   669: 1.23469e-05
Row 670:   71: 0.000145027   72: 0.000145027   82: 0.000145027   477: -2.07181e-05   478: -9.52912e-21   479: -2.07181e-05   480: -1.07255e-21   483: -2.07181e-05   484: 8.47033e-21   670: 1.0359e-05
Row 671:   66: 0.000174754   67: 0.000174754   82: 0.000174754   455: -2.49649e-05   456: -1.13291e-20   459: -2.49649e-05   460: -1.39356e-21   463: -2.49649e-05   464: 1.02703e-20   671: 1.24824e-05
Row 672:   58: 0.000154839   62: 0.000154839   83: 0.000154839   407: -2.21199e-05   408: -9.84676e-21   413: -2.21199e-05   414: -1.17434e-21   439: -2.21199e-05   440: 9.31736e-21   672: 1.10599e-05
Row 673:   62: 0.000145044   77: 0.000145044   83: 0.000145044   437: -2.07206e-05   438: -9.52912e-21   439: -2.07206e-05   440: -1.09938e-21   513: -2.07206e-05   514: 8.25857e-21   673: 1.03603e-05
Row 674:   58: 0.000144717   73: 0.000144717   83: 0.000144717   411: -2.06739e-05   412: -9.27555e-22   413: -2.06739e-05   414: -9.52912e-21   491: -2.06739e-05   492: -8.57621e-21   674: 1.03369e-05
Row 675:   70: 0.000146036   73: 0.000146036   80: 0.000146036   473: -2.08622e-05   474: -9.42324e-21   475: -2.08622e-05   476: -1.20145e-21   489: -2.08622e-05   490: 8.78797e-21   675: 1.04311e-05
Row 676:   66: 0.000127291   78: 0.000127291   82: 0.000127291   457: -1.81844e-05   458: -9.55124e-22   459: -1.81844e-05   460: -8.04681e-21   519: -1.81844e-05   520: -7.30566e-21   676: 9.0922e-06
Row 677:   73: 0.000146885   80: 0.000146885   84: 0.000146885   489: -2.09836e-05   490: -9.09796e-22   493: -2.09836e-05   494: -9.31736e-21   527: -2.09836e-05   528: -8.68209e-21   677: 1.04918e-05
Row 678:   75: 0.000119572   80: 0.000119572   84: 0.000119572   503: -1.70817e-05   504: -7.72918e-21   505: -1.70817e-05   506: -1.02421e-21   527: -1.70817e-05   528: 6.98802e-21   678: 8.54083e-06
Row 679:   72: 0.00011776   75: 0.00011776   84: 0.00011776   481: -1.68229e-05   482: -7.72918e-21   485: -1.68229e-05   486: -8.6112e-22   505: -1.68229e-05   506: 6.98802e-21   679: 8.41143e-06
Row 680:   76: 0.000114288   77: 0.000114288   85: 0.000114288   507: -1.63269e-05   508: -7.10701e-22   511: -1.63269e-05   512: -7.30566e-21   515: -1.63269e-05   516: -6.35275e-21   680: 8.16344e-06
Row 681:   77: 0.000141438   83: 0.000141438   85: 0.000141438   513: -2.02054e-05   514: -9.7042e-22   515: -2.02054e-05   516: -9.31736e-21   535: -2.02054e-05   536: -8.36445e-21   681: 1.01027e-05
Row 682:   72: 0.000163837   82: 0.000163837   86: 0.000163837   483: -2.34053e-05   484: -1.0622e-21   487: -2.34053e-05   488: -1.01644e-20   533: -2.34053e-05   534: -9.31736e-21   682: 1.17027e-05
Row 683:   72: 0.000163008   84: 0.000163008   86: 0.000163008   485: -2.32869e-05   486: -1.09055e-20   487: -2.32869e-05   488: -1.14236e-21   539: -2.32869e-05   540: 9.74088e-21   683: 1.16434e-05
Row 684:   78: 0.000144071   82: 0.000144071   86: 0.000144071   519: -2.05816e-05   520: -9.42324e-21   521: -2.05816e-05   522: -1.27997e-21   533: -2.05816e-05   534: 8.47033e-21   684: 1.02908e-05
Row 685:   78: 0.000141576   79: 0.000141576   86: 0.000141576   517: -2.02252e-05   518: -9.73181e-22   521: -2.02252e-05   522: -9.1056e-21   523: -2.02252e-05   524: -8.25857e-21   685: 1.01126e-05
Row 686:   74: 0.000150894   79: 0.000150894   87: 0.000150894   497: -2.15562e-05   498: -9.74088e-21   501: -2.15562e-05   502: -1.05437e-21   525: -2.15562e-05   526: 9.1056e-21   686: 1.07781e-05
Row 687:   79: 0.000163851   86: 0.000163851   87: 0.000163851   523: -2.34072e-05   524: -1.05879e-20   525: -2.34072e-05   526: -1.1763e-21   547: -2.34072e-05   548: 1.00585e-20   687: 1.17036e-05
Row 688:   74: 0.000146983   81: 0.000146983   87: 0.000146983   499: -2.09975e-05   500: -1.06453e-21   501: -2.09975e-05   502: -9.42324e-21   531: -2.09975e-05   532: -8.78797e-21   688: 1.04988e-05
Row 689:   76: 0.000113292   81: 0.000113292   85: 0.000113292   509: -1.61846e-05   510: -7.41154e-21   511: -1.61846e-05   512: -7.95905e-22   529: -1.61846e-05   530: 6.98802e-21   689: 8.0923e-06
Row 690:   73: 0.000140563   84: 0.000140563   88: 0.000140563   493: -2.00804e-05   494: -7.87299e-22   495: -2.00804e-05   496: -8.89385e-21   541: -2.00804e-05   542: -8.04681e-21   690: 1.00402e-05
Row 691:   73: 0.00014978   83: 0.00014978   88: 0.00014978   491: -2.13971e-05   492: -9.74088e-21   495: -2.13971e-05   496: -1.02269e-21   537: -2.13971e-05   538: 8.89385e-21   691: 1.06986e-05
Row 692:   84: 0.000157217   86: 0.000157217   88: 0.000157217   539: -2.24595e-05   540: -1.07301e-21   541: -2.24595e-05   542: -1.02703e-20   549: -2.24595e-05   550: -9.31736e-21   692: 1.12298e-05
Row 693:   83: 0.00013705   85: 0.00013705   88: 0.00013705   535: -1.95786e-05   536: -8.89385e-21   537: -1.95786e-05   538: -1.04085e-21   545: -1.95786e-05   546: 8.25857e-21   693: 9.7893e-06
Row 694:   81: 0.000140737   85: 0.000140737   87: 0.000140737   529: -2.01052e-05   530: -8.72046e-22   531: -2.01052e-05   532: -9.21148e-21   543: -2.01052e-05   544: -8.25857e-21   694: 1.00526e-05
Row 695:   86: 0.000169746   87: 0.000169746   88: 0.000169746   547: -2.42494e-05   548: -1.06261e-21   549: -2.42494e-05   550: -1.10114e-20   551: -2.42494e-05   552: -1.01644e-20   695: 1.21247e-05
Row 696:   85: 0.000138883   87: 0.000138883   88: 0.000138883   543: -1.98405e-05   544: -9.1056e-21   545: -1.98405e-05   546: -1.17865e-21   551: -1.98405e-05   552: 8.04681e-21   696: 9.92025e-06
In [6]:
print(mstar.AsVector())
 0.00520833
 0.00260417
 0.00260417
 -0.000520833
 8.68056e-05
 -0.000520833
 8.68056e-05
 -0.000260417
 -1.28749e-19
 0.000173611
 0.00520833
 0.00260417
 0.00260417
 -0.000520833
 8.68056e-05
 -0.000520833
 8.68056e-05
 -0.000260417
 1.28749e-19
 0.000173611
 0.00520833
 0.00260417
 0.00260417
 -0.000520833
 8.68056e-05
 -0.000520833
 8.68056e-05
 -0.000260417
 1.28749e-19
 0.000173611
 0.00520833
 0.00260417
 0.00260417
 -0.000520833
 8.68056e-05
 -0.000520833
 8.68056e-05
 -0.000260417
 1.28749e-19
 0.000173611
 0.00260417
 0.0163738
 0.00229828
 0.0058886
 0.00558272
 -0.000520833
 -8.68056e-05
 -0.000260417
 -1.42302e-19
 -0.000459656
 7.66094e-05
 -0.00117772
 0.000196287
 -0.00111654
 0.000186091
 -0.000229828
 -1.15196e-19
 -0.000328444
 1.69407e-19
 0.000173611
 0.000153219
 0.000218962
 0.00229828
 0.0142215
 0.00235821
 0.00475257
 0.00481249
 -0.000459656
 -7.66094e-05
 -0.000229828
 -1.24514e-19
 -0.000471641
 7.86068e-05
 -0.000950513
 0.000158419
 -0.000962498
 0.000160416
 -0.000235821
 -1.18585e-19
 -0.000245428
 1.25361e-19
 0.000153219
 0.000157214
 0.000163619
 0.00235821
 0.0140022
 0.00225885
 0.00464288
 0.00474223
 -0.000471641
 -7.86068e-05
 -0.000235821
 -1.27902e-19
 -0.000451771
 7.52951e-05
 -0.000928575
 0.000154763
 -0.000948446
 0.000158074
 -0.000225885
 -1.15196e-19
 -0.000238402
 -1.21973e-19
 0.00015059
 0.000157214
 0.000158935
 0.00225885
 0.0136816
 0.00228517
 0.00455563
 0.00458194
 -0.000451771
 -7.52951e-05
 -0.000225885
 -1.2282e-19
 -0.000457033
 7.61722e-05
 -0.000911126
 0.000151854
 -0.000916389
 0.000152731
 -0.000228517
 -1.15196e-19
 -0.000229678
 1.15196e-19
 0.00015059
 0.000152344
 0.000153119
 0.00228517
 0.0138903
 0.00237377
 0.00465998
 0.00457138
 -0.000457033
 -7.61722e-05
 -0.000228517
 -1.23667e-19
 -0.000474754
 7.91257e-05
 -0.000931996
 0.000155333
 -0.000914276
 0.000152379
 -0.000237377
 -1.25361e-19
 -0.000228621
 -1.15196e-19
 0.000158251
 0.000152344
 0.000152414
 0.00237377
 0.0132999
 0.00223318
 0.00441679
 0.0042762
 -0.000474754
 -7.91257e-05
 -0.000237377
 -1.29596e-19
 -0.000446635
 7.44392e-05
 -0.000883358
 0.000147226
 -0.00085524
 0.00014254
 -0.000223318
 -1.11808e-19
 -0.000204302
 1.05032e-19
 0.000158251
 0.000148878
 0.000136201
 0.00260417
 0.00223318
 0.021583
 0.00593425
 0.00595416
 0.00485725
 -0.000520833
 -8.68056e-05
 -0.000260417
 -3.38813e-21
 -0.000446635
 -7.44392e-05
 -0.000223318
 -1.2282e-19
 -0.00118685
 0.000197808
 -0.00119083
 0.000198472
 -0.000971451
 0.000161908
 -0.000333008
 -1.69407e-19
 -0.000262408
 -1.32137e-19
 0.000173611
 0.000222005
 0.000148878
 0.000174938
 0.00260417
 0.00593425
 0.0164725
 0.00230202
 0.00563211
 -0.000260417
 -1.42302e-19
 -0.000520833
 -8.68056e-05
 -0.00118685
 -0.000197808
 -0.000333008
 -1.82959e-19
 -0.000460405
 7.67341e-05
 -0.00112642
 0.000187737
 -0.000230202
 -1.18585e-19
 0.000173611
 0.000153468
 0.000222005
 0.00230202
 0.0143342
 0.00237096
 0.00479613
 0.00486507
 -0.000460405
 -7.67341e-05
 -0.000230202
 -1.23667e-19
 -0.000474192
 7.9032e-05
 -0.000959226
 0.000159871
 -0.000973014
 0.000162169
 -0.000237096
 -1.18585e-19
 -0.000249411
 1.28749e-19
 0.000153468
 0.000158064
 0.000166274
 0.00237096
 0.0138437
 0.0021948
 0.00455091
 0.00472707
 -0.000474192
 -7.9032e-05
 -0.000237096
 -1.29596e-19
 -0.000438961
 7.31601e-05
 -0.000910182
 0.000151697
 -0.000945413
 0.000157569
 -0.00021948
 -1.11808e-19
 -0.00023561
 -1.21973e-19
 0.00014632
 0.000158064
 0.000157074
 0.0021948
 0.0130092
 0.00212498
 0.0043796
 0.00430978
 -0.000438961
 -7.31601e-05
 -0.00021948
 -1.19432e-19
 -0.000424997
 7.08328e-05
 -0.00087592
 0.000145987
 -0.000861955
 0.000143659
 -0.000212498
 -1.0842e-19
 -0.000218479
 1.15196e-19
 0.00014632
 0.000141666
 0.000145653
 0.00212498
 0.0129094
 0.00220475
 0.00432972
 0.00424995
 -0.000424997
 -7.08328e-05
 -0.000212498
 -1.16891e-19
 -0.000440949
 7.34916e-05
 -0.000865943
 0.000144324
 -0.00084999
 0.000141665
 -0.000220475
 -1.15196e-19
 -0.000212497
 -1.0842e-19
 0.000146983
 0.000141666
 0.000141665
 0.00220475
 0.0125009
 0.0021434
 0.00410704
 0.00404569
 -0.000440949
 -7.34916e-05
 -0.000220475
 -1.19432e-19
 -0.00042868
 7.14466e-05
 -0.000821408
 0.000136901
 -0.000809138
 0.000134856
 -0.00021434
 -1.11808e-19
 -0.000190229
 9.82558e-20
 0.000146983
 0.000142893
 0.000126819
 0.00260417
 0.0021434
 0.0210621
 0.00585676
 0.00578346
 0.00467426
 -0.000520833
 -8.68056e-05
 -0.000260417
 -3.38813e-21
 -0.00042868
 -7.14466e-05
 -0.00021434
 -1.17738e-19
 -0.00117135
 0.000195225
 -0.00115669
 0.000192782
 -0.000934852
 0.000155809
 -0.00032526
 -1.6263e-19
 -0.000253086
 -1.28749e-19
 0.000173611
 0.00021684
 0.000142893
 0.000168724
 0.00260417
 0.00585676
 0.0162883
 0.00228738
 0.00553997
 -0.000260417
 -1.42302e-19
 -0.000520833
 -8.68056e-05
 -0.00117135
 -0.000195225
 -0.00032526
 -1.77877e-19
 -0.000457476
 7.62459e-05
 -0.00110799
 0.000184666
 -0.000228738
 -1.18585e-19
 0.000173611
 0.000152492
 0.00021684
 0.00228738
 0.0143341
 0.00238991
 0.00477716
 0.00487969
 -0.000457476
 -7.62459e-05
 -0.000228738
 -1.25361e-19
 -0.000477982
 7.96636e-05
 -0.000955432
 0.000159239
 -0.000975938
 0.000162656
 -0.000238991
 -1.18585e-19
 -0.000248978
 1.28749e-19
 0.000152492
 0.000159327
 0.000165986
 0.00238991
 0.0143452
 0.00232874
 0.00478268
 0.00484385
 -0.000477982
 -7.96636e-05
 -0.000238991
 -1.29596e-19
 -0.000465749
 7.76248e-05
 -0.000956536
 0.000159423
 -0.000968769
 0.000161462
 -0.000232874
 -1.21973e-19
 -0.000245394
 -1.28749e-19
 0.00015525
 0.000159327
 0.000163596
 0.00232874
 0.0140201
 0.00232374
 0.00468632
 0.00468132
 -0.000465749
 -7.76248e-05
 -0.000232874
 -1.26208e-19
 -0.000464748
 7.7458e-05
 -0.000937265
 0.000156211
 -0.000936264
 0.000156044
 -0.000232374
 -1.18585e-19
 -0.000235758
 1.21973e-19
 0.00015525
 0.000154916
 0.000157172
 0.00232374
 0.0139707
 0.00235233
 0.00466161
 0.00463302
 -0.000464748
 -7.7458e-05
 -0.000232374
 -1.27055e-19
 -0.000470467
 7.84111e-05
 -0.000932321
 0.000155387
 -0.000926603
 0.000154434
 -0.000235233
 -1.21973e-19
 -0.000230927
 -1.18585e-19
 0.000156822
 0.000154916
 0.000153952
 0.00235233
 0.0131126
 0.00219508
 0.00436123
 0.00420399
 -0.000470467
 -7.84111e-05
 -0.000235233
 -1.27902e-19
 -0.000439017
 7.31695e-05
 -0.000872247
 0.000145374
 -0.000840797
 0.000140133
 -0.000219508
 -1.11808e-19
 -0.00020089
 1.05032e-19
 0.000156822
 0.000146339
 0.000133927
 0.00260417
 0.00219508
 0.0212547
 0.00585915
 0.00582808
 0.00476818
 -0.000520833
 -8.68056e-05
 -0.000260417
 -3.38813e-21
 -0.000439017
 -7.31695e-05
 -0.000219508
 -1.19432e-19
 -0.00117183
 0.000195305
 -0.00116562
 0.000194269
 -0.000953636
 0.000158939
 -0.000325499
 -1.69407e-19
 -0.00025731
 -1.32137e-19
 0.000173611
 0.000216999
 0.000146339
 0.00017154
 0.00260417
 0.00585915
 0.016254
 0.00226785
 0.00552283
 -0.000260417
 -1.42302e-19
 -0.000520833
 -8.68056e-05
 -0.00117183
 -0.000195305
 -0.000325499
 -1.77877e-19
 -0.000453569
 7.55949e-05
 -0.00110457
 0.000184094
 -0.000226785
 -1.15196e-19
 0.000173611
 0.00015119
 0.000216999
 0.00226785
 0.0138853
 0.00228072
 0.00466194
 0.00467481
 -0.000453569
 -7.55949e-05
 -0.000226785
 -1.2282e-19
 -0.000456144
 7.60239e-05
 -0.000932388
 0.000155398
 -0.000934963
 0.000155827
 -0.000228072
 -1.18585e-19
 -0.00023941
 1.21973e-19
 0.00015119
 0.000152048
 0.000159606
 0.00228072
 0.0134621
 0.00215531
 0.00445032
 0.00457573
 -0.000456144
 -7.60239e-05
 -0.000228072
 -1.2282e-19
 -0.000431062
 7.18436e-05
 -0.000890065
 0.000148344
 -0.000915147
 0.000152524
 -0.000215531
 -1.0842e-19
 -0.000229502
 -1.15196e-19
 0.000143687
 0.000152048
 0.000153001
 0.00215531
 0.0130849
 0.00218893
 0.00435354
 0.00438717
 -0.000431062
 -7.18436e-05
 -0.000215531
 -1.17738e-19
 -0.000437786
 7.29644e-05
 -0.000870709
 0.000145118
 -0.000877433
 0.000146239
 -0.000218893
 -1.11808e-19
 -0.000219824
 1.11808e-19
 0.000143687
 0.000145929
 0.000146549
 0.00218893
 0.0133995
 0.00230402
 0.00451081
 0.00439572
 -0.000437786
 -7.29644e-05
 -0.000218893
 -1.18585e-19
 -0.000460804
 7.68007e-05
 -0.000902162
 0.00015036
 -0.000879144
 0.000146524
 -0.000230402
 -1.18585e-19
 -0.000220679
 -1.15196e-19
 0.000153601
 0.000145929
 0.000147119
 0.00230402
 0.0129629
 0.00218734
 0.00429412
 0.00417744
 -0.000460804
 -7.68007e-05
 -0.000230402
 -1.24514e-19
 -0.000437468
 7.29113e-05
 -0.000858824
 0.000143137
 -0.000835488
 0.000139248
 -0.000218734
 -1.11808e-19
 -0.00019901
 1.05032e-19
 0.000153601
 0.000145823
 0.000132673
 0.00260417
 0.0058886
 0.00218734
 0.021317
 0.00586698
 0.00476988
 -0.000260417
 -3.38813e-21
 -0.000520833
 -8.68056e-05
 -0.00117772
 -0.000196287
 -0.000328444
 -1.01644e-20
 -0.000437468
 -7.29113e-05
 -0.000218734
 -1.20279e-19
 -0.0011734
 0.000195566
 -0.000953976
 0.000158996
 -0.000258254
 -1.32137e-19
 0.000173611
 0.000218962
 0.000145823
 0.000172169
 0.00558272
 0.00475257
 0.00586698
 0.0316705
 0.00527279
 0.00497975
 0.00521572
 -0.000229828
 -5.0822e-21
 -0.000328444
 -1.81265e-19
 -0.00111654
 -0.000186091
 -0.000950513
 -0.000158419
 -0.000245428
 -5.0822e-21
 -0.0011734
 -0.000195566
 -0.000258254
 -1.42302e-19
 -0.00105456
 0.00017576
 -0.00099595
 0.000165992
 -0.00104314
 0.000173857
 -0.00028185
 -1.42302e-19
 -0.000239721
 1.25361e-19
 0.000153219
 0.000218962
 0.000163619
 0.0001879
 0.000172169
 0.000159814
 0.00464288
 0.00455563
 0.0273626
 0.0046814
 0.00448984
 0.00444425
 0.00454856
 -0.000225885
 -8.47033e-21
 -0.000928575
 -0.000154763
 -0.000238402
 -1.30443e-19
 -0.000911126
 -0.000151854
 -0.000229678
 -8.47033e-21
 -0.00093628
 0.000156047
 -0.000897969
 0.000149661
 -0.000888851
 0.000148142
 -0.000909713
 0.000151619
 -0.000229738
 1.15196e-19
 -0.000219307
 -1.15196e-19
 -0.000225119
 -1.15196e-19
 0.00015059
 0.000158935
 0.000153119
 0.000146204
 0.000153158
 0.000150079
 0.00465998
 0.00441679
 0.0282066
 0.00459044
 0.00442359
 0.00509607
 0.00501973
 -0.000237377
 -5.0822e-21
 -0.000931996
 -0.000155333
 -0.000228621
 -1.2282e-19
 -0.000883358
 -0.000147226
 -0.000204302
 -3.38813e-21
 -0.000918089
 0.000153015
 -0.000884718
 0.000147453
 -0.00101921
 0.000169869
 -0.00100395
 0.000167324
 -0.000230423
 1.18585e-19
 -0.000238057
 -1.25361e-19
 -0.00027155
 -1.38913e-19
 0.000158251
 0.000152414
 0.000136201
 0.000158705
 0.000153615
 0.000181033
 0.00595416
 0.00563211
 0.00479613
 0.0321497
 0.00508905
 0.00535371
 0.00532457
 -0.000333008
 -1.01644e-20
 -0.00119083
 -0.000198472
 -0.000262408
 -1.42302e-19
 -0.000230202
 -5.0822e-21
 -0.00112642
 -0.000187737
 -0.000959226
 -0.000159871
 -0.000249411
 -6.77626e-21
 -0.00101781
 0.000169635
 -0.00107074
 0.000178457
 -0.00106491
 0.000177486
 -0.000246497
 1.21973e-19
 -0.00028596
 -1.49078e-19
 0.000153468
 0.000222005
 0.000166274
 0.000174938
 0.000164331
 0.00019064
 0.00455091
 0.0043796
 0.0266468
 0.0047088
 0.00424451
 0.00423499
 0.00452796
 -0.00021948
 -6.77626e-21
 -0.000910182
 -0.000151697
 -0.00023561
 -1.28749e-19
 -0.00087592
 -0.000145987
 -0.000218479
 -5.0822e-21
 -0.000941759
 0.00015696
 -0.000848903
 0.000141484
 -0.000846999
 0.000141166
 -0.000905593
 0.000150932
 -0.000235269
 1.18585e-19
 -0.000205972
 -1.0842e-19
 -0.000217527
 -1.0842e-19
 0.00014632
 0.000157074
 0.000145653
 0.000137315
 0.000156846
 0.000145018
 0.00432972
 0.00410704
 0.0258685
 0.00416669
 0.00415419
 0.00466053
 0.00445034
 -0.000220475
 -6.77626e-21
 -0.000865943
 -0.000144324
 -0.000212497
 -1.16891e-19
 -0.000821408
 -0.000136901
 -0.000190229
 -5.0822e-21
 -0.000833337
 0.00013889
 -0.000830838
 0.000138473
 -0.000932106
 0.000155351
 -0.000890069
 0.000148345
 -0.000204172
 1.05032e-19
 -0.00022519
 -1.15196e-19
 -0.000240863
 -1.21973e-19
 0.000146983
 0.000126819
 0.000141665
 0.000136115
 0.000150127
 0.000160575
 0.00578346
 0.00553997
 0.00477716
 0.0313612
 0.0048697
 0.00527093
 0.00511998
 -0.00032526
 -6.77626e-21
 -0.00115669
 -0.000192782
 -0.000253086
 -1.37219e-19
 -0.000228738
 -6.77626e-21
 -0.00110799
 -0.000184666
 -0.000955432
 -0.000159239
 -0.000248978
 -8.47033e-21
 -0.000973941
 0.000162323
 -0.00105419
 0.000175698
 -0.001024
 0.000170666
 -0.000233884
 1.18585e-19
 -0.000278114
 -1.42302e-19
 0.000152492
 0.00021684
 0.000165986
 0.000185409
 0.000168724
 0.000155923
 0.00478268
 0.00468632
 0.0284262
 0.00484376
 0.00467636
 0.00468303
 0.00475407
 -0.000232874
 -3.38813e-21
 -0.000956536
 -0.000159423
 -0.000245394
 -1.32137e-19
 -0.000937265
 -0.000156211
 -0.000235758
 -8.47033e-21
 -0.000968753
 0.000161459
 -0.000935272
 0.000155879
 -0.000936606
 0.000156101
 -0.000950815
 0.000158469
 -0.000238983
 1.21973e-19
 -0.000231878
 -1.18585e-19
 -0.000236425
 -1.18585e-19
 0.00015525
 0.000157172
 0.000163596
 0.000154585
 0.000159322
 0.000157617
 0.00466161
 0.00436123
 0.0278942
 0.00459698
 0.00432534
 0.00498889
 0.00496015
 -0.000235233
 -6.77626e-21
 -0.000932321
 -0.000155387
 -0.000230927
 -1.27055e-19
 -0.000872247
 -0.000145374
 -0.00020089
 -3.38813e-21
 -0.000919395
 0.000153233
 -0.000865069
 0.000144178
 -0.000997777
 0.000166296
 -0.000992029
 0.000165338
 -0.00022877
 1.15196e-19
 -0.000231644
 -1.15196e-19
 -0.000267245
 -1.38913e-19
 0.000156822
 0.000133927
 0.000153952
 0.000154429
 0.000152513
 0.000178163
 0.00582808
 0.00552283
 0.00466194
 0.0312511
 0.00494464
 0.0051581
 0.00513554
 -0.000325499
 -1.01644e-20
 -0.00116562
 -0.000194269
 -0.00025731
 -1.42302e-19
 -0.000226785
 -8.47033e-21
 -0.00110457
 -0.000184094
 -0.000932388
 -0.000155398
 -0.00023941
 -6.77626e-21
 -0.000988928
 0.000164821
 -0.00103162
 0.000171937
 -0.00102711
 0.000171185
 -0.000237154
 1.18585e-19
 -0.0002764
 -1.38913e-19
 0.00015119
 0.000216999
 0.000159606
 0.00017154
 0.000158103
 0.000184267
 0.00445032
 0.00435354
 0.0261316
 0.00448035
 0.00427953
 0.00423189
 0.00433593
 -0.000215531
 -5.0822e-21
 -0.000890065
 -0.000148344
 -0.000229502
 -1.24514e-19
 -0.000870709
 -0.000145118
 -0.000219824
 -6.77626e-21
 -0.00089607
 0.000149345
 -0.000855906
 0.000142651
 -0.000846379
 0.000141063
 -0.000867186
 0.000144531
 -0.000218533
 1.11808e-19
 -0.00020813
 -1.0842e-19
 -0.00021506
 -1.11808e-19
 0.000143687
 0.000146549
 0.000153001
 0.000138753
 0.000145689
 0.000143373
 0.00451081
 0.00429412
 0.0273317
 0.00442687
 0.0043015
 0.00494489
 0.00485356
 -0.000230402
 -5.0822e-21
 -0.000902162
 -0.00015036
 -0.000220679
 -1.21126e-19
 -0.000858824
 -0.000143137
 -0.00019901
 -3.38813e-21
 -0.000885373
 0.000147562
 -0.000860301
 0.000143383
 -0.000988978
