Processing math: 100%
CoefficientFunctions
In NGSolve, CoefficientFunctions are representations of functions defined on the computational domain Ω. Examples are expressions of coordinate variables x,y,z and functions that are constant on subdomains. Much of the magic behind the seamless integration of NGSolve with python lies in CoefficientFunctions. This tutorial introduces you to them.
In [1]:
%gui tk
Define a function
In [2]:
myfunc = x*(1-x)
myfunc   # You have just created a CoefficientFunction
Out[2]:
<ngsolve.fem.CoefficientFunction at 0x7f26cc702a78>
In [3]:
x        # This is a built-in CoefficientFunction
Out[3]:
<ngsolve.fem.CoefficientFunction at 0x7f26965ddd50>
Draw the function
In [4]:
Evaluate the function
In [5]:
mip = mesh(0.2, 0.2)
myfunc(mip)
Out[5]:
0.16000000000000003
Note that myfunc(0.2,0.3) does not work: You need to give points in the form of MappedIntegrationPoints like mip above. The mesh knows how to produce them.
Examining functions on sets of points
In [6]:
for p,v in zip(pts, vals):
         %(p[0], p[1], v))
In [7]:
plt.plot(px,vals)
plt.xlabel('x')
Interpolate a CoefficientFunction
In [8]:
fes = H1(mesh, order=1)
u = GridFunction(fes)
u.Set(myfunc)
Draw(u)         # Cf.: Draw(myfunc, mesh, "firstfun")
  • The Set method interpolates myfunc to obtain the grid function u.
  • Set does an Oswald-type interpolation as follows:
    • It first zeros the grid function;
    • It then projects myfunc in L2 on each mesh element;
    • It then averages dofs on element interfaces for conformity.
Integrate a CoefficientFunction
In [9]:
Integrate(myfunc, mesh)
Out[9]:
0.166666666666666
Differentiate
There is no facility to directly differentiate a CoefficientFunction. But you can interpolate it into a GridFunction and then differentiate the GridFunction.
In [10]:
u.Set(myfunc)
gradu = grad(u)
gradu[0]
Out[10]:
<ngsolve.fem.CoefficientFunction at 0x7f2696608ce0>
In [11]:
Draw(gradu[0], mesh, 'dx_firstfun')
Obviously the accuracy of this process can be improved for smooth functions by using higher order finite element spaces.
Vector-valued CoefficientFunctions
Above, gradu provided an example of a vector-valued coefficient function. To visualize it, click on Visual menu in GUI and check Draw Surface Vectors.
In [12]:
You can also define vector coefficient expressions directly:
In [13]:
In [14]:
Draw(vecfun, mesh, "vecfun")
Expression tree
In [15]:
print(myfunc)
  coef coordinate x, real
    coef N5ngfem27ConstantCoefficientFunctionE, real