 0.00016483
 -0.000970712
 0.000161785
 -0.000222008
 1.15196e-19
 -0.000231141
 -1.18585e-19
 -0.000263348
 -1.32137e-19
 0.000153601
 0.000132673
 0.000147119
 0.000148005
 0.000154094
 0.000175565
 0.00481249
 0.00474223
 0.00527279
 0.0046814
 0.0298921
 0.00493104
 0.00545217
 -0.000235821
 -8.47033e-21
 -0.000245428
 -1.35525e-19
 -0.000962498
 -0.000160416
 -0.000238402
 -1.01644e-20
 -0.000948446
 -0.000158074
 -0.00105456
 -0.00017576
 -0.00028185
 -1.52466e-19
 -0.00093628
 -0.000156047
 -0.000229738
 -3.38813e-21
 -0.000986208
 0.000164368
 -0.00109043
 0.000181739
 -0.000263367
 -1.35525e-19
 0.000157214
 0.000158935
 0.000163619
 0.000153158
 0.0001879
 0.000175578
 0.00458194
 0.00457138
 0.00448984
 0.00459044
 0.0272516
 0.00445339
 0.00456456
 -0.000228517
 -3.38813e-21
 -0.000229678
 -1.24514e-19
 -0.000916389
 -0.000152731
 -0.000228621
 -3.38813e-21
 -0.000914276
 -0.000152379
 -0.000897969
 -0.000149661
 -0.000219307
 -1.19432e-19
 -0.000918089
 -0.000153015
 -0.000230423
 -3.38813e-21
 -0.000890679
 0.000148446
 -0.000912912
 0.000152152
 -0.000226033
 1.21973e-19
 0.000152344
 0.000152414
 0.000153119
 0.000146204
 0.000153615
 0.000150689
 0.0042762
 0.00485725
 0.00442359
 0.00508905
 0.0234916
 0.00484554
 -0.000223318
 -6.77626e-21
 -0.000204302
 -1.10961e-19
 -0.00085524
 -0.00014254
 -0.000262408
 -8.47033e-21
 -0.000971451
 -0.000161908
 -0.000884718
 -0.000147453
 -0.000238057
 -1.29596e-19
 -0.00101781
 -0.000169635
 -0.000246497
 -1.01644e-20
 -0.000969108
 0.000161518
 0.000148878
 0.000136201
 0.000158705
 0.000174938
 0.000164331
 0.00486507
 0.00472707
 0.00535371
 0.0047088
 0.030371
 0.00561162
 0.00510471
 -0.000237096
 -5.0822e-21
 -0.000249411
 -1.35525e-19
 -0.000973014
 -0.000162169
 -0.00023561
 -5.0822e-21
 -0.000945413
 -0.000157569
 -0.00107074
 -0.000178457
 -0.00028596
 -1.57548e-19
 -0.000941759
 -0.00015696
 -0.000235269
 -8.47033e-21
 -0.00112232
 0.000187054
 -0.00102094
 0.000170157
 -0.000275202
 1.38913e-19
 0.000158064
 0.000157074
 0.000166274
 0.000156846
 0.00019064
 0.000183468
 0.00430978
 0.00424995
 0.00424451
 0.00416669
 0.0252491
 0.00414807
 0.00413007
 -0.000212498
 -3.38813e-21
 -0.000218479
 -1.20279e-19
 -0.000861955
 -0.000143659
 -0.000212497
 -5.0822e-21
 -0.00084999
 -0.000141665
 -0.000848903
 -0.000141484
 -0.000205972
 -1.12655e-19
 -0.000833337
 -0.00013889
 -0.000204172
 -3.38813e-21
 -0.000829615
 0.000138269
 -0.000826014
 0.000137669
 -0.000208835
 1.11808e-19
 0.000141666
 0.000145653
 0.000141665
 0.000137315
 0.000139224
 0.000136115
 0.00404569
 0.00467426
 0.00415419
 0.0048697
 0.0223346
 0.00459074
 -0.00021434
 -5.0822e-21
 -0.000190229
 -1.03338e-19
 -0.000809138
 -0.000134856
 -0.000253086
 -5.0822e-21
 -0.000934852
 -0.000155809
 -0.000830838
 -0.000138473
 -0.00022519
 -1.2282e-19
 -0.000973941
 -0.000162323
 -0.000233884
 -3.38813e-21
 -0.000918148
 0.000153025
 0.000142893
 0.000126819
 0.000168724
 0.000155923
 0.000150127
 0.00487969
 0.00484385
 0.00527093
 0.00484376
 0.0304892
 0.00552116
 0.00512985
 -0.000238991
 -8.47033e-21
 -0.000248978
 -1.35525e-19
 -0.000975938
 -0.000162656
 -0.000245394
 -6.77626e-21
 -0.000968769
 -0.000161462
 -0.00105419
 -0.000175698
 -0.000278114
 -1.50772e-19
 -0.000968753
 -0.000161459
 -0.000238983
 -1.01644e-20
 -0.00110423
 0.000184039
 -0.00102597
 0.000170995
 -0.000274002
 1.38913e-19
 0.000159327
 0.000163596
 0.000165986
 0.000185409
 0.000159322
 0.000182668
 0.00468132
 0.00463302
 0.00467636
 0.00459698
 0.0278813
 0.00466237
 0.00463129
 -0.000232374
 -5.0822e-21
 -0.000235758
 -1.29596e-19
 -0.000936264
 -0.000156044
 -0.000230927
 -5.0822e-21
 -0.000926603
 -0.000154434
 -0.000935272
 -0.000155879
 -0.000231878
 -1.27055e-19
 -0.000919395
 -0.000153233
 -0.00022877
 -6.77626e-21
 -0.000932474
 0.000155412
 -0.000926258
 0.000154376
 -0.000234359
 1.21973e-19
 0.000154916
 0.000157172
 0.000153952
 0.000154585
 0.000156239
 0.000152513
 0.00420399
 0.00476818
 0.00432534
 0.00494464
 0.0229301
 0.00468798
 -0.000219508
 -3.38813e-21
 -0.00020089
 -1.09267e-19
 -0.000840797
 -0.000140133
 -0.00025731
 -3.38813e-21
 -0.000953636
 -0.000158939
 -0.000865069
 -0.000144178
 -0.000231644
 -1.26208e-19
 -0.000988928
 -0.000164821
 -0.000237154
 -8.47033e-21
 -0.000937597
 0.000156266
 0.000146339
 0.000133927
 0.00017154
 0.000154429
 0.000158103
 0.00467481
 0.00457573
 0.0051581
 0.00448035
 0.0289194
 0.00472588
 0.00530456
 -0.000228072
 -6.77626e-21
 -0.00023941
 -1.30443e-19
 -0.000934963
 -0.000155827
 -0.000229502
 -3.38813e-21
 -0.000915147
 -0.000152524
 -0.00103162
 -0.000171937
 -0.0002764
 -1.52466e-19
 -0.00089607
 -0.000149345
 -0.000218533
 -5.0822e-21
 -0.000945177
 0.000157529
 -0.00106091
 0.000176819
 -0.000254055
 -1.28749e-19
 0.000152048
 0.000159606
 0.000153001
 0.000145689
 0.000184267
 0.00016937
 0.00438717
 0.00439572
 0.00427953
 0.00442687
 0.026094
 0.00423297
 0.00437176
 -0.000218893
 -3.38813e-21
 -0.000219824
 -1.21126e-19
 -0.000877433
 -0.000146239
 -0.000220679
 -6.77626e-21
 -0.000879144
 -0.000146524
 -0.000855906
 -0.000142651
 -0.00020813
 -1.14349e-19
 -0.000885373
 -0.000147562
 -0.000222008
 -5.0822e-21
 -0.000846595
 0.000141099
 -0.000874352
 0.000145725
 -0.000215168
 1.11808e-19
 0.000145929
 0.000146549
 0.000147119
 0.000138753
 0.000148005
 0.000143445
 0.00417744
 0.00476988
 0.00497975
 0.0043015
 0.0229372
 0.00470862
 -0.000218734
 -3.38813e-21
 -0.00019901
 -1.09267e-19
 -0.000835488
 -0.000139248
 -0.000258254
 -8.47033e-21
 -0.000953976
 -0.000158996
 -0.00099595
 -0.000165992
 -0.000239721
 -6.77626e-21
 -0.000860301
 -0.000143383
 -0.000231141
 -1.25361e-19
 -0.000941724
 0.000156954
 0.000145823
 0.000132673
 0.000172169
 0.000159814
 0.000154094
 0.00423189
 0.00423297
 0.0242349
 0.00391886
 0.00435232
 0.00396559
 0.00353321
 -0.00020813
 -5.0822e-21
 -0.000846379
 -0.000141063
 -0.00021506
 -1.17738e-19
 -0.000846595
 -0.000141099
 -0.000215168
 -3.38813e-21
 -0.000783772
 0.000130629
 -0.000870464
 0.000145077
 -0.000793118
 0.000132186
 -0.000706643
 0.000117774
 -0.000176827
 9.14796e-20
 -0.000220064
 -1.11808e-19
 -0.000176495
 -9.14796e-20
 0.000138753
 0.000143373
 0.000143445
 0.000146709
 0.000117884
 0.000117663
 0.00509607
 0.00532457
 0.00484554
 0.00561162
 0.0371921
 0.00542756
 0.00546337
 0.00542342
 -0.000238057
 -6.77626e-21
 -0.00101921
 -0.000169869
 -0.00027155
 -1.49078e-19
 -0.000246497
 -1.34678e-19
 -0.00028596
 -6.77626e-21
 -0.00106491
 -0.000177486
 -0.000969108
 -0.000161518
 -0.00112232
 -0.000187054
 -0.000275202
 -3.38813e-21
 -0.00108551
 0.000180919
 -0.00109267
 0.000182112
 -0.00108468
 0.000180781
 -0.000271206
 1.42302e-19
 -0.000271136
 -1.38913e-19
 0.000158705
 0.000181033
 0.000164331
 0.00019064
 0.000183468
 0.000180804
 0.000180757
 0.00468303
 0.00466237
 0.0276996
 0.00468683
 0.00467345
 0.00450061
 0.00449334
 -0.000231878
 -3.38813e-21
 -0.000936606
 -0.000156101
 -0.000236425
 -1.28749e-19
 -0.000932474
 -0.000155412
 -0.000234359
 -6.77626e-21
 -0.000937367
 0.000156228
 -0.000934689
 0.000155782
 -0.000900123
 0.00015002
 -0.000898668
 0.000149778
 -0.000232259
 1.21973e-19
 -0.000232986
 -1.18585e-19
 -0.000217076
 -1.15196e-19
 0.000154585
 0.000157617
 0.000156239
 0.000155324
 0.000154839
 0.000144717
 0.00423499
 0.00414807
 0.0237923
 0.00433386
 0.00380286
 0.00341423
 0.00385832
 -0.000205972
 -3.38813e-21
 -0.000846999
 -0.000141166
 -0.000217527
 -1.18585e-19
 -0.000829615
 -0.000138269
 -0.000208835
 -3.38813e-21
 -0.000866772
 0.000144462
 -0.000760572
 0.000126762
 -0.000682846
 0.000113808
 -0.000771664
 0.000128611
 -0.000215859
 1.11808e-19
 -0.00017145
 -8.47033e-20
 -0.000169973
 -8.80914e-20
 0.000137315
 0.000145018
 0.000139224
 0.0001143
 0.000143906
 0.000113315
 0.00466053
 0.00511998
 0.00459074
 0.00552116
 0.0349119
 0.00524315
 0.00484091
 0.00493542
 -0.00022519
 -8.47033e-21
 -0.000932106
 -0.000155351
 -0.000240863
 -1.30443e-19
 -0.000233884
 -1.28749e-19
 -0.000278114
 -1.01644e-20
 -0.001024
 -0.000170666
 -0.000918148
 -0.000153025
 -0.00110423
 -0.000184039
 -0.000274002
 -8.47033e-21
 -0.00104863
 0.000174772
 -0.000968183
 0.000161364
 -0.000987084
 0.000164514
 -0.000250313
 -1.25361e-19
 -0.000243229
 1.18585e-19
 0.000185409
 0.000155923
 0.000182668
 0.000150127
 0.000160575
 0.000162153
 0.000166875
 0.00444425
 0.00445339
 0.0255334
 0.00454504
 0.00417377
 0.00377739
 0.00413952
 -0.000219307
 -6.77626e-21
 -0.000888851
 -0.000148142
 -0.000225119
 -1.2282e-19
 -0.000890679
 -0.000148446
 -0.000226033
 -3.38813e-21
 -0.000909008
 0.000151501
 -0.000834754
 0.000139126
 -0.000755477
 0.000125913
 -0.000827903
 0.000137984
 -0.000228471
 -1.18585e-19
 -0.000192258
 9.82558e-20
 -0.00018548
 9.48677e-20
 0.000146204
 0.000150079
 0.000150689
 0.000128172
 0.000152314
 0.000123653
 0.00475407
 0.00512985
 0.00468683
 0.00524315
 0.0289909
 0.00467879
 0.00449825
 -0.000238983
 -1.3129e-19
 -0.000236425
 -5.0822e-21
 -0.000950815
 -0.000158469
 -0.000274002
 -1.49078e-19
 -0.00102597
 -0.000170995
 -0.000937367
 -0.000156228
 -0.000232259
 -3.38813e-21
 -0.00104863
 -0.000174772
 -0.000250313
 -1.36372e-19
 -0.000935759
 0.00015596
 -0.00089965
 0.000149942
 -0.000217566
 1.15196e-19
 0.000159322
 0.000157617
 0.000182668
 0.000166875
 0.000154839
 0.000145044
 0.00501973
 0.00456456
 0.00542756
 0.00454504
 0.029113
 0.00499172
 0.00456437
 -0.000230423
 -1.26208e-19
 -0.00027155
 -6.77626e-21
 -0.00100395
 -0.000167324
 -0.000226033
 -1.23667e-19
 -0.000912912
 -0.000152152
 -0.00108551
 -0.000180919
 -0.000271206
 -6.77626e-21
 -0.000909008
 -0.000151501
 -0.000228471
 -1.24514e-19
 -0.000998344
 0.000166391
 -0.000912874
 0.000152146
 -0.000227966
 -1.18585e-19
 0.000153615
 0.000181033
 0.000150689
 0.000180804
 0.000152314
 0.000151977
 0.00433593
 0.00472588
 0.00391886
 0.0258768
 0.00504652
 0.00355593
 0.00429363
 -0.000218533
 -1.19432e-19
 -0.00021506
 -6.77626e-21
 -0.000867186
 -0.000144531
 -0.000945177
 -0.000157529
 -0.000254055
 -1.38913e-19
 -0.000783772
 -0.000130629
 -0.000176827
 -3.38813e-21
 -0.0010093
 0.000168217
 -0.000711186
 0.000118531
 -0.000858727
 0.000143121
 -0.000250597
 1.28749e-19
 -0.000178767
 -9.48677e-20
 0.000145689
 0.000143373
 0.00016937
 0.000117884
 0.000167065
 0.000119178
 0.00498889
 0.00513554
 0.00468798
 0.00530456
 0.00504652
 0.0354096
 0.00520628
 0.0050398
 -0.000231644
 -6.77626e-21
 -0.000997777
 -0.000166296
 -0.000267245
 -1.4569e-19
 -0.000237154
 -1.28749e-19
 -0.0002764
 -8.47033e-21
 -0.00102711
 -0.000171185
 -0.000937597
 -0.000156266
 -0.000254055
 -8.47033e-21
 -0.00106091
 -0.000176819
 -0.0010093
 -0.000168217
 -0.000250597
 -1.01644e-20
 -0.00104126
 0.000173543
 -0.00100796
 0.000167993
 -0.000253384
 1.28749e-19
 0.000154429
 0.000158103
 0.000184267
 0.00016937
 0.000178163
 0.000167065
 0.000168922
 0.00454856
 0.00493104
 0.00417377
 0.027271
 0.00525498
 0.00383195
 0.00453068
 -0.000229738
 -1.25361e-19
 -0.000225119
 -3.38813e-21
 -0.000909713
 -0.000151619
 -0.000986208
 -0.000164368
 -0.000263367
 -1.43996e-19
 -0.000834754
 -0.000139126
 -0.000192258
 -3.38813e-21
 -0.001051
 0.000175166
 -0.00076639
 0.000127732
 -0.000906135
 0.000151023
 -0.000262131
 1.32137e-19
 -0.000190936
 -9.82558e-20
 0.000153158
 0.000150079
 0.000175578
 0.000128172
 0.000174754
 0.000127291
 0.00521572
 0.00494489
 0.00545217
 0.00470862
 0.00525498
 0.0360169
 0.00522634
 0.00521417
 -0.00028185
 -6.77626e-21
 -0.000239721
 -1.30443e-19
 -0.00104314
 -0.000173857
 -0.000231141
 -1.69407e-21
 -0.000988978
 -0.00016483
 -0.000263348
 -1.4569e-19
 -0.000263367
 -1.69407e-21
 -0.00109043
 -0.000181739
 -0.000941724
 -0.000156954
 -0.001051
 -0.000175166
 -0.000262131
 -5.0822e-21
 -0.00104527
 0.000174211
 -0.00104283
 0.000173806
 -0.000259286
 1.32137e-19
 0.0001879
 0.000175578
 0.000159814
 0.000154094
 0.000175565
 0.000172857
 0.000174754
 0.00452796
 0.00510471
 0.00546337
 0.00433386
 0.028705
 0.00491393
 0.00436116
 -0.000235269
 -1.27902e-19
 -0.000217527
 -5.0822e-21
 -0.000905593
 -0.000150932
 -0.000275202
 -1.49078e-19
 -0.00102094
 -0.000170157
 -0.00109267
 -0.000182112
 -0.000271136
 -1.47384e-19
 -0.000866772
 -0.000144462
 -0.000215859
 -6.77626e-21
 -0.000982786
 0.000163798
 -0.000872232
 0.000145372
 -0.000220257
 1.11808e-19
 0.000156846
 0.000145018
 0.000183468
 0.000180757
 0.000143906
 0.000146838
 0.00445034
 0.00413007
 0.00380286
 0.00484091
 0.0248257
 0.00344186
 0.00415964
 -0.000204172
 -1.10961e-19
 -0.000240863
 -5.0822e-21
 -0.000890069
 -0.000148345
 -0.000208835
 -1.13502e-19
 -0.000826014
 -0.000137669
 -0.000760572
 -0.000126762
 -0.00017145
 -9.31736e-20
 -0.000968183
 -0.000161364
 -0.000243229
 -6.77626e-21
 -0.000688372
 0.000114729
 -0.000831929
 0.000138655
 -0.000172736
 8.80914e-20
 0.000139224
 0.000136115
 0.000160575
 0.0001143
 0.000162153
 0.000115157
 0.00496015
 0.00463129
 0.00467345
 0.00520628
 0.0287159
 0.00452039
 0.00472437
 -0.00022877
 -1.23667e-19
 -0.000267245
 -8.47033e-21
 -0.000992029
 -0.000165338
 -0.000234359
 -1.27902e-19
 -0.000926258
 -0.000154376
 -0.000934689
 -0.000155782
 -0.000232986
 -1.27055e-19
 -0.00104126
 -0.000173543
 -0.000253384
 -5.0822e-21
 -0.000904078
 0.00015068
 -0.000944874
 0.000157479
 -0.000219053
 1.11808e-19
 0.000156239
 0.000152513
 0.000178163
 0.000155324
 0.000168922
 0.000146036
 0.00485356
 0.00437176
 0.00435232
 0.00522634
 0.0279483
 0.00437604
 0.00476826
 -0.000222008
 -1.21126e-19
 -0.000263348
 -3.38813e-21
 -0.000970712
 -0.000161785
 -0.000215168
 -1.16891e-19
 -0.000874352
 -0.000145725
 -0.000870464
 -0.000145077
 -0.000220064
 -1.20279e-19
 -0.00104527
 -0.000174211
 -0.000259286
 -6.77626e-21
 -0.000875208
 0.000145868
 -0.000953652
 0.000158942
 -0.00021754
 1.0842e-19
 0.000148005
 0.000143445
 0.000175565
 0.000146709
 0.000172857
 0.000145027
 0.00396559
 0.00437604
 0.0256201
 0.00353135
 0.00463296
 0.00421152
 0.00490268
 -0.000220064
 -6.77626e-21
 -0.000793118
 -0.000132186
 -0.000176495
 -9.74088e-20
 -0.000875208
 -0.000145868
 -0.00021754
 -3.38813e-21
 -0.000706269
 0.000117712
 -0.000926592
 0.000154432
 -0.000842304
 0.000140384
 -0.000980536
 0.000163423
 -0.00017664
 9.14796e-20
 -0.000245756
 -1.25361e-19
 -0.000244512
 1.28749e-19
 0.000146709
 0.000117663
 0.000145027
 0.00011776
 0.000163837
 0.000163008
 0.00450061
 0.00452039
 0.0264991
 0.00439381
 0.00441745
 0.00431173
 0.00435514
 -0.000232986
 -1.01644e-20
 -0.000900123
 -0.00015002
 -0.000217076
 -1.18585e-19
 -0.000904078
 -0.00015068
 -0.000219053
 -6.77626e-21
 -0.000878763
 0.00014646
 -0.000883491
 0.000147248
 -0.000862345
 0.000143724
 -0.000871029
 0.000145171
 -0.000220328
 -1.11808e-19
 -0.00022467
 1.15196e-19
 -0.000210845
 -1.05032e-19
 0.000155324
 0.000144717
 0.000146036
 0.000146885
 0.000140563
 0.00014978
 0.00542342
 0.00499172
 0.00491393
 0.0287476
 0.00454306
 0.00440731
 0.00446814
 -0.000271206
 -1.47384e-19
 -0.000271136
 -6.77626e-21
 -0.00108468
 -0.000180781
 -0.000998344
 -0.000166391
 -0.000227966
 -1.24514e-19
 -0.000982786
 -0.000163798
 -0.000220257
 -6.77626e-21
 -0.000908612
 0.000151435
 -0.000881463
 0.00014691
 -0.000893629
 0.000148938
 -0.00022634
 1.15196e-19
 -0.000220474
 -1.15196e-19
 0.000180804
 0.000180757
 0.000151977
 0.000146838
 0.000150894
 0.000146983
 0.00353321
 0.00355593
 0.00353135
 0.0177617
 0.00358124
 0.00355997
 -0.000176827
 -9.65618e-20
 -0.000176495
 -5.0822e-21
 -0.000706643
 -0.000117774
 -0.000711186
 -0.000118531
 -0.000178767
 -9.82558e-20
 -0.000706269
 -0.000117712
 -0.00017664
 -5.0822e-21
 -0.000716248
 0.000119375
 -0.000711995
 0.000118666
 -0.000179357
 9.14796e-20
 0.000117884
 0.000117663
 0.000119178
 0.000119572
 0.00011776
 0.00341423
 0.00344186
 0.0171106
 0.00344168
 0.00339911
 0.00341371
 -0.00017145
 -3.38813e-21
 -0.000682846
 -0.000113808
 -0.000169973
 -9.23266e-20
 -0.000688372
 -0.000114729
 -0.000172736
 -5.0822e-21
 -0.000688336
 0.000114723
 -0.000679822
 0.000113304
 -0.000682741
 0.00011379
 -0.000171432
 -8.80914e-20
 -0.000169938
 8.80914e-20
 0.0001143
 0.000115157
 0.000113315
 0.000114288
 0.000113292
 0.00493542
 0.00467879
 0.00415964
 0.00344168
 0.0253487
 0.00429723
 0.00383589
 -0.000250313
 -1.01644e-20
 -0.000243229
 -1.33831e-19
 -0.000987084
 -0.000164514
 -0.000935759
 -0.00015596
 -0.000217566
 -3.38813e-21
 -0.000172736
 -9.40207e-20
 -0.000831929
 -0.000138655
 -0.000688336
 -0.000114723
 -0.000171432
 -9.31736e-20
 -0.000859447
 0.000143241
 -0.000767179
 0.000127863
 -0.000212157
 -1.05032e-19
 0.000162153
 0.000115157
 0.000166875
 0.000145044
 0.000114288
 0.000141438
 0.00377739
 0.00383195
 0.0199429
 0.00397845
 0.00407043
 0.00428471
 -0.000192258
 -1.05032e-19
 -0.000755477
 -0.000125913
 -0.00018548
 -6.77626e-21
 -0.00076639
 -0.000127732
 -0.000190936
 -1.04185e-19
 -0.00079569
 0.000132615
 -0.000814086
 0.000135681
 -0.000856943
 0.000142824
 -0.000212365
 -1.0842e-19
 -0.000216107
 1.0842e-19
 0.000128172
 0.000123653
 0.000127291
 0.000144071
 0.000141576
 0.00413952
 0.00456437
 0.00454306
 0.00397845
 0.026528
 0.00458141
 0.00472116
 -0.000228471
 -3.38813e-21
 -0.00018548
 -1.00797e-19
 -0.000827903
 -0.000137984
 -0.000227966
 -6.77626e-21
 -0.000912874
 -0.000152146
 -0.000908612
 -0.000151435
 -0.00022634
 -6.77626e-21
 -0.00079569
 -0.000132615
 -0.000212365
 -1.16044e-19
 -0.000916281
 0.000152714
 -0.000944233
 0.000157372
 -0.000245776
 1.28749e-19
 0.000152314
 0.000123653
 0.000151977
 0.000141576
 0.000150894
 0.000163851
 0.00429363
 0.0050398
 0.00472437
 0.00439381
 0.00358124
 0.0260297
 0.00399686
 -0.000250597
 -1.37219e-19
 -0.000178767
 -5.0822e-21
 -0.000858727
 -0.000143121
 -0.000253384
 -1.38913e-19
 -0.00100796
 -0.000167993
 -0.000219053
 -1.20279e-19
 -0.000944874
 -0.000157479
 -0.000878763
 -0.00014646
 -0.000220328
 -1.20279e-19
 -0.000716248
 -0.000119375
 -0.000179357
 -5.0822e-21
 -0.000799371
 0.000133229
 0.000167065
 0.000168922
 0.000119178
 0.000146036
 0.000146885
 0.000119572
 0.00385832
 0.00436116
 0.00440731
 0.00339911
 0.0241521
 0.00381043
 0.00431579
 -0.000215859
 -1.18585e-19
 -0.000169973
 -5.0822e-21
 -0.000771664
 -0.000128611
 -0.000220257
 -1.21126e-19
 -0.000872232
 -0.000145372
 -0.000881463
 -0.00014691
 -0.000220474
 -1.20279e-19
 -0.000679822
 -0.000113304
 -0.000169938
 -5.0822e-21
 -0.000762086
 0.000127014
 -0.000863158
 0.00014386
 -0.000211105
 -1.0842e-19
 0.000143906
 0.000146838
 0.000113315
 0.000146983
 0.000113292
 0.000140737
 0.00453068
 0.00521417
 0.00476826
 0.00463296
 0.00407043
 0.0278351
 0.00461862
 -0.000262131
 -1.43996e-19
 -0.000190936
 -5.0822e-21
 -0.000906135
 -0.000151023
 -0.000259286
 -1.43996e-19
 -0.00104283
 -0.000173806
 -0.00021754
 -1.18585e-19
 -0.000953652
 -0.000158942
 -0.000926592
 -0.000154432
 -0.000245756
 -1.33831e-19
 -0.000814086
 -0.000135681
 -0.000216107
 -8.47033e-21
 -0.000923725
 0.000153954
 0.000172857
 0.000145027
 0.000174754
 0.000127291
 0.000163837
 0.000144071
 0.00449334
 0.00449825
 0.00441745
 0.00429723
 0.026186
 0.00417732
 0.00430245
 -0.000232259
 -1.26208e-19
 -0.000217076
 -5.0822e-21
 -0.000898668
 -0.000149778
 -0.000217566
 -1.19432e-19
 -0.00089965
 -0.000149942
 -0.000883491
 -0.000147248
 -0.00022467
 -5.0822e-21
 -0.000859447
 -0.000143241
 -0.000212157
 -1.14349e-19
 -0.000835464
 0.000139244
 -0.00086049
 0.000143415
 -0.000205575
 1.01644e-19
 0.000154839
 0.000145044
 0.000144717
 0.000141438
 0.00014978
 0.00013705
 0.00421152
 0.00431173
 0.00355997
 0.00399686
 0.0253502
 0.00480337
 0.0044667
 -0.00017664
 -9.57147e-20
 -0.000842304
 -0.000140384
 -0.000244512
 -3.38813e-21
 -0.000220328
 -5.0822e-21
 -0.000862345
 -0.000143724
 -0.000210845
 -1.13502e-19
 -0.000179357
 -9.74088e-20
 -0.000711995
 -0.000118666
 -0.000799371
 -0.000133229
 -0.000960675
 0.000160112
 -0.00089334
 0.00014889
 -0.000235825
 -1.18585e-19
 0.000146885
 0.000119572
 0.00011776
 0.000163008
 0.000140563
 0.000157217
 0.00341371
 0.00383589
 0.00381043
 0.00417732
 0.0235707
 0.0041943
 0.004139
 -0.000171432
 -5.0822e-21
 -0.000169938
 -9.23266e-20
 -0.000682741
 -0.00011379
 -0.000212157
 -8.47033e-21
 -0.000767179
 -0.000127863
 -0.000762086
 -0.000127014
 -0.000211105
 -1.14349e-19
 -0.000835464
 -0.000139244
 -0.000205575
 -6.77626e-21
 -0.00083886
 0.00013981
 -0.000827801
 0.000137967
 -0.000208325
 1.0842e-19
 0.000114288
 0.000141438
 0.000113292
 0.00013705
 0.000140737
 0.000138883
 0.00490268
 0.00428471
 0.00458141
 0.00461862
 0.00480337
 0.0330992
 0.00500395
 0.00490444
 -0.000245756
 -6.77626e-21
 -0.000244512
 -1.32984e-19
 -0.000980536
 -0.000163423
 -0.000212365
 -6.77626e-21
 -0.000216107
 -1.17738e-19
 -0.000856943
 -0.000142824
 -0.000916281
 -0.000152714
 -0.000245776
 -5.0822e-21
 -0.000923725
 -0.000153954
 -0.000960675
 -0.000160112
 -0.000235825
 -1.28749e-19
 -0.00100079
 0.000166798
 -0.000980887
 0.000163481
 -0.000254619
 -1.25361e-19
 0.000163837
 0.000163008
 0.000144071
 0.000141576
 0.000163851
 0.000157217
 0.000169746
 0.00446814
 0.00472116
 0.00431579
 0.0041943
 0.00500395
 0.0273328
 0.00462944
 -0.00022634
 -1.23667e-19
 -0.000220474
 -5.0822e-21
 -0.000893629
 -0.000148938
 -0.000245776
 -1.34678e-19
 -0.000944233
 -0.000157372
 -0.000211105
 -5.0822e-21
 -0.000863158
 -0.00014386
 -0.00083886
 -0.00013981
 -0.000208325
 -6.77626e-21
 -0.00100079
 -0.000166798
 -0.000254619
 -1.38913e-19
 -0.000925887
 0.000154315
 0.000150894
 0.000163851
 0.000146983
 0.000140737
 0.000169746
 0.000138883
 0.00435514
 0.00430245
 0.0044667
 0.004139
 0.00490444
 0.00462944
 0.0267972
 -0.00022467
 -1.2282e-19
 -0.000210845
 -6.77626e-21
 -0.000871029
 -0.000145171
 -0.000205575
 -1.13502e-19
 -0.00086049
 -0.000143415
 -0.000235825
 -1.01644e-20
 -0.00089334
 -0.00014889
 -0.000208325
 -1.13502e-19
 -0.000827801
 -0.000137967
 -0.000254619
 -5.0822e-21
 -0.000980887
 -0.000163481
 -0.000925887
 -0.000154315
 0.000140563
 0.00014978
 0.000157217
 0.00013705
 0.000169746
 0.000138883
 -0.000520833
 -0.000520833
 -0.000260417
 8.68056e-05
 4.23516e-22
 4.34028e-05
 -6.2004e-06
 4.34028e-05
 -6.2004e-06
 -2.48016e-05
 8.68056e-05
 -8.68056e-05
 -3.38813e-21
 4.23516e-22
 9.3006e-06
 -6.2004e-06
 3.1002e-06
 6.2004e-06
 -3.1002e-06
 -1.27963e-21
 -0.000520833
 -0.000260417
 -0.000520833
 4.34028e-05
 -6.2004e-06
 8.68056e-05
 2.00641e-20
 4.34028e-05
 6.2004e-06
 -2.48016e-05
 8.68056e-05
 -1.42302e-19
 -8.68056e-05
 -6.2004e-06
 3.1002e-06
 2.00641e-20
 9.3006e-06
 6.2004e-06
 3.1002e-06
 -1.11173e-20
 -0.000520833
 -0.000520833
 -0.000260417
 8.68056e-05
 2.00641e-20
 4.34028e-05
 -6.2004e-06
 4.34028e-05
 -6.2004e-06
 -2.48016e-05
 8.68056e-05
 -8.68056e-05
 -1.42302e-19
 2.00641e-20
 9.3006e-06
 -6.2004e-06
 3.1002e-06
 6.2004e-06
 -3.1002e-06
 -1.13291e-20
 -0.000520833
 -0.000260417
 -0.000520833
 4.34028e-05
 -6.2004e-06
 8.68056e-05
 4.23516e-22
 4.34028e-05
 6.2004e-06
 -2.48016e-05
 8.68056e-05
 -3.38813e-21
 -8.68056e-05
 -6.2004e-06
 3.1002e-06
 4.23516e-22
 9.3006e-06
 6.2004e-06
 3.1002e-06
 -1.50092e-21
 -0.000520833
 -0.000520833
 -0.000260417
 8.68056e-05
 2.00641e-20
 4.34028e-05
 -6.2004e-06
 4.34028e-05
 -6.2004e-06
 -2.48016e-05
 8.68056e-05
 -8.68056e-05
 -1.42302e-19
 2.00641e-20
 9.3006e-06
 -6.2004e-06
 3.1002e-06
 6.2004e-06
 -3.1002e-06
 -1.13291e-20
 -0.000520833
 -0.000260417
 -0.000520833
 4.34028e-05
 -6.2004e-06
 8.68056e-05
 4.23516e-22
 4.34028e-05
 6.2004e-06
 -2.48016e-05
 8.68056e-05
 -3.38813e-21
 -8.68056e-05
 -6.2004e-06
 3.1002e-06
 4.23516e-22
 9.3006e-06
 6.2004e-06
 3.1002e-06
 -1.50092e-21
 -0.000520833
 -0.000520833
 -0.000260417
 8.68056e-05
 2.00641e-20
 4.34028e-05
 -6.2004e-06
 4.34028e-05
 -6.2004e-06
 -2.48016e-05
 8.68056e-05
 -8.68056e-05
 -1.42302e-19
 2.00641e-20
 9.3006e-06
 -6.2004e-06
 3.1002e-06
 6.2004e-06
 -3.1002e-06
 -1.13291e-20
 -0.000520833
 -0.000260417
 -0.000520833
 4.34028e-05
 -6.2004e-06
 8.68056e-05
 4.23516e-22
 4.34028e-05
 6.2004e-06
 -2.48016e-05
 8.68056e-05
 -3.38813e-21
 -8.68056e-05
 -6.2004e-06
 3.1002e-06
 4.23516e-22
 9.3006e-06
 6.2004e-06
 3.1002e-06
 -1.50092e-21
 -0.000459656
 -0.000459656
 -0.000229828
 7.66094e-05
 3.83047e-05
 -5.4721e-06
 3.83047e-05
 -5.4721e-06
 -2.18884e-05
 7.66094e-05
 -7.66094e-05
 -5.0822e-21
 8.20815e-06
 -5.4721e-06
 2.73605e-06
 5.4721e-06
 -2.73605e-06
 -1.01322e-21
 -0.000260417
 -0.00117772
 -0.00117772
 -0.000328444
 4.34028e-05
 6.2004e-06
 4.34028e-05
 6.2004e-06
 0.000196287
 4.7328e-20
 5.47406e-05
 -7.82009e-06
 5.47406e-05
 -7.82009e-06
 -2.48016e-05
 -3.12803e-05
 -1.28749e-19
 0.000196287
 -0.000196287
 -1.81265e-19
 -6.2004e-06
 -3.1002e-06
 6.2004e-06
 3.1002e-06
 4.7328e-20
 2.10307e-05
 -7.82009e-06
 3.91004e-06
 7.82009e-06
 -3.91004e-06
 -1.01644e-20
 -1.46113e-20
 -0.00111654
 -0.000229828
 -0.000328444
 -0.00111654
 3.83047e-05
 -5.4721e-06
 5.47406e-05
 -7.82009e-06
 0.000186091
 1.70465e-20
 3.83047e-05
 5.4721e-06
 5.47406e-05
 7.82009e-06
 -2.18884e-05
 -3.12803e-05
 0.000186091
 -1.24514e-19
 -1.01644e-20
 -0.000186091
 -5.4721e-06
 2.73605e-06
 -7.82009e-06
 3.91004e-06
 1.70465e-20
 1.99383e-05
 5.4721e-06
 2.73605e-06
 7.82009e-06
 3.91004e-06
 -9.95264e-21
 -1.60029e-21
 -0.000471641
 -0.000471641
 -0.000235821
 7.86068e-05
 4.23516e-22
 3.93034e-05
 -5.61477e-06
 3.93034e-05
 -5.61477e-06
 -2.24591e-05
 7.86068e-05
 -7.86068e-05
 -8.47033e-21
 4.23516e-22
 8.42216e-06
 -5.61477e-06
 2.80739e-06
 5.61477e-06
 -2.80739e-06
 -1.05159e-21
 -0.000229828
 -0.000950513
 -0.000950513
 -0.000245428
 3.83047e-05
 5.4721e-06
 3.83047e-05
 5.4721e-06
 0.000158419
 3.71106e-20
 4.09047e-05
 -5.84353e-06
 4.09047e-05
 -5.84353e-06
 -2.18884e-05
 -2.33741e-05
 -1.15196e-19
 0.000158419
 -0.000158419
 -1.35525e-19
 -5.4721e-06
 -2.73605e-06
 5.4721e-06
 2.73605e-06
 3.71106e-20
 1.69734e-05
 -5.84353e-06
 2.92177e-06
 5.84353e-06
 -2.92177e-06
 -8.89385e-21
 -1.0482e-20
 -0.000962498
 -0.000235821
 -0.000245428
 -0.000962498
 3.93034e-05
 -5.61477e-06
 4.09047e-05
 -5.84353e-06
 0.000160416
 1.86877e-20
 3.93034e-05
 5.61477e-06
 4.09047e-05
 5.84353e-06
 -2.24591e-05
 -2.33741e-05
 0.000160416
 -1.27902e-19
 -5.0822e-21
 -0.000160416
 -5.61477e-06
 2.80739e-06
 -5.84353e-06
 2.92177e-06
 1.86877e-20
 1.71875e-05
 5.61477e-06
 2.80739e-06
 5.84353e-06
 2.92177e-06
 -9.95264e-21
 -1.31778e-21
 -0.000451771
 -0.000451771
 -0.000225885
 7.52951e-05
 -4.23516e-22
 3.76476e-05
 -5.37822e-06
 3.76476e-05
 -5.37822e-06
 -2.15129e-05
 7.52951e-05
 -7.52951e-05
 -8.47033e-21
 -4.23516e-22
 8.06733e-06
 -5.37822e-06
 2.68911e-06
 5.37822e-06
 -2.68911e-06
 -8.80202e-22
 -0.000928575
 -0.000225885
 -0.000928575
 -0.000238402
 3.76476e-05
 -5.37822e-06
 0.000154763
 1.64113e-20
 3.97337e-05
 -5.67624e-06
 3.76476e-05
 5.37822e-06
 3.97337e-05
 -5.67624e-06
 -2.15129e-05
 -2.2705e-05
 0.000154763
 -1.2282e-19
 -0.000154763
 -1.01644e-20
 -5.37822e-06
 2.68911e-06
 1.64113e-20
 1.65817e-05
 -5.67624e-06
 2.83812e-06
 5.37822e-06
 2.68911e-06
 5.67624e-06
 -2.83812e-06
 -9.84676e-21
 -1.05341e-21
 -0.000235821
 -0.000948446
 -0.000238402
 -0.000948446
 3.93034e-05
 5.61477e-06
 3.93034e-05
 5.61477e-06
 3.97337e-05
 -5.67624e-06
 0.000158074
 3.4993e-20
 3.97337e-05
 5.67624e-06
 -2.24591e-05
 -2.2705e-05
 -1.18585e-19
 0.000158074
 -1.30443e-19
 -0.000158074
 -5.61477e-06
 -2.80739e-06
 5.61477e-06
 2.80739e-06
 -5.67624e-06
 2.83812e-06
 3.4993e-20
 1.69365e-05
 5.67624e-06
 2.83812e-06
 -9.21148e-21
 -1.01644e-20
 -0.000457033
 -0.000457033
 -0.000228517
 7.61722e-05
 3.80861e-05
 -5.44087e-06
 3.80861e-05
 -5.44087e-06
 -2.17635e-05
 7.61722e-05
 -7.61722e-05
 -3.38813e-21
 8.16131e-06
 -5.44087e-06
 2.72044e-06
 5.44087e-06
 -2.72044e-06
 -1.0179e-21
 -0.000225885
 -0.000911126
 -0.000911126
 -0.000229678
 3.76476e-05
 5.37822e-06
 3.76476e-05
 5.37822e-06
 0.000151854
 3.62107e-20
 3.82796e-05
 -5.46852e-06
 3.82796e-05
 -5.46852e-06
 -2.15129e-05
 -2.18741e-05
 -1.15196e-19
 0.000151854
 -0.000151854
 -1.24514e-19
 -5.37822e-06
 -2.68911e-06
 5.37822e-06
 2.68911e-06
 3.62107e-20
 1.62701e-05
 -5.46852e-06
 2.73426e-06
 5.46852e-06
 -2.73426e-06
 -8.89385e-21
 -9.95264e-21
 -0.000916389
 -0.000228517
 -0.000229678
 -0.000916389
 3.80861e-05
 -5.44087e-06
 3.82796e-05
 -5.46852e-06
 0.000152731
 1.70995e-20
 3.80861e-05
 5.44087e-06
 3.82796e-05
 5.46852e-06
 -2.17635e-05
 -2.18741e-05
 0.000152731
 -1.23667e-19
 -8.47033e-21
 -0.000152731
 -5.44087e-06
 2.72044e-06
 -5.46852e-06
 2.73426e-06
 1.70995e-20
 1.63641e-05
 5.44087e-06
 2.72044e-06
 5.46852e-06
 2.73426e-06
 -9.95264e-21
 -1.2278e-21
 -0.000474754
 -0.000474754
 -0.000237377
 7.91257e-05
 -4.23516e-22
 3.95628e-05
 -5.65183e-06
 3.95628e-05
 -5.65183e-06
 -2.26073e-05
 7.91257e-05
 -7.91257e-05
 -5.0822e-21
 -4.23516e-22
 8.47775e-06
 -5.65183e-06
 2.82592e-06
 5.65183e-06
 -2.82592e-06
 -1.21399e-21
 -0.000931996
 -0.000237377
 -0.000931996
 -0.000228621
 3.95628e-05
 -5.65183e-06
 0.000155333
 1.81053e-20
 3.81035e-05
 -5.44336e-06
 3.95628e-05
 5.65183e-06
 3.81035e-05
 -5.44336e-06
 -2.26073e-05
 -2.17735e-05
 0.000155333
 -1.29596e-19
 -0.000155333
 -3.38813e-21
 -5.65183e-06
 2.82592e-06
 1.81053e-20
 1.66428e-05
 -5.44336e-06
 2.72168e-06
 5.65183e-06
 2.82592e-06
 5.44336e-06
 -2.72168e-06
 -1.01644e-20
 -9.57355e-22
 -0.000228517
 -0.000914276
 -0.000228621
 -0.000914276
 3.80861e-05
 5.44087e-06
 3.80861e-05
 5.44087e-06
 3.81035e-05
 -5.44336e-06
 0.000152379
 3.62107e-20
 3.81035e-05
 5.44336e-06
 -2.17635e-05
 -2.17735e-05
 -1.15196e-19
 0.000152379
 -1.2282e-19
 -0.000152379
 -5.44087e-06
 -2.72044e-06
 5.44087e-06
 2.72044e-06
 -5.44336e-06
 2.72168e-06
 3.62107e-20
 1.63264e-05
 5.44336e-06
 2.72168e-06
 -8.68209e-21
 -9.95264e-21
 -0.000446635
 -0.000446635
 -0.000223318
 7.44392e-05
 -4.23516e-22
 3.72196e-05
 -5.31709e-06
 3.72196e-05
 -5.31709e-06
 -2.12683e-05
 7.44392e-05
 -7.44392e-05
 -6.77626e-21
 -4.23516e-22
 7.97563e-06
 -5.31709e-06
 2.65854e-06
 5.31709e-06
 -2.65854e-06
 -9.74759e-22
 -0.000237377
 -0.000883358
 -0.000883358
 -0.000204302
 3.95628e-05
 5.65183e-06
 3.95628e-05
 5.65183e-06
 0.000147226
 3.45695e-20
 3.40504e-05
 -4.86434e-06
 3.40504e-05
 -4.86434e-06
 -2.26073e-05
 -1.94574e-05
 -1.25361e-19
 0.000147226
 -0.000147226
 -1.10961e-19
 -5.65183e-06
 -2.82592e-06
 5.65183e-06
 2.82592e-06
 3.45695e-20
 1.57743e-05
 -4.86434e-06
 2.43217e-06
 4.86434e-06
 -2.43217e-06
 -9.42324e-21
 -8.78797e-21
 -0.00085524
 -0.000223318
 -0.000204302
 -0.00085524
 3.72196e-05
 -5.31709e-06
 3.40504e-05
 -4.86434e-06
 0.00014254
 1.78406e-20
 3.72196e-05
 5.31709e-06
 3.40504e-05
 4.86434e-06
 -2.12683e-05
 -1.94574e-05
 0.00014254
 -1.2282e-19
 -3.38813e-21
 -0.00014254
 -5.31709e-06
 2.65854e-06
 -4.86434e-06
 2.43217e-06
 1.78406e-20
 1.52721e-05
 5.31709e-06
 2.65854e-06
 4.86434e-06
 2.43217e-06
 -9.52912e-21
 -9.5929e-22
 -0.000260417
 -0.00118685
 -0.00118685
 -0.000333008
 4.34028e-05
 6.2004e-06
 4.34028e-05
 6.2004e-06
 0.000197808
 -2.28699e-20
 5.55014e-05
 -7.92876e-06
 5.55014e-05
 -7.92876e-06
 -2.48016e-05
 -3.17151e-05
 1.28749e-19
 0.000197808
 -0.000197808
 -1.01644e-20
 -6.2004e-06
 -3.1002e-06
 6.2004e-06
 3.1002e-06
 -2.28699e-20
 2.11937e-05
 -7.92876e-06
 3.96438e-06
 7.92876e-06
 -3.96438e-06
 1.03762e-20
 -1.59924e-21
 -0.00119083
 -0.000333008
 -0.00119083
 -0.000262408
 5.55014e-05
 -7.92876e-06
 0.000198472
 2.48816e-20
 4.37346e-05
 -6.2478e-06
 5.55014e-05
 7.92876e-06
 4.37346e-05
 -6.2478e-06
 -3.17151e-05
 -2.49912e-05
 0.000198472
 -1.82959e-19
 -0.000198472
 -8.47033e-21
 -7.92876e-06
 3.96438e-06
 2.48816e-20
 2.12649e-05
 -6.2478e-06
 3.1239e-06
 7.92876e-06
 3.96438e-06
 6.2478e-06
 -3.1239e-06
 -1.41878e-20
 -1.2154e-21
 -0.000223318
 -0.000971451
 -0.000262408
 -0.000971451
 3.72196e-05
 5.31709e-06
 3.72196e-05
 5.31709e-06
 4.37346e-05
 -6.2478e-06
 0.000161908
 3.74283e-20
 4.37346e-05
 6.2478e-06
 -2.12683e-05
 -2.49912e-05
 -1.11808e-19
 0.000161908
 -1.42302e-19
 -0.000161908
 -5.31709e-06
 -2.65854e-06
 5.31709e-06
 2.65854e-06
 -6.2478e-06
 3.1239e-06
 3.74283e-20
 1.73473e-05
 6.2478e-06
 3.1239e-06
 -8.99973e-21
 -1.11173e-20
 -0.000460405
 -0.000460405
 -0.000230202
 7.67341e-05
 -8.47033e-22
 3.83671e-05
 -5.48101e-06
 3.83671e-05
 -5.48101e-06
 -2.1924e-05
 7.67341e-05
 -7.67341e-05
 -5.0822e-21
 -8.47033e-22
 8.22151e-06
 -5.48101e-06
 2.7405e-06
 5.48101e-06
 -2.7405e-06
 -9.46847e-22
 -0.000333008
 -0.00112642
 -0.000230202
 -0.00112642
 5.55014e-05
 7.92876e-06
 5.55014e-05
 7.92876e-06
 3.83671e-05
 -5.48101e-06
 0.000187737
 4.19281e-20
 3.83671e-05
 5.48101e-06
 -2.1924e-05
 -3.17151e-05
 -1.69407e-19
 0.000187737
 -1.23667e-19
 -0.000187737
 -7.92876e-06
 -3.96438e-06
 7.92876e-06
 3.96438e-06
 -5.48101e-06
 2.7405e-06
 4.19281e-20
 2.01147e-05
 5.48101e-06
 2.7405e-06
 -9.95264e-21
 -1.33408e-20
 -0.000474192
 -0.000474192
 -0.000237096
 7.9032e-05
 3.9516e-05
 -5.64515e-06
 3.9516e-05
 -5.64515e-06
 -2.25806e-05
 7.9032e-05
 -7.9032e-05
 -5.0822e-21
 8.46772e-06
 -5.64515e-06
 2.82257e-06
 5.64515e-06
 -2.82257e-06
 -1.10787e-21
 -0.000230202
 -0.000959226
 -0.000959226
 -0.000249411
 3.83671e-05
 5.48101e-06
 3.83671e-05
 5.48101e-06
 0.000159871
 3.48342e-20
 4.15684e-05
 -5.93835e-06
 4.15684e-05
 -5.93835e-06
 -2.1924e-05
 -2.37534e-05
 -1.18585e-19
 0.000159871
 -0.000159871
 -1.35525e-19
 -5.48101e-06
 -2.7405e-06
 5.48101e-06
 2.7405e-06
 3.48342e-20
 1.7129e-05
 -5.93835e-06
 2.96917e-06
 5.93835e-06
 -2.96917e-06
 -8.99973e-21
 -1.07997e-20
 -0.000973014
 -0.000237096
 -0.000249411
 -0.000973014
 3.9516e-05
 -5.64515e-06
 4.15684e-05
 -5.93835e-06
 0.000162169
 1.73642e-20
 3.9516e-05
 5.64515e-06
 4.15684e-05
 5.93835e-06
 -2.25806e-05
 -2.37534e-05
 0.000162169
 -1.29596e-19
 -6.77626e-21
 -0.000162169
 -5.64515e-06
 2.82257e-06
 -5.93835e-06
 2.96917e-06
 1.73642e-20
 1.73752e-05
 5.64515e-06
 2.82257e-06
 5.93835e-06
 2.96917e-06
 -1.0482e-20
 -1.29252e-21
 -0.000438961
 -0.000438961
 -0.00021948
 7.31601e-05
 -4.23516e-22
 3.65801e-05
 -5.22572e-06
 3.65801e-05
 -5.22572e-06
 -2.09029e-05
 7.31601e-05
 -7.31601e-05
 -6.77626e-21
 -4.23516e-22
 7.83859e-06
 -5.22572e-06
 2.61286e-06
 5.22572e-06
 -2.61286e-06
 -8.06128e-22
 -0.000910182
 -0.00021948
 -0.000910182
 -0.00023561
 3.65801e-05
 -5.22572e-06
 0.000151697
 1.72583e-20
 3.92684e-05
 -5.60977e-06
 3.65801e-05
 5.22572e-06
 3.92684e-05
 -5.60977e-06
 -2.09029e-05
 -2.24391e-05
 0.000151697
 -1.19432e-19
 -0.000151697
 -5.0822e-21
 -5.22572e-06
 2.61286e-06
 1.72583e-20
 1.62532e-05
 -5.60977e-06
 2.80489e-06
 5.22572e-06
 2.61286e-06
 5.60977e-06
 -2.80489e-06
 -9.31736e-21
 -1.14258e-21
 -0.000237096
 -0.000945413
 -0.00023561
 -0.000945413
 3.9516e-05
 5.64515e-06
 3.9516e-05
 5.64515e-06
 3.92684e-05
 -5.60977e-06
 0.000157569
 3.43048e-20
 3.92684e-05
 5.60977e-06
 -2.25806e-05
 -2.24391e-05
 -1.18585e-19
 0.000157569
 -1.28749e-19
 -0.000157569
 -5.64515e-06
 -2.82257e-06
 5.64515e-06
 2.82257e-06
 -5.60977e-06
 2.80489e-06
 3.43048e-20
 1.68824e-05
 5.60977e-06
 2.80489e-06
 -9.42324e-21
 -1.03762e-20
 -0.000424997
 -0.000424997
 -0.000212498
 7.08328e-05
 3.54164e-05
 -5.05948e-06
 3.54164e-05
 -5.05948e-06
 -2.02379e-05
 7.08328e-05
 -7.08328e-05
 -3.38813e-21
 7.58922e-06
 -5.05948e-06
 2.52974e-06
 5.05948e-06
 -2.52974e-06
 -9.29052e-22
 -0.00021948
 -0.00087592
 -0.00087592
 -0.000218479
 3.65801e-05
 5.22572e-06
 3.65801e-05
 5.22572e-06
 0.000145987
 3.38284e-20
 3.64132e-05
 -5.20189e-06
 3.64132e-05
 -5.20189e-06
 -2.09029e-05
 -2.08076e-05
 -1.11808e-19
 0.000145987
 -0.000145987
 -1.20279e-19
 -5.22572e-06
 -2.61286e-06
 5.22572e-06
 2.61286e-06
 3.38284e-20
 1.56414e-05
 -5.20189e-06
 2.60095e-06
 5.20189e-06
 -2.60095e-06
 -8.47033e-21
 -9.42324e-21
 -0.000861955
 -0.000212498
 -0.000218479
 -0.000861955
 3.54164e-05
 -5.05948e-06
 3.64132e-05
 -5.20189e-06
 0.000143659
 1.5776e-20
 3.54164e-05
 5.05948e-06
 3.64132e-05
 5.20189e-06
 -2.02379e-05
 -2.08076e-05
 0.000143659
 -1.16891e-19
 -5.0822e-21
 -0.000143659
 -5.05948e-06
 2.52974e-06
 -5.20189e-06
 2.60095e-06
 1.5776e-20
 1.53921e-05
 5.05948e-06
 2.52974e-06
 5.20189e-06
 2.60095e-06
 -8.99973e-21
 -1.19931e-21
 -0.000440949
 -0.000440949
 -0.000220475
 7.34916e-05
 -4.23516e-22
 3.67458e-05
 -5.2494e-06
 3.67458e-05
 -5.2494e-06
 -2.09976e-05
 7.34916e-05
 -7.34916e-05
 -6.77626e-21
 -4.23516e-22
 7.87409e-06
 -5.2494e-06
 2.6247e-06
 5.2494e-06
 -2.6247e-06
 -1.01694e-21
 -0.000865943
 -0.000220475
 -0.000865943
 -0.000212497
 3.67458e-05
 -5.2494e-06
 0.000144324
 1.69936e-20
 3.54161e-05
 -5.05945e-06
 3.67458e-05
 5.2494e-06
 3.54161e-05
 -5.05945e-06
 -2.09976e-05
 -2.02378e-05
 0.000144324
 -1.19432e-19
 -0.000144324
 -5.0822e-21
 -5.2494e-06
 2.6247e-06
 1.69936e-20
 1.54633e-05
 -5.05945e-06
 2.52972e-06
 5.2494e-06
 2.6247e-06
 5.05945e-06
 -2.52972e-06
 -9.21148e-21
 -9.05794e-22
 -0.000212498
 -0.00084999
 -0.000212497
 -0.00084999
 3.54164e-05
 5.05948e-06
 3.54164e-05
 5.05948e-06
 3.54161e-05
 -5.05945e-06
 0.000141665
 3.35107e-20
 3.54161e-05
 5.05945e-06
 -2.02379e-05
 -2.02378e-05
 -1.0842e-19
 0.000141665
 -1.16891e-19
 -0.000141665
 -5.05948e-06
 -2.52974e-06
 5.05948e-06
 2.52974e-06
 -5.05945e-06
 2.52972e-06
 3.35107e-20
 1.51784e-05
 5.05945e-06
 2.52972e-06
 -8.04681e-21
 -8.99973e-21
 -0.00042868
 -0.00042868
 -0.00021434
 7.14466e-05
 4.23516e-22
 3.57233e-05
 -5.10333e-06
 3.57233e-05
 -5.10333e-06
 -2.04133e-05
 7.14466e-05
 -7.14466e-05
 -5.0822e-21
 4.23516e-22
 7.65499e-06
 -5.10333e-06
 2.55166e-06
 5.10333e-06
 -2.55166e-06
 -9.35689e-22
 -0.000220475
 -0.000821408
 -0.000821408
 -0.000190229
 3.67458e-05
 5.2494e-06
 3.67458e-05
 5.2494e-06
 0.000136901
 3.28755e-20
 3.17049e-05
 -4.52927e-06
 3.17049e-05
 -4.52927e-06
 -2.09976e-05
 -1.81171e-05
 -1.15196e-19
 0.000136901
 -0.000136901
 -1.03338e-19
 -5.2494e-06
 -2.6247e-06
 5.2494e-06
 2.6247e-06
 3.28755e-20
 1.4668e-05
 -4.52927e-06
 2.26463e-06
 4.52927e-06
 -2.26463e-06
 -8.78797e-21
 -8.47033e-21
 -0.000809138
 -0.00021434
 -0.000190229
 -0.000809138
 3.57233e-05
 -5.10333e-06
 3.17049e-05
 -4.52927e-06
 0.000134856
 1.59348e-20
 3.57233e-05
 5.10333e-06
 3.17049e-05
 4.52927e-06
 -2.04133e-05
 -1.81171e-05
 0.000134856
 -1.17738e-19
 -5.0822e-21
 -0.000134856
 -5.10333e-06
 2.55166e-06
 -4.52927e-06
 2.26463e-06
 1.59348e-20
 1.44489e-05
 5.10333e-06
 2.55166e-06
 4.52927e-06
 2.26463e-06
 -9.31736e-21
 -9.42087e-22
 -0.000260417
 -0.00117135
 -0.00117135
 -0.00032526
 4.34028e-05
 6.2004e-06
 4.34028e-05
 6.2004e-06
 0.000195225
 -2.20229e-20
 5.42099e-05
 -7.74428e-06
 5.42099e-05
 -7.74428e-06
 -2.48016e-05
 -3.09771e-05
 1.28749e-19
 0.000195225
 -0.000195225
 -6.77626e-21
 -6.2004e-06
 -3.1002e-06
 6.2004e-06
 3.1002e-06
 -2.20229e-20
 2.0917e-05
 -7.74428e-06
 3.87214e-06
 7.74428e-06
 -3.87214e-06
 1.03762e-20
 -1.24845e-21
 -0.00115669
 -0.00032526
 -0.00115669
 -0.000253086
 5.42099e-05
 -7.74428e-06
 0.000192782
 2.47757e-20
 4.21811e-05
 -6.02587e-06
 5.42099e-05
 7.74428e-06
 4.21811e-05
 -6.02587e-06
 -3.09771e-05
 -2.41035e-05
 0.000192782
 -1.77877e-19
 -0.000192782
 -5.0822e-21
 -7.74428e-06
 3.87214e-06
 2.47757e-20
 2.06552e-05
 -6.02587e-06
 3.01293e-06
 7.74428e-06
 3.87214e-06
 6.02587e-06
 -3.01293e-06
 -1.41878e-20
 -1.07568e-21
 -0.00021434
 -0.000934852
 -0.000253086
 -0.000934852
 3.57233e-05
 5.10333e-06
 3.57233e-05
 5.10333e-06
 4.21811e-05
 -6.02587e-06
 0.000155809
 3.4993e-20
 4.21811e-05
 6.02587e-06
 -2.04133e-05
 -2.41035e-05
 -1.11808e-19
 0.000155809
 -1.37219e-19
 -0.000155809
 -5.10333e-06
 -2.55166e-06
 5.10333e-06
 2.55166e-06
 -6.02587e-06
 3.01293e-06
 3.4993e-20
 1.66938e-05
 6.02587e-06
 3.01293e-06
 -8.47033e-21
 -1.09055e-20
 -0.000457476
 -0.000457476
 -0.000228738
 7.62459e-05
 4.23516e-22
 3.8123e-05
 -5.44614e-06
 3.8123e-05
 -5.44614e-06
 -2.17846e-05
 7.62459e-05
 -7.62459e-05
 -6.77626e-21
 4.23516e-22
 8.16921e-06
 -5.44614e-06
 2.72307e-06
 5.44614e-06
 -2.72307e-06
 -1.20088e-21
 -0.00032526
 -0.00110799
 -0.000228738
 -0.00110799
 5.42099e-05
 7.74428e-06
 5.42099e-05
 7.74428e-06
 3.8123e-05
 -5.44614e-06
 0.000184666
 4.25634e-20
 3.8123e-05
 5.44614e-06
 -2.17846e-05
 -3.09771e-05
 -1.6263e-19
 0.000184666
 -1.25361e-19
 -0.000184666
 -7.74428e-06
 -3.87214e-06
 7.74428e-06
 3.87214e-06
 -5.44614e-06
 2.72307e-06
 4.25634e-20
 1.97856e-05
 5.44614e-06
 2.72307e-06
 -9.74088e-21
 -1.27055e-20
 -0.000477982
 -0.000477982
 -0.000238991
 7.96636e-05
 3.98318e-05
 -5.69026e-06
 3.98318e-05
 -5.69026e-06
 -2.2761e-05
 7.96636e-05
 -7.96636e-05
 -8.47033e-21
 8.53538e-06
 -5.69026e-06
 2.84513e-06
 5.69026e-06
 -2.84513e-06
 -9.75323e-22
 -0.000228738
 -0.000955432
 -0.000955432
 -0.000248978
 3.8123e-05
 5.44614e-06
 3.8123e-05
 5.44614e-06
 0.000159239
 3.5893e-20
 4.14964e-05
 -5.92806e-06
 4.14964e-05
 -5.92806e-06
 -2.17846e-05
 -2.37122e-05
 -1.18585e-19
 0.000159239
 -0.000159239
 -1.35525e-19
 -5.44614e-06
 -2.72307e-06
 5.44614e-06
 2.72307e-06
 3.5893e-20
 1.70613e-05
 -5.92806e-06
 2.96403e-06
 5.92806e-06
 -2.96403e-06
 -8.99973e-21
 -1.06938e-20
 -0.000975938
 -0.000238991
 -0.000248978
 -0.000975938
 3.98318e-05
 -5.69026e-06
 4.14964e-05
 -5.92806e-06
 0.000162656
 1.8423e-20
 3.98318e-05
 5.69026e-06
 4.14964e-05
 5.92806e-06
 -2.2761e-05
 -2.37122e-05
 0.000162656
 -1.29596e-19
 -8.47033e-21
 -0.000162656
 -5.69026e-06
 2.84513e-06
 -5.92806e-06
 2.96403e-06
 1.8423e-20
 1.74275e-05
 5.69026e-06
 2.84513e-06
 5.92806e-06
 2.96403e-06
 -1.02703e-20
 -1.32496e-21
 -0.000465749
 -0.000465749
 -0.000232874
 7.76248e-05
 3.88124e-05
 -5.54463e-06
 3.88124e-05
 -5.54463e-06
 -2.21785e-05
 7.76248e-05
 -7.76248e-05
 -3.38813e-21
 8.31694e-06
 -5.54463e-06
 2.77231e-06
 5.54463e-06
 -2.77231e-06
 -1.22986e-21
 -0.000956536
 -0.000232874
 -0.000956536
 -0.000245394
 3.88124e-05
 -5.54463e-06
 0.000159423
 1.65171e-20
 4.0899e-05
 -5.84271e-06
 3.88124e-05
 5.54463e-06
 4.0899e-05
 -5.84271e-06
 -2.21785e-05
 -2.33708e-05
 0.000159423
 -1.26208e-19
 -0.000159423
 -6.77626e-21
 -5.54463e-06
 2.77231e-06
 1.65171e-20
 1.7081e-05
 -5.84271e-06
 2.92136e-06
 5.54463e-06
 2.77231e-06
 5.84271e-06
 -2.92136e-06
 -9.95264e-21
 -9.25353e-22
 -0.000238991
 -0.000968769
 -0.000245394
 -0.000968769
 3.98318e-05
 5.69026e-06
 3.98318e-05
 5.69026e-06
 4.0899e-05
 -5.84271e-06
 0.000161462
 3.68459e-20
 4.0899e-05
 5.84271e-06
 -2.2761e-05
 -2.33708e-05
 -1.18585e-19
 0.000161462
 -1.32137e-19
 -0.000161462
 -5.69026e-06
 -2.84513e-06
 5.69026e-06
 2.84513e-06
 -5.84271e-06
 2.92136e-06
 3.68459e-20
 1.72994e-05
 5.84271e-06
 2.92136e-06
 -9.31736e-21
 -1.05879e-20
 -0.000464748
 -0.000464748
 -0.000232374
 7.7458e-05
 -4.23516e-22
 3.8729e-05
 -5.53272e-06
 3.8729e-05
 -5.53272e-06
 -2.21309e-05
 7.7458e-05
 -7.7458e-05
 -5.0822e-21
 -4.23516e-22
 8.29908e-06
 -5.53272e-06
 2.76636e-06
 5.53272e-06
 -2.76636e-06
 -9.86042e-22
 -0.000232874
 -0.000937265
 -0.000937265
 -0.000235758
 3.88124e-05
 5.54463e-06
 3.88124e-05
 5.54463e-06
 0.000156211
 3.63695e-20
 3.9293e-05
 -5.61328e-06
 3.9293e-05
 -5.61328e-06
 -2.21785e-05
 -2.24531e-05
 -1.21973e-19
 0.000156211
 -0.000156211
 -1.29596e-19
 -5.54463e-06
 -2.77231e-06
 5.54463e-06
 2.77231e-06
 3.63695e-20
 1.67369e-05
 -5.61328e-06
 2.80664e-06
 5.61328e-06
 -2.80664e-06
 -9.1056e-21
 -1.01644e-20
 -0.000936264
 -0.000232374
 -0.000235758
 -0.000936264
 3.8729e-05
 -5.53272e-06
 3.9293e-05
 -5.61328e-06
 0.000156044
 1.77348e-20
 3.8729e-05
 5.53272e-06
 3.9293e-05
 5.61328e-06
 -2.21309e-05
 -2.24531e-05
 0.000156044
 -1.27055e-19
 -8.47033e-21
 -0.000156044
 -5.53272e-06
 2.76636e-06
 -5.61328e-06
 2.80664e-06
 1.77348e-20
 1.6719e-05
 5.53272e-06
 2.76636e-06
 5.61328e-06
 2.80664e-06
 -1.01644e-20
 -1.14921e-21
 -0.000470467
 -0.000470467
 -0.000235233
 7.84111e-05
 4.23516e-22
 3.92056e-05
 -5.60079e-06
 3.92056e-05
 -5.60079e-06
 -2.24032e-05
 7.84111e-05
 -7.84111e-05
 -6.77626e-21
 4.23516e-22
 8.40119e-06
 -5.60079e-06
 2.8004e-06
 5.60079e-06
 -2.8004e-06
 -1.12026e-21
 -0.000932321
 -0.000235233
 -0.000932321
 -0.000230927
 3.92056e-05
 -5.60079e-06
 0.000155387
 1.81053e-20
 3.84879e-05
 -5.49827e-06
 3.92056e-05
 5.60079e-06
 3.84879e-05
 -5.49827e-06
 -2.24032e-05
 -2.19931e-05
 0.000155387
 -1.27902e-19
 -0.000155387
 -5.0822e-21
 -5.60079e-06
 2.8004e-06
 1.81053e-20
 1.66486e-05
 -5.49827e-06
 2.74914e-06
 5.60079e-06
 2.8004e-06
 5.49827e-06
 -2.74914e-06
 -9.84676e-21
 -8.98413e-22
 -0.000232374
 -0.000926603
 -0.000230927
 -0.000926603
 3.8729e-05
 5.53272e-06
 3.8729e-05
 5.53272e-06
 3.84879e-05
 -5.49827e-06
 0.000154434
 3.49401e-20
 3.84879e-05
 5.49827e-06
 -2.21309e-05
 -2.19931e-05
 -1.18585e-19
 0.000154434
 -1.27055e-19
 -0.000154434
 -5.53272e-06
 -2.76636e-06
 5.53272e-06
 2.76636e-06
 -5.49827e-06
 2.74914e-06
 3.49401e-20
 1.65465e-05
 5.49827e-06
 2.74914e-06
 -9.42324e-21
 -9.95264e-21
 -0.000439017
 -0.000439017
 -0.000219508
 7.31695e-05
 -4.23516e-22
 3.65847e-05
 -5.22639e-06
 3.65847e-05
 -5.22639e-06
 -2.09056e-05
 7.31695e-05
 -7.31695e-05
 -3.38813e-21
 -4.23516e-22
 7.83959e-06
 -5.22639e-06
 2.6132e-06
 5.22639e-06
 -2.6132e-06
 -9.02727e-22
 -0.000235233
 -0.000872247
 -0.000872247
 -0.00020089
 3.92056e-05
 5.60079e-06
 3.92056e-05
 5.60079e-06
 0.000145374
 3.36696e-20
 3.34817e-05
 -4.7831e-06
 3.34817e-05
 -4.7831e-06
 -2.24032e-05
 -1.91324e-05
 -1.21973e-19
 0.000145374
 -0.000145374
 -1.09267e-19
 -5.60079e-06
 -2.8004e-06
 5.60079e-06
 2.8004e-06
 3.36696e-20
 1.55758e-05
 -4.7831e-06
 2.39155e-06
 4.7831e-06
 -2.39155e-06
 -9.31736e-21
 -8.89385e-21
 -0.000840797
 -0.000219508
 -0.00020089
 -0.000840797
 3.65847e-05
 -5.22639e-06
 3.34817e-05
 -4.7831e-06
 0.000140133
 1.65171e-20
 3.65847e-05
 5.22639e-06
 3.34817e-05
 4.7831e-06
 -2.09056e-05
 -1.91324e-05
 0.000140133
 -1.19432e-19
 -3.38813e-21
 -0.000140133
 -5.22639e-06
 2.6132e-06
 -4.7831e-06
 2.39155e-06
 1.65171e-20
 1.50142e-05
 5.22639e-06
 2.6132e-06
 4.7831e-06
 2.39155e-06
 -9.31736e-21
 -1.13497e-21
 -0.000260417
 -0.00117183
 -0.00117183
 -0.000325499
 4.34028e-05
 6.2004e-06
 4.34028e-05
 6.2004e-06
 0.000195305
 -2.03288e-20
 5.42498e-05
 -7.74997e-06
 5.42498e-05
 -7.74997e-06
 -2.48016e-05
 -3.09999e-05
 1.28749e-19
 0.000195305
 -0.000195305
 -1.01644e-20
 -6.2004e-06
 -3.1002e-06
 6.2004e-06
 3.1002e-06
 -2.03288e-20
 2.09255e-05
 -7.74997e-06
 3.87498e-06
 7.74997e-06
 -3.87498e-06
 1.03762e-20
 -1.65219e-21
 -0.00116562
 -0.000325499
 -0.00116562
 -0.00025731
 5.42498e-05
 -7.74997e-06
 0.000194269
 2.47757e-20
 4.2885e-05
 -6.12642e-06
 5.42498e-05
 7.74997e-06
 4.2885e-05
 -6.12642e-06
 -3.09999e-05
 -2.45057e-05
 0.000194269
 -1.77877e-19
 -0.000194269
 -3.38813e-21
 -7.74997e-06
 3.87498e-06
 2.47757e-20
 2.08146e-05
 -6.12642e-06
 3.06321e-06
 7.74997e-06
 3.87498e-06
 6.12642e-06
 -3.06321e-06
 -1.3976e-20
 -1.11427e-21
 -0.000219508
 -0.000953636
 -0.00025731
 -0.000953636
 3.65847e-05
 5.22639e-06
 3.65847e-05
 5.22639e-06
 4.2885e-05
 -6.12642e-06
 0.000158939
 3.69518e-20
 4.2885e-05
 6.12642e-06
 -2.09056e-05
 -2.45057e-05
 -1.11808e-19
 0.000158939
 -1.42302e-19
 -0.000158939
 -5.22639e-06
 -2.6132e-06
 5.22639e-06
 2.6132e-06
 -6.12642e-06
 3.06321e-06
 3.69518e-20
 1.70292e-05
 6.12642e-06
 3.06321e-06
 -8.47033e-21
 -1.11173e-20
 -0.000453569
 -0.000453569
 -0.000226785
 7.55949e-05
 3.77974e-05
 -5.39964e-06
 3.77974e-05
 -5.39964e-06
 -2.15985e-05
 7.55949e-05
 -7.55949e-05
 -8.47033e-21
 8.09945e-06
 -5.39964e-06
 2.69982e-06
 5.39964e-06
 -2.69982e-06
 -1.02997e-21
 -0.000325499
 -0.00110457
 -0.000226785
 -0.00110457
 5.42498e-05
 7.74997e-06
 5.42498e-05
 7.74997e-06
 3.77974e-05
 -5.39964e-06
 0.000184094
 4.24575e-20
 3.77974e-05
 5.39964e-06
 -2.15985e-05
 -3.09999e-05
 -1.69407e-19
 0.000184094
 -1.2282e-19
 -0.000184094
 -7.74997e-06
 -3.87498e-06
 7.74997e-06
 3.87498e-06
 -5.39964e-06
 2.69982e-06
 4.24575e-20
 1.97244e-05
 5.39964e-06
 2.69982e-06
 -9.635e-21
 -1.24937e-20
 -0.000456144
 -0.000456144
 -0.000228072
 7.60239e-05
 -8.47033e-22
 3.8012e-05
 -5.43028e-06
 3.8012e-05
 -5.43028e-06
 -2.17211e-05
 7.60239e-05
 -7.60239e-05
 -6.77626e-21
 -8.47033e-22
 8.14542e-06
 -5.43028e-06
 2.71514e-06
 5.43028e-06
 -2.71514e-06
 -9.56313e-22
 -0.000226785
 -0.000932388
 -0.000932388
 -0.00023941
 3.77974e-05
 5.39964e-06
 3.77974e-05
 5.39964e-06
 0.000155398
 3.54166e-20
 3.99016e-05
 -5.70023e-06
 3.99016e-05
 -5.70023e-06
 -2.15985e-05
 -2.28009e-05
 -1.15196e-19
 0.000155398
 -0.000155398
 -1.30443e-19
 -5.39964e-06
 -2.69982e-06
 5.39964e-06
 2.69982e-06
 3.54166e-20
 1.66498e-05
 -5.70023e-06
 2.85011e-06
 5.70023e-06
 -2.85011e-06
 -8.78797e-21
 -1.05879e-20
 -0.000934963
 -0.000228072
 -0.00023941
 -0.000934963
 3.8012e-05
 -5.43028e-06
 3.99016e-05
 -5.70023e-06
 0.000155827
 1.6623e-20
 3.8012e-05
 5.43028e-06
 3.99016e-05
 5.70023e-06
 -2.17211e-05
 -2.28009e-05
 0.000155827
 -1.2282e-19
 -6.77626e-21
 -0.000155827
 -5.43028e-06
 2.71514e-06
 -5.70023e-06
 2.85011e-06
 1.6623e-20
 1.66958e-05
 5.43028e-06
 2.71514e-06
 5.70023e-06
 2.85011e-06
 -9.74088e-21
 -1.32113e-21
 -0.000431062
 -0.000431062
 -0.000215531
 7.18436e-05
 3.59218e-05
 -5.13169e-06
 3.59218e-05
 -5.13169e-06
 -2.05267e-05
 7.18436e-05
 -7.18436e-05
 -5.0822e-21
 7.69753e-06
 -5.13169e-06
 2.56584e-06
 5.13169e-06
 -2.56584e-06
 -1.06523e-21
 -0.000890065
 -0.000215531
 -0.000890065
 -0.000229502
 3.59218e-05
 -5.13169e-06
 0.000148344
 1.61466e-20
 3.82503e-05
 -5.46433e-06
 3.59218e-05
 5.13169e-06
 3.82503e-05
 -5.46433e-06
 -2.05267e-05
 -2.18573e-05
 0.000148344
 -1.17738e-19
 -0.000148344
 -3.38813e-21
 -5.13169e-06
 2.56584e-06
 1.61466e-20
 1.5894e-05
 -5.46433e-06
 2.73216e-06
 5.13169e-06
 2.56584e-06
 5.46433e-06
 -2.73216e-06
 -9.1056e-21
 -9.14871e-22
 -0.000228072
 -0.000915147
 -0.000229502
 -0.000915147
 3.8012e-05
 5.43028e-06
 3.8012e-05
 5.43028e-06
 3.82503e-05
 -5.46433e-06
 0.000152524
 3.65283e-20
 3.82503e-05
 5.46433e-06
 -2.17211e-05
 -2.18573e-05
 -1.18585e-19
 0.000152524
 -1.24514e-19
 -0.000152524
 -5.43028e-06
 -2.71514e-06
 5.43028e-06
 2.71514e-06
 -5.46433e-06
 2.73216e-06
 3.65283e-20
 1.63419e-05
 5.46433e-06
 2.73216e-06
 -8.68209e-21
 -9.84676e-21
 -0.000437786
 -0.000437786
 -0.000218893
 7.29644e-05
 3.64822e-05
 -5.21174e-06
 3.64822e-05
 -5.21174e-06
 -2.0847e-05
 7.29644e-05
 -7.29644e-05
 -3.38813e-21
 7.81761e-06
 -5.21174e-06
 2.60587e-06
 5.21174e-06
 -2.60587e-06
 -1.04191e-21
 -0.000215531
 -0.000870709
 -0.000870709
 -0.000219824
 3.59218e-05
 5.13169e-06
 3.59218e-05
 5.13169e-06
 0.000145118
 3.42519e-20
 3.66373e-05
 -5.23389e-06
 3.66373e-05
 -5.23389e-06
 -2.05267e-05
 -2.09356e-05
 -1.0842e-19
 0.000145118
 -0.000145118
 -1.21126e-19
 -5.13169e-06
 -2.56584e-06
 5.13169e-06
 2.56584e-06
 3.42519e-20
 1.55484e-05
 -5.23389e-06
 2.61695e-06
 5.23389e-06
 -2.61695e-06
 -8.68209e-21
 -9.52912e-21
 -0.000877433
 -0.000218893
 -0.000219824
 -0.000877433
 3.64822e-05
 -5.21174e-06
 3.66373e-05
 -5.23389e-06
 0.000146239
 1.56701e-20
 3.64822e-05
 5.21174e-06
 3.66373e-05
 5.23389e-06
 -2.0847e-05
 -2.09356e-05
 0.000146239
 -1.18585e-19
 -6.77626e-21
 -0.000146239
 -5.21174e-06
 2.60587e-06
 -5.23389e-06
 2.61695e-06
 1.56701e-20
 1.56684e-05
 5.21174e-06
 2.60587e-06
 5.23389e-06
 2.61695e-06
 -9.42324e-21
 -1.22357e-21
 -0.000460804
 -0.000460804
 -0.000230402
 7.68007e-05
 3.84003e-05
 -5.48576e-06
 3.84003e-05
 -5.48576e-06
 -2.19431e-05
 7.68007e-05
 -7.68007e-05
 -5.0822e-21
 8.22865e-06
 -5.48576e-06
 2.74288e-06
 5.48576e-06
 -2.74288e-06
 -9.32262e-22
 -0.000902162
 -0.000230402
 -0.000902162
 -0.000220679
 3.84003e-05
 -5.48576e-06
 0.00015036
 1.82112e-20
 3.67798e-05
 -5.25426e-06
 3.84003e-05
 5.48576e-06
 3.67798e-05
 -5.25426e-06
 -2.19431e-05
 -2.1017e-05
 0.00015036
 -1.24514e-19
 -0.00015036
 -6.77626e-21
 -5.48576e-06
 2.74288e-06
 1.82112e-20
 1.611e-05
 -5.25426e-06
 2.62713e-06
 5.48576e-06
 2.74288e-06
 5.25426e-06
 -2.62713e-06
 -9.95264e-21
 -8.31921e-22
 -0.000218893
 -0.000879144
 -0.000220679
 -0.000879144
 3.64822e-05
 5.21174e-06
 3.64822e-05
 5.21174e-06
 3.67798e-05
 -5.25426e-06
 0.000146524
 3.18167e-20
 3.67798e-05
 5.25426e-06
 -2.0847e-05
 -2.1017e-05
 -1.11808e-19
 0.000146524
 -1.21126e-19
 -0.000146524
 -5.21174e-06
 -2.60587e-06
 5.21174e-06
 2.60587e-06
 -5.25426e-06
 2.62713e-06
 3.18167e-20
 1.5699e-05
 5.25426e-06
 2.62713e-06
 -8.25857e-21
 -9.31736e-21
 -0.000437468
 -0.000437468
 -0.000218734
 7.29113e-05
 3.64557e-05
 -5.20795e-06
 3.64557e-05
 -5.20795e-06
 -2.08318e-05
 7.29113e-05
 -7.29113e-05
 -3.38813e-21
 7.81193e-06
 -5.20795e-06
 2.60398e-06
 5.20795e-06
 -2.60398e-06
 -1.0832e-21
 -0.000230402
 -0.000858824
 -0.000858824
 -0.00019901
 3.84003e-05
 5.48576e-06
 3.84003e-05
 5.48576e-06
 0.000143137
 3.25578e-20
 3.31683e-05
 -4.73833e-06
 3.31683e-05
 -4.73833e-06
 -2.19431e-05
 -1.89533e-05
 -1.18585e-19
 0.000143137
 -0.000143137
 -1.09267e-19
 -5.48576e-06
 -2.74288e-06
 5.48576e-06
 2.74288e-06
 3.25578e-20
 1.53361e-05
 -4.73833e-06
 2.36916e-06
 4.73833e-06
 -2.36916e-06
 -9.1056e-21
 -8.57621e-21
 -0.000835488
 -0.000218734
 -0.00019901
 -0.000835488
 3.64557e-05
 -5.20795e-06
 3.31683e-05
 -4.73833e-06
 0.000139248
 1.67818e-20
 3.64557e-05
 5.20795e-06
 3.31683e-05
 4.73833e-06
 -2.08318e-05
 -1.89533e-05
 0.000139248
 -1.20279e-19
 -3.38813e-21
 -0.000139248
 -5.20795e-06
 2.60398e-06
 -4.73833e-06
 2.36916e-06
 1.67818e-20
 1.49194e-05
 5.20795e-06
 2.60398e-06
 4.73833e-06
 2.36916e-06
 -9.42324e-21
 -8.12576e-22
 -0.000328444
 -0.0011734
 -0.0011734
 -0.000258254
 5.47406e-05
 7.82009e-06
 5.47406e-05
 7.82009e-06
 0.000195566
 -2.49875e-20
 4.30423e-05
 -6.14891e-06
 4.30423e-05
 -6.14891e-06
 -3.12803e-05
 -2.45956e-05
 1.69407e-19
 0.000195566
 -0.000195566
 -8.47033e-21
 -7.82009e-06
 -3.91004e-06
 7.82009e-06
 3.91004e-06
 -2.49875e-20
 2.09535e-05
 -6.14891e-06
 3.07445e-06
 6.14891e-06
 -3.07445e-06
 1.3129e-20
 -1.02295e-21
 -0.000218734
 -0.000953976
 -0.000258254
 -0.000953976
 3.64557e-05
 5.20795e-06
 3.64557e-05
 5.20795e-06
 4.30423e-05
 -6.14891e-06
 0.000158996
 3.73753e-20
 4.30423e-05
 6.14891e-06
 -2.08318e-05
 -2.45956e-05
 -1.11808e-19
 0.000158996
 -1.42302e-19
 -0.000158996
 -5.20795e-06
 -2.60398e-06
 5.20795e-06
 2.60398e-06
 -6.14891e-06
 3.07445e-06
 3.73753e-20
 1.70353e-05
 6.14891e-06
 3.07445e-06
 -8.89385e-21
 -1.10114e-20
 -0.000245428
 -0.00105456
 -0.00105456
 -0.00028185
 4.09047e-05
 5.84353e-06
 4.09047e-05
 5.84353e-06
 0.00017576
 -1.86347e-20
 4.69751e-05
 -6.71072e-06
 4.69751e-05
 -6.71072e-06
 -2.33741e-05
 -2.68429e-05
 1.25361e-19
 0.00017576
 -0.00017576
 -6.77626e-21
 -5.84353e-06
 -2.92177e-06
 5.84353e-06
 2.92177e-06
 -1.86347e-20
 1.88314e-05
 -6.71072e-06
 3.35536e-06
 6.71072e-06
 -3.35536e-06
 9.74088e-21
 -1.22942e-21
 -0.000258254
 -0.00099595
 -0.00099595
 -0.000239721
 4.30423e-05
 6.14891e-06
 4.30423e-05
 6.14891e-06
 0.000165992
 3.944e-20
 3.99535e-05
 -5.70765e-06
 3.99535e-05
 -5.70765e-06
 -2.45956e-05
 -2.28306e-05
 -1.32137e-19
 0.000165992
 -0.000165992
 -1.30443e-19
 -6.14891e-06
 -3.07445e-06
 6.14891e-06
 3.07445e-06
 3.944e-20
 1.77848e-05
 -5.70765e-06
 2.85382e-06
 5.70765e-06
 -2.85382e-06
 -9.95264e-21
 -1.03762e-20
 -0.00104314
 -0.00028185
 -0.000239721
 -0.00104314
 4.69751e-05
 -6.71072e-06
 3.99535e-05
 -5.70765e-06
 0.000173857
 2.1017e-20
 4.69751e-05
 6.71072e-06
 3.99535e-05
 5.70765e-06
 -2.68429e-05
 -2.28306e-05
 0.000173857
 -1.52466e-19
 -6.77626e-21
 -0.000173857
 -6.71072e-06
 3.35536e-06
 -5.70765e-06
 2.85382e-06
 2.1017e-20
 1.86276e-05
 6.71072e-06
 3.35536e-06
 5.70765e-06
 2.85382e-06
 -1.21761e-20
 -1.32113e-21
 -0.000238402
 -0.00093628
 -0.00093628
 -0.000229738
 3.97337e-05
 5.67624e-06
 3.97337e-05
 5.67624e-06
 0.000156047
 3.56283e-20
 3.82896e-05
 -5.46994e-06
 3.82896e-05
 -5.46994e-06
 -2.2705e-05
 -2.18798e-05
 -1.21973e-19
 0.000156047
 -0.000156047
 -1.25361e-19
 -5.67624e-06
 -2.83812e-06
 5.67624e-06
 2.83812e-06
 3.56283e-20
 1.67193e-05
 -5.46994e-06
 2.73497e-06
 5.46994e-06
 -2.73497e-06
 -9.21148e-21
 -9.95264e-21
 -0.000229678
 -0.000897969
 -0.000897969
 -0.000219307
 3.82796e-05
 5.46852e-06
 3.82796e-05
 5.46852e-06
 0.000149661
 -1.69407e-20
 3.65511e-05
 -5.22159e-06
 3.65511e-05
 -5.22159e-06
 -2.18741e-05
 -2.08864e-05
 1.15196e-19
 0.000149661
 -0.000149661
 -6.77626e-21
 -5.46852e-06
 -2.73426e-06
 5.46852e-06
 2.73426e-06
 -1.69407e-20
 1.60352e-05
 -5.22159e-06
 2.61079e-06
 5.22159e-06
 -2.61079e-06
 8.89385e-21
 -9.25172e-22
 -0.000888851
 -0.000219307
 -0.000888851
 -0.000225119
 3.65511e-05
 -5.22159e-06
 0.000148142
 1.68877e-20
 3.75198e-05
 -5.35997e-06
 3.65511e-05
 5.22159e-06
 3.75198e-05
 -5.35997e-06
 -2.08864e-05
 -2.14399e-05
 0.000148142
 -1.19432e-19
 -0.000148142
 -3.38813e-21
 -5.22159e-06
 2.61079e-06
 1.68877e-20
 1.58723e-05
 -5.35997e-06
 2.67999e-06
 5.22159e-06
 2.61079e-06
 5.35997e-06
 -2.67999e-06
 -9.31736e-21
 -8.65147e-22
 -0.000909713
 -0.000229738
 -0.000225119
 -0.000909713
 3.82896e-05
 -5.46994e-06
 3.75198e-05
 -5.35997e-06
 0.000151619
 1.69936e-20
 3.82896e-05
 5.46994e-06
 3.75198e-05
 5.35997e-06
 -2.18798e-05
 -2.14399e-05
 0.000151619
 -3.38813e-21
 -1.2282e-19
 -0.000151619
 -5.46994e-06
 2.73497e-06
 -5.35997e-06
 2.67999e-06
 1.69936e-20
 1.62449e-05
 5.46994e-06
 2.73497e-06
 5.35997e-06
 2.67999e-06
 -1.12883e-21
 -9.635e-21
 -0.000228621
 -0.000918089
 -0.000918089
 -0.000230423
 3.81035e-05
 5.44336e-06
 3.81035e-05
 5.44336e-06
 0.000153015
 3.44107e-20
 3.84038e-05
 -5.48626e-06
 3.84038e-05
 -5.48626e-06
 -2.17735e-05
 -2.19451e-05
 -1.15196e-19
 0.000153015
 -0.000153015
 -1.26208e-19
 -5.44336e-06
 -2.72168e-06
 5.44336e-06
 2.72168e-06
 3.44107e-20
 1.63944e-05
 -5.48626e-06
 2.74313e-06
 5.48626e-06
 -2.74313e-06
 -8.89385e-21
 -1.00585e-20
 -0.000204302
 -0.000884718
 -0.000884718
 -0.000238057
 3.40504e-05
 4.86434e-06
 3.40504e-05
 4.86434e-06
 0.000147453
 -1.69407e-20
 3.96761e-05
 -5.66802e-06
 3.96761e-05
 -5.66802e-06
 -1.94574e-05
 -2.26721e-05
 1.05032e-19
 0.000147453
 -0.000147453
 -6.77626e-21
 -4.86434e-06
 -2.43217e-06
 4.86434e-06
 2.43217e-06
 -1.69407e-20
 1.57985e-05
 -5.66802e-06
 2.83401e-06
 5.66802e-06
 -2.83401e-06
 8.04681e-21
 -9.92299e-22
 -0.00101921
 -0.000238057
 -0.00101921
 -0.00027155
 3.96761e-05
 -5.66802e-06
 0.000169869
 1.84759e-20
 4.52583e-05
 -6.46547e-06
 3.96761e-05
 5.66802e-06
 4.52583e-05
 -6.46547e-06
 -2.26721e-05
 -2.58619e-05
 0.000169869
 -1.29596e-19
 -0.000169869
 -6.77626e-21
 -5.66802e-06
 2.83401e-06
 1.84759e-20
 1.82002e-05
 -6.46547e-06
 3.23274e-06
 5.66802e-06
 2.83401e-06
 6.46547e-06
 -3.23274e-06
 -1.01644e-20
 -1.33946e-21
 -0.00100395
 -0.000230423
 -0.00027155
 -0.00100395
 3.84038e-05
 -5.48626e-06
 4.52583e-05
 -6.46547e-06
 0.000167324
 2.13346e-20
 3.84038e-05
 5.48626e-06
 4.52583e-05
 6.46547e-06
 -2.19451e-05
 -2.58619e-05
 0.000167324
 -3.38813e-21
 -1.49078e-19
 -0.000167324
 -5.48626e-06
 2.74313e-06
 -6.46547e-06
 3.23274e-06
 2.13346e-20
 1.79276e-05
 5.48626e-06
 2.74313e-06
 6.46547e-06
 3.23274e-06
 -9.96003e-22
 -1.15408e-20
 -0.000262408
 -0.00101781
 -0.00101781
 -0.000246497
 4.37346e-05
 6.2478e-06
 4.37346e-05
 6.2478e-06
 0.000169635
 4.10282e-20
 4.10829e-05
 -5.86898e-06
 4.10829e-05
 -5.86898e-06
 -2.49912e-05
 -2.34759e-05
 -1.32137e-19
 0.000169635
 -0.000169635
 -1.34678e-19
 -6.2478e-06
 -3.1239e-06
 6.2478e-06
 3.1239e-06
 4.10282e-20
 1.81752e-05
 -5.86898e-06
 2.93449e-06
 5.86898e-06
 -2.93449e-06
 -1.03762e-20
 -1.10114e-20
 -0.000249411
 -0.00107074
 -0.00107074
 -0.00028596
 4.15684e-05
 5.93835e-06
 4.15684e-05
 5.93835e-06
 0.000178457
 -1.86347e-20
 4.766e-05
 -6.80857e-06
 4.766e-05
 -6.80857e-06
 -2.37534e-05
 -2.72343e-05
 1.28749e-19
 0.000178457
 -0.000178457
 -6.77626e-21
 -5.93835e-06
 -2.96917e-06
 5.93835e-06
 2.96917e-06
 -1.86347e-20
 1.91204e-05
 -6.80857e-06
 3.40429e-06
 6.80857e-06
 -3.40429e-06
 9.74088e-21
 -1.09855e-21
 -0.00106491
 -0.000246497
 -0.00028596
 -0.00106491
 4.10829e-05
 -5.86898e-06
 4.766e-05
 -6.80857e-06
 0.000177486
 2.20758e-20
 4.10829e-05
 5.86898e-06
 4.766e-05
 6.80857e-06
 -2.34759e-05
 -2.72343e-05
 0.000177486
 -1.01644e-20
 -1.57548e-19
 -0.000177486
 -5.86898e-06
 2.93449e-06
 -6.80857e-06
 3.40429e-06
 2.20758e-20
 1.90163e-05
 5.86898e-06
 2.93449e-06
 6.80857e-06
 3.40429e-06
 -1.05858e-21
 -1.24937e-20
 -0.00023561
 -0.000941759
 -0.000941759
 -0.000235269
 3.92684e-05
 5.60977e-06
 3.92684e-05
 5.60977e-06
 0.00015696
 3.52577e-20
 3.92115e-05
 -5.60165e-06
 3.92115e-05
 -5.60165e-06
 -2.24391e-05
 -2.24066e-05
 -1.21973e-19
 0.00015696
 -0.00015696
 -1.27902e-19
 -5.60977e-06
 -2.80489e-06
 5.60977e-06
 2.80489e-06
 3.52577e-20
 1.68171e-05
 -5.60165e-06
 2.80082e-06
 5.60165e-06
 -2.80082e-06
 -9.52912e-21
 -1.00585e-20
 -0.000218479
 -0.000848903
 -0.000848903
 -0.000205972
 3.64132e-05
 5.20189e-06
 3.64132e-05
 5.20189e-06
 0.000141484
 -1.69407e-20
 3.43287e-05
 -4.90409e-06
 3.43287e-05
 -4.90409e-06
 -2.08076e-05
 -1.96164e-05
 1.15196e-19
 0.000141484
 -0.000141484
 -3.38813e-21
 -5.20189e-06
 -2.60095e-06
 5.20189e-06
 2.60095e-06
 -1.69407e-20
 1.5159e-05
 -4.90409e-06
 2.45205e-06
 4.90409e-06
 -2.45205e-06
 8.78797e-21
 -8.42681e-22
 -0.000846999
 -0.000205972
 -0.000846999
 -0.000217527
 3.43287e-05
 -4.90409e-06
 0.000141166
 1.55642e-20
 3.62545e-05
 -5.17922e-06
 3.43287e-05
 4.90409e-06
 3.62545e-05
 -5.17922e-06
 -1.96164e-05
 -2.07169e-05
 0.000141166
 -1.12655e-19
 -0.000141166
 -5.0822e-21
 -4.90409e-06
 2.45205e-06
 1.55642e-20
 1.5125e-05
 -5.17922e-06
 2.58961e-06
 4.90409e-06
 2.45205e-06
 5.17922e-06
 -2.58961e-06
 -8.68209e-21
 -9.50785e-22
 -0.000905593
 -0.000235269
 -0.000217527
 -0.000905593
 3.92115e-05
 -5.60165e-06
 3.62545e-05
 -5.17922e-06
 0.000150932
 1.61466e-20
 3.92115e-05
 5.60165e-06
 3.62545e-05
 5.17922e-06
 -2.24066e-05
 -2.07169e-05
 0.000150932
 -8.47033e-21
 -1.18585e-19
 -0.000150932
 -5.60165e-06
 2.80082e-06
 -5.17922e-06
 2.58961e-06
 1.61466e-20
 1.61713e-05
 5.60165e-06
 2.80082e-06
 5.17922e-06
 2.58961e-06
 -1.04999e-21
 -9.52912e-21
 -0.000212497
 -0.000833337
 -0.000833337
 -0.000204172
 3.54161e-05
 5.05945e-06
 3.54161e-05
 5.05945e-06
 0.00013889
 3.25049e-20
 3.40286e-05
 -4.86123e-06
 3.40286e-05
 -4.86123e-06
 -2.02378e-05
 -1.94449e-05
 -1.0842e-19
 0.00013889
 -0.00013889
 -1.10961e-19
 -5.05945e-06
 -2.52972e-06
 5.05945e-06
 2.52972e-06
 3.25049e-20
 1.4881e-05
 -4.86123e-06
 2.43062e-06
 4.86123e-06
 -2.43062e-06
 -8.57621e-21
 -8.89385e-21
 -0.000190229
 -0.000830838
 -0.000830838
 -0.00022519
 3.17049e-05
 4.52927e-06
 3.17049e-05
 4.52927e-06
 0.000138473
 -1.52466e-20
 3.75317e-05
 -5.36167e-06
 3.75317e-05
 -5.36167e-06
 -1.81171e-05
 -2.14467e-05
 9.82558e-20
 0.000138473
 -0.000138473
 -8.47033e-21
 -4.52927e-06
 -2.26463e-06
 4.52927e-06
 2.26463e-06
 -1.52466e-20
 1.48364e-05
 -5.36167e-06
 2.68083e-06
 5.36167e-06
 -2.68083e-06
 7.72918e-21
 -1.00337e-21
 -0.000932106
 -0.00022519
 -0.000932106
 -0.000240863
 3.75317e-05
 -5.36167e-06
 0.000155351
 1.74171e-20
 4.01438e-05
 -5.73483e-06
 3.75317e-05
 5.36167e-06
 4.01438e-05
 -5.73483e-06
 -2.14467e-05
 -2.29393e-05
 0.000155351
 -1.2282e-19
 -0.000155351
 -5.0822e-21
 -5.36167e-06
 2.68083e-06
 1.74171e-20
 1.66447e-05
 -5.73483e-06
 2.86741e-06
 5.36167e-06
 2.68083e-06
 5.73483e-06
 -2.86741e-06
 -9.635e-21
 -1.16082e-21
 -0.000890069
 -0.000204172
 -0.000240863
 -0.000890069
 3.40286e-05
 -4.86123e-06
 4.01438e-05
 -5.73483e-06
 0.000148345
 1.88994e-20
 3.40286e-05
 4.86123e-06
 4.01438e-05
 5.73483e-06
 -1.94449e-05
 -2.29393e-05
 0.000148345
 -3.38813e-21
 -1.30443e-19
 -0.000148345
 -4.86123e-06
 2.43062e-06
 -5.73483e-06
 2.86741e-06
 1.88994e-20
 1.58941e-05
 4.86123e-06
 2.43062e-06
 5.73483e-06
 2.86741e-06
 -1.10829e-21
 -1.0482e-20
 -0.000253086
 -0.000973941
 -0.000973941
 -0.000233884
 4.21811e-05
 6.02587e-06
 4.21811e-05
 6.02587e-06
 0.000162323
 3.70577e-20
 3.89807e-05
 -5.56867e-06
 3.89807e-05
 -5.56867e-06
 -2.41035e-05
 -2.22747e-05
 -1.28749e-19
 0.000162323
 -0.000162323
 -1.28749e-19
 -6.02587e-06
 -3.01293e-06
 6.02587e-06
 3.01293e-06
 3.70577e-20
 1.73918e-05
 -5.56867e-06
 2.78433e-06
 5.56867e-06
 -2.78433e-06
 -9.74088e-21
 -1.03762e-20
 -0.000248978
 -0.00105419
 -0.00105419
 -0.000278114
 4.14964e-05
 5.92806e-06
 4.14964e-05
 5.92806e-06
 0.000175698
 -2.20229e-20
 4.63524e-05
 -6.62177e-06
 4.63524e-05
 -6.62177e-06
 -2.37122e-05
 -2.64871e-05
 1.28749e-19
 0.000175698
 -0.000175698
 -1.01644e-20
 -5.92806e-06
 -2.96403e-06
 5.92806e-06
 2.96403e-06
 -2.20229e-20
 1.88247e-05
 -6.62177e-06
 3.31088e-06
 6.62177e-06
 -3.31088e-06
 9.95264e-21
 -1.3333e-21
 -0.001024
 -0.000233884
 -0.000278114
 -0.001024
 3.89807e-05
 -5.56867e-06
 4.63524e-05
 -6.62177e-06
 0.000170666
 2.00112e-20
 3.89807e-05
 5.56867e-06
 4.63524e-05
 6.62177e-06
 -2.64871e-05
 -2.22747e-05
 0.000170666
 -3.38813e-21
 -1.50772e-19
 -0.000170666
 -5.56867e-06
 2.78433e-06
 -6.62177e-06
 3.31088e-06
 2.00112e-20
 1.82857e-05
 5.56867e-06
 2.78433e-06
 6.62177e-06
 3.31088e-06
 -1.11173e-20
 -1.16774e-21
 -0.000245394
 -0.000968753
 -0.000968753
 -0.000238983
 4.0899e-05
 5.84271e-06
 4.0899e-05
 5.84271e-06
 0.000161459
 3.71636e-20
 3.98304e-05
 -5.69006e-06
 3.98304e-05
 -5.69006e-06
 -2.33708e-05
 -2.27602e-05
 -1.28749e-19
 0.000161459
 -0.000161459
 -1.3129e-19
 -5.84271e-06
 -2.92136e-06
 5.84271e-06
 2.92136e-06
 3.71636e-20
 1.72992e-05
 -5.69006e-06
 2.84503e-06
 5.69006e-06
 -2.84503e-06
 -9.52912e-21
 -1.02703e-20
 -0.000235758
 -0.000935272
 -0.000935272
 -0.000231878
 3.9293e-05
 5.61328e-06
 3.9293e-05
 5.61328e-06
 0.000155879
 -1.82112e-20
 3.86464e-05
 -5.52091e-06
 3.86464e-05
 -5.52091e-06
 -2.24531e-05
 -2.20836e-05
 1.21973e-19
 0.000155879
 -0.000155879
 -3.38813e-21
 -5.61328e-06
 -2.80664e-06
 5.61328e-06
 2.80664e-06
 -1.82112e-20
 1.67013e-05
 -5.52091e-06
 2.76045e-06
 5.52091e-06
 -2.76045e-06
 9.42324e-21
 -8.65891e-22
 -0.000936606
 -0.000231878
 -0.000936606
 -0.000236425
 3.86464e-05
 -5.52091e-06
 0.000156101
 1.76818e-20
 3.94041e-05
 -5.62916e-06
 3.86464e-05
 5.52091e-06
 3.94041e-05
 -5.62916e-06
 -2.20836e-05
 -2.25166e-05
 0.000156101
 -1.27055e-19
 -0.000156101
 -5.0822e-21
 -5.52091e-06
 2.76045e-06
 1.76818e-20
 1.67251e-05
 -5.62916e-06
 2.81458e-06
 5.52091e-06
 2.76045e-06
 5.62916e-06
 -2.81458e-06
 -1.01644e-20
 -9.74957e-22
 -0.000950815
 -0.000238983
 -0.000236425
 -0.000950815
 3.98304e-05
 -5.69006e-06
 3.94041e-05
 -5.62916e-06
 0.000158469
 1.81053e-20
 3.98304e-05
 5.69006e-06
 3.94041e-05
 5.62916e-06
 -2.27602e-05
 -2.25166e-05
 0.000158469
 -1.01644e-20
 -1.28749e-19
 -0.000158469
 -5.69006e-06
 2.84503e-06
 -5.62916e-06
 2.81458e-06
 1.81053e-20
 1.69788e-05
 5.69006e-06
 2.84503e-06
 5.62916e-06
 2.81458e-06
 -1.02356e-21
 -1.00585e-20
 -0.000230927
 -0.000919395
 -0.000919395
 -0.00022877
 3.84879e-05
 5.49827e-06
 3.84879e-05
 5.49827e-06
 0.000153233
 3.60518e-20
 3.81284e-05
 -5.44691e-06
 3.81284e-05
 -5.44691e-06
 -2.19931e-05
 -2.17876e-05
 -1.18585e-19
 0.000153233
 -0.000153233
 -1.23667e-19
 -5.49827e-06
 -2.74914e-06
 5.49827e-06
 2.74914e-06
 3.60518e-20
 1.64178e-05
 -5.44691e-06
 2.72346e-06
 5.44691e-06
 -2.72346e-06
 -9.1056e-21
 -9.84676e-21
 -0.00020089
 -0.000865069
 -0.000865069
 -0.000231644
 3.34817e-05
 4.7831e-06
 3.34817e-05
 4.7831e-06
 0.000144178
 -1.27055e-20
 3.86074e-05
 -5.51534e-06
 3.86074e-05
 -5.51534e-06
 -1.91324e-05
 -2.20614e-05
 1.05032e-19
 0.000144178
 -0.000144178
 -6.77626e-21
 -4.7831e-06
 -2.39155e-06
 4.7831e-06
 2.39155e-06
 -1.27055e-20
 1.54477e-05
 -5.51534e-06
 2.75767e-06
 5.51534e-06
 -2.75767e-06
 8.04681e-21
 -9.46629e-22
 -0.000997777
 -0.000231644
 -0.000997777
 -0.000267245
 3.86074e-05
 -5.51534e-06
 0.000166296
 1.72054e-20
 4.45408e-05
 -6.36296e-06
 3.86074e-05
 5.51534e-06
 4.45408e-05
 -6.36296e-06
 -2.20614e-05
 -2.54519e-05
 0.000166296
 -1.26208e-19
 -0.000166296
 -8.47033e-21
 -5.51534e-06
 2.75767e-06
 1.72054e-20
 1.78175e-05
 -6.36296e-06
 3.18148e-06
 5.51534e-06
 2.75767e-06
 6.36296e-06
 -3.18148e-06
 -9.95264e-21
 -1.30388e-21
 -0.000992029
 -0.00022877
 -0.000267245
 -0.000992029
 3.81284e-05
 -5.44691e-06
 4.45408e-05
 -6.36296e-06
 0.000165338
 2.017e-20
 3.81284e-05
 5.44691e-06
 4.45408e-05
 6.36296e-06
 -2.17876e-05
 -2.54519e-05
 0.000165338
 -6.77626e-21
 -1.4569e-19
 -0.000165338
 -5.44691e-06
 2.72346e-06
 -6.36296e-06
 3.18148e-06
 2.017e-20
 1.77148e-05
 5.44691e-06
 2.72346e-06
 6.36296e-06
 3.18148e-06
 -1.23601e-21
 -1.14349e-20
 -0.00025731
 -0.000988928
 -0.000988928
 -0.000237154
 4.2885e-05
 6.12642e-06
 4.2885e-05
 6.12642e-06
 0.000164821
 3.47813e-20
 3.95257e-05
 -5.64652e-06
 3.95257e-05
 -5.64652e-06
 -2.45057e-05
 -2.25861e-05
 -1.32137e-19
 0.000164821
 -0.000164821
 -1.28749e-19
 -6.12642e-06
 -3.06321e-06
 6.12642e-06
 3.06321e-06
 3.47813e-20
 1.76594e-05
 -5.64652e-06
 2.82326e-06
 5.64652e-06
 -2.82326e-06
 -1.00585e-20
 -1.03762e-20
 -0.00023941
 -0.00103162
 -0.00103162
 -0.0002764
 3.99016e-05
 5.70023e-06
 3.99016e-05
 5.70023e-06
 0.000171937
 -1.86347e-20
 4.60667e-05
 -6.58096e-06
 4.60667e-05
 -6.58096e-06
 -2.28009e-05
 -2.63238e-05
 1.21973e-19
 0.000171937
 -0.000171937
 -8.47033e-21
 -5.70023e-06
 -2.85011e-06
 5.70023e-06
 2.85011e-06
 -1.86347e-20
 1.84218e-05
 -6.58096e-06
 3.29048e-06
 6.58096e-06
 -3.29048e-06
 9.31736e-21
 -1.31299e-21
 -0.00102711
 -0.000237154
 -0.0002764
 -0.00102711
 3.95257e-05
 -5.64652e-06
 4.60667e-05
 -6.58096e-06
 0.000171185
 2.17582e-20
 3.95257e-05
 5.64652e-06
 4.60667e-05
 6.58096e-06
 -2.25861e-05
 -2.63238e-05
 0.000171185
 -8.47033e-21
 -1.52466e-19
 -0.000171185
 -5.64652e-06
 2.82326e-06
 -6.58096e-06
 3.29048e-06
 2.17582e-20
 1.83412e-05
 5.64652e-06
 2.82326e-06
 6.58096e-06
 3.29048e-06
 -1.26203e-21
 -1.18585e-20
 -0.000229502
 -0.00089607
 -0.00089607
 -0.000218533
 3.82503e-05
 5.46433e-06
 3.82503e-05
 5.46433e-06
 0.000149345
 3.53636e-20
 3.64222e-05
 -5.20317e-06
 3.64222e-05
 -5.20317e-06
 -2.18573e-05
 -2.08127e-05
 -1.15196e-19
 0.000149345
 -0.000149345
 -1.19432e-19
 -5.46433e-06
 -2.73216e-06
 5.46433e-06
 2.73216e-06
 3.53636e-20
 1.60012e-05
 -5.20317e-06
 2.60158e-06
 5.20317e-06
 -2.60158e-06
 -9.31736e-21
 -9.52912e-21
 -0.000219824
 -0.000855906
 -0.000855906
 -0.00020813
 3.66373e-05
 5.23389e-06
 3.66373e-05
 5.23389e-06
 0.000142651
 -1.86347e-20
 3.46883e-05
 -4.95547e-06
 3.46883e-05
 -4.95547e-06
 -2.09356e-05
 -1.98219e-05
 1.11808e-19
 0.000142651
 -0.000142651
 -5.0822e-21
 -5.23389e-06
 -2.61695e-06
 5.23389e-06
 2.61695e-06
 -1.86347e-20
 1.5284e-05
 -4.95547e-06
 2.47773e-06
 4.95547e-06
 -2.47773e-06
 8.99973e-21
 -8.9921e-22
 -0.000846379
 -0.00020813
 -0.000846379
 -0.00021506
 3.46883e-05
 -4.95547e-06
 0.000141063
 1.59877e-20
 3.58433e-05
 -5.12047e-06
 3.46883e-05
 4.95547e-06
 3.58433e-05
 -5.12047e-06
 -1.98219e-05
 -2.04819e-05
 0.000141063
 -1.14349e-19
 -0.000141063
 -6.77626e-21
 -4.95547e-06
 2.47773e-06
 1.59877e-20
 1.51139e-05
 -5.12047e-06
 2.56023e-06
 4.95547e-06
 2.47773e-06
 5.12047e-06
 -2.56023e-06
 -8.89385e-21
 -1.05026e-21
 -0.000867186
 -0.000218533
 -0.00021506
 -0.000867186
 3.64222e-05
 -5.20317e-06
 3.58433e-05
 -5.12047e-06
 0.000144531
 1.65701e-20
 3.64222e-05
 5.20317e-06
 3.58433e-05
 5.12047e-06
 -2.08127e-05
 -2.04819e-05
 0.000144531
 -5.0822e-21
 -1.17738e-19
 -0.000144531
 -5.20317e-06
 2.60158e-06
 -5.12047e-06
 2.56023e-06
 1.65701e-20
 1.54855e-05
 5.20317e-06
 2.60158e-06
 5.12047e-06
 2.56023e-06
 -1.16518e-21
 -9.1056e-21
 -0.000220679
 -0.000885373
 -0.000885373
 -0.000222008
 3.67798e-05
 5.25426e-06
 3.67798e-05
 5.25426e-06
 0.000147562
 3.40401e-20
 3.70013e-05
 -5.2859e-06
 3.70013e-05
 -5.2859e-06
 -2.1017e-05
 -2.11436e-05
 -1.15196e-19
 0.000147562
 -0.000147562
 -1.21126e-19
 -5.25426e-06
 -2.62713e-06
 5.25426e-06
 2.62713e-06
 3.40401e-20
 1.58102e-05
 -5.2859e-06
 2.64295e-06
 5.2859e-06
 -2.64295e-06
 -8.47033e-21
 -9.635e-21
 -0.00019901
 -0.000860301
 -0.000860301
 -0.000231141
 3.31683e-05
 4.73833e-06
 3.31683e-05
 4.73833e-06
 0.000143383
 -1.48231e-20
 3.85235e-05
 -5.50335e-06
 3.85235e-05
 -5.50335e-06
 -1.89533e-05
 -2.20134e-05
 1.05032e-19
 0.000143383
 -0.000143383
 -1.69407e-21
 -4.73833e-06
 -2.36916e-06
 4.73833e-06
 2.36916e-06
 -1.48231e-20
 1.53625e-05
 -5.50335e-06
 2.75168e-06
 5.50335e-06
 -2.75168e-06
 7.94093e-21
 -1.01474e-21
 -0.000988978
 -0.000231141
 -0.000988978
 -0.000263348
 3.85235e-05
 -5.50335e-06
 0.00016483
 1.82112e-20
 4.38913e-05
 -6.27019e-06
 3.85235e-05
 5.50335e-06
 4.38913e-05
 -6.27019e-06
 -2.20134e-05
 -2.50808e-05
 0.00016483
 -1.25361e-19
 -0.00016483
 -3.38813e-21
 -5.50335e-06
 2.75168e-06
 1.82112e-20
 1.76603e-05
 -6.27019e-06
 3.1351e-06
 5.50335e-06
 2.75168e-06
 6.27019e-06
 -3.1351e-06
 -1.01644e-20
 -1.07536e-21
 -0.000970712
 -0.000222008
 -0.000263348
 -0.000970712
 3.70013e-05
 -5.2859e-06
 4.38913e-05
 -6.27019e-06
 0.000161785
 2.017e-20
 3.70013e-05
 5.2859e-06
 4.38913e-05
 6.27019e-06
 -2.11436e-05
 -2.50808e-05
 0.000161785
 -5.0822e-21
 -1.4569e-19
 -0.000161785
 -5.2859e-06
 2.64295e-06
 -6.27019e-06
 3.1351e-06
 2.017e-20
 1.73341e-05
 5.2859e-06
 2.64295e-06
 6.27019e-06
 3.1351e-06
 -9.85995e-22
 -1.14349e-20
 -0.000229738
 -0.000986208
 -0.000986208
 -0.000263367
 3.82896e-05
 5.46994e-06
 3.82896e-05
 5.46994e-06
 0.000164368
 -1.90582e-20
 4.38944e-05
 -6.27063e-06
 4.38944e-05
 -6.27063e-06
 -2.18798e-05
 -2.50825e-05
 1.15196e-19
 0.000164368
 -0.000164368
 -1.69407e-21
 -5.46994e-06
 -2.73497e-06
 5.46994e-06
 2.73497e-06
 -1.90582e-20
 1.76109e-05
 -6.27063e-06
 3.13532e-06
 6.27063e-06
 -3.13532e-06
 9.21148e-21
 -1.10515e-21
 -0.00028185
 -0.00109043
 -0.000263367
 -0.00109043
 4.69751e-05
 6.71072e-06
 4.69751e-05
 6.71072e-06
 4.38944e-05
 -6.27063e-06
 0.000181739
 4.04458e-20
 4.38944e-05
 6.27063e-06
 -2.68429e-05
 -2.50825e-05
 -1.42302e-19
 0.000181739
 -1.43996e-19
 -0.000181739
 -6.71072e-06
 -3.35536e-06
 6.71072e-06
 3.35536e-06
 -6.27063e-06
 3.13532e-06
 4.04458e-20
 1.9472e-05
 6.27063e-06
 3.13532e-06
 -1.07997e-20
 -1.13291e-20
 -0.000219307
 -0.000890679
 -0.000890679
 -0.000226033
 3.65511e-05
 5.22159e-06
 3.65511e-05
 5.22159e-06
 0.000148446
 3.42519e-20
 3.76721e-05
 -5.38173e-06
 3.76721e-05
 -5.38173e-06
 -2.08864e-05
 -2.15269e-05
 -1.15196e-19
 0.000148446
 -0.000148446
 -1.23667e-19
 -5.22159e-06
 -2.61079e-06
 5.22159e-06
 2.61079e-06
 3.42519e-20
 1.5905e-05
 -5.38173e-06
 2.69087e-06
 5.38173e-06
 -2.69087e-06
 -8.47033e-21
 -9.52912e-21
 -0.000230423
 -0.000912912
 -0.000226033
 -0.000912912
 3.84038e-05
 5.48626e-06
 3.84038e-05
 5.48626e-06
 3.76721e-05
 -5.38173e-06
 0.000152152
 -1.86347e-20
 3.76721e-05
 5.38173e-06
 -2.19451e-05
 -2.15269e-05
 1.18585e-19
 0.000152152
 -3.38813e-21
 -0.000152152
 -5.48626e-06
 -2.74313e-06
 5.48626e-06
 2.74313e-06
 -5.38173e-06
 2.69087e-06
 -1.86347e-20
 1.6302e-05
 5.38173e-06
 2.69087e-06
 8.89385e-21
 -1.15619e-21
 -0.000238057
 -0.000246497
 -0.000969108
 -0.000969108
 3.96761e-05
 5.66802e-06
 3.96761e-05
 5.66802e-06
 4.10829e-05
 5.86898e-06
 4.10829e-05
 5.86898e-06
 0.000161518
 -2.26721e-05
 -2.34759e-05
 -1.25361e-19
 1.21973e-19
 0.000161518
 -0.000161518
 -5.66802e-06
 -2.83401e-06
 5.66802e-06
 2.83401e-06
 -5.86898e-06
 -2.93449e-06
 5.86898e-06
 2.93449e-06
 1.73055e-05
 -9.635e-21
 9.52912e-21
 -0.00028596
 -0.00112232
 -0.00112232
 -0.000275202
 4.766e-05
 6.80857e-06
 4.766e-05
 6.80857e-06
 0.000187054
 4.16105e-20
 4.5867e-05
 -6.55242e-06
 4.5867e-05
 -6.55242e-06
 -2.72343e-05
 -2.62097e-05
 -1.49078e-19
 0.000187054
 -0.000187054
 -1.49078e-19
 -6.80857e-06
 -3.40429e-06
 6.80857e-06
 3.40429e-06
 4.16105e-20
 2.00415e-05
 -6.55242e-06
 3.27621e-06
 6.55242e-06
 -3.27621e-06
 -1.10114e-20
 -1.19643e-20
 -0.000235269
 -0.00102094
 -0.000275202
 -0.00102094
 3.92115e-05
 5.60165e-06
 3.92115e-05
 5.60165e-06
 4.5867e-05
 -6.55242e-06
 0.000170157
 -1.99053e-20
 4.5867e-05
 6.55242e-06
 -2.24066e-05
 -2.62097e-05
 1.18585e-19
 0.000170157
 -3.38813e-21
 -0.000170157
 -5.60165e-06
 -2.80082e-06
 5.60165e-06
 2.80082e-06
 -6.55242e-06
 3.27621e-06
 -1.99053e-20
 1.82311e-05
 6.55242e-06
 3.27621e-06
 8.99973e-21
 -1.47477e-21
 -0.000205972
 -0.000829615
 -0.000829615
 -0.000208835
 3.43287e-05
 4.90409e-06
 3.43287e-05
 4.90409e-06
 0.000138269
 3.26108e-20
 3.48059e-05
 -4.97227e-06
 3.48059e-05
 -4.97227e-06
 -1.96164e-05
 -1.98891e-05
 -1.0842e-19
 0.000138269
 -0.000138269
 -1.13502e-19
 -4.90409e-06
 -2.45205e-06
 4.90409e-06
 2.45205e-06
 3.26108e-20
 1.48146e-05
 -4.97227e-06
 2.48614e-06
 4.97227e-06
 -2.48614e-06
 -8.04681e-21
 -9.1056e-21
 -0.000204172
 -0.000826014
 -0.000208835
 -0.000826014
 3.40286e-05
 4.86123e-06
 3.40286e-05
 4.86123e-06
 3.48059e-05
 -4.97227e-06
 0.000137669
 -1.52466e-20
 3.48059e-05
 4.97227e-06
 -1.98891e-05
 -1.94449e-05
 1.05032e-19
 0.000137669
 -3.38813e-21
 -0.000137669
 -4.86123e-06
 -2.43062e-06
 4.86123e-06
 2.43062e-06
 -4.97227e-06
 2.48614e-06
 -1.52466e-20
 1.47503e-05
 4.97227e-06
 2.48614e-06
 -9.56159e-22
 8.04681e-21
 -0.00022519
 -0.000233884
 -0.000918148
 -0.000918148
 3.75317e-05
 5.36167e-06
 3.75317e-05
 5.36167e-06
 3.89807e-05
 5.56867e-06
 3.89807e-05
 5.56867e-06
 0.000153025
 -2.22747e-05
 -2.14467e-05
 -1.15196e-19
 1.18585e-19
 0.000153025
 -0.000153025
 -5.36167e-06
 -2.68083e-06
 5.36167e-06
 2.68083e-06
 -5.56867e-06
 -2.78433e-06
 5.56867e-06
 2.78433e-06
 1.63955e-05
 9.1056e-21
 -8.78797e-21
 -0.000278114
 -0.00110423
 -0.00110423
 -0.000274002
 4.63524e-05
 6.62177e-06
 4.63524e-05
 6.62177e-06
 0.000184039
 4.16105e-20
 4.5667e-05
 -6.52386e-06
 4.5667e-05
 -6.52386e-06
 -2.64871e-05
 -2.60954e-05
 -1.42302e-19
 0.000184039
 -0.000184039
 -1.49078e-19
 -6.62177e-06
 -3.31088e-06
 6.62177e-06
 3.31088e-06
 4.16105e-20
 1.97184e-05
 -6.52386e-06
 3.26193e-06
 6.52386e-06
 -3.26193e-06
 -1.07997e-20
 -1.18585e-20
 -0.000238983
 -0.00102597
 -0.000274002
 -0.00102597
 3.98304e-05
 5.69006e-06
 3.98304e-05
 5.69006e-06
 4.5667e-05
 -6.52386e-06
 0.000170995
 -1.90582e-20
 4.5667e-05
 6.52386e-06
 -2.27602e-05
 -2.60954e-05
 1.21973e-19
 0.000170995
 -8.47033e-21
 -0.000170995
 -5.69006e-06
 -2.84503e-06
 5.69006e-06
 2.84503e-06
 -6.52386e-06
 3.26193e-06
 -1.90582e-20
 1.83209e-05
 6.52386e-06
 3.26193e-06
 9.52912e-21
 -1.68169e-21
 -0.000231878
 -0.000932474
 -0.000932474
 -0.000234359
 3.86464e-05
 5.52091e-06
 3.86464e-05
 5.52091e-06
 0.000155412
 3.28225e-20
 3.90598e-05
 -5.57998e-06
 3.90598e-05
 -5.57998e-06
 -2.20836e-05
 -2.23199e-05
 -1.18585e-19
 0.000155412
 -0.000155412
 -1.27902e-19
 -5.52091e-06
 -2.76045e-06
 5.52091e-06
 2.76045e-06
 3.28225e-20
 1.66513e-05
 -5.57998e-06
 2.78999e-06
 5.57998e-06
 -2.78999e-06
 -9.1056e-21
 -1.00585e-20
 -0.00022877
 -0.000926258
 -0.000234359
 -0.000926258
 3.81284e-05
 5.44691e-06
 3.81284e-05
 5.44691e-06
 3.90598e-05
 -5.57998e-06
 0.000154376
 -1.77877e-20
 3.90598e-05
 5.57998e-06
 -2.23199e-05
 -2.17876e-05
 1.15196e-19
 0.000154376
 -6.77626e-21
 -0.000154376
 -5.44691e-06
 -2.72346e-06
 5.44691e-06
 2.72346e-06
 -5.57998e-06
 2.78999e-06
 -1.77877e-20
 1.65403e-05
 5.57998e-06
 2.78999e-06
 -1.0968e-21
 9.1056e-21
 -0.000231644
 -0.000237154
 -0.000937597
 -0.000937597
 3.86074e-05
 5.51534e-06
 3.86074e-05
 5.51534e-06
 3.95257e-05
 5.64652e-06
 3.95257e-05
 5.64652e-06
 0.000156266
 -1.69407e-21
 -2.20614e-05
 -2.25861e-05
 -1.15196e-19
 1.18585e-19
 0.000156266
 -0.000156266
 -5.51534e-06
 -2.75767e-06
 5.51534e-06
 2.75767e-06
 -5.64652e-06
 -2.82326e-06
 5.64652e-06
 2.82326e-06
 -1.69407e-21
 1.67428e-05
 -9.31736e-21
 9.635e-21
 -0.000218533
 -0.000945177
 -0.000945177
 -0.000254055
 3.64222e-05
 5.20317e-06
 3.64222e-05
 5.20317e-06
 0.000157529
 -1.60936e-20
 4.23426e-05
 -6.04894e-06
 4.23426e-05
 -6.04894e-06
 -2.08127e-05
 -2.41957e-05
 1.11808e-19
 0.000157529
 -0.000157529
 -8.47033e-21
 -5.20317e-06
 -2.60158e-06
 5.20317e-06
 2.60158e-06
 -1.60936e-20
 1.68782e-05
 -6.04894e-06
 3.02447e-06
 6.04894e-06
 -3.02447e-06
 8.47033e-21
 -1.15649e-21
 -0.0002764
 -0.00106091
 -0.000254055
 -0.00106091
 4.60667e-05
 6.58096e-06
 4.60667e-05
 6.58096e-06
 4.23426e-05
 -6.04894e-06
 0.000176819
 3.90165e-20
 4.23426e-05
 6.04894e-06
 -2.63238e-05
 -2.41957e-05
 -1.38913e-19
 0.000176819
 -1.38913e-19
 -0.000176819
 -6.58096e-06
 -3.29048e-06
 6.58096e-06
 3.29048e-06
 -6.04894e-06
 3.02447e-06
 3.90165e-20
 1.89448e-05
 6.04894e-06
 3.02447e-06
 -1.10114e-20
 -1.07997e-20
 -0.00020813
 -0.000846595
 -0.000846595
 -0.000215168
 3.46883e-05
 4.95547e-06
 3.46883e-05
 4.95547e-06
 0.000141099
 3.17108e-20
 3.58613e-05
 -5.12305e-06
 3.58613e-05
 -5.12305e-06
 -1.98219e-05
 -2.04922e-05
 -1.0842e-19
 0.000141099
 -0.000141099
 -1.16891e-19
 -4.95547e-06
 -2.47773e-06
 4.95547e-06
 2.47773e-06
 3.17108e-20
 1.51178e-05
 -5.12305e-06
 2.56152e-06
 5.12305e-06
 -2.56152e-06
 -8.25857e-21
 -9.42324e-21
 -0.000222008
 -0.000874352
 -0.000215168
 -0.000874352
 3.70013e-05
 5.2859e-06
 3.70013e-05
 5.2859e-06
 3.58613e-05
 -5.12305e-06
 0.000145725
 -1.73642e-20
 3.58613e-05
 5.12305e-06
 -2.11436e-05
 -2.04922e-05
 1.15196e-19
 0.000145725
 -3.38813e-21
 -0.000145725
 -5.2859e-06
 -2.64295e-06
 5.2859e-06
 2.64295e-06
 -5.12305e-06
 2.56152e-06
 -1.73642e-20
 1.56134e-05
 5.12305e-06
 2.56152e-06
 8.99973e-21
 -1.04859e-21
 -0.000239721
 -0.000231141
 -0.000941724
 -0.000941724
 3.99535e-05
 5.70765e-06
 3.99535e-05
 5.70765e-06
 3.85235e-05
 5.50335e-06
 3.85235e-05
 5.50335e-06
 0.000156954
 -1.69407e-21
 -2.28306e-05
 -2.20134e-05
 1.25361e-19
 -1.18585e-19
 0.000156954
 -0.000156954
 -5.70765e-06
 -2.85382e-06
 5.70765e-06
 2.85382e-06
 -5.50335e-06
 -2.75168e-06
 5.50335e-06
 2.75168e-06
 -1.69407e-21
 1.68165e-05
 9.1056e-21
 -9.1056e-21
 -0.00021506
 -0.000783772
 -0.000783772
 -0.000176827
 3.58433e-05
 5.12047e-06
 3.58433e-05
 5.12047e-06
 0.000130629
 3.02285e-20
 2.94711e-05
 -4.21016e-06
 2.94711e-05
 -4.21016e-06
 -2.04819e-05
 -1.68406e-05
 -1.11808e-19
 0.000130629
 -0.000130629
 -9.65618e-20
 -5.12047e-06
 -2.56023e-06
 5.12047e-06
 2.56023e-06
 3.02285e-20
 1.39959e-05
 -4.21016e-06
 2.10508e-06
 4.21016e-06
 -2.10508e-06
 -8.25857e-21
 -7.72918e-21
 -0.000215168
 -0.000870464
 -0.000870464
 -0.000220064
 3.58613e-05
 5.12305e-06
 3.58613e-05
 5.12305e-06
 0.000145077
 -1.69407e-20
 3.66774e-05
 -5.23962e-06
 3.66774e-05
 -5.23962e-06
 -2.04922e-05
 -2.09585e-05
 1.11808e-19
 0.000145077
 -0.000145077
 -6.77626e-21
 -5.12305e-06
 -2.56152e-06
 5.12305e-06
 2.56152e-06
 -1.69407e-20
 1.5544e-05
 -5.23962e-06
 2.61981e-06
 5.23962e-06
 -2.61981e-06
 8.78797e-21
 -1.01002e-21
 -0.000793118
 -0.000220064
 -0.000793118
 -0.000176495
 3.66774e-05
 -5.23962e-06
 0.000132186
 1.73112e-20
 2.94158e-05
 -4.20226e-06
 3.66774e-05
 5.23962e-06
 2.94158e-05
 -4.20226e-06
 -2.09585e-05
 -1.6809e-05
 0.000132186
 -1.20279e-19
 -0.000132186
 -5.0822e-21
 -5.23962e-06
 2.61981e-06
 1.73112e-20
 1.41628e-05
 -4.20226e-06
 2.10113e-06
 5.23962e-06
 2.61981e-06
 4.20226e-06
 -2.10113e-06
 -9.42324e-21
 -6.42452e-22
 -0.000706643
 -0.000176827
 -0.000176495
 -0.000706643
 2.94711e-05
 -4.21016e-06
 2.94158e-05
 -4.20226e-06
 0.000117774
 1.33937e-20
 2.94711e-05
 4.21016e-06
 2.94158e-05
 4.20226e-06
 -1.68406e-05
 -1.6809e-05
 0.000117774
 -3.38813e-21
 -9.74088e-20
 -0.000117774
 -4.21016e-06
 2.10508e-06
 -4.20226e-06
 2.10113e-06
 1.33937e-20
 1.26186e-05
 4.21016e-06
 2.10508e-06
 4.20226e-06
 2.10113e-06
 -8.72298e-22
 -7.51742e-21
 -0.00027155
 -0.00108551
 -0.00108551
 -0.000271206
 4.52583e-05
 6.46547e-06
 4.52583e-05
 6.46547e-06
 0.000180919
 3.87518e-20
 4.5201e-05
 -6.45729e-06
 4.5201e-05
 -6.45729e-06
 -2.58619e-05
 -2.58292e-05
 -1.38913e-19
 0.000180919
 -0.000180919
 -1.47384e-19
 -6.46547e-06
 -3.23274e-06
 6.46547e-06
 3.23274e-06
 3.87518e-20
 1.93841e-05
 -6.45729e-06
 3.22864e-06
 6.45729e-06
 -3.22864e-06
 -1.05879e-20
 -1.19643e-20
 -0.000275202
 -0.00109267
 -0.00109267
 -0.000271136
 4.5867e-05
 6.55242e-06
 4.5867e-05
 6.55242e-06
 0.000182112
 -1.99053e-20
 4.51893e-05
 -6.45561e-06
 4.51893e-05
 -6.45561e-06
 -2.62097e-05
 -2.58224e-05
 1.38913e-19
 0.000182112
 -0.000182112
 -6.77626e-21
 -6.55242e-06
 -3.27621e-06
 6.55242e-06
 3.27621e-06
 -1.99053e-20
 1.9512e-05
 -6.45561e-06
 3.2278e-06
 6.45561e-06
 -3.2278e-06
 1.07997e-20
 -1.27809e-21
 -0.00108468
 -0.000271206
 -0.000271136
 -0.00108468
 4.5201e-05
 -6.45729e-06
 4.51893e-05
 -6.45561e-06
 0.000180781
 2.02229e-20
 4.5201e-05
 6.45729e-06
 4.51893e-05
 6.45561e-06
 -2.58292e-05
 -2.58224e-05
 0.000180781
 -6.77626e-21
 -1.47384e-19
 -0.000180781
 -6.45729e-06
 3.22864e-06
 -6.45561e-06
 3.2278e-06
 2.02229e-20
 1.93693e-05
 6.45729e-06
 3.22864e-06
 6.45561e-06
 3.2278e-06
 -1.59915e-21
 -1.15408e-20
 -0.000236425
 -0.000937367
 -0.000937367
 -0.000232259
 3.94041e-05
 5.62916e-06
 3.94041e-05
 5.62916e-06
 0.000156228
 3.37225e-20
 3.87098e-05
 -5.52997e-06
 3.87098e-05
 -5.52997e-06
 -2.25166e-05
 -2.21199e-05
 -1.18585e-19
 0.000156228
 -0.000156228
 -1.26208e-19
 -5.62916e-06
 -2.81458e-06
 5.62916e-06
 2.81458e-06
 3.37225e-20
 1.67387e-05
 -5.52997e-06
 2.76498e-06
 5.52997e-06
 -2.76498e-06
 -9.31736e-21
 -9.84676e-21
 -0.000234359
 -0.000934689
 -0.000934689
 -0.000232986
 3.90598e-05
 5.57998e-06
 3.90598e-05
 5.57998e-06
 0.000155782
 -1.86347e-20
 3.88309e-05
 -5.54728e-06
 3.88309e-05
 -5.54728e-06
 -2.23199e-05
 -2.21891e-05
 1.21973e-19
 0.000155782
 -0.000155782
 -1.01644e-20
 -5.57998e-06
 -2.78999e-06
 5.57998e-06
 2.78999e-06
 -1.86347e-20
 1.66909e-05
 -5.54728e-06
 2.77364e-06
 5.54728e-06
 -2.77364e-06
 8.89385e-21
 -8.99897e-22
 -0.000900123
 -0.000232986
 -0.000900123
 -0.000217076
 3.88309e-05
 -5.54728e-06
 0.00015002
 1.75759e-20
 3.61793e-05
 -5.16847e-06
 3.88309e-05
 5.54728e-06
 3.61793e-05
 -5.16847e-06
 -2.21891e-05
 -2.06739e-05
 0.00015002
 -1.27055e-19
 -0.00015002
 -5.0822e-21
 -5.54728e-06
 2.77364e-06
 1.75759e-20
 1.60736e-05
 -5.16847e-06
 2.58423e-06
 5.54728e-06
 2.77364e-06
 5.16847e-06
 -2.58423e-06
 -1.00585e-20
 -9.27555e-22
 -0.000898668
 -0.000232259
 -0.000217076
 -0.000898668
 3.87098e-05
 -5.52997e-06
 3.61793e-05
 -5.16847e-06
 0.000149778
 1.69936e-20
 3.87098e-05
 5.52997e-06
 3.61793e-05
 5.16847e-06
 -2.21199e-05
 -2.06739e-05
 0.000149778
 -3.38813e-21
 -1.18585e-19
 -0.000149778
 -5.52997e-06
 2.76498e-06
 -5.16847e-06
 2.58423e-06
 1.69936e-20
 1.60477e-05
 5.52997e-06
 2.76498e-06
 5.16847e-06
 2.58423e-06
 -1.17434e-21
 -9.52912e-21
 -0.000217527
 -0.000866772
 -0.000866772
 -0.000215859
 3.62545e-05
 5.17922e-06
 3.62545e-05
 5.17922e-06
 0.000144462
 3.21343e-20
 3.59765e-05
 -5.1395e-06
 3.59765e-05
 -5.1395e-06
 -2.07169e-05
 -2.0558e-05
 -1.0842e-19
 0.000144462
 -0.000144462
 -1.18585e-19
 -5.17922e-06
 -2.58961e-06
 5.17922e-06
 2.58961e-06
 3.21343e-20
 1.54781e-05
 -5.1395e-06
 2.56975e-06
 5.1395e-06
 -2.56975e-06
 -8.57621e-21
 -9.31736e-21
 -0.000208835
 -0.000760572
 -0.000760572
 -0.00017145
 3.48059e-05
 4.97227e-06
 3.48059e-05
 4.97227e-06
 0.000126762
 -1.69407e-20
 2.85751e-05
 -4.08215e-06
 2.85751e-05
 -4.08215e-06
 -1.98891e-05
 -1.63286e-05
 1.11808e-19
 0.000126762
 -0.000126762
 -3.38813e-21
 -4.97227e-06
 -2.48614e-06
 4.97227e-06
 2.48614e-06
 -1.69407e-20
 1.35816e-05
 -4.08215e-06
 2.04108e-06
 4.08215e-06
 -2.04108e-06
 8.25857e-21
 -7.48248e-22
 -0.000682846
 -0.00017145
 -0.000682846
 -0.000169973
 2.85751e-05
 -4.08215e-06
 0.000113808
 1.33408e-20
 2.83288e-05
 -4.04697e-06
 2.85751e-05
 4.08215e-06
 2.83288e-05
 -4.04697e-06
 -1.63286e-05
 -1.61879e-05
 0.000113808
 -9.31736e-20
 -0.000113808
 -5.0822e-21
 -4.08215e-06
 2.04108e-06
 1.33408e-20
 1.21937e-05
 -4.04697e-06
 2.02349e-06
 4.08215e-06
 2.04108e-06
 4.04697e-06
 -2.02349e-06
 -7.30566e-21
 -7.50892e-22
 -0.000771664
 -0.000215859
 -0.000169973
 -0.000771664
 3.59765e-05
 -5.1395e-06
 2.83288e-05
 -4.04697e-06
 0.000128611
 1.29702e-20
 3.59765e-05
 5.1395e-06
 2.83288e-05
 4.04697e-06
 -2.0558e-05
 -1.61879e-05
 0.000128611
 -6.77626e-21
 -9.23266e-20
 -0.000128611
 -5.1395e-06
 2.56975e-06
 -4.04697e-06
 2.02349e-06
 1.29702e-20
 1.37797e-05
 5.1395e-06
 2.56975e-06
 4.04697e-06
 2.02349e-06
 -1.11554e-21
 -7.19978e-21
 -0.000274002
 -0.00104863
 -0.00104863
 -0.000250313
 4.5667e-05
 6.52386e-06
 4.5667e-05
 6.52386e-06
 0.000174772
 -2.11758e-20
 4.17188e-05
 -5.95983e-06
 4.17188e-05
 -5.95983e-06
 -2.60954e-05
 -2.38393e-05
 1.38913e-19
 0.000174772
 -0.000174772
 -1.01644e-20
 -6.52386e-06
 -3.26193e-06
 6.52386e-06
 3.26193e-06
 -2.11758e-20
 1.87255e-05
 -5.95983e-06
 2.97992e-06
 5.95983e-06
 -2.97992e-06
 1.07997e-20
 -1.03041e-21
 -0.000240863
 -0.000968183
 -0.000968183
 -0.000243229
 4.01438e-05
 5.73483e-06
 4.01438e-05
 5.73483e-06
 0.000161364
 3.47284e-20
 4.05381e-05
 -5.79116e-06
 4.05381e-05
 -5.79116e-06
 -2.29393e-05
 -2.31646e-05
 -1.21973e-19
 0.000161364
 -0.000161364
 -1.33831e-19
 -5.73483e-06
 -2.86741e-06
 5.73483e-06
 2.86741e-06
 3.47284e-20
 1.7289e-05
 -5.79116e-06
 2.89558e-06
 5.79116e-06
 -2.89558e-06
 -9.31736e-21
 -1.03762e-20
 -0.000987084
 -0.000250313
 -0.000243229
 -0.000987084
 4.17188e-05
 -5.95983e-06
 4.05381e-05
 -5.79116e-06
 0.000164514
 1.91641e-20
 4.17188e-05
 5.95983e-06
 4.05381e-05
 5.79116e-06
 -2.31646e-05
 -2.38393e-05
 0.000164514
 -1.36372e-19
 -6.77626e-21
 -0.000164514
 -5.95983e-06
 2.97992e-06
 -5.79116e-06
 2.89558e-06
 1.91641e-20
 1.76265e-05
 5.95983e-06
 2.97992e-06
 5.79116e-06
 2.89558e-06
 -1.32118e-21
 -1.0482e-20
 -0.000226033
 -0.000909008
 -0.000909008
 -0.000228471
 3.76721e-05
 5.38173e-06
 3.76721e-05
 5.38173e-06
 0.000151501
 -1.82112e-20
 3.80786e-05
 -5.43979e-06
 3.80786e-05
 -5.43979e-06
 -2.15269e-05
 -2.17592e-05
 1.21973e-19
 0.000151501
 -0.000151501
 -3.38813e-21
 -5.38173e-06
 -2.69087e-06
 5.38173e-06
 2.69087e-06
 -1.82112e-20
 1.62323e-05
 -5.43979e-06
 2.7199e-06
 5.43979e-06
 -2.7199e-06
 8.78797e-21
 -1.08483e-21
 -0.000225119
 -0.000834754
 -0.000834754
 -0.000192258
 3.75198e-05
 5.35997e-06
 3.75198e-05
 5.35997e-06
 0.000139126
 3.11814e-20
 3.20431e-05
 -4.57758e-06
 3.20431e-05
 -4.57758e-06
 -2.14399e-05
 -1.83103e-05
 -1.15196e-19
 0.000139126
 -0.000139126
 -1.05032e-19
 -5.35997e-06
 -2.67999e-06
 5.35997e-06
 2.67999e-06
 3.11814e-20
 1.49063e-05
 -4.57758e-06
 2.28879e-06
 4.57758e-06
 -2.28879e-06
 -8.47033e-21
 -8.25857e-21
 -0.000755477
 -0.000192258
 -0.000755477
 -0.00018548
 3.20431e-05
 -4.57758e-06
 0.000125913
 1.38172e-20
 3.09134e-05
 -4.41619e-06
 3.20431e-05
 4.57758e-06
 3.09134e-05
 -4.41619e-06
 -1.83103e-05
 -1.76648e-05
 0.000125913
 -3.38813e-21
 -0.000125913
 -1.00797e-19
 -4.57758e-06
 2.28879e-06
 1.38172e-20
 1.34907e-05
 -4.41619e-06
 2.2081e-06
 4.57758e-06
 2.28879e-06
 4.41619e-06
 -2.2081e-06
 -9.77634e-22
 -7.94093e-21
 -0.000827903
 -0.000228471
 -0.00018548
 -0.000827903
 3.80786e-05
 -5.43979e-06
 3.09134e-05
 -4.41619e-06
 0.000137984
 1.70465e-20
 3.80786e-05
 5.43979e-06
 3.09134e-05
 4.41619e-06
 -2.17592e-05
 -1.76648e-05
 0.000137984
 -1.24514e-19
 -6.77626e-21
 -0.000137984
 -5.43979e-06
 2.7199e-06
 -4.41619e-06
 2.2081e-06
 1.70465e-20
 1.4784e-05
 5.43979e-06
 2.7199e-06
 4.41619e-06
 2.2081e-06
 -9.74088e-21
 -9.80977e-22
 -0.000250313
 -0.000935759
 -0.000935759
 -0.000217566
 4.17188e-05
 5.95983e-06
 4.17188e-05
 5.95983e-06
 0.00015596
 3.66871e-20
 3.62611e-05
 -5.18015e-06
 3.62611e-05
 -5.18015e-06
 -2.38393e-05
 -2.07206e-05
 -1.25361e-19
 0.00015596
 -0.00015596
 -1.19432e-19
 -5.95983e-06
 -2.97992e-06
 5.95983e-06
 2.97992e-06
 3.66871e-20
 1.671e-05
 -5.18015e-06
 2.59008e-06
 5.18015e-06
 -2.59008e-06
 -9.74088e-21
 -9.52912e-21
 -0.000232259
 -0.00089965
 -0.000217566
 -0.00089965
 3.87098e-05
 5.52997e-06
 3.87098e-05
 5.52997e-06
 3.62611e-05
 -5.18015e-06
 0.000149942
 -1.73642e-20
 3.62611e-05
 5.18015e-06
 -2.21199e-05
 -2.07206e-05
 1.21973e-19
 0.000149942
 -3.38813e-21
 -0.000149942
 -5.52997e-06
 -2.76498e-06
 5.52997e-06
 2.76498e-06
 -5.18015e-06
 2.59008e-06
 -1.73642e-20
 1.60652e-05
 5.18015e-06
 2.59008e-06
 9.31736e-21
 -1.09938e-21
 -0.000271206
 -0.000998344
 -0.000998344
 -0.000227966
 4.5201e-05
 6.45729e-06
 4.5201e-05
 6.45729e-06
 0.000166391
 -2.20229e-20
 3.79943e-05
 -5.42776e-06
 3.79943e-05
 -5.42776e-06
 -2.58292e-05
 -2.1711e-05
 1.42302e-19
 0.000166391
 -0.000166391
 -6.77626e-21
 -6.45729e-06
 -3.22864e-06
 6.45729e-06
 3.22864e-06
 -2.20229e-20
 1.78276e-05
 -5.42776e-06
 2.71388e-06
 5.42776e-06
 -2.71388e-06
 1.07997e-20
 -8.39623e-22
 -0.000228471
 -0.000912874
 -0.000227966
 -0.000912874
 3.80786e-05
 5.43979e-06
 3.80786e-05
 5.43979e-06
 3.79943e-05
 -5.42776e-06
 0.000152146
 3.57871e-20
 3.79943e-05
 5.42776e-06
 -2.17592e-05
 -2.1711e-05
 -1.18585e-19
 0.000152146
 -1.24514e-19
 -0.000152146
 -5.43979e-06
 -2.7199e-06
 5.43979e-06
 2.7199e-06
 -5.42776e-06
 2.71388e-06
 3.57871e-20
 1.63013e-05
 5.42776e-06
 2.71388e-06
 -8.68209e-21
 -9.84676e-21
 -0.000254055
 -0.0010093
 -0.0010093
 -0.000250597
 4.23426e-05
 6.04894e-06
 4.23426e-05
 6.04894e-06
 0.000168217
 3.92282e-20
 4.17661e-05
 -5.96659e-06
 4.17661e-05
 -5.96659e-06
 -2.41957e-05
 -2.38664e-05
 -1.28749e-19
 0.000168217
 -0.000168217
 -1.37219e-19
 -6.04894e-06
 -3.02447e-06
 6.04894e-06
 3.02447e-06
 3.92282e-20
 1.80233e-05
 -5.96659e-06
 2.98329e-06
 5.96659e-06
 -2.98329e-06
 -9.84676e-21
 -1.11173e-20
 -0.000176827
 -0.000711186
 -0.000711186
 -0.000178767
 2.94711e-05
 4.21016e-06
 2.94711e-05
 4.21016e-06
 0.000118531
 -1.3129e-20
 2.97944e-05
 -4.25635e-06
 2.97944e-05
 -4.25635e-06
 -1.68406e-05
 -1.70254e-05
 9.14796e-20
 0.000118531
 -0.000118531
 -5.0822e-21
 -4.21016e-06
 -2.10508e-06
 4.21016e-06
 2.10508e-06
 -1.3129e-20
 1.26998e-05
 -4.25635e-06
 2.12817e-06
 4.25635e-06
 -2.12817e-06
 6.88214e-21
 -8.83364e-22
 -0.000858727
 -0.000250597
 -0.000178767
 -0.000858727
 4.17661e-05
 -5.96659e-06
 2.97944e-05
 -4.25635e-06
 0.000143121
 1.43466e-20
 4.17661e-05
 5.96659e-06
 2.97944e-05
 4.25635e-06
 -2.38664e-05
 -1.70254e-05
 0.000143121
 -1.01644e-20
 -9.82558e-20
 -0.000143121
 -5.96659e-06
 2.98329e-06
 -4.25635e-06
 2.12817e-06
 1.43466e-20
 1.53344e-05
 5.96659e-06
 2.98329e-06
 4.25635e-06
 2.12817e-06
 -1.25054e-21
 -7.51742e-21
 -0.000267245
 -0.00104126
 -0.00104126
 -0.000253384
 4.45408e-05
 6.36296e-06
 4.45408e-05
 6.36296e-06
 0.000173543
 4.00752e-20
 4.22306e-05
 -6.03294e-06
 4.22306e-05
 -6.03294e-06
 -2.54519e-05
 -2.41318e-05
 -1.38913e-19
 0.000173543
 -0.000173543
 -1.38913e-19
 -6.36296e-06
 -3.18148e-06
 6.36296e-06
 3.18148e-06
 4.00752e-20
 1.85939e-05
 -6.03294e-06
 3.01647e-06
 6.03294e-06
 -3.01647e-06
 -1.03762e-20
 -1.09055e-20
 -0.000250597
 -0.00100796
 -0.000253384
 -0.00100796
 4.17661e-05
 5.96659e-06
 4.17661e-05
 5.96659e-06
 4.22306e-05
 -6.03294e-06
 0.000167993
 -2.28699e-20
 4.22306e-05
 6.03294e-06
 -2.38664e-05
 -2.41318e-05
 1.28749e-19
 0.000167993
 -5.0822e-21
 -0.000167993
 -5.96659e-06
 -2.98329e-06
 5.96659e-06
 2.98329e-06
 -6.03294e-06
 3.01647e-06
 -2.28699e-20
 1.79993e-05
 6.03294e-06
 3.01647e-06
 1.02703e-20
 -1.35543e-21
 -0.000263367
 -0.001051
 -0.001051
 -0.000262131
 4.38944e-05
 6.27063e-06
 4.38944e-05
 6.27063e-06
 0.000175166
 4.04988e-20
 4.36886e-05
 -6.24122e-06
 4.36886e-05
 -6.24122e-06
 -2.50825e-05
 -2.49649e-05
 -1.35525e-19
 0.000175166
 -0.000175166
 -1.43996e-19
 -6.27063e-06
 -3.13532e-06
 6.27063e-06
 3.13532e-06
 4.04988e-20
 1.87678e-05
 -6.24122e-06
 3.12061e-06
 6.24122e-06
 -3.12061e-06
 -1.01644e-20
 -1.13291e-20
 -0.000192258
 -0.00076639
 -0.00076639
 -0.000190936
 3.20431e-05
 4.57758e-06
 3.20431e-05
 4.57758e-06
 0.000127732
 -1.60936e-20
 3.18227e-05
 -4.5461e-06
 3.18227e-05
 -4.5461e-06
 -1.83103e-05
 -1.81844e-05
 9.82558e-20
 0.000127732
 -0.000127732
 -5.0822e-21
 -4.57758e-06
 -2.28879e-06
 4.57758e-06
 2.28879e-06
 -1.60936e-20
 1.36855e-05
 -4.5461e-06
 2.27305e-06
 4.5461e-06
 -2.27305e-06
 7.72918e-21
 -9.55124e-22
 -0.000906135
 -0.000262131
 -0.000190936
 -0.000906135
 4.36886e-05
 -6.24122e-06
 3.18227e-05
 -4.5461e-06
 0.000151023
 1.58819e-20
 4.36886e-05
 6.24122e-06
 3.18227e-05
 4.5461e-06
 -2.49649e-05
 -1.81844e-05
 0.000151023
 -5.0822e-21
 -1.04185e-19
 -0.000151023
 -6.24122e-06
 3.12061e-06
 -4.5461e-06
 2.27305e-06
 1.58819e-20
 1.6181e-05
 6.24122e-06
 3.12061e-06
 4.5461e-06
 2.27305e-06
 -1.39356e-21
 -8.04681e-21
 -0.000263348
 -0.00104527
 -0.00104527
 -0.000259286
 4.38913e-05
 6.27019e-06
 4.38913e-05
 6.27019e-06
 0.000174211
 3.91223e-20
 4.32143e-05
 -6.17347e-06
 4.32143e-05
 -6.17347e-06
 -2.50808e-05
 -2.46939e-05
 -1.32137e-19
 0.000174211
 -0.000174211
 -1.43996e-19
 -6.27019e-06
 -3.1351e-06
 6.27019e-06
 3.1351e-06
 3.91223e-20
 1.86655e-05
 -6.17347e-06
 3.08674e-06
 6.17347e-06
 -3.08674e-06
 -1.05879e-20
 -1.12232e-20
 -0.000262131
 -0.00104283
 -0.000259286
 -0.00104283
 4.36886e-05
 6.24122e-06
 4.36886e-05
 6.24122e-06
 4.32143e-05
 -6.17347e-06
 0.000173806
 -1.99053e-20
 4.32143e-05
 6.17347e-06
 -2.46939e-05
 -2.49649e-05
 1.32137e-19
 0.000173806
 -6.77626e-21
 -0.000173806
 -6.24122e-06
 -3.12061e-06
 6.24122e-06
 3.12061e-06
 -6.17347e-06
 3.08674e-06
 -1.99053e-20
 1.8622e-05
 6.17347e-06
 3.08674e-06
 -1.17421e-21
 1.02703e-20
 -0.000271136
 -0.000982786
 -0.000982786
 -0.000220257
 4.51893e-05
 6.45561e-06
 4.51893e-05
 6.45561e-06
 0.000163798
 3.5893e-20
 3.67095e-05
 -5.24422e-06
 3.67095e-05
 -5.24422e-06
 -2.58224e-05
 -2.09769e-05
 -1.38913e-19
 0.000163798
 -0.000163798
 -1.21126e-19
 -6.45561e-06
 -3.2278e-06
 6.45561e-06
 3.2278e-06
 3.5893e-20
 1.75497e-05
 -5.24422e-06
 2.62211e-06
 5.24422e-06
 -2.62211e-06
 -1.05879e-20
 -9.74088e-21
 -0.000215859
 -0.000872232
 -0.000220257
 -0.000872232
 3.59765e-05
 5.1395e-06
 3.59765e-05
 5.1395e-06
 3.67095e-05
 -5.24422e-06
 0.000145372
 -1.56701e-20
 3.67095e-05
 5.24422e-06
 -2.0558e-05
 -2.09769e-05
 1.11808e-19
 0.000145372
 -6.77626e-21
 -0.000145372
 -5.1395e-06
 -2.56975e-06
 5.1395e-06
 2.56975e-06
 -5.24422e-06
 2.62211e-06
 -1.56701e-20
 1.55756e-05
 5.24422e-06
 2.62211e-06
 8.57621e-21
 -1.18203e-21
 -0.00017145
 -0.000688372
 -0.000688372
 -0.000172736
 2.85751e-05
 4.08215e-06
 2.85751e-05
 4.08215e-06
 0.000114729
 2.69992e-20
 2.87893e-05
 -4.11275e-06
 2.87893e-05
 -4.11275e-06
 -1.63286e-05
 -1.6451e-05
 -8.47033e-20
 0.000114729
 -0.000114729
 -9.40207e-20
 -4.08215e-06
 -2.04108e-06
 4.08215e-06
 2.04108e-06
 2.69992e-20
 1.22924e-05
 -4.11275e-06
 2.05638e-06
 4.11275e-06
 -2.05638e-06
 -6.77626e-21
 -7.30566e-21
 -0.000243229
 -0.000831929
 -0.000172736
 -0.000831929
 4.05381e-05
 5.79116e-06
 4.05381e-05
 5.79116e-06
 2.87893e-05
 -4.11275e-06
 0.000138655
 -1.99053e-20
 2.87893e-05
 4.11275e-06
 -2.31646e-05
 -1.6451e-05
 1.18585e-19
 0.000138655
 -5.0822e-21
 -0.000138655
 -5.79116e-06
 -2.89558e-06
 5.79116e-06
 2.89558e-06
 -4.11275e-06
 2.05638e-06
 -1.99053e-20
 1.48559e-05
 4.11275e-06
 2.05638e-06
 9.95264e-21
 -9.59613e-22
 -0.000232986
 -0.000904078
 -0.000904078
 -0.000219053
 3.88309e-05
 5.54728e-06
 3.88309e-05
 5.54728e-06
 0.00015068
 3.34049e-20
 3.65089e-05
 -5.21555e-06
 3.65089e-05
 -5.21555e-06
 -2.21891e-05
 -2.08622e-05
 -1.18585e-19
 0.00015068
 -0.00015068
 -1.20279e-19
 -5.54728e-06
 -2.77364e-06
 5.54728e-06
 2.77364e-06
 3.34049e-20
 1.61442e-05
 -5.21555e-06
 2.60778e-06
 5.21555e-06
 -2.60778e-06
 -8.89385e-21
 -9.42324e-21
 -0.000253384
 -0.000944874
 -0.000219053
 -0.000944874
 4.22306e-05
 6.03294e-06
 4.22306e-05
 6.03294e-06
 3.65089e-05
 -5.21555e-06
 0.000157479
 -1.77877e-20
 3.65089e-05
 5.21555e-06
 -2.41318e-05
 -2.08622e-05
 1.28749e-19
 0.000157479
 -6.77626e-21
 -0.000157479
 -6.03294e-06
 -3.01647e-06
 6.03294e-06
 3.01647e-06
 -5.21555e-06
 2.60778e-06
 -1.77877e-20
 1.68727e-05
 5.21555e-06
 2.60778e-06
 9.74088e-21
 -1.20145e-21
 -0.000220064
 -0.000875208
 -0.000875208
 -0.00021754
 3.66774e-05
 5.23962e-06
 3.66774e-05
 5.23962e-06
 0.000145868
 3.30872e-20
 3.62567e-05
 -5.17952e-06
 3.62567e-05
 -5.17952e-06
 -2.09585e-05
 -2.07181e-05
 -1.11808e-19
 0.000145868
 -0.000145868
 -1.18585e-19
 -5.23962e-06
 -2.61981e-06
 5.23962e-06
 2.61981e-06
 3.30872e-20
 1.56287e-05
 -5.17952e-06
 2.58976e-06
 5.17952e-06
 -2.58976e-06
 -8.68209e-21
 -9.52912e-21
 -0.000259286
 -0.000953652
 -0.00021754
 -0.000953652
 4.32143e-05
 6.17347e-06
 4.32143e-05
 6.17347e-06
 3.62567e-05
 -5.17952e-06
 0.000158942
 -2.07523e-20
 3.62567e-05
 5.17952e-06
 -2.46939e-05
 -2.07181e-05
 1.32137e-19
 0.000158942
 -3.38813e-21
 -0.000158942
 -6.17347e-06
 -3.08674e-06
 6.17347e-06
 3.08674e-06
 -5.17952e-06
 2.58976e-06
 -2.07523e-20
 1.70295e-05
 5.17952e-06
 2.58976e-06
 1.06938e-20
 -1.07255e-21
 -0.000176495
 -0.000706269
 -0.000706269
 -0.00017664
 2.94158e-05
 4.20226e-06
 2.94158e-05
 4.20226e-06
 0.000117712
 2.65227e-20
 2.944e-05
 -4.20571e-06
 2.944e-05
 -4.20571e-06
 -1.6809e-05
 -1.68229e-05
 -9.14796e-20
 0.000117712
 -0.000117712
 -9.57147e-20
 -4.20226e-06
 -2.10113e-06
 4.20226e-06
 2.10113e-06
 2.65227e-20
 1.2612e-05
 -4.20571e-06
 2.10286e-06
 4.20571e-06
 -2.10286e-06
 -6.98802e-21
 -7.72918e-21
 -0.00021754
 -0.000926592
 -0.000926592
 -0.000245756
 3.62567e-05
 5.17952e-06
 3.62567e-05
 5.17952e-06
 0.000154432
 -1.73642e-20
 4.09593e-05
 -5.85133e-06
 4.09593e-05
 -5.85133e-06
 -2.07181e-05
 -2.34053e-05
 1.0842e-19
 0.000154432
 -0.000154432
 -6.77626e-21
 -5.17952e-06
 -2.58976e-06
 5.17952e-06
 2.58976e-06
 -1.73642e-20
 1.65463e-05
 -5.85133e-06
 2.92566e-06
 5.85133e-06
 -2.92566e-06
 8.47033e-21
 -1.0622e-21
 -0.000842304
 -0.00017664
 -0.000842304
 -0.000244512
 2.944e-05
 -4.20571e-06
 0.000140384
 1.8423e-20
 4.0752e-05
 -5.82172e-06
 2.944e-05
 4.20571e-06
 4.0752e-05
 -5.82172e-06
 -1.68229e-05
 -2.32869e-05
 0.000140384
 -5.0822e-21
 -0.000140384
 -1.32984e-19
 -4.20571e-06
 2.10286e-06
 1.8423e-20
 1.50411e-05
 -5.82172e-06
 2.91086e-06
 4.20571e-06
 2.10286e-06
 5.82172e-06
 -2.91086e-06
 -8.6112e-22
 -1.09055e-20
 -0.000980536
 -0.000245756
 -0.000244512
 -0.000980536
 4.09593e-05
 -5.85133e-06
 4.0752e-05
 -5.82172e-06
 0.000163423
 1.87406e-20
 4.09593e-05
 5.85133e-06
 4.0752e-05
 5.82172e-06
 -2.34053e-05
 -2.32869e-05
 0.000163423
 -1.33831e-19
 -3.38813e-21
 -0.000163423
 -5.85133e-06
 2.92566e-06
 -5.82172e-06
 2.91086e-06
 1.87406e-20
 1.75096e-05
 5.85133e-06
 2.92566e-06
 5.82172e-06
 2.91086e-06
 -1.01644e-20
 -1.14236e-21
 -0.000219053
 -0.000878763
 -0.000878763
 -0.000220328
 3.65089e-05
 5.21555e-06
 3.65089e-05
 5.21555e-06
 0.00014646
 -1.94818e-20
 3.67214e-05
 -5.24591e-06
 3.67214e-05
 -5.24591e-06
 -2.08622e-05
 -2.09836e-05
 1.11808e-19
 0.00014646
 -0.00014646
 -5.0822e-21
 -5.21555e-06
 -2.60778e-06
 5.21555e-06
 2.60778e-06
 -1.94818e-20
 1.56922e-05
 -5.24591e-06
 2.62295e-06
 5.24591e-06
 -2.62295e-06
 8.78797e-21
 -9.09796e-22
 -0.000217076
 -0.000883491
 -0.000883491
 -0.00022467
 3.61793e-05
 5.16847e-06
 3.61793e-05
 5.16847e-06
 0.000147248
 3.37754e-20
 3.74449e-05
 -5.34928e-06
 3.74449e-05
 -5.34928e-06
 -2.06739e-05
 -2.13971e-05
 -1.15196e-19
 0.000147248
 -0.000147248
 -1.2282e-19
 -5.16847e-06
 -2.58423e-06
 5.16847e-06
 2.58423e-06
 3.37754e-20
 1.57766e-05
 -5.34928e-06
 2.67464e-06
 5.34928e-06
 -2.67464e-06
 -8.57621e-21
 -9.74088e-21
 -0.000862345
 -0.000220328
 -0.000862345
 -0.000210845
 3.67214e-05
 -5.24591e-06
 0.000143724
 1.61995e-20
 3.51408e-05
 -5.02011e-06
 3.67214e-05
 5.24591e-06
 3.51408e-05
 -5.02011e-06
 -2.09836e-05
 -2.00804e-05
 0.000143724
 -1.20279e-19
 -0.000143724
 -6.77626e-21
 -5.24591e-06
 2.62295e-06
 1.61995e-20
 1.5399e-05
 -5.02011e-06
 2.51005e-06
 5.24591e-06
 2.62295e-06
 5.02011e-06
 -2.51005e-06
 -9.31736e-21
 -7.87299e-22
 -0.000871029
 -0.00022467
 -0.000210845
 -0.000871029
 3.74449e-05
 -5.34928e-06
 3.51408e-05
 -5.02011e-06
 0.000145171
 1.72583e-20
 3.74449e-05
 5.34928e-06
 3.51408e-05
 5.02011e-06
 -2.00804e-05
 -2.13971e-05
 0.000145171
 -5.0822e-21
 -1.13502e-19
 -0.000145171
 -5.34928e-06
 2.67464e-06
 -5.02011e-06
 2.51005e-06
 1.72583e-20
 1.55541e-05
 5.34928e-06
 2.67464e-06
 5.02011e-06
 2.51005e-06
 -8.89385e-21
 -1.02269e-21
 -0.000227966
 -0.000908612
 -0.000908612
 -0.00022634
 3.79943e-05
 5.42776e-06
 3.79943e-05
 5.42776e-06
 0.000151435
 3.43578e-20
 3.77234e-05
 -5.38906e-06
 3.77234e-05
 -5.38906e-06
 -2.1711e-05
 -2.15562e-05
 -1.18585e-19
 0.000151435
 -0.000151435
 -1.23667e-19
 -5.42776e-06
 -2.71388e-06
 5.42776e-06
 2.71388e-06
 3.43578e-20
 1.62252e-05
 -5.38906e-06
 2.69453e-06
 5.38906e-06
 -2.69453e-06
 -8.89385e-21
 -9.74088e-21
 -0.000220257
 -0.000881463
 -0.000881463
 -0.000220474
 3.67095e-05
 5.24422e-06
 3.67095e-05
 5.24422e-06
 0.00014691
 -1.69407e-20
 3.67457e-05
 -5.24938e-06
 3.67457e-05
 -5.24938e-06
 -2.09769e-05
 -2.09975e-05
 1.11808e-19
 0.00014691
 -0.00014691
 -5.0822e-21
 -5.24422e-06
 -2.62211e-06
 5.24422e-06
 2.62211e-06
 -1.69407e-20
 1.57404e-05
 -5.24938e-06
 2.62469e-06
 5.24938e-06
 -2.62469e-06
 8.89385e-21
 -1.06453e-21
 -0.000893629
 -0.00022634
 -0.000220474
 -0.000893629
 3.77234e-05
 -5.38906e-06
 3.67457e-05
 -5.24938e-06
 0.000148938
 1.56701e-20
 3.77234e-05
 5.38906e-06
 3.67457e-05
 5.24938e-06
 -2.15562e-05
 -2.09975e-05
 0.000148938
 -6.77626e-21
 -1.20279e-19
 -0.000148938
 -5.38906e-06
 2.69453e-06
 -5.24938e-06
 2.62469e-06
 1.56701e-20
 1.59577e-05
 5.38906e-06
 2.69453e-06
 5.24938e-06
 2.62469e-06
 -1.05437e-21
 -9.42324e-21
 -0.000178767
 -0.000716248
 -0.000716248
 -0.000179357
 2.97944e-05
 4.25635e-06
 2.97944e-05
 4.25635e-06
 0.000119375
 2.69462e-20
 2.98929e-05
 -4.27041e-06
 2.98929e-05
 -4.27041e-06
 -1.70254e-05
 -1.70817e-05
 -9.48677e-20
 0.000119375
 -0.000119375
 -9.74088e-20
 -4.25635e-06
 -2.12817e-06
 4.25635e-06
 2.12817e-06
 2.69462e-20
 1.27901e-05
 -4.27041e-06
 2.13521e-06
 4.27041e-06
 -2.13521e-06
 -6.98802e-21
 -7.72918e-21
 -0.00017664
 -0.000711995
 -0.000179357
 -0.000711995
 2.944e-05
 4.20571e-06
 2.944e-05
 4.20571e-06
 2.98929e-05
 -4.27041e-06
 0.000118666
 -1.43996e-20
 2.98929e-05
 4.27041e-06
 -1.70817e-05
 -1.68229e-05
 9.14796e-20
 0.000118666
 -5.0822e-21
 -0.000118666
 -4.20571e-06
 -2.10286e-06
 4.20571e-06
 2.10286e-06
 -4.27041e-06
 2.13521e-06
 -1.43996e-20
 1.27142e-05
 4.27041e-06
 2.13521e-06
 -1.02421e-21
 6.98802e-21
 -0.000172736
 -0.000688336
 -0.000688336
 -0.000171432
 2.87893e-05
 4.11275e-06
 2.87893e-05
 4.11275e-06
 0.000114723
 -1.35525e-20
 2.8572e-05
 -4.08172e-06
 2.8572e-05
 -4.08172e-06
 -1.6451e-05
 -1.63269e-05
 8.80914e-20
 0.000114723
 -0.000114723
 -5.0822e-21
 -4.11275e-06
 -2.05638e-06
 4.11275e-06
 2.05638e-06
 -1.35525e-20
 1.22917e-05
 -4.08172e-06
 2.04086e-06
 4.08172e-06
 -2.04086e-06
 6.67038e-21
 -7.10701e-22
 -0.000169973
 -0.000679822
 -0.000679822
 -0.000169938
 2.83288e-05
 4.04697e-06
 2.83288e-05
 4.04697e-06
 0.000113304
 2.5358e-20
 2.83231e-05
 -4.04615e-06
 2.83231e-05
 -4.04615e-06
 -1.61879e-05
 -1.61846e-05
 -8.80914e-20
 0.000113304
 -0.000113304
 -9.23266e-20
 -4.04697e-06
 -2.02349e-06
 4.04697e-06
 2.02349e-06
 2.5358e-20
 1.21397e-05
 -4.04615e-06
 2.02308e-06
 4.04615e-06
 -2.02308e-06
 -6.56451e-21
 -7.41154e-21
 -0.000682741
 -0.000171432
 -0.000169938
 -0.000682741
 2.8572e-05
 -4.08172e-06
 2.83231e-05
 -4.04615e-06
 0.00011379
 1.34466e-20
 2.8572e-05
 4.08172e-06
 2.83231e-05
 4.04615e-06
 -1.63269e-05
 -1.61846e-05
 0.00011379
 -9.31736e-20
 -5.0822e-21
 -0.00011379
 -4.08172e-06
 2.04086e-06
 -4.04615e-06
 2.02308e-06
 1.34466e-20
 1.21918e-05
 4.08172e-06
 2.04086e-06
 4.04615e-06
 2.02308e-06
 -7.30566e-21
 -7.95905e-22
 -0.000217566
 -0.000859447
 -0.000859447
 -0.000212157
 3.62611e-05
 5.18015e-06
 3.62611e-05
 5.18015e-06
 0.000143241
 -1.86347e-20
 3.53595e-05
 -5.05136e-06
 3.53595e-05
 -5.05136e-06
 -2.07206e-05
 -2.02054e-05
 1.15196e-19
 0.000143241
 -0.000143241
 -8.47033e-21
 -5.18015e-06
 -2.59008e-06
 5.18015e-06
 2.59008e-06
 -1.86347e-20
 1.53473e-05
 -5.05136e-06
 2.52568e-06
 5.05136e-06
 -2.52568e-06
 8.25857e-21
 -9.7042e-22
 -0.000171432
 -0.000767179
 -0.000212157
 -0.000767179
 2.8572e-05
 4.08172e-06
 2.8572e-05
 4.08172e-06
 3.53595e-05
 -5.05136e-06
 0.000127863
 2.87991e-20
 3.53595e-05
 5.05136e-06
 -1.63269e-05
 -2.02054e-05
 -8.80914e-20
 0.000127863
 -1.14349e-19
 -0.000127863
 -4.08172e-06
 -2.04086e-06
 4.08172e-06
 2.04086e-06
 -5.05136e-06
 2.52568e-06
 2.87991e-20
 1.36996e-05
 5.05136e-06
 2.52568e-06
 -6.35275e-21
 -9.31736e-21
 -0.00018548
 -0.00079569
 -0.00079569
 -0.000212365
 3.09134e-05
 4.41619e-06
 3.09134e-05
 4.41619e-06
 0.000132615
 -1.52466e-20
 3.53941e-05
 -5.0563e-06
 3.53941e-05
 -5.0563e-06
 -1.76648e-05
 -2.02252e-05
 9.48677e-20
 0.000132615
 -0.000132615
 -6.77626e-21
 -4.41619e-06
 -2.2081e-06
 4.41619e-06
 2.2081e-06
 -1.52466e-20
 1.42087e-05
 -5.0563e-06
 2.52815e-06
 5.0563e-06
 -2.52815e-06
 7.19978e-21
 -9.73181e-22
 -0.000190936
 -0.000814086
 -0.000814086
 -0.000216107
 3.18227e-05
 4.5461e-06
 3.18227e-05
 4.5461e-06
 0.000135681
 3.20284e-20
 3.60178e-05
 -5.1454e-06
 3.60178e-05
 -5.1454e-06
 -1.81844e-05
 -2.05816e-05
 -9.82558e-20
 0.000135681
 -0.000135681
 -1.17738e-19
 -4.5461e-06
 -2.27305e-06
 4.5461e-06
 2.27305e-06
 3.20284e-20
 1.45372e-05
 -5.1454e-06
 2.5727e-06
 5.1454e-06
 -2.5727e-06
 -7.30566e-21
 -9.42324e-21
 -0.000856943
 -0.000212365
 -0.000216107
 -0.000856943
 3.53941e-05
 -5.0563e-06
 3.60178e-05
 -5.1454e-06
 0.000142824
 1.59348e-20
 3.53941e-05
 5.0563e-06
 3.60178e-05
 5.1454e-06
 -2.05816e-05
 -2.02252e-05
 0.000142824
 -1.16044e-19
 -8.47033e-21
 -0.000142824
 -5.0563e-06
 2.52815e-06
 -5.1454e-06
 2.5727e-06
 1.59348e-20
 1.53025e-05
 5.0563e-06
 2.52815e-06
 5.1454e-06
 2.5727e-06
 -1.27997e-21
 -9.1056e-21
 -0.000212365
 -0.000916281
 -0.000916281
 -0.000245776
 3.53941e-05
 5.0563e-06
 3.53941e-05
 5.0563e-06
 0.000152714
 3.47813e-20
 4.09627e-05
 -5.85181e-06
 4.09627e-05
 -5.85181e-06
 -2.02252e-05
 -2.34072e-05
 -1.0842e-19
 0.000152714
 -0.000152714
 -1.34678e-19
 -5.0563e-06
 -2.52815e-06
 5.0563e-06
 2.52815e-06
 3.47813e-20
 1.63622e-05
 -5.85181e-06
 2.9259e-06
 5.85181e-06
 -2.9259e-06
 -8.25857e-21
 -1.05879e-20
 -0.00022634
 -0.000944233
 -0.000245776
 -0.000944233
 3.77234e-05
 5.38906e-06
 3.77234e-05
 5.38906e-06
 4.09627e-05
 -5.85181e-06
 0.000157372
 -1.69407e-20
 4.09627e-05
 5.85181e-06
 -2.15562e-05
 -2.34072e-05
 1.15196e-19
 0.000157372
 -5.0822e-21
 -0.000157372
 -5.38906e-06
 -2.69453e-06
 5.38906e-06
 2.69453e-06
 -5.85181e-06
 2.9259e-06
 -1.69407e-20
 1.68613e-05
 5.85181e-06
 2.9259e-06
 9.1056e-21
 -1.1763e-21
 -0.000220328
 -0.000179357
 -0.000799371
 -0.000799371
 3.67214e-05
 5.24591e-06
 3.67214e-05
 5.24591e-06
 2.98929e-05
 4.27041e-06
 2.98929e-05
 4.27041e-06
 0.000133229
 1.69407e-21
 -2.09836e-05
 -1.70817e-05
 -1.11808e-19
 9.14796e-20
 0.000133229
 -0.000133229
 -5.24591e-06
 -2.62295e-06
 5.24591e-06
 2.62295e-06
 -4.27041e-06
 -2.13521e-06
 4.27041e-06
 2.13521e-06
 1.69407e-21
 1.42745e-05
 -8.68209e-21
 6.98802e-21
 -0.000169938
 -0.000762086
 -0.000762086
 -0.000211105
 2.83231e-05
 4.04615e-06
 2.83231e-05
 4.04615e-06
 0.000127014
 -1.3129e-20
 3.51841e-05
 -5.0263e-06
 3.51841e-05
 -5.0263e-06
 -1.61846e-05
 -2.01052e-05
 8.80914e-20
 0.000127014
 -0.000127014
 -5.0822e-21
 -4.04615e-06
 -2.02308e-06
 4.04615e-06
 2.02308e-06
 -1.3129e-20
 1.36087e-05
 -5.0263e-06
 2.51315e-06
 5.0263e-06
 -2.51315e-06
 6.98802e-21
 -8.72046e-22
 -0.000220474
 -0.000863158
 -0.000211105
 -0.000863158
 3.67457e-05
 5.24938e-06
 3.67457e-05
 5.24938e-06
 3.51841e-05
 -5.0263e-06
 0.00014386
 3.1499e-20
 3.51841e-05
 5.0263e-06
 -2.09975e-05
 -2.01052e-05
 -1.15196e-19
 0.00014386
 -1.14349e-19
 -0.00014386
 -5.24938e-06
 -2.62469e-06
 5.24938e-06
 2.62469e-06
 -5.0263e-06
 2.51315e-06
 3.1499e-20
 1.54135e-05
 5.0263e-06
 2.51315e-06
 -8.78797e-21
 -9.21148e-21
 -0.000245756
 -0.000216107
 -0.000923725
 -0.000923725
 4.09593e-05
 5.85133e-06
 4.09593e-05
 5.85133e-06
 3.60178e-05
 5.1454e-06
 3.60178e-05
 5.1454e-06
 0.000153954
 -2.34053e-05
 -2.05816e-05
 -1.25361e-19
 1.0842e-19
 0.000153954
 -0.000153954
 -5.85133e-06
 -2.92566e-06
 5.85133e-06
 2.92566e-06
 -5.1454e-06
 -2.5727e-06
 5.1454e-06
 2.5727e-06
 1.64951e-05
 -9.31736e-21
 8.47033e-21
 -0.000212157
 -0.000835464
 -0.000835464
 -0.000205575
 3.53595e-05
 5.05136e-06
 3.53595e-05
 5.05136e-06
 0.000139244
 3.19755e-20
 3.42625e-05
 -4.89465e-06
 3.42625e-05
 -4.89465e-06
 -2.02054e-05
 -1.95786e-05
 -1.05032e-19
 0.000139244
 -0.000139244
 -1.13502e-19
 -5.05136e-06
 -2.52568e-06
 5.05136e-06
 2.52568e-06
 3.19755e-20
 1.4919e-05
 -4.89465e-06
 2.44732e-06
 4.89465e-06
 -2.44732e-06
 -8.36445e-21
 -8.89385e-21
 -0.00022467
 -0.00086049
 -0.000205575
 -0.00086049
 3.74449e-05
 5.34928e-06
 3.74449e-05
 5.34928e-06
 3.42625e-05
 -4.89465e-06
 0.000143415
 -1.69407e-20
 3.42625e-05
 4.89465e-06
 -2.13971e-05
 -1.95786e-05
 1.15196e-19
 0.000143415
 -6.77626e-21
 -0.000143415
 -5.34928e-06
 -2.67464e-06
 5.34928e-06
 2.67464e-06
 -4.89465e-06
 2.44732e-06
 -1.69407e-20
 1.53659e-05
 4.89465e-06
 2.44732e-06
 8.89385e-21
 -1.04085e-21
 -0.000244512
 -0.000960675
 -0.000960675
 -0.000235825
 4.0752e-05
 5.82172e-06
 4.0752e-05
 5.82172e-06
 0.000160112
 -1.86347e-20
 3.93042e-05
 -5.61489e-06
 3.93042e-05
 -5.61489e-06
 -2.32869e-05
 -2.24595e-05
 1.28749e-19
 0.000160112
 -0.000160112
 -1.01644e-20
 -5.82172e-06
 -2.91086e-06
 5.82172e-06
 2.91086e-06
 -1.86347e-20
 1.71549e-05
 -5.61489e-06
 2.80744e-06
 5.61489e-06
 -2.80744e-06
 9.74088e-21
 -1.07301e-21
 -0.000210845
 -0.00089334
 -0.000235825
 -0.00089334
 3.51408e-05
 5.02011e-06
 3.51408e-05
 5.02011e-06
 3.93042e-05
 -5.61489e-06
 0.00014889
 3.51519e-20
 3.93042e-05
 5.61489e-06
 -2.00804e-05
 -2.24595e-05
 -1.05032e-19
 0.00014889
 -1.28749e-19
 -0.00014889
 -5.02011e-06
 -2.51005e-06
 5.02011e-06
 2.51005e-06
 -5.61489e-06
 2.80744e-06
 3.51519e-20
 1.59525e-05
 5.61489e-06
 2.80744e-06
 -8.04681e-21
 -1.02703e-20
 -0.000211105
 -0.00083886
 -0.00083886
 -0.000208325
 3.51841e-05
 5.0263e-06
 3.51841e-05
 5.0263e-06
 0.00013981
 3.3246e-20
 3.47209e-05
 -4.96012e-06
 3.47209e-05
 -4.96012e-06
 -2.01052e-05
 -1.98405e-05
 -1.0842e-19
 0.00013981
 -0.00013981
 -1.13502e-19
 -5.0263e-06
 -2.51315e-06
 5.0263e-06
 2.51315e-06
 3.3246e-20
 1.49796e-05
 -4.96012e-06
 2.48006e-06
 4.96012e-06
 -2.48006e-06
 -8.25857e-21
 -9.1056e-21
 -0.000205575
 -0.000827801
 -0.000208325
 -0.000827801
 3.42625e-05
 4.89465e-06
 3.42625e-05
 4.89465e-06
 3.47209e-05
 -4.96012e-06
 0.000137967
 -1.77877e-20
 3.47209e-05
 4.96012e-06
 -1.95786e-05
 -1.98405e-05
 1.01644e-19
 0.000137967
 -6.77626e-21
 -0.000137967
 -4.89465e-06
 -2.44732e-06
 4.89465e-06
 2.44732e-06
 -4.96012e-06
 2.48006e-06
 -1.77877e-20
 1.47822e-05
 4.96012e-06
 2.48006e-06
 8.25857e-21
 -1.17865e-21
 -0.000245776
 -0.00100079
 -0.00100079
 -0.000254619
 4.09627e-05
 5.85181e-06
 4.09627e-05
 5.85181e-06
 0.000166798
 -1.82112e-20
 4.24364e-05
 -6.06235e-06
 4.24364e-05
 -6.06235e-06
 -2.34072e-05
 -2.42494e-05
 1.28749e-19
 0.000166798
 -0.000166798
 -5.0822e-21
 -5.85181e-06
 -2.9259e-06
 5.85181e-06
 2.9259e-06
 -1.82112e-20
 1.78712e-05
 -6.06235e-06
 3.03117e-06
 6.06235e-06
 -3.03117e-06
 1.00585e-20
 -1.06261e-21
 -0.000235825
 -0.000980887
 -0.000254619
 -0.000980887
 3.93042e-05
 5.61489e-06
 3.93042e-05
 5.61489e-06
 4.24364e-05
 -6.06235e-06
 0.000163481
 3.73224e-20
 4.24364e-05
 6.06235e-06
 -2.24595e-05
 -2.42494e-05
 -1.18585e-19
 0.000163481
 -1.38913e-19
 -0.000163481
 -5.61489e-06
 -2.80744e-06
 5.61489e-06
 2.80744e-06
 -6.06235e-06
 3.03117e-06
 3.73224e-20
 1.75158e-05
 6.06235e-06
 3.03117e-06
 -9.31736e-21
 -1.10114e-20
 -0.000208325
 -0.000254619
 -0.000925887
 -0.000925887
 3.47209e-05
 4.96012e-06
 3.47209e-05
 4.96012e-06
 4.24364e-05
 6.06235e-06
 4.24364e-05
 6.06235e-06
 0.000154315
 3.38813e-21
 -2.42494e-05
 -1.98405e-05
 1.0842e-19
 -1.25361e-19
 0.000154315
 -0.000154315
 -4.96012e-06
 -2.48006e-06
 4.96012e-06
 2.48006e-06
 -6.06235e-06
 -3.03117e-06
 6.06235e-06
 3.03117e-06
 3.38813e-21
 1.65337e-05
 -1.01644e-20
 8.04681e-21
 0.000173611
 0.000173611
 0.000173611
 -2.48016e-05
 -1.27963e-21
 -2.48016e-05
 -1.11173e-20
 -2.48016e-05
 -1.01644e-20
 1.24008e-05
 0.000153219
 0.000153219
 0.000153219
 -2.18884e-05
 -1.01322e-21
 -2.18884e-05
 -9.95264e-21
 -2.18884e-05
 -8.89385e-21
 1.09442e-05
 0.00015059
 0.00015059
 0.00015059
 -2.15129e-05
 -8.80202e-22
 -2.15129e-05
 -9.84676e-21
 -2.15129e-05
 -8.89385e-21
 1.07564e-05
 0.000158251
 0.000158251
 0.000158251
 -2.26073e-05
 -1.21399e-21
 -2.26073e-05
 -1.01644e-20
 -2.26073e-05
 -9.42324e-21
 1.13037e-05
 0.000173611
 0.000173611
 0.000173611
 -2.48016e-05
 -1.13291e-20
 -2.48016e-05
 -1.50092e-21
 -2.48016e-05
 1.03762e-20
 1.24008e-05
 0.000153468
 0.000153468
 0.000153468
 -2.1924e-05
 -9.46847e-22
 -2.1924e-05
 -9.95264e-21
 -2.1924e-05
 -8.99973e-21
 1.0962e-05
 0.00014632
 0.00014632
 0.00014632
 -2.09029e-05
 -8.06128e-22
 -2.09029e-05
 -9.31736e-21
 -2.09029e-05
 -8.47033e-21
 1.04514e-05
 0.000146983
 0.000146983
 0.000146983
 -2.09976e-05
 -1.01694e-21
 -2.09976e-05
 -9.21148e-21
 -2.09976e-05
 -8.78797e-21
 1.04988e-05
 0.000173611
 0.000173611
 0.000173611
 -2.48016e-05
 -1.13291e-20
 -2.48016e-05
 -1.50092e-21
 -2.48016e-05
 1.03762e-20
 1.24008e-05
 0.000152492
 0.000152492
 0.000152492
 -2.17846e-05
 -1.20088e-21
 -2.17846e-05
 -9.74088e-21
 -2.17846e-05
 -8.99973e-21
 1.08923e-05
 0.00015525
 0.00015525
 0.00015525
 -2.21785e-05
 -1.22986e-21
 -2.21785e-05
 -9.95264e-21
 -2.21785e-05
 -9.1056e-21
 1.10893e-05
 0.000156822
 0.000156822
 0.000156822
 -2.24032e-05
 -1.12026e-21
 -2.24032e-05
 -9.84676e-21
 -2.24032e-05
 -9.31736e-21
 1.12016e-05
 0.000173611
 0.000173611
 0.000173611
 -2.48016e-05
 -1.13291e-20
 -2.48016e-05
 -1.50092e-21
 -2.48016e-05
 1.03762e-20
 1.24008e-05
 0.00015119
 0.00015119
 0.00015119
 -2.15985e-05
 -1.02997e-21
 -2.15985e-05
 -9.635e-21
 -2.15985e-05
 -8.78797e-21
 1.07993e-05
 0.000143687
 0.000143687
 0.000143687
 -2.05267e-05
 -1.06523e-21
 -2.05267e-05
 -9.1056e-21
 -2.05267e-05
 -8.68209e-21
 1.02634e-05
 0.000153601
 0.000153601
 0.000153601
 -2.19431e-05
 -9.32262e-22
 -2.19431e-05
 -9.95264e-21
 -2.19431e-05
 -9.1056e-21
 1.09715e-05
 0.000218962
 0.000218962
 0.000218962
 -3.12803e-05
 -1.46113e-20
 -3.12803e-05
 -1.60029e-21
 -3.12803e-05
 1.3129e-20
 1.56402e-05
 0.000222005
 0.000222005
 0.000222005
 -3.17151e-05
 -1.59924e-21
 -3.17151e-05
 -1.41878e-20
 -3.17151e-05
 -1.33408e-20
 1.58575e-05
 0.00021684
 0.00021684
 0.00021684
 -3.09771e-05
 -1.24845e-21
 -3.09771e-05
 -1.41878e-20
 -3.09771e-05
 -1.27055e-20
 1.54886e-05
 0.000216999
 0.000216999
 0.000216999
 -3.09999e-05
 -1.65219e-21
 -3.09999e-05
 -1.3976e-20
 -3.09999e-05
 -1.24937e-20
 1.54999e-05
 0.000157214
 0.000157214
 0.000157214
 -2.24591e-05
 -1.05159e-21
 -2.24591e-05
 -9.95264e-21
 -2.24591e-05
 -9.21148e-21
 1.12295e-05
 0.000152344
 0.000152344
 0.000152344
 -2.17635e-05
 -1.0179e-21
 -2.17635e-05
 -9.95264e-21
 -2.17635e-05
 -8.68209e-21
 1.08817e-05
 0.000148878
 0.000148878
 0.000148878
 -2.12683e-05
 -9.74759e-22
 -2.12683e-05
 -9.52912e-21
 -2.12683e-05
 -8.99973e-21
 1.06342e-05
 0.000158064
 0.000158064
 0.000158064
 -2.25806e-05
 -1.10787e-21
 -2.25806e-05
 -1.0482e-20
 -2.25806e-05
 -9.42324e-21
 1.12903e-05
 0.000141666
 0.000141666
 0.000141666
 -2.02379e-05
 -9.29052e-22
 -2.02379e-05
 -8.99973e-21
 -2.02379e-05
 -8.04681e-21
 1.0119e-05
 0.000152414
 0.000152414
 0.000152414
 -2.17735e-05
 -9.57355e-22
 -2.17735e-05
 -9.95264e-21
 -2.17735e-05
 -8.89385e-21
 1.08867e-05
 0.000142893
 0.000142893
 0.000142893
 -2.04133e-05
 -9.35689e-22
 -2.04133e-05
 -9.31736e-21
 -2.04133e-05
 -8.47033e-21
 1.02067e-05
 0.000159327
 0.000159327
 0.000159327
 -2.2761e-05
 -9.75323e-22
 -2.2761e-05
 -1.02703e-20
 -2.2761e-05
 -9.31736e-21
 1.13805e-05
 0.000154916
 0.000154916
 0.000154916
 -2.21309e-05
 -9.86042e-22
 -2.21309e-05
 -1.01644e-20
 -2.21309e-05
 -9.42324e-21
 1.10654e-05
 0.000158935
 0.000158935
 0.000158935
 -2.2705e-05
 -1.05341e-21
 -2.2705e-05
 -1.01644e-20
 -2.2705e-05
 -9.21148e-21
 1.13525e-05
 0.000146339
 0.000146339
 0.000146339
 -2.09056e-05
 -9.02727e-22
 -2.09056e-05
 -9.31736e-21
 -2.09056e-05
 -8.47033e-21
 1.04528e-05
 0.000163619
 0.000163619
 0.000163619
 -2.33741e-05
 -1.0482e-20
 -2.33741e-05
 -1.31778e-21
 -2.33741e-05
 9.74088e-21
 1.16871e-05
 0.000152048
 0.000152048
 0.000152048
 -2.17211e-05
 -9.56313e-22
 -2.17211e-05
 -9.74088e-21
 -2.17211e-05
 -8.68209e-21
 1.08606e-05
 0.000145929
 0.000145929
 0.000145929
 -2.0847e-05
 -1.04191e-21
 -2.0847e-05
 -9.42324e-21
 -2.0847e-05
 -8.25857e-21
 1.04235e-05
 0.000145823
 0.000145823
 0.000145823
 -2.08318e-05
 -1.0832e-21
 -2.08318e-05
 -9.42324e-21
 -2.08318e-05
 -8.89385e-21
 1.04159e-05
 0.000157074
 0.000157074
 0.000157074
 -2.24391e-05
 -1.14258e-21
 -2.24391e-05
 -1.03762e-20
 -2.24391e-05
 -9.52912e-21
 1.12195e-05
 0.000153119
 0.000153119
 0.000153119
 -2.18741e-05
 -9.95264e-21
 -2.18741e-05
 -1.2278e-21
 -2.18741e-05
 8.89385e-21
 1.0937e-05
 0.000136201
 0.000136201
 0.000136201
 -1.94574e-05
 -8.78797e-21
 -1.94574e-05
 -9.5929e-22
 -1.94574e-05
 8.04681e-21
 9.72868e-06
 0.000145653
 0.000145653
 0.000145653
 -2.08076e-05
 -9.42324e-21
 -2.08076e-05
 -1.19931e-21
 -2.08076e-05
 8.78797e-21
 1.04038e-05
 0.000126819
 0.000126819
 0.000126819
 -1.81171e-05
 -8.47033e-21
 -1.81171e-05
 -9.42087e-22
 -1.81171e-05
 7.72918e-21
 9.05853e-06
 0.000157172
 0.000157172
 0.000157172
 -2.24531e-05
 -1.01644e-20
 -2.24531e-05
 -1.14921e-21
 -2.24531e-05
 9.42324e-21
 1.12266e-05
 0.000133927
 0.000133927
 0.000133927
 -1.91324e-05
 -8.89385e-21
 -1.91324e-05
 -1.13497e-21
 -1.91324e-05
 8.04681e-21
 9.5662e-06
 0.000146549
 0.000146549
 0.000146549
 -2.09356e-05
 -9.52912e-21
 -2.09356e-05
 -1.22357e-21
 -2.09356e-05
 8.99973e-21
 1.04678e-05
 0.000132673
 0.000132673
 0.000132673
 -1.89533e-05
 -8.57621e-21
 -1.89533e-05
 -8.12576e-22
 -1.89533e-05
 7.94093e-21
 9.47665e-06
 0.000141665
 0.000141665
 0.000141665
 -2.02378e-05
 -9.05794e-22
 -2.02378e-05
 -8.99973e-21
 -2.02378e-05
 -8.57621e-21
 1.01189e-05
 0.000163596
 0.000163596
 0.000163596
 -2.33708e-05
 -9.25353e-22
 -2.33708e-05
 -1.05879e-20
 -2.33708e-05
 -9.52912e-21
 1.16854e-05
 0.000153952
 0.000153952
 0.000153952
 -2.19931e-05
 -8.98413e-22
 -2.19931e-05
 -9.95264e-21
 -2.19931e-05
 -9.1056e-21
 1.09965e-05
 0.000147119
 0.000147119
 0.000147119
 -2.1017e-05
 -8.31921e-22
 -2.1017e-05
 -9.31736e-21
 -2.1017e-05
 -8.47033e-21
 1.05085e-05
 0.000159606
 0.000159606
 0.000159606
 -2.28009e-05
 -1.05879e-20
 -2.28009e-05
 -1.32113e-21
 -2.28009e-05
 9.31736e-21
 1.14005e-05
 0.000166274
 0.000166274
 0.000166274
 -2.37534e-05
 -1.07997e-20
 -2.37534e-05
 -1.29252e-21
 -2.37534e-05
 9.74088e-21
 1.18767e-05
 0.000165986
 0.000165986
 0.000165986
 -2.37122e-05
 -1.06938e-20
 -2.37122e-05
 -1.32496e-21
 -2.37122e-05
 9.95264e-21
 1.18561e-05
 0.000153001
 0.000153001
 0.000153001
 -2.18573e-05
 -9.14871e-22
 -2.18573e-05
 -9.84676e-21
 -2.18573e-05
 -9.31736e-21
 1.09287e-05
 0.000138753
 0.000138753
 0.000138753
 -1.98219e-05
 -8.9921e-22
 -1.98219e-05
 -8.89385e-21
 -1.98219e-05
 -8.25857e-21
 9.91093e-06
 0.000158705
 0.000158705
 0.000158705
 -2.26721e-05
 -9.92299e-22
 -2.26721e-05
 -1.01644e-20
 -2.26721e-05
 -9.635e-21
 1.1336e-05
 0.000154585
 0.000154585
 0.000154585
 -2.20836e-05
 -8.65891e-22
 -2.20836e-05
 -1.01644e-20
 -2.20836e-05
 -9.1056e-21
 1.10418e-05
 0.000137315
 0.000137315
 0.000137315
 -1.96164e-05
 -8.42681e-22
 -1.96164e-05
 -8.68209e-21
 -1.96164e-05
 -8.04681e-21
 9.80819e-06
 0.000174938
 0.000174938
 0.000174938
 -2.49912e-05
 -1.2154e-21
 -2.49912e-05
 -1.11173e-20
 -2.49912e-05
 -1.03762e-20
 1.24956e-05
 0.000185409
 0.000185409
 0.000185409
 -2.64871e-05
 -1.3333e-21
 -2.64871e-05
 -1.11173e-20
 -2.64871e-05
 -1.07997e-20
 1.32435e-05
 0.000168724
 0.000168724
 0.000168724
 -2.41035e-05
 -1.07568e-21
 -2.41035e-05
 -1.09055e-20
 -2.41035e-05
 -9.74088e-21
 1.20517e-05
 0.000146204
 0.000146204
 0.000146204
 -2.08864e-05
 -9.25172e-22
 -2.08864e-05
 -9.31736e-21
 -2.08864e-05
 -8.47033e-21
 1.04432e-05
 0.000159322
 0.000159322
 0.000159322
 -2.27602e-05
 -1.02703e-20
 -2.27602e-05
 -1.02356e-21
 -2.27602e-05
 9.52912e-21
 1.13801e-05
 0.000157617
 0.000157617
 0.000157617
 -2.25166e-05
 -9.74957e-22
 -2.25166e-05
 -1.00585e-20
 -2.25166e-05
 -9.31736e-21
 1.12583e-05
 0.000153615
 0.000153615
 0.000153615
 -2.19451e-05
 -1.00585e-20
 -2.19451e-05
 -9.96003e-22
 -2.19451e-05
 8.89385e-21
 1.09725e-05
 0.000181033
 0.000181033
 0.000181033
 -2.58619e-05
 -1.33946e-21
 -2.58619e-05
 -1.15408e-20
 -2.58619e-05
 -1.05879e-20
 1.29309e-05
 0.000145689
 0.000145689
 0.000145689
 -2.08127e-05
 -9.52912e-21
 -2.08127e-05
 -1.16518e-21
 -2.08127e-05
 8.47033e-21
 1.04063e-05
 0.000143373
 0.000143373
 0.000143373
 -2.04819e-05
 -1.05026e-21
 -2.04819e-05
 -9.1056e-21
 -2.04819e-05
 -8.25857e-21
 1.02409e-05
 0.00017154
 0.00017154
 0.00017154
 -2.45057e-05
 -1.11427e-21
 -2.45057e-05
 -1.11173e-20
 -2.45057e-05
 -1.00585e-20
 1.22528e-05
 0.000154429
 0.000154429
 0.000154429
 -2.20614e-05
 -9.46629e-22
 -2.20614e-05
 -9.95264e-21
 -2.20614e-05
 -9.31736e-21
 1.10307e-05
 0.000153158
 0.000153158
 0.000153158
 -2.18798e-05
 -9.95264e-21
 -2.18798e-05
 -1.12883e-21
 -2.18798e-05
 9.21148e-21
 1.09399e-05
 0.000150079
 0.000150079
 0.000150079
 -2.14399e-05
 -8.65147e-22
 -2.14399e-05
 -9.635e-21
 -2.14399e-05
 -8.47033e-21
 1.07199e-05
 0.0001879
 0.0001879
 0.0001879
 -2.68429e-05
 -1.22942e-21
 -2.68429e-05
 -1.21761e-20
 -2.68429e-05
 -1.07997e-20
 1.34214e-05
 0.000175578
 0.000175578
 0.000175578
 -2.50825e-05
 -1.10515e-21
 -2.50825e-05
 -1.13291e-20
 -2.50825e-05
 -1.01644e-20
 1.25413e-05
 0.000158103
 0.000158103
 0.000158103
 -2.25861e-05
 -1.03762e-20
 -2.25861e-05
 -1.26203e-21
 -2.25861e-05
 9.635e-21
 1.1293e-05
 0.000184267
 0.000184267
 0.000184267
 -2.63238e-05
 -1.31299e-21
 -2.63238e-05
 -1.18585e-20
 -2.63238e-05
 -1.10114e-20
 1.31619e-05
 0.000172169
 0.000172169
 0.000172169
 -2.45956e-05
 -1.02295e-21
 -2.45956e-05
 -1.10114e-20
 -2.45956e-05
 -9.95264e-21
 1.22978e-05
 0.000156846
 0.000156846
 0.000156846
 -2.24066e-05
 -1.00585e-20
 -2.24066e-05
 -1.04999e-21
 -2.24066e-05
 8.99973e-21
 1.12033e-05
 0.000145018
 0.000145018
 0.000145018
 -2.07169e-05
 -9.50785e-22
 -2.07169e-05
 -9.52912e-21
 -2.07169e-05
 -8.57621e-21
 1.03584e-05
 0.000164331
 0.000164331
 0.000164331
 -2.34759e-05
 -1.10114e-20
 -2.34759e-05
 -1.05858e-21
 -2.34759e-05
 9.52912e-21
 1.1738e-05
 0.000155923
 0.000155923
 0.000155923
 -2.22747e-05
 -1.03762e-20
 -2.22747e-05
 -1.16774e-21
 -2.22747e-05
 9.1056e-21
 1.11373e-05
 0.000159814
 0.000159814
 0.000159814
 -2.28306e-05
 -1.03762e-20
 -2.28306e-05
 -1.32113e-21
 -2.28306e-05
 9.1056e-21
 1.14153e-05
 0.000139224
 0.000139224
 0.000139224
 -1.98891e-05
 -9.1056e-21
 -1.98891e-05
 -9.56159e-22
 -1.98891e-05
 8.25857e-21
 9.94455e-06
 0.000136115
 0.000136115
 0.000136115
 -1.94449e-05
 -8.89385e-21
 -1.94449e-05
 -1.10829e-21
 -1.94449e-05
 8.04681e-21
 9.72246e-06
 0.00016937
 0.00016937
 0.00016937
 -2.41957e-05
 -1.15649e-21
 -2.41957e-05
 -1.07997e-20
 -2.41957e-05
 -9.84676e-21
 1.20979e-05
 0.000150689
 0.000150689
 0.000150689
 -2.15269e-05
 -9.52912e-21
 -2.15269e-05
 -1.15619e-21
 -2.15269e-05
 8.78797e-21
 1.07635e-05
 0.00019064
 0.00019064
 0.00019064
 -2.72343e-05
 -1.09855e-21
 -2.72343e-05
 -1.24937e-20
 -2.72343e-05
 -1.10114e-20
 1.36171e-05
 0.000182668
 0.000182668
 0.000182668
 -2.60954e-05
 -1.18585e-20
 -2.60954e-05
 -1.68169e-21
 -2.60954e-05
 1.07997e-20
 1.30477e-05
 0.000156239
 0.000156239
 0.000156239
 -2.23199e-05
 -1.00585e-20
 -2.23199e-05
 -1.0968e-21
 -2.23199e-05
 8.89385e-21
 1.116e-05
 0.000152513
 0.000152513
 0.000152513
 -2.17876e-05
 -9.84676e-21
 -2.17876e-05
 -1.23601e-21
 -2.17876e-05
 9.1056e-21
 1.08938e-05
 0.000183468
 0.000183468
 0.000183468
 -2.62097e-05
 -1.19643e-20
 -2.62097e-05
 -1.47477e-21
 -2.62097e-05
 1.07997e-20
 1.31048e-05
 0.000150127
 0.000150127
 0.000150127
 -2.14467e-05
 -1.00337e-21
 -2.14467e-05
 -9.635e-21
 -2.14467e-05
 -8.78797e-21
 1.07233e-05
 0.000160575
 0.000160575
 0.000160575
 -2.29393e-05
 -1.16082e-21
 -2.29393e-05
 -1.0482e-20
 -2.29393e-05
 -9.31736e-21
 1.14697e-05
 0.000148005
 0.000148005
 0.000148005
 -2.11436e-05
 -9.635e-21
 -2.11436e-05
 -9.85995e-22
 -2.11436e-05
 8.99973e-21
 1.05718e-05
 0.000178163
 0.000178163
 0.000178163
 -2.54519e-05
 -1.30388e-21
 -2.54519e-05
 -1.14349e-20
 -2.54519e-05
 -1.03762e-20
 1.27259e-05
 0.000143445
 0.000143445
 0.000143445
 -2.04922e-05
 -9.42324e-21
 -2.04922e-05
 -1.04859e-21
 -2.04922e-05
 8.78797e-21
 1.02461e-05
 0.000154094
 0.000154094
 0.000154094
 -2.20134e-05
 -1.01474e-21
 -2.20134e-05
 -1.01644e-20
 -2.20134e-05
 -9.1056e-21
 1.10067e-05
 0.000175565
 0.000175565
 0.000175565
 -2.50808e-05
 -1.07536e-21
 -2.50808e-05
 -1.14349e-20
 -2.50808e-05
 -1.05879e-20
 1.25404e-05
 0.000146709
 0.000146709
 0.000146709
 -2.09585e-05
 -1.01002e-21
 -2.09585e-05
 -9.42324e-21
 -2.09585e-05
 -8.68209e-21
 1.04792e-05
 0.000155324
 0.000155324
 0.000155324
 -2.21891e-05
 -8.99897e-22
 -2.21891e-05
 -1.00585e-20
 -2.21891e-05
 -8.89385e-21
 1.10946e-05
 0.000180804
 0.000180804
 0.000180804
 -2.58292e-05
 -1.19643e-20
 -2.58292e-05
 -1.59915e-21
 -2.58292e-05
 1.07997e-20
 1.29146e-05
 0.000180757
 0.000180757
 0.000180757
 -2.58224e-05
 -1.27809e-21
 -2.58224e-05
 -1.15408e-20
 -2.58224e-05
 -1.05879e-20
 1.29112e-05
 0.000117884
 0.000117884
 0.000117884
 -1.68406e-05
 -7.72918e-21
 -1.68406e-05
 -8.72298e-22
 -1.68406e-05
 6.88214e-21
 8.42031e-06
 0.000117663
 0.000117663
 0.000117663
 -1.6809e-05
 -6.42452e-22
 -1.6809e-05
 -7.51742e-21
 -1.6809e-05
 -6.98802e-21
 8.40451e-06
 0.0001143
 0.0001143
 0.0001143
 -1.63286e-05
 -7.48248e-22
 -1.63286e-05
 -7.30566e-21
 -1.63286e-05
 -6.77626e-21
 8.1643e-06
 0.000162153
 0.000162153
 0.000162153
 -2.31646e-05
 -1.03762e-20
 -2.31646e-05
 -1.32118e-21
 -2.31646e-05
 9.95264e-21
 1.15823e-05
 0.000115157
 0.000115157
 0.000115157
 -1.6451e-05
 -7.30566e-21
 -1.6451e-05
 -9.59613e-22
 -1.6451e-05
 6.67038e-21
 8.22551e-06
 0.000166875
 0.000166875
 0.000166875
 -2.38393e-05
 -1.03041e-21
 -2.38393e-05
 -1.0482e-20
 -2.38393e-05
 -9.74088e-21
 1.19197e-05
 0.000128172
 0.000128172
 0.000128172
 -1.83103e-05
 -8.25857e-21
 -1.83103e-05
 -9.77634e-22
 -1.83103e-05
 7.72918e-21
 9.15517e-06
 0.000152314
 0.000152314
 0.000152314
 -2.17592e-05
 -1.08483e-21
 -2.17592e-05
 -9.74088e-21
 -2.17592e-05
 -8.68209e-21
 1.08796e-05
 0.000123653
 0.000123653
 0.000123653
 -1.76648e-05
 -7.94093e-21
 -1.76648e-05
 -9.80977e-22
 -1.76648e-05
 7.19978e-21
 8.83239e-06
 0.000151977
 0.000151977
 0.000151977
 -2.1711e-05
 -8.39623e-22
 -2.1711e-05
 -9.84676e-21
 -2.1711e-05
 -8.89385e-21
 1.08555e-05
 0.000167065
 0.000167065
 0.000167065
 -2.38664e-05
 -1.11173e-20
 -2.38664e-05
 -1.25054e-21
 -2.38664e-05
 1.02703e-20
 1.19332e-05
 0.000168922
 0.000168922
 0.000168922
 -2.41318e-05
 -1.09055e-20
 -2.41318e-05
 -1.35543e-21
 -2.41318e-05
 9.74088e-21
 1.20659e-05
 0.000119178
 0.000119178
 0.000119178
 -1.70254e-05
 -8.83364e-22
 -1.70254e-05
 -7.51742e-21
 -1.70254e-05
 -6.98802e-21
 8.51269e-06
 0.000143906
 0.000143906
 0.000143906
 -2.0558e-05
 -9.31736e-21
 -2.0558e-05
 -1.11554e-21
 -2.0558e-05
 8.57621e-21
 1.0279e-05
 0.000146838
 0.000146838
 0.000146838
 -2.09769e-05
 -9.74088e-21
 -2.09769e-05
 -1.18203e-21
 -2.09769e-05
 8.89385e-21
 1.04884e-05
 0.000113315
 0.000113315
 0.000113315
 -1.61879e-05
 -7.50892e-22
 -1.61879e-05
 -7.19978e-21
 -1.61879e-05
 -6.56451e-21
 8.09394e-06
 0.000172857
 0.000172857
 0.000172857
 -2.46939e-05
 -1.12232e-20
 -2.46939e-05
 -1.17421e-21
 -2.46939e-05
 1.06938e-20
 1.23469e-05
 0.000145027
 0.000145027
 0.000145027
 -2.07181e-05
 -9.52912e-21
 -2.07181e-05
 -1.07255e-21
 -2.07181e-05
 8.47033e-21
 1.0359e-05
 0.000174754
 0.000174754
 0.000174754
 -2.49649e-05
 -1.13291e-20
 -2.49649e-05
 -1.39356e-21
 -2.49649e-05
 1.02703e-20
 1.24824e-05
 0.000154839
 0.000154839
 0.000154839
 -2.21199e-05
 -9.84676e-21
 -2.21199e-05
 -1.17434e-21
 -2.21199e-05
 9.31736e-21
 1.10599e-05
 0.000145044
 0.000145044
 0.000145044
 -2.07206e-05
 -9.52912e-21
 -2.07206e-05
 -1.09938e-21
 -2.07206e-05
 8.25857e-21
 1.03603e-05
 0.000144717
 0.000144717
 0.000144717
 -2.06739e-05
 -9.27555e-22
 -2.06739e-05
 -9.52912e-21
 -2.06739e-05
 -8.57621e-21
 1.03369e-05
 0.000146036
 0.000146036
 0.000146036
 -2.08622e-05
 -9.42324e-21
 -2.08622e-05
 -1.20145e-21
 -2.08622e-05
 8.78797e-21
 1.04311e-05
 0.000127291
 0.000127291
 0.000127291
 -1.81844e-05
 -9.55124e-22
 -1.81844e-05
 -8.04681e-21
 -1.81844e-05
 -7.30566e-21
 9.0922e-06
 0.000146885
 0.000146885
 0.000146885
 -2.09836e-05
 -9.09796e-22
 -2.09836e-05
 -9.31736e-21
 -2.09836e-05
 -8.68209e-21
 1.04918e-05
 0.000119572
 0.000119572
 0.000119572
 -1.70817e-05
 -7.72918e-21
 -1.70817e-05
 -1.02421e-21
 -1.70817e-05
 6.98802e-21
 8.54083e-06
 0.00011776
 0.00011776
 0.00011776
 -1.68229e-05
 -7.72918e-21
 -1.68229e-05
 -8.6112e-22
 -1.68229e-05
 6.98802e-21
 8.41143e-06
 0.000114288
 0.000114288
 0.000114288
 -1.63269e-05
 -7.10701e-22
 -1.63269e-05
 -7.30566e-21
 -1.63269e-05
 -6.35275e-21
 8.16344e-06
 0.000141438
 0.000141438
 0.000141438
 -2.02054e-05
 -9.7042e-22
 -2.02054e-05
 -9.31736e-21
 -2.02054e-05
 -8.36445e-21
 1.01027e-05
 0.000163837
 0.000163837
 0.000163837
 -2.34053e-05
 -1.0622e-21
 -2.34053e-05
 -1.01644e-20
 -2.34053e-05
 -9.31736e-21
 1.17027e-05
 0.000163008
 0.000163008
 0.000163008
 -2.32869e-05
 -1.09055e-20
 -2.32869e-05
 -1.14236e-21
 -2.32869e-05
 9.74088e-21
 1.16434e-05
 0.000144071
 0.000144071
 0.000144071
 -2.05816e-05
 -9.42324e-21
 -2.05816e-05
 -1.27997e-21
 -2.05816e-05
 8.47033e-21
 1.02908e-05
 0.000141576
 0.000141576
 0.000141576
 -2.02252e-05
 -9.73181e-22
 -2.02252e-05
 -9.1056e-21
 -2.02252e-05
 -8.25857e-21
 1.01126e-05
 0.000150894
 0.000150894
 0.000150894
 -2.15562e-05
 -9.74088e-21
 -2.15562e-05
 -1.05437e-21
 -2.15562e-05
 9.1056e-21
 1.07781e-05
 0.000163851
 0.000163851
 0.000163851
 -2.34072e-05
 -1.05879e-20
 -2.34072e-05
 -1.1763e-21
 -2.34072e-05
 1.00585e-20
 1.17036e-05
 0.000146983
 0.000146983
 0.000146983
 -2.09975e-05
 -1.06453e-21
 -2.09975e-05
 -9.42324e-21
 -2.09975e-05
 -8.78797e-21
 1.04988e-05
 0.000113292
 0.000113292
 0.000113292
 -1.61846e-05
 -7.41154e-21
 -1.61846e-05
 -7.95905e-22
 -1.61846e-05
 6.98802e-21
 8.0923e-06
 0.000140563
 0.000140563
 0.000140563
 -2.00804e-05
 -7.87299e-22
 -2.00804e-05
 -8.89385e-21
 -2.00804e-05
 -8.04681e-21
 1.00402e-05
 0.00014978
 0.00014978
 0.00014978
 -2.13971e-05
 -9.74088e-21
 -2.13971e-05
 -1.02269e-21
 -2.13971e-05
 8.89385e-21
 1.06986e-05
 0.000157217
 0.000157217
 0.000157217
 -2.24595e-05
 -1.07301e-21
 -2.24595e-05
 -1.02703e-20
 -2.24595e-05
 -9.31736e-21
 1.12298e-05
 0.00013705
 0.00013705
 0.00013705
 -1.95786e-05
 -8.89385e-21
 -1.95786e-05
 -1.04085e-21
 -1.95786e-05
 8.25857e-21
 9.7893e-06
 0.000140737
 0.000140737
 0.000140737
 -2.01052e-05
 -8.72046e-22
 -2.01052e-05
 -9.21148e-21
 -2.01052e-05
 -8.25857e-21
 1.00526e-05
 0.000169746
 0.000169746
 0.000169746
 -2.42494e-05
 -1.06261e-21
 -2.42494e-05
 -1.10114e-20
 -2.42494e-05
 -1.01644e-20
 1.21247e-05
 0.000138883
 0.000138883
 0.000138883
 -1.98405e-05
 -9.1056e-21
 -1.98405e-05
 -1.17865e-21
 -1.98405e-05
 8.04681e-21
 9.92025e-06
Using the vector we can build the linear combination of the matrices $A$ and $M$:
In [7]:
We set the r.h.s. $f = exp(-6 ((x+\frac12)^2+y^2)) - exp(-6 ((x-\frac12)^2+y^2))$
In [8]:
Draw(gaussp,mesh,"f")
f += SymbolicLFI(gaussp*v)
and the initial data: $u_0 = (1-y^2)x$
In [9]:
gfu.Set((1-y*y)*x)
Draw(gfu,mesh,"u")
In [10]:
res = gfu.vec.CreateVector()
    t_intermediate += dt
print("")
time+=t_intermediate
 9.999999999999897
Supplementary 1: time-dependent r.h.s. data
Next, we want to consider time-dependent r.h.s. data $f=f(t)$:
To this end, we introduce a parameter t representing the time.
A Parameter is a constant CoefficientFunction the value of which can be changed with the Set-function.
In [11]:
t = Parameter(0.0)
In [12]:
omega=1
tt = 0
Draw(gausspt,mesh,"ft")
time = 0.0
while time < 10 - 0.5 * dt:
    t.Set(time)
    tt = time
    #gausspt = exp(-6*((x+sin(omega*tt))*(x+sin(omega*tt))+y*y))-exp(-6*((x-sin(omega*tt))*(x-sin(omega*tt))+y*y))
    time += 1e-4
In [13]:
ft = LinearForm(fes)
ft += SymbolicLFI(gausspt*v)
time = 0.0
t.Set(0.0)
gfu.Set((1-y*y)*x)
Draw(gfu,mesh,"u")
In [14]:
tstep = 20 # time that we want to step over within one block-run
    t.Set(time+t_intermediate+dt)
    ft.Assemble()
print("")
 20.00000000000146
Supplementary 2: Time dependent boundary conditions
Now, we want to consider changing boundary conditions $u|_{\partial \Omega} = u_D(t)$ and set $f=0$.
We use the simple implicit Euler time stepping method again for this problem. Now, we directly use the non-incremental form: $$ (M + \Delta t A) u^{n+1} = M u^n $$ We homogenize w.r.t. to the boundary conditions, i.e. we split $u^{n+1} = u^{n+1}_0 + u^{n+1}_D$ where $u^{n+1}_D$ is some function in the FESpace with the correct boundary condition and $u^{n+1}_0$ is the sought for function with zero boundary values:
$$ \underbrace{(M + \Delta t A)}_{M^\ast} u^{n+1}_0 = M u^n - \underbrace{(M + \Delta t A)}_{M^\ast} u^{n+1}_D $$
In [15]:
time = 0.0
t.Set(0.0)
gfu.Set(uD,BND)
Draw(gfu,mesh,"u")
# visualization stuff
visoptions.mminval = 0.0
visoptions.mmaxval = 0.2
visoptions.deformation = 0
visoptions.autoscale = 0
In [16]:
    #non-incremental form
    res.data = m.mat * gfu.vec
    gfu.Set(uD,BND)
    res.data -= mstar * gfu.vec
print("")
 9.999999999999897
Supplementary 3: Singly diagonally implicit Runge-Kutta methods
We consider more sophisticated time integration methods, SDIRK methods. To simplify presentation we set $f=0$.
SDIRK methods for the semi-discrete problem $\frac{d}{dt} u = M^{-1} F(u) = -M^{-1} \cdot A u$ are of the form: $$ u^{n+1} = u^n + \Delta t M^{-1} \sum_{i=0}^{s-1} b_i k_i $$ with $$ k_i = - A u_i \quad \text{ where $u_i$ is the solution to } \quad (M + a^\ast \Delta t A) u_i = M u^n - \Delta t \sum_{i=0}^{i-1} a_{ij} k_j, \quad i=0,..,s-1. $$ The coefficients a,b and c are stored in the butcher tableau: $$ \begin{array}{c|cccc} c_0 & a_{00} & 0 & \ddots& \\ c_1 & a_{10} & a_{11} & 0 & \ddots \\ \vdots & \vdots & \vdots & \ddots & 0\\ c_{s-1} & a_{s-1,0} & a_{s-1,1} & \dots& a_{s-1,s-1} \\ \hline & b_{0} & b_1 & \dots& b_{s-1} \\ \end{array} $$ For an SDIRK method we have $a^\ast = a_{ii},~i=0,..,s-1$.
We can use for example the 2 stage SDIRK (order 3) method $$ \begin{array}{c|cc} p & p & 0 \\ 1-p & 1-2p & p \\ \hline & 1/2 & 1/2 \\ \end{array} $$ with $p = \frac{3 - \sqrt{3}}{6}$.
In [17]:
    stages = 1
    a = [[1]]
    b = [1]
    c = [1]
    astar = 1
class sdirk2: #order 3
    p = (3 - sqrt(3))/6
    stages = 2
    a = [[p, 0],
         [1 - 2*p, p]]
    b = [1/2, 1/2]
    c = [p, 1 - p]
    astar = p
class sdirk5: #order 4
    stages = 5
    a = [[1/4, 0, 0, 0, 0],
         [1/2, 1/4, 0, 0, 0],
         [17/50,-1/25, 1/4, 0, 0],
    c = [1/4, 3/4, 11/20, 1/2, 1]
    astar = 1/4
butchertab = sdirk2()
rhsi = gfu.vec.CreateVector()
Mu0 = gfu.vec.CreateVector()
ui = gfu.vec.CreateVector()
We have to update the $M^\ast$ matrix and reset initial data
In [18]:
time = 0.0
t.Set(0.0)
gfu.Set(uD,BND)
Draw(gfu,mesh,"u")
In [19]:
    Mu0.data = m.mat * gfu.vec
        rhsi.data = Mu0
        for j in range(0,i):
        gfu.Set(uD,BND)
        ui.data = gfu.vec
        rhsi.data -= mstar * ui
        ui.data += invmstar * rhsi
        # compute k[i] from ui
        k[i].data = - a.mat * ui
    t.Set(time+t_intermediate)
    # Adding up the ks:
    gfu.Set(uD,BND)
    Mu0.data -= m.mat * gfu.vec
    gfu.vec.data += invmass * Mu0
print("")
 9.999999999999897
Supplementary 4: VTK Output ("exporting the nice pictures")
In [20]:
                names=["sol"],
                filename="vtk_example1",
                subdivision=3)
vtk.Do()
In [21]:
vtk.Do()
And time dependent data:
In [22]:
vtk.Do()
gfu.Set((1-y*y)*x)
time = 0
i = 0
    i += 1
    if (i%10 == 0):
        vtk.Do()
print("")
 1.0000000000000007
